[U-Boot-Users] [PATCH] fdt: suppress unused variable 'bd' warning
Signed-off-by: Kim Phillips kim.phillips@freescale.com --- gvb, please apply, in addition to:
"fdt: remove unused OF_FLAT_TREE_MAX_SIZE references" sent Fri, 10 Aug 2007 14:34:14 -0500
Thanks, Kim.
common/fdt_support.c | 1 - 1 files changed, 0 insertions(+), 1 deletions(-)
diff --git a/common/fdt_support.c b/common/fdt_support.c index caaa682..175d59e 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -46,7 +46,6 @@ struct fdt_header *fdt;
int fdt_chosen(void *fdt, ulong initrd_start, ulong initrd_end, int force) { - bd_t *bd = gd->bd; int nodeoffset; int err; u32 tmp; /* used to set 32 bit integer properties */
I took this one directly, as it's an obvious fix. Thanks. Applied.
Wolfgang beat me to it, thanks.
Oooo, I forgot that one. :-( Thanks for the reminder, I'll apply it. Ref: http://article.gmane.org/gmane.comp.boot-loaders.u-boot/30889
Thanks, Kim.
...and thank /you/ for your series on 83xx throwing the LIBFDT switch. :-)
Best regards, gvb
Jerry Van Baren
Kim Phillips
