[PATCH 00/19] sunxi: SPL cleanup part 1
This is the first part of a series to clean up the Allwinner SPL a bit. One big driver for this whole clean up is to eventually accommodate the RISC-V chips, which share most platform devices, but cannot use any code that currently lives under arch/arm. So the idea is to disentangle the code, to get a cleaner separation between ARM specific and platform specific code. Another related reason is that the RISC-V port aims to use a DM SPL, so we want to split off code bits that won't be needed when we have the DM framework in the SPL.
This first part of the series is mostly preparation, and some smaller cleanups, of code that was around for a long time and missed some updates. We start with some removal of no longer needed definitions, in the first seven patches. The next seven patches tighten the SPL clock code: quite some functions were compiled for U-Boot proper, however were not needed there. Sorting this out helps to identify legacy code. The final five patches move the SPL pinmux setup code into separate functions and files, and convert the #ifdef hell into proper C "if" statements.
It would be great if Samuel can have a look and say whether this is helpful or not. For instance I don't really know how much of the SPL clock code will be needed for the RISC-V port, since we don't really model the bus clocks in the DT at all, and currently don't support PLLs in the DM clock code.
Much of this first series should be good regardless, for instance the replacement of #ifdef's with C "if" statements, since that became tedious to expand for new SoCs and boards. But if some parts should live in a different directory, or should be grouped differently, this can certainly be factored in.
Please have a look, review and test!
Cheers, Andre
Andre Przywara (19): sunxi: cleanup sunxi-common.h sunxi: sun50i-h6: remove unneeded base addresses from header sunxi: sun4i: remove unneeded base addresses from header sunxi: sun9i: remove unneeded base addresses from header sunxi: move #ifdef guards around tzpc_init() to header file sunxi: remove common.h inclusion sunxi: simplify U-Boot proper only builds sunxi: remove unneeded i2c_init_board() call for U-Boot proper sunxi: compile clock.c for SPL only sunxi: sun4i: make more clock functions SPL only sunxi: sun6i: make more clock functions SPL only sunxi: sun50i_h6: make more clock functions SPL only sunxi: sun8i_a83t: make more clock functions SPL only sunxi: sun9i: make more clock functions SPL only sunxi: move pinmux setup into separate SPL only file sunxi: SPL pinmux: rewrite without #ifdefs sunxi: move UART pinmux setup into separate file sunxi: SPL pinmux: split out UART pinmux per port sunxi: SPL pinmux: rewrite UART setup without #ifdefs
arch/arm/Kconfig | 4 +- arch/arm/include/asm/arch-sunxi/clock_sun9i.h | 3 - arch/arm/include/asm/arch-sunxi/cpu_sun4i.h | 47 --- .../include/asm/arch-sunxi/cpu_sun50i_h6.h | 21 -- arch/arm/include/asm/arch-sunxi/cpu_sun9i.h | 41 --- arch/arm/include/asm/arch-sunxi/tzpc.h | 6 + arch/arm/mach-sunxi/Kconfig | 16 +- arch/arm/mach-sunxi/Makefile | 4 +- arch/arm/mach-sunxi/board.c | 113 +------ arch/arm/mach-sunxi/clock.c | 3 - arch/arm/mach-sunxi/clock_sun4i.c | 6 +- arch/arm/mach-sunxi/clock_sun50i_h6.c | 58 ++-- arch/arm/mach-sunxi/clock_sun6i.c | 4 +- arch/arm/mach-sunxi/clock_sun8i_a83t.c | 6 +- arch/arm/mach-sunxi/clock_sun9i.c | 98 +++--- arch/arm/mach-sunxi/cpu_info.c | 1 - arch/arm/mach-sunxi/dram_helpers.c | 3 +- arch/arm/mach-sunxi/dram_sun4i.c | 1 - arch/arm/mach-sunxi/dram_sun50i_h6.c | 1 - arch/arm/mach-sunxi/dram_sun50i_h616.c | 1 - arch/arm/mach-sunxi/dram_sun6i.c | 1 - arch/arm/mach-sunxi/dram_sun8i_a23.c | 1 - arch/arm/mach-sunxi/dram_sun8i_a33.c | 1 - arch/arm/mach-sunxi/dram_sun8i_a83t.c | 1 - arch/arm/mach-sunxi/dram_sun9i.c | 1 - arch/arm/mach-sunxi/dram_suniv.c | 2 +- arch/arm/mach-sunxi/dram_sunxi_dw.c | 1 - arch/arm/mach-sunxi/gtbus_sun9i.c | 1 - arch/arm/mach-sunxi/pmic_bus.c | 1 - arch/arm/mach-sunxi/prcm.c | 1 - arch/arm/mach-sunxi/spl_pinmux.c | 312 +++++++++++++++++ arch/arm/mach-sunxi/spl_spi_sunxi.c | 1 - arch/arm/mach-sunxi/timer.c | 1 - arch/arm/mach-sunxi/uart_pinmux.c | 158 +++++++++ board/sunxi/board.c | 318 +----------------- include/configs/sunxi-common.h | 56 +-- 36 files changed, 592 insertions(+), 702 deletions(-) create mode 100644 arch/arm/mach-sunxi/spl_pinmux.c create mode 100644 arch/arm/mach-sunxi/uart_pinmux.c
The sunxi-common.h configs header used to contain a lot of random Allwinner platform related constants, but over the years we moved a lot of those definitions out there.
Clean up the file to remove outdated comments which are leftovers from the olden days. Also remove the definition of LOW_LEVEL_SRAM_STACK, which is actually used nowhere in the whole source tree.
This also uses the opportunity to add some section comments that helps structuring the header file and improving readability.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- include/configs/sunxi-common.h | 56 ++++++++-------------------------- 1 file changed, 12 insertions(+), 44 deletions(-)
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index b8ca77d031d..b29a25d5617 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -14,8 +14,9 @@
#include <linux/stringify.h>
-/* Serial & console */ -/* ns16550 reg in the low bits of cpu reg */ +/**************************************************************************** + * base addresses for the SPL UART driver * + ****************************************************************************/ #ifdef CONFIG_MACH_SUNIV /* suniv doesn't have apb2 and uart is connected to apb1 */ #define CFG_SYS_NS16550_CLK 100000000 @@ -31,8 +32,9 @@ # define CFG_SYS_NS16550_COM5 SUNXI_R_UART_BASE #endif
-/* CPU */ - +/**************************************************************************** + * DRAM base address * + ****************************************************************************/ /* * The DRAM Base differs between some models. We cannot use macros for the * CONFIG_FOO defines which contain the DRAM base address since they end @@ -52,16 +54,6 @@ /* V3s do not have enough memory to place code at 0x4a000000 */ #endif
-/* - * The A80's A1 sram starts at 0x00010000 rather then at 0x00000000 and is - * slightly bigger. Note that it is possible to map the first 32 KiB of the - * A1 at 0x00000000 like with older SoCs by writing 0x16aa0001 to the - * undocumented 0x008000e0 SYS_CTRL register. Where the 16aa is a key and - * the 1 actually activates the mapping of the first 32 KiB to 0x00000000. - * A64 and H5 also has SRAM A1 at 0x00010000, but no magic remap register - * is known yet. - * H6 has SRAM A1 at 0x00020000. - */ #define CFG_SYS_INIT_RAM_ADDR CONFIG_SUNXI_SRAM_ADDRESS /* FIXME: this may be larger on some SoCs */ #define CFG_SYS_INIT_RAM_SIZE 0x8000 /* 32 KiB */ @@ -69,36 +61,13 @@ #define PHYS_SDRAM_0 CFG_SYS_SDRAM_BASE #define PHYS_SDRAM_0_SIZE 0x80000000 /* 2 GiB */
-/* - * Miscellaneous configurable options - */ - -/* FLASH and environment organization */ - +/**************************************************************************** + * environment variables holding default load addresses * + ****************************************************************************/ /* * We cannot use expressions here, because expressions won't be evaluated in * autoconf.mk. */ -#if CONFIG_SUNXI_SRAM_ADDRESS == 0x10000 -#ifdef CONFIG_ARM64 -/* end of SRAM A2 for now, as SRAM A1 is pretty tight for an ARM64 build */ -#define LOW_LEVEL_SRAM_STACK 0x00054000 -#else -#define LOW_LEVEL_SRAM_STACK 0x00018000 -#endif /* !CONFIG_ARM64 */ -#elif CONFIG_SUNXI_SRAM_ADDRESS == 0x20000 -#ifdef CONFIG_MACH_SUN50I_H616 -#define LOW_LEVEL_SRAM_STACK 0x52a00 /* below FEL buffers */ -#else -/* end of SRAM A2 on H6 for now */ -#define LOW_LEVEL_SRAM_STACK 0x00118000 -#endif -#else -#define LOW_LEVEL_SRAM_STACK 0x00008000 /* End of sram */ -#endif - -/* Ethernet support */ - #ifdef CONFIG_ARM64 /* * Boards seem to come with at least 512MB of DRAM. @@ -174,15 +143,11 @@ "ramdisk_addr_r=" RAMDISK_ADDR_R "\0"
#ifdef CONFIG_ARM64 - #define MEM_LAYOUT_ENV_EXTRA_SETTINGS \ "kernel_comp_addr_r=" KERNEL_COMP_ADDR_R "\0" \ "kernel_comp_size=" KERNEL_COMP_SIZE "\0" - #else - #define MEM_LAYOUT_ENV_EXTRA_SETTINGS "" - #endif
#define DFU_ALT_INFO_RAM \ @@ -191,6 +156,9 @@ "fdt ram " FDT_ADDR_R " 0x100000;" \ "ramdisk ram " RAMDISK_ADDR_R " 0x4000000\0"
+/**************************************************************************** + * definitions for the distro boot system * + ****************************************************************************/ #ifdef CONFIG_MMC #if CONFIG_MMC_SUNXI_SLOT_EXTRA != -1 #define BOOTENV_DEV_MMC_AUTO(devtypeu, devtypel, instance) \
The cpu_sun50i_h6.h header file defined the base addresses for quite some peripherals of the Allwinner H6 and related CPUs, even though we now only use a fraction of that. Most of the addresses are now either read from the DT, or were never used in U-Boot in the first place.
Removed the ones that are not used in the whole of the U-Boot source. to make it clear that this file only contains addresses that are needed for the SPL operation.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- .../include/asm/arch-sunxi/cpu_sun50i_h6.h | 21 ------------------- 1 file changed, 21 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/cpu_sun50i_h6.h b/arch/arm/include/asm/arch-sunxi/cpu_sun50i_h6.h index 15ee092d358..8a3f465545a 100644 --- a/arch/arm/include/asm/arch-sunxi/cpu_sun50i_h6.h +++ b/arch/arm/include/asm/arch-sunxi/cpu_sun50i_h6.h @@ -7,25 +7,14 @@ #ifndef _SUNXI_CPU_SUN50I_H6_H #define _SUNXI_CPU_SUN50I_H6_H
-#define SUNXI_SRAM_A1_BASE CONFIG_SUNXI_SRAM_ADDRESS -#define SUNXI_SRAM_C_BASE 0x00028000 -#define SUNXI_SRAM_A2_BASE 0x00100000 - -#define SUNXI_DE3_BASE 0x01000000 -#define SUNXI_SS_BASE 0x01904000 -#define SUNXI_EMCE_BASE 0x01905000 - #define SUNXI_SRAMC_BASE 0x03000000 #define SUNXI_CCM_BASE 0x03001000 -#define SUNXI_DMA_BASE 0x03002000 /* SID address space starts at 0x03006000, but e-fuse is at offset 0x200 */ #define SUNXI_SIDC_BASE 0x03006000 #define SUNXI_SID_BASE 0x03006200 #define SUNXI_TIMER_BASE 0x03009000 -#define SUNXI_PSI_BASE 0x0300C000
#define SUNXI_GIC400_BASE 0x03020000 -#define SUNXI_IOMMU_BASE 0x030F0000
#ifdef CONFIG_MACH_SUN50I_H6 #define SUNXI_DRAM_COM_BASE 0x04002000 @@ -46,18 +35,8 @@ #define SUNXI_TWI1_BASE 0x05002400 #define SUNXI_TWI2_BASE 0x05002800 #define SUNXI_TWI3_BASE 0x05002C00 -#define SUNXI_SPI0_BASE 0x05010000 -#define SUNXI_SPI1_BASE 0x05011000 -#define SUNXI_GMAC_BASE 0x05020000 -#define SUNXI_USB0_BASE 0x05100000 -#define SUNXI_XHCI_BASE 0x05200000 -#define SUNXI_USB3_BASE 0x05311000 -#define SUNXI_PCIE_BASE 0x05400000
#define SUNXI_HDMI_BASE 0x06000000 -#define SUNXI_TCON_TOP_BASE 0x06510000 -#define SUNXI_TCON_LCD0_BASE 0x06511000 -#define SUNXI_TCON_TV0_BASE 0x06515000
#define SUNXI_RTC_BASE 0x07000000 #define SUNXI_R_CPUCFG_BASE 0x07000400
The cpu_sun4i.h header file defined the base addresses for quite some peripherals of earlier Allwinner CPUs, even though we now only use a fraction of that. Most of the addresses are now either read from the DT, or were never used in U-Boot in the first place.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/include/asm/arch-sunxi/cpu_sun4i.h | 47 --------------------- 1 file changed, 47 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h b/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h index 3daee2f574a..f023a4cfd93 100644 --- a/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h +++ b/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h @@ -36,58 +36,20 @@
#define SUNXI_SRAMC_BASE 0x01c00000 #define SUNXI_DRAMC_BASE 0x01c01000 -#define SUNXI_DMA_BASE 0x01c02000 #define SUNXI_NFC_BASE 0x01c03000 -#define SUNXI_TS_BASE 0x01c04000 -#define SUNXI_SPI0_BASE 0x01c05000 -#define SUNXI_SPI1_BASE 0x01c06000 -#define SUNXI_MS_BASE 0x01c07000 -#define SUNXI_TVD_BASE 0x01c08000 -#define SUNXI_CSI0_BASE 0x01c09000 #ifndef CONFIG_MACH_SUNXI_H3_H5 #define SUNXI_TVE0_BASE 0x01c0a000 #endif -#define SUNXI_EMAC_BASE 0x01c0b000 #define SUNXI_LCD0_BASE 0x01c0C000 #define SUNXI_LCD1_BASE 0x01c0d000 -#define SUNXI_VE_BASE 0x01c0e000 #define SUNXI_MMC0_BASE 0x01c0f000 #define SUNXI_MMC1_BASE 0x01c10000 #define SUNXI_MMC2_BASE 0x01c11000 #define SUNXI_MMC3_BASE 0x01c12000 -#ifdef CONFIG_SUNXI_GEN_SUN4I -#define SUNXI_USB0_BASE 0x01c13000 -#define SUNXI_USB1_BASE 0x01c14000 -#endif #define SUNXI_SS_BASE 0x01c15000 #if !defined(CONFIG_MACH_SUNXI_H3_H5) && !defined(CONFIG_MACH_SUN50I) #define SUNXI_HDMI_BASE 0x01c16000 #endif -#define SUNXI_SPI2_BASE 0x01c17000 -#define SUNXI_SATA_BASE 0x01c18000 -#ifdef CONFIG_SUNXI_GEN_SUN4I -#define SUNXI_PATA_BASE 0x01c19000 -#define SUNXI_ACE_BASE 0x01c1a000 -#define SUNXI_TVE1_BASE 0x01c1b000 -#define SUNXI_USB2_BASE 0x01c1c000 -#endif -#ifdef CONFIG_SUNXI_GEN_SUN6I -#if defined(CONFIG_MACH_SUNXI_H3_H5) || defined(CONFIG_MACH_SUN50I) -#define SUNXI_USBPHY_BASE 0x01c19000 -#define SUNXI_USB0_BASE SUNXI_USBPHY_BASE -#define SUNXI_USB1_BASE 0x01c1a000 -#define SUNXI_USB2_BASE 0x01c1b000 -#define SUNXI_USB3_BASE 0x01c1c000 -#define SUNXI_USB4_BASE 0x01c1d000 -#else -#define SUNXI_USB0_BASE 0x01c19000 -#define SUNXI_USB1_BASE 0x01c1a000 -#define SUNXI_USB2_BASE 0x01c1b000 -#endif -#endif -#define SUNXI_CSI1_BASE 0x01c1d000 -#define SUNXI_TZASC_BASE 0x01c1e000 -#define SUNXI_SPI3_BASE 0x01c1f000
#define SUNXI_CCM_BASE 0x01c20000 #define SUNXI_INTC_BASE 0x01c20400 @@ -177,8 +139,6 @@ defined(CONFIG_MACH_SUN50I) #else #define SUNXI_TVE0_BASE 0x01e40000 #endif -#define SUNXI_MP_BASE 0x01e80000 -#define SUNXI_AVG_BASE 0x01ea0000
#if defined(CONFIG_MACH_SUNXI_H3_H5) || defined(CONFIG_MACH_SUN50I) #define SUNXI_HDMI_BASE 0x01ee0000 @@ -197,13 +157,6 @@ defined(CONFIG_MACH_SUN50I) #define SUN6I_P2WI_BASE 0x01f03400 #define SUNXI_RSB_BASE 0x01f03400
-/* CoreSight Debug Module */ -#define SUNXI_CSDM_BASE 0x3f500000 - -#define SUNXI_DDRII_DDRIII_BASE 0x40000000 /* 2 GiB */ - -#define SUNXI_BROM_BASE 0xffff0000 /* 32 kiB */ - #define SUNXI_CPU_CFG (SUNXI_TIMER_BASE + 0x13c)
/* SS bonding ids used for cpu identification */
The cpu_sun9i.h header file defined the base addresses for quite some peripherals of the Allwinner A80 CPU, even though we now only use a fraction of that. Most of the addresses are now either read from the DT, or were never used in U-Boot in the first place.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/include/asm/arch-sunxi/cpu_sun9i.h | 41 --------------------- 1 file changed, 41 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/cpu_sun9i.h b/arch/arm/include/asm/arch-sunxi/cpu_sun9i.h index 2bf2675d5c1..73de4707c16 100644 --- a/arch/arm/include/asm/arch-sunxi/cpu_sun9i.h +++ b/arch/arm/include/asm/arch-sunxi/cpu_sun9i.h @@ -20,7 +20,6 @@
/* AHB0 Module */ #define SUNXI_NFC_BASE (REGS_AHB0_BASE + 0x3000) -#define SUNXI_TSC_BASE (REGS_AHB0_BASE + 0x4000)
#define SUNXI_GTBUS_BASE (REGS_AHB0_BASE + 0x9000) /* SID address space starts at 0x01ce000, but e-fuse is at offset 0x200 */ @@ -32,14 +31,7 @@ #define SUNXI_MMC3_BASE (REGS_AHB0_BASE + 0x12000) #define SUNXI_MMC_COMMON_BASE (REGS_AHB0_BASE + 0x13000)
-#define SUNXI_SPI0_BASE (REGS_AHB0_BASE + 0x1A000) -#define SUNXI_SPI1_BASE (REGS_AHB0_BASE + 0x1B000) -#define SUNXI_SPI2_BASE (REGS_AHB0_BASE + 0x1C000) -#define SUNXI_SPI3_BASE (REGS_AHB0_BASE + 0x1D000) - #define SUNXI_GIC400_BASE (REGS_AHB0_BASE + 0x40000) -#define SUNXI_ARMA9_GIC_BASE (REGS_AHB0_BASE + 0x41000) -#define SUNXI_ARMA9_CPUIF_BASE (REGS_AHB0_BASE + 0x42000)
#define SUNXI_DRAM_COM_BASE (REGS_AHB0_BASE + 0x62000) #define SUNXI_DRAM_CTL0_BASE (REGS_AHB0_BASE + 0x63000) @@ -47,59 +39,26 @@ #define SUNXI_DRAM_PHY0_BASE (REGS_AHB0_BASE + 0x65000) #define SUNXI_DRAM_PHY1_BASE (REGS_AHB0_BASE + 0x66000)
-/* AHB1 Module */ -#define SUNXI_DMA_BASE (REGS_AHB1_BASE + 0x002000) -#define SUNXI_USBOTG_BASE (REGS_AHB1_BASE + 0x100000) -#define SUNXI_USBEHCI0_BASE (REGS_AHB1_BASE + 0x200000) -#define SUNXI_USBEHCI1_BASE (REGS_AHB1_BASE + 0x201000) -#define SUNXI_USBEHCI2_BASE (REGS_AHB1_BASE + 0x202000) - -/* AHB2 Module */ -#define SUNXI_DE_SYS_BASE (REGS_AHB2_BASE + 0x000000) -#define SUNXI_DISP_SYS_BASE (REGS_AHB2_BASE + 0x010000) #define SUNXI_DE_FE0_BASE (REGS_AHB2_BASE + 0x100000) -#define SUNXI_DE_FE1_BASE (REGS_AHB2_BASE + 0x140000) -#define SUNXI_DE_FE2_BASE (REGS_AHB2_BASE + 0x180000) - #define SUNXI_DE_BE0_BASE (REGS_AHB2_BASE + 0x200000) -#define SUNXI_DE_BE1_BASE (REGS_AHB2_BASE + 0x240000) -#define SUNXI_DE_BE2_BASE (REGS_AHB2_BASE + 0x280000) - -#define SUNXI_DE_DEU0_BASE (REGS_AHB2_BASE + 0x300000) -#define SUNXI_DE_DEU1_BASE (REGS_AHB2_BASE + 0x340000) -#define SUNXI_DE_DRC0_BASE (REGS_AHB2_BASE + 0x400000) -#define SUNXI_DE_DRC1_BASE (REGS_AHB2_BASE + 0x440000) - #define SUNXI_LCD0_BASE (REGS_AHB2_BASE + 0xC00000) #define SUNXI_LCD1_BASE (REGS_AHB2_BASE + 0xC10000) #define SUNXI_LCD2_BASE (REGS_AHB2_BASE + 0xC20000) -#define SUNXI_MIPI_DSI0_BASE (REGS_AHB2_BASE + 0xC40000) -/* Also seen as SUNXI_MIPI_DSI0_DPHY_BASE 0x01ca1000 */ -#define SUNXI_MIPI_DSI0_DPHY_BASE (REGS_AHB2_BASE + 0xC40100) #define SUNXI_HDMI_BASE (REGS_AHB2_BASE + 0xD00000)
/* APB0 Module */ #define SUNXI_CCM_BASE (REGS_APB0_BASE + 0x0000) -#define SUNXI_CCMMODULE_BASE (REGS_APB0_BASE + 0x0400) #define SUNXI_TIMER_BASE (REGS_APB0_BASE + 0x0C00) #define SUNXI_PWM_BASE (REGS_APB0_BASE + 0x1400) -#define SUNXI_LRADC_BASE (REGS_APB0_BASE + 0x1800)
/* APB1 Module */ #define SUNXI_TWI0_BASE (REGS_APB1_BASE + 0x2800) #define SUNXI_TWI1_BASE (REGS_APB1_BASE + 0x2C00) -#define SUNXI_TWI2_BASE (REGS_APB1_BASE + 0x3000) -#define SUNXI_TWI3_BASE (REGS_APB1_BASE + 0x3400) -#define SUNXI_TWI4_BASE (REGS_APB1_BASE + 0x3800)
/* RCPUS Module */ #define SUNXI_PRCM_BASE (REGS_RCPUS_BASE + 0x1400) #define SUNXI_RSB_BASE (REGS_RCPUS_BASE + 0x3400)
-/* Misc. */ -#define SUNXI_BROM_BASE 0xFFFF0000 /* 32K */ -#define SUNXI_CPU_CFG (SUNXI_TIMER_BASE + 0x13c) - #ifndef __ASSEMBLY__ void sunxi_board_init(void); void sunxi_reset(void);
Some later 32-bit SoCs require some setup of the Secure Peripherals Controller, which is handled in tzpc_init(). At the moment this is guarded in board.c by some #ifdefs selecting the SoCs that need it.
