[PATCH] arm64: versal: Disable DDR cache mapping if DDR is not enabled
Similar change was done in past by commit 3b644a3c2f69 ("arm64: zynqmp: Provide a config to not map DDR region in MMU table").
arch/arm/mach-versal/Kconfig | 6 ++++++ arch/arm/mach-versal/cpu.c | 9 +++++++++ 2 files changed, 15 insertions(+)
diff --git a/arch/arm/mach-versal/Kconfig b/arch/arm/mach-versal/Kconfig index a08e5ae41490..e1d66e8d32b7 100644 --- a/arch/arm/mach-versal/Kconfig +++ b/arch/arm/mach-versal/Kconfig @@ -56,4 +56,10 @@ config DEFINE_TCM_OCM_MMAP This option if enabled defines the TCM and OCM memory and its memory attributes in MMU table entry.
+config VERSAL_NO_DDR + bool "Disable DDR MMU mapping" + help + This option configures MMU with no DDR to avoid speculative + access to DDR memory where DDR is not present. + endif diff --git a/arch/arm/mach-versal/cpu.c b/arch/arm/mach-versal/cpu.c index 6ee6cd43eca4..829a6c1b3e53 100644 --- a/arch/arm/mach-versal/cpu.c +++ b/arch/arm/mach-versal/cpu.c @@ -81,6 +81,15 @@ void mem_map_fill(void) if (!gd->bd->bi_dram[i].size) break;
+#if defined(CONFIG_VERSAL_NO_DDR) + if (gd->bd->bi_dram[i].start < 0x80000000UL || + gd->bd->bi_dram[i].start > 0x100000000UL) { + printf("Ignore caches over %llx/%llx\n", + gd->bd->bi_dram[i].start, + gd->bd->bi_dram[i].size); + continue; + } +#endif versal_mem_map[banks].virt = gd->bd->bi_dram[i].start; versal_mem_map[banks].phys = gd->bd->bi_dram[i].start; versal_mem_map[banks].size = gd->bd->bi_dram[i].size;
po 23. 3. 2020 v 15:44 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
help
continue;
+#endif versal_mem_map[banks].virt = gd->bd->bi_dram[i].start; versal_mem_map[banks].phys = gd->bd->bi_dram[i].start; versal_mem_map[banks].size = gd->bd->bi_dram[i].size; -- 2.25.1
Applied. M
Michal Simek
Michal Simek
