[U-Boot] [PATCH 0/3] Update DWC2 driver
This series : _ adds dwc_vbus_supply_exit() to disable VBUS on device removal _ increases timeout in wait_for_chhltd() _ replaces printf() and pr_err by dev_info() and dev_err()
Christophe Kerello (2): usb: dwc2: disable external vbus supply when the device is removed usb: dwc2: increase timeout in wait_for_chhltd
Patrice Chotard (1): usb: dwc2: Replace printf, pr_err by dev_info, dev_err
drivers/usb/host/dwc2.c | 60 ++++++++++++++++++++++++++++++++++++++----------- 1 file changed, 47 insertions(+), 13 deletions(-)
This patch adds an interface to disable the power in dwc2 driver. This new interface is called when the device is removed.
Signed-off-by: Christophe Kerello christophe.kerello@st.com Signed-off-by: Patrice Chotard patrice.chotard@st.com --- drivers/usb/host/dwc2.c | 38 +++++++++++++++++++++++++++++++++++--- 1 file changed, 35 insertions(+), 3 deletions(-)
diff --git a/drivers/usb/host/dwc2.c b/drivers/usb/host/dwc2.c index 0efe645044c5..cd70b2a195ca 100644 --- a/drivers/usb/host/dwc2.c +++ b/drivers/usb/host/dwc2.c @@ -34,6 +34,9 @@ struct dwc2_priv { #ifdef CONFIG_DM_USB uint8_t aligned_buffer[DWC2_DATA_BUF_SIZE] __aligned(ARCH_DMA_MINALIGN); uint8_t status_buffer[DWC2_STATUS_BUF_SIZE] __aligned(ARCH_DMA_MINALIGN); +#ifdef CONFIG_DM_REGULATOR + struct udevice *vbus_supply; +#endif #else uint8_t *aligned_buffer; uint8_t *status_buffer; @@ -168,16 +171,17 @@ static void dwc_otg_core_reset(struct dwc2_core_regs *regs) #if defined(CONFIG_DM_USB) && defined(CONFIG_DM_REGULATOR) static int dwc_vbus_supply_init(struct udevice *dev) { - struct udevice *vbus_supply; + struct dwc2_priv *priv = dev_get_priv(dev); int ret;
- ret = device_get_supply_regulator(dev, "vbus-supply", &vbus_supply); + ret = device_get_supply_regulator(dev, "vbus-supply", + &priv->vbus_supply); if (ret) { debug("%s: No vbus supply\n", dev->name); return 0; }
- ret = regulator_set_enable(vbus_supply, true); + ret = regulator_set_enable(priv->vbus_supply, true); if (ret) { pr_err("Error enabling vbus supply\n"); return ret; @@ -185,11 +189,34 @@ static int dwc_vbus_supply_init(struct udevice *dev)
return 0; } + +static int dwc_vbus_supply_exit(struct udevice *dev) +{ + struct dwc2_priv *priv = dev_get_priv(dev); + int ret; + + if (priv->vbus_supply) { + ret = regulator_set_enable(priv->vbus_supply, false); + if (ret) { + dev_err(dev, "Error disabling vbus supply\n"); + return ret; + } + } + + return 0; +} #else static int dwc_vbus_supply_init(struct udevice *dev) { return 0; } + +#if defined(CONFIG_DM_USB) +static int dwc_vbus_supply_exit(struct udevice *dev) +{ + return 0; +} +#endif #endif
/* @@ -1269,6 +1296,11 @@ static int dwc2_usb_probe(struct udevice *dev) static int dwc2_usb_remove(struct udevice *dev) { struct dwc2_priv *priv = dev_get_priv(dev); + int ret; + + ret = dwc_vbus_supply_exit(dev); + if (ret) + return ret;
dwc2_uninit_common(priv->regs);
This patch increases timeout to 2s. It was seen on 2 USB devices (Verbatim STORE N GO 070B4AED0FB22358 and USB DISK 2.0 9000729BA41DDF40) that the request sense command takes between 1.3s and and 1.5s.
