[PATCH v3 00/18] Support for rk3568 based QNAP TS433 NAS
Currently QNAP builds a series of RK3568- (and RK3588-) based NAS systems. This series provides support for the 4-bay variant called TS433.
The whole series of devices is pretty similar so adding support for the other variants will be pretty easy, once device-specific devicetrees land.
The cherry-picked dts patches landed in the 6.12-rc1 merge window in the Linux kernel.
This currently goes on top of today's u-boot master.
changes in v3: - list qnap/index in doc/boards/index - add CONFIG_SYS_HAS_NONCACHED_MEMORY to defconfig to fix cache error changes in v2: - use actual cherry-picked upstream dts commits, now that they are merged
Heiko Stuebner (17): arm64: dts: rockchip: add PCIe supply regulator to Qnap-TS433 arm64: dts: rockchip: enable second PCIe controller on the Qnap-TS433 arm64: dts: rockchip: enable uart0 on Qnap-TS433 arm64: dts: rockchip: enable usb ports on Qnap-TS433 arm64: dts: rockchip: add stdout path on Qnap-TS433 arm64: dts: rockchip: enable sata1+2 on Qnap-TS433 arm64: dts: rockchip: add board-aliases for Qnap-TS433 arm64: dts: rockchip: add hdd leds to Qnap-TS433 arm64: dts: rockchip: enable the tsadc on the Qnap-TS433 arm64: dts: rockchip: add gpio-keys to Qnap-TS433 arm64: dts: rockchip: define cpu-supply on the Qnap-TS433 arm64: dts: rockchip: add missing pmic information on Qnap-TS433 arm64: dts: rockchip: enable gpu on Qnap-TS433 arm64: dts: rockchip: add 2 pmu_io_domain supplies for Qnap-TS433 arm64: dts: rockchip: actually enable pmu-io-domains on qnap-ts433 arm64: dts: rockchip: add product-data eeproms to QNAP TS433 board: rockchip: add support for Qnap TS433 devices
Uwe Kleine-König (1): arm64: dts: rockchip: Simplify network PHY connection on qnap-ts433
arch/arm/dts/rk3568-qnap-ts433-u-boot.dtsi | 6 + arch/arm/mach-rockchip/rk3568/Kconfig | 14 + board/qnap/ts433/Kconfig | 12 + board/qnap/ts433/MAINTAINERS | 8 + configs/qnap-ts433-rk3568_defconfig | 87 +++ doc/board/index.rst | 1 + doc/board/qnap/index.rst | 9 + doc/board/qnap/ts433.rst | 91 +++ doc/board/rockchip/rockchip.rst | 1 + .../src/arm64/rockchip/rk3568-qnap-ts433.dts | 571 +++++++++++++++++- include/configs/qnap_ts433.h | 10 + 11 files changed, 804 insertions(+), 6 deletions(-) create mode 100644 arch/arm/dts/rk3568-qnap-ts433-u-boot.dtsi create mode 100644 board/qnap/ts433/Kconfig create mode 100644 board/qnap/ts433/MAINTAINERS create mode 100644 configs/qnap-ts433-rk3568_defconfig create mode 100644 doc/board/qnap/index.rst create mode 100644 doc/board/qnap/ts433.rst create mode 100644 include/configs/qnap_ts433.h
Add the vcc3v3-supply regulator and its link to the pcie controllers.
Tested-by: Uwe Kleine-König ukleinek@debian.org Signed-off-by: Heiko Stuebner heiko@sntech.de Link: https://lore.kernel.org/r/20240723195538.1133436-2-heiko@sntech.de
[ upstream commit: e0ec6d48226fb3d4df18895b56f0b7a94c0fe474 ]
(cherry picked from commit 59939b4343db08fa08098238160007e6ded72be9) Reviewed-by: Kever Yang kever.yang@rock-chips.com --- .../src/arm64/rockchip/rk3568-qnap-ts433.dts | 21 +++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts index 6a998166003..07b4f095d76 100644 --- a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts +++ b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts @@ -12,6 +12,25 @@ / { model = "Qnap TS-433-4G NAS System 4-Bay"; compatible = "qnap,ts433", "rockchip,rk3568"; + + dc_12v: regulator-dc-12v { + compatible = "regulator-fixed"; + regulator-name = "dc_12v"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + }; + + vcc3v3_pcie: regulator-vcc3v3-pcie { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_pcie"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + enable-active-high; + gpios = <&gpio0 RK_PD4 GPIO_ACTIVE_HIGH>; + vin-supply = <&dc_12v>; + }; };
&gmac0 { @@ -62,9 +81,11 @@ status = "okay"; };
+/* Connected to a JMicron AHCI SATA controller */ &pcie3x1 { /* The downstream dts has: rockchip,bifurcation, XXX: find out what this is about */ reset-gpios = <&gpio0 RK_PC7 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc3v3_pcie>; status = "okay"; };
The TS433 uses both pcie controllers for sata and the 2nd network interface. Set the needed data-lanes in the pcie3 phy and enable the second pcie controller, as well as remove the bifurcation comment.
Tested-by: Uwe Kleine-König ukleinek@debian.org Signed-off-by: Heiko Stuebner heiko@sntech.de Link: https://lore.kernel.org/r/20240723195538.1133436-3-heiko@sntech.de
[ upstream commit: 0f5f87a1d602a33028522784eb005647fa1b5c11 ]
(cherry picked from commit 7d8f260e65cc84076ec9456954de0f136948a2c8) --- dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts | 10 +++++++++- 1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts index 07b4f095d76..9bf9c3b65ca 100644 --- a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts +++ b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts @@ -78,17 +78,25 @@ };
&pcie30phy { + data-lanes = <1 2>; status = "okay"; };
/* Connected to a JMicron AHCI SATA controller */ &pcie3x1 { - /* The downstream dts has: rockchip,bifurcation, XXX: find out what this is about */ reset-gpios = <&gpio0 RK_PC7 GPIO_ACTIVE_HIGH>; vpcie3v3-supply = <&vcc3v3_pcie>; status = "okay"; };
+/* Connected to the 2.5G NIC for the upper network jack */ +&pcie3x2 { + num-lanes = <1>; + reset-gpios = <&gpio2 RK_PD6 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc3v3_pcie>; + status = "okay"; +}; + &sdhci { bus-width = <8>; max-frequency = <200000000>;
Uart0 is connected to an MCU on the board that handles system control like the fan-speed. So far no driver for it is available though.
