[U-Boot] [PATCH v1 03/24] ARMv8/fsl-lsch3: Patch cpu node properties in DT for online cores
U-Boot should only add "enable-method" and "cpu-release-address" properties to the "cpu" node of the online cores.
Signed-off-by: Arnab Basu arnab.basu@freescale.com Signed-off-by: York Sun yorksun@freescale.com ---
arch/arm/cpu/armv8/fsl-lsch3/fdt.c | 23 ++++++++++++++--------- arch/arm/cpu/armv8/fsl-lsch3/mp.c | 8 ++++++++ arch/arm/cpu/armv8/fsl-lsch3/mp.h | 1 + 3 files changed, 23 insertions(+), 9 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-lsch3/fdt.c b/arch/arm/cpu/armv8/fsl-lsch3/fdt.c index e392eb9..2287e26 100644 --- a/arch/arm/cpu/armv8/fsl-lsch3/fdt.c +++ b/arch/arm/cpu/armv8/fsl-lsch3/fdt.c @@ -16,7 +16,7 @@ void ft_fixup_cpu(void *blob) __maybe_unused u64 spin_tbl_addr = (u64)get_spin_tbl_addr(); fdt32_t *reg; int addr_cells; - u64 val; + u64 val, core_id; size_t *boot_code_size = &(__secondary_boot_code_size);
off = fdt_path_offset(blob, "/cpus"); @@ -29,15 +29,20 @@ void ft_fixup_cpu(void *blob) off = fdt_node_offset_by_prop_value(blob, -1, "device_type", "cpu", 4); while (off != -FDT_ERR_NOTFOUND) { reg = (fdt32_t *)fdt_getprop(blob, off, "reg", 0); + core_id = of_read_number(reg, addr_cells); if (reg) { - val = spin_tbl_addr; - val += id_to_core(of_read_number(reg, addr_cells)) - * SPIN_TABLE_ELEM_SIZE; - val = cpu_to_fdt64(val); - fdt_setprop_string(blob, off, "enable-method", - "spin-table"); - fdt_setprop(blob, off, "cpu-release-addr", - &val, sizeof(val)); + if (core_id == 0 || (is_core_online(core_id))) { + val = spin_tbl_addr; + val += id_to_core(core_id) * + SPIN_TABLE_ELEM_SIZE; + val = cpu_to_fdt64(val); + fdt_setprop_string(blob, off, "enable-method", + "spin-table"); + fdt_setprop(blob, off, "cpu-release-addr", + &val, sizeof(val)); + } else { + debug("skipping offline core\n"); + } } else { puts("Warning: found cpu node without reg property\n"); } diff --git a/arch/arm/cpu/armv8/fsl-lsch3/mp.c b/arch/arm/cpu/armv8/fsl-lsch3/mp.c index 94998bf..ce9c0c1 100644 --- a/arch/arm/cpu/armv8/fsl-lsch3/mp.c +++ b/arch/arm/cpu/armv8/fsl-lsch3/mp.c @@ -83,6 +83,14 @@ int is_core_valid(unsigned int core) return !!((1 << core) & cpu_mask()); }
+int is_core_online(u64 cpu_id) +{ + u64 *table; + int pos = id_to_core(cpu_id); + table = (u64 *)get_spin_tbl_addr() + pos * WORDS_PER_SPIN_TABLE_ENTRY; + return table[SPIN_TABLE_ELEM_STATUS_IDX] == 1; +} + int cpu_reset(int nr) { puts("Feature is not implemented.\n"); diff --git a/arch/arm/cpu/armv8/fsl-lsch3/mp.h b/arch/arm/cpu/armv8/fsl-lsch3/mp.h index 06ac0bc..66144d6 100644 --- a/arch/arm/cpu/armv8/fsl-lsch3/mp.h +++ b/arch/arm/cpu/armv8/fsl-lsch3/mp.h @@ -32,5 +32,6 @@ int fsl_lsch3_wake_seconday_cores(void); void *get_spin_tbl_addr(void); phys_addr_t determine_mp_bootpg(void); void secondary_boot_func(void); +int is_core_online(u64 cpu_id); #endif #endif /* _FSL_CH3_MP_H */
Flushing L3 cache in CCN-504 requries d-cache to be disabled. Using assembly function to guarantee stack is not used before flushing is completed. Timeout is needed for simualtor on which CCN-504 is not implemented. Return value can be checked for timeout situation.
Change bootm.c to disable dcache instead of simply flushing, required by flushing L3.
arch/arm/cpu/armv8/cache.S | 6 +++ arch/arm/cpu/armv8/cache_v8.c | 18 ++++--- arch/arm/cpu/armv8/fsl-lsch3/cpu.c | 53 --------------------- arch/arm/cpu/armv8/fsl-lsch3/lowlevel.S | 78 +++++++++++++++++++++++++++++++ arch/arm/include/asm/system.h | 1 + arch/arm/lib/bootm.c | 2 +- 6 files changed, 97 insertions(+), 61 deletions(-)
diff --git a/arch/arm/cpu/armv8/cache.S b/arch/arm/cpu/armv8/cache.S index 4b3ee6e..7f9e339 100644 --- a/arch/arm/cpu/armv8/cache.S +++ b/arch/arm/cpu/armv8/cache.S @@ -155,3 +155,9 @@ ENTRY(__asm_invalidate_icache_all) isb sy ret ENDPROC(__asm_invalidate_icache_all) + +ENTRY(__asm_flush_l3_cache) + mov x0, #0 /* return status as success */ + ret +ENDPROC(__asm_flush_l3_cache) + .weak __asm_flush_l3_cache diff --git a/arch/arm/cpu/armv8/cache_v8.c b/arch/arm/cpu/armv8/cache_v8.c index 9dbcdf2..c5ec529 100644 --- a/arch/arm/cpu/armv8/cache_v8.c +++ b/arch/arm/cpu/armv8/cache_v8.c @@ -73,17 +73,21 @@ void invalidate_dcache_all(void) __asm_invalidate_dcache_all(); }
-void __weak flush_l3_cache(void) -{ -} - /* - * Performs a clean & invalidation of the entire data cache at all levels + * Performs a clean & invalidation of the entire data cache at all levels. + * This function needs to be inline to avoid using stack. + * __asm_flush_l3_cache return status of timeout */ -void flush_dcache_all(void) +inline void flush_dcache_all(void) { + int ret; + __asm_flush_dcache_all(); - flush_l3_cache(); + ret = __asm_flush_l3_cache(); + if (ret) + debug("flushing dcache returns 0x%x\n", ret); + else + debug("flushing dcache successfully.\n"); }
/* diff --git a/arch/arm/cpu/armv8/fsl-lsch3/cpu.c b/arch/arm/cpu/armv8/fsl-lsch3/cpu.c index ada1690..2aaac01 100644 --- a/arch/arm/cpu/armv8/fsl-lsch3/cpu.c +++ b/arch/arm/cpu/armv8/fsl-lsch3/cpu.c @@ -243,59 +243,6 @@ int arch_cpu_init(void) }
/* - * flush_l3_cache - * Dickens L3 cache can be flushed by transitioning from FAM to SFONLY power - * state, by writing to HP-F P-state request register. - * Fixme: This function should moved to a common file if other SoCs also use - * the same Dickens. - */ -#define HNF0_PSTATE_REQ 0x04200010 -#define HNF1_PSTATE_REQ 0x04210010 -#define HNF2_PSTATE_REQ 0x04220010 -#define HNF3_PSTATE_REQ 0x04230010 -#define HNF4_PSTATE_REQ 0x04240010 -#define HNF5_PSTATE_REQ 0x04250010 -#define HNF6_PSTATE_REQ 0x04260010 -#define HNF7_PSTATE_REQ 0x04270010 -#define HNFPSTAT_MASK (0xFFFFFFFFFFFFFFFC) -#define HNFPSTAT_FAM 0x3 -#define HNFPSTAT_SFONLY 0x01 - -static void hnf_pstate_req(u64 *ptr, u64 state) -{ - int timeout = 1000; - out_le64(ptr, (in_le64(ptr) & HNFPSTAT_MASK) | (state & 0x3)); - ptr++; - /* checking if the transition is completed */ - while (timeout > 0) { - if (((in_le64(ptr) & 0x0c) >> 2) == (state & 0x3)) - break; - udelay(100); - timeout--; - } -} - -void flush_l3_cache(void) -{ - hnf_pstate_req((u64 *)HNF0_PSTATE_REQ, HNFPSTAT_SFONLY); - hnf_pstate_req((u64 *)HNF1_PSTATE_REQ, HNFPSTAT_SFONLY); - hnf_pstate_req((u64 *)HNF2_PSTATE_REQ, HNFPSTAT_SFONLY); - hnf_pstate_req((u64 *)HNF3_PSTATE_REQ, HNFPSTAT_SFONLY); - hnf_pstate_req((u64 *)HNF4_PSTATE_REQ, HNFPSTAT_SFONLY); - hnf_pstate_req((u64 *)HNF5_PSTATE_REQ, HNFPSTAT_SFONLY); - hnf_pstate_req((u64 *)HNF6_PSTATE_REQ, HNFPSTAT_SFONLY); - hnf_pstate_req((u64 *)HNF7_PSTATE_REQ, HNFPSTAT_SFONLY); - hnf_pstate_req((u64 *)HNF0_PSTATE_REQ, HNFPSTAT_FAM); - hnf_pstate_req((u64 *)HNF1_PSTATE_REQ, HNFPSTAT_FAM); - hnf_pstate_req((u64 *)HNF2_PSTATE_REQ, HNFPSTAT_FAM); - hnf_pstate_req((u64 *)HNF3_PSTATE_REQ, HNFPSTAT_FAM); - hnf_pstate_req((u64 *)HNF4_PSTATE_REQ, HNFPSTAT_FAM); - hnf_pstate_req((u64 *)HNF5_PSTATE_REQ, HNFPSTAT_FAM); - hnf_pstate_req((u64 *)HNF6_PSTATE_REQ, HNFPSTAT_FAM); - hnf_pstate_req((u64 *)HNF7_PSTATE_REQ, HNFPSTAT_FAM); -} - -/* * This function is called from lib/board.c. * It recreates MMU table in main memory. MMU and d-cache are enabled earlier. * There is no need to disable d-cache for this operation. diff --git a/arch/arm/cpu/armv8/fsl-lsch3/lowlevel.S b/arch/arm/cpu/armv8/fsl-lsch3/lowlevel.S index c283787..886576e 100644 --- a/arch/arm/cpu/armv8/fsl-lsch3/lowlevel.S +++ b/arch/arm/cpu/armv8/fsl-lsch3/lowlevel.S @@ -100,6 +100,84 @@ ENTRY(lowlevel_init) ret ENDPROC(lowlevel_init)
+hnf_pstate_poll: + /* x0 has the desired status, return 0 for success, 1 for timeout + * clobber x1, x2, x3, x4, x6, x7 + */ + mov x1, x0 + mov x7, #0 /* flag for timeout */ + mrs x3, cntpct_el0 /* read timer */ + add x3, x3, #1200 /* timeout after 100 microseconds */ + mov x0, #0x18 + movk x0, #0x420, lsl #16 /* HNF0_PSTATE_STATUS */ + mov w6, #8 /* HN-F node count */ +1: + ldr x2, [x0] + cmp x2, x1 /* check status */ + b.eq 2f + mrs x4, cntpct_el0 + cmp x4, x3 + b.ls 1b + mov x7, #1 /* timeout */ + b 3f +2: + add x0, x0, #0x10000 /* move to next node */ + subs w6, w6, #1 + cbnz w6, 1b +3: + mov x0, x7 + ret + +hnf_set_pstate: + /* x0 has the desired state, clobber x1, x2, x6 */ + mov x1, x0 + /* power state to SFONLY */ + mov w6, #8 /* HN-F node count */ + mov x0, #0x10 + movk x0, #0x420, lsl #16 /* HNF0_PSTATE_REQ */ +1: /* set pstate to sfonly */ + ldr x2, [x0] + and x2, x2, #0xfffffffffffffffc /* & HNFPSTAT_MASK */ + orr x2, x2, x1 + str x2, [x0] + add x0, x0, #0x10000 /* move to next node */ + subs w6, w6, #1 + cbnz w6, 1b + + ret + +ENTRY(__asm_flush_l3_cache) + /* + * Return status in x0 + * success 0 + * tmeout 1 for setting SFONLY, 2 for FAM, 3 for both + */ + mov x29, lr + mov x8, #0 + + dsb sy + mov x0, #0x1 /* HNFPSTAT_SFONLY */ + bl hnf_set_pstate + + mov x0, #0x4 /* SFONLY status */ + bl hnf_pstate_poll + cbz x0, 1f + mov x8, #1 /* timeout */ +1: + dsb sy + mov x0, #0x3 /* HNFPSTAT_FAM */ + bl hnf_set_pstate + + mov x0, #0xc /* FAM status */ + bl hnf_pstate_poll + cbz x0, 1f + add x8, x8, #0x2 +1: + mov x0, x8 + mov lr, x29 + ret +ENDPROC(__asm_flush_l3_cache) + /* Keep literals not used by the secondary boot code outside it */ .ltorg
diff --git a/arch/arm/include/asm/system.h b/arch/arm/include/asm/system.h index 89f2294..7c4624a 100644 --- a/arch/arm/include/asm/system.h +++ b/arch/arm/include/asm/system.h @@ -70,6 +70,7 @@ void __asm_invalidate_dcache_all(void); void __asm_flush_dcache_range(u64 start, u64 end); void __asm_invalidate_tlb_all(void); void __asm_invalidate_icache_all(void); +int __asm_flush_l3_cache(void);
void armv8_switch_to_el2(void); void armv8_switch_to_el1(void); diff --git a/arch/arm/lib/bootm.c b/arch/arm/lib/bootm.c index a7f7c67..c59ae43 100644 --- a/arch/arm/lib/bootm.c +++ b/arch/arm/lib/bootm.c @@ -191,7 +191,7 @@ __weak void setup_board_tags(struct tag **in_params) {} static void do_nonsec_virt_switch(void) { smp_kick_all_cpus(); - flush_dcache_all(); /* flush cache before swtiching to EL2 */ + dcache_disable(); /* flush cache before swtiching to EL2 */ armv8_switch_to_el2(); #ifdef CONFIG_ARMV8_SWITCH_TO_EL1 armv8_switch_to_el1();
LS2085A and its variants can have up to four clusters. It is safe to enable timebase for all even some may be disabled.
board/freescale/ls2085a/ls2085a.c | 11 +++++++++-- 1 file changed, 9 insertions(+), 2 deletions(-)
diff --git a/board/freescale/ls2085a/ls2085a.c b/board/freescale/ls2085a/ls2085a.c index 163a4c4..ee75d1b 100644 --- a/board/freescale/ls2085a/ls2085a.c +++ b/board/freescale/ls2085a/ls2085a.c @@ -59,8 +59,15 @@ int timer_init(void) u32 __iomem *cntcr = (u32 *)CONFIG_SYS_FSL_TIMER_ADDR; u32 __iomem *cltbenr = (u32 *)CONFIG_SYS_FSL_PMU_CLTBENR;
- out_le32(cltbenr, 0x1); /* enable cluster0 timebase */ - out_le32(cntcr, 0x1); /* enable clock for timer */ + /* Enable timebase for all clusters. + * It is safe to do so even some clusters are not enabled. + */ + out_le32(cltbenr, 0xf); + + /* Enable clock for timer + * This is a global setting. + */ + out_le32(cntcr, 0x1);
return 0; }
This patch adds the fdt-fixup logic for the clock frequency of the NS16550A related device tree nodes.
Signed-off-by: Bhupesh Sharma bhupesh.sharma@freescale.com ---
arch/arm/cpu/armv8/fsl-lsch3/fdt.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-lsch3/fdt.c b/arch/arm/cpu/armv8/fsl-lsch3/fdt.c index 2287e26..7eb9b6a 100644 --- a/arch/arm/cpu/armv8/fsl-lsch3/fdt.c +++ b/arch/arm/cpu/armv8/fsl-lsch3/fdt.c @@ -60,4 +60,9 @@ void ft_cpu_setup(void *blob, bd_t *bd) #ifdef CONFIG_MP ft_fixup_cpu(blob); #endif + +#ifdef CONFIG_SYS_NS16550 + do_fixup_by_compat_u32(blob, "ns16550", + "clock-frequency", CONFIG_SYS_NS16550_CLK, 1); +#endif }
On ZeBu emulator, CAS to preamble overrides need to be set to satisfy the timing. This only impact platforms with CONFIG_EMU.