Signed-off-by: Christophe Kerello christophe.kerello@st.com Signed-off-by: Patrice Chotard patrice.chotard@st.com --- drivers/usb/host/dwc2.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/usb/host/dwc2.c b/drivers/usb/host/dwc2.c index cd70b2a195ca..596f583406e4 100644 --- a/drivers/usb/host/dwc2.c +++ b/drivers/usb/host/dwc2.c @@ -811,7 +811,7 @@ int wait_for_chhltd(struct dwc2_hc_regs *hc_regs, uint32_t *sub, u8 *toggle) uint32_t hcint, hctsiz;
ret = wait_for_bit_le32(&hc_regs->hcint, DWC2_HCINT_CHHLTD, true, - 1000, false); + 2000, false); if (ret) return ret;
Replace printf() call by dev_info() and pr_err() by dev_err()
Signed-off-by: Patrice Chotard patrice.chotard@st.com --- drivers/usb/host/dwc2.c | 20 +++++++++++--------- 1 file changed, 11 insertions(+), 9 deletions(-)
diff --git a/drivers/usb/host/dwc2.c b/drivers/usb/host/dwc2.c index 596f583406e4..03a2ed2f504b 100644 --- a/drivers/usb/host/dwc2.c +++ b/drivers/usb/host/dwc2.c @@ -114,7 +114,7 @@ static void dwc_otg_flush_tx_fifo(struct dwc2_core_regs *regs, const int num) ret = wait_for_bit_le32(®s->grstctl, DWC2_GRSTCTL_TXFFLSH, false, 1000, false); if (ret) - printf("%s: Timeout!\n", __func__); + dev_info(dev, "%s: Timeout!\n", __func__);
/* Wait for 3 PHY Clocks */ udelay(1); @@ -133,7 +133,7 @@ static void dwc_otg_flush_rx_fifo(struct dwc2_core_regs *regs) ret = wait_for_bit_le32(®s->grstctl, DWC2_GRSTCTL_RXFFLSH, false, 1000, false); if (ret) - printf("%s: Timeout!\n", __func__); + dev_info(dev, "%s: Timeout!\n", __func__);
/* Wait for 3 PHY Clocks */ udelay(1); @@ -151,14 +151,14 @@ static void dwc_otg_core_reset(struct dwc2_core_regs *regs) ret = wait_for_bit_le32(®s->grstctl, DWC2_GRSTCTL_AHBIDLE, true, 1000, false); if (ret) - printf("%s: Timeout!\n", __func__); + dev_info(dev, "%s: Timeout!\n", __func__);
/* Core Soft Reset */ writel(DWC2_GRSTCTL_CSFTRST, ®s->grstctl); ret = wait_for_bit_le32(®s->grstctl, DWC2_GRSTCTL_CSFTRST, false, 1000, false); if (ret) - printf("%s: Timeout!\n", __func__); + dev_info(dev, "%s: Timeout!\n", __func__);
/* * Wait for core to come out of reset. @@ -183,7 +183,7 @@ static int dwc_vbus_supply_init(struct udevice *dev)
ret = regulator_set_enable(priv->vbus_supply, true); if (ret) { - pr_err("Error enabling vbus supply\n"); + dev_err(dev, "Error enabling vbus supply\n"); return ret; }
@@ -297,7 +297,7 @@ static void dwc_otg_core_host_init(struct udevice *dev, ret = wait_for_bit_le32(®s->hc_regs[i].hcchar, DWC2_HCCHAR_CHEN, false, 1000, false); if (ret) - printf("%s: Timeout!\n", __func__); + dev_info("%s: Timeout!\n", __func__); }
/* Turn on the vbus power. */ @@ -1118,7 +1118,7 @@ int _submit_int_msg(struct dwc2_priv *priv, struct usb_device *dev, timeout = get_timer(0) + USB_TIMEOUT_MS(pipe); for (;;) { if (get_timer(0) > timeout) { - printf("Timeout poll on interrupt endpoint\n"); + dev_err(dev, "Timeout poll on interrupt endpoint\n"); return -ETIMEDOUT; } ret = _submit_bulk_msg(priv, dev, pipe, buffer, len); @@ -1134,11 +1134,13 @@ static int dwc2_init_common(struct udevice *dev, struct dwc2_priv *priv) int i, j;
snpsid = readl(®s->gsnpsid); - printf("Core Release: %x.%03x\n", snpsid >> 12 & 0xf, snpsid & 0xfff); + dev_info(dev, "Core Release: %x.%03x\n", + snpsid >> 12 & 0xf, snpsid & 0xfff);
if ((snpsid & DWC2_SNPSID_DEVID_MASK) != DWC2_SNPSID_DEVID_VER_2xx && (snpsid & DWC2_SNPSID_DEVID_MASK) != DWC2_SNPSID_DEVID_VER_3xx) { - printf("SNPSID invalid (not DWC2 OTG device): %08x\n", snpsid); + dev_info(dev, "SNPSID invalid (not DWC2 OTG device): %08x\n", + snpsid); return -ENODEV; }
Applied all three, thanks
