[U-Boot] [PATCH] exynos: video: Enable stdout env var backward compatibility for LCD
Commit bb5930d5c97f ("exynos: video: Convert several boards to driver model for video") converted the Exynos Chromebooks machines to use DM for video, but this breaks backward compatibility with the stdout env var since now stdout is expected to be "vidconsole" instead of "lcd".
This causes display to not work when updating u-boot on these boards if the old stdout env var is used. Since these are consumer devices, there's no easy way to have a serial console so users may be confused thinking that u-boot failed to boot, or in the best case will need to update the stdout env var blindly to make the display to work again.
There's a CONFIG_VIDCONSOLE_AS_LCD config option to workaround this, so enable it in the Chromebooks' default configuration files to allow users to change their stdout env var before the workaround is removed.
Suggested-by: Simon Glass sjg@chromium.org Signed-off-by: Javier Martinez Canillas javier@osg.samsung.com
configs/peach-pi_defconfig | 1 + configs/peach-pit_defconfig | 1 + configs/snow_defconfig | 1 + configs/spring_defconfig | 1 + 4 files changed, 4 insertions(+)
diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index ef0211842138..fb933efc5a9c 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -60,5 +60,6 @@ CONFIG_DISPLAY=y CONFIG_VIDEO_BRIDGE=y CONFIG_VIDEO_BRIDGE_PARADE_PS862X=y CONFIG_LCD=y +CONFIG_VIDCONSOLE_AS_LCD=y CONFIG_TPM=y CONFIG_ERRNO_STR=y diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index 14fe00eb2a4d..cbac99dd8362 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -60,5 +60,6 @@ CONFIG_DISPLAY=y CONFIG_VIDEO_BRIDGE=y CONFIG_VIDEO_BRIDGE_PARADE_PS862X=y CONFIG_LCD=y +CONFIG_VIDCONSOLE_AS_LCD=y CONFIG_TPM=y CONFIG_ERRNO_STR=y diff --git a/configs/snow_defconfig b/configs/snow_defconfig index 47b498b6b2d9..ea0412a73f06 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -68,5 +68,6 @@ CONFIG_VIDEO_BRIDGE=y CONFIG_VIDEO_BRIDGE_PARADE_PS862X=y CONFIG_VIDEO_BRIDGE_NXP_PTN3460=y CONFIG_LCD=y +CONFIG_VIDCONSOLE_AS_LCD=y CONFIG_TPM=y CONFIG_ERRNO_STR=y diff --git a/configs/spring_defconfig b/configs/spring_defconfig index 4a782c80da8f..d20ac0b0e8ce 100644 --- a/configs/spring_defconfig +++ b/configs/spring_defconfig @@ -67,5 +67,6 @@ CONFIG_DISPLAY=y CONFIG_VIDEO_BRIDGE=y CONFIG_VIDEO_BRIDGE_PARADE_PS862X=y CONFIG_LCD=y +CONFIG_VIDCONSOLE_AS_LCD=y CONFIG_TPM=y CONFIG_ERRNO_STR=y
On Tuesday, 17 January 2017, Javier Martinez Canillas < javier@osg.samsung.com> wrote:
Suggested-by: Simon Glass <sjg@chromium.org javascript:;> Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com javascript:;>
diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index ef0211842138..fb933efc5a9c 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -60,5 +60,6 @@ CONFIG_DISPLAY=y CONFIG_VIDEO_BRIDGE=y CONFIG_VIDEO_BRIDGE_PARADE_PS862X=y CONFIG_LCD=y +CONFIG_VIDCONSOLE_AS_LCD=y CONFIG_TPM=y CONFIG_ERRNO_STR=y diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index 14fe00eb2a4d..cbac99dd8362 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -60,5 +60,6 @@ CONFIG_DISPLAY=y CONFIG_VIDEO_BRIDGE=y CONFIG_VIDEO_BRIDGE_PARADE_PS862X=y CONFIG_LCD=y +CONFIG_VIDCONSOLE_AS_LCD=y CONFIG_TPM=y CONFIG_ERRNO_STR=y diff --git a/configs/snow_defconfig b/configs/snow_defconfig index 47b498b6b2d9..ea0412a73f06 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -68,5 +68,6 @@ CONFIG_VIDEO_BRIDGE=y CONFIG_VIDEO_BRIDGE_PARADE_PS862X=y CONFIG_VIDEO_BRIDGE_NXP_PTN3460=y CONFIG_LCD=y +CONFIG_VIDCONSOLE_AS_LCD=y CONFIG_TPM=y CONFIG_ERRNO_STR=y diff --git a/configs/spring_defconfig b/configs/spring_defconfig index 4a782c80da8f..d20ac0b0e8ce 100644 --- a/configs/spring_defconfig +++ b/configs/spring_defconfig @@ -67,5 +67,6 @@ CONFIG_DISPLAY=y CONFIG_VIDEO_BRIDGE=y CONFIG_VIDEO_BRIDGE_PARADE_PS862X=y CONFIG_LCD=y +CONFIG_VIDCONSOLE_AS_LCD=y CONFIG_TPM=y CONFIG_ERRNO_STR=y -- 2.7.4
U-Boot mailing list U-Boot@lists.denx.de javascript:; http://lists.denx.de/mailman/listinfo/u-boot
applied to u-boot-samsung
Thanks
Minkyu Kang