These should be set before MEM_EN is set.
drivers/ddr/fsl/ctrl_regs.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/drivers/ddr/fsl/ctrl_regs.c b/drivers/ddr/fsl/ctrl_regs.c index 03d7ff1..b3477f0 100644 --- a/drivers/ddr/fsl/ctrl_regs.c +++ b/drivers/ddr/fsl/ctrl_regs.c @@ -2372,7 +2372,11 @@ compute_fsl_memctl_config_regs(const memctl_options_t *popts, #ifdef CONFIG_SYS_FSL_DDR_EMU /* disble DDR training for emulator */ ddr->debug[2] = 0x00000400; - ddr->debug[4] = 0xff800000; + ddr->debug[4] = 0xff800800; + ddr->debug[5] = 0x08000800; + ddr->debug[6] = 0x08000800; + ddr->debug[7] = 0x08000800; + ddr->debug[8] = 0x08000800; #endif #ifdef CONFIG_SYS_FSL_ERRATUM_A004508 if ((ip_rev >= 0x40000) && (ip_rev < 0x40400))
Add bit opearation accessors to DDR driver for little- and big-endian.
include/fsl_ddr.h | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/include/fsl_ddr.h b/include/fsl_ddr.h index 675557a..3286c95 100644 --- a/include/fsl_ddr.h +++ b/include/fsl_ddr.h @@ -23,9 +23,15 @@ #ifdef CONFIG_SYS_FSL_DDR_LE #define ddr_in32(a) in_le32(a) #define ddr_out32(a, v) out_le32(a, v) +#define ddr_setbits32(a, v) setbits_le32(a, v) +#define ddr_clrbits32(a, v) clrbits_le32(a, v) +#define ddr_clrsetbits32(a, clear, set) clrsetbits_le32(a, clear, set) #else #define ddr_in32(a) in_be32(a) #define ddr_out32(a, v) out_be32(a, v) +#define ddr_setbits32(a, v) setbits_be32(a, v) +#define ddr_clrbits32(a, v) clrbits_be32(a, v) +#define ddr_clrsetbits32(a, clear, set) clrsetbits_be32(a, clear, set) #endif
#define _DDR_ADDR CONFIG_SYS_FSL_DDR_ADDR
Erratum A008336 requires setting EDDRTQCR1[2] in DDRC DCSR space for 64-bit DDR controllers.
arch/arm/include/asm/arch-fsl-lsch3/config.h | 5 +++++ drivers/ddr/fsl/fsl_ddr_gen4.c | 22 ++++++++++++++++++++++ 2 files changed, 27 insertions(+)
diff --git a/arch/arm/include/asm/arch-fsl-lsch3/config.h b/arch/arm/include/asm/arch-fsl-lsch3/config.h index d4f688b..256adb0 100644 --- a/arch/arm/include/asm/arch-fsl-lsch3/config.h +++ b/arch/arm/include/asm/arch-fsl-lsch3/config.h @@ -30,6 +30,11 @@ #define CONFIG_SYS_FSL_PMU_CLTBENR (CONFIG_SYS_FSL_PMU_ADDR + \ 0x18A0)
+#define CONFIG_SYS_FSL_DCSR_DDR_ADDR 0x70012c000ULL +#define CONFIG_SYS_FSL_DCSR_DDR2_ADDR 0x70012d000ULL +#define CONFIG_SYS_FSL_DCSR_DDR3_ADDR 0x700132000ULL +#define CONFIG_SYS_FSL_DCSR_DDR4_ADDR 0x700133000ULL + #define I2C1_BASE_ADDR (CONFIG_SYS_IMMR + 0x01000000) #define I2C2_BASE_ADDR (CONFIG_SYS_IMMR + 0x01010000) #define I2C3_BASE_ADDR (CONFIG_SYS_IMMR + 0x01020000) diff --git a/drivers/ddr/fsl/fsl_ddr_gen4.c b/drivers/ddr/fsl/fsl_ddr_gen4.c index a3c01e7..480f384 100644 --- a/drivers/ddr/fsl/fsl_ddr_gen4.c +++ b/drivers/ddr/fsl/fsl_ddr_gen4.c @@ -32,24 +32,39 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, u32 temp_sdram_cfg; u32 total_gb_size_per_controller; int timeout; +#ifdef CONFIG_SYS_FSL_ERRATUM_A008336 + u32 *eddrtqcr1; +#endif
switch (ctrl_num) { case 0: ddr = (void *)CONFIG_SYS_FSL_DDR_ADDR; +#ifdef CONFIG_SYS_FSL_ERRATUM_A008336 + eddrtqcr1 = (void *)CONFIG_SYS_FSL_DCSR_DDR_ADDR + 0x800; +#endif break; #if defined(CONFIG_SYS_FSL_DDR2_ADDR) && (CONFIG_NUM_DDR_CONTROLLERS > 1) case 1: ddr = (void *)CONFIG_SYS_FSL_DDR2_ADDR; +#ifdef CONFIG_SYS_FSL_ERRATUM_A008336 + eddrtqcr1 = (void *)CONFIG_SYS_FSL_DCSR_DDR2_ADDR + 0x800; +#endif break; #endif #if defined(CONFIG_SYS_FSL_DDR3_ADDR) && (CONFIG_NUM_DDR_CONTROLLERS > 2) case 2: ddr = (void *)CONFIG_SYS_FSL_DDR3_ADDR; +#ifdef CONFIG_SYS_FSL_ERRATUM_A008336 + eddrtqcr1 = (void *)CONFIG_SYS_FSL_DCSR_DDR3_ADDR + 0x800; +#endif break; #endif #if defined(CONFIG_SYS_FSL_DDR4_ADDR) && (CONFIG_NUM_DDR_CONTROLLERS > 3) case 3: ddr = (void *)CONFIG_SYS_FSL_DDR4_ADDR; +#ifdef CONFIG_SYS_FSL_ERRATUM_A008336 + eddrtqcr1 = (void *)CONFIG_SYS_FSL_DCSR_DDR4_ADDR + 0x800; +#endif break; #endif default: @@ -60,6 +75,13 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, if (step == 2) goto step2;
+#ifdef CONFIG_SYS_FSL_ERRATUM_A008336 +#ifdef CONFIG_LS2085A + /* A008336 only applies to general DDR controllers */ + if ((ctrl_num == 0) || (ctrl_num == 1)) +#endif + ddr_out32(eddrtqcr1, 0x63b30002); +#endif if (regs->ddr_eor) ddr_out32(&ddr->eor, regs->ddr_eor);
Erratum A008514 workround requires writing register eddrtqcr1 with value 0x63b20002.
drivers/ddr/fsl/fsl_ddr_gen4.c | 22 +++++++++++++++++----- 1 file changed, 17 insertions(+), 5 deletions(-)
diff --git a/drivers/ddr/fsl/fsl_ddr_gen4.c b/drivers/ddr/fsl/fsl_ddr_gen4.c index 480f384..f44c155 100644 --- a/drivers/ddr/fsl/fsl_ddr_gen4.c +++ b/drivers/ddr/fsl/fsl_ddr_gen4.c @@ -32,21 +32,24 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, u32 temp_sdram_cfg; u32 total_gb_size_per_controller; int timeout; -#ifdef CONFIG_SYS_FSL_ERRATUM_A008336 +#if defined(CONFIG_SYS_FSL_ERRATUM_A008336) || \ + defined(CONFIG_SYS_FSL_ERRATUM_A008514) u32 *eddrtqcr1; #endif
switch (ctrl_num) { case 0: ddr = (void *)CONFIG_SYS_FSL_DDR_ADDR; -#ifdef CONFIG_SYS_FSL_ERRATUM_A008336 +#if defined(CONFIG_SYS_FSL_ERRATUM_A008336) || \ + defined(CONFIG_SYS_FSL_ERRATUM_A008514) eddrtqcr1 = (void *)CONFIG_SYS_FSL_DCSR_DDR_ADDR + 0x800; #endif break; #if defined(CONFIG_SYS_FSL_DDR2_ADDR) && (CONFIG_NUM_DDR_CONTROLLERS > 1) case 1: ddr = (void *)CONFIG_SYS_FSL_DDR2_ADDR; -#ifdef CONFIG_SYS_FSL_ERRATUM_A008336 +#if defined(CONFIG_SYS_FSL_ERRATUM_A008336) || \ + defined(CONFIG_SYS_FSL_ERRATUM_A008514) eddrtqcr1 = (void *)CONFIG_SYS_FSL_DCSR_DDR2_ADDR + 0x800; #endif break; @@ -54,7 +57,8 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, #if defined(CONFIG_SYS_FSL_DDR3_ADDR) && (CONFIG_NUM_DDR_CONTROLLERS > 2) case 2: ddr = (void *)CONFIG_SYS_FSL_DDR3_ADDR; -#ifdef CONFIG_SYS_FSL_ERRATUM_A008336 +#if defined(CONFIG_SYS_FSL_ERRATUM_A008336) || \ + defined(CONFIG_SYS_FSL_ERRATUM_A008514) eddrtqcr1 = (void *)CONFIG_SYS_FSL_DCSR_DDR3_ADDR + 0x800; #endif break; @@ -62,7 +66,8 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, #if defined(CONFIG_SYS_FSL_DDR4_ADDR) && (CONFIG_NUM_DDR_CONTROLLERS > 3) case 3: ddr = (void *)CONFIG_SYS_FSL_DDR4_ADDR; -#ifdef CONFIG_SYS_FSL_ERRATUM_A008336 +#if defined(CONFIG_SYS_FSL_ERRATUM_A008336) || \ + defined(CONFIG_SYS_FSL_ERRATUM_A008514) eddrtqcr1 = (void *)CONFIG_SYS_FSL_DCSR_DDR4_ADDR + 0x800; #endif break; @@ -82,6 +87,13 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, #endif ddr_out32(eddrtqcr1, 0x63b30002); #endif +#ifdef CONFIG_SYS_FSL_ERRATUM_A008514 +#ifdef CONFIG_LS2085A + /* A008514 only applies to DP-DDR controler */ + if (ctrl_num == 2) +#endif + ddr_out32(eddrtqcr1, 0x63b20002); +#endif if (regs->ddr_eor) ddr_out32(&ddr->eor, regs->ddr_eor);
FSL-LSCH3 platforms can have multiple DDR clocks. LS2085A has one clock for general DDR controlers, and another clock for DP-DDR. DDR driver needs to change to support multiple clocks.
arch/arm/cpu/armv8/fsl-lsch3/cpu.c | 1 + arch/arm/cpu/armv8/fsl-lsch3/speed.c | 16 ++++++++++++++-- arch/arm/include/asm/arch-fsl-lsch3/immap_lsch3.h | 3 +++ arch/arm/include/asm/global_data.h | 3 +++ 4 files changed, 21 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-lsch3/cpu.c b/arch/arm/cpu/armv8/fsl-lsch3/cpu.c index 2aaac01..42cee65 100644 --- a/arch/arm/cpu/armv8/fsl-lsch3/cpu.c +++ b/arch/arm/cpu/armv8/fsl-lsch3/cpu.c @@ -367,6 +367,7 @@ int print_cpuinfo(void) printf("\n Bus: %-4s MHz ", strmhz(buf, sysinfo.freq_systembus)); printf("DDR: %-4s MHz", strmhz(buf, sysinfo.freq_ddrbus)); + printf(" DP-DDR: %-4s MHz", strmhz(buf, sysinfo.freq_ddrbus2)); puts("\n");
return 0; diff --git a/arch/arm/cpu/armv8/fsl-lsch3/speed.c b/arch/arm/cpu/armv8/fsl-lsch3/speed.c index dc4a34b..72cd999 100644 --- a/arch/arm/cpu/armv8/fsl-lsch3/speed.c +++ b/arch/arm/cpu/armv8/fsl-lsch3/speed.c @@ -77,8 +77,10 @@ void get_sys_info(struct sys_info *sys_info) sys_info->freq_systembus = sysclk; #ifdef CONFIG_DDR_CLK_FREQ sys_info->freq_ddrbus = CONFIG_DDR_CLK_FREQ; + sys_info->freq_ddrbus2 = CONFIG_DDR_CLK_FREQ; #else sys_info->freq_ddrbus = sysclk; + sys_info->freq_ddrbus2 = sysclk; #endif
sys_info->freq_systembus *= (in_le32(&gur->rcwsr[0]) >> @@ -87,6 +89,9 @@ void get_sys_info(struct sys_info *sys_info) sys_info->freq_ddrbus *= (in_le32(&gur->rcwsr[0]) >> FSL_CHASSIS3_RCWSR0_MEM_PLL_RAT_SHIFT) & FSL_CHASSIS3_RCWSR0_MEM_PLL_RAT_MASK; + sys_info->freq_ddrbus2 *= (in_le32(&gur->rcwsr[0]) >> + FSL_CHASSIS3_RCWSR0_MEM2_PLL_RAT_SHIFT) & + FSL_CHASSIS3_RCWSR0_MEM2_PLL_RAT_MASK;
for (i = 0; i < CONFIG_SYS_FSL_NUM_CC_PLLS; i++) { /* @@ -129,7 +134,7 @@ int get_clocks(void) gd->cpu_clk = sys_info.freq_processor[0]; gd->bus_clk = sys_info.freq_systembus; gd->mem_clk = sys_info.freq_ddrbus; - + gd->arch.mem2_clk = sys_info.freq_ddrbus2; #if defined(CONFIG_FSL_ESDHC) gd->arch.sdhc_clk = gd->bus_clk / 2; #endif /* defined(CONFIG_FSL_ESDHC) */ @@ -156,11 +161,18 @@ ulong get_bus_freq(ulong dummy) * get_ddr_freq * return ddr bus freq in Hz *********************************************/ -ulong get_ddr_freq(ulong dummy) +ulong get_ddr_freq(ulong ctrl_num) { if (!gd->mem_clk) get_clocks();
+ /* + * DDR controller 0 & 1 are on memory complex 0 + * DDR controler 2 is on memory complext 1 + */ + if (ctrl_num >= 2) + return gd->arch.mem2_clk; + return gd->mem_clk; }
diff --git a/arch/arm/include/asm/arch-fsl-lsch3/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-lsch3/immap_lsch3.h index ee1d651..dd11ef7 100644 --- a/arch/arm/include/asm/arch-fsl-lsch3/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-lsch3/immap_lsch3.h @@ -15,6 +15,7 @@ struct sys_info { unsigned long freq_processor[CONFIG_MAX_CPUS]; unsigned long freq_systembus; unsigned long freq_ddrbus; + unsigned long freq_ddrbus2; unsigned long freq_localbus; unsigned long freq_qe; #ifdef CONFIG_SYS_DPAA_FMAN @@ -60,6 +61,8 @@ struct ccsr_gur { #define FSL_CHASSIS3_RCWSR0_SYS_PLL_RAT_MASK 0x1f #define FSL_CHASSIS3_RCWSR0_MEM_PLL_RAT_SHIFT 10 #define FSL_CHASSIS3_RCWSR0_MEM_PLL_RAT_MASK 0x3f +#define FSL_CHASSIS3_RCWSR0_MEM2_PLL_RAT_SHIFT 18 +#define FSL_CHASSIS3_RCWSR0_MEM2_PLL_RAT_MASK 0x3f u8 res_180[0x200-0x180]; u32 scratchrw[32]; /* Scratch Read/Write */ u8 res_280[0x300-0x280]; diff --git a/arch/arm/include/asm/global_data.h b/arch/arm/include/asm/global_data.h index 438f128..bb24f33 100644 --- a/arch/arm/include/asm/global_data.h +++ b/arch/arm/include/asm/global_data.h @@ -48,6 +48,9 @@ struct arch_global_data { #ifdef CONFIG_OMAP struct omap_boot_parameters omap_boot_params; #endif +#ifdef CONFIG_FSL_LSCH3 + unsigned long mem2_clk; +#endif };
#include <asm-generic/global_data.h>
Controller number is passed for function calls to support individual DDR clock, depending on SoC implementation. It is backward compatible with exising platforms. Multiple clocks have been verifyed on LS2085A emulator.
