[U-Boot] [PATCH] NAND: cmd_nand.c: fix invalid pointers to static relocated chip names
When U-boot starting from NAND the pointers to chip names are set before relocation. If the original memory block is overwritten after relocation that led to invalid string data in the nand utility.
Signed-off-by: Valeriy Glushkov gvv@lstec.com --- diff --git a/common/cmd_nand.c b/common/cmd_nand.c index b94a2bf..14925cd 100644 --- a/common/cmd_nand.c +++ b/common/cmd_nand.c @@ -10,6 +10,7 @@
#include <common.h>
+DECLARE_GLOBAL_DATA_PTR;
#ifndef CONFIG_NAND_LEGACY /* @@ -193,7 +194,7 @@ int do_nand(cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) for (i = 0; i < CFG_MAX_NAND_DEVICE; i++) { if (nand_info[i].name) printf("Device %d: %s, sector size %u KiB\n", - i, nand_info[i].name, + i, nand_info[i].name + gd->reloc_off, nand_info[i].erasesize >> 10); } return 0; @@ -207,7 +208,7 @@ int do_nand(cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) puts("\nno devices available\n"); else printf("\nDevice %d: %s\n", nand_curr_device, - nand_info[nand_curr_device].name); + nand_info[nand_curr_device].name + gd->reloc_off); return 0; } dev = (int)simple_strtoul(argv[2], NULL, 10); @@ -215,7 +216,7 @@ int do_nand(cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) puts("No such device\n"); return 1; } - printf("Device %d: %s", dev, nand_info[dev].name); + printf("Device %d: %s", dev, nand_info[dev].name + gd->reloc_off); puts("... is now current device\n"); nand_curr_device = dev;
@@ -993,8 +994,8 @@ int do_nandboot (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) show_boot_progress (55);
printf ("\nLoading from device %d: %s at 0x%lx (offset 0x%lx)\n", - dev, nand_dev_desc[dev].name, nand_dev_desc[dev].IO_ADDR, - offset); + dev, nand_dev_desc[dev].name + gd->reloc_off, + nand_dev_desc[dev].IO_ADDR, offset);
if (nand_legacy_rw (nand_dev_desc + dev, NANDRW_READ, offset, SECTORSIZE, NULL, (u_char *)addr)) {
what will happen when it does not start from nand but an other device??
btw please fix you mailer to show your real address in the From
Best Regards, J.
I have not tried it for non-NAND boot, but it should work for any type of boot devices where gd->reloc_off is set properly.
The previous version still works for nay NOR boot, as the non-relocated pointers to static strings are always point to the RO data in the NOR. But for the NAND boot where we start directly from RAM, this happens, because the initial non-relocated memory can be overwritten any time...
Best regards, Valeriy Glushkov
P.S. Sorry for the invalid email address. Fixed.
----- Original Message ----- From: "Jean-Christophe PLAGNIOL-VILLARD" plagnioj@jcrosoft.com To: "Valeriy Glushkov" gvv@lstec.com Cc: u-boot@lists.denx.de Sent: 19 ?????? 2009 ?. 15:05 Subject: Re: [U-Boot] [PATCH] NAND: cmd_nand.c: fix invalid pointers tostatic relocated chip names
Best Regards, J.
gvv@horse.lst.loc
Valeriy Glushkov
