[U-Boot] [PATCH V3 0/4] common/lcd cleanup
This patch series attempts to simplify #ifdef complexity in common/lcd.c.
It was compile tested on Arm and PowerPC using MAKEALL
Changes in V3: - Rebased on latest u-boot-video - Removed volatile qualifiers in patch 3 since the use of volatile is discouraged and it looks like it is safe to remove them.
Changes in V2: - Rebased on u-boot-video - patches 2 and 3 of original patchset dropped because I'm not sure what to do about them - simplify lcd_logo: used bitmap_display() to further simplify code - simplify lcd_display_bitmap: fixed pointer increment error - simplify lcd_display_bitmap: change to simplify lcd_logo breaks MCC200 board because it does not #define CONFIG_CMD_BMP. Added a local implementation of bitmap_display().
Nikita Kiryanov (4): common lcd: simplify lcd_logo common lcd: simplify lcd_display common lcd: simplify core functions common lcd: simplify lcd_display_bitmap
board/mcc200/lcd.c | 20 +++++++ common/lcd.c | 145 +++++++++++++++++++++++++++------------------------- 2 files changed, 96 insertions(+), 69 deletions(-)
Simplify lcd_logo by extracting bmp unzip into its own function.
Signed-off-by: Nikita Kiryanov nikita@compulab.co.il Signed-off-by: Igor Grinberg grinberg@compulab.co.il ---
Changes in V2: - used bitmap_display() to further simplify code
common/lcd.c | 12 +----------- 1 files changed, 1 insertions(+), 11 deletions(-)
diff --git a/common/lcd.c b/common/lcd.c index 506a138..8890635 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -842,17 +842,7 @@ static void *lcd_logo(void) } #endif /* CONFIG_SPLASH_SCREEN_ALIGN */
-#ifdef CONFIG_VIDEO_BMP_GZIP - bmp_image_t *bmp = (bmp_image_t *)addr; - unsigned long len; - - if (!((bmp->header.signature[0] == 'B') && - (bmp->header.signature[1] == 'M'))) { - addr = (ulong)gunzip_bmp(addr, &len); - } -#endif - - if (lcd_display_bitmap(addr, x, y) == 0) + if (bmp_display(addr, x, y) == 0) return (void *)lcd_base; } #endif /* CONFIG_SPLASH_SCREEN */
Simplify lcd_display by centralizing code into a funciton
Signed-off-by: Nikita Kiryanov nikita@compulab.co.il Signed-off-by: Igor Grinberg grinberg@compulab.co.il --- common/lcd.c | 27 ++++++++++++++++++--------- 1 files changed, 18 insertions(+), 9 deletions(-)
diff --git a/common/lcd.c b/common/lcd.c index 8890635..4a5c8d5 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -607,6 +607,22 @@ static inline void bitmap_plot(int x, int y) {}
#ifdef CONFIG_SPLASH_SCREEN_ALIGN #define BMP_ALIGN_CENTER 0x7FFF + +static void splash_align_axis(int *axis, unsigned long panel_size, + unsigned long picture_size) +{ + unsigned long panel_picture_delta = panel_size - picture_size; + unsigned long axis_alignment; + + if (*axis == BMP_ALIGN_CENTER) + axis_alignment = panel_picture_delta / 2; + else if (*axis < 0) + axis_alignment = panel_picture_delta + *axis + 1; + else + return; + + *axis = max(0, axis_alignment); +} #endif
int lcd_display_bitmap(ulong bmp_image, int x, int y) @@ -722,15 +738,8 @@ int lcd_display_bitmap(ulong bmp_image, int x, int y) padded_line = (width&0x3) ? ((width&~0x3)+4) : (width);
#ifdef CONFIG_SPLASH_SCREEN_ALIGN - if (x == BMP_ALIGN_CENTER) - x = max(0, (pwidth - width) / 2); - else if (x < 0) - x = max(0, pwidth - width + x + 1); - - if (y == BMP_ALIGN_CENTER) - y = max(0, (panel_info.vl_row - height) / 2); - else if (y < 0) - y = max(0, panel_info.vl_row - height + y + 1); + splash_align_axis(&x, pwidth, width); + splash_align_axis(&y, panel_info.vl_row, height); #endif /* CONFIG_SPLASH_SCREEN_ALIGN */
if ((x + width) > pwidth)
Move highly platform dependant code into its own function to reduce the number of #ifdefs in the bigger functions
Changes in V3: - Removed volatile qualifiers in patch 3 since the use of volatile is discouraged and it looks like it is safe to remove them.