Move those #ifdef guards into the header file, providing an empty stub function for all other SoCs, so that the #ifdefs can be removed from the .c file, to improve readability.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/include/asm/arch-sunxi/tzpc.h | 6 ++++++ arch/arm/mach-sunxi/board.c | 2 -- 2 files changed, 6 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/tzpc.h b/arch/arm/include/asm/arch-sunxi/tzpc.h index 7a6fcaebdb5..92696088a39 100644 --- a/arch/arm/include/asm/arch-sunxi/tzpc.h +++ b/arch/arm/include/asm/arch-sunxi/tzpc.h @@ -28,6 +28,12 @@ struct sunxi_tzpc { #define SUN8I_H3_TZPC_DECPORT1_ALL 0xff #define SUN8I_H3_TZPC_DECPORT2_ALL 0x7f
+#if defined CONFIG_MACH_SUN6I || defined CONFIG_MACH_SUN8I_H3 void tzpc_init(void); +#else +static inline void tzpc_init(void) +{ +} +#endif
#endif /* _SUNXI_TZPC_H */ diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index 11a49418225..d998149e375 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -459,10 +459,8 @@ void board_init_f(ulong dummy) { sunxi_sram_init();
-#if defined CONFIG_MACH_SUN6I || defined CONFIG_MACH_SUN8I_H3 /* Enable non-secure access to some peripherals */ tzpc_init(); -#endif
clock_init(); timer_init();
The usage of the common.h include file is deprecated, and has already been removed from several files.
Get rid of all inclusions in the arch/arm/mach-sunxi directory. Most files actually don't need the header at all, for the few others just include the headers that we actually require.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/mach-sunxi/board.c | 1 - arch/arm/mach-sunxi/clock.c | 1 - arch/arm/mach-sunxi/clock_sun4i.c | 1 - arch/arm/mach-sunxi/clock_sun50i_h6.c | 1 - arch/arm/mach-sunxi/clock_sun6i.c | 1 - arch/arm/mach-sunxi/clock_sun8i_a83t.c | 1 - arch/arm/mach-sunxi/clock_sun9i.c | 1 - arch/arm/mach-sunxi/cpu_info.c | 1 - arch/arm/mach-sunxi/dram_helpers.c | 3 ++- arch/arm/mach-sunxi/dram_sun4i.c | 1 - arch/arm/mach-sunxi/dram_sun50i_h6.c | 1 - arch/arm/mach-sunxi/dram_sun50i_h616.c | 1 - arch/arm/mach-sunxi/dram_sun6i.c | 1 - arch/arm/mach-sunxi/dram_sun8i_a23.c | 1 - arch/arm/mach-sunxi/dram_sun8i_a33.c | 1 - arch/arm/mach-sunxi/dram_sun8i_a83t.c | 1 - arch/arm/mach-sunxi/dram_sun9i.c | 1 - arch/arm/mach-sunxi/dram_suniv.c | 2 +- arch/arm/mach-sunxi/dram_sunxi_dw.c | 1 - arch/arm/mach-sunxi/gtbus_sun9i.c | 1 - arch/arm/mach-sunxi/pmic_bus.c | 1 - arch/arm/mach-sunxi/prcm.c | 1 - arch/arm/mach-sunxi/spl_spi_sunxi.c | 1 - arch/arm/mach-sunxi/timer.c | 1 - 24 files changed, 3 insertions(+), 24 deletions(-)
diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index d998149e375..0140b07d32a 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -9,7 +9,6 @@ * Some init for sunxi platform. */
-#include <common.h> #include <cpu_func.h> #include <init.h> #include <log.h> diff --git a/arch/arm/mach-sunxi/clock.c b/arch/arm/mach-sunxi/clock.c index da3a0eb0584..b6c68c94f67 100644 --- a/arch/arm/mach-sunxi/clock.c +++ b/arch/arm/mach-sunxi/clock.c @@ -7,7 +7,6 @@ * (C) Copyright 2013 Luke Kenneth Casson Leighton lkcl@lkcl.net */
-#include <common.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/prcm.h> diff --git a/arch/arm/mach-sunxi/clock_sun4i.c b/arch/arm/mach-sunxi/clock_sun4i.c index 471609764d2..8f1d1b65f00 100644 --- a/arch/arm/mach-sunxi/clock_sun4i.c +++ b/arch/arm/mach-sunxi/clock_sun4i.c @@ -9,7 +9,6 @@ * (C) Copyright 2013 Luke Kenneth Casson Leighton lkcl@lkcl.net */
-#include <common.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> diff --git a/arch/arm/mach-sunxi/clock_sun50i_h6.c b/arch/arm/mach-sunxi/clock_sun50i_h6.c index bea91c78bc5..dac3663e1be 100644 --- a/arch/arm/mach-sunxi/clock_sun50i_h6.c +++ b/arch/arm/mach-sunxi/clock_sun50i_h6.c @@ -1,4 +1,3 @@ -#include <common.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/clock.h> diff --git a/arch/arm/mach-sunxi/clock_sun6i.c b/arch/arm/mach-sunxi/clock_sun6i.c index 6bd75a15f6d..aad9df282ec 100644 --- a/arch/arm/mach-sunxi/clock_sun6i.c +++ b/arch/arm/mach-sunxi/clock_sun6i.c @@ -9,7 +9,6 @@ * (C) Copyright 2013 Luke Kenneth Casson Leighton lkcl@lkcl.net */
-#include <common.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/prcm.h> diff --git a/arch/arm/mach-sunxi/clock_sun8i_a83t.c b/arch/arm/mach-sunxi/clock_sun8i_a83t.c index 31e4281529a..198fe9dbd73 100644 --- a/arch/arm/mach-sunxi/clock_sun8i_a83t.c +++ b/arch/arm/mach-sunxi/clock_sun8i_a83t.c @@ -9,7 +9,6 @@ * (C) Copyright 2015 Vishnu Patekar vishnupatekar0510@gmail.com */
-#include <common.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/prcm.h> diff --git a/arch/arm/mach-sunxi/clock_sun9i.c b/arch/arm/mach-sunxi/clock_sun9i.c index 8ba4802f3b3..edaff9a28ce 100644 --- a/arch/arm/mach-sunxi/clock_sun9i.c +++ b/arch/arm/mach-sunxi/clock_sun9i.c @@ -9,7 +9,6 @@ * Philipp Tomsich philipp.tomsich@theobroma-systems.com */
-#include <common.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/prcm.h> diff --git a/arch/arm/mach-sunxi/cpu_info.c b/arch/arm/mach-sunxi/cpu_info.c index 7fecc3b88dd..310dca06e57 100644 --- a/arch/arm/mach-sunxi/cpu_info.c +++ b/arch/arm/mach-sunxi/cpu_info.c @@ -5,7 +5,6 @@ * Tom Cubie tangliang@allwinnertech.com */
-#include <common.h> #include <init.h> #include <asm/io.h> #include <asm/arch/cpu.h> diff --git a/arch/arm/mach-sunxi/dram_helpers.c b/arch/arm/mach-sunxi/dram_helpers.c index cdf2750f1c5..4a867df7af8 100644 --- a/arch/arm/mach-sunxi/dram_helpers.c +++ b/arch/arm/mach-sunxi/dram_helpers.c @@ -5,8 +5,9 @@ * (C) Copyright 2015 Hans de Goede hdegoede@redhat.com */
-#include <common.h> +#include <config.h> #include <time.h> +#include <vsprintf.h> #include <asm/barriers.h> #include <asm/io.h> #include <asm/arch/dram.h> diff --git a/arch/arm/mach-sunxi/dram_sun4i.c b/arch/arm/mach-sunxi/dram_sun4i.c index 80a6c4bc0fd..2cce381c9df 100644 --- a/arch/arm/mach-sunxi/dram_sun4i.c +++ b/arch/arm/mach-sunxi/dram_sun4i.c @@ -20,7 +20,6 @@ * rather undocumented and full of magic. */
-#include <common.h> #include <init.h> #include <asm/io.h> #include <asm/arch/clock.h> diff --git a/arch/arm/mach-sunxi/dram_sun50i_h6.c b/arch/arm/mach-sunxi/dram_sun50i_h6.c index bff2e42513c..e7e2e6a06ff 100644 --- a/arch/arm/mach-sunxi/dram_sun50i_h6.c +++ b/arch/arm/mach-sunxi/dram_sun50i_h6.c @@ -5,7 +5,6 @@ * (C) Copyright 2017 Icenowy Zheng icenowy@aosc.io * */ -#include <common.h> #include <init.h> #include <log.h> #include <asm/io.h> diff --git a/arch/arm/mach-sunxi/dram_sun50i_h616.c b/arch/arm/mach-sunxi/dram_sun50i_h616.c index c5c1331a4c3..68c49e85f9d 100644 --- a/arch/arm/mach-sunxi/dram_sun50i_h616.c +++ b/arch/arm/mach-sunxi/dram_sun50i_h616.c @@ -12,7 +12,6 @@ * (C) Copyright 2020 Jernej Skrabec jernej.skrabec@siol.net * */ -#include <common.h> #include <init.h> #include <log.h> #include <asm/io.h> diff --git a/arch/arm/mach-sunxi/dram_sun6i.c b/arch/arm/mach-sunxi/dram_sun6i.c index 0590110d4ac..c023845908f 100644 --- a/arch/arm/mach-sunxi/dram_sun6i.c +++ b/arch/arm/mach-sunxi/dram_sun6i.c @@ -9,7 +9,6 @@ * * (C) Copyright 2014 Hans de Goede hdegoede@redhat.com */ -#include <common.h> #include <errno.h> #include <init.h> #include <asm/io.h> diff --git a/arch/arm/mach-sunxi/dram_sun8i_a23.c b/arch/arm/mach-sunxi/dram_sun8i_a23.c index 056cb03efb1..1c3c6d8126e 100644 --- a/arch/arm/mach-sunxi/dram_sun8i_a23.c +++ b/arch/arm/mach-sunxi/dram_sun8i_a23.c @@ -19,7 +19,6 @@ * This may be used as a (possible) reference for future work / cleanups. */
-#include <common.h> #include <errno.h> #include <init.h> #include <asm/io.h> diff --git a/arch/arm/mach-sunxi/dram_sun8i_a33.c b/arch/arm/mach-sunxi/dram_sun8i_a33.c index 367b74061ed..0d08b6a424e 100644 --- a/arch/arm/mach-sunxi/dram_sun8i_a33.c +++ b/arch/arm/mach-sunxi/dram_sun8i_a33.c @@ -7,7 +7,6 @@ * (C) Copyright 2015 Vishnu Patekar vishnupatekar0510@gmail.com * (C) Copyright 2015 Hans de Goede hdegoede@redhat.com */ -#include <common.h> #include <errno.h> #include <init.h> #include <asm/io.h> diff --git a/arch/arm/mach-sunxi/dram_sun8i_a83t.c b/arch/arm/mach-sunxi/dram_sun8i_a83t.c index a3f833dd341..ef833321e37 100644 --- a/arch/arm/mach-sunxi/dram_sun8i_a83t.c +++ b/arch/arm/mach-sunxi/dram_sun8i_a83t.c @@ -7,7 +7,6 @@ * (C) Copyright 2015 Vishnu Patekar vishnupatekar0510@gmail.com * (C) Copyright 2015 Hans de Goede hdegoede@redhat.com */ -#include <common.h> #include <errno.h> #include <init.h> #include <asm/io.h> diff --git a/arch/arm/mach-sunxi/dram_sun9i.c b/arch/arm/mach-sunxi/dram_sun9i.c index 14be212e891..002b6df39d5 100644 --- a/arch/arm/mach-sunxi/dram_sun9i.c +++ b/arch/arm/mach-sunxi/dram_sun9i.c @@ -10,7 +10,6 @@ * Philipp Tomsich philipp.tomsich@theobroma-systems.com */
-#include <common.h> #include <dm.h> #include <errno.h> #include <init.h> diff --git a/arch/arm/mach-sunxi/dram_suniv.c b/arch/arm/mach-sunxi/dram_suniv.c index 9e583e18553..640f872ad4c 100644 --- a/arch/arm/mach-sunxi/dram_suniv.c +++ b/arch/arm/mach-sunxi/dram_suniv.c @@ -9,7 +9,7 @@ * Copyright(c) 2007-2018 Jianjun Jiang 8192542@qq.com */
-#include <common.h> +#include <config.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/dram.h> diff --git a/arch/arm/mach-sunxi/dram_sunxi_dw.c b/arch/arm/mach-sunxi/dram_sunxi_dw.c index 9382d3d0be8..b4074f7d9b3 100644 --- a/arch/arm/mach-sunxi/dram_sunxi_dw.c +++ b/arch/arm/mach-sunxi/dram_sunxi_dw.c @@ -8,7 +8,6 @@ * (C) Copyright 2015 Hans de Goede hdegoede@redhat.com * (C) Copyright 2015 Jens Kuske jenskuske@gmail.com */ -#include <common.h> #include <init.h> #include <log.h> #include <asm/io.h> diff --git a/arch/arm/mach-sunxi/gtbus_sun9i.c b/arch/arm/mach-sunxi/gtbus_sun9i.c index 5624621b500..a058fea6bef 100644 --- a/arch/arm/mach-sunxi/gtbus_sun9i.c +++ b/arch/arm/mach-sunxi/gtbus_sun9i.c @@ -6,7 +6,6 @@ * Philipp Tomsich philipp.tomsich@theobroma-systems.com */
-#include <common.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/gtbus_sun9i.h> diff --git a/arch/arm/mach-sunxi/pmic_bus.c b/arch/arm/mach-sunxi/pmic_bus.c index 8e7625fe057..87df312725c 100644 --- a/arch/arm/mach-sunxi/pmic_bus.c +++ b/arch/arm/mach-sunxi/pmic_bus.c @@ -9,7 +9,6 @@ */
#include <axp_pmic.h> -#include <common.h> #include <dm.h> #include <asm/arch/p2wi.h> #include <asm/arch/rsb.h> diff --git a/arch/arm/mach-sunxi/prcm.c b/arch/arm/mach-sunxi/prcm.c index 71a2e44918e..ef7c46eab3b 100644 --- a/arch/arm/mach-sunxi/prcm.c +++ b/arch/arm/mach-sunxi/prcm.c @@ -13,7 +13,6 @@ * Tom Cubie tangliang@allwinnertech.com */
-#include <common.h> #include <errno.h> #include <asm/io.h> #include <asm/arch/cpu.h> diff --git a/arch/arm/mach-sunxi/spl_spi_sunxi.c b/arch/arm/mach-sunxi/spl_spi_sunxi.c index c2410dd7bb1..0a2714d2dd9 100644 --- a/arch/arm/mach-sunxi/spl_spi_sunxi.c +++ b/arch/arm/mach-sunxi/spl_spi_sunxi.c @@ -3,7 +3,6 @@ * Copyright (C) 2016 Siarhei Siamashka siarhei.siamashka@gmail.com */
-#include <common.h> #include <image.h> #include <log.h> #include <spl.h> diff --git a/arch/arm/mach-sunxi/timer.c b/arch/arm/mach-sunxi/timer.c index 9a6f6c06d8c..1bbfad5e520 100644 --- a/arch/arm/mach-sunxi/timer.c +++ b/arch/arm/mach-sunxi/timer.c @@ -5,7 +5,6 @@ * Tom Cubie tangliang@allwinnertech.com */
-#include <common.h> #include <init.h> #include <time.h> #include <asm/global_data.h>
At the moment every Allwinner board builds and requires an SPL, even though we select this individually in each _defconfig file. For experiments and for early bringup of new SoCs it would be beneficial to only build U-Boot proper, for instance to postpone a tedious SPL port (including DRAM support) in the initial phase.
Protect some SPL related symbols that we unconditionally select at the moment with "if SPL", to avoid Kconfig conflicts when CONFIG_SPL is disabled.
This alone does not cleanly build U-Boot proper only yet, but gets it far enough so that the binary can be harvested.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/Kconfig | 4 ++-- arch/arm/mach-sunxi/Kconfig | 16 ++++++++-------- 2 files changed, 10 insertions(+), 10 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index d812685c984..adce50c66a4 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1143,14 +1143,14 @@ config ARCH_SUNXI select SPL_SEPARATE_BSS if SPL select SPL_STACK_R if SPL select SPL_SYS_MALLOC_SIMPLE if SPL - select SPL_SYS_THUMB_BUILD if !ARM64 + select SPL_SYS_THUMB_BUILD if SPL && !ARM64 select SUNXI_GPIO select SYS_NS16550 select SYS_THUMB_BUILD if !ARM64 select USB if DISTRO_DEFAULTS select USB_KEYBOARD if DISTRO_DEFAULTS && USB_HOST select USB_STORAGE if DISTRO_DEFAULTS && USB_HOST - select SPL_USE_TINY_PRINTF + select SPL_USE_TINY_PRINTF if SPL select USE_PREBOOT select SYS_RELOC_GD_ENV_ADDR imply BOARD_LATE_INIT diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index a4a8d8e9445..421a48bc357 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -182,7 +182,7 @@ config SUNXI_GEN_SUN6I config SUN50I_GEN_H6 bool select FIT - select SPL_LOAD_FIT + select SPL_LOAD_FIT if SPL select MMC_SUNXI_HAS_NEW_MODE select SUPPORT_SPL ---help--- @@ -272,7 +272,7 @@ config MACH_SUN6I select ARCH_SUPPORT_PSCI select SPL_ARMV7_SET_CORTEX_SMPEN select DRAM_SUN6I - select SPL_I2C + select SPL_I2C if SPL select SUN6I_PRCM select SUNXI_GEN_SUN6I select SUPPORT_SPL @@ -300,7 +300,7 @@ config MACH_SUN8I_A23 select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI select DRAM_SUN8I_A23 - select SPL_I2C + select SPL_I2C if SPL select SUNXI_GEN_SUN6I select SUPPORT_SPL select SYS_I2C_SUN8I_RSB @@ -313,7 +313,7 @@ config MACH_SUN8I_A33 select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI select DRAM_SUN8I_A33 - select SPL_I2C + select SPL_I2C if SPL select SUNXI_GEN_SUN6I select SUPPORT_SPL select SYS_I2C_SUN8I_RSB @@ -323,7 +323,7 @@ config MACH_SUN8I_A83T bool "sun8i (Allwinner A83T)" select CPU_V7A select DRAM_SUN8I_A83T - select SPL_I2C + select SPL_I2C if SPL select SUNXI_GEN_SUN6I select MMC_SUNXI_HAS_NEW_MODE select MMC_SUNXI_HAS_MODE_SWITCH @@ -382,7 +382,7 @@ config MACH_SUN9I select CPU_V7A select SPL_ARMV7_SET_CORTEX_SMPEN select DRAM_SUN9I - select SPL_I2C + select SPL_I2C if SPL select SUN6I_PRCM select SUNXI_GEN_SUN6I select SUPPORT_SPL @@ -398,7 +398,7 @@ config MACH_SUN50I select SUNXI_DRAM_DW select SUNXI_DRAM_DW_32BIT select FIT - select SPL_LOAD_FIT + select SPL_LOAD_FIT if SPL select SUNXI_A64_TIMER_ERRATUM
config MACH_SUN50I_H5 @@ -407,7 +407,7 @@ config MACH_SUN50I_H5 select MACH_SUNXI_H3_H5 select MMC_SUNXI_HAS_NEW_MODE select FIT - select SPL_LOAD_FIT + select SPL_LOAD_FIT if SPL
config MACH_SUN50I_H6 bool "sun50i (Allwinner H6)"
The driver used for the Allwinner I2C IP is using proper DT and DM enablement for a while: we enable the clock gate and de-assert the reset line in the driver's probe() routine, and the pinmux setup is taken care of by the DM framework.
