[U-Boot] [PATCH] [UBI] Basic Unsorted Block Image (UBI) support (part 1)
Now it can use UBI support on U-Boot
Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- Makefile | 1 + drivers/mtd/Makefile | 1 + drivers/mtd/mtdcore.c | 142 ++++ drivers/mtd/mtdpart.c | 531 +++++++++++++ drivers/mtd/ubi/Makefile | 48 ++ drivers/mtd/ubi/build.c | 1182 ++++++++++++++++++++++++++++ drivers/mtd/ubi/crc32.c | 514 ++++++++++++ drivers/mtd/ubi/crc32defs.h | 32 + drivers/mtd/ubi/crc32table.h | 136 ++++ drivers/mtd/ubi/debug.c | 192 +++++ drivers/mtd/ubi/debug.h | 152 ++++ drivers/mtd/ubi/eba.c | 1256 ++++++++++++++++++++++++++++++ drivers/mtd/ubi/io.c | 1274 ++++++++++++++++++++++++++++++ drivers/mtd/ubi/kapi.c | 638 +++++++++++++++ drivers/mtd/ubi/misc.c | 106 +++ drivers/mtd/ubi/scan.c | 1361 ++++++++++++++++++++++++++++++++ drivers/mtd/ubi/scan.h | 165 ++++ drivers/mtd/ubi/ubi-media.h | 372 +++++++++ drivers/mtd/ubi/ubi.h | 641 +++++++++++++++ drivers/mtd/ubi/upd.c | 441 +++++++++++ drivers/mtd/ubi/vmt.c | 862 +++++++++++++++++++++ drivers/mtd/ubi/vtbl.c | 837 ++++++++++++++++++++ drivers/mtd/ubi/wl.c | 1670 ++++++++++++++++++++++++++++++++++++++++ include/linux/crc32.h | 27 + include/linux/mtd/mtd.h | 1 + include/linux/mtd/partitions.h | 84 ++ include/linux/mtd/ubi.h | 186 +++++ include/linux/types.h | 24 + include/mtd/ubi-header.h | 372 +++++++++ include/mtd/ubi-user.h | 268 +++++++ include/ubi_uboot.h | 209 +++++ 31 files changed, 13725 insertions(+), 0 deletions(-) create mode 100644 drivers/mtd/mtdcore.c create mode 100644 drivers/mtd/mtdpart.c create mode 100644 drivers/mtd/ubi/Makefile create mode 100644 drivers/mtd/ubi/build.c create mode 100644 drivers/mtd/ubi/crc32.c create mode 100644 drivers/mtd/ubi/crc32defs.h create mode 100644 drivers/mtd/ubi/crc32table.h create mode 100644 drivers/mtd/ubi/debug.c create mode 100644 drivers/mtd/ubi/debug.h create mode 100644 drivers/mtd/ubi/eba.c create mode 100644 drivers/mtd/ubi/io.c create mode 100644 drivers/mtd/ubi/kapi.c create mode 100644 drivers/mtd/ubi/misc.c create mode 100644 drivers/mtd/ubi/scan.c create mode 100644 drivers/mtd/ubi/scan.h create mode 100644 drivers/mtd/ubi/ubi-media.h create mode 100644 drivers/mtd/ubi/ubi.h create mode 100644 drivers/mtd/ubi/upd.c create mode 100644 drivers/mtd/ubi/vmt.c create mode 100644 drivers/mtd/ubi/vtbl.c create mode 100644 drivers/mtd/ubi/wl.c create mode 100644 include/linux/crc32.h create mode 100644 include/linux/mtd/partitions.h create mode 100644 include/linux/mtd/ubi.h create mode 100644 include/mtd/ubi-header.h create mode 100644 include/mtd/ubi-user.h create mode 100644 include/ubi_uboot.h
diff --git a/Makefile b/Makefile index 9a132f7..93759e4 100644 --- a/Makefile +++ b/Makefile @@ -230,6 +230,7 @@ LIBS += drivers/mtd/libmtd.a LIBS += drivers/mtd/nand/libnand.a LIBS += drivers/mtd/nand_legacy/libnand_legacy.a LIBS += drivers/mtd/onenand/libonenand.a +LIBS += drivers/mtd/ubi/libubi.a LIBS += drivers/mtd/spi/libspi_flash.a LIBS += drivers/net/libnet.a LIBS += drivers/net/phy/libphy.a diff --git a/drivers/mtd/Makefile b/drivers/mtd/Makefile index 6538f7a..d225a68 100644 --- a/drivers/mtd/Makefile +++ b/drivers/mtd/Makefile @@ -25,6 +25,7 @@ include $(TOPDIR)/config.mk
LIB := $(obj)libmtd.a
+COBJS-$(CONFIG_CMD_UBI) += mtdcore.o mtdpart.o COBJS-$(CONFIG_HAS_DATAFLASH) += at45.o COBJS-$(CONFIG_FLASH_CFI_DRIVER) += cfi_flash.o COBJS-$(CONFIG_HAS_DATAFLASH) += dataflash.o diff --git a/drivers/mtd/mtdcore.c b/drivers/mtd/mtdcore.c new file mode 100644 index 0000000..a9f494a --- /dev/null +++ b/drivers/mtd/mtdcore.c @@ -0,0 +1,142 @@ +/* + * $Id: mtdcore.c,v 1.47 2005/11/07 11:14:20 gleixner Exp $ + * + * Core registration and callback routines for MTD + * drivers and users. + */ + +#include <linux/mtd/mtd.h> +#include <linux/mtd/compat.h> +#include <ubi_uboot.h> + +struct mtd_info *mtd_table[MAX_MTD_DEVICES]; + +int add_mtd_device(struct mtd_info *mtd) +{ + int i; + + BUG_ON(mtd->writesize == 0); + + for (i=0; i < MAX_MTD_DEVICES; i++) + if (!mtd_table[i]) { + mtd_table[i] = mtd; + mtd->index = i; + mtd->usecount = 0; + + printf("mtd: Giving out device %d to %s\n",i, mtd->name); + /* No need to get a refcount on the module containing + the notifier, since we hold the mtd_table_mutex */ + + /* We _know_ we aren't being removed, because + our caller is still holding us here. So none + of this try_ nonsense, and no bitching about it + either. :) */ + return 0; + } + + return 1; +} + +/** + * del_mtd_device - unregister an MTD device + * @mtd: pointer to MTD device info structure + * + * Remove a device from the list of MTD devices present in the system, + * and notify each currently active MTD 'user' of its departure. + * Returns zero on success or 1 on failure, which currently will happen + * if the requested device does not appear to be present in the list. + */ +int del_mtd_device (struct mtd_info *mtd) +{ + int ret; + + if (mtd_table[mtd->index] != mtd) { + ret = -ENODEV; + } else if (mtd->usecount) { + printk(KERN_NOTICE "Removing MTD device #%d (%s) with use count %d\n", + mtd->index, mtd->name, mtd->usecount); + ret = -EBUSY; + } else { + /* No need to get a refcount on the module containing + * the notifier, since we hold the mtd_table_mutex */ + mtd_table[mtd->index] = NULL; + + ret = 0; + } + + return ret; +} + +/** + * get_mtd_device - obtain a validated handle for an MTD device + * @mtd: last known address of the required MTD device + * @num: internal device number of the required MTD device + * + * Given a number and NULL address, return the num'th entry in the device + * table, if any. Given an address and num == -1, search the device table + * for a device with that address and return if it's still present. Given + * both, return the num'th driver only if its address matches. Return + * error code if not. + */ +struct mtd_info *get_mtd_device(struct mtd_info *mtd, int num) +{ + struct mtd_info *ret = NULL; + int i, err = -ENODEV; + + if (num == -1) { + for (i=0; i< MAX_MTD_DEVICES; i++) + if (mtd_table[i] == mtd) + ret = mtd_table[i]; + } else if (num < MAX_MTD_DEVICES) { + ret = mtd_table[num]; + if (mtd && mtd != ret) + ret = NULL; + } + + if (!ret) + goto out_unlock; + + ret->usecount++; + return ret; + +out_unlock: + return ERR_PTR(err); +} + +/** + * get_mtd_device_nm - obtain a validated handle for an MTD device by + * device name + * @name: MTD device name to open + * + * This function returns MTD device description structure in case of + * success and an error code in case of failure. + */ +struct mtd_info *get_mtd_device_nm(const char *name) +{ + int i, err = -ENODEV; + struct mtd_info *mtd = NULL; + + for (i = 0; i < MAX_MTD_DEVICES; i++) { + if (mtd_table[i] && !strcmp(name, mtd_table[i]->name)) { + mtd = mtd_table[i]; + break; + } + } + + if (!mtd) + goto out_unlock; + + mtd->usecount++; + return mtd; + +out_unlock: + return ERR_PTR(err); +} + +void put_mtd_device(struct mtd_info *mtd) +{ + int c; + + c = --mtd->usecount; + BUG_ON(c < 0); +} diff --git a/drivers/mtd/mtdpart.c b/drivers/mtd/mtdpart.c new file mode 100644 index 0000000..113516a --- /dev/null +++ b/drivers/mtd/mtdpart.c @@ -0,0 +1,531 @@ +/* + * Simple MTD partitioning layer + * + * (C) 2000 Nicolas Pitre nico@cam.org + * + * This code is GPL + * + * $Id: mtdpart.c,v 1.55 2005/11/07 11:14:20 gleixner Exp $ + * + * 02-21-2002 Thomas Gleixner gleixner@autronix.de + * added support for read_oob, write_oob + */ + +#include <common.h> +#include <malloc.h> +#include <asm/errno.h> + +#include <linux/types.h> +#include <linux/list.h> +#include <linux/mtd/mtd.h> +#include <linux/mtd/partitions.h> +#include <linux/mtd/compat.h> + +/* Our partition linked list */ +static LIST_HEAD(mtd_partitions); + +/* Our partition node structure */ +struct mtd_part { + struct mtd_info mtd; + struct mtd_info *master; + u_int32_t offset; + int index; + struct list_head list; + int registered; +}; + +/* + * Given a pointer to the MTD object in the mtd_part structure, we can retrieve + * the pointer to that structure with this macro. + */ +#define PART(x) ((struct mtd_part *)(x)) + + +/* + * MTD methods which simply translate the effective address and pass through + * to the _real_ device. + */ + +static int part_read (struct mtd_info *mtd, loff_t from, size_t len, + size_t *retlen, u_char *buf) +{ + struct mtd_part *part = PART(mtd); + int res; + + if (from >= mtd->size) + len = 0; + else if (from + len > mtd->size) + len = mtd->size - from; + res = part->master->read (part->master, from + part->offset, + len, retlen, buf); +#if 0 + if (unlikely(res)) { + if (res == -EUCLEAN) + mtd->ecc_stats.corrected++; + if (res == -EBADMSG) + mtd->ecc_stats.failed++; + } +#endif + return res; +} + +#if 0 +static int part_point (struct mtd_info *mtd, loff_t from, size_t len, + size_t *retlen, void **virt, resource_size_t *phys) +{ + struct mtd_part *part = PART(mtd); + if (from >= mtd->size) + len = 0; + else if (from + len > mtd->size) + len = mtd->size - from; + return part->master->point (part->master, from + part->offset, + len, retlen, virt, phys); +} + +static void part_unpoint(struct mtd_info *mtd, loff_t from, size_t len) +{ + struct mtd_part *part = PART(mtd); + + part->master->unpoint(part->master, from + part->offset, len); +} + +static int part_read_oob(struct mtd_info *mtd, loff_t from, + struct mtd_oob_ops *ops) +{ + struct mtd_part *part = PART(mtd); + int res; + + if (from >= mtd->size) + return -EINVAL; + if (ops->datbuf && from + ops->len > mtd->size) + return -EINVAL; + res = part->master->read_oob(part->master, from + part->offset, ops); + + if (unlikely(res)) { + if (res == -EUCLEAN) + mtd->ecc_stats.corrected++; + if (res == -EBADMSG) + mtd->ecc_stats.failed++; + } + return res; +} + +static int part_read_user_prot_reg (struct mtd_info *mtd, loff_t from, size_t len, + size_t *retlen, u_char *buf) +{ + struct mtd_part *part = PART(mtd); + return part->master->read_user_prot_reg (part->master, from, + len, retlen, buf); +} + +static int part_get_user_prot_info (struct mtd_info *mtd, + struct otp_info *buf, size_t len) +{ + struct mtd_part *part = PART(mtd); + return part->master->get_user_prot_info (part->master, buf, len); +} + +static int part_read_fact_prot_reg (struct mtd_info *mtd, loff_t from, size_t len, + size_t *retlen, u_char *buf) +{ + struct mtd_part *part = PART(mtd); + return part->master->read_fact_prot_reg (part->master, from, + len, retlen, buf); +} + +static int part_get_fact_prot_info (struct mtd_info *mtd, + struct otp_info *buf, size_t len) +{ + struct mtd_part *part = PART(mtd); + return part->master->get_fact_prot_info (part->master, buf, len); +} +#endif + +static int part_write (struct mtd_info *mtd, loff_t to, size_t len, + size_t *retlen, const u_char *buf) +{ + struct mtd_part *part = PART(mtd); + if (!(mtd->flags & MTD_WRITEABLE)) + return -EROFS; + if (to >= mtd->size) + len = 0; + else if (to + len > mtd->size) + len = mtd->size - to; + return part->master->write (part->master, to + part->offset, + len, retlen, buf); +} + +#if 0 +static int part_panic_write (struct mtd_info *mtd, loff_t to, size_t len, + size_t *retlen, const u_char *buf) +{ + struct mtd_part *part = PART(mtd); + if (!