[U-Boot-Users] [PATCH] Nios-II Support (5 of 7)
-Add support for Altera Nios-II processors. -Add support for Psyent PCI-5441 board. -Add support for Psyent PK1C20 board.
Regards, --Scott
diff -Naurb u-boot-2004-08-24/include/configs/PCI5441.h u-boot-nios2/include/configs/PCI5441.h --- u-boot-2004-08-24/include/configs/PCI5441.h 1969-12-31 19:00:00.000000000 -0500 +++ u-boot-nios2/include/configs/PCI5441.h 2004-08-24 05:54:30.000000000 -0400 @@ -0,0 +1,155 @@ +/* + * (C) Copyright 2004, Psyent Corporation <www.psyent.com> + * Scott McNutt smcnutt@psyent.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/*------------------------------------------------------------------------ + * BOARD/CPU + *----------------------------------------------------------------------*/ +#define CONFIG_PCI5441 1 /* PCI-5441 board */ +#define CONFIG_SYS_CLK_FREQ 50000000 /* 50 MHz core clk */ + +#define CFG_RESET_ADDR 0x00000000 /* Hard-reset address */ +#define CFG_EXCEPTION_ADDR 0x01000020 /* Exception entry point*/ +#define CFG_NIOS_SYSID_BASE 0x00920828 /* System id address */ +#define CONFIG_BOARD_EARLY_INIT_F 1 /* enable early board-spec. init*/ + +/*------------------------------------------------------------------------ + * CACHE -- the following will support II/s and II/f. The II/s does not + * have dcache, so the cache instructions will behave as NOPs. + *----------------------------------------------------------------------*/ +#define CFG_ICACHE_SIZE 4096 /* 4 KByte total */ +#define CFG_ICACHELINE_SIZE 32 /* 32 bytes/line */ +#define CFG_DCACHE_SIZE 2048 /* 2 KByte (II/f) */ +#define CFG_DCACHELINE_SIZE 4 /* 4 bytes/line (II/f) */ + +/*------------------------------------------------------------------------ + * MEMORY BASE ADDRESSES + *----------------------------------------------------------------------*/ +#define CFG_FLASH_BASE 0x00000000 /* FLASH base addr */ +#define CFG_FLASH_SIZE 0x00800000 /* 8 MByte */ +#define CFG_SDRAM_BASE 0x01000000 /* SDRAM base addr */ +#define CFG_SDRAM_SIZE 0x01000000 /* 16 MByte */ + +/*------------------------------------------------------------------------ + * MEMORY ORGANIZATION + * -Monitor at top. + * -The heap is placed below the monitor. + * -Global data is placed below the heap. + * -The stack is placed below global data (&grows down). + *----------------------------------------------------------------------*/ +#define CFG_MONITOR_LEN (128 * 1024) /* Reserve 128k */ +#define CFG_GBL_DATA_SIZE 128 /* Global data size rsvd*/ +#define CFG_MALLOC_LEN (CFG_ENV_SIZE + 128*1024) + +#define CFG_MONITOR_BASE TEXT_BASE +#define CFG_MALLOC_BASE (CFG_MONITOR_BASE - CFG_MALLOC_LEN) +#define CFG_GBL_DATA_OFFSET (CFG_MALLOC_BASE - CFG_GBL_DATA_SIZE) +#define CFG_INIT_SP CFG_GBL_DATA_OFFSET + +/*------------------------------------------------------------------------ + * FLASH (AM29LV065D) + *----------------------------------------------------------------------*/ +#define CFG_MAX_FLASH_SECT 128 /* Max # sects per bank */ +#define CFG_MAX_FLASH_BANKS 1 /* Max # of flash banks */ +#define CFG_FLASH_ERASE_TOUT 8000 /* Erase timeout (msec) */ +#define CFG_FLASH_WRITE_TOUT 100 /* Write timeout (msec) */ +#define CFG_FLASH_WORD_SIZE unsigned char /* flash word size */ + +/*------------------------------------------------------------------------ + * ENVIRONMENT -- Put environment in sector CFG_MONITOR_LEN above + * CFG_RESET_ADDR, since we assume the monitor is stored at the + * reset address, no? This will keep the environment in user region + * of flash. NOTE: the monitor length must be multiple of sector size + * (which is common practice). + *----------------------------------------------------------------------*/ +#define CFG_ENV_IS_IN_FLASH 1 /* Environment in flash */ +#define CFG_ENV_SIZE (64 * 1024) /* 64 KByte (1 sector) */ +#define CONFIG_ENV_OVERWRITE /* Serial change Ok */ +#define CFG_ENV_ADDR (CFG_RESET_ADDR + CFG_MONITOR_LEN) + +/*------------------------------------------------------------------------ + * CONSOLE + *----------------------------------------------------------------------*/ +#if defined(CONFIG_CONSOLE_JTAG) +#define CFG_NIOS_CONSOLE 0x00920820 /* JTAG UART base addr */ +#else +#define CFG_NIOS_CONSOLE 0x009208a0 /* UART base addr */ +#endif + +#define CFG_NIOS_FIXEDBAUD 1 /* Baudrate is fixed */ +#define CONFIG_BAUDRATE 115200 /* Initial baudrate */ +#define CFG_BAUDRATE_TABLE {115200} /* It's fixed ;-) */ + +#define CFG_CONSOLE_INFO_QUIET 1 /* Suppress console info*/ + +/*------------------------------------------------------------------------ + * DEBUG + *----------------------------------------------------------------------*/ +#undef CONFIG_ROM_STUBS /* Stubs not in ROM */ + +/*------------------------------------------------------------------------ + * TIMEBASE -- + * + * The high res timer defaults to 1 msec. Since it includes the period + * registers, we can slow it down to 10 msec using TMRCNT. If the default + * period is acceptable, TMRCNT can be left undefined. + *----------------------------------------------------------------------*/ +#define CFG_NIOS_TMRBASE 0x00920860 /* Tick timer base addr */ +#define CFG_NIOS_TMRIRQ 3 /* Timer IRQ num */ +#define CFG_NIOS_TMRMS 10 /* 10 msec per tick */ +#define CFG_NIOS_TMRCNT (CFG_NIOS_TMRMS * (CONFIG_SYS_CLK_FREQ/1000)) +#define CFG_HZ (CONFIG_SYS_CLK_FREQ/(CFG_NIOS_TMRCNT + 1)) + +/*------------------------------------------------------------------------ + * COMMANDS + *----------------------------------------------------------------------*/ +#define CONFIG_COMMANDS (CFG_CMD_BDI | \ + CFG_CMD_ECHO | \ + CFG_CMD_ENV | \ + CFG_CMD_FLASH | \ + CFG_CMD_IMI | \ + CFG_CMD_IRQ | \ + CFG_CMD_LOADS | \ + CFG_CMD_LOADB | \ + CFG_CMD_MEMORY | \ + CFG_CMD_MISC | \ + CFG_CMD_RUN | \ + CFG_CMD_SAVES ) +#include <cmd_confdefs.h> + +/*------------------------------------------------------------------------ + * MISC + *----------------------------------------------------------------------*/ +#define CFG_LONGHELP /* Provide extended help*/ +#define CFG_PROMPT "==> " /* Command prompt */ +#define CFG_CBSIZE 256 /* Console I/O buf size */ +#define CFG_MAXARGS 16 /* Max command args */ +#define CFG_BARGSIZE CFG_CBSIZE /* Boot arg buf size */ +#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print buf size */ +#define CFG_LOAD_ADDR CFG_SDRAM_BASE /* Default load address */ +#define CFG_MEMTEST_START CFG_SDRAM_BASE /* Start addr for test */ +#define CFG_MEMTEST_END CFG_INIT_SP - 0x00020000 + +#endif /* __CONFIG_H */ diff -Naurb u-boot-2004-08-24/include/configs/PK1C20.h u-boot-nios2/include/configs/PK1C20.h --- u-boot-2004-08-24/include/configs/PK1C20.h 1969-12-31 19:00:00.000000000 -0500 +++ u-boot-nios2/include/configs/PK1C20.h 2004-08-24 05:54:10.000000000 -0400 @@ -0,0 +1,188 @@ +/* + * (C) Copyright 2004, Psyent Corporation <www.psyent.com> + * Scott McNutt smcnutt@psyent.