drivers/ddr/fsl/arm_ddr_gen3.c | 2 +- drivers/ddr/fsl/ctrl_regs.c | 208 +++++++++++++++++-------------- drivers/ddr/fsl/ddr1_dimm_params.c | 18 +-- drivers/ddr/fsl/ddr2_dimm_params.c | 12 +- drivers/ddr/fsl/ddr3_dimm_params.c | 8 +- drivers/ddr/fsl/ddr4_dimm_params.c | 8 +- drivers/ddr/fsl/fsl_ddr_gen4.c | 2 +- drivers/ddr/fsl/lc_common_dimm_params.c | 27 ++-- drivers/ddr/fsl/main.c | 25 ++-- drivers/ddr/fsl/mpc85xx_ddr_gen3.c | 4 +- drivers/ddr/fsl/options.c | 6 +- drivers/ddr/fsl/util.c | 12 +- include/fsl_ddr.h | 15 ++- include/fsl_ddr_dimm_params.h | 2 +- 14 files changed, 190 insertions(+), 159 deletions(-)
diff --git a/drivers/ddr/fsl/arm_ddr_gen3.c b/drivers/ddr/fsl/arm_ddr_gen3.c index c139da6..7160da4 100644 --- a/drivers/ddr/fsl/arm_ddr_gen3.c +++ b/drivers/ddr/fsl/arm_ddr_gen3.c @@ -222,7 +222,7 @@ step2: bus_width = 3 - ((ddr_in32(&ddr->sdram_cfg) & SDRAM_CFG_DBW_MASK) >> SDRAM_CFG_DBW_SHIFT); timeout = ((total_gb_size_per_controller << (6 - bus_width)) * 100 / - (get_ddr_freq(0) >> 20)) << 1; + (get_ddr_freq(ctrl_num) >> 20)) << 1; total_gb_size_per_controller >>= 4; /* shift down to gb size */ debug("total %d GB\n", total_gb_size_per_controller); debug("Need to wait up to %d * 10ms\n", timeout); diff --git a/drivers/ddr/fsl/ctrl_regs.c b/drivers/ddr/fsl/ctrl_regs.c index b3477f0..713c3ed 100644 --- a/drivers/ddr/fsl/ctrl_regs.c +++ b/drivers/ddr/fsl/ctrl_regs.c @@ -17,8 +17,6 @@ #include <fsl_immap.h> #include <asm/io.h>
-unsigned int picos_to_mclk(unsigned int picos); - /* * Determine Rtt value. * @@ -78,10 +76,11 @@ static inline int fsl_ddr_get_rtt(void) * 16 for <= 2933MT/s * 18 for higher */ -static inline unsigned int compute_cas_write_latency(void) +static inline unsigned int compute_cas_write_latency( + const unsigned int ctrl_num) { unsigned int cwl; - const unsigned int mclk_ps = get_memory_clk_period_ps(); + const unsigned int mclk_ps = get_memory_clk_period_ps(ctrl_num); if (mclk_ps >= 1250) cwl = 9; else if (mclk_ps >= 1070) @@ -111,10 +110,11 @@ static inline unsigned int compute_cas_write_latency(void) * 11 if 0.935ns > tCK >= 0.833ns * 12 if 0.833ns > tCK >= 0.75ns */ -static inline unsigned int compute_cas_write_latency(void) +static inline unsigned int compute_cas_write_latency( + const unsigned int ctrl_num) { unsigned int cwl; - const unsigned int mclk_ps = get_memory_clk_period_ps(); + const unsigned int mclk_ps = get_memory_clk_period_ps(ctrl_num);
if (mclk_ps >= 2500) cwl = 5; @@ -287,7 +287,8 @@ static inline int avoid_odt_overlap(const dimm_params_t *dimm_params) * Avoid writing for DDR I. The new PQ38 DDR controller * dreams up non-zero default values to be backwards compatible. */ -static void set_timing_cfg_0(fsl_ddr_cfg_regs_t *ddr, +static void set_timing_cfg_0(const unsigned int ctrl_num, + fsl_ddr_cfg_regs_t *ddr, const memctl_options_t *popts, const dimm_params_t *dimm_params) { @@ -306,7 +307,7 @@ static void set_timing_cfg_0(fsl_ddr_cfg_regs_t *ddr, /* Mode register set cycle time (tMRD). */ unsigned char tmrd_mclk; #if defined(CONFIG_SYS_FSL_DDR4) || defined(CONFIG_SYS_FSL_DDR3) - const unsigned int mclk_ps = get_memory_clk_period_ps(); + const unsigned int mclk_ps = get_memory_clk_period_ps(ctrl_num); #endif
#ifdef CONFIG_SYS_FSL_DDR4 @@ -314,15 +315,15 @@ static void set_timing_cfg_0(fsl_ddr_cfg_regs_t *ddr, int txp = max((int)mclk_ps * 4, 6000); /* unit=ps */ trwt_mclk = 2; twrt_mclk = 1; - act_pd_exit_mclk = picos_to_mclk(txp); + act_pd_exit_mclk = picos_to_mclk(ctrl_num, txp); pre_pd_exit_mclk = act_pd_exit_mclk; /* * MRS_CYC = max(tMRD, tMOD) * tMRD = 8nCK, tMOD = max(24nCK, 15ns) */ - tmrd_mclk = max(24U, picos_to_mclk(15000)); + tmrd_mclk = max(24U, picos_to_mclk(ctrl_num, 15000)); #elif defined(CONFIG_SYS_FSL_DDR3) - unsigned int data_rate = get_ddr_freq(0); + unsigned int data_rate = get_ddr_freq(ctrl_num); int txp; unsigned int ip_rev; int odt_overlap; @@ -344,7 +345,8 @@ static void set_timing_cfg_0(fsl_ddr_cfg_regs_t *ddr, * tMRD = 4nCK (8nCK for RDIMM) * tMOD = max(12nCK, 15ns) */ - tmrd_mclk = max((unsigned int)12, picos_to_mclk(15000)); + tmrd_mclk = max((unsigned int)12, + picos_to_mclk(ctrl_num, 15000)); } else { /* * MRS_CYC = tMRD @@ -388,7 +390,7 @@ static void set_timing_cfg_0(fsl_ddr_cfg_regs_t *ddr, taxpd_mclk = 1; } else { /* act_pd_exit_mclk = tXARD, see above */ - act_pd_exit_mclk = picos_to_mclk(txp); + act_pd_exit_mclk = picos_to_mclk(ctrl_num, txp); /* Mode register MR0[A12] is '1' - fast exit */ pre_pd_exit_mclk = act_pd_exit_mclk; taxpd_mclk = 1; @@ -424,11 +426,12 @@ static void set_timing_cfg_0(fsl_ddr_cfg_regs_t *ddr, #endif /* !defined(CONFIG_SYS_FSL_DDR1) */
/* DDR SDRAM Timing Configuration 3 (TIMING_CFG_3) */ -static void set_timing_cfg_3(fsl_ddr_cfg_regs_t *ddr, - const memctl_options_t *popts, - const common_timing_params_t *common_dimm, - unsigned int cas_latency, - unsigned int additive_latency) +static void set_timing_cfg_3(const unsigned int ctrl_num, + fsl_ddr_cfg_regs_t *ddr, + const memctl_options_t *popts, + const common_timing_params_t *common_dimm, + unsigned int cas_latency, + unsigned int additive_latency) { /* Extended precharge to activate interval (tRP) */ unsigned int ext_pretoact = 0; @@ -447,18 +450,18 @@ static void set_timing_cfg_3(fsl_ddr_cfg_regs_t *ddr, /* Control Adjust */ unsigned int cntl_adj = 0;
- ext_pretoact = picos_to_mclk(common_dimm->trp_ps) >> 4; - ext_acttopre = picos_to_mclk(common_dimm->tras_ps) >> 4; - ext_acttorw = picos_to_mclk(common_dimm->trcd_ps) >> 4; + ext_pretoact = picos_to_mclk(ctrl_num, common_dimm->trp_ps) >> 4; + ext_acttopre = picos_to_mclk(ctrl_num, common_dimm->tras_ps) >> 4; + ext_acttorw = picos_to_mclk(ctrl_num, common_dimm->trcd_ps) >> 4; ext_caslat = (2 * cas_latency - 1) >> 4; ext_add_lat = additive_latency >> 4; #ifdef CONFIG_SYS_FSL_DDR4 - ext_refrec = (picos_to_mclk(common_dimm->trfc1_ps) - 8) >> 4; + ext_refrec = (picos_to_mclk(ctrl_num, common_dimm->trfc1_ps) - 8) >> 4; #else - ext_refrec = (picos_to_mclk(common_dimm->trfc_ps) - 8) >> 4; + ext_refrec = (picos_to_mclk(ctrl_num, common_dimm->trfc_ps) - 8) >> 4; /* ext_wrrec only deals with 16 clock and above, or 14 with OTF */ #endif - ext_wrrec = (picos_to_mclk(common_dimm->twr_ps) + + ext_wrrec = (picos_to_mclk(ctrl_num, common_dimm->twr_ps) + (popts->otf_burst_chop_en ? 2 : 0)) >> 4;
ddr->timing_cfg_3 = (0 @@ -475,10 +478,11 @@ static void set_timing_cfg_3(fsl_ddr_cfg_regs_t *ddr, }
/* DDR SDRAM Timing Configuration 1 (TIMING_CFG_1) */ -static void set_timing_cfg_1(fsl_ddr_cfg_regs_t *ddr, - const memctl_options_t *popts, - const common_timing_params_t *common_dimm, - unsigned int cas_latency) +static void set_timing_cfg_1(const unsigned int ctrl_num, + fsl_ddr_cfg_regs_t *ddr, + const memctl_options_t *popts, + const common_timing_params_t *common_dimm, + unsigned int cas_latency) { /* Precharge-to-activate interval (tRP) */ unsigned char pretoact_mclk; @@ -510,9 +514,9 @@ static void set_timing_cfg_1(fsl_ddr_cfg_regs_t *ddr, 1, 2, 3, 4, 5, 6, 7, 8, 10, 10, 12, 12, 14, 14, 0, 0}; #endif
- pretoact_mclk = picos_to_mclk(common_dimm->trp_ps); - acttopre_mclk = picos_to_mclk(common_dimm->tras_ps); - acttorw_mclk = picos_to_mclk(common_dimm->trcd_ps); + pretoact_mclk = picos_to_mclk(ctrl_num, common_dimm->trp_ps); + acttopre_mclk = picos_to_mclk(ctrl_num, common_dimm->tras_ps); + acttorw_mclk = picos_to_mclk(ctrl_num, common_dimm->trcd_ps);
/* * Translate CAS Latency to a DDR controller field value: @@ -547,19 +551,19 @@ static void set_timing_cfg_1(fsl_ddr_cfg_regs_t *ddr, #endif
#ifdef CONFIG_SYS_FSL_DDR4 - refrec_ctrl = picos_to_mclk(common_dimm->trfc1_ps) - 8; - wrrec_mclk = picos_to_mclk(common_dimm->twr_ps); - acttoact_mclk = max(picos_to_mclk(common_dimm->trrds_ps), 4U); - wrtord_mclk = max(2U, picos_to_mclk(2500)); + refrec_ctrl = picos_to_mclk(ctrl_num, common_dimm->trfc1_ps) - 8; + wrrec_mclk = picos_to_mclk(ctrl_num, common_dimm->twr_ps); + acttoact_mclk = max(picos_to_mclk(ctrl_num, common_dimm->trrds_ps), 4U); + wrtord_mclk = max(2U, picos_to_mclk(ctrl_num, 2500)); if ((wrrec_mclk < 1) || (wrrec_mclk > 24)) printf("Error: WRREC doesn't support %d clocks\n", wrrec_mclk); else wrrec_mclk = wrrec_table[wrrec_mclk - 1]; #else - refrec_ctrl = picos_to_mclk(common_dimm->trfc_ps) - 8; - wrrec_mclk = picos_to_mclk(common_dimm->twr_ps); - acttoact_mclk = picos_to_mclk(common_dimm->trrd_ps); - wrtord_mclk = picos_to_mclk(common_dimm->twtr_ps); + refrec_ctrl = picos_to_mclk(ctrl_num, common_dimm->trfc_ps) - 8; + wrrec_mclk = picos_to_mclk(ctrl_num, common_dimm->twr_ps); + acttoact_mclk = picos_to_mclk(ctrl_num, common_dimm->trrd_ps); + wrtord_mclk = picos_to_mclk(ctrl_num, common_dimm->twtr_ps); if ((wrrec_mclk < 1) || (wrrec_mclk > 16)) printf("Error: WRREC doesn't support %d clocks\n", wrrec_mclk); else @@ -602,11 +606,12 @@ static void set_timing_cfg_1(fsl_ddr_cfg_regs_t *ddr, }
/* DDR SDRAM Timing Configuration 2 (TIMING_CFG_2) */ -static void set_timing_cfg_2(fsl_ddr_cfg_regs_t *ddr, - const memctl_options_t *popts, - const common_timing_params_t *common_dimm, - unsigned int cas_latency, - unsigned int additive_latency) +static void set_timing_cfg_2(const unsigned int ctrl_num, + fsl_ddr_cfg_regs_t *ddr, + const memctl_options_t *popts, + const common_timing_params_t *common_dimm, + unsigned int cas_latency, + unsigned int additive_latency) { /* Additive latency */ unsigned char add_lat_mclk; @@ -623,7 +628,7 @@ static void set_timing_cfg_2(fsl_ddr_cfg_regs_t *ddr, /* Window for four activates (tFAW) */ unsigned short four_act; #ifdef CONFIG_SYS_FSL_DDR3 - const unsigned int mclk_ps = get_memory_clk_period_ps(); + const unsigned int mclk_ps = get_memory_clk_period_ps(ctrl_num); #endif
/* FIXME add check that this must be less than acttorw_mclk */ @@ -641,13 +646,13 @@ static void set_timing_cfg_2(fsl_ddr_cfg_regs_t *ddr, #elif defined(CONFIG_SYS_FSL_DDR2) wr_lat = cas_latency - 1; #else - wr_lat = compute_cas_write_latency(); + wr_lat = compute_cas_write_latency(ctrl_num); #endif
#ifdef CONFIG_SYS_FSL_DDR4 - rd_to_pre = picos_to_mclk(7500); + rd_to_pre = picos_to_mclk(ctrl_num, 7500); #else - rd_to_pre = picos_to_mclk(common_dimm->trtp_ps); + rd_to_pre = picos_to_mclk(ctrl_num, common_dimm->trtp_ps); #endif /* * JEDEC has some min requirements for tRTP @@ -665,19 +670,20 @@ static void set_timing_cfg_2(fsl_ddr_cfg_regs_t *ddr, wr_data_delay = popts->write_data_delay; #ifdef CONFIG_SYS_FSL_DDR4 cpo = 0; - cke_pls = max(3U, picos_to_mclk(5000)); + cke_pls = max(3U, picos_to_mclk(ctrl_num, 5000)); #elif defined(CONFIG_SYS_FSL_DDR3) /* * cke pulse = max(3nCK, 7.5ns) for DDR3-800 * max(3nCK, 5.625ns) for DDR3-1066, 1333 * max(3nCK, 5ns) for DDR3-1600, 1866, 2133 */ - cke_pls = max(3U, picos_to_mclk(mclk_ps > 1870 ? 7500 : - (mclk_ps > 1245 ? 5625 : 5000))); + cke_pls = max(3U, picos_to_mclk(ctrl_num, mclk_ps > 1870 ? 7500 : + (mclk_ps > 1245 ? 5625 : 5000))); #else cke_pls = FSL_DDR_MIN_TCKE_PULSE_WIDTH_DDR; #endif - four_act = picos_to_mclk(popts->tfaw_window_four_activates_ps); + four_act = picos_to_mclk(ctrl_num, + popts->tfaw_window_four_activates_ps);
ddr->timing_cfg_2 = (0 | ((add_lat_mclk & 0xf) << 28) @@ -818,7 +824,8 @@ static void set_ddr_sdram_cfg(fsl_ddr_cfg_regs_t *ddr, }
/* DDR SDRAM control configuration 2 (DDR_SDRAM_CFG_2) */ -static void set_ddr_sdram_cfg_2(fsl_ddr_cfg_regs_t *ddr, +static void set_ddr_sdram_cfg_2(const unsigned int ctrl_num, + fsl_ddr_cfg_regs_t *ddr, const memctl_options_t *popts, const unsigned int unq_mrs_en) { @@ -865,7 +872,7 @@ static void set_ddr_sdram_cfg_2(fsl_ddr_cfg_regs_t *ddr, #endif
#if (CONFIG_SYS_FSL_DDR_VER >= FSL_DDR_VER_4_7) - slow = get_ddr_freq(0) < 1249000000; + slow = get_ddr_freq(ctrl_num) < 1249000000; #endif
if (popts->registered_dimm_en) { @@ -915,7 +922,8 @@ static void set_ddr_sdram_cfg_2(fsl_ddr_cfg_regs_t *ddr,
#ifdef CONFIG_SYS_FSL_DDR4 /* DDR SDRAM Mode configuration 2 (DDR_SDRAM_MODE_2) */ -static void set_ddr_sdram_mode_2(fsl_ddr_cfg_regs_t *ddr, +static void set_ddr_sdram_mode_2(const unsigned int ctrl_num, + fsl_ddr_cfg_regs_t *ddr, const memctl_options_t *popts, const common_timing_params_t *common_dimm, const unsigned int unq_mrs_en) @@ -926,10 +934,10 @@ static void set_ddr_sdram_mode_2(fsl_ddr_cfg_regs_t *ddr, unsigned int wr_crc = 0; /* Disable */ unsigned int rtt_wr = 0; /* Rtt_WR - dynamic ODT off */ unsigned int srt = 0; /* self-refresh temerature, normal range */ - unsigned int cwl = compute_cas_write_latency() - 9; + unsigned int cwl = compute_cas_write_latency(ctrl_num) - 9; unsigned int mpr = 0; /* serial */ unsigned int wc_lat; - const unsigned int mclk_ps = get_memory_clk_period_ps(); + const unsigned int mclk_ps = get_memory_clk_period_ps(ctrl_num);