(mtd->flags & MTD_WRITEABLE)) + return -EROFS; + if (to >= mtd->size) + len = 0; + else if (to + len > mtd->size) + len = mtd->size - to; + return part->master->panic_write (part->master, to + part->offset, + len, retlen, buf); +} + +static int part_write_oob(struct mtd_info *mtd, loff_t to, + struct mtd_oob_ops *ops) +{ + struct mtd_part *part = PART(mtd); + + if (!(mtd->flags & MTD_WRITEABLE)) + return -EROFS; + + if (to >= mtd->size) + return -EINVAL; + if (ops->datbuf && to + ops->len > mtd->size) + return -EINVAL; + return part->master->write_oob(part->master, to + part->offset, ops); +} + +static int part_write_user_prot_reg (struct mtd_info *mtd, loff_t from, size_t len, + size_t *retlen, u_char *buf) +{ + struct mtd_part *part = PART(mtd); + return part->master->write_user_prot_reg (part->master, from, + len, retlen, buf); +} + +static int part_lock_user_prot_reg (struct mtd_info *mtd, loff_t from, size_t len) +{ + struct mtd_part *part = PART(mtd); + return part->master->lock_user_prot_reg (part->master, from, len); +} + +static int part_writev (struct mtd_info *mtd, const struct kvec *vecs, + unsigned long count, loff_t to, size_t *retlen) +{ + struct mtd_part *part = PART(mtd); + if (!(mtd->flags & MTD_WRITEABLE)) + return -EROFS; + return part->master->writev (part->master, vecs, count, + to + part->offset, retlen); +} +#endif + +static int part_erase (struct mtd_info *mtd, struct erase_info *instr) +{ + struct mtd_part *part = PART(mtd); + int ret; + if (!(mtd->flags & MTD_WRITEABLE)) + return -EROFS; + if (instr->addr >= mtd->size) + return -EINVAL; + instr->addr += part->offset; + ret = part->master->erase(part->master, instr); + if (ret) { + if (instr->fail_addr != 0xffffffff) + instr->fail_addr -= part->offset; + instr->addr -= part->offset; + } + return ret; +} + +void mtd_erase_callback(struct erase_info *instr) +{ + if (instr->mtd->erase == part_erase) { + struct mtd_part *part = PART(instr->mtd); + + if (instr->fail_addr != 0xffffffff) + instr->fail_addr -= part->offset; + instr->addr -= part->offset; + } + if (instr->callback) + instr->callback(instr); +} +#if 0 +EXPORT_SYMBOL_GPL(mtd_erase_callback); +#endif + +#if 0 +static int part_lock (struct mtd_info *mtd, loff_t ofs, size_t len) +{ + struct mtd_part *part = PART(mtd); + if ((len + ofs) > mtd->size) + return -EINVAL; + return part->master->lock(part->master, ofs + part->offset, len); +} + +static int part_unlock (struct mtd_info *mtd, loff_t ofs, size_t len) +{ + struct mtd_part *part = PART(mtd); + if ((len + ofs) > mtd->size) + return -EINVAL; + return part->master->unlock(part->master, ofs + part->offset, len); +} +#endif + +static void part_sync(struct mtd_info *mtd) +{ + struct mtd_part *part = PART(mtd); + part->master->sync(part->master); +} + +#if 0 +static int part_suspend(struct mtd_info *mtd) +{ + struct mtd_part *part = PART(mtd); + return part->master->suspend(part->master); +} + +static void part_resume(struct mtd_info *mtd) +{ + struct mtd_part *part = PART(mtd); + part->master->resume(part->master); +} +#endif + +static int part_block_isbad (struct mtd_info *mtd, loff_t ofs) +{ + struct mtd_part *part = PART(mtd); + if (ofs >= mtd->size) + return -EINVAL; + ofs += part->offset; + return part->master->block_isbad(part->master, ofs); +} + +static int part_block_markbad (struct mtd_info *mtd, loff_t ofs) +{ + struct mtd_part *part = PART(mtd); + int res; + + if (!(mtd->flags & MTD_WRITEABLE)) + return -EROFS; + if (ofs >= mtd->size) + return -EINVAL; + ofs += part->offset; + res = part->master->block_markbad(part->master, ofs); +#if 0 + if (!res) + mtd->ecc_stats.badblocks++; +#endif + return res; +} + +/* + * This function unregisters and destroy all slave MTD objects which are + * attached to the given master MTD object. + */ + +int del_mtd_partitions(struct mtd_info *master) +{ + struct list_head *node; + struct mtd_part *slave; + + for (node = mtd_partitions.next; + node != &mtd_partitions; + node = node->next) { + slave = list_entry(node, struct mtd_part, list); + if (slave->master == master) { + struct list_head *prev = node->prev; + __list_del(prev, node->next); + if(slave->registered) + del_mtd_device(&slave->mtd); + kfree(slave); + node = prev; + } + } + + return 0; +} + +/* + * This function, given a master MTD object and a partition table, creates + * and registers slave MTD objects which are bound to the master according to + * the partition definitions. + * (Q: should we register the master MTD object as well?) + */ + +int add_mtd_partitions(struct mtd_info *master, + const struct mtd_partition *parts, + int nbparts) +{ + struct mtd_part *slave; + u_int32_t cur_offset = 0; + int i; + + printk (KERN_NOTICE "Creating %d MTD partitions on "%s":\n", nbparts, master->name); + + for (i = 0; i < nbparts; i++) { + + /* allocate the partition structure */ + slave = kzalloc (sizeof(*slave), GFP_KERNEL); + if (!slave) { + printk ("memory allocation error while creating partitions for "%s"\n", + master->name); + del_mtd_partitions(master); + return -ENOMEM; + } + list_add(&slave->list, &mtd_partitions); + + /* set up the MTD object for this partition */ + slave->mtd.type = master->type; + slave->mtd.flags = master->flags & ~parts[i].mask_flags; + slave->mtd.size = parts[i].size; + slave->mtd.writesize = master->writesize; + slave->mtd.oobsize = master->oobsize; + slave->mtd.oobavail = master->oobavail; + slave->mtd.subpage_sft = master->subpage_sft; + + slave->mtd.name = parts[i].name; + slave->mtd.owner = master->owner; + + slave->mtd.read = part_read; + slave->mtd.write = part_write; + +#if 0 + if (master->panic_write) + slave->mtd.panic_write = part_panic_write; + + if(master->point && master->unpoint){ + slave->mtd.point = part_point; + slave->mtd.unpoint = part_unpoint; + } + + if (master->read_oob) + slave->mtd.read_oob = part_read_oob; + if (master->write_oob) + slave->mtd.write_oob = part_write_oob; + if(master->read_user_prot_reg) + slave->mtd.read_user_prot_reg = part_read_user_prot_reg; + if(master->read_fact_prot_reg) + slave->mtd.read_fact_prot_reg = part_read_fact_prot_reg; + if(master->write_user_prot_reg) + slave->mtd.write_user_prot_reg = part_write_user_prot_reg; + if(master->lock_user_prot_reg) + slave->mtd.lock_user_prot_reg = part_lock_user_prot_reg; + if(master->get_user_prot_info) + slave->mtd.get_user_prot_info = part_get_user_prot_info; + if(master->get_fact_prot_info) + slave->mtd.get_fact_prot_info = part_get_fact_prot_info; +#endif + if (master->sync) + slave->mtd.sync = part_sync; +#if 0 + if (!i && master->suspend && master->resume) { + slave->mtd.suspend = part_suspend; + slave->mtd.resume = part_resume; + } + if (master->writev) + slave->mtd.writev = part_writev; + if (master->lock) + slave->mtd.lock = part_lock; + if (master->unlock) + slave->mtd.unlock = part_unlock; +#endif + if (master->block_isbad) + slave->mtd.block_isbad = part_block_isbad; + if (master->block_markbad) + slave->mtd.block_markbad = part_block_markbad; + slave->mtd.erase = part_erase; + slave->master = master; + slave->offset = parts[i].offset; + slave->index = i; + + if (slave->offset == MTDPART_OFS_APPEND) + slave->offset = cur_offset; + if (slave->offset == MTDPART_OFS_NXTBLK) { + slave->offset = cur_offset; + if ((cur_offset % master->erasesize) != 0) { + /* Round up to next erasesize */ + slave->offset = ((cur_offset / master->erasesize) + 1) * master->erasesize; + printk(KERN_NOTICE "Moving partition %d: " + "0x%08x -> 0x%08x\n", i, + cur_offset, slave->offset); + } + } + if (slave->mtd.size == MTDPART_SIZ_FULL) + slave->mtd.size = master->size - slave->offset; + cur_offset = slave->offset + slave->mtd.size; + + printk (KERN_NOTICE "0x%08x-0x%08x : "%s"\n", slave->offset, + slave->offset + slave->mtd.size, slave->mtd.name); + + /* let's do some sanity checks */ + if (slave->offset >= master->size) { + /* let's register it anyway to preserve ordering */ + slave->offset = 0; + slave->mtd.size = 0; + printk ("mtd: partition "%s" is out of reach -- disabled\n", + parts[i].name); + } + if (slave->offset + slave->mtd.size > master->size) { + slave->mtd.size = master->size - slave->offset; + printk ("mtd: partition "%s" extends beyond the end of device "%s" -- size truncated to %#x\n", + parts[i].name, master->name, slave->mtd.size); + } + if (master->numeraseregions>1) { + /* Deal with variable erase size stuff */ + int i; + struct mtd_erase_region_info *regions = master->eraseregions; + + /* Find the first erase regions which is part of this partition. */ + for (i=0; i < master->numeraseregions && slave->offset >= regions[i].offset; i++) + ; + + for (i--; i < master->numeraseregions && slave->offset + slave->mtd.size > regions[i].offset; i++) { + if (slave->mtd.erasesize < regions[i].erasesize) { + slave->mtd.erasesize = regions[i].erasesize; + } + } + } else { + /* Single erase size */ + slave->mtd.erasesize = master->erasesize; + } + + if ((slave->mtd.flags & MTD_WRITEABLE) && + (slave->offset % slave->mtd.erasesize)) { + /* Doesn't start on a boundary of major erase size */ + /* FIXME: Let it be writable if it is on a boundary of _minor_ erase size though */ + slave->mtd.flags &= ~MTD_WRITEABLE; + printk ("mtd: partition "%s" doesn't start on an erase block boundary -- force read-only\n", + parts[i].name); + } + if ((slave->mtd.flags & MTD_WRITEABLE) && + (slave->mtd.size % slave->mtd.erasesize)) { + slave->mtd.flags &= ~MTD_WRITEABLE; + printk ("mtd: partition "%s" doesn't end on an erase block -- force read-only\n", + parts[i].name); + } + +#if 0 + slave->mtd.ecclayout = master->ecclayout; + if (master->block_isbad) { + uint32_t offs = 0; + + while(offs < slave->mtd.size) { + if (master->block_isbad(master, + offs + slave->offset)) + slave->mtd.ecc_stats.badblocks++; + offs += slave->mtd.erasesize; + } + } + + if(parts[i].mtdp) + { /* store the object pointer (caller may or may not register it */ + *parts[i].mtdp = &slave->mtd; + slave->registered = 0; + } + else +#endif + { + /* register our partition */ + add_mtd_device(&slave->mtd); + slave->registered = 1; + } + } + + return 0; +} + +#if 0 +EXPORT_SYMBOL(add_mtd_partitions); +EXPORT_SYMBOL(del_mtd_partitions); +#endif diff --git a/drivers/mtd/ubi/Makefile b/drivers/mtd/ubi/Makefile new file mode 100644 index 0000000..30eed96 --- /dev/null +++ b/drivers/mtd/ubi/Makefile @@ -0,0 +1,48 @@ +# +# (C) Copyright 2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB := $(obj)libubi.a +COBJS-y += build.o vtbl.o vmt.o upd.o kapi.o eba.o io.o wl.o scan.o crc32.o + +COBJS-y += misc.o +COBJS-y += debug.o + +COBJS := $(COBJS-y) +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +all: $(LIB) + +$(LIB): $(obj).depend $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/drivers/mtd/ubi/build.c b/drivers/mtd/ubi/build.c new file mode 100644 index 0000000..bf8a19f --- /dev/null +++ b/drivers/mtd/ubi/build.c @@ -0,0 +1,1182 @@ +/* + * Copyright (c) International Business Machines Corp., 2006 + * Copyright (c) Nokia Corporation, 2007 + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See + * the GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + * Author: Artem Bityutskiy (Битюцкий Артём), + * Frank Haverkamp + */ + +/* + * This file includes UBI initialization and building of UBI devices. + * + * When UBI is initialized, it attaches all the MTD devices specified as the + * module load parameters or the kernel boot parameters. If MTD devices were + * specified, UBI does not attach any MTD device, but it is possible to do + * later using the "UBI control device". + * + * At the moment we only attach UBI devices by scanning, which will become a + * bottleneck when flashes reach certain large size. Then one may improve UBI + * and add other methods, although it does not seem to be easy to do. + */ + +#if 0 +#include <linux/err.h> +#include <linux/module.h> +#include <linux/moduleparam.h> +#include <linux/stringify.h> +#include <linux/stat.h> +#include <linux/miscdevice.h> +#include <linux/log2.h> +#include <linux/kthread.h> +#endif +#include <ubi_uboot.h> +#include "ubi.h" + +/* Maximum length of the 'mtd=' parameter */ +#define MTD_PARAM_LEN_MAX 64 + +/** + * struct mtd_dev_param - MTD device parameter description data structure. + * @name: MTD device name or number string + * @vid_hdr_offs: VID header offset + */ +struct mtd_dev_param +{ + char name[MTD_PARAM_LEN_MAX]; + int vid_hdr_offs; +}; + +/* Numbers of elements set in the @mtd_dev_param array */ +static int mtd_devs = 0; + +/* MTD devices specification parameters */ +static struct mtd_dev_param mtd_dev_param[UBI_MAX_DEVICES]; + +/* Root UBI "class" object (corresponds to '/<sysfs>/class/ubi/') */ +struct class *ubi_class; + +#if 0 +/* Slab cache for wear-leveling entries */ +struct kmem_cache *ubi_wl_entry_slab; + +/* UBI control character device */ +static struct miscdevice ubi_ctrl_cdev = { + .minor = MISC_DYNAMIC_MINOR, + .name = "ubi_ctrl", + .fops = &ubi_ctrl_cdev_operations, +}; +#endif + +/* All UBI devices in system */ +struct ubi_device *ubi_devices[UBI_MAX_DEVICES]; + +#if 0 +/* Serializes UBI devices creations and removals */ +DEFINE_MUTEX(ubi_devices_mutex); + +/* Protects @ubi_devices and @ubi->ref_count */ +static DEFINE_SPINLOCK(ubi_devices_lock); + +/* "Show" method for files in '/<sysfs>/class/ubi/' */ +static ssize_t ubi_version_show(struct class *class, char *buf) +{ + return sprintf(buf, "%d\n", UBI_VERSION); +} + +/* UBI version attribute ('/<sysfs>/class/ubi/version') */ +static struct class_attribute ubi_version = + __ATTR(version, S_IRUGO, ubi_version_show, NULL); + +static ssize_t dev_attribute_show(struct device *dev, + struct device_attribute *attr, char *buf); + +/* UBI device attributes (correspond to files in '/<sysfs>/class/ubi/ubiX') */ +static struct device_attribute dev_eraseblock_size = + __ATTR(eraseblock_size, S_IRUGO, dev_attribute_show, NULL); +static struct device_attribute dev_avail_eraseblocks = + __ATTR(avail_eraseblocks, S_IRUGO, dev_attribute_show, NULL); +static struct device_attribute dev_total_eraseblocks = + __ATTR(total_eraseblocks, S_IRUGO, dev_attribute_show, NULL); +static struct device_attribute dev_volumes_count = + __ATTR(volumes_count, S_IRUGO, dev_attribute_show, NULL); +static struct device_attribute dev_max_ec = + __ATTR(max_ec, S_IRUGO, dev_attribute_show, NULL); +static struct device_attribute dev_reserved_for_bad = + __ATTR(reserved_for_bad, S_IRUGO, dev_attribute_show, NULL); +static struct device_attribute dev_bad_peb_count = + __ATTR(bad_peb_count, S_IRUGO, dev_attribute_show, NULL); +static struct device_attribute dev_max_vol_count = + __ATTR(max_vol_count, S_IRUGO, dev_attribute_show, NULL); +static struct device_attribute dev_min_io_size = + __ATTR(min_io_size, S_IRUGO, dev_attribute_show, NULL); +static struct device_attribute dev_bgt_enabled = + __ATTR(bgt_enabled, S_IRUGO, dev_attribute_show, NULL); +static struct device_attribute dev_mtd_num = + __ATTR(mtd_num, S_IRUGO, dev_attribute_show, NULL); +#endif + +/** + * ubi_get_device - get UBI device. + * @ubi_num: UBI device number + * + * This function returns UBI device description object for UBI device number + * @ubi_num, or %NULL if the device does not exist. This function increases the + * device reference count to prevent removal of the device. In other words, the + * device cannot be removed if its reference count is not zero. + */ +struct ubi_device *ubi_get_device(int ubi_num) +{ + struct ubi_device *ubi; + + spin_lock(&ubi_devices_lock); + ubi = ubi_devices[ubi_num]; + if (ubi) { + ubi_assert(ubi->ref_count >= 0); + ubi->ref_count += 1; + get_device(&ubi->dev); + } + spin_unlock(&ubi_devices_lock); + + return ubi; +} + +/** + * ubi_put_device - drop an UBI device reference. + * @ubi: UBI device description object + */ +void ubi_put_device(struct ubi_device *ubi) +{ + spin_lock(&ubi_devices_lock); + ubi->ref_count -= 1; + put_device(&ubi->dev); + spin_unlock(&ubi_devices_lock); +} + +/** + * ubi_get_by_major - get UBI device description object by character device + * major number. + * @major: major number + * + * This function is similar to 'ubi_get_device()', but it searches the device + * by its major number. + */ +struct ubi_device *ubi_get_by_major(int major) +{ + int i; + struct ubi_device *ubi; + + spin_lock(&ubi_devices_lock); + for (i = 0; i < UBI_MAX_DEVICES; i++) { + ubi = ubi_devices[i]; + if (ubi && MAJOR(ubi->cdev.dev) == major) { + ubi_assert(ubi->ref_count >= 0); + ubi->ref_count += 1; + get_device(&ubi->dev); + spin_unlock(&ubi_devices_lock); + return ubi; + } + } + spin_unlock(&ubi_devices_lock); + + return NULL; +} + +/** + * ubi_major2num - get UBI device number by character device major number. + * @major: major number + * + * This function searches UBI device number object by its major number. If UBI + * device was not found, this function returns -ENODEV, otherwise the UBI device + * number is returned. + */ +int ubi_major2num(int major) +{ + int i, ubi_num = -ENODEV; + + spin_lock(&ubi_devices_lock); + for (i = 0; i < UBI_MAX_DEVICES; i++) { + struct ubi_device *ubi = ubi_devices[i]; + + if (ubi && MAJOR(ubi->cdev.dev) == major) { + ubi_num = ubi->ubi_num; + break; + } + } + spin_unlock(&ubi_devices_lock); + + return ubi_num; +} + +#if 0 +/* "Show" method for files in '/<sysfs>/class/ubi/ubiX/' */ +static ssize_t dev_attribute_show(struct device *dev, + struct device_attribute *attr, char *buf) +{ + ssize_t ret; + struct ubi_device *ubi; + + /* + * The below code looks weird, but it actually makes sense. We get the + * UBI device reference from the contained 'struct ubi_device'. But it + * is unclear if the device was removed or not yet. Indeed, if the + * device was removed before we increased its reference count, + * 'ubi_get_device()' will return -ENODEV and we fail. + * + * Remember, 'struct ubi_device' is freed in the release function, so + * we still can use 'ubi->ubi_num'. + */ + ubi = container_of(dev, struct ubi_device, dev); + ubi = ubi_get_device(ubi->ubi_num); + if (!ubi) + return -ENODEV; + + if (attr == &dev_eraseblock_size) + ret = sprintf(buf, "%d\n", ubi->leb_size); + else if (attr == &dev_avail_eraseblocks) + ret = sprintf(buf, "%d\n", ubi->avail_pebs); + else if (attr == &dev_total_eraseblocks) + ret = sprintf(buf, "%d\n", ubi->good_peb_count); + else if (attr == &dev_volumes_count) + ret = sprintf(buf, "%d\n", ubi->vol_count - UBI_INT_VOL_COUNT); + else if (attr == &dev_max_ec) + ret = sprintf(buf, "%d\n", ubi->max_ec); + else if (attr == &dev_reserved_for_bad) + ret = sprintf(buf, "%d\n", ubi->beb_rsvd_pebs); + else if (attr == &dev_bad_peb_count) + ret = sprintf(buf, "%d\n", ubi->bad_peb_count); + else if (attr == &dev_max_vol_count) + ret = sprintf(buf, "%d\n", ubi->vtbl_slots); + else if (attr == &dev_min_io_size) + ret = sprintf(buf, "%d\n", ubi->min_io_size); + else if (attr == &dev_bgt_enabled) + ret = sprintf(buf, "%d\n", ubi->thread_enabled); + else if (attr == &dev_mtd_num) + ret = sprintf(buf, "%d\n", ubi->mtd->index); + else + ret = -EINVAL; + + ubi_put_device(ubi); + return ret; +} + +/* Fake "release" method for UBI devices */ +static void dev_release(struct device *dev) { } + +/** + * ubi_sysfs_init - initialize sysfs for an UBI device. + * @ubi: UBI device description object + * + * This function returns zero in case of success and a negative error code in + * case of failure. + */ +static int ubi_sysfs_init(struct ubi_device *ubi) +{ + int err; + + ubi->dev.release = dev_release; + ubi->dev.devt = ubi->cdev.dev; + ubi->dev.class = ubi_class; + sprintf(&ubi->dev.bus_id[0], UBI_NAME_STR"%d", ubi->ubi_num); + err = device_register(&ubi->dev); + if (err) + return err; + + err = device_create_file(&ubi->dev, &dev_eraseblock_size); + if (err) + return err; + err = device_create_file(&ubi->dev, &dev_avail_eraseblocks); + if (err) + return err; + err = device_create_file(&ubi->dev, &dev_total_eraseblocks); + if (err) + return err; + err = device_create_file(&ubi->dev, &dev_volumes_count); + if (err) + return err; + err = device_create_file(&ubi->dev, &dev_max_ec); + if (err) + return err; + err = device_create_file(&ubi->dev, &dev_reserved_for_bad); + if (err) + return err; + err = device_create_file(&ubi->dev, &dev_bad_peb_count); + if (err) + return err; + err = device_create_file(&ubi->dev, &dev_max_vol_count); + if (err) + return err; + err = device_create_file(&ubi->dev, &dev_min_io_size); + if (err) + return err; + err = device_create_file(&ubi->dev, &dev_bgt_enabled); + if (err) + return err; + err = device_create_file(&ubi->dev, &dev_mtd_num); + return err; +} + +/** + * ubi_sysfs_close - close sysfs for an UBI device. + * @ubi: UBI device description object + */ +static void ubi_sysfs_close(struct ubi_device *ubi) +{ + device_remove_file(&ubi->dev, &dev_mtd_num); + device_remove_file(&ubi->dev, &dev_bgt_enabled); + device_remove_file(&ubi->dev, &dev_min_io_size); + device_remove_file(&ubi->dev, &dev_max_vol_count); + device_remove_file(&ubi->dev, &dev_bad_peb_count); + device_remove_file(&ubi->dev, &dev_reserved_for_bad); + device_remove_file(&ubi->dev, &dev_max_ec); + device_remove_file(&ubi->dev, &dev_volumes_count); + device_remove_file(&ubi->dev, &dev_total_eraseblocks); + device_remove_file(&ubi->dev, &dev_avail_eraseblocks); + device_remove_file(&ubi->dev, &dev_eraseblock_size); + device_unregister(&ubi->dev); +} +#endif + +/** + * kill_volumes - destroy all volumes. + * @ubi: UBI device description object + */ +static void kill_volumes(struct ubi_device *ubi) +{ + int i; + + for (i = 0; i < ubi->vtbl_slots; i++) + if (ubi->volumes[i]) + ubi_free_volume(ubi, ubi->volumes[i]); +} + +/** + * uif_init - initialize user interfaces for an UBI device. + * @ubi: UBI device description object + * + * This function returns zero in case of success and a negative error code in + * case of failure. + */ +static int