common/lcd.c | 62 ++++++++++++++++++++++++++++----------------------------- 1 files changed, 30 insertions(+), 32 deletions(-)
diff --git a/common/lcd.c b/common/lcd.c index 4a5c8d5..0f93eae 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -498,23 +498,37 @@ static int lcd_getbgcolor(void) /************************************************************************/ /* ** Chipset depending Bitmap / Logo stuff... */ /************************************************************************/ +static inline ushort *configuration_get_cmap(void) +{ +#if defined CONFIG_CPU_PXA + struct pxafb_info *fbi = &panel_info.pxa; + return (ushort *)fbi->palette; +#elif defined(CONFIG_MPC823) + immap_t *immr = (immap_t *) CONFIG_SYS_IMMR; + cpm8xx_t *cp = &(immr->im_cpm); + return (ushort *)&(cp->lcd_cmap[255 * sizeof(ushort)]); +#elif defined(CONFIG_ATMEL_LCD) + return (ushort *)(panel_info.mmio + ATMEL_LCDC_LUT(0)); +#else + return (ushort *)panel_info.cmap; +#endif +} + #ifdef CONFIG_LCD_LOGO void bitmap_plot(int x, int y) { #ifdef CONFIG_ATMEL_LCD - uint *cmap; + uint *cmap = (uint *)bmp_logo_palette; #else - ushort *cmap; + ushort *cmap = (ushort *)bmp_logo_palette; #endif ushort i, j; uchar *bmap; uchar *fb; ushort *fb16; -#if defined(CONFIG_CPU_PXA) - struct pxafb_info *fbi = &panel_info.pxa; -#elif defined(CONFIG_MPC823) - volatile immap_t *immr = (immap_t *) CONFIG_SYS_IMMR; - volatile cpm8xx_t *cp = &(immr->im_cpm); +#if defined(CONFIG_MPC823) + immap_t *immr = (immap_t *) CONFIG_SYS_IMMR; + cpm8xx_t *cp = &(immr->im_cpm); #endif
debug("Logo: width %d height %d colors %d cmap %d\n", @@ -525,20 +539,17 @@ void bitmap_plot(int x, int y) fb = (uchar *)(lcd_base + y * lcd_line_length + x);
if (NBITS(panel_info.vl_bpix) < 12) { - /* Leave room for default color map */ -#if defined(CONFIG_CPU_PXA) - cmap = (ushort *) fbi->palette; -#elif defined(CONFIG_MPC823) + /* Leave room for default color map + * default case: generic system with no cmap (most likely 16bpp) + * cmap was set to the source palette, so no change is done. + * This avoids even more ifdefs in the next stanza + */ +#if defined(CONFIG_MPC823) cmap = (ushort *) &(cp->lcd_cmap[BMP_LOGO_OFFSET * sizeof(ushort)]); #elif defined(CONFIG_ATMEL_LCD) - cmap = (uint *) (panel_info.mmio + ATMEL_LCDC_LUT(0)); + cmap = (uint *)configuration_get_cmap(); #else - /* - * default case: generic system with no cmap (most likely 16bpp) - * We set cmap to the source palette, so no change is done. - * This avoids even more ifdef in the next stanza - */ - cmap = bmp_logo_palette; + cmap = configuration_get_cmap(); #endif
WATCHDOG_RESET(); @@ -639,12 +650,6 @@ int lcd_display_bitmap(ulong bmp_image, int x, int y) unsigned long width, height, byte_width; unsigned long pwidth = panel_info.vl_col; unsigned colors, bpix, bmp_bpix; -#if defined(CONFIG_CPU_PXA) - struct pxafb_info *fbi = &panel_info.pxa; -#elif defined(CONFIG_MPC823) - volatile immap_t *immr = (immap_t *) CONFIG_SYS_IMMR; - volatile cpm8xx_t *cp = &(immr->im_cpm); -#endif
if (!((bmp->header.signature[0] == 'B') && (bmp->header.signature[1] == 'M'))) { @@ -682,14 +687,7 @@ int lcd_display_bitmap(ulong bmp_image, int x, int y) #if !defined(CONFIG_MCC200) /* MCC200 LCD doesn't need CMAP, supports 1bpp b&w only */ if (bmp_bpix == 8) { -#if defined(CONFIG_CPU_PXA) - cmap = (ushort *)fbi->palette; -#elif defined(CONFIG_MPC823) - cmap = (ushort *)&(cp->lcd_cmap[255*sizeof(ushort)]); -#elif !defined(CONFIG_ATMEL_LCD) && !defined(CONFIG_EXYNOS_FB) - cmap = panel_info.cmap; -#endif - + cmap = configuration_get_cmap(); cmap_base = cmap;
/* Set color map */
Move highly platform dependant code into its own functions to reduce the number of #ifdefs in lcd_display_bitmap
To avoid breaking the mcc200 board which does not #define CONFIG_CMD_BMP, this patch also implements bmp_display() for mcc200.
