[PATCH v1] armv8: crypto: SHA-512 using ARMv8 Crypto Extensions
Add support for the SHA-512 Secure Hash Algorithm which uses ARMv8 Crypto Extensions. The CPU should support ARMv8.2 instruction set and implement SHA512H, SHA512H2, SHA512SU0, and SHA512SU1 instructions.
This information can be obtained from ID_AA64ISAR0_EL1 (AArch64 Instruction Set Attribute Register 0), bits [15:12] should be 0b0010 [1], that indicates support for SHA512* instructions in AArch64 state. As not all ARMv8-base SoCs support that, ARMV8_CE_SHA512 is left disabled by default for now.
Tested in QEMU for ARMv8 with compiled-in SHA-2 support. Even on emulated cpu the hashing speed increase was visible:
With CE usage: => time hash sha512 0x40200000 0x2000000 Calculate hash Calculate hash sha512 for 40200000 ... 421fffff ==> 1aeae269f4eb7c37...
time: 0.215 seconds
Without CE usage: => time hash sha512 0x40200000 0x2000000 sha512 for 40200000 ... 421fffff ==> 1aeae269f4eb7c37...
time: 0.356 seconds
Real HW tests should provide much more improvement and objective results with 10x speed increase at least.
The implementation is based on original implementation from Ard Biesheuvel in Linux kernel [2]
[1] https://developer.arm.com/documentation/ddi0601/2023-12/AArch64-Registers/ID... [2] https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/arch...
CC: Ard Biesheuvel ard.biesheuvel@linaro.org CC: Loic Poulain loic.poulain@linaro.org Signed-off-by: Igor Opaniuk igor.opaniuk@gmail.com ---
arch/arm/cpu/armv8/Kconfig | 5 + arch/arm/cpu/armv8/Makefile | 1 + arch/arm/cpu/armv8/sha512_ce_core.S | 210 ++++++++++++++++++++++++++++ arch/arm/cpu/armv8/sha512_ce_glue.c | 20 +++ lib/sha512.c | 6 +- 5 files changed, 240 insertions(+), 2 deletions(-) create mode 100644 arch/arm/cpu/armv8/sha512_ce_core.S create mode 100644 arch/arm/cpu/armv8/sha512_ce_glue.c
diff --git a/arch/arm/cpu/armv8/Kconfig b/arch/arm/cpu/armv8/Kconfig index 9f0fb369f7..fd5c26421b 100644 --- a/arch/arm/cpu/armv8/Kconfig +++ b/arch/arm/cpu/armv8/Kconfig @@ -204,6 +204,11 @@ config ARMV8_CE_SHA256 bool "SHA-256 digest algorithm (ARMv8 Crypto Extensions)" default y if SHA256
+config ARMV8_CE_SHA512 + bool "SHA-512 digest algorithm (ARMv8 Crypto Extensions)" + depends on SHA512 + default n + endif
endif diff --git a/arch/arm/cpu/armv8/Makefile b/arch/arm/cpu/armv8/Makefile index bba4f570db..3894f2bb2a 100644 --- a/arch/arm/cpu/armv8/Makefile +++ b/arch/arm/cpu/armv8/Makefile @@ -45,3 +45,4 @@ obj-$(CONFIG_TARGET_BCMNS3) += bcmns3/ obj-$(CONFIG_XEN) += xen/ obj-$(CONFIG_ARMV8_CE_SHA1) += sha1_ce_glue.o sha1_ce_core.o obj-$(CONFIG_ARMV8_CE_SHA256) += sha256_ce_glue.o sha256_ce_core.o +obj-$(CONFIG_ARMV8_CE_SHA512) += sha512_ce_glue.o sha512_ce_core.o \ No newline at end of file diff --git a/arch/arm/cpu/armv8/sha512_ce_core.S b/arch/arm/cpu/armv8/sha512_ce_core.S new file mode 100644 index 0000000000..906291f35b --- /dev/null +++ b/arch/arm/cpu/armv8/sha512_ce_core.S @@ -0,0 +1,210 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ +/* + * sha512-ce-core.S - core SHA-384/SHA-512 transform using v8 Crypto + * Extensions + * + * Copyright (C) 2018 Linaro Ltd ard.biesheuvel@linaro.org + * Copyright (C) 2024 Igor Opaniuk igor.opaniuk@gmail.com + */ + + #include <config.h> + #include <linux/linkage.h> + #include <asm/system.h> + #include <asm/macro.h> + + .macro adr_l, dst, sym + adrp \dst, \sym + add \dst, \dst, :lo12:\sym + .endm + + .irp b,0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19 + .set .Lq\b, \b + .set .Lv\b().2d, \b + .endr + + .macro sha512h, rd, rn, rm + .inst 0xce608000 | .L\rd | (.L\rn << 5) | (.L\rm << 16) + .endm + + .macro sha512h2, rd, rn, rm + .inst 0xce608400 | .L\rd | (.L\rn << 5) | (.L\rm << 16) + .endm + + .macro sha512su0, rd, rn + .inst 0xcec08000 | .L\rd | (.L\rn << 5) + .endm + + .macro sha512su1, rd, rn, rm + .inst 0xce608800 | .L\rd | (.L\rn << 5) | (.L\rm << 16) + .endm + + /* + * The SHA-512 round constants + */ + .section ".rodata", "a" + .align 4 +.Lsha512_rcon: + .quad 0x428a2f98d728ae22, 0x7137449123ef65cd + .quad 0xb5c0fbcfec4d3b2f, 0xe9b5dba58189dbbc + .quad 0x3956c25bf348b538, 0x59f111f1b605d019 + .quad 0x923f82a4af194f9b, 0xab1c5ed5da6d8118 + .quad 0xd807aa98a3030242, 0x12835b0145706fbe + .quad 0x243185be4ee4b28c, 0x550c7dc3d5ffb4e2 + .quad 0x72be5d74f27b896f, 0x80deb1fe3b1696b1 + .quad 0x9bdc06a725c71235, 0xc19bf174cf692694 + .quad 0xe49b69c19ef14ad2, 0xefbe4786384f25e3 + .quad 0x0fc19dc68b8cd5b5, 0x240ca1cc77ac9c65 + .quad 0x2de92c6f592b0275, 0x4a7484aa6ea6e483 + .quad 0x5cb0a9dcbd41fbd4, 0x76f988da831153b5 + .quad 0x983e5152ee66dfab, 0xa831c66d2db43210 + .quad 0xb00327c898fb213f, 0xbf597fc7beef0ee4 + .quad 0xc6e00bf33da88fc2, 0xd5a79147930aa725 + .quad 0x06ca6351e003826f, 0x142929670a0e6e70 + .quad 0x27b70a8546d22ffc, 0x2e1b21385c26c926 + .quad 0x4d2c6dfc5ac42aed, 0x53380d139d95b3df + .quad 0x650a73548baf63de, 0x766a0abb3c77b2a8 + .quad 0x81c2c92e47edaee6, 0x92722c851482353b + .quad 0xa2bfe8a14cf10364, 0xa81a664bbc423001 + .quad 0xc24b8b70d0f89791, 0xc76c51a30654be30 + .quad 0xd192e819d6ef5218, 0xd69906245565a910 + .quad 0xf40e35855771202a, 0x106aa07032bbd1b8 + .quad 0x19a4c116b8d2d0c8, 0x1e376c085141ab53 + .quad 0x2748774cdf8eeb99, 0x34b0bcb5e19b48a8 + .quad 0x391c0cb3c5c95a63, 0x4ed8aa4ae3418acb + .quad 0x5b9cca4f7763e373, 0x682e6ff3d6b2b8a3 + .quad 0x748f82ee5defb2fc, 0x78a5636f43172f60 + .quad 0x84c87814a1f0ab72, 0x8cc702081a6439ec + .quad 0x90befffa23631e28, 0xa4506cebde82bde9 + .quad 0xbef9a3f7b2c67915, 0xc67178f2e372532b + .quad 