[U-Boot] [GIT PULL] Pull request: u-boot-imx
Hi Albert,
please pull from u-boot-imx, thanks.
The following changes since commit 32ec258f829808dd7cf74fd83ba999fdaaeab715:
IXP: Fix GPIO_INT_ACT_LOW_SET() (2012-03-08 08:11:45 +0100)
are available in the git repository at: git://www.denx.de/git/u-boot-imx.git master
Dirk Behme (1): imximage: Remove overwriting of flash_offset
Eric Nelson (2): i.MX6: mx6qsabrelite: add ext2 support mx6q: mx6qsabrelite: setup_spi() should be called in board_init to allow use for environment
Fabio Estevam (5): mx51evk: Fix CONFIG_SYS_MEMTEST_END mx53evk: Fix CONFIG_SYS_MEMTEST_END mx53smd: Fix CONFIG_SYS_MEMTEST_END efikamx: Fix CONFIG_SYS_MEMTEST_END mx31pdk: Fix CONFIG_SYS_MEMTEST_END
Helmut Raiger (1): mx31: add "ARM11P power gating" to get_reset_cause
arch/arm/cpu/arm1136/mx31/generic.c | 2 ++ board/freescale/mx6qsabrelite/mx6qsabrelite.c | 8 ++++---- include/configs/efikamx.h | 2 +- include/configs/mx31pdk.h | 2 +- include/configs/mx51evk.h | 2 +- include/configs/mx53evk.h | 2 +- include/configs/mx53smd.h | 2 +- include/configs/mx6qsabrelite.h | 1 + tools/imximage.c | 18 ++++++++++++++---- tools/imximage.h | 1 + 10 files changed, 27 insertions(+), 13 deletions(-)
Hi Stefano,
Le 08/03/2012 08:52, Stefano Babic a écrit :
Hi Albert,
Applied to u-boot-arm/master, thanks.
Amicalement,
Le 26/03/2012 22:45, Albert ARIBAUD a écrit :
Hi Stefano,
Hi Albert,
Amicalement,
Correction: I seem to have misapplied this and the TI tree, so I rolled back my changes...
The imx master branch has moved and no longer starts with the commits above from the base above. Stefano, can you rebase on u-boot-arm and re-issue an up-to-date request?
Amicalement,
Hi Stefano,
Hi Albert,
Amicalement,
Yes, you're right- I had to rebase on u-boot.git because I needed some fixes. I will resend my pull request.
Stefano
Amicalement,
Hi Albert,
please pull from u-boot-imx (rebased on current u-boot-arm).
The following changes since commit cd207cde948ecf9ff50a0fa1ae2650f65579c9c9:
IXP: Fix GPIO_INT_ACT_LOW_SET() (2012-03-26 23:09:26 +0200)
Eric Nelson (4): i.MX6: mx6qsabrelite: add ext2 support mx6q: mx6qsabrelite: setup_spi() should be called in board_init to allow use for environment i.MX6: mx6q_sabrelite: add CONFIG_REVISION_TAG i.MX6: mx6qsabrelite: add MACH_TYPE_MX6Q_SABRELITE
Fabio Estevam (15): mx51evk: Fix CONFIG_SYS_MEMTEST_END mx53evk: Fix CONFIG_SYS_MEMTEST_END mx53smd: Fix CONFIG_SYS_MEMTEST_END efikamx: Fix CONFIG_SYS_MEMTEST_END mx31pdk: Fix CONFIG_SYS_MEMTEST_END mx6: Fix reset cause for Power On Reset case mx6: Remove duplicate definition of ANATOP_BASE_ADDR pmic_i2c: Return error in case of invalid pmic_i2c_tx_num mxs_spi: Return proper timeout error mx6: Read silicon revision from register USB: ehci-mx6: Add proper IO accessors mx28evk: Provide default values for SPI bus and chip select configs: imx: Use CONFIG_SF_DEFAULT_CS mx53: Make PLL2 to be the parent of UART clock mx53ard: Initialize return code with error
Marek Vasut (3): i.MX28: Enable additional DRAM address bits i.MX28: Make the stabilization delays shorter i.MX28: Drop __naked function from spl_mem_init
arch/arm/cpu/arm1136/mx31/generic.c | 2 + arch/arm/cpu/arm926ejs/mx28/spl_mem_init.c | 12 +-- arch/arm/cpu/arm926ejs/mx28/spl_power_init.c | 8 +- arch/arm/cpu/armv7/imx-common/cpu.c | 25 ++++- arch/arm/cpu/armv7/mx5/lowlevel_init.S | 20 +++- arch/arm/cpu/armv7/mx6/soc.c | 8 ++- arch/arm/include/asm/arch-mx6/imx-regs.h | 143 ++++++++++++++++++++++++- board/freescale/mx53ard/mx53ard.c | 2 +- board/freescale/mx6qsabrelite/mx6qsabrelite.c | 13 ++- drivers/misc/pmic_i2c.c | 6 + drivers/spi/mxs_spi.c | 6 +- drivers/usb/host/ehci-mx6.c | 13 +-- include/configs/efikamx.h | 4 +- include/configs/m28evk.h | 2 +- include/configs/mx28evk.h | 2 + include/configs/mx31pdk.h | 2 +- include/configs/mx51evk.h | 2 +- include/configs/mx53evk.h | 2 +- include/configs/mx53smd.h | 2 +- include/configs/mx6qsabrelite.h | 4 + include/configs/vision2.h | 2 +- tools/imximage.c | 18 +++- tools/imximage.h | 1 + 23 files changed, 251 insertions(+), 48 deletions(-)
Hi Stefano,
Le 27/03/2012 09:46, Stefano Babic a écrit :
Hi Albert,
Amicalement,
Albert ARIBAUD
Stefano Babic
