[PATCH 1/2] w1: w1-gpio: claim the gpio with correct initial flag
gpio_request_by_name should be called with proper flags. The 0 value flag is invalid, and causes bad initialization of the gpio.
Signed-off-by: Eugen Hristev eugen.hristev@microchip.com --- drivers/w1/w1-gpio.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/w1/w1-gpio.c b/drivers/w1/w1-gpio.c index 3b0ead6f6d..9346f810ce 100644 --- a/drivers/w1/w1-gpio.c +++ b/drivers/w1/w1-gpio.c @@ -156,7 +156,7 @@ static int w1_gpio_of_to_plat(struct udevice *dev) struct w1_gpio_pdata *pdata = dev_get_plat(dev); int ret;
- ret = gpio_request_by_name(dev, "gpios", 0, &pdata->gpio, 0); + ret = gpio_request_by_name(dev, "gpios", 0, &pdata->gpio, GPIOD_IS_IN); if (ret < 0) printf("Error claiming GPIO %d\n", ret);
The GPIO polarity for onewire must be GPIO_ACTIVE_HIGH. On previous versions this used to work as it looks like the right flag values are being passed since : https://lists.denx.de/pipermail/u-boot/2020-April/407195.html
And that series broke the old functionality for onewire nodes. Some boards had the correct value for the polarity, but it wasn't clear so I replaced it with the right macro for the flag, instead of an empty value.
Signed-off-by: Eugen Hristev eugen.hristev@microchip.com --- arch/arm/dts/at91-sama5d27_som1_ek.dts | 3 ++- arch/arm/dts/at91-sama5d27_wlsom1_ek.dts | 3 ++- arch/arm/dts/at91-sama5d2_ptc_ek.dts | 2 +- arch/arm/dts/at91-sama5d2_xplained.dts | 3 ++- arch/arm/dts/at91-sama5d3_xplained.dts | 2 +- arch/arm/dts/at91-sama5d4_xplained.dts | 2 +- arch/arm/dts/sam9x60ek.dts | 2 +- 7 files changed, 10 insertions(+), 7 deletions(-)
diff --git a/arch/arm/dts/at91-sama5d27_som1_ek.dts b/arch/arm/dts/at91-sama5d27_som1_ek.dts index 4cd6db66fe..ee851a1bef 100644 --- a/arch/arm/dts/at91-sama5d27_som1_ek.dts +++ b/arch/arm/dts/at91-sama5d27_som1_ek.dts @@ -43,6 +43,7 @@ * OTHER DEALINGS IN THE SOFTWARE. */ /dts-v1/; +#include <dt-bindings/gpio/gpio.h> #include "sama5d27_som1.dtsi"
/ { @@ -55,7 +56,7 @@ };
onewire_tm: onewire { - gpios = <&pioA 17 0>; + gpios = <&pioA 17 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_onewire_tm_default>; status = "okay"; diff --git a/arch/arm/dts/at91-sama5d27_wlsom1_ek.dts b/arch/arm/dts/at91-sama5d27_wlsom1_ek.dts index ab23f5c209..f3f6942143 100644 --- a/arch/arm/dts/at91-sama5d27_wlsom1_ek.dts +++ b/arch/arm/dts/at91-sama5d27_wlsom1_ek.dts @@ -7,6 +7,7 @@ * Author: Nicolas Ferre nicolas.ferre@microcihp.com */ /dts-v1/; +#include <dt-bindings/gpio/gpio.h> #include "sama5d27_wlsom1.dtsi"
/ { @@ -18,7 +19,7 @@ };
onewire_tm: onewire { - gpios = <&pioA PIN_PC9 0>; + gpios = <&pioA PIN_PC9 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_onewire_tm_default>; status = "okay"; diff --git a/arch/arm/dts/at91-sama5d2_ptc_ek.dts b/arch/arm/dts/at91-sama5d2_ptc_ek.dts index 068a117585..cd3711a02a 100644 --- a/arch/arm/dts/at91-sama5d2_ptc_ek.dts +++ b/arch/arm/dts/at91-sama5d2_ptc_ek.dts @@ -57,7 +57,7 @@ };
onewire_tm: onewire { - gpios = <&pioA PIN_PB31 0>; + gpios = <&pioA PIN_PB31 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_onewire_tm_default>; status = "okay"; diff --git a/arch/arm/dts/at91-sama5d2_xplained.dts b/arch/arm/dts/at91-sama5d2_xplained.dts index 7f0d1696ba..b733c4d4ce 100644 --- a/arch/arm/dts/at91-sama5d2_xplained.dts +++ b/arch/arm/dts/at91-sama5d2_xplained.dts @@ -1,4 +1,5 @@ /dts-v1/; +#include <dt-bindings/gpio/gpio.h> #include "sama5d2.dtsi" #include "sama5d2-pinfunc.h"
@@ -12,7 +13,7 @@ };
onewire_tm: onewire { - gpios = <&pioA PIN_PB0 0>; + gpios = <&pioA PIN_PB0 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_onewire_tm_default>; status = "okay"; diff --git a/arch/arm/dts/at91-sama5d3_xplained.dts b/arch/arm/dts/at91-sama5d3_xplained.dts index 20fba5f067..fc508002a7 100644 --- a/arch/arm/dts/at91-sama5d3_xplained.dts +++ b/arch/arm/dts/at91-sama5d3_xplained.dts @@ -37,7 +37,7 @@ };
onewire_tm: onewire { - gpios = <&pioE 23 GPIO_ACTIVE_LOW>; + gpios = <&pioE 23 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_onewire_tm_default>; status = "okay"; diff --git a/arch/arm/dts/at91-sama5d4_xplained.dts b/arch/arm/dts/at91-sama5d4_xplained.dts index 7da5086865..74959253dc 100644 --- a/arch/arm/dts/at91-sama5d4_xplained.dts +++ b/arch/arm/dts/at91-sama5d4_xplained.dts @@ -59,7 +59,7 @@ };
onewire_tm: onewire { - gpios = <&pioE 15 GPIO_ACTIVE_LOW>; + gpios = <&pioE 15 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_onewire_tm_default>; status = "okay"; diff --git a/arch/arm/dts/sam9x60ek.dts b/arch/arm/dts/sam9x60ek.dts index 96914b3ea2..77edd593b4 100644 --- a/arch/arm/dts/sam9x60ek.dts +++ b/arch/arm/dts/sam9x60ek.dts @@ -29,7 +29,7 @@ };
onewire_tm: onewire { - gpios = <&pioD 14 0>; + gpios = <&pioD 14 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_onewire_tm_default>; status = "okay";
- ret = gpio_request_by_name(dev, "gpios", 0, &pdata->gpio, GPIOD_IS_IN); if (ret < 0) printf("Error claiming GPIO %d\n", ret);
Applied both to u-boot-atmel/master
Eugen Hristev
Eugen.Hristev@microchip.com