0xca273eceea26619c, 0xd186b8c721c0c207 + .quad 0xeada7dd6cde0eb1e, 0xf57d4f7fee6ed178 + .quad 0x06f067aa72176fba, 0x0a637dc5a2c898a6 + .quad 0x113f9804bef90dae, 0x1b710b35131c471b + .quad 0x28db77f523047d84, 0x32caab7b40c72493 + .quad 0x3c9ebe0a15c9bebc, 0x431d67c49c100d4c + .quad 0x4cc5d4becb3e42b6, 0x597f299cfc657e2a + .quad 0x5fcb6fab3ad6faec, 0x6c44198c4a475817 + + .macro dround, i0, i1, i2, i3, i4, rc0, rc1, in0, in1, in2, in3, in4 + .ifnb \rc1 + ld1 {v\rc1().2d}, [x4], #16 + .endif + add v5.2d, v\rc0().2d, v\in0().2d + ext v6.16b, v\i2().16b, v\i3().16b, #8 + ext v5.16b, v5.16b, v5.16b, #8 + ext v7.16b, v\i1().16b, v\i2().16b, #8 + add v\i3().2d, v\i3().2d, v5.2d + .ifnb \in1 + ext v5.16b, v\in3().16b, v\in4().16b, #8 + sha512su0 v\in0().2d, v\in1().2d + .endif + sha512h q\i3, q6, v7.2d + .ifnb \in1 + sha512su1 v\in0().2d, v\in2().2d, v5.2d + .endif + add v\i4().2d, v\i1().2d, v\i3().2d + sha512h2 q\i3, q\i1, v\i0().2d + .endm + + /* + * void sha512_ce_transform(struct sha512_state *sst, u8 const *src, + * int blocks) + */ + .text +ENTRY(sha512_ce_transform) + /* load state */ + ld1 {v8.2d-v11.2d}, [x0] + + /* load first 4 round constants */ + adr_l x3, .Lsha512_rcon + ld1 {v20.2d-v23.2d}, [x3], #64 + + /* load input */ +0: ld1 {v12.2d-v15.2d}, [x1], #64 + ld1 {v16.2d-v19.2d}, [x1], #64 + sub w2, w2, #1 +#if __BYTE_ORDER == __LITTLE_ENDIAN + rev64 v12.16b, v12.16b + rev64 v13.16b, v13.16b + rev64 v14.16b, v14.16b + rev64 v15.16b, v15.16b + rev64 v16.16b, v16.16b + rev64 v17.16b, v17.16b + rev64 v18.16b, v18.16b + rev64 v19.16b, v19.16b +#endif + mov x4, x3 // rc pointer + + mov v0.16b, v8.16b + mov v1.16b, v9.16b + mov v2.16b, v10.16b + mov v3.16b, v11.16b + + // v0 ab cd -- ef gh ab + // v1 cd -- ef gh ab cd + // v2 ef gh ab cd -- ef + // v3 gh ab cd -- ef gh + // v4 -- ef gh ab cd -- + + dround 0, 1, 2, 3, 4, 20, 24, 12, 13, 19, 16, 17 + dround 3, 0, 4, 2, 1, 21, 25, 13, 14, 12, 17, 18 + dround 2, 3, 1, 4, 0, 22, 26, 14, 15, 13, 18, 19 + dround 4, 2, 0, 1, 3, 23, 27, 15, 16, 14, 19, 12 + dround 1, 4, 3, 0, 2, 24, 28, 16, 17, 15, 12, 13 + + dround 0, 1, 2, 3, 4, 25, 29, 17, 18, 16, 13, 14 + dround 3, 0, 4, 2, 1, 26, 30, 18, 19, 17, 14, 15 + dround 2, 3, 1, 4, 0, 27, 31, 19, 12, 18, 15, 16 + dround 4, 2, 0, 1, 3, 28, 24, 12, 13, 19, 16, 17 + dround 1, 4, 3, 0, 2, 29, 25, 13, 14, 12, 17, 18 + + dround 0, 1, 2, 3, 4, 30, 26, 14, 15, 13, 18, 19 + dround 3, 0, 4, 2, 1, 31, 27, 15, 16, 14, 19, 12 + dround 2, 3, 1, 4, 0, 24, 28, 16, 17, 15, 12, 13 + dround 4, 2, 0, 1, 3, 25, 29, 17, 18, 16, 13, 14 + dround 1, 4, 3, 0, 2, 26, 30, 18, 19, 17, 14, 15 + + dround 0, 1, 2, 3, 4, 27, 31, 19, 12, 18, 15, 16 + dround 3, 0, 4, 2, 1, 28, 24, 12, 13, 19, 16, 17 + dround 2, 3, 1, 4, 0, 29, 25, 13, 14, 12, 17, 18 + dround 4, 2, 0, 1, 3, 30, 26, 14, 15, 13, 18, 19 + dround 1, 4, 3, 0, 2, 31, 27, 15, 16, 14, 19, 12 + + dround 0, 1, 2, 3, 4, 24, 28, 16, 17, 15, 12, 13 + dround 3, 0, 4, 2, 1, 25, 29, 17, 18, 16, 13, 14 + dround 2, 3, 1, 4, 0, 26, 30, 18, 19, 17, 14, 15 + dround 4, 2, 0, 1, 3, 27, 31, 19, 12, 18, 15, 16 + dround 1, 4, 3, 0, 2, 28, 24, 12, 13, 19, 16, 17 + + dround 0, 1, 2, 3, 4, 29, 25, 13, 14, 12, 17, 18 + dround 3, 0, 4, 2, 1, 30, 26, 14, 15, 13, 18, 19 + dround 2, 3, 1, 4, 0, 31, 27, 15, 16, 14, 19, 12 + dround 4, 2, 0, 1, 3, 24, 28, 16, 17, 15, 12, 13 + dround 1, 4, 3, 0, 2, 25, 29, 17, 18, 16, 13, 14 + + dround 0, 1, 2, 3, 4, 26, 30, 18, 19, 17, 14, 15 + dround 3, 0, 4, 2, 1, 27, 31, 19, 12, 18, 15, 16 + dround 2, 3, 1, 4, 0, 28, 24, 12 + dround 4, 2, 0, 1, 3, 29, 25, 13 + dround 1, 4, 3, 0, 2, 30, 26, 14 + + dround 0, 1, 2, 3, 4, 31, 27, 15 + dround 3, 0, 4, 2, 1, 24, , 16 + dround 2, 3, 1, 4, 0, 25, , 17 + dround 4, 2, 0, 1, 3, 26, , 18 + dround 1, 4, 3, 0, 2, 27, , 19 + + /* update state */ + add v8.2d, v8.2d, v0.2d + add v9.2d, v9.2d, v1.2d + add v10.2d, v10.2d, v2.2d + add v11.2d, v11.2d, v3.2d + + /* handled all input blocks? */ + cbnz w2, 0b + + /* store new state */ +3: st1 {v8.2d-v11.2d}, [x0] + mov w0, w2 + ret +ENDPROC(sha512_ce_transform) diff --git a/arch/arm/cpu/armv8/sha512_ce_glue.c b/arch/arm/cpu/armv8/sha512_ce_glue.c new file mode 100644 index 0000000000..4db78c8efd --- /dev/null +++ b/arch/arm/cpu/armv8/sha512_ce_glue.c @@ -0,0 +1,20 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * sha512_ce_glue.c - SHA-512 secure hash using ARMv8 Crypto Extensions + * + * Copyright (C) 2024 Igor Opaniuk igor.opaniuk@gmail.com + */ + +#include <u-boot/sha512.h> + +extern void sha512_ce_transform(u64 state[SHA512_SUM_LEN / 8], u8 const *src, + u32 blocks); + +void sha512_block_fn(sha512_context *ctx, const unsigned char *data, + unsigned int blocks) +{ + if (!blocks) + return; + + sha512_ce_transform(ctx->state, data, blocks); +} diff --git a/lib/sha512.c b/lib/sha512.c index ffe2c5cd96..186ca4d2ca 100644 --- a/lib/sha512.c +++ b/lib/sha512.c @@ -16,6 +16,8 @@ #include <compiler.h> #include <u-boot/sha512.h>
+#include <linux/compiler_attributes.h> + const uint8_t sha384_der_prefix[SHA384_DER_LEN] = { 0x30, 0x41, 0x30, 0x0d, 0x06, 0x09, 0x60, 0x86, 0x48, 0x01, 0x65, 0x03, 0x04, 0x02, 0x02, 0x05, @@ -187,8 +189,8 @@ sha512_transform(uint64_t *state, const uint8_t *input) a = b = c = d = e = f = g = h = t1 = t2 = 0; }
-static void sha512_block_fn(sha512_context *sst, const uint8_t *src, - int blocks) +__weak void sha512_block_fn(sha512_context *sst, const uint8_t *src, + int blocks) { while (blocks--) { sha512_transform(sst->state, src);
[Fixing Ard's email address for something more current.]
