[U-Boot] [PATCH] ColdFire: Fix M5253EVB dram bring up issue
Signed-off-by: TsiChung Liew Tsi-Chung.Liew@freescale.com --- board/freescale/m5253evbe/m5253evbe.c | 13 +++++++++---- 1 files changed, 9 insertions(+), 4 deletions(-)
diff --git a/board/freescale/m5253evbe/m5253evbe.c b/board/freescale/m5253evbe/m5253evbe.c index f80a47c..f3b1efd 100644 --- a/board/freescale/m5253evbe/m5253evbe.c +++ b/board/freescale/m5253evbe/m5253evbe.c @@ -36,8 +36,6 @@ int checkboard(void)
phys_size_t initdram(int board_type) { - int i; - /* * Check to see if the SDRAM has already been initialized * by a run control tool @@ -50,21 +48,27 @@ phys_size_t initdram(int board_type)
/* Initialize DRAM Control Register: DCR */ mbar_writeShort(MCFSIM_DCR, (0x8400 | RC)); + asm("nop");
- mbar_writeLong(MCFSIM_DACR0, 0x00003224); + mbar_writeLong(MCFSIM_DACR0, 0x00002320); + asm("nop");
/* Initialize DMR0 */ dramsize = ((CFG_SDRAM_SIZE << 20) - 1) & 0xFFFC0000; mbar_writeLong(MCFSIM_DMR0, dramsize | 1); + asm("nop");
- mbar_writeLong(MCFSIM_DACR0, 0x0000322c); + mbar_writeLong(MCFSIM_DACR0, 0x00002328); + asm("nop");
/* Write to this block to initiate precharge */ *(u32 *) (CFG_SDRAM_BASE) = 0xa5a5a5a5; + asm("nop");
/* Set RE bit in DACR */ mbar_writeLong(MCFSIM_DACR0, mbar_readLong(MCFSIM_DACR0) | 0x8000); + asm("nop");
/* Wait for at least 8 auto refresh cycles to occur */ udelay(500); @@ -72,6 +76,7 @@ phys_size_t initdram(int board_type) /* Finish the configuration by issuing the MRS */ mbar_writeLong(MCFSIM_DACR0, mbar_readLong(MCFSIM_DACR0) | 0x0040); + asm("nop");
*(u32 *) (CFG_SDRAM_BASE + 0x800) = 0xa5a5a5a5; }
Tsi-Chung Liew