uif_init(struct ubi_device *ubi) +{ + int i, err; + dev_t dev; + + sprintf(ubi->ubi_name, UBI_NAME_STR "%d", ubi->ubi_num); + + /* + * Major numbers for the UBI character devices are allocated + * dynamically. Major numbers of volume character devices are + * equivalent to ones of the corresponding UBI character device. Minor + * numbers of UBI character devices are 0, while minor numbers of + * volume character devices start from 1. Thus, we allocate one major + * number and ubi->vtbl_slots + 1 minor numbers. + */ + err = alloc_chrdev_region(&dev, 0, ubi->vtbl_slots + 1, ubi->ubi_name); + if (err) { + ubi_err("cannot register UBI character devices"); + return err; + } + + ubi_assert(MINOR(dev) == 0); + cdev_init(&ubi->cdev, &ubi_cdev_operations); + dbg_msg("%s major is %u", ubi->ubi_name, MAJOR(dev)); + ubi->cdev.owner = THIS_MODULE; + + err = cdev_add(&ubi->cdev, dev, 1); + if (err) { + ubi_err("cannot add character device"); + goto out_unreg; + } + + err = ubi_sysfs_init(ubi); + if (err) + goto out_sysfs; + + for (i = 0; i < ubi->vtbl_slots; i++) + if (ubi->volumes[i]) { + err = ubi_add_volume(ubi, ubi->volumes[i]); + if (err) { + ubi_err("cannot add volume %d", i); + goto out_volumes; + } + } + + return 0; + +out_volumes: + kill_volumes(ubi); +out_sysfs: + ubi_sysfs_close(ubi); + cdev_del(&ubi->cdev); +out_unreg: + unregister_chrdev_region(ubi->cdev.dev, ubi->vtbl_slots + 1); + ubi_err("cannot initialize UBI %s, error %d", ubi->ubi_name, err); + return err; +} + +/** + * uif_close - close user interfaces for an UBI device. + * @ubi: UBI device description object + */ +static void uif_close(struct ubi_device *ubi) +{ + kill_volumes(ubi); + ubi_sysfs_close(ubi); + cdev_del(&ubi->cdev); + unregister_chrdev_region(ubi->cdev.dev, ubi->vtbl_slots + 1); +} + +/** + * attach_by_scanning - attach an MTD device using scanning method. + * @ubi: UBI device descriptor + * + * This function returns zero in case of success and a negative error code in + * case of failure. + * + * Note, currently this is the only method to attach UBI devices. Hopefully in + * the future we'll have more scalable attaching methods and avoid full media + * scanning. But even in this case scanning will be needed as a fall-back + * attaching method if there are some on-flash table corruptions. + */ +static int attach_by_scanning(struct ubi_device *ubi) +{ + int err; + struct ubi_scan_info *si; + + si = ubi_scan(ubi); + if (IS_ERR(si)) + return PTR_ERR(si); + + ubi->bad_peb_count = si->bad_peb_count; + ubi->good_peb_count = ubi->peb_count - ubi->bad_peb_count; + ubi->max_ec = si->max_ec; + ubi->mean_ec = si->mean_ec; + + err = ubi_read_volume_table(ubi, si); + if (err) + goto out_si; + + err = ubi_wl_init_scan(ubi, si); + if (err) + goto out_vtbl; + + err = ubi_eba_init_scan(ubi, si); + if (err) + goto out_wl; + + ubi_scan_destroy_si(si); + return 0; + +out_wl: + ubi_wl_close(ubi); +out_vtbl: + vfree(ubi->vtbl); +out_si: + ubi_scan_destroy_si(si); + return err; +} + +/** + * io_init - initialize I/O unit for a given UBI device. + * @ubi: UBI device description object + * + * If @ubi->vid_hdr_offset or @ubi->leb_start is zero, default offsets are + * assumed: + * o EC header is always at offset zero - this cannot be changed; + * o VID header starts just after the EC header at the closest address + * aligned to @io->hdrs_min_io_size; + * o data starts just after the VID header at the closest address aligned to + * @io->min_io_size + * + * This function returns zero in case of success and a negative error code in + * case of failure. + */ +static int io_init(struct ubi_device *ubi) +{ + if (ubi->mtd->numeraseregions != 0) { + /* + * Some flashes have several erase regions. Different regions + * may have different eraseblock size and other + * characteristics. It looks like mostly multi-region flashes + * have one "main" region and one or more small regions to + * store boot loader code or boot parameters or whatever. I + * guess we should just pick the largest region. But this is + * not implemented. + */ + ubi_err("multiple regions, not implemented"); + return -EINVAL; + } + + if (ubi->vid_hdr_offset < 0) + return -EINVAL; + + /* + * Note, in this implementation we support MTD devices with 0x7FFFFFFF + * physical eraseblocks maximum. + */ + + ubi->peb_size = ubi->mtd->erasesize; + ubi->peb_count = ubi->mtd->size / ubi->mtd->erasesize; + ubi->flash_size = ubi->mtd->size; + + if (ubi->mtd->block_isbad && ubi->mtd->block_markbad) + ubi->bad_allowed = 1; + + ubi->min_io_size = ubi->mtd->writesize; + ubi->hdrs_min_io_size = ubi->mtd->writesize >> ubi->mtd->subpage_sft; + + /* + * Make sure minimal I/O unit is power of 2. Note, there is no + * fundamental reason for this assumption. It is just an optimization + * which allows us to avoid costly division operations. + */ + if (!is_power_of_2(ubi->min_io_size)) { + ubi_err("min. I/O unit (%d) is not power of 2", + ubi->min_io_size); + return -EINVAL; + } + + ubi_assert(ubi->hdrs_min_io_size > 0); + ubi_assert(ubi->hdrs_min_io_size <= ubi->min_io_size); + ubi_assert(ubi->min_io_size % ubi->hdrs_min_io_size == 0); + + /* Calculate default aligned sizes of EC and VID headers */ + ubi->ec_hdr_alsize = ALIGN(UBI_EC_HDR_SIZE, ubi->hdrs_min_io_size); + ubi->vid_hdr_alsize = ALIGN(UBI_VID_HDR_SIZE, ubi->hdrs_min_io_size); + + dbg_msg("min_io_size %d", ubi->min_io_size); + dbg_msg("hdrs_min_io_size %d", ubi->hdrs_min_io_size); + dbg_msg("ec_hdr_alsize %d", ubi->ec_hdr_alsize); + dbg_msg("vid_hdr_alsize %d", ubi->vid_hdr_alsize); + + if (ubi->vid_hdr_offset == 0) + /* Default offset */ + ubi->vid_hdr_offset = ubi->vid_hdr_aloffset = + ubi->ec_hdr_alsize; + else { + ubi->vid_hdr_aloffset = ubi->vid_hdr_offset & + ~(ubi->hdrs_min_io_size - 1); + ubi->vid_hdr_shift = ubi->vid_hdr_offset - + ubi->vid_hdr_aloffset; + } + + /* Similar for the data offset */ + ubi->leb_start = ubi->vid_hdr_offset + UBI_EC_HDR_SIZE; + ubi->leb_start = ALIGN(ubi->leb_start, ubi->min_io_size); + + dbg_msg("vid_hdr_offset %d", ubi->vid_hdr_offset); + dbg_msg("vid_hdr_aloffset %d", ubi->vid_hdr_aloffset); + dbg_msg("vid_hdr_shift %d", ubi->vid_hdr_shift); + dbg_msg("leb_start %d", ubi->leb_start); + + /* The shift must be aligned to 32-bit boundary */ + if (ubi->vid_hdr_shift % 4) { + ubi_err("unaligned VID header shift %d", + ubi->vid_hdr_shift); + return -EINVAL; + } + + /* Check sanity */ + if (ubi->vid_hdr_offset < UBI_EC_HDR_SIZE || + ubi->leb_start < ubi->vid_hdr_offset + UBI_VID_HDR_SIZE || + ubi->leb_start > ubi->peb_size - UBI_VID_HDR_SIZE || + ubi->leb_start & (ubi->min_io_size - 1)) { + ubi_err("bad VID header (%d) or data offsets (%d)", + ubi->vid_hdr_offset, ubi->leb_start); + return -EINVAL; + } + + /* + * It may happen that EC and VID headers are situated in one minimal + * I/O unit. In this case we can only accept this UBI image in + * read-only mode. + */ + if (ubi->vid_hdr_offset + UBI_VID_HDR_SIZE <= ubi->hdrs_min_io_size) { + ubi_warn("EC and VID headers are in the same minimal I/O unit, " + "switch to read-only mode"); + ubi->ro_mode = 1; + } + + ubi->leb_size = ubi->peb_size - ubi->leb_start; + + if (!(ubi->mtd->flags & MTD_WRITEABLE)) { + ubi_msg("MTD device %d is write-protected, attach in " + "read-only mode", ubi->mtd->index); + ubi->ro_mode = 1; + } + + ubi_msg("physical eraseblock size: %d bytes (%d KiB)", + ubi->peb_size, ubi->peb_size >> 10); + ubi_msg("logical eraseblock size: %d bytes", ubi->leb_size); + ubi_msg("smallest flash I/O unit: %d", ubi->min_io_size); + if (ubi->hdrs_min_io_size != ubi->min_io_size) + ubi_msg("sub-page size: %d", + ubi->hdrs_min_io_size); + ubi_msg("VID header offset: %d (aligned %d)", + ubi->vid_hdr_offset, ubi->vid_hdr_aloffset); + ubi_msg("data offset: %d", ubi->leb_start); + + /* + * Note, ideally, we have to initialize ubi->bad_peb_count here. But + * unfortunately, MTD does not provide this information. We should loop + * over all physical eraseblocks and invoke mtd->block_is_bad() for + * each physical eraseblock. So, we skip ubi->bad_peb_count + * uninitialized and initialize it after scanning. + */ + + return 0; +} + +/** + * autoresize - re-size the volume which has the "auto-resize" flag set. + * @ubi: UBI device description object + * @vol_id: ID of the volume to re-size + * + * This function re-sizes the volume marked by the @UBI_VTBL_AUTORESIZE_FLG in + * the volume table to the largest possible size. See comments in ubi-header.h + * for more description of the flag. Returns zero in case of success and a + * negative error code in case of failure. + */ +static int autoresize(struct ubi_device *ubi, int vol_id) +{ + struct ubi_volume_desc desc; + struct ubi_volume *vol = ubi->volumes[vol_id]; + int err, old_reserved_pebs = vol->reserved_pebs; + + /* + * Clear the auto-resize flag in the volume in-memory copy of the + * volume table, and 'ubi_resize_volume()' will propogate this change + * to the flash. + */ + ubi->vtbl[vol_id].flags &= ~UBI_VTBL_AUTORESIZE_FLG; + + if (ubi->avail_pebs == 0) { + struct ubi_vtbl_record vtbl_rec; + + /* + * No avalilable PEBs to re-size the volume, clear the flag on + * flash and exit. + */ + memcpy(&vtbl_rec, &ubi->vtbl[vol_id], + sizeof(struct ubi_vtbl_record)); + err = ubi_change_vtbl_record(ubi, vol_id, &vtbl_rec); + if (err) + ubi_err("cannot clean auto-resize flag for volume %d", + vol_id); + } else { + desc.vol = vol; + err = ubi_resize_volume(&desc, + old_reserved_pebs + ubi->avail_pebs); + if (err) + ubi_err("cannot auto-resize volume %d", vol_id); + } + + if (err) + return err; + + ubi_msg("volume %d ("%s") re-sized from %d to %d LEBs", vol_id, + vol->name, old_reserved_pebs, vol->reserved_pebs); + return 0; +} + +/** + * ubi_attach_mtd_dev - attach an MTD device. + * @mtd_dev: MTD device description object + * @ubi_num: number to assign to the new UBI device + * @vid_hdr_offset: VID header offset + * + * This function attaches MTD device @mtd_dev to UBI and assign @ubi_num number + * to the newly created UBI device, unless @ubi_num is %UBI_DEV_NUM_AUTO, in + * which case this function finds a vacant device nubert and assings it + * automatically. Returns the new UBI device number in case of success and a + * negative error code in case of failure. + * + * Note, the invocations of this function has to be serialized by the + * @ubi_devices_mutex. + */ +int ubi_attach_mtd_dev(struct mtd_info *mtd, int ubi_num, int vid_hdr_offset) +{ + struct ubi_device *ubi; + int i, err; + + /* + * Check if we already have the same MTD device attached. + * + * Note, this function assumes that UBI devices creations and deletions + * are serialized, so it does not take the &ubi_devices_lock. + */ + for (i = 0; i < UBI_MAX_DEVICES; i++) { + ubi = ubi_devices[i]; + if (ubi && mtd->index == ubi->mtd->index) { + dbg_err("mtd%d is already attached to ubi%d", + mtd->index, i); + return -EEXIST; + } + } + + /* + * Make sure this MTD device is not emulated on top of an UBI volume + * already. Well, generally this recursion works fine, but there