[U-Boot] [PATCH v4] common/Makefile: Add new symbol CONFIG_SPL_ENV_xxx for environment in SPL
There will need the environment in SPL for reasons other than network support (in particular, hwconfig contains info for how to set up DDR).
Add a new symbol CONFIG_SPL_ENV_SUPPORT to replace CONFIG_SPL_NET_SUPPORT for environment in common/Makefile. Meanwhile we add the following symbol for different storage medium: CONFIG_SPL_ENV_IS_IN_NAND CONFIG_SPL_ENV_IS_IN_MMC CONFIG_SPL_ENV_IS_IN_SPI_FLASH CONFIG_SPL_ENV_IS_NOWHERE
Signed-off-by: Ying Zhang b40530@freescale.com --- Compared with the previous version, add symbol CONFIG_SPL_ENV_IS_IN_NOWHERE in include/configs/am335x_evm.h and include/configs/am335x_evm.h
README | 15 +++++++++++++++ common/Makefile | 19 +++++++++++-------- include/configs/a3m071.h | 1 + include/configs/am335x_evm.h | 2 ++ include/configs/pcm051.h | 2 ++ 5 files changed, 31 insertions(+), 8 deletions(-)
diff --git a/README b/README index 0c4cb20..04f12a5 100644 --- a/README +++ b/README @@ -2992,6 +2992,21 @@ FIT uImage format: CONFIG_SPL_LIBGENERIC_SUPPORT Support for lib/libgeneric.o in SPL binary
+ CONFIG_SPL_ENV_SUPPORT + Support for the environment operating in SPL binary + + CONFIG_SPL_ENV_IS_NOWHERE + Store ENV in memory only in SPL binary + + CONFIG_SPL_ENV_IS_IN_MMC + Store ENV in MMC/SD Card in SPL binary + + CONFIG_SPL_ENV_IS_IN_NAND + Store ENV in nand in SPL binary + + CONFIG_SPL_ENV_IS_IN_SPI_FLASH + Store ENV in SPI flash in SPL binary + CONFIG_SPL_PAD_TO Image offset to which the SPL should be padded before appending the SPL payload. By default, this is defined as diff --git a/common/Makefile b/common/Makefile index f50bf2e..352a3c3 100644 --- a/common/Makefile +++ b/common/Makefile @@ -44,7 +44,6 @@ COBJS-$(CONFIG_SYS_GENERIC_BOARD) += board_r.o COBJS-y += cmd_boot.o COBJS-$(CONFIG_CMD_BOOTM) += cmd_bootm.o COBJS-y += cmd_help.o -COBJS-y += cmd_nvedit.o COBJS-y += cmd_version.o
# environment @@ -215,18 +214,22 @@ COBJS-$(CONFIG_CMD_GPT) += cmd_gpt.o endif
ifdef CONFIG_SPL_BUILD -COBJS-y += cmd_nvedit.o COBJS-y += env_common.o COBJS-$(CONFIG_ENV_IS_IN_FLASH) += env_flash.o COBJS-$(CONFIG_SPL_YMODEM_SUPPORT) += xyzModem.o -COBJS-$(CONFIG_SPL_NET_SUPPORT) += cmd_nvedit.o -COBJS-$(CONFIG_SPL_NET_SUPPORT) += env_attr.o -COBJS-$(CONFIG_SPL_NET_SUPPORT) += env_callback.o -COBJS-$(CONFIG_SPL_NET_SUPPORT) += env_common.o -COBJS-$(CONFIG_SPL_NET_SUPPORT) += env_flags.o -COBJS-$(CONFIG_SPL_NET_SUPPORT) += env_nowhere.o COBJS-$(CONFIG_SPL_NET_SUPPORT) += miiphyutil.o +# environment +COBJS-$(CONFIG_SPL_ENV_SUPPORT) += env_common.o +COBJS-$(CONFIG_SPL_ENV_SUPPORT) += env_attr.o +COBJS-$(CONFIG_SPL_ENV_SUPPORT) += env_flags.o +COBJS-$(CONFIG_SPL_ENV_SUPPORT) += env_callback.o +COBJS-$(CONFIG_SPL_ENV_IS_NOWHERE) += env_nowhere.o +COBJS-$(CONFIG_SPL_ENV_IS_IN_MMC) += env_mmc.o +COBJS-$(CONFIG_SPL_ENV_IS_IN_NAND) += env_nand.o +COBJS-$(CONFIG_SPL_ENV_IS_IN_SPI_FLASH) += env_sf.o endif +# core command +COBJS-y += cmd_nvedit.o COBJS-$(CONFIG_BOUNCE_BUFFER) += bouncebuf.o COBJS-y += console.o COBJS-y += dlmalloc.o diff --git a/include/configs/a3m071.h b/include/configs/a3m071.h index e9af825..8f29229 100644 --- a/include/configs/a3m071.h +++ b/include/configs/a3m071.h @@ -426,6 +426,7 @@ #define CONFIG_SPL_BSS_MAX_SIZE (64 << 10)
#define CONFIG_SPL_OS_BOOT +#define CONFIG_SPL_ENV_SUPPORT /* Place patched DT blob (fdt) at this address */ #define CONFIG_SYS_SPL_ARGS_ADDR 0x01800000
diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index ef00306..ca132a7 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -325,6 +325,8 @@ #define CONFIG_SPL_GPIO_SUPPORT #define CONFIG_SPL_YMODEM_SUPPORT #define CONFIG_SPL_NET_SUPPORT +#define CONFIG_SPL_ENV_SUPPORT +#define CONFIG_SPL_ENV_IS_NOWHERE #define CONFIG_SPL_NET_VCI_STRING "AM335x U-Boot SPL" #define CONFIG_SPL_ETH_SUPPORT #define CONFIG_SPL_SPI_SUPPORT diff --git a/include/configs/pcm051.h b/include/configs/pcm051.h index d0ea74e..532f2be 100644 --- a/include/configs/pcm051.h +++ b/include/configs/pcm051.h @@ -224,6 +224,8 @@ #define CONFIG_SPL_GPIO_SUPPORT #define CONFIG_SPL_YMODEM_SUPPORT #define CONFIG_SPL_NET_SUPPORT +#define CONFIG_SPL_ENV_SUPPORT +#define CONFIG_SPL_ENV_IS_NOWHERE #define CONFIG_SPL_NET_VCI_STRING "pcm051 U-Boot SPL" #define CONFIG_SPL_ETH_SUPPORT #define CONFIG_SPL_SPI_SUPPORT
ying.zhang@freescale.com
