[U-Boot] [PATCH v4 0/9] rockchip: video: rk3399: enable HDMI output
This series provides HDMI enablement for the RK3399 and will support video console on the RK3399 either with VOP-lit or VOP-big: - pinctrl and clk support for the hdmi node - a refactoring of rk_vop.c and rk_hdmi.c to allow for the minor differences between the RK3288 and RK3399 VOP and HDMI blocks
This has been tested (on top of sjg/master) using 'bmp display' and 'setenv stdout vidconsole' on the RK3399-Q7 with various HDMI monitors, both for VOP-lit and VOP-big (setting the other one to 'disabled').
v4 splits the changes to the rk_vop and rk_hdmi components into more manageable series of changes.
Changes in v4: - added patch to break down into smaller changes - added patch to break down into smaller changes - added patch to break down into smaller changes - split the massive "refactor, split and add RK3399 support"-change into smaller chunks that are more easily digestible - new patch (split off from the earlier RK3399 HDMI encoder change) - splits the large change into smaller changes
Changes in v3: - splits the VOP driver into SOC-specific and common portions - moves the "maximum x" and "maximum y" resolution config into Kconfig (instead of having hard-coded values that may need to be revised each time someone adds a new device or new features) - split into separate drivers for the SOC-specific portion of the driver - rebase to sjg/next
Changes in v2: - removed DEBUG from the patch (as was done in our production branches, but missing from the patch-prep branch) - updated SJG's comment (with a TODO for the RK3288) to reflect the new code structure
Philipp Tomsich (9): rockchip: video: Kconfig: reformat help for VIDEO_ROCKCHIP rockchip: video: Kconfig: set MAX_XRES and MAX_YRES via Kconfig rockchip: video: refactor rk_vop and split RK3328-specific code off rockchip: video: rk3399: enable HDMI output (from the rk_vop) for the RK3399 rockchip: video: add mpixelclock settings from Linux driver rockchip: video: split RK3228-specific part off from rk_hdmi rockchip: video: rk3399: add HDMI TX support on the RK3399 rockchip: dts: rk3399: enable HDMI output in the DTS rockchip: board: puma_rk3399: enable BMP_16BPP, BMP_24BPP and BMP_32BPP
arch/arm/dts/rk3399.dtsi | 39 +++++ arch/arm/include/asm/arch-rockchip/grf_rk3399.h | 3 + arch/arm/include/asm/arch-rockchip/vop_rk3288.h | 11 ++ drivers/video/rockchip/Kconfig | 29 +++- drivers/video/rockchip/Makefile | 6 +- drivers/video/rockchip/rk3288_hdmi.c | 116 +++++++++++++++ drivers/video/rockchip/rk3288_vop.c | 95 ++++++++++++ drivers/video/rockchip/rk3399_hdmi.c | 81 +++++++++++ drivers/video/rockchip/rk3399_vop.c | 105 ++++++++++++++ drivers/video/rockchip/rk_hdmi.c | 114 ++++----------- drivers/video/rockchip/rk_hdmi.h | 32 ++++ drivers/video/rockchip/rk_vop.c | 185 ++++++++++++------------ drivers/video/rockchip/rk_vop.h | 32 ++++ include/configs/puma_rk3399.h | 4 + 14 files changed, 662 insertions(+), 190 deletions(-) create mode 100644 drivers/video/rockchip/rk3288_hdmi.c create mode 100644 drivers/video/rockchip/rk3288_vop.c create mode 100644 drivers/video/rockchip/rk3399_hdmi.c create mode 100644 drivers/video/rockchip/rk3399_vop.c create mode 100644 drivers/video/rockchip/rk_hdmi.h create mode 100644 drivers/video/rockchip/rk_vop.h
For consistency sake (and as we are about to add new options to this file), reformat the help for VIDEO_ROCKCHIP.
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Changes in v4: - added to break down into smaller changes
drivers/video/rockchip/Kconfig | 11 ++++++----- 1 file changed, 6 insertions(+), 5 deletions(-)
diff --git a/drivers/video/rockchip/Kconfig b/drivers/video/rockchip/Kconfig index 80e399f..4ad2da5 100644 --- a/drivers/video/rockchip/Kconfig +++ b/drivers/video/rockchip/Kconfig @@ -12,11 +12,12 @@ menuconfig VIDEO_ROCKCHIP bool "Enable Rockchip Video Support" depends on DM_VIDEO help - Rockchip SoCs provide video output capabilities for High-Definition - Multimedia Interface (HDMI), Low-voltage Differential Signalling - (LVDS), embedded DisplayPort (eDP) and Display Serial Interface - (DSI). This driver supports the on-chip video output device, and - targets the Rockchip RK3288 and RK3399. + Rockchip SoCs provide video output capabilities for High-Definition + Multimedia Interface (HDMI), Low-voltage Differential Signalling + (LVDS), embedded DisplayPort (eDP) and Display Serial Interface (DSI). + + This driver supports the on-chip video output device, and targets the + Rockchip RK3288 and RK3399.
if VIDEO_ROCKCHIP
On 31 May 2017 at 09:59, Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
Changes in v4:
Hi Philipp,
On Wed, 31 May 2017 17:59:28 +0200 Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
Changes in v4:
applied to u-boot-video/master, thanks!
-- Anatolij
This introduces two new Kconfig options that configure the maximum allowable framebuffer size (i.e. the memory reservation/allocation for the framebuffer): - VIDEO_ROCKCHIP_MAX_XRES - VIDEO_ROCKCHIP_MAX_YRES The resulting memory allocation will cover 4 byte per pixel for these resolutions.
drivers/video/rockchip/Kconfig | 18 ++++++++++++++++++ drivers/video/rockchip/rk_vop.c | 3 ++- 2 files changed, 20 insertions(+), 1 deletion(-)
diff --git a/drivers/video/rockchip/Kconfig b/drivers/video/rockchip/Kconfig index 4ad2da5..b1d7c62 100644 --- a/drivers/video/rockchip/Kconfig +++ b/drivers/video/rockchip/Kconfig @@ -19,6 +19,24 @@ menuconfig VIDEO_ROCKCHIP This driver supports the on-chip video output device, and targets the Rockchip RK3288 and RK3399.
+config VIDEO_ROCKCHIP_MAX_XRES + int "Maximum horizontal resolution (for memory allocation purposes)" + depends on VIDEO_ROCKCHIP + default 1920 + help + The maximum horizontal resolution to support for the framebuffer. + This configuration is used for reserving/allocating memory for the + framebuffer during device-model binding/probing. + +config VIDEO_ROCKCHIP_MAX_YRES + int "Maximum vertical resolution (for memory allocation purposes)" + depends on VIDEO_ROCKCHIP + default 1080 + help + The maximum vertical resolution to support for the framebuffer. + This configuration is used for reserving/allocating memory for the + framebuffer during device-model binding/probing. + if VIDEO_ROCKCHIP
config DISPLAY_ROCKCHIP_EDP diff --git a/drivers/video/rockchip/rk_vop.c b/drivers/video/rockchip/rk_vop.c index aa6ca8c..16d1484 100644 --- a/drivers/video/rockchip/rk_vop.c +++ b/drivers/video/rockchip/rk_vop.c @@ -357,7 +357,8 @@ static int rk_vop_bind(struct udevice *dev) { struct video_uc_platdata *plat = dev_get_uclass_platdata(dev);
- plat->size = 1920 * 1200 * 4; + plat->size = 4 * (CONFIG_VIDEO_ROCKCHIP_MAX_XRES * + CONFIG_VIDEO_ROCKCHIP_MAX_YRES);
return 0; }
Changes in v4:
On Wed, 31 May 2017 17:59:29 +0200 Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote: ...
Changes in v4:
-- Anatolij
To prepare for adding the RK3399 VOP driver (which shares most of its registers and config logic with the RK3228 VOP), this change refactors the driver and splits the RK3288-specific driver off.