This means the explicit call to the i2c_init_board() routine is not needed for U-Boot proper. As the board_init() function in board.c is only called for U-Boot proper, we can remove the call, something that the comment there hinted at already.
Fix the comment for the board_init() function on the way: we were not really doing board specific setup there. The fact that this function is called from U-Boot proper only is probably more helpful for reasoning about this code.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- board/sunxi/board.c | 9 +-------- 1 file changed, 1 insertion(+), 8 deletions(-)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 8c12c8deade..1313b01dcea 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -186,7 +186,7 @@ enum env_location env_get_location(enum env_operation op, int prio) return ENVL_UNKNOWN; }
-/* add board specific code here */ +/* called only from U-Boot proper */ int board_init(void) { __maybe_unused int id_pfr1, ret; @@ -226,13 +226,6 @@ int board_init(void) if (ret) return ret;
-#if CONFIG_IS_ENABLED(DM_I2C) - /* - * Temporary workaround for enabling I2C clocks until proper sunxi DM - * clk, reset and pinctrl drivers land. - */ - i2c_init_board(); -#endif eth_init_board();
With the clock_twi_onoff() function now being called only from the SPL, the whole clock.c file in arch/arm/mach-sunxi is needed by SPL code only.
Remove the redundant #ifdef from the clock_init() function, actually this function was already only called from the SPL. Then adjust the Makefile to compile clock.c only with CONFIG_SPL_BUILD defined.
This avoids unnecessary code in U-Boot proper and allows further refactoring and code-split between the SPL and U-Boot proper.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/mach-sunxi/Makefile | 2 +- arch/arm/mach-sunxi/clock.c | 2 -- 2 files changed, 1 insertion(+), 3 deletions(-)
diff --git a/arch/arm/mach-sunxi/Makefile b/arch/arm/mach-sunxi/Makefile index 1d4c70ec352..3f83c0280ef 100644 --- a/arch/arm/mach-sunxi/Makefile +++ b/arch/arm/mach-sunxi/Makefile @@ -7,7 +7,6 @@ # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
obj-y += board.o -obj-y += clock.o obj-y += cpu_info.o obj-y += dram_helpers.o obj-$(CONFIG_SUN6I_PRCM) += prcm.o @@ -31,6 +30,7 @@ obj-y += timer.o endif
ifdef CONFIG_SPL_BUILD +obj-y += clock.o obj-$(CONFIG_MACH_SUNIV) += dram_suniv.o obj-$(CONFIG_DRAM_SUN4I) += dram_sun4i.o obj-$(CONFIG_DRAM_SUN6I) += dram_sun6i.o diff --git a/arch/arm/mach-sunxi/clock.c b/arch/arm/mach-sunxi/clock.c index b6c68c94f67..5e9fa0d0748 100644 --- a/arch/arm/mach-sunxi/clock.c +++ b/arch/arm/mach-sunxi/clock.c @@ -23,10 +23,8 @@ __weak void gtbus_init(void)
int clock_init(void) { -#ifdef CONFIG_SPL_BUILD clock_init_safe(); gtbus_init(); -#endif clock_init_uart(); clock_init_sec();
In clock_sun4i.c, responsible for (mostly early) clock setup on early generation Allwinner SoCs, many functions are only needed by the SPL, and are thus already guarded by CONFIG_SPL_BUILD.
Over the years drivers like for the UART or I2C were converted to DM, so they care about clock setup themselves now, by using a proper DM clock driver.
This means those devices need the clock setup functions here for the SPL only. Include those functions into the existing CONFIG_SPL_BUILD guards, so they are compiled for the SPL only.
This avoids unnecessary code in U-Boot proper and helps further refactoring. Add some comments on the way to help understanding of the file.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/mach-sunxi/clock_sun4i.c | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-sunxi/clock_sun4i.c b/arch/arm/mach-sunxi/clock_sun4i.c index 8f1d1b65f00..eead5a924f4 100644 --- a/arch/arm/mach-sunxi/clock_sun4i.c +++ b/arch/arm/mach-sunxi/clock_sun4i.c @@ -41,7 +41,6 @@ void clock_init_safe(void) setbits_le32(&ccm->pll6_cfg, 0x1 << CCM_PLL6_CTRL_SATA_EN_SHIFT); #endif } -#endif
void clock_init_uart(void) { @@ -75,7 +74,6 @@ int clock_twi_onoff(int port, int state) return 0; }
-#ifdef CONFIG_SPL_BUILD #define PLL1_CFG(N, K, M, P) ( 1 << CCM_PLL1_CFG_ENABLE_SHIFT | \ 0 << CCM_PLL1_CFG_VCO_RST_SHIFT | \ 8 << CCM_PLL1_CFG_VCO_BIAS_SHIFT | \ @@ -175,8 +173,9 @@ void clock_set_pll1(unsigned int hz) &ccm->cpu_ahb_apb0_cfg); sdelay(20); } -#endif +#endif /* CONFIG_SPL_BUILD */
+/* video, DRAM, PLL_PERIPH clocks */ void clock_set_pll3(unsigned int clk) { struct sunxi_ccm_reg * const ccm =
In clock_sun6i.c, responsible for (mostly early) clock setup on older generation Allwinner SoCs, many functions are only needed by the SPL, and are thus already guarded by CONFIG_SPL_BUILD.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/mach-sunxi/clock_sun6i.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/arm/mach-sunxi/clock_sun6i.c b/arch/arm/mach-sunxi/clock_sun6i.c index aad9df282ec..59f7e15ffe8 100644 --- a/arch/arm/mach-sunxi/clock_sun6i.c +++ b/arch/arm/mach-sunxi/clock_sun6i.c @@ -62,7 +62,6 @@ void clock_init_safe(void) setbits_le32(&ccm->sata_clk_cfg, CCM_SATA_CTRL_ENABLE); #endif } -#endif /* CONFIG_SPL_BUILD */
void clock_init_sec(void) { @@ -124,7 +123,6 @@ void clock_init_uart(void) #endif }
-#ifdef CONFIG_SPL_BUILD void clock_set_pll1(unsigned int clk) { struct sunxi_ccm_reg * const ccm = @@ -173,6 +171,7 @@ void clock_set_pll1(unsigned int clk) } #endif /* CONFIG_SPL_BUILD */
In clock_sun50i_h6.c, responsible for (mostly early) clock setup on newer generation Allwinner SoCs, many functions are only needed by the SPL, and are thus already guarded by CONFIG_SPL_BUILD.
This means those devices need the clock setup functions here for the SPL only. Include those functions into the existing CONFIG_SPL_BUILD guards, so they are compiled for the SPL only. By moving the clock_get_pll6() function to the end of the file, all SPL-only clocks can be contained within one #ifdef guard.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/mach-sunxi/clock_sun50i_h6.c | 57 +++++++++++++-------------- 1 file changed, 28 insertions(+), 29 deletions(-)
diff --git a/arch/arm/mach-sunxi/clock_sun50i_h6.c b/arch/arm/mach-sunxi/clock_sun50i_h6.c index dac3663e1be..cc2ee336416 100644 --- a/arch/arm/mach-sunxi/clock_sun50i_h6.c +++ b/arch/arm/mach-sunxi/clock_sun50i_h6.c @@ -51,7 +51,6 @@ void clock_init_safe(void) */ writel(MBUS_CLK_SRC_PLL6X2 | MBUS_CLK_M(3), &ccm->mbus_cfg); } -#endif
void clock_init_uart(void) { @@ -73,7 +72,6 @@ void clock_init_uart(void) 1 << (RESET_SHIFT + CONFIG_CONS_INDEX - 1)); }
-#ifdef CONFIG_SPL_BUILD void clock_set_pll1(unsigned int clk) { struct sunxi_ccm_reg * const ccm = @@ -105,33 +103,6 @@ void clock_set_pll1(unsigned int clk) val |= CCM_CPU_AXI_MUX_PLL_CPUX; writel(val, &ccm->cpu_axi_cfg); } -#endif - -unsigned int clock_get_pll6(void) -{ - struct sunxi_ccm_reg *const ccm = - (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; - uint32_t rval = readl(&ccm->pll6_cfg); - int n = ((rval & CCM_PLL6_CTRL_N_MASK) >> CCM_PLL6_CTRL_N_SHIFT) + 1; - int div2 = ((rval & CCM_PLL6_CTRL_DIV2_MASK) >> - CCM_PLL6_CTRL_DIV2_SHIFT) + 1; - int div1, m; - - if (IS_ENABLED(CONFIG_SUNXI_GEN_NCAT2)) { - div1 = ((rval & CCM_PLL6_CTRL_P0_MASK) >> - CCM_PLL6_CTRL_P0_SHIFT) + 1; - m = 1; - } else { - div1 = ((rval & CCM_PLL6_CTRL_DIV1_MASK) >> - CCM_PLL6_CTRL_DIV1_SHIFT) + 1; - if (IS_ENABLED(CONFIG_MACH_SUN50I_H6)) - m = 4; - else - m = 2; - } - - return 24000000U * n / m / div1 / div2; -}
int clock_twi_onoff(int port, int state) { @@ -160,3 +131,31 @@ int clock_twi_onoff(int port, int state)
return 0; } +#endif /* CONFIG_SPL_BUILD */ + +/* PLL_PERIPH0 clock, used by the MMC driver */ +unsigned int clock_get_pll6(void) +{ + struct sunxi_ccm_reg *const ccm = + (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + uint32_t rval = readl(&ccm->pll6_cfg); + int n = ((rval & CCM_PLL6_CTRL_N_MASK) >> CCM_PLL6_CTRL_N_SHIFT) + 1; + int div2 = ((rval & CCM_PLL6_CTRL_DIV2_MASK) >> + CCM_PLL6_CTRL_DIV2_SHIFT) + 1; + int div1, m; + + if (IS_ENABLED(CONFIG_SUNXI_GEN_NCAT2)) { + div1 = ((rval & CCM_PLL6_CTRL_P0_MASK) >> + CCM_PLL6_CTRL_P0_SHIFT) + 1; + m = 1; + } else { + div1 = ((rval & CCM_PLL6_CTRL_DIV1_MASK) >> + CCM_PLL6_CTRL_DIV1_SHIFT) + 1; + if (IS_ENABLED(CONFIG_MACH_SUN50I_H6)) + m = 4; + else + m = 2; + } + + return 24000000U * n / m / div1 / div2; +}
In clock_sun8i_a83t.c, responsible for (mostly early) clock setup on the Allwinner A83T SoC, many functions are only needed by the SPL, and are thus already guarded by CONFIG_SPL_BUILD.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/mach-sunxi/clock_sun8i_a83t.c | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-sunxi/clock_sun8i_a83t.c b/arch/arm/mach-sunxi/clock_sun8i_a83t.c index 198fe9dbd73..9eeba084f95 100644 --- a/arch/arm/mach-sunxi/clock_sun8i_a83t.c +++ b/arch/arm/mach-sunxi/clock_sun8i_a83t.c @@ -46,7 +46,6 @@ void clock_init_safe(void) /* timestamp */ writel(1, 0x01720000); } -#endif
void clock_init_uart(void) { @@ -70,7 +69,6 @@ void clock_init_uart(void) CONFIG_CONS_INDEX - 1)); }
-#ifdef CONFIG_SPL_BUILD void clock_set_pll1(unsigned int clk) { struct sunxi_ccm_reg * const ccm = @@ -102,8 +100,9 @@ void clock_set_pll1(unsigned int clk) CPU_CLK_SRC_PLL1 << C1_CPUX_CLK_SRC_SHIFT, &ccm->cpu_axi_cfg); } -#endif +#endif /* CONFIG_SPL_BUILD */
+/* DRAM and PLL_PERIPH0 clock (used by the MMC driver) */ void clock_set_pll5(unsigned int clk) { struct sunxi_ccm_reg * const ccm =
In clock_sun9i.c, responsible for (mostly early) clock setup on the Allwinner A80 SoC, many functions are only needed by the SPL, and are thus already guarded by CONFIG_SPL_BUILD.
Over the years drivers like for the UART or I2C were converted to DM, and they care about clock setup themselves now, by using a proper DM clock driver.
This means those devices need the clock setup functions here for the SPL only. Move some functions around, to group all SPL-only function within one #ifdef guard. Some functions were exported, but never used outside of this file, so remove their prototypes from the header file and mark them as static.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/include/asm/arch-sunxi/clock_sun9i.h | 3 - arch/arm/mach-sunxi/clock_sun9i.c | 97 +++++++++---------- 2 files changed, 48 insertions(+), 52 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/clock_sun9i.h b/arch/arm/include/asm/arch-sunxi/clock_sun9i.h index fe6b8ba2732..0264bfe1c50 100644 --- a/arch/arm/include/asm/arch-sunxi/clock_sun9i.h +++ b/arch/arm/include/asm/arch-sunxi/clock_sun9i.h @@ -220,10 +220,7 @@ struct sunxi_ccm_reg {
#ifndef __ASSEMBLY__ void clock_set_pll1(unsigned int clk); -void clock_set_pll2(unsigned int clk); -void clock_set_pll4(unsigned int clk); void clock_set_pll6(unsigned int clk); -void clock_set_pll12(unsigned int clk); unsigned int clock_get_pll4_periph0(void); #endif
diff --git a/arch/arm/mach-sunxi/clock_sun9i.c b/arch/arm/mach-sunxi/clock_sun9i.c index edaff9a28ce..5913e40cb65 100644 --- a/arch/arm/mach-sunxi/clock_sun9i.c +++ b/arch/arm/mach-sunxi/clock_sun9i.c @@ -17,6 +17,52 @@
+static void clock_set_pll2(unsigned int clk) +{ + struct sunxi_ccm_reg * const ccm = + (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + const int p = 0; + + /* Switch cluster 1 to 24MHz clock while changing PLL2 */ + clrsetbits_le32(&ccm->cpu_clk_source, C1_CPUX_CLK_SRC_MASK, + C1_CPUX_CLK_SRC_OSC24M); + + writel(CCM_PLL2_CTRL_EN | CCM_PLL2_CTRL_P(p) | + CCM_PLL2_CLOCK_TIME_2 | CCM_PLL2_CTRL_N(clk / 24000000), + &ccm->pll2_c1_cfg); + + sdelay(2000); + + /* Switch cluster 1 back to PLL2 */ + clrsetbits_le32(&ccm->cpu_clk_source, C1_CPUX_CLK_SRC_MASK, + C1_CPUX_CLK_SRC_PLL2); +} + +static void clock_set_pll4(unsigned int clk) +{ + struct sunxi_ccm_reg * const ccm = + (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + + writel(CCM_PLL4_CTRL_EN | CCM_PLL4_CTRL_N(clk / 24000000), + &ccm->pll4_periph0_cfg); + + sdelay(2000); +} + +static void clock_set_pll12(unsigned int clk) +{ + struct sunxi_ccm_reg * const ccm = + (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + + if (readl(&ccm->pll12_periph1_cfg) & CCM_PLL12_CTRL_EN) + return; + + writel(CCM_PLL12_CTRL_EN | CCM_PLL12_CTRL_N(clk / 24000000), + &ccm->pll12_periph1_cfg); + + sdelay(2000); +} + void clock_init_safe(void) { struct sunxi_ccm_reg * const ccm = @@ -63,7 +109,6 @@ void clock_init_safe(void) /* set enable-bit in TSTAMP_CTRL_REG */ writel(1, 0x01720000); } -#endif
void clock_init_uart(void) { @@ -80,7 +125,6 @@ void clock_init_uart(void) CONFIG_CONS_INDEX - 1)); }
-#ifdef CONFIG_SPL_BUILD void clock_set_pll1(unsigned int clk) { struct sunxi_ccm_reg * const ccm = @@ -108,27 +152,6 @@ void clock_set_pll1(unsigned int clk) C0_CPUX_CLK_SRC_PLL1); }
-void clock_set_pll2(unsigned int clk) -{ - struct sunxi_ccm_reg * const ccm = - (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; - const int p = 0; - - /* Switch cluster 1 to 24MHz clock while changing PLL2 */ - clrsetbits_le32(&ccm->cpu_clk_source, C1_CPUX_CLK_SRC_MASK, - C1_CPUX_CLK_SRC_OSC24M); - - writel(CCM_PLL2_CTRL_EN | CCM_PLL2_CTRL_P(p) | - CCM_PLL2_CLOCK_TIME_2 | CCM_PLL2_CTRL_N(clk / 24000000), - &ccm->pll2_c1_cfg); - - sdelay(2000); - - /* Switch cluster 1 back to PLL2 */ - clrsetbits_le32(&ccm->cpu_clk_source, C1_CPUX_CLK_SRC_MASK, - C1_CPUX_CLK_SRC_PLL2); -} - void clock_set_pll6(unsigned int clk) { struct sunxi_ccm_reg * const ccm = @@ -143,32 +166,6 @@ void clock_set_pll6(unsigned int clk) sdelay(2000); }
-void clock_set_pll12(unsigned int clk) -{ - struct sunxi_ccm_reg * const ccm = - (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; - - if (readl(&ccm->pll12_periph1_cfg) & CCM_PLL12_CTRL_EN) - return; - - writel(CCM_PLL12_CTRL_EN | CCM_PLL12_CTRL_N(clk / 24000000), - &ccm->pll12_periph1_cfg); - - sdelay(2000); -} - - -void clock_set_pll4(unsigned int clk) -{ - struct sunxi_ccm_reg * const ccm = - (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; - - writel(CCM_PLL4_CTRL_EN | CCM_PLL4_CTRL_N(clk / 24000000), - &ccm->pll4_periph0_cfg); - - sdelay(2000); -} -#endif
int clock_twi_onoff(int port, int state) { @@ -193,7 +190,9 @@ int clock_twi_onoff(int port, int state)
+/* PLL_PERIPH0 clock (used by the MMC driver) */ unsigned int clock_get_pll4_periph0(void) { struct sunxi_ccm_reg *const ccm =
At the moment the board/sunxi/board.c file contains a number of pinmux setup functions, that are only called by the SPL, to program the configured pins for the UART, NAND or eMMC devices.
Move those functions into a separate file, to help keeping the board.c file clean, and allow compiling this new file for the SPL only.
To help review, this file is as much copy&paste as possible. This raises some checkpatch complaints, but this will be fixed and further cleanup will be provided in a subsequent patch. Right now we just add some comments to some #endif's to mark nested regions. It also removes a now redundant CONFIG_SPL_BUILD guard, and fixes a whitespace problem for the R528 eMMC setup.
