[PATCH 0/3] Improvements to FIT hashing
Here are some small changes to the FIT hashing code in order to use more code from common/, which in turns allows hw implementations of SHA.
This was motivated by a need to reduce the SPL size for the Aspeed platforms by using the hardware engine. I have a driver for the Aspeed SoC that I will submit.
Joel Stanley (3): hw_sha: Fix coding style errors fit: Use hash.c to call SHA code hash: Allow for SHA512 hardware implementations
common/hash.c | 24 ++++++++++++++++++++++-- common/image-fit.c | 34 ++++++++-------------------------- include/hw_sha.h | 38 ++++++++++++++++++++++++++++++++------ lib/Kconfig | 15 +++++++-------- 4 files changed, 69 insertions(+), 42 deletions(-)
Checkpatch complains about:
ERROR: "foo * bar" should be "foo *bar"
and
CHECK: Alignment should match open parenthesis
Signed-off-by: Joel Stanley joel@jms.id.au --- include/hw_sha.h | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/include/hw_sha.h b/include/hw_sha.h index 991e496a3cb2..15b1a1c79836 100644 --- a/include/hw_sha.h +++ b/include/hw_sha.h @@ -18,8 +18,8 @@ * should allocate at least 32 bytes at pOut in advance. * @param chunk_size chunk size for sha256 */ -void hw_sha256(const uchar * in_addr, uint buflen, - uchar * out_addr, uint chunk_size); +void hw_sha256(const uchar *in_addr, uint buflen, uchar *out_addr, + uint chunk_size);
/** * Computes hash value of input pbuf using h/w acceleration @@ -31,8 +31,8 @@ void hw_sha256(const uchar * in_addr, uint buflen, * should allocate at least 32 bytes at pOut in advance. * @param chunk_size chunk_size for sha1 */ -void hw_sha1(const uchar * in_addr, uint buflen, - uchar * out_addr, uint chunk_size); +void hw_sha1(const uchar *in_addr, uint buflen, uchar *out_addr, + uint chunk_size);
/* * Create the context for sha progressive hashing using h/w acceleration @@ -56,7 +56,7 @@ int hw_sha_init(struct hash_algo *algo, void **ctxp); * @return 0 if ok, -ve on error */ int hw_sha_update(struct hash_algo *algo, void *ctx, const void *buf, - unsigned int size, int is_last); + unsigned int size, int is_last);
/* * Copy sha hash result at destination location @@ -70,6 +70,6 @@ int hw_sha_update(struct hash_algo *algo, void *ctx, const void *buf, * @return 0 if ok, -ve on error */ int hw_sha_finish(struct hash_algo *algo, void *ctx, void *dest_buf, - int size); + int size);
#endif
and
Currently the FIT hashing will call directly into the SHA algorithms to get a hash.
This moves the fit code to use hash_lookup_algo, giving a common entrypoint into the hashing code and removing the duplicated algorithm look up. It also allows the use of hardware acceleration if configured.
Signed-off-by: Joel Stanley joel@jms.id.au --- common/image-fit.c | 34 ++++++++-------------------------- 1 file changed, 8 insertions(+), 26 deletions(-)
diff --git a/common/image-fit.c b/common/image-fit.c index 28b3d2b19111..3451cdecc95b 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -1210,37 +1210,19 @@ int fit_set_timestamp(void *fit, int noffset, time_t timestamp) * 0, on success * -1, when algo is unsupported */ -int calculate_hash(const void *data, int data_len, const char *algo, +int calculate_hash(const void *data, int data_len, const char *algo_name, uint8_t *value, int *value_len) { - if (IMAGE_ENABLE_CRC32 && strcmp(algo, "crc32") == 0) { - *((uint32_t *)value) = crc32_wd(0, data, data_len, - CHUNKSZ_CRC32); - *((uint32_t *)value) = cpu_to_uimage(*((uint32_t *)value)); - *value_len = 4; - } else if (IMAGE_ENABLE_SHA1 && strcmp(algo, "sha1") == 0) { - sha1_csum_wd((unsigned char *)data, data_len, - (unsigned char *)value, CHUNKSZ_SHA1); - *value_len = 20; - } else if (IMAGE_ENABLE_SHA256 && strcmp(algo, "sha256") == 0) { - sha256_csum_wd((unsigned char *)data, data_len, - (unsigned char *)value, CHUNKSZ_SHA256); - *value_len = SHA256_SUM_LEN; - } else if (IMAGE_ENABLE_SHA384 && strcmp(algo, "sha384") == 0) { - sha384_csum_wd((unsigned char *)data, data_len, - (unsigned char *)value, CHUNKSZ_SHA384); - *value_len = SHA384_SUM_LEN; - } else if (IMAGE_ENABLE_SHA512 && strcmp(algo, "sha512") == 0) { - sha512_csum_wd((unsigned char *)data, data_len, - (unsigned char *)value, CHUNKSZ_SHA512); - *value_len = SHA512_SUM_LEN; - } else if (IMAGE_ENABLE_MD5 && strcmp(algo, "md5") == 0) { - md5_wd((unsigned char *)data, data_len, value, CHUNKSZ_MD5); - *value_len = 16; - } else { + struct hash_algo *algo; + + if (hash_lookup_algo(algo_name, &algo)) { debug("Unsupported hash alogrithm\n"); return -1; } + + algo->hash_func_ws(data, data_len, value, algo->chunk_size); + *value_len = algo->digest_size; + return 0; }