Tested-by: Uwe Kleine-König ukleinek@debian.org Signed-off-by: Heiko Stuebner heiko@sntech.de Link: https://lore.kernel.org/r/20240723195538.1133436-4-heiko@sntech.de
[ upstream commit: 07ef8be476bebd77cba3ca4804be03cc0dba414f ]
(cherry picked from commit aaa5b1c4bd8f0e4327078d513f0eef05cb829bcf) Reviewed-by: Kever Yang kever.yang@rock-chips.com --- dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts index 9bf9c3b65ca..bc26f2e98c1 100644 --- a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts +++ b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts @@ -104,6 +104,14 @@ status = "okay"; };
+/* + * Connected to an MCU, that provides access to more LEDs, + * buzzer, fan control and more. + */ +&uart0 { + status = "okay"; +}; + /* * Pins available on CN3 connector at TTL voltage level (3V3). * ,_ _.
Enable usb controllers and phys and add regulator infrastructure for the usb ports on the TS433.
Of course there are no schematics available for the device, so the regulator information comes from the vendor-devicetree with unknown accuracy.
Tested-by: Uwe Kleine-König ukleinek@debian.org Signed-off-by: Heiko Stuebner heiko@sntech.de Link: https://lore.kernel.org/r/20240723195538.1133436-5-heiko@sntech.de
[ upstream commit: d992203f57c5caad0dbd4a9c669d79b315873c81 ]
(cherry picked from commit bb745ef13efb9f6589f9eda8f66664bf263a13f3) Reviewed-by: Kever Yang kever.yang@rock-chips.com --- .../src/arm64/rockchip/rk3568-qnap-ts433.dts | 105 ++++++++++++++++++ 1 file changed, 105 insertions(+)
diff --git a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts index bc26f2e98c1..da735c4764f 100644 --- a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts +++ b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts @@ -31,6 +31,49 @@ gpios = <&gpio0 RK_PD4 GPIO_ACTIVE_HIGH>; vin-supply = <&dc_12v>; }; + + vcc5v0_host: regulator-vcc5v0-host { + compatible = "regulator-fixed"; + enable-active-high; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_host_en>; + gpio = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>; + regulator-name = "vcc5v0_host"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc5v0_usb>; + }; + + vcc5v0_otg: regulator-vcc5v0-otg { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PA5 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_otg_en>; + regulator-name = "vcc5v0_otg"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc5v0_usb>; + }; + + vcc5v0_usb: regulator-vcc5v0-usb { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_usb"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&dc_12v>; + }; +}; + +/* connected to usb_host0_xhci */ +&combphy0 { + status = "okay"; };
&gmac0 { @@ -97,6 +140,18 @@ status = "okay"; };
+&pinctrl { + usb { + vcc5v0_host_en: vcc5v0-host-en { + rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + vcc5v0_otg_en: vcc5v0-otg-en { + rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + &sdhci { bus-width = <8>; max-frequency = <200000000>; @@ -121,3 +176,53 @@ &uart2 { status = "okay"; }; + +&usb2phy0 { + status = "okay"; +}; + +/* connected to usb_host0_xhci */ +&usb2phy0_otg { + phy-supply = <&vcc5v0_otg>; + status = "okay"; +}; + +&usb2phy1 { + status = "okay"; +}; + +/* connected to usb_host1_ehci/ohci */ +&usb2phy1_host { + phy-supply = <&vcc5v0_host>; + status = "okay"; +}; + +/* connected to usb_host0_ehci/ohci */ +&usb2phy1_otg { + phy-supply = <&vcc5v0_host>; + status = "okay"; +}; + +/* right port backside */ +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +/* front port */ +&usb_host0_xhci { + dr_mode = "host"; + status = "okay"; +}; + +/* left port backside */ +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +};
As most Rockchip boards do, the TS433 also uses uart2 for its serial output. Set the correct chosen entry for it.
Tested-by: Uwe Kleine-König ukleinek@debian.org Signed-off-by: Heiko Stuebner heiko@sntech.de Link: https://lore.kernel.org/r/20240723195538.1133436-6-heiko@sntech.de
[ upstream commit: e1cb5d8a92e41171bf4d5ddc459bd96372500901 ]
(cherry picked from commit 1e1af2af2192490a3d174624ac1bb976aa6afffa) Reviewed-by: Kever Yang kever.yang@rock-chips.com --- dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts index da735c4764f..be1c2286c2d 100644 --- a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts +++ b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts @@ -13,6 +13,10 @@ model = "Qnap TS-433-4G NAS System 4-Bay"; compatible = "qnap,ts433", "rockchip,rk3568";
+ chosen { + stdout-path = "serial2:115200n8"; + }; + dc_12v: regulator-dc-12v { compatible = "regulator-fixed"; regulator-name = "dc_12v";
The TS433 has 4 bays. The last two are accessed via a pci-connected sata controller, while the first two are accessed via the rk3568's sata controllers. Enable these two now.
Tested-by: Uwe Kleine-König ukleinek@debian.org Signed-off-by: Heiko Stuebner heiko@sntech.de Link: https://lore.kernel.org/r/20240723195538.1133436-7-heiko@sntech.de
[ upstream commit: 673c1353b3d476b9c5df6b84a777ed171e5594f5 ]
(cherry picked from commit dfa45bbda057851d0c2167b4c311c0301637cc19) Reviewed-by: Kever Yang kever.yang@rock-chips.com --- .../src/arm64/rockchip/rk3568-qnap-ts433.dts | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+)
diff --git a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts index be1c2286c2d..40af4dd0e41 100644 --- a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts +++ b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts @@ -80,6 +80,16 @@ status = "okay"; };
+/* connected to sata1 */ +&combphy1 { + status = "okay"; +}; + +/* connected to sata2 */ +&combphy2 { + status = "okay"; +}; + &gmac0 { assigned-clocks = <&cru SCLK_GMAC0_RX_TX>, <&cru SCLK_GMAC0>; assigned-clock-parents = <&cru SCLK_GMAC0_RGMII_SPEED>, <&cru CLK_MAC0_2TOP>; @@ -156,6 +166,14 @@ }; };
+&sata1 { + status = "okay"; +}; + +&sata2 { + status = "okay"; +}; + &sdhci { bus-width = <8>; max-frequency = <200000000>;
Add the aliases for the internal network interface as well as the emmc on the board and make sure the dedicated RTC is always the first one.
