[U-Boot] [PATCH 1/2] power: ftpmu010: move drivers/power/ftpmu010.h to include/
Also add API declarations.
Signed-off-by: Po-Yu Chuang ratbert@faraday-tech.com --- drivers/power/ftpmu010.c | 2 +- drivers/power/ftpmu010.h | 146 -------------------------------------------- include/ftpmu010.h | 150 ++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 151 insertions(+), 147 deletions(-) delete mode 100644 drivers/power/ftpmu010.h create mode 100644 include/ftpmu010.h
diff --git a/drivers/power/ftpmu010.c b/drivers/power/ftpmu010.c index 7924ac1..dc4ca5d 100644 --- a/drivers/power/ftpmu010.c +++ b/drivers/power/ftpmu010.c @@ -23,7 +23,7 @@
#include <common.h> #include <asm/io.h> -#include "ftpmu010.h" +#include <ftpmu010.h>
static struct ftpmu010 *pmu = (struct ftpmu010 *)CONFIG_FTPMU010_BASE;
diff --git a/drivers/power/ftpmu010.h b/drivers/power/ftpmu010.h deleted file mode 100644 index 8ef7a37..0000000 --- a/drivers/power/ftpmu010.h +++ /dev/null @@ -1,146 +0,0 @@ -/* - * (C) Copyright 2009 Faraday Technology - * Po-Yu Chuang ratbert@faraday-tech.com - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. - */ - -/* - * Power Management Unit - */ -#ifndef __FTPMU010_H -#define __FTPMU010_H - -struct ftpmu010 { - unsigned int IDNMBR0; /* 0x00 */ - unsigned int reserved0; /* 0x04 */ - unsigned int OSCC; /* 0x08 */ - unsigned int PMODE; /* 0x0C */ - unsigned int PMCR; /* 0x10 */ - unsigned int PED; /* 0x14 */ - unsigned int PEDSR; /* 0x18 */ - unsigned int reserved1; /* 0x1C */ - unsigned int PMSR; /* 0x20 */ - unsigned int PGSR; /* 0x24 */ - unsigned int MFPSR; /* 0x28 */ - unsigned int MISC; /* 0x2C */ - unsigned int PDLLCR0; /* 0x30 */ - unsigned int PDLLCR1; /* 0x34 */ - unsigned int AHBMCLKOFF; /* 0x38 */ - unsigned int APBMCLKOFF; /* 0x3C */ - unsigned int DCSRCR0; /* 0x40 */ - unsigned int DCSRCR1; /* 0x44 */ - unsigned int DCSRCR2; /* 0x48 */ - unsigned int SDRAMHTC; /* 0x4C */ - unsigned int PSPR0; /* 0x50 */ - unsigned int PSPR1; /* 0x54 */ - unsigned int PSPR2; /* 0x58 */ - unsigned int PSPR3; /* 0x5C */ - unsigned int PSPR4; /* 0x60 */ - unsigned int PSPR5; /* 0x64 */ - unsigned int PSPR6; /* 0x68 */ - unsigned int PSPR7; /* 0x6C */ - unsigned int PSPR8; /* 0x70 */ - unsigned int PSPR9; /* 0x74 */ - unsigned int PSPR10; /* 0x78 */ - unsigned int PSPR11; /* 0x7C */ - unsigned int PSPR12; /* 0x80 */ - unsigned int PSPR13; /* 0x84 */ - unsigned int PSPR14; /* 0x88 */ - unsigned int