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/*------------------------------------------------------------------------ + * BOARD/CPU + *----------------------------------------------------------------------*/ +#define CONFIG_PK1C20 1 /* PK1C20 board */ +#define CONFIG_SYS_CLK_FREQ 50000000 /* 50 MHz core clk */ + +#define CFG_RESET_ADDR 0x00000000 /* Hard-reset address */ +#define CFG_EXCEPTION_ADDR 0x01000020 /* Exception entry point*/ +#define CFG_NIOS_SYSID_BASE 0x00920828 /* System id address */ +#define CONFIG_BOARD_EARLY_INIT_F 1 /* enable early board-spec. init*/ + +/*------------------------------------------------------------------------ + * CACHE -- the following will support II/s and II/f. The II/s does not + * have dcache, so the cache instructions will behave as NOPs. + *----------------------------------------------------------------------*/ +#define CFG_ICACHE_SIZE 4096 /* 4 KByte total */ +#define CFG_ICACHELINE_SIZE 32 /* 32 bytes/line */ +#define CFG_DCACHE_SIZE 2048 /* 2 KByte (II/f) */ +#define CFG_DCACHELINE_SIZE 4 /* 4 bytes/line (II/f) */ + +/*------------------------------------------------------------------------ + * MEMORY BASE ADDRESSES + *----------------------------------------------------------------------*/ +#define CFG_FLASH_BASE 0x00000000 /* FLASH base addr */ +#define CFG_FLASH_SIZE 0x00800000 /* 8 MByte */ +#define CFG_SDRAM_BASE 0x01000000 /* SDRAM base addr */ +#define CFG_SDRAM_SIZE 0x01000000 /* 16 MByte */ +#define CFG_SRAM_BASE 0x00800000 /* SRAM base addr */ +#define CFG_SRAM_SIZE 0x00200000 /* 2 MByte */ + +/*------------------------------------------------------------------------ + * MEMORY ORGANIZATION + * -Monitor at top. + * -The heap is placed below the monitor. + * -Global data is placed below the heap. + * -The stack is placed below global data (&grows down). + *----------------------------------------------------------------------*/ +#define CFG_MONITOR_LEN (128 * 1024) /* Reserve 128k */ +#define CFG_GBL_DATA_SIZE 128 /* Global data size rsvd*/ +#define CFG_MALLOC_LEN (CFG_ENV_SIZE + 128*1024) + +#define CFG_MONITOR_BASE TEXT_BASE +#define CFG_MALLOC_BASE (CFG_MONITOR_BASE - CFG_MALLOC_LEN) +#define CFG_GBL_DATA_OFFSET (CFG_MALLOC_BASE - CFG_GBL_DATA_SIZE) +#define CFG_INIT_SP CFG_GBL_DATA_OFFSET + +/*------------------------------------------------------------------------ + * FLASH (AM29LV065D) + *----------------------------------------------------------------------*/ +#define CFG_MAX_FLASH_SECT 128 /* Max # sects per bank */ +#define CFG_MAX_FLASH_BANKS 1 /* Max # of flash banks */ +#define CFG_FLASH_ERASE_TOUT 8000 /* Erase timeout (msec) */ +#define CFG_FLASH_WRITE_TOUT 100 /* Write timeout (msec) */ +#define CFG_FLASH_WORD_SIZE unsigned char /* flash word size */ + +/*------------------------------------------------------------------------ + * ENVIRONMENT -- Put environment in sector CFG_MONITOR_LEN above + * CFG_RESET_ADDR, since we assume the monitor is stored at the + * reset address, no? This will keep the environment in user region + * of flash. NOTE: the monitor length must be multiple of sector size + * (which is common practice). + *----------------------------------------------------------------------*/ +#define CFG_ENV_IS_IN_FLASH 1 /* Environment in flash */ +#define CFG_ENV_SIZE (64 * 1024) /* 64 KByte (1 sector) */ +#define CONFIG_ENV_OVERWRITE /* Serial change Ok */ +#define CFG_ENV_ADDR (CFG_RESET_ADDR + CFG_MONITOR_LEN) + +/*------------------------------------------------------------------------ + * CONSOLE + *----------------------------------------------------------------------*/ +#if defined(CONFIG_CONSOLE_JTAG) +#define CFG_NIOS_CONSOLE 0x00920820 /* JTAG UART base addr */ +#else +#define CFG_NIOS_CONSOLE 0x009208a0 /* UART base addr */ +#endif + +#define CFG_NIOS_FIXEDBAUD 1 /* Baudrate is fixed */ +#define CONFIG_BAUDRATE 115200 /* Initial