[PATCH] dm: soc: Add SoC id for attribute matching
Add SoC identification string for attribute matching. Also changed the comments from "an SOC" to "a SoC".
Signed-off-by: Biju Das biju.das.jz@bp.renesas.com Reviewed-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com --- drivers/soc/soc-uclass.c | 19 ++++++++++++++++++- drivers/soc/soc_sandbox.c | 8 ++++++++ include/soc.h | 39 +++++++++++++++++++++++++++++++++------ test/dm/soc.c | 8 ++++++++ 4 files changed, 67 insertions(+), 7 deletions(-)
diff --git a/drivers/soc/soc-uclass.c b/drivers/soc/soc-uclass.c index c32d647864..a3f8be841b 100644 --- a/drivers/soc/soc-uclass.c +++ b/drivers/soc/soc-uclass.c @@ -46,6 +46,16 @@ int soc_get_revision(struct udevice *dev, char *buf, int size) return ops->get_revision(dev, buf, size); }
+int soc_get_soc_id(struct udevice *dev, char *buf, int size) +{ + struct soc_ops *ops = soc_get_ops(dev); + + if (!ops->get_soc_id) + return -ENOSYS; + + return ops->get_soc_id(dev, buf, size); +} + const struct soc_attr * soc_device_match(const struct soc_attr *matches) { @@ -61,7 +71,7 @@ soc_device_match(const struct soc_attr *matches)
while (1) { if (!(matches->machine || matches->family || - matches->revision)) + matches->revision || matches->soc_id)) break;
match = true; @@ -87,6 +97,13 @@ soc_device_match(const struct soc_attr *matches) } }
+ if (matches->soc_id) { + if (!soc_get_soc_id(soc, str, SOC_MAX_STR_SIZE)) { + if (strcmp(matches->soc_id, str)) + match = false; + } + } + if (match) return matches;
diff --git a/drivers/soc/soc_sandbox.c b/drivers/soc/soc_sandbox.c index 5c82ad84fc..1a81d3562a 100644 --- a/drivers/soc/soc_sandbox.c +++ b/drivers/soc/soc_sandbox.c @@ -31,10 +31,18 @@ int soc_sandbox_get_revision(struct udevice *dev, char *buf, int size) return 0; }
+int soc_sandbox_get_soc_id(struct udevice *dev, char *buf, int size) +{ + snprintf(buf, size, "r8a774a1"); + + return 0; +} + static const struct soc_ops soc_sandbox_ops = { .get_family = soc_sandbox_get_family, .get_revision = soc_sandbox_get_revision, .get_machine = soc_sandbox_get_machine, + .get_soc_id = soc_sandbox_get_soc_id, };
int soc_sandbox_probe(struct udevice *dev) diff --git a/include/soc.h b/include/soc.h index a55eb1b572..ae7b36846f 100644 --- a/include/soc.h +++ b/include/soc.h @@ -20,18 +20,20 @@ * variants. Example: am33 * @machine - Name of a specific SoC. Example: am3352 * @revision - Name of a specific SoC revision. Example: SR1.1 + * @soc_id - SoC identification String. Example: r8a774a1 * @data - A pointer to user data for the SoC variant */ struct soc_attr { const char *family; const char *machine; const char *revision; + const char *soc_id; const void *data; };
struct soc_ops { /** - * get_machine() - Get machine name of an SOC + * get_machine() - Get machine name of a SoC * * @dev: Device to check (UCLASS_SOC) * @buf: Buffer to place string @@ -41,7 +43,7 @@ struct soc_ops { int (*get_machine)(struct udevice *dev, char *buf, int size);
/** - * get_revision() - Get revision name of a SOC + * get_revision() - Get revision name of a SoC * * @dev: Device to check (UCLASS_SOC) * @buf: Buffer to place string @@ -51,7 +53,7 @@ struct soc_ops { int (*get_revision)(struct udevice *dev, char *buf, int size);
