[PATCH v6 00/16] Add Rockchip RK3399 USB3.0 Host support
This series add quirks for DWC3 and add Rockchip RK3399 USB3.0 host support.
The function has been tested pass on rk3399-evb and roc-rk3399-pc board.
For V6 update: - Use [PATCH v6 04/16] instead of [PATCH v5 05/16] to fix that the current Generic PHY subsystem is unable to find PHY if the PHY node is not part of the root structure. - Add 'Reviewed-by' tag for all patches except [PATCH v6 04/16].
For V5 update: - Fix dwc3-generic driver followed Marek's comments for [PATCH v4 12/16]. - Add 'Reviewed-by' and 'Tested-by' tag for [PATCH v4 07/16] and [PATCH v4 08/16].
For V4 update: - Collect Jagan's all fixed patches [1]. - Amend specific u-boot changes from dts to dtsi for [PATCH v3 6/7].
For V3 update: - Fix compile error for [PATCH v2 1/9]. - Use Jagan's Type-C driver instead of [PATCH v2 5/9]. - Cleanup dts changes for [PATCH v2 7/9]. - Cleanup config changes for [PATCH v2 8/9] and [PATCH v2 9/9].
For V2 update: - Amend type-c driver followed Jagan's comments for [PATCH 5/8]. - Fix dts commit for [PATCH 7/8]. - Split RK3399 default config for [PATCH 8/8]. - Add 'Reviewed-by' tag for [PATCH 1/8], [PATCH 2/8] and [PATCH 3/8].
[1] https://patchwork.ozlabs.org/project/uboot/cover/20200506075025.1677-1-jagan...
BR, Frank
Frank Wang (8): arm: mach-rockchip: bind sub-nodes for rk3399_syscon usb: dwc3: add dis_enblslpm_quirk usb: dwc3: add dis_u2_freeclk_exists_quirk usb: dwc3: amend UTMI/UTMIW phy interface setup usb: dwc3: add make compatible for rockchip platform driver: usb: drop legacy rockchip xhci driver ARM: dts: rk3399-evb: usb3.0 host support configs: evb-rk3399: update support usb3.0 host
Jagan Teki (8): clk: rk3399: Enable/Disable the USB2PHY clk clk: rk3399: Set empty for TCPHY assigned-clocks clk: rk3399: Enable/Disable TCPHY clocks phy: rockchip: Add Rockchip USB2PHY driver phy: rockchip: Add Rockchip USB TypeC PHY driver usb: dwc3: Add disable u2mac linestate check quirk usb: dwc3: Enable AutoRetry feature in the controller roc-rk3399-pc: Enable USB3.0 Host
arch/arm/dts/rk3399-evb-u-boot.dtsi | 13 + arch/arm/mach-rockchip/rk3399/syscon_rk3399.c | 3 + configs/evb-rk3399_defconfig | 6 + configs/roc-pc-mezzanine-rk3399_defconfig | 5 + configs/roc-pc-rk3399_defconfig | 6 + drivers/Makefile | 1 + drivers/clk/rockchip/clk_rk3399.c | 38 + drivers/phy/Kconfig | 1 + drivers/phy/rockchip/Kconfig | 21 + drivers/phy/rockchip/Makefile | 7 + drivers/phy/rockchip/phy-rockchip-inno-usb2.c | 312 +++++++ drivers/phy/rockchip/phy-rockchip-typec.c | 796 ++++++++++++++++++ drivers/usb/common/common.c | 25 + drivers/usb/dwc3/core.c | 106 ++- drivers/usb/dwc3/core.h | 19 + drivers/usb/dwc3/dwc3-generic.c | 33 +- drivers/usb/host/Kconfig | 9 - drivers/usb/host/Makefile | 1 - drivers/usb/host/xhci-rockchip.c | 196 ----- include/dwc3-uboot.h | 3 + include/linux/usb/phy.h | 18 + 21 files changed, 1376 insertions(+), 243 deletions(-) create mode 100644 drivers/phy/rockchip/Kconfig create mode 100644 drivers/phy/rockchip/Makefile create mode 100644 drivers/phy/rockchip/phy-rockchip-inno-usb2.c create mode 100644 drivers/phy/rockchip/phy-rockchip-typec.c delete mode 100644 drivers/usb/host/xhci-rockchip.c
Enable/Disable the USB2PHY clk for rk3399.
CLK is clear in enable and set in disable functionality.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- drivers/clk/rockchip/clk_rk3399.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/drivers/clk/rockchip/clk_rk3399.c b/drivers/clk/rockchip/clk_rk3399.c index 5fb72d83c2..b53f2f984e 100644 --- a/drivers/clk/rockchip/clk_rk3399.c +++ b/drivers/clk/rockchip/clk_rk3399.c @@ -1091,6 +1091,12 @@ static int rk3399_clk_enable(struct clk *clk) case SCLK_MACREF_OUT: rk_clrreg(&priv->cru->clkgate_con[5], BIT(6)); break; + case SCLK_USB2PHY0_REF: + rk_clrreg(&priv->cru->clkgate_con[6], BIT(5)); + break; + case SCLK_USB2PHY1_REF: + rk_clrreg(&priv->cru->clkgate_con[6], BIT(6)); + break; case ACLK_GMAC: rk_clrreg(&priv->cru->clkgate_con[32], BIT(0)); break; @@ -1167,6 +1173,12 @@ static int rk3399_clk_disable(struct clk *clk) case SCLK_MACREF_OUT: rk_setreg(&priv->cru->clkgate_con[5], BIT(6)); break; + case SCLK_USB2PHY0_REF: + rk_setreg(&priv->cru->clkgate_con[6], BIT(5)); + break; + case SCLK_USB2PHY1_REF: + rk_setreg(&priv->cru->clkgate_con[6], BIT(6)); + break; case ACLK_GMAC: rk_setreg(&priv->cru->clkgate_con[32], BIT(0)); break;
Due to v5.7-rc1 sync the SD controller nodes in rk3399.dtsi have SCLK_UPHY0_TCPDCORE, SCLK_UPHY1_TCPDCORE assigned-clocks which are usually required for Linux and don't require to handle them in U-Boot.
assigned-clocks = <&cru SCLK_UPHY0_TCPDCORE>; assigned-clocks = <&cru SCLK_UPHY1_TCPDCORE>;
So, mark them as empty in clock otherwise device probe on those typec phy driver would fail.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- drivers/clk/rockchip/clk_rk3399.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/clk/rockchip/clk_rk3399.c b/drivers/clk/rockchip/clk_rk3399.c index b53f2f984e..98fc6a3267 100644 --- a/drivers/clk/rockchip/clk_rk3399.c +++ b/drivers/clk/rockchip/clk_rk3399.c @@ -997,6 +997,8 @@ static ulong rk3399_clk_set_rate(struct clk *clk, ulong rate) case ACLK_VOP1: case HCLK_VOP1: case HCLK_SD: + case SCLK_UPHY0_TCPDCORE: + case SCLK_UPHY1_TCPDCORE: /** * assigned-clocks handling won't require for vopl, so * return 0 to satisfy clk_set_defaults during device probe.
Enable/Disable TCPHY clock for rk3399 platform.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- drivers/clk/rockchip/clk_rk3399.c | 24 ++++++++++++++++++++++++ 1 file changed, 24 insertions(+)
diff --git a/drivers/clk/rockchip/clk_rk3399.c b/drivers/clk/rockchip/clk_rk3399.c index 98fc6a3267..06232f1903 100644 --- a/drivers/clk/rockchip/clk_rk3399.c +++ b/drivers/clk/rockchip/clk_rk3399.c @@ -1144,6 +1144,18 @@ static int rk3399_clk_enable(struct clk *clk) case HCLK_HOST1_ARB: rk_clrreg(&priv->cru->clksel_con[20], BIT(8)); break; + case SCLK_UPHY0_TCPDPHY_REF: + rk_clrreg(&priv->cru->clkgate_con[13], BIT(4)); + break; + case SCLK_UPHY0_TCPDCORE: + rk_clrreg(&priv->cru->clkgate_con[13], BIT(5)); + break; + case SCLK_UPHY1_TCPDPHY_REF: + rk_clrreg(&priv->cru->clkgate_con[13], BIT(6)); + break; + case SCLK_UPHY1_TCPDCORE: + rk_clrreg(&priv->cru->clkgate_con[13], BIT(7)); + break; case SCLK_PCIEPHY_REF: rk_clrreg(&priv->cru->clksel_con[18], BIT(10)); break; @@ -1226,6 +1238,18 @@ static int rk3399_clk_disable(struct clk *clk) case HCLK_HOST1_ARB: rk_setreg(&priv->cru->clksel_con[20], BIT(8)); break; + case SCLK_UPHY0_TCPDPHY_REF: + rk_setreg(&priv->cru->clkgate_con[13], BIT(4)); + break; + case SCLK_UPHY0_TCPDCORE: + rk_setreg(&priv->cru->clkgate_con[13], BIT(5)); + break; + case SCLK_UPHY1_TCPDPHY_REF: + rk_setreg(&priv->cru->clkgate_con[13], BIT(6)); + break; + case SCLK_UPHY1_TCPDCORE: + rk_setreg(&priv->cru->clkgate_con[13], BIT(7)); + break; case SCLK_PCIEPHY_REF: rk_clrreg(&priv->cru->clksel_con[18], BIT(10)); break;
There are some sub-nodes under the grf DT, so add bind callback function in rk3399 syscon driver to scan them recursively.
Signed-off-by: Frank Wang frank.wang@rock-chips.com --- arch/arm/mach-rockchip/rk3399/syscon_rk3399.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/mach-rockchip/rk3399/syscon_rk3399.c b/arch/arm/mach-rockchip/rk3399/syscon_rk3399.c index 259ca44d68..f27b0ced82 100644 --- a/arch/arm/mach-rockchip/rk3399/syscon_rk3399.c +++ b/arch/arm/mach-rockchip/rk3399/syscon_rk3399.c @@ -20,6 +20,9 @@ static const struct udevice_id rk3399_syscon_ids[] = { U_BOOT_DRIVER(syscon_rk3399) = { .name = "rk3399_syscon", .id = UCLASS_SYSCON, +#if !CONFIG_IS_ENABLED(OF_PLATDATA) + .bind = dm_scan_fdt_dev, +#endif .of_match = rk3399_syscon_ids, };
Reviewed-by: Jagan Teki jagan@amarulasolutions.com Tested-by: Jagan Teki jagan@amarulasolutions.com # roc-rk3399-pc
Thanks, - Kever
- .bind = dm_scan_fdt_dev,
Add Rockchip USB2PHY driver with initial support.
This will help to use it for EHCI controller in host mode, and USB 3.0 controller in otg mode.
More functionality like charge, vbus detection will add it in future changes.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: Frank Wang frank.wang@rock-chips.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- drivers/Makefile | 1 + drivers/phy/Kconfig | 1 + drivers/phy/rockchip/Kconfig | 14 + drivers/phy/rockchip/Makefile | 6 + drivers/phy/rockchip/phy-rockchip-inno-usb2.c | 312 ++++++++++++++++++ 5 files changed, 334 insertions(+) create mode 100644 drivers/phy/rockchip/Kconfig create mode 100644 drivers/phy/rockchip/Makefile create mode 100644 drivers/phy/rockchip/phy-rockchip-inno-usb2.c
diff --git a/drivers/Makefile b/drivers/Makefile index 4208750428..94e8c5da17 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -91,6 +91,7 @@ obj-y += dfu/ obj-$(CONFIG_PCH) += pch/ obj-y += phy/allwinner/ obj-y += phy/marvell/ +obj-y += phy/rockchip/ obj-y += rtc/ obj-y += scsi/ obj-y += sound/ diff --git a/drivers/phy/Kconfig b/drivers/phy/Kconfig index 1e38c8741f..9c775107e9 100644 --- a/drivers/phy/Kconfig +++ b/drivers/phy/Kconfig @@ -225,4 +225,5 @@ config PHY_MTK_TPHY multi-ports is first version, otherwise is second veriosn, so you can easily distinguish them by banks layout.
