[U-Boot] [PATCH 1/1 V3] cmd_bdinfo: move implementation to arch instead of common
introduce two new weak functions board_bdinfo and cpu_bdinfo to allow board and cpu to print more information
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com Cc: Haavard Skinnemoen haavard.skinnemoen@atmel.com Cc: Mike Frysinger vapier@gentoo.org --- rebase for-next Precedent version Ack-by: Mike Frysinger vapier@gentoo.org Ack-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com common/cmd_bdinfo.c | 455 ++++++++--------------------------------------- include/bdinfo.h | 48 +++++ lib_arm/Makefile | 1 + lib_arm/bdinfo.c | 53 ++++++ lib_avr32/Makefile | 1 + lib_avr32/bdinfo.c | 47 +++++ lib_blackfin/Makefile | 1 + lib_blackfin/bdinfo.c | 55 ++++++ lib_i386/Makefile | 1 + lib_i386/bdinfo.c | 47 +++++ lib_m68k/Makefile | 1 + lib_m68k/bdinfo.c | 75 ++++++++ lib_microblaze/Makefile | 1 + lib_microblaze/bdinfo.c | 51 ++++++ lib_mips/Makefile | 1 + lib_mips/bdinfo.c | 47 +++++ lib_nios/Makefile | 1 + lib_nios/bdinfo.c | 46 +++++ lib_nios2/Makefile | 1 + lib_nios2/bdinfo.c | 54 ++++++ lib_ppc/Makefile | 1 + lib_ppc/bdinfo.c | 107 +++++++++++ lib_sh/Makefile | 1 + lib_sh/bdinfo.c | 47 +++++ lib_sparc/Makefile | 13 +- lib_sparc/bdinfo.c | 61 +++++++ 26 files changed, 829 insertions(+), 388 deletions(-) rewrite common/cmd_bdinfo.c (88%) create mode 100644 include/bdinfo.h create mode 100644 lib_arm/bdinfo.c create mode 100644 lib_avr32/bdinfo.c create mode 100644 lib_blackfin/bdinfo.c create mode 100644 lib_i386/bdinfo.c create mode 100644 lib_m68k/bdinfo.c create mode 100644 lib_microblaze/bdinfo.c create mode 100644 lib_mips/bdinfo.c create mode 100644 lib_nios/bdinfo.c create mode 100644 lib_nios2/bdinfo.c create mode 100644 lib_ppc/bdinfo.c create mode 100644 lib_sh/bdinfo.c create mode 100644 lib_sparc/bdinfo.c
diff --git a/common/cmd_bdinfo.c b/common/cmd_bdinfo.c dissimilarity index 88% index 700314b..75e5e83 100644 --- a/common/cmd_bdinfo.c +++ b/common/cmd_bdinfo.c @@ -1,384 +1,71 @@ -/* - * (C) Copyright 2003 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -/* - * Boot support - */ -#include <common.h> -#include <command.h> - -DECLARE_GLOBAL_DATA_PTR; - -static void print_num(const char *, ulong); - -static void print_eth(int idx); - -#ifndef CONFIG_ARM /* PowerPC and other */ -static void print_lnum(const char *, u64); - -#ifdef CONFIG_PPC -static void print_str(const char *, const char *); - -int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) -{ - bd_t *bd = gd->bd; - char buf[32]; - -#ifdef DEBUG - print_num ("bd address", (ulong)bd ); -#endif - print_num ("memstart", bd->bi_memstart ); - print_lnum ("memsize", bd->bi_memsize ); - print_num ("flashstart", bd->bi_flashstart ); - print_num ("flashsize", bd->bi_flashsize ); - print_num ("flashoffset", bd->bi_flashoffset ); - print_num ("sramstart", bd->bi_sramstart ); - print_num ("sramsize", bd->bi_sramsize ); -#if defined(CONFIG_5xx) || defined(CONFIG_8xx) || \ - defined(CONFIG_8260) || defined(CONFIG_E500) - print_num ("immr_base", bd->bi_immr_base ); -#endif - print_num ("bootflags", bd->bi_bootflags ); -#if defined(CONFIG_405GP) || defined(CONFIG_405CR) || \ - defined(CONFIG_405EP) || defined(CONFIG_XILINX_405) || \ - defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ - defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ - defined(CONFIG_440SP) || defined(CONFIG_440SPE) - print_str ("procfreq", strmhz(buf, bd->bi_procfreq)); - print_str ("plb_busfreq", strmhz(buf, bd->bi_plb_busfreq)); -#if defined(CONFIG_405GP) || defined(CONFIG_405EP) || defined(CONFIG_XILINX_405) || \ - defined(CONFIG_440EP) || defined(CONFIG_440GR) || defined(CONFIG_440SPE) || \ - defined(CONFIG_440EPX) || defined(CONFIG_440GRX) - print_str ("pci_busfreq", strmhz(buf, bd->bi_pci_busfreq)); -#endif -#else /* ! CONFIG_405GP, CONFIG_405CR, CONFIG_405EP, CONFIG_XILINX_405, CONFIG_440EP CONFIG_440GR */ -#if defined(CONFIG_CPM2) - print_str ("vco", strmhz(buf, bd->bi_vco)); - print_str ("sccfreq", strmhz(buf, bd->bi_sccfreq)); - print_str ("brgfreq", strmhz(buf, bd->bi_brgfreq)); -#endif - print_str ("intfreq", strmhz(buf, bd->bi_intfreq)); -#if defined(CONFIG_CPM2) - print_str ("cpmfreq", strmhz(buf, bd->bi_cpmfreq)); -#endif - print_str ("busfreq", strmhz(buf, bd->bi_busfreq)); -#endif /* CONFIG_405GP, CONFIG_405CR, CONFIG_405EP, CONFIG_XILINX_405, CONFIG_440EP CONFIG_440GR */ -#if defined(CONFIG_MPC8220) - print_str ("inpfreq", strmhz(buf, bd->bi_inpfreq)); - print_str ("flbfreq", strmhz(buf, bd->bi_flbfreq)); - print_str ("pcifreq", strmhz(buf, bd->bi_pcifreq)); - print_str ("vcofreq", strmhz(buf, bd->bi_vcofreq)); - print_str ("pevfreq", strmhz(buf, bd->bi_pevfreq)); -#endif - - print_eth(0); -#if defined(CONFIG_HAS_ETH1) - print_eth(1); -#endif -#if defined(CONFIG_HAS_ETH2) - print_eth(2); -#endif -#if defined(CONFIG_HAS_ETH3) - print_eth(3); -#endif -#if defined(CONFIG_HAS_ETH4) - print_eth(4); -#endif -#if defined(CONFIG_HAS_ETH5) - print_eth(5); -#endif - -#ifdef CONFIG_HERMES - print_str ("ethspeed", strmhz(buf, bd->bi_ethspeed)); -#endif - printf ("IP addr = %pI4\n", &bd->bi_ip_addr); - printf ("baudrate = %6ld bps\n", bd->bi_baudrate ); - return 0; -} - -#elif defined(CONFIG_NIOS) /* NIOS*/ - -int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) -{ - bd_t *bd = gd->bd; - - print_num ("memstart", (ulong)bd->bi_memstart); - print_lnum ("memsize", (u64)bd->bi_memsize); - print_num ("flashstart", (ulong)bd->bi_flashstart); - print_num ("flashsize", (ulong)bd->bi_flashsize); - print_num ("flashoffset", (ulong)bd->bi_flashoffset); - - print_eth(0); - printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); - printf ("baudrate = %ld bps\n", bd->bi_baudrate); - - return 0; -} - -#elif defined(CONFIG_NIOS2) /* Nios-II */ - -int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) -{ - bd_t *bd = gd->bd; - - print_num ("mem start", (ulong)bd->bi_memstart); - print_lnum ("mem size", (u64)bd->bi_memsize); - print_num ("flash start", (ulong)bd->bi_flashstart); - print_num ("flash size", (ulong)bd->bi_flashsize); - print_num ("flash offset", (ulong)bd->bi_flashoffset); - -#if defined(CONFIG_SYS_SRAM_BASE) - print_num ("sram start", (ulong)bd->bi_sramstart); - print_num ("sram size", (ulong)bd->bi_sramsize); -#endif - -#if defined(CONFIG_CMD_NET) - print_eth(0); - printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); -#endif - - printf ("baudrate = %ld bps\n", bd->bi_baudrate); - - return 0; -} -#elif defined(CONFIG_MICROBLAZE) /* ! PPC, which leaves Microblaze */ - -int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) -{ - bd_t *bd = gd->bd; - print_num ("mem start ", (ulong)bd->bi_memstart); - print_lnum ("mem size ", (u64)bd->bi_memsize); - print_num ("flash start ", (ulong)bd->bi_flashstart); - print_num ("flash size ", (ulong)bd->bi_flashsize); - print_num ("flash offset ", (ulong)bd->bi_flashoffset); -#if defined(CONFIG_SYS_SRAM_BASE) - print_num ("sram start ", (ulong)bd->bi_sramstart); - print_num ("sram size ", (ulong)bd->bi_sramsize); -#endif -#if defined(CONFIG_CMD_NET) - print_eth(0); - printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); -#endif - printf ("baudrate = %ld bps\n", (ulong)bd->bi_baudrate); - return 0; -} - -#elif defined(CONFIG_SPARC) /* SPARC */ -int do_bdinfo(cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) -{ - bd_t *bd = gd->bd; - -#ifdef DEBUG - print_num("bd address ", (ulong) bd); -#endif - print_num("memstart ", bd->bi_memstart); - print_lnum("memsize ", bd->bi_memsize); - print_num("flashstart ", bd->bi_flashstart); - print_num("CONFIG_SYS_MONITOR_BASE ", CONFIG_SYS_MONITOR_BASE); - print_num("CONFIG_ENV_ADDR ", CONFIG_ENV_ADDR); - printf("CONFIG_SYS_RELOC_MONITOR_BASE = 0x%lx (%d)\n", CONFIG_SYS_RELOC_MONITOR_BASE, - CONFIG_SYS_MONITOR_LEN); - printf("CONFIG_SYS_MALLOC_BASE = 0x%lx (%d)\n", CONFIG_SYS_MALLOC_BASE, - CONFIG_SYS_MALLOC_LEN); - printf("CONFIG_SYS_INIT_SP_OFFSET = 0x%lx (%d)\n", CONFIG_SYS_INIT_SP_OFFSET, - CONFIG_SYS_STACK_SIZE); - printf("CONFIG_SYS_PROM_OFFSET = 0x%lx (%d)\n", CONFIG_SYS_PROM_OFFSET, - CONFIG_SYS_PROM_SIZE); - printf("CONFIG_SYS_GBL_DATA_OFFSET = 0x%lx (%d)\n", CONFIG_SYS_GBL_DATA_OFFSET, - CONFIG_SYS_GBL_DATA_SIZE); - -#if defined(CONFIG_CMD_NET) - print_eth(0); - printf("ip_addr = %pI4\n", &bd->bi_ip_addr); -#endif - printf("baudrate = %6ld bps\n", bd->bi_baudrate); - return 0; -} - -#elif defined(CONFIG_M68K) /* M68K */ -static void print_str(const char *, const char *); - -int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) -{ - bd_t *bd = gd->bd; - char buf[32]; - - print_num ("memstart", (ulong)bd->bi_memstart); - print_lnum ("memsize", (u64)bd->bi_memsize); - print_num ("flashstart", (ulong)bd->bi_flashstart); - print_num ("flashsize", (ulong)bd->bi_flashsize); - print_num ("flashoffset", (ulong)bd->bi_flashoffset); -#if defined(CONFIG_SYS_INIT_RAM_ADDR) - print_num ("sramstart", (ulong)bd->bi_sramstart); - print_num ("sramsize", (ulong)bd->bi_sramsize); -#endif -#if defined(CONFIG_SYS_MBAR) - print_num ("mbar", bd->bi_mbar_base); -#endif - print_str ("cpufreq", strmhz(buf, bd->bi_intfreq)); - print_str ("busfreq", strmhz(buf, bd->bi_busfreq)); -#ifdef CONFIG_PCI - print_str ("pcifreq", strmhz(buf, bd->bi_pcifreq)); -#endif -#ifdef CONFIG_EXTRA_CLOCK - print_str ("flbfreq", strmhz(buf, bd->bi_flbfreq)); - print_str ("inpfreq", strmhz(buf, bd->bi_inpfreq)); - print_str ("vcofreq", strmhz(buf, bd->bi_vcofreq)); -#endif -#if defined(CONFIG_CMD_NET) - print_eth(0); -#if defined(CONFIG_HAS_ETH1) - print_eth(1); -#endif -#if defined(CONFIG_HAS_ETH2) - print_eth(2); -#endif -#if defined(CONFIG_HAS_ETH3) - print_eth(3); -#endif - - printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); -#endif - printf ("baudrate = %ld bps\n", bd->bi_baudrate); - - return 0; -} - -#elif defined(CONFIG_BLACKFIN) -static void print_str(const char *, const char *); - -int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) -{ - bd_t *bd = gd->bd; - char buf[32]; - - printf("U-Boot = %s\n", bd->bi_r_version); - printf("CPU = %s\n", bd->bi_cpu); - printf("Board = %s\n", bd->bi_board_name); - print_str("VCO", strmhz(buf, bd->bi_vco)); - print_str("CCLK", strmhz(buf, bd->bi_cclk)); - print_str("SCLK", strmhz(buf, bd->bi_sclk)); - - print_num("boot_params", (ulong)bd->bi_boot_params); - print_num("memstart", (ulong)bd->bi_memstart); - print_lnum("memsize", (u64)bd->bi_memsize); - print_num("flashstart", (ulong)bd->bi_flashstart); - print_num("flashsize", (ulong)bd->bi_flashsize); - print_num("flashoffset", (ulong)bd->bi_flashoffset); - - print_eth(0); - printf("ip_addr = %pI4\n", &bd->bi_ip_addr); - printf("baudrate = %d bps\n", bd->bi_baudrate); - - return 0; -} - -#else /* ! PPC, which leaves MIPS */ - -int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) -{ - bd_t *bd = gd->bd; - - print_num ("boot_params", (ulong)bd->bi_boot_params); - print_num ("memstart", (ulong)bd->bi_memstart); - print_lnum ("memsize", (u64)bd->bi_memsize); - print_num ("flashstart", (ulong)bd->bi_flashstart); - print_num ("flashsize", (ulong)bd->bi_flashsize); - print_num ("flashoffset", (ulong)bd->bi_flashoffset); - - print_eth(0); - printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); - printf ("baudrate = %d bps\n", bd->bi_baudrate); - - return 0; -} -#endif /* MIPS */ - -#else /* ARM */ - -int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) -{ - int i; - bd_t *bd = gd->bd; - - print_num ("arch_number", bd->bi_arch_number); - print_num ("env_t", (ulong)bd->bi_env); - print_num ("boot_params", (ulong)bd->bi_boot_params); - - for (i=0; i<CONFIG_NR_DRAM_BANKS; ++i) { - print_num("DRAM bank", i); - print_num("-> start", bd->bi_dram[i].start); - print_num("-> size", bd->bi_dram[i].size); - } - -#if defined(CONFIG_CMD_NET) - print_eth(0); - printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); -#endif - printf ("baudrate = %d bps\n", bd->bi_baudrate); - - return 0; -} - -#endif /* CONFIG_ARM XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX */ - -static void print_num(const char *name, ulong value) -{ - printf ("%-12s= 0x%08lX\n", name, value); -} - -static void print_eth(int idx) -{ - char name[10], *val; - if (idx) - sprintf(name, "eth%iaddr", idx); - else - strcpy(name, "ethaddr"); - val = getenv(name); - if (!val) - val = "(not set)"; - printf("%-12s= %s\n", name, val); -} - -#ifndef CONFIG_ARM -static void print_lnum(const char *name, u64 value) -{ - printf ("%-12s= 0x%.8llX\n", name, value); -} -#endif - -#if defined(CONFIG_PPC) || defined(CONFIG_M68K) || defined(CONFIG_BLACKFIN) -static void print_str(const char *name, const char *str) -{ - printf ("%-12s= %6s MHz\n", name, str); -} -#endif /* CONFIG_PPC */ - - -/* -------------------------------------------------------------------- */ - -U_BOOT_CMD( - bdinfo, 1, 1, do_bdinfo, - "print Board Info structure", - NULL -); +/* + * (C) Copyright 2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Boot support + */ +#include <common.h> +#include <command.h> +#include <bdinfo.h> + +void board_bdinfo(cmd_tbl_t *, int, int, char **) __attribute__((weak)); +void cpu_bdinfo(cmd_tbl_t *, int, int, char **) __attribute__((weak)); + +int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + /* call arch bdinfo */ + arch_bdinfo(cmdtp, flag, argc, argv); + + /* call soc bdinfo */ + if(cpu_bdinfo) { + printf("CPU Info\n"); + cpu_bdinfo(cmdtp, flag, argc, argv); + } + + /* call board bdinfo */ + if(board_bdinfo) { + printf("Board Info\n"); + board_bdinfo(cmdtp, flag, argc, argv); + } + + return 0; +} + +void print_eth(int idx) +{ + char name[10], *val; + if (idx) + sprintf(name, "eth%iaddr", idx); + else + strcpy(name, "ethaddr"); + val = getenv(name); + if (!val) + val = "(not set)"; + printf("%-12s= %s\n", name, val); +} + +U_BOOT_CMD( + bdinfo, 1, 1, do_bdinfo, + "print Board Info structure", + NULL +); diff --git a/include/bdinfo.h b/include/bdinfo.h new file mode 100644 index 0000000..5d56bec --- /dev/null +++ b/include/bdinfo.h @@ -0,0 +1,48 @@ +/* + * (C) Copyright 2008 + * Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _BDINFO_H_ +#define _BDINFO_H_ + +void arch_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char **argv); +void board_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char **argv); +void cpu_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char **argv); + +static inline void print_num(const char *name, ulong value) +{ + printf ("%-12s= 0x%08lX\n", name, value); +} + +static inline void print_lnum(const char *name, u64 value) +{ + printf ("%-12s= 0x%.8llX\n", name, value); +} + +static inline void print_str(const char *name, const char *str) +{ + printf ("%-12s= %6s MHz\n", name, str); +} + +void print_eth(int idx); + +#endif /* _BDINFO_H_ */ diff --git a/lib_arm/Makefile b/lib_arm/Makefile index c8795b2..3ca7c74 100644 --- a/lib_arm/Makefile +++ b/lib_arm/Makefile @@ -32,6 +32,7 @@ SOBJS-y += _modsi3.o SOBJS-y += _udivsi3.o SOBJS-y += _umodsi3.o
+COBJS-$(CONFIG_CMD_BDI) += bdinfo.o COBJS-y += board.o COBJS-y += bootm.o COBJS-y += cache.o diff --git a/lib_arm/bdinfo.c b/lib_arm/bdinfo.c new file mode 100644 index 0000000..0e5084b --- /dev/null +++ b/lib_arm/bdinfo.c @@ -0,0 +1,53 @@ +/* + * (C) Copyright 2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Boot support + */ +#include <common.h> +#include <command.h> +#include <bdinfo.h> + +DECLARE_GLOBAL_DATA_PTR; + +void arch_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + int i; + bd_t *bd = gd->bd; + + print_num ("arch_number", bd->bi_arch_number); + print_num ("env_t", (ulong)bd->bi_env); + print_num ("boot_params", (ulong)bd->bi_boot_params); + + for (i = 0; i < CONFIG_NR_DRAM_BANKS; ++i) { + print_num("DRAM bank", i); + print_num("-> start", bd->bi_dram[i].start); + print_num("-> size", bd->bi_dram[i].size); + } + +#if defined(CONFIG_CMD_NET) + print_eth(0); + printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); +#endif + printf ("baudrate = %d bps\n", bd->bi_baudrate); +} diff --git a/lib_avr32/Makefile b/lib_avr32/Makefile index 37b8051..b014721 100644 --- a/lib_avr32/Makefile +++ b/lib_avr32/Makefile @@ -29,6 +29,7 @@ LIB = $(obj)lib$(ARCH).a
SOBJS-y += memset.o