/** - * get_family() - Get family name of an SOC + * get_family() - Get family name of a SoC * * @dev: Device to check (UCLASS_SOC) * @buf: Buffer to place string @@ -59,6 +61,16 @@ struct soc_ops { * @return 0 if OK, -ENOSPC if buffer is too small, other -ve on error */ int (*get_family)(struct udevice *dev, char *buf, int size); + + /** + * get_soc_id() - Get SoC identification name of a SoC + * + * @dev: Device to check (UCLASS_SOC) + * @buf: Buffer to place string + * @size: Size of string space + * @return 0 if OK, -ENOSPC if buffer is too small, other -ve on error + */ + int (*get_soc_id)(struct udevice *dev, char *buf, int size); };
#define soc_get_ops(dev) ((struct soc_ops *)(dev)->driver->ops) @@ -76,7 +88,7 @@ struct soc_ops { int soc_get(struct udevice **devp);
/** - * soc_get_machine() - Get machine name of an SOC + * soc_get_machine() - Get machine name of a SoC * @dev: Device to check (UCLASS_SOC) * @buf: Buffer to place string * @size: Size of string space @@ -86,7 +98,7 @@ int soc_get(struct udevice **devp); int soc_get_machine(struct udevice *dev, char *buf, int size);
/** - * soc_get_revision() - Get revision name of an SOC + * soc_get_revision() - Get revision name of a SoC * @dev: Device to check (UCLASS_SOC) * @buf: Buffer to place string * @size: Size of string space @@ -96,7 +108,7 @@ int soc_get_machine(struct udevice *dev, char *buf, int size); int soc_get_revision(struct udevice *dev, char *buf, int size);
/** - * soc_get_family() - Get family name of an SOC + * soc_get_family() - Get family name of a SoC * @dev: Device to check (UCLASS_SOC) * @buf: Buffer to place string * @size: Size of string space @@ -105,6 +117,16 @@ int soc_get_revision(struct udevice *dev, char *buf, int size); */ int soc_get_family(struct udevice *dev, char *buf, int size);
+/** + * soc_get_soc_id() - Get SoC identification name of a SoC + * @dev: Device to check (UCLASS_SOC) + * @buf: Buffer to place string + * @size: Size of string space + * + * Return: 0 if OK, -ENOSPC if buffer is too small, other -ve on error + */ +int soc_get_soc_id(struct udevice *dev, char *buf, int size); + /** * soc_device_match() - Return match from an array of soc_attr * @matches: Array with any combination of family, revision or machine set @@ -136,6 +158,11 @@ static inline int soc_get_family(struct udevice *dev, char *buf, int size) return -ENOSYS; }
+static inline int soc_get_soc_id(struct udevice *dev, char *buf, int size) +{ + return -ENOSYS; +} + static inline const struct soc_attr * soc_device_match(const struct soc_attr *matches) { diff --git a/test/dm/soc.c b/test/dm/soc.c index 17e1b5ba01..82cd53ff29 100644 --- a/test/dm/soc.c +++ b/test/dm/soc.c @@ -32,24 +32,28 @@ static int dm_test_soc(struct unit_test_state *uts) .family = "SANDBOX0xx", .machine = "SANDBOX012", .revision = "1.0", + .soc_id = "r8a774a1", .data = NULL, }, { .family = "SANDBOX1xx", .machine = "SANDBOX107", .revision = "1.0", + .soc_id = "r8a774a1", .data = NULL, }, { .family = "SANDBOX1xx", .machine = "SANDBOX123", .revision = "1.0", + .soc_id = "r8a774a1", .data = &soc_sandbox123_data, }, { .family = "SANDBOX1xx", .machine = "SANDBOX131", .revision = "2.0", + .soc_id = "r8a774a1", .data = NULL, }, { /* sentinel */ } @@ -78,6 +82,7 @@ static int dm_test_soc(struct unit_test_state *uts) { .family = "SANDBOX0xx", .revision = "1.0", + .soc_id = "r8a774b1", .data = NULL, }, { @@ -99,6 +104,9 @@ static int dm_test_soc(struct unit_test_state *uts) ut_assertok(soc_get_revision(dev, text, sizeof(text))); ut_asserteq_str(text, "1.0");
+ ut_assertok(soc_get_soc_id(dev, text, sizeof(text))); + ut_asserteq_str(text, "r8a774a1"); + soc_data = soc_device_match(sb_soc_devices_full); ut_assert(soc_data);
This is not a correct change, "an" should be used if the word that follows starts with a vowel sound, which "SoC" does.
