[U-Boot] [PATCH] arch/arm: Add individual TLB size support.
This adds CONFIG_TLB_SIZE for individual board, whose TLB size maybe larger than PGTABLE_SIZE.
Signed-off-by: Xiubo Li Li.Xiubo@freescale.com --- arch/arm/lib/board.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/lib/board.c b/arch/arm/lib/board.c index dc34190..b7327ce 100644 --- a/arch/arm/lib/board.c +++ b/arch/arm/lib/board.c @@ -353,7 +353,11 @@ void board_init_f(ulong bootflag)
#if !(defined(CONFIG_SYS_ICACHE_OFF) && defined(CONFIG_SYS_DCACHE_OFF)) /* reserve TLB table */ +#ifdef CONFIG_TLB_SIZE + gd->arch.tlb_size = CONFIG_TLB_SIZE; +#else gd->arch.tlb_size = PGTABLE_SIZE; +#endif addr -= gd->arch.tlb_size;
/* round down to next 64 kB limit */
Hi Xiubo,
- gd->arch.tlb_size = CONFIG_TLB_SIZE;
There is no code in current mainline which defines CONFIG_TLB_SIZE; that makes the patch a dead code addition.
Besides, what's the point of this as opposed to, e.g., just defining the right PGTABLE_SIZE, or renaming PGTABLE_SIZE as CONFIG_TLB_SIZE?
Amicalement,
Hi Albert,
Subject: Re: [PATCH] arch/arm: Add individual TLB size support.
Hi Xiubo,
Yes, this will be used by our LS1 SoC first, and it is still doing The upstream.
We'll add the LPAE support in uboot and need more space for tlb.
Thanks very much,
BRs Xiubo
Hi Li.Xiubo@freescale.com,
On Wed, 10 Sep 2014 03:10:27 +0000, "Li.Xiubo@freescale.com" Li.Xiubo@freescale.com wrote:
Hi Albert,
Hi Xiubo,
Then please sumbit this patch as part of the LS1 SoC support series, where the code it creates will actually be used.
I still don't get it. Is gd->arch.tlb_size the size of a page table or of a translation lookahead buffer?
Thanks very much,
BRs Xiubo
Amicalement,
Hi Albert,
On Thu, 11 Sep 2014 17:55:00 +0200, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Albert,
Hi Xiubo,
Ping on both points. Meanwhile I've put the patch in 'Changes Requested' state.
Thanks very much,
BRs Xiubo
Amicalement,
Amicalement,
Albert ARIBAUD
Li.Xiuboï¼ freescale.com
Xiubo Li