PSPR15; /* 0x8C */ - unsigned int AHBDMA_RACCS; /* 0x90 */ - unsigned int reserved2; /* 0x94 */ - unsigned int reserved3; /* 0x98 */ - unsigned int JSS; /* 0x9C */ - unsigned int CFC_RACC; /* 0xA0 */ - unsigned int SSP1_RACC; /* 0xA4 */ - unsigned int UART1TX_RACC; /* 0xA8 */ - unsigned int UART1RX_RACC; /* 0xAC */ - unsigned int UART2TX_RACC; /* 0xB0 */ - unsigned int UART2RX_RACC; /* 0xB4 */ - unsigned int SDC_RACC; /* 0xB8 */ - unsigned int I2SAC97_RACC; /* 0xBC */ - unsigned int IRDATX_RACC; /* 0xC0 */ - unsigned int reserved4; /* 0xC4 */ - unsigned int USBD_RACC; /* 0xC8 */ - unsigned int IRDARX_RACC; /* 0xCC */ - unsigned int IRDA_RACC; /* 0xD0 */ - unsigned int ED0_RACC; /* 0xD4 */ - unsigned int ED1_RACC; /* 0xD8 */ -}; - -/* - * ID Number 0 Register - */ -#define FTPMU010_ID_A320A 0x03200000 -#define FTPMU010_ID_A320C 0x03200010 -#define FTPMU010_ID_A320D 0x03200030 - -/* - * OSC Control Register - */ -#define FTPMU010_OSCC_OSCH_TRI (1 << 11) -#define FTPMU010_OSCC_OSCH_STABLE (1 << 9) -#define FTPMU010_OSCC_OSCH_OFF (1 << 8) - -#define FTPMU010_OSCC_OSCL_TRI (1 << 3) -#define FTPMU010_OSCC_OSCL_RTCLSEL (1 << 2) -#define FTPMU010_OSCC_OSCL_STABLE (1 << 1) -#define FTPMU010_OSCC_OSCL_OFF (1 << 0) - -/* - * Power Mode Register - */ -#define FTPMU010_PMODE_DIVAHBCLK_MASK (0x7 << 4) -#define FTPMU010_PMODE_DIVAHBCLK_2 (0x0 << 4) -#define FTPMU010_PMODE_DIVAHBCLK_3 (0x1 << 4) -#define FTPMU010_PMODE_DIVAHBCLK_4 (0x2 << 4) -#define FTPMU010_PMODE_DIVAHBCLK_6 (0x3 << 4) -#define FTPMU010_PMODE_DIVAHBCLK_8 (0x4 << 4) -#define FTPMU010_PMODE_DIVAHBCLK(pmode) (((pmode) >> 4) & 0x7) -#define FTPMU010_PMODE_FCS (1 << 2) -#define FTPMU010_PMODE_TURBO (1 << 1) -#define FTPMU010_PMODE_SLEEP (1 << 0) - -/* - * Power Manager Status Register - */ -#define FTPMU010_PMSR_SMR (1 << 10) - -#define FTPMU010_PMSR_RDH (1 << 2) -#define FTPMU010_PMSR_PH (1 << 1) -#define FTPMU010_PMSR_CKEHLOW (1 << 0) - -/* - * Multi-Function Port Setting Register - */ -#define FTPMU010_MFPSR_MODEMPINSEL (1 << 14) -#define FTPMU010_MFPSR_AC97CLKOUTSEL (1 << 13) -#define FTPMU010_MFPSR_AC97PINSEL (1 << 3) - -/* - * PLL/DLL Control Register 0 - */ -#define FTPMU010_PDLLCR0_HCLKOUTDIS(cr0) (((cr0) >> 20) & 0xf) -#define FTPMU010_PDLLCR0_DLLFRAG (1 << 19) -#define FTPMU010_PDLLCR0_DLLSTSEL (1 << 18) -#define FTPMU010_PDLLCR0_DLLSTABLE (1 << 17) -#define FTPMU010_PDLLCR0_DLLDIS (1 << 16) -#define FTPMU010_PDLLCR0_PLL1NS(cr0) (((cr0) >> 