[U-Boot] [PATCH] freescale: vid: add support LTC3882 and rework of the VID support
Add support new regular chip: LTC3882.
The origianl VID code didn't properly read the FUSESR on all chips and set the voltages on all chips. It didn't properly support the voltage regulators in use by NXP and report voltage changes.
Signed-off-by: Zhang Ying-22455 ying.zhang22455@nxp.com --- .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 9 +- board/freescale/common/vid.c | 465 +++++++++++--------- board/freescale/common/vid.h | 19 + 3 files changed, 291 insertions(+), 202 deletions(-)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index 957e23b..0ee7a3f 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -201,10 +201,15 @@ struct ccsr_gur { u32 gpporcr3; u32 gpporcr4; u8 res_030[0x60-0x30]; -#define FSL_CHASSIS3_DCFG_FUSESR_VID_SHIFT 2 +#define FSL_CHASSIS3_DCFG_FUSESR_VID_SHIFT 25 #define FSL_CHASSIS3_DCFG_FUSESR_VID_MASK 0x1F -#define FSL_CHASSIS3_DCFG_FUSESR_ALTVID_SHIFT 7 +#define FSL_CHASSIS3_DCFG_FUSESR_ALTVID_SHIFT 20 #define FSL_CHASSIS3_DCFG_FUSESR_ALTVID_MASK 0x1F +#define FSL_CHASSIS3_DCFG_FUSESR_LOW_VID_SHIFT 2 +#define FSL_CHASSIS3_DCFG_FUSESR_LOW_VID_MASK 0x1F +#define FSL_CHASSIS3_DCFG_FUSESR_LOW_ALTVID_SHIFT 7 +#define FSL_CHASSIS3_DCFG_FUSESR_LOW_ALTVID_MASK 0x1F + u8 res_030[0x60-0x30]; u32 dcfg_fusesr; /* Fuse status register */ u8 res_064[0x70-0x64]; u32 devdisr; /* Device disable control 1 */ diff --git a/board/freescale/common/vid.c b/board/freescale/common/vid.c index d6d1bfc..1e2ddb0 100644 --- a/board/freescale/common/vid.c +++ b/board/freescale/common/vid.c @@ -11,6 +11,7 @@ #ifdef CONFIG_FSL_LSCH2 #include <asm/arch/immap_lsch2.h> #elif defined(CONFIG_FSL_LSCH3) +#include <asm/arch/soc.h> #include <asm/arch/immap_lsch3.h> #else #include <asm/immap_85xx.h> @@ -33,8 +34,42 @@ int __weak board_vdd_drop_compensation(void) return 0; }
+#if defined(CONFIG_VOL_MONITOR_LTC3882) +/* Helper function to write a mV value as LTC L16 into the chip, + * returning a boolean for success */ +static int write_l16_mV_LTC3882(int i2caddress, int cmd, int mv) +{ + int wait, vdd_last, l16; + int ret; + u8 buf[2]; + + /* Scale mV to L16 */ + l16 = mv; + l16 <<= 12; + l16 /= 1000; + debug("VID: cmd 0x%02x voltage write 0x%04x\n", cmd, l16); + buf[0] = (l16 & 0xff); + buf[1] = (l16 >> 8); + + /* This code assumes that both channels run the very + * SAME voltage. This is likely true for LS2 style + * devices. For any other configuration, all hell will + * break loose! + */ + ret = i2c_write(i2caddress, LTC3882_PAGE, 1, + (void *)"\377", 1); + if (!ret) + ret = i2c_write(i2caddress, cmd, 1, + (void *)&buf[0], 2); + if (!ret) + ret = i2c_write(i2caddress, LTC3882_PAGE, 1, + (void *)"\0", 1); + return ret; +} +#endif + /* - * Get the i2c address configuration for the IR regulator chip + * Get the i2c address configuration for the regulator chip * * There are some variance in the RDB HW regarding the I2C address configuration * for the IR regulator chip, which is likely a problem of external resistor @@ -45,9 +80,13 @@ int __weak