[U-Boot-Users] [PATCH] FSL: Convert board/freescale/common/Makefile to use CONFIG_
Convert the board/freescale/common/Makefile to use CONFIG_* options to select which files to conditionally compile into the board/freescale/common library rather than conditionally compiling entire files.
Supports CONFIG_FSL_PIXIS and CONFIG_FSL_DIU_FB. CONFIG_ID_EEPROM is introduced until CFG_ID_EEPROM is gone.
Signed-off-by: Jon Loeliger jdl@freescale.com --- board/freescale/common/Makefile | 12 +++++++----- board/freescale/common/fsl_diu_fb.c | 3 --- board/freescale/common/pixis.c | 4 +--- board/freescale/common/sys_eeprom.c | 2 -- board/freescale/mpc8610hpcd/Makefile | 12 ++++++------ include/configs/MPC8610HPCD.h | 3 +++ include/configs/MPC8641HPCN.h | 3 +++ 7 files changed, 20 insertions(+), 19 deletions(-)
diff --git a/board/freescale/common/Makefile b/board/freescale/common/Makefile index 9cee9f1..a060957 100644 --- a/board/freescale/common/Makefile +++ b/board/freescale/common/Makefile @@ -29,11 +29,13 @@ endif
LIB = $(obj)lib$(VENDOR).a
-COBJS := sys_eeprom.o \ - pixis.o \ - pq-mds-pib.o \ - fsl_logo_bmp.o \ - fsl_diu_fb.o +COBJS := pq-mds-pib.o + +COBJS-${CONFIG_ID_EEPROM} += sys_eeprom.o +COBJS-${CONFIG_FSL_DIU_FB} += fsl_diu_fb.o fsl_logo_bmp.o +COBJS-${CONFIG_FSL_PIXIS} += pixis.o + +COBJS += ${COBJS-y}
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/freescale/common/fsl_diu_fb.c b/board/freescale/common/fsl_diu_fb.c index 5a8576e..2336f6b 100644 --- a/board/freescale/common/fsl_diu_fb.c +++ b/board/freescale/common/fsl_diu_fb.c @@ -27,8 +27,6 @@ #include <i2c.h> #include <malloc.h>
-#ifdef CONFIG_FSL_DIU_FB - #include "fsl_diu_fb.h"
#ifdef DEBUG @@ -615,4 +613,3 @@ void fsl_diu_clear_screen(void)
memset(info->screen_base, 0, info->smem_len); } -#endif /* CONFIG_FSL_DIU_FB */ diff --git a/board/freescale/common/pixis.c b/board/freescale/common/pixis.c index 45dcf4d..00eb4a0 100644 --- a/board/freescale/common/pixis.c +++ b/board/freescale/common/pixis.c @@ -25,9 +25,8 @@ #include <common.h> #include <command.h> #include <watchdog.h> - -#ifdef CONFIG_FSL_PIXIS #include <asm/cache.h> + #include "pixis.h"
@@ -474,4 +473,3 @@ U_BOOT_CMD( " pixis_reset altbank cf <SYSCLK freq> <COREPLL ratio> <MPXPLL ratio>\n" " pixis_reset cf <SYSCLK freq> <COREPLL ratio> <MPXPLL ratio>\n" ); -#endif /* CONFIG_FSL_PIXIS */ diff --git a/board/freescale/common/sys_eeprom.c b/board/freescale/common/sys_eeprom.c index 7bc663b..bb91e67 100644 --- a/board/freescale/common/sys_eeprom.c +++ b/board/freescale/common/sys_eeprom.c @@ -27,7 +27,6 @@ #include <i2c.h> #include <linux/ctype.h>
-#ifdef CFG_ID_EEPROM typedef struct { unsigned char id[4]; /* 0x0000 - 0x0003 */ unsigned char sn[12]; /* 0x0004 - 0x000F */ @@ -253,4 +252,3 @@ int mac_read_from_eeprom(void) } return 0; } -#endif /* CFG_ID_EEPROM */ diff --git a/board/freescale/mpc8610hpcd/Makefile b/board/freescale/mpc8610hpcd/Makefile index 76087c1..12a92ae 100644 --- a/board/freescale/mpc8610hpcd/Makefile +++ b/board/freescale/mpc8610hpcd/Makefile @@ -27,14 +27,14 @@ endif
LIB = $(obj)lib$(BOARD).a
-COBJS := $(BOARD).o \ - ../common/sys_eeprom.o \ - ../common/pixis.o \ - mpc8610hpcd_diu.o \ - ../common/fsl_diu_fb.o - SOBJS := init.o