+COBJS-$(CONFIG_CMD_BDI) += bdinfo.o COBJS-y += board.o COBJS-y += bootm.o COBJS-y += interrupts.o diff --git a/lib_avr32/bdinfo.c b/lib_avr32/bdinfo.c new file mode 100644 index 0000000..616481d --- /dev/null +++ b/lib_avr32/bdinfo.c @@ -0,0 +1,47 @@ +/* + * (C) Copyright 2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Boot support + */ +#include <common.h> +#include <command.h> +#include <bdinfo.h> + +DECLARE_GLOBAL_DATA_PTR; + +void arch_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + bd_t *bd = gd->bd; + + print_num ("boot_params", (ulong)bd->bi_boot_params); + print_num ("memstart", (ulong)bd->bi_memstart); + print_lnum ("memsize", (u64)bd->bi_memsize); + print_num ("flashstart", (ulong)bd->bi_flashstart); + print_num ("flashsize", (ulong)bd->bi_flashsize); + print_num ("flashoffset", (ulong)bd->bi_flashoffset); + + print_eth(0); + printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); + printf ("baudrate = %d bps\n", bd->bi_baudrate); +} diff --git a/lib_blackfin/Makefile b/lib_blackfin/Makefile index 46ef7f3..44b9660 100644 --- a/lib_blackfin/Makefile +++ b/lib_blackfin/Makefile @@ -36,6 +36,7 @@ SOBJS-y += memcpy.o SOBJS-y += memmove.o SOBJS-y += memset.o
+COBJS-$(CONFIG_CMD_BDI) += bdinfo.o COBJS-y += board.o COBJS-y += boot.o COBJS-y += cache.o diff --git a/lib_blackfin/bdinfo.c b/lib_blackfin/bdinfo.c new file mode 100644 index 0000000..1b1aaa5 --- /dev/null +++ b/lib_blackfin/bdinfo.c @@ -0,0 +1,55 @@ +/* + * (C) Copyright 2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Boot support + */ +#include <common.h> +#include <command.h> +#include <bdinfo.h> + +DECLARE_GLOBAL_DATA_PTR; + +void arch_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + bd_t *bd = gd->bd; + char buf[32]; + + printf("U-Boot = %s\n", bd->bi_r_version); + printf("CPU = %s\n", bd->bi_cpu); + printf("Board = %s\n", bd->bi_board_name); + print_str("VCO", strmhz(buf, bd->bi_vco)); + print_str("CCLK", strmhz(buf, bd->bi_cclk)); + print_str("SCLK", strmhz(buf, bd->bi_sclk)); + + print_num("boot_params", (ulong)bd->bi_boot_params); + print_num("memstart", (ulong)bd->bi_memstart); + print_lnum("memsize", (u64)bd->bi_memsize); + print_num("flashstart", (ulong)bd->bi_flashstart); + print_num("flashsize", (ulong)bd->bi_flashsize); + print_num("flashoffset", (ulong)bd->bi_flashoffset); + + print_eth(0); + printf("ip_addr = %pI4\n", &bd->bi_ip_addr); + printf("baudrate = %d bps\n", bd->bi_baudrate); +} diff --git a/lib_i386/Makefile b/lib_i386/Makefile index 4fbcd08..7ed130e 100644 --- a/lib_i386/Makefile +++ b/lib_i386/Makefile @@ -29,6 +29,7 @@ SOBJS-y += bios.o SOBJS-y += bios_pci.o SOBJS-y += realmode_switch.o
+COBJS-$(CONFIG_CMD_BDI) += bdinfo.o COBJS-y += bios_setup.o COBJS-y += board.o COBJS-y += bootm.o diff --git a/lib_i386/bdinfo.c b/lib_i386/bdinfo.c new file mode 100644 index 0000000..616481d --- /dev/null +++ b/lib_i386/bdinfo.c @@ -0,0 +1,47 @@ +/* + * (C) Copyright 2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Boot support + */ +#include <common.h> +#include <command.h> +#include <bdinfo.h> + +DECLARE_GLOBAL_DATA_PTR; + +void arch_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + bd_t *bd = gd->bd; + + print_num ("boot_params", (ulong)bd->bi_boot_params); + print_num ("memstart", (ulong)bd->bi_memstart); + print_lnum ("memsize", (u64)bd->bi_memsize); + print_num ("flashstart", (ulong)bd->bi_flashstart); + print_num ("flashsize", (ulong)bd->bi_flashsize); + print_num ("flashoffset", (ulong)bd->bi_flashoffset); + + print_eth(0); + printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); + printf ("baudrate = %d bps\n", bd->bi_baudrate); +} diff --git a/lib_m68k/Makefile b/lib_m68k/Makefile index 6db35ed..d261d7e 100644 --- a/lib_m68k/Makefile +++ b/lib_m68k/Makefile @@ -27,6 +27,7 @@ LIB = $(obj)lib$(ARCH).a
SOBJS-y +=
+COBJS-$(CONFIG_CMD_BDI) += bdinfo.o COBJS-y += board.o COBJS-y += bootm.o COBJS-y += cache.o diff --git a/lib_m68k/bdinfo.c b/lib_m68k/bdinfo.c new file mode 100644 index 0000000..e77a1cf --- /dev/null +++ b/lib_m68k/bdinfo.c @@ -0,0 +1,75 @@ +/* + * (C) Copyright 2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Boot support + */ +#include <common.h> +#include <command.h> +#include <bdinfo.h> + +DECLARE_GLOBAL_DATA_PTR; + +void arch_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + bd_t *bd = gd->bd; + char buf[32]; + + print_num ("memstart", (ulong)bd->bi_memstart); + print_lnum ("memsize", (u64)bd->bi_memsize); + print_num ("flashstart", (ulong)bd->bi_flashstart); + print_num ("flashsize", (ulong)bd->bi_flashsize); + print_num ("flashoffset", (ulong)bd->bi_flashoffset); +#if defined(CONFIG_SYS_INIT_RAM_ADDR) + print_num ("sramstart", (ulong)bd->bi_sramstart); + print_num ("sramsize", (ulong)bd->bi_sramsize); +#endif +#if defined(CONFIG_SYS_MBAR) + print_num ("mbar", bd->bi_mbar_base); +#endif + print_str ("cpufreq", strmhz(buf, bd->bi_intfreq)); + print_str ("busfreq", strmhz(buf, bd->bi_busfreq)); +#ifdef CONFIG_PCI + print_str ("pcifreq", strmhz(buf, bd->bi_pcifreq)); +#endif +#ifdef CONFIG_EXTRA_CLOCK + print_str ("flbfreq", strmhz(buf, bd->bi_flbfreq)); + print_str ("inpfreq", strmhz(buf, bd->bi_inpfreq)); + print_str ("vcofreq", strmhz(buf, bd->bi_vcofreq)); +#endif +#if defined(CONFIG_CMD_NET) + print_eth(0); +#if defined(CONFIG_HAS_ETH1) + print_eth(1); +#endif +#if defined(CONFIG_HAS_ETH2) + print_eth(2); +#endif +#if defined(CONFIG_HAS_ETH3) + print_eth(3); +#endif + + printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); +#endif + printf ("baudrate = %ld bps\n", bd->bi_baudrate); +} diff --git a/lib_microblaze/Makefile b/lib_microblaze/Makefile index 9b0f296..821d1cf 100644 --- a/lib_microblaze/Makefile +++ b/lib_microblaze/Makefile @@ -27,6 +27,7 @@ LIB = $(obj)lib$(ARCH).a
SOBJS-y +=
+COBJS-$(CONFIG_CMD_BDI) += bdinfo.o COBJS-y += board.o COBJS-y += bootm.o COBJS-y += cache.o diff --git a/lib_microblaze/bdinfo.c b/lib_microblaze/bdinfo.c new file mode 100644 index 0000000..eba2f4d --- /dev/null +++ b/lib_microblaze/bdinfo.c @@ -0,0 +1,51 @@ +/* + * (C) Copyright 2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Boot support + */ +#include <common.h> +#include <command.h> +#include <bdinfo.h> + +DECLARE_GLOBAL_DATA_PTR; + +void arch_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + bd_t *bd = gd->bd; + + print_num ("mem start ", (ulong)bd->bi_memstart); + print_lnum ("mem size ", (u64)bd->bi_memsize); + print_num ("flash start ", (ulong)bd->bi_flashstart); + print_num ("flash size ", (ulong)bd->bi_flashsize); + print_num ("flash offset ", (ulong)bd->bi_flashoffset); +#if defined(CONFIG_SYS_SRAM_BASE) + print_num ("sram start ", (ulong)bd->bi_sramstart); + print_num ("sram size ", (ulong)bd->bi_sramsize); +#endif +#if defined(CONFIG_CMD_NET) + print_eth(0); + printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); +#endif + printf ("baudrate = %ld bps\n", (ulong)bd->bi_baudrate); +} diff --git a/lib_mips/Makefile b/lib_mips/Makefile index 7967e58..a42219c 100644 --- a/lib_mips/Makefile +++ b/lib_mips/Makefile @@ -27,6 +27,7 @@ LIB = $(obj)lib$(ARCH).a
SOBJS-y +=
+COBJS-$(CONFIG_CMD_BDI) += bdinfo.o COBJS-y += board.o ifeq ($(CONFIG_QEMU_MIPS),y) COBJS-y += bootm_qemu_mips.o diff --git a/lib_mips/bdinfo.c b/lib_mips/bdinfo.c new file mode 100644 index 0000000..616481d --- /dev/null +++ b/lib_mips/bdinfo.c @@ -0,0 +1,47 @@ +/* + * (C) Copyright 2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Boot support + */ +#include <common.h> +#include <command.h> +#include <bdinfo.h> + +DECLARE_GLOBAL_DATA_PTR; + +void arch_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + bd_t *bd = gd->bd; + + print_num ("boot_params", (ulong)bd->bi_boot_params); + print_num ("memstart", (ulong)bd->bi_memstart); + print_lnum ("memsize", (u64)bd->bi_memsize); + print_num ("flashstart", (ulong)bd->bi_flashstart); + print_num ("flashsize", (ulong)bd->bi_flashsize); + print_num ("flashoffset", (ulong)bd->bi_flashoffset); + + print_eth(0); + printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); + printf ("baudrate = %d bps\n", bd->bi_baudrate); +} diff --git a/lib_nios/Makefile b/lib_nios/Makefile index f66e989..f50605c 100644 --- a/lib_nios/Makefile +++ b/lib_nios/Makefile @@ -27,6 +27,7 @@ LIB = $(obj)lib$(ARCH).a
SOBJS-y +=