The new file is placed in arch/arm/mach-sunxi, as the plan is to keep all (legacy) SPL code in there.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/mach-sunxi/Makefile | 1 + arch/arm/mach-sunxi/spl_pinmux.c | 326 +++++++++++++++++++++++++++++++ board/sunxi/board.c | 309 +---------------------------- 3 files changed, 328 insertions(+), 308 deletions(-) create mode 100644 arch/arm/mach-sunxi/spl_pinmux.c
diff --git a/arch/arm/mach-sunxi/Makefile b/arch/arm/mach-sunxi/Makefile index 3f83c0280ef..c15ef01aaad 100644 --- a/arch/arm/mach-sunxi/Makefile +++ b/arch/arm/mach-sunxi/Makefile @@ -31,6 +31,7 @@ endif
ifdef CONFIG_SPL_BUILD obj-y += clock.o +obj-y += spl_pinmux.o obj-$(CONFIG_MACH_SUNIV) += dram_suniv.o obj-$(CONFIG_DRAM_SUN4I) += dram_sun4i.o obj-$(CONFIG_DRAM_SUN6I) += dram_sun6i.o diff --git a/arch/arm/mach-sunxi/spl_pinmux.c b/arch/arm/mach-sunxi/spl_pinmux.c new file mode 100644 index 00000000000..45cc2cfe2b1 --- /dev/null +++ b/arch/arm/mach-sunxi/spl_pinmux.c @@ -0,0 +1,326 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2023 Arm Ltd. + * (C) Copyright 2012-2013 Henrik Nordstrom henrik@henriknordstrom.net + * (C) Copyright 2013 Luke Kenneth Casson Leighton lkcl@lkcl.net + * (C) Copyright 2007-2011 + * Allwinner Technology Co., Ltd. <www.allwinnertech.com> + * Tom Cubie tangliang@allwinnertech.com + * + * Code to setup pinmux configuration in the SPL, which lacks the DT to + * look this up properly. + */ + +#include <asm/arch/clock.h> +#include <asm/arch/mmc.h> +#include <asm/io.h> +#include <asm/u-boot.h> +#include <sunxi_gpio.h> + +void i2c_init_board(void) +{ +#ifdef CONFIG_I2C0_ENABLE +#if defined(CONFIG_MACH_SUN4I) || \ + defined(CONFIG_MACH_SUN5I) || \ + defined(CONFIG_MACH_SUN7I) || \ + defined(CONFIG_MACH_SUN8I_R40) + sunxi_gpio_set_cfgpin(SUNXI_GPB(0), SUN4I_GPB_TWI0); + sunxi_gpio_set_cfgpin(SUNXI_GPB(1), SUN4I_GPB_TWI0); + clock_twi_onoff(0, 1); +#elif defined(CONFIG_MACH_SUN6I) + sunxi_gpio_set_cfgpin(SUNXI_GPH(14), SUN6I_GPH_TWI0); + sunxi_gpio_set_cfgpin(SUNXI_GPH(15), SUN6I_GPH_TWI0); + clock_twi_onoff(0, 1); +#elif defined(CONFIG_MACH_SUN8I_V3S) + sunxi_gpio_set_cfgpin(SUNXI_GPB(6), SUN8I_V3S_GPB_TWI0); + sunxi_gpio_set_cfgpin(SUNXI_GPB(7), SUN8I_V3S_GPB_TWI0); + clock_twi_onoff(0, 1); +#elif defined(CONFIG_MACH_SUN8I) + sunxi_gpio_set_cfgpin(SUNXI_GPH(2), SUN8I_GPH_TWI0); + sunxi_gpio_set_cfgpin(SUNXI_GPH(3), SUN8I_GPH_TWI0); + clock_twi_onoff(0, 1); +#elif defined(CONFIG_MACH_SUN50I) + sunxi_gpio_set_cfgpin(SUNXI_GPH(0), SUN50I_GPH_TWI0); + sunxi_gpio_set_cfgpin(SUNXI_GPH(1), SUN50I_GPH_TWI0); + clock_twi_onoff(0, 1); +#endif +#endif /* CONFIG_I2C0_ENABLE */ + +#ifdef CONFIG_I2C1_ENABLE +#if defined(CONFIG_MACH_SUN4I) || \ + defined(CONFIG_MACH_SUN7I) || \ + defined(CONFIG_MACH_SUN8I_R40) + sunxi_gpio_set_cfgpin(SUNXI_GPB(18), SUN4I_GPB_TWI1); + sunxi_gpio_set_cfgpin(SUNXI_GPB(19), SUN4I_GPB_TWI1); + clock_twi_onoff(1, 1); +#elif defined(CONFIG_MACH_SUN5I) + sunxi_gpio_set_cfgpin(SUNXI_GPB(15), SUN5I_GPB_TWI1); + sunxi_gpio_set_cfgpin(SUNXI_GPB(16), SUN5I_GPB_TWI1); + clock_twi_onoff(1, 1); +#elif defined(CONFIG_MACH_SUN6I) + sunxi_gpio_set_cfgpin(SUNXI_GPH(16), SUN6I_GPH_TWI1); + sunxi_gpio_set_cfgpin(SUNXI_GPH(17), SUN6I_GPH_TWI1); + clock_twi_onoff(1, 1); +#elif defined(CONFIG_MACH_SUN8I) + sunxi_gpio_set_cfgpin(SUNXI_GPH(4), SUN8I_GPH_TWI1); + sunxi_gpio_set_cfgpin(SUNXI_GPH(5), SUN8I_GPH_TWI1); + clock_twi_onoff(1, 1); +#elif defined(CONFIG_MACH_SUN50I) + sunxi_gpio_set_cfgpin(SUNXI_GPH(2), SUN50I_GPH_TWI1); + sunxi_gpio_set_cfgpin(SUNXI_GPH(3), SUN50I_GPH_TWI1); + clock_twi_onoff(1, 1); +#endif +#endif /* CONFIG_I2C1_ENABLE */ + +#ifdef CONFIG_R_I2C_ENABLE +#ifdef CONFIG_MACH_SUN50I + clock_twi_onoff(5, 1); + sunxi_gpio_set_cfgpin(SUNXI_GPL(8), SUN50I_GPL_R_TWI); + sunxi_gpio_set_cfgpin(SUNXI_GPL(9), SUN50I_GPL_R_TWI); +#elif defined(CONFIG_MACH_SUN50I_H616) + clock_twi_onoff(5, 1); + sunxi_gpio_set_cfgpin(SUNXI_GPL(0), SUN50I_H616_GPL_R_TWI); + sunxi_gpio_set_cfgpin(SUNXI_GPL(1), SUN50I_H616_GPL_R_TWI); +#else + clock_twi_onoff(5, 1); + sunxi_gpio_set_cfgpin(SUNXI_GPL(0), SUN8I_H3_GPL_R_TWI); + sunxi_gpio_set_cfgpin(SUNXI_GPL(1), SUN8I_H3_GPL_R_TWI); +#endif +#endif /* CONFIG_R_I2C_ENABLE */ +} + +#if defined(CONFIG_NAND_SUNXI) +static void nand_pinmux_setup(void) +{ + unsigned int pin; + + for (pin = SUNXI_GPC(0); pin <= SUNXI_GPC(19); pin++) + sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_NAND); + +#if defined CONFIG_MACH_SUN4I || defined CONFIG_MACH_SUN7I + for (pin = SUNXI_GPC(20); pin <= SUNXI_GPC(22); pin++) + sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_NAND); +#endif + /* sun4i / sun7i do have a PC23, but it is not used for nand, + * only sun7i has a PC24 */ +#ifdef CONFIG_MACH_SUN7I + sunxi_gpio_set_cfgpin(SUNXI_GPC(24), SUNXI_GPC_NAND); +#endif +} + +static void nand_clock_setup(void) +{ + struct sunxi_ccm_reg *const ccm = + (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + + setbits_le32(&ccm->ahb_gate0, (CLK_GATE_OPEN << AHB_GATE_OFFSET_NAND0)); +#if defined CONFIG_MACH_SUN6I || defined CONFIG_MACH_SUN8I || \ + defined CONFIG_MACH_SUN9I || defined CONFIG_MACH_SUN50I + setbits_le32(&ccm->ahb_reset0_cfg, (1 << AHB_GATE_OFFSET_NAND0)); +#endif + setbits_le32(&ccm->nand0_clk_cfg, CCM_NAND_CTRL_ENABLE | AHB_DIV_1); +} + +void board_nand_init(void) +{ + nand_pinmux_setup(); + nand_clock_setup(); +} +#endif /* CONFIG_NAND_SUNXI */ + +#ifdef CONFIG_MMC +static void mmc_pinmux_setup(int sdc) +{ + unsigned int pin; + + switch (sdc) { + case 0: + /* SDC0: PF0-PF5 */ + for (pin = SUNXI_GPF(0); pin <= SUNXI_GPF(5); pin++) { + sunxi_gpio_set_cfgpin(pin, SUNXI_GPF_SDC0); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } + break; + + case 1: +#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN7I) || \ + defined(CONFIG_MACH_SUN8I_R40) + if (IS_ENABLED(CONFIG_MMC1_PINS_PH)) { + /* SDC1: PH22-PH-27 */ + for (pin = SUNXI_GPH(22); pin <= SUNXI_GPH(27); pin++) { + sunxi_gpio_set_cfgpin(pin, SUN4I_GPH_SDC1); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } + } else { + /* SDC1: PG0-PG5 */ + for (pin = SUNXI_GPG(0); pin <= SUNXI_GPG(5); pin++) { + sunxi_gpio_set_cfgpin(pin, SUN4I_GPG_SDC1); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } + } +#elif defined(CONFIG_MACH_SUN5I) + /* SDC1: PG3-PG8 */ + for (pin = SUNXI_GPG(3); pin <= SUNXI_GPG(8); pin++) { + sunxi_gpio_set_cfgpin(pin, SUN5I_GPG_SDC1); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } +#elif defined(CONFIG_MACH_SUN6I) + /* SDC1: PG0-PG5 */ + for (pin = SUNXI_GPG(0); pin <= SUNXI_GPG(5); pin++) { + sunxi_gpio_set_cfgpin(pin, SUN6I_GPG_SDC1); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } +#elif defined(CONFIG_MACH_SUN8I) + /* SDC1: PG0-PG5 */ + for (pin = SUNXI_GPG(0); pin <= SUNXI_GPG(5); pin++) { + sunxi_gpio_set_cfgpin(pin, SUN8I_GPG_SDC1); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } +#endif + break; + + case 2: +#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN7I) + /* SDC2: PC6-PC11 */ + for (pin = SUNXI_GPC(6); pin <= SUNXI_GPC(11); pin++) { + sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } +#elif defined(CONFIG_MACH_SUN5I) + /* SDC2: PC6-PC15 */ + for (pin = SUNXI_GPC(6); pin <= SUNXI_GPC(15); pin++) { + sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } +#elif defined(CONFIG_MACH_SUN6I) + /* SDC2: PC6-PC15, PC24 */ + for (pin = SUNXI_GPC(6); pin <= SUNXI_GPC(15); pin++) { + sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } + + sunxi_gpio_set_cfgpin(SUNXI_GPC(24), SUNXI_GPC_SDC2); + sunxi_gpio_set_pull(SUNXI_GPC(24), SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(SUNXI_GPC(24), 2); +#elif defined(CONFIG_MACH_SUN8I_R40) + /* SDC2: PC6-PC15, PC24 */ + for (pin = SUNXI_GPC(6); pin <= SUNXI_GPC(15); pin++) { + sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } + + sunxi_gpio_set_cfgpin(SUNXI_GPC(24), SUNXI_GPC_SDC2); + sunxi_gpio_set_pull(SUNXI_GPC(24), SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(SUNXI_GPC(24), 2); +#elif defined(CONFIG_MACH_SUN8I) || defined(CONFIG_MACH_SUN50I) + /* SDC2: PC5-PC6, PC8-PC16 */ + for (pin = SUNXI_GPC(5); pin <= SUNXI_GPC(6); pin++) { + sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } + + for (pin = SUNXI_GPC(8); pin <= SUNXI_GPC(16); pin++) { + sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } +#elif defined(CONFIG_MACH_SUN50I_H6) + /* SDC2: PC4-PC14 */ + for (pin = SUNXI_GPC(4); pin <= SUNXI_GPC(14); pin++) { + sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } +#elif defined(CONFIG_MACH_SUN50I_H616) + /* SDC2: PC0-PC1, PC5-PC6, PC8-PC11, PC13-PC16 */ + for (pin = SUNXI_GPC(0); pin <= SUNXI_GPC(16); pin++) { + if (pin > SUNXI_GPC(1) && pin < SUNXI_GPC(5)) + continue; + if (pin == SUNXI_GPC(7) || pin == SUNXI_GPC(12)) + continue; + sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 3); + } +#elif defined(CONFIG_MACH_SUN9I) + /* SDC2: PC6-PC16 */ + for (pin = SUNXI_GPC(6); pin <= SUNXI_GPC(16); pin++) { + sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } +#elif defined(CONFIG_MACH_SUN8I_R528) + /* SDC2: PC2-PC7 */ + for (pin = SUNXI_GPC(2); pin <= SUNXI_GPC(7); pin++) { + sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } +#else + puts("ERROR: No pinmux setup defined for MMC2!\n"); +#endif + break; + + case 3: +#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN7I) || \ + defined(CONFIG_MACH_SUN8I_R40) + /* SDC3: PI4-PI9 */ + for (pin = SUNXI_GPI(4); pin <= SUNXI_GPI(9); pin++) { + sunxi_gpio_set_cfgpin(pin, SUNXI_GPI_SDC3); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } +#elif defined(CONFIG_MACH_SUN6I) + /* SDC3: PC6-PC15, PC24 */ + for (pin = SUNXI_GPC(6); pin <= SUNXI_GPC(15); pin++) { + sunxi_gpio_set_cfgpin(pin, SUN6I_GPC_SDC3); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } + + sunxi_gpio_set_cfgpin(SUNXI_GPC(24), SUN6I_GPC_SDC3); + sunxi_gpio_set_pull(SUNXI_GPC(24), SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(SUNXI_GPC(24), 2); +#endif + break; + + default: + printf("sunxi: invalid MMC slot %d for pinmux setup\n", sdc); + break; + } +} + +int board_mmc_init(struct bd_info *bis) +{ + /* + * The BROM always accesses MMC port 0 (typically an SD card), and + * most boards seem to have such a slot. The others haven't reported + * any problem with unconditionally enabling this in the SPL. + */ + if (!IS_ENABLED(CONFIG_UART0_PORT_F)) { + mmc_pinmux_setup(0); + if (!sunxi_mmc_init(0)) + return -1; + } + + if (CONFIG_MMC_SUNXI_SLOT_EXTRA != -1) { + mmc_pinmux_setup(CONFIG_MMC_SUNXI_SLOT_EXTRA); + if (!sunxi_mmc_init(CONFIG_MMC_SUNXI_SLOT_EXTRA)) + return -1; + } + + return 0; +} + +#endif /* CONFIG_MMC */ diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 1313b01dcea..5f80c097a15 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -54,78 +54,6 @@
DECLARE_GLOBAL_DATA_PTR;
-void i2c_init_board(void) -{ -#ifdef CONFIG_I2C0_ENABLE -#if defined(CONFIG_MACH_SUN4I) || \ - defined(CONFIG_MACH_SUN5I) || \ - defined(CONFIG_MACH_SUN7I) || \ - defined(CONFIG_MACH_SUN8I_R40) - sunxi_gpio_set_cfgpin(SUNXI_GPB(0), SUN4I_GPB_TWI0); - sunxi_gpio_set_cfgpin(SUNXI_GPB(1), SUN4I_GPB_TWI0); - clock_twi_onoff(0, 1); -#elif defined(CONFIG_MACH_SUN6I) - sunxi_gpio_set_cfgpin(SUNXI_GPH(14), SUN6I_GPH_TWI0); - sunxi_gpio_set_cfgpin(SUNXI_GPH(15), SUN6I_GPH_TWI0); - clock_twi_onoff(0, 1); -#elif defined(CONFIG_MACH_SUN8I_V3S) - sunxi_gpio_set_cfgpin(SUNXI_GPB(6), SUN8I_V3S_GPB_TWI0); - sunxi_gpio_set_cfgpin(SUNXI_GPB(7), SUN8I_V3S_GPB_TWI0); - clock_twi_onoff(0, 1); -#elif defined(CONFIG_MACH_SUN8I) - sunxi_gpio_set_cfgpin(SUNXI_GPH(2), SUN8I_GPH_TWI0); - sunxi_gpio_set_cfgpin(SUNXI_GPH(3), SUN8I_GPH_TWI0); - clock_twi_onoff(0, 1); -#elif defined(CONFIG_MACH_SUN50I) - sunxi_gpio_set_cfgpin(SUNXI_GPH(0), SUN50I_GPH_TWI0); - sunxi_gpio_set_cfgpin(SUNXI_GPH(1), SUN50I_GPH_TWI0); - clock_twi_onoff(0, 1); -#endif -#endif - -#ifdef CONFIG_I2C1_ENABLE -#if defined(CONFIG_MACH_SUN4I) || \ - defined(CONFIG_MACH_SUN7I) || \ - defined(CONFIG_MACH_SUN8I_R40) - sunxi_gpio_set_cfgpin(SUNXI_GPB(18), SUN4I_GPB_TWI1); - sunxi_gpio_set_cfgpin(SUNXI_GPB(19), SUN4I_GPB_TWI1); - clock_twi_onoff(1, 1); -#elif defined(CONFIG_MACH_SUN5I) - sunxi_gpio_set_cfgpin(SUNXI_GPB(15), SUN5I_GPB_TWI1); - sunxi_gpio_set_cfgpin(SUNXI_GPB(16), SUN5I_GPB_TWI1); - clock_twi_onoff(1, 1); -#elif defined(CONFIG_MACH_SUN6I) - sunxi_gpio_set_cfgpin(SUNXI_GPH(16), SUN6I_GPH_TWI1); - sunxi_gpio_set_cfgpin(SUNXI_GPH(17), SUN6I_GPH_TWI1); - clock_twi_onoff(1, 1); -#elif defined(CONFIG_MACH_SUN8I) - sunxi_gpio_set_cfgpin(SUNXI_GPH(4), SUN8I_GPH_TWI1); - sunxi_gpio_set_cfgpin(SUNXI_GPH(5), SUN8I_GPH_TWI1); - clock_twi_onoff(1, 1); -#elif defined(CONFIG_MACH_SUN50I) - sunxi_gpio_set_cfgpin(SUNXI_GPH(2), SUN50I_GPH_TWI1); - sunxi_gpio_set_cfgpin(SUNXI_GPH(3), SUN50I_GPH_TWI1); - clock_twi_onoff(1, 1); -#endif -#endif - -#ifdef CONFIG_R_I2C_ENABLE -#ifdef CONFIG_MACH_SUN50I - clock_twi_onoff(5, 1); - sunxi_gpio_set_cfgpin(SUNXI_GPL(8), SUN50I_GPL_R_TWI); - sunxi_gpio_set_cfgpin(SUNXI_GPL(9), SUN50I_GPL_R_TWI); -#elif CONFIG_MACH_SUN50I_H616 - clock_twi_onoff(5, 1); - sunxi_gpio_set_cfgpin(SUNXI_GPL(0), SUN50I_H616_GPL_R_TWI); - sunxi_gpio_set_cfgpin(SUNXI_GPL(1), SUN50I_H616_GPL_R_TWI); -#else - clock_twi_onoff(5, 1); - sunxi_gpio_set_cfgpin(SUNXI_GPL(0), SUN8I_H3_GPL_R_TWI); - sunxi_gpio_set_cfgpin(SUNXI_GPL(1), SUN8I_H3_GPL_R_TWI); -#endif -#endif -} - /* * Try to use the environment from the boot source first. * For MMC, this means a FAT partition on the boot device (SD or eMMC). @@ -282,241 +210,7 @@ int dram_init(void) return 0; }