The changes in detail are: - introduces a data-structure for chip-specific drivers to register features/callbacks with the common driver: at this time, this is limited to a callback for setting the pin polarities (between the VOP and the encoder modules) and a flag to signal 10bit RGB capability - refactors the probing of regulators into a helper function that can take a list of regulator names to probe and autoset - moves the priv data-structure into a (common) header file to be used by the chip-specific drivers to provide base addresses to the common driver - uses a callback into the chip-specific driver to set pin polarities (replacing the direct register accesses previously used) - splits enabling the output (towards an encoder) into a separate help function withint the common driver
arch/arm/include/asm/arch-rockchip/vop_rk3288.h | 1 + drivers/video/rockchip/Makefile | 1 + drivers/video/rockchip/rk3288_vop.c | 95 +++++++++++++ drivers/video/rockchip/rk_vop.c | 182 ++++++++++++------------ drivers/video/rockchip/rk_vop.h | 32 +++++ 5 files changed, 217 insertions(+), 94 deletions(-) create mode 100644 drivers/video/rockchip/rk3288_vop.c create mode 100644 drivers/video/rockchip/rk_vop.h
diff --git a/arch/arm/include/asm/arch-rockchip/vop_rk3288.h b/arch/arm/include/asm/arch-rockchip/vop_rk3288.h index d5599ec..049f192 100644 --- a/arch/arm/include/asm/arch-rockchip/vop_rk3288.h +++ b/arch/arm/include/asm/arch-rockchip/vop_rk3288.h @@ -197,6 +197,7 @@ enum vop_modes { #define V_DSP_DEN_POL(x) (((x) & 1) << 6) #define V_DSP_VSYNC_POL(x) (((x) & 1) << 5) #define V_DSP_HSYNC_POL(x) (((x) & 1) << 4) +#define V_DSP_PIN_POL(x) (((x) & 0xf) << 4) #define V_DSP_OUT_MODE(x) ((x) & 0xf)
/* VOP_DSP_CTRL1 */ diff --git a/drivers/video/rockchip/Makefile b/drivers/video/rockchip/Makefile index cd54b12..9477ad0 100644 --- a/drivers/video/rockchip/Makefile +++ b/drivers/video/rockchip/Makefile @@ -7,6 +7,7 @@
ifdef CONFIG_VIDEO_ROCKCHIP obj-y += rk_vop.o +obj-$(CONFIG_ROCKCHIP_RK3288) += rk3288_vop.o obj-$(CONFIG_DISPLAY_ROCKCHIP_EDP) += rk_edp.o obj-$(CONFIG_DISPLAY_ROCKCHIP_LVDS) += rk_lvds.o obj-$(CONFIG_DISPLAY_ROCKCHIP_HDMI) += rk_hdmi.o diff --git a/drivers/video/rockchip/rk3288_vop.c b/drivers/video/rockchip/rk3288_vop.c new file mode 100644 index 0000000..e3e1ec7 --- /dev/null +++ b/drivers/video/rockchip/rk3288_vop.c @@ -0,0 +1,95 @@ +/* + * Copyright (c) 2017 Theobroma Systems Design und Consulting GmbH + * Copyright (c) 2015 Google, Inc + * Copyright 2014 Rockchip Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <display.h> +#include <dm.h> +#include <regmap.h> +#include <syscon.h> +#include <video.h> +#include <asm/hardware.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/grf_rk3288.h> +#include "rk_vop.h" + +DECLARE_GLOBAL_DATA_PTR; + +static void rk3288_set_pin_polarity(struct udevice *dev, + enum vop_modes mode, u32 polarity) +{ + struct rk_vop_priv *priv = dev_get_priv(dev); + struct rk3288_vop *regs = priv->regs; + + /* The RK3328 VOP (v3.1) has its polarity configuration in ctrl0 */ + clrsetbits_le32(®s->dsp_ctrl0, + M_DSP_DCLK_POL | M_DSP_DEN_POL | + M_DSP_VSYNC_POL | M_DSP_HSYNC_POL, + V_DSP_PIN_POL(polarity)); +} + +static void rk3288_set_io_vsel(struct udevice *dev) +{ + struct rk3288_grf *grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); + + /* lcdc(vop) iodomain select 1.8V */ + rk_setreg(&grf->io_vsel, 1 << 0); +} + +/* + * Try some common regulators. We should really get these from the + * device tree somehow. + */ +static const char * const rk3288_regulator_names[] = { + "vcc18_lcd", + "VCC18_LCD", + "vdd10_lcd_pwren_h", + "vdd10_lcd", + "VDD10_LCD", + "vcc33_lcd" +}; + +static int rk3288_vop_probe(struct udevice *dev) +{ + /* Before relocation we don't need to do anything */ + if (!(gd->flags & GD_FLG_RELOC)) + return 0; + + /* Set the LCDC(vop) iodomain to 1.8V */ + rk3288_set_io_vsel(dev); + + /* Probe regulators required for the RK3288 VOP */ + rk_vop_probe_regulators(dev, rk3288_regulator_names, + ARRAY_SIZE(rk3288_regulator_names)); + + return rk_vop_probe(dev); +} + +struct rkvop_driverdata rk3288_driverdata = { + .features = VOP_FEATURE_OUTPUT_10BIT, + .set_pin_polarity = rk3288_set_pin_polarity, +}; + +static const struct udevice_id rk3288_vop_ids[] = { + { .compatible = "rockchip,rk3288-vop", + .data = (ulong)&rk3288_driverdata }, + { } +}; + +static const struct video_ops rk3288_vop_ops = { +}; + +U_BOOT_DRIVER(rk_vop) = { + .name = "rk3288_vop", + .id = UCLASS_VIDEO, + .of_match = rk3288_vop_ids, + .ops = &rk3288_vop_ops, + .bind = rk_vop_bind, + .probe = rk3288_vop_probe, + .priv_auto_alloc_size = sizeof(struct rk_vop_priv), +}; diff --git a/drivers/video/rockchip/rk_vop.c b/drivers/video/rockchip/rk_vop.c index 16d1484..c15f93d 100644 --- a/drivers/video/rockchip/rk_vop.c +++ b/drivers/video/rockchip/rk_vop.c @@ -17,24 +17,25 @@ #include <asm/hardware.h> #include <asm/io.h> #include <asm/arch/clock.h> -#include <asm/arch/cru_rk3288.h> -#include <asm/arch/grf_rk3288.h> #include <asm/arch/edp_rk3288.h> #include <asm/arch/vop_rk3288.h> #include <dm/device-internal.h> #include <dm/uclass-internal.h> -#include <dt-bindings/clock/rk3288-cru.h> #include <power/regulator.h> +#include "rk_vop.h"
-struct rk_vop_priv { - struct rk3288_vop *regs; - struct rk3288_grf *grf; +enum vop_pol { + HSYNC_POSITIVE = 0, + VSYNC_POSITIVE = 1, + DEN_NEGATIVE = 2, + DCLK_INVERT = 3 };
-void rkvop_enable(struct rk3288_vop *regs, ulong fbbase, - int fb_bits_per_pixel, const struct display_timing *edid) +static void rkvop_enable(struct rk3288_vop *regs, ulong fbbase, + int fb_bits_per_pixel, + const struct display_timing *edid) { u32 lb_mode; u32 rgb_mode; @@ -89,54 +90,83 @@ void rkvop_enable(struct rk3288_vop *regs, ulong fbbase, writel(0x01, ®s->reg_cfg_done); /* enable reg config */ }
-void rkvop_mode_set(struct rk3288_vop *regs, - const struct display_timing *edid, enum vop_modes mode) +static void rkvop_set_pin_polarity(struct udevice *dev, + enum vop_modes mode, u32 polarity) { - u32 hactive = edid->hactive.typ; - u32 vactive = edid->vactive.typ; - u32 hsync_len = edid->hsync_len.typ; - u32 hback_porch = edid->hback_porch.typ; - u32 vsync_len = edid->vsync_len.typ; - u32 vback_porch = edid->vback_porch.typ; - u32 hfront_porch = edid->hfront_porch.typ; - u32 vfront_porch = edid->vfront_porch.typ; - uint flags; - int mode_flags; + struct rkvop_driverdata *ops = + (struct rkvop_driverdata *)dev_get_driver_data(dev); + + if (ops->set_pin_polarity) + ops->set_pin_polarity(dev, mode, polarity); +} + +static void rkvop_enable_output(struct udevice *dev, enum vop_modes mode) +{ + struct rk_vop_priv *priv = dev_get_priv(dev); + struct rk3288_vop *regs = priv->regs;
