[U-Boot] [PATCH] arm: dts: sync dts for Allwinner H6
Sync Kernel DTS for Allwinner H6 boards.
commit <d45331b00ddb> Linux 5.3-rc4
Signed-off-by: Clément Péron peron.clem@gmail.com --- arch/arm/dts/sun50i-h6-beelink-gs1.dts | 76 ++++++++++++++++++++++++++ arch/arm/dts/sun50i-h6-pine-h64.dts | 12 ++++ arch/arm/dts/sun50i-h6.dtsi | 43 ++++++++++++++- 3 files changed, 128 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/sun50i-h6-beelink-gs1.dts b/arch/arm/dts/sun50i-h6-beelink-gs1.dts index 54b0882bed..0dc33c90dd 100644 --- a/arch/arm/dts/sun50i-h6-beelink-gs1.dts +++ b/arch/arm/dts/sun50i-h6-beelink-gs1.dts @@ -14,6 +14,7 @@ compatible = "azw,beelink-gs1", "allwinner,sun50i-h6";
aliases { + ethernet0 = &emac; serial0 = &uart0; };
@@ -21,6 +22,17 @@ stdout-path = "serial0:115200n8"; };
+ connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; + leds { compatible = "gpio-leds";
@@ -41,6 +53,40 @@ }; };
+&de { + status = "okay"; +}; + +&ehci0 { + status = "okay"; +}; + +&emac { + pinctrl-names = "default"; + pinctrl-0 = <&ext_rgmii_pins>; + phy-mode = "rgmii"; + phy-handle = <&ext_rgmii_phy>; + phy-supply = <®_aldo2>; + status = "okay"; +}; + +&hdmi { + status = "okay"; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + +&mdio { + ext_rgmii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + }; +}; + &mmc0 { vmmc-supply = <®_cldo1>; cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; @@ -57,6 +103,15 @@ status = "okay"; };
+&ohci0 { + status = "okay"; +}; + +&pio { + vcc-pd-supply = <®_cldo1>; + vcc-pg-supply = <®_aldo1>; +}; + &r_i2c { status = "okay";
@@ -177,8 +232,29 @@ }; };
+&r_pio { + /* + * PL0 and PL1 are used for PMIC I2C + * don't enable the pl-supply else + * it will fail at boot + * + * vcc-pl-supply = <®_aldo1>; + */ + vcc-pm-supply = <®_aldo1>; +}; + &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_ph_pins>; status = "okay"; }; + +&usb2otg { + dr_mode = "host"; + status = "okay"; +}; + +&usb2phy { + usb0_vbus-supply = <®_vcc5v>; + status = "okay"; +}; diff --git a/arch/arm/dts/sun50i-h6-pine-h64.dts b/arch/arm/dts/sun50i-h6-pine-h64.dts index 4802902e12..1898345183 100644 --- a/arch/arm/dts/sun50i-h6-pine-h64.dts +++ b/arch/arm/dts/sun50i-h6-pine-h64.dts @@ -127,6 +127,12 @@ status = "okay"; };
+&pio { + vcc-pc-supply = <®_bldo2>; + vcc-pd-supply = <®_cldo1>; + vcc-pg-supply = <®_aldo1>; +}; + &r_i2c { status = "okay";
@@ -243,10 +249,16 @@ pcf8563: rtc@51 { compatible = "nxp,pcf8563"; reg = <0x51>; + interrupt-parent = <&r_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; #clock-cells = <0>; }; };
+&r_pio { + vcc-pm-supply = <®_aldo1>; +}; + &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_ph_pins>; diff --git a/arch/arm/dts/sun50i-h6.dtsi b/arch/arm/dts/sun50i-h6.dtsi index e0dc4a05c1..7628a7c830 100644 --- a/arch/arm/dts/sun50i-h6.dtsi +++ b/arch/arm/dts/sun50i-h6.dtsi @@ -101,7 +101,7 @@ #size-cells = <1>; ranges;
- display-engine@1000000 { + bus@1000000 { compatible = "allwinner,sun50i-h6-de3", "allwinner,sun50i-a64-de2"; reg = <0x1000000 0x400000>; @@ -203,11 +203,32 @@ #reset-cells = <1>; };
+ dma: dma-controller@3002000 { + compatible = "allwinner,sun50i-h6-dma"; + reg = <0x03002000 0x1000>; + interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_DMA>, <&ccu CLK_MBUS_DMA>; + clock-names = "bus", "mbus"; + dma-channels = <16>; + dma-requests = <46>; + resets = <&ccu RST_BUS_DMA>; + #dma-cells = <1>; + }; + sid: sid@3006000 { compatible = "allwinner,sun50i-h6-sid"; reg = <0x03006000 0x400>; };
+ watchdog: watchdog@30090a0 { + compatible = "allwinner,sun50i-h6-wdt", + "allwinner,sun6i-a31-wdt"; + reg = <0x030090a0 0x20>; + interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>; + /* Broken on some H6 boards */ + status = "disabled"; + }; + pio: pinctrl@300b000 { compatible = "allwinner,sun50i-h6-pinctrl"; reg = <0x0300b000 0x400>; @@ -243,6 +264,15 @@ bias-pull-up; };
+ /omit-if-no-ref/ + mmc1_pins: mmc1-pins { + pins = "PG0", "PG1", "PG2", "PG3", + "PG4", "PG5"; + function = "mmc1"; + drive-strength = <30>; + bias-pull-up; + }; + mmc2_pins: mmc2-pins { pins = "PC1", "PC4", "PC5", "PC6", "PC7", "PC8", "PC9", "PC10", @@ -294,6 +324,8 @@ resets = <&ccu RST_BUS_MMC1>; reset-names = "ahb"; interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pins>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; @@ -445,7 +477,6 @@ resets = <&ccu RST_BUS_OHCI3>, <&ccu RST_BUS_EHCI3>; phys = <&usb2phy 3>; - phy-names = "usb"; status = "disabled"; };
@@ -457,7 +488,6 @@ <&ccu CLK_USB_OHCI3>; resets = <&ccu RST_BUS_OHCI3>; phys = <&usb2phy 3>; - phy-names = "usb"; status = "disabled"; };
@@ -613,6 +643,13 @@ #reset-cells = <1>; };
+ r_watchdog: watchdog@7020400 { + compatible = "allwinner,sun50i-h6-wdt", + "allwinner,sun6i-a31-wdt"; + reg = <0x07020400 0x20>; + interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>; + }; + r_intc: interrupt-controller@7021000 { compatible = "allwinner,sun50i-h6-r-intc", "allwinner,sun6i-a31-r-intc";
Hi
aliases {
connector {
type = "a";
port {
+&de {
status = "okay";
+&ehci0 {
status = "okay";
+&emac {
phy-mode = "rgmii";
status = "okay";
+&hdmi {
status = "okay";
+&hdmi_out {
+&mdio {
reg = <1>;
+&ohci0 {
status = "okay";
+&pio {
+&r_pio {
+&usb2otg {
dr_mode = "host";
status = "okay";
+&usb2phy {
status = "okay";
+&pio {
+&r_pio {
#dma-cells = <1>;
/omit-if-no-ref/
Avoid this patch the /omit-if-no-ref/ can't be interpreted on U-boot.
Regards, Clément
"PG4", "PG5";
function = "mmc1";
bias-pull-up;
-- 2.20.1
Clément Péron