3) & 0x1ff) -#define FTPMU010_PDLLCR0_PLL1STSEL (1 << 2) -#define FTPMU010_PDLLCR0_PLL1STABLE (1 << 1) -#define FTPMU010_PDLLCR0_PLL1DIS (1 << 0) - -#endif /* __FTPMU010_H */ diff --git a/include/ftpmu010.h b/include/ftpmu010.h new file mode 100644 index 0000000..640f056 --- /dev/null +++ b/include/ftpmu010.h @@ -0,0 +1,150 @@ +/* + * (C) Copyright 2009 Faraday Technology + * Po-Yu Chuang ratbert@faraday-tech.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +/* + * Power Management Unit + */ +#ifndef __FTPMU010_H +#define __FTPMU010_H + +struct ftpmu010 { + unsigned int IDNMBR0; /* 0x00 */ + unsigned int reserved0; /* 0x04 */ + unsigned int OSCC; /* 0x08 */ + unsigned int PMODE; /* 0x0C */ + unsigned int PMCR; /* 0x10 */ + unsigned int PED; /* 0x14 */ + unsigned int PEDSR; /* 0x18 */ + unsigned int reserved1; /* 0x1C */ + unsigned int PMSR; /* 0x20 */ + unsigned int PGSR; /* 0x24 */ + unsigned int MFPSR; /* 0x28 */ + unsigned int MISC; /* 0x2C */ + unsigned int PDLLCR0; /* 0x30 */ + unsigned int PDLLCR1; /* 0x34 */ + unsigned int AHBMCLKOFF; /* 0x38 */ + unsigned int APBMCLKOFF; /* 0x3C */ + unsigned int DCSRCR0; /* 0x40 */ + unsigned int DCSRCR1; /* 0x44 */ + unsigned int DCSRCR2; /* 0x48 */ + unsigned int SDRAMHTC; /* 0x4C */ + unsigned int PSPR0; /* 0x50 */ + unsigned int PSPR1; /* 0x54 */ + unsigned int PSPR2; /* 0x58 */ + unsigned int PSPR3; /* 0x5C */ + unsigned int PSPR4; /* 0x60 */ + unsigned int PSPR5; /* 0x64 */ + unsigned int PSPR6; /* 0x68 */ + unsigned int PSPR7; /* 0x6C */ + unsigned int PSPR8; /* 0x70 */ + unsigned int PSPR9; /* 0x74 */ + unsigned int PSPR10; /* 0x78 */ + unsigned int PSPR11; /* 0x7C */ + unsigned int PSPR12; /* 0x80 */ + unsigned int PSPR13; /* 0x84 */ + unsigned int PSPR14; /* 0x88 */ + unsigned int PSPR15; /* 0x8C */ + unsigned int AHBDMA_RACCS; /* 0x90 */ + unsigned int reserved2; /* 0x94 */ + unsigned int reserved3; /* 0x98 */ + unsigned int JSS; /* 0x9C */ + unsigned int CFC_RACC; /* 0xA0 */ + unsigned int SSP1_RACC; /* 0xA4 */ + unsigned int UART1TX_RACC; /* 0xA8 */ + unsigned int UART1RX_RACC; /* 0xAC */ + unsigned int UART2TX_RACC; /* 0xB0 */ + unsigned int UART2RX_RACC; /* 0xB4 */ + unsigned int SDC_RACC; /* 0xB8 */ + unsigned int I2SAC97_RACC; /* 0xBC */ + unsigned int IRDATX_RACC; /* 0xC0 */ + unsigned int reserved4; /* 0xC4 */ + unsigned int USBD_RACC; /* 0xC8 */ + unsigned int IRDARX_RACC; /* 0xCC */ + unsigned int IRDA_RACC; /* 0xD0 */ + unsigned int ED0_RACC; /* 0xD4 */ + unsigned int ED1_RACC; /* 0xD8 */ +}; + +/* + * ID Number 0 Register + */ +#define FTPMU010_ID_A320A 0x03200000 +#define FTPMU010_ID_A320C 0x03200010 +#define FTPMU010_ID_A320D 0x03200030 + +/* + * OSC Control Register + */ +#define FTPMU010_OSCC_OSCH_TRI (1 << 11) +#define FTPMU010_OSCC_OSCH_STABLE (1 << 9) +#define FTPMU010_OSCC_OSCH_OFF (1 << 8) + +#define FTPMU010_OSCC_OSCL_TRI (1 << 3) +#define FTPMU010_OSCC_OSCL_RTCLSEL (1 << 2) +#define FTPMU010_OSCC_OSCL_STABLE (1 << 1) +#define FTPMU010_OSCC_OSCL_OFF (1 << 0) + +/* + * Power Mode Register + */ +#define FTPMU010_PMODE_DIVAHBCLK_MASK (0x7 << 4) +#define FTPMU010_PMODE_DIVAHBCLK_2 (0x0 << 4) +#define FTPMU010_PMODE_DIVAHBCLK_3 (0x1 << 4) +#define FTPMU010_PMODE_DIVAHBCLK_4 (0x2 << 4) +#define FTPMU010_PMODE_DIVAHBCLK_6 (0x3 << 4) +#define FTPMU010_PMODE_DIVAHBCLK_8 (0x4 << 4) +#define FTPMU010_PMODE_DIVAHBCLK(pmode) (((pmode) >> 4) & 0x7) +#define FTPMU010_PMODE_FCS (1 << 2) +#define FTPMU010_PMODE_TURBO (1 << 1) +#define FTPMU010_PMODE_SLEEP (1 << 0) + +/* + * Power Manager Status Register + */ +#define FTPMU010_PMSR_SMR (1 << 10) + +#define FTPMU010_PMSR_RDH (1 << 2) +#define FTPMU010_PMSR_PH (1 << 1) +#define FTPMU010_PMSR_CKEHLOW (1 << 0) + +/* + * Multi-Function Port Setting Register + */ +#define FTPMU010_MFPSR_MODEMPINSEL (1 << 14) +#define FTPMU010_MFPSR_AC97CLKOUTSEL (1 << 13) +#define FTPMU010_MFPSR_AC97PINSEL (1 << 3) + +/* + * PLL/DLL Control Register 0 + */ +#define FTPMU010_PDLLCR0_HCLKOUTDIS(cr0) (((cr0) >> 20) & 0xf) +#define FTPMU010_PDLLCR0_DLLFRAG (1 << 19) +#define FTPMU010_PDLLCR0_DLLSTSEL (1 << 18) +#define FTPMU010_PDLLCR0_DLLSTABLE (1 << 17) +#define FTPMU010_PDLLCR0_DLLDIS (1 << 16) +#define FTPMU010_PDLLCR0_PLL1NS(cr0) (((cr0) >> 3) & 0x1ff) +#define FTPMU010_PDLLCR0_PLL1STSEL (1 << 2) +#define FTPMU010_PDLLCR0_PLL1STABLE (1 << 1) +#define FTPMU010_PDLLCR0_PLL1DIS (1 << 0) + +void ftpmu010_32768osc_enable(void); +void ftpmu010_dlldis_disable(void); +void ftpmu010_sdram_clk_disable(unsigned int cr0); + +#endif /* __FTPMU010_H */
Hi Po-Yu,
2011/2/16 Po-Yu Chuang ratbert.chuang@gmail.com:
Just one comment which has been replied earlier in the previous discuss. Put ftpmu010.h into "include/faraday" instead of "include".
Hi Macpaul,
On Wed, Feb 16, 2011 at 5:23 PM, Macpaul Lin macpaul@gmail.com wrote:
Hi Po-Yu,
Agree. It will be nicer.
Wolfgang, do you have any comment?