baudrate */ +#define CFG_BAUDRATE_TABLE {115200} /* It's fixed ;-) */ + +#define CFG_CONSOLE_INFO_QUIET 1 /* Suppress console info*/ + +/*------------------------------------------------------------------------ + * DEBUG + *----------------------------------------------------------------------*/ +#undef CONFIG_ROM_STUBS /* Stubs not in ROM */ + +/*------------------------------------------------------------------------ + * TIMEBASE -- + * + * The high res timer defaults to 1 msec. Since it includes the period + * registers, we can slow it down to 10 msec using TMRCNT. If the default + * period is acceptable, TMRCNT can be left undefined. + *----------------------------------------------------------------------*/ +#define CFG_NIOS_TMRBASE 0x00920860 /* Tick timer base addr */ +#define CFG_NIOS_TMRIRQ 3 /* Timer IRQ num */ +#define CFG_NIOS_TMRMS 10 /* 10 msec per tick */ +#define CFG_NIOS_TMRCNT (CFG_NIOS_TMRMS * (CONFIG_SYS_CLK_FREQ/1000)) +#define CFG_HZ (CONFIG_SYS_CLK_FREQ/(CFG_NIOS_TMRCNT + 1)) + +/*------------------------------------------------------------------------ + * STATUS LED -- Provides a simple blinking led. For Nios2 each board + * must implement its own led routines -- leds are, after all, + * board-specific, no? + *----------------------------------------------------------------------*/ +#define CFG_LEDPIO_ADDR 0x00920840 /* LED PIO base addr */ +#define CONFIG_STATUS_LED /* Enable status driver */ + +#define STATUS_LED_BIT 1 /* Bit-0 on PIO */ +#define STATUS_LED_STATE 1 /* Blinking */ +#define STATUS_LED_PERIOD (500/CFG_NIOS_TMRMS) /* Every 500 msec */ + +/*------------------------------------------------------------------------ + * ETHERNET -- The header file for the SMC91111 driver hurts my eyes ... + * and really doesn't need any additional clutter. So I choose the lazy + * way out to avoid changes there -- define the base address to ensure + * cache bypass so there's no need to monkey with inx/outx macros. + *----------------------------------------------------------------------*/ +#define CONFIG_SMC91111_BASE 0x80910300 /* Base addr (bypass) */ +#define CONFIG_DRIVER_SMC91111 /* Using SMC91c111 */ +#undef CONFIG_SMC91111_EXT_PHY /* Internal PHY */ +#define CONFIG_SMC_USE_32_BIT /* 32-bit interface */ + +#define CONFIG_ETHADDR 08:00:3e:26:0a:5b +#define CONFIG_NETMASK 255.255.255.0 +#define CONFIG_IPADDR 192.168.2.21 +#define CONFIG_SERVERIP 192.168.2.16 + +/*------------------------------------------------------------------------ + * COMMANDS + *----------------------------------------------------------------------*/ +#define CONFIG_COMMANDS (CFG_CMD_BDI | \ + CFG_CMD_DHCP | \ + CFG_CMD_ECHO | \ + CFG_CMD_ENV | \ + CFG_CMD_FLASH | \ + CFG_CMD_IMI | \ + CFG_CMD_IRQ | \ + CFG_CMD_LOADS | \ + CFG_CMD_LOADB | \ + CFG_CMD_MEMORY | \ + CFG_CMD_MISC | \ + CFG_CMD_NET | \ + CFG_CMD_PING | \ + CFG_CMD_RUN | \ + CFG_CMD_SAVES ) +#include <cmd_confdefs.h> + +/*------------------------------------------------------------------------ + * MISC + *----------------------------------------------------------------------*/ +#define CFG_LONGHELP /* Provide extended help*/ +#define CFG_PROMPT "==> " /* Command prompt */ +#define CFG_CBSIZE 256 /* Console I/O buf size */ +#define CFG_MAXARGS 16 /* Max command args */ +#define CFG_BARGSIZE CFG_CBSIZE /* Boot arg buf size */ +#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print buf size */ +#define CFG_LOAD_ADDR CFG_SDRAM_BASE /* Default load address */ +#define CFG_MEMTEST_START CFG_SDRAM_BASE /* Start addr for test */ +#define CFG_MEMTEST_END CFG_INIT_SP - 0x00020000 + +#endif /* __CONFIG_H */ diff -Naurb u-boot-2004-08-24/include/image.h u-boot-nios2/include/image.h --- u-boot-2004-08-24/include/image.h 2004-04-18 17:13:45.000000000 -0400 +++ u-boot-nios2/include/image.h 2004-08-24 07:16:51.000000000 -0400 @@ -67,6 +67,7 @@ #define IH_CPU_M68K 12 /* M68K */ #define IH_CPU_NIOS 13 /* Nios-32 */ #define IH_CPU_MICROBLAZE 14 /* MicroBlaze */ +#define IH_CPU_NIOS2 15 /* Nios-II */