Changes in V2: - fixed pointer increment error - change to simplify lcd_logo breaks MCC200 board because it does not #define CONFIG_CMD_BMP. Added a local implementation of bitmap_display().
board/mcc200/lcd.c | 20 ++++++++++++++++++++ common/lcd.c | 44 +++++++++++++++++++++++++++----------------- 2 files changed, 47 insertions(+), 17 deletions(-)
diff --git a/board/mcc200/lcd.c b/board/mcc200/lcd.c index d8f754c..893f4b7 100644 --- a/board/mcc200/lcd.c +++ b/board/mcc200/lcd.c @@ -21,6 +21,7 @@ #include <common.h> #include <lcd.h> #include <mpc5xxx.h> +#include <malloc.h>
#ifdef CONFIG_LCD
@@ -210,4 +211,23 @@ void show_progress (int size, int tot) }
#endif + +int bmp_display(ulong addr, int x, int y) +{ + int ret; + bmp_image_t *bmp = (bmp_image_t *)addr; + + if (!bmp) { + printf("There is no valid bmp file at the given address\n"); + return 1; + } + + ret = lcd_display_bitmap((ulong)bmp, x, y); + + if ((unsigned long)bmp != addr) + free(bmp); + + return ret; +} + #endif /* CONFIG_LCD */ diff --git a/common/lcd.c b/common/lcd.c index 0f93eae..88dfa51 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -636,6 +636,29 @@ static void splash_align_axis(int *axis, unsigned long panel_size, } #endif
+#if defined CONFIG_CPU_PXA || defined(CONFIG_ATMEL_LCD) +#define FB_PUT_BYTE(fb, from) *(fb)++ = *(from)++ +#elif defined(CONFIG_MPC823) || defined(CONFIG_MCC200) +#define FB_PUT_BYTE(fb, from) *(fb)++ = (255 - *(from)++) +#endif + +#if defined(CONFIG_BMP_16BPP) +#if defined(CONFIG_ATMEL_LCD_BGR555) +static inline void fb_put_word(uchar **fb, uchar **from) +{ + *(*fb)++ = (((*from)[0] & 0x1f) << 2) | ((*from)[1] & 0x03); + *(*fb)++ = ((*from)[0] & 0xe0) | (((*from)[1] & 0x7c) >> 2); + *from += 2; +} +#else +static inline void fb_put_word(uchar **fb, uchar **from) +{ + *(*fb)++ = *(*from)++; + *(*fb)++ = *(*from)++; +} +#endif +#endif /* CONFIG_BMP_16BPP */ + int lcd_display_bitmap(ulong bmp_image, int x, int y) { #if !defined(CONFIG_MCC200) @@ -761,11 +784,7 @@ int lcd_display_bitmap(ulong bmp_image, int x, int y) WATCHDOG_RESET(); for (j = 0; j < width; j++) { if (bpix != 16) { -#if defined(CONFIG_CPU_PXA) || defined(CONFIG_ATMEL_LCD) - *(fb++) = *(bmap++); -#elif defined(CONFIG_MPC823) || defined(CONFIG_MCC200) - *(fb++) = 255 - *(bmap++); -#endif + FB_PUT_BYTE(fb, bmap); } else { *(uint16_t *)fb = cmap_base[*(bmap++)]; fb += sizeof(uint16_t) / sizeof(*fb); @@ -780,18 +799,9 @@ int lcd_display_bitmap(ulong bmp_image, int x, int y) case 16: for (i = 0; i < height; ++i) { WATCHDOG_RESET(); - for (j = 0; j < width; j++) { -#if defined(CONFIG_ATMEL_LCD_BGR555) - *(fb++) = ((bmap[0] & 0x1f) << 2) | - (bmap[1] & 0x03); - *(fb++) = (bmap[0] & 0xe0) | - ((bmap[1] & 0x7c) >> 2); - bmap += 2; -#else - *(fb++) = *(bmap++); - *(fb++) = *(bmap++); -#endif - } + for (j = 0; j < width; j++) + fb_put_word(&fb, &bmap); + bmap += (padded_line - width) * 2; fb -= (width * 2 + lcd_line_length); }
Gentle ping.