On Sat, 10 Feb 2024 12:07:09 +0000, Igor Opaniuk igor.opaniuk@foundries.io wrote:
But since you can actually probe it at runtime, what's the problem?
Unfortunately, QEMU is not a good oracle for optimisations, and is more akin to rolling a dice. In your case, you *should* see an improvement, but this should be evaluated on bare metal.
time: 0.215 seconds
time: 0.356 seconds
- bool "SHA-512 digest algorithm (ARMv8 Crypto Extensions)"
- depends on SHA512
- default n
endif
- sha512-ce-core.S - core SHA-384/SHA-512 transform using v8 Crypto
- Extensions
- Copyright (C) 2018 Linaro Ltd ard.biesheuvel@linaro.org
- Copyright (C) 2024 Igor Opaniuk igor.opaniuk@gmail.com
- #include <config.h>
- #include <linux/linkage.h>
- #include <asm/system.h>
- #include <asm/macro.h>
- .macro adr_l, dst, sym
- adrp \dst, \sym
- add \dst, \dst, :lo12:\sym
- .endm
- .irp b,0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19
- .set .Lq\b, \b
- .set .Lv\b().2d, \b
- .endr
- .macro sha512h, rd, rn, rm
- .inst 0xce608000 | .L\rd | (.L\rn << 5) | (.L\rm << 16)
- .endm
- .macro sha512h2, rd, rn, rm
- .inst 0xce608400 | .L\rd | (.L\rn << 5) | (.L\rm << 16)
- .endm
- .macro sha512su0, rd, rn
- .inst 0xcec08000 | .L\rd | (.L\rn << 5)
- .endm
- .macro sha512su1, rd, rn, rm
- .inst 0xce608800 | .L\rd | (.L\rn << 5) | (.L\rm << 16)
- .endm
- .section ".rodata", "a"
- .align 4
+.Lsha512_rcon:
- .quad 0x428a2f98d728ae22, 0x7137449123ef65cd
- .quad 0xb5c0fbcfec4d3b2f, 0xe9b5dba58189dbbc
- .quad 0x3956c25bf348b538, 0x59f111f1b605d019
- .quad 0x923f82a4af194f9b, 0xab1c5ed5da6d8118
- .quad 0xd807aa98a3030242, 0x12835b0145706fbe
- .quad 0x243185be4ee4b28c, 0x550c7dc3d5ffb4e2
- .quad 0x72be5d74f27b896f, 0x80deb1fe3b1696b1
- .quad 0x9bdc06a725c71235, 0xc19bf174cf692694
- .quad 0xe49b69c19ef14ad2, 0xefbe4786384f25e3
- .quad 0x0fc19dc68b8cd5b5, 0x240ca1cc77ac9c65
- .quad 0x2de92c6f592b0275, 0x4a7484aa6ea6e483
- .quad 0x5cb0a9dcbd41fbd4, 0x76f988da831153b5
- .quad 0x983e5152ee66dfab, 0xa831c66d2db43210
- .quad 0xb00327c898fb213f, 0xbf597fc7beef0ee4
- .quad 0xc6e00bf33da88fc2, 0xd5a79147930aa725
- .quad 0x06ca6351e003826f, 0x142929670a0e6e70
- .quad 0x27b70a8546d22ffc, 0x2e1b21385c26c926
- .quad 0x4d2c6dfc5ac42aed, 0x53380d139d95b3df
- .quad 0x650a73548baf63de, 0x766a0abb3c77b2a8