are + * different problems like the UBI module takes a reference to itself + * by attaching (and thus, opening) the emulated MTD device. This + * results in inability to unload the module. And in general it makes + * no sense to attach emulated MTD devices, so we prohibit this. + */ + if (mtd->type == MTD_UBIVOLUME) { + ubi_err("refuse attaching mtd%d - it is already emulated on " + "top of UBI", mtd->index); + return -EINVAL; + } + + if (ubi_num == UBI_DEV_NUM_AUTO) { + /* Search for an empty slot in the @ubi_devices array */ + for (ubi_num = 0; ubi_num < UBI_MAX_DEVICES; ubi_num++) + if (!ubi_devices[ubi_num]) + break; + if (ubi_num == UBI_MAX_DEVICES) { + dbg_err("only %d UBI devices may be created", UBI_MAX_DEVICES); + return -ENFILE; + } + } else { + if (ubi_num >= UBI_MAX_DEVICES) + return -EINVAL; + + /* Make sure ubi_num is not busy */ + if (ubi_devices[ubi_num]) { + dbg_err("ubi%d already exists", ubi_num); + return -EEXIST; + } + } + + ubi = kzalloc(sizeof(struct ubi_device), GFP_KERNEL); + if (!ubi) + return -ENOMEM; + + ubi->mtd = mtd; + ubi->ubi_num = ubi_num; + ubi->vid_hdr_offset = vid_hdr_offset; + ubi->autoresize_vol_id = -1; + + mutex_init(&ubi->buf_mutex); + mutex_init(&ubi->ckvol_mutex); + mutex_init(&ubi->volumes_mutex); + spin_lock_init(&ubi->volumes_lock); + + ubi_msg("attaching mtd%d to ubi%d", mtd->index, ubi_num); + + err = io_init(ubi); + if (err) + goto out_free; + + ubi->peb_buf1 = vmalloc(ubi->peb_size); + if (!ubi->peb_buf1) + goto out_free; + + ubi->peb_buf2 = vmalloc(ubi->peb_size); + if (!ubi->peb_buf2) + goto out_free; + +#ifdef CONFIG_MTD_UBI_DEBUG + mutex_init(&ubi->dbg_buf_mutex); + ubi->dbg_peb_buf = vmalloc(ubi->peb_size); + if (!ubi->dbg_peb_buf) + goto out_free; +#endif + + err = attach_by_scanning(ubi); + if (err) { + dbg_err("failed to attach by scanning, error %d", err); + goto out_free; + } + + if (ubi->autoresize_vol_id != -1) { + err = autoresize(ubi, ubi->autoresize_vol_id); + if (err) + goto out_detach; + } + + err = uif_init(ubi); + if (err) + goto out_detach; + + ubi->bgt_thread = kthread_create(ubi_thread, ubi, ubi->bgt_name); + if (IS_ERR(ubi->bgt_thread)) { + err = PTR_ERR(ubi->bgt_thread); + ubi_err("cannot spawn "%s", error %d", ubi->bgt_name, + err); + goto out_uif; + } + + ubi_msg("attached mtd%d to ubi%d", mtd->index, ubi_num); + ubi_msg("MTD device name: "%s"", mtd->name); + ubi_msg("MTD device size: %llu MiB", ubi->flash_size >> 20); + ubi_msg("number of good PEBs: %d", ubi->good_peb_count); + ubi_msg("number of bad PEBs: %d", ubi->bad_peb_count); + ubi_msg("max. allowed volumes: %d", ubi->vtbl_slots); + ubi_msg("wear-leveling threshold: %d", CONFIG_MTD_UBI_WL_THRESHOLD); + ubi_msg("number of internal volumes: %d", UBI_INT_VOL_COUNT); + ubi_msg("number of user volumes: %d", + ubi->vol_count - UBI_INT_VOL_COUNT); + ubi_msg("available PEBs: %d", ubi->avail_pebs); + ubi_msg("total number of reserved PEBs: %d", ubi->rsvd_pebs); + ubi_msg("number of PEBs reserved for bad PEB handling: %d", + ubi->beb_rsvd_pebs); + ubi_msg("max/mean erase counter: %d/%d", ubi->max_ec, ubi->mean_ec); + + /* Enable the background thread */ + if (!DBG_DISABLE_BGT) { + ubi->thread_enabled = 1; + wake_up_process(ubi->bgt_thread); + } + + ubi_devices[ubi_num] = ubi; + return ubi_num; + +out_uif: + uif_close(ubi); +out_detach: + ubi_eba_close(ubi); + ubi_wl_close(ubi); + vfree(ubi->vtbl); +out_free: + vfree(ubi->peb_buf1); + vfree(ubi->peb_buf2); +#ifdef CONFIG_MTD_UBI_DEBUG + vfree(ubi->dbg_peb_buf); +#endif + kfree(ubi); + return err; +} + +/** + * ubi_detach_mtd_dev - detach an MTD device. + * @ubi_num: UBI device number to detach from + * @anyway: detach MTD even if device reference count is not zero + * + * This function destroys an UBI device number @ubi_num and detaches the + * underlying MTD device. Returns zero in case of success and %-EBUSY if the + * UBI device is busy and cannot be destroyed, and %-EINVAL if it does not + * exist. + * + * Note, the invocations of this function has to be serialized by the + * @ubi_devices_mutex. + */ +int ubi_detach_mtd_dev(int ubi_num, int anyway) +{ + struct ubi_device *ubi; + + if (ubi_num < 0 || ubi_num >= UBI_MAX_DEVICES) + return -EINVAL; + + spin_lock(&ubi_devices_lock); + ubi = ubi_devices[ubi_num]; + if (!ubi) { + spin_unlock(&ubi_devices_lock); + return -EINVAL; + } + + if (ubi->ref_count) { + if (!anyway) { + spin_unlock(&ubi_devices_lock); + return -EBUSY; + } + /* This may only happen if there is a bug */ + ubi_err("%s reference count %d, destroy anyway", + ubi->ubi_name, ubi->ref_count); + } + ubi_devices[ubi_num] = NULL; + spin_unlock(&ubi_devices_lock); + + ubi_assert(ubi_num == ubi->ubi_num); + dbg_msg("detaching mtd%d from ubi%d", ubi->mtd->index, ubi_num); + + /* + * Before freeing anything, we have to stop the background thread to + * prevent it from doing anything on this device while we are freeing. + */ + if (ubi->bgt_thread) + kthread_stop(ubi->bgt_thread); + + uif_close(ubi); + ubi_eba_close(ubi); + ubi_wl_close(ubi); + vfree(ubi->vtbl); + put_mtd_device(ubi->mtd); + vfree(ubi->peb_buf1); + vfree(ubi->peb_buf2); +#ifdef CONFIG_MTD_UBI_DEBUG + vfree(ubi->dbg_peb_buf); +#endif + ubi_msg("mtd%d is detached from ubi%d", ubi->mtd->index, ubi->ubi_num); + kfree(ubi); + return 0; +} + +/** + * find_mtd_device - open an MTD device by its name or number. + * @mtd_dev: name or number of the device + * + * This function tries to open and MTD device described by @mtd_dev string, + * which is first treated as an ASCII number, and if it is not true, it is + * treated as MTD device name. Returns MTD device description object in case of + * success and a negative error code in case of failure. + */ +static struct mtd_info * __init open_mtd_device(const char *mtd_dev) +{ + struct mtd_info *mtd; + int mtd_num; + char *endp; + + mtd_num = simple_strtoul(mtd_dev, &endp, 0); + if (*endp != '\0' || mtd_dev == endp) { + /* + * This does not look like an ASCII integer, probably this is + * MTD device name. + */ + mtd = get_mtd_device_nm(mtd_dev); + } else + mtd = get_mtd_device(NULL, mtd_num); + + return mtd; +} + +int __init ubi_init(void) +{ + int err, i, k; + + /* Ensure that EC and VID headers have correct size */ + BUILD_BUG_ON(sizeof(struct ubi_ec_hdr) != 64); + BUILD_BUG_ON(sizeof(struct ubi_vid_hdr) != 64); + + if (mtd_devs > UBI_MAX_DEVICES) { + ubi_err("too many MTD devices, maximum is %d", UBI_MAX_DEVICES); + return -EINVAL; + } + + /* Create base sysfs directory and sysfs files */ + ubi_class = class_create(THIS_MODULE, UBI_NAME_STR); + if (IS_ERR(ubi_class)) { + err = PTR_ERR(ubi_class); + ubi_err("cannot create UBI class"); + goto out; + } + + err = class_create_file(ubi_class, &ubi_version); + if (err) { + ubi_err("cannot create sysfs file"); + goto out_class; + } + + err = misc_register(&ubi_ctrl_cdev); + if (err) { + ubi_err("cannot register device"); + goto out_version; + } + +#if 0 + ubi_wl_entry_slab = kmem_cache_create("ubi_wl_entry_slab", + sizeof(struct ubi_wl_entry), + 0, 0, NULL); + if (!ubi_wl_entry_slab) + goto out_dev_unreg; +#endif + + /* Attach MTD devices */ + for (i = 0; i < mtd_devs; i++) { + struct mtd_dev_param *p = &mtd_dev_param[i]; + struct mtd_info *mtd; + + cond_resched(); + + mtd = open_mtd_device(p->name); + if (IS_ERR(mtd)) { + err = PTR_ERR(mtd); + goto out_detach; + } + + mutex_lock(&ubi_devices_mutex); + err = ubi_attach_mtd_dev(mtd, UBI_DEV_NUM_AUTO, + p->vid_hdr_offs); + mutex_unlock(&ubi_devices_mutex); + if (err < 0) { + put_mtd_device(mtd); + ubi_err("cannot attach mtd%d", mtd->index); + goto out_detach; + } + } + + return 0; + +out_detach: + for (k = 0; k < i; k++) + if (ubi_devices[k]) { + mutex_lock(&ubi_devices_mutex); + ubi_detach_mtd_dev(ubi_devices[k]->ubi_num, 1); + mutex_unlock(&ubi_devices_mutex); + } + kmem_cache_destroy(ubi_wl_entry_slab); +out_dev_unreg: + misc_deregister(&ubi_ctrl_cdev); +out_version: + class_remove_file(ubi_class, &ubi_version); +out_class: + class_destroy(ubi_class); +out: + ubi_err("UBI error: cannot initialize UBI, error %d", err); + return err; +} +module_init(ubi_init); + +void __exit ubi_exit(void) +{ + int i; + + for (i = 0; i < UBI_MAX_DEVICES; i++) + if (ubi_devices[i]) { + mutex_lock(&ubi_devices_mutex); + ubi_detach_mtd_dev(ubi_devices[i]->ubi_num, 1); + mutex_unlock(&ubi_devices_mutex); + } + kmem_cache_destroy(ubi_wl_entry_slab); + misc_deregister(&ubi_ctrl_cdev); + class_remove_file(ubi_class, &ubi_version); + class_destroy(ubi_class); +} +module_exit(ubi_exit); + +/** + * bytes_str_to_int - convert a string representing number of bytes to an + * integer. + * @str: the string to convert + * + * This function returns positive resulting integer in case of success and a + * negative error code in case of failure. + */ +static int __init bytes_str_to_int(const char *str) +{ + char *endp; + unsigned long result; + + result = simple_strtoul(str, &endp, 0); + if (str == endp || result < 0) { + printk(KERN_ERR "UBI error: incorrect bytes count: "%s"\n", + str); + return -EINVAL; + } + + switch (*endp) { + case 'G': + result *= 1024; + case 'M': + result *= 1024; + case 'K': + result *= 1024; + if (endp[1] == 'i' && endp[2] == 'B') + endp += 2; + case '\0': + break; + default: + printk(KERN_ERR "UBI error: incorrect bytes count: "%s"\n", + str); + return -EINVAL; + } + + return result; +} + +/** + * ubi_mtd_param_parse - parse the 'mtd=' UBI parameter. + * @val: the parameter value to parse + * @kp: not used + * + * This function returns zero in case of success and a negative error code in + * case of error. + */ +int __init ubi_mtd_param_parse(const char *val, struct kernel_param *kp) +{ + int i, len; + struct mtd_dev_param *p; + char buf[MTD_PARAM_LEN_MAX]; + char *pbuf = &buf[0]; + char *tokens[2] = {NULL, NULL}; + + if (!val) + return -EINVAL; + + if (mtd_devs == UBI_MAX_DEVICES) { + printk(KERN_ERR "UBI error: too many parameters, max. is %d\n", + UBI_MAX_DEVICES); + return -EINVAL; + } + + len = strnlen(val, MTD_PARAM_LEN_MAX); + if (len == MTD_PARAM_LEN_MAX) { + printk(KERN_ERR "UBI error: parameter "%s" is too long, " + "max. is %d\n", val, MTD_PARAM_LEN_MAX); + return -EINVAL; + } + + if (len == 0) { + printk(KERN_WARNING "UBI warning: empty 'mtd=' parameter - " + "ignored\n"); + return 0; + } + + strcpy(buf, val); + + /* Get rid of the final newline */ + if (buf[len - 1] == '\n') + buf[len - 1] = '\0'; + + for (i = 0; i < 2; i++) + tokens[i] = strsep(&pbuf, ","); + + if (pbuf) { + printk(KERN_ERR "UBI error: too many arguments at "%s"\n", + val); + return -EINVAL; + } + + p = &mtd_dev_param[mtd_devs]; + strcpy(&p->name[0], tokens[0]); + + if (tokens[1]) + p->vid_hdr_offs = bytes_str_to_int(tokens[1]); + + if (p->vid_hdr_offs < 0) + return p->vid_hdr_offs; + + mtd_devs += 1; + return 0; +} + +module_param_call(mtd, ubi_mtd_param_parse, NULL, NULL, 000); +MODULE_PARM_DESC(mtd, "MTD devices to attach. Parameter format: " + "mtd=<name|num>[,<vid_hdr_offs>].\n" + "Multiple "mtd" parameters may be specified.