+source "drivers/phy/rockchip/Kconfig" endmenu diff --git a/drivers/phy/rockchip/Kconfig b/drivers/phy/rockchip/Kconfig new file mode 100644 index 0000000000..d73ac695e1 --- /dev/null +++ b/drivers/phy/rockchip/Kconfig @@ -0,0 +1,14 @@ +# +# Phy drivers for Rockchip platforms +# + +menu "Rockchip PHY driver" + +config PHY_ROCKCHIP_INNO_USB2 + bool "Rockchip INNO USB2PHY Driver" + depends on ARCH_ROCKCHIP + select PHY + help + Support for Rockchip USB2.0 PHY with Innosilicon IP block. + +endmenu diff --git a/drivers/phy/rockchip/Makefile b/drivers/phy/rockchip/Makefile new file mode 100644 index 0000000000..9b0cbc6acf --- /dev/null +++ b/drivers/phy/rockchip/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2020 Amarula Solutions(India) +# + +obj-$(CONFIG_PHY_ROCKCHIP_INNO_USB2) += phy-rockchip-inno-usb2.o diff --git a/drivers/phy/rockchip/phy-rockchip-inno-usb2.c b/drivers/phy/rockchip/phy-rockchip-inno-usb2.c new file mode 100644 index 0000000000..c5ea6ca31f --- /dev/null +++ b/drivers/phy/rockchip/phy-rockchip-inno-usb2.c @@ -0,0 +1,312 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * Rockchip USB2.0 PHY with Innosilicon IP block driver + * + * Copyright (C) 2016 Fuzhou Rockchip Electronics Co., Ltd + * Copyright (C) 2020 Amarula Solutions(India) + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <dm/lists.h> +#include <generic-phy.h> +#include <reset.h> +#include <syscon.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <linux/iopoll.h> +#include <asm/arch-rockchip/clock.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define usleep_range(a, b) udelay((b)) +#define BIT_WRITEABLE_SHIFT 16 + +enum rockchip_usb2phy_port_id { + USB2PHY_PORT_OTG, + USB2PHY_PORT_HOST, + USB2PHY_NUM_PORTS, +}; + +struct usb2phy_reg { + unsigned int offset; + unsigned int bitend; + unsigned int bitstart; + unsigned int disable; + unsigned int enable; +}; + +struct rockchip_usb2phy_port_cfg { + struct usb2phy_reg phy_sus; + struct usb2phy_reg bvalid_det_en; + struct usb2phy_reg bvalid_det_st; + struct usb2phy_reg bvalid_det_clr; + struct usb2phy_reg ls_det_en; + struct usb2phy_reg ls_det_st; + struct usb2phy_reg ls_det_clr; + struct usb2phy_reg utmi_avalid; + struct usb2phy_reg utmi_bvalid; + struct usb2phy_reg utmi_ls; + struct usb2phy_reg utmi_hstdet; +}; + +struct rockchip_usb2phy_cfg { + unsigned int reg; + const struct rockchip_usb2phy_port_cfg port_cfgs[USB2PHY_NUM_PORTS]; +}; + +struct rockchip_usb2phy { + void *reg_base; + struct clk phyclk; + const struct rockchip_usb2phy_cfg *phy_cfg; +}; + +static inline int property_enable(void *reg_base, + const struct usb2phy_reg *reg, bool en) +{ + unsigned int val, mask, tmp; + + tmp = en ? reg->enable : reg->disable; + mask = GENMASK(reg->bitend, reg->bitstart); + val = (tmp << reg->bitstart) | (mask << BIT_WRITEABLE_SHIFT); + + return writel(val, reg_base + reg->offset); +} + +static const +struct rockchip_usb2phy_port_cfg *us2phy_get_port(struct phy *phy) +{ + struct udevice *parent = dev_get_parent(phy->dev); + struct rockchip_usb2phy *priv = dev_get_priv(parent); + const struct rockchip_usb2phy_cfg *phy_cfg = priv->phy_cfg; + + return &phy_cfg->port_cfgs[phy->id]; +} + +static int rockchip_usb2phy_power_on(struct phy *phy) +{ + struct udevice *parent = dev_get_parent(phy->dev); + struct rockchip_usb2phy *priv = dev_get_priv(parent); + const struct rockchip_usb2phy_port_cfg *port_cfg = us2phy_get_port(phy); + + property_enable(priv->reg_base, &port_cfg->phy_sus, false); + + /* waiting for the utmi_clk to become stable */ + usleep_range(1500, 2000); + + return 0; +} + +static int rockchip_usb2phy_power_off(struct phy *phy) +{ + struct udevice *parent = dev_get_parent(phy->dev); + struct rockchip_usb2phy *priv = dev_get_priv(parent); + const struct rockchip_usb2phy_port_cfg *port_cfg = us2phy_get_port(phy); + + property_enable(priv->reg_base, &port_cfg->phy_sus, true); + + return 0; +} + +static int rockchip_usb2phy_init(struct phy *phy) +{ + struct udevice *parent = dev_get_parent(phy->dev); + struct rockchip_usb2phy *priv = dev_get_priv(parent); + const struct rockchip_usb2phy_port_cfg *port_cfg = us2phy_get_port(phy); + int ret; + + ret = clk_enable(&priv->phyclk); + if (ret) { + dev_err(phy->dev, "failed to enable phyclk (ret=%d)\n", ret); + return ret; + } + + if (phy->id == USB2PHY_PORT_OTG) { + property_enable(priv->reg_base, &port_cfg->bvalid_det_clr, true); + property_enable(priv->reg_base, &port_cfg->bvalid_det_en, true); + } else if (phy->id == USB2PHY_PORT_HOST) { + property_enable(priv->reg_base, &port_cfg->bvalid_det_clr, true); + property_enable(priv->reg_base, &port_cfg->bvalid_det_en, true); + } + + return 0; +} + +static int rockchip_usb2phy_exit(struct phy *phy) +{ + struct udevice *parent = dev_get_parent(phy->dev); + struct rockchip_usb2phy *priv = dev_get_priv(parent); + + clk_disable(&priv->phyclk); + + return 0; +} + +static int rockchip_usb2phy_of_xlate(struct phy *phy, + struct ofnode_phandle_args *args) +{ + const char *name = phy->dev->name; + + if (!strcasecmp(name, "host-port")) + phy->id = USB2PHY_PORT_HOST; + else if (!strcasecmp(name, "otg-port")) + phy->id = USB2PHY_PORT_OTG; + else + dev_err(phy->dev, "improper %s device\n", name); + + return 0; +} + +static struct phy_ops rockchip_usb2phy_ops = { + .init = rockchip_usb2phy_init, + .exit = rockchip_usb2phy_exit, + .power_on = rockchip_usb2phy_power_on, + .power_off = rockchip_usb2phy_power_off, + .of_xlate = rockchip_usb2phy_of_xlate, +}; + +static int rockchip_usb2phy_probe(struct udevice *dev) +{ + struct rockchip_usb2phy *priv = dev_get_priv(dev); + const struct rockchip_usb2phy_cfg *phy_cfgs; + unsigned int reg; + int index, ret; + + priv->reg_base = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); + if (IS_ERR(priv->reg_base)) + return PTR_ERR(priv->reg_base); + + ret = ofnode_read_u32(dev_ofnode(dev), "reg", ®); + if (ret) { + dev_err(dev, "failed to read reg property (ret = %d)\n", ret); + return ret; + } + + phy_cfgs = (const struct rockchip_usb2phy_cfg *) + dev_get_driver_data(dev); + if (!phy_cfgs) + return -EINVAL; + + /* find out a proper config which can be matched with dt. */ + index = 0; + while (phy_cfgs[index].reg) { + if (phy_cfgs[index].reg == reg) { + priv->phy_cfg = &phy_cfgs[index]; + break; + } + + ++index; + } + + if (!priv->phy_cfg) { + dev_err(dev, "failed find proper phy-cfg\n"); + return -EINVAL; + } + + ret = clk_get_by_name(dev, "phyclk", &priv->phyclk); + if (ret) { + dev_err(dev, "failed to get the phyclk (ret=%d)\n", ret); + return ret; + } + + return 0; +} + +static int rockchip_usb2phy_bind(struct udevice *dev) +{ + struct udevice *usb2phy_dev; + ofnode node; + const char *name; + int ret = 0; + + dev_for_each_subnode(node, dev) { + if (!ofnode_valid(node)) { + dev_info(dev, "subnode %s not found\n", dev->name); + return -ENXIO; + } + + name = ofnode_get_name(node); + dev_dbg(dev, "subnode %s\n", name); + + ret = device_bind_driver_to_node(dev, "rockchip_usb2phy_port", + name, node, &usb2phy_dev); + if (ret) { + dev_err(dev, + "'%s' cannot bind 'rockchip_usb2phy_port'\n", name); + return ret; + } + } + + return ret; +} + +static const struct rockchip_usb2phy_cfg rk3399_usb2phy_cfgs[] = { + { + .reg = 0xe450, + .port_cfgs = { + [USB2PHY_PORT_OTG] = { + .phy_sus = { 0xe454, 1, 0, 2, 1 }, + .bvalid_det_en = { 0xe3c0, 3, 3, 0, 1 }, + .bvalid_det_st = { 0xe3e0, 3, 3, 0, 1 }, + .bvalid_det_clr = { 0xe3d0, 3, 3, 0, 1 }, + .utmi_avalid = { 0xe2ac, 7, 7, 0, 1 }, + .utmi_bvalid = { 0xe2ac, 12, 12, 0, 1 }, + }, + [USB2PHY_PORT_HOST] = { + .phy_sus = { 0xe458, 1, 0, 0x2, 0x1 }, + .ls_det_en = { 0xe3c0, 6, 6, 0, 1 }, + .ls_det_st = { 0xe3e0, 6, 6, 0, 1 }, + .ls_det_clr = { 0xe3d0, 6, 6, 0, 1 }, + .utmi_ls = { 0xe2ac, 22, 21, 0, 1 }, + .utmi_hstdet = { 0xe2ac, 23, 23, 0, 1 } + } + }, + }, + { + .reg = 0xe460, + .port_cfgs = { + [USB2PHY_PORT_OTG] = { + .phy_sus = { 0xe464, 1, 0, 2, 1 }, + .bvalid_det_en = { 0xe3c0, 8, 8, 0, 1 }, + .bvalid_det_st = { 0xe3e0, 8, 8, 0, 1 }, + .bvalid_det_clr = { 0xe3d0, 8, 8, 0, 1 }, + .utmi_avalid = { 0xe2ac, 10, 10, 0, 1 }, + .utmi_bvalid = { 0xe2ac, 16, 16, 0, 1 }, + }, + [USB2PHY_PORT_HOST] = { + .phy_sus = { 0xe468, 1, 0, 0x2, 0x1 }, + .ls_det_en = { 0xe3c0, 11, 11, 0, 1 }, + .ls_det_st = { 0xe3e0, 11, 11, 0, 1 }, + .ls_det_clr = { 0xe3d0, 11, 11, 0, 1 }, + .utmi_ls = { 0xe2ac, 26, 25, 0, 1 }, + .utmi_hstdet = { 0xe2ac, 27, 27, 0, 1 } + } + }, + }, + { /* sentinel */ } +}; + +static const struct udevice_id rockchip_usb2phy_ids[] = { + { + .compatible = "rockchip,rk3399-usb2phy", + .data = (ulong)&rk3399_usb2phy_cfgs, + }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(rockchip_usb2phy_port) = { + .name = "rockchip_usb2phy_port", + .id = UCLASS_PHY, + .ops = &rockchip_usb2phy_ops, +}; + +U_BOOT_DRIVER(rockchip_usb2phy) = { + .name = "rockchip_usb2phy", + .id = UCLASS_PHY, + .of_match = rockchip_usb2phy_ids, + .probe = rockchip_usb2phy_probe, + .bind = rockchip_usb2phy_bind, + .priv_auto_alloc_size = sizeof(struct rockchip_usb2phy), +};
Add USB TYPEC PHY driver for rockchip platform.
Referenced from Linux TypeC PHY driver, currently supporting usb3-port and dp-port need to add it in the future.
Signed-off-by: Frank Wang frank.wang@rock-chips.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- drivers/phy/rockchip/Kconfig | 7 + drivers/phy/rockchip/Makefile | 1 + drivers/phy/rockchip/phy-rockchip-typec.c | 796 ++++++++++++++++++++++ 3 files changed, 804 insertions(+) create mode 100644 drivers/phy/rockchip/phy-rockchip-typec.c
diff --git a/drivers/phy/rockchip/Kconfig b/drivers/phy/rockchip/Kconfig index d73ac695e1..84cc7c876d 100644 --- a/drivers/phy/rockchip/Kconfig +++ b/drivers/phy/rockchip/Kconfig @@ -11,4 +11,11 @@ config PHY_ROCKCHIP_INNO_USB2 help Support for Rockchip USB2.0 PHY with Innosilicon IP block.