/* * Image Types diff -Naurb u-boot-2004-08-24/include/nios2.h u-boot-nios2/include/nios2.h --- u-boot-2004-08-24/include/nios2.h 1969-12-31 19:00:00.000000000 -0500 +++ u-boot-nios2/include/nios2.h 2004-08-24 05:49:58.000000000 -0400 @@ -0,0 +1,63 @@ +/* + * (C) Copyright 2004, Psyent Corporation <www.psyent.com> + * Scott McNutt smcnutt@psyent.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __NIOS2_H__ +#define __NIOS2_H__ + +/*------------------------------------------------------------------------ + * Control registers -- use with wrctl() & rdctl() + *----------------------------------------------------------------------*/ +#define CTL_STATUS 0 /* Processor status reg */ +#define CTL_ESTATUS 1 /* Exception status reg */ +#define CTL_BSTATUS 2 /* Break status reg */ +#define CTL_IENABLE 3 /* Interrut enable reg */ +#define CTL_IPENDING 4 /* Interrut pending reg */ + +/*------------------------------------------------------------------------ + * Access to control regs + *----------------------------------------------------------------------*/ +#define _str_(x) #x + +#define rdctl(reg)\ + ({unsigned int val;\ + asm volatile( "rdctl %0, ctl" _str_(reg)\ + : "=r" (val) ); val;}) + +#define wrctl(reg,val)\ + asm volatile( "wrctl ctl" _str_(reg) ",%0"\ + : : "r" (val)) + +/*------------------------------------------------------------------------ + * Control reg bit masks + *----------------------------------------------------------------------*/ +#define STATUS_IE (1<<0) /* Interrupt enable */ +#define STATUS_U (1<<1) /* User-mode */ + +/*------------------------------------------------------------------------ + * Bit-31 Cache bypass -- only valid for data access. When data cache + * is not implemented, bit 31 is ignored for compatibility. + *----------------------------------------------------------------------*/ +#define CACHE_BYPASS(a) ((a) | 0x80000000) +#define CACHE_NO_BYPASS(a) ((a) & ~0x80000000) + +#endif /* __NIOS2_H__ */ diff -Naurb u-boot-2004-08-24/include/nios2-io.h u-boot-nios2/include/nios2-io.h --- u-boot-2004-08-24/include/nios2-io.h 1969-12-31 19:00:00.000000000 -0500 +++ u-boot-nios2/include/nios2-io.h 2004-08-24 05:49:58.000000000 -0400 @@ -0,0 +1,200 @@ +/* + * (C) Copyright 2004, Psyent Corporation <www.psyent.com> + * Scott McNutt smcnutt@psyent.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/************************************************************************* + * Altera Nios2 Standard Peripherals + ************************************************************************/ + +#ifndef __NIOS2IO_H__ +#define __NIOS2IO_H__ + +/*------------------------------------------------------------------------ + * UART (http://www.altera.com/literature/ds/ds_nios_uart.pdf) + *----------------------------------------------------------------------*/ +typedef volatile struct nios_uart_t { + unsigned rxdata; /* Rx data reg */ + unsigned txdata; /* Tx data reg */ + unsigned status; /* Status reg */ + unsigned control; /* Control reg */ + unsigned divisor; /* Baud rate divisor reg */ + unsigned endofpacket; /* End-of-packet reg */ +}nios_uart_t; + +/* status register */ +#define NIOS_UART_PE (1 << 