regards, Po-Yu Chuang
Signed-off-by: Po-Yu Chuang ratbert@faraday-tech.com --- v2: move include/ftpmu010.h to include/faraday/ftpmu010.h
drivers/power/ftpmu010.c | 2 +- drivers/power/ftpmu010.h | 146 ------------------------------------------ include/faraday/ftpmu010.h | 150 ++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 151 insertions(+), 147 deletions(-) delete mode 100644 drivers/power/ftpmu010.h create mode 100644 include/faraday/ftpmu010.h
diff --git a/drivers/power/ftpmu010.c b/drivers/power/ftpmu010.c index 7924ac1..c6a8cda 100644 --- a/drivers/power/ftpmu010.c +++ b/drivers/power/ftpmu010.c @@ -23,7 +23,7 @@
#include <common.h> #include <asm/io.h> -#include "ftpmu010.h" +#include <faraday/ftpmu010.h>
diff --git a/drivers/power/ftpmu010.h b/drivers/power/ftpmu010.h deleted file mode 100644 index 8ef7a37..0000000 --- a/drivers/power/ftpmu010.h +++ /dev/null @@ -1,146 +0,0 @@ -/* - * (C) Copyright 2009 Faraday Technology - * Po-Yu Chuang ratbert@faraday-tech.com - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. - */ - -/* - * Power Management Unit - */ -#ifndef __FTPMU010_H -#define __FTPMU010_H - -struct ftpmu010 { - unsigned int IDNMBR0; /* 0x00 */ - unsigned int reserved0; /* 0x04 */ - unsigned int OSCC; /* 0x08 */ - unsigned int PMODE; /* 0x0C */ - unsigned int PMCR; /* 0x10 */ - unsigned int PED; /* 0x14 */ - unsigned int PEDSR; /* 0x18 */ - unsigned int reserved1; /* 0x1C */ - unsigned int PMSR; /* 0x20 */ - unsigned int PGSR; /* 0x24 */ - unsigned int MFPSR; /* 0x28 */ - unsigned int MISC; /* 0x2C */ - unsigned int PDLLCR0; /* 0x30 */ - unsigned int PDLLCR1; /* 0x34 */ - unsigned int AHBMCLKOFF; /* 0x38 */ - unsigned int APBMCLKOFF; /* 0x3C */ - unsigned int DCSRCR0; /* 0x40 */ - unsigned int DCSRCR1; /* 0x44 */ - unsigned int DCSRCR2; /* 0x48 */ - unsigned int SDRAMHTC; /* 0x4C */ - unsigned int PSPR0; /* 0x50 */ - unsigned int PSPR1; /* 0x54 */ - unsigned int PSPR2; /* 0x58 */ - unsigned int PSPR3; /* 0x5C */ - unsigned int PSPR4; /* 0x60 */ - unsigned int PSPR5; /* 0x64 */ - unsigned int PSPR6; /* 0x68 */ - unsigned int PSPR7; /* 0x6C */ - unsigned int PSPR8; /* 0x70 */ - unsigned int PSPR9; /* 0x74 */ - unsigned int PSPR10; /* 0x78 */ - unsigned int PSPR11; /* 0x7C */ - unsigned int PSPR12; /* 0x80 */ - unsigned int PSPR13; /* 0x84 */ - unsigned int PSPR14; /* 0x88 */ - unsigned int PSPR15; /* 0x8C */ - unsigned int AHBDMA_RACCS; /* 0x90 */ - unsigned int reserved2; /* 0x94 */ - unsigned int reserved3; /* 0x98 */ - unsigned int JSS; /* 0x9C */ - unsigned int CFC_RACC; /* 0xA0 */ - unsigned int SSP1_RACC; /* 0xA4 */ - unsigned int UART1TX_RACC; /* 0xA8 */ - unsigned int UART1RX_RACC; /* 0xAC */ - unsigned int UART2TX_RACC; /* 0xB0 */ - unsigned int UART2RX_RACC; /* 0xB4 */ - unsigned int SDC_RACC; /* 0xB8 */ - unsigned int I2SAC97_RACC; /* 0xBC */ - unsigned int IRDATX_RACC; /* 0xC0 */ - unsigned int reserved4; /* 0xC4 */ - unsigned int USBD_RACC; /* 