board_vdd_drop_compensation(void) * 0x08 (Verified on T1040RDB-PA,T4240RDB-PB,X-T4240RDB-16GPA) * 0x09 (Verified on T1040RDB-PA) * 0x38 (Verified on T2080QDS, T2081QDS, T4240RDB) + * + * For other types of regulator chips, we check the IDs before we + * return the address to avoid making damaging mistakes */ -static int find_ir_chip_on_i2c(void) +static int find_vid_chip_on_i2c(void) { +#if defined(CONFIG_VOL_MONITOR_IR36021_READ) || defined(CONFIG_VOL_MONITOR_IR36021_SET) int i2caddress; int ret; u8 byte; @@ -63,6 +102,23 @@ static int find_ir_chip_on_i2c(void) if ((ret >= 0) && (byte == IR36021_MFR_ID)) return i2caddress; } +#endif +#if defined(CONFIG_VOL_MONITOR_LTC3882) + int i2caddress = I2C_VOL_MONITOR_ADDR; + int ret; + u8 buf[8]; + + ret = i2c_read(i2caddress, + LTC3882_MFR_ID, 1, (void *)&buf[0], + 4); + if (!ret && memcmp(buf, "\3LTC", 4) == 0) { + ret = i2c_read(i2caddress, + LTC3882_MFR_MODEL, 1, (void *)&buf[0], + 8); + if (!ret && memcmp(buf, "\7LTC3882", 8) == 0) + return i2caddress; + } +#endif return -1; }
@@ -83,10 +139,15 @@ static int find_ir_chip_on_i2c(void) #ifdef CONFIG_VOL_MONITOR_INA220 #define WAIT_FOR_ADC 532 /* wait for 532 microseconds for ADC */ #define ADC_MIN_ACCURACY 4 -#else +#endif +#ifdef CONFIG_VOL_MONITOR_IR36021_READ #define WAIT_FOR_ADC 138 /* wait for 138 microseconds for ADC */ #define ADC_MIN_ACCURACY 4 #endif +#ifdef CONFIG_VOL_MONITOR_LTC3882 +#define WAIT_FOR_ADC 0 +#define ADC_MIN_ACCURACY 4 +#endif
#ifdef CONFIG_VOL_MONITOR_INA220 static int read_voltage_from_INA220(int i2caddress) @@ -98,7 +159,7 @@ static int read_voltage_from_INA220(int i2caddress) for (i = 0; i < NUM_READINGS; i++) { ret = i2c_read(I2C_VOL_MONITOR_ADDR, I2C_VOL_MONITOR_BUS_V_OFFSET, 1, - (void *)&buf, 2); + (void *)&buf[0], 2); if (ret) { printf("VID: failed to read core voltage\n"); return ret; @@ -141,23 +202,43 @@ static int read_voltage_from_IR(int i2caddress) printf("VID: Core voltage sensor error\n"); return -1; } - debug("VID: bus voltage reads 0x%02x\n", vol_mon); - /* Resolution is 1/128V. We scale up here to get 1/128mV - * and divide at the end - */ - voltage_read += vol_mon * 1000; + debug("VID: Core voltage reads 0x%02x\n", vol_mon); + voltage_read += vol_mon; udelay(WAIT_FOR_ADC); } /* Scale down to the real mV as IR resolution is 1/128V, rounding up */ + voltage_read *= 1000; voltage_read = DIV_ROUND_UP(voltage_read, 128);
/* calculate the average */ voltage_read /= NUM_READINGS;
- /* Compensate for a board specific voltage drop between regulator and - * SoC before converting into an IR VID value - */ - voltage_read -= board_vdd_drop_compensation(); + return voltage_read; +} +#endif + +/* read voltage from LTC3882 */ +#ifdef CONFIG_VOL_MONITOR_LTC3882 +static int read_voltage_from_LTC3882(int i2caddress) +{ + int ret, voltage_read = 0; + int vol_mon; + u8 buf[2]; + + ret = i2c_read(i2caddress, + LTC3882_READ_VOUT, 1, + (void *)&buf[0], 2); + if (ret) { + printf("VID: failed to read core voltage\n"); + return ret; + } + vol_mon = (buf[1] << 8) | buf[0]; + + /* Scale L16 to mV */ + debug("VID: Core voltage reads 0x%04x\n", vol_mon); + vol_mon *= 1000; + voltage_read = DIV_ROUND_UP(vol_mon, 4096); + debug("VID: Core voltage reads as %d mV\n", voltage_read);
