[U-Boot] [U-boot] [PATCH] keystone: init: enable UART1 to be able use it from kernel
Currently PWREMU_MGMT is not configured in the Linux generic UART driver as this register seems to be specific TI UART IP. So this needs to be enabled in u-boot to use UART1 from kernel space.
Acked-By: Vitaly Andrianov vitalya@ti.com Signed-off-by: Murali Karicheri m-karicheri2@ti.com Signed-off-by: Ivan Khoronzhuk ivan.khoronzhuk@ti.com --- arch/arm/cpu/armv7/keystone/init.c | 9 +++++++++ arch/arm/include/asm/arch-keystone/hardware-k2hk.h | 2 -- arch/arm/include/asm/arch-keystone/hardware.h | 3 +++ include/configs/k2hk_evm.h | 3 ++- 4 files changed, 14 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/armv7/keystone/init.c b/arch/arm/cpu/armv7/keystone/init.c index 044015a..4df5ae1 100644 --- a/arch/arm/cpu/armv7/keystone/init.c +++ b/arch/arm/cpu/armv7/keystone/init.c @@ -8,6 +8,7 @@ */
#include <common.h> +#include <ns16550.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/hardware.h> @@ -30,6 +31,14 @@ int arch_cpu_init(void) share_all_segments(11); /* PCIE */ #endif
+ /* + * just initialise the COM2 port so that TI specific + * UART register PWREMU_MGMT is initialized. Linux UART + * driver doesn't handle this. + */ + NS16550_init((NS16550_t)(CONFIG_SYS_NS16550_COM2), + CONFIG_SYS_NS16550_CLK / 16 / CONFIG_BAUDRATE); + return 0; }
diff --git a/arch/arm/include/asm/arch-keystone/hardware-k2hk.h b/arch/arm/include/asm/arch-keystone/hardware-k2hk.h index 50ff13a..7ac2662 100644 --- a/arch/arm/include/asm/arch-keystone/hardware-k2hk.h +++ b/arch/arm/include/asm/arch-keystone/hardware-k2hk.h @@ -115,8 +115,6 @@ #define K2HK_LPSC_ARM_SREFLEX 51 #define K2HK_LPSC_TETRIS 52
-#define K2HK_UART0_BASE 0x02530c00 - /* DDR3A definitions */ #define K2HK_DDR3A_EMIF_CTRL_BASE 0x21010000 #define K2HK_DDR3A_EMIF_DATA_BASE 0x80000000 diff --git a/arch/arm/include/asm/arch-keystone/hardware.h b/arch/arm/include/asm/arch-keystone/hardware.h index a305a0c..6c532ca 100644 --- a/arch/arm/include/asm/arch-keystone/hardware.h +++ b/arch/arm/include/asm/arch-keystone/hardware.h @@ -142,6 +142,9 @@ struct ddr3_emif_config { #define KS2_DDR3_PMCTL_OFFSET 0x38 #define KS2_DDR3_ZQCFG_OFFSET 0xC8
+#define KS2_UART0_BASE 0x02530c00 +#define KS2_UART1_BASE 0x02531000 + #ifdef CONFIG_SOC_K2HK #include <asm/arch/hardware-k2hk.h> #endif diff --git a/include/configs/k2hk_evm.h b/include/configs/k2hk_evm.h index dde7329..998390e 100644 --- a/include/configs/k2hk_evm.h +++ b/include/configs/k2hk_evm.h @@ -71,7 +71,8 @@ #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_MEM32 #define CONFIG_SYS_NS16550_REG_SIZE -4 -#define CONFIG_SYS_NS16550_COM1 K2HK_UART0_BASE +#define CONFIG_SYS_NS16550_COM1 KS2_UART0_BASE +#define CONFIG_SYS_NS16550_COM2 KS2_UART1_BASE #define CONFIG_SYS_NS16550_CLK clk_get_rate(K2HK_CLK1_6) #define CONFIG_CONS_INDEX 1 #define CONFIG_BAUDRATE 115200
Applied to u-boot-ti/master, thanks!
Ivan Khoronzhuk