-#if defined(CONFIG_NAND_SUNXI) && defined(CONFIG_SPL_BUILD) -static void nand_pinmux_setup(void) -{ - unsigned int pin; - - for (pin = SUNXI_GPC(0); pin <= SUNXI_GPC(19); pin++) - sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_NAND); - -#if defined CONFIG_MACH_SUN4I || defined CONFIG_MACH_SUN7I - for (pin = SUNXI_GPC(20); pin <= SUNXI_GPC(22); pin++) - sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_NAND); -#endif - /* sun4i / sun7i do have a PC23, but it is not used for nand, - * only sun7i has a PC24 */ -#ifdef CONFIG_MACH_SUN7I - sunxi_gpio_set_cfgpin(SUNXI_GPC(24), SUNXI_GPC_NAND); -#endif -} - -static void nand_clock_setup(void) -{ - struct sunxi_ccm_reg *const ccm = - (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; - - setbits_le32(&ccm->ahb_gate0, (CLK_GATE_OPEN << AHB_GATE_OFFSET_NAND0)); -#if defined CONFIG_MACH_SUN6I || defined CONFIG_MACH_SUN8I || \ - defined CONFIG_MACH_SUN9I || defined CONFIG_MACH_SUN50I - setbits_le32(&ccm->ahb_reset0_cfg, (1 << AHB_GATE_OFFSET_NAND0)); -#endif - setbits_le32(&ccm->nand0_clk_cfg, CCM_NAND_CTRL_ENABLE | AHB_DIV_1); -} - -void board_nand_init(void) -{ - nand_pinmux_setup(); - nand_clock_setup(); -} -#endif /* CONFIG_NAND_SUNXI */ - -#ifdef CONFIG_MMC -static void mmc_pinmux_setup(int sdc) -{ - unsigned int pin; - - switch (sdc) { - case 0: - /* SDC0: PF0-PF5 */ - for (pin = SUNXI_GPF(0); pin <= SUNXI_GPF(5); pin++) { - sunxi_gpio_set_cfgpin(pin, SUNXI_GPF_SDC0); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } - break; - - case 1: -#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN7I) || \ - defined(CONFIG_MACH_SUN8I_R40) - if (IS_ENABLED(CONFIG_MMC1_PINS_PH)) { - /* SDC1: PH22-PH-27 */ - for (pin = SUNXI_GPH(22); pin <= SUNXI_GPH(27); pin++) { - sunxi_gpio_set_cfgpin(pin, SUN4I_GPH_SDC1); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } - } else { - /* SDC1: PG0-PG5 */ - for (pin = SUNXI_GPG(0); pin <= SUNXI_GPG(5); pin++) { - sunxi_gpio_set_cfgpin(pin, SUN4I_GPG_SDC1); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } - } -#elif defined(CONFIG_MACH_SUN5I) - /* SDC1: PG3-PG8 */ - for (pin = SUNXI_GPG(3); pin <= SUNXI_GPG(8); pin++) { - sunxi_gpio_set_cfgpin(pin, SUN5I_GPG_SDC1); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } -#elif defined(CONFIG_MACH_SUN6I) - /* SDC1: PG0-PG5 */ - for (pin = SUNXI_GPG(0); pin <= SUNXI_GPG(5); pin++) { - sunxi_gpio_set_cfgpin(pin, SUN6I_GPG_SDC1); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } -#elif defined(CONFIG_MACH_SUN8I) - /* SDC1: PG0-PG5 */ - for (pin = SUNXI_GPG(0); pin <= SUNXI_GPG(5); pin++) { - sunxi_gpio_set_cfgpin(pin, SUN8I_GPG_SDC1); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } -#endif - break; - - case 2: -#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN7I) - /* SDC2: PC6-PC11 */ - for (pin = SUNXI_GPC(6); pin <= SUNXI_GPC(11); pin++) { - sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } -#elif defined(CONFIG_MACH_SUN5I) - /* SDC2: PC6-PC15 */ - for (pin = SUNXI_GPC(6); pin <= SUNXI_GPC(15); pin++) { - sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } -#elif defined(CONFIG_MACH_SUN6I) - /* SDC2: PC6-PC15, PC24 */ - for (pin = SUNXI_GPC(6); pin <= SUNXI_GPC(15); pin++) { - sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } - - sunxi_gpio_set_cfgpin(SUNXI_GPC(24), SUNXI_GPC_SDC2); - sunxi_gpio_set_pull(SUNXI_GPC(24), SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(SUNXI_GPC(24), 2); -#elif defined(CONFIG_MACH_SUN8I_R40) - /* SDC2: PC6-PC15, PC24 */ - for (pin = SUNXI_GPC(6); pin <= SUNXI_GPC(15); pin++) { - sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } - - sunxi_gpio_set_cfgpin(SUNXI_GPC(24), SUNXI_GPC_SDC2); - sunxi_gpio_set_pull(SUNXI_GPC(24), SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(SUNXI_GPC(24), 2); -#elif defined(CONFIG_MACH_SUN8I) || defined(CONFIG_MACH_SUN50I) - /* SDC2: PC5-PC6, PC8-PC16 */ - for (pin = SUNXI_GPC(5); pin <= SUNXI_GPC(6); pin++) { - sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } - - for (pin = SUNXI_GPC(8); pin <= SUNXI_GPC(16); pin++) { - sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } -#elif defined(CONFIG_MACH_SUN50I_H6) - /* SDC2: PC4-PC14 */ - for (pin = SUNXI_GPC(4); pin <= SUNXI_GPC(14); pin++) { - sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } -#elif defined(CONFIG_MACH_SUN50I_H616) - /* SDC2: PC0-PC1, PC5-PC6, PC8-PC11, PC13-PC16 */ - for (pin = SUNXI_GPC(0); pin <= SUNXI_GPC(16); pin++) { - if (pin > SUNXI_GPC(1) && pin < SUNXI_GPC(5)) - continue; - if (pin == SUNXI_GPC(7) || pin == SUNXI_GPC(12)) - continue; - sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 3); - } -#elif defined(CONFIG_MACH_SUN9I) - /* SDC2: PC6-PC16 */ - for (pin = SUNXI_GPC(6); pin <= SUNXI_GPC(16); pin++) { - sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } -#elif defined(CONFIG_MACH_SUN8I_R528) - /* SDC2: PC2-PC7 */ - for (pin = SUNXI_GPC(2); pin <= SUNXI_GPC(7); pin++) { - sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } -#else - puts("ERROR: No pinmux setup defined for MMC2!\n"); -#endif - break; - - case 3: -#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN7I) || \ - defined(CONFIG_MACH_SUN8I_R40) - /* SDC3: PI4-PI9 */ - for (pin = SUNXI_GPI(4); pin <= SUNXI_GPI(9); pin++) { - sunxi_gpio_set_cfgpin(pin, SUNXI_GPI_SDC3); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } -#elif defined(CONFIG_MACH_SUN6I) - /* SDC3: PC6-PC15, PC24 */ - for (pin = SUNXI_GPC(6); pin <= SUNXI_GPC(15); pin++) { - sunxi_gpio_set_cfgpin(pin, SUN6I_GPC_SDC3); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } - - sunxi_gpio_set_cfgpin(SUNXI_GPC(24), SUN6I_GPC_SDC3); - sunxi_gpio_set_pull(SUNXI_GPC(24), SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(SUNXI_GPC(24), 2); -#endif - break; - - default: - printf("sunxi: invalid MMC slot %d for pinmux setup\n", sdc); - break; - } -} - -int board_mmc_init(struct bd_info *bis) -{ - /* - * The BROM always accesses MMC port 0 (typically an SD card), and - * most boards seem to have such a slot. The others haven't reported - * any problem with unconditionally enabling this in the SPL. - */ - if (!IS_ENABLED(CONFIG_UART0_PORT_F)) { - mmc_pinmux_setup(0); - if (!sunxi_mmc_init(0)) - return -1; - } - - if (CONFIG_MMC_SUNXI_SLOT_EXTRA != -1) { - mmc_pinmux_setup(CONFIG_MMC_SUNXI_SLOT_EXTRA); - if (!sunxi_mmc_init(CONFIG_MMC_SUNXI_SLOT_EXTRA)) - return -1; - } - - return 0; -} - -#if CONFIG_MMC_SUNXI_SLOT_EXTRA != -1 +#if defined(CONFIG_MMC) && CONFIG_MMC_SUNXI_SLOT_EXTRA != -1 int mmc_get_env_dev(void) { switch (sunxi_get_boot_device()) { @@ -528,7 +222,6 @@ int mmc_get_env_dev(void) return CONFIG_SYS_MMC_ENV_DEV; } } -#endif #endif /* CONFIG_MMC */
At the moment the SPL functions setting up the required pinmux for the UART, NAND and MMC controllers make heavy use of #ifdefs, which are sometimes even nested. This makes them hard to read, and more importantly hard to extend.
Rewrite those functions with the help of IS_ENABLED(), to use proper C "if" statements. For the I2C case, also split the function up into one per I2C controller, to further simplify the code layout.
The MMC function gets further simplified, by replacing the repeated direct calls to the GPIO functions with using variables, that describe a range of pins to handle, including skipped pins and outliers. The actual pinmux functions are then called from one place.
One part of the NAND clock setup relies on SoC specific struct members, so that has to keep using #ifdefs, to avoid breaking compilation for other SoCs.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/mach-sunxi/spl_pinmux.c | 434 +++++++++++++++---------------- 1 file changed, 210 insertions(+), 224 deletions(-)
diff --git a/arch/arm/mach-sunxi/spl_pinmux.c b/arch/arm/mach-sunxi/spl_pinmux.c index 45cc2cfe2b1..18f8cd93b6a 100644 --- a/arch/arm/mach-sunxi/spl_pinmux.c +++ b/arch/arm/mach-sunxi/spl_pinmux.c @@ -17,95 +17,105 @@ #include <asm/u-boot.h> #include <sunxi_gpio.h>
+static void i2c0_init_board(void) +{ + if (IS_ENABLED(CONFIG_MACH_SUN4I) || IS_ENABLED(CONFIG_MACH_SUN5I) || + IS_ENABLED(CONFIG_MACH_SUN7I) || IS_ENABLED(CONFIG_MACH_SUN8I_R40)) { + sunxi_gpio_set_cfgpin(SUNXI_GPB(0), SUN4I_GPB_TWI0); + sunxi_gpio_set_cfgpin(SUNXI_GPB(1), SUN4I_GPB_TWI0); + clock_twi_onoff(0, 1); + } else if (IS_ENABLED(CONFIG_MACH_SUN6I)) { + sunxi_gpio_set_cfgpin(SUNXI_GPH(14), SUN6I_GPH_TWI0); + sunxi_gpio_set_cfgpin(SUNXI_GPH(15), SUN6I_GPH_TWI0); + clock_twi_onoff(0, 1); + } else if (IS_ENABLED(CONFIG_MACH_SUN8I_V3S)) { + sunxi_gpio_set_cfgpin(SUNXI_GPB(6), SUN8I_V3S_GPB_TWI0); + sunxi_gpio_set_cfgpin(SUNXI_GPB(7), SUN8I_V3S_GPB_TWI0); + clock_twi_onoff(0, 1); + } else if (IS_ENABLED(CONFIG_MACH_SUN8I)) { + sunxi_gpio_set_cfgpin(SUNXI_GPH(2), SUN8I_GPH_TWI0); + sunxi_gpio_set_cfgpin(SUNXI_GPH(3), SUN8I_GPH_TWI0); + clock_twi_onoff(0, 1); + } else if (IS_ENABLED(CONFIG_MACH_SUN50I)) { + sunxi_gpio_set_cfgpin(SUNXI_GPH(0), SUN50I_GPH_TWI0); + sunxi_gpio_set_cfgpin(SUNXI_GPH(1), SUN50I_GPH_TWI0); + clock_twi_onoff(0, 1); + } +} + +static void i2c1_init_board(void) +{ + if (IS_ENABLED(CONFIG_MACH_SUN4I) || IS_ENABLED(CONFIG_MACH_SUN7I) || + IS_ENABLED(CONFIG_MACH_SUN8I_R40)) { + sunxi_gpio_set_cfgpin(SUNXI_GPB(18), SUN4I_GPB_TWI1); + sunxi_gpio_set_cfgpin(SUNXI_GPB(19), SUN4I_GPB_TWI1); + clock_twi_onoff(1, 1); + } else if (IS_ENABLED(CONFIG_MACH_SUN5I)) { + sunxi_gpio_set_cfgpin(SUNXI_GPB(15), SUN5I_GPB_TWI1); + sunxi_gpio_set_cfgpin(SUNXI_GPB(16), SUN5I_GPB_TWI1); + clock_twi_onoff(1, 1); + } else if (IS_ENABLED(CONFIG_MACH_SUN6I)) { + sunxi_gpio_set_cfgpin(SUNXI_GPH(16), SUN6I_GPH_TWI1); + sunxi_gpio_set_cfgpin(SUNXI_GPH(17), SUN6I_GPH_TWI1); + clock_twi_onoff(1, 1); + } else if (IS_ENABLED(CONFIG_MACH_SUN8I)) { + sunxi_gpio_set_cfgpin(SUNXI_GPH(4), SUN8I_GPH_TWI1); + sunxi_gpio_set_cfgpin(SUNXI_GPH(5), SUN8I_GPH_TWI1); + clock_twi_onoff(1, 1); + } else if (IS_ENABLED(CONFIG_MACH_SUN50I)) { + sunxi_gpio_set_cfgpin(SUNXI_GPH(2), SUN50I_GPH_TWI1); + sunxi_gpio_set_cfgpin(SUNXI_GPH(3), SUN50I_GPH_TWI1); + clock_twi_onoff(1, 1); + } +} + +static void i2cr_init_board(void) +{ + if (IS_ENABLED(CONFIG_MACH_SUN50I)) { + clock_twi_onoff(5, 1); + sunxi_gpio_set_cfgpin(SUNXI_GPL(8), SUN50I_GPL_R_TWI); + sunxi_gpio_set_cfgpin(SUNXI_GPL(9), SUN50I_GPL_R_TWI); + } else if (IS_ENABLED(CONFIG_MACH_SUN50I_H616)) { + clock_twi_onoff(5, 1); + sunxi_gpio_set_cfgpin(SUNXI_GPL(0), SUN50I_H616_GPL_R_TWI); + sunxi_gpio_set_cfgpin(SUNXI_GPL(1), SUN50I_H616_GPL_R_TWI); + } else { + clock_twi_onoff(5, 1); + sunxi_gpio_set_cfgpin(SUNXI_GPL(0), SUN8I_H3_GPL_R_TWI); + sunxi_gpio_set_cfgpin(SUNXI_GPL(1), SUN8I_H3_GPL_R_TWI); + } +} + void i2c_init_board(void) { -#ifdef CONFIG_I2C0_ENABLE -#if defined(CONFIG_MACH_SUN4I) || \ - defined(CONFIG_MACH_SUN5I) || \ - defined(CONFIG_MACH_SUN7I) || \ - defined(CONFIG_MACH_SUN8I_R40) - sunxi_gpio_set_cfgpin(SUNXI_GPB(0), SUN4I_GPB_TWI0); - sunxi_gpio_set_cfgpin(SUNXI_GPB(1), SUN4I_GPB_TWI0); - clock_twi_onoff(0, 1); -#elif defined(CONFIG_MACH_SUN6I) - sunxi_gpio_set_cfgpin(SUNXI_GPH(14), SUN6I_GPH_TWI0); - sunxi_gpio_set_cfgpin(SUNXI_GPH(15), SUN6I_GPH_TWI0); - clock_twi_onoff(0, 1); -#elif defined(CONFIG_MACH_SUN8I_V3S) - sunxi_gpio_set_cfgpin(SUNXI_GPB(6), SUN8I_V3S_GPB_TWI0); - sunxi_gpio_set_cfgpin(SUNXI_GPB(7), SUN8I_V3S_GPB_TWI0); - clock_twi_onoff(0, 1); -#elif defined(CONFIG_MACH_SUN8I) - sunxi_gpio_set_cfgpin(SUNXI_GPH(2), SUN8I_GPH_TWI0); - sunxi_gpio_set_cfgpin(SUNXI_GPH(3), SUN8I_GPH_TWI0); - clock_twi_onoff(0, 1); -#elif defined(CONFIG_MACH_SUN50I) - sunxi_gpio_set_cfgpin(SUNXI_GPH(0), SUN50I_GPH_TWI0); - sunxi_gpio_set_cfgpin(SUNXI_GPH(1), SUN50I_GPH_TWI0); - clock_twi_onoff(0, 1); -#endif -#endif /* CONFIG_I2C0_ENABLE */ + if (IS_ENABLED(CONFIG_I2C0_ENABLE)) + i2c0_init_board();
-#ifdef CONFIG_I2C1_ENABLE -#if defined(CONFIG_MACH_SUN4I) || \ - defined(CONFIG_MACH_SUN7I) || \ - defined(CONFIG_MACH_SUN8I_R40) - sunxi_gpio_set_cfgpin(SUNXI_GPB(18), SUN4I_GPB_TWI1); - sunxi_gpio_set_cfgpin(SUNXI_GPB(19), SUN4I_GPB_TWI1); - clock_twi_onoff(1, 1); -#elif defined(CONFIG_MACH_SUN5I) - sunxi_gpio_set_cfgpin(SUNXI_GPB(15), SUN5I_GPB_TWI1); - sunxi_gpio_set_cfgpin(SUNXI_GPB(16), SUN5I_GPB_TWI1); - clock_twi_onoff(1, 1); -#elif defined(CONFIG_MACH_SUN6I) - sunxi_gpio_set_cfgpin(SUNXI_GPH(16), SUN6I_GPH_TWI1); - sunxi_gpio_set_cfgpin(SUNXI_GPH(17), SUN6I_GPH_TWI1); - clock_twi_onoff(1, 1); -#elif defined(CONFIG_MACH_SUN8I) - sunxi_gpio_set_cfgpin(SUNXI_GPH(4), SUN8I_GPH_TWI1); - sunxi_gpio_set_cfgpin(SUNXI_GPH(5), SUN8I_GPH_TWI1); - clock_twi_onoff(1, 1); -#elif defined(CONFIG_MACH_SUN50I) - sunxi_gpio_set_cfgpin(SUNXI_GPH(2), SUN50I_GPH_TWI1); - sunxi_gpio_set_cfgpin(SUNXI_GPH(3), SUN50I_GPH_TWI1); - clock_twi_onoff(1, 1); -#endif -#endif /* CONFIG_I2C1_ENABLE */ + if (IS_ENABLED(CONFIG_I2C1_ENABLE)) + i2c1_init_board();
-#ifdef CONFIG_R_I2C_ENABLE -#ifdef CONFIG_MACH_SUN50I - clock_twi_onoff(5, 1); - sunxi_gpio_set_cfgpin(SUNXI_GPL(8), SUN50I_GPL_R_TWI); - sunxi_gpio_set_cfgpin(SUNXI_GPL(9), SUN50I_GPL_R_TWI); -#elif defined(CONFIG_MACH_SUN50I_H616) - clock_twi_onoff(5, 1); - sunxi_gpio_set_cfgpin(SUNXI_GPL(0), SUN50I_H616_GPL_R_TWI); - sunxi_gpio_set_cfgpin(SUNXI_GPL(1), SUN50I_H616_GPL_R_TWI); -#else - clock_twi_onoff(5, 1); - sunxi_gpio_set_cfgpin(SUNXI_GPL(0), SUN8I_H3_GPL_R_TWI); - sunxi_gpio_set_cfgpin(SUNXI_GPL(1), SUN8I_H3_GPL_R_TWI); -#endif -#endif /* CONFIG_R_I2C_ENABLE */ + if (IS_ENABLED(CONFIG_R_I2C_ENABLE)) + i2cr_init_board(); }
#if defined(CONFIG_NAND_SUNXI) -static void nand_pinmux_setup(void) +void nand_pinmux_setup(void) { unsigned int pin;
for (pin = SUNXI_GPC(0); pin <= SUNXI_GPC(19); pin++) sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_NAND);
-#if defined CONFIG_MACH_SUN4I || defined CONFIG_MACH_SUN7I - for (pin = SUNXI_GPC(20); pin <= SUNXI_GPC(22); pin++) - sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_NAND); -#endif - /* sun4i / sun7i do have a PC23, but it is not used for nand, - * only sun7i has a PC24 */ -#ifdef CONFIG_MACH_SUN7I - sunxi_gpio_set_cfgpin(SUNXI_GPC(24), SUNXI_GPC_NAND); -#endif + if (IS_ENABLED(CONFIG_MACH_SUN4I) || IS_ENABLED(CONFIG_MACH_SUN7I)) { + for (pin = SUNXI_GPC(20); pin <= SUNXI_GPC(22); pin++) + sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_NAND); + } + /* + * sun4i / sun7i do have a PC23, but it is not used for NAND. + * Only sun7i has a PC24. + */ + if (IS_ENABLED(CONFIG_MACH_SUN7I)) + sunxi_gpio_set_cfgpin(SUNXI_GPC(24), SUNXI_GPC_NAND); }
static void nand_clock_setup(void) @@ -114,10 +124,12 @@ static void nand_clock_setup(void) (struct sunxi_ccm_reg *)SUNXI_CCM_BASE;
setbits_le32(&ccm->ahb_gate0, (CLK_GATE_OPEN << AHB_GATE_OFFSET_NAND0)); + #if defined CONFIG_MACH_SUN6I || defined CONFIG_MACH_SUN8I || \ - defined CONFIG_MACH_SUN9I || defined CONFIG_MACH_SUN50I + defined CONFIG_MACH_SUN9I || defined CONFIG_MACH_SUN50I setbits_le32(&ccm->ahb_reset0_cfg, (1 << AHB_GATE_OFFSET_NAND0)); #endif + setbits_le32(&ccm->nand0_clk_cfg, CCM_NAND_CTRL_ENABLE | AHB_DIV_1); }
@@ -131,174 +143,149 @@ void board_nand_init(void) #ifdef CONFIG_MMC static void mmc_pinmux_setup(int sdc) { - unsigned int pin; + unsigned int pin, first_pin, last_pin, pin_mux; + unsigned int skip_pin = ~0, extra_pin = ~0;