return voltage_read; } @@ -170,9 +251,19 @@ static int read_voltage(int i2caddress) voltage_read = read_voltage_from_INA220(i2caddress); #elif defined CONFIG_VOL_MONITOR_IR36021_READ voltage_read = read_voltage_from_IR(i2caddress); +#elif defined CONFIG_VOL_MONITOR_LTC3882 + voltage_read = read_voltage_from_LTC3882(i2caddress); #else - return -1; + voltage_read = -1; #endif + if (voltage_read >= 0) + { + /* Compensate for a board specific voltage drop between regulator and + * SoC before converting into an IR VID value + */ + voltage_read -= board_vdd_drop_compensation(); + } + return voltage_read; }
@@ -198,6 +289,8 @@ static int wait_for_new_voltage(int vdd, int i2caddress) for (timeout = 0; abs(vdd - vdd_current) > (IR_VDD_STEP_UP + IR_VDD_STEP_DOWN) && timeout < MAX_LOOP_WAIT_NEW_VOL; timeout++) { + debug("VID: waiting for delta %d mV <-> %d mV to disappear\n", vdd, vdd_current); + udelay(1000); vdd_current = read_voltage(i2caddress); } if (timeout >= MAX_LOOP_WAIT_NEW_VOL) { @@ -216,18 +309,18 @@ static int wait_for_voltage_stable(int i2caddress) int timeout, vdd_current, vdd;
vdd = read_voltage(i2caddress); - udelay(NUM_READINGS * WAIT_FOR_ADC); + udelay(1000);
/* wait until voltage is stable */ vdd_current = read_voltage(i2caddress); /* The maximum timeout is - * MAX_LOOP_WAIT_VOL_STABLE * NUM_READINGS * WAIT_FOR_ADC + * MAX_LOOP_WAIT_VOL_STABLE * (1000µs + NUM_READINGS * WAIT_FOR_ADC) */ for (timeout = MAX_LOOP_WAIT_VOL_STABLE; abs(vdd - vdd_current) > ADC_MIN_ACCURACY && timeout > 0; timeout--) { vdd = vdd_current; - udelay(NUM_READINGS * WAIT_FOR_ADC); + udelay(1000); vdd_current = read_voltage(i2caddress); } if (timeout == 0) @@ -242,16 +335,27 @@ static int set_voltage_to_IR(int i2caddress, int vdd) int wait, vdd_last; int ret; u8 vid; + u8 buf;
- /* Compensate for a board specific voltage drop between regulator and - * SoC before converting into an IR VID value - */ - vdd += board_vdd_drop_compensation(); -#ifdef CONFIG_FSL_LSCH2 - vid = DIV_ROUND_UP(vdd - 265, 5); -#else - vid = DIV_ROUND_UP(vdd - 245, 5); -#endif + /* check if IR chip works in Intel mode*/ + ret = i2c_read(i2caddress, + IR36021_INTEL_MODE_OOFSET, + 1, (void *)&buf, 1); + if (ret) { + printf("VID: failed to read IR chip mode.\n"); + return -1; + } + if ((buf & IR36021_MODE_MASK) != IR36021_INTEL_MODE) { + /* AMD SVI2 mode. */ + /* An increase by 5 in the VID value causes a decrease + * by 4/128V in the output rail, -6.25mV per step. + * The scale appears to be 0V based starting from 0xf8. + */ + vid = 248 - DIV_ROUND_UP(vdd * 4, 25); + } else { + /* Intel mode */ + vid = DIV_ROUND_UP(vdd - 245, 5); + }