Simon,
# This is not a direct comment on this patch.
0, on success
- -1, when algo is unsupported
CHUNKSZ_CRC32);
*value_len = 4;
*value_len = 20;
*value_len = 16;
- } else {
- struct hash_algo *algo;
- if (hash_lookup_algo(algo_name, &algo)) { debug("Unsupported hash alogrithm\n"); return -1; }
- algo->hash_func_ws(data, data_len, value, algo->chunk_size);
- *value_len = algo->digest_size;
With this patch applied, there co-exists a very similar, hence confusing function, hash_calculate(), in rsa-checksum.c (now checksum.c?). If there is no particular reason for those two functions, we'd better unify them?
-Takahiro Akashi
return 0; }
-- 2.30.0
On Wed, 17 Feb 2021 at 05:04, AKASHI Takahiro takahiro.akashi@linaro.org wrote:
Simon,
0, on success
CHUNKSZ_CRC32);
*value_len = 4;
*value_len = 20;
*value_len = 16;
} else {
hash_calculate is doing a progressive hash over a count of regions. This code is hashing a single chunk of data.
I agree the naming could be improved to make this clearer.
Cheers,
Joel
-Takahiro Akashi
-- 2.30.0
This breaks a few boards: ls1046ardb_qspi_spl imx8mm_beacon imx8mn_beacon imx8mn_beacon_2g imx8mm_evk imx8mn_ddr4_evk imx8mn_evk imx8mp_evk imx8mq_evk imx8mm_venice imx8mq_phanbell phycore-imx8mm phycore-imx8mp pico-imx8mq verdin-imx8mm mt8183_pumpkin mt8516_pumpkin that use FIT images, in SPL, but don't actually check hashes apparently. Just including hash.o for the hash-lookup function fails because we don't have crc16, etc, enabled and also I think need: https://patchwork.ozlabs.org/project/uboot/patch/20210322133331.1646575-1-mr... for consistent symbol naming.
So, I like this patch in concept, but I think it'll need to be reworked a bit, after I pull in some other changes soon. Thanks!
Similar to support for SHA1 and SHA256, allow the use of hardware hashing engine by enabling the algorithm and setting CONFIG_SHA_HW_ACCEL / CONFIG_SHA_PROG_HW_ACCEL.