The TS433 actually has two rtc devices. One coming from the rk809 pmic without added functionality and also a dedicated RTC from Mycrocrystal that is battery backed to keep the time.
Tested-by: Uwe Kleine-König ukleinek@debian.org Signed-off-by: Heiko Stuebner heiko@sntech.de Link: https://lore.kernel.org/r/20240723195538.1133436-8-heiko@sntech.de
[ upstream commit: dadd4256e12360d3ff1f6481b2e4697f9d890caf ]
(cherry picked from commit cb53815764403f7f17967a32eec2aeb6625b396f) Reviewed-by: Kever Yang kever.yang@rock-chips.com --- dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts index 40af4dd0e41..8be36250aa1 100644 --- a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts +++ b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts @@ -13,6 +13,12 @@ model = "Qnap TS-433-4G NAS System 4-Bay"; compatible = "qnap,ts433", "rockchip,rk3568";
+ aliases { + ethernet0 = &gmac0; + mmc0 = &sdhci; + rtc0 = &rtc_rv8263; + }; + chosen { stdout-path = "serial2:115200n8"; }; @@ -120,7 +126,7 @@ &i2c1 { status = "okay";
- rtc@51 { + rtc_rv8263: rtc@51 { compatible = "microcrystal,rv8263"; reg = <0x51>; wakeup-source;
Add the 4 gpio-controlled LEDs to the Qnap-TS433.
They are meant for individual disk activitivy, but I haven't found a way for how to connect them to their individual sata slot yet.
Tested-by: Uwe Kleine-König ukleinek@debian.org Signed-off-by: Heiko Stuebner heiko@sntech.de Link: https://lore.kernel.org/r/20240723195538.1133436-9-heiko@sntech.de
[ upstream commit: ea91aabf18bcad6f5eceae6848ea6570ea61f126 ]
(cherry picked from commit 5a11b1bb40ac7b39e04077c045c3e3409fa352e2) Reviewed-by: Kever Yang kever.yang@rock-chips.com --- .../src/arm64/rockchip/rk3568-qnap-ts433.dts | 59 +++++++++++++++++++ 1 file changed, 59 insertions(+)
diff --git a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts index 8be36250aa1..abeb00add42 100644 --- a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts +++ b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts @@ -6,6 +6,7 @@
/dts-v1/;
+#include <dt-bindings/leds/common.h> #include <dt-bindings/gpio/gpio.h> #include "rk3568.dtsi"
@@ -23,6 +24,46 @@ stdout-path = "serial2:115200n8"; };
+ leds { + compatible = "gpio-leds"; + + led-0 { + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_DISK; + gpios = <&gpio1 RK_PD5 GPIO_ACTIVE_LOW>; + linux,default-trigger = "disk-activity"; + pinctrl-names = "default"; + pinctrl-0 = <&hdd1_led_pin>; + }; + + led-1 { + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_DISK; + gpios = <&gpio1 RK_PD6 GPIO_ACTIVE_LOW>; + linux,default-trigger = "disk-activity"; + pinctrl-names = "default"; + pinctrl-0 = <&hdd2_led_pin>; + }; + + led-2 { + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_DISK; + gpios = <&gpio1 RK_PD7 GPIO_ACTIVE_LOW>; + linux,default-trigger = "disk-activity"; + pinctrl-names = "default"; + pinctrl-0 = <&hdd3_led_pin>; + }; + + led-3 { + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_DISK; + gpios = <&gpio2 RK_PA0 GPIO_ACTIVE_LOW>; + linux,default-trigger = "disk-activity"; + pinctrl-names = "default"; + pinctrl-0 = <&hdd4_led_pin>; + }; + }; + dc_12v: regulator-dc-12v { compatible = "regulator-fixed"; regulator-name = "dc_12v"; @@ -161,6 +202,24 @@ };
&pinctrl { + leds { + hdd1_led_pin: hdd1-led-pin { + rockchip,pins = <1 RK_PD5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + hdd2_led_pin: hdd2-led-pin { + rockchip,pins = <1 RK_PD6 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + hdd3_led_pin: hdd3-led-pin { + rockchip,pins = <1 RK_PD7 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + hdd4_led_pin: hdd4_led-pin { + rockchip,pins = <2 RK_PA0 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + usb { vcc5v0_host_en: vcc5v0-host-en { rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>;
Enable the tsadc node to allow for temperature measurements of the soc.
Tested-by: Uwe Kleine-König ukleinek@debian.org Signed-off-by: Heiko Stuebner heiko@sntech.de Link: https://lore.kernel.org/r/20240723195538.1133436-10-heiko@sntech.de
[ upstream commit: 2dfdddd9d20306fd0d04b88fcbbf36d76fb67f11 ]
(cherry picked from commit d33949501abd1145ea572b605844f0ef4247478d) Reviewed-by: Kever Yang kever.yang@rock-chips.com --- dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts index abeb00add42..34fc31ea9a3 100644 --- a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts +++ b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts @@ -246,6 +246,12 @@ status = "okay"; };
+&tsadc { + rockchip,hw-tshut-mode = <1>; + rockchip,hw-tshut-polarity = <0>; + status = "okay"; +}; + /* * Connected to an MCU, that provides access to more LEDs, * buzzer, fan control and more.
The TS433 has 3 buttons, power and copy in the front as well as a reset pinhole button on the back. The power-button is connected to the embedded controller while the other two buttons are just gpio connected.
Add the gpio-keys definition for the two buttons we can handle right now.