ret = i2c_write(i2caddress, IR36021_LOOP1_MANUAL_ID_OFFSET, 1, (void *)&vid, sizeof(vid)); @@ -262,7 +366,35 @@ static int set_voltage_to_IR(int i2caddress, int vdd) wait = wait_for_new_voltage(vdd, i2caddress); if (wait < 0) return -1; - debug("VID: Waited %d us\n", wait * NUM_READINGS * WAIT_FOR_ADC); + + debug("VID: Waited %d us\n", wait * (1000 + NUM_READINGS * WAIT_FOR_ADC)); + + vdd_last = wait_for_voltage_stable(i2caddress); + if (vdd_last < 0) + return -1; + debug("VID: Current voltage is %d mV\n", vdd_last); + return vdd_last; +} +#endif + +#ifdef CONFIG_VOL_MONITOR_LTC3882 +/* Set the voltage to the LTC3882 chip */ +static int set_voltage_to_LTC3882(int i2caddress, int vdd) +{ + int wait, vdd_last; + int ret; + + ret = write_l16_mV_LTC3882(i2caddress, + LTC3882_VOUT_COMMAND, + vdd); + if (ret) { + printf("VID: failed to write VID\n"); + return -1; + } + wait = wait_for_new_voltage(vdd, i2caddress); + if (wait < 0) + return -1; + debug("VID: Waited %d us\n", wait * (1000 + NUM_READINGS * WAIT_FOR_ADC));
vdd_last = wait_for_voltage_stable(i2caddress); if (vdd_last < 0) @@ -276,185 +408,110 @@ static int set_voltage(int i2caddress, int vdd) { int vdd_last = -1;
+ /* Compensate for a board specific voltage drop between regulator and + * SoC before converting into a VID value + */ + vdd += board_vdd_drop_compensation(); #ifdef CONFIG_VOL_MONITOR_IR36021_SET vdd_last = set_voltage_to_IR(i2caddress, vdd); +#elif defined(CONFIG_VOL_MONITOR_LTC3882) + vdd_last = set_voltage_to_LTC3882(i2caddress, vdd); #else #error Specific voltage monitor must be defined #endif return vdd_last; }
-#ifdef CONFIG_FSL_LSCH3 -int adjust_vdd(ulong vdd_override) +#if defined(CONFIG_FSL_LSCH3) +static bool soc_has_lowbitsinfusesr(struct ccsr_gur *gur) { - int re_enable = disable_interrupts(); - struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); - u32 fusesr; - u8 vid, buf; - int vdd_target, vdd_current, vdd_last; - int ret, i2caddress; - unsigned long vdd_string_override; - char *vdd_string; - static const uint16_t vdd[32] = { - 10500, - 0, /* reserved */ - 9750, - 0, /* reserved */ - 9500, - 0, /* reserved */ - 0, /* reserved */ - 0, /* reserved */ - 0, /* reserved */ - 0, /* reserved */ - 0, /* reserved */ - 0, /* reserved */ - 0, /* reserved */ - 0, /* reserved */ - 0, /* reserved */ - 0, /* reserved */ - 10000, /* 1.0000V */ - 0, /* reserved */ - 10250, - 0, /* reserved */ - 10500, - 0, /* reserved */ - 0, /* reserved */ - 0, /* reserved */ - 0, /* reserved */ - 0, /* reserved */ - 0, /* reserved */ - 0, /* reserved */ - 0, /* reserved */ - 0, /* reserved */ - 0, /* reserved */ - 0, /* reserved */ - }; - struct vdd_drive { - u8 vid; - unsigned voltage; - };
- ret = i2c_multiplexer_select_vid_channel(I2C_MUX_CH_VOL_MONITOR); - if (ret) { - debug("VID: I2C failed to switch channel\n"); - ret = -1; - goto exit; - } - ret = find_ir_chip_on_i2c(); - if (ret < 0) { - printf("VID: Could not find voltage regulator on I2C.\n"); - ret = -1; - goto exit; - } else { - i2caddress = ret; - debug("VID: IR Chip found on I2C address 0x%02x\n", i2caddress); - } + u32 svr = in_le32(&gur->svr);