\n" + "MTD devices may be specified by their number or name.\n" + "Optional "vid_hdr_offs" parameter specifies UBI VID " + "header position and data starting position to be used " + "by UBI.\n" + "Example: mtd=content,1984 mtd=4 - attach MTD device" + "with name "content" using VID header offset 1984, and " + "MTD device number 4 with default VID header offset."); + +MODULE_VERSION(__stringify(UBI_VERSION)); +MODULE_DESCRIPTION("UBI - Unsorted Block Images"); +MODULE_AUTHOR("Artem Bityutskiy"); +MODULE_LICENSE("GPL"); diff --git a/drivers/mtd/ubi/crc32.c b/drivers/mtd/ubi/crc32.c new file mode 100644 index 0000000..1204543 --- /dev/null +++ b/drivers/mtd/ubi/crc32.c @@ -0,0 +1,514 @@ +/* + * Oct 15, 2000 Matt Domsch Matt_Domsch@dell.com + * Nicer crc32 functions/docs submitted by linux@horizon.com. Thanks! + * Code was from the public domain, copyright abandoned. Code was + * subsequently included in the kernel, thus was re-licensed under the + * GNU GPL v2. + * + * Oct 12, 2000 Matt Domsch Matt_Domsch@dell.com + * Same crc32 function was used in 5 other places in the kernel. + * I made one version, and deleted the others. + * There are various incantations of crc32(). Some use a seed of 0 or ~0. + * Some xor at the end with ~0. The generic crc32() function takes + * seed as an argument, and doesn't xor at the end. Then individual + * users can do whatever they need. + * drivers/net/smc9194.c uses seed ~0, doesn't xor with ~0. + * fs/jffs2 uses seed 0, doesn't xor with ~0. + * fs/partitions/efi.c uses seed ~0, xor's with ~0. + * + * This source code is licensed under the GNU General Public License, + * Version 2. See the file COPYING for more details. + */ + +//#include <linux/crc32.h> +//#include <linux/kernel.h> +//#include <linux/module.h> +//#include <linux/compiler.h> +#include <linux/types.h> + +#include <asm/byteorder.h> + +//#include <linux/slab.h> +//#include <linux/init.h> +//#include <asm/atomic.h> +#include "crc32defs.h" +#define CRC_LE_BITS 8 + +# define __force +#ifndef __constant_cpu_to_le32 +#define __constant_cpu_to_le32(x) ((__force __le32)(__u32)(x)) +#endif +#ifndef __constant_le32_to_cpu +#define __constant_le32_to_cpu(x) ((__force __u32)(__le32)(x)) +#endif + +#if CRC_LE_BITS == 8 +#define tole(x) __constant_cpu_to_le32(x) +#define tobe(x) __constant_cpu_to_be32(x) +#else +#define tole(x) (x) +#define tobe(x) (x) +#endif +#include "crc32table.h" +#if 0 +MODULE_AUTHOR("Matt Domsch Matt_Domsch@dell.com"); +MODULE_DESCRIPTION("Ethernet CRC32 calculations"); +MODULE_LICENSE("GPL"); +#endif +/** + * crc32_le() - Calculate bitwise little-endian Ethernet AUTODIN II CRC32 + * @crc: seed value for computation. ~0 for Ethernet, sometimes 0 for + * other uses, or the previous crc32 value if computing incrementally. + * @p: pointer to buffer over which CRC is run + * @len: length of buffer @p + */ +u32 crc32_le(u32 crc, unsigned char const *p, size_t len); + +#if CRC_LE_BITS == 1 +/* + * In fact, the table-based code will work in this case, but it can be + * simplified by inlining the table in ?: form. + */ + +u32 crc32_le(u32 crc, unsigned char const *p, size_t len) +{ + int i; + while (len--) { + crc ^= *p++; + for (i = 0; i < 8; i++) + crc = (crc >> 1) ^ ((crc & 1) ? CRCPOLY_LE : 0); + } + return crc; +} +#else /* Table-based approach */ + +u32 crc32_le(u32 crc, unsigned char const *p, size_t len) +{ +# if CRC_LE_BITS == 8 + const u32 *b =(u32 *)p; + const u32 *tab = crc32table_le; + +# ifdef __LITTLE_ENDIAN +# define DO_CRC(x) crc = tab[ (crc ^ (x)) & 255 ] ^ (crc>>8) +# else +# define DO_CRC(x) crc = tab[ ((crc >> 24) ^ (x)) & 255] ^ (crc<<8) +# endif + //printf("Crc32_le crc=%x\n",crc); + crc = __cpu_to_le32(crc); + /* Align it */ + if((((long)b)&3 && len)){ + do { + u8 *p = (u8 *)b; + DO_CRC(*p++); + b = (void *)p; + } while ((--len) && ((long)b)&3 ); + } + if((len >= 4)){ + /* load data 32 bits wide, xor data 32 bits wide. */ + size_t save_len = len & 3; + len = len >> 2; + --b; /* use pre increment below(*++b) for speed */ + do { + crc ^= *++b; + DO_CRC(0); + DO_CRC(0); + DO_CRC(0); + DO_CRC(0); + } while (--len); + b++; /* point to next byte(s) */ + len = save_len; + } + /* And the last few bytes */ + if(len){ + do { + u8 *p = (u8 *)b; + DO_CRC(*p++); + b = (void *)p; + } while (--len); + } + + return __le32_to_cpu(crc); +#undef ENDIAN_SHIFT +#undef DO_CRC + +# elif CRC_LE_BITS == 4 + while (len--) { + crc ^= *p++; + crc = (crc >> 4) ^ crc32table_le[crc & 15]; + crc = (crc >> 4) ^ crc32table_le[crc & 15]; + } + return crc; +# elif CRC_LE_BITS == 2 + while (len--) { + crc ^= *p++; + crc = (crc >> 2) ^ crc32table_le[crc & 3]; + crc = (crc >> 2) ^ crc32table_le[crc & 3]; + crc = (crc >> 2) ^ crc32table_le[crc & 3]; + crc = (crc >> 2) ^ crc32table_le[crc & 3]; + } + return crc; +# endif +} +#endif +#if 0 +/** + * crc32_be() - Calculate bitwise big-endian Ethernet AUTODIN II CRC32 + * @crc: seed value for computation. ~0 for Ethernet, sometimes 0 for + * other uses, or the previous crc32 value if computing incrementally. + * @p: pointer to buffer over which CRC is run + * @len: length of buffer @p + */ +u32 __attribute_pure__ crc32_be(u32 crc, unsigned char const *p, size_t len); + +#if CRC_BE_BITS == 1 +/* + * In fact, the table-based code will work in this case, but it can be + * simplified by inlining the table in ?: form. + */ + +u32 __attribute_pure__ crc32_be(u32 crc, unsigned char const *p, size_t len) +{ + int i; + while (len--) { + crc ^= *p++ << 24; + for (i = 0; i < 8; i++) + crc = + (crc << 1) ^ ((crc & 0x80000000) ? CRCPOLY_BE : + 0); + } + return crc; +} + +#else /* Table-based approach */ +u32 __attribute_pure__ crc32_be(u32 crc, unsigned char const *p, size_t len) +{ +# if CRC_BE_BITS == 8 + const u32 *b =(u32 *)p; + const u32 *tab = crc32table_be; + +# ifdef __LITTLE_ENDIAN +# define DO_CRC(x) crc = tab[ (crc ^ (x)) & 255 ] ^ (crc>>8) +# else +# define DO_CRC(x) crc = tab[ ((crc >> 24) ^ (x)) & 255] ^ (crc<<8) +# endif + + crc = __cpu_to_be32(crc); + /* Align it */ + if(unlikely(((long)b)&3 && len)){ + do { + u8 *p = (u8 *)b; + DO_CRC(*p++); + b = (u32 *)p; + } while ((--len) && ((long)b)&3 ); + } + if(likely(len >= 4)){ + /* load data 32 bits wide, xor data 32 bits wide. */ + size_t save_len = len & 3; + len = len >> 2; + --b; /* use pre increment below(*++b) for speed */ + do { + crc ^= *++b; + DO_CRC(0); + DO_CRC(0); + DO_CRC(0); + DO_CRC(0); + } while (--len); + b++; /* point to next byte(s) */ + len = save_len; + } + /* And the last few bytes */ + if(len){ + do { + u8 *p = (u8 *)b; + DO_CRC(*p++); + b = (void *)p; + } while (--len); + } + return __be32_to_cpu(crc); +#undef ENDIAN_SHIFT +#undef DO_CRC + +# elif CRC_BE_BITS == 4 + while (len--) { + crc ^= *p++ << 24; + crc = (crc << 4) ^ crc32table_be[crc >> 28]; + crc = (crc << 4) ^ crc32table_be[crc >> 28]; + } + return crc; +# elif CRC_BE_BITS == 2 + while (len--) { + crc ^= *p++ << 24; + crc = (crc << 2) ^ crc32table_be[crc >> 30]; + crc = (crc << 2) ^ crc32table_be[crc >> 30]; + crc = (crc << 2) ^ crc32table_be[crc >> 30]; + crc = (crc << 2) ^ crc32table_be[crc >> 30]; + } + return crc; +# endif +} +#endif + +EXPORT_SYMBOL(crc32_le); +EXPORT_SYMBOL(crc32_be); +#endif +/* + * A brief CRC tutorial. + * + * A CRC is a long-division remainder. You add the CRC to the message, + * and the whole thing (message+CRC) is a multiple of the given + * CRC polynomial. To check the CRC, you can either check that the + * CRC matches the recomputed value, *or* you can check that the + * remainder computed on the message+CRC is 0. This latter approach + * is used by a lot of hardware implementations, and is why so many + * protocols put the end-of-frame flag after the CRC. + * + * It's actually the same long division you learned in school, except that + * - We're working in binary, so the digits are only 0 and 1, and + * - When dividing polynomials, there are no carries. Rather than add and + * subtract, we just xor. Thus, we tend to get a bit sloppy about + * the difference between adding and subtracting. + * + * A 32-bit CRC polynomial is actually 33 bits long. But since it's + * 33 bits long, bit 32 is always going to be set, so usually the CRC + * is written in hex with the most significant bit omitted. (If you're + * familiar with the IEEE 754 floating-point format, it's the same idea.) + * + * Note that a CRC is computed over a string of *bits*, so you have + * to decide on the endianness of the bits within each byte. To get + * the best error-detecting properties, this should correspond to the + * order they're actually sent. For example, standard RS-232 serial is + * little-endian; the most significant bit (sometimes used for parity) + * is sent last. And when appending a CRC word to a message, you should + * do it in the right order, matching the endianness. + * + * Just like with ordinary division, the remainder is always smaller than + * the divisor (the CRC polynomial) you're dividing by. Each step of the + * division, you take one more digit (bit) of the dividend and append it + * to the current remainder. Then you figure out the appropriate multiple + * of the divisor to subtract to being the remainder back into range. + * In binary, it's easy - it has to be either 0 or 1, and to make the + * XOR cancel, it's just a copy of bit 32 of the remainder. + * + * When computing a CRC, we don't care about the quotient, so we can + * throw the quotient bit away, but subtract the appropriate multiple of + * the polynomial from the remainder and we're back to where we started, + * ready to process the next bit. + * + * A big-endian CRC written this way would be coded like: + * for (i = 0; i < input_bits; i++) { + * multiple = remainder & 0x80000000 ? CRCPOLY : 0; + * remainder = (remainder << 1 | next_input_bit()) ^ multiple; + * } + * Notice how, to get at bit 32 of the shifted remainder, we look + * at bit 31 of the remainder *before* shifting it. + * + * But also notice how the next_input_bit() bits we're shifting into + * the remainder don't actually affect any decision-making until + * 32 bits later. Thus, the first 32 cycles of this are pretty boring. + * Also, to add the CRC to a message, we need a 32-bit-long hole for it at + * the end, so we have to add 32 extra cycles shifting in zeros at the + * end of every message, + * + * So the standard trick is to rearrage merging in the next_input_bit() + * until the moment it's needed. Then the first 32 cycles can be precomputed, + * and merging in the final 32 zero bits to make room for the CRC can be + * skipped entirely. + * This changes the code to: + * for (i = 0; i < input_bits; i++) { + * remainder ^= next_input_bit() << 31; + * multiple = (remainder & 0x80000000) ? CRCPOLY : 0; + * remainder = (remainder << 1) ^ multiple; + * } + * With this optimization, the little-endian code is simpler: + * for (i = 0; i < input_bits; i++) { + * remainder ^= next_input_bit(); + * multiple = (remainder & 1) ? CRCPOLY : 0; + * remainder = (remainder >> 1) ^ multiple; + * } + * + * Note that