Re: [PATCH 03/11] net: dwc_eth_qos: Fold board_interface_eth_init into STM32 glue code
On 3/9/24 03:11, Marek Vasut wrote:
Move board_interface_eth_init() into eqos_probe_syscfg_stm32() in STM32 driver glue code. The eqos_probe_syscfg_stm32() parses STM32 specific DT properties of this MAC and configures SYSCFG registers accordingly, there is nothing board specific happening in this function, move it into generic driver code instead. Drop the now unused duplicates from board files.
Signed-off-by: Marek Vasut marex@denx.de
Cc: Christophe Roullier christophe.roullier@st.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Patrice Chotard patrice.chotard@foss.st.com Cc: Patrick Delaunay patrick.delaunay@foss.st.com Cc: Ramon Fried rfried.dev@gmail.com Cc: u-boot@dh-electronics.com Cc: uboot-stm32@st-md-mailman.stormreply.com
board/dhelectronics/dh_stm32mp1/board.c | 82 ----------------------- board/st/stm32mp1/stm32mp1.c | 82 ----------------------- drivers/net/dwc_eth_qos_stm32.c | 86 ++++++++++++++++++++++++- 3 files changed, 84 insertions(+), 166 deletions(-)
diff --git a/board/dhelectronics/dh_stm32mp1/board.c b/board/dhelectronics/dh_stm32mp1/board.c index d1f662d9701..f179c857116 100644 --- a/board/dhelectronics/dh_stm32mp1/board.c +++ b/board/dhelectronics/dh_stm32mp1/board.c @@ -48,12 +48,10 @@
/* SYSCFG registers */ #define SYSCFG_BOOTR 0x00 -#define SYSCFG_PMCSETR 0x04 #define SYSCFG_IOCTRLSETR 0x18 #define SYSCFG_ICNR 0x1C #define SYSCFG_CMPCR 0x20 #define SYSCFG_CMPENSETR 0x24 -#define SYSCFG_PMCCLRR 0x44
#define SYSCFG_BOOTR_BOOT_MASK GENMASK(2, 0) #define SYSCFG_BOOTR_BOOTPD_SHIFT 4 @@ -69,16 +67,6 @@
#define SYSCFG_CMPENSETR_MPU_EN BIT(0)
-#define SYSCFG_PMCSETR_ETH_CLK_SEL BIT(16) -#define SYSCFG_PMCSETR_ETH_REF_CLK_SEL BIT(17)
-#define SYSCFG_PMCSETR_ETH_SELMII BIT(20)
-#define SYSCFG_PMCSETR_ETH_SEL_MASK GENMASK(23, 21) -#define SYSCFG_PMCSETR_ETH_SEL_GMII_MII 0 -#define SYSCFG_PMCSETR_ETH_SEL_RGMII BIT(21) -#define SYSCFG_PMCSETR_ETH_SEL_RMII BIT(23)
- #define KS_CCR 0x08 #define KS_CCR_EEPROM BIT(9) #define KS_BE0 BIT(12)
@@ -679,76 +667,6 @@ void board_quiesce_devices(void) #endif }
-/* eth init function : weak called in eqos driver */ -int board_interface_eth_init(struct udevice *dev,
phy_interface_t interface_type)
u8 *syscfg;
u32 value;
bool eth_clk_sel_reg = false;
bool eth_ref_clk_sel_reg = false;
/* Gigabit Ethernet 125MHz clock selection. */
eth_clk_sel_reg = dev_read_bool(dev, "st,eth-clk-sel");
/* Ethernet 50Mhz RMII clock selection */
dev_read_bool(dev, "st,eth-ref-clk-sel");
syscfg = (u8 *)syscon_get_first_range(STM32MP_SYSCON_SYSCFG);
if (!syscfg)
return -ENODEV;
switch (interface_type) {
case PHY_INTERFACE_MODE_MII:
value = SYSCFG_PMCSETR_ETH_SEL_GMII_MII |
SYSCFG_PMCSETR_ETH_REF_CLK_SEL;
debug("%s: PHY_INTERFACE_MODE_MII\n", __func__);
break;
case PHY_INTERFACE_MODE_GMII:
if (eth_clk_sel_reg)
SYSCFG_PMCSETR_ETH_CLK_SEL;
else
value = SYSCFG_PMCSETR_ETH_SEL_GMII_MII;
debug("%s: PHY_INTERFACE_MODE_GMII\n", __func__);
break;
case PHY_INTERFACE_MODE_RMII:
if (eth_ref_clk_sel_reg)
value = SYSCFG_PMCSETR_ETH_SEL_RMII |
else
value = SYSCFG_PMCSETR_ETH_SEL_RMII;
debug("%s: PHY_INTERFACE_MODE_RMII\n", __func__);
break;
case PHY_INTERFACE_MODE_RGMII:
case PHY_INTERFACE_MODE_RGMII_ID:
case PHY_INTERFACE_MODE_RGMII_RXID:
case PHY_INTERFACE_MODE_RGMII_TXID:
value = SYSCFG_PMCSETR_ETH_SEL_RGMII |
else
value = SYSCFG_PMCSETR_ETH_SEL_RGMII;
debug("%s: PHY_INTERFACE_MODE_RGMII\n", __func__);
break;
default:
debug("%s: Do not manage %d interface\n",
__func__, interface_type);
/* Do not manage others interfaces */
return -EINVAL;
/* clear and set ETH configuration bits */
writel(SYSCFG_PMCSETR_ETH_SEL_MASK | SYSCFG_PMCSETR_ETH_SELMII |
SYSCFG_PMCSETR_ETH_REF_CLK_SEL | SYSCFG_PMCSETR_ETH_CLK_SEL,
syscfg + SYSCFG_PMCCLRR);
writel(value, syscfg + SYSCFG_PMCSETR);
- #if defined(CONFIG_OF_BOARD_SETUP) int ft_board_setup(void *blob, struct bd_info *bd) { diff --git
a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index a17c314daeb..f284b0dfd28 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -52,12 +52,10 @@
#define SYSCFG_BOOTR_BOOT_MASK GENMASK(2, 0) #define SYSCFG_BOOTR_BOOTPD_SHIFT 4 @@ -73,16 +71,6 @@
- #define USB_LOW_THRESHOLD_UV 200000 #define USB_WARNING_LOW_THRESHOLD_UV 660000 #define USB_START_LOW_THRESHOLD_UV 1230000
@@ -742,76 +730,6 @@ void board_quiesce_devices(void) setup_led(LEDST_OFF); }
u8 *syscfg;
u32 value;
if (!syscfg)
return -ENODEV;
log_debug("PHY_INTERFACE_MODE_MII\n");
break;
else
log_debug("PHY_INTERFACE_MODE_GMII\n");
break;
else
log_debug("PHY_INTERFACE_MODE_RMII\n");
break;
else
log_debug("PHY_INTERFACE_MODE_RGMII\n");
break;
default:
log_debug("Do not manage %d interface\n",
interface_type);
return -EINVAL;
- enum env_location env_get_location(enum env_operation op, int prio)
{ u32 bootmode = get_bootmode(); diff --git a/drivers/net/dwc_eth_qos_stm32.c b/drivers/net/dwc_eth_qos_stm32.c index fd29a604987..7520a136ed0 100644 --- a/drivers/net/dwc_eth_qos_stm32.c +++ b/drivers/net/dwc_eth_qos_stm32.c @@ -24,11 +24,26 @@ #include <netdev.h> #include <phy.h> #include <reset.h> +#include <syscon.h> #include <wait_bit.h> #include <linux/delay.h>
#include "dwc_eth_qos.h"
+/* SYSCFG registers */ +#define SYSCFG_PMCSETR 0x04 +#define SYSCFG_PMCCLRR 0x44
+#define SYSCFG_PMCSETR_ETH_CLK_SEL BIT(16) +#define SYSCFG_PMCSETR_ETH_REF_CLK_SEL BIT(17)
+#define SYSCFG_PMCSETR_ETH_SELMII BIT(20)
+#define SYSCFG_PMCSETR_ETH_SEL_MASK GENMASK(23, 21) +#define SYSCFG_PMCSETR_ETH_SEL_GMII_MII 0 +#define SYSCFG_PMCSETR_ETH_SEL_RGMII BIT(21) +#define SYSCFG_PMCSETR_ETH_SEL_RMII BIT(23)
- static ulong eqos_get_tick_clk_rate_stm32(struct udevice *dev) {
#ifdef CONFIG_CLK @@ -108,11 +123,78 @@ static int eqos_stop_clks_stm32(struct udevice *dev) return 0; }
+static int eqos_probe_syscfg_stm32(struct udevice *dev,
phy_interface_t interface_type) {
u8 *syscfg;
u32 value;
eth_ref_clk_sel_reg = dev_read_bool(dev, "st,eth-ref-clk-sel");
if (!syscfg)
return -ENODEV;
break;
else
break;
else
break;
else
break;
default:
interface_type);
return -EINVAL;
- static int eqos_probe_resources_stm32(struct udevice *dev) { struct eqos_priv *eqos = dev_get_priv(dev);
int ret; phy_interface_t interface;
int ret; debug("%s(dev=%p):\n", __func__, dev);
@@ -123,7 +205,7 @@ static int eqos_probe_resources_stm32(struct udevice *dev) return -EINVAL; }
ret = board_interface_eth_init(dev, interface);
ret = eqos_probe_syscfg_stm32(dev, interface); if (ret) return -EINVAL;
Reviewed-by: Christophe Roullier christophe.roullier@foss.st.com
Christophe ROULLIER