switch (mode) { case VOP_MODE_HDMI: clrsetbits_le32(®s->sys_ctrl, M_ALL_OUT_EN, V_HDMI_OUT_EN(1)); break; + case VOP_MODE_EDP: - default: clrsetbits_le32(®s->sys_ctrl, M_ALL_OUT_EN, V_EDP_OUT_EN(1)); break; + case VOP_MODE_LVDS: clrsetbits_le32(®s->sys_ctrl, M_ALL_OUT_EN, V_RGB_OUT_EN(1)); break; + case VOP_MODE_MIPI: clrsetbits_le32(®s->sys_ctrl, M_ALL_OUT_EN, V_MIPI_OUT_EN(1)); - break; + break; + + default: + debug("%s: unsupported output mode %x\n", __func__, mode); } +}
- if (mode == VOP_MODE_HDMI || mode == VOP_MODE_EDP) - /* RGBaaa */ - mode_flags = 15; - else - /* RGB888 */ - mode_flags = 0; +static void rkvop_mode_set(struct udevice *dev, + const struct display_timing *edid, + enum vop_modes mode) +{ + struct rk_vop_priv *priv = dev_get_priv(dev); + struct rk3288_vop *regs = priv->regs; + struct rkvop_driverdata *data = + (struct rkvop_driverdata *)dev_get_driver_data(dev);
- flags = V_DSP_OUT_MODE(mode_flags) | - V_DSP_HSYNC_POL(!!(edid->flags & DISPLAY_FLAGS_HSYNC_HIGH)) | - V_DSP_VSYNC_POL(!!(edid->flags & DISPLAY_FLAGS_VSYNC_HIGH)); + u32 hactive = edid->hactive.typ; + u32 vactive = edid->vactive.typ; + u32 hsync_len = edid->hsync_len.typ; + u32 hback_porch = edid->hback_porch.typ; + u32 vsync_len = edid->vsync_len.typ; + u32 vback_porch = edid->vback_porch.typ; + u32 hfront_porch = edid->hfront_porch.typ; + u32 vfront_porch = edid->vfront_porch.typ; + int mode_flags; + u32 pin_polarity; + + pin_polarity = BIT(DCLK_INVERT); + if (edid->flags & DISPLAY_FLAGS_HSYNC_HIGH) + pin_polarity |= BIT(HSYNC_POSITIVE); + if (edid->flags & DISPLAY_FLAGS_VSYNC_HIGH) + pin_polarity |= BIT(VSYNC_POSITIVE); + + rkvop_set_pin_polarity(dev, mode, pin_polarity); + rkvop_enable_output(dev, mode);
- clrsetbits_le32(®s->dsp_ctrl0, - M_DSP_OUT_MODE | M_DSP_VSYNC_POL | M_DSP_HSYNC_POL, - flags); + mode_flags = 0; /* RGB888 */ + if ((data->features & VOP_FEATURE_OUTPUT_10BIT) && + (mode == VOP_MODE_HDMI || mode == VOP_MODE_EDP)) + mode_flags = 15; /* RGBaaa */ + + clrsetbits_le32(®s->dsp_ctrl0, M_DSP_OUT_MODE, + V_DSP_OUT_MODE(mode_flags));
writel(V_HSYNC(hsync_len) | V_HORPRD(hsync_len + hback_porch + hactive + hfront_porch), @@ -185,7 +215,7 @@ void rkvop_mode_set(struct rk3288_vop *regs, * node within the VOP's 'port' list. * @return 0 if OK, -ve if something went wrong */ -int rk_display_init(struct udevice *dev, ulong fbbase, int ep_node) +static int rk_display_init(struct udevice *dev, ulong fbbase, int ep_node) { struct video_priv *uc_priv = dev_get_uclass_priv(dev); const void *blob = gd->fdt_blob; @@ -255,18 +285,18 @@ int rk_display_init(struct udevice *dev, ulong fbbase, int ep_node) /* Set bitwidth for vop display according to vop mode */ switch (vop_id) { case VOP_MODE_EDP: - case VOP_MODE_HDMI: case VOP_MODE_LVDS: l2bpp = VIDEO_BPP16; break; + case VOP_MODE_HDMI: case VOP_MODE_MIPI: l2bpp = VIDEO_BPP32; break; default: l2bpp = VIDEO_BPP16; } - rkvop_mode_set(regs, &timing, vop_id);
+ rkvop_mode_set(dev, &timing, vop_id); rkvop_enable(regs, fbbase, 1 << l2bpp, &timing);
ret = display_enable(disp, 1 << l2bpp, &timing); @@ -281,53 +311,37 @@ int rk_display_init(struct udevice *dev, ulong fbbase, int ep_node) return 0; }
-static int rk_vop_probe(struct udevice *dev) +void rk_vop_probe_regulators(struct udevice *dev, + const char * const *names, int cnt) +{ + int i, ret; + const char *name; + struct udevice *reg; + + for (i = 0; i < cnt; ++i) { + name = names[i]; + debug("%s: probing regulator '%s'\n", dev->name, name); + + ret = regulator_autoset_by_name(name, ®); + if (!ret) + ret = regulator_set_enable(reg, true); + } +} + +int rk_vop_probe(struct udevice *dev) { struct video_uc_platdata *plat = dev_get_uclass_platdata(dev); const void *blob = gd->fdt_blob; struct rk_vop_priv *priv = dev_get_priv(dev); - struct udevice *reg; - int ret, port, node; + int ret = 0; + int port, node;
/* Before relocation we don't need to do anything */ if (!(gd->flags & GD_FLG_RELOC)) return 0;
- priv->grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); priv->regs = (struct rk3288_vop *)dev_get_addr(dev);
- /* lcdc(vop) iodomain select 1.8V */ - rk_setreg(&priv->grf->io_vsel, 1 << 0); - - /* - * Try some common regulators. We should really get these from the - * device tree somehow. - */ - ret = regulator_autoset_by_name("vcc18_lcd", ®); - if (ret) - debug("%s: Cannot autoset regulator vcc18_lcd\n", __func__); - ret = regulator_autoset_by_name("VCC18_LCD", ®); - if (ret) - debug("%s: Cannot autoset regulator VCC18_LCD\n", __func__); - ret = regulator_autoset_by_name("vdd10_lcd_pwren_h", ®); - if (ret) { - debug("%s: Cannot autoset regulator vdd10_lcd_pwren_h\n", - __func__); - } - ret = regulator_autoset_by_name("vdd10_lcd", ®); - if (ret) { - debug("%s: Cannot autoset regulator vdd10_lcd\n", - __func__); - } - ret = regulator_autoset_by_name("VDD10_LCD", ®); - if (ret) { - debug("%s: Cannot autoset regulator VDD10_LCD\n", - __func__); - } - ret = regulator_autoset_by_name("vcc33_lcd", ®); - if (ret) - debug("%s: Cannot autoset regulator vcc33_lcd\n", __func__); - /* * Try all the ports until we find one that works. In practice this * tries EDP first if available, then HDMI. @@ -353,7 +367,7 @@ static int rk_vop_probe(struct udevice *dev) return ret; }
-static int rk_vop_bind(struct udevice *dev) +int rk_vop_bind(struct udevice *dev) { struct video_uc_platdata *plat = dev_get_uclass_platdata(dev);
@@ -362,23 +376,3 @@ static int rk_vop_bind(struct udevice *dev)
return 0; } - -static const struct video_ops rk_vop_ops = { -}; - -static const struct udevice_id rk_vop_ids[] = { - { .compatible = "rockchip,rk3399-vop-big" }, - { .compatible = "rockchip,rk3399-vop-lit" }, - { .compatible = "rockchip,rk3288-vop" }, - { } -}; - -U_BOOT_DRIVER(rk_vop) = { - .name = "rk_vop", - .id = UCLASS_VIDEO, - .of_match = rk_vop_ids, - .ops = &rk_vop_ops, - .bind = rk_vop_bind, - .probe = rk_vop_probe, - .priv_auto_alloc_size = sizeof(struct rk_vop_priv), -}; diff --git a/drivers/video/rockchip/rk_vop.h b/drivers/video/rockchip/rk_vop.h new file mode 100644 index 0000000..f65ac17 --- /dev/null +++ b/drivers/video/rockchip/rk_vop.h @@ -0,0 +1,32 @@ +/* + * Copyright (c) 2017 Theobroma Systems Design und Consulting GmbH + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __RK_VOP_H__ +#define __RK_VOP_H__ + +#include <asm/arch/vop_rk3288.h> + +struct rk_vop_priv { + void *regs; +}; + +enum vop_features { + VOP_FEATURE_OUTPUT_10BIT = (1 << 0), +}; + +struct rkvop_driverdata { + /* configuration */ + u32 features; + /* block-specific setters/getters */ + void (*set_pin_polarity)(struct udevice *, enum vop_modes, u32); +}; + +int rk_vop_probe(struct udevice *dev); +int rk_vop_bind(struct udevice *dev); +void rk_vop_probe_regulators(struct udevice *dev, + const char * const *names, int cnt); + +#endif
Changes in v4:
But please comment the functions in the header files:
1.9.1
headline is wrong. it should be "rockchip: video: refactor rk_vop and split RK3288-specific code off
Changes in v4:
- Copyright (c) 2017 Theobroma Systems Design und Consulting GmbH
- Copyright (c) 2015 Google, Inc
- Copyright 2014 Rockchip Inc.