Changes in V3:
Changes in V2:
Gentle ping.
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Nikita Kiryanov Sent: Monday, August 20, 2012 9:16 AM To: Nikita Kiryanov Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH V3 0/4] common/lcd cleanup
Gentle ping.
Changes in V3:
is
Changes in V2:
local
_______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi guys,
This series is waiting for several month already. Only the V3 is one month old and hasn't got any comments so far. So, if Anatolij for some reason cannot deal with it, please merge it via a staging tree of yours.
Thanks
Changes in V3:
Changes in V2:
Dear Igor Grinberg,
Hi guys,
Anatolij, poke?
It was probably forgotten, simple bump would suffice. Sorry for the delay.
Thanks
Changes in V3:
Changes in V2:
Best regards, Marek Vasut
On Wed, 05 Sep 2012 09:51:12 +0300 Igor Grinberg grinberg@compulab.co.il wrote:
Hi guys,
Sorry for the delay, I'm really busy with other projects and have only very limitted capacity to process U-Boot patches. These are not lost, and assigned to me at patchwork. For now I've applied this series, hope it will not break anything for all these affected platforms. But please do not expect me pushing to u-boot/master this week, Wolfgang won't pull this week anyway, I'm afraid.
Thanks for the patience, and sorry again
Anatolij
Commit 203c37b8c5556aad1901ce4954792afd718c7d42 (common lcd: simplify core functions)
and commit bfdcc65e1163b4891643c2a670570c478b9af2a4 (common lcd: simplify lcd_display_bitmap)
caused build breakage for at91sam9x5ek board configurations and for trats board. Fix these build errors.
Signed-off-by: Anatolij Gustschin agust@denx.de --- common/lcd.c | 14 ++++++++++---- 1 files changed, 10 insertions(+), 4 deletions(-)
diff --git a/common/lcd.c b/common/lcd.c index fcc09ac..b6be800 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -509,8 +509,14 @@ static inline ushort *configuration_get_cmap(void) return (ushort *)&(cp->lcd_cmap[255 * sizeof(ushort)]); #elif defined(CONFIG_ATMEL_LCD) return (ushort *)(panel_info.mmio + ATMEL_LCDC_LUT(0)); +#elif !defined(CONFIG_ATMEL_HLCD) && !defined(CONFIG_EXYNOS_FB) + return panel_info.cmap; #else - return (ushort *)panel_info.cmap; +#if defined(CONFIG_LCD_LOGO) + return bmp_logo_palette; +#else + return NULL; +#endif #endif }
@@ -636,10 +642,10 @@ static void splash_align_axis(int *axis, unsigned long panel_size, } #endif
-#if defined CONFIG_CPU_PXA || defined(CONFIG_ATMEL_LCD) -#define FB_PUT_BYTE(fb, from) *(fb)++ = *(from)++ -#elif defined(CONFIG_MPC823) || defined(CONFIG_MCC200) +#if defined(CONFIG_MPC823) || defined(CONFIG_MCC200) #define FB_PUT_BYTE(fb, from) *(fb)++ = (255 - *(from)++) +#else +#define FB_PUT_BYTE(fb, from) *(fb)++ = *(from)++ #endif
Acked-by: Nikita Kiryanov nikita@compulab.co.il
- return panel_info.cmap; #else
- return bmp_logo_palette;
+#else
- return NULL;
+#endif #endif }
Applied to u-boot-video/master.
Anatolij
participants (5)
Anatolij Gustschin
Igor Grinberg
Nikita Kiryanov
Nikita Kiryanov