Signed-off-by: Joel Stanley joel@jms.id.au --- common/hash.c | 24 ++++++++++++++++++++++-- include/hw_sha.h | 26 ++++++++++++++++++++++++++ lib/Kconfig | 15 +++++++-------- 3 files changed, 55 insertions(+), 10 deletions(-)
diff --git a/common/hash.c b/common/hash.c index fc64002f736a..10dff7ddb0e7 100644 --- a/common/hash.c +++ b/common/hash.c @@ -97,7 +97,7 @@ static int hash_finish_sha256(struct hash_algo *algo, void *ctx, void } #endif
-#if defined(CONFIG_SHA384) +#if defined(CONFIG_SHA384) && !defined(CONFIG_SHA_PROG_HW_ACCEL) static int hash_init_sha384(struct hash_algo *algo, void **ctxp) { sha512_context *ctx = malloc(sizeof(sha512_context)); @@ -125,7 +125,7 @@ static int hash_finish_sha384(struct hash_algo *algo, void *ctx, void } #endif
-#if defined(CONFIG_SHA512) +#if defined(CONFIG_SHA512) && !defined(CONFIG_SHA_PROG_HW_ACCEL) static int hash_init_sha512(struct hash_algo *algo, void **ctxp) { sha512_context *ctx = malloc(sizeof(sha512_context)); @@ -260,10 +260,20 @@ static struct hash_algo hash_algo[] = { .name = "sha384", .digest_size = SHA384_SUM_LEN, .chunk_size = CHUNKSZ_SHA384, +#ifdef CONFIG_SHA_HW_ACCEL + .hash_func_ws = hw_sha384, +#else .hash_func_ws = sha384_csum_wd, +#endif +#ifdef CONFIG_SHA_PROG_HW_ACCEL + .hash_init = hw_sha_init, + .hash_update = hw_sha_update, + .hash_finish = hw_sha_finish, +#else .hash_init = hash_init_sha384, .hash_update = hash_update_sha384, .hash_finish = hash_finish_sha384, +#endif }, #endif #ifdef CONFIG_SHA512 @@ -271,10 +281,20 @@ static struct hash_algo hash_algo[] = { .name = "sha512", .digest_size = SHA512_SUM_LEN, .chunk_size = CHUNKSZ_SHA512, +#ifdef CONFIG_SHA_HW_ACCEL + .hash_func_ws = hw_sha512, +#else .hash_func_ws = sha512_csum_wd, +#endif +#ifdef CONFIG_SHA_PROG_HW_ACCEL + .hash_init = hw_sha_init, + .hash_update = hw_sha_update, + .hash_finish = hw_sha_finish, +#else .hash_init = hash_init_sha512, .hash_update = hash_update_sha512, .hash_finish = hash_finish_sha512, +#endif }, #endif { diff --git a/include/hw_sha.h b/include/hw_sha.h index 15b1a1c79836..d4f3471c4308 100644 --- a/include/hw_sha.h +++ b/include/hw_sha.h @@ -8,6 +8,32 @@ #define __HW_SHA_H #include <hash.h>
+/** + * Computes hash value of input pbuf using h/w acceleration + * + * @param in_addr A pointer to the input buffer + * @param bufleni Byte length of input buffer + * @param out_addr A pointer to the output buffer. When complete + * 64 bytes are copied to pout[0]...pout[63]. Thus, a user + * should allocate at least 64 bytes at pOut in advance. + * @param chunk_size chunk size for sha512 + */ +void hw_sha512(const uchar *in_addr, uint buflen, uchar *out_addr, + uint chunk_size); + +/** + * Computes hash value of input pbuf using h/w acceleration + * + * @param in_addr A pointer to the input buffer + * @param bufleni Byte length of input buffer + * @param out_addr A pointer to the output buffer. When complete + * 48 bytes are copied to pout[0]...pout[47]. Thus, a user + * should allocate at least 48 bytes at pOut in advance. + * @param chunk_size chunk size for sha384 + */ +void hw_sha384(const uchar *in_addr, uint buflen, uchar *out_addr, + uint chunk_size); + /** * Computes hash value of input pbuf using h/w acceleration * diff --git a/lib/Kconfig b/lib/Kconfig index b35a71ac368b..0d753eedeced 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -389,19 +389,18 @@ config SHA384 config SHA_HW_ACCEL bool "Enable hashing using hardware" help - This option enables hardware acceleration - for SHA1/SHA256 hashing. - This affects the 'hash' command and also the - hash_lookup_algo() function. + This option enables hardware acceleration for SHA hashing. + This affects the 'hash' command and also the hash_lookup_algo() + function.
config SHA_PROG_HW_ACCEL bool "Enable Progressive hashing support using hardware" depends on SHA_HW_ACCEL help - This option enables hardware-acceleration for - SHA1/SHA256 progressive hashing. - Data can be streamed in a block at a time and the hashing - is performed in hardware. + This option enables hardware-acceleration for SHA progressive + hashing. + Data can be streamed in a block at a time and the hashing is + performed in hardware.
config MD5 bool "Support MD5 algorithm"
This merged patch leads to errors compiling the EFI TCG2 protocol on boards with CONFIG_SHA_HW_ACCEL.
