Pull request: u-boot-imx u-boot-imx-20210717
Hi Tom,
please pull from u-boot-imx, thanks !
The following changes since commit db473cd489002bd37a77cea4ad607fe8a2b9ca21:
Merge branch '2021-07-09-arm-updates' (2021-07-09 14:05:11 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-imx.git tags/u-boot-imx-20210717
for you to fetch changes up to edf95bdeddeab8f0fd7b88d4865fbc6e99071c73:
mx7ulp: wdog: Wait for WDOG unlock and reconfiguration to complete (2021-07-17 14:59:56 +0200)
---------------------------------------------------------------- i.MX ----
- mx7ulp : fix WDOG - imx8 : Phytec - USB3 support for i.MX8
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/8277
---------------------------------------------------------------- Breno Lima (2): mx7ulp: Update unlock and refresh sequences in sWDOG driver mx7ulp: wdog: Wait for WDOG unlock and reconfiguration to complete
Christoph Niedermaier (1): ARM: imx6: Update dhelectronics/dh_imx6/MAINTAINERS file
Cody Gray (1): mx6sabresd: Make checkboard respect CONFIG_NXP_BOARD_REVISION
Fabio Estevam (2): smegw01: Allow booting the Yocto image by default smegw01: Select the CMD_UNZIP option
Frieder Schrempf (4): mtd: spi-nor-ids: Add support for Macronix MX25V8035F and MX25R1635F clk: imx8mm: Add SPI clocks imx8m: Restrict usable memory to space below 4G boundary spi: fsl_qspi: Build driver only if DM_SPI is available
Kacper Kubkowski (1): arm/mach-imx: Fix macros in mmdc_size.c
Marek Vasut (2): spl: mmc: Factor out eMMC boot partition selection code ARM: imx: Pick correct eMMC boot partition from ROM log
Stefano Babic (1): spi: mxc_spi: fix warnings if CLK_ENABLED not set
Teresa Remmet (9): arm: dts: imx8mp: Resync imx8mp device tree include arm: dts: imx8mp: Add common u-boot dtsi arm: dts: imx8mp-phyboard-pollux: Sync dts files with kernel board: phytec: phycore_imx8mp: Change debug UART board: phytec: phycore_imx8mp: Add fec support board: phytec: phycore_imx8mp: Set VDD_ARM to 0,95V board: phytec: phycore-imx8mp: Enable DVS1 control arm: dts: imx8mp-phyboard-pollux-rdk-u-boot: Add wdog pinctrl entry board: phytec: imx8mp-phycore: Switch to binman
Tim Harvey (26): imx: ventana: remove USB_KEYBOARD support imx: ventana: remove unneeded includes imx: ventana: increase SYS_BOOTM_LEN imx: ventana: add legacy uboot image support imx: ventana: add PMIC fix for GW54xx-G imx: ventana: put PFUZ100 regulators in continuous mode imx: ventana: put LTC3676 regulators in continuous mode imx: ventana: add DP83867 PHY LED configuration imx: ventana: display neteowrk PHY imx: ventana: add support for DLC0700XDP21LF LCD display imx: ventana: display 'none' for MMC if board does not have it pci: imx: use reset-gpios if defined by device-tree board: gateworks: venice: add imx8mm-gw7901 support net: fec: use device sequence vs index when fetching fec net: fec: set phy_of_node properly for fixed-link phy net: add set_promisc function to enable/disable Promiscuous mode net: fec: add set_promisc function net: dsa: enable master promisc mode if available and needed net: add support for KSZ9477/KSZ9897/KSZ9567 GbE switch arm: dts: imx8mm-venice-gw7901.dts: fix dsa switch configuration configs: imx8mm_venice_defconfig: add support for gbe switch board: gateworks: venice: gsc: fix typo board: gateworks: venice: gsc: fix voltage offset board: gateworks: venice: display DTB used board: gateworks: venice: add ftd_file env vars on boot board: gateworks: venice: remove forced enable of GSC thermal protection