Tested-by: Uwe Kleine-König ukleinek@debian.org Signed-off-by: Heiko Stuebner heiko@sntech.de Link: https://lore.kernel.org/r/20240723195538.1133436-11-heiko@sntech.de
[ upstream commit: 9b682d31b24f1f70b5b4d0618095d46e0722b9d8 ]
(cherry picked from commit f0b858c751382ee9faf18f9b19b0817c6b50ac1c) Reviewed-by: Kever Yang kever.yang@rock-chips.com --- .../src/arm64/rockchip/rk3568-qnap-ts433.dts | 29 +++++++++++++++++++ 1 file changed, 29 insertions(+)
diff --git a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts index 34fc31ea9a3..9f964b6f411 100644 --- a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts +++ b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts @@ -6,6 +6,7 @@
/dts-v1/;
+#include <dt-bindings/input/input.h> #include <dt-bindings/leds/common.h> #include <dt-bindings/gpio/gpio.h> #include "rk3568.dtsi" @@ -24,6 +25,24 @@ stdout-path = "serial2:115200n8"; };
+ keys { + compatible = "gpio-keys"; + pinctrl-0 = <©_button_pin>, <&reset_button_pin>; + pinctrl-names = "default"; + + key-copy { + label = "copy"; + gpios = <&gpio0 RK_PB6 GPIO_ACTIVE_LOW>; + linux,code = <KEY_COPY>; + }; + + key-reset { + label = "reset"; + gpios = <&gpio0 RK_PB5 GPIO_ACTIVE_LOW>; + linux,code = <KEY_RESTART>; + }; + }; + leds { compatible = "gpio-leds";
@@ -202,6 +221,16 @@ };
&pinctrl { + keys { + copy_button_pin: copy-button-pin { + rockchip,pins = <0 RK_PB6 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + reset_button_pin: reset-button-pin { + rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + leds { hdd1_led_pin: hdd1-led-pin { rockchip,pins = <1 RK_PD5 RK_FUNC_GPIO &pcfg_pull_up>;
The TS433 seems to use a silergy,syr827 regulator for the cpu supply. At least that is the compatible used in the vendor devicetree, though it could very well also be another fan53555 clone.
Define the needed regulator node and hook up the cpu-supply to the cpu cores.
Tested-by: Uwe Kleine-König ukleinek@debian.org Signed-off-by: Heiko Stuebner heiko@sntech.de Link: https://lore.kernel.org/r/20240723195538.1133436-12-heiko@sntech.de
[ upstream commit: 99b36ba910d896bddbb9a190ca686c6d9cd0325f ]
(cherry picked from commit 2f0afd1a3cbf6f3192dc7a5c496affab718671b3) Reviewed-by: Kever Yang kever.yang@rock-chips.com --- .../src/arm64/rockchip/rk3568-qnap-ts433.dts | 41 +++++++++++++++++++ 1 file changed, 41 insertions(+)
diff --git a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts index 9f964b6f411..4bccefc0537 100644 --- a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts +++ b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts @@ -130,6 +130,16 @@ vin-supply = <&vcc5v0_usb>; };
+ vcc5v0_sys: regulator-vcc5v0-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&dc_12v>; + }; + vcc5v0_usb: regulator-vcc5v0-usb { compatible = "regulator-fixed"; regulator-name = "vcc5v0_usb"; @@ -156,6 +166,22 @@ status = "okay"; };
+&cpu0 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu1 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu2 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu3 { + cpu-supply = <&vdd_cpu>; +}; + &gmac0 { assigned-clocks = <&cru SCLK_GMAC0_RX_TX>, <&cru SCLK_GMAC0>; assigned-clock-parents = <&cru SCLK_GMAC0_RGMII_SPEED>, <&cru CLK_MAC0_2TOP>; @@ -175,12 +201,27 @@ };
&i2c0 { + status = "okay"; + pmic@20 { compatible = "rockchip,rk809"; reg = <0x20>; interrupt-parent = <&gpio0>; interrupts = <3 IRQ_TYPE_LEVEL_LOW>; }; + + vdd_cpu: regulator@40 { + compatible = "silergy,syr827"; + reg = <0x40>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1390000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc5v0_sys>; + }; };
&i2c1 {
Fill in the missing pieces for RK809 pmic used on the TS433.
The regulator setup comes from the vendor-devicetree, so without proper schematics its accuracy is somewhat unclear, but it looks really similar to all the other rk3568 boards, so follows the reference design it seems.
The one caveat is related to vcc3v3_sd. This regulator needs to stay on. When turned off because of no users, access to both PCIe controllers will stall. Maybe this rail does supply the 100MHz refclk generation or so.