+COBJS := $(BOARD).o + +COBJS-${CONFIG_FSL_DIU_FB} += mpc8610hpcd_diu.o + +COBJS += ${COBJS-y} + SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) SOBJS := $(addprefix $(obj),$(SOBJS)) diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index f77c29d..ac4b3e1 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -141,6 +141,9 @@ #endif
#define CFG_ID_EEPROM +#ifdef CFG_ID_EEPROM +#define CONFIG_ID_EEPROM +#endif #define ID_EEPROM_ADDR 0x57
diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index 7f485c6..ab875f0 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -152,6 +152,9 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #endif
#define CFG_ID_EEPROM 1 +#ifdef CFG_ID_EEPROM +#define CONFIG_ID_EEPROM +#endif #define ID_EEPROM_ADDR 0x57
On Tue, 15 Jan 2008 15:21:09 -0600 Jon Loeliger jdl@freescale.com wrote:
<snip>
pixis.o \
pq-mds-pib.o \
fsl_logo_bmp.o \
fsl_diu_fb.o
what, no love for pq-mds-pib.o (CONFIG_PQ_MDS_PIB)?
Kim
<snip> > -COBJS := sys_eeprom.o \ > - pixis.o \ > - pq-mds-pib.o \ > - fsl_logo_bmp.o \ > - fsl_diu_fb.o > +COBJS := pq-mds-pib.o > + > +COBJS-${CONFIG_ID_EEPROM} += sys_eeprom.o > +COBJS-${CONFIG_FSL_DIU_FB} += fsl_diu_fb.o fsl_logo_bmp.o > +COBJS-${CONFIG_FSL_PIXIS} += pixis.o > + > +COBJS += ${COBJS-y}
Nit: Don't do it this way; do this instead (to match the style used in other Makefiles):
+COBJS-y := pq-mds-pib.o +COBJS-${CONFIG_ID_EEPROM} += sys_eeprom.o +COBJS-${CONFIG_FSL_DIU_FB} += fsl_diu_fb.o fsl_logo_bmp.o +COBJS-${CONFIG_FSL_PIXIS} += pixis.o
-SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c)
Kim
This SF.net email is sponsored by: Microsoft Defy all challenges. Microsoft(R) Visual Studio 2008. http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/ _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
So, are you going to submit a patch to convert them all to be like that then?
I looked at this one in drivers/net:
COBJS-y += tsec.o COBJS-y += tsi108_eth.o COBJS-y += uli526x.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS))
which clearly left COBJS around and set it up based on COBJS-y contents. So I guess my question boils down to "future intent" here. Should all the files end up on COBJS or on COBJS-y really?
Thanks, jdl
Hmm, I missed that when drivers/Makefile was split up into the subdirectories. When I first split up the COBJS, I eliminated COBJS entirely in favor of COBJS-y. It's not a big deal though.
However, I would at the very least change this:
to this:
COBJS=y += pq-mds-pib.o
So that all obj files are added in the same way.
Cheers, g.
Double nit-nit: You actually have to cover OBJS as well as SRCS here. :-)
SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) OBJS := $(addprefix $(obj),$(COBJS-y))
otherwise nothing gets built at all...
[singing] O-ho, the swell shiny new patch Is a-coming' down the 'net, Oh please let be for me! [nuff]
jdl
<snip> > -COBJS := sys_eeprom.o \ > - pixis.o \ > - pq-mds-pib.o \ > - fsl_logo_bmp.o \ > - fsl_diu_fb.o > +COBJS := pq-mds-pib.o > + > +COBJS-${CONFIG_ID_EEPROM} += sys_eeprom.o > +COBJS-${CONFIG_FSL_DIU_FB} += fsl_diu_fb.o fsl_logo_bmp.o > +COBJS-${CONFIG_FSL_PIXIS} += pixis.o > + > +COBJS += ${COBJS-y} >
Kim
Well, I was hitting the stuff that I nominally had some degree of Custodian-ship over directly.
I will take this as direct "permission" that I'll be submitting non-86xx stuff through my repository.
New patch coming!
jdl
Grant Likely
Jon Loeliger
Kim Phillips