switch (sdc) { case 0: /* SDC0: PF0-PF5 */ - for (pin = SUNXI_GPF(0); pin <= SUNXI_GPF(5); pin++) { - sunxi_gpio_set_cfgpin(pin, SUNXI_GPF_SDC0); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } + first_pin = SUNXI_GPF(0); + last_pin = SUNXI_GPF(5); + pin_mux = SUNXI_GPF_SDC0; break; - case 1: -#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN7I) || \ - defined(CONFIG_MACH_SUN8I_R40) - if (IS_ENABLED(CONFIG_MMC1_PINS_PH)) { - /* SDC1: PH22-PH-27 */ - for (pin = SUNXI_GPH(22); pin <= SUNXI_GPH(27); pin++) { - sunxi_gpio_set_cfgpin(pin, SUN4I_GPH_SDC1); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); + if (IS_ENABLED(CONFIG_MACH_SUN4I) || + IS_ENABLED(CONFIG_MACH_SUN7I) || + IS_ENABLED(CONFIG_MACH_SUN8I_R40)) { + if (IS_ENABLED(CONFIG_MMC1_PINS_PH)) { + /* SDC1: PH22-PH-27 */ + first_pin = SUNXI_GPH(22); + last_pin = SUNXI_GPH(27); + pin_mux = SUN4I_GPH_SDC1; + } else { + /* SDC1: PG0-PG5 */ + first_pin = SUNXI_GPG(0); + last_pin = SUNXI_GPG(5); + pin_mux = SUN4I_GPG_SDC1; } - } else { + } else if (IS_ENABLED(CONFIG_MACH_SUN5I)) { + /* SDC1: PG3-PG8 */ + first_pin = SUNXI_GPG(3); + last_pin = SUNXI_GPG(8); + pin_mux = SUN4I_GPG_SDC1; + } else if (IS_ENABLED(CONFIG_MACH_SUN6I)) { /* SDC1: PG0-PG5 */ - for (pin = SUNXI_GPG(0); pin <= SUNXI_GPG(5); pin++) { - sunxi_gpio_set_cfgpin(pin, SUN4I_GPG_SDC1); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } - } -#elif defined(CONFIG_MACH_SUN5I) - /* SDC1: PG3-PG8 */ - for (pin = SUNXI_GPG(3); pin <= SUNXI_GPG(8); pin++) { - sunxi_gpio_set_cfgpin(pin, SUN5I_GPG_SDC1); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } -#elif defined(CONFIG_MACH_SUN6I) - /* SDC1: PG0-PG5 */ - for (pin = SUNXI_GPG(0); pin <= SUNXI_GPG(5); pin++) { - sunxi_gpio_set_cfgpin(pin, SUN6I_GPG_SDC1); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } -#elif defined(CONFIG_MACH_SUN8I) - /* SDC1: PG0-PG5 */ - for (pin = SUNXI_GPG(0); pin <= SUNXI_GPG(5); pin++) { - sunxi_gpio_set_cfgpin(pin, SUN8I_GPG_SDC1); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); + first_pin = SUNXI_GPG(0); + last_pin = SUNXI_GPG(5); + pin_mux = SUN6I_GPG_SDC1; + } else if (IS_ENABLED(CONFIG_MACH_SUN8I)) { + /* SDC1: PG0-PG5 */ + first_pin = SUNXI_GPG(0); + last_pin = SUNXI_GPG(5); + pin_mux = SUN8I_GPG_SDC1; } -#endif break; - case 2: -#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN7I) - /* SDC2: PC6-PC11 */ - for (pin = SUNXI_GPC(6); pin <= SUNXI_GPC(11); pin++) { - sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } -#elif defined(CONFIG_MACH_SUN5I) - /* SDC2: PC6-PC15 */ - for (pin = SUNXI_GPC(6); pin <= SUNXI_GPC(15); pin++) { - sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } -#elif defined(CONFIG_MACH_SUN6I) - /* SDC2: PC6-PC15, PC24 */ - for (pin = SUNXI_GPC(6); pin <= SUNXI_GPC(15); pin++) { - sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } + if (IS_ENABLED(CONFIG_MACH_SUN4I) || + IS_ENABLED(CONFIG_MACH_SUN7I)) { + /* SDC2: PC6-PC11 */ + first_pin = SUNXI_GPG(6); + last_pin = SUNXI_GPG(11); + pin_mux = SUNXI_GPC_SDC2; + } else if (IS_ENABLED(CONFIG_MACH_SUN5I)) { + /* SDC2: PC6-PC15 */ + first_pin = SUNXI_GPG(6); + last_pin = SUNXI_GPG(15); + pin_mux = SUNXI_GPC_SDC2; + } else if (IS_ENABLED(CONFIG_MACH_SUN6I)) { + /* SDC2: PC6-PC15, PC24 */ + first_pin = SUNXI_GPG(6); + last_pin = SUNXI_GPG(15); + extra_pin = SUNXI_GPC(24); + pin_mux = SUNXI_GPC_SDC2; + } else if (IS_ENABLED(CONFIG_MACH_SUN8I_R40)) { + /* SDC2: PC6-PC15, PC24 */ + first_pin = SUNXI_GPC(6); + last_pin = SUNXI_GPC(15); + extra_pin = SUNXI_GPC(24); + pin_mux = SUNXI_GPC_SDC2; + } else if (IS_ENABLED(CONFIG_MACH_SUN8I) || + IS_ENABLED(CONFIG_MACH_SUN50I)) { + /* SDC2: PC5-PC6, PC8-PC16 */ + first_pin = SUNXI_GPC(5); + last_pin = SUNXI_GPC(16); + skip_pin = SUNXI_GPC(7); + pin_mux = SUNXI_GPC_SDC2; + } else if (IS_ENABLED(CONFIG_MACH_SUN50I_H6)) { + /* SDC2: PC4-PC14 */ + first_pin = SUNXI_GPC(4); + last_pin = SUNXI_GPC(14); + pin_mux = SUNXI_GPC_SDC2; + } else if (IS_ENABLED(CONFIG_MACH_SUN50I_H616)) { + /* SDC2: PC0-PC1, PC5-PC6, PC8-PC11, PC13-PC16 */ + first_pin = SUNXI_GPC(5); + last_pin = SUNXI_GPC(11); + skip_pin = SUNXI_GPC(7); + pin_mux = SUNXI_GPC_SDC2;
- sunxi_gpio_set_cfgpin(SUNXI_GPC(24), SUNXI_GPC_SDC2); - sunxi_gpio_set_pull(SUNXI_GPC(24), SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(SUNXI_GPC(24), 2); -#elif defined(CONFIG_MACH_SUN8I_R40) - /* SDC2: PC6-PC15, PC24 */ - for (pin = SUNXI_GPC(6); pin <= SUNXI_GPC(15); pin++) { - sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } - - sunxi_gpio_set_cfgpin(SUNXI_GPC(24), SUNXI_GPC_SDC2); - sunxi_gpio_set_pull(SUNXI_GPC(24), SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(SUNXI_GPC(24), 2); -#elif defined(CONFIG_MACH_SUN8I) || defined(CONFIG_MACH_SUN50I) - /* SDC2: PC5-PC6, PC8-PC16 */ - for (pin = SUNXI_GPC(5); pin <= SUNXI_GPC(6); pin++) { - sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } - - for (pin = SUNXI_GPC(8); pin <= SUNXI_GPC(16); pin++) { - sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } -#elif defined(CONFIG_MACH_SUN50I_H6) - /* SDC2: PC4-PC14 */ - for (pin = SUNXI_GPC(4); pin <= SUNXI_GPC(14); pin++) { - sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } -#elif defined(CONFIG_MACH_SUN50I_H616) - /* SDC2: PC0-PC1, PC5-PC6, PC8-PC11, PC13-PC16 */ - for (pin = SUNXI_GPC(0); pin <= SUNXI_GPC(16); pin++) { - if (pin > SUNXI_GPC(1) && pin < SUNXI_GPC(5)) - continue; - if (pin == SUNXI_GPC(7) || pin == SUNXI_GPC(12)) - continue; - sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 3); - } -#elif defined(CONFIG_MACH_SUN9I) - /* SDC2: PC6-PC16 */ - for (pin = SUNXI_GPC(6); pin <= SUNXI_GPC(16); pin++) { - sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } -#elif defined(CONFIG_MACH_SUN8I_R528) - /* SDC2: PC2-PC7 */ - for (pin = SUNXI_GPC(2); pin <= SUNXI_GPC(7); pin++) { - sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); + for (pin = SUNXI_GPC(0); pin <= SUNXI_GPC(1); pin++) { + sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 3); + } + for (pin = SUNXI_GPC(13); pin <= SUNXI_GPC(16); pin++) { + sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 3); + } + } else if (IS_ENABLED(CONFIG_MACH_SUN9I)) { + /* SDC2: PC6-PC16 */ + first_pin = SUNXI_GPC(6); + last_pin = SUNXI_GPC(16); + pin_mux = SUNXI_GPC_SDC2; + } else if (IS_ENABLED(CONFIG_MACH_SUN8I_R528)) { + /* SDC2: PC2-PC7 */ + first_pin = SUNXI_GPC(2); + last_pin = SUNXI_GPC(7); + pin_mux = SUNXI_GPC_SDC2; + } else { + puts("ERROR: No pinmux setup defined for MMC2!\n"); } -#else - puts("ERROR: No pinmux setup defined for MMC2!\n"); -#endif break; - case 3: -#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN7I) || \ - defined(CONFIG_MACH_SUN8I_R40) - /* SDC3: PI4-PI9 */ - for (pin = SUNXI_GPI(4); pin <= SUNXI_GPI(9); pin++) { - sunxi_gpio_set_cfgpin(pin, SUNXI_GPI_SDC3); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); + if (IS_ENABLED(CONFIG_MACH_SUN4I) || + IS_ENABLED(CONFIG_MACH_SUN7I) || + IS_ENABLED(CONFIG_MACH_SUN8I_R40)) { + /* SDC3: PI4-PI9 */ + first_pin = SUNXI_GPI(4); + last_pin = SUNXI_GPI(9); + pin_mux = SUNXI_GPI_SDC3; + } else if (IS_ENABLED(CONFIG_MACH_SUN6I)) { + /* SDC3: PC6-PC15, PC24 */ + first_pin = SUNXI_GPC(6); + last_pin = SUNXI_GPC(15); + extra_pin = SUNXI_GPC(24); + pin_mux = SUN6I_GPC_SDC3; } -#elif defined(CONFIG_MACH_SUN6I) - /* SDC3: PC6-PC15, PC24 */ - for (pin = SUNXI_GPC(6); pin <= SUNXI_GPC(15); pin++) { - sunxi_gpio_set_cfgpin(pin, SUN6I_GPC_SDC3); - sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(pin, 2); - } - - sunxi_gpio_set_cfgpin(SUNXI_GPC(24), SUN6I_GPC_SDC3); - sunxi_gpio_set_pull(SUNXI_GPC(24), SUNXI_GPIO_PULL_UP); - sunxi_gpio_set_drv(SUNXI_GPC(24), 2); -#endif break;
default: printf("sunxi: invalid MMC slot %d for pinmux setup\n", sdc); break; } + + for (pin = first_pin; pin <= last_pin; pin++) { + if (pin == skip_pin) + continue; + sunxi_gpio_set_cfgpin(pin, pin_mux); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } + if (extra_pin != ~0) { + sunxi_gpio_set_cfgpin(extra_pin, pin_mux); + sunxi_gpio_set_pull(extra_pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(extra_pin, 2); + } }
int board_mmc_init(struct bd_info *bis) @@ -322,5 +309,4 @@ int board_mmc_init(struct bd_info *bis)
return 0; } - #endif /* CONFIG_MMC */
The code that programs the pinmuxes for the configured UART dominates the gpio_init() function, and is only needed by SPL code.
Move those lines into a separate function in a new file, that gets compiled for the SPL only.
That simplifies further cleanup, and helps to separate SPL-only code from generic code. To help review, this only copies the code (generating some checkpatch complaints), further cleanup will be provided in subsequent patches.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/mach-sunxi/Makefile | 1 + arch/arm/mach-sunxi/board.c | 110 ++------------------------ arch/arm/mach-sunxi/uart_pinmux.c | 124 ++++++++++++++++++++++++++++++ 3 files changed, 130 insertions(+), 105 deletions(-) create mode 100644 arch/arm/mach-sunxi/uart_pinmux.c
diff --git a/arch/arm/mach-sunxi/Makefile b/arch/arm/mach-sunxi/Makefile index c15ef01aaad..9a9dffc176f 100644 --- a/arch/arm/mach-sunxi/Makefile +++ b/arch/arm/mach-sunxi/Makefile @@ -32,6 +32,7 @@ endif ifdef CONFIG_SPL_BUILD obj-y += clock.o obj-y += spl_pinmux.o +obj-y += uart_pinmux.o obj-$(CONFIG_MACH_SUNIV) += dram_suniv.o obj-$(CONFIG_DRAM_SUN4I) += dram_sun4i.o obj-$(CONFIG_DRAM_SUN6I) += dram_sun6i.o diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index 0140b07d32a..dd642c0d2f0 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -75,113 +75,13 @@ phys_addr_t board_get_usable_ram_top(phys_size_t total_size) #endif /* CONFIG_ARM64 */
#ifdef CONFIG_SPL_BUILD +void uart_pinmux_setup(void); + static int gpio_init(void) { - __maybe_unused uint val; -#if CONFIG_CONS_INDEX == 1 && defined(CONFIG_UART0_PORT_F) -#if defined(CONFIG_MACH_SUN4I) || \ - defined(CONFIG_MACH_SUN7I) || \ - defined(CONFIG_MACH_SUN8I_R40) - /* disable GPB22,23 as uart0 tx,rx to avoid conflict */ - sunxi_gpio_set_cfgpin(SUNXI_GPB(22), SUNXI_GPIO_INPUT); - sunxi_gpio_set_cfgpin(SUNXI_GPB(23), SUNXI_GPIO_INPUT); -#endif -#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN5I) || \ - defined(CONFIG_MACH_SUN7I) || defined(CONFIG_MACH_SUN8I_R40) || \ - defined(CONFIG_MACH_SUN9I) - sunxi_gpio_set_cfgpin(SUNXI_GPF(2), SUNXI_GPF_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPF(4), SUNXI_GPF_UART0); -#else - sunxi_gpio_set_cfgpin(SUNXI_GPF(2), SUN8I_GPF_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPF(4), SUN8I_GPF_UART0); -#endif - sunxi_gpio_set_pull(SUNXI_GPF(4), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUNIV) - sunxi_gpio_set_cfgpin(SUNXI_GPE(0), SUNIV_GPE_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPE(1), SUNIV_GPE_UART0); - sunxi_gpio_set_pull(SUNXI_GPE(1), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 1 && (defined(CONFIG_MACH_SUN4I) || \ - defined(CONFIG_MACH_SUN7I) || \ - defined(CONFIG_MACH_SUN8I_R40)) - sunxi_gpio_set_cfgpin(SUNXI_GPB(22), SUN4I_GPB_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPB(23), SUN4I_GPB_UART0); - sunxi_gpio_set_pull(SUNXI_GPB(23), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN5I) - sunxi_gpio_set_cfgpin(SUNXI_GPB(19), SUN5I_GPB_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPB(20), SUN5I_GPB_UART0); - sunxi_gpio_set_pull(SUNXI_GPB(20), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN6I) - sunxi_gpio_set_cfgpin(SUNXI_GPH(20), SUN6I_GPH_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPH(21), SUN6I_GPH_UART0); - sunxi_gpio_set_pull(SUNXI_GPH(21), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN8I_A33) - sunxi_gpio_set_cfgpin(SUNXI_GPB(0), SUN8I_A33_GPB_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPB(1), SUN8I_A33_GPB_UART0); - sunxi_gpio_set_pull(SUNXI_GPB(1), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUNXI_H3_H5) - sunxi_gpio_set_cfgpin(SUNXI_GPA(4), SUN8I_H3_GPA_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPA(5), SUN8I_H3_GPA_UART0); - sunxi_gpio_set_pull(SUNXI_GPA(5), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN50I) - sunxi_gpio_set_cfgpin(SUNXI_GPB(8), SUN50I_GPB_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPB(9), SUN50I_GPB_UART0); - sunxi_gpio_set_pull(SUNXI_GPB(9), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN50I_H6) - sunxi_gpio_set_cfgpin(SUNXI_GPH(0), SUN50I_H6_GPH_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPH(1), SUN50I_H6_GPH_UART0); - sunxi_gpio_set_pull(SUNXI_GPH(1), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN50I_H616) - sunxi_gpio_set_cfgpin(SUNXI_GPH(0), SUN50I_H616_GPH_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPH(1), SUN50I_H616_GPH_UART0); - sunxi_gpio_set_pull(SUNXI_GPH(1), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN8I_A83T) - sunxi_gpio_set_cfgpin(SUNXI_GPB(9), SUN8I_A83T_GPB_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPB(10), SUN8I_A83T_GPB_UART0); - sunxi_gpio_set_pull(SUNXI_GPB(10), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN8I_V3S) - sunxi_gpio_set_cfgpin(SUNXI_GPB(8), SUN8I_V3S_GPB_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPB(9), SUN8I_V3S_GPB_UART0); - sunxi_gpio_set_pull(SUNXI_GPB(9), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN9I) - sunxi_gpio_set_cfgpin(SUNXI_GPH(12), SUN9I_GPH_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPH(13), SUN9I_GPH_UART0); - sunxi_gpio_set_pull(SUNXI_GPH(13), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN8I_R528) - sunxi_gpio_set_cfgpin(SUNXI_GPE(2), 6); - sunxi_gpio_set_cfgpin(SUNXI_GPE(3), 6); - sunxi_gpio_set_pull(SUNXI_GPE(3), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 2 && defined(CONFIG_MACH_SUNIV) - sunxi_gpio_set_cfgpin(SUNXI_GPA(2), SUNIV_GPE_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPA(3), SUNIV_GPE_UART0); - sunxi_gpio_set_pull(SUNXI_GPA(3), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 2 && defined(CONFIG_MACH_SUN5I) - sunxi_gpio_set_cfgpin(SUNXI_GPG(3), SUN5I_GPG_UART1); - sunxi_gpio_set_cfgpin(SUNXI_GPG(4), SUN5I_GPG_UART1); - sunxi_gpio_set_pull(SUNXI_GPG(4), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 3 && defined(CONFIG_MACH_SUN8I_H3) - sunxi_gpio_set_cfgpin(SUNXI_GPA(0), SUN8I_H3_GPA_UART2); - sunxi_gpio_set_cfgpin(SUNXI_GPA(1), SUN8I_H3_GPA_UART2); - sunxi_gpio_set_pull(SUNXI_GPA(1), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 3 && defined(CONFIG_MACH_SUN8I) - sunxi_gpio_set_cfgpin(SUNXI_GPB(0), SUN8I_GPB_UART2); - sunxi_gpio_set_cfgpin(SUNXI_GPB(1), SUN8I_GPB_UART2); - sunxi_gpio_set_pull(SUNXI_GPB(1), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 4 && defined(CONFIG_MACH_SUN8I_R528) - sunxi_gpio_set_cfgpin(SUNXI_GPB(6), 7); - sunxi_gpio_set_cfgpin(SUNXI_GPB(7), 7); - sunxi_gpio_set_pull(SUNXI_GPB(7), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 5 && defined(CONFIG_MACH_SUN8I) - sunxi_gpio_set_cfgpin(SUNXI_GPL(2), SUN8I_GPL_R_UART); - sunxi_gpio_set_cfgpin(SUNXI_GPL(3), SUN8I_GPL_R_UART); - sunxi_gpio_set_pull(SUNXI_GPL(3), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 2 && defined(CONFIG_MACH_SUN8I) && \ - !defined(CONFIG_MACH_SUN8I_R40) - sunxi_gpio_set_cfgpin(SUNXI_GPG(6), SUN8I_GPG_UART1); - sunxi_gpio_set_cfgpin(SUNXI_GPG(7), SUN8I_GPG_UART1); - sunxi_gpio_set_pull(SUNXI_GPG(7), SUNXI_GPIO_PULL_UP); -#else -#error Unsupported console port number. Please fix pin mux settings in board.c -#endif + u32 val; + + uart_pinmux_setup();
