[U-Boot] [PATCH] Revert "spi: cadence_qspi_apb: Use 32 bit indirect read transaction when possible"
This reverts commit b63b46313ed29e9b0c36b3d6b9407f6eade40c8f.
This commit changed cadence_qspi_apb to use bouncebuf.c, which invalidates the data cache after reading. This is meant for dma transfers only and breaks the cadence_qspi driver which copies via cpu only: data that is copied by the cpu is in cache only and the cache invalidation at the end throws away this data.
Signed-off-by: Simon Goldschmidt sgoldschmidt@de.pepperl-fuchs.com --- drivers/spi/cadence_qspi_apb.c | 22 ++++++---------------- 1 file changed, 6 insertions(+), 16 deletions(-)
diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index e02f2217f4..5d5b6f0d35 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -634,8 +634,6 @@ int cadence_qspi_apb_indirect_read_execute(struct cadence_spi_platdata *plat, { unsigned int remaining = n_rx; unsigned int bytes_to_read = 0; - struct bounce_buffer bb; - u8 *bb_rxbuf; int ret;
writel(n_rx, plat->regbase + CQSPI_REG_INDIRECTRDBYTES); @@ -644,11 +642,6 @@ int cadence_qspi_apb_indirect_read_execute(struct cadence_spi_platdata *plat, writel(CQSPI_REG_INDIRECTRD_START, plat->regbase + CQSPI_REG_INDIRECTRD);
- ret = bounce_buffer_start(&bb, (void *)rxbuf, n_rx, GEN_BB_WRITE); - if (ret) - return ret; - bb_rxbuf = bb.bounce_buffer; - while (remaining > 0) { ret = cadence_qspi_wait_for_data(plat); if (ret < 0) { @@ -662,13 +655,12 @@ int cadence_qspi_apb_indirect_read_execute(struct cadence_spi_platdata *plat, bytes_to_read *= CQSPI_FIFO_WIDTH; bytes_to_read = bytes_to_read > remaining ? remaining : bytes_to_read; - readsl(plat->ahbbase, bb_rxbuf, bytes_to_read >> 2); - if (bytes_to_read % 4) - readsb(plat->ahbbase, - bb_rxbuf + rounddown(bytes_to_read, 4), - bytes_to_read % 4); - - bb_rxbuf += bytes_to_read; + /* Handle non-4-byte aligned access to avoid data abort. */ + if (((uintptr_t)rxbuf % 4) || (bytes_to_read % 4)) + readsb(plat->ahbbase, rxbuf, bytes_to_read); + else + readsl(plat->ahbbase, rxbuf, bytes_to_read >> 2); + rxbuf += bytes_to_read; remaining -= bytes_to_read; bytes_to_read = cadence_qspi_get_rd_sram_level(plat); } @@ -685,7 +677,6 @@ int cadence_qspi_apb_indirect_read_execute(struct cadence_spi_platdata *plat, /* Clear indirect completion status */ writel(CQSPI_REG_INDIRECTRD_DONE, plat->regbase + CQSPI_REG_INDIRECTRD); - bounce_buffer_stop(&bb);
@@ -693,7 +684,6 @@ failrd: /* Cancel the indirect read */ writel(CQSPI_REG_INDIRECTRD_CANCEL, plat->regbase + CQSPI_REG_INDIRECTRD); - bounce_buffer_stop(&bb); return ret; }
Goldschmidt Simon
