[U-Boot] [PATCH] ARM: socfpga: configure pl310 from dts
Read the cache properties of the L2 cache controller from the device tree and configure it.
Signed-off-by: Dinh Nguyen dinguyen@kernel.org --- arch/arm/include/asm/pl310.h | 4 ++++ arch/arm/mach-socfpga/misc.c | 45 +++++++++++++++++++++++++++++------- 2 files changed, 41 insertions(+), 8 deletions(-)
diff --git a/arch/arm/include/asm/pl310.h b/arch/arm/include/asm/pl310.h index b83978b1cc..346dbe476d 100644 --- a/arch/arm/include/asm/pl310.h +++ b/arch/arm/include/asm/pl310.h @@ -19,6 +19,10 @@ #define L310_AUX_CTRL_DATA_PREFETCH_MASK (1 << 28) #define L310_AUX_CTRL_INST_PREFETCH_MASK (1 << 29)
+#define L310_LATENCY_CTRL_SETUP(n) ((n) << 0) +#define L310_LATENCY_CTRL_RD(n) ((n) << 4) +#define L310_LATENCY_CTRL_WR(n) ((n) << 8) + #define L2X0_CACHE_ID_PART_MASK (0xf << 6) #define L2X0_CACHE_ID_PART_L310 (3 << 6) #define L2X0_CACHE_ID_RTL_MASK 0x3f diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc.c index fcf211d62b..b53f22e621 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -57,19 +57,48 @@ void enable_caches(void) }
#ifdef CONFIG_SYS_L2_PL310 +static void setup_cache_latency(void) +{ + const void *blob = gd->fdt_blob; + int node; + u32 latency; + u32 data[3]; + + /* find the l2-cache node */ + node = fdt_node_offset_by_compatible(blob, -1, "arm,pl310-cache"); + + fdtdec_get_int_array(blob, node, "arm,tag-latency", data, 3); + latency = L310_LATENCY_CTRL_RD(data[0] - 1) | + L310_LATENCY_CTRL_WR(data[1] - 1) | + L310_LATENCY_CTRL_SETUP(data[2] - 1); + + writel(latency, &pl310->pl310_tag_latency_ctrl); + + fdtdec_get_int_array(blob, node, "arm,data-latency", data, 3); + latency = L310_LATENCY_CTRL_RD(data[0] - 1) | + L310_LATENCY_CTRL_WR(data[1] - 1) | + L310_LATENCY_CTRL_SETUP(data[2] - 1); + writel(latency, &pl310->pl310_data_latency_ctrl); + + if (fdtdec_get_bool(blob, node, "arm,shared-override")) + setbits_le32(&pl310->pl310_aux_ctrl, + L310_SHARED_ATT_OVERRIDE_ENABLE); + + if (fdtdec_get_config_int(blob, "prefetch-data", 1)) + setbits_le32(&pl310->pl310_aux_ctrl, + L310_AUX_CTRL_DATA_PREFETCH_MASK); + + if (fdtdec_get_config_int(blob, "prefetch-instr", 1)) + setbits_le32(&pl310->pl310_aux_ctrl, + L310_AUX_CTRL_INST_PREFETCH_MASK); +} + void v7_outer_cache_enable(void) { /* Disable the L2 cache */ clrbits_le32(&pl310->pl310_ctrl, L2X0_CTRL_EN);
- writel(0x111, &pl310->pl310_tag_latency_ctrl); - writel(0x121, &pl310->pl310_data_latency_ctrl); - - /* enable BRESP, instruction and data prefetch, full line of zeroes */ - setbits_le32(&pl310->pl310_aux_ctrl, - L310_AUX_CTRL_DATA_PREFETCH_MASK | - L310_AUX_CTRL_INST_PREFETCH_MASK | - L310_SHARED_ATT_OVERRIDE_ENABLE); + setup_cache_latency();
/* Enable the L2 cache */ setbits_le32(&pl310->pl310_ctrl, L2X0_CTRL_EN);
I really hoped there would be a small fix for the latency configuration I can apply for the current release.
Regarding the PL310 DT stuff, this looks rather generic, can it be made into generic code rather than socfpga specific one ?
- const void *blob = gd->fdt_blob;
- int node;
- u32 latency;
- u32 data[3];
- /* find the l2-cache node */
- node = fdt_node_offset_by_compatible(blob, -1, "arm,pl310-cache");
- fdtdec_get_int_array(blob, node, "arm,tag-latency", data, 3);
- latency = L310_LATENCY_CTRL_RD(data[0] - 1) |
- writel(latency, &pl310->pl310_tag_latency_ctrl);
- fdtdec_get_int_array(blob, node, "arm,data-latency", data, 3);
- writel(latency, &pl310->pl310_data_latency_ctrl);
- if (fdtdec_get_bool(blob, node, "arm,shared-override"))
- if (fdtdec_get_config_int(blob, "prefetch-data", 1))
- if (fdtdec_get_config_int(blob, "prefetch-instr", 1))
Dinh Nguyen