the other details of endianness have been hidden in CRCPOLY + * (which must be bit-reversed) and next_input_bit(). + * + * However, as long as next_input_bit is returning the bits in a sensible + * order, we can actually do the merging 8 or more bits at a time rather + * than one bit at a time: + * for (i = 0; i < input_bytes; i++) { + * remainder ^= next_input_byte() << 24; + * for (j = 0; j < 8; j++) { + * multiple = (remainder & 0x80000000) ? CRCPOLY : 0; + * remainder = (remainder << 1) ^ multiple; + * } + * } + * Or in little-endian: + * for (i = 0; i < input_bytes; i++) { + * remainder ^= next_input_byte(); + * for (j = 0; j < 8; j++) { + * multiple = (remainder & 1) ? CRCPOLY : 0; + * remainder = (remainder << 1) ^ multiple; + * } + * } + * If the input is a multiple of 32 bits, you can even XOR in a 32-bit + * word at a time and increase the inner loop count to 32. + * + * You can also mix and match the two loop styles, for example doing the + * bulk of a message byte-at-a-time and adding bit-at-a-time processing + * for any fractional bytes at the end. + * + * The only remaining optimization is to the byte-at-a-time table method. + * Here, rather than just shifting one bit of the remainder to decide + * in the correct multiple to subtract, we can shift a byte at a time. + * This produces a 40-bit (rather than a 33-bit) intermediate remainder, + * but again the multiple of the polynomial to subtract depends only on + * the high bits, the high 8 bits in this case. + * + * The multile we need in that case is the low 32 bits of a 40-bit + * value whose high 8 bits are given, and which is a multiple of the + * generator polynomial. This is simply the CRC-32 of the given + * one-byte message. + * + * Two more details: normally, appending zero bits to a message which + * is already a multiple of a polynomial produces a larger multiple of that + * polynomial. To enable a CRC to detect this condition, it's common to + * invert the CRC before appending it. This makes the remainder of the + * message+crc come out not as zero, but some fixed non-zero value. + * + * The same problem applies to zero bits prepended to the message, and + * a similar solution is used. Instead of starting with a remainder of + * 0, an initial remainder of all ones is used. As long as you start + * the same way on decoding, it doesn't make a difference. + */ + +#ifdef UNITTEST + +#include <stdlib.h> +#include <stdio.h> + +#if 0 /*Not used at present */ +static void +buf_dump(char const *prefix, unsigned char const *buf, size_t len) +{ + fputs(prefix, stdout); + while (len--) + printf(" %02x", *buf++); + putchar('\n'); + +} +#endif + +static void bytereverse(unsigned char *buf, size_t len) +{ + while (len--) { + unsigned char x = bitrev8(*buf); + *buf++ = x; + } +} + +static void random_garbage(unsigned char *buf, size_t len) +{ + while (len--) + *buf++ = (unsigned char) random(); +} + +#if 0 /* Not used at present */ +static void store_le(u32 x, unsigned char *buf) +{ + buf[0] = (unsigned char) x; + buf[1] = (unsigned char) (x >> 8); + buf[2] = (unsigned char) (x >> 16); + buf[3] = (unsigned char) (x >> 24); +} +#endif + +static void store_be(u32 x, unsigned char *buf) +{ + buf[0] = (unsigned char) (x >> 24); + buf[1] = (unsigned char) (x >> 16); + buf[2] = (unsigned char) (x >> 8); + buf[3] = (unsigned char) x; +} + +/* + * This checks that CRC(buf + CRC(buf)) = 0, and that + * CRC commutes with bit-reversal. This has the side effect + * of bytewise bit-reversing the input buffer, and returns + * the CRC of the reversed buffer. + */ +static u32 test_step(u32 init, unsigned char *buf, size_t len) +{ + u32 crc1, crc2; + size_t i; + + crc1 = crc32_be(init, buf, len); + store_be(crc1, buf + len); + crc2 = crc32_be(init, buf, len + 4); + if (crc2) + printf("\nCRC cancellation fail: 0x%08x should be 0\n", + crc2); + + for (i = 0; i <= len + 4; i++) { + crc2 = crc32_be(init, buf, i); + crc2 = crc32_be(crc2, buf + i, len + 4 - i); + if (crc2) + printf("\nCRC split fail: 0x%08x\n", crc2); + } + + /* Now swap it around for the other test */ + + bytereverse(buf, len + 4); + init = bitrev32(init); + crc2 = bitrev32(crc1); + if (crc1 != bitrev32(crc2)) + printf("\nBit reversal fail: 0x%08x -> 0x%08x -> 0x%08x\n", + crc1, crc2, bitrev32(crc2)); + crc1 = crc32_le(init, buf, len); + if (crc1 != crc2) + printf("\nCRC endianness fail: 0x%08x != 0x%08x\n", crc1, + crc2); + crc2 = crc32_le(init, buf, len + 4); + if (crc2) + printf("\nCRC cancellation fail: 0x%08x should be 0\n", + crc2); + + for (i = 0; i <= len + 4; i++) { + crc2 = crc32_le(init, buf, i); + crc2 = crc32_le(crc2, buf + i, len + 4 - i); + if (crc2) + printf("\nCRC split fail: 0x%08x\n", crc2); + } + + return crc1; +} + +#define SIZE 64 +#define INIT1 0 +#define INIT2 0 + +int main(void) +{ + unsigned char buf1[SIZE + 4]; + unsigned char buf2[SIZE + 4]; + unsigned char buf3[SIZE + 4]; + int i, j; + u32 crc1, crc2, crc3; + + for (i = 0; i <= SIZE; i++) { + printf("\rTesting length %d...", i); + fflush(stdout); + random_garbage(buf1, i); + random_garbage(buf2, i); + for (j = 0; j < i; j++) + buf3[j] = buf1[j] ^ buf2[j]; + + crc1 = test_step(INIT1, buf1, i); + crc2 = test_step(INIT2, buf2, i); + /* Now check that CRC(buf1 ^ buf2) = CRC(buf1) ^ CRC(buf2) */ + crc3 = test_step(INIT1 ^ INIT2, buf3, i); + if (crc3 != (crc1 ^ crc2)) + printf("CRC XOR fail: 0x%08x != 0x%08x ^ 0x%08x\n", + crc3, crc1, crc2); + } + printf("\nAll test complete. No failures expected.\n"); + return 0; +} + +#endif /* UNITTEST */ diff --git a/drivers/mtd/ubi/crc32defs.h b/drivers/mtd/ubi/crc32defs.h new file mode 100644 index 0000000..9b6773d --- /dev/null +++ b/drivers/mtd/ubi/crc32defs.h @@ -0,0 +1,32 @@ +/* + * There are multiple 16-bit CRC polynomials in common use, but this is + * *the* standard CRC-32 polynomial, first popularized by Ethernet. + * x^32+x^26+x^23+x^22+x^16+x^12+x^11+x^10+x^8+x^7+x^5+x^4+x^2+x^1+x^0 + */ +#define CRCPOLY_LE 0xedb88320 +#define CRCPOLY_BE 0x04c11db7 + +/* How many bits at a time to use. Requires a table of 4<<CRC_xx_BITS bytes. */ +/* For less performance-sensitive, use 4 */ +#ifndef CRC_LE_BITS +# define CRC_LE_BITS 8 +#endif +#ifndef CRC_BE_BITS +# define CRC_BE_BITS 8 +#endif + +/* + * Little-endian CRC computation. Used with serial bit streams sent + * lsbit-first. Be sure to use cpu_to_le32() to append the computed CRC. + */ +#if CRC_LE_BITS > 8 || CRC_LE_BITS < 1 || CRC_LE_BITS & CRC_LE_BITS-1 +# error CRC_LE_BITS must be a power of 2 between 1 and 8 +#endif + +/* + * Big-endian CRC computation. Used with serial bit streams sent + * msbit-first. Be sure to use cpu_to_be32() to append the computed CRC. + */ +#if CRC_BE_BITS > 8 || CRC_BE_BITS < 1 || CRC_BE_BITS & CRC_BE_BITS-1 +# error CRC_BE_BITS must be a power of 2 between 1 and 8 +#endif diff --git a/drivers/mtd/ubi/crc32table.h b/drivers/mtd/ubi/crc32table.h new file mode 100644 index 0000000..1b1e9c7 --- /dev/null +++ b/drivers/mtd/ubi/crc32table.h @@ -0,0 +1,136 @@ +/* this file is generated - do not edit */ + +static const u32 crc32table_le[] = { +tole(0x00000000L), tole(0x77073096L), tole(0xee0e612cL), tole(0x990951baL), +tole(0x076dc419L), tole(0x706af48fL), tole(0xe963a535L), tole(0x9e6495a3L), +tole(0x0edb8832L), tole(0x79dcb8a4L), tole(0xe0d5e91eL), tole(0x97d2d988L), +tole(0x09b64c2bL), tole(0x7eb17cbdL), tole(0xe7b82d07L), tole(0x90bf1d91L), +tole(0x1db71064L), tole(0x6ab020f2L), tole(0xf3b97148L), tole(0x84be41deL), +tole(0x1adad47dL), tole(0x6ddde4ebL), tole(0xf4d4b551L), tole(0x83d385c7L), +tole(0x136c9856L), tole(0x646ba8c0L), tole(0xfd62f97aL), tole(0x8a65c9ecL), +tole(0x14015c4fL), tole(0x63066cd9L), tole(0xfa0f3d63L), tole(0x8d080df5L), +tole(0x3b6e20c8L), tole(0x4c69105eL), tole(0xd56041e4L), tole(0xa2677172L), +tole(0x3c03e4d1L), tole(0x4b04d447L), tole(0xd20d85fdL), tole(0xa50ab56bL), +tole(0x35b5a8faL), tole(0x42b2986cL), tole(0xdbbbc9d6L), tole(0xacbcf940L), +tole(0x32d86ce3L), tole(0x45df5c75L), tole(0xdcd60dcfL), tole(0xabd13d59L), +tole(0x26d930acL), tole(0x51de003aL), tole(0xc8d75180L), tole(0xbfd06116L), +tole(0x21b4f4b5L), tole(0x56b3c423L), tole(0xcfba9599L), tole(0xb8bda50fL), +tole(0x2802b89eL), tole(0x5f058808L), tole(0xc60cd9b2L), tole(0xb10be924L), +tole(0x2f6f7c87L), tole(0x58684c11L), tole(0xc1611dabL), tole(0xb6662d3dL), +tole(0x76dc4190L), tole(0x01db7106L), tole(0x98d220bcL), tole(0xefd5102aL), +tole(0x71b18589L), tole(0x06b6b51fL), tole(0x9fbfe4a5L), tole(0xe8b8d433L), +tole(0x7807c9a2L), tole(0x0f00f934L), tole(0x9609a88eL), tole(0xe10e9818L), +tole(0x7f6a0dbbL), tole(0x086d3d2dL), tole(0x91646c97L), tole(0xe6635c01L), +tole(0x6b6b51f4L), tole(0x1c6c6162L), tole(0x856530d8L), tole(0xf262004eL), +tole(0x6c0695edL), tole(0x1b01a57bL), tole(0x8208f4c1L), tole(0xf50fc457L), +tole(0x65b0d9c6L), tole(0x12b7e950L), tole(0x8bbeb8eaL), tole(0xfcb9887cL), +tole(0x62dd1ddfL), tole(0x15da2d49L), tole(0x8cd37cf3L), tole(0xfbd44c65L), +tole(0x4db26158L), tole(0x3ab551ceL), tole(0xa3bc0074L), tole(0xd4bb30e2L), +tole(0x4adfa541L), tole(0x3dd895d7L), tole(0xa4d1c46dL), tole(0xd3d6f4fbL), +tole(0x4369e96aL), tole(0x346ed9fcL), tole(0xad678846L), tole(0xda60b8d0L), +tole(0x44042d73L), tole(0x33031de5L), tole(0xaa0a4c5fL), tole(0xdd0d7cc9L), +tole(0x5005713cL), tole(0x270241aaL), tole(0xbe0b1010L), tole(0xc90c2086L), +tole(0x5768b525L), tole(0x206f85b3L), tole(0xb966d409L), tole(0xce61e49fL), +tole(0x5edef90eL), tole(0x29d9c998L), tole(0xb0d09822L), tole(0xc7d7a8b4L), +tole(0x59b33d17L), tole(0x2eb40d81L), tole(0xb7bd5c3bL), tole(0xc0ba6cadL), +tole(0xedb88320L), tole(0x9abfb3b6L), tole(0x03b6e20cL), tole(0x74b1d29aL), +tole(0xead54739L), tole(0x9dd277afL), tole(0x04db2615L), tole(0x73dc1683L), +tole(0xe3630b12L), tole(0x94643b84L), tole(0x0d6d6a3eL), tole(0x7a6a5aa8L), +tole(0xe40ecf0bL), tole(0x9309ff9dL), tole(0x0a00ae27L), tole(0x7d079eb1L), +tole(0xf00f9344L), tole(0x8708a3d2L), tole(0x1e01f268L), tole(0x6906c2feL), +tole(0xf762575dL), tole(0x806567cbL), tole(0x196c3671L), tole(0x6e6b06e7L), +tole(0xfed41b76L), tole(0x89d32be0L), tole(0x10da7a5aL), tole(0x67dd4accL), +tole(0xf9b9df6fL), tole(0x8ebeeff9L), tole(0x17b7be43L), tole(0x60b08ed5L), +tole(0xd6d6a3e8L), tole(0xa1d1937eL), tole(0x38d8c2c4L), tole(0x4fdff252L), +tole(0xd1bb67f1L), tole(0xa6bc5767L), tole(0x3fb506ddL), tole(0x48b2364bL), +tole(0xd80d2bdaL), tole(0xaf0a1b4cL), tole(0x36034af6L), tole(0x41047a60L), +tole(0xdf60efc3L), tole(0xa867df55L), tole(0x316e8eefL), tole(0x4669be79L), +tole(0xcb61b38cL), tole(0xbc66831aL), tole(0x256fd2a0L), tole(0x5268e236L), +tole(0xcc0c7795L), tole(0xbb0b4703L), tole(0x220216b9L), tole(0x5505262fL), +tole(0xc5ba3bbeL), tole(0xb2bd0b28L), tole(0x2bb45a92L), tole(0x5cb36a04L), +tole(0xc2d7ffa7L), tole(0xb5d0cf31L), tole(0x2cd99e8bL), tole(0x5bdeae1dL), +tole(0x9b64c2b0L), tole(0xec63f226L), tole(0x756aa39cL), tole(0x026d930aL), +tole(0x9c0906a9L), tole(0xeb0e363fL), tole(0x72076785L), tole(0x05005713L), +tole(0x95bf4a82L), tole(0xe2b87a14L), tole(0x7bb12baeL), tole(0x0cb61b38L), +tole(0x92d28e9bL), tole(0xe5d5be0dL), tole(0x7cdcefb7L), tole(0x0bdbdf21L), +tole(0x86d3d2d4L), tole(0xf1d4e242L), tole(0x68ddb3f8L), tole(0x1fda836eL), +tole(0x81be16cdL), tole(0xf6b9265bL), tole(0x6fb077e1L), tole(0x18b74777L), +tole(0x88085ae6L), tole(0xff0f6a70L), tole(0x66063bcaL), tole(0x11010b5cL), +tole(0x8f659effL), tole(0xf862ae69L), tole(0x616bffd3L), tole(0x166ccf45L), +tole(0xa00ae278L), tole(0xd70dd2eeL), tole(0x4e048354L), tole(0x3903b3c2L), +tole(0xa7672661L), tole(0xd06016f7L), tole(0x4969474dL), tole(0x3e6e77dbL), +tole(0xaed16a4aL), tole(0xd9d65adcL), tole(0x40df0b66L), tole(0x37d83bf0L), +tole(0xa9bcae53L), tole(0xdebb9ec5L), tole(0x47b2cf7fL), tole(0x30b5ffe9L), +tole(0xbdbdf21cL), tole(0xcabac28aL), tole(0x53b39330L), tole(0x24b4a3a6L), +tole(0xbad03605L), tole(0xcdd70693L), tole(0x54de5729L), tole(0x23d967bfL), +tole(0xb3667a2eL), tole(0xc4614ab8L), tole(0x5d681b02L), tole(0x2a6f2b94L), +tole(0xb40bbe37L), tole(0xc30c8ea1L), tole(0x5a05df1bL), tole(0x2d02ef8dL) +}; +#if 