if (popts->rtt_override) rtt_wr = popts->rtt_wr_override_value; @@ -1002,7 +1010,8 @@ static void set_ddr_sdram_mode_2(fsl_ddr_cfg_regs_t *ddr, } #elif defined(CONFIG_SYS_FSL_DDR3) /* DDR SDRAM Mode configuration 2 (DDR_SDRAM_MODE_2) */ -static void set_ddr_sdram_mode_2(fsl_ddr_cfg_regs_t *ddr, +static void set_ddr_sdram_mode_2(const unsigned int ctrl_num, + fsl_ddr_cfg_regs_t *ddr, const memctl_options_t *popts, const common_timing_params_t *common_dimm, const unsigned int unq_mrs_en) @@ -1013,7 +1022,7 @@ static void set_ddr_sdram_mode_2(fsl_ddr_cfg_regs_t *ddr, unsigned int rtt_wr = 0; /* Rtt_WR - dynamic ODT off */ unsigned int srt = 0; /* self-refresh temerature, normal range */ unsigned int asr = 0; /* auto self-refresh disable */ - unsigned int cwl = compute_cas_write_latency() - 5; + unsigned int cwl = compute_cas_write_latency(ctrl_num) - 5; unsigned int pasr = 0; /* partial array self refresh disable */
if (popts->rtt_override) @@ -1077,7 +1086,8 @@ static void set_ddr_sdram_mode_2(fsl_ddr_cfg_regs_t *ddr,
#else /* for DDR2 and DDR1 */ /* DDR SDRAM Mode configuration 2 (DDR_SDRAM_MODE_2) */ -static void set_ddr_sdram_mode_2(fsl_ddr_cfg_regs_t *ddr, +static void set_ddr_sdram_mode_2(const unsigned int ctrl_num, + fsl_ddr_cfg_regs_t *ddr, const memctl_options_t *popts, const common_timing_params_t *common_dimm, const unsigned int unq_mrs_en) @@ -1144,7 +1154,8 @@ static void set_ddr_sdram_mode_9(fsl_ddr_cfg_regs_t *ddr, }
/* DDR SDRAM Mode configuration 10 (DDR_SDRAM_MODE_10) */ -static void set_ddr_sdram_mode_10(fsl_ddr_cfg_regs_t *ddr, +static void set_ddr_sdram_mode_10(const unsigned int ctrl_num, + fsl_ddr_cfg_regs_t *ddr, const memctl_options_t *popts, const common_timing_params_t *common_dimm, const unsigned int unq_mrs_en) @@ -1152,7 +1163,7 @@ static void set_ddr_sdram_mode_10(fsl_ddr_cfg_regs_t *ddr, int i; unsigned short esdmode6 = 0; /* Extended SDRAM mode 6 */ unsigned short esdmode7 = 0; /* Extended SDRAM mode 7 */ - unsigned int tccdl_min = picos_to_mclk(common_dimm->tccdl_ps); + unsigned int tccdl_min = picos_to_mclk(ctrl_num, common_dimm->tccdl_ps);
esdmode6 = ((tccdl_min - 4) & 0x7) << 10;
@@ -1196,14 +1207,15 @@ static void set_ddr_sdram_mode_10(fsl_ddr_cfg_regs_t *ddr, #endif
/* DDR SDRAM Interval Configuration (DDR_SDRAM_INTERVAL) */ -static void set_ddr_sdram_interval(fsl_ddr_cfg_regs_t *ddr, - const memctl_options_t *popts, - const common_timing_params_t *common_dimm) +static void set_ddr_sdram_interval(const unsigned int ctrl_num, + fsl_ddr_cfg_regs_t *ddr, + const memctl_options_t *popts, + const common_timing_params_t *common_dimm) { unsigned int refint; /* Refresh interval */ unsigned int bstopre; /* Precharge interval */
- refint = picos_to_mclk(common_dimm->refresh_rate_ps); + refint = picos_to_mclk(ctrl_num, common_dimm->refresh_rate_ps);
bstopre = popts->bstopre;
@@ -1217,7 +1229,8 @@ static void set_ddr_sdram_interval(fsl_ddr_cfg_regs_t *ddr,
#ifdef CONFIG_SYS_FSL_DDR4 /* DDR SDRAM Mode configuration set (DDR_SDRAM_MODE) */ -static void set_ddr_sdram_mode(fsl_ddr_cfg_regs_t *ddr, +static void set_ddr_sdram_mode(const unsigned int ctrl_num, + fsl_ddr_cfg_regs_t *ddr, const memctl_options_t *popts, const common_timing_params_t *common_dimm, unsigned int cas_latency, @@ -1292,7 +1305,7 @@ static void set_ddr_sdram_mode(fsl_ddr_cfg_regs_t *ddr, * 1=fast exit DLL on (tXP) */
- wr_mclk = picos_to_mclk(common_dimm->twr_ps); + wr_mclk = picos_to_mclk(ctrl_num, common_dimm->twr_ps); if (wr_mclk <= 24) { wr = wr_table[wr_mclk - 10]; } else { @@ -1387,7 +1400,8 @@ static void set_ddr_sdram_mode(fsl_ddr_cfg_regs_t *ddr,
#elif defined(CONFIG_SYS_FSL_DDR3) /* DDR SDRAM Mode configuration set (DDR_SDRAM_MODE) */ -static void set_ddr_sdram_mode(fsl_ddr_cfg_regs_t *ddr, +static void set_ddr_sdram_mode(const unsigned int ctrl_num, + fsl_ddr_cfg_regs_t *ddr, const memctl_options_t *popts, const common_timing_params_t *common_dimm, unsigned int cas_latency, @@ -1466,7 +1480,7 @@ static void set_ddr_sdram_mode(fsl_ddr_cfg_regs_t *ddr, */ dll_on = 1;
- wr_mclk = picos_to_mclk(common_dimm->twr_ps); + wr_mclk = picos_to_mclk(ctrl_num, common_dimm->twr_ps); if (wr_mclk <= 16) { wr = wr_table[wr_mclk - 5]; } else { @@ -1582,7 +1596,8 @@ static void set_ddr_sdram_mode(fsl_ddr_cfg_regs_t *ddr, #else /* !CONFIG_SYS_FSL_DDR3 */
/* DDR SDRAM Mode configuration set (DDR_SDRAM_MODE) */ -static void set_ddr_sdram_mode(fsl_ddr_cfg_regs_t *ddr, +static void set_ddr_sdram_mode(const unsigned int ctrl_num, + fsl_ddr_cfg_regs_t *ddr, const memctl_options_t *popts, const common_timing_params_t *common_dimm, unsigned int cas_latency, @@ -1654,7 +1669,7 @@ static void set_ddr_sdram_mode(fsl_ddr_cfg_regs_t *ddr, #if defined(CONFIG_SYS_FSL_DDR1) wr = 0; /* Historical */ #elif defined(CONFIG_SYS_FSL_DDR2) - wr = picos_to_mclk(common_dimm->twr_ps); + wr = picos_to_mclk(ctrl_num, common_dimm->twr_ps); #endif dll_res = 0; mode = 0; @@ -1842,15 +1857,16 @@ static void set_timing_cfg_6(fsl_ddr_cfg_regs_t *ddr) debug("FSLDDR: timing_cfg_6 = 0x%08x\n", ddr->timing_cfg_6); }
-static void set_timing_cfg_7(fsl_ddr_cfg_regs_t *ddr, - const common_timing_params_t *common_dimm) +static void set_timing_cfg_7(const unsigned int ctrl_num, + fsl_ddr_cfg_regs_t *ddr, + const common_timing_params_t *common_dimm) { unsigned int txpr, tcksre, tcksrx; unsigned int cke_rst, cksre, cksrx, par_lat, cs_to_cmd;
- txpr = max(5U, picos_to_mclk(common_dimm->trfc1_ps + 10000)); - tcksre = max(5U, picos_to_mclk(10000)); - tcksrx = max(5U, picos_to_mclk(10000)); + txpr = max(5U, picos_to_mclk(ctrl_num, common_dimm->trfc1_ps + 10000)); + tcksre = max(5U, picos_to_mclk(ctrl_num, 10000)); + tcksrx = max(5U, picos_to_mclk(ctrl_num, 10000)); par_lat = 0; cs_to_cmd = 0;
@@ -1883,14 +1899,15 @@ static void set_timing_cfg_7(fsl_ddr_cfg_regs_t *ddr, debug("FSLDDR: timing_cfg_7 = 0x%08x\n", ddr->timing_cfg_7); }
-static void set_timing_cfg_8(fsl_ddr_cfg_regs_t *ddr, +static void set_timing_cfg_8(const unsigned int ctrl_num, + fsl_ddr_cfg_regs_t *ddr, const memctl_options_t *popts, const common_timing_params_t *common_dimm, unsigned int cas_latency) { unsigned int rwt_bg, wrt_bg, rrt_bg, wwt_bg; unsigned int acttoact_bg, wrtord_bg, pre_all_rec; - unsigned int tccdl = picos_to_mclk(common_dimm->tccdl_ps); + unsigned int tccdl = picos_to_mclk(ctrl_num, common_dimm->tccdl_ps); unsigned int wr_lat = ((ddr->timing_cfg_2 & 0x00780000) >> 19) + ((ddr->timing_cfg_2 & 0x00040000) >> 14);
@@ -1914,8 +1931,8 @@ static void set_timing_cfg_8(fsl_ddr_cfg_regs_t *ddr, wwt_bg = tccdl - 4; }
- acttoact_bg = picos_to_mclk(common_dimm->trrdl_ps); - wrtord_bg = max(4U, picos_to_mclk(7500)); + acttoact_bg = picos_to_mclk(ctrl_num, common_dimm->trrdl_ps); + wrtord_bg = max(4U, picos_to_mclk(ctrl_num, 7500)); if (popts->otf_burst_chop_en) wrtord_bg += 2;
@@ -2147,7 +2164,8 @@ check_fsl_memctl_config_regs(const fsl_ddr_cfg_regs_t *ddr) }
unsigned int -compute_fsl_memctl_config_regs(const memctl_options_t *popts, +compute_fsl_memctl_config_regs(const unsigned int ctrl_num, + const memctl_options_t *popts, fsl_ddr_cfg_regs_t *ddr, const common_timing_params_t *common_dimm, const dimm_params_t *dimm_params, @@ -2319,14 +2337,14 @@ compute_fsl_memctl_config_regs(const memctl_options_t *popts, set_ddr_eor(ddr, popts);
#if !defined(CONFIG_SYS_FSL_DDR1) - set_timing_cfg_0(ddr, popts, dimm_params); + set_timing_cfg_0(ctrl_num, ddr, popts, dimm_params); #endif
- set_timing_cfg_3(ddr, popts, common_dimm, cas_latency, + set_timing_cfg_3(ctrl_num, ddr, popts, common_dimm, cas_latency, additive_latency); - set_timing_cfg_1(ddr, popts, common_dimm, cas_latency); - set_timing_cfg_2(ddr, popts, common_dimm, - cas_latency, additive_latency); + set_timing_cfg_1(ctrl_num, ddr, popts, common_dimm, cas_latency); + set_timing_cfg_2(ctrl_num, ddr, popts, common_dimm, + cas_latency, additive_latency);
set_ddr_cdr1(ddr, popts); set_ddr_cdr2(ddr, popts); @@ -2338,15 +2356,15 @@ compute_fsl_memctl_config_regs(const memctl_options_t *popts, if ((ip_rev > 0x40700) && (popts->cswl_override != 0)) ddr->debug[18] = popts->cswl_override;
- set_ddr_sdram_cfg_2(ddr, popts, unq_mrs_en); - set_ddr_sdram_mode(ddr, popts, common_dimm, - cas_latency, additive_latency, unq_mrs_en); - set_ddr_sdram_mode_2(ddr, popts, common_dimm, unq_mrs_en); + set_ddr_sdram_cfg_2(ctrl_num, ddr, popts, unq_mrs_en); + set_ddr_sdram_mode(ctrl_num, ddr, popts, common_dimm, + cas_latency, additive_latency, unq_mrs_en); + set_ddr_sdram_mode_2(ctrl_num, ddr, popts, common_dimm, unq_mrs_en); #ifdef CONFIG_SYS_FSL_DDR4 set_ddr_sdram_mode_9(ddr, popts, common_dimm, unq_mrs_en); - set_ddr_sdram_mode_10(ddr, popts, common_dimm, unq_mrs_en); + set_ddr_sdram_mode_10(ctrl_num, ddr, popts, common_dimm, unq_mrs_en); #endif - set_ddr_sdram_interval(ddr, popts, common_dimm); + set_ddr_sdram_interval(ctrl_num, ddr, popts, common_dimm); set_ddr_data_init(ddr); set_ddr_sdram_clk_cntl(ddr, popts); set_ddr_init_addr(ddr); @@ -2356,8 +2374,8 @@ compute_fsl_memctl_config_regs(const memctl_options_t *popts, #ifdef CONFIG_SYS_FSL_DDR4 set_ddr_sdram_cfg_3(ddr, popts); set_timing_cfg_6(ddr); - set_timing_cfg_7(ddr, common_dimm); - set_timing_cfg_8(ddr, popts, common_dimm, cas_latency); + set_timing_cfg_7(ctrl_num, ddr, common_dimm); + set_timing_cfg_8(ctrl_num, ddr, popts, common_dimm, cas_latency); set_timing_cfg_9(ddr); set_ddr_dq_mapping(ddr, dimm_params); #endif diff --git a/drivers/ddr/fsl/ddr1_dimm_params.c b/drivers/ddr/fsl/ddr1_dimm_params.c index 7df27b9..7f1c3af 100644 --- a/drivers/ddr/fsl/ddr1_dimm_params.c +++ b/drivers/ddr/fsl/ddr1_dimm_params.c @@ -228,10 +228,10 @@ compute_derated_DDR1_CAS_latency(unsigned int mclk_ps) * * FIXME: use #define for the retvals */ -unsigned int -ddr_compute_dimm_parameters(const ddr1_spd_eeprom_t *spd, - dimm_params_t *pdimm, - unsigned int dimm_number) +unsigned int ddr_compute_dimm_parameters(const unsigned int ctrl_num, + const ddr1_spd_eeprom_t *spd, + dimm_params_t *pdimm, + unsigned int dimm_number) { unsigned int retval;
@@ -311,16 +311,16 @@ ddr_compute_dimm_parameters(const ddr1_spd_eeprom_t *spd, & ~(1 << pdimm->caslat_x_minus_1));
/* Compute CAS latencies below that defined by SPD */ - pdimm->caslat_lowest_derated - = compute_derated_DDR1_CAS_latency(get_memory_clk_period_ps()); + pdimm->caslat_lowest_derated = compute_derated_DDR1_CAS_latency( + get_memory_clk_period_ps(ctrl_num));
/* Compute timing parameters */ pdimm->trcd_ps = spd->trcd * 250; pdimm->trp_ps = spd->trp * 250; pdimm->tras_ps = spd->tras * 1000;
- pdimm->twr_ps = mclk_to_picos(3); - pdimm->twtr_ps = mclk_to_picos(1); + pdimm->twr_ps = mclk_to_picos(ctrl_num, 3); + pdimm->twtr_ps = mclk_to_picos(ctrl_num, 1); pdimm->trfc_ps = compute_trfc_ps_from_spd(0, spd->trfc);
pdimm->trrd_ps = spd->trrd * 250; @@ -335,7 +335,7 @@ ddr_compute_dimm_parameters(const ddr1_spd_eeprom_t *spd, pdimm->tdh_ps = convert_bcd_hundredths_to_cycle_time_ps(spd->data_hold);
- pdimm->trtp_ps = mclk_to_picos(2); /* By the book. */ + pdimm->trtp_ps = mclk_to_picos(ctrl_num, 2); /* By the book. */ pdimm->tdqsq_max_ps = spd->tdqsq * 10; pdimm->tqhs_ps = spd->tqhs * 10;
diff --git a/drivers/ddr/fsl/ddr2_dimm_params.c b/drivers/ddr/fsl/ddr2_dimm_params.c index d865df7..49cc1a0 100644 --- a/drivers/ddr/fsl/ddr2_dimm_params.c +++ b/drivers/ddr/fsl/ddr2_dimm_params.c @@ -211,10 +211,10 @@ compute_derated_DDR2_CAS_latency(unsigned int mclk_ps) * * FIXME: use #define for the retvals */ -unsigned int -ddr_compute_dimm_parameters(const ddr2_spd_eeprom_t *spd, - dimm_params_t *pdimm, - unsigned int dimm_number) +unsigned int ddr_compute_dimm_parameters(const unsigned int ctrl_num, + const ddr2_spd_eeprom_t *spd, + dimm_params_t *pdimm, + unsigned int dimm_number) { unsigned int retval;
@@ -310,8 +310,8 @@ ddr_compute_dimm_parameters(const ddr2_spd_eeprom_t *spd, & ~(1 << pdimm->caslat_x_minus_1));
/* Compute CAS latencies below that defined by SPD */ - pdimm->caslat_lowest_derated - = compute_derated_DDR2_CAS_latency(get_memory_clk_period_ps()); + pdimm->caslat_lowest_derated = compute_derated_DDR2_CAS_latency( + get_memory_clk_period_ps(ctrl_num));
/* Compute timing parameters */ pdimm->trcd_ps = spd->trcd * 250; diff --git a/drivers/ddr/fsl/ddr3_dimm_params.c b/drivers/ddr/fsl/ddr3_dimm_params.c index a4b8c10..6917715 100644 --- a/drivers/ddr/fsl/ddr3_dimm_params.c +++ b/drivers/ddr/fsl/ddr3_dimm_params.c @@ -83,10 +83,10 @@ compute_ranksize(const ddr3_spd_eeprom_t *spd) * Writes the results to the dimm_params_t structure pointed by pdimm. * */ -unsigned int -ddr_compute_dimm_parameters(const ddr3_spd_eeprom_t *spd, - dimm_params_t *pdimm, - unsigned int dimm_number) +unsigned int ddr_compute_dimm_parameters(const unsigned int ctrl_num, + const ddr3_spd_eeprom_t *spd, + dimm_params_t *pdimm, + unsigned int dimm_number) { unsigned int retval; unsigned int mtb_ps; diff --git a/drivers/ddr/fsl/ddr4_dimm_params.c b/drivers/ddr/fsl/ddr4_dimm_params.c index aaddc8f..bbfb4ee 100644 --- a/drivers/ddr/fsl/ddr4_dimm_params.c +++ b/drivers/ddr/fsl/ddr4_dimm_params.c @@ -119,10 +119,10 @@ compute_ranksize(const struct ddr4_spd_eeprom_s *spd) * Writes the results to the dimm_params_t structure pointed by pdimm. * */ -unsigned int -ddr_compute_dimm_parameters(const generic_spd_eeprom_t *spd, - dimm_params_t *pdimm, - unsigned int dimm_number) +unsigned int ddr_compute_dimm_parameters(const unsigned int ctrl_num, + const generic_spd_eeprom_t *spd, + dimm_params_t *pdimm, + unsigned int dimm_number) { unsigned int retval; int i; diff --git a/drivers/ddr/fsl/fsl_ddr_gen4.c b/drivers/ddr/fsl/fsl_ddr_gen4.c index f44c155..7f34d3d 100644 --- a/drivers/ddr/fsl/fsl_ddr_gen4.c +++ b/drivers/ddr/fsl/fsl_ddr_gen4.c @@ -279,7 +279,7 @@ step2: bus_width = 3 - ((ddr_in32(&ddr->sdram_cfg) & SDRAM_CFG_DBW_MASK) >> SDRAM_CFG_DBW_SHIFT); timeout = ((total_gb_size_per_controller << (6 - bus_width)) * 100 / - (get_ddr_freq(0) >> 20)) << 2; + (get_ddr_freq(ctrl_num) >> 20)) << 2; total_gb_size_per_controller >>= 4; /* shift down to gb size */ debug("total %d GB\n", total_gb_size_per_controller); debug("Need to wait up to %d * 10ms\n", timeout); diff --git a/drivers/ddr/fsl/lc_common_dimm_params.c b/drivers/ddr/fsl/lc_common_dimm_params.c index 73db444..b295344 100644 --- a/drivers/ddr/fsl/lc_common_dimm_params.c +++ b/drivers/ddr/fsl/lc_common_dimm_params.c @@ -13,7 +13,8 @@
#if defined(CONFIG_SYS_FSL_DDR3) || defined(CONFIG_SYS_FSL_DDR4) static unsigned int -compute_cas_latency(const dimm_params_t *dimm_params, +compute_cas_latency(const unsigned int ctrl_num, + const dimm_params_t *dimm_params, common_timing_params_t *outpdimm, unsigned int number_of_dimms) { @@ -22,7 +23,7 @@ compute_cas_latency(const dimm_params_t *dimm_params, unsigned int caslat_actual; unsigned int retry = 16; unsigned int tmp; - const unsigned int mclk_ps = get_memory_clk_period_ps(); + const unsigned int mclk_ps = get_memory_clk_period_ps(ctrl_num); #ifdef CONFIG_SYS_FSL_DDR3 const unsigned int taamax = 20000; #else @@ -72,12 +73,13 @@ compute_cas_latency(const dimm_params_t *dimm_params, } #else /* for DDR1 and DDR2 */ static unsigned int -compute_cas_latency(const dimm_params_t *dimm_params, +compute_cas_latency(const unsigned int ctrl_num, + const dimm_params_t *dimm_params, common_timing_params_t *outpdimm, unsigned int number_of_dimms) { int i; - const unsigned int mclk_ps = get_memory_clk_period_ps(); + const unsigned int mclk_ps = get_memory_clk_period_ps(ctrl_num); unsigned int lowest_good_caslat; unsigned int not_ok; unsigned int temp1, temp2; @@ -212,7 +214,8 @@ compute_cas_latency(const dimm_params_t *dimm_params, * by dimm_params. */ unsigned int -compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params, +compute_lowest_common_dimm_parameters(const unsigned int ctrl_num, + const dimm_params_t *dimm_params, common_timing_params_t *outpdimm, const unsigned int number_of_dimms) { @@ -442,7 +445,8 @@ compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params, printf("ERROR: Mix different RDIMM detected!\n");
/* calculate cas latency for all DDR types */ - if (compute_cas_latency(dimm_params, outpdimm, number_of_dimms)) + if (compute_cas_latency(ctrl_num, dimm_params, + outpdimm, number_of_dimms)) return 1;
/* Determine if all DIMMs ECC capable. */ @@ -518,11 +522,12 @@ compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params,
#if defined(CONFIG_SYS_FSL_DDR2) if ((outpdimm->lowest_common_spd_caslat < 4) && - (picos_to_mclk(trcd_ps) > outpdimm->lowest_common_spd_caslat)) { - additive_latency = picos_to_mclk(trcd_ps) - + (picos_to_mclk(ctrl_num, trcd_ps) > + outpdimm->lowest_common_spd_caslat)) { + additive_latency = picos_to_mclk(ctrl_num, trcd_ps) - outpdimm->lowest_common_spd_caslat; - if (mclk_to_picos(additive_latency) > trcd_ps) { - additive_latency = picos_to_mclk(trcd_ps); + if (mclk_to_picos(ctrl_num, additive_latency) > trcd_ps) { + additive_latency = picos_to_mclk(ctrl_num, trcd_ps); debug("setting additive_latency to %u because it was " " greater than tRCD_ps\n", additive_latency); } @@ -534,7 +539,7 @@ compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params, * * AL <= tRCD(min) */ - if (mclk_to_picos(additive_latency) > trcd_ps) { + if (mclk_to_picos(ctrl_num, additive_latency) > trcd_ps) { printf("Error: invalid additive latency exceeds tRCD(min).\n"); return 1; } diff --git a/drivers/ddr/fsl/main.c b/drivers/ddr/fsl/main.c index 6f291eb..f49939b 100644 --- a/drivers/ddr/fsl/main.c +++ b/drivers/ddr/fsl/main.c @@ -450,7 +450,8 @@ fsl_ddr_compute(fsl_ddr_info_t *pinfo, unsigned int start_step, &(pinfo->spd_installed_dimms[i][j]); dimm_params_t *pdimm = &(pinfo->dimm_params[i][j]); - retval = compute_dimm_parameters(spd, pdimm, i); + retval = compute_dimm_parameters( + i, spd, pdimm, j); #ifdef CONFIG_SYS_DDR_RAW_TIMING if (!i && !j && retval) { printf("SPD error on controller %d! " @@ -507,10 +508,11 @@ fsl_ddr_compute(fsl_ddr_info_t *pinfo, unsigned int start_step, for (i = first_ctrl; i <= last_ctrl; i++) { debug("Computing lowest common DIMM" " parameters for memctl=%u\n", i); - compute_lowest_common_dimm_parameters( - pinfo->dimm_params[i], - &timing_params[i], - CONFIG_DIMM_SLOTS_PER_CTLR); + compute_lowest_common_dimm_parameters + (i, + pinfo->dimm_params[i], + &timing_params[i], + CONFIG_DIMM_SLOTS_PER_CTLR); }
case STEP_GATHER_OPTS: @@ -562,12 +564,13 @@ fsl_ddr_compute(fsl_ddr_info_t *pinfo, unsigned int start_step, continue; }
- compute_fsl_memctl_config_regs( - &pinfo->memctl_opts[i], - &ddr_reg[i], &timing_params[i], - pinfo->dimm_params[i], - dbw_capacity_adjust[i], - size_only); + compute_fsl_memctl_config_regs + (i, + &pinfo->memctl_opts[i], + &ddr_reg[i], &timing_params[i], + pinfo->dimm_params[i], + dbw_capacity_adjust[i], + size_only); }
default: diff --git a/drivers/ddr/fsl/mpc85xx_ddr_gen3.c b/drivers/ddr/fsl/mpc85xx_ddr_gen3.c index 8f4d01a..6752d4d 100644 --- a/drivers/ddr/fsl/mpc85xx_ddr_gen3.c +++ b/drivers/ddr/fsl/mpc85xx_ddr_gen3.c @@ -426,7 +426,7 @@ step2: bus_width = 3 - ((ddr->sdram_cfg & SDRAM_CFG_DBW_MASK) >> SDRAM_CFG_DBW_SHIFT); timeout = ((total_gb_size_per_controller << (6 - bus_width)) * 100 / - (get_ddr_freq(0) >> 20)) << 1; + (get_ddr_freq(ctrl_num) >> 20)) << 1; #ifdef CONFIG_SYS_FSL_ERRATUM_DDR111_DDR134 timeout_save = timeout; #endif @@ -538,12 +538,14 @@ step2: case 1: out_be32(&ddr->cs1_bnds, regs->cs[csn].bnds); break; +#if CONFIG_CHIP_SELECTS_PER_CTRL > 2 case 2: out_be32(&ddr->cs2_bnds, regs->cs[csn].bnds); break; case 3: out_be32(&ddr->cs3_bnds, regs->cs[csn].bnds); break; +#endif } clrbits_be32(&ddr->sdram_cfg, 0x2); } diff --git a/drivers/ddr/fsl/options.c b/drivers/ddr/fsl/options.c index 6d098d1..5beb11b 100644 --- a/drivers/ddr/fsl/options.c +++ b/drivers/ddr/fsl/options.c @@ -732,7 +732,7 @@ unsigned int populate_memctl_options(int all_dimms_registered, #endif
/* Global Timing Parameters. */ - debug("mclk_ps = %u ps\n", get_memory_clk_period_ps()); + debug("mclk_ps = %u ps\n", get_memory_clk_period_ps(ctrl_num));
/* Pick a caslat override. */ popts->cas_latency_override = 0; @@ -785,7 +785,7 @@ unsigned int populate_memctl_options(int all_dimms_registered, * FIXME: width, was considering looking at pdimm->primary_sdram_width */ #if defined(CONFIG_SYS_FSL_DDR1) - popts->tfaw_window_four_activates_ps = mclk_to_picos(1); + popts->tfaw_window_four_activates_ps = mclk_to_picos(ctrl_num, 1);
#elif defined(CONFIG_SYS_FSL_DDR2) /* @@ -1036,7 +1036,7 @@ done: if (pdimm[0].n_ranks == 4) popts->quad_rank_present = 1;
- ddr_freq = get_ddr_freq(0) / 1000000; + ddr_freq = get_ddr_freq(ctrl_num) / 1000000; if (popts->registered_dimm_en) { popts->rcw_override = 1; popts->rcw_1 = 0x000a5a00; diff --git a/drivers/ddr/fsl/util.c b/drivers/ddr/fsl/util.c index 58b519b..ad569de 100644 --- a/drivers/ddr/fsl/util.c +++ b/drivers/ddr/fsl/util.c @@ -43,9 +43,9 @@ u32 fsl_ddr_get_version(void) * propagation, compute a suitably rounded mclk_ps to compute * a working memory controller configuration. */ -unsigned int get_memory_clk_period_ps(void) +unsigned int get_memory_clk_period_ps(const unsigned int ctrl_num) { - unsigned int data_rate = get_ddr_freq(0); + unsigned int data_rate = get_ddr_freq(ctrl_num); unsigned int result;
/* Round to nearest 10ps, being careful about 64-bit multiply/divide */ @@ -59,10 +59,10 @@ unsigned int get_memory_clk_period_ps(void) }
/* Convert picoseconds into DRAM clock cycles (rounding up if needed). */ -unsigned int picos_to_mclk(unsigned int picos) +unsigned int picos_to_mclk(const unsigned int ctrl_num, unsigned int picos) { unsigned long long clks, clks_rem; - unsigned long data_rate = get_ddr_freq(0); + unsigned long data_rate = get_ddr_freq(ctrl_num);
/* Short circuit for zero picos */ if (!picos) @@ -88,9 +88,9 @@ unsigned int picos_to_mclk(unsigned int picos) return (unsigned int) clks; }
-unsigned int mclk_to_picos(unsigned int mclk) +unsigned int mclk_to_picos(const unsigned int ctrl_num, unsigned int mclk) { - return get_memory_clk_period_ps() * mclk; + return get_memory_clk_period_ps(ctrl_num) * mclk; }
#ifdef CONFIG_PPC diff --git a/include/fsl_ddr.h b/include/fsl_ddr.h index 3286c95..96fde91 100644 --- a/include/fsl_ddr.h +++ b/include/fsl_ddr.h @@ -44,11 +44,12 @@ u32 fsl_ddr_get_version(void); * to this specific DDR technology. */ static __inline__ int -compute_dimm_parameters(const generic_spd_eeprom_t *spd, +compute_dimm_parameters(const unsigned int ctrl_num, + const generic_spd_eeprom_t *spd, dimm_params_t *pdimm, unsigned int dimm_number) { - return ddr_compute_dimm_parameters(spd, pdimm, dimm_number); + return ddr_compute_dimm_parameters(ctrl_num, spd, pdimm, dimm_number); } #endif
@@ -92,13 +93,15 @@ fsl_ddr_compute(fsl_ddr_info_t *pinfo, unsigned int start_step, unsigned int size_only); const char *step_to_string(unsigned int step);
-unsigned int compute_fsl_memctl_config_regs(const memctl_options_t *popts, +unsigned int compute_fsl_memctl_config_regs(const unsigned int ctrl_num, + const memctl_options_t *popts, fsl_ddr_cfg_regs_t *ddr, const common_timing_params_t *common_dimm, const dimm_params_t *dimm_parameters, unsigned int dbw_capacity_adjust, unsigned int size_only); unsigned int compute_lowest_common_dimm_parameters( + const unsigned int ctrl_num, const dimm_params_t *dimm_params, common_timing_params_t *outpdimm, unsigned int number_of_dimms); @@ -108,9 +111,9 @@ unsigned int populate_memctl_options(int all_dimms_registered, unsigned int ctrl_num); void check_interleaving_options(fsl_ddr_info_t *pinfo);
-unsigned int mclk_to_picos(unsigned int mclk); -unsigned int get_memory_clk_period_ps(void); -unsigned int picos_to_mclk(unsigned int picos); +unsigned int mclk_to_picos(const unsigned int ctrl_num, unsigned int mclk); +unsigned int get_memory_clk_period_ps(const unsigned int ctrl_num); +unsigned int picos_to_mclk(const unsigned int ctrl_num, unsigned int picos); void fsl_ddr_set_lawbar( const common_timing_params_t *memctl_common_params, unsigned int memctl_interleaved, diff --git a/include/fsl_ddr_dimm_params.h b/include/fsl_ddr_dimm_params.h index 09a67a6..751e935 100644 --- a/include/fsl_ddr_dimm_params.h +++ b/include/fsl_ddr_dimm_params.h @@ -112,7 +112,7 @@ typedef struct dimm_params_s { #endif } dimm_params_t;
-extern unsigned int ddr_compute_dimm_parameters( +unsigned int ddr_compute_dimm_parameters(const unsigned int ctrl_num, const generic_spd_eeprom_t *spd, dimm_params_t *pdimm, unsigned int dimm_number);
DP-DDR benefits from auto precharge because of its specific application.
board/freescale/ls2085a/ddr.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/board/freescale/ls2085a/ddr.c b/board/freescale/ls2085a/ddr.c index b4a3fc9..4884fa2 100644 --- a/board/freescale/ls2085a/ddr.c +++ b/board/freescale/ls2085a/ddr.c @@ -77,6 +77,7 @@ found: popts->data_bus_width = 1; popts->otf_burst_chop_en = 0; popts->burst_length = DDR_BL8; + popts->bstopre = 0; /* enable auto precharge */ } /* * Factors to consider for half-strength driver enable:
wwt_bg should match rrt_bg. It was a typo in driver.
drivers/ddr/fsl/ctrl_regs.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/ddr/fsl/ctrl_regs.c b/drivers/ddr/fsl/ctrl_regs.c index 713c3ed..690e73d 100644 --- a/drivers/ddr/fsl/ctrl_regs.c +++ b/drivers/ddr/fsl/ctrl_regs.c @@ -1928,7 +1928,7 @@ static void set_timing_cfg_8(const unsigned int ctrl_num, wwt_bg = tccdl - 4; } else { rrt_bg = tccdl - 2; - wwt_bg = tccdl - 4; + wwt_bg = tccdl - 2; }
LS NADK memory manager by default works on HugeTLB. Hence bootargs must include parameters default_hugepagesz (default hugepagesize, hugepagesz (hugepage size) and hugepages (number of hugepages to be reserved in kernel for the given size).