Tested-by: Uwe Kleine-König ukleinek@debian.org Signed-off-by: Heiko Stuebner heiko@sntech.de Link: https://lore.kernel.org/r/20240723195538.1133436-13-heiko@sntech.de
[ upstream commit: ee078c7daa98353496410b715a5acbb41d7d3a90 ]
(cherry picked from commit 48951cb085998a5c8e3650351a794b136dac648f) Reviewed-by: Kever Yang kever.yang@rock-chips.com --- .../src/arm64/rockchip/rk3568-qnap-ts433.dts | 227 +++++++++++++++++- 1 file changed, 226 insertions(+), 1 deletion(-)
diff --git a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts index 4bccefc0537..b807da6e850 100644 --- a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts +++ b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts @@ -102,6 +102,16 @@ vin-supply = <&dc_12v>; };
+ vcc3v3_sys: regulator-vcc3v3-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&dc_12v>; + }; + vcc5v0_host: regulator-vcc5v0-host { compatible = "regulator-fixed"; enable-active-high; @@ -207,7 +217,216 @@ compatible = "rockchip,rk809"; reg = <0x20>; interrupt-parent = <&gpio0>; - interrupts = <3 IRQ_TYPE_LEVEL_LOW>; + interrupts = <RK_PA3 IRQ_TYPE_LEVEL_LOW>; + #clock-cells = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>; + system-power-controller; + vcc1-supply = <&vcc3v3_sys>; + vcc2-supply = <&vcc3v3_sys>; + vcc3-supply = <&vcc3v3_sys>; + vcc4-supply = <&vcc3v3_sys>; + vcc5-supply = <&vcc3v3_sys>; + vcc6-supply = <&vcc3v3_sys>; + vcc7-supply = <&vcc3v3_sys>; + vcc8-supply = <&vcc3v3_sys>; + vcc9-supply = <&vcc3v3_sys>; + wakeup-source; + + regulators { + vdd_logic: DCDC_REG1 { + regulator-name = "vdd_logic"; + regulator-always-on; + regulator-boot-on; + regulator-initial-mode = <0x2>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_gpu: DCDC_REG2 { + regulator-name = "vdd_gpu"; + regulator-always-on; + regulator-initial-mode = <0x2>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + regulator-initial-mode = <0x2>; + + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vdd_npu: DCDC_REG4 { + regulator-name = "vdd_npu"; + regulator-initial-mode = <0x2>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v8: DCDC_REG5 { + regulator-name = "vcc_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdda0v9_image: LDO_REG1 { + regulator-name = "vdda0v9_image"; + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdda_0v9: LDO_REG2 { + regulator-name = "vdda_0v9"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdda0v9_pmu: LDO_REG3 { + regulator-name = "vdda0v9_pmu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <900000>; + }; + }; + + vccio_acodec: LDO_REG4 { + regulator-name = "vccio_acodec"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vccio_sd: LDO_REG5 { + regulator-name = "vccio_sd"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v3_pmu: LDO_REG6 { + regulator-name = "vcc3v3_pmu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcca_1v8: LDO_REG7 { + regulator-name = "vcca_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcca1v8_pmu: LDO_REG8 { + regulator-name = "vcca1v8_pmu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcca1v8_image: LDO_REG9 { + regulator-name = "vcca1v8_image"; + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_3v3: SWITCH_REG1 { + regulator-name = "vcc_3v3"; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v3_sd: SWITCH_REG2 { + regulator-name = "vcc3v3_sd"; + /* + * turning this off, breaks access to both + * PCIe controllers, refclk generator perhaps + */ + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; };
vdd_cpu: regulator@40 { @@ -290,6 +509,12 @@ }; };
+ pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + usb { vcc5v0_host_en: vcc5v0-host-en { rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>;
The TS433 doesn't provide display output, but the gpu nevertheless can be used for compute tasks for example.
So there is no reason not to enable it.
Tested-by: Uwe Kleine-König ukleinek@debian.org Signed-off-by: Heiko Stuebner heiko@sntech.de Link: https://lore.kernel.org/r/20240723195538.1133436-14-heiko@sntech.de
[ upstream commit: 9130eb62586f4cef0557d0378fb7e78d7397ab2d ]
(cherry picked from commit e324a9e8ea083ebdca207b5ca2ed86d2b5f862a0) Reviewed-by: Kever Yang kever.yang@rock-chips.com --- dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts index b807da6e850..9a0cb69c3cf 100644 --- a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts +++ b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts @@ -210,6 +210,11 @@ status = "okay"; };
+&gpu { + mali-supply = <&vdd_gpu>; + status = "okay"; +}; + &i2c0 { status = "okay";
Add the two supplies for the pmu-io-domains that are defined in the vendor devicetree for the TS433.
Tested-by: Uwe Kleine-König ukleinek@debian.org Signed-off-by: Heiko Stuebner heiko@sntech.de Link: https://lore.kernel.org/r/20240723195538.1133436-15-heiko@sntech.de
[ upstream commit: 64b7f16fb3947e5d08d9e9b860ce966250e45d52 ]
(cherry picked from commit 9b4d4c02b5762196063ab03c5439f96cbbaf2485) Reviewed-by: Kever Yang kever.yang@rock-chips.com --- dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts index 9a0cb69c3cf..6c4269b3d95 100644 --- a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts +++ b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts @@ -531,6 +531,11 @@ }; };
+&pmu_io_domains { + vccio4-supply = <&vcc_1v8>; + vccio6-supply = <&vcc_1v8>; +}; + &sata1 { status = "okay"; };
While it requires to have the right phy driver loaded (i.e. motorcomm) to make the phy asserting the right delays, this is generally the preferred way to define the MAC <-> PHY connection.
Signed-off-by: Uwe Kleine-König ukleinek@debian.org Reviewed-by: Andrew Lunn andrew@lunn.ch Link: https://lore.kernel.org/r/20240304084612.711678-2-ukleinek@debian.org Signed-off-by: Heiko Stuebner heiko@sntech.de
[ upstream commit: e8d45544f806f3b55c30345de84262cbb9504902 ]
(cherry picked from commit e0bbe061fd537bd7b113c53eb046bbcbf0e6597d) Reviewed-by: Kever Yang kever.yang@rock-chips.com --- dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts | 4 +--- 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts index 6c4269b3d95..20e4fa6c185 100644 --- a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts +++ b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts @@ -198,15 +198,13 @@ assigned-clock-rates = <0>, <125000000>; clock_in_out = "output"; phy-handle = <&rgmii_phy0>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id"; pinctrl-names = "default"; pinctrl-0 = <&gmac0_miim &gmac0_tx_bus2 &gmac0_rx_bus2 &gmac0_rgmii_clk &gmac0_rgmii_bus>; - rx_delay = <0x2f>; - tx_delay = <0x3c>; status = "okay"; };
Contrary to the vendor-kernel the pmu-io-domains are not enabled by default. This resulted in the value not being set according to the regulator, which in turn made the gmac0 interface that is connected to the vccio4 supply inoperable.
Fixes: 64b7f16fb394 ("arm64: dts: rockchip: add 2 pmu_io_domain supplies for Qnap-TS433") Signed-off-by: Heiko Stuebner heiko@sntech.de Link: https://lore.kernel.org/r/20240805162052.3345768-1-heiko@sntech.de
[ upstream commit: 40cc4257169712f0ae3835820a4c5afbdd1a16ff ]
(cherry picked from commit f509fcb1fb82117e551b489592ac5714a6c5cd8d) Reviewed-by: Kever Yang kever.yang@rock-chips.com --- dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts | 1 + 1 file changed, 1 insertion(+)
diff --git a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts index 20e4fa6c185..90d8d526629 100644 --- a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts +++ b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts @@ -532,6 +532,7 @@ &pmu_io_domains { vccio4-supply = <&vcc_1v8>; vccio6-supply = <&vcc_1v8>; + status = "okay"; };
&sata1 {
The device contains two i2c-connected eeproms holding some product- specific values. One sitting on the mainboard and one on the statically connected backplane.
