[U-Boot] [PATCH] tools/env: allow overwrite of ethaddr on default
This patch allows the U-Boot user space companion utility, fw_setenv, to overwrite the 'ethaddr' key/value pair if the current value is set to a per-board-configured default.
This change allows 'fw_setenv' to match the behavior of 'setenv' / 'env set' on the U-Boot command line.
Signed-off-by: Grant Erickson marathon96@gmail.com --- tools/env/fw_env.c | 14 ++++++++++++-- 1 files changed, 12 insertions(+), 2 deletions(-)
diff --git a/tools/env/fw_env.c b/tools/env/fw_env.c index 996682e..2185be9 100644 --- a/tools/env/fw_env.c +++ b/tools/env/fw_env.c @@ -45,6 +45,8 @@
#include "fw_env.h"
+#include <config.h> + #define WHITESPACE(c) ((c == '\t') || (c == ' '))
#define min(x, y) ({ \ @@ -390,15 +392,23 @@ int fw_env_write(char *name, char *value) * Delete any existing definition */ if (oldval) { +#ifndef CONFIG_ENV_OVERWRITE + /* * Ethernet Address and serial# can be set only once */ - if ((strcmp (name, "ethaddr") == 0) || - (strcmp (name, "serial#") == 0)) { + if ( + (strcmp(name, "serial#") == 0) || + ((strcmp(name, "ethaddr") == 0) +#if defined(CONFIG_OVERWRITE_ETHADDR_ONCE) && defined(CONFIG_ETHADDR) + && (strcmp(oldval, MK_STR(CONFIG_ETHADDR)) != 0) +#endif /* CONFIG_OVERWRITE_ETHADDR_ONCE && CONFIG_ETHADDR */ + ) ) { fprintf (stderr, "Can't overwrite "%s"\n", name); errno = EROFS; return -1; } +#endif /* CONFIG_ENV_OVERWRITE */
if (*++nxt == '\0') { *env = '\0';
Dear Grant Erickson,
Applied, thanks.
Dear Wolfgang,
Applied, thanks.
This patch breaks building 'env' without board configuration. This is bad cause our automatic build environment build this tool for different boards. Specific configuration is done via /etc/fw_env.config. Can't we use some build-time configuration like http://patchwork.ozlabs.org/patch/120372/ ?
best regards
Andreas Bießmann
Hello,
i recently stumbled upon a compile-error which appears after trying to compile via
/./MAKEALL --arch arm --cpu pxa --vendor toradex/
, it appears U-Boot uses software-FP whereas the native XScale-libs use hardware-FP, see for yourself please :
/[dmack@Blizzard ~/workspace/u-boot]$ ./MAKEALL --arch arm --cpu pxa --vendor toradex/
/Configuring for colibri_pxa270 board.../
/arm-linux-ld: ERROR: /usr/lib/gcc/arm-xscale-linux-gnu/3.4.6/libgcc.a(_udivsi3.oS) uses hardware FP, whereas u-boot uses software FP/
/arm-linux-ld: failed to merge target specific data of file /usr/lib/gcc/arm-xscale-linux-gnu/3.4.6/libgcc.a(_udivsi3.oS)/
/arm-linux-ld: ERROR: /usr/lib/gcc/arm-xscale-linux-gnu/3.4.6/libgcc.a(_divsi3.oS) uses hardware FP, whereas u-boot uses software FP/
/arm-linux-ld: failed to merge target specific data of file /usr/lib/gcc/arm-xscale-linux-gnu/3.4.6/libgcc.a(_divsi3.oS)/
/arm-linux-ld: ERROR: /usr/lib/gcc/arm-xscale-linux-gnu/3.4.6/libgcc.a(_umodsi3.oS) uses hardware FP, whereas u-boot uses software FP/
/arm-linux-ld: failed to merge target specific data of file /usr/lib/gcc/arm-xscale-linux-gnu/3.4.6/libgcc.a(_umodsi3.oS)/
/arm-linux-ld: ERROR: /usr/lib/gcc/arm-xscale-linux-gnu/3.4.6/libgcc.a(_modsi3.oS) uses hardware FP, whereas u-boot uses software FP/
/arm-linux-ld: failed to merge target specific data of file /usr/lib/gcc/arm-xscale-linux-gnu/3.4.6/libgcc.a(_modsi3.oS)/
/arm-linux-ld: ERROR: /usr/lib/gcc/arm-xscale-linux-gnu/3.4.6/libgcc.a(_dvmd_lnx.oS) uses hardware FP, whereas u-boot uses software FP/
/arm-linux-ld: failed to merge target specific data of file /usr/lib/gcc/arm-xscale-linux-gnu/3.4.6/libgcc.a(_dvmd_lnx.oS)/
/arm-linux-ld: ERROR: /usr/lib/gcc/arm-xscale-linux-gnu/3.4.6/libgcc.a(_lshrdi3.oS) uses hardware FP, whereas u-boot uses software FP/
/arm-linux-ld: failed to merge target specific data of file /usr/lib/gcc/arm-xscale-linux-gnu/3.4.6/libgcc.a(_lshrdi3.oS)/
/arm-linux-ld: ERROR: /usr/lib/gcc/arm-xscale-linux-gnu/3.4.6/libgcc.a(_ashldi3.oS) uses hardware FP, whereas u-boot uses software FP/
/arm-linux-ld: failed to merge target specific data of file /usr/lib/gcc/arm-xscale-linux-gnu/3.4.6/libgcc.a(_ashldi3.oS)/
/arm-linux-ld: ERROR: /usr/lib/gcc/arm-xscale-linux-gnu/3.4.6/libgcc.a(_udivdi3.oS) uses hardware FP, whereas u-boot uses software FP/
/arm-linux-ld: failed to merge target specific data of file /usr/lib/gcc/arm-xscale-linux-gnu/3.4.6/libgcc.a(_udivdi3.oS)/
/arm-linux-ld: ERROR: /usr/lib/gcc/arm-xscale-linux-gnu/3.4.6/libgcc.a(_clz.oS) uses hardware FP, whereas u-boot uses software FP/
/arm-linux-ld: failed to merge target specific data of file /usr/lib/gcc/arm-xscale-linux-gnu/3.4.6/libgcc.a(_clz.oS)/
/make: *** [u-boot] Fehler 1/
/size: './u-boot': No such file/
/--------------------- SUMMARY ----------------------------/
/Boards compiled: 1/
/Boards with warnings or errors: 1 ( colibri_pxa270 )/
Is there a solution for this, am i missing something?
Daniel
Dear Daniel Mack,
This is a tool chain problem. You should get one that supports soft-FP, especially on processors that don;t have a FPU in the first place.
GCC 3.4 has always been (in)famous for causing issues, especially on ARM. And it is so old that you can consider it unsupported.
I guess you did not bother to check the mailing list archives? You should.
Applied, thanks.
update your patch to take the new code into account. you're going to have to rebase anyways to get it merged. -mike
participants (5)
Andreas Bießmann
Daniel Mack
Grant Erickson
Mike Frysinger