There is not as single implementation of hw_sha384 and hw_sha512. You could only use CONFIG_SHA_HW_ACCEL for selecting these functions if these were implemented for *all* boards with CONFIG_SHA_HW_ACCEL=y. But this will never happen.
*This patch needs to be reverted.*
Why do we have CONFIG_SHA_HW_ACCEL at all and don't use weak functions instead?
Best regards
Heinrich
- Computes hash value of input pbuf using h/w acceleration
- @param in_addr A pointer to the input buffer
- @param bufleni Byte length of input buffer
- @param out_addr A pointer to the output buffer. When complete
- @param chunk_size chunk size for sha512
uint chunk_size);
- @param chunk_size chunk size for sha384
uint chunk_size);
function.
hashing.
Hi Heinrich,
This is all a mess. We should not use weak functions IMO, but instead have a driver interface, like we do with filesystems.
Part of the challenge is the need to keep code size small for platforms that only need one algorithm.
On 12.05.21 18:05, Simon Glass wrote:
Hi Heinrich,
If a function is not referenced, the linker will eliminate it. But with a driver interface every function in the interface is referenced.
Best regards
Heinrich
Hi Heinrich,
Best regards
Heinrich
There's a fundamental problem with TCG2. The algorithms you need to support and log are dictated by the TPM2 hardware and it's configuration. That's a thing we can't detect at build time.
So since we don't know that, we are requiring support for all the known algorithms U-Boot supports and are mandated from the spec (SHA1/256/384/512). One way to solve this is move the 'select' to 'depends', and only allow for the protocol, if all the algorithms we need are present in the .config. But this is just a way to sidestep the problem for now. I agree with Heinrich that using a single Kconfig isn't realistic.
Hi Heinrich,
Hi Heinrich,
Indeed, but we can still have an option for enabling the progressive interface. My point is that the implementation (software or hardware) should use a driver.
Heinrich
Am 12. Mai 2021 19:32:42 MESZ schrieb Simon Glass sjg@chromium.org:
Hi Heinrich,
Hi Heinrich,
hashing
on
You
if
functions
instead?
instead
with
Anyway that should not stop us from reverting a problematic patch. We can work on refactoring afterwards.
Best regards
Heinrich
Hi Heinrich,
Hi Heinrich,
Hi Heinrich,
hashing
on
You
if
functions
instead?
instead
with
Well the patch was applied because tests passed. We should be careful about reverting a patch due to problems it causes in the future.
On 5/13/21 4:36 PM, Simon Glass wrote:
Hi Heinrich,
Hi Heinrich,
Hi Heinrich,
On 17.02.21 04:20, Joel Stanley wrote: > Similar to support for SHA1 and SHA256, allow the use of hardware
hashing
> CONFIG_SHA_PROG_HW_ACCEL. > > Signed-off-by: Joel Stanley joel@jms.id.au
on
You
if
functions
instead?
instead
with
The code compiled because SHA384 and SHA512 were not used together with CONFIG_SHA_HW_ACCEL=y. But we need these functions to implement the TCG2 protocol on boards with TPMv2.
Gitlab CI had no issues with reverting the patch.
Best regards
Heinrich
Hi Heinrich,
Hi Heinrich,
Hi Heinrich,
Hi Heinrich,
> > On 17.02.21 04:20, Joel Stanley wrote: >> Similar to support for SHA1 and SHA256, allow the use of hardware
hashing
>> CONFIG_SHA_PROG_HW_ACCEL. >> >> Signed-off-by: Joel Stanley joel@jms.id.au > > This merged patch leads to errors compiling the EFI TCG2 protocol
on
> boards with CONFIG_SHA_HW_ACCEL. > > There is not as single implementation of hw_sha384 and hw_sha512.
You
if
> this will never happen. > > *This patch needs to be reverted.* > > Why do we have CONFIG_SHA_HW_ACCEL at all and don't use weak
functions
> instead?
instead
with
Let's fix it then. The patch makes all the hashing algorithms work the same, which seems right to me. If we come to converting this to a linker list, which we should, then it will be easier with this patch applied than not.
OK. It's up to Tom what he wants to do. But how about sending a patch to do what you want, instead?
Regards, SImon
Helli Simon,
Do you have any thoughts on this series?
Cheers,
Joel
-- 2.30.0
participants (6)
AKASHI Takahiro
Ilias Apalodimas
Joel Stanley
