[PATCH] net: tulip: Remove CONFIG_TULIP_*
These macros are not used by any board, remove them to simplify the driver. The EEPROM accessors are still retained however, as those might still be useful.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com --- README | 2 - drivers/net/dc2114x.c | 88 ++---------------------------------- scripts/config_whitelist.txt | 3 -- 3 files changed, 5 insertions(+), 88 deletions(-)
diff --git a/README b/README index 19dae14ac0..aeae97d50f 100644 --- a/README +++ b/README @@ -896,8 +896,6 @@ The following options need to be configured:
CONFIG_TULIP Support for Digital 2114x chips. - Optional CONFIG_TULIP_SELECT_MEDIA for board specific - modem chip initialisation (KS8761/QS6611).
CONFIG_NATSEMI Support for National dp83815 chips. diff --git a/drivers/net/dc2114x.c b/drivers/net/dc2114x.c index 43c2253f10..40bfc5281b 100644 --- a/drivers/net/dc2114x.c +++ b/drivers/net/dc2114x.c @@ -77,15 +77,6 @@
#define POLL_DEMAND 1
-#ifdef CONFIG_TULIP_FIX_DAVICOM -#define RESET_DM9102(dev) {\ - unsigned long i;\ - i=INL(dev, 0x0);\ - udelay(1000);\ - OUTL(dev, i | BMR_SWR, DE4X5_BMR);\ - udelay(1000);\ -} -#else #define RESET_DE4X5(dev) {\ int i;\ i=INL(dev, DE4X5_BMR);\ @@ -97,7 +88,6 @@ for (i=0;i<5;i++) {INL(dev, DE4X5_BMR); udelay(10000);}\ udelay(1000);\ } -#endif
#define START_DE4X5(dev) {\ s32 omr; \ @@ -114,11 +104,7 @@ }
#define NUM_RX_DESC PKTBUFSRX -#ifndef CONFIG_TULIP_FIX_DAVICOM - #define NUM_TX_DESC 1 /* Number of TX descriptors */ -#else - #define NUM_TX_DESC 4 -#endif +#define NUM_TX_DESC 1 /* Number of TX descriptors */ #define RX_BUFF_SZ PKTSIZE_ALIGN
#define TOUT_LOOP 1000000 @@ -140,29 +126,22 @@ static int tx_new; /* TX descriptor ring pointer */ static char rxRingSize; static char txRingSize;
-#if defined(UPDATE_SROM) || !defined(CONFIG_TULIP_FIX_DAVICOM) static void sendto_srom(struct eth_device* dev, u_int command, u_long addr); static int getfrom_srom(struct eth_device* dev, u_long addr); static int do_eeprom_cmd(struct eth_device *dev, u_long ioaddr,int cmd,int cmd_len); static int do_read_eeprom(struct eth_device *dev,u_long ioaddr,int location,int addr_len); -#endif /* UPDATE_SROM || !CONFIG_TULIP_FIX_DAVICOM */ #ifdef UPDATE_SROM static int write_srom(struct eth_device *dev, u_long ioaddr, int index, int new_value); static void update_srom(struct eth_device *dev, bd_t *bis); #endif -#ifndef CONFIG_TULIP_FIX_DAVICOM static int read_srom(struct eth_device *dev, u_long ioaddr, int index); static void read_hw_addr(struct eth_device* dev, bd_t * bis); -#endif /* CONFIG_TULIP_FIX_DAVICOM */ static void send_setup_frame(struct eth_device* dev, bd_t * bis);
static int dc21x4x_init(struct eth_device* dev, bd_t* bis); static int dc21x4x_send(struct eth_device *dev, void *packet, int length); static int dc21x4x_recv(struct eth_device* dev); static void dc21x4x_halt(struct eth_device* dev); -#ifdef CONFIG_TULIP_SELECT_MEDIA -extern void dc21x4x_select_media(struct eth_device* dev); -#endif