+config PHY_ROCKCHIP_TYPEC + bool "Rockchip TYPEC PHY Driver" + depends on ARCH_ROCKCHIP + select PHY + help + Enable this to support the Rockchip USB TYPEC PHY. + endmenu diff --git a/drivers/phy/rockchip/Makefile b/drivers/phy/rockchip/Makefile index 9b0cbc6acf..95b2f8a3c0 100644 --- a/drivers/phy/rockchip/Makefile +++ b/drivers/phy/rockchip/Makefile @@ -4,3 +4,4 @@ #
obj-$(CONFIG_PHY_ROCKCHIP_INNO_USB2) += phy-rockchip-inno-usb2.o +obj-$(CONFIG_PHY_ROCKCHIP_TYPEC) += phy-rockchip-typec.o diff --git a/drivers/phy/rockchip/phy-rockchip-typec.c b/drivers/phy/rockchip/phy-rockchip-typec.c new file mode 100644 index 0000000000..c9c8e1c542 --- /dev/null +++ b/drivers/phy/rockchip/phy-rockchip-typec.c @@ -0,0 +1,796 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * ROCKCHIP Type-C PHY driver. + * + * Copyright (C) 2020 Amarula Solutions(India) + * Copyright (C) Fuzhou Rockchip Electronics Co.Ltd + * Author: Chris Zhong zyw@rock-chips.com + * Kever Yang kever.yang@rock-chips.com + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <dm/lists.h> +#include <generic-phy.h> +#include <reset.h> +#include <syscon.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <linux/iopoll.h> +#include <asm/arch-rockchip/clock.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define usleep_range(a, b) udelay((b)) + +#define CMN_SSM_BANDGAP (0x21 << 2) +#define CMN_SSM_BIAS (0x22 << 2) +#define CMN_PLLSM0_PLLEN (0x29 << 2) +#define CMN_PLLSM0_PLLPRE (0x2a << 2) +#define CMN_PLLSM0_PLLVREF (0x2b << 2) +#define CMN_PLLSM0_PLLLOCK (0x2c << 2) +#define CMN_PLLSM1_PLLEN (0x31 << 2) +#define CMN_PLLSM1_PLLPRE (0x32 << 2) +#define CMN_PLLSM1_PLLVREF (0x33 << 2) +#define CMN_PLLSM1_PLLLOCK (0x34 << 2) +#define CMN_PLLSM1_USER_DEF_CTRL (0x37 << 2) +#define CMN_ICAL_OVRD (0xc1 << 2) +#define CMN_PLL0_VCOCAL_OVRD (0x83 << 2) +#define CMN_PLL0_VCOCAL_INIT (0x84 << 2) +#define CMN_PLL0_VCOCAL_ITER (0x85 << 2) +#define CMN_PLL0_LOCK_REFCNT_START (0x90 << 2) +#define CMN_PLL0_LOCK_PLLCNT_START (0x92 << 2) +#define CMN_PLL0_LOCK_PLLCNT_THR (0x93 << 2) +#define CMN_PLL0_INTDIV (0x94 << 2) +#define CMN_PLL0_FRACDIV (0x95 << 2) +#define CMN_PLL0_HIGH_THR (0x96 << 2) +#define CMN_PLL0_DSM_DIAG (0x97 << 2) +#define CMN_PLL0_SS_CTRL1 (0x98 << 2) +#define CMN_PLL0_SS_CTRL2 (0x99 << 2) +#define CMN_PLL1_VCOCAL_START (0xa1 << 2) +#define CMN_PLL1_VCOCAL_OVRD (0xa3 << 2) +#define CMN_PLL1_VCOCAL_INIT (0xa4 << 2) +#define CMN_PLL1_VCOCAL_ITER (0xa5 << 2) +#define CMN_PLL1_LOCK_REFCNT_START (0xb0 << 2) +#define CMN_PLL1_LOCK_PLLCNT_START (0xb2 << 2) +#define CMN_PLL1_LOCK_PLLCNT_THR (0xb3 << 2) +#define CMN_PLL1_INTDIV (0xb4 << 2) +#define CMN_PLL1_FRACDIV (0xb5 << 2) +#define CMN_PLL1_HIGH_THR (0xb6 << 2) +#define CMN_PLL1_DSM_DIAG (0xb7 << 2) +#define CMN_PLL1_SS_CTRL1 (0xb8 << 2) +#define CMN_PLL1_SS_CTRL2 (0xb9 << 2) +#define CMN_RXCAL_OVRD (0xd1 << 2) + +#define CMN_TXPUCAL_CTRL (0xe0 << 2) +#define CMN_TXPUCAL_OVRD (0xe1 << 2) +#define CMN_TXPDCAL_CTRL (0xf0 << 2) +#define CMN_TXPDCAL_OVRD (0xf1 << 2) + +/* For CMN_TXPUCAL_CTRL, CMN_TXPDCAL_CTRL */ +#define CMN_TXPXCAL_START BIT(15) +#define CMN_TXPXCAL_DONE BIT(14) +#define CMN_TXPXCAL_NO_RESPONSE BIT(13) +#define CMN_TXPXCAL_CURRENT_RESPONSE BIT(12) + +#define CMN_TXPU_ADJ_CTRL (0x108 << 2) +#define CMN_TXPD_ADJ_CTRL (0x10c << 2) + +/* + * For CMN_TXPUCAL_CTRL, CMN_TXPDCAL_CTRL, + * CMN_TXPU_ADJ_CTRL, CMN_TXPDCAL_CTRL + * + * NOTE: some of these registers are documented to be 2's complement + * signed numbers, but then documented to be always positive. Weird. + * In such a case, using CMN_CALIB_CODE_POS() avoids the unnecessary + * sign extension. + */ +#define CMN_CALIB_CODE_WIDTH 7 +#define CMN_CALIB_CODE_OFFSET 0 +#define CMN_CALIB_CODE_MASK GENMASK(CMN_CALIB_CODE_WIDTH, 0) +#define CMN_CALIB_CODE(x) \ + sign_extend32((x) >> CMN_CALIB_CODE_OFFSET, CMN_CALIB_CODE_WIDTH) + +#define CMN_CALIB_CODE_POS_MASK GENMASK(CMN_CALIB_CODE_WIDTH - 1, 0) +#define CMN_CALIB_CODE_POS(x) \ + (((x) >> CMN_CALIB_CODE_OFFSET) & CMN_CALIB_CODE_POS_MASK) + +#define CMN_DIAG_PLL0_FBH_OVRD (0x1c0 << 2) +#define CMN_DIAG_PLL0_FBL_OVRD (0x1c1 << 2) +#define CMN_DIAG_PLL0_OVRD (0x1c2 << 2) +#define CMN_DIAG_PLL0_V2I_TUNE (0x1c5 << 2) +#define CMN_DIAG_PLL0_CP_TUNE (0x1c6 << 2) +#define CMN_DIAG_PLL0_LF_PROG (0x1c7 << 2) +#define CMN_DIAG_PLL1_FBH_OVRD (0x1d0 << 2) +#define CMN_DIAG_PLL1_FBL_OVRD (0x1d1 << 2) +#define CMN_DIAG_PLL1_OVRD (0x1d2 << 2) +#define CMN_DIAG_PLL1_V2I_TUNE (0x1d5 << 2) +#define CMN_DIAG_PLL1_CP_TUNE (0x1d6 << 2) +#define CMN_DIAG_PLL1_LF_PROG (0x1d7 << 2) +#define CMN_DIAG_PLL1_PTATIS_TUNE1 (0x1d8 << 2) +#define CMN_DIAG_PLL1_PTATIS_TUNE2 (0x1d9 << 2) +#define CMN_DIAG_PLL1_INCLK_CTRL (0x1da << 2) +#define CMN_DIAG_HSCLK_SEL (0x1e0 << 2) + +#define XCVR_PSM_RCTRL(n) ((0x4001 | ((n) << 9)) << 2) +#define XCVR_PSM_CAL_TMR(n) ((0x4002 | ((n) << 9)) << 2) +#define XCVR_PSM_A0IN_TMR(n) ((0x4003 | ((n) << 9)) << 2) +#define TX_TXCC_CAL_SCLR_MULT(n) ((0x4047 | ((n) << 9)) << 2) +#define TX_TXCC_CPOST_MULT_00(n) ((0x404c | ((n) << 9)) << 2) +#define TX_TXCC_CPOST_MULT_01(n) ((0x404d | ((n) << 9)) << 2) +#define TX_TXCC_CPOST_MULT_10(n) ((0x404e | ((n) << 9)) << 2) +#define TX_TXCC_CPOST_MULT_11(n) ((0x404f | ((n) << 9)) << 2) +#define TX_TXCC_MGNFS_MULT_000(n) ((0x4050 | ((n) << 9)) << 2) +#define TX_TXCC_MGNFS_MULT_001(n) ((0x4051 | ((n) << 9)) << 2) +#define TX_TXCC_MGNFS_MULT_010(n) ((0x4052 | ((n) << 9)) << 2) +#define TX_TXCC_MGNFS_MULT_011(n) ((0x4053 | ((n) << 9)) << 2) +#define TX_TXCC_MGNFS_MULT_100(n) ((0x4054 | ((n) << 9)) << 2) +#define TX_TXCC_MGNFS_MULT_101(n) ((0x4055 | ((n) << 9)) << 2) +#define TX_TXCC_MGNFS_MULT_110(n) ((0x4056 | ((n) << 9)) << 2) +#define TX_TXCC_MGNFS_MULT_111(n) ((0x4057 | ((n) << 9)) << 2) +#define TX_TXCC_MGNLS_MULT_000(n) ((0x4058 | ((n) << 9)) << 2) +#define TX_TXCC_MGNLS_MULT_001(n) ((0x4059 | ((n) << 9)) << 2) +#define TX_TXCC_MGNLS_MULT_010(n) ((0x405a | ((n) << 9)) << 2) +#define TX_TXCC_MGNLS_MULT_011(n) ((0x405b | ((n) << 9)) << 2) +#define TX_TXCC_MGNLS_MULT_100(n) ((0x405c | ((n) << 9)) << 2) +#define TX_TXCC_MGNLS_MULT_101(n) ((0x405d | ((n) << 9)) << 2) +#define TX_TXCC_MGNLS_MULT_110(n) ((0x405e | ((n) << 9)) << 2) +#define TX_TXCC_MGNLS_MULT_111(n) ((0x405f | ((n) << 9)) << 2) + +#define XCVR_DIAG_PLLDRC_CTRL(n) ((0x40e0 | ((n) << 9)) << 2) +#define XCVR_DIAG_BIDI_CTRL(n) ((0x40e8 | ((n) << 9)) << 2) +#define XCVR_DIAG_LANE_FCM_EN_MGN(n) ((0x40f2 | ((n) << 9)) << 2) +#define TX_PSC_A0(n) ((0x4100 | ((n) << 9)) << 2) +#define TX_PSC_A1(n) ((0x4101 | ((n) << 9)) << 2) +#define TX_PSC_A2(n) ((0x4102 | ((n) << 9)) << 2) +#define TX_PSC_A3(n) ((0x4103 | ((n) << 9)) << 2) +#define TX_RCVDET_CTRL(n) ((0x4120 | ((n) << 9)) << 2) +#define TX_RCVDET_EN_TMR(n) ((0x4122 | ((n) << 9)) << 2) +#define TX_RCVDET_ST_TMR(n) ((0x4123 | ((n) << 9)) << 2) +#define TX_DIAG_TX_DRV(n) ((0x41e1 | ((n) << 9)) << 2) +#define TX_DIAG_BGREF_PREDRV_DELAY (0x41e7 << 2) + +/* Use this for "n" in macros like "_MULT_XXX" to target the aux channel */ +#define AUX_CH_LANE 8 + +#define TX_ANA_CTRL_REG_1 (0x5020 << 2) + +#define TXDA_DP_AUX_EN BIT(15) +#define AUXDA_SE_EN BIT(14) +#define TXDA_CAL_LATCH_EN BIT(13) +#define AUXDA_POLARITY BIT(12) +#define TXDA_DRV_POWER_ISOLATION_EN BIT(11) +#define TXDA_DRV_POWER_EN_PH_2_N BIT(10) +#define TXDA_DRV_POWER_EN_PH_1_N BIT(9) +#define TXDA_BGREF_EN BIT(8) +#define TXDA_DRV_LDO_EN BIT(7) +#define TXDA_DECAP_EN_DEL BIT(6) +#define TXDA_DECAP_EN BIT(5) +#define TXDA_UPHY_SUPPLY_EN_DEL BIT(4) +#define TXDA_UPHY_SUPPLY_EN BIT(3) +#define TXDA_LOW_LEAKAGE_EN BIT(2) +#define TXDA_DRV_IDLE_LOWI_EN BIT(1) +#define TXDA_DRV_CMN_MODE_EN BIT(0) + +#define TX_ANA_CTRL_REG_2 (0x5021 << 2) + +#define AUXDA_DEBOUNCING_CLK BIT(15) +#define TXDA_LPBK_RECOVERED_CLK_EN BIT(14) +#define TXDA_LPBK_ISI_GEN_EN BIT(13) +#define TXDA_LPBK_SERIAL_EN BIT(12) +#define TXDA_LPBK_LINE_EN BIT(11) +#define TXDA_DRV_LDO_REDC_SINKIQ BIT(10) +#define XCVR_DECAP_EN_DEL BIT(9) +#define XCVR_DECAP_EN BIT(8) +#define TXDA_MPHY_ENABLE_HS_NT BIT(7) +#define TXDA_MPHY_SA_MODE BIT(6) +#define TXDA_DRV_LDO_RBYR_FB_EN BIT(5) +#define TXDA_DRV_RST_PULL_DOWN BIT(4) +#define TXDA_DRV_LDO_BG_FB_EN BIT(3) +#define TXDA_DRV_LDO_BG_REF_EN BIT(2) +#define TXDA_DRV_PREDRV_EN_DEL BIT(1) +#define TXDA_DRV_PREDRV_EN BIT(0) + +#define TXDA_COEFF_CALC_CTRL (0x5022 << 2) + +#define TX_HIGH_Z BIT(6) +#define TX_VMARGIN_OFFSET 3 +#define TX_VMARGIN_MASK 0x7 +#define LOW_POWER_SWING_EN BIT(2) +#define TX_FCM_DRV_MAIN_EN BIT(1) +#define TX_FCM_FULL_MARGIN BIT(0) + +#define TX_DIG_CTRL_REG_2 (0x5024 << 2) + +#define TX_HIGH_Z_TM_EN BIT(15) +#define TX_RESCAL_CODE_OFFSET 0 +#define TX_RESCAL_CODE_MASK 0x3f + +#define TXDA_CYA_AUXDA_CYA (0x5025 << 2) +#define TX_ANA_CTRL_REG_3 (0x5026 << 2) +#define TX_ANA_CTRL_REG_4 (0x5027 << 2) +#define TX_ANA_CTRL_REG_5 (0x5029 << 2) + +#define RX_PSC_A0(n) ((0x8000 | ((n) << 9)) << 2) +#define RX_PSC_A1(n) ((0x8001 | ((n) << 9)) << 2) +#define RX_PSC_A2(n) ((0x8002 | ((n) << 9)) << 2) +#define RX_PSC_A3(n) ((0x8003 | ((n) << 9)) << 2) +#define RX_PSC_CAL(n) ((0x8006 | ((n) << 9)) << 2) +#define RX_PSC_RDY(n) ((0x8007 | ((n) << 9)) << 2) +#define RX_IQPI_ILL_CAL_OVRD (0x8023 << 2) +#define RX_EPI_ILL_CAL_OVRD (0x8033 << 2) +#define RX_SDCAL0_OVRD (0x8041 << 2) +#define RX_SDCAL1_OVRD (0x8049 << 2) +#define RX_SLC_INIT (0x806d << 2) +#define RX_SLC_RUN (0x806e << 2) +#define RX_CDRLF_CNFG2 (0x8081 << 2) +#define RX_SIGDET_HL_FILT_TMR(n) ((0x8090 | ((n) << 9)) << 2) +#define RX_SLC_IOP0_OVRD (0x8101 << 2) +#define RX_SLC_IOP1_OVRD (0x8105 << 2) +#define RX_SLC_QOP0_OVRD (0x8109 << 2) +#define RX_SLC_QOP1_OVRD (0x810d << 2) +#define RX_SLC_EOP0_OVRD (0x8111 << 2) +#define RX_SLC_EOP1_OVRD (0x8115 << 2) +#define RX_SLC_ION0_OVRD (0x8119 << 2) +#define RX_SLC_ION1_OVRD (0x811d << 2) +#define RX_SLC_QON0_OVRD (0x8121 << 2) +#define RX_SLC_QON1_OVRD (0x8125 << 2) +#define RX_SLC_EON0_OVRD (0x8129 << 2) +#define RX_SLC_EON1_OVRD (0x812d << 2) +#define RX_SLC_IEP0_OVRD (0x8131 << 2) +#define RX_SLC_IEP1_OVRD (0x8135 << 2) +#define RX_SLC_QEP0_OVRD (0x8139 << 2) +#define RX_SLC_QEP1_OVRD (0x813d << 2) +#define RX_SLC_EEP0_OVRD (0x8141 << 2) +#define RX_SLC_EEP1_OVRD (0x8145 << 2) +#define RX_SLC_IEN0_OVRD (0x8149 << 2) +#define RX_SLC_IEN1_OVRD (0x814d << 2) +#define RX_SLC_QEN0_OVRD (0x8151 << 2) +#define RX_SLC_QEN1_OVRD (0x8155 << 2) +#define RX_SLC_EEN0_OVRD (0x8159 << 2) +#define RX_SLC_EEN1_OVRD (0x815d << 2) +#define RX_REE_CTRL_DATA_MASK(n) ((0x81bb | ((n) << 9)) << 2) +#define RX_DIAG_SIGDET_TUNE(n) ((0x81dc | ((n) << 9)) << 2) +#define RX_DIAG_SC2C_DELAY (0x81e1 << 2) + +#define PMA_LANE_CFG (0xc000 << 2) +#define PIPE_CMN_CTRL1 (0xc001 << 2) +#define PIPE_CMN_CTRL2 (0xc002 << 2) +#define PIPE_COM_LOCK_CFG1 (0xc003 << 2) +#define PIPE_COM_LOCK_CFG2 (0xc004 << 2) +#define PIPE_RCV_DET_INH (0xc005 << 2) +#define DP_MODE_CTL (0xc008 << 2) +#define DP_CLK_CTL (0xc009 << 2) +#define STS (0xc00F << 2) +#define PHY_ISO_CMN_CTRL (0xc010 << 2) +#define PHY_DP_TX_CTL (0xc408 << 2) +#define PMA_CMN_CTRL1 (0xc800 << 2) +#define PHY_PMA_ISO_CMN_CTRL (0xc810 << 2) +#define PHY_ISOLATION_CTRL (0xc81f << 2) +#define PHY_PMA_ISO_XCVR_CTRL(n) ((0xcc11 | ((n) << 6)) << 2) +#define PHY_PMA_ISO_LINK_MODE(n) ((0xcc12 | ((n) << 6)) << 2) +#define PHY_PMA_ISO_PWRST_CTRL(n) ((0xcc13 | ((n) << 6)) << 2) +#define PHY_PMA_ISO_TX_DATA_LO(n) ((0xcc14 | ((n) << 6)) << 2) +#define PHY_PMA_ISO_TX_DATA_HI(n) ((0xcc15 | ((n) << 6)) << 2) +#define PHY_PMA_ISO_RX_DATA_LO(n) ((0xcc16 | ((n) << 6)) << 2) +#define PHY_PMA_ISO_RX_DATA_HI(n) ((0xcc17 | ((n) << 6)) << 2) +#define TX_BIST_CTRL(n) ((0x4140 | ((n) << 9)) << 2) +#define TX_BIST_UDDWR(n) ((0x4141 | ((n) << 9)) << 2) + +/* + * Selects which PLL clock will be driven on the analog high speed + * clock 0: PLL 0 div 1 + * clock 1: PLL 1 div 2 + */ +#define CLK_PLL_CONFIG 0X30 +#define CLK_PLL_MASK 0x33 + +#define CMN_READY BIT(0) + +#define DP_PLL_CLOCK_ENABLE BIT(2) +#define DP_PLL_ENABLE BIT(0) +#define DP_PLL_DATA_RATE_RBR ((2 << 12) | (4 << 8)) +#define DP_PLL_DATA_RATE_HBR ((2 << 12) | (4 << 8)) +#define DP_PLL_DATA_RATE_HBR2 ((1 << 12) | (2 << 8)) + +#define DP_MODE_A0 BIT(4) +#define DP_MODE_A2 BIT(6) +#define DP_MODE_ENTER_A0 0xc101 +#define DP_MODE_ENTER_A2 0xc104 + +#define PHY_MODE_SET_TIMEOUT 100000 + +#define PIN_ASSIGN_C_E 0x51d9 +#define PIN_ASSIGN_D_F 0x5100 + +#define MODE_DISCONNECT 0 +#define MODE_UFP_USB BIT(0) +#define MODE_DFP_USB BIT(1) +#define MODE_DFP_DP BIT(2) + +struct usb3phy_reg { + u32 offset; + u32 enable_bit; + u32 write_enable; +}; + +/** + * struct rockchip_usb3phy_port_cfg: usb3-phy port configuration. + * @reg: the base address for usb3-phy config. + * @typec_conn_dir: the register of type-c connector direction. + * @usb3tousb2_en: the register of type-c force usb2 to usb2 enable. + * @external_psm: the register of type-c phy external psm clock. + * @pipe_status: the register of type-c phy pipe status. + * @usb3_host_disable: the register of type-c usb3 host disable. + * @usb3_host_port: the register of type-c usb3 host port. + * @uphy_dp_sel: the register of type-c phy DP select control. + */ +struct rockchip_usb3phy_port_cfg { + unsigned int reg; + struct usb3phy_reg typec_conn_dir; + struct usb3phy_reg usb3tousb2_en; + struct usb3phy_reg external_psm; + struct usb3phy_reg pipe_status; + struct usb3phy_reg usb3_host_disable; + struct usb3phy_reg usb3_host_port; + struct usb3phy_reg uphy_dp_sel; +}; + +struct rockchip_tcphy { + void __iomem *reg_base; + void __iomem *grf_base; + struct clk clk_core; + struct clk clk_ref; + struct reset_ctl uphy_rst; + struct reset_ctl pipe_rst; + struct reset_ctl tcphy_rst; + const struct rockchip_usb3phy_port_cfg *port_cfgs; + u8 mode; +}; + +struct phy_reg { + u16 value; + u32 addr; +}; + +static struct phy_reg usb3_pll_cfg[] = { + { 0xf0, CMN_PLL0_VCOCAL_INIT }, + { 0x18, CMN_PLL0_VCOCAL_ITER }, + { 0xd0, CMN_PLL0_INTDIV }, + { 0x4a4a, CMN_PLL0_FRACDIV }, + { 0x34, CMN_PLL0_HIGH_THR }, + { 0x1ee, CMN_PLL0_SS_CTRL1 }, + { 0x7f03, CMN_PLL0_SS_CTRL2 }, + { 0x20, CMN_PLL0_DSM_DIAG }, + { 0, CMN_DIAG_PLL0_OVRD }, + { 0, CMN_DIAG_PLL0_FBH_OVRD }, + { 0, CMN_DIAG_PLL0_FBL_OVRD }, + { 0x7, CMN_DIAG_PLL0_V2I_TUNE }, + { 0x45, CMN_DIAG_PLL0_CP_TUNE }, + { 0x8, CMN_DIAG_PLL0_LF_PROG }, +}; + +static inline int property_enable(struct rockchip_tcphy *priv, + const struct usb3phy_reg *reg, bool en) +{ + u32 mask = 1 << reg->write_enable; + u32 val = en << reg->enable_bit; + + return writel(val | mask, priv->grf_base + reg->offset); +} + +static int rockchip_tcphy_get_mode(struct rockchip_tcphy *priv) +{ + /* TODO: Add proper logic to find DP or USB3 mode */ + return MODE_DFP_USB | MODE_UFP_USB; +} + +static void rockchip_tcphy_cfg_24m(struct rockchip_tcphy *priv) +{ + u32 i, rdata; + + /* + * cmn_ref_clk_sel = 3, select the 24Mhz for clk parent + * cmn_psm_clk_dig_div = 2, set the clk division to 2 + */ + writel(0x830, priv->reg_base + PMA_CMN_CTRL1); + for (i = 0; i < 4; i++) { + /* + * The following PHY configuration assumes a 24 MHz reference + * clock. + */ + writel(0x90, priv->reg_base + XCVR_DIAG_LANE_FCM_EN_MGN(i)); + writel(0x960, priv->reg_base + TX_RCVDET_EN_TMR(i)); + writel(0x30, priv->reg_base + TX_RCVDET_ST_TMR(i)); + } + + rdata = readl(priv->reg_base + CMN_DIAG_HSCLK_SEL); + rdata &= ~CLK_PLL_MASK; + rdata |= CLK_PLL_CONFIG; + writel(rdata, priv->reg_base + CMN_DIAG_HSCLK_SEL); +} + +static void rockchip_tcphy_cfg_usb3_pll(struct rockchip_tcphy *priv) +{ + u32 i; + + /* load the configuration of PLL0 */ + for (i = 0; i < ARRAY_SIZE(usb3_pll_cfg); i++) + writel(usb3_pll_cfg[i].value, + priv->reg_base + usb3_pll_cfg[i].addr); +} + +static void rockchip_tcphy_tx_usb3_cfg_lane(struct rockchip_tcphy *priv, + u32 lane) +{ + writel(0x7799, priv->reg_base + TX_PSC_A0(lane)); + writel(0x7798, priv->reg_base + TX_PSC_A1(lane)); + writel(0x5098, priv->reg_base + TX_PSC_A2(lane)); + writel(0x5098, priv->reg_base + TX_PSC_A3(lane)); + writel(0, priv->reg_base + TX_TXCC_MGNFS_MULT_000(lane)); + writel(0xbf, priv->reg_base + XCVR_DIAG_BIDI_CTRL(lane)); +} + +static void rockchip_tcphy_rx_usb3_cfg_lane(struct rockchip_tcphy *priv, + u32 lane) +{ + writel(0xa6fd, priv->reg_base + RX_PSC_A0(lane)); + writel(0xa6fd, priv->reg_base + RX_PSC_A1(lane)); + writel(0xa410, priv->reg_base + RX_PSC_A2(lane)); + writel(0x2410, priv->reg_base + RX_PSC_A3(lane)); + writel(0x23ff, priv->reg_base + RX_PSC_CAL(lane)); + writel(0x13, priv->reg_base + RX_SIGDET_HL_FILT_TMR(lane)); + writel(0x03e7, priv->reg_base + RX_REE_CTRL_DATA_MASK(lane)); + writel(0x1004, priv->reg_base + RX_DIAG_SIGDET_TUNE(lane)); + writel(0x2010, priv->reg_base + RX_PSC_RDY(lane)); + writel(0xfb, priv->reg_base + XCVR_DIAG_BIDI_CTRL(lane)); +} + +static int rockchip_tcphy_init(struct rockchip_tcphy *priv) +{ + const struct rockchip_usb3phy_port_cfg *cfg = priv->port_cfgs; + u32 val; + int ret; + + ret = clk_enable(&priv->clk_core); + if (ret) { + dev_err(phy->dev, "failed to enable core clk (ret=%d)\n", ret); + return ret; + } + + ret = clk_enable(&priv->clk_ref); + if (ret) { + dev_err(phy->dev, "failed to enable ref clk (ret=%d)\n", ret); + goto err_clk_core; + } + + ret = reset_deassert(&priv->tcphy_rst); + if (ret) { + dev_err(phy->dev, "failed to deassert uphy-tcphy reset (ret=%d)\n", + ret); + goto err_clk_ref; + } + + property_enable(priv, &cfg->typec_conn_dir, 0); + + rockchip_tcphy_cfg_24m(priv); + + rockchip_tcphy_cfg_usb3_pll(priv); + + rockchip_tcphy_tx_usb3_cfg_lane(priv, 0); + rockchip_tcphy_rx_usb3_cfg_lane(priv, 1); + + ret = reset_deassert(&priv->uphy_rst); + if (ret) { + dev_err(phy->dev, "failed to deassert uphy rst (ret=%d)\n", + ret); + goto err_tcphy_rst; + } + + ret = readl_poll_sleep_timeout(priv->reg_base + PMA_CMN_CTRL1, + val, val & CMN_READY, 10, + PHY_MODE_SET_TIMEOUT); + if (ret < 0) { + dev_err(phy->dev, "PMA Timeout!\n"); + ret = -ETIMEDOUT; + goto err_uphy_rst; + } + + ret = reset_deassert(&priv->pipe_rst); + if (ret) { + dev_err(phy->dev, "failed to deassert pipe rst (ret=%d)\n", + ret); + goto err_uphy_rst; + } + + return 0; + +err_uphy_rst: + reset_assert(&priv->uphy_rst); +err_tcphy_rst: + reset_assert(&priv->tcphy_rst); +err_clk_ref: + clk_disable(&priv->clk_ref); +err_clk_core: + clk_disable(&priv->clk_core); + return ret; +} + +static void rockchip_tcphy_exit(struct rockchip_tcphy *priv) +{ + reset_assert(&priv->tcphy_rst); + reset_assert(&priv->uphy_rst); + reset_assert(&priv->pipe_rst); + clk_disable(&priv->clk_core); + clk_disable(&priv->clk_ref); +} + +static int tcphy_cfg_usb3_to_usb2_only(struct rockchip_tcphy *priv, + bool value) +{ + const struct rockchip_usb3phy_port_cfg *cfg = priv->port_cfgs; + + property_enable(priv, &cfg->usb3tousb2_en, value); + property_enable(priv, &cfg->usb3_host_disable, value); + property_enable(priv, &cfg->usb3_host_port, !value); + + return 0; +} + +static int rockchip_usb3_phy_power_on(struct phy *phy) +{ + struct udevice *parent = dev_get_parent(phy->dev); + struct rockchip_tcphy *priv = dev_get_priv(parent); + const struct rockchip_usb3phy_port_cfg *cfg = priv->port_cfgs; + const struct usb3phy_reg *reg = &cfg->pipe_status; + int timeout, new_mode; + u32 val; + int ret; + + new_mode = rockchip_tcphy_get_mode(priv); + if (new_mode < 0) { + dev_err(phy->dev, "invalid mode %d\n", new_mode); + return new_mode; + } + + if (priv->mode == new_mode) + return 0; + + if (priv->mode == MODE_DISCONNECT) { + ret = rockchip_tcphy_init(priv); + if (ret) { + dev_err(dev, "failed to init tcphy (ret=%d)\n", ret); + return ret; + } + } + + /* wait TCPHY for pipe ready */ + for (timeout = 0; timeout < 100; timeout++) { + val = readl(priv->grf_base + reg->offset); + if (!