+COBJS-$(CONFIG_CMD_BDI) += bdinfo.o COBJS-y += board.o COBJS-y += bootm.o COBJS-y += cache.o diff --git a/lib_nios/bdinfo.c b/lib_nios/bdinfo.c new file mode 100644 index 0000000..6e42c24 --- /dev/null +++ b/lib_nios/bdinfo.c @@ -0,0 +1,46 @@ +/* + * (C) Copyright 2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Boot support + */ +#include <common.h> +#include <command.h> +#include <bdinfo.h> + +DECLARE_GLOBAL_DATA_PTR; + +void arch_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + bd_t *bd = gd->bd; + + print_num ("memstart", (ulong)bd->bi_memstart); + print_lnum ("memsize", (u64)bd->bi_memsize); + print_num ("flashstart", (ulong)bd->bi_flashstart); + print_num ("flashsize", (ulong)bd->bi_flashsize); + print_num ("flashoffset", (ulong)bd->bi_flashoffset); + + print_eth(0); + printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); + printf ("baudrate = %ld bps\n", bd->bi_baudrate); +} diff --git a/lib_nios2/Makefile b/lib_nios2/Makefile index b69bc38..f5a7bbe 100644 --- a/lib_nios2/Makefile +++ b/lib_nios2/Makefile @@ -27,6 +27,7 @@ LIB = $(obj)lib$(ARCH).a
SOBJS-y += cache.o
+COBJS-$(CONFIG_CMD_BDI) += bdinfo.o COBJS-y += board.o COBJS-y += bootm.o COBJS-y += divmod.o diff --git a/lib_nios2/bdinfo.c b/lib_nios2/bdinfo.c new file mode 100644 index 0000000..5b39fb1 --- /dev/null +++ b/lib_nios2/bdinfo.c @@ -0,0 +1,54 @@ +/* + * (C) Copyright 2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Boot support + */ +#include <common.h> +#include <command.h> +#include <bdinfo.h> + +DECLARE_GLOBAL_DATA_PTR; + +void arch_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + bd_t *bd = gd->bd; + + print_num ("mem start", (ulong)bd->bi_memstart); + print_lnum ("mem size", (u64)bd->bi_memsize); + print_num ("flash start", (ulong)bd->bi_flashstart); + print_num ("flash size", (ulong)bd->bi_flashsize); + print_num ("flash offset", (ulong)bd->bi_flashoffset); + +#if defined(CONFIG_SYS_SRAM_BASE) + print_num ("sram start", (ulong)bd->bi_sramstart); + print_num ("sram size", (ulong)bd->bi_sramsize); +#endif + +#if defined(CONFIG_CMD_NET) + print_eth(0); + printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); +#endif + + printf ("baudrate = %ld bps\n", bd->bi_baudrate); +} diff --git a/lib_ppc/Makefile b/lib_ppc/Makefile index 60ea0c9..865cfc0 100644 --- a/lib_ppc/Makefile +++ b/lib_ppc/Makefile @@ -30,6 +30,7 @@ SOBJS-y += ppcstring.o SOBJS-y += ticks.o
COBJS-y += bat_rw.o +COBJS-$(CONFIG_CMD_BDI) += bdinfo.o COBJS-y += board.o COBJS-y += bootm.o COBJS-y += cache.o diff --git a/lib_ppc/bdinfo.c b/lib_ppc/bdinfo.c new file mode 100644 index 0000000..5aad37c --- /dev/null +++ b/lib_ppc/bdinfo.c @@ -0,0 +1,107 @@ +/* + * (C) Copyright 2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Boot support + */ +#include <common.h> +#include <command.h> +#include <bdinfo.h> + +DECLARE_GLOBAL_DATA_PTR; + +void arch_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + bd_t *bd = gd->bd; + char buf[32]; + +#ifdef DEBUG + print_num ("bd address", (ulong)bd ); +#endif + print_num ("memstart", bd->bi_memstart ); + print_lnum ("memsize", bd->bi_memsize ); + print_num ("flashstart", bd->bi_flashstart ); + print_num ("flashsize", bd->bi_flashsize ); + print_num ("flashoffset", bd->bi_flashoffset ); + print_num ("sramstart", bd->bi_sramstart ); + print_num ("sramsize", bd->bi_sramsize ); +#if defined(CONFIG_5xx) || defined(CONFIG_8xx) || \ + defined(CONFIG_8260) || defined(CONFIG_E500) + print_num ("immr_base", bd->bi_immr_base ); +#endif + print_num ("bootflags", bd->bi_bootflags ); +#if defined(CONFIG_405GP) || defined(CONFIG_405CR) || \ + defined(CONFIG_405EP) || defined(CONFIG_XILINX_405) || \ + defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ + defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_440SP) || defined(CONFIG_440SPE) + print_str ("procfreq", strmhz(buf, bd->bi_procfreq)); + print_str ("plb_busfreq", strmhz(buf, bd->bi_plb_busfreq)); +#if defined(CONFIG_405GP) || defined(CONFIG_405EP) || defined(CONFIG_XILINX_405) || \ + defined(CONFIG_440EP) || defined(CONFIG_440GR) || defined(CONFIG_440SPE) || \ + defined(CONFIG_440EPX) || defined(CONFIG_440GRX) + print_str ("pci_busfreq", strmhz(buf, bd->bi_pci_busfreq)); +#endif +#else /* ! CONFIG_405GP, CONFIG_405CR, CONFIG_405EP, CONFIG_XILINX_405, CONFIG_440EP CONFIG_440GR */ +#if defined(CONFIG_CPM2) + print_str ("vco", strmhz(buf, bd->bi_vco)); + print_str ("sccfreq", strmhz(buf, bd->bi_sccfreq)); + print_str ("brgfreq", strmhz(buf, bd->bi_brgfreq)); +#endif + print_str ("intfreq", strmhz(buf, bd->bi_intfreq)); +#if defined(CONFIG_CPM2) + print_str ("cpmfreq", strmhz(buf, bd->bi_cpmfreq)); +#endif + print_str ("busfreq", strmhz(buf, bd->bi_busfreq)); +#endif /* CONFIG_405GP, CONFIG_405CR, CONFIG_405EP, CONFIG_XILINX_405, CONFIG_440EP CONFIG_440GR */ +#if defined(CONFIG_MPC8220) + print_str ("inpfreq", strmhz(buf, bd->bi_inpfreq)); + print_str ("flbfreq", strmhz(buf, bd->bi_flbfreq)); + print_str ("pcifreq", strmhz(buf, bd->bi_pcifreq)); + print_str ("vcofreq", strmhz(buf, bd->bi_vcofreq)); + print_str ("pevfreq", strmhz(buf, bd->bi_pevfreq)); +#endif + + print_eth(0); +#if defined(CONFIG_HAS_ETH1) + print_eth(1); +#endif +#if defined(CONFIG_HAS_ETH2) + print_eth(2); +#endif +#if defined(CONFIG_HAS_ETH3) + print_eth(3); +#endif +#if defined(CONFIG_HAS_ETH4) + print_eth(4); +#endif +#if defined(CONFIG_HAS_ETH5) + print_eth(5); +#endif + +#ifdef CONFIG_HERMES + print_str ("ethspeed", strmhz(buf, bd->bi_ethspeed)); +#endif + printf ("IP addr = %pI4\n", &bd->bi_ip_addr); + printf ("baudrate = %6ld bps\n", bd->bi_baudrate ); +} diff --git a/lib_sh/Makefile b/lib_sh/Makefile index f7c6479..e7ff16d 100644 --- a/lib_sh/Makefile +++ b/lib_sh/Makefile @@ -24,6 +24,7 @@ LIB = $(obj)lib$(ARCH).a
SOBJS-y +=
+COBJS-$(CONFIG_CMD_BDI) += bdinfo.o COBJS-y += board.o COBJS-y += bootm.o ifeq ($(CONFIG_SH2),y) diff --git a/lib_sh/bdinfo.c b/lib_sh/bdinfo.c new file mode 100644 index 0000000..616481d --- /dev/null +++ b/lib_sh/bdinfo.c @@ -0,0 +1,47 @@ +/* + * (C) Copyright 2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Boot support + */ +#include <common.h> +#include <command.h> +#include <bdinfo.h> + +DECLARE_GLOBAL_DATA_PTR; + +void arch_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + bd_t *bd = gd->bd; + + print_num ("boot_params", (ulong)bd->bi_boot_params); + print_num ("memstart", (ulong)bd->bi_memstart); + print_lnum ("memsize", (u64)bd->bi_memsize); + print_num ("flashstart", (ulong)bd->bi_flashstart); + print_num ("flashsize", (ulong)bd->bi_flashsize); + print_num ("flashoffset", (ulong)bd->bi_flashoffset); + + print_eth(0); + printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); + printf ("baudrate = %d bps\n", bd->bi_baudrate); +} diff --git a/lib_sparc/Makefile b/lib_sparc/Makefile index 040ca10..0952bd9 100644 --- a/lib_sparc/Makefile +++ b/lib_sparc/Makefile @@ -25,12 +25,17 @@ include $(TOPDIR)/config.mk
-SOBJS = +SOBJS-y +=
-COBJS = board.o cache.o interrupts.o time.o bootm.o +COBJS-$(CONFIG_CMD_BDI) += bdinfo.o +COBJS-y += board.o +COBJS-y += cache.o +COBJS-y += interrupts.o +COBJS-y += time.o +COBJS-y += bootm.o
-SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) +SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y))
$(LIB): $(obj).depend $(OBJS) $(AR) $(ARFLAGS) $@ $(OBJS) diff --git a/lib_sparc/bdinfo.c b/lib_sparc/bdinfo.c new file mode 100644 index 0000000..fdd4d11 --- /dev/null +++ b/lib_sparc/bdinfo.c @@ -0,0 +1,61 @@ +/* + * (C) Copyright 2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Boot support + */ +#include <common.h> +#include <command.h> +#include <bdinfo.h> + +DECLARE_GLOBAL_DATA_PTR; + +void arch_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + bd_t *bd = gd->bd; + +#ifdef DEBUG + print_num("bd address ", (ulong) bd); +#endif + print_num("memstart ", bd->bi_memstart); + print_lnum("memsize ", bd->bi_memsize); + print_num("flashstart ", bd->bi_flashstart); + print_num("CONFIG_SYS_MONITOR_BASE ", CONFIG_SYS_MONITOR_BASE); + print_num("CONFIG_ENV_ADDR ", CONFIG_ENV_ADDR); + printf("CONFIG_SYS_RELOC_MONITOR_BASE = 0x%lx (%d)\n", CONFIG_SYS_RELOC_MONITOR_BASE, + CONFIG_SYS_MONITOR_LEN); + printf("CONFIG_SYS_MALLOC_BASE = 0x%lx (%d)\n", CONFIG_SYS_MALLOC_BASE, + CONFIG_SYS_MALLOC_LEN); + printf("CONFIG_SYS_INIT_SP_OFFSET = 0x%lx (%d)\n", CONFIG_SYS_INIT_SP_OFFSET, + CONFIG_SYS_STACK_SIZE); + printf("CONFIG_SYS_PROM_OFFSET = 0x%lx (%d)\n", CONFIG_SYS_PROM_OFFSET, + CONFIG_SYS_PROM_SIZE); + printf("CONFIG_SYS_GBL_DATA_OFFSET = 0x%lx (%d)\n", CONFIG_SYS_GBL_DATA_OFFSET, + CONFIG_SYS_GBL_DATA_SIZE); + +#if defined(CONFIG_CMD_NET) + print_eth(0); + printf("ip_addr = %pI4\n", &bd->bi_ip_addr); +#endif + printf("baudrate = %6ld bps\n", bd->bi_baudrate); +}
Hi
Two minor code style comments.