- struct rk_vop_priv *priv = dev_get_priv(dev);
- struct rk3288_vop *regs = priv->regs;
- /* The RK3328 VOP (v3.1) has its polarity configuration in ctrl0 */
- struct rk3288_grf *grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF);
- rk_setreg(&grf->io_vsel, 1 << 0);
- Try some common regulators. We should really get these from the
- device tree somehow.
- "vcc18_lcd",
- "VCC18_LCD",
- "vdd10_lcd_pwren_h",
- "vdd10_lcd",
- "VDD10_LCD",
- "vcc33_lcd"
- /* Before relocation we don't need to do anything */
- if (!(gd->flags & GD_FLG_RELOC))
- /* Set the LCDC(vop) iodomain to 1.8V */
- rk3288_set_io_vsel(dev);
- /* Probe regulators required for the RK3288 VOP */
- rk_vop_probe_regulators(dev, rk3288_regulator_names,
- return rk_vop_probe(dev);
- .features = VOP_FEATURE_OUTPUT_10BIT,
- .set_pin_polarity = rk3288_set_pin_polarity,
- { .compatible = "rockchip,rk3288-vop",
- .name = "rk3288_vop",
- .of_match = rk3288_vop_ids,
- .ops = &rk3288_vop_ops,
- .probe = rk3288_vop_probe,
+enum vop_pol {
- HSYNC_POSITIVE = 0,
- VSYNC_POSITIVE = 1,
- DEN_NEGATIVE = 2,
- DCLK_INVERT = 3 };
{ u32 lb_mode; u32 rgb_mode;const struct display_timing *edid)
{enum vop_modes mode, u32 polarity)
- uint flags;
- int mode_flags;
- struct rkvop_driverdata *ops =
- if (ops->set_pin_polarity)
case VOP_MODE_EDP:
- case VOP_MODE_LVDS: clrsetbits_le32(®s->sys_ctrl, M_ALL_OUT_EN, V_RGB_OUT_EN(1)); break;
- case VOP_MODE_MIPI: clrsetbits_le32(®s->sys_ctrl, M_ALL_OUT_EN, V_MIPI_OUT_EN(1));
break;
break;
- default:
}debug("%s: unsupported output mode %x\n", __func__, mode);
/* RGBaaa */
mode_flags = 15;
- else
/* RGB888 */
mode_flags = 0;
- struct rkvop_driverdata *data =
- int mode_flags;
- u32 pin_polarity;
- pin_polarity = BIT(DCLK_INVERT);
- if (edid->flags & DISPLAY_FLAGS_HSYNC_HIGH)
- if (edid->flags & DISPLAY_FLAGS_VSYNC_HIGH)
- rkvop_set_pin_polarity(dev, mode, pin_polarity);
- rkvop_enable_output(dev, mode);
flags);
- @return 0 if OK, -ve if something went wrong
- case VOP_MODE_HDMI: case VOP_MODE_MIPI: l2bpp = VIDEO_BPP32; break; default: l2bpp = VIDEO_BPP16; }
- int i, ret;
- const char *name;
- for (i = 0; i < cnt; ++i) {
name = names[i];
if (!ret)
int ret = 0;
int port, node;
if (ret)
if (ret)
if (ret) {
__func__);
if (ret) {
__func__);
if (ret) {
__func__);
if (ret)
- Try all the ports until we find one that works. In practice this
- tries EDP first if available, then HDMI.
return 0; }
- .name = "rk_vop",
- void *regs;
- VOP_FEATURE_OUTPUT_10BIT = (1 << 0),
- /* configuration */
- u32 features;
- /* block-specific setters/getters */
- void (*set_pin_polarity)(struct udevice *, enum vop_modes, u32);
On Wed, 31 May 2017 17:59:30 +0200 Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote: ...
Changes in v4:
Rebased on master and applied to u-boot-video/master (with s/RK3328/RK3288/ in the subject. Thanks!
-- Anatolij
This commit adds a driver for the RK3399 VOPs capable and all the necessary plumbing to feed the HDMI encoder. For the VOP-big, this correctly tracks the ability to feed 10bit RGB data to the encoder.
