[U-Boot] DDR training code for Armada 38x
Hi Stefan,
When you did the port from Marvell's source did you script any of the tidy-up that you did along the way?
I'm running up a new board and with the upstream u-boot DDR training occasionally fails. But with the Marvell bootloader it doesn't fail. The initial port was done from TIP-1.29 but Marvell are now up to TIP-1.55 so there is probably some difference that results in my board working.
One difference I've spotted so far is that Marvell enable 2T timing mode for all Armada 38x boards (the comment says "resolve low freq instability"). But doing that doesn't magically make my board work. I'm thinking I need to compare TIP-1.29 with TIP-1.55 to look for other differences but obviously that's going to be hard given the style changes. If you have any scripts (or even just a record of the regexes) that you used would you be able to share them?
Thanks, Chris
Hi Chris,
Not really. At least not in a reproducible way. I spent long hours running Lindent, recursive-replace tools and especially manual code inspection and re-formatting on this huge code. Still the outcome is far from perfect, but hopefully better that the original version.
Did you compare all DDR register values (the "good" ones and the "bad" ones) and only the the 2T timing is different?
Has the style changed in between the Marvell versions as well? I have not looked into this code for quite some time.
Please find some scripts attached, I've located that I have used while doing this porting.
Thanks, Stefan
On Wed, Sep 20, 2017 at 5:31 PM, Stefan Roese sr@denx.de wrote:
Hi Chris,
There are more differences. 2T was the one that stuckout. As you know working backwards from register values to where the code sets them can be tricky with this code.
What I meant was u-boot has 1.29 and I have 1.55 from Marvell. The oldest Marvell version I have is 1.34 which helped me find the 2T thing. I'm wondering what differences exist between 1.29 and 1.34. 1.55 also has support for some newer integrated switch+CPU chips so it is a little hard to separate those bits from the A38X code.
Thanks. That's a start at least.
For the internet historians,
On Thu, Sep 21, 2017 at 4:25 PM, Chris Packham judge.packham@gmail.com wrote:
Hi Chris,
In the end once I fixed the ecc_scrubbing[1] I stopped seeing the training failures so I've basically stopped looking at the differences between the Marvell bootloader and u-boot. But in the meantime I can summarize the differences I have identified in case they might help someone in the future.
* Marvell unconditionally enable 2T timing for A38X * Different settings for RD/WR ODT particularly in situations using only one chip-select.
There are more differences in the register dumps but I haven't looked into the meaning of them.
-- [1] - https://lists.denx.de/pipermail/u-boot/2017-September/307243.html
Hi Chris,
Hi Chris,
- Marvell unconditionally enable 2T timing for A38X
- Different settings for RD/WR ODT particularly in situations using
Thanks for the update Chris. I'm currently build-testing the MVEBU patches in Travis and will send the pull request, once this completes without issues.
Thanks, Stefan
Chris Packham
Stefan Roese