2009/2/21 Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com:
- (C) Copyright 2003
- Wolfgang Denk, DENX Software Engineering, wd@denx.de.
- project.
- MA 02111-1307 USA
- Boot support
bd_t *bd = gd->bd;
char buf[32];
-#ifdef DEBUG
-#endif
-#endif
-#endif
-#endif
-#endif
print_eth(0);
print_eth(1);
print_eth(2);
print_eth(3);
print_eth(4);
print_eth(5);
-#endif
-#endif
bd_t *bd = gd->bd;
print_eth(0);
bd_t *bd = gd->bd;
-#endif
print_eth(0);
-#endif
bd_t *bd = gd->bd;
print_eth(0);
-#endif
bd_t *bd = gd->bd;
-#ifdef DEBUG
-#endif
print_eth(0);
-#endif
bd_t *bd = gd->bd;
char buf[32];
-#endif
-#ifdef CONFIG_PCI
print_eth(0);
print_eth(1);
print_eth(2);
print_eth(3);
-#endif
-#endif
bd_t *bd = gd->bd;
char buf[32];
print_eth(0);
bd_t *bd = gd->bd;
print_eth(0);
-#else /* ARM */
int i;
bd_t *bd = gd->bd;
print_eth(0);
-#endif
if (idx)
else
val = getenv(name);
if (!val)
val = "(not set)";
-} -#endif
-U_BOOT_CMD(
NULL
- project.
- MA 02111-1307 USA
- Boot support
if(cpu_bdinfo) {
Space after if.
if(board_bdinfo) {
Space after if.
Regards, Magnus
you dont need to quote everything up to the point where you actually comment. snipping unrelated context you arent talking about makes reading replies a lot easier. otherwise, we need to scroll over ~15 pages just to figure out what you added ... -mike
On Saturday 21 February 2009 03:46:20 Jean-Christophe PLAGNIOL-VILLARD wrote:
--- a/common/cmd_bdinfo.c +++ b/common/cmd_bdinfo.c +void board_bdinfo(cmd_tbl_t *, int, int, char **) __attribute__((weak)); +void cpu_bdinfo(cmd_tbl_t *, int, int, char **) __attribute__((weak));
since other people are expected to implement these functions, better to put the prototype into a common header so that the implementation and the caller agree on the function signature. the compiler can check this way.
- /* call arch bdinfo */
- arch_bdinfo(cmdtp, flag, argc, argv);
- /* call soc bdinfo */
- if(cpu_bdinfo) {
- /* call board bdinfo */
- if(board_bdinfo) {
there should be a space after that "if". i would use "puts" instead of "printf" since you arent using any format strings.
otherwise, the Blackfin part looks fine, thanks Acked-by: Mike Frysinger vapier@gentoo.org -mike
done in the bdinfo.h but IIRC we specify it's weak here not in the header
- if(cpu_bdinfo) {
ok
Best Regards, J.
Aren't the Acked-by lines supposed to go above the '---' line?
Haavard
yes, and they replace the CC: lines -mike
due to a lost of change on this part I've just put you two on Cc
but If you are ok I've put your Ack-by
Best Regards, J.
introduce 3 new weak functions board_bdinfo, cpu_bdinfo and soc_bdinfo to allow board, cpu and soc to print more information
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com Acked-by: Mike Frysinger vapier@gentoo.org Ack-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com --- Change from V3 SOC weak function and Mike Suggestion
Best Regards, J. common/cmd_bdinfo.c | 462 ++++++++--------------------------------------- include/bdinfo.h | 49 +++++ lib_arm/Makefile | 1 + lib_arm/bdinfo.c | 53 ++++++ lib_avr32/Makefile | 1 + lib_avr32/bdinfo.c | 47 +++++ lib_blackfin/Makefile | 1 + lib_blackfin/bdinfo.c | 55 ++++++ lib_i386/Makefile | 1 + lib_i386/bdinfo.c | 47 +++++ lib_m68k/Makefile | 1 + lib_m68k/bdinfo.c | 75 ++++++++ lib_microblaze/Makefile | 1 + lib_microblaze/bdinfo.c | 51 +++++ lib_mips/Makefile | 1 + lib_mips/bdinfo.c | 47 +++++ lib_nios/Makefile | 1 + lib_nios/bdinfo.c | 46 +++++ lib_nios2/Makefile | 1 + lib_nios2/bdinfo.c | 54 ++++++ lib_ppc/Makefile | 1 + lib_ppc/bdinfo.c | 107 +++++++++++ lib_sh/Makefile | 1 + lib_sh/bdinfo.c | 47 +++++ lib_sparc/Makefile | 13 +- lib_sparc/bdinfo.c | 61 ++++++ 26 files changed, 837 insertions(+), 388 deletions(-) rewrite common/cmd_bdinfo.c (88%) create mode 100644 include/bdinfo.h create mode 100644 lib_arm/bdinfo.c create mode 100644 lib_avr32/bdinfo.c create mode 100644 lib_blackfin/bdinfo.c create mode 100644 lib_i386/bdinfo.c create mode 100644 lib_m68k/bdinfo.c create mode 100644 lib_microblaze/bdinfo.c create mode 100644 lib_mips/bdinfo.c create mode 100644 lib_nios/bdinfo.c create mode 100644 lib_nios2/bdinfo.c create mode 100644 lib_ppc/bdinfo.c create mode 100644 lib_sh/bdinfo.c create mode 100644 lib_sparc/bdinfo.c
diff --git a/common/cmd_bdinfo.c b/common/cmd_bdinfo.c dissimilarity index 88% index 700314b..2d83b93 100644 --- a/common/cmd_bdinfo.c +++ b/common/cmd_bdinfo.c @@ -1,384 +1,78 @@ -/* - * (C) Copyright 2003 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -/* - * Boot support - */ -#include <common.h> -#include <command.h> - -DECLARE_GLOBAL_DATA_PTR; - -static void print_num(const char *, ulong); - -static void print_eth(int idx); - -#ifndef CONFIG_ARM /* PowerPC and other */ -static void print_lnum(const char *, u64); - -#ifdef CONFIG_PPC -static void print_str(const char *, const char *); - -int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) -{ - bd_t *bd = gd->bd; - char buf[32]; - -#ifdef DEBUG - print_num ("bd address", (ulong)bd ); -#endif - print_num ("memstart", bd->bi_memstart ); - print_lnum ("memsize", bd->bi_memsize ); - print_num ("flashstart", bd->bi_flashstart ); - print_num ("flashsize", bd->bi_flashsize ); - print_num ("flashoffset", bd->bi_flashoffset ); - print_num ("sramstart", bd->bi_sramstart ); - print_num ("sramsize", bd->bi_sramsize ); -#if defined(CONFIG_5xx) || defined(CONFIG_8xx) || \ - defined(CONFIG_8260) || defined(CONFIG_E500) - print_num ("immr_base", bd->bi_immr_base ); -#endif - print_num ("bootflags", bd->bi_bootflags ); -#if defined(CONFIG_405GP) || defined(CONFIG_405CR) || \ - defined(CONFIG_405EP) || defined(CONFIG_XILINX_405) || \ - defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ - defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ - defined(CONFIG_440SP) || defined(CONFIG_440SPE) - print_str ("procfreq", strmhz(buf, bd->bi_procfreq)); - print_str ("plb_busfreq", strmhz(buf, bd->bi_plb_busfreq)); -#if defined(CONFIG_405GP) || defined(CONFIG_405EP) || defined(CONFIG_XILINX_405) || \ - defined(CONFIG_440EP) || defined(CONFIG_440GR) || defined(CONFIG_440SPE) || \ - defined(CONFIG_440EPX) || defined(CONFIG_440GRX) - print_str ("pci_busfreq", strmhz(buf, bd->bi_pci_busfreq)); -#endif -#else /* ! CONFIG_405GP, CONFIG_405CR, CONFIG_405EP, CONFIG_XILINX_405, CONFIG_440EP CONFIG_440GR */ -#if defined(CONFIG_CPM2) - print_str ("vco", strmhz(buf, bd->bi_vco)); - print_str ("sccfreq", strmhz(buf, bd->bi_sccfreq)); - print_str ("brgfreq", strmhz(buf, bd->bi_brgfreq)); -#endif - print_str ("intfreq", strmhz(buf, bd->bi_intfreq)); -#if defined(CONFIG_CPM2) - print_str ("cpmfreq", strmhz(buf, bd->bi_cpmfreq)); -#endif - print_str ("busfreq", strmhz(buf, bd->bi_busfreq)); -#endif /* CONFIG_405GP, CONFIG_405CR, CONFIG_405EP, CONFIG_XILINX_405, CONFIG_440EP CONFIG_440GR */ -#if defined(CONFIG_MPC8220) - print_str ("inpfreq", strmhz(buf, bd->bi_inpfreq)); - print_str ("flbfreq", strmhz(buf, bd->bi_flbfreq)); - print_str ("pcifreq", strmhz(buf, bd->bi_pcifreq)); - print_str ("vcofreq", strmhz(buf, bd->bi_vcofreq)); - print_str ("pevfreq", strmhz(buf, bd->bi_pevfreq)); -#endif - - print_eth(0); -#if defined(CONFIG_HAS_ETH1) - print_eth(1); -#endif -#if defined(CONFIG_HAS_ETH2) - print_eth(2); -#endif -#if defined(CONFIG_HAS_ETH3) - print_eth(3); -#endif -#if defined(CONFIG_HAS_ETH4) - print_eth(4); -#endif -#if defined(CONFIG_HAS_ETH5) - print_eth(5); -#endif - -#ifdef CONFIG_HERMES - print_str ("ethspeed", strmhz(buf, bd->bi_ethspeed)); -#endif - printf ("IP addr = %pI4\n", &bd->bi_ip_addr); - printf ("baudrate = %6ld bps\n", bd->bi_baudrate ); - return 0; -} - -#elif defined(CONFIG_NIOS) /* NIOS*/ - -int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) -{ - bd_t *bd = gd->bd; - - print_num ("memstart", (ulong)bd->bi_memstart); - print_lnum ("memsize", (u64)bd->bi_memsize); - print_num ("flashstart", (ulong)bd->bi_flashstart); - print_num ("flashsize", (ulong)bd->bi_flashsize); - print_num ("flashoffset", (ulong)bd->bi_flashoffset); - - print_eth(0); - printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); - printf ("baudrate = %ld bps\n", bd->bi_baudrate); - - return 0; -} - -#elif defined(CONFIG_NIOS2) /* Nios-II */ - -int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) -{ - bd_t *bd = gd->bd; - - print_num ("mem start", (ulong)bd->bi_memstart); - print_lnum ("mem size", (u64)bd->bi_memsize); - print_num ("flash start", (ulong)bd->bi_flashstart); - print_num ("flash size", (ulong)bd->bi_flashsize); - print_num ("flash offset", (ulong)bd->bi_flashoffset); - -#if defined(CONFIG_SYS_SRAM_BASE) - print_num ("sram start", (ulong)bd->bi_sramstart); - print_num ("sram size", (ulong)bd->bi_sramsize); -#endif - -#if defined(CONFIG_CMD_NET) - print_eth(0); - printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); -#endif - - printf ("baudrate = %ld bps\n", bd->bi_baudrate); - - return 0; -} -#elif defined(CONFIG_MICROBLAZE) /* ! PPC, which leaves Microblaze */ - -int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) -{ - bd_t *bd = gd->bd; - print_num ("mem start ", (ulong)bd->bi_memstart); - print_lnum ("mem size ", (u64)bd->bi_memsize); - print_num ("flash start ", (ulong)bd->bi_flashstart); - print_num ("flash size ", (ulong)bd->bi_flashsize); - print_num ("flash offset ", (ulong)bd->bi_flashoffset); -#if defined(CONFIG_SYS_SRAM_BASE) - print_num ("sram start ", (ulong)bd->bi_sramstart); - print_num ("sram size ", (ulong)bd->bi_sramsize); -#endif -#if defined(CONFIG_CMD_NET) - print_eth(0); - printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); -#endif - printf ("baudrate = %ld bps\n", (ulong)bd->bi_baudrate); - return 0; -} - -#elif defined(CONFIG_SPARC) /* SPARC */ -int do_bdinfo(cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) -{ - bd_t *bd = gd->bd; - -#ifdef DEBUG - print_num("bd address ", (ulong) bd); -#endif - print_num("memstart ", bd->bi_memstart); - print_lnum("memsize ", bd->bi_memsize); - print_num("flashstart ", bd->bi_flashstart); - print_num("CONFIG_SYS_MONITOR_BASE ", CONFIG_SYS_MONITOR_BASE); - print_num("CONFIG_ENV_ADDR ", CONFIG_ENV_ADDR); - printf("CONFIG_SYS_RELOC_MONITOR_BASE = 0x%lx (%d)\n", CONFIG_SYS_RELOC_MONITOR_BASE, - CONFIG_SYS_MONITOR_LEN); - printf("CONFIG_SYS_MALLOC_BASE = 0x%lx (%d)\n", CONFIG_SYS_MALLOC_BASE, - CONFIG_SYS_MALLOC_LEN); - printf("CONFIG_SYS_INIT_SP_OFFSET = 0x%lx (%d)\n", CONFIG_SYS_INIT_SP_OFFSET, - CONFIG_SYS_STACK_SIZE); - printf("CONFIG_SYS_PROM_OFFSET = 0x%lx (%d)\n", CONFIG_SYS_PROM_OFFSET, - CONFIG_SYS_PROM_SIZE); - printf("CONFIG_SYS_GBL_DATA_OFFSET = 0x%lx (%d)\n", CONFIG_SYS_GBL_DATA_OFFSET, - CONFIG_SYS_GBL_DATA_SIZE); - -#if defined(CONFIG_CMD_NET) - print_eth(0); - printf("ip_addr = %pI4\n", &bd->bi_ip_addr); -#endif - printf("baudrate = %6ld bps\n", bd->bi_baudrate); - return 0; -} - -#elif defined(CONFIG_M68K) /* M68K */ -static void print_str(const char *, const char *); - -int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) -{ - bd_t *bd = gd->bd; - char buf[32]; - - print_num ("memstart", (ulong)bd->bi_memstart); - print_lnum ("memsize", (u64)bd->bi_memsize); - print_num ("flashstart", (ulong)bd->bi_flashstart); - print_num ("flashsize", (ulong)bd->bi_flashsize); - print_num ("flashoffset", (ulong)bd->bi_flashoffset); -#if defined(CONFIG_SYS_INIT_RAM_ADDR) - print_num ("sramstart", (ulong)bd->bi_sramstart); - print_num ("sramsize", (ulong)bd->bi_sramsize); -#endif -#if defined(CONFIG_SYS_MBAR) - print_num ("mbar", bd->bi_mbar_base); -#endif - print_str ("cpufreq", strmhz(buf, bd->bi_intfreq)); - print_str ("busfreq", strmhz(buf, bd->bi_busfreq)); -#ifdef CONFIG_PCI - print_str ("pcifreq", strmhz(buf, bd->bi_pcifreq)); -#endif -#ifdef CONFIG_EXTRA_CLOCK - print_str ("flbfreq", strmhz(buf, bd->bi_flbfreq)); - print_str ("inpfreq", strmhz(buf, bd->bi_inpfreq)); - print_str ("vcofreq", strmhz(buf, bd->bi_vcofreq)); -#endif -#if defined(CONFIG_CMD_NET) - print_eth(0); -#if defined(CONFIG_HAS_ETH1) - print_eth(1); -#endif -#if defined(CONFIG_HAS_ETH2) - print_eth(2); -#endif -#if defined(CONFIG_HAS_ETH3) - print_eth(3); -#endif - - printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); -#endif - printf ("baudrate = %ld bps\n", bd->bi_baudrate); - - return 0; -} - -#elif defined(CONFIG_BLACKFIN) -static void print_str(const char *, const char *); - -int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) -{ - bd_t *bd = gd->bd; - char buf[32]; - - printf("U-Boot = %s\n", bd->bi_r_version); - printf("CPU = %s\n", bd->bi_cpu); - printf("Board = %s\n", bd->bi_board_name); - print_str("VCO", strmhz(buf, bd->bi_vco)); - print_str("CCLK", strmhz(buf, bd->bi_cclk)); - print_str("SCLK", strmhz(buf, bd->bi_sclk)); - - print_num("boot_params", (ulong)bd->bi_boot_params); - print_num("memstart", (ulong)bd->bi_memstart); - print_lnum("memsize", (u64)bd->bi_memsize); - print_num("flashstart", (ulong)bd->bi_flashstart); - print_num("flashsize", (ulong)bd->bi_flashsize); - print_num("flashoffset", (ulong)bd->bi_flashoffset); - - print_eth(0); - printf("ip_addr = %pI4\n", &bd->bi_ip_addr); - printf("baudrate = %d bps\n", bd->bi_baudrate); - - return 0; -} - -#else /* ! PPC, which leaves MIPS */ - -int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) -{ - bd_t *bd = gd->bd; - - print_num ("boot_params", (ulong)bd->bi_boot_params); - print_num ("memstart", (ulong)bd->bi_memstart); - print_lnum ("memsize", (u64)bd->bi_memsize); - print_num ("flashstart", (ulong)bd->bi_flashstart); - print_num ("flashsize", (ulong)bd->bi_flashsize); - print_num ("flashoffset", (ulong)bd->bi_flashoffset); - - print_eth(0); - printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); - printf ("baudrate = %d bps\n", bd->bi_baudrate); - - return 0; -} -#endif /* MIPS */ - -#else /* ARM */ - -int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) -{ - int i; - bd_t *bd = gd->bd; - - print_num ("arch_number", bd->bi_arch_number); - print_num ("env_t", (ulong)bd->bi_env); - print_num ("boot_params", (ulong)bd->bi_boot_params); - - for (i=0; i<CONFIG_NR_DRAM_BANKS; ++i) { - print_num("DRAM bank", i); - print_num("-> start", bd->bi_dram[i].start); - print_num("-> size", bd->bi_dram[i].size); - } - -#if defined(CONFIG_CMD_NET) - print_eth(0); - printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); -#endif - printf ("baudrate = %d bps\n", bd->bi_baudrate); - - return 0; -} - -#endif /* CONFIG_ARM XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX */ - -static void print_num(const char *name, ulong value) -{ - printf ("%-12s= 0x%08lX\n", name, value); -} - -static void print_eth(int idx) -{ - char name[10], *val; - if (idx) - sprintf(name, "eth%iaddr", idx); - else - strcpy(name, "ethaddr"); - val = getenv(name); - if (!val) - val = "(not set)"; - printf("%-12s= %s\n", name, val); -} - -#ifndef CONFIG_ARM -static void print_lnum(const char *name, u64 value) -{ - printf ("%-12s= 0x%.8llX\n", name, value); -} -#endif - -#if defined(CONFIG_PPC) || defined(CONFIG_M68K) || defined(CONFIG_BLACKFIN) -static void print_str(const char *name, const char *str) -{ - printf ("%-12s= %6s MHz\n", name, str); -} -#endif /* CONFIG_PPC */ - - -/* -------------------------------------------------------------------- */ - -U_BOOT_CMD( - bdinfo, 1, 1, do_bdinfo, - "print Board Info structure", - NULL -); +/* + * (C) Copyright 2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Boot support + */ +#include <common.h> +#include <command.h> +#include <bdinfo.h> + +void board_bdinfo(cmd_tbl_t *, int, int, char **) __attribute__((weak)); +void cpu_bdinfo(cmd_tbl_t *, int, int, char **) __attribute__((weak)); +void