(val & BIT(reg->enable_bit))) { + priv->mode |= new_mode & (MODE_DFP_USB | MODE_UFP_USB); + + /* enable usb3 host */ + tcphy_cfg_usb3_to_usb2_only(priv, false); + return 0; + } + usleep_range(10, 20); + } + + if (priv->mode == MODE_DISCONNECT) + rockchip_tcphy_exit(priv); + + return -ETIMEDOUT; +} + +static int rockchip_usb3_phy_power_off(struct phy *phy) +{ + struct udevice *parent = dev_get_parent(phy->dev); + struct rockchip_tcphy *priv = dev_get_priv(parent); + + tcphy_cfg_usb3_to_usb2_only(priv, false); + + if (priv->mode == MODE_DISCONNECT) + goto exit; + + priv->mode &= ~(MODE_UFP_USB | MODE_DFP_USB); + if (priv->mode == MODE_DISCONNECT) + rockchip_tcphy_exit(priv); + +exit: + return 0; +} + +static struct phy_ops rockchip_tcphy_usb3_ops = { + .power_on = rockchip_usb3_phy_power_on, + .power_off = rockchip_usb3_phy_power_off, +}; + +static void rockchip_tcphy_pre_init(struct udevice *dev) +{ + struct rockchip_tcphy *priv = dev_get_priv(dev); + const struct rockchip_usb3phy_port_cfg *cfg = priv->port_cfgs; + + reset_assert(&priv->tcphy_rst); + reset_assert(&priv->uphy_rst); + reset_assert(&priv->pipe_rst); + + /* select external psm clock */ + property_enable(priv, &cfg->external_psm, 1); + property_enable(priv, &cfg->usb3tousb2_en, 0); + + priv->mode = MODE_DISCONNECT; +} + +static int rockchip_tcphy_parse_dt(struct udevice *dev) +{ + struct rockchip_tcphy *priv = dev_get_priv(dev); + int ret; + + priv->grf_base = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); + if (IS_ERR(priv->grf_base)) + return PTR_ERR(priv->grf_base); + + ret = clk_get_by_name(dev, "tcpdcore", &priv->clk_core); + if (ret) { + dev_err(dev, "failed to get tcpdcore clk (ret=%d)\n", ret); + return ret; + } + + ret = clk_get_by_name(dev, "tcpdphy-ref", &priv->clk_ref); + if (ret) { + dev_err(dev, "failed to get tcpdphy-ref clk (ret=%d)\n", ret); + return ret; + } + + ret = reset_get_by_name(dev, "uphy", &priv->uphy_rst); + if (ret) { + dev_err(dev, "failed to get uphy reset (ret=%d)\n", ret); + return ret; + } + + ret = reset_get_by_name(dev, "uphy-pipe", &priv->pipe_rst); + if (ret) { + dev_err(dev, "failed to get uphy-pipe reset (ret=%d)\n", ret); + return ret; + } + + ret = reset_get_by_name(dev, "uphy-tcphy", &priv->tcphy_rst); + if (ret) { + dev_err(dev, "failed to get uphy-tcphy reset (ret=%d)\n", ret); + return ret; + } + + return 0; +} + +static int rockchip_tcphy_probe(struct udevice *dev) +{ + struct rockchip_tcphy *priv = dev_get_priv(dev); + const struct rockchip_usb3phy_port_cfg *phy_cfgs; + unsigned int reg; + int index, ret; + + priv->reg_base = (void __iomem *)dev_read_addr(dev); + if (IS_ERR(priv->reg_base)) + return PTR_ERR(priv->reg_base); + + ret = dev_read_u32_index(dev, "reg", 1, ®); + if (ret) { + dev_err(dev, "failed to read reg property (ret = %d)\n", ret); + return ret; + } + + phy_cfgs = (const struct rockchip_usb3phy_port_cfg *) + dev_get_driver_data(dev); + if (!phy_cfgs) + return -EINVAL; + + /* find out a proper config which can be matched with dt. */ + index = 0; + while (phy_cfgs[index].reg) { + if (phy_cfgs[index].reg == reg) { + priv->port_cfgs = &phy_cfgs[index]; + break; + } + + ++index; + } + + if (!priv->port_cfgs) { + dev_err(dev, "failed find proper phy-cfg\n"); + return -EINVAL; + } + + ret = rockchip_tcphy_parse_dt(dev); + if (ret) + return ret; + + rockchip_tcphy_pre_init(dev); + + return 0; +} + +static int rockchip_tcphy_bind(struct udevice *dev) +{ + struct udevice *tcphy_dev; + ofnode node; + const char *name; + int ret = 0; + + dev_for_each_subnode(node, dev) { + if (!ofnode_valid(node)) { + dev_info(dev, "subnode %s not found\n", dev->name); + return -ENXIO; + } + + name = ofnode_get_name(node); + dev_dbg(dev, "subnode %s\n", name); + + if (!strcasecmp(name, "dp-port")) { + dev_dbg(dev, "Warning: dp-port not supported yet!\n"); + continue; + } else if (!strcasecmp(name, "usb3-port")) { + ret = device_bind_driver_to_node(dev, + "rockchip_tcphy_usb3_port", + name, node, &tcphy_dev); + if (ret) { + dev_err(dev, + "'%s' cannot bind 'rockchip_tcphy_usb3_port'\n", + name); + return ret; + } + } + } + + return ret; +} + +static const struct rockchip_usb3phy_port_cfg rk3399_typec_phy_cfgs[] = { + { + .reg = 0xff7c0000, + .typec_conn_dir = { 0xe580, 0, 16 }, + .usb3tousb2_en = { 0xe580, 3, 19 }, + .external_psm = { 0xe588, 14, 30 }, + .pipe_status = { 0xe5c0, 0, 0 }, + .usb3_host_disable = { 0x2434, 0, 16 }, + .usb3_host_port = { 0x2434, 12, 28 }, + .uphy_dp_sel = { 0x6268, 19, 19 }, + }, + { + .reg = 0xff800000, + .typec_conn_dir = { 0xe58c, 0, 16 }, + .usb3tousb2_en = { 0xe58c, 3, 19 }, + .external_psm = { 0xe594, 14, 30 }, + .pipe_status = { 0xe5c0, 16, 16 }, + .usb3_host_disable = { 0x2444, 0, 16 }, + .usb3_host_port = { 0x2444, 12, 28 }, + .uphy_dp_sel = { 0x6268, 3, 19 }, + }, + { /* sentinel */ } +}; + +static const struct udevice_id rockchip_typec_phy_ids[] = { + { + .compatible = "rockchip,rk3399-typec-phy", + .data = (ulong)&rk3399_typec_phy_cfgs, + }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(rockchip_tcphy_usb3_port) = { + .name = "rockchip_tcphy_usb3_port", + .id = UCLASS_PHY, + .ops = &rockchip_tcphy_usb3_ops, +}; + +U_BOOT_DRIVER(rockchip_typec_phy) = { + .name = "rockchip_typec_phy", + .id = UCLASS_PHY, + .of_match = rockchip_typec_phy_ids, + .probe = rockchip_tcphy_probe, + .bind = rockchip_tcphy_bind, + .priv_auto_alloc_size = sizeof(struct rockchip_tcphy), +};
Add a quirk to clear the GUSB2PHYCFG.ENBLSLPM bit, which controls whether the PHY receives the suspend signal from the controller.
Refer to commit ec791d149bca("usb: dwc3: Add dis_enblslpm_quirk") in Linux Kernel.
Signed-off-by: Frank Wang frank.wang@rock-chips.com Reviewed-by: Kever Yang kever.yang@rock-chips.com Reviewed-by: Jagan Teki jagan@amarulasolutions.com Tested-by: Jagan Teki jagan@amarulasolutions.com --- drivers/usb/dwc3/core.c | 6 ++++++ drivers/usb/dwc3/core.h | 2 ++ include/dwc3-uboot.h | 1 + 3 files changed, 9 insertions(+)
diff --git a/drivers/usb/dwc3/core.c b/drivers/usb/dwc3/core.c index 0972e458eb..20be617fd4 100644 --- a/drivers/usb/dwc3/core.c +++ b/drivers/usb/dwc3/core.c @@ -398,6 +398,9 @@ static void dwc3_phy_setup(struct dwc3 *dwc) if (dwc->dis_u2_susphy_quirk) reg &= ~DWC3_GUSB2PHYCFG_SUSPHY;
+ if (dwc->dis_enblslpm_quirk) + reg &= ~DWC3_GUSB2PHYCFG_ENBLSLPM; + dwc3_writel(dwc->regs, DWC3_GUSB2PHYCFG(0), reg);
mdelay(100); @@ -719,6 +722,7 @@ int dwc3_uboot_init(struct dwc3_device *dwc3_dev) dwc->dis_u3_susphy_quirk = dwc3_dev->dis_u3_susphy_quirk; dwc->dis_u2_susphy_quirk = dwc3_dev->dis_u2_susphy_quirk; dwc->dis_del_phy_power_chg_quirk = dwc3_dev->dis_del_phy_power_chg_quirk; + dwc->dis_enblslpm_quirk = dwc3_dev->dis_enblslpm_quirk;
dwc->tx_de_emphasis_quirk = dwc3_dev->tx_de_emphasis_quirk; if (dwc3_dev->tx_de_emphasis) @@ -926,6 +930,8 @@ void dwc3_of_parse(struct dwc3 *dwc) "snps,dis_u2_susphy_quirk"); dwc->dis_del_phy_power_chg_quirk = dev_read_bool(dev, "snps,dis-del-phy-power-chg-quirk"); + dwc->dis_enblslpm_quirk = dev_read_bool(dev, + "snps,dis_enblslpm_quirk"); dwc->tx_de_emphasis_quirk = dev_read_bool(dev, "snps,tx_de_emphasis_quirk"); tmp = dev_read_u8_array_ptr(dev, "snps,tx_de_emphasis", 1); diff --git a/drivers/usb/dwc3/core.h b/drivers/usb/dwc3/core.h index 7f45a9c459..e76e357f1e 100644 --- a/drivers/usb/dwc3/core.h +++ b/drivers/usb/dwc3/core.h @@ -162,6 +162,7 @@ /* Global USB2 PHY Configuration Register */ #define DWC3_GUSB2PHYCFG_PHYSOFTRST (1 << 31) #define DWC3_GUSB2PHYCFG_SUSPHY (1 << 6) +#define DWC3_GUSB2PHYCFG_ENBLSLPM (1 << 8) #define DWC3_GUSB2PHYCFG_PHYIF(n) ((n) << 3) #define DWC3_GUSB2PHYCFG_PHYIF_MASK DWC3_GUSB2PHYCFG_PHYIF(1) #define DWC3_GUSB2PHYCFG_USBTRDTIM(n) ((n) << 10) @@ -822,6 +823,7 @@ struct dwc3 { unsigned dis_u3_susphy_quirk:1; unsigned dis_u2_susphy_quirk:1; unsigned dis_del_phy_power_chg_quirk:1; + unsigned dis_enblslpm_quirk:1;
unsigned tx_de_emphasis_quirk:1; unsigned tx_de_emphasis:2; diff --git a/include/dwc3-uboot.h b/include/dwc3-uboot.h index ecae34bf06..98d51e05e1 100644 --- a/include/dwc3-uboot.h +++ b/include/dwc3-uboot.h @@ -34,6 +34,7 @@ struct dwc3_device { unsigned dis_u3_susphy_quirk; unsigned dis_u2_susphy_quirk; unsigned dis_del_phy_power_chg_quirk; + unsigned dis_enblslpm_quirk; unsigned tx_de_emphasis_quirk; unsigned tx_de_emphasis; int index;
Add a quirk to clear the GUSB2PHYCFG.U2_FREECLK_EXISTS bit, which specifies whether the USB2.0 PHY provides a free-running PHY clock, which is active when the clock control input is active.
Refer to commit 27f83eeb6b42("usb: dwc3: add dis_u2_freeclk_exists_quirk") in Linux Rockchip Kernel.
diff --git a/drivers/usb/dwc3/core.c b/drivers/usb/dwc3/core.c index 20be617fd4..3cb66515a2 100644 --- a/drivers/usb/dwc3/core.c +++ b/drivers/usb/dwc3/core.c @@ -401,6 +401,9 @@ static void dwc3_phy_setup(struct dwc3 *dwc) if (dwc->dis_enblslpm_quirk) reg &= ~DWC3_GUSB2PHYCFG_ENBLSLPM;
+ if (dwc->dis_u2_freeclk_exists_quirk) + reg &= ~DWC3_GUSB2PHYCFG_U2_FREECLK_EXISTS; + dwc3_writel(dwc->regs, DWC3_GUSB2PHYCFG(0), reg);
mdelay(100); @@ -723,6 +726,7 @@ int dwc3_uboot_init(struct dwc3_device *dwc3_dev) dwc->dis_u2_susphy_quirk = dwc3_dev->dis_u2_susphy_quirk; dwc->dis_del_phy_power_chg_quirk = dwc3_dev->dis_del_phy_power_chg_quirk; dwc->dis_enblslpm_quirk = dwc3_dev->dis_enblslpm_quirk; + dwc->dis_u2_freeclk_exists_quirk = dwc3_dev->dis_u2_freeclk_exists_quirk;
dwc->tx_de_emphasis_quirk = dwc3_dev->tx_de_emphasis_quirk; if (dwc3_dev->tx_de_emphasis) @@ -932,6 +936,8 @@ void dwc3_of_parse(struct dwc3 *dwc) "snps,dis-del-phy-power-chg-quirk"); dwc->dis_enblslpm_quirk = dev_read_bool(dev, "snps,dis_enblslpm_quirk"); + dwc->dis_u2_freeclk_exists_quirk = dev_read_bool(dev, + "snps,dis-u2-freeclk-exists-quirk"); dwc->tx_de_emphasis_quirk = dev_read_bool(dev, "snps,tx_de_emphasis_quirk"); tmp = dev_read_u8_array_ptr(dev, "snps,tx_de_emphasis", 1); diff --git a/drivers/usb/dwc3/core.h b/drivers/usb/dwc3/core.h index e76e357f1e..c5e656885a 100644 --- a/drivers/usb/dwc3/core.h +++ b/drivers/usb/dwc3/core.h @@ -161,6 +161,7 @@
/* Global USB2 PHY Configuration Register */ #define DWC3_GUSB2PHYCFG_PHYSOFTRST (1 << 31) +#define DWC3_GUSB2PHYCFG_U2_FREECLK_EXISTS (1 << 30) #define DWC3_GUSB2PHYCFG_SUSPHY (1 << 6) #define DWC3_GUSB2PHYCFG_ENBLSLPM (1 << 8) #define DWC3_GUSB2PHYCFG_PHYIF(n) ((n) << 3) @@ -824,6 +825,7 @@ struct dwc3 { unsigned dis_u2_susphy_quirk:1; unsigned dis_del_phy_power_chg_quirk:1; unsigned dis_enblslpm_quirk:1; + unsigned dis_u2_freeclk_exists_quirk:1;
unsigned tx_de_emphasis_quirk:1; unsigned tx_de_emphasis:2; diff --git a/include/dwc3-uboot.h b/include/dwc3-uboot.h index 98d51e05e1..193d225d31 100644 --- a/include/dwc3-uboot.h +++ b/include/dwc3-uboot.h @@ -35,6 +35,7 @@ struct dwc3_device { unsigned dis_u2_susphy_quirk; unsigned dis_del_phy_power_chg_quirk; unsigned dis_enblslpm_quirk; + unsigned dis_u2_freeclk_exists_quirk; unsigned tx_de_emphasis_quirk; unsigned tx_de_emphasis; int index;
This patch adds a quirk to disable USB 2.0 MAC linestate check during HS transmit. Refer the dwc3 databook, we can use it for some special platforms if the linestate not reflect the expected line state(J) during transmission.
When use this quirk, the controller implements a fixed 40-bit TxEndDelay after the packet is given on UTMI and ignores the linestate during the transmit of a token (during token-to-token and token-to-data IPGAP).
On some rockchip platforms (e.g. rk3399), it requires to disable the u2mac linestate check to decrease the SSPLIT token to SETUP token inter-packet delay from 566ns to 466ns, and fix the issue that FS/LS devices not recognized if inserted through USB 3.0 HUB.