Changes in v4: - split the massive "refactor, split and add RK3399 support"-change into smaller chunks that are more easily digestible
Changes in v2: None
arch/arm/include/asm/arch-rockchip/vop_rk3288.h | 10 +++ drivers/video/rockchip/Makefile | 1 + drivers/video/rockchip/rk3399_vop.c | 105 ++++++++++++++++++++++++ 3 files changed, 116 insertions(+) create mode 100644 drivers/video/rockchip/rk3399_vop.c
diff --git a/arch/arm/include/asm/arch-rockchip/vop_rk3288.h b/arch/arm/include/asm/arch-rockchip/vop_rk3288.h index 049f192..21e59be 100644 --- a/arch/arm/include/asm/arch-rockchip/vop_rk3288.h +++ b/arch/arm/include/asm/arch-rockchip/vop_rk3288.h @@ -201,6 +201,16 @@ enum vop_modes { #define V_DSP_OUT_MODE(x) ((x) & 0xf)
/* VOP_DSP_CTRL1 */ +#define V_RK3399_DSP_MIPI_POL(x) ((x) << 28) +#define V_RK3399_DSP_EDP_POL(x) ((x) << 24) +#define V_RK3399_DSP_HDMI_POL(x) ((x) << 20) +#define V_RK3399_DSP_LVDS_POL(x) ((x) << 16) + +#define M_RK3399_DSP_MIPI_POL (V_RK3399_DSP_MIPI_POL(0xf)) +#define M_RK3399_DSP_EDP_POL (V_RK3399_DSP_EDP_POL(0xf)) +#define M_RK3399_DSP_HDMI_POL (V_RK3399_DSP_HDMI_POL(0xf)) +#define M_RK3399_DSP_LVDS_POL (V_RK3399_DSP_LVDS_POL(0xf)) + #define M_DSP_LAYER3_SEL (3 << 14) #define M_DSP_LAYER2_SEL (3 << 12) #define M_DSP_LAYER1_SEL (3 << 10) diff --git a/drivers/video/rockchip/Makefile b/drivers/video/rockchip/Makefile index 9477ad0..495d5f7 100644 --- a/drivers/video/rockchip/Makefile +++ b/drivers/video/rockchip/Makefile @@ -8,6 +8,7 @@ ifdef CONFIG_VIDEO_ROCKCHIP obj-y += rk_vop.o obj-$(CONFIG_ROCKCHIP_RK3288) += rk3288_vop.o +obj-$(CONFIG_ROCKCHIP_RK3399) += rk3399_vop.o obj-$(CONFIG_DISPLAY_ROCKCHIP_EDP) += rk_edp.o obj-$(CONFIG_DISPLAY_ROCKCHIP_LVDS) += rk_lvds.o obj-$(CONFIG_DISPLAY_ROCKCHIP_HDMI) += rk_hdmi.o diff --git a/drivers/video/rockchip/rk3399_vop.c b/drivers/video/rockchip/rk3399_vop.c new file mode 100644 index 0000000..91a40ab --- /dev/null +++ b/drivers/video/rockchip/rk3399_vop.c @@ -0,0 +1,105 @@ +/* + * Copyright (c) 2017 Theobroma Systems Design und Consulting GmbH + * Copyright (c) 2015 Google, Inc + * Copyright 2014 Rockchip Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <display.h> +#include <dm.h> +#include <regmap.h> +#include <video.h> +#include <asm/hardware.h> +#include <asm/io.h> +#include "rk_vop.h" + +DECLARE_GLOBAL_DATA_PTR; + +static void rk3399_set_pin_polarity(struct udevice *dev, + enum vop_modes mode, u32 polarity) +{ + struct rk_vop_priv *priv = dev_get_priv(dev); + struct rk3288_vop *regs = priv->regs; + + /* + * The RK3399 VOPs (v3.5 and v3.6) require a per-mode setting of + * the polarity configuration (in ctrl1). + */ + switch (mode) { + case VOP_MODE_HDMI: + clrsetbits_le32(®s->dsp_ctrl1, + M_RK3399_DSP_HDMI_POL, + V_RK3399_DSP_HDMI_POL(polarity)); + break; + + case VOP_MODE_EDP: + clrsetbits_le32(®s->dsp_ctrl1, + M_RK3399_DSP_EDP_POL, + V_RK3399_DSP_EDP_POL(polarity)); + break; + + case VOP_MODE_MIPI: + clrsetbits_le32(®s->dsp_ctrl1, + M_RK3399_DSP_MIPI_POL, + V_RK3399_DSP_MIPI_POL(polarity)); + break; + + case VOP_MODE_LVDS: + /* The RK3399 has neither parallel RGB nor LVDS output. */ + default: + debug("%s: unsupported output mode %x\n", __func__, mode); + } +} + +/* + * Try some common regulators. We should really get these from the + * device tree somehow. + */ +static const char * const rk3399_regulator_names[] = { + "vcc33_lcd" +}; + +static int rk3399_vop_probe(struct udevice *dev) +{ + /* Before relocation we don't need to do anything */ + if (!(gd->flags & GD_FLG_RELOC)) + return 0; + + /* Probe regulators required for the RK3399 VOP */ + rk_vop_probe_regulators(dev, rk3399_regulator_names, + ARRAY_SIZE(rk3399_regulator_names)); + + return rk_vop_probe(dev); +} + +struct rkvop_driverdata rk3399_lit_driverdata = { + .set_pin_polarity = rk3399_set_pin_polarity, +}; + +struct rkvop_driverdata rk3399_big_driverdata = { + .features = VOP_FEATURE_OUTPUT_10BIT, + .set_pin_polarity = rk3399_set_pin_polarity, +}; + +static const struct udevice_id rk3399_vop_ids[] = { + { .compatible = "rockchip,rk3399-vop-big", + .data = (ulong)&rk3399_big_driverdata }, + { .compatible = "rockchip,rk3399-vop-lit", + .data = (ulong)&rk3399_lit_driverdata }, + { } +}; + +static const struct video_ops rk3399_vop_ops = { +}; + +U_BOOT_DRIVER(rk3399_vop) = { + .name = "rk3399_vop", + .id = UCLASS_VIDEO, + .of_match = rk3399_vop_ids, + .ops = &rk3399_vop_ops, + .bind = rk_vop_bind, + .probe = rk3399_vop_probe, + .priv_auto_alloc_size = sizeof(struct rk_vop_priv), +};
Changes in v4:
Changes in v3:
Changes in v2: None
On Wed, 31 May 2017 17:59:31 +0200 Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote: ...
Changes in v4:
Changes in v3:
Changes in v2: None
-- Anatolij
The Linux driver now supports higher mpixelclock settings. Add these to rockchip_phy_config[] and rockchip_mpll_cfg[].
Changes in v4: - new patch (split off from the earlier RK3399 HDMI encoder change)
drivers/video/rockchip/rk_hdmi.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/drivers/video/rockchip/rk_hdmi.c b/drivers/video/rockchip/rk_hdmi.c index db07588..2af4995 100644 --- a/drivers/video/rockchip/rk_hdmi.c +++ b/drivers/video/rockchip/rk_hdmi.c @@ -35,6 +35,9 @@ static const struct hdmi_phy_config rockchip_phy_config[] = { .mpixelclock = 297000000, .sym_ctr = 0x8039, .term = 0x0005, .vlev_ctr = 0x028d, }, { + .mpixelclock = 584000000, + .sym_ctr = 0x8039, .term = 0x0000, .vlev_ctr = 0x019d, + }, { .mpixelclock = ~0ul, .sym_ctr = 0x0000, .term = 0x0000, .vlev_ctr = 0x0000, } @@ -60,6 +63,12 @@ static const struct hdmi_mpll_config rockchip_mpll_cfg[] = { .mpixelclock = 148500000, .cpce = 0x0051, .gmp = 0x0003, .curr = 0x0000, }, { + .mpixelclock = 272000000, + .cpce = 0x0040, .gmp = 0x0003, .curr = 0x0000, + }, { + .mpixelclock = 340000000, + .cpce = 0x0040, .gmp = 0x0003, .curr = 0x0000, + }, { .mpixelclock = ~0ul, .cpce = 0x0051, .gmp = 0x0003, .curr = 0x0000, }
Changes in v4:
On Wed, 31 May 2017 17:59:32 +0200 Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote: ...
Changes in v4:
-- Anatolij
To prepare for the addition of RK3399 HDMI support, the HDMI driver is refactored and broken into a chip-specific and a generic part. This change adds the internal interfaces, makes common/reusable functions externally visible and splits the RK3228 driver into a separate file.
For the probing of regulators, we reuse the infrastructure created during the VOP refactoring... i.e. we simply call into the helper function defined for the VOP.