#if defined(CONFIG_E500) #define phys_to_bus(a) (a) @@ -183,9 +162,6 @@ static void OUTL(struct eth_device* dev, int command, u_long addr) static struct pci_device_id supported[] = { { PCI_VENDOR_ID_DEC, PCI_DEVICE_ID_DEC_TULIP_FAST }, { PCI_VENDOR_ID_DEC, PCI_DEVICE_ID_DEC_21142 }, -#ifdef CONFIG_TULIP_FIX_DAVICOM - { PCI_VENDOR_ID_DAVICOM, PCI_DEVICE_ID_DAVICOM_DM9102A }, -#endif { } };
@@ -209,35 +185,22 @@ int dc21x4x_initialize(bd_t *bis) /* Get the chip configuration revision register. */ pci_read_config_dword(devbusfn, PCI_REVISION_ID, &cfrv);
-#ifndef CONFIG_TULIP_FIX_DAVICOM if ((cfrv & CFRV_RN) < DC2114x_BRK ) { printf("Error: The chip is not DC21143.\n"); continue; } -#endif
pci_read_config_word(devbusfn, PCI_COMMAND, &status); status |= -#ifdef CONFIG_TULIP_USE_IO - PCI_COMMAND_IO | -#else PCI_COMMAND_MEMORY | -#endif PCI_COMMAND_MASTER; pci_write_config_word(devbusfn, PCI_COMMAND, status);
pci_read_config_word(devbusfn, PCI_COMMAND, &status); -#ifdef CONFIG_TULIP_USE_IO - if (!(status & PCI_COMMAND_IO)) { - printf("Error: Can not enable I/O access.\n"); - continue; - } -#else if (!(status & PCI_COMMAND_MEMORY)) { printf("Error: Can not enable MEMORY access.\n"); continue; } -#endif
if (!(status & PCI_COMMAND_MASTER)) { printf("Error: Can not enable Bus Mastering.\n"); @@ -251,15 +214,9 @@ int dc21x4x_initialize(bd_t *bis) pci_write_config_byte(devbusfn, PCI_LATENCY_TIMER, 0x60); }
-#ifdef CONFIG_TULIP_USE_IO - /* read BAR for memory space access */ - pci_read_config_dword(devbusfn, PCI_BASE_ADDRESS_0, &iobase); - iobase &= PCI_BASE_ADDRESS_IO_MASK; -#else /* read BAR for memory space access */ pci_read_config_dword(devbusfn, PCI_BASE_ADDRESS_1, &iobase); iobase &= PCI_BASE_ADDRESS_MEM_MASK; -#endif debug ("dc21x4x: DEC 21142 PCI Device @0x%x\n", iobase);
dev = (struct eth_device*) malloc(sizeof *dev); @@ -270,17 +227,9 @@ int dc21x4x_initialize(bd_t *bis) } memset(dev, 0, sizeof(*dev));
-#ifdef CONFIG_TULIP_FIX_DAVICOM - sprintf(dev->name, "Davicom#%d", card_number); -#else sprintf(dev->name, "dc21x4x#%d", card_number); -#endif
-#ifdef CONFIG_TULIP_USE_IO - dev->iobase = pci_io_to_phys(devbusfn, iobase); -#else dev->iobase = pci_mem_to_phys(devbusfn, iobase); -#endif dev->priv = (void*) devbusfn; dev->init = dc21x4x_init; dev->halt = dc21x4x_halt; @@ -292,9 +241,8 @@ int dc21x4x_initialize(bd_t *bis)
udelay(10 * 1000);
-#ifndef CONFIG_TULIP_FIX_DAVICOM read_hw_addr(dev, bis); -#endif + eth_register(dev);
card_number++; @@ -311,46 +259,28 @@ static int dc21x4x_init(struct eth_device* dev, bd_t* bis) /* Ensure we're not sleeping. */ pci_write_config_byte(devbusfn, PCI_CFDA_PSM, WAKEUP);
-#ifdef CONFIG_TULIP_FIX_DAVICOM - RESET_DM9102(dev); -#else RESET_DE4X5(dev); -#endif
if ((INL(dev, DE4X5_STS) & (STS_TS | STS_RS)) != 0) { printf("Error: Cannot reset ethernet controller.\n"); return -1; }