While the eeprom chips themself have a size of 512 byte, the eeprom data only uses 256 byte each, probably to stay compatible with other models.
Signed-off-by: Heiko Stuebner heiko@sntech.de Link: https://lore.kernel.org/r/20240810211438.286441-3-heiko@sntech.de
[ upstream commit: da6f4130234448122fe3e66c8116f7d9eea8a5c7 ]
(cherry picked from commit 0b3109708caf5002ba188ae28eae9ce46b2c39b4) Reviewed-by: Kever Yang kever.yang@rock-chips.com --- .../src/arm64/rockchip/rk3568-qnap-ts433.dts | 20 +++++++++++++++++++ 1 file changed, 20 insertions(+)
diff --git a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts index 90d8d526629..e601d9271ba 100644 --- a/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts +++ b/dts/upstream/src/arm64/rockchip/rk3568-qnap-ts433.dts @@ -454,6 +454,26 @@ reg = <0x51>; wakeup-source; }; + + /* eeprom for vital-product-data on the mainboard */ + eeprom@54 { + compatible = "giantec,gt24c04a", "atmel,24c04"; + reg = <0x54>; + label = "VPD_MB"; + num-addresses = <2>; + pagesize = <16>; + read-only; + }; + + /* eeprom for vital-product-data on the backplane */ + eeprom@56 { + compatible = "giantec,gt24c04a", "atmel,24c04"; + reg = <0x56>; + label = "VPD_BP"; + num-addresses = <2>; + pagesize = <16>; + read-only; + }; };
&mdio0 {
The Qnap TS433 is a 4-bay NAS based around the RK3568.
Two SATA bays are connected to the RK3568's own SATA controllers while the other two are connected to a JMicron SATA controller living on the PCIe bus.
It provides one 2.5Gb and one 1Gb ethernet port as well as 3 usb ports.
Signed-off-by: Heiko Stuebner heiko@sntech.de --- arch/arm/dts/rk3568-qnap-ts433-u-boot.dtsi | 6 ++ arch/arm/mach-rockchip/rk3568/Kconfig | 14 ++++ board/qnap/ts433/Kconfig | 12 +++ board/qnap/ts433/MAINTAINERS | 8 ++ configs/qnap-ts433-rk3568_defconfig | 87 +++++++++++++++++++++ doc/board/index.rst | 1 + doc/board/qnap/index.rst | 9 +++ doc/board/qnap/ts433.rst | 91 ++++++++++++++++++++++ doc/board/rockchip/rockchip.rst | 1 + include/configs/qnap_ts433.h | 10 +++ 10 files changed, 239 insertions(+) create mode 100644 arch/arm/dts/rk3568-qnap-ts433-u-boot.dtsi create mode 100644 board/qnap/ts433/Kconfig create mode 100644 board/qnap/ts433/MAINTAINERS create mode 100644 configs/qnap-ts433-rk3568_defconfig create mode 100644 doc/board/qnap/index.rst create mode 100644 doc/board/qnap/ts433.rst create mode 100644 include/configs/qnap_ts433.h
diff --git a/arch/arm/dts/rk3568-qnap-ts433-u-boot.dtsi b/arch/arm/dts/rk3568-qnap-ts433-u-boot.dtsi new file mode 100644 index 00000000000..19acbceb468 --- /dev/null +++ b/arch/arm/dts/rk3568-qnap-ts433-u-boot.dtsi @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2024 Heiko Stuebner heiko@sntech.de + */ + +#include "rk356x-u-boot.dtsi" diff --git a/arch/arm/mach-rockchip/rk3568/Kconfig b/arch/arm/mach-rockchip/rk3568/Kconfig index e646f714c92..ce327ed6f9e 100644 --- a/arch/arm/mach-rockchip/rk3568/Kconfig +++ b/arch/arm/mach-rockchip/rk3568/Kconfig @@ -32,6 +32,19 @@ config TARGET_POWKIDDY_X55_RK3566 help Powkiddy X55 handheld gaming console with an RK3566 SoC.