0) /* parity error */ +#define NIOS_UART_FE (1 << 1) /* frame error */ +#define NIOS_UART_BRK (1 << 2) /* break detect */ +#define NIOS_UART_ROE (1 << 3) /* rx overrun */ +#define NIOS_UART_TOE (1 << 4) /* tx overrun */ +#define NIOS_UART_TMT (1 << 5) /* tx empty */ +#define NIOS_UART_TRDY (1 << 6) /* tx ready */ +#define NIOS_UART_RRDY (1 << 7) /* rx ready */ +#define NIOS_UART_E (1 << 8) /* exception */ +#define NIOS_UART_DCTS (1 << 10) /* cts change */ +#define NIOS_UART_CTS (1 << 11) /* cts */ +#define NIOS_UART_EOP (1 << 12) /* eop detected */ + +/* control register */ +#define NIOS_UART_IPE (1 << 0) /* parity error int ena*/ +#define NIOS_UART_IFE (1 << 1) /* frame error int ena */ +#define NIOS_UART_IBRK (1 << 2) /* break detect int ena */ +#define NIOS_UART_IROE (1 << 3) /* rx overrun int ena */ +#define NIOS_UART_ITOE (1 << 4) /* tx overrun int ena */ +#define NIOS_UART_ITMT (1 << 5) /* tx empty int ena */ +#define NIOS_UART_ITRDY (1 << 6) /* tx ready int ena */ +#define NIOS_UART_IRRDY (1 << 7) /* rx ready int ena */ +#define NIOS_UART_IE (1 << 8) /* exception int ena */ +#define NIOS_UART_TBRK (1 << 9) /* transmit break */ +#define NIOS_UART_IDCTS (1 << 10) /* cts change int ena */ +#define NIOS_UART_RTS (1 << 11) /* rts */ +#define NIOS_UART_IEOP (1 << 12) /* eop detected int ena */ + + +/*------------------------------------------------------------------------ + * TIMER (http://www.altera.com/literature/ds/ds_nios_timer.pdf) + *----------------------------------------------------------------------*/ +typedef volatile struct nios_timer_t { + unsigned status; /* Timer status reg */ + unsigned control; /* Timer control reg */ + unsigned periodl; /* Timeout period low */ + unsigned periodh; /* Timeout period high */ + unsigned snapl; /* Snapshot low */ + unsigned snaph; /* Snapshot high */ +}nios_timer_t; + +/* status register */ +#define NIOS_TIMER_TO (1 << 0) /* Timeout */ +#define NIOS_TIMER_RUN (1 << 1) /* Timer running */ + +/* control register */ +#define NIOS_TIMER_ITO (1 << 0) /* Timeout int ena */ +#define NIOS_TIMER_CONT (1 << 1) /* Continuous mode */ +#define NIOS_TIMER_START (1 << 2) /* Start timer */ +#define NIOS_TIMER_STOP (1 << 3) /* Stop timer */ + + +/*------------------------------------------------------------------------ + * PIO (http://www.altera.com/literature/ds/ds_nios_pio.pdf) + *----------------------------------------------------------------------*/ +typedef volatile struct nios_pio_t { + unsigned int data; /* Data value at each PIO in/out */ + unsigned int direction; /* Data direct. for each PIO bit */ + unsigned int interruptmask; /* Per-bit IRQ enable/disable */ + unsigned int edgecapture; /* Per-bit sync. edge detect & hold */ +}nios_pio_t; + +/* direction register */ +#define NIOS_PIO_OUT (1) /* PIO bit is output */ +#define NIOS_PIO_IN (0) /* PIO bit is input */ + + +/*------------------------------------------------------------------------ + * SPI (http://www.altera.com/literature/ds/ds_nios_spi.pdf) + *----------------------------------------------------------------------*/ +typedef volatile struct nios_spi_t { + unsigned rxdata; /* Rx data reg */ + unsigned txdata; /* Tx data reg */ + unsigned status; /* Status reg */ + unsigned control; /* Control reg */ + unsigned reserved; /* (master only) */ + unsigned slaveselect; /* SPI slave select mask (master only) */ +}nios_spi_t; + +/* status register */ +#define NIOS_SPI_ROE (1 << 3) /* rx overrun */ +#define NIOS_SPI_TOE (1 << 4) /* tx overrun */ +#define NIOS_SPI_TMT (1 << 5) /* tx empty */ +#define NIOS_SPI_TRDY (1 << 6) /* tx ready */ +#define NIOS_SPI_RRDY (1 << 7) /* rx ready */ +#define NIOS_SPI_E (1 << 8) /* exception */ + +/* control register */ +#define NIOS_SPI_IROE (1 << 3) /* rx overrun int ena */ +#define NIOS_SPI_ITOE (1 << 4) /* tx overrun int ena */ +#define NIOS_SPI_ITRDY (1 << 6) /* tx ready int ena */ +#define NIOS_SPI_IRRDY (1 << 7) /* rx ready int ena */ +#define NIOS_SPI_IE (1 << 8) /* exception int ena */ +#define NIOS_SPI_SSO (1 << 10) /* override SS_n output */ + +/*------------------------------------------------------------------------ + * ASMI + *----------------------------------------------------------------------*/ +typedef volatile struct nios_asmi_t { + unsigned rxdata; /* Rx data reg */ + unsigned txdata; /* Tx data reg */ + unsigned status; /* Status reg */ + unsigned control; /* Control reg */ + unsigned reserved; + unsigned slavesel; /* Slave select */ + unsigned endofpacket; /* End-of-packet reg */ +}nios_asmi_t; + +/* status register */ +#define NIOS_ASMI_ROE (1 << 3) /* rx overrun */ +#define NIOS_ASMI_TOE (1 << 4) /* tx overrun */ +#define NIOS_ASMI_TMT (1 << 5) /* tx empty */ +#define NIOS_ASMI_TRDY (1 << 6) /* tx ready */ +#define NIOS_ASMI_RRDY (1 << 7) /* rx ready */ +#define NIOS_ASMI_E (1 << 8) /* exception */ +#define NIOS_ASMI_EOP (1 << 9) /* eop detected */ + +/* control register */ +#define NIOS_ASMI_IROE (1 << 3) /* rx overrun int ena */ +#define NIOS_ASMI_ITOE (1 << 4) /* tx overrun int ena */ +#define NIOS_ASMI_ITRDY (1 << 6) /* tx ready int ena */ +#define NIOS_ASMI_IRRDY (1 << 7) /* rx ready int ena */ +#define NIOS_ASMI_IE (1 << 8) /* exception int ena */ +#define NIOS_ASMI_IEOP (1 << 9) /* rx eop int ena */ +#define NIOS_ASMI_SSO (1 << 10) /* slave select enable */ + +/*------------------------------------------------------------------------ + * JTAG UART + *----------------------------------------------------------------------*/ +typedef volatile struct nios_jtag_t { + unsigned data; /* Data register */ + unsigned control; /* Control register */ +}nios_jtag_t; + +/* data register */ +#define NIOS_JTAG_RVALID (1<<15) /* Read valid */ +#define NIOS_JTAG_DATA(d) ((d)&0x0ff) /* Read data */ +#define NIOS_JTAG_RAVAIL(d) ((d)>>16) /* Read space avail */ + +/* control register */ +#define NIOS_JTAG_RE (1 << 0) /* read intr enable */ +#define NIOS_JTAG_WE (1 << 1) /* write intr enable */ +#define NIOS_JTAG_RI (1 << 8) /* read intr pending */ +#define NIOS_JTAG_WI (1 << 9) /* write intr pending*/ +#define NIOS_JTAG_AC (1 << 10) /* activity indicator */ +#define NIOS_JTAG_RRDY (1 << 12) /* read available */ +#define NIOS_JTAG_WSPACE(d) ((d)>>16) /* Write space avail */ + +/*------------------------------------------------------------------------ + * SYSTEM ID + *----------------------------------------------------------------------*/ +typedef volatile struct nios_sysid_t { + unsigned id; /* The system build id*/ + unsigned timestamp; /* Timestamp */ +}nios_sysid_t; + +#endif /* __NIOS2IO_H__ */ diff -Naurb u-boot-2004-08-24/include/status_led.h u-boot-nios2/include/status_led.h --- u-boot-2004-08-24/include/status_led.h 2004-07-10 18:36:00.000000000 -0400 +++ u-boot-nios2/include/status_led.h 2004-08-24 07:18:07.000000000 -0400 @@ -340,6 +340,9 @@ #elif defined(CONFIG_WRSBC8240) /* XXX empty just to avoid the error */ /************************************************************************/ +#elif defined(CONFIG_NIOS2) +/* XXX empty just to avoid the error */ +/************************************************************************/ #else # error Status LED configuration missing #endif
Added, thanks.
Scott McNutt