Signed-off-by: Kuldip Giroh kuldip.giroh@freescale.com ---
include/configs/ls2085a_common.h | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/include/configs/ls2085a_common.h b/include/configs/ls2085a_common.h index 3898443..55e7307 100644 --- a/include/configs/ls2085a_common.h +++ b/include/configs/ls2085a_common.h @@ -274,7 +274,9 @@ "console=ttyAMA0,38400n8\0"
#define CONFIG_BOOTARGS "console=ttyS1,115200 root=/dev/ram0 " \ - "earlyprintk=uart8250-8bit,0x21c0600" + "earlyprintk=uart8250-8bit,0x21c0600 " \ + "default_hugepagesz=2m hugepagesz=2m " \ + "hugepages=16" #define CONFIG_BOOTCOMMAND "cp.b $kernel_start $kernel_load " \ "$kernel_size && bootm $kernel_load" #define CONFIG_BOOTDELAY 1
Set system clock to 100MHz and DDR clock to 133MHz.
Signed-off-by: York Sun yorksun@freescale.com ---
include/configs/ls2085a_common.h | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/include/configs/ls2085a_common.h b/include/configs/ls2085a_common.h index 55e7307..387f904 100644 --- a/include/configs/ls2085a_common.h +++ b/include/configs/ls2085a_common.h @@ -249,7 +249,8 @@ /* Physical Memory Map */ /* fixme: these need to be checked against the board */ #define CONFIG_CHIP_SELECTS_PER_CTRL 4 -#define CONFIG_SYS_CLK_FREQ 133333333 +#define CONFIG_SYS_CLK_FREQ 100000000 +#define CONFIG_DDR_CLK_FREQ 133333333
#define CONFIG_NR_DRAM_BANKS 3
Add sync of refresh for multiple DDR controllers. DDRC initialization needs to complete first. Code is re-ordered to keep refresh close.
README | 3 +++ drivers/ddr/fsl/main.c | 4 ++++ drivers/ddr/fsl/util.c | 55 ++++++++++++++++++++++++++++++++++++++++++++++++ include/fsl_ddr.h | 2 ++ 4 files changed, 64 insertions(+)
diff --git a/README b/README index 604f0fa..60ff006 100644 --- a/README +++ b/README @@ -4914,6 +4914,9 @@ Low Level (hardware related) configuration options: - CONFIG_FSL_DDR_INTERACTIVE Enable interactive DDR debugging. See doc/README.fsl-ddr.
+- CONFIG_FSL_DDR_SYNC_REFRESH + Enable sync of refresh for multiple controllers. + - CONFIG_SYS_83XX_DDR_USES_CS0 Only for 83xx systems. If specified, then DDR should be configured using CS0 and CS1 instead of CS2 and CS3. diff --git a/drivers/ddr/fsl/main.c b/drivers/ddr/fsl/main.c index f49939b..b72b242 100644 --- a/drivers/ddr/fsl/main.c +++ b/drivers/ddr/fsl/main.c @@ -692,6 +692,10 @@ phys_size_t __fsl_ddr_sdram(fsl_ddr_info_t *pinfo) } }
+#ifdef CONFIG_FSL_DDR_SYNC_REFRESH + fsl_ddr_sync_memctl_refresh(first_ctrl, last_ctrl); +#endif + #ifdef CONFIG_PPC /* program LAWs */ for (i = first_ctrl; i <= last_ctrl; i++) { diff --git a/drivers/ddr/fsl/util.c b/drivers/ddr/fsl/util.c index ad569de..664081b 100644 --- a/drivers/ddr/fsl/util.c +++ b/drivers/ddr/fsl/util.c @@ -308,3 +308,58 @@ void board_add_ram_info(int use_default) { detail_board_ddr_info(); } + +#ifdef CONFIG_FSL_DDR_SYNC_REFRESH +#define DDRC_DEBUG20_INIT_DONE 0x80000000 +#define DDRC_DEBUG2_RF 0x00000040 +void fsl_ddr_sync_memctl_refresh(unsigned int first_ctrl, + unsigned int last_ctrl) +{ + unsigned int i; + u32 ddrc_debug20; + u32 ddrc_debug2[CONFIG_NUM_DDR_CONTROLLERS] = {}; + u32 *ddrc_debug2_p[CONFIG_NUM_DDR_CONTROLLERS] = {}; + struct ccsr_ddr __iomem *ddr; + + for (i = first_ctrl; i <= last_ctrl; i++) { + switch (i) { + case 0: + ddr = (void *)CONFIG_SYS_FSL_DDR_ADDR; + break; +#if defined(CONFIG_SYS_FSL_DDR2_ADDR) && (CONFIG_NUM_DDR_CONTROLLERS > 1) + case 1: + ddr = (void *)CONFIG_SYS_FSL_DDR2_ADDR; + break; +#endif +#if defined(CONFIG_SYS_FSL_DDR3_ADDR) && (CONFIG_NUM_DDR_CONTROLLERS > 2) + case 2: + ddr = (void *)CONFIG_SYS_FSL_DDR3_ADDR; + break; +#endif +#if defined(CONFIG_SYS_FSL_DDR4_ADDR) && (CONFIG_NUM_DDR_CONTROLLERS > 3) + case 3: + ddr = (void *)CONFIG_SYS_FSL_DDR4_ADDR; + break; +#endif + default: + printf("%s unexpected ctrl = %u\n", __func__, i); + return; + } + ddrc_debug20 = ddr_in32(&ddr->debug[19]); + ddrc_debug2_p[i] = &ddr->debug[1]; + while (!(ddrc_debug20 & DDRC_DEBUG20_INIT_DONE)) { + /* keep polling until DDRC init is done */ + udelay(100); + ddrc_debug20 = ddr_in32(&ddr->debug[19]); + } + ddrc_debug2[i] = ddr_in32(&ddr->debug[1]) | DDRC_DEBUG2_RF; + } + /* + * Sync refresh + * This is put together to make sure the refresh reqeusts are sent + * closely to each other. + */ + for (i = first_ctrl; i <= last_ctrl; i++) + ddr_out32(ddrc_debug2_p[i], ddrc_debug2[i]); +} +#endif /* CONFIG_FSL_DDR_SYNC_REFRESH */ diff --git a/include/fsl_ddr.h b/include/fsl_ddr.h index 96fde91..feccef9 100644 --- a/include/fsl_ddr.h +++ b/include/fsl_ddr.h @@ -118,6 +118,8 @@ void fsl_ddr_set_lawbar( const common_timing_params_t *memctl_common_params, unsigned int memctl_interleaved, unsigned int ctrl_num); +void fsl_ddr_sync_memctl_refresh(unsigned int first_ctrl, + unsigned int last_ctrl);
int fsl_ddr_interactive_env_var_exists(void); unsigned long long fsl_ddr_interactive(fsl_ddr_info_t *pinfo, int var_is_set);
Since Linux v3.16-rc1 earlyprintk has been removed for arm64. Switch to using earlycon.
Signed-off-by: Arnab Basu arnab.basu@freescale.com Signed-off-by: York Sun yorksun@freescale.com ---
include/configs/ls2085a_common.h | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/include/configs/ls2085a_common.h b/include/configs/ls2085a_common.h index 387f904..7e8d944 100644 --- a/include/configs/ls2085a_common.h +++ b/include/configs/ls2085a_common.h @@ -274,10 +274,10 @@ "kernel_size=0x1000000\0" \ "console=ttyAMA0,38400n8\0"
-#define CONFIG_BOOTARGS "console=ttyS1,115200 root=/dev/ram0 " \ - "earlyprintk=uart8250-8bit,0x21c0600 " \ - "default_hugepagesz=2m hugepagesz=2m " \ - "hugepages=16" +#define CONFIG_BOOTARGS "console=ttyS1,115200 root=/dev/ram0 " \ + "earlycon=uart8250,mmio,0x21c0600,115200 " \ + "default_hugepagesz=2m hugepagesz=2m " \ + "hugepages=16" #define CONFIG_BOOTCOMMAND "cp.b $kernel_start $kernel_load " \ "$kernel_size && bootm $kernel_load" #define CONFIG_BOOTDELAY 1
Move the load address of the kernel image to get it away from the region of the uncompressed kernel.
Signed-off-by: Stuart Yoder stuart.yoder@freescale.com ---
include/configs/ls2085a_common.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/ls2085a_common.h b/include/configs/ls2085a_common.h index 7e8d944..befd4c7 100644 --- a/include/configs/ls2085a_common.h +++ b/include/configs/ls2085a_common.h @@ -270,7 +270,7 @@ "fdt_high=0xffffffffffffffff\0" \ "initrd_high=0xffffffffffffffff\0" \ "kernel_start=0x581200000\0" \ - "kernel_load=0x806f0000\0" \ + "kernel_load=0xa0000000\0" \ "kernel_size=0x1000000\0" \ "console=ttyAMA0,38400n8\0"
This patch enusres that right banners are printed for LS2085A emulator and simulator platforms.
include/configs/ls2085a_common.h | 3 --- include/configs/ls2085a_emu.h | 3 +++ include/configs/ls2085a_simu.h | 3 +++ 3 files changed, 6 insertions(+), 3 deletions(-)
diff --git a/include/configs/ls2085a_common.h b/include/configs/ls2085a_common.h index befd4c7..55f4c96 100644 --- a/include/configs/ls2085a_common.h +++ b/include/configs/ls2085a_common.h @@ -27,9 +27,6 @@ #define CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_BOARD_EARLY_INIT_F 1
-#define CONFIG_IDENT_STRING " LS2085A-EMU" -#define CONFIG_BOOTP_VCI_STRING "U-boot.LS2085A-EMU" - /* Flat Device Tree Definitions */ #define CONFIG_OF_LIBFDT #define CONFIG_OF_BOARD_SETUP diff --git a/include/configs/ls2085a_emu.h b/include/configs/ls2085a_emu.h index 487cd99..2d2e1ea 100644 --- a/include/configs/ls2085a_emu.h +++ b/include/configs/ls2085a_emu.h @@ -9,6 +9,9 @@
#include "ls2085a_common.h"
+#define CONFIG_IDENT_STRING " LS2085A-EMU" +#define CONFIG_BOOTP_VCI_STRING "U-boot.LS2085A-EMU" + #define CONFIG_DDR_SPD #define CONFIG_SYS_FSL_DDR_EMU /* Support emulator */ #define SPD_EEPROM_ADDRESS1 0x51 diff --git a/include/configs/ls2085a_simu.h b/include/configs/ls2085a_simu.h index 0f40b78..af34f3f 100644 --- a/include/configs/ls2085a_simu.h +++ b/include/configs/ls2085a_simu.h @@ -9,6 +9,9 @@
+#define CONFIG_IDENT_STRING " LS2085A-SIMU" +#define CONFIG_BOOTP_VCI_STRING "U-boot.LS2085A-SIMU" + /* SMSC 91C111 ethernet configuration */ #define CONFIG_SMC91111 #define CONFIG_SMC91111_BASE (0x2210000)
Erratum A008336 applied to LS2085A.
arch/arm/include/asm/arch-fsl-lsch3/config.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/include/asm/arch-fsl-lsch3/config.h b/arch/arm/include/asm/arch-fsl-lsch3/config.h index 256adb0..1bada10 100644 --- a/arch/arm/include/asm/arch-fsl-lsch3/config.h +++ b/arch/arm/include/asm/arch-fsl-lsch3/config.h @@ -101,4 +101,8 @@ #error SoC not defined #endif
+#ifdef CONFIG_LS2085A +#define CONFIG_SYS_FSL_ERRATUM_A008336 +#endif + #endif /* _ASM_ARMV8_FSL_LSCH3_CONFIG_ */
Erratum A008514 appleis to ls2085a.
arch/arm/include/asm/arch-fsl-lsch3/config.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/include/asm/arch-fsl-lsch3/config.h b/arch/arm/include/asm/arch-fsl-lsch3/config.h index 1bada10..b140c1f 100644 --- a/arch/arm/include/asm/arch-fsl-lsch3/config.h +++ b/arch/arm/include/asm/arch-fsl-lsch3/config.h @@ -103,6 +103,7 @@
#ifdef CONFIG_LS2085A #define CONFIG_SYS_FSL_ERRATUM_A008336 +#define CONFIG_SYS_FSL_ERRATUM_A008514 #endif
Enable sync of DDR refresh for LS2085a platform. GPP DDR controllers stay in sync. DP-DDR has only one controller so it does no harm.
include/configs/ls2085a_emu.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/ls2085a_emu.h b/include/configs/ls2085a_emu.h index 2d2e1ea..a02d694 100644 --- a/include/configs/ls2085a_emu.h +++ b/include/configs/ls2085a_emu.h @@ -20,4 +20,5 @@ #define SPD_EEPROM_ADDRESS SPD_EEPROM_ADDRESS1 #define CONFIG_SYS_SPD_BUS_NUM 1 /* SPD on I2C bus 1 */
+#define CONFIG_FSL_DDR_SYNC_REFRESH #endif /* __LS2_EMU_H */
From: "J. German Rivera" German.Rivera@freescale.com
Upgrade Manage Complex (MC) flib API to 0.5.2. Rename directory fsl_mc to fsl-mc. Change the fsl-mc node in Linux device tree from "fsl,dprcr" to "fsl-mc". Print MC version info when appropriate.
