[PATCH] versal: Return ENVL_NOWHERE instead of ENVL_UNKNOWN
The system fails to boot without any environment location, so return ENVL_NOWHERE when there's nowhere to store the environment instead of ENVL_UNKNOWN.
The same change was also done by commit 50918d0df5cb ("xilinx: Return ENVL_NOWHERE instead of ENVL_UNKNOWN") for zynq and zynqmp.
Signed-off-by: T Karthik Reddy t.karthik.reddy@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
board/xilinx/versal/board.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/xilinx/versal/board.c b/board/xilinx/versal/board.c index 03604d730a0b..299e128f7b9d 100644 --- a/board/xilinx/versal/board.c +++ b/board/xilinx/versal/board.c @@ -269,13 +269,13 @@ enum env_location env_get_location(enum env_operation op, int prio) return ENVL_FAT; if (IS_ENABLED(CONFIG_ENV_IS_IN_EXT4)) return ENVL_EXT4; - return ENVL_UNKNOWN; + return ENVL_NOWHERE; case OSPI_MODE: case QSPI_MODE_24BIT: case QSPI_MODE_32BIT: if (IS_ENABLED(CONFIG_ENV_IS_IN_SPI_FLASH)) return ENVL_SPI_FLASH; - return ENVL_UNKNOWN; + return ENVL_NOWHERE; case JTAG_MODE: default: return ENVL_NOWHERE;
st 24. 11. 2021 v 12:16 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
-- 2.33.1
Applied. M
Michal Simek
Michal Simek