/* * Update PIO power bias configuration by copying the hardware diff --git a/arch/arm/mach-sunxi/uart_pinmux.c b/arch/arm/mach-sunxi/uart_pinmux.c new file mode 100644 index 00000000000..af5ecc4fb3c --- /dev/null +++ b/arch/arm/mach-sunxi/uart_pinmux.c @@ -0,0 +1,124 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2023 Arm Ltd. + * (C) Copyright 2012-2013 Henrik Nordstrom henrik@henriknordstrom.net + * (C) Copyright 2013 Luke Kenneth Casson Leighton lkcl@lkcl.net + * (C) Copyright 2007-2011 + * Allwinner Technology Co., Ltd. <www.allwinnertech.com> + * Tom Cubie tangliang@allwinnertech.com + * + * Code to setup the UART pinmux configuration in the SPL, which lacks + * the DT to look this up properly. + */ + +#include <asm/gpio.h> +#include <config.h> +#include <sunxi_gpio.h> + +void uart_pinmux_setup(void) +{ +#if CONFIG_CONS_INDEX == 1 && defined(CONFIG_UART0_PORT_F) +#if defined(CONFIG_MACH_SUN4I) || \ + defined(CONFIG_MACH_SUN7I) || \ + defined(CONFIG_MACH_SUN8I_R40) + /* disable GPB22,23 as uart0 tx,rx to avoid conflict */ + sunxi_gpio_set_cfgpin(SUNXI_GPB(22), SUNXI_GPIO_INPUT); + sunxi_gpio_set_cfgpin(SUNXI_GPB(23), SUNXI_GPIO_INPUT); +#endif +#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN5I) || \ + defined(CONFIG_MACH_SUN7I) || defined(CONFIG_MACH_SUN8I_R40) || \ + defined(CONFIG_MACH_SUN9I) + sunxi_gpio_set_cfgpin(SUNXI_GPF(2), SUNXI_GPF_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPF(4), SUNXI_GPF_UART0); +#else + sunxi_gpio_set_cfgpin(SUNXI_GPF(2), SUN8I_GPF_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPF(4), SUN8I_GPF_UART0); +#endif + sunxi_gpio_set_pull(SUNXI_GPF(4), SUNXI_GPIO_PULL_UP); +#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUNIV) + sunxi_gpio_set_cfgpin(SUNXI_GPE(0), SUNIV_GPE_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPE(1), SUNIV_GPE_UART0); + sunxi_gpio_set_pull(SUNXI_GPE(1), SUNXI_GPIO_PULL_UP); +#elif CONFIG_CONS_INDEX == 1 && (defined(CONFIG_MACH_SUN4I) || \ + defined(CONFIG_MACH_SUN7I) || \ + defined(CONFIG_MACH_SUN8I_R40)) + sunxi_gpio_set_cfgpin(SUNXI_GPB(22), SUN4I_GPB_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPB(23), SUN4I_GPB_UART0); + sunxi_gpio_set_pull(SUNXI_GPB(23), SUNXI_GPIO_PULL_UP); +#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN5I) + sunxi_gpio_set_cfgpin(SUNXI_GPB(19), SUN5I_GPB_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPB(20), SUN5I_GPB_UART0); + sunxi_gpio_set_pull(SUNXI_GPB(20), SUNXI_GPIO_PULL_UP); +#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN6I) + sunxi_gpio_set_cfgpin(SUNXI_GPH(20), SUN6I_GPH_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPH(21), SUN6I_GPH_UART0); + sunxi_gpio_set_pull(SUNXI_GPH(21), SUNXI_GPIO_PULL_UP); +#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN8I_A33) + sunxi_gpio_set_cfgpin(SUNXI_GPB(0), SUN8I_A33_GPB_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPB(1), SUN8I_A33_GPB_UART0); + sunxi_gpio_set_pull(SUNXI_GPB(1), SUNXI_GPIO_PULL_UP); +#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUNXI_H3_H5) + sunxi_gpio_set_cfgpin(SUNXI_GPA(4), SUN8I_H3_GPA_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPA(5), SUN8I_H3_GPA_UART0); + sunxi_gpio_set_pull(SUNXI_GPA(5), SUNXI_GPIO_PULL_UP); +#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN50I) + sunxi_gpio_set_cfgpin(SUNXI_GPB(8), SUN50I_GPB_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPB(9), SUN50I_GPB_UART0); + sunxi_gpio_set_pull(SUNXI_GPB(9), SUNXI_GPIO_PULL_UP); +#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN50I_H6) + sunxi_gpio_set_cfgpin(SUNXI_GPH(0), SUN50I_H6_GPH_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPH(1), SUN50I_H6_GPH_UART0); + sunxi_gpio_set_pull(SUNXI_GPH(1), SUNXI_GPIO_PULL_UP); +#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN50I_H616) + sunxi_gpio_set_cfgpin(SUNXI_GPH(0), SUN50I_H616_GPH_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPH(1), SUN50I_H616_GPH_UART0); + sunxi_gpio_set_pull(SUNXI_GPH(1), SUNXI_GPIO_PULL_UP); +#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN8I_A83T) + sunxi_gpio_set_cfgpin(SUNXI_GPB(9), SUN8I_A83T_GPB_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPB(10), SUN8I_A83T_GPB_UART0); + sunxi_gpio_set_pull(SUNXI_GPB(10), SUNXI_GPIO_PULL_UP); +#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN8I_V3S) + sunxi_gpio_set_cfgpin(SUNXI_GPB(8), SUN8I_V3S_GPB_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPB(9), SUN8I_V3S_GPB_UART0); + sunxi_gpio_set_pull(SUNXI_GPB(9), SUNXI_GPIO_PULL_UP); +#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN9I) + sunxi_gpio_set_cfgpin(SUNXI_GPH(12), SUN9I_GPH_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPH(13), SUN9I_GPH_UART0); + sunxi_gpio_set_pull(SUNXI_GPH(13), SUNXI_GPIO_PULL_UP); +#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN8I_R528) + sunxi_gpio_set_cfgpin(SUNXI_GPE(2), 6); + sunxi_gpio_set_cfgpin(SUNXI_GPE(3), 6); + sunxi_gpio_set_pull(SUNXI_GPE(3), SUNXI_GPIO_PULL_UP); +#elif CONFIG_CONS_INDEX == 2 && defined(CONFIG_MACH_SUNIV) + sunxi_gpio_set_cfgpin(SUNXI_GPA(2), SUNIV_GPE_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPA(3), SUNIV_GPE_UART0); + sunxi_gpio_set_pull(SUNXI_GPA(3), SUNXI_GPIO_PULL_UP); +#elif CONFIG_CONS_INDEX == 2 && defined(CONFIG_MACH_SUN5I) + sunxi_gpio_set_cfgpin(SUNXI_GPG(3), SUN5I_GPG_UART1); + sunxi_gpio_set_cfgpin(SUNXI_GPG(4), SUN5I_GPG_UART1); + sunxi_gpio_set_pull(SUNXI_GPG(4), SUNXI_GPIO_PULL_UP); +#elif CONFIG_CONS_INDEX == 3 && defined(CONFIG_MACH_SUN8I_H3) + sunxi_gpio_set_cfgpin(SUNXI_GPA(0), SUN8I_H3_GPA_UART2); + sunxi_gpio_set_cfgpin(SUNXI_GPA(1), SUN8I_H3_GPA_UART2); + sunxi_gpio_set_pull(SUNXI_GPA(1), SUNXI_GPIO_PULL_UP); +#elif CONFIG_CONS_INDEX == 3 && defined(CONFIG_MACH_SUN8I) + sunxi_gpio_set_cfgpin(SUNXI_GPB(0), SUN8I_GPB_UART2); + sunxi_gpio_set_cfgpin(SUNXI_GPB(1), SUN8I_GPB_UART2); + sunxi_gpio_set_pull(SUNXI_GPB(1), SUNXI_GPIO_PULL_UP); +#elif CONFIG_CONS_INDEX == 4 && defined(CONFIG_MACH_SUN8I_R528) + sunxi_gpio_set_cfgpin(SUNXI_GPB(6), 7); + sunxi_gpio_set_cfgpin(SUNXI_GPB(7), 7); + sunxi_gpio_set_pull(SUNXI_GPB(7), SUNXI_GPIO_PULL_UP); +#elif CONFIG_CONS_INDEX == 5 && defined(CONFIG_MACH_SUN8I) + sunxi_gpio_set_cfgpin(SUNXI_GPL(2), SUN8I_GPL_R_UART); + sunxi_gpio_set_cfgpin(SUNXI_GPL(3), SUN8I_GPL_R_UART); + sunxi_gpio_set_pull(SUNXI_GPL(3), SUNXI_GPIO_PULL_UP); +#elif CONFIG_CONS_INDEX == 2 && defined(CONFIG_MACH_SUN8I) && \ + !defined(CONFIG_MACH_SUN8I_R40) + sunxi_gpio_set_cfgpin(SUNXI_GPG(6), SUN8I_GPG_UART1); + sunxi_gpio_set_cfgpin(SUNXI_GPG(7), SUN8I_GPG_UART1); + sunxi_gpio_set_pull(SUNXI_GPG(7), SUNXI_GPIO_PULL_UP); +#else +#error Unsupported console port number. Please fix pin mux settings in board.c +#endif +}
The UART SPL pinmux function is particularly hard to read, as it combines per-SoC definitions with per-configuration choices (which UART to use).
Split the existing single function into one per UART port, to reduce the #ifdef hell and improve readability. The four cases which deal with UARTs other than 0 or 1 are left in the main function, to reduce clutter.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/mach-sunxi/uart_pinmux.c | 66 ++++++++++++++++++++----------- 1 file changed, 42 insertions(+), 24 deletions(-)
diff --git a/arch/arm/mach-sunxi/uart_pinmux.c b/arch/arm/mach-sunxi/uart_pinmux.c index af5ecc4fb3c..cb4b16f0e37 100644 --- a/arch/arm/mach-sunxi/uart_pinmux.c +++ b/arch/arm/mach-sunxi/uart_pinmux.c @@ -15,9 +15,8 @@ #include <config.h> #include <sunxi_gpio.h>
-void uart_pinmux_setup(void) +void uart0_portf_pinmux_setup(void) { -#if CONFIG_CONS_INDEX == 1 && defined(CONFIG_UART0_PORT_F) #if defined(CONFIG_MACH_SUN4I) || \ defined(CONFIG_MACH_SUN7I) || \ defined(CONFIG_MACH_SUN8I_R40) @@ -35,68 +34,92 @@ void uart_pinmux_setup(void) sunxi_gpio_set_cfgpin(SUNXI_GPF(4), SUN8I_GPF_UART0); #endif sunxi_gpio_set_pull(SUNXI_GPF(4), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUNIV) +} + +void uart0_pinmux_setup(void) +{ +#if defined(CONFIG_MACH_SUNIV) sunxi_gpio_set_cfgpin(SUNXI_GPE(0), SUNIV_GPE_UART0); sunxi_gpio_set_cfgpin(SUNXI_GPE(1), SUNIV_GPE_UART0); sunxi_gpio_set_pull(SUNXI_GPE(1), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 1 && (defined(CONFIG_MACH_SUN4I) || \ - defined(CONFIG_MACH_SUN7I) || \ - defined(CONFIG_MACH_SUN8I_R40)) +#elif (defined(CONFIG_MACH_SUN4I) || \ + defined(CONFIG_MACH_SUN7I) || \ + defined(CONFIG_MACH_SUN8I_R40)) sunxi_gpio_set_cfgpin(SUNXI_GPB(22), SUN4I_GPB_UART0); sunxi_gpio_set_cfgpin(SUNXI_GPB(23), SUN4I_GPB_UART0); sunxi_gpio_set_pull(SUNXI_GPB(23), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN5I) +#elif defined(CONFIG_MACH_SUN5I) sunxi_gpio_set_cfgpin(SUNXI_GPB(19), SUN5I_GPB_UART0); sunxi_gpio_set_cfgpin(SUNXI_GPB(20), SUN5I_GPB_UART0); sunxi_gpio_set_pull(SUNXI_GPB(20), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN6I) +#elif defined(CONFIG_MACH_SUN6I) sunxi_gpio_set_cfgpin(SUNXI_GPH(20), SUN6I_GPH_UART0); sunxi_gpio_set_cfgpin(SUNXI_GPH(21), SUN6I_GPH_UART0); sunxi_gpio_set_pull(SUNXI_GPH(21), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN8I_A33) +#elif defined(CONFIG_MACH_SUN8I_A33) sunxi_gpio_set_cfgpin(SUNXI_GPB(0), SUN8I_A33_GPB_UART0); sunxi_gpio_set_cfgpin(SUNXI_GPB(1), SUN8I_A33_GPB_UART0); sunxi_gpio_set_pull(SUNXI_GPB(1), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUNXI_H3_H5) +#elif defined(CONFIG_MACH_SUNXI_H3_H5) sunxi_gpio_set_cfgpin(SUNXI_GPA(4), SUN8I_H3_GPA_UART0); sunxi_gpio_set_cfgpin(SUNXI_GPA(5), SUN8I_H3_GPA_UART0); sunxi_gpio_set_pull(SUNXI_GPA(5), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN50I) +#elif defined(CONFIG_MACH_SUN50I) sunxi_gpio_set_cfgpin(SUNXI_GPB(8), SUN50I_GPB_UART0); sunxi_gpio_set_cfgpin(SUNXI_GPB(9), SUN50I_GPB_UART0); sunxi_gpio_set_pull(SUNXI_GPB(9), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN50I_H6) +#elif defined(CONFIG_MACH_SUN50I_H6) sunxi_gpio_set_cfgpin(SUNXI_GPH(0), SUN50I_H6_GPH_UART0); sunxi_gpio_set_cfgpin(SUNXI_GPH(1), SUN50I_H6_GPH_UART0); sunxi_gpio_set_pull(SUNXI_GPH(1), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN50I_H616) +#elif defined(CONFIG_MACH_SUN50I_H616) sunxi_gpio_set_cfgpin(SUNXI_GPH(0), SUN50I_H616_GPH_UART0); sunxi_gpio_set_cfgpin(SUNXI_GPH(1), SUN50I_H616_GPH_UART0); sunxi_gpio_set_pull(SUNXI_GPH(1), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN8I_A83T) +#elif defined(CONFIG_MACH_SUN8I_A83T) sunxi_gpio_set_cfgpin(SUNXI_GPB(9), SUN8I_A83T_GPB_UART0); sunxi_gpio_set_cfgpin(SUNXI_GPB(10), SUN8I_A83T_GPB_UART0); sunxi_gpio_set_pull(SUNXI_GPB(10), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN8I_V3S) +#elif defined(CONFIG_MACH_SUN8I_V3S) sunxi_gpio_set_cfgpin(SUNXI_GPB(8), SUN8I_V3S_GPB_UART0); sunxi_gpio_set_cfgpin(SUNXI_GPB(9), SUN8I_V3S_GPB_UART0); sunxi_gpio_set_pull(SUNXI_GPB(9), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN9I) +#elif defined(CONFIG_MACH_SUN9I) sunxi_gpio_set_cfgpin(SUNXI_GPH(12), SUN9I_GPH_UART0); sunxi_gpio_set_cfgpin(SUNXI_GPH(13), SUN9I_GPH_UART0); sunxi_gpio_set_pull(SUNXI_GPH(13), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN8I_R528) +#elif defined(CONFIG_MACH_SUN8I_R528) sunxi_gpio_set_cfgpin(SUNXI_GPE(2), 6); sunxi_gpio_set_cfgpin(SUNXI_GPE(3), 6); sunxi_gpio_set_pull(SUNXI_GPE(3), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 2 && defined(CONFIG_MACH_SUNIV) +#endif +} + +void uart1_pinmux_setup(void) +{ +#if defined(CONFIG_MACH_SUNIV) sunxi_gpio_set_cfgpin(SUNXI_GPA(2), SUNIV_GPE_UART0); sunxi_gpio_set_cfgpin(SUNXI_GPA(3), SUNIV_GPE_UART0); sunxi_gpio_set_pull(SUNXI_GPA(3), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 2 && defined(CONFIG_MACH_SUN5I) +#elif defined(CONFIG_MACH_SUN5I) sunxi_gpio_set_cfgpin(SUNXI_GPG(3), SUN5I_GPG_UART1); sunxi_gpio_set_cfgpin(SUNXI_GPG(4), SUN5I_GPG_UART1); sunxi_gpio_set_pull(SUNXI_GPG(4), SUNXI_GPIO_PULL_UP); +#elif defined(CONFIG_MACH_SUN8I) && !defined(CONFIG_MACH_SUN8I_R40) + sunxi_gpio_set_cfgpin(SUNXI_GPG(6), SUN8I_GPG_UART1); + sunxi_gpio_set_cfgpin(SUNXI_GPG(7), SUN8I_GPG_UART1); + sunxi_gpio_set_pull(SUNXI_GPG(7), SUNXI_GPIO_PULL_UP); +#endif +} + +void uart_pinmux_setup(void) +{ +#if CONFIG_CONS_INDEX == 1 + uart0_pinmux_setup(); + return; +#elif CONFIG_CONS_INDEX == 2 + uart1_pinmux_setup(); + return; #elif CONFIG_CONS_INDEX == 3 && defined(CONFIG_MACH_SUN8I_H3) sunxi_gpio_set_cfgpin(SUNXI_GPA(0), SUN8I_H3_GPA_UART2); sunxi_gpio_set_cfgpin(SUNXI_GPA(1), SUN8I_H3_GPA_UART2); @@ -113,11 +136,6 @@ void uart_pinmux_setup(void) sunxi_gpio_set_cfgpin(SUNXI_GPL(2), SUN8I_GPL_R_UART); sunxi_gpio_set_cfgpin(SUNXI_GPL(3), SUN8I_GPL_R_UART); sunxi_gpio_set_pull(SUNXI_GPL(3), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 2 && defined(CONFIG_MACH_SUN8I) && \ - !defined(CONFIG_MACH_SUN8I_R40) - sunxi_gpio_set_cfgpin(SUNXI_GPG(6), SUN8I_GPG_UART1); - sunxi_gpio_set_cfgpin(SUNXI_GPG(7), SUN8I_GPG_UART1); - sunxi_gpio_set_pull(SUNXI_GPG(7), SUNXI_GPIO_PULL_UP); #else #error Unsupported console port number. Please fix pin mux settings in board.c #endif
The existing SPL UART pinmux setup is using #ifdef's heavily, which makes it hard to read and even harder to extend.
Replace the #ifdef's with proper C "if" statements, with the help of the magic IS_ENABLED() macro.