- .quad 0x81c2c92e47edaee6, 0x92722c851482353b
- .quad 0xa2bfe8a14cf10364, 0xa81a664bbc423001
- .quad 0xc24b8b70d0f89791, 0xc76c51a30654be30
- .quad 0xd192e819d6ef5218, 0xd69906245565a910
- .quad 0xf40e35855771202a, 0x106aa07032bbd1b8
- .quad 0x19a4c116b8d2d0c8, 0x1e376c085141ab53
- .quad 0x2748774cdf8eeb99, 0x34b0bcb5e19b48a8
- .quad 0x391c0cb3c5c95a63, 0x4ed8aa4ae3418acb
- .quad 0x5b9cca4f7763e373, 0x682e6ff3d6b2b8a3
- .quad 0x748f82ee5defb2fc, 0x78a5636f43172f60
- .quad 0x84c87814a1f0ab72, 0x8cc702081a6439ec
- .quad 0x90befffa23631e28, 0xa4506cebde82bde9
- .quad 0xbef9a3f7b2c67915, 0xc67178f2e372532b
- .quad 0xca273eceea26619c, 0xd186b8c721c0c207
- .quad 0xeada7dd6cde0eb1e, 0xf57d4f7fee6ed178
- .quad 0x06f067aa72176fba, 0x0a637dc5a2c898a6
- .quad 0x113f9804bef90dae, 0x1b710b35131c471b
- .quad 0x28db77f523047d84, 0x32caab7b40c72493
- .quad 0x3c9ebe0a15c9bebc, 0x431d67c49c100d4c
- .quad 0x4cc5d4becb3e42b6, 0x597f299cfc657e2a
- .quad 0x5fcb6fab3ad6faec, 0x6c44198c4a475817
- .macro dround, i0, i1, i2, i3, i4, rc0, rc1, in0, in1, in2, in3, in4
- .ifnb \rc1
- ld1 {v\rc1().2d}, [x4], #16
- .endif
- add v5.2d, v\rc0().2d, v\in0().2d
- ext v6.16b, v\i2().16b, v\i3().16b, #8
- ext v5.16b, v5.16b, v5.16b, #8
- ext v7.16b, v\i1().16b, v\i2().16b, #8
- add v\i3().2d, v\i3().2d, v5.2d
- .ifnb \in1
- ext v5.16b, v\in3().16b, v\in4().16b, #8
- sha512su0 v\in0().2d, v\in1().2d
- .endif
- sha512h q\i3, q6, v7.2d
- .ifnb \in1
- sha512su1 v\in0().2d, v\in2().2d, v5.2d
- .endif
- add v\i4().2d, v\i1().2d, v\i3().2d
- sha512h2 q\i3, q\i1, v\i0().2d
- .endm
* int blocks)
- .text
- /* load state */
- ld1 {v8.2d-v11.2d}, [x0]
- /* load first 4 round constants */
- adr_l x3, .Lsha512_rcon
- ld1 {v20.2d-v23.2d}, [x3], #64
- /* load input */
- ld1 {v16.2d-v19.2d}, [x1], #64
- sub w2, w2, #1
- mov x4, x3 // rc pointer
- mov v0.16b, v8.16b
- mov v1.16b, v9.16b
- mov v2.16b, v10.16b
- mov v3.16b, v11.16b
- // v0 ab cd -- ef gh ab
- // v1 cd -- ef gh ab cd
- // v2 ef gh ab cd -- ef
- // v3 gh ab cd -- ef gh
- // v4 -- ef gh ab cd --
- dround 0, 1, 2, 3, 4, 20, 24, 12, 13, 19, 16, 17
- dround 3, 0, 4, 2, 1, 21, 25, 13, 14, 12, 17, 18
- dround 2, 3, 1, 4, 0, 22, 26, 14, 15, 13, 18, 19
- dround 4, 2, 0, 1, 3, 23, 27, 15, 16, 14, 19, 12
- dround 1, 4, 3, 0, 2, 24, 28, 16, 17, 15, 12, 13