-#ifdef CONFIG_TULIP_SELECT_MEDIA - dc21x4x_select_media(dev); -#else OUTL(dev, OMR_SDP | OMR_PS | OMR_PM, DE4X5_OMR); -#endif
for (i = 0; i < NUM_RX_DESC; i++) { rx_ring[i].status = cpu_to_le32(R_OWN); rx_ring[i].des1 = cpu_to_le32(RX_BUFF_SZ); rx_ring[i].buf = cpu_to_le32( phys_to_bus((u32)net_rx_packets[i])); -#ifdef CONFIG_TULIP_FIX_DAVICOM - rx_ring[i].next = cpu_to_le32( - phys_to_bus((u32)&rx_ring[(i + 1) % NUM_RX_DESC])); -#else rx_ring[i].next = 0; -#endif }
for (i=0; i < NUM_TX_DESC; i++) { tx_ring[i].status = 0; tx_ring[i].des1 = 0; tx_ring[i].buf = 0; - -#ifdef CONFIG_TULIP_FIX_DAVICOM - tx_ring[i].next = cpu_to_le32(phys_to_bus((u32) &tx_ring[(i+1) % NUM_TX_DESC])); -#else tx_ring[i].next = 0; -#endif }
rxRingSize = NUM_RX_DESC; @@ -520,9 +450,7 @@ Done: return; }
-#if defined(UPDATE_SROM) || !defined(CONFIG_TULIP_FIX_DAVICOM) -/* SROM Read and write routines. - */ +/* SROM Read and write routines. */ static void sendto_srom(struct eth_device* dev, u_int command, u_long addr) { @@ -594,13 +522,12 @@ static int do_read_eeprom(struct eth_device *dev, u_long ioaddr, int location, i
return retval; } -#endif /* UPDATE_SROM || !CONFIG_TULIP_FIX_DAVICOM */
-/* This executes a generic EEPROM command, typically a write or write +/* + * This executes a generic EEPROM command, typically a write or write * enable. It returns the data output from the EEPROM, and thus may * also be used for reads. */ -#if defined(UPDATE_SROM) || !defined(CONFIG_TULIP_FIX_DAVICOM) static int do_eeprom_cmd(struct eth_device *dev, u_long ioaddr, int cmd, int cmd_len) { unsigned retval = 0; @@ -636,9 +563,7 @@ static int do_eeprom_cmd(struct eth_device *dev, u_long ioaddr, int cmd, int cmd
-#ifndef CONFIG_TULIP_FIX_DAVICOM static int read_srom(struct eth_device *dev, u_long ioaddr, int index) { int ee_addr_size = do_read_eeprom(dev, ioaddr, 0xff, 8) & 0x40000 ? 8 : 6; @@ -647,7 +572,6 @@ static int read_srom(struct eth_device *dev, u_long ioaddr, int index) (((SROM_READ_CMD << ee_addr_size) | index) << 16) | 0xffff, 3 + ee_addr_size + 16); } -#endif /* CONFIG_TULIP_FIX_DAVICOM */
#ifdef UPDATE_SROM static int write_srom(struct eth_device *dev, u_long ioaddr, int index, int new_value) @@ -695,7 +619,6 @@ static int write_srom(struct eth_device *dev, u_long ioaddr, int index, int new_ } #endif
-#ifndef CONFIG_TULIP_FIX_DAVICOM static void read_hw_addr(struct eth_device *dev, bd_t *bis) { u_short tmp, *p = (u_short *)(&dev->enetaddr[0]); @@ -721,7 +644,6 @@ Done: #endif return; } -#endif /* CONFIG_TULIP_FIX_DAVICOM */
#ifdef UPDATE_SROM static void update_srom(struct eth_device *dev, bd_t *bis) diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 7e08c563cd..7e784b1c96 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -4079,9 +4079,6 @@ CONFIG_TSECV2_1 CONFIG_TSEC_TBI CONFIG_TSEC_TBICR_SETTINGS CONFIG_TULIP -CONFIG_TULIP_FIX_DAVICOM -CONFIG_TULIP_SELECT_MEDIA -CONFIG_TULIP_USE_IO CONFIG_TWL6030_INPUT CONFIG_TWL6030_POWER CONFIG_TWR