Signed-off-by: J. German Rivera German.Rivera@freescale.com Signed-off-by: Lijun Pan Lijun.Pan@freescale.com ---
arch/arm/cpu/armv8/fsl-lsch3/cpu.c | 2 +- board/freescale/ls2085a/ls2085a.c | 18 ++++- drivers/net/Makefile | 2 +- drivers/net/{fsl_mc => fsl-mc}/Makefile | 4 +- drivers/net/fsl-mc/dpmng.c | 91 +++++++++++++++++++++ drivers/net/fsl-mc/fsl_dpmng_cmd.h | 49 ++++++++++++ drivers/net/{fsl_mc => fsl-mc}/mc.c | 132 ++++++++++++++++++++----------- drivers/net/fsl-mc/mc_sys.c | 63 +++++++++++++++ include/configs/ls2085a_common.h | 4 +- include/fsl-mc/fsl_dpmng.h | 121 ++++++++++++++++++++++++++++ include/{ => fsl-mc}/fsl_mc.h | 0 include/fsl-mc/fsl_mc_cmd.h | 132 +++++++++++++++++++++++++++++++ include/fsl-mc/fsl_mc_sys.h | 26 ++++++ 13 files changed, 592 insertions(+), 52 deletions(-) rename drivers/net/{fsl_mc => fsl-mc}/Makefile (75%) create mode 100644 drivers/net/fsl-mc/dpmng.c create mode 100644 drivers/net/fsl-mc/fsl_dpmng_cmd.h rename drivers/net/{fsl_mc => fsl-mc}/mc.c (67%) create mode 100644 drivers/net/fsl-mc/mc_sys.c create mode 100644 include/fsl-mc/fsl_dpmng.h rename include/{ => fsl-mc}/fsl_mc.h (100%) create mode 100644 include/fsl-mc/fsl_mc_cmd.h create mode 100644 include/fsl-mc/fsl_mc_sys.h
diff --git a/arch/arm/cpu/armv8/fsl-lsch3/cpu.c b/arch/arm/cpu/armv8/fsl-lsch3/cpu.c index 42cee65..4997487 100644 --- a/arch/arm/cpu/armv8/fsl-lsch3/cpu.c +++ b/arch/arm/cpu/armv8/fsl-lsch3/cpu.c @@ -10,10 +10,10 @@ #include <asm/armv8/mmu.h> #include <asm/io.h> #include <asm/arch-fsl-lsch3/immap_lsch3.h> +#include <fsl-mc/fsl_mc.h> #include "cpu.h" #include "mp.h" #include "speed.h" -#include <fsl_mc.h>
DECLARE_GLOBAL_DATA_PTR;
diff --git a/board/freescale/ls2085a/ls2085a.c b/board/freescale/ls2085a/ls2085a.c index ee75d1b..519d61c 100644 --- a/board/freescale/ls2085a/ls2085a.c +++ b/board/freescale/ls2085a/ls2085a.c @@ -12,7 +12,7 @@ #include <asm/io.h> #include <fdt_support.h> #include <libfdt.h> -#include <fsl_mc.h> +#include <fsl-mc/fsl_mc.h> #include <environment.h>
DECLARE_GLOBAL_DATA_PTR; @@ -98,7 +98,21 @@ void fdt_fixup_board_enet(void *fdt) { int offset;
- offset = fdt_path_offset(fdt, "/fsl,dprc@0"); + offset = fdt_path_offset(fdt, "/fsl-mc"); + + /* + * TODO: Remove this when backward compatibility + * with old DT node (fsl,dprc@0) is no longer needed. + */ + if (offset < 0) + offset = fdt_path_offset(fdt, "/fsl,dprc@0"); + + if (offset < 0) { + printf("%s: ERROR: fsl-mc node not found in device tree (error %d)\n", + __func__, offset); + return; + } + if (get_mc_boot_status() == 0) fdt_status_okay(fdt, offset); else diff --git a/drivers/net/Makefile b/drivers/net/Makefile index fb0cf8c..f9ddda1 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -65,4 +65,4 @@ obj-$(CONFIG_XILINX_EMACLITE) += xilinx_emaclite.o obj-$(CONFIG_XILINX_LL_TEMAC) += xilinx_ll_temac.o xilinx_ll_temac_mdio.o \ xilinx_ll_temac_fifo.o xilinx_ll_temac_sdma.o obj-$(CONFIG_ZYNQ_GEM) += zynq_gem.o -obj-$(CONFIG_FSL_MC_ENET) += fsl_mc/ +obj-$(CONFIG_FSL_MC_ENET) += fsl-mc/ diff --git a/drivers/net/fsl_mc/Makefile b/drivers/net/fsl-mc/Makefile similarity index 75% rename from drivers/net/fsl_mc/Makefile rename to drivers/net/fsl-mc/Makefile index 4834086..206ac6b 100644 --- a/drivers/net/fsl_mc/Makefile +++ b/drivers/net/fsl-mc/Makefile @@ -5,4 +5,6 @@ #
# Layerscape MC driver -obj-y += mc.o +obj-y += mc.o \ + mc_sys.o \ + dpmng.o diff --git a/drivers/net/fsl-mc/dpmng.c b/drivers/net/fsl-mc/dpmng.c new file mode 100644 index 0000000..cc14c7b --- /dev/null +++ b/drivers/net/fsl-mc/dpmng.c @@ -0,0 +1,91 @@ +/* Copyright 2014 Freescale Semiconductor Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <fsl-mc/fsl_mc_sys.h> +#include <fsl-mc/fsl_mc_cmd.h> +#include <fsl-mc/fsl_dpmng.h> +#include "fsl_dpmng_cmd.h" + +int mc_get_version(struct fsl_mc_io *mc_io, struct mc_version *mc_ver_info) +{ + struct mc_command cmd = { 0 }; + int err; + + /* prepare command */ + cmd.header = mc_encode_cmd_header(DPMNG_CMDID_GET_VERSION, + MC_CMD_PRI_LOW, 0); + + /* send command to mc*/ + err = mc_send_command(mc_io, &cmd); + if (err) + return err; + + /* retrieve response parameters */ + DPMNG_RSP_GET_VERSION(cmd, mc_ver_info); + + return 0; +} + +int dpmng_reset_aiop(struct fsl_mc_io *mc_io, int container_id, + int aiop_tile_id) +{ + struct mc_command cmd = { 0 }; + + /* prepare command */ + cmd.header = mc_encode_cmd_header(DPMNG_CMDID_RESET_AIOP, + MC_CMD_PRI_LOW, 0); + DPMNG_CMD_RESET_AIOP(cmd, container_id, aiop_tile_id); + + /* send command to mc*/ + return mc_send_command(mc_io, &cmd); +} + +int dpmng_load_aiop(struct fsl_mc_io *mc_io, + int container_id, + int aiop_tile_id, + uint64_t img_iova, + uint32_t img_size) +{ + struct mc_command cmd = { 0 }; + + /* prepare command */ + cmd.header = mc_encode_cmd_header(DPMNG_CMDID_LOAD_AIOP, + MC_CMD_PRI_LOW, + 0); + DPMNG_CMD_LOAD_AIOP(cmd, container_id, aiop_tile_id, img_size, + img_iova); + + /* send command to mc*/ + return mc_send_command(mc_io, &cmd); +} + +int dpmng_run_aiop(struct fsl_mc_io *mc_io, + int container_id, + int aiop_tile_id, + const struct dpmng_aiop_run_cfg *cfg) +{ + struct mc_command cmd = { 0 }; + + /* prepare command */ + cmd.header = mc_encode_cmd_header(DPMNG_CMDID_RUN_AIOP, + MC_CMD_PRI_LOW, + 0); + DPMNG_CMD_RUN_AIOP(cmd, container_id, aiop_tile_id, cfg); + + /* send command to mc*/ + return mc_send_command(mc_io, &cmd); +} + +int dpmng_reset_mc_portal(struct fsl_mc_io *mc_io) +{ + struct mc_command cmd = { 0 }; + + /* prepare command */ + cmd.header = mc_encode_cmd_header(DPMNG_CMDID_RESET_MC_PORTAL, + MC_CMD_PRI_LOW, + 0); + + /* send command to mc*/ + return mc_send_command(mc_io, &cmd); +} diff --git a/drivers/net/fsl-mc/fsl_dpmng_cmd.h b/drivers/net/fsl-mc/fsl_dpmng_cmd.h new file mode 100644 index 0000000..c9fe021 --- /dev/null +++ b/drivers/net/fsl-mc/fsl_dpmng_cmd.h @@ -0,0 +1,49 @@ +/* Copyright 2014 Freescale Semiconductor Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef __FSL_DPMNG_CMD_H +#define __FSL_DPMNG_CMD_H + +/* Command IDs */ +#define DPMNG_CMDID_GET_VERSION 0x831 +#define DPMNG_CMDID_RESET_AIOP 0x832 +#define DPMNG_CMDID_LOAD_AIOP 0x833 +#define DPMNG_CMDID_RUN_AIOP 0x834 +#define DPMNG_CMDID_RESET_MC_PORTAL 0x835 + +/* cmd, param, offset, width, type, arg_name */ +#define DPMNG_RSP_GET_VERSION(cmd, mc_ver_info) \ +do { \ + MC_RSP_OP(cmd, 0, 0, 32, uint32_t, mc_ver_info->revision); \ + MC_RSP_OP(cmd, 0, 32, 32, uint32_t, mc_ver_info->major); \ + MC_RSP_OP(cmd, 1, 0, 32, uint32_t, mc_ver_info->minor); \ +} while (0) + +/* cmd, param, offset, width, type, arg_name */ +#define DPMNG_CMD_RESET_AIOP(cmd, container_id, aiop_tile_id) \ +do { \ + MC_CMD_OP(cmd, 0, 0, 32, int, aiop_tile_id); \ + MC_CMD_OP(cmd, 0, 32, 32, int, container_id); \ +} while (0) + +/* cmd, param, offset, width, type, arg_name */ +#define DPMNG_CMD_LOAD_AIOP(cmd, container_id, aiop_tile_id, img_size, \ + img_iova) \ +do { \ + MC_CMD_OP(cmd, 0, 0, 32, int, aiop_tile_id); \ + MC_CMD_OP(cmd, 0, 32, 32, int, container_id); \ + MC_CMD_OP(cmd, 1, 0, 32, uint32_t, img_size); \ + MC_CMD_OP(cmd, 2, 0, 64, uint64_t, img_iova); \ +} while (0) + +/* cmd, param, offset, width, type, arg_name */ +#define DPMNG_CMD_RUN_AIOP(cmd, container_id, aiop_tile_id, cfg) \ +do { \ + MC_CMD_OP(cmd, 0, 0, 32, int, aiop_tile_id); \ + MC_CMD_OP(cmd, 0, 32, 32, int, container_id); \ + MC_CMD_OP(cmd, 1, 0, 32, uint32_t, cfg->cores_mask); \ + MC_CMD_OP(cmd, 2, 0, 64, uint64_t, cfg->options); \ +} while (0) + +#endif /* __FSL_DPMNG_CMD_H */ diff --git a/drivers/net/fsl_mc/mc.c b/drivers/net/fsl-mc/mc.c similarity index 67% rename from drivers/net/fsl_mc/mc.c rename to drivers/net/fsl-mc/mc.c index df84568..74b0085 100644 --- a/drivers/net/fsl_mc/mc.c +++ b/drivers/net/fsl-mc/mc.c @@ -3,9 +3,12 @@ * * SPDX-License-Identifier: GPL-2.0+ */ + #include <errno.h> #include <asm/io.h> -#include <fsl_mc.h> +#include <fsl-mc/fsl_mc.h> +#include <fsl-mc/fsl_mc_sys.h> +#include <fsl-mc/fsl_dpmng.h>
DECLARE_GLOBAL_DATA_PTR; static int mc_boot_status; @@ -14,7 +17,7 @@ static int mc_boot_status; * Copying MC firmware or DPL image to DDR */ static int mc_copy_image(const char *title, - u64 image_addr, u32 image_size, u64 mc_ram_addr) + u64 image_addr, u32 image_size, u64 mc_ram_addr) { debug("%s copied to address %p\n", title, (void *)mc_ram_addr); memcpy((void *)mc_ram_addr, (void *)image_addr, image_size); @@ -25,10 +28,9 @@ static int mc_copy_image(const char *title, * MC firmware FIT image parser checks if the image is in FIT * format, verifies integrity of the image and calculates * raw image address and size values. - * Returns 0 if success and 1 if any of the above mentioned + * Returns 0 on success and a negative errno on error. * task fail. **/ - int parse_mc_firmware_fit_image(const void **raw_image_addr, size_t *raw_image_size) { @@ -39,7 +41,7 @@ int parse_mc_firmware_fit_image(const void **raw_image_addr, size_t size; const char *uname = "firmware";
- /* Check if the image is in NOR flash*/ + /* Check if the image is in NOR flash */ #ifdef CONFIG_SYS_LS_MC_FW_IN_NOR fit_hdr = (void *)CONFIG_SYS_LS_MC_FW_ADDR; #else @@ -50,26 +52,26 @@ int parse_mc_firmware_fit_image(const void **raw_image_addr, format = genimg_get_format(fit_hdr);
if (format != IMAGE_FORMAT_FIT) { - debug("Not a FIT image\n"); - return 1; + printf("fsl-mc: ERROR: Bad firmware image (not a FIT image)\n"); + return -EINVAL; }
if (!fit_check_format(fit_hdr)) { - debug("Bad FIT image format\n"); - return 1; + printf("fsl-mc: ERROR: Bad firmware image (bad FIT header)\n"); + return -EINVAL; }
node_offset = fit_image_get_node(fit_hdr, uname);
if (node_offset < 0) { - debug("Can not find %s subimage\n", uname); - return 1; + printf("fsl-mc: ERROR: Bad firmware image (missing subimage)\n"); + return -ENOENT; }
/* Verify MC firmware image */ if (!(fit_image_verify(fit_hdr, node_offset))) { - debug("Bad MC firmware hash"); - return 1; + printf("fsl-mc: ERROR: Bad firmware image (bad CRC)\n"); + return -EINVAL; }
/* Get address and size of raw image */ @@ -90,12 +92,13 @@ int mc_init(bd_t *bis) u64 mc_dpl_offset; u32 reg_gsr; u32 mc_fw_boot_status; - void *fdt_hdr; + void *dpl_fdt_hdr; int dpl_size; const void *raw_image_addr; size_t raw_image_size = 0; - - BUILD_BUG_ON(CONFIG_SYS_LS_MC_FW_LENGTH % 4 != 0); + struct fsl_mc_io mc_io; + int portal_id; + struct mc_version mc_ver_info;
/* * The MC private DRAM block was already carved at the end of DRAM @@ -130,25 +133,44 @@ int mc_init(bd_t *bis) /* * Load the MC FW at the beginning of the MC private DRAM block: */ - mc_copy_image( - "MC Firmware", - (u64)raw_image_addr, - raw_image_size, - mc_ram_addr); + mc_copy_image("MC Firmware", + (u64)raw_image_addr, raw_image_size, mc_ram_addr); + + /* + * Get address and size of the DPL blob stored in flash: + */ +#ifdef CONFIG_SYS_LS_MC_DPL_IN_NOR + dpl_fdt_hdr = (void *)CONFIG_SYS_LS_MC_DPL_ADDR; +#else +#error "No CONFIG_SYS_LS_MC_DPL_IN_xxx defined" +#endif + + error = fdt_check_header(dpl_fdt_hdr); + if (error != 0) { + printf("fsl-mc: ERROR: Bad DPL image (bad header)\n"); + goto out; + } + + dpl_size = fdt_totalsize(dpl_fdt_hdr); + if (dpl_size > CONFIG_SYS_LS_MC_DPL_MAX_LENGTH) { + printf("fsl-mc: ERROR: Bad DPL image (too large: %d)\n", + dpl_size); + error = -EINVAL; + goto out; + }
/* * Calculate offset in the MC private DRAM block at which the MC DPL * blob is to be placed: */ #ifdef CONFIG_SYS_LS_MC_DRAM_DPL_OFFSET - BUILD_BUG_ON( - (CONFIG_SYS_LS_MC_DRAM_DPL_OFFSET & 0x3) != 0 || - CONFIG_SYS_LS_MC_DRAM_DPL_OFFSET > 0xffffffff); + BUILD_BUG_ON((CONFIG_SYS_LS_MC_DRAM_DPL_OFFSET & 0x3) != 0 || + CONFIG_SYS_LS_MC_DRAM_DPL_OFFSET > 0xffffffff);
mc_dpl_offset = CONFIG_SYS_LS_MC_DRAM_DPL_OFFSET; #else mc_dpl_offset = mc_get_dram_block_size() - - roundup(CONFIG_SYS_LS_MC_DPL_LENGTH, 4096); + roundup(CONFIG_SYS_LS_MC_DPL_MAX_LENGTH, 4096);
if ((mc_dpl_offset & 0x3) != 0 || mc_dpl_offset > 0xffffffff) { printf("%s: Invalid MC DPL offset: %llu\n", @@ -158,23 +180,14 @@ int mc_init(bd_t *bis) } #endif
- /* Check if DPL image is in NOR flash */ -#ifdef CONFIG_SYS_LS_MC_DPL_IN_NOR - fdt_hdr = (void *)CONFIG_SYS_LS_MC_DPL_ADDR; -#else -#error "No CONFIG_SYS_LS_MC_DPL_IN_xxx defined" -#endif - - dpl_size = fdt_totalsize(fdt_hdr); - /* * Load the MC DPL blob at the far end of the MC private DRAM block: + * + * TODO: Should we place the DPL at a different location to match + * assumptions of MC firmware about its memory layout? */ - mc_copy_image( - "MC DPL blob", - (u64)fdt_hdr, - dpl_size, - mc_ram_addr + mc_dpl_offset); + mc_copy_image("MC DPL blob", + (u64)dpl_fdt_hdr, dpl_size, mc_ram_addr + mc_dpl_offset);
debug("mc_ccsr_regs %p\n", mc_ccsr_regs);
@@ -200,6 +213,8 @@ int mc_init(bd_t *bis) */ out_le32(&mc_ccsr_regs->reg_gsr, (u32)(mc_dpl_offset >> 2));
+ printf("\nfsl-mc: Booting Management Complex ...\n"); + /* * Deassert reset and release MC core 0 to run */ @@ -219,17 +234,13 @@ int mc_init(bd_t *bis) }
if (timeout <= 0) { - printf("%s: timeout booting management complex firmware\n", - __func__); + printf("fsl-mc: timeout booting management complex firmware\n");