- /* check IR chip work on Intel mode*/ - ret = i2c_read(i2caddress, - IR36021_INTEL_MODE_OOFSET, - 1, (void *)&buf, 1); - if (ret) { - printf("VID: failed to read IR chip mode.\n"); - ret = -1; - goto exit; - } - if ((buf & IR36021_MODE_MASK) != IR36021_INTEL_MODE) { - printf("VID: IR Chip is not used in Intel mode.\n"); - ret = -1; - goto exit; + /* LS2088A derivatives have different FUSESR */ + switch(SVR_SOC_VER(svr)) { + case SVR_LS2088A: + case SVR_LS2048A: + case SVR_LS2084A: + case SVR_LS2044A: + return true; }
- /* get the voltage ID from fuse status register */ - fusesr = in_le32(&gur->dcfg_fusesr); - vid = (fusesr >> FSL_CHASSIS3_DCFG_FUSESR_ALTVID_SHIFT) & - FSL_CHASSIS3_DCFG_FUSESR_ALTVID_MASK; - if ((vid == 0) || (vid == FSL_CHASSIS3_DCFG_FUSESR_ALTVID_MASK)) { - vid = (fusesr >> FSL_CHASSIS3_DCFG_FUSESR_VID_SHIFT) & - FSL_CHASSIS3_DCFG_FUSESR_VID_MASK; - } - vdd_target = vdd[vid]; + return false; +} +#endif
- /* check override variable for overriding VDD */ - vdd_string = env_get(CONFIG_VID_FLS_ENV); - if (vdd_override == 0 && vdd_string && - !strict_strtoul(vdd_string, 10, &vdd_string_override)) - vdd_override = vdd_string_override; +int vid_set_mv_limits(int absmax, + int marginhigh, int marginlow, + int ovfault, int ovwarn, + int uvwarn, int uvfault) +{ + int ret; + int i2caddress;
- if (vdd_override >= VDD_MV_MIN && vdd_override <= VDD_MV_MAX) { - vdd_target = vdd_override * 10; /* convert to 1/10 mV */ - debug("VDD override is %lu\n", vdd_override); - } else if (vdd_override != 0) { - printf("Invalid value.\n"); + ret = i2c_multiplexer_select_vid_channel(I2C_MUX_CH_VOL_MONITOR); + if (ret) { + debug("VID: I2C failed to switch channel\n"); + return ret; } + i2caddress = find_vid_chip_on_i2c();
- /* divide and round up by 10 to get a value in mV */ - vdd_target = DIV_ROUND_UP(vdd_target, 10); - if (vdd_target == 0) { - debug("VID: VID not used\n"); - ret = 0; - goto exit; - } else if (vdd_target < VDD_MV_MIN || vdd_target > VDD_MV_MAX) { - /* Check vdd_target is in valid range */ - printf("VID: Target VID %d mV is not in range.\n", - vdd_target); +#if defined(CONFIG_VOL_MONITOR_LTC3882) + if (i2caddress >= 0) { + /* We need to program the voltage limits + * properly, or the chip may freak out on + * VID changes. + */ + ret = write_l16_mV_LTC3882(i2caddress, + LTC3882_VOUT_MAX, + absmax); + if (!ret) + ret = write_l16_mV_LTC3882(i2caddress, + LTC3882_VOUT_MARGIN_HIGH, + marginhigh); + if (!ret) + ret = write_l16_mV_LTC3882(i2caddress, + LTC3882_VOUT_MARGIN_LOW, + marginlow); + if (!ret) + ret = write_l16_mV_LTC3882(i2caddress, + LTC3882_VOUT_OV_FAULT_LIMIT, + ovfault); + if (!ret) + ret = write_l16_mV_LTC3882(i2caddress, + LTC3882_VOUT_OV_WARN_LIMIT, + ovwarn); + if (!ret) + ret = write_l16_mV_LTC3882(i2caddress, + LTC3882_VOUT_UV_WARN_LIMIT, + uvwarn); + if (!ret) + ret = write_l16_mV_LTC3882(i2caddress, + LTC3882_VOUT_UV_FAULT_LIMIT, + uvfault); + } else ret = -1; - goto exit; - } else { - debug("VID: vid = %d mV\n", vdd_target); - }
