[U-Boot] please pull u-boot-samsung master
Dear Albert,
The following changes since commit 9f024f62e4604274a23213dcee30016092e32e7b:
Merge branch 'fixes' of git://git.denx.de/u-boot-mips (2013-02-15 12:23:42 -0500)
git://git.denx.de/u-boot-samsung master
for you to fetch changes up to ce0c1bc13556fbf1bdfa2a4a27ca6744e7beb32a:
mmc:sdhci:fix: Change default interrupts enabled at SDHCI initialization (2013-03-12 19:50:49 +0900)
---------------------------------------------------------------- Akshay Saraswat (8): Exynos5: TMU: Add driver for Thermal Management Unit Exynos5: FDT: Add TMU device node values Exynos5: TMU: Add TMU init and status check Exynos5: Config: Enable support for Exynos TMU driver TMU: Add TMU support in dtt command Exynos5: Config: Enable dtt command for TMU Exynos5: TMU: Add hardware tripping Exynos5: FDT: Add a H/W-trip member to TMU node
Rajeshwari Shinde (11): EXYNOS5: Add function to setup set ps hold SMDK5250: Add PMIC voltage settings EXYNOS5: Add function to enable XXTI clock source Sound: MAX98095: Add the driver for codec Sound: Support for MAX98095 codec in driver EXYNOS5: GPIO to enable MAX98095 EXYNOS5: FDT: Add compatible strings for MAX98095 config: Snow: Enable MAX98095 codec SMDK5250: FDT: Retrieve board model via DT EXYNOS5: Add initial DTS file for Snow. EXYNOS5: Snow: Add a configuration file
Simon Glass (1): EXYNOS: Correct ordering of SPL machine_params
Łukasz Majewski (1): mmc:sdhci:fix: Change default interrupts enabled at SDHCI initialization
MAINTAINERS | 4 + arch/arm/cpu/armv7/exynos/power.c | 45 +++ arch/arm/dts/exynos5250.dtsi | 5 + arch/arm/include/asm/arch-exynos/power.h | 24 ++ arch/arm/include/asm/arch-exynos/spl.h | 3 +- arch/arm/include/asm/arch-exynos/tmu.h | 58 +++ board/samsung/dts/exynos5250-smdk5250.dts | 13 + board/samsung/dts/exynos5250-snow.dts | 58 +++ board/samsung/smdk5250/smdk5250.c | 178 +++++++++- boards.cfg | 1 + common/cmd_dtt.c | 32 +- doc/device-tree-bindings/exynos/tmu.txt | 44 +++ drivers/mmc/sdhci.c | 8 +- drivers/power/Makefile | 1 + drivers/power/exynos-tmu.c | 319 +++++++++++++++++ drivers/sound/Makefile | 1 + drivers/sound/max98095.c | 550 +++++++++++++++++++++++++++++ drivers/sound/max98095.h | 311 ++++++++++++++++ drivers/sound/sound.c | 9 +- include/configs/exynos5250-dt.h | 6 + include/configs/snow.h | 33 ++ include/fdtdec.h | 2 + include/power/max77686_pmic.h | 32 ++ include/sound.h | 1 + include/tmu.h | 46 +++ lib/fdtdec.c | 2 + 26 files changed, 1776 insertions(+), 10 deletions(-) create mode 100644 arch/arm/include/asm/arch-exynos/tmu.h create mode 100644 board/samsung/dts/exynos5250-snow.dts create mode 100644 doc/device-tree-bindings/exynos/tmu.txt create mode 100644 drivers/power/exynos-tmu.c create mode 100644 drivers/sound/max98095.c create mode 100644 drivers/sound/max98095.h create mode 100644 include/configs/snow.h create mode 100644 include/tmu.h
Hi Minkyu,
On Thu, 21 Mar 2013 18:54:28 +0900, Minkyu Kang mk7.kang@samsung.com wrote:
Dear Albert,
Somehow this had escaped my attention. Pulling it in today.
Amicalement,
Hi Minkyu,
Dear Albert,
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Minkyu Kang