Version-changes: 4 - add this path (as part of breaking up the large HDMI change for the RK3399)
Changes in v4: None Changes in v3: None Changes in v2: None
drivers/video/rockchip/Makefile | 3 +- drivers/video/rockchip/rk3288_hdmi.c | 116 +++++++++++++++++++++++++++++++++++ drivers/video/rockchip/rk_hdmi.c | 105 +++++-------------------------- drivers/video/rockchip/rk_hdmi.h | 32 ++++++++++ 4 files changed, 166 insertions(+), 90 deletions(-) create mode 100644 drivers/video/rockchip/rk3288_hdmi.c create mode 100644 drivers/video/rockchip/rk_hdmi.h
diff --git a/drivers/video/rockchip/Makefile b/drivers/video/rockchip/Makefile index 495d5f7..65d0ed6 100644 --- a/drivers/video/rockchip/Makefile +++ b/drivers/video/rockchip/Makefile @@ -11,6 +11,7 @@ obj-$(CONFIG_ROCKCHIP_RK3288) += rk3288_vop.o obj-$(CONFIG_ROCKCHIP_RK3399) += rk3399_vop.o obj-$(CONFIG_DISPLAY_ROCKCHIP_EDP) += rk_edp.o obj-$(CONFIG_DISPLAY_ROCKCHIP_LVDS) += rk_lvds.o -obj-$(CONFIG_DISPLAY_ROCKCHIP_HDMI) += rk_hdmi.o +obj-hdmi-$(CONFIG_ROCKCHIP_RK3288) += rk3288_hdmi.o +obj-$(CONFIG_DISPLAY_ROCKCHIP_HDMI) += rk_hdmi.o $(obj-hdmi-y) obj-$(CONFIG_DISPLAY_ROCKCHIP_MIPI) += rk_mipi.o endif diff --git a/drivers/video/rockchip/rk3288_hdmi.c b/drivers/video/rockchip/rk3288_hdmi.c new file mode 100644 index 0000000..eae0dd2 --- /dev/null +++ b/drivers/video/rockchip/rk3288_hdmi.c @@ -0,0 +1,116 @@ +/* + * Copyright (c) 2017 Theobroma Systems Design und Consulting GmbH + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <clk.h> +#include <display.h> +#include <dm.h> +#include <dw_hdmi.h> +#include <edid.h> +#include <regmap.h> +#include <syscon.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/hardware.h> +#include <asm/arch/grf_rk3288.h> +#include <power/regulator.h> +#include "rk_hdmi.h" + +static int rk3288_hdmi_enable(struct udevice *dev, int panel_bpp, + const struct display_timing *edid) +{ + struct rk_hdmi_priv *priv = dev_get_priv(dev); + struct display_plat *uc_plat = dev_get_uclass_platdata(dev); + int vop_id = uc_plat->source_id; + struct rk3288_grf *grf = priv->grf; + + /* hdmi source select hdmi controller */ + rk_setreg(&grf->soc_con6, 1 << 15); + + /* hdmi data from vop id */ + rk_clrsetreg(&grf->soc_con6, 1 << 4, (vop_id == 1) ? (1 << 4) : 0); + + return 0; +} + +static int rk3288_hdmi_ofdata_to_platdata(struct udevice *dev) +{ + struct rk_hdmi_priv *priv = dev_get_priv(dev); + struct dw_hdmi *hdmi = &priv->hdmi; + + hdmi->i2c_clk_high = 0x7a; + hdmi->i2c_clk_low = 0x8d; + + /* + * TODO(sjg@chromium.org): The above values don't work - these + * ones work better, but generate lots of errors in the data. + */ + hdmi->i2c_clk_high = 0x0d; + hdmi->i2c_clk_low = 0x0d; + + return rk_hdmi_ofdata_to_platdata(dev); +} + +static int rk3288_clk_config(struct udevice *dev) +{ + struct display_plat *uc_plat = dev_get_uclass_platdata(dev); + struct clk clk; + int ret; + + /* + * Configure the maximum clock to permit whatever resolution the + * monitor wants + */ + ret = clk_get_by_index(uc_plat->src_dev, 0, &clk); + if (ret >= 0) { + ret = clk_set_rate(&clk, 384000000); + clk_free(&clk); + } + if (ret < 0) { + debug("%s: Failed to set clock in source device '%s': ret=%d\n", + __func__, uc_plat->src_dev->name, ret); + return ret; + } + + return 0; +} + +static const char * const rk3288_regulator_names[] = { + "vcc50_hdmi" +}; + +static int rk3288_hdmi_probe(struct udevice *dev) +{ + /* Enable VOP clock for RK3288 */ + rk3288_clk_config(dev); + + /* Enable regulators required for HDMI */ + rk_hdmi_probe_regulators(dev, rk3288_regulator_names, + ARRAY_SIZE(rk3288_regulator_names)); + + return rk_hdmi_probe(dev); +} + +static const struct dm_display_ops rk3288_hdmi_ops = { + .read_edid = rk_hdmi_read_edid, + .enable = rk3288_hdmi_enable, +}; + +static const struct udevice_id rk3288_hdmi_ids[] = { + { .compatible = "rockchip,rk3288-dw-hdmi" }, + { } +}; + +U_BOOT_DRIVER(rk3288_hdmi_rockchip) = { + .name = "rk3288_hdmi_rockchip", + .id = UCLASS_DISPLAY, + .of_match = rk3288_hdmi_ids, + .ops = &rk3288_hdmi_ops, + .ofdata_to_platdata = rk3288_hdmi_ofdata_to_platdata, + .probe = rk3288_hdmi_probe, + .priv_auto_alloc_size = sizeof(struct rk_hdmi_priv), +}; diff --git a/drivers/video/rockchip/rk_hdmi.c b/drivers/video/rockchip/rk_hdmi.c index 2af4995..25f84a7 100644 --- a/drivers/video/rockchip/rk_hdmi.c +++ b/drivers/video/rockchip/rk_hdmi.c @@ -1,4 +1,5 @@ /* + * Copyright (c) 2017 Theobroma Systems Design und Consulting GmbH * Copyright (c) 2015 Google, Inc * Copyright 2014 Rockchip Inc. * @@ -16,13 +17,9 @@ #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/clock.h> -#include <asm/arch/grf_rk3288.h> -#include <power/regulator.h> - -struct rk_hdmi_priv { - struct dw_hdmi hdmi; - struct rk3288_grf *grf; -}; +#include <asm/arch/hardware.h> +#include "rk_hdmi.h" +#include "rk_vop.h" /* for rk_vop_probe_regulators */
static const struct hdmi_phy_config rockchip_phy_config[] = { { @@ -74,22 +71,14 @@ static const struct hdmi_mpll_config rockchip_mpll_cfg[] = { } };
-static int rk_hdmi_read_edid(struct udevice *dev, u8 *buf, int buf_size) +int rk_hdmi_read_edid(struct udevice *dev, u8 *buf, int buf_size) { struct rk_hdmi_priv *priv = dev_get_priv(dev);
return dw_hdmi_read_edid(&priv->hdmi, buf, buf_size); }
-static int rk_hdmi_enable(struct udevice *dev, int panel_bpp, - const struct display_timing *edid) -{ - struct rk_hdmi_priv *priv = dev_get_priv(dev); - - return dw_hdmi_enable(&priv->hdmi, edid); -} - -static int rk_hdmi_ofdata_to_platdata(struct udevice *dev) +int rk_hdmi_ofdata_to_platdata(struct udevice *dev) { struct rk_hdmi_priv *priv = dev_get_priv(dev); struct dw_hdmi *hdmi = &priv->hdmi; @@ -97,15 +86,9 @@ static int rk_hdmi_ofdata_to_platdata(struct udevice *dev) hdmi->ioaddr = (ulong)dev_get_addr(dev); hdmi->mpll_cfg = rockchip_mpll_cfg; hdmi->phy_cfg = rockchip_phy_config; - hdmi->i2c_clk_high = 0x7a; - hdmi->i2c_clk_low = 0x8d; - - /* - * TODO(sjg@chromium.org): The above values don't work - these ones - * work better, but generate lots of errors in the data. - */ - hdmi->i2c_clk_high = 0x0d; - hdmi->i2c_clk_low = 0x0d; + + /* hdmi->i2c_clk_{high,low} are set up by the SoC driver */ + hdmi->reg_io_width = 4; hdmi->phy_set = dw_hdmi_phy_cfg;
@@ -114,53 +97,17 @@ static int rk_hdmi_ofdata_to_platdata(struct udevice *dev) return 0; }
-static int rk_hdmi_probe(struct udevice *dev) +void rk_hdmi_probe_regulators(struct udevice *dev, + const char * const *names, int cnt) +{ + rk_vop_probe_regulators(dev, names, cnt); +} + +int rk_hdmi_probe(struct udevice *dev) { - struct display_plat *uc_plat = dev_get_uclass_platdata(dev); struct rk_hdmi_priv *priv = dev_get_priv(dev); struct dw_hdmi *hdmi = &priv->hdmi; - struct udevice *reg; - struct clk clk; int ret; - int vop_id = uc_plat->source_id; - - ret = clk_get_by_index(dev, 0, &clk); - if (ret >= 0) { - ret = clk_set_rate(&clk, 0); - clk_free(&clk); - } - if (ret) { - debug("%s: Failed to set hdmi clock: ret=%d\n", __func__, ret); - return ret; - } - - /* - * Configure the maximum clock to permit whatever resolution the - * monitor wants - */ - ret = clk_get_by_index(uc_plat->src_dev, 0, &clk); - if (ret >= 0) { - ret = clk_set_rate(&clk, 384000000); - clk_free(&clk); - } - if (ret < 0) { - debug("%s: Failed to set clock in source device '%s': ret=%d\n", - __func__, uc_plat->src_dev->name, ret); - return ret; - } - - ret = regulator_get_by_platname("vcc50_hdmi", ®); - if (!ret) - ret = regulator_set_enable(reg, true); - if (ret) - debug("%s: Cannot set regulator vcc50_hdmi\n", __func__); - - /* hdmi source select hdmi controller */ - rk_setreg(&priv->grf->soc_con6, 1 << 15); - - /* hdmi data from vop id */ - rk_clrsetreg(&priv->grf->soc_con6, 1 << 4, - (vop_id == 1) ? (1 << 4) : 0);
ret = dw_hdmi_phy_wait_for_hpd(hdmi); if (ret < 0) { @@ -173,23 +120,3 @@ static int rk_hdmi_probe(struct udevice *dev)
return 0; } - -static const struct dm_display_ops rk_hdmi_ops = { - .read_edid = rk_hdmi_read_edid, - .enable = rk_hdmi_enable, -}; - -static const struct udevice_id rk_hdmi_ids[] = { - { .compatible = "rockchip,rk3288-dw-hdmi" }, - { } -}; - -U_BOOT_DRIVER(hdmi_rockchip) = { - .name = "hdmi_rockchip", - .id = UCLASS_DISPLAY, - .of_match = rk_hdmi_ids, - .ops = &rk_hdmi_ops, - .ofdata_to_platdata = rk_hdmi_ofdata_to_platdata, - .probe = rk_hdmi_probe, - .priv_auto_alloc_size = sizeof(struct rk_hdmi_priv), -}; diff --git a/drivers/video/rockchip/rk_hdmi.h b/drivers/video/rockchip/rk_hdmi.h new file mode 100644 index 0000000..501ed3a --- /dev/null +++ b/drivers/video/rockchip/rk_hdmi.h @@ -0,0 +1,32 @@ +/* + * Copyright (c) 2017 Theobroma Systems Design und Consulting GmbH + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __RK_HDMI_H__ +#define __RK_HDMI_H__ + +struct rkhdmi_driverdata { + /* configuration */ + u8 i2c_clk_high; + u8 i2c_clk_low; + const char * const *regulator_names; + u32 regulator_names_cnt; + /* setters/getters */ + int (*set_input_vop)(struct udevice *dev); + int (*clk_config)(struct udevice *dev); +}; + +struct rk_hdmi_priv { + struct dw_hdmi hdmi; + void *grf; +}; + +int rk_hdmi_read_edid(struct udevice *dev, u8 *buf, int buf_size); +void rk_hdmi_probe_regulators(struct udevice *dev, + const char * const *names, int cnt); +int rk_hdmi_ofdata_to_platdata(struct udevice *dev); +int rk_hdmi_probe(struct udevice *dev); + +#endif
Version-changes: 4
Again please comment the header-file functions:
1.9.1
headline is wrong. it should be "rockchip: video: splitRK3288-specific part off from rk_hdmi"
Version-changes: 4
- struct rk3288_grf *grf = priv->grf;
- rk_setreg(&grf->soc_con6, 1 << 15);
- rk_clrsetreg(&grf->soc_con6, 1 << 4, (vop_id == 1) ? (1 << 4) : 0);
- struct dw_hdmi *hdmi = &priv->hdmi;
- return rk_hdmi_ofdata_to_platdata(dev);
- struct clk clk;
- int ret;
* monitor wants
- if (ret >= 0) {
clk_free(&clk);
- if (ret < 0) {
return ret;
- "vcc50_hdmi"
- /* Enable VOP clock for RK3288 */
- rk3288_clk_config(dev);
- /* Enable regulators required for HDMI */
- rk_hdmi_probe_regulators(dev, rk3288_regulator_names,
- return rk_hdmi_probe(dev);
- .enable = rk3288_hdmi_enable,
- .name = "rk3288_hdmi_rockchip",
- .of_match = rk3288_hdmi_ids,
- .ops = &rk3288_hdmi_ops,
- .ofdata_to_platdata = rk3288_hdmi_ofdata_to_platdata,
- .probe = rk3288_hdmi_probe,
- /* hdmi->i2c_clk_{high,low} are set up by the SoC driver */
- hdmi->reg_io_width = 4; hdmi->phy_set = dw_hdmi_phy_cfg;
- rk_vop_probe_regulators(dev, names, cnt);
if (ret >= 0) {
clk_free(&clk);
if (ret) {
return ret;
* monitor wants
if (ret >= 0) {
clk_free(&clk);
if (ret < 0) {
return ret;
if (!ret)
if (ret)
return 0; }
- u8 i2c_clk_high;
- u8 i2c_clk_low;
- const char * const *regulator_names;
- u32 regulator_names_cnt;
- /* setters/getters */
- int (*set_input_vop)(struct udevice *dev);
- int (*clk_config)(struct udevice *dev);
- void *grf;
On Wed, 31 May 2017 17:59:33 +0200 Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
Version-changes: 4
Rebased on master and applied to u-boot-video/master (with s/RK3228/RK3288/ in commit message).
Please send a subsequent path adding comments for the header-file functions, as Simon noted. Thanks!
-- Anatolij
This commit enables the RK3399 HDMI TX, which is very similar to the one found on the RK3288. As requested by Simon, this splits the HDMI driver into a SOC-specific portion (rk3399_hdmi.c, rk3288_hdmi.c) and a common portion (rk_hdmi.c).
Note that the I2C communication for reading the EDID works well with the default settings, but does not with the alternate settings used on the RK3288... this configuration aspect is reflected by the driverdata for the RK3399 driver.
Having some sort of DTS-based configuration for the regulator dependencies would be nice for the future, but for now we simply use lists of regulator names (also via driverdata) that we probe.