To cover the non-configured case, which is currently handled by an #error preprocessor directive, create a prototype for a non-existing function. Replace that #error line with a call to that function, which will be removed by the compiler and linker in the normal case, but will cause a linker error otherwise.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/mach-sunxi/uart_pinmux.c | 240 ++++++++++++++++-------------- 1 file changed, 128 insertions(+), 112 deletions(-)
diff --git a/arch/arm/mach-sunxi/uart_pinmux.c b/arch/arm/mach-sunxi/uart_pinmux.c index cb4b16f0e37..ba42352fbcf 100644 --- a/arch/arm/mach-sunxi/uart_pinmux.c +++ b/arch/arm/mach-sunxi/uart_pinmux.c @@ -15,128 +15,144 @@ #include <config.h> #include <sunxi_gpio.h>
-void uart0_portf_pinmux_setup(void) +/* Non-existing function to trigger speaking link error. */ +void Unsupported_console_number_Please_fix_UART_pin_mux_settings(void); + +static void uart0_portf_pinmux_setup(void) { -#if defined(CONFIG_MACH_SUN4I) || \ - defined(CONFIG_MACH_SUN7I) || \ - defined(CONFIG_MACH_SUN8I_R40) - /* disable GPB22,23 as uart0 tx,rx to avoid conflict */ - sunxi_gpio_set_cfgpin(SUNXI_GPB(22), SUNXI_GPIO_INPUT); - sunxi_gpio_set_cfgpin(SUNXI_GPB(23), SUNXI_GPIO_INPUT); -#endif -#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN5I) || \ - defined(CONFIG_MACH_SUN7I) || defined(CONFIG_MACH_SUN8I_R40) || \ - defined(CONFIG_MACH_SUN9I) - sunxi_gpio_set_cfgpin(SUNXI_GPF(2), SUNXI_GPF_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPF(4), SUNXI_GPF_UART0); -#else - sunxi_gpio_set_cfgpin(SUNXI_GPF(2), SUN8I_GPF_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPF(4), SUN8I_GPF_UART0); -#endif + if (IS_ENABLED(CONFIG_MACH_SUN4I) || IS_ENABLED(CONFIG_MACH_SUN7I) || + IS_ENABLED(CONFIG_MACH_SUN8I_R40)) { + /* disable GPB22,23 as uart0 tx,rx to avoid conflict */ + sunxi_gpio_set_cfgpin(SUNXI_GPB(22), SUNXI_GPIO_INPUT); + sunxi_gpio_set_cfgpin(SUNXI_GPB(23), SUNXI_GPIO_INPUT); + } + + if (IS_ENABLED(CONFIG_MACH_SUN4I) || IS_ENABLED(CONFIG_MACH_SUN5I) || + IS_ENABLED(CONFIG_MACH_SUN7I) || IS_ENABLED(CONFIG_MACH_SUN8I_R40) || + IS_ENABLED(CONFIG_MACH_SUN9I)) { + sunxi_gpio_set_cfgpin(SUNXI_GPF(2), SUNXI_GPF_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPF(4), SUNXI_GPF_UART0); + } else { + sunxi_gpio_set_cfgpin(SUNXI_GPF(2), SUN8I_GPF_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPF(4), SUN8I_GPF_UART0); + } sunxi_gpio_set_pull(SUNXI_GPF(4), SUNXI_GPIO_PULL_UP); }
-void uart0_pinmux_setup(void) +static void uart0_pinmux_setup(void) { -#if defined(CONFIG_MACH_SUNIV) - sunxi_gpio_set_cfgpin(SUNXI_GPE(0), SUNIV_GPE_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPE(1), SUNIV_GPE_UART0); - sunxi_gpio_set_pull(SUNXI_GPE(1), SUNXI_GPIO_PULL_UP); -#elif (defined(CONFIG_MACH_SUN4I) || \ - defined(CONFIG_MACH_SUN7I) || \ - defined(CONFIG_MACH_SUN8I_R40)) - sunxi_gpio_set_cfgpin(SUNXI_GPB(22), SUN4I_GPB_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPB(23), SUN4I_GPB_UART0); - sunxi_gpio_set_pull(SUNXI_GPB(23), SUNXI_GPIO_PULL_UP); -#elif defined(CONFIG_MACH_SUN5I) - sunxi_gpio_set_cfgpin(SUNXI_GPB(19), SUN5I_GPB_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPB(20), SUN5I_GPB_UART0); - sunxi_gpio_set_pull(SUNXI_GPB(20), SUNXI_GPIO_PULL_UP); -#elif defined(CONFIG_MACH_SUN6I) - sunxi_gpio_set_cfgpin(SUNXI_GPH(20), SUN6I_GPH_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPH(21), SUN6I_GPH_UART0); - sunxi_gpio_set_pull(SUNXI_GPH(21), SUNXI_GPIO_PULL_UP); -#elif defined(CONFIG_MACH_SUN8I_A33) - sunxi_gpio_set_cfgpin(SUNXI_GPB(0), SUN8I_A33_GPB_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPB(1), SUN8I_A33_GPB_UART0); - sunxi_gpio_set_pull(SUNXI_GPB(1), SUNXI_GPIO_PULL_UP); -#elif defined(CONFIG_MACH_SUNXI_H3_H5) - sunxi_gpio_set_cfgpin(SUNXI_GPA(4), SUN8I_H3_GPA_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPA(5), SUN8I_H3_GPA_UART0); - sunxi_gpio_set_pull(SUNXI_GPA(5), SUNXI_GPIO_PULL_UP); -#elif defined(CONFIG_MACH_SUN50I) - sunxi_gpio_set_cfgpin(SUNXI_GPB(8), SUN50I_GPB_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPB(9), SUN50I_GPB_UART0); - sunxi_gpio_set_pull(SUNXI_GPB(9), SUNXI_GPIO_PULL_UP); -#elif defined(CONFIG_MACH_SUN50I_H6) - sunxi_gpio_set_cfgpin(SUNXI_GPH(0), SUN50I_H6_GPH_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPH(1), SUN50I_H6_GPH_UART0); - sunxi_gpio_set_pull(SUNXI_GPH(1), SUNXI_GPIO_PULL_UP); -#elif defined(CONFIG_MACH_SUN50I_H616) - sunxi_gpio_set_cfgpin(SUNXI_GPH(0), SUN50I_H616_GPH_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPH(1), SUN50I_H616_GPH_UART0); - sunxi_gpio_set_pull(SUNXI_GPH(1), SUNXI_GPIO_PULL_UP); -#elif defined(CONFIG_MACH_SUN8I_A83T) - sunxi_gpio_set_cfgpin(SUNXI_GPB(9), SUN8I_A83T_GPB_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPB(10), SUN8I_A83T_GPB_UART0); - sunxi_gpio_set_pull(SUNXI_GPB(10), SUNXI_GPIO_PULL_UP); -#elif defined(CONFIG_MACH_SUN8I_V3S) - sunxi_gpio_set_cfgpin(SUNXI_GPB(8), SUN8I_V3S_GPB_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPB(9), SUN8I_V3S_GPB_UART0); - sunxi_gpio_set_pull(SUNXI_GPB(9), SUNXI_GPIO_PULL_UP); -#elif defined(CONFIG_MACH_SUN9I) - sunxi_gpio_set_cfgpin(SUNXI_GPH(12), SUN9I_GPH_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPH(13), SUN9I_GPH_UART0); - sunxi_gpio_set_pull(SUNXI_GPH(13), SUNXI_GPIO_PULL_UP); -#elif defined(CONFIG_MACH_SUN8I_R528) - sunxi_gpio_set_cfgpin(SUNXI_GPE(2), 6); - sunxi_gpio_set_cfgpin(SUNXI_GPE(3), 6); - sunxi_gpio_set_pull(SUNXI_GPE(3), SUNXI_GPIO_PULL_UP); -#endif + if (IS_ENABLED(CONFIG_UART0_PORT_F)) { + uart0_portf_pinmux_setup(); + return; + } + + if (IS_ENABLED(CONFIG_MACH_SUNIV)) { + sunxi_gpio_set_cfgpin(SUNXI_GPE(0), SUNIV_GPE_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPE(1), SUNIV_GPE_UART0); + sunxi_gpio_set_pull(SUNXI_GPE(1), SUNXI_GPIO_PULL_UP); + } else if (IS_ENABLED(CONFIG_MACH_SUN4I) || + IS_ENABLED(CONFIG_MACH_SUN7I) || + IS_ENABLED(CONFIG_MACH_SUN8I_R40)) { + sunxi_gpio_set_cfgpin(SUNXI_GPB(22), SUN4I_GPB_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPB(23), SUN4I_GPB_UART0); + sunxi_gpio_set_pull(SUNXI_GPB(23), SUNXI_GPIO_PULL_UP); + } else if (IS_ENABLED(CONFIG_MACH_SUN5I)) { + sunxi_gpio_set_cfgpin(SUNXI_GPB(19), SUN5I_GPB_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPB(20), SUN5I_GPB_UART0); + sunxi_gpio_set_pull(SUNXI_GPB(20), SUNXI_GPIO_PULL_UP); + } else if (IS_ENABLED(CONFIG_MACH_SUN6I)) { + sunxi_gpio_set_cfgpin(SUNXI_GPH(20), SUN6I_GPH_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPH(21), SUN6I_GPH_UART0); + sunxi_gpio_set_pull(SUNXI_GPH(21), SUNXI_GPIO_PULL_UP); + } else if (IS_ENABLED(CONFIG_MACH_SUN8I_A33)) { + sunxi_gpio_set_cfgpin(SUNXI_GPB(0), SUN8I_A33_GPB_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPB(1), SUN8I_A33_GPB_UART0); + sunxi_gpio_set_pull(SUNXI_GPB(1), SUNXI_GPIO_PULL_UP); + } else if (IS_ENABLED(CONFIG_MACH_SUNXI_H3_H5)) { + sunxi_gpio_set_cfgpin(SUNXI_GPA(4), SUN8I_H3_GPA_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPA(5), SUN8I_H3_GPA_UART0); + sunxi_gpio_set_pull(SUNXI_GPA(5), SUNXI_GPIO_PULL_UP); + } else if (IS_ENABLED(CONFIG_MACH_SUN50I)) { + sunxi_gpio_set_cfgpin(SUNXI_GPB(8), SUN50I_GPB_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPB(9), SUN50I_GPB_UART0); + sunxi_gpio_set_pull(SUNXI_GPB(9), SUNXI_GPIO_PULL_UP); + } else if (IS_ENABLED(CONFIG_MACH_SUN50I_H6)) { + sunxi_gpio_set_cfgpin(SUNXI_GPH(0), SUN50I_H6_GPH_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPH(1), SUN50I_H6_GPH_UART0); + sunxi_gpio_set_pull(SUNXI_GPH(1), SUNXI_GPIO_PULL_UP); + } else if (IS_ENABLED(CONFIG_MACH_SUN50I_H616)) { + sunxi_gpio_set_cfgpin(SUNXI_GPH(0), SUN50I_H616_GPH_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPH(1), SUN50I_H616_GPH_UART0); + sunxi_gpio_set_pull(SUNXI_GPH(1), SUNXI_GPIO_PULL_UP); + } else if (IS_ENABLED(CONFIG_MACH_SUN8I_A83T)) { + sunxi_gpio_set_cfgpin(SUNXI_GPB(9), SUN8I_A83T_GPB_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPB(10), SUN8I_A83T_GPB_UART0); + sunxi_gpio_set_pull(SUNXI_GPB(10), SUNXI_GPIO_PULL_UP); + } else if (IS_ENABLED(CONFIG_MACH_SUN8I_V3S)) { + sunxi_gpio_set_cfgpin(SUNXI_GPB(8), SUN8I_V3S_GPB_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPB(9), SUN8I_V3S_GPB_UART0); + sunxi_gpio_set_pull(SUNXI_GPB(9), SUNXI_GPIO_PULL_UP); + } else if (IS_ENABLED(CONFIG_MACH_SUN9I)) { + sunxi_gpio_set_cfgpin(SUNXI_GPH(12), SUN9I_GPH_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPH(13), SUN9I_GPH_UART0); + sunxi_gpio_set_pull(SUNXI_GPH(13), SUNXI_GPIO_PULL_UP); + } else if (IS_ENABLED(CONFIG_MACH_SUN8I_R528)) { + sunxi_gpio_set_cfgpin(SUNXI_GPE(2), 6); + sunxi_gpio_set_cfgpin(SUNXI_GPE(3), 6); + sunxi_gpio_set_pull(SUNXI_GPE(3), SUNXI_GPIO_PULL_UP); + } else { + Unsupported_console_number_Please_fix_UART_pin_mux_settings(); + } }
-void uart1_pinmux_setup(void) +static void uart1_pinmux_setup(void) { -#if defined(CONFIG_MACH_SUNIV) - sunxi_gpio_set_cfgpin(SUNXI_GPA(2), SUNIV_GPE_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPA(3), SUNIV_GPE_UART0); - sunxi_gpio_set_pull(SUNXI_GPA(3), SUNXI_GPIO_PULL_UP); -#elif defined(CONFIG_MACH_SUN5I) - sunxi_gpio_set_cfgpin(SUNXI_GPG(3), SUN5I_GPG_UART1); - sunxi_gpio_set_cfgpin(SUNXI_GPG(4), SUN5I_GPG_UART1); - sunxi_gpio_set_pull(SUNXI_GPG(4), SUNXI_GPIO_PULL_UP); -#elif defined(CONFIG_MACH_SUN8I) && !defined(CONFIG_MACH_SUN8I_R40) - sunxi_gpio_set_cfgpin(SUNXI_GPG(6), SUN8I_GPG_UART1); - sunxi_gpio_set_cfgpin(SUNXI_GPG(7), SUN8I_GPG_UART1); - sunxi_gpio_set_pull(SUNXI_GPG(7), SUNXI_GPIO_PULL_UP); -#endif + if (IS_ENABLED(CONFIG_MACH_SUNIV)) { + sunxi_gpio_set_cfgpin(SUNXI_GPA(2), SUNIV_GPE_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPA(3), SUNIV_GPE_UART0); + sunxi_gpio_set_pull(SUNXI_GPA(3), SUNXI_GPIO_PULL_UP); + } else if (IS_ENABLED(CONFIG_MACH_SUN5I)) { + sunxi_gpio_set_cfgpin(SUNXI_GPG(3), SUN5I_GPG_UART1); + sunxi_gpio_set_cfgpin(SUNXI_GPG(4), SUN5I_GPG_UART1); + sunxi_gpio_set_pull(SUNXI_GPG(4), SUNXI_GPIO_PULL_UP); + } else if (IS_ENABLED(CONFIG_MACH_SUN8I) && + !IS_ENABLED(CONFIG_MACH_SUN8I_R40)) { + sunxi_gpio_set_cfgpin(SUNXI_GPG(6), SUN8I_GPG_UART1); + sunxi_gpio_set_cfgpin(SUNXI_GPG(7), SUN8I_GPG_UART1); + sunxi_gpio_set_pull(SUNXI_GPG(7), SUNXI_GPIO_PULL_UP); + } else { + Unsupported_console_number_Please_fix_UART_pin_mux_settings(); + } }
void uart_pinmux_setup(void) { -#if CONFIG_CONS_INDEX == 1 - uart0_pinmux_setup(); - return; -#elif CONFIG_CONS_INDEX == 2 - uart1_pinmux_setup(); - return; -#elif CONFIG_CONS_INDEX == 3 && defined(CONFIG_MACH_SUN8I_H3) - sunxi_gpio_set_cfgpin(SUNXI_GPA(0), SUN8I_H3_GPA_UART2); - sunxi_gpio_set_cfgpin(SUNXI_GPA(1), SUN8I_H3_GPA_UART2); - sunxi_gpio_set_pull(SUNXI_GPA(1), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 3 && defined(CONFIG_MACH_SUN8I) - sunxi_gpio_set_cfgpin(SUNXI_GPB(0), SUN8I_GPB_UART2); - sunxi_gpio_set_cfgpin(SUNXI_GPB(1), SUN8I_GPB_UART2); - sunxi_gpio_set_pull(SUNXI_GPB(1), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 4 && defined(CONFIG_MACH_SUN8I_R528) - sunxi_gpio_set_cfgpin(SUNXI_GPB(6), 7); - sunxi_gpio_set_cfgpin(SUNXI_GPB(7), 7); - sunxi_gpio_set_pull(SUNXI_GPB(7), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 5 && defined(CONFIG_MACH_SUN8I) - sunxi_gpio_set_cfgpin(SUNXI_GPL(2), SUN8I_GPL_R_UART); - sunxi_gpio_set_cfgpin(SUNXI_GPL(3), SUN8I_GPL_R_UART); - sunxi_gpio_set_pull(SUNXI_GPL(3), SUNXI_GPIO_PULL_UP); -#else -#error Unsupported console port number. Please fix pin mux settings in board.c -#endif + if (CONFIG_CONS_INDEX == 1) { + uart0_pinmux_setup(); + return; + } + if (CONFIG_CONS_INDEX == 2) { + uart1_pinmux_setup(); + return; + } + if (CONFIG_CONS_INDEX == 3 && IS_ENABLED(CONFIG_MACH_SUN8I_H3)) { + sunxi_gpio_set_cfgpin(SUNXI_GPA(0), SUN8I_H3_GPA_UART2); + sunxi_gpio_set_cfgpin(SUNXI_GPA(1), SUN8I_H3_GPA_UART2); + sunxi_gpio_set_pull(SUNXI_GPA(1), SUNXI_GPIO_PULL_UP); + } else if (CONFIG_CONS_INDEX == 3 && IS_ENABLED(CONFIG_MACH_SUN8I)) { + sunxi_gpio_set_cfgpin(SUNXI_GPB(0), SUN8I_GPB_UART2); + sunxi_gpio_set_cfgpin(SUNXI_GPB(1), SUN8I_GPB_UART2); + sunxi_gpio_set_pull(SUNXI_GPB(1), SUNXI_GPIO_PULL_UP); + } else if (CONFIG_CONS_INDEX == 4 && + IS_ENABLED(CONFIG_MACH_SUN8I_R528)) { + sunxi_gpio_set_cfgpin(SUNXI_GPB(6), 7); + sunxi_gpio_set_cfgpin(SUNXI_GPB(7), 7); + sunxi_gpio_set_pull(SUNXI_GPB(7), SUNXI_GPIO_PULL_UP); + } else if (CONFIG_CONS_INDEX == 5 && IS_ENABLED(CONFIG_MACH_SUN8I)) { + sunxi_gpio_set_cfgpin(SUNXI_GPL(2), SUN8I_GPL_R_UART); + sunxi_gpio_set_cfgpin(SUNXI_GPL(3), SUN8I_GPL_R_UART); + sunxi_gpio_set_pull(SUNXI_GPL(3), SUNXI_GPIO_PULL_UP); + } else { + Unsupported_console_number_Please_fix_UART_pin_mux_settings(); + } }
On Wed, 3 Jan 2024 00:12:20 +0000 Andre Przywara andre.przywara@arm.com wrote:
This is the first part of a series to clean up the Allwinner SPL a bit.
will anyone have a chance to look at this?
I compiled patches 1-4,6,7 for all sunxi boards and the resulting binaries were identical compared to the base, so if no one screams, I would like to merge those 6 patches ASAP.
The other patches can surely wait, though I would be glad if someone would have a look and could confirm if that goes into the right direction in general.
Cheers, Andre
One big driver for this whole clean up is to eventually accommodate the RISC-V chips, which share most platform devices, but cannot use any code that currently lives under arch/arm. So the idea is to disentangle the code, to get a cleaner separation between ARM specific and platform specific code. Another related reason is that the RISC-V port aims to use a DM SPL, so we want to split off code bits that won't be needed when we have the DM framework in the SPL.
This first part of the series is mostly preparation, and some smaller cleanups, of code that was around for a long time and missed some updates. We start with some removal of no longer needed definitions, in the first seven patches. The next seven patches tighten the SPL clock code: quite some functions were compiled for U-Boot proper, however were not needed there. Sorting this out helps to identify legacy code. The final five patches move the SPL pinmux setup code into separate functions and files, and convert the #ifdef hell into proper C "if" statements.
It would be great if Samuel can have a look and say whether this is helpful or not. For instance I don't really know how much of the SPL clock code will be needed for the RISC-V port, since we don't really model the bus clocks in the DT at all, and currently don't support PLLs in the DM clock code.
Much of this first series should be good regardless, for instance the replacement of #ifdef's with C "if" statements, since that became tedious to expand for new SoCs and boards. But if some parts should live in a different directory, or should be grouped differently, this can certainly be factored in.
Please have a look, review and test!
Cheers, Andre
Andre Przywara (19): sunxi: cleanup sunxi-common.h sunxi: sun50i-h6: remove unneeded base addresses from header sunxi: sun4i: remove unneeded base addresses from header sunxi: sun9i: remove unneeded base addresses from header sunxi: move #ifdef guards around tzpc_init() to header file sunxi: remove common.h inclusion sunxi: simplify U-Boot proper only builds sunxi: remove unneeded i2c_init_board() call for U-Boot proper sunxi: compile clock.c for SPL only sunxi: sun4i: make more clock functions SPL only sunxi: sun6i: make more clock functions SPL only sunxi: sun50i_h6: make more clock functions SPL only sunxi: sun8i_a83t: make more clock functions SPL only sunxi: sun9i: make more clock functions SPL only sunxi: move pinmux setup into separate SPL only file sunxi: SPL pinmux: rewrite without #ifdefs sunxi: move UART pinmux setup into separate file sunxi: SPL pinmux: split out UART pinmux per port sunxi: SPL pinmux: rewrite UART setup without #ifdefs
arch/arm/Kconfig | 4 +- arch/arm/include/asm/arch-sunxi/clock_sun9i.h | 3 - arch/arm/include/asm/arch-sunxi/cpu_sun4i.h | 47 --- .../include/asm/arch-sunxi/cpu_sun50i_h6.h | 21 -- arch/arm/include/asm/arch-sunxi/cpu_sun9i.h | 41 --- arch/arm/include/asm/arch-sunxi/tzpc.h | 6 + arch/arm/mach-sunxi/Kconfig | 16 +- arch/arm/mach-sunxi/Makefile | 4 +- arch/arm/mach-sunxi/board.c | 113 +------ arch/arm/mach-sunxi/clock.c | 3 - arch/arm/mach-sunxi/clock_sun4i.c | 6 +- arch/arm/mach-sunxi/clock_sun50i_h6.c | 58 ++-- arch/arm/mach-sunxi/clock_sun6i.c | 4 +- arch/arm/mach-sunxi/clock_sun8i_a83t.c | 6 +- arch/arm/mach-sunxi/clock_sun9i.c | 98 +++--- arch/arm/mach-sunxi/cpu_info.c | 1 - arch/arm/mach-sunxi/dram_helpers.c | 3 +- arch/arm/mach-sunxi/dram_sun4i.c | 1 - arch/arm/mach-sunxi/dram_sun50i_h6.c | 1 - arch/arm/mach-sunxi/dram_sun50i_h616.c | 1 - arch/arm/mach-sunxi/dram_sun6i.c | 1 - arch/arm/mach-sunxi/dram_sun8i_a23.c | 1 - arch/arm/mach-sunxi/dram_sun8i_a33.c | 1 - arch/arm/mach-sunxi/dram_sun8i_a83t.c | 1 - arch/arm/mach-sunxi/dram_sun9i.c | 1 - arch/arm/mach-sunxi/dram_suniv.c | 2 +- arch/arm/mach-sunxi/dram_sunxi_dw.c | 1 - arch/arm/mach-sunxi/gtbus_sun9i.c | 1 - arch/arm/mach-sunxi/pmic_bus.c | 1 - arch/arm/mach-sunxi/prcm.c | 1 - arch/arm/mach-sunxi/spl_pinmux.c | 312 +++++++++++++++++ arch/arm/mach-sunxi/spl_spi_sunxi.c | 1 - arch/arm/mach-sunxi/timer.c | 1 - arch/arm/mach-sunxi/uart_pinmux.c | 158 +++++++++ board/sunxi/board.c | 318 +----------------- include/configs/sunxi-common.h | 56 +-- 36 files changed, 592 insertions(+), 702 deletions(-) create mode 100644 arch/arm/mach-sunxi/spl_pinmux.c create mode 100644 arch/arm/mach-sunxi/uart_pinmux.c
Andre Przywara