"SOC" could be changed to "SoC", no strong feelings there.
Is there any additional background here? Why is soc_id needed? Can "machine" not meet the same purpose?
My thought was "family" would cover a range of parts and "machine" was to be a specific SoC. Is a more specific ID needed?
- struct soc_ops *ops = soc_get_ops(dev);
- if (!ops->get_soc_id)
return -ENOSYS;
- return ops->get_soc_id(dev, buf, size);
- const struct soc_attr * soc_device_match(const struct soc_attr *matches) {
matches->revision))
match = true;
match = false;
- if (match) return matches;
- snprintf(buf, size, "r8a774a1");
- @machine - Name of a specific SoC. Example: am3352
- @revision - Name of a specific SoC revision. Example: SR1.1
- @soc_id - SoC identification String. Example: r8a774a1
- @data - A pointer to user data for the SoC variant
- @dev: Device to check (UCLASS_SOC)
- @buf: Buffer to place string
- soc_get_machine() - Get machine name of an SOC
- soc_get_machine() - Get machine name of a SoC
- @size: Size of string space
- soc_get_revision() - Get revision name of an SOC
- soc_get_revision() - Get revision name of a SoC
- soc_get_family() - Get family name of an SOC
- soc_get_family() - Get family name of a SoC
- soc_get_soc_id() - Get SoC identification name of a SoC
- Return: 0 if OK, -ENOSPC if buffer is too small, other -ve on error
- soc_device_match() - Return match from an array of soc_attr
- @matches: Array with any combination of family, revision or machine set
- return -ENOSYS;
- static inline const struct soc_attr * soc_device_match(const struct soc_attr *matches) {
Some more thought will need to be given here, you can't just add the new value everywhere, some should not match.
Regards, Dave
}, { .family = "SANDBOX1xx", .machine = "SANDBOX123", .revision = "1.0",.soc_id = "r8a774a1", .data = NULL,
}, { .family = "SANDBOX1xx", .machine = "SANDBOX131", .revision = "2.0",.soc_id = "r8a774a1", .data = &soc_sandbox123_data,
}, { /* sentinel */ }.soc_id = "r8a774a1", .data = NULL,
}, {.soc_id = "r8a774b1", .data = NULL,
- ut_assertok(soc_get_soc_id(dev, text, sizeof(text)));
- ut_asserteq_str(text, "r8a774a1");
- soc_data = soc_device_match(sb_soc_devices_full); ut_assert(soc_data);
Hi Dave,
Thanks for the feedback.
Subject: Re: [PATCH] dm: soc: Add SoC id for attribute matching
Agreed. Will change back to an SoC on V2.
The below one still uses "a SOC". Will change to "an SoC" as well. - * get_revision() - Get revision name of a SOC + * get_revision() - Get revision name of a SoC
OK.
Signed-off-by: Biju Das biju.das.jz@bp.renesas.com Reviewed-by: Lad Prabhakar <prabhakar.mahadev-
lad.rj@bp.renesas.com>
int size)
Renesas SoC and other SoC vendors use SoC_ID for SoC identification.See the details here [1]
[1] https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/driv...
Please see other SoC vendors as well [2] which uses SoC_ID for identification. [2] https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/driv...
Yes, Please see above.
Family in over case is: RCar Gen3 SoC family or RZ/G2 SoC family Machine is Name of machine for eg;- "HopeRun HiHope RZ/G2M with sub board" SoC_ID is some thing SoC specific for eg:- r8a774a1 Revision is : ES x.y.
I think in your case, it is different??
return -ENOSYS;
- return ops->get_soc_id(dev, buf, size); }
matches->revision))
match = true;
match = false;
return 0; }
int size);
*buf, int size);
+error */ int soc_get_soc_id(struct udevice *dev, char *buf, int +size);
machine set
return -ENOSYS; }
+static inline int soc_get_soc_id(struct udevice *dev, char *buf, int +size) {
- return -ENOSYS;
I have ran the ut_dm test case and is passing.
./test/py/test.py --bd sandbox --build -k ut_dm.
Please let me know, if I should remove the same.
Regards, Biju
Biju Das
Dave Gerlach