Reference from below Linux commit,
commit <65db7a0c9816> ("usb: dwc3: add disable u2mac linestate check quirk")
Cc: Marek Vasut marex@denx.de Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- drivers/usb/dwc3/core.c | 20 ++++++++++++++++++++ drivers/usb/dwc3/core.h | 7 +++++++ include/dwc3-uboot.h | 1 + 3 files changed, 28 insertions(+)
diff --git a/drivers/usb/dwc3/core.c b/drivers/usb/dwc3/core.c index 3cb66515a2..dc92f471c1 100644 --- a/drivers/usb/dwc3/core.c +++ b/drivers/usb/dwc3/core.c @@ -725,6 +725,7 @@ int dwc3_uboot_init(struct dwc3_device *dwc3_dev) dwc->dis_u3_susphy_quirk = dwc3_dev->dis_u3_susphy_quirk; dwc->dis_u2_susphy_quirk = dwc3_dev->dis_u2_susphy_quirk; dwc->dis_del_phy_power_chg_quirk = dwc3_dev->dis_del_phy_power_chg_quirk; + dwc->dis_tx_ipgap_linecheck_quirk = dwc3_dev->dis_tx_ipgap_linecheck_quirk; dwc->dis_enblslpm_quirk = dwc3_dev->dis_enblslpm_quirk; dwc->dis_u2_freeclk_exists_quirk = dwc3_dev->dis_u2_freeclk_exists_quirk;
@@ -934,6 +935,8 @@ void dwc3_of_parse(struct dwc3 *dwc) "snps,dis_u2_susphy_quirk"); dwc->dis_del_phy_power_chg_quirk = dev_read_bool(dev, "snps,dis-del-phy-power-chg-quirk"); + dwc->dis_tx_ipgap_linecheck_quirk = dev_read_bool(dev, + "snps,dis-tx-ipgap-linecheck-quirk"); dwc->dis_enblslpm_quirk = dev_read_bool(dev, "snps,dis_enblslpm_quirk"); dwc->dis_u2_freeclk_exists_quirk = dev_read_bool(dev, @@ -954,6 +957,7 @@ void dwc3_of_parse(struct dwc3 *dwc) int dwc3_init(struct dwc3 *dwc) { int ret; + u32 reg;
dwc3_cache_hwparams(dwc);
@@ -975,6 +979,22 @@ int dwc3_init(struct dwc3 *dwc) goto event_fail; }
+ if (dwc->revision >= DWC3_REVISION_250A) { + reg = dwc3_readl(dwc->regs, DWC3_GUCTL1); + + /* + * Enable hardware control of sending remote wakeup + * in HS when the device is in the L1 state. + */ + if (dwc->revision >= DWC3_REVISION_290A) + reg |= DWC3_GUCTL1_DEV_L1_EXIT_BY_HW; + + if (dwc->dis_tx_ipgap_linecheck_quirk) + reg |= DWC3_GUCTL1_TX_IPGAP_LINECHECK_DIS; + + dwc3_writel(dwc->regs, DWC3_GUCTL1, reg); + } + ret = dwc3_core_init_mode(dwc); if (ret) goto mode_fail; diff --git a/drivers/usb/dwc3/core.h b/drivers/usb/dwc3/core.h index c5e656885a..b510d8a983 100644 --- a/drivers/usb/dwc3/core.h +++ b/drivers/usb/dwc3/core.h @@ -73,6 +73,7 @@ #define DWC3_GCTL 0xc110 #define DWC3_GEVTEN 0xc114 #define DWC3_GSTS 0xc118 +#define DWC3_GUCTL1 0xc11c #define DWC3_GSNPSID 0xc120 #define DWC3_GGPIO 0xc124 #define DWC3_GUID 0xc128 @@ -159,6 +160,10 @@ #define DWC3_GCTL_GBLHIBERNATIONEN (1 << 1) #define DWC3_GCTL_DSBLCLKGTNG (1 << 0)
+/* Global User Control 1 Register */ +#define DWC3_GUCTL1_TX_IPGAP_LINECHECK_DIS BIT(28) +#define DWC3_GUCTL1_DEV_L1_EXIT_BY_HW BIT(24) + /* Global USB2 PHY Configuration Register */ #define DWC3_GUSB2PHYCFG_PHYSOFTRST (1 << 31) #define DWC3_GUSB2PHYCFG_U2_FREECLK_EXISTS (1 << 30) @@ -771,6 +776,7 @@ struct dwc3 { #define DWC3_REVISION_260A 0x5533260a #define DWC3_REVISION_270A 0x5533270a #define DWC3_REVISION_280A 0x5533280a +#define DWC3_REVISION_290A 0x5533290a
enum dwc3_ep0_next ep0_next_event; enum dwc3_ep0_state ep0state; @@ -824,6 +830,7 @@ struct dwc3 { unsigned dis_u3_susphy_quirk:1; unsigned dis_u2_susphy_quirk:1; unsigned dis_del_phy_power_chg_quirk:1; + unsigned dis_tx_ipgap_linecheck_quirk:1; unsigned dis_enblslpm_quirk:1; unsigned dis_u2_freeclk_exists_quirk:1;
diff --git a/include/dwc3-uboot.h b/include/dwc3-uboot.h index 193d225d31..e08530ec4e 100644 --- a/include/dwc3-uboot.h +++ b/include/dwc3-uboot.h @@ -34,6 +34,7 @@ struct dwc3_device { unsigned dis_u3_susphy_quirk; unsigned dis_u2_susphy_quirk; unsigned dis_del_phy_power_chg_quirk; + unsigned dis_tx_ipgap_linecheck_quirk; unsigned dis_enblslpm_quirk; unsigned dis_u2_freeclk_exists_quirk; unsigned tx_de_emphasis_quirk;
By default when core sees any transaction error (CRC or overflow) it replies with terminating retry ACK (Retry=1 and Nump == 0).
Enabling this Auto Retry feature in controller will make the core send a non-terminanting ACK upon such transaction errors. That is, ACK TP with Retry=1 and Nump != 0.
Doing so will give controller a chance to recover from transient error conditions.
commit <b138e23d3dff> ("usb: dwc3: core: Enable AutoRetry feature in the controller")
Cc: Marek Vasut marex@denx.de Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- drivers/usb/dwc3/core.c | 9 +++++++++ drivers/usb/dwc3/core.h | 3 +++ 2 files changed, 12 insertions(+)
diff --git a/drivers/usb/dwc3/core.c b/drivers/usb/dwc3/core.c index dc92f471c1..aab6c34c2d 100644 --- a/drivers/usb/dwc3/core.c +++ b/drivers/usb/dwc3/core.c @@ -995,6 +995,15 @@ int dwc3_init(struct dwc3 *dwc) dwc3_writel(dwc->regs, DWC3_GUCTL1, reg); }
+ if (dwc->dr_mode == USB_DR_MODE_HOST || + dwc->dr_mode == USB_DR_MODE_OTG) { + reg = dwc3_readl(dwc->regs, DWC3_GUCTL); + + reg |= DWC3_GUCTL_HSTINAUTORETRY; + + dwc3_writel(dwc->regs, DWC3_GUCTL, reg); + } + ret = dwc3_core_init_mode(dwc); if (ret) goto mode_fail; diff --git a/drivers/usb/dwc3/core.h b/drivers/usb/dwc3/core.h index b510d8a983..2adcaf0029 100644 --- a/drivers/usb/dwc3/core.h +++ b/drivers/usb/dwc3/core.h @@ -160,6 +160,9 @@ #define DWC3_GCTL_GBLHIBERNATIONEN (1 << 1) #define DWC3_GCTL_DSBLCLKGTNG (1 << 0)
+/* Global User Control Register */ +#define DWC3_GUCTL_HSTINAUTORETRY BIT(14) + /* Global User Control 1 Register */ #define DWC3_GUCTL1_TX_IPGAP_LINECHECK_DIS BIT(28) #define DWC3_GUCTL1_DEV_L1_EXIT_BY_HW BIT(24)
Let move 8/16-bit UTMI+ interface initialization into DWC3 core init that is convenient for both DM_USB and u-boot traditional process.
Signed-off-by: Frank Wang frank.wang@rock-chips.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- drivers/usb/common/common.c | 25 ++++++++++++++ drivers/usb/dwc3/core.c | 65 +++++++++++++++++++------------------ drivers/usb/dwc3/core.h | 5 +++ include/linux/usb/phy.h | 18 ++++++++++ 4 files changed, 82 insertions(+), 31 deletions(-)
diff --git a/drivers/usb/common/common.c b/drivers/usb/common/common.c index 0db281b970..d4ae18693c 100644 --- a/drivers/usb/common/common.c +++ b/drivers/usb/common/common.c @@ -10,6 +10,7 @@ #include <dm.h> #include <linux/usb/otg.h> #include <linux/usb/ch9.h> +#include <linux/usb/phy.h>
@@ -64,3 +65,27 @@ enum usb_device_speed usb_get_maximum_speed(ofnode node)
return USB_SPEED_UNKNOWN; } + +#if CONFIG_IS_ENABLED(DM_USB) +static const char *const usbphy_modes[] = { + [USBPHY_INTERFACE_MODE_UNKNOWN] = "", + [USBPHY_INTERFACE_MODE_UTMI] = "utmi", + [USBPHY_INTERFACE_MODE_UTMIW] = "utmi_wide", +}; + +enum usb_phy_interface usb_get_phy_mode(ofnode node) +{ + const char *phy_type; + int i; + + phy_type = ofnode_get_property(node, "phy_type", NULL); + if (!phy_type) + return USBPHY_INTERFACE_MODE_UNKNOWN; + + for (i = 0; i < ARRAY_SIZE(usbphy_modes); i++) + if (!strcmp(phy_type, usbphy_modes[i])) + return i; + + return USBPHY_INTERFACE_MODE_UNKNOWN; +} +#endif diff --git a/drivers/usb/dwc3/core.c b/drivers/usb/dwc3/core.c index aab6c34c2d..c8cb9e13b2 100644 --- a/drivers/usb/dwc3/core.c +++ b/drivers/usb/dwc3/core.c @@ -334,6 +334,34 @@ static void dwc3_cache_hwparams(struct dwc3 *dwc) parms->hwparams8 = dwc3_readl(dwc->regs, DWC3_GHWPARAMS8); }
+static void dwc3_hsphy_mode_setup(struct dwc3 *dwc) +{ + enum usb_phy_interface hsphy_mode = dwc->hsphy_mode; + u32 reg; + + /* Set dwc3 usb2 phy config */ + reg = dwc3_readl(dwc->regs, DWC3_GUSB2PHYCFG(0)); + + switch (hsphy_mode) { + case USBPHY_INTERFACE_MODE_UTMI: + reg &= ~(DWC3_GUSB2PHYCFG_PHYIF_MASK | + DWC3_GUSB2PHYCFG_USBTRDTIM_MASK); + reg |= DWC3_GUSB2PHYCFG_PHYIF(UTMI_PHYIF_8_BIT) | + DWC3_GUSB2PHYCFG_USBTRDTIM(USBTRDTIM_UTMI_8_BIT); + break; + case USBPHY_INTERFACE_MODE_UTMIW: + reg &= ~(DWC3_GUSB2PHYCFG_PHYIF_MASK | + DWC3_GUSB2PHYCFG_USBTRDTIM_MASK); + reg |= DWC3_GUSB2PHYCFG_PHYIF(UTMI_PHYIF_16_BIT) | + DWC3_GUSB2PHYCFG_USBTRDTIM(USBTRDTIM_UTMI_16_BIT); + break; + default: + break; + } + + dwc3_writel(dwc->regs, DWC3_GUSB2PHYCFG(0), reg); +} + /** * dwc3_phy_setup - Configure USB PHY Interface of DWC3 Core * @dwc: Pointer to our controller context structure @@ -382,6 +410,8 @@ static void dwc3_phy_setup(struct dwc3 *dwc)
dwc3_writel(dwc->regs, DWC3_GUSB3PIPECTL(0), reg);
+ dwc3_hsphy_mode_setup(dwc); + mdelay(100);
reg = dwc3_readl(dwc->regs, DWC3_GUSB2PHYCFG(0)); @@ -626,35 +656,6 @@ static void dwc3_core_exit_mode(struct dwc3 *dwc) dwc3_gadget_run(dwc); }
-static void dwc3_uboot_hsphy_mode(struct dwc3_device *dwc3_dev, - struct dwc3 *dwc) -{ - enum usb_phy_interface hsphy_mode = dwc3_dev->hsphy_mode; - u32 reg; - - /* Set dwc3 usb2 phy config */ - reg = dwc3_readl(dwc->regs, DWC3_GUSB2PHYCFG(0)); - - switch (hsphy_mode) { - case USBPHY_INTERFACE_MODE_UTMI: - reg &= ~(DWC3_GUSB2PHYCFG_PHYIF_MASK | - DWC3_GUSB2PHYCFG_USBTRDTIM_MASK); - reg |= DWC3_GUSB2PHYCFG_PHYIF(UTMI_PHYIF_8_BIT) | - DWC3_GUSB2PHYCFG_USBTRDTIM(USBTRDTIM_UTMI_8_BIT); - break; - case USBPHY_INTERFACE_MODE_UTMIW: - reg &= ~(DWC3_GUSB2PHYCFG_PHYIF_MASK | - DWC3_GUSB2PHYCFG_USBTRDTIM_MASK); - reg |= DWC3_GUSB2PHYCFG_PHYIF(UTMI_PHYIF_16_BIT) | - DWC3_GUSB2PHYCFG_USBTRDTIM(USBTRDTIM_UTMI_16_BIT); - break; - default: - break; - } - - dwc3_writel(dwc->regs, DWC3_GUSB2PHYCFG(0), reg); -} - #define DWC3_ALIGN_MASK (16 - 1)
/** @@ -743,6 +744,8 @@ int dwc3_uboot_init(struct dwc3_device *dwc3_dev) dwc->hird_threshold = hird_threshold | (dwc->is_utmi_l1_suspend << 4);
+ dwc->hsphy_mode = dwc3_dev->hsphy_mode; + dwc->index = dwc3_dev->index;
dwc3_cache_hwparams(dwc); @@ -767,8 +770,6 @@ int dwc3_uboot_init(struct dwc3_device *dwc3_dev) goto err0; }
- dwc3_uboot_hsphy_mode(dwc3_dev, dwc); - ret = dwc3_event_buffers_setup(dwc); if (ret) { dev_err(dwc->dev, "failed to setup event buffers\n"); @@ -901,6 +902,8 @@ void dwc3_of_parse(struct dwc3 *dwc) */ hird_threshold = 12;
+ dwc->hsphy_mode = usb_get_phy_mode(dev->node); + dwc->has_lpm_erratum = dev_read_bool(dev, "snps,has-lpm-erratum"); tmp = dev_read_u8_array_ptr(dev, "snps,lpm-nyet-threshold", 1); diff --git a/drivers/usb/dwc3/core.h b/drivers/usb/dwc3/core.h index 2adcaf0029..8e562ae6c4 100644 --- a/drivers/usb/dwc3/core.h +++ b/drivers/usb/dwc3/core.h @@ -21,6 +21,7 @@
#include <linux/usb/ch9.h> #include <linux/usb/otg.h> +#include <linux/usb/phy.h>
#define DWC3_MSG_MAX 500
@@ -658,6 +659,9 @@ struct dwc3_scratchpad_array { * @maximum_speed: maximum speed requested (mainly for testing purposes) * @revision: revision register contents * @dr_mode: requested mode of operation + * @hsphy_mode: UTMI phy mode, one of following: + * - USBPHY_INTERFACE_MODE_UTMI + * - USBPHY_INTERFACE_MODE_UTMIW * @dcfg: saved contents of DCFG register * @gctl: saved contents of GCTL register * @isoch_delay: wValue from Set Isochronous Delay request; @@ -749,6 +753,7 @@ struct dwc3 { size_t regs_size;
enum usb_dr_mode dr_mode; + enum usb_phy_interface hsphy_mode;
/* used for suspend/resume */ u32 dcfg; diff --git a/include/linux/usb/phy.h b/include/linux/usb/phy.h index 158ca9cd85..1e1217a958 100644 --- a/include/linux/usb/phy.h +++ b/include/linux/usb/phy.h @@ -10,10 +10,28 @@ #ifndef __LINUX_USB_PHY_H #define __LINUX_USB_PHY_H
+#include <dm/ofnode.h> + enum usb_phy_interface { USBPHY_INTERFACE_MODE_UNKNOWN, USBPHY_INTERFACE_MODE_UTMI, USBPHY_INTERFACE_MODE_UTMIW, };
+#if CONFIG_IS_ENABLED(DM_USB) +/** + * usb_get_phy_mode - Get phy mode for given device_node + * @np: Pointer to the given device_node + * + * The function gets phy interface string from property 'phy_type', + * and returns the corresponding enum usb_phy_interface + */ +enum usb_phy_interface usb_get_phy_mode(ofnode node); +#else +static inline enum usb_phy_interface usb_get_phy_mode(ofnode node) +{ + return USBPHY_INTERFACE_MODE_UNKNOWN; +} +#endif + #endif /* __LINUX_USB_PHY_H */
RK3399 Type-C PHY is required that must hold whole USB3.0 OTG controller in resetting to hold pipe power state in P2 before initializing the PHY. This commit fixed it and added device compatible for rockchip platform.