/* TODO: Get an error status from an MC CCSR register */ error = -ETIMEDOUT; goto out; }
- printf("Management complex booted (boot status: %#x)\n", - mc_fw_boot_status); - if (mc_fw_boot_status != 0x1) { /* * TODO: Identify critical errors from the GSR register's FS @@ -237,8 +248,41 @@ int mc_init(bd_t *bis) * appropriate errno, so that the status property is set to * failure in the fsl,dprc device tree node. */ + printf("fsl-mc: WARNING: Firmware booted with error (GSR: %#x)\n", + reg_gsr); }
+ /* + * TODO: need to obtain the portal_id for the root container from the + * DPL + */ + portal_id = 0; + + /* + * Check that the MC firmware is responding portal commands: + */ + mc_io.mmio_regs = SOC_MC_PORTAL_ADDR(portal_id); + debug("Checking access to MC portal of root DPRC container (portal_id %d, portal physical addr %p)\n", + portal_id, mc_io.mmio_regs); + + error = mc_get_version(&mc_io, &mc_ver_info); + if (error != 0) { + printf("fsl-mc: ERROR: Firmware version check failed (error: %d)\n", + error); + goto out; + } + + if (MC_VER_MAJOR != mc_ver_info.major) + printf("fsl-mc: ERROR: Firmware major version mismatch (found: %d, expected: %d)\n", + mc_ver_info.major, MC_VER_MAJOR); + + if (MC_VER_MINOR != mc_ver_info.minor) + printf("fsl-mc: WARNING: Firmware minor version mismatch (found: %d, expected: %d)\n", + mc_ver_info.minor, MC_VER_MINOR); + + printf("fsl-mc: Management Complex booted (version: %d.%d.%d, boot status: %#x)\n", + mc_ver_info.major, mc_ver_info.minor, mc_ver_info.revision, + mc_fw_boot_status); out: if (error != 0) mc_boot_status = -error; diff --git a/drivers/net/fsl-mc/mc_sys.c b/drivers/net/fsl-mc/mc_sys.c new file mode 100644 index 0000000..7c8e003 --- /dev/null +++ b/drivers/net/fsl-mc/mc_sys.c @@ -0,0 +1,63 @@ +/* + * Freescale Layerscape MC I/O wrapper + * + * Copyright (C) 2014 Freescale Semiconductor, Inc. + * Author: German Rivera German.Rivera@freescale.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <fsl-mc/fsl_mc_sys.h> +#include <fsl-mc/fsl_mc_cmd.h> +#include <common.h> +#include <errno.h> +#include <asm/io.h> + +#define MC_CMD_HDR_READ_CMDID(_hdr) \ + ((uint16_t)u64_dec((_hdr), MC_CMD_HDR_CMDID_O, MC_CMD_HDR_CMDID_S)) + +/** + * mc_send_command - Send MC command and wait for response + * + * @mc_io: Pointer to MC I/O object to be used + * @cmd: MC command buffer. On input, it contains the command to send to the MC. + * On output, it contains the response from the MC if any. + * + * Depending on the sharing option specified when creating the MC portal + * wrapper, this function will use a spinlock or mutex to ensure exclusive + * access to the MC portal from the point when the command is sent until a + * response is received from the MC. + */ +int mc_send_command(struct fsl_mc_io *mc_io, + struct mc_command *cmd) +{ + enum mc_cmd_status status; + int timeout = 2000; + + mc_write_command(mc_io->mmio_regs, cmd); + + for ( ; ; ) { + status = mc_read_response(mc_io->mmio_regs, cmd); + if (status != MC_CMD_STATUS_READY) + break; + + if (--timeout == 0) { + printf("Error: Timeout waiting for MC response\n"); + return -ETIMEDOUT; + } + + udelay(500); + } + + if (status != MC_CMD_STATUS_OK) { + printf("Error: MC command failed (portal: %p, obj handle: %#x, command: %#x, status: %#x)\n", + mc_io->mmio_regs, + (unsigned int)MC_CMD_HDR_READ_AUTHID(cmd->header), + (unsigned int)MC_CMD_HDR_READ_CMDID(cmd->header), + (unsigned int)status); + + return -EIO; + } + + return 0; +} diff --git a/include/configs/ls2085a_common.h b/include/configs/ls2085a_common.h index 55f4c96..17a1cde 100644 --- a/include/configs/ls2085a_common.h +++ b/include/configs/ls2085a_common.h @@ -207,12 +207,10 @@ #define CONFIG_SYS_LS_MC_DRAM_BLOCK_MIN_SIZE (512UL * 1024 * 1024) #define CONFIG_SYS_LS_MC_FW_IN_NOR #define CONFIG_SYS_LS_MC_FW_ADDR 0x580200000ULL -/* TODO Actual FW length needs to be determined at runtime from FW header */ -#define CONFIG_SYS_LS_MC_FW_LENGTH (4U * 1024 * 1024) #define CONFIG_SYS_LS_MC_DPL_IN_NOR #define CONFIG_SYS_LS_MC_DPL_ADDR 0x5806C0000ULL /* TODO Actual DPL max length needs to be confirmed with the MC FW team */ -#define CONFIG_SYS_LS_MC_DPL_LENGTH 4096 +#define CONFIG_SYS_LS_MC_DPL_MAX_LENGTH (256 * 1024) #define CONFIG_SYS_LS_MC_DRAM_DPL_OFFSET 0xe00000
/* Carve the MC private DRAM block from the end of DRAM */ diff --git a/include/fsl-mc/fsl_dpmng.h b/include/fsl-mc/fsl_dpmng.h new file mode 100644 index 0000000..c2e1ddd --- /dev/null +++ b/include/fsl-mc/fsl_dpmng.h @@ -0,0 +1,121 @@ +/* Copyright 2014 Freescale Semiconductor Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ +/*! + * @file fsl_dpmng.h + * @brief Management Complex General API + */ + +#ifndef __FSL_DPMNG_H +#define __FSL_DPMNG_H + +/*! + * @Group grp_dpmng Management Complex General API + * + * @brief Contains general API for the Management Complex firmware + * @{ + */ + +struct fsl_mc_io; + +/** + * @brief Management Complex firmware version information + */ +#define MC_VER_MAJOR 4 +#define MC_VER_MINOR 0 + +struct mc_version { + uint32_t major; + /*!< Major version number: incremented on API compatibility changes */ + uint32_t minor; + /*!< Minor version number: incremented on API additions (that are + * backward compatible); reset when major version is incremented + */ + uint32_t revision; + /*!< Internal revision number: incremented on implementation changes + * and/or bug fixes that have no impact on API + */ +}; + +/** + * @brief Retrieves the Management Complex firmware version information + * + * @param[in] mc_io Pointer to opaque I/O object + * @param[out] mc_ver_info Pointer to version information structure + * + * @returns '0' on Success; Error code otherwise. + */ +int mc_get_version(struct fsl_mc_io *mc_io, struct mc_version *mc_ver_info); + +/** + * @brief Resets an AIOP tile + * + * @param[in] mc_io Pointer to opaque I/O object + * @param[in] container_id AIOP container ID + * @param[in] aiop_tile_id AIOP tile ID to reset + * + * @returns '0' on Success; Error code otherwise. + */ +int dpmng_reset_aiop(struct fsl_mc_io *mc_io, + int container_id, + int aiop_tile_id); + +/** + * @brief Loads an image to AIOP tile + * + * @param[in] mc_io Pointer to opaque I/O object + * @param[in] container_id AIOP container ID + * @param[in] aiop_tile_id AIOP tile ID to reset + * @param[in] img_iova I/O virtual address of AIOP ELF image + * @param[in] img_size Size of AIOP ELF image in memory (in bytes) + * + * @returns '0' on Success; Error code otherwise. + */ +int dpmng_load_aiop(struct fsl_mc_io *mc_io, + int container_id, + int aiop_tile_id, + uint64_t img_iova, + uint32_t img_size); + +/** + * @brief AIOP run configuration + */ +struct dpmng_aiop_run_cfg { + uint32_t cores_mask; + /*!< Mask of AIOP cores to run (core 0 in most significant bit) */ + uint64_t options; + /*!< Execution options (currently none defined) */ +}; + +/** + * @brief Starts AIOP tile execution + * + * @param[in] mc_io Pointer to MC portal's I/O object + * @param[in] container_id AIOP container ID + * @param[in] aiop_tile_id AIOP tile ID to reset + * @param[in] cfg AIOP run configuration + * + * @returns '0' on Success; Error code otherwise. + */ +int dpmng_run_aiop(struct fsl_mc_io *mc_io, + int container_id, + int aiop_tile_id, + const struct dpmng_aiop_run_cfg *cfg); + +/** + * @brief Resets MC portal + * + * This function closes all object handles (tokens) that are currently + * open in the MC portal on which the command is submitted. This allows + * cleanup of stale handles that belong to non-functional user processes. + * + * @param[in] mc_io Pointer to MC portal's I/O object + * + * @returns '0' on Success; Error code otherwise. + */ +int dpmng_reset_mc_portal(struct fsl_mc_io *mc_io); + +/** @} */ + +#endif /* __FSL_DPMNG_H */ diff --git a/include/fsl_mc.h b/include/fsl-mc/fsl_mc.h similarity index 100% rename from include/fsl_mc.h rename to include/fsl-mc/fsl_mc.h diff --git a/include/fsl-mc/fsl_mc_cmd.h b/include/fsl-mc/fsl_mc_cmd.h new file mode 100644 index 0000000..e7fcb5b --- /dev/null +++ b/include/fsl-mc/fsl_mc_cmd.h @@ -0,0 +1,132 @@ +/* Copyright 2014 Freescale Semiconductor Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef __FSL_MC_CMD_H +#define __FSL_MC_CMD_H + +#define MC_CMD_NUM_OF_PARAMS 7 + +#define MAKE_UMASK64(_width) \ + ((uint64_t)((_width) < 64 ? ((uint64_t)1 << (_width)) - 1 : -1)) + +static inline uint64_t u64_enc(int lsoffset, int width, uint64_t val) +{ + return (uint64_t)(((uint64_t)val & MAKE_UMASK64(width)) << lsoffset); +} +static inline uint64_t u64_dec(uint64_t val, int lsoffset, int width) +{ + return (uint64_t)((val >> lsoffset) & MAKE_UMASK64(width)); +} + +struct mc_command { + uint64_t header; + uint64_t params[MC_CMD_NUM_OF_PARAMS]; +}; + +enum mc_cmd_status { + MC_CMD_STATUS_OK = 0x0, /*!< Completed successfully */ + MC_CMD_STATUS_READY = 0x1, /*!< Ready to be processed */ + MC_CMD_STATUS_AUTH_ERR = 0x3, /*!< Authentication error */ + MC_CMD_STATUS_NO_PRIVILEGE = 0x4, /*!< No privilege */ + MC_CMD_STATUS_DMA_ERR = 0x5, /*!< DMA or I/O error */ + MC_CMD_STATUS_CONFIG_ERR = 0x6, /*!< Configuration error */ + MC_CMD_STATUS_TIMEOUT = 0x7, /*!< Operation timed out */ + MC_CMD_STATUS_NO_RESOURCE = 0x8, /*!< No resources */ + MC_CMD_STATUS_NO_MEMORY = 0x9, /*!< No memory available */ + MC_CMD_STATUS_BUSY = 0xA, /*!< Device is busy */ + MC_CMD_STATUS_UNSUPPORTED_OP = 0xB, /*!< Unsupported operation */ + MC_CMD_STATUS_INVALID_STATE = 0xC /*!< Invalid state */ +}; + +#define MC_CMD_HDR_CMDID_O 52 /* Command ID field offset */ +#define MC_CMD_HDR_CMDID_S 12 /* Command ID field size */ +#define MC_CMD_HDR_AUTHID_O 38 /* Authentication ID field offset */ +#define MC_CMD_HDR_AUTHID_S 10 /* Authentication ID field size */ +#define MC_CMD_HDR_STATUS_O 16 /* Status field offset */ +#define MC_CMD_HDR_STATUS_S 8 /* Status field size*/ +#define MC_CMD_HDR_PRI_O 15 /* Priority field offset */ +#define MC_CMD_HDR_PRI_S 1 /* Priority field size */ + +#define MC_CMD_HDR_READ_STATUS(_hdr) \ + ((enum mc_cmd_status)u64_dec((_hdr), \ + MC_CMD_HDR_STATUS_O, MC_CMD_HDR_STATUS_S)) + +#define MC_CMD_HDR_READ_AUTHID(_hdr) \ + ((uint16_t)u64_dec((_hdr), MC_CMD_HDR_AUTHID_O, MC_CMD_HDR_AUTHID_S)) + +#define MC_CMD_PRI_LOW 0 /*!< Low Priority command indication */ +#define MC_CMD_PRI_HIGH 1 /*!< High Priority command indication */ + +#define MC_CMD_OP(_cmd, _param, _offset, _width, _type, _arg) \ + ((_cmd).params[_param] |= u64_enc((_offset), (_width), _arg)) + +#define MC_RSP_OP(_cmd, _param, _offset, _width, _type, _arg) \ + (_arg = (_type)u64_dec(_cmd.params[_param], (_offset), (_width))) + +static inline uint64_t mc_encode_cmd_header(uint16_t cmd_id, + uint8_t priority, + uint16_t auth_id) +{ + uint64_t hdr; + + hdr = u64_enc(MC_CMD_HDR_CMDID_O, MC_CMD_HDR_CMDID_S, cmd_id); + hdr |= u64_enc(MC_CMD_HDR_AUTHID_O, MC_CMD_HDR_AUTHID_S, auth_id); + hdr |= u64_enc(MC_CMD_HDR_PRI_O, MC_CMD_HDR_PRI_S, priority); + hdr |= u64_enc(MC_CMD_HDR_STATUS_O, MC_CMD_HDR_STATUS_S, + MC_CMD_STATUS_READY); + + return hdr; +} + +/** + * mc_write_command - writes a command to a Management Complex (MC) portal + * + * @portal: pointer to an MC portal + * @cmd: pointer to a filled command + */ +static inline void mc_write_command(struct mc_command __iomem *portal, + struct mc_command *cmd) +{ + int i; + + /* copy command parameters into the portal */ + for (i = 0; i < MC_CMD_NUM_OF_PARAMS; i++) + writeq(cmd->params[i], &portal->params[i]); + + /* submit the command by writing the header */ + writeq(cmd->header, &portal->header); +} + +/** + * mc_read_response - reads the response for the last MC command from a + * Management Complex (MC) portal + * + * @portal: pointer to an MC portal + * @resp: pointer to command response buffer + * + * Returns MC_CMD_STATUS_OK on Success; Error code otherwise. + */ +static inline enum mc_cmd_status mc_read_response( + struct mc_command __iomem *portal, + struct mc_command *resp) +{ + int i; + enum mc_cmd_status status; + + /* Copy command response header from MC portal: */ + resp->header = readq(&portal->header); + status = MC_CMD_HDR_READ_STATUS(resp->header); + if (status != MC_CMD_STATUS_OK) + return status; + + /* Copy command response data from MC portal: */ + for (i = 0; i < MC_CMD_NUM_OF_PARAMS; i++) + resp->params[i] = readq(&portal->params[i]); + + return status; +} + +int mc_send_command(struct fsl_mc_io *mc_io, struct mc_command *cmd); + +#endif /* __FSL_MC_CMD_H */ diff --git a/include/fsl-mc/fsl_mc_sys.h b/include/fsl-mc/fsl_mc_sys.h new file mode 100644 index 0000000..c0befe0 --- /dev/null +++ b/include/fsl-mc/fsl_mc_sys.h @@ -0,0 +1,26 @@ +/* + * Freescale Layerscape Management Complex (MC) Environment-specific code + * + * Copyright (C) 2014 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _FSL_MC_SYS_H +#define _FSL_MC_SYS_H + +#include <asm/io.h> + +struct mc_command; + +/* + * struct mc_portal_wrapper - MC command portal wrapper object + */ +struct fsl_mc_io { + struct mc_command __iomem *mmio_regs; +}; + +int mc_send_command(struct fsl_mc_io *mc_io, + struct mc_command *cmd); + +#endif /* _FSL_MC_SYS_H */
York Sun