- /* - * Read voltage monitor to check real voltage. - */ - vdd_last = read_voltage(i2caddress); - if (vdd_last < 0) { - printf("VID: Couldn't read sensor abort VID adjustment\n"); - ret = -1; - goto exit; - } - vdd_current = vdd_last; - debug("VID: Core voltage is currently at %d mV\n", vdd_last); - /* - * Adjust voltage to at or one step above target. - * As measurements are less precise than setting the values - * we may run through dummy steps that cancel each other - * when stepping up and then down. - */ - while (vdd_last > 0 && - vdd_last < vdd_target) { - vdd_current += IR_VDD_STEP_UP; - vdd_last = set_voltage(i2caddress, vdd_current); - } - while (vdd_last > 0 && - vdd_last > vdd_target + (IR_VDD_STEP_DOWN - 1)) { - vdd_current -= IR_VDD_STEP_DOWN; - vdd_last = set_voltage(i2caddress, vdd_current); - } +#endif + if (ret) + printf("VID: Setting voltage limits failed! VID regulation may not be stable!\n");
- if (vdd_last > 0) - printf("VID: Core voltage after adjustment is at %d mV\n", - vdd_last); - else - ret = -1; -exit: - if (re_enable) - enable_interrupts(); i2c_multiplexer_select_vid_channel(I2C_MUX_CH_DEFAULT); + return ret; } -#else /* !CONFIG_FSL_LSCH3 */ + int adjust_vdd(ulong vdd_override) { int re_enable = disable_interrupts(); -#if defined(CONFIG_FSL_LSCH2) +#if defined(CONFIG_FSL_LSCH2) || defined(CONFIG_FSL_LSCH3) struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); #else ccsr_gur_t __iomem *gur = (void __iomem *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); #endif u32 fusesr; - u8 vid, buf; + u8 vid; int vdd_target, vdd_current, vdd_last; int ret, i2caddress; unsigned long vdd_string_override; @@ -498,33 +555,22 @@ int adjust_vdd(ulong vdd_override) ret = -1; goto exit; } - ret = find_ir_chip_on_i2c(); + ret = find_vid_chip_on_i2c(); if (ret < 0) { printf("VID: Could not find voltage regulator on I2C.\n"); ret = -1; goto exit; } else { i2caddress = ret; - debug("VID: IR Chip found on I2C address 0x%02x\n", i2caddress); - } - - /* check IR chip work on Intel mode*/ - ret = i2c_read(i2caddress, - IR36021_INTEL_MODE_OOFSET, - 1, (void *)&buf, 1); - if (ret) { - printf("VID: failed to read IR chip mode.\n"); - ret = -1; - goto exit; - } - if ((buf & IR36021_MODE_MASK) != IR36021_INTEL_MODE) { - printf("VID: IR Chip is not used in Intel mode.\n"); - ret = -1; - goto exit; + debug("VID: Voltage regulator found on I2C address 0x%02x\n", i2caddress); }
/* get the voltage ID from fuse status register */ +#ifdef CONFIG_FSL_LSCH3 + fusesr = in_le32(&gur->dcfg_fusesr); +#else fusesr = in_be32(&gur->dcfg_fusesr); +#endif /* * VID is used according to the table below * --------------------------------------- @@ -549,6 +595,22 @@ int adjust_vdd(ulong vdd_override) vid = (fusesr >> FSL_CHASSIS2_DCFG_FUSESR_VID_SHIFT) & FSL_CHASSIS2_DCFG_FUSESR_VID_MASK; } +#elif defined(CONFIG_FSL_LSCH3) + if(soc_has_lowbitsinfusesr(gur)) { + vid = (fusesr >> FSL_CHASSIS3_DCFG_FUSESR_LOW_ALTVID_SHIFT) & + FSL_CHASSIS3_DCFG_FUSESR_LOW_ALTVID_MASK; + if ((vid == 0) || (vid == FSL_CHASSIS3_DCFG_FUSESR_LOW_ALTVID_MASK)) { + vid = (fusesr >> FSL_CHASSIS3_DCFG_FUSESR_LOW_VID_SHIFT) & + FSL_CHASSIS3_DCFG_FUSESR_LOW_VID_MASK; + } + } else { + vid = (fusesr >> FSL_CHASSIS3_DCFG_FUSESR_ALTVID_SHIFT) & + FSL_CHASSIS3_DCFG_FUSESR_ALTVID_MASK; + if ((vid == 0) || (vid == FSL_CHASSIS3_DCFG_FUSESR_ALTVID_MASK)) { + vid = (fusesr >> FSL_CHASSIS3_DCFG_FUSESR_VID_SHIFT) & + FSL_CHASSIS3_DCFG_FUSESR_VID_MASK; + } + } #else vid = (fusesr >> FSL_CORENET_DCFG_FUSESR_ALTVID_SHIFT) & FSL_CORENET_DCFG_FUSESR_ALTVID_MASK; @@ -568,7 +630,7 @@ int adjust_vdd(ulong vdd_override) vdd_target = vdd_override * 10; /* convert to 1/10 mV */ debug("VDD override is %lu\n", vdd_override); } else if (vdd_override != 0) { - printf("Invalid value.