- dround 0, 1, 2, 3, 4, 25, 29, 17, 18, 16, 13, 14
- dround 3, 0, 4, 2, 1, 26, 30, 18, 19, 17, 14, 15
- dround 2, 3, 1, 4, 0, 27, 31, 19, 12, 18, 15, 16
- dround 4, 2, 0, 1, 3, 28, 24, 12, 13, 19, 16, 17
- dround 1, 4, 3, 0, 2, 29, 25, 13, 14, 12, 17, 18
- dround 0, 1, 2, 3, 4, 30, 26, 14, 15, 13, 18, 19
- dround 3, 0, 4, 2, 1, 31, 27, 15, 16, 14, 19, 12
- dround 2, 3, 1, 4, 0, 24, 28, 16, 17, 15, 12, 13
- dround 4, 2, 0, 1, 3, 25, 29, 17, 18, 16, 13, 14
- dround 1, 4, 3, 0, 2, 26, 30, 18, 19, 17, 14, 15
- dround 0, 1, 2, 3, 4, 27, 31, 19, 12, 18, 15, 16
- dround 3, 0, 4, 2, 1, 28, 24, 12, 13, 19, 16, 17
- dround 2, 3, 1, 4, 0, 29, 25, 13, 14, 12, 17, 18
- dround 4, 2, 0, 1, 3, 30, 26, 14, 15, 13, 18, 19
- dround 1, 4, 3, 0, 2, 31, 27, 15, 16, 14, 19, 12
- dround 0, 1, 2, 3, 4, 24, 28, 16, 17, 15, 12, 13
- dround 3, 0, 4, 2, 1, 25, 29, 17, 18, 16, 13, 14
- dround 2, 3, 1, 4, 0, 26, 30, 18, 19, 17, 14, 15
- dround 4, 2, 0, 1, 3, 27, 31, 19, 12, 18, 15, 16
- dround 1, 4, 3, 0, 2, 28, 24, 12, 13, 19, 16, 17
- dround 0, 1, 2, 3, 4, 29, 25, 13, 14, 12, 17, 18
- dround 3, 0, 4, 2, 1, 30, 26, 14, 15, 13, 18, 19
- dround 2, 3, 1, 4, 0, 31, 27, 15, 16, 14, 19, 12
- dround 4, 2, 0, 1, 3, 24, 28, 16, 17, 15, 12, 13
- dround 1, 4, 3, 0, 2, 25, 29, 17, 18, 16, 13, 14
- dround 0, 1, 2, 3, 4, 26, 30, 18, 19, 17, 14, 15
- dround 3, 0, 4, 2, 1, 27, 31, 19, 12, 18, 15, 16
- dround 2, 3, 1, 4, 0, 28, 24, 12
- dround 4, 2, 0, 1, 3, 29, 25, 13
- dround 1, 4, 3, 0, 2, 30, 26, 14
- dround 0, 1, 2, 3, 4, 31, 27, 15
- dround 3, 0, 4, 2, 1, 24, , 16
- dround 2, 3, 1, 4, 0, 25, , 17
- dround 4, 2, 0, 1, 3, 26, , 18
- dround 1, 4, 3, 0, 2, 27, , 19
- /* update state */
- add v8.2d, v8.2d, v0.2d
- add v9.2d, v9.2d, v1.2d
- add v10.2d, v10.2d, v2.2d
- add v11.2d, v11.2d, v3.2d
- /* handled all input blocks? */
- cbnz w2, 0b
- /* store new state */
- mov w0, w2
- ret
- sha512_ce_glue.c - SHA-512 secure hash using ARMv8 Crypto Extensions
u32 blocks);
- if (!blocks)
return;
- sha512_ce_transform(ctx->state, data, blocks);
int blocks)
int blocks)
I really think using a weak symbol for this is the wrong approach. You should instead allow the NEON version to be compiled in and called if ID_AA64ISAR0_EL1.SHA2 tells you that FEAT_SHA512 is supported.