soc_bdinfo(cmd_tbl_t *, int, int, char **) __attribute__((weak)); + +int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + /* call arch bdinfo */ + arch_bdinfo(cmdtp, flag, argc, argv); + + /* call cpu bdinfo */ + if (cpu_bdinfo) { + puts("CPU Info\n"); + cpu_bdinfo(cmdtp, flag, argc, argv); + } + + /* call soc bdinfo */ + if (soc_bdinfo) { + puts("SOC Info\n"); + soc_bdinfo(cmdtp, flag, argc, argv); + } + + /* call board bdinfo */ + if (board_bdinfo) { + puts("Board Info\n"); + board_bdinfo(cmdtp, flag, argc, argv); + } + + return 0; +} + +void print_eth(int idx) +{ + char name[10], *val; + if (idx) + sprintf(name, "eth%iaddr", idx); + else + strcpy(name, "ethaddr"); + val = getenv(name); + if (!val) + val = "(not set)"; + printf("%-12s= %s\n", name, val); +} + +U_BOOT_CMD( + bdinfo, 1, 1, do_bdinfo, + "print Board Info structure", + NULL +); diff --git a/include/bdinfo.h b/include/bdinfo.h new file mode 100644 index 0000000..cc44544 --- /dev/null +++ b/include/bdinfo.h @@ -0,0 +1,49 @@ +/* + * (C) Copyright 2008 + * Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _BDINFO_H_ +#define _BDINFO_H_ + +void arch_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char **argv); +void board_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char **argv); +void cpu_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char **argv); +void soc_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char **argv); + +static inline void print_num(const char *name, ulong value) +{ + printf ("%-12s= 0x%08lX\n", name, value); +} + +static inline void print_lnum(const char *name, u64 value) +{ + printf ("%-12s= 0x%.8llX\n", name, value); +} + +static inline void print_str(const char *name, const char *str) +{ + printf ("%-12s= %6s MHz\n", name, str); +} + +void print_eth(int idx); + +#endif /* _BDINFO_H_ */ diff --git a/lib_arm/Makefile b/lib_arm/Makefile index c8795b2..3ca7c74 100644 --- a/lib_arm/Makefile +++ b/lib_arm/Makefile @@ -32,6 +32,7 @@ SOBJS-y += _modsi3.o SOBJS-y += _udivsi3.o SOBJS-y += _umodsi3.o
SOBJS-y += memset.o
SOBJS-y +=
SOBJS-y +=
SOBJS-y +=
SOBJS-y +=
SOBJS-y += cache.o
SOBJS-y +=
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- common/cmd_bdinfo.c | 6 ++++- lib_arm/bdinfo.c | 10 ++++---- lib_avr32/bdinfo.c | 16 +++++++------- lib_i386/bdinfo.c | 16 +++++++------- lib_m68k/bdinfo.c | 32 ++++++++++++++-------------- lib_microblaze/bdinfo.c | 18 +++++++------- lib_mips/bdinfo.c | 16 +++++++------- lib_nios/bdinfo.c | 14 ++++++------ lib_nios2/bdinfo.c | 18 +++++++------- lib_ppc/bdinfo.c | 54 +++++++++++++++++++++++----------------------- lib_sh/bdinfo.c | 16 +++++++------- 11 files changed, 110 insertions(+), 106 deletions(-)
diff --git a/common/cmd_bdinfo.c b/common/cmd_bdinfo.c index 2d83b93..db25330 100644 --- a/common/cmd_bdinfo.c +++ b/common/cmd_bdinfo.c @@ -60,14 +60,18 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[])
void print_eth(int idx) { - char name[10], *val; + char name[10]; + char *val; + if (idx) sprintf(name, "eth%iaddr", idx); else strcpy(name, "ethaddr"); + val = getenv(name); if (!val) val = "(not set)"; + printf("%-12s= %s\n", name, val); }
diff --git a/lib_arm/bdinfo.c b/lib_arm/bdinfo.c index 0e5084b..d5b5a4b 100644 --- a/lib_arm/bdinfo.c +++ b/lib_arm/bdinfo.c @@ -35,9 +35,9 @@ void arch_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) int i; bd_t *bd = gd->bd;
- print_num ("arch_number", bd->bi_arch_number); - print_num ("env_t", (ulong)bd->bi_env); - print_num ("boot_params", (ulong)bd->bi_boot_params); + print_num("arch_number", bd->bi_arch_number); + print_num("env_t", (ulong)bd->bi_env); + print_num("boot_params", (ulong)bd->bi_boot_params);
for (i = 0; i < CONFIG_NR_DRAM_BANKS; ++i) { print_num("DRAM bank", i); @@ -47,7 +47,7 @@ void arch_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[])
#if defined(CONFIG_CMD_NET) print_eth(0); - printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); + printf("ip_addr = %pI4\n", &bd->bi_ip_addr); #endif - printf ("baudrate = %d bps\n", bd->bi_baudrate); + printf("baudrate = %d bps\n", bd->bi_baudrate); } diff --git a/lib_avr32/bdinfo.c b/lib_avr32/bdinfo.c index 616481d..a040c7a 100644 --- a/lib_avr32/bdinfo.c +++ b/lib_avr32/bdinfo.c @@ -34,14 +34,14 @@ void arch_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { bd_t *bd = gd->bd;
- print_num ("boot_params", (ulong)bd->bi_boot_params); - print_num ("memstart", (ulong)bd->bi_memstart); - print_lnum ("memsize", (u64)bd->bi_memsize); - print_num ("flashstart", (ulong)bd->bi_flashstart); - print_num ("flashsize", (ulong)bd->bi_flashsize); - print_num ("flashoffset", (ulong)bd->bi_flashoffset); + print_num("boot_params", (ulong)bd->bi_boot_params); + print_num("memstart", (ulong)bd->bi_memstart); + print_lnum("memsize", (u64)bd->bi_memsize); + print_num("flashstart", (ulong)bd->bi_flashstart); + print_num("flashsize", (ulong)bd->bi_flashsize); + print_num("flashoffset", (ulong)bd->bi_flashoffset);
print_eth(0); - printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); - printf ("baudrate = %d bps\n", bd->bi_baudrate); + printf("ip_addr = %pI4\n", &bd->bi_ip_addr); + printf("baudrate = %d bps\n", bd->bi_baudrate); } diff --git a/lib_i386/bdinfo.c b/lib_i386/bdinfo.c index 616481d..a040c7a 100644 --- a/lib_i386/bdinfo.c +++ b/lib_i386/bdinfo.c @@ -34,14 +34,14 @@ void arch_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { bd_t *bd = gd->bd;
print_eth(0); - printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); - printf ("baudrate = %d bps\n", bd->bi_baudrate); + printf("ip_addr = %pI4\n", &bd->bi_ip_addr); + printf("baudrate = %d bps\n", bd->bi_baudrate); } diff --git a/lib_m68k/bdinfo.c b/lib_m68k/bdinfo.c index e77a1cf..e271145 100644 --- a/lib_m68k/bdinfo.c +++ b/lib_m68k/bdinfo.c @@ -35,27 +35,27 @@ void arch_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) bd_t *bd = gd->bd; char buf[32];
- print_num ("memstart", (ulong)bd->bi_memstart); - print_lnum ("memsize", (u64)bd->bi_memsize); - print_num ("flashstart", (ulong)bd->bi_flashstart); - print_num ("flashsize", (ulong)bd->bi_flashsize); - print_num ("flashoffset", (ulong)bd->bi_flashoffset); + print_num("memstart", (ulong)bd->bi_memstart); + print_lnum("memsize", (u64)bd->bi_memsize); + print_num("flashstart", (ulong)bd->bi_flashstart); + print_num("flashsize", (ulong)bd->bi_flashsize); + print_num("flashoffset", (ulong)bd->bi_flashoffset); #if defined(CONFIG_SYS_INIT_RAM_ADDR) - print_num ("sramstart", (ulong)bd->bi_sramstart); - print_num ("sramsize", (ulong)bd->bi_sramsize); + print_num("sramstart", (ulong)bd->bi_sramstart); + print_num("sramsize", (ulong)bd->bi_sramsize); #endif #if defined(CONFIG_SYS_MBAR) - print_num ("mbar", bd->bi_mbar_base); + print_num("mbar", bd->bi_mbar_base); #endif - print_str ("cpufreq", strmhz(buf, bd->bi_intfreq)); - print_str ("busfreq", strmhz(buf, bd->bi_busfreq)); + print_str("cpufreq", strmhz(buf, bd->bi_intfreq)); + print_str("busfreq", strmhz(buf, bd->bi_busfreq)); #ifdef CONFIG_PCI - print_str ("pcifreq", strmhz(buf, bd->bi_pcifreq)); + print_str("pcifreq", strmhz(buf, bd->bi_pcifreq)); #endif #ifdef CONFIG_EXTRA_CLOCK - print_str ("flbfreq", strmhz(buf, bd->bi_flbfreq)); - print_str ("inpfreq", strmhz(buf, bd->bi_inpfreq)); - print_str ("vcofreq", strmhz(buf, bd->bi_vcofreq)); + print_str("flbfreq", strmhz(buf, bd->bi_flbfreq)); + print_str("inpfreq", strmhz(buf, bd->bi_inpfreq)); + print_str("vcofreq", strmhz(buf, bd->bi_vcofreq)); #endif #if defined(CONFIG_CMD_NET) print_eth(0); @@ -69,7 +69,7 @@ void arch_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) print_eth(3); #endif
- printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); + printf("ip_addr = %pI4\n", &bd->bi_ip_addr); #endif - printf ("baudrate = %ld bps\n", bd->bi_baudrate); + printf("baudrate = %ld bps\n", bd->bi_baudrate); } diff --git a/lib_microblaze/bdinfo.c b/lib_microblaze/bdinfo.c index eba2f4d..908f94e 100644 --- a/lib_microblaze/bdinfo.c +++ b/lib_microblaze/bdinfo.c @@ -34,18 +34,18 @@ void arch_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { bd_t *bd = gd->bd;
- print_num ("mem start ", (ulong)bd->bi_memstart); - print_lnum ("mem size ", (u64)bd->bi_memsize); - print_num ("flash start ", (ulong)bd->bi_flashstart); - print_num ("flash size ", (ulong)bd->bi_flashsize); - print_num ("flash offset ", (ulong)bd->bi_flashoffset); + print_num("mem start ", (ulong)bd->bi_memstart); + print_lnum("mem size ", (u64)bd->bi_memsize); + print_num("flash start ", (ulong)bd->bi_flashstart); + print_num("flash size ", (ulong)bd->bi_flashsize); + print_num("flash offset ", (ulong)bd->bi_flashoffset); #if defined(CONFIG_SYS_SRAM_BASE) - print_num ("sram start ", (ulong)bd->bi_sramstart); - print_num ("sram size ", (ulong)bd->bi_sramsize); + print_num("sram start ", (ulong)bd->bi_sramstart); + print_num("sram size ", (ulong)bd->bi_sramsize); #endif #if defined(CONFIG_CMD_NET) print_eth(0); - printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); + printf("ip_addr = %pI4\n", &bd->bi_ip_addr); #endif - printf ("baudrate = %ld bps\n", (ulong)bd->bi_baudrate); + printf("baudrate = %ld bps\n", (ulong)bd->bi_baudrate); } diff --git a/lib_mips/bdinfo.c b/lib_mips/bdinfo.c index 616481d..a040c7a 100644 --- a/lib_mips/bdinfo.c +++ b/lib_mips/bdinfo.c @@ -34,14 +34,14 @@ void arch_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { bd_t *bd = gd->bd;
print_eth(0); - printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); - printf ("baudrate = %d bps\n", bd->bi_baudrate); + printf("ip_addr = %pI4\n", &bd->bi_ip_addr); + printf("baudrate = %d bps\n", bd->bi_baudrate); } diff --git a/lib_nios/bdinfo.c b/lib_nios/bdinfo.c index 6e42c24..2959c9d 100644 --- a/lib_nios/bdinfo.c +++ b/lib_nios/bdinfo.c @@ -34,13 +34,13 @@ void arch_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { bd_t *bd = gd->bd;
print_eth(0); - printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); - printf ("baudrate = %ld bps\n", bd->bi_baudrate); + printf("ip_addr = %pI4\n", &bd->bi_ip_addr); + printf("baudrate = %ld bps\n", bd->bi_baudrate); } diff --git a/lib_nios2/bdinfo.c b/lib_nios2/bdinfo.c index 5b39fb1..95836c6 100644 --- a/lib_nios2/bdinfo.c +++ b/lib_nios2/bdinfo.c @@ -34,21 +34,21 @@ void arch_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { bd_t *bd = gd->bd;
- print_num ("mem start", (ulong)bd->bi_memstart); - print_lnum ("mem size", (u64)bd->bi_memsize); - print_num ("flash start", (ulong)bd->bi_flashstart); - print_num ("flash size", (ulong)bd->bi_flashsize); - print_num ("flash offset", (ulong)bd->bi_flashoffset); + print_num("mem start", (ulong)bd->bi_memstart); + print_lnum("mem size", (u64)bd->bi_memsize); + print_num("flash start", (ulong)bd->bi_flashstart); + print_num("flash size", (ulong)bd->bi_flashsize); + print_num("flash offset", (ulong)bd->bi_flashoffset);
#if defined(CONFIG_SYS_SRAM_BASE) - print_num ("sram start", (ulong)bd->bi_sramstart); - print_num ("sram size", (ulong)bd->bi_sramsize); + print_num("sram start", (ulong)bd->bi_sramstart); + print_num("sram size", (ulong)bd->bi_sramsize); #endif
- printf ("baudrate = %ld bps\n", bd->bi_baudrate); + printf("baudrate = %ld bps\n", bd->bi_baudrate); } diff --git a/lib_ppc/bdinfo.c b/lib_ppc/bdinfo.c index 5aad37c..80a5470 100644 --- a/lib_ppc/bdinfo.c +++ b/lib_ppc/bdinfo.c @@ -36,50 +36,50 @@ void arch_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) char buf[32];
#ifdef DEBUG - print_num ("bd address", (ulong)bd ); + print_num("bd address", (ulong)bd ); #endif - print_num ("memstart", bd->bi_memstart ); - print_lnum ("memsize", bd->bi_memsize ); - print_num ("flashstart", bd->bi_flashstart ); - print_num ("flashsize", bd->bi_flashsize ); - print_num ("flashoffset", bd->bi_flashoffset ); - print_num ("sramstart", bd->bi_sramstart ); - print_num ("sramsize", bd->bi_sramsize ); + print_num("memstart", bd->bi_memstart ); + print_lnum("memsize", bd->bi_memsize ); + print_num("flashstart", bd->bi_flashstart ); + print_num("flashsize", bd->bi_flashsize ); + print_num("flashoffset", bd->bi_flashoffset ); + print_num("sramstart", bd->bi_sramstart ); + print_num("sramsize", bd->bi_sramsize ); #if defined(CONFIG_5xx) || defined(CONFIG_8xx) || \ defined(CONFIG_8260) || defined(CONFIG_E500) - print_num ("immr_base", bd->bi_immr_base ); + print_num("immr_base", bd->bi_immr_base ); #endif - print_num ("bootflags", bd->bi_bootflags ); + print_num("bootflags", bd->bi_bootflags ); #if defined(CONFIG_405GP) || defined(CONFIG_405CR) || \ defined(CONFIG_405EP) || defined(CONFIG_XILINX_405) || \ defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ defined(CONFIG_440SP) || defined(CONFIG_440SPE) - print_str ("procfreq", strmhz(buf, bd->bi_procfreq)); - print_str ("plb_busfreq", strmhz(buf, bd->bi_plb_busfreq)); + print_str("procfreq", strmhz(buf, bd->bi_procfreq)); + print_str("plb_busfreq", strmhz(buf, bd->bi_plb_busfreq)); #if defined(CONFIG_405GP) || defined(CONFIG_405EP) || defined(CONFIG_XILINX_405) || \ defined(CONFIG_440EP) || defined(CONFIG_440GR) || defined(CONFIG_440SPE) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) - print_str ("pci_busfreq", strmhz(buf, bd->bi_pci_busfreq)); + print_str("pci_busfreq", strmhz(buf, bd->bi_pci_busfreq)); #endif #else /* ! CONFIG_405GP, CONFIG_405CR, CONFIG_405EP, CONFIG_XILINX_405, CONFIG_440EP CONFIG_440GR */ #if defined(CONFIG_CPM2) - print_str ("vco", strmhz(buf, bd->bi_vco)); - print_str ("sccfreq", strmhz(buf, bd->bi_sccfreq)); - print_str ("brgfreq", strmhz(buf, bd->bi_brgfreq)); + print_str("vco", strmhz(buf, bd->bi_vco)); + print_str("sccfreq", strmhz(buf, bd->bi_sccfreq)); + print_str("brgfreq", strmhz(buf, bd->bi_brgfreq)); #endif - print_str ("intfreq", strmhz(buf, bd->bi_intfreq)); + print_str("intfreq", strmhz(buf, bd->bi_intfreq)); #if defined(CONFIG_CPM2) - print_str ("cpmfreq", strmhz(buf, bd->bi_cpmfreq)); + print_str("cpmfreq", strmhz(buf, bd->bi_cpmfreq)); #endif - print_str ("busfreq", strmhz(buf, bd->bi_busfreq)); + print_str("busfreq", strmhz(buf, bd->bi_busfreq)); #endif /* CONFIG_405GP, CONFIG_405CR, CONFIG_405EP, CONFIG_XILINX_405, CONFIG_440EP CONFIG_440GR */ #if defined(CONFIG_MPC8220) - print_str ("inpfreq", strmhz(buf, bd->bi_inpfreq)); - print_str ("flbfreq", strmhz(buf, bd->bi_flbfreq)); - print_str ("pcifreq", strmhz(buf, bd->bi_pcifreq)); - print_str ("vcofreq", strmhz(buf, bd->bi_vcofreq)); - print_str ("pevfreq", strmhz(buf, bd->bi_pevfreq)); + print_str("inpfreq", strmhz(buf, bd->bi_inpfreq)); + print_str("flbfreq", strmhz(buf, bd->bi_flbfreq)); + print_str("pcifreq", strmhz(buf, bd->bi_pcifreq)); + print_str("vcofreq", strmhz(buf, bd->bi_vcofreq)); + print_str("pevfreq", strmhz(buf, bd->bi_pevfreq)); #endif
print_eth(0); @@ -100,8 +100,8 @@ void arch_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) #endif
#ifdef CONFIG_HERMES - print_str ("ethspeed", strmhz(buf, bd->bi_ethspeed)); + print_str("ethspeed", strmhz(buf, bd->bi_ethspeed)); #endif - printf ("IP addr = %pI4\n", &bd->bi_ip_addr); - printf ("baudrate = %6ld bps\n", bd->bi_baudrate ); + printf("IP addr = %pI4\n", &bd->bi_ip_addr); + printf("baudrate = %6ld bps\n", bd->bi_baudrate); } diff --git a/lib_sh/bdinfo.c b/lib_sh/bdinfo.c index 616481d..a040c7a 100644 --- a/lib_sh/bdinfo.c +++ b/lib_sh/bdinfo.c @@ -34,14 +34,14 @@ void arch_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { bd_t *bd = gd->bd;
Dear Jean-Christophe PLAGNIOL-VILLARD,
Sorry, does not apply any more.
Please rebase and resubmit (also "[PATCH 2/2] bdinfo: coding style cleanup" which depends on this).
participants (5)
Haavard Skinnemoen
Magnus Lilja
Mike Frysinger