+config TARGET_QNAP_TS433_RK3568 + bool "QNAP-TS433" + help + Qnap TS433 4-bay NAS with a RK3568 SoC. + + It provides the following featureset: + * 4GB LPDDR4 + * 4GB eMMC + * 2 SATA ports connected to two RK3568's SATA controllers + * 2 SATA ports connected to a JMicron JMB58x AHCI SATA controller + * 1 1G network controller + * 1 2.5G Realtek RTL8125 network controller + config TARGET_QUARTZ64_RK3566 bool "Pine64 Quartz64" help @@ -70,6 +83,7 @@ source "board/hardkernel/odroid_m1/Kconfig" source "board/hardkernel/odroid_m1s/Kconfig" source "board/pine64/quartz64_rk3566/Kconfig" source "board/powkiddy/x55/Kconfig" +source "board/qnap/ts433/Kconfig" source "board/radxa/zero3-rk3566/Kconfig" source "board/xunlong/orangepi-3b-rk3566/Kconfig"
diff --git a/board/qnap/ts433/Kconfig b/board/qnap/ts433/Kconfig new file mode 100644 index 00000000000..b00e1f9f2ef --- /dev/null +++ b/board/qnap/ts433/Kconfig @@ -0,0 +1,12 @@ +if TARGET_QNAP_TS433_RK3568 + +config SYS_BOARD + default "qnap_ts433" + +config SYS_VENDOR + default "qnap" + +config SYS_CONFIG_NAME + default "qnap_ts433" + +endif diff --git a/board/qnap/ts433/MAINTAINERS b/board/qnap/ts433/MAINTAINERS new file mode 100644 index 00000000000..c2b31ad9794 --- /dev/null +++ b/board/qnap/ts433/MAINTAINERS @@ -0,0 +1,8 @@ +QNAP-TS433 +M: Heiko Stuebner heiko@sntech.de +S: Maintained +F: board/qnap/ts433/ +F: doc/board/qnap/ +F: include/configs/qnap_ts433.h +F: configs/qnap-ts433-rk3568_defconfig +F: arch/arm/dts/rk3568-qnap-ts433-u-boot.dtsi diff --git a/configs/qnap-ts433-rk3568_defconfig b/configs/qnap-ts433-rk3568_defconfig new file mode 100644 index 00000000000..840da7f3759 --- /dev/null +++ b/configs/qnap-ts433-rk3568_defconfig @@ -0,0 +1,87 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SYS_HAS_NONCACHED_MEMORY=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3568-qnap-ts433" +CONFIG_ROCKCHIP_RK3568=y +CONFIG_SPL_SERIAL=y +CONFIG_TARGET_QNAP_TS433_RK3568=y +CONFIG_DEBUG_UART_BASE=0xFE660000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_PCI=y +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3568-qnap-ts433.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_ATF=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SATA=y +CONFIG_CMD_USB=y +CONFIG_CMD_ROCKUSB=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_AHCI_PCI=y +CONFIG_DWC_AHCI=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_LED=y +CONFIG_LED_GPIO=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y +CONFIG_RTL8169=y +CONFIG_PCIE_DW_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y +CONFIG_SPL_PINCTRL=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_FAN53555=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_SPL_RAM=y +CONFIG_SCSI=y +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_ERRNO_STR=y diff --git a/doc/board/index.rst b/doc/board/index.rst index 3fb7c84f10c..fe775b1b05d 100644 --- a/doc/board/index.rst +++ b/doc/board/index.rst @@ -42,6 +42,7 @@ Board-specific doc phytec/index purism/index qualcomm/index + qnap/index renesas/index rockchip/index samsung/index diff --git a/doc/board/qnap/index.rst b/doc/board/qnap/index.rst new file mode 100644 index 00000000000..652ea11a056 --- /dev/null +++ b/doc/board/qnap/index.rst @@ -0,0 +1,9 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Qnap +==== + +.. toctree:: + :maxdepth: 2 + + ts433.rst diff --git a/doc/board/qnap/ts433.rst b/doc/board/qnap/ts433.rst new file mode 100644 index 00000000000..5c7fd314b7a --- /dev/null +++ b/doc/board/qnap/ts433.rst @@ -0,0 +1,91 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +U-Boot for Qnap TS433 Devices +================================= + +This allows U-Boot to boot the Qnap TS433 NAS + +Preparing the serial +-------------------- + +Qnap devices run their serial console with a 115200 baudrate. As the +binary DDR-init and maskrom-downloader expect a 1500000 rate, it is +necessary to adapt the binaries if their output is needed. + +This can be done with a binary provided in the rkbin repository. +First the ddrbin_param.txt in the rkbin repo needs to be modified: + +.. code-block:: bash + + diff --git a/tools/ddrbin_param.txt b/tools/ddrbin_param.txt + index 0dfdd318..82ade7e7 100644 + --- a/tools/ddrbin_param.txt + +++ b/tools/ddrbin_param.txt + @@ -11,7 +11,7 @@ lp5_freq= + + uart id= + uart iomux= + -uart baudrate= + +uart baudrate=115200 + + sr_idle= + pd_idle= + +And after that the ddrbin_tool binary can be used to modify apply this +modification and also a new maskrom downloader can be build: + +.. code-block:: bash + + $ tools/ddrbin_tool rk3568 tools/ddrbin_param.txt bin/rk35/rk3568_ddr_1560MHz_v1.21.bin + $ tools/boot_merger RKBOOT/RK3568MINIALL.ini + +Building U-Boot +--------------- + +.. code-block:: bash + + $ export CROSS_COMPILE=aarch64-linux-gnu- + $ export BL31=../rkbin/bin/rk35/rk3568_bl31_v1.34.elf + $ export ROCKCHIP_TPL=../rkbin/bin/rk35/rk3568_ddr_1056MHz_v1.13.bin + $ make qnap-ts433-rk3568_defconfig + $ make + +This will build ``u-boot-rockchip.bin`` which can be written to the +on-board eMMC. + +Image installation +------------------ + +The Qnap thankfully provides an easily accessible serial header as well as +a very user-friendly jumper-header to bring the device into maskrom mode. + +To access both, the drive trays need to be removed. Looking at the board, +through the upper cutout of the metal frame the white 4-port serial-header +can be seen next to a barcode sticker. It's pinout is as follows: + +.. code-block:: bash + + ,_ _. + |1234| 1=TX 2=VCC + `----' 3=RX 4=GND + + +Directly below it, the mentioned 2-pin jumper header can be seen. + +To