Signed-off-by: Frank Wang frank.wang@rock-chips.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- drivers/usb/dwc3/dwc3-generic.c | 33 +++++++++++++++++++++++++++------ 1 file changed, 27 insertions(+), 6 deletions(-)
diff --git a/drivers/usb/dwc3/dwc3-generic.c b/drivers/usb/dwc3/dwc3-generic.c index eabd53a36d..421e0be135 100644 --- a/drivers/usb/dwc3/dwc3-generic.c +++ b/drivers/usb/dwc3/dwc3-generic.c @@ -24,6 +24,12 @@ #include <clk.h> #include <usb/xhci.h>
+struct dwc3_glue_data { + struct clk_bulk clks; + struct reset_ctl_bulk resets; + fdt_addr_t regs; +}; + struct dwc3_generic_plat { fdt_addr_t base; u32 maximum_speed; @@ -47,6 +53,7 @@ static int dwc3_generic_probe(struct udevice *dev, int rc; struct dwc3_generic_plat *plat = dev_get_platdata(dev); struct dwc3 *dwc3 = &priv->dwc3; + struct dwc3_glue_data *glue = dev_get_platdata(dev->parent);
dwc3->dev = dev; dwc3->maximum_speed = plat->maximum_speed; @@ -55,10 +62,22 @@ static int dwc3_generic_probe(struct udevice *dev, dwc3_of_parse(dwc3); #endif
+ /* + * It must hold whole USB3.0 OTG controller in resetting to hold pipe + * power state in P2 before initializing TypeC PHY on RK3399 platform. + */ + if (device_is_compatible(dev->parent, "rockchip,rk3399-dwc3")) { + reset_assert_bulk(&glue->resets); + udelay(1); + } + rc = dwc3_setup_phy(dev, &priv->phys); if (rc) return rc;
+ if (device_is_compatible(dev->parent, "rockchip,rk3399-dwc3")) + reset_deassert_bulk(&glue->resets); + priv->base = map_physmem(plat->base, DWC3_OTG_REGS_END, MAP_NOCACHE); dwc3->regs = priv->base + DWC3_GLOBALS_REGS_START;
@@ -186,12 +205,6 @@ U_BOOT_DRIVER(dwc3_generic_host) = { }; #endif
-struct dwc3_glue_data { - struct clk_bulk clks; - struct reset_ctl_bulk resets; - fdt_addr_t regs; -}; - struct dwc3_glue_ops { void (*select_dr_mode)(struct udevice *dev, int index, enum usb_dr_mode mode); @@ -394,6 +407,12 @@ static int dwc3_glue_probe(struct udevice *dev) if (ret) return ret;
+ if (glue->resets.count == 0) { + ret = dwc3_glue_reset_init(child, glue); + if (ret) + return ret; + } + while (child) { enum usb_dr_mode dr_mode;
@@ -424,6 +443,8 @@ static const struct udevice_id dwc3_glue_ids[] = { { .compatible = "ti,dwc3", .data = (ulong)&ti_ops }, { .compatible = "ti,am437x-dwc3", .data = (ulong)&ti_ops }, { .compatible = "ti,am654-dwc3" }, + { .compatible = "rockchip,rk3328-dwc3" }, + { .compatible = "rockchip,rk3399-dwc3" }, { } };
fdt_addr_t regs;
struct dwc3_glue_data *glue = dev_get_platdata(dev->parent); dwc3->dev = dev; dwc3->maximum_speed = plat->maximum_speed;
udelay(1);
Need to include <linux/delay.h> to fix build warnings, maybe Kever will do while applying?
Jagan.
We have changed to use dwc3 generic driver for usb3.0 host, so the legacy Rockchip's xHCI driver is not needed, and drop it.
Signed-off-by: Frank Wang frank.wang@rock-chips.com Reviewed-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- drivers/usb/host/Kconfig | 9 -- drivers/usb/host/Makefile | 1 - drivers/usb/host/xhci-rockchip.c | 196 ------------------------------- 3 files changed, 206 deletions(-) delete mode 100644 drivers/usb/host/xhci-rockchip.c
diff --git a/drivers/usb/host/Kconfig b/drivers/usb/host/Kconfig index 2f381dc958..088931a6b9 100644 --- a/drivers/usb/host/Kconfig +++ b/drivers/usb/host/Kconfig @@ -53,15 +53,6 @@ config USB_XHCI_PCI help Enables support for the PCI-based xHCI controller.
-config USB_XHCI_ROCKCHIP - bool "Support for Rockchip on-chip xHCI USB controller" - depends on ARCH_ROCKCHIP - depends on DM_REGULATOR - depends on DM_USB - default y - help - Enables support for the on-chip xHCI controller on Rockchip SoCs. - config USB_XHCI_RCAR bool "Renesas RCar USB 3.0 support" default y diff --git a/drivers/usb/host/Makefile b/drivers/usb/host/Makefile index e8e3b17e42..29d4f87e38 100644 --- a/drivers/usb/host/Makefile +++ b/drivers/usb/host/Makefile @@ -48,7 +48,6 @@ obj-$(CONFIG_USB_XHCI_BRCM) += xhci-brcm.o obj-$(CONFIG_USB_XHCI_HCD) += xhci.o xhci-mem.o xhci-ring.o obj-$(CONFIG_USB_XHCI_DWC3) += xhci-dwc3.o obj-$(CONFIG_USB_XHCI_DWC3_OF_SIMPLE) += dwc3-of-simple.o -obj-$(CONFIG_USB_XHCI_ROCKCHIP) += xhci-rockchip.o obj-$(CONFIG_USB_XHCI_EXYNOS) += xhci-exynos5.o obj-$(CONFIG_USB_XHCI_FSL) += xhci-fsl.o obj-$(CONFIG_USB_XHCI_MTK) += xhci-mtk.o diff --git a/drivers/usb/host/xhci-rockchip.c b/drivers/usb/host/xhci-rockchip.c deleted file mode 100644 index b67722fe45..0000000000 --- a/drivers/usb/host/xhci-rockchip.c +++ /dev/null @@ -1,196 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (c) 2016 Rockchip, Inc. - * Authors: Daniel Meng daniel.meng@rock-chips.com - */ -#include <common.h> -#include <dm.h> -#include <malloc.h> -#include <usb.h> -#include <watchdog.h> -#include <linux/errno.h> -#include <linux/compat.h> -#include <linux/usb/dwc3.h> -#include <power/regulator.h> - -#include <usb/xhci.h> - -struct rockchip_xhci_platdata { - fdt_addr_t hcd_base; - struct udevice *vbus_supply; -}; - -/* - * Contains pointers to register base addresses - * for the usb controller. - */ -struct rockchip_xhci { - struct usb_platdata usb_plat; - struct xhci_ctrl ctrl; - struct xhci_hccr *hcd; - struct dwc3 *dwc3_reg; -}; - -static int xhci_usb_ofdata_to_platdata(struct udevice *dev) -{ - struct rockchip_xhci_platdata *plat = dev_get_platdata(dev); - int ret = 0; - - /* - * Get the base address for XHCI controller from the device node - */ - plat->hcd_base = dev_read_addr(dev); - if (plat->hcd_base == FDT_ADDR_T_NONE) { - pr_err("Can't get the XHCI register base address\n"); - return -ENXIO; - } - - /* Vbus regulator */ - ret = device_get_supply_regulator(dev, "vbus-supply", - &plat->vbus_supply); - if (ret) - debug("Can't get VBus regulator!\n"); - - return 0; -} - -/* - * rockchip_dwc3_phy_setup() - Configure USB PHY Interface of DWC3 Core - * @dwc: Pointer to our controller context structure - * @dev: Pointer to ulcass device - */ -static void rockchip_dwc3_phy_setup(struct dwc3 *dwc3_reg, - struct udevice *dev) -{ - u32 reg; - u32 utmi_bits; - - /* Set dwc3 usb2 phy config */ - reg = readl(&dwc3_reg->g_usb2phycfg[0]); - - if (dev_read_bool(dev, "snps,dis-enblslpm-quirk")) - reg &= ~DWC3_GUSB2PHYCFG_ENBLSLPM; - - utmi_bits = dev_read_u32_default(dev, "snps,phyif-utmi-bits", -1); - if (utmi_bits == 16) { - reg |= DWC3_GUSB2PHYCFG_PHYIF; - reg &= ~DWC3_GUSB2PHYCFG_USBTRDTIM_MASK; - reg |= DWC3_GUSB2PHYCFG_USBTRDTIM_16BIT; - } else if (utmi_bits == 8) { - reg &= ~DWC3_GUSB2PHYCFG_PHYIF; - reg &= ~DWC3_GUSB2PHYCFG_USBTRDTIM_MASK; - reg |= DWC3_GUSB2PHYCFG_USBTRDTIM_8BIT; - } - - if (dev_read_bool(dev, "snps,dis-u2-freeclk-exists-quirk")) - reg &= ~DWC3_GUSB2PHYCFG_U2_FREECLK_EXISTS; - - if (dev_read_bool(dev, "snps,dis-u2-susphy-quirk")) - reg &= ~DWC3_GUSB2PHYCFG_SUSPHY; - - writel(reg, &dwc3_reg->g_usb2phycfg[0]); -} - -static int rockchip_xhci_core_init(struct rockchip_xhci *rkxhci, - struct udevice *dev) -{ - int ret; - - ret = dwc3_core_init(rkxhci->dwc3_reg); - if (ret) { - pr_err("failed to initialize core\n"); - return ret; - } - - rockchip_dwc3_phy_setup(rkxhci->dwc3_reg, dev); - - /* We are hard-coding DWC3 core to Host Mode */ - dwc3_set_mode(rkxhci->dwc3_reg, DWC3_GCTL_PRTCAP_HOST); - - return 0; -} - -static int rockchip_xhci_core_exit(struct rockchip_xhci *rkxhci) -{ - return 0; -} - -static int xhci_usb_probe(struct udevice *dev) -{ - struct rockchip_xhci_platdata *plat = dev_get_platdata(dev); - struct rockchip_xhci *ctx = dev_get_priv(dev); - struct xhci_hcor *hcor; - int ret; - - ctx->hcd = (struct xhci_hccr *)plat->hcd_base; - ctx->dwc3_reg = (struct dwc3 *)((char *)(ctx->hcd) + DWC3_REG_OFFSET); - hcor = (struct xhci_hcor *)((uint64_t)ctx->hcd + - HC_LENGTH(xhci_readl(&ctx->hcd->cr_capbase))); - - if (plat->vbus_supply) { - ret = regulator_set_enable(plat->vbus_supply, true); - if (ret) { - pr_err("XHCI: failed to set VBus supply\n"); - return ret; - } - } - - ret = rockchip_xhci_core_init(ctx, dev); - if (ret) { - pr_err("XHCI: failed to initialize controller\n"); - return ret; - } - - return xhci_register(dev, ctx->hcd, hcor); -} - -static int xhci_usb_remove(struct udevice *dev) -{ - struct rockchip_xhci_platdata *plat = dev_get_platdata(dev); - struct rockchip_xhci *ctx = dev_get_priv(dev); - int ret; - - ret = xhci_deregister(dev); - if (ret) - return ret; - ret = rockchip_xhci_core_exit(ctx); - if (ret) - return ret; - - if (plat->vbus_supply) { - ret = regulator_set_enable(plat->vbus_supply, false); - if (ret) - pr_err("XHCI: failed to set VBus supply\n"); - } - - return ret; -} - -static const struct udevice_id xhci_usb_ids[] = { - { .compatible = "rockchip,rk3328-xhci" }, - { } -}; - -U_BOOT_DRIVER(usb_xhci) = { - .name = "xhci_rockchip", - .id = UCLASS_USB, - .of_match = xhci_usb_ids, - .ofdata_to_platdata = xhci_usb_ofdata_to_platdata, - .probe = xhci_usb_probe, - .remove = xhci_usb_remove, - .ops = &xhci_usb_ops, - .bind = dm_scan_fdt_dev, - .platdata_auto_alloc_size = sizeof(struct rockchip_xhci_platdata), - .priv_auto_alloc_size = sizeof(struct rockchip_xhci), - .flags = DM_FLAG_ALLOC_PRIV_DMA, -}; - -static const struct udevice_id usb_phy_ids[] = { - { .compatible = "rockchip,rk3328-usb3-phy" }, - { } -}; - -U_BOOT_DRIVER(usb_phy) = { - .name = "usb_phy_rockchip", - .of_match = usb_phy_ids, -};
Am Dienstag, 26. Mai 2020, 05:34:32 CEST schrieb Frank Wang:
this needs to be adapted for commit f7ae49fc4f36 ("common: Drop log.h from common header") which added a #include <log.h> to xhci-rockchip.c
Heiko
Configure 'tcphy1' and 'usbdrd_dwc3_1' nodes to support USB3.0 host for Rockchip RK3399 Evaluation Board.