\n"); + printf("VID: Invalid override value %lu mV.\n", vdd_override); } if (vdd_target == 0) { debug("VID: VID not used\n"); @@ -577,7 +639,7 @@ int adjust_vdd(ulong vdd_override) } else { /* divide and round up by 10 to get a value in mV */ vdd_target = DIV_ROUND_UP(vdd_target, 10); - debug("VID: vid = %d mV\n", vdd_target); + printf("VID: SoC target voltage = %d mV\n", vdd_target); }
/* @@ -598,19 +660,23 @@ int adjust_vdd(ulong vdd_override) * when stepping up and then down. */ while (vdd_last > 0 && - vdd_last < vdd_target) { + vdd_last < vdd_target && + vdd_current < vdd_target) { vdd_current += IR_VDD_STEP_UP; vdd_last = set_voltage(i2caddress, vdd_current); } while (vdd_last > 0 && - vdd_last > vdd_target + (IR_VDD_STEP_DOWN - 1)) { + vdd_last > vdd_target + (IR_VDD_STEP_DOWN - 1) && + vdd_current > vdd_target + (IR_VDD_STEP_DOWN - 1)) { vdd_current -= IR_VDD_STEP_DOWN; vdd_last = set_voltage(i2caddress, vdd_current); }
- if (vdd_last > 0) + if (vdd_last > 0) { printf("VID: Core voltage after adjustment is at %d mV\n", vdd_last); + ret = 0; + } else ret = -1; exit: @@ -621,7 +687,6 @@ exit:
return ret; } -#endif
static int print_vdd(void) { @@ -629,16 +694,16 @@ static int print_vdd(void)
ret = i2c_multiplexer_select_vid_channel(I2C_MUX_CH_VOL_MONITOR); if (ret) { - debug("VID : I2c failed to switch channel\n"); + debug("VID : I2C failed to switch channel\n"); return -1; } - ret = find_ir_chip_on_i2c(); + ret = find_vid_chip_on_i2c(); if (ret < 0) { printf("VID: Could not find voltage regulator on I2C.\n"); goto exit; } else { i2caddress = ret; - debug("VID: IR Chip found on I2C address 0x%02x\n", i2caddress); + debug("VID: Chip found on I2C address 0x%02x\n", i2caddress); }
/* diff --git a/board/freescale/common/vid.h b/board/freescale/common/vid.h index 9182c20..ea2ea7a 100644 --- a/board/freescale/common/vid.h +++ b/board/freescale/common/vid.h @@ -16,9 +16,28 @@ #define IR36021_INTEL_MODE 0x00 #define IR36021_AMD_MODE 0x20
+/* Declarations for the LTC3882 */ +#define LTC3882_PAGE 0x00 +#define LTC3882_VOUT_COMMAND 0x21 +#define LTC3882_VOUT_MAX 0x24 +#define LTC3882_VOUT_MARGIN_HIGH 0x25 +#define LTC3882_VOUT_MARGIN_LOW 0x26 +#define LTC3882_VOUT_OV_FAULT_LIMIT 0x40 +#define LTC3882_VOUT_OV_WARN_LIMIT 0x42 +#define LTC3882_VOUT_UV_WARN_LIMIT 0x43 +#define LTC3882_VOUT_UV_FAULT_LIMIT 0x44 +#define LTC3882_READ_VOUT 0x8B +#define LTC3882_MFR_ID 0x99 +#define LTC3882_MFR_MODEL 0x9A + /* step the IR regulator in 5mV increments */ #define IR_VDD_STEP_DOWN 5 #define IR_VDD_STEP_UP 5 + +int vid_set_mv_limits(int absmax, + int marginhigh, int marginlow, + int ovfault, int ovwarn, + int uvwarn, int uvfault); int adjust_vdd(ulong vdd_override);
#endif /* __VID_H_ */