It isn't like checking an ID register is going to majorly affect the timing of this, and the same u-boot build can boot on systems that have the extension or not. Remember that u-boot can be used in VMs, where the HW capabilities are variable.
Thanks,
M.
Hello Marc,
That actually was my initial plan, I just decided to move one step one step at a time and address that in the next patch series.
I fully agree with you here, but unfortunately it turned out that the only board with ARMv8.2-ready SoC (Cortex A55). I have now at hand doesn't support SHA512* instructions, but after all decided so send the patch to get rid of the feeling that it was all in vain :)
Maybe I added a bit of confusion to the commit message, as the initial idea was about functional validation (that it works in QEMU at least). I didn't want to make any comparison in a virtualized environment as it obviously didn't make any sense.
time: 0.215 seconds
time: 0.356 seconds
depends on SHA512
default n
endif
- Extensions
adrp \dst, \sym
.endm
.set .Lq\b, \b
.set .Lv\b\().2d, \b
.endr
.endm
.endm
.endm
.endm
.align 4
+.Lsha512_rcon:
.ifnb \rc1
ld1 {v\rc1\().2d}, [x4], #16
.endif
add v5.2d, v\rc0\().2d, v\in0\().2d
ext v6.16b, v\i2\().16b, v\i3\().16b, #8
ext v7.16b, v\i1\().16b, v\i2\().16b, #8
add v\i3\().2d, v\i3\().2d, v5.2d
.ifnb \in1
ext v5.16b, v\in3\().16b, v\in4\().16b, #8
sha512su0 v\in0\().2d, v\in1\().2d
.endif
.ifnb \in1
sha512su1 v\in0\().2d, v\in2\().2d, v5.2d
.endif
add v\i4\().2d, v\i1\().2d, v\i3\().2d
sha512h2 q\i3, q\i1, v\i0\().2d
.endm
* int blocks)
.text
/* load state */
/* load input */
sub w2, w2, #1
mov v0.16b, v8.16b
mov v1.16b, v9.16b
mov v2.16b, v10.16b
mov v3.16b, v11.16b
/* update state */
cbnz w2, 0b
mov w0, w2
ret
u32 blocks);
if (!blocks)
return;
int blocks)
int blocks)
I followed the same approach as Loic Poulain did already in his 084d8e6bf9ea("armv8 SHA-1 using ARMv8 Crypto Extensions:").
I plan to rework it in future and add dynamic selection of proper implementation based on capabilities reported in the ID register.
And adding the NEON version definitely makes sense, thanks! This is what I probably needed to start with.
Thanks,
M.
-- Without deviation from the norm, progress is not possible.
Thanks for your review/comments!
Regards, Igor
time: 0.215 seconds
time: 0.356 seconds
[snip]
- depends on SHA512
- default n
Like the sha256 one, this should be default y I think, the performance improvement is likely worth the size increase.
Hi Tom,
time: 0.215 seconds
time: 0.356 seconds
[snip]
depends on SHA512
default n
That was done on purpose, as SHA512* instructions (comparing to SHA256*) were introduced only in ARMv8.2-A, and most of the currently supported ARMv8 SoCs in U-Boot don't support it. We probably would end up with most of them reporting Synchronous Abort crashes.
As Marc suggested in the previous email, we should have both versions compiled-in (sw and hw-accelerated) and dynamic selection of proper version in runtime based on CPU capabilities, and I plan to address that in future in a separate patch series.
-- Tom
Regards, Igor
On 2/11/24 18:26, Igor Opaniuk wrote:
Hi Tom,
time: 0.215 seconds
time: 0.356 seconds
[snip]
depends on SHA512
default n
sounds good but then remove default n from Kconfig because that's default anyway.
M
Igor Opaniuk
Marc Zyngier
Michal Simek
