[U-Boot] [PULL] : Please pull u-boot-imx
Hi Albert,
please pull from u-boot-imx, thanks.
The following changes since commit fdce7b633a1de24456226b18527cc7900c34282a:
gpio: omap5-uevm: Configure the tca6424 gpio expander (2013-07-30 09:21:42 -0400)
git://www.denx.de/git/u-boot-imx.git master
for you to fetch changes up to 326ea986ac150acdc7656d57fca647db80b50158:
Merge git://git.denx.de/u-boot-arm (2013-07-31 11:30:38 +0200)
Dirk Behme (1): mxc_gpio: Correct the GPIO handling in gpio_direction_output()
Eric Nelson (1): mxc_ipuv3: fix memory alignment of framebuffer
Fabio Estevam (1): mx6qsabrelite: Remove mx6qsabrelite code in favor of nitrogen6x
Marek Vasut (1): ARM: mxs: Consolidate configuration options
Otavio Salvador (1): wandboard: Use splash image at screen center by default
Pardeep Kumar Singla (2): mx6: Factor out common HDMI setup code mx6qsabresd: Add splash screen support via HDMI
Robert Winkler (2): imx: Add documentation for imx specific commands imx: nitrogen6x: mx6qsabrelite: Add support for DVI monitors
Stefano Babic (1): Merge git://git.denx.de/u-boot-arm
MAINTAINERS | 2 +- README | 15 + arch/arm/cpu/armv7/mx6/clock.c | 8 + arch/arm/cpu/armv7/mx6/soc.c | 43 + arch/arm/imx-common/cmd_hdmidet.c | 3 +- arch/arm/include/asm/arch-mx6/clock.h | 2 +- arch/arm/include/asm/arch-mx6/mxc_hdmi.h | 8 + .../nitrogen6x/README.mx6qsabrelite} | 0 board/boundary/nitrogen6x/nitrogen6x.c | 46 +- board/freescale/mx6qsabrelite/Makefile | 28 - board/freescale/mx6qsabrelite/mx6qsabrelite.c | 832 -------------------- board/freescale/mx6sabresd/mx6sabresd.c | 64 +- board/wandboard/wandboard.c | 44 +- boards.cfg | 2 +- drivers/gpio/mxc_gpio.c | 4 +- drivers/video/mxc_ipuv3_fb.c | 5 +- include/configs/apx4devkit.h | 120 +-- include/configs/m28evk.h | 192 +---- include/configs/mx23_olinuxino.h | 142 +--- include/configs/mx23evk.h | 115 +-- include/configs/mx28evk.h | 173 +--- include/configs/mx6qsabrelite.h | 284 ------- include/configs/mx6sabre_common.h | 3 +- include/configs/mx6sabresd.h | 19 + include/configs/mxs.h | 191 +++++ include/configs/nitrogen6x.h | 81 +- include/configs/sc_sps_1.h | 139 +--- include/configs/wandboard.h | 2 + 28 files changed, 601 insertions(+), 1966 deletions(-) rename board/{freescale/mx6qsabrelite/README => boundary/nitrogen6x/README.mx6qsabrelite} (100%) delete mode 100644 board/freescale/mx6qsabrelite/Makefile delete mode 100644 board/freescale/mx6qsabrelite/mx6qsabrelite.c delete mode 100644 include/configs/mx6qsabrelite.h create mode 100644 include/configs/mxs.h
Hi Stefano,
On Mon, 12 Aug 2013 15:47:53 +0200, Stefano Babic sbabic@denx.de wrote:
Hi Albert,
Applied to u-boot-arm/master, thanks -- BUT at the moment I cannot push to u-boot-arm at denx. While this gets solved, I have set up a temporary repo at 88.191.163.10. People can fetch it with
git fetch git://88.191.163.10/u-boot-arm
You won't have write access of course.
Amicalement,
Albert ARIBAUD
Stefano Babic