Signed-off-by: Frank Wang frank.wang@rock-chips.com Reviewed-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- arch/arm/dts/rk3399-evb-u-boot.dtsi | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/arch/arm/dts/rk3399-evb-u-boot.dtsi b/arch/arm/dts/rk3399-evb-u-boot.dtsi index e5659d7999..1bebe258f0 100644 --- a/arch/arm/dts/rk3399-evb-u-boot.dtsi +++ b/arch/arm/dts/rk3399-evb-u-boot.dtsi @@ -23,3 +23,16 @@ &rk808 { u-boot,dm-pre-reloc; }; + +&tcphy1 { + status = "okay"; +}; + +&usbdrd3_1 { + status = "okay"; +}; + +&usbdrd_dwc3_1 { + dr_mode = "host"; + status = "okay"; +};
Update evb-rk3399 default config to support USB3.0 Host.
Signed-off-by: Frank Wang frank.wang@rock-chips.com Reviewed-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- configs/evb-rk3399_defconfig | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index 7f14e18b1b..6cfb4e5dac 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -28,6 +28,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ROCKCHIP=y @@ -35,10 +36,13 @@ CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_TYPEC=y CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_PWM=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y +CONFIG_DM_RESET=y CONFIG_DM_RNG=y CONFIG_RNG_ROCKCHIP=y CONFIG_BAUDRATE=1500000 @@ -49,6 +53,8 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y
Enable USB3.0 Host support for ROC-RK3399-PC boards.
Tested USB3.0 SSD on Type C1 port on board.
=> usb start starting USB... Bus usb@fe380000: USB EHCI 1.00 Bus usb@fe3c0000: USB EHCI 1.00 Bus dwc3: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fe380000 for devices... 1 USB Device(s) found scanning bus usb@fe3c0000 for devices... 2 USB Device(s) found scanning bus dwc3 for devices... 6 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found => usb tree USB device tree: 1 Hub (480 Mb/s, 0mA) u-boot EHCI Host Controller
1 Hub (480 Mb/s, 0mA) | u-boot EHCI Host Controller | +-2 Hub (480 Mb/s, 100mA) USB 2.0 Hub [MTT]
1 Hub (5 Gb/s, 0mA) | U-Boot XHCI Host Controller | +-2 Hub (480 Mb/s, 0mA) | | VIA Labs, Inc. USB2.0 Hub | | | +-4 Hub (480 Mb/s, 100mA) | | USB 2.0 Hub | | | +-5 (480 Mb/s, 100mA) | VIA Technologies Inc. USB 2.0 BILLBOARD 0000000000000001 | +-3 Hub (5 Gb/s, 0mA) | VIA Labs, Inc. USB3.0 Hub | +-6 Mass Storage (5 Gb/s, 224mA) JMicron External Disk 3.0 DB12345678A2
=> usb reset resetting USB... Bus usb@fe380000: USB EHCI 1.00 Bus usb@fe3c0000: USB EHCI 1.00 Bus dwc3: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fe380000 for devices... 1 USB Device(s) found scanning bus usb@fe3c0000 for devices... 2 USB Device(s) found scanning bus dwc3 for devices... 6 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- configs/roc-pc-mezzanine-rk3399_defconfig | 5 +++++ configs/roc-pc-rk3399_defconfig | 6 ++++++ 2 files changed, 11 insertions(+)
diff --git a/configs/roc-pc-mezzanine-rk3399_defconfig b/configs/roc-pc-mezzanine-rk3399_defconfig index 0b853805f3..1f10856caa 100644 --- a/configs/roc-pc-mezzanine-rk3399_defconfig +++ b/configs/roc-pc-mezzanine-rk3399_defconfig @@ -29,6 +29,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y @@ -39,6 +40,8 @@ CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y CONFIG_NVME=y CONFIG_PCI=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_TYPEC=y CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_PWM=y CONFIG_REGULATOR_RK8XX=y @@ -54,6 +57,8 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y diff --git a/configs/roc-pc-rk3399_defconfig b/configs/roc-pc-rk3399_defconfig index aff690f039..76e76c160e 100644 --- a/configs/roc-pc-rk3399_defconfig +++ b/configs/roc-pc-rk3399_defconfig @@ -28,6 +28,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y @@ -36,11 +37,14 @@ CONFIG_SPI_FLASH_WINBOND=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_TYPEC=y CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_PWM=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y CONFIG_RAM_RK3399_LPDDR4=y +CONFIG_DM_RESET=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_ROCKCHIP_SPI=y @@ -50,6 +54,8 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_KEYBOARD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y
On Tue, May 26, 2020 at 9:02 AM Frank Wang frank.wang@rock-chips.com wrote:
This series add quirks for DWC3 and add Rockchip RK3399 USB3.0 host support.
The function has been tested pass on rk3399-evb and roc-rk3399-pc board.
For V6 update:
- Use [PATCH v6 04/16] instead of [PATCH v5 05/16] to fix that the current Generic PHY subsystem is unable to find PHY if the PHY node is not part of the root structure.
- Add 'Reviewed-by' tag for all patches except [PATCH v6 04/16].
For V5 update:
- Fix dwc3-generic driver followed Marek's comments for [PATCH v4 12/16].
- Add 'Reviewed-by' and 'Tested-by' tag for [PATCH v4 07/16] and [PATCH v4 08/16].
For V4 update:
- Collect Jagan's all fixed patches [1].
- Amend specific u-boot changes from dts to dtsi for [PATCH v3 6/7].
For V3 update:
- Fix compile error for [PATCH v2 1/9].
- Use Jagan's Type-C driver instead of [PATCH v2 5/9].
- Cleanup dts changes for [PATCH v2 7/9].
- Cleanup config changes for [PATCH v2 8/9] and [PATCH v2 9/9].
For V2 update:
- Amend type-c driver followed Jagan's comments for [PATCH 5/8].
- Fix dts commit for [PATCH 7/8].
- Split RK3399 default config for [PATCH 8/8].
- Add 'Reviewed-by' tag for [PATCH 1/8], [PATCH 2/8] and [PATCH 3/8].
[1] https://patchwork.ozlabs.org/project/uboot/cover/20200506075025.1677-1-jagan...
BR, Frank
Frank Wang (8): arm: mach-rockchip: bind sub-nodes for rk3399_syscon usb: dwc3: add dis_enblslpm_quirk usb: dwc3: add dis_u2_freeclk_exists_quirk usb: dwc3: amend UTMI/UTMIW phy interface setup usb: dwc3: add make compatible for rockchip platform driver: usb: drop legacy rockchip xhci driver ARM: dts: rk3399-evb: usb3.0 host support configs: evb-rk3399: update support usb3.0 host
I have a new sandisk Type C and A storage disk. Here are the tests in roc-rk3399-pc.
1 Hub (5 Gb/s, 0mA) U-Boot XHCI Host Controller
=> usb reset resetting USB... Bus usb@fe380000: USB EHCI 1.00 Bus usb@fe3c0000: USB EHCI 1.00 Bus dwc3: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fe380000 for devices... 1 USB Device(s) found scanning bus usb@fe3c0000 for devices... 2 USB Device(s) found scanning bus dwc3 for devices... cannot reset port 1!? 2 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found => usb tree USB device tree: 1 Hub (480 Mb/s, 0mA) u-boot EHCI Host Controller
1 Hub (5 Gb/s, 0mA) | U-Boot XHCI Host Controller | +-2 Mass Storage (5 Gb/s, 224mA) SanDisk Dual Drive 040130e3ee554b7078843f4eb331646
=> usb reset resetting USB... Bus usb@fe380000: USB EHCI 1.00 Bus usb@fe3c0000: USB EHCI 1.00 Bus dwc3: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fe380000 for devices... 2 USB Device(s) found scanning bus usb@fe3c0000 for devices... 2 USB Device(s) found scanning bus dwc3 for devices... 1 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found => usb tree USB device tree: 1 Hub (480 Mb/s, 0mA) | u-boot EHCI Host Controller | +-2 Mass Storage (480 Mb/s, 224mA) SanDisk Dual Drive 040130e3ee554b7078843f4eb331646
=> usb reset resetting USB... Bus usb@fe380000: USB EHCI 1.00 Bus usb@fe3c0000: USB EHCI 1.00 Bus dwc3: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fe380000 for devices... 1 USB Device(s) found scanning bus usb@fe3c0000 for devices... EHCI timed out on TD - token=0x80008d80
USB device not accepting new address (error=22) 2 USB Device(s) found scanning bus dwc3 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found => resetting USB... Bus usb@fe380000: USB EHCI 1.00 Bus usb@fe3c0000: USB EHCI 1.00 Bus dwc3: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fe380000 for devices... 1 USB Device(s) found scanning bus usb@fe3c0000 for devices... 3 USB Device(s) found scanning bus dwc3 for devices... 1 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found => usb tree USB device tree: 1 Hub (480 Mb/s, 0mA) u-boot EHCI Host Controller
1 Hub (480 Mb/s, 0mA) | u-boot EHCI Host Controller | +-2 Hub (480 Mb/s, 100mA) | USB 2.0 Hub [MTT] | +-3 Mass Storage (480 Mb/s, 224mA) SanDisk Dual Drive 040130e3ee554b7078843f4eb331646
USB device not accepting new address (error=22) 2 USB Device(s) found scanning bus dwc3 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found => usb reset resetting USB... Bus usb@fe380000: USB EHCI 1.00 Bus usb@fe3c0000: USB EHCI 1.00 Bus dwc3: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fe380000 for devices... 1 USB Device(s) found scanning bus usb@fe3c0000 for devices... 3 USB Device(s) found scanning bus dwc3 for devices... 1 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found => usb tree USB device tree: 1 Hub (480 Mb/s, 0mA) u-boot EHCI Host Controller
Jagan.
W dniu 26.05.2020 o 05:32, Frank Wang pisze:
For V6 update:
Tested-by: Marcin Juszkiewicz marcin@juszkiewicz.com.pl
On RockPro64 (config changes attached):
Model: Pine64 RockPro64 v2.1 Net: eth0: ethernet@fe300000 Hit any key to stop autoboot: 0 => usb start;usb tree starting USB... Bus usb@fe380000: USB EHCI 1.00 Bus usb@fe3c0000: USB EHCI 1.00 Bus dwc3: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus dwc3: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fe380000 for devices... 1 USB Device(s) found scanning bus usb@fe3c0000 for devices... 1 USB Device(s) found scanning bus dwc3 for devices... 2 USB Device(s) found scanning bus dwc3 for devices... 1 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found USB device tree: 1 Hub (480 Mb/s, 0mA) u-boot EHCI Host Controller
1 Hub (5 Gb/s, 0mA) | U-Boot XHCI Host Controller | +-2 Mass Storage (480 Mb/s, 224mA) SanDisk Ultra USB 3.0 4C530001300923104300
Device is Sandisk C/A pendrive. Recognized as HighSpeed in USB-C port but as SuperSpeed in USB-A one:
=> usb reset;usb tree resetting USB... Bus usb@fe380000: USB EHCI 1.00 Bus usb@fe3c0000: USB EHCI 1.00 Bus dwc3: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus dwc3: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fe380000 for devices... 1 USB Device(s) found scanning bus usb@fe3c0000 for devices... 1 USB Device(s) found scanning bus dwc3 for devices... 1 USB Device(s) found scanning bus dwc3 for devices... cannot reset port 1!? 2 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found USB device tree: 1 Hub (480 Mb/s, 0mA) u-boot EHCI Host Controller
1 Hub (5 Gb/s, 0mA) | U-Boot XHCI Host Controller | +-2 Mass Storage (5 Gb/s, 224mA) SanDisk Ultra USB 3.0 4C530001300923104300
Whatever SuperSpeed device I plug into USB-C port it gets recognized as HighSpeed only.
"cannot reset port 1!?" message appears on almost (3/4) each 'usb start' and each 'usb reset' command.
Also checked one of those usb-c 2 usb-a/hdmi/usb-c-charge dongles and Sandisk was recognized as HighSpeed.
For V6 update:
For V5 update:
For V4 update:
For V3 update:
For V2 update:
BR, Frank
Jagan Teki (8): clk: rk3399: Enable/Disable the USB2PHY clk clk: rk3399: Set empty for TCPHY assigned-clocks clk: rk3399: Enable/Disable TCPHY clocks phy: rockchip: Add Rockchip USB2PHY driver phy: rockchip: Add Rockchip USB TypeC PHY driver usb: dwc3: Add disable u2mac linestate check quirk usb: dwc3: Enable AutoRetry feature in the controller roc-rk3399-pc: Enable USB3.0 Host
arch/arm/dts/rk3399-evb-u-boot.dtsi | 13 + arch/arm/mach-rockchip/rk3399/syscon_rk3399.c | 3 + configs/evb-rk3399_defconfig | 6 + configs/roc-pc-mezzanine-rk3399_defconfig | 5 + configs/roc-pc-rk3399_defconfig | 6 + drivers/Makefile | 1 + drivers/clk/rockchip/clk_rk3399.c | 38 + drivers/phy/Kconfig | 1 + drivers/phy/rockchip/Kconfig | 21 + drivers/phy/rockchip/Makefile | 7 + drivers/phy/rockchip/phy-rockchip-inno-usb2.c | 312 +++++++ drivers/phy/rockchip/phy-rockchip-typec.c | 796 ++++++++++++++++++ drivers/usb/common/common.c | 25 + drivers/usb/dwc3/core.c | 106 ++- drivers/usb/dwc3/core.h | 19 + drivers/usb/dwc3/dwc3-generic.c | 33 +- drivers/usb/host/Kconfig | 9 - drivers/usb/host/Makefile | 1 - drivers/usb/host/xhci-rockchip.c | 196 ----- include/dwc3-uboot.h | 3 + include/linux/usb/phy.h | 18 + 21 files changed, 1376 insertions(+), 243 deletions(-) create mode 100644 drivers/phy/rockchip/Kconfig create mode 100644 drivers/phy/rockchip/Makefile create mode 100644 drivers/phy/rockchip/phy-rockchip-inno-usb2.c create mode 100644 drivers/phy/rockchip/phy-rockchip-typec.c delete mode 100644 drivers/usb/host/xhci-rockchip.c
Applied to u-boot-rockchip master.
Thanks, - Kever
participants (5)
Frank Wang
Heiko Stuebner
Jagan Teki
Kever Yang
Marcin Juszkiewicz