0xC8 */ - unsigned int IRDARX_RACC; /* 0xCC */ - unsigned int IRDA_RACC; /* 0xD0 */ - unsigned int ED0_RACC; /* 0xD4 */ - unsigned int ED1_RACC; /* 0xD8 */ -}; - -/* - * ID Number 0 Register - */ -#define FTPMU010_ID_A320A 0x03200000 -#define FTPMU010_ID_A320C 0x03200010 -#define FTPMU010_ID_A320D 0x03200030 - -/* - * OSC Control Register - */ -#define FTPMU010_OSCC_OSCH_TRI (1 << 11) -#define FTPMU010_OSCC_OSCH_STABLE (1 << 9) -#define FTPMU010_OSCC_OSCH_OFF (1 << 8) - -#define FTPMU010_OSCC_OSCL_TRI (1 << 3) -#define FTPMU010_OSCC_OSCL_RTCLSEL (1 << 2) -#define FTPMU010_OSCC_OSCL_STABLE (1 << 1) -#define FTPMU010_OSCC_OSCL_OFF (1 << 0) - -/* - * Power Mode Register - */ -#define FTPMU010_PMODE_DIVAHBCLK_MASK (0x7 << 4) -#define FTPMU010_PMODE_DIVAHBCLK_2 (0x0 << 4) -#define FTPMU010_PMODE_DIVAHBCLK_3 (0x1 << 4) -#define FTPMU010_PMODE_DIVAHBCLK_4 (0x2 << 4) -#define FTPMU010_PMODE_DIVAHBCLK_6 (0x3 << 4) -#define FTPMU010_PMODE_DIVAHBCLK_8 (0x4 << 4) -#define FTPMU010_PMODE_DIVAHBCLK(pmode) (((pmode) >> 4) & 0x7) -#define FTPMU010_PMODE_FCS (1 << 2) -#define FTPMU010_PMODE_TURBO (1 << 1) -#define FTPMU010_PMODE_SLEEP (1 << 0) - -/* - * Power Manager Status Register - */ -#define FTPMU010_PMSR_SMR (1 << 10) - -#define FTPMU010_PMSR_RDH (1 << 2) -#define FTPMU010_PMSR_PH (1 << 1) -#define FTPMU010_PMSR_CKEHLOW (1 << 0) - -/* - * Multi-Function Port Setting Register - */ -#define FTPMU010_MFPSR_MODEMPINSEL (1 << 14) -#define FTPMU010_MFPSR_AC97CLKOUTSEL (1 << 13) -#define FTPMU010_MFPSR_AC97PINSEL (1 << 3) - -/* - * PLL/DLL Control Register 0 - */ -#define FTPMU010_PDLLCR0_HCLKOUTDIS(cr0) (((cr0) >> 20) & 0xf) -#define FTPMU010_PDLLCR0_DLLFRAG (1 << 19) -#define FTPMU010_PDLLCR0_DLLSTSEL (1 << 18) -#define FTPMU010_PDLLCR0_DLLSTABLE (1 << 17) -#define FTPMU010_PDLLCR0_DLLDIS (1 << 16) -#define FTPMU010_PDLLCR0_PLL1NS(cr0) (((cr0) >> 3) & 0x1ff) -#define FTPMU010_PDLLCR0_PLL1STSEL (1 << 2) -#define FTPMU010_PDLLCR0_PLL1STABLE (1 << 1) -#define FTPMU010_PDLLCR0_PLL1DIS (1 << 0) - -#endif /* __FTPMU010_H */ diff --git a/include/faraday/ftpmu010.h b/include/faraday/ftpmu010.h new file mode 100644 index 0000000..640f056 --- /dev/null +++ b/include/faraday/ftpmu010.h @@ -0,0 +1,150 @@ +/* + * (C) Copyright 2009 Faraday Technology + * Po-Yu Chuang ratbert@faraday-tech.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +/* + * Power Management Unit + */ +#ifndef __FTPMU010_H +#define __FTPMU010_H + +struct ftpmu010 { + unsigned int IDNMBR0; /* 0x00 */ + unsigned int reserved0; /* 0x04 */ + unsigned int OSCC; /* 0x08 */ + unsigned int PMODE; /* 0x0C */ + unsigned int PMCR; /* 0x10 */ + unsigned int PED; /* 0x14 */ + unsigned int PEDSR; /* 0x18 */ + unsigned int reserved1; /* 0x1C */ + unsigned int PMSR; /* 0x20 */ + unsigned int PGSR; /* 0x24 */ + unsigned int MFPSR; /* 0x28 */ + unsigned int MISC; /* 0x2C */ + unsigned int PDLLCR0; /* 0x30 */ + unsigned int PDLLCR1; /* 0x34 */ + unsigned int AHBMCLKOFF; /* 0x38 */ + unsigned int APBMCLKOFF; /* 0x3C */ + unsigned int DCSRCR0; /* 0x40 */ + unsigned int DCSRCR1; /* 0x44 */ + unsigned int DCSRCR2; /* 0x48 */ + unsigned int SDRAMHTC; /* 0x4C */ + unsigned int PSPR0; /* 0x50 */ + unsigned int PSPR1; /* 0x54 */ + unsigned int PSPR2; /* 0x58 */ + unsigned int PSPR3; /* 0x5C */ + unsigned int PSPR4; /* 0x60 */ + unsigned int PSPR5; /* 0x64 */ + unsigned int PSPR6; /* 0x68 */ + unsigned int PSPR7; /* 0x6C */ + unsigned int PSPR8; /* 0x70 */ + unsigned int PSPR9; /* 0x74 */ + unsigned int PSPR10; /* 0x78 */ + unsigned int PSPR11; /* 0x7C */ + unsigned int PSPR12; /* 0x80 */ + unsigned int PSPR13; /* 0x84 */ + unsigned int PSPR14; /* 0x88 */ + unsigned int PSPR15; /* 0x8C */ + unsigned int AHBDMA_RACCS; /* 0x90 */ + unsigned int reserved2; /* 0x94 */ + unsigned int reserved3; /* 0x98 */ + unsigned int JSS; /* 0x9C */ + unsigned int CFC_RACC; /* 0xA0 */ + unsigned int SSP1_RACC; /* 0xA4 */ + unsigned int UART1TX_RACC; /* 0xA8 */ + unsigned int UART1RX_RACC; /* 0xAC */ + unsigned int UART2TX_RACC; /* 0xB0 */ + unsigned int UART2RX_RACC; /* 0xB4 */ + unsigned int SDC_RACC; /* 0xB8 */ + unsigned int I2SAC97_RACC; /* 0xBC */ + unsigned int IRDATX_RACC; /* 0xC0 */ + unsigned int reserved4; /* 0xC4 */ + unsigned int USBD_RACC; /* 0xC8 */ + unsigned int IRDARX_RACC; /* 0xCC */ + unsigned int IRDA_RACC; /* 0xD0 */ + unsigned int ED0_RACC; /* 0xD4 */ + unsigned int ED1_RACC; /* 0xD8 */ +}; + +/* + * ID Number 0 Register + */ +#define FTPMU010_ID_A320A 0x03200000 +#define FTPMU010_ID_A320C 0x03200010 +#define FTPMU010_ID_A320D 0x03200030 + +/* + * OSC Control Register + */ +#define FTPMU010_OSCC_OSCH_TRI (1 << 11) +#define FTPMU010_OSCC_OSCH_STABLE (1 << 9) +#define FTPMU010_OSCC_OSCH_OFF (1 << 8) + +#define FTPMU010_OSCC_OSCL_TRI (1 << 3) +#define FTPMU010_OSCC_OSCL_RTCLSEL (1 << 2) +#define FTPMU010_OSCC_OSCL_STABLE (1 << 1) +#define FTPMU010_OSCC_OSCL_OFF (1 << 0) + +/* + * Power Mode Register + */ +#define FTPMU010_PMODE_DIVAHBCLK_MASK (0x7 << 4) +#define FTPMU010_PMODE_DIVAHBCLK_2 (0x0 << 4) +#define FTPMU010_PMODE_DIVAHBCLK_3 (0x1 << 4) +#define FTPMU010_PMODE_DIVAHBCLK_4 (0x2 << 4) +#define FTPMU010_PMODE_DIVAHBCLK_6 (0x3 << 4) +#define FTPMU010_PMODE_DIVAHBCLK_8 (0x4 << 4) +#define FTPMU010_PMODE_DIVAHBCLK(pmode) (((pmode) >> 4) & 0x7) +#define FTPMU010_PMODE_FCS (1 << 2) +#define FTPMU010_PMODE_TURBO (1 << 1) +#define FTPMU010_PMODE_SLEEP (1 << 0) + +/* + * Power Manager Status Register + */ +#define FTPMU010_PMSR_SMR (1 << 10) + +#define FTPMU010_PMSR_RDH (1 << 2) +#define FTPMU010_PMSR_PH (1 << 1) +#define FTPMU010_PMSR_CKEHLOW (1 << 0) + +/* + * Multi-Function Port Setting Register + */ +#define FTPMU010_MFPSR_MODEMPINSEL (1 << 14) +#define FTPMU010_MFPSR_AC97CLKOUTSEL (1 << 13) +#define FTPMU010_MFPSR_AC97PINSEL (1 << 3) + +/* + * PLL/DLL Control Register 0 + */ +#define FTPMU010_PDLLCR0_HCLKOUTDIS(cr0) (((cr0) >> 