0 +static const u32 crc32table_be[] = { +tobe(0x00000000L), tobe(0x04c11db7L), tobe(0x09823b6eL), tobe(0x0d4326d9L), +tobe(0x130476dcL), tobe(0x17c56b6bL), tobe(0x1a864db2L), tobe(0x1e475005L), +tobe(0x2608edb8L), tobe(0x22c9f00fL), tobe(0x2f8ad6d6L), tobe(0x2b4bcb61L), +tobe(0x350c9b64L), tobe(0x31cd86d3L), tobe(0x3c8ea00aL), tobe(0x384fbdbdL), +tobe(0x4c11db70L), tobe(0x48d0c6c7L), tobe(0x4593e01eL), tobe(0x4152fda9L), +tobe(0x5f15adacL), tobe(0x5bd4b01bL), tobe(0x569796c2L), tobe(0x52568b75L), +tobe(0x6a1936c8L), tobe(0x6ed82b7fL), tobe(0x639b0da6L), tobe(0x675a1011L), +tobe(0x791d4014L), tobe(0x7ddc5da3L), tobe(0x709f7b7aL), tobe(0x745e66cdL), +tobe(0x9823b6e0L), tobe(0x9ce2ab57L), tobe(0x91a18d8eL), tobe(0x95609039L), +tobe(0x8b27c03cL), tobe(0x8fe6dd8bL), tobe(0x82a5fb52L), tobe(0x8664e6e5L), +tobe(0xbe2b5b58L), tobe(0xbaea46efL), tobe(0xb7a96036L), tobe(0xb3687d81L), +tobe(0xad2f2d84L), tobe(0xa9ee3033L), tobe(0xa4ad16eaL), tobe(0xa06c0b5dL), +tobe(0xd4326d90L), tobe(0xd0f37027L), tobe(0xddb056feL), tobe(0xd9714b49L), +tobe(0xc7361b4cL), tobe(0xc3f706fbL), tobe(0xceb42022L), tobe(0xca753d95L), +tobe(0xf23a8028L), tobe(0xf6fb9d9fL), tobe(0xfbb8bb46L), tobe(0xff79a6f1L), +tobe(0xe13ef6f4L), tobe(0xe5ffeb43L), tobe(0xe8bccd9aL), tobe(0xec7dd02dL), +tobe(0x34867077L), tobe(0x30476dc0L), tobe(0x3d044b19L), tobe(0x39c556aeL), +tobe(0x278206abL), tobe(0x23431b1cL), tobe(0x2e003dc5L), tobe(0x2ac12072L), +tobe(0x128e9dcfL), tobe(0x164f8078L), tobe(0x1b0ca6a1L), tobe(0x1fcdbb16L), +tobe(0x018aeb13L), tobe(0x054bf6a4L), tobe(0x0808d07dL), tobe(0x0cc9cdcaL), +tobe(0x7897ab07L), tobe(0x7c56b6b0L), tobe(0x71159069L), tobe(0x75d48ddeL), +tobe(0x6b93dddbL), tobe(0x6f52c06cL), tobe(0x6211e6b5L), tobe(0x66d0fb02L), +tobe(0x5e9f46bfL), tobe(0x5a5e5b08L), tobe(0x571d7dd1L), tobe(0x53dc6066L), +tobe(0x4d9b3063L), tobe(0x495a2dd4L), tobe(0x44190b0dL), tobe(0x40d816baL), +tobe(0xaca5c697L), tobe(0xa864db20L), tobe(0xa527fdf9L), tobe(0xa1e6e04eL), +tobe(0xbfa1b04bL), tobe(0xbb60adfcL), tobe(0xb6238b25L), tobe(0xb2e29692L), +tobe(0x8aad2b2fL), tobe(0x8e6c3698L), tobe(0x832f1041L), tobe(0x87ee0df6L), +tobe(0x99a95df3L), tobe(0x9d684044L), tobe(0x902b669dL), tobe(0x94ea7b2aL), +tobe(0xe0b41de7L), tobe(0xe4750050L), tobe(0xe9362689L), tobe(0xedf73b3eL), +tobe(0xf3b06b3bL), tobe(0xf771768cL), tobe(0xfa325055L), tobe(0xfef34de2L), +tobe(0xc6bcf05fL), tobe(0xc27dede8L), tobe(0xcf3ecb31L), tobe(0xcbffd686L), +tobe(0xd5b88683L), tobe(0xd1799b34L), tobe(0xdc3abdedL), tobe(0xd8fba05aL), +tobe(0x690ce0eeL), tobe(0x6dcdfd59L), tobe(0x608edb80L), tobe(0x644fc637L), +tobe(0x7a089632L), tobe(0x7ec98b85L), tobe(0x738aad5cL), tobe(0x774bb0ebL), +tobe(0x4f040d56L), tobe(0x4bc510e1L), tobe(0x46863638L), tobe(0x42472b8fL), +tobe(0x5c007b8aL), tobe(0x58c1663dL), tobe(0x558240e4L), tobe(0x51435d53L), +tobe(0x251d3b9eL), tobe(0x21dc2629L), tobe(0x2c9f00f0L), tobe(0x285e1d47L), +tobe(0x36194d42L), tobe(0x32d850f5L), tobe(0x3f9b762cL), tobe(0x3b5a6b9bL), +tobe(0x0315d626L), tobe(0x07d4cb91L), tobe(0x0a97ed48L), tobe(0x0e56f0ffL), +tobe(0x1011a0faL), tobe(0x14d0bd4dL), tobe(0x19939b94L), tobe(0x1d528623L), +tobe(0xf12f560eL), tobe(0xf5ee4bb9L), tobe(0xf8ad6d60L), tobe(0xfc6c70d7L), +tobe(0xe22b20d2L), tobe(0xe6ea3d65L), tobe(0xeba91bbcL), tobe(0xef68060bL), +tobe(0xd727bbb6L), tobe(0xd3e6a601L), tobe(0xdea580d8L), tobe(0xda649d6fL), +tobe(0xc423cd6aL), tobe(0xc0e2d0ddL), tobe(0xcda1f604L), tobe(0xc960ebb3L), +tobe(0xbd3e8d7eL), tobe(0xb9ff90c9L), tobe(0xb4bcb610L), tobe(0xb07daba7L), +tobe(0xae3afba2L), tobe(0xaafbe615L), tobe(0xa7b8c0ccL), tobe(0xa379dd7bL), +tobe(0x9b3660c6L), tobe(0x9ff77d71L), tobe(0x92b45ba8L), tobe(0x9675461fL), +tobe(0x8832161aL), tobe(0x8cf30badL), tobe(0x81b02d74L), tobe(0x857130c3L), +tobe(0x5d8a9099L), tobe(0x594b8d2eL), tobe(0x5408abf7L), tobe(0x50c9b640L), +tobe(0x4e8ee645L), tobe(0x4a4ffbf2L), tobe(0x470cdd2bL), tobe(0x43cdc09cL), +tobe(0x7b827d21L), tobe(0x7f436096L), tobe(0x7200464fL), tobe(0x76c15bf8L), +tobe(0x68860bfdL), tobe(0x6c47164aL), tobe(0x61043093L), tobe(0x65c52d24L), +tobe(0x119b4be9L), tobe(0x155a565eL), tobe(0x18197087L), tobe(0x1cd86d30L), +tobe(0x029f3d35L), tobe(0x065e2082L), tobe(0x0b1d065bL), tobe(0x0fdc1becL), +tobe(0x3793a651L), tobe(0x3352bbe6L), tobe(0x3e119d3fL), tobe(0x3ad08088L), +tobe(0x2497d08dL), tobe(0x2056cd3aL), tobe(0x2d15ebe3L), tobe(0x29d4f654L), +tobe(0xc5a92679L), tobe(0xc1683bceL), tobe(0xcc2b1d17L), tobe(0xc8ea00a0L), +tobe(0xd6ad50a5L), tobe(0xd26c4d12L), tobe(0xdf2f6bcbL), tobe(0xdbee767cL), +tobe(0xe3a1cbc1L), tobe(0xe760d676L), tobe(0xea23f0afL), tobe(0xeee2ed18L), +tobe(0xf0a5bd1dL), tobe(0xf464a0aaL), tobe(0xf9278673L), tobe(0xfde69bc4L), +tobe(0x89b8fd09L), tobe(0x8d79e0beL), tobe(0x803ac667L), tobe(0x84fbdbd0L), +tobe(0x9abc8bd5L), tobe(0x9e7d9662L), tobe(0x933eb0bbL), tobe(0x97ffad0cL), +tobe(0xafb010b1L), tobe(0xab710d06L), tobe(0xa6322bdfL), tobe(0xa2f33668L), +tobe(0xbcb4666dL), tobe(0xb8757bdaL), tobe(0xb5365d03L), tobe(0xb1f740b4L) +}; +#endif diff --git a/drivers/mtd/ubi/debug.c b/drivers/mtd/ubi/debug.c new file mode 100644 index 0000000..492ab5c --- /dev/null +++ b/drivers/mtd/ubi/debug.c @@ -0,0 +1,192 @@ +/* + * Copyright (c) International Business Machines Corp., 2006 + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See + * the GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + * Author: Artem Bityutskiy (Битюцкий Артём) + */ + +/* + * Here we keep all the UBI debugging stuff which should normally be disabled + * and compiled-out, but it is extremely helpful when hunting bugs or doing big + * changes. + */ +#include <ubi_uboot.h> + +#ifdef CONFIG_MTD_UBI_DEBUG_MSG + +#include "ubi.h" + +/** + * ubi_dbg_dump_ec_hdr - dump an erase counter header. + * @ec_hdr: the erase counter header to dump + */ +void ubi_dbg_dump_ec_hdr(const struct ubi_ec_hdr *ec_hdr) +{ + dbg_msg("erase counter header dump:"); + dbg_msg("magic %#08x", be32_to_cpu(ec_hdr->magic)); + dbg_msg("version %d", (int)ec_hdr->version); + dbg_msg("ec %llu", (long long)be64_to_cpu(ec_hdr->ec)); + dbg_msg("vid_hdr_offset %d", be32_to_cpu(ec_hdr->vid_hdr_offset)); + dbg_msg("data_offset %d", be32_to_cpu(ec_hdr->data_offset)); + dbg_msg("hdr_crc %#08x", be32_to_cpu(ec_hdr->hdr_crc)); + dbg_msg("erase counter header hexdump:"); + print_hex_dump(KERN_DEBUG, "", DUMP_PREFIX_OFFSET, 32, 1, + ec_hdr, UBI_EC_HDR_SIZE, 1); +} + +/** + * ubi_dbg_dump_vid_hdr - dump a volume identifier header. + * @vid_hdr: the volume identifier header to dump + */ +void ubi_dbg_dump_vid_hdr(const struct ubi_vid_hdr *vid_hdr) +{ + dbg_msg("volume identifier header dump:"); + dbg_msg("magic %08x", be32_to_cpu(vid_hdr->magic)); + dbg_msg("version %d", (int)vid_hdr->version); + dbg_msg("vol_type %d", (int)vid_hdr->vol_type); + dbg_msg("copy_flag %d", (int)vid_hdr->copy_flag); + dbg_msg("compat %d", (int)vid_hdr->compat); + dbg_msg("vol_id %d", be32_to_cpu(vid_hdr->vol_id)); + dbg_msg("lnum %d", be32_to_cpu(vid_hdr->lnum)); + dbg_msg("leb_ver %u", be32_to_cpu(vid_hdr->leb_ver)); + dbg_msg("data_size %d", be32_to_cpu(vid_hdr->data_size)); + dbg_msg("used_ebs %d", be32_to_cpu(vid_hdr->used_ebs)); + dbg_msg("data_pad %d", be32_to_cpu(vid_hdr->data_pad)); + dbg_msg("sqnum %llu", + (unsigned long long)be64_to_cpu(vid_hdr->sqnum)); + dbg_msg("hdr_crc %08x", be32_to_cpu(vid_hdr->hdr_crc)); + dbg_msg("volume identifier header hexdump:"); +} + +/** + * ubi_dbg_dump_vol_info- dump volume information. + * @vol: UBI volume description object + */ +void ubi_dbg_dump_vol_info(const struct ubi_volume *vol) +{ + dbg_msg("volume information dump:"); + dbg_msg("vol_id %d", vol->vol_id); + dbg_msg("reserved_pebs %d", vol->reserved_pebs); + dbg_msg("alignment %d", vol->alignment); + dbg_msg("data_pad %d", vol->data_pad); + dbg_msg("vol_type %d", vol->vol_type); + dbg_msg("name_len %d", vol->name_len); + dbg_msg("usable_leb_size %d", vol->usable_leb_size); + dbg_msg("used_ebs %d", vol->used_ebs); + dbg_msg("used_bytes %lld", vol->used_bytes); + dbg_msg("last_eb_bytes %d", vol->last_eb_bytes); + dbg_msg("corrupted %d", vol->corrupted); + dbg_msg("upd_marker %d", vol->upd_marker); + + if (vol->name_len <= UBI_VOL_NAME_MAX && + strnlen(vol->name, vol->name_len + 1) == vol->name_len) { + dbg_msg("name %s", vol->name); + } else { + dbg_msg("the 1st 5 characters of the name: %c%c%c%c%c", + vol->name[0], vol->name[1], vol->name[2], + vol->name[3], vol->name[4]); + } +} + +/** + * ubi_dbg_dump_vtbl_record - dump a &struct ubi_vtbl_record object. + * @r: the object to dump + * @idx: volume table index + */ +void ubi_dbg_dump_vtbl_record(const struct ubi_vtbl_record *r, int idx) +{ + int name_len = be16_to_cpu(r->name_len); + + dbg_msg("volume table record %d dump:", idx); + dbg_msg("reserved_pebs %d", be32_to_cpu(r->reserved_pebs)); + dbg_msg("alignment %d", be32_to_cpu(r->alignment)); + dbg_msg("data_pad %d", be32_to_cpu(r->data_pad)); + dbg_msg("vol_type %d", (int)r->vol_type); + dbg_msg("upd_marker %d", (int)r->upd_marker); + dbg_msg("name_len %d", name_len); + + if (r->name[0] == '\0') { + dbg_msg("name NULL"); + return; + } + + if (name_len <= UBI_VOL_NAME_MAX && + strnlen(&r->name[0], name_len + 1) == name_len) { + dbg_msg("name %s", &r->name[0]); + } else { + dbg_msg("1st 5 characters of the name: %c%c%c%c%c", + r->name[0], r->name[1], r->name[2], r->name[3], + r->name[4]); + } + dbg_msg("crc %#08x", be32_to_cpu(r->crc)); +} + +/** + * ubi_dbg_dump_sv - dump a &struct ubi_scan_volume object. + * @sv: the object to dump + */ +void ubi_dbg_dump_sv(const struct ubi_scan_volume *sv) +{ + dbg_msg("volume scanning information dump:"); + dbg_msg("vol_id %d", sv->vol_id); + dbg_msg("highest_lnum %d", sv->highest_lnum); + dbg_msg("leb_count %d", sv->leb_count); + dbg_msg("compat %d", sv->compat); + dbg_msg("vol_type %d", sv->vol_type); + dbg_msg("used_ebs %d", sv->used_ebs); + dbg_msg("last_data_size %d", sv->last_data_size); + dbg_msg("data_pad %d", sv->data_pad); +} + +/** + * ubi_dbg_dump_seb - dump a &struct ubi_scan_leb object. + * @seb: the object to dump + