[PATCH] efi_loader: optional persistence of variables
Since be66b89da306 ("efi_loader: configuration of variables store") the choice of EFI_VARIABLE_FILE_STORE or EFI_MM_COMM_TEE is mutually-exclusive, however efi_var_to_file also allows for "neither". Set Kconfig choice optional.
Signed-off-by: Tom Saeger tom.saeger@oracle.com --- lib/efi_loader/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index e5e35fe51f65..9add2a286ff4 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -44,6 +44,7 @@ config EFI_SETUP_EARLY
choice prompt "Store for non-volatile UEFI variables" + optional default EFI_VARIABLE_FILE_STORE help Select where non-volatile UEFI variables shall be stored.
base-commit: 5f68470d69f853b1652ebe93525b60064717fe2e
- optional
Storing non-volatile variables is required by the UEFI specification.
How should a user understand that a boot option he just created vanishes upon reboot?
Please, explain your use case.
Best regards
Heinrich
- optional
bootefi ${kernel_addr}
in this case linux kernel for an Armv8 platform. This platform does not want or need any variables to persist.
bootefi eventually calls efi_var_from_file(), where *NOT* defining CONFIG_EFI_VARIABLE_FILE_STORE would allow this use case to work, otherwise it fails. This was possible before be66b89da306 ("efi_loader: configuration of variables store").
Thoughts?
--Tom
Best regards
Heinrich
- optional
Please, describe exactly what does not work. Is it building or is it running the bootefi command?
Does your system have an ESP?
Where does bootefi fail?
Best regards
Heinrich
Thoughts?
--Tom
Best regards
Heinrich
- optional
after be66b89da306 CONFIG_EFI_VARIABLE_FILE_STORE is now selected due to Kconfig choice. This is the difference.
It fails while running, but the difference is the build. I'd rather configure for the old behavior - that being return EFI_SUCCESS from efi_var_from_file() when CONFIG_EFI_VARIABLE_FILE_STORE isn't defined.
The call-stack is something like:
do_bootefi->efi_init_obj_list->efi_init_variables->efi_var_from_file
Best regards
Heinrich
Thoughts?
--Tom
Best regards
Heinrich
- optional
I think perhaps I stumbled upon an unsupported mode, which the prior Kconfig unintentionally allowed.
If so - this patch doesn't make sense.
It was however convenient for our application. (NO ESP, NO persistence)
I'll look into this - perhaps it should, despite strong desire to disallow changes to it.
When CONFIG_EFI_VARIABLE_FILE_STORE is defined, runtime complains (as it should)
"Failed to persist EFI variables"
Best regards
Heinrich
Appreciate all your feedback,
--Tom
Thoughts?
--Tom
Best regards
Heinrich
- optional
This message is written as an error log message in efi_var_to_file(). The only caller is efi_set_variable_int() which ignores the return value of efi_var_to_file().
This does not lead to a boot failure.
Which failure do you try to solve?
Best regards
Heinrich
Tom Saeger