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com ---
Changes in v4: - splits the large change into smaller changes
Changes in v3: - split into separate drivers for the SOC-specific portion of the driver - rebase to sjg/next
--- arch/arm/include/asm/arch-rockchip/grf_rk3399.h | 3 + drivers/video/rockchip/Makefile | 1 + drivers/video/rockchip/rk3399_hdmi.c | 81 +++++++++++++++++++++++++ 3 files changed, 85 insertions(+) create mode 100644 drivers/video/rockchip/rk3399_hdmi.c
diff --git a/arch/arm/include/asm/arch-rockchip/grf_rk3399.h b/arch/arm/include/asm/arch-rockchip/grf_rk3399.h index eda9956..8d21eb7 100644 --- a/arch/arm/include/asm/arch-rockchip/grf_rk3399.h +++ b/arch/arm/include/asm/arch-rockchip/grf_rk3399.h @@ -534,6 +534,9 @@ enum { GRF_DSI0_VOP_SEL_MASK = 1 << GRF_DSI0_VOP_SEL_SHIFT, GRF_DSI0_VOP_SEL_B = 0, GRF_DSI0_VOP_SEL_L = 1, + GRF_RK3399_HDMI_VOP_SEL_MASK = 1 << 6, + GRF_RK3399_HDMI_VOP_SEL_B = 0 << 6, + GRF_RK3399_HDMI_VOP_SEL_L = 1 << 6,
/* GRF_SOC_CON22 */ GRF_DPHY_TX0_RXMODE_SHIFT = 0, diff --git a/drivers/video/rockchip/Makefile b/drivers/video/rockchip/Makefile index 65d0ed6..872dc0f 100644 --- a/drivers/video/rockchip/Makefile +++ b/drivers/video/rockchip/Makefile @@ -12,6 +12,7 @@ obj-$(CONFIG_ROCKCHIP_RK3399) += rk3399_vop.o obj-$(CONFIG_DISPLAY_ROCKCHIP_EDP) += rk_edp.o obj-$(CONFIG_DISPLAY_ROCKCHIP_LVDS) += rk_lvds.o obj-hdmi-$(CONFIG_ROCKCHIP_RK3288) += rk3288_hdmi.o +obj-hdmi-$(CONFIG_ROCKCHIP_RK3399) += rk3399_hdmi.o obj-$(CONFIG_DISPLAY_ROCKCHIP_HDMI) += rk_hdmi.o $(obj-hdmi-y) obj-$(CONFIG_DISPLAY_ROCKCHIP_MIPI) += rk_mipi.o endif diff --git a/drivers/video/rockchip/rk3399_hdmi.c b/drivers/video/rockchip/rk3399_hdmi.c new file mode 100644 index 0000000..b1e5097 --- /dev/null +++ b/drivers/video/rockchip/rk3399_hdmi.c @@ -0,0 +1,81 @@ +/* + * Copyright (c) 2017 Theobroma Systems Design und Consulting GmbH + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <clk.h> +#include <display.h> +#include <dm.h> +#include <dw_hdmi.h> +#include <edid.h> +#include <regmap.h> +#include <syscon.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/hardware.h> +#include <asm/arch/grf_rk3399.h> +#include <power/regulator.h> +#include "rk_hdmi.h" + +static int rk3399_hdmi_enable(struct udevice *dev, int panel_bpp, + const struct display_timing *edid) +{ + struct rk_hdmi_priv *priv = dev_get_priv(dev); + struct display_plat *uc_plat = dev_get_uclass_platdata(dev); + int vop_id = uc_plat->source_id; + struct rk3399_grf_regs *grf = priv->grf; + + /* select the hdmi encoder input data from our source_id */ + rk_clrsetreg(&grf->soc_con20, GRF_RK3399_HDMI_VOP_SEL_MASK, + (vop_id == 1) ? GRF_RK3399_HDMI_VOP_SEL_L : 0); + + return dw_hdmi_enable(&priv->hdmi, edid); +} + +static int rk3399_hdmi_ofdata_to_platdata(struct udevice *dev) +{ + struct rk_hdmi_priv *priv = dev_get_priv(dev); + struct dw_hdmi *hdmi = &priv->hdmi; + + hdmi->i2c_clk_high = 0x7a; + hdmi->i2c_clk_low = 0x8d; + + return rk_hdmi_ofdata_to_platdata(dev); +} + +static const char * const rk3399_regulator_names[] = { + "vcc1v8_hdmi", + "vcc0v9_hdmi" +}; + +static int rk3399_hdmi_probe(struct udevice *dev) +{ + /* Enable regulators required for HDMI */ + rk_hdmi_probe_regulators(dev, rk3399_regulator_names, + ARRAY_SIZE(rk3399_regulator_names)); + + return rk_hdmi_probe(dev); +} + +static const struct dm_display_ops rk3399_hdmi_ops = { + .read_edid = rk_hdmi_read_edid, + .enable = rk3399_hdmi_enable, +}; + +static const struct udevice_id rk3399_hdmi_ids[] = { + { .compatible = "rockchip,rk3399-dw-hdmi" }, + { } +}; + +U_BOOT_DRIVER(rk3399_hdmi_rockchip) = { + .name = "rk3399_hdmi_rockchip", + .id = UCLASS_DISPLAY, + .of_match = rk3399_hdmi_ids, + .ops = &rk3399_hdmi_ops, + .ofdata_to_platdata = rk3399_hdmi_ofdata_to_platdata, + .probe = rk3399_hdmi_probe, + .priv_auto_alloc_size = sizeof(struct rk_hdmi_priv), +};
Changes in v4:
Changes in v3:
Changes in v2:
On Wed, 31 May 2017 17:59:34 +0200 Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote: ...
Changes in v4:
Changes in v3:
Changes in v2:
-- Anatolij
This commit enables HDMI output in the DTS by adding the necessary nodes to vopl/vopb and by adding the HDMI node.
arch/arm/dts/rk3399.dtsi | 39 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 39 insertions(+)
diff --git a/arch/arm/dts/rk3399.dtsi b/arch/arm/dts/rk3399.dtsi index f3d3f53..7f1fc50 100644 --- a/arch/arm/dts/rk3399.dtsi +++ b/arch/arm/dts/rk3399.dtsi @@ -1419,6 +1419,11 @@ reg = <3>; remote-endpoint = <&mipi_in_vopl>; }; + + vopl_out_hdmi: endpoint@1 { + reg = <1>; + remote-endpoint = <&hdmi_in_vopl>; + }; }; };
@@ -1440,6 +1445,40 @@ reg = <3>; remote-endpoint = <&mipi_in_vopb>; }; + + vopb_out_hdmi: endpoint@1 { + reg = <1>; + remote-endpoint = <&hdmi_in_vopb>; + }; + }; + }; + + hdmi: hdmi@ff940000 { + compatible = "rockchip,rk3399-dw-hdmi"; + reg = <0x0 0xff940000 0x0 0x20000>; + reg-io-width = <4>; + rockchip,grf = <&grf>; + pinctrl-names = "default"; + pinctrl-0 = <&hdmi_i2c_xfer>; + power-domains = <&power RK3399_PD_HDCP>; + interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru PCLK_HDMI_CTRL>, <&cru SCLK_HDMI_SFR>, <&cru PLL_VPLL>, <&cru PCLK_VIO_GRF>; + clock-names = "iahb", "isfr", "vpll", "grf"; + status = "disabled"; + + ports { + hdmi_in: port { + #address-cells = <1>; + #size-cells = <0>; + hdmi_in_vopb: endpoint@0 { + reg = <0>; + remote-endpoint = <&vopb_out_hdmi>; + }; + hdmi_in_vopl: endpoint@1 { + reg = <1>; + remote-endpoint = <&vopl_out_hdmi>; + }; + }; }; };
On Wed, 31 May 2017 17:59:35 +0200 Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
-- Anatolij
Hi Anatolij,
I cannot see this patch there. Can you please point me to it? I'd like to bring in some more patches but they depend on this series.
Hi Simon,
On Wed, 7 Jun 2017 06:51:19 -0600 Simon Glass sjg@chromium.org wrote: ...
it is here http://patchwork.ozlabs.org/patch/769240/
I applied patches 1-8 here:
http://git.denx.de/?p=u-boot/u-boot-video.git;a=shortlog;h=refs/heads/merge
But patch 9 depends on changes in u-boot-rockchip.git. I can rebase when u-boot-rockchip.git is merged in u-boot.git/master and then also can add patch 9. Or you can merge this series into u-boot-rockchip if it is easier.
Thanks,
Anatolij
Hi Anatolij,
On 7 June 2017 at 07:05, Anatolij Gustschin agust@denx.de wrote:
Hi Simon,
OK I will go ahead and merge them again to rockchip since I have other patches that rely on these. This is getting tricky!
Hi Simon,
On Wed, 7 Jun 2017 21:30:15 -0600 Simon Glass sjg@chromium.org wrote: ...
OK, thanks!
-- Anatolij
With video output support for the RK3399-Q7 (Puma) available, we want CMD_BMP enabled and the support for 16bit, 24bit and 32bit BMPs defined.
Version-changes: 2 - enable SYS_WHITE_ON_BLACK via defconfig
include/configs/puma_rk3399.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/include/configs/puma_rk3399.h b/include/configs/puma_rk3399.h index ece8bba..af1dae8 100644 --- a/include/configs/puma_rk3399.h +++ b/include/configs/puma_rk3399.h @@ -26,4 +26,8 @@ #define CONFIG_SERIAL_TAG #define CONFIG_ENV_OVERWRITE
+#define CONFIG_BMP_16BPP +#define CONFIG_BMP_24BPP +#define CONFIG_BMP_32BPP + #endif
Version-changes: 2
On Wed, 31 May 2017 17:59:36 +0200 Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote: ...
#endif
this one depends on committed changes in rockchip repo, I'll apply this patch after u-boot-rockchip.git is merged to master.
-- Anatolij
On Wed, 31 May 2017 17:59:36 +0200 Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote: ... Applied to u-boot-rockchip, thanks!
participants (5)
Anatolij Gustschin
Eric
Philipp Tomsich
sjg@google.com