Ye Li (4): phy: phy-imx8mq-usb: Add USB PHY driver for i.MX8MQ arm: dts: imx8mq: Add alias for two usb controllers arm: imx8mq: Add USB clock init function imx8mq_evk: Enable the USB3.0 host port
arch/arm/dts/Makefile | 1 + arch/arm/dts/imx8mm-venice-gw7901-u-boot.dtsi | 117 ++++++++++++++++++ arch/arm/dts/imx8mm-venice-gw7901.dts | 1055 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/imx8mp-evk-u-boot.dtsi | 143 +-------------------- arch/arm/dts/imx8mp-phyboard-pollux-rdk-u-boot.dtsi | 47 ++----- arch/arm/dts/imx8mp-phyboard-pollux-rdk.dts | 58 +++++++-- arch/arm/dts/imx8mp-phycore-som.dtsi | 2 +- arch/arm/dts/imx8mp-u-boot.dtsi | 149 ++++++++++++++++++++++ arch/arm/dts/imx8mp.dtsi | 146 +++++++++++++++++++++- arch/arm/dts/imx8mq.dtsi | 2 + arch/arm/include/asm/arch-imx8m/clock.h | 1 + arch/arm/include/asm/arch-mx6/sys_proto.h | 3 +- arch/arm/mach-imx/imx8m/Kconfig | 1 + arch/arm/mach-imx/imx8m/clock_imx8mq.c | 22 ++++ arch/arm/mach-imx/imx8m/soc.c | 75 +++++++++++ arch/arm/mach-imx/mmdc_size.c | 10 +- board/dhelectronics/dh_imx6/MAINTAINERS | 3 +- board/freescale/imx8mq_evk/imx8mq_evk.c | 4 + board/freescale/mx6sxsabresd/mx6sxsabresd.c | 5 +- board/gateworks/gw_ventana/common.c | 55 +++++++++ board/gateworks/gw_ventana/gw_ventana.c | 45 ++++--- board/gateworks/venice/gsc.c | 12 +- board/gateworks/venice/imx8mm_venice.c | 25 +++- board/gateworks/venice/spl.c | 55 ++++++++- board/phytec/phycore_imx8mp/imximage-8mp-sd.cfg | 10 ++ board/phytec/phycore_imx8mp/phycore-imx8mp.c | 14 +++ board/phytec/phycore_imx8mp/spl.c | 23 +++- common/spl/spl_mmc.c | 37 ++++-- configs/gwventana_emmc_defconfig | 2 - configs/gwventana_gw5904_defconfig | 2 - configs/gwventana_nand_defconfig | 2 - configs/imx8mm_venice_defconfig | 6 +- configs/imx8mq_evk_defconfig | 9 ++ configs/phycore-imx8mp_defconfig | 12 +- configs/smegw01_defconfig | 1 + drivers/clk/imx/clk-imx8mm.c | 23 +++- drivers/mtd/spi/spi-nor-ids.c | 2 + drivers/net/Kconfig | 7 ++ drivers/net/Makefile | 1 + drivers/net/fec_mxc.c | 21 +++- drivers/net/fec_mxc.h | 1 + drivers/net/ksz9477.c | 546 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/pci/pcie_imx.c | 29 ++++- drivers/phy/Kconfig | 7 ++ drivers/phy/Makefile | 1 + drivers/phy/phy-imx8mq-usb.c | 197 +++++++++++++++++++++++++++++ drivers/spi/Makefile | 2 +- drivers/spi/mxc_spi.c | 4 +- drivers/watchdog/ulp_wdog.c | 57 ++++++--- include/configs/gw_ventana.h | 3 + include/configs/phycore_imx8mp.h | 21 +++- include/configs/smegw01.h | 6 +- include/net.h | 2 + include/spl.h | 23 ++++ net/dsa-uclass.c | 9 +- 55 files changed, 2826 insertions(+), 290 deletions(-) create mode 100644 arch/arm/dts/imx8mm-venice-gw7901-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mm-venice-gw7901.dts create mode 100644 arch/arm/dts/imx8mp-u-boot.dtsi create mode 100644 board/phytec/phycore_imx8mp/imximage-8mp-sd.cfg create mode 100644 drivers/net/ksz9477.c create mode 100644 drivers/phy/phy-imx8mq-usb.c
On Sat, Jul 17, 2021 at 04:08:06PM +0200, Stefano Babic wrote:
Hi Tom,
Stefano Babic
