[U-Boot] [PATCH v2 0/3] efi_loader: improve boot sequence in distro_bootcmd
The current distro_bootcmd has several issues regarding efi boot. (See the patch#1 for details.)
Patch#1: fix distro's issues and make its intent clear Patch#2,#3: address related issues on qemu-arm
Please note that patch#2 is now rebased on Bin's patch[1].
[1] https://lists.denx.de/pipermail/u-boot/2018-October/344421.html
Changes in v2 (Oct 22, 2018): * rewrite my previous changes after Alex's comments, including - boot bootmgr only once before searching for boot binary - dtb must be loaded from the same device with boot binary's * add patch#2 as part of this patch set, in particular adding CONFIG_SYS
Thanks, -Takahio Akashi
AKASHI Takahiro (3): efi_loader: rework fdt handling in distro boot script ARM: qemu-arm: rework Kconfig ARM: qemu-arm: define fdt_addr_r
arch/arm/mach-qemu/Kconfig | 18 ++++++++------- board/emulation/qemu-arm/Kconfig | 6 +++++ include/config_distro_bootcmd.h | 38 +++++++++++++++++--------------- include/configs/qemu-arm.h | 1 + 4 files changed, 37 insertions(+), 26 deletions(-)
The current scenario for default UEFI booting, scan_dev_for_efi, has several issues: * load dtb dynamically even if its loacation (device) is not the same as BOOTEFI_NAME binary's, (reported by Alex) * invoke 'bootmgr' only if BOOTEFI_NAME binary does exit even though 'bootmgr' can and should work independently whether or not the binary exist, * in addition, invoke 'bootmgr' with dynamically-loaded dtb. This behavior is not expected. (reported by Alex) * always assume that a 'fdtfile' variable is defined, ("test -e ${devtype} ${devnum}:${distro_bootpart} "${prefix}${efi_fdtfile}" always returns true even if fdtfile is NULL with prefix=="/".) * redundantly check for 'fdt_addr_r' in boot_efi_binary
In this patch, all the issues above are sorted out. Please note that the default behavior can be customized with: fdtfile: a dtb file name efi_dtb_prefixes: a list of paths for searching for a dtb file
(this feature does work even without this patch.)
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- include/config_distro_bootcmd.h | 38 +++++++++++++++++---------------- 1 file changed, 20 insertions(+), 18 deletions(-)
diff --git a/include/config_distro_bootcmd.h b/include/config_distro_bootcmd.h index 373fee78a999..256698309eb9 100644 --- a/include/config_distro_bootcmd.h +++ b/include/config_distro_bootcmd.h @@ -115,7 +115,7 @@ */ #define BOOTENV_EFI_SET_FDTFILE_FALLBACK \ "if test -z "${fdtfile}" -a -n "${soc}"; then " \ - "setenv efi_fdtfile ${soc}-${board}${boardver}.dtb; " \ + "efi_fdtfile=${soc}-${board}${boardver}.dtb; " \ "fi; " #else #define BOOTENV_EFI_SET_FDTFILE_FALLBACK @@ -124,26 +124,20 @@
#define BOOTENV_SHARED_EFI \ "boot_efi_binary=" \ - "if fdt addr ${fdt_addr_r}; then " \ - "bootefi bootmgr ${fdt_addr_r};" \ - "else " \ - "bootefi bootmgr ${fdtcontroladdr};" \ - "fi;" \ "load ${devtype} ${devnum}:${distro_bootpart} " \ "${kernel_addr_r} efi/boot/"BOOTEFI_NAME"; " \ - "if fdt addr ${fdt_addr_r}; then " \ - "bootefi ${kernel_addr_r} ${fdt_addr_r};" \ - "else " \ - "bootefi ${kernel_addr_r} ${fdtcontroladdr};" \ - "fi\0" \ + "bootefi ${kernel_addr_r} ${efi_fdt_addr};\0" \ \ "load_efi_dtb=" \ - "load ${devtype} ${devnum}:${distro_bootpart} " \ - "${fdt_addr_r} ${prefix}${efi_fdtfile}\0" \ + "load ${devtype} ${devnum}:${distro_bootpart} " \ + "${fdt_addr_r} ${prefix}${efi_fdtfile}; " \ + "if fdt addr ${fdt_addr_r}; then " \ + "efi_fdt_addr=${fdt_addr_r}; " \ + "fi;\0" \ \ "efi_dtb_prefixes=/ /dtb/ /dtb/current/\0" \ - "scan_dev_for_efi=" \ - "setenv efi_fdtfile ${fdtfile}; " \ + "set_efi_fdt_addr=" \ + "efi_fdtfile=${fdtfile}; " \ BOOTENV_EFI_SET_FDTFILE_FALLBACK \ "for prefix in ${efi_dtb_prefixes}; do " \ "if test -e ${devtype} " \ @@ -151,19 +145,26 @@ "${prefix}${efi_fdtfile}; then " \ "run load_efi_dtb; " \ "fi;" \ - "done;" \ + "done;\0" \ + \ + "scan_dev_for_efi=" \ "if test -e ${devtype} ${devnum}:${distro_bootpart} " \ "efi/boot/"BOOTEFI_NAME"; then " \ "echo Found EFI removable media binary " \ "efi/boot/"BOOTEFI_NAME"; " \ + "efi_fdt_addr=${fdtcontroladdr}; " \ + "if test -n "${fdtfile}"; then " \ + "run set_efi_fdt_addr; " \ + "fi; " \ "run boot_efi_binary; " \ "echo EFI LOAD FAILED: continuing...; " \ - "fi; " \ - "setenv efi_fdtfile\0" + "fi;\0" #define SCAN_DEV_FOR_EFI "run scan_dev_for_efi;" +#define BOOT_EFI_BOOT_MANAGER "bootefi bootmgr;" #else #define BOOTENV_SHARED_EFI #define SCAN_DEV_FOR_EFI +#define BOOT_EFI_BOOT_MANAGER #endif
#ifdef CONFIG_SATA @@ -409,6 +410,7 @@ BOOT_TARGET_DEVICES(BOOTENV_DEV) \ \ "distro_bootcmd=" BOOTENV_SET_SCSI_NEED_INIT \ + BOOT_EFI_BOOT_MANAGER \ "for target in ${boot_targets}; do " \ "run bootcmd_${target}; " \ "done\0"
- load dtb dynamically even if its loacation (device) is not the same as BOOTEFI_NAME binary's, (reported by Alex)
- invoke 'bootmgr' only if BOOTEFI_NAME binary does exit even though 'bootmgr' can and should work independently whether or not the binary exist,
- in addition, invoke 'bootmgr' with dynamically-loaded dtb. This behavior is not expected. (reported by Alex)
- always assume that a 'fdtfile' variable is defined, ("test -e ${devtype} ${devnum}:${distro_bootpart} "${prefix}${efi_fdtfile}" always returns true even if fdtfile is NULL with prefix=="/".)
- redundantly check for 'fdt_addr_r' in boot_efi_binary
"fi; ""efi_fdtfile=${soc}-${board}${boardver}.dtb; " \
"else " \
"load ${devtype} ${devnum}:${distro_bootpart} " \ "${kernel_addr_r} efi/boot/"BOOTEFI_NAME"; " \"fi;" \
"else " \
"fi\0" \
\ "load_efi_dtb=" \"bootefi ${kernel_addr_r} ${efi_fdt_addr};\0" \
\ "efi_dtb_prefixes=/ /dtb/ /dtb/current/\0" \"fi;\0" \
- "set_efi_fdt_addr=" \
BOOTENV_EFI_SET_FDTFILE_FALLBACK \ "for prefix in ${efi_dtb_prefixes}; do " \ "if test -e ${devtype} " \"efi_fdtfile=${fdtfile}; " \
"done;" \
"done;\0" \
- "scan_dev_for_efi=" \ "if test -e ${devtype} ${devnum}:${distro_bootpart} " \ "efi/boot/"BOOTEFI_NAME"; then " \ "echo Found EFI removable media binary " \ "efi/boot/"BOOTEFI_NAME"; " \
"if test -n \"${fdtfile}\"; then " \
"fi; " \
"fi;\0"
The last-minute change may have introduced a problem. By moving "bootmgr" from scan_dev_for_efi" to here, grub fails to start a grub.cfg menu, saying "error: no such device: /.disk/info."
Do you have any ideas?
-Takahiro Akashi
-- 2.19.0
"else " \
"else " \
"fi\0" \
"done;" \
"done;\0" \
"fi; " \
"fi;\0"
I would guess that bootmgr doesn't set the loaded image target correctly and before it just happened to work because there was a load command before the bootmgr command?
https://github.com/u-boot/u-boot/blob/master/cmd/fs.c#L26
Alex
"else " \
"else " \
"fi\0" \
"done;" \
"done;\0" \
"fi; " \
"fi;\0"
The root cause was that efi_init_obj_list(), particularly efi_disk_register(), is executed only once. In my case, efi bootmgr is called before "usb start" in scan_dev_for_efi, and any USB devices will not be added to efi object list forever. Therefore, later on, grub itself can start but cannot detect/access its own boot device (USB mass storage) via efi interface.
I think we can fix this problem in several ways: 1. run all 'device-scanning' commands, like "usb start" and "scsi scan," before calling bootmgr in distro_bootcmd, 2. modify efi_obj_init_list() to check and register newly-detected devices, 3. add a device to efi object list dynamically whenever a 'device-scanning' command detects one, 4. search and check for a device on-the-fly with each efi device path (or handle?) specified in efi interface
What do you think?
-Takahiro Akashi
Alex
"else " \
"else " \
"fi\0" \
"done;" \
"done;\0" \
"fi; " \
"fi;\0"
- run all 'device-scanning' commands, like "usb start" and "scsi scan," before calling bootmgr in distro_bootcmd,
This would work, though it's slightly complicated - hm :/.
- modify efi_obj_init_list() to check and register newly-detected devices,
That won't work, because then efibootmgr won't be able to boot from USB, no?
- add a device to efi object list dynamically whenever a 'device-scanning' command detects one,
Same here I assume.
- search and check for a device on-the-fly with each efi device path (or handle?) specified in efi interface
That won't work either, because we simply don't initialize USB in the efibootmgr case, so there won't be anything on the fly ;).
What do you think?
I guess one of your options above mentions this and I just missed it, but I think we'll have to find out what to initialize in the efibootmgr command based on the device path we're trying to execute and then initialize that respective subsystem.
So if we see that the device path involves USB, we need to run "usb start" from within the efibootmgr code.
Alex
"else " \
"else " \
"fi\0" \
"done;" \
"done;\0" \
"fi; " \
"fi;\0"
Same here I assume.
What do you think?
I don't think that this behavior is consistent with other U-boot commands. For example, "load usb 0:1 ..." doesn't work unless we run "usb start" first. Efi bootmgr should not be an exception.
-Takahiro Akashi
Alex
Define a missing CONFIG_SYS_SOC and move some CONFIG_SYS_* to a more canonical place (i.e. under board).
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- arch/arm/mach-qemu/Kconfig | 18 ++++++++++-------- board/emulation/qemu-arm/Kconfig | 6 ++++++ 2 files changed, 16 insertions(+), 8 deletions(-)
diff --git a/arch/arm/mach-qemu/Kconfig b/arch/arm/mach-qemu/Kconfig index a2e4b98b8887..d75a95183a75 100644 --- a/arch/arm/mach-qemu/Kconfig +++ b/arch/arm/mach-qemu/Kconfig @@ -3,22 +3,24 @@ if ARCH_QEMU config SYS_VENDOR default "emulation"
-config SYS_BOARD - default "qemu-arm" +config SYS_SOC + default "qemu"
-config SYS_CONFIG_NAME - default "qemu-arm" - -endif +choice + prompt "QEMU cpu type"
config TARGET_QEMU_ARM_32BIT - bool "Support qemu_arm" + bool "Arm" depends on ARCH_QEMU select ARCH_SUPPORT_PSCI select CPU_V7A select SYS_ARCH_TIMER
config TARGET_QEMU_ARM_64BIT - bool "Support qemu_arm64" + bool "AArch64" depends on ARCH_QEMU select ARM64 + +endchoice + +endif diff --git a/board/emulation/qemu-arm/Kconfig b/board/emulation/qemu-arm/Kconfig index d1c08c2f6a80..ef49e4e85f04 100644 --- a/board/emulation/qemu-arm/Kconfig +++ b/board/emulation/qemu-arm/Kconfig @@ -1,5 +1,11 @@ if TARGET_QEMU_ARM_32BIT || TARGET_QEMU_ARM_64BIT
+config SYS_BOARD + default "qemu-arm" + +config SYS_CONFIG_NAME + default "qemu-arm" + config SYS_TEXT_BASE default 0x00000000
This variable, fdt_addr_t, is missing in the current qemu-arm.h while it seems to be mandatory, at least, to run distro_bootcmd as expected. So just add its definition. A size of 1MB would be enough.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- include/configs/qemu-arm.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/qemu-arm.h b/include/configs/qemu-arm.h index 91fb8d47edf8..0e66f946dde5 100644 --- a/include/configs/qemu-arm.h +++ b/include/configs/qemu-arm.h @@ -55,6 +55,7 @@ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ "fdt_addr=0x40000000\0" \ + "fdt_addr_r=0x40100000\0" \ "scriptaddr=0x40200000\0" \ "pxefile_addr_r=0x40300000\0" \ "kernel_addr_r=0x40400000\0" \
Hi Takahiro,
On Mon, 22 Oct 2018 13:40:07 +0900 AKASHI Takahiro takahiro.akashi@linaro.org wrote:
- "fdt_addr_r=0x40100000\0" \ "scriptaddr=0x40200000\0" \ "pxefile_addr_r=0x40300000\0" \ "kernel_addr_r=0x40400000\0" \
The same problem as in the previous version still exists; applying these as-is would regress any boot entries in PXE files that use the FDTDIR directive since it'd try to load a non-existent .dtb and fail.
We need some way to avoid that; maybe some magic value (e.g. fdtfile=none) or a separate environment variable or CONFIG_ option.
- Tuomas
AKASHI Takahiro
Alexander Graf
Tuomas Tynkkynen