write your u-boot to the device, it needs to be powered off first. Then +a jumper or suitable cable needs to be used to connect the two pins of the +maskrom header. Turning on the device now will start it in maskrom mode. + +It is important that the jumper gets removed after that stop and before +actually trying to write to the emmc. + +The front usb-port needs to be connected to the host with an USB-A-to-A +cable to allow flashing. + +The flashing itself is done via rkdeveloptool, which can be found for +example as package of that name in Debian-based distributions: + +.. code-block:: bash + + $ rkdeveloptool db rk356x_spl_loader_v1.21.113.bin + $ rkdeveloptool wl 64 u-boot-rockchip.bin diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index 7b11a2e0a35..0783603ec50 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -119,6 +119,7 @@ List of mainline supported Rockchip boards: - FriendlyElec NanoPi R5S (nanopi-r5s-rk3568) - Generic RK3566/RK3568 (generic-rk3568) - Hardkernel ODROID-M1 (odroid-m1-rk3568) + - QNAP TS-433 (qnap-ts433-rk3568) - Radxa E25 Carrier Board (radxa-e25-rk3568) - Radxa ROCK 3A (rock-3a-rk3568) - Radxa ROCK 3B (rock-3b-rk3568) diff --git a/include/configs/qnap_ts433.h b/include/configs/qnap_ts433.h new file mode 100644 index 00000000000..aee4546bf07 --- /dev/null +++ b/include/configs/qnap_ts433.h @@ -0,0 +1,10 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ + +#ifndef __QNAP_TS433_H +#define __QNAP_TS433_H + +#define ROCKCHIP_DEVICE_SETTINGS + +#include <configs/rk3568_common.h> + +#endif
Thanks, - Kever
- (C) Copyright 2024 Heiko Stuebner heiko@sntech.de
- bool "QNAP-TS433"
- help
* 4GB LPDDR4
* 4GB eMMC
- config TARGET_QUARTZ64_RK3566 bool "Pine64 Quartz64" help
+config SYS_BOARD
- default "qnap_ts433"
+config SYS_VENDOR
- default "qnap"
- qnap/index renesas/index rockchip/index samsung/index
+Qnap +====
+.. toctree::
- :maxdepth: 2
- ts433.rst
- diff --git a/tools/ddrbin_param.txt b/tools/ddrbin_param.txt
- index 0dfdd318..82ade7e7 100644
- --- a/tools/ddrbin_param.txt
- +++ b/tools/ddrbin_param.txt
- @@ -11,7 +11,7 @@ lp5_freq=
uart id=
uart iomux=
- -uart baudrate=
- +uart baudrate=115200
sr_idle=
pd_idle=
- $ tools/ddrbin_tool rk3568 tools/ddrbin_param.txt bin/rk35/rk3568_ddr_1560MHz_v1.21.bin
- $ tools/boot_merger RKBOOT/RK3568MINIALL.ini
- $ export CROSS_COMPILE=aarch64-linux-gnu-
- $ export BL31=../rkbin/bin/rk35/rk3568_bl31_v1.34.elf
- $ export ROCKCHIP_TPL=../rkbin/bin/rk35/rk3568_ddr_1056MHz_v1.13.bin
- $ make qnap-ts433-rk3568_defconfig
- $ make
- ,_ _.
- |1234| 1=TX 2=VCC
- `----' 3=RX 4=GND
- $ rkdeveloptool db rk356x_spl_loader_v1.21.113.bin
- $ rkdeveloptool wl 64 u-boot-rockchip.bin
Hi Heiko,
Again, I got a warning/error from CI system for the doc :(
https://source.denx.de/u-boot/custodians/u-boot-rockchip/-/jobs/941781
/builds/u-boot/custodians/u-boot-rockchip/doc/board/qnap/ts433.rst:66: WARNING: Lexing literal_block ",_ _.\n|1234| 1=TX 2=VCC\n`----' 3=RX 4=GND" as "bash" resulted in an error at token: "'". Retrying in relaxed mode. [misc.highlighting_failure]
Maybe you can try with below command in your environment?
$ make htmldocs KDOC_WERROR=1
I didn't success to run this on my computer due to lots of modules missing one after another.
- bool "QNAP-TS433"
- help
* 4GB LPDDR4
* 4GB eMMC
+config SYS_BOARD
+config SYS_VENDOR
- default "qnap"
+Qnap +====
+.. toctree::
- :maxdepth: 2
- ts433.rst
uart id=
uart iomux=
- -uart baudrate=
sr_idle=
pd_idle=
- $ make
- ,_ _.
- |1234| 1=TX 2=VCC
- `----' 3=RX 4=GND
Hi Heiko,
On 2024/11/8 18:32, Kever Yang wrote:
Hi Heiko,
I have fix this with replace the "bash" with "none", and apply this patch set.
Thanks, - Kever
Thanks,
- Kever
+#include "rk356x-u-boot.dtsi" diff --git a/arch/arm/mach-rockchip/rk3568/Kconfig b/arch/arm/mach-rockchip/rk3568/Kconfig index e646f714c92..ce327ed6f9e 100644 --- a/arch/arm/mach-rockchip/rk3568/Kconfig +++ b/arch/arm/mach-rockchip/rk3568/Kconfig @@ -32,6 +32,19 @@ config TARGET_POWKIDDY_X55_RK3566 help Powkiddy X55 handheld gaming console with an RK3566 SoC. +config TARGET_QNAP_TS433_RK3568 + bool "QNAP-TS433" + help + Qnap TS433 4-bay NAS with a RK3568 SoC.
config TARGET_QUARTZ64_RK3566 bool "Pine64 Quartz64" help @@ -70,6 +83,7 @@ source "board/hardkernel/odroid_m1/Kconfig" source "board/hardkernel/odroid_m1s/Kconfig" source "board/pine64/quartz64_rk3566/Kconfig" source "board/powkiddy/x55/Kconfig" +source "board/qnap/ts433/Kconfig" source "board/radxa/zero3-rk3566/Kconfig" source "board/xunlong/orangepi-3b-rk3566/Kconfig" diff --git a/board/qnap/ts433/Kconfig b/board/qnap/ts433/Kconfig new file mode 100644 index 00000000000..b00e1f9f2ef --- /dev/null +++ b/board/qnap/ts433/Kconfig @@ -0,0 +1,12 @@ +if TARGET_QNAP_TS433_RK3568
+Qnap +====
Hi Kever,
Am Montag, 11. November 2024, 11:12:24 CET schrieb Kever Yang:
thanks a lot :-)
I was looking into that issue too, this morning (now), and an initial doc-build did not warn at least for me with Spinx from Debian testing.
But looking at the CI error output, it does not seem to like the ASCII-art describing the uart connector. And as definitly is not bash scripting, changing the formatting away from bash is probably the rigth thing to do. Let's hope the CI does succeed now.
Thanks a lot Heiko
Thanks,
- Kever
Thanks,
- Kever
- bool "QNAP-TS433"
- help
* 4GB LPDDR4
* 4GB eMMC
controller
+config SYS_BOARD
+config SYS_VENDOR
- default "qnap"
+Qnap +====
+.. toctree::
- :maxdepth: 2
- ts433.rst
uart id=
uart iomux=
- -uart baudrate=
sr_idle=
pd_idle=
- $ export
- $ make
- ,_ _.
- |1234| 1=TX 2=VCC
- `----' 3=RX 4=GND
Heiko Stuebner
Heiko Stübner
Kever Yang