20) & 0xf) +#define FTPMU010_PDLLCR0_DLLFRAG (1 << 19) +#define FTPMU010_PDLLCR0_DLLSTSEL (1 << 18) +#define FTPMU010_PDLLCR0_DLLSTABLE (1 << 17) +#define FTPMU010_PDLLCR0_DLLDIS (1 << 16) +#define FTPMU010_PDLLCR0_PLL1NS(cr0) (((cr0) >> 3) & 0x1ff) +#define FTPMU010_PDLLCR0_PLL1STSEL (1 << 2) +#define FTPMU010_PDLLCR0_PLL1STABLE (1 << 1) +#define FTPMU010_PDLLCR0_PLL1DIS (1 << 0) + +void ftpmu010_32768osc_enable(void); +void ftpmu010_dlldis_disable(void); +void ftpmu010_sdram_clk_disable(unsigned int cr0); + +#endif /* __FTPMU010_H */
Hi Wolfgang and Albert,
2011/2/18 Po-Yu Chuang ratbert.chuang@gmail.com
include/faraday/ftpmu010.h | 150 ++++++++++++++++++++++++++++++--
If the patch is reviewed and acceptable, would you please apply this patch in order to move ftpmu010.h from driver folder to include/faraday folder? Thus Po-Yu and I will commit the header definitions of those hardware peripherals made by Faraday into "include/faraday" folder to avoid this kind of "include ../../xxx.h" statement in other codes.
Thanks a lot.
Best regards, Macpaul Lin
HI all,
2011/2/25 Macpaul Lin macpaul@gmail.com
drivers/power/ftpmu010.c | 2 +- drivers/power/ftpmu010.h | 146 ------------------------------------------ include/faraday/ftpmu010.h | 150 ++++++++++++++++++++++++++++++--
Previous patch (/patch/83344/, http://patchwork.ozlabs.org/patch/83344/) about ftpmu010.h include path fix in a320 was set to "superseded" in patchwork to avoid confusing when applying code.
Two better patches has been submit by Po-Yu as patch http://patchwork.ozlabs.org/patch/83534/ and patch http://patchwork.ozlabs.org/patch/83535/
-- Best regards, Macpaul Lin
Signed-off-by: Po-Yu Chuangratbert@faraday-tech.com
Applied to u-boot-arm/next, thanks!
Wolfgang: I have put the patches in 'Awaiting upstream' state as none of the states described in http://www.denx.de/wiki/view/U-Boot/Patches#Patchwork_work_flow seemed to fit "sitting in -next waiting to get into -master". If you'd prefer another state, just let me know.
Amicalement,
Hi Po-Yu,
Sorry I didn't notice that there are API declaration before in ftpmu010.h.
Po-Yu, does these three function declaration is a necessity in a320evb?
I'm using gcc 4.4 without these 3 function declaration seems okay. Because I'm going to refine another enhancement patch for using ftpmu010 in lowlevel_init.S. Hence I need to use #ifndef __ASSEMBLY__ to protect these three APIs. However, to compile adp-ag101 board (NDS32) doesn't require these 3 functions to be declared here. I need your opinion to clarify this.
Thanks a lot.
Hi Macpaul,
This is used by a320evb.
These are not.
Either adp-ag101 does not use any of them or you put the declarations somewhere in board-specific code which is wrong.
No problem here. Please use __ASSEMBLY__.
Does your board use ftpmu010_dlldis_disable() or ftpmu010_sdram_clk_disable() ?
Best regards, Po-Yu Chuang
Albert ARIBAUD
Macpaul Lin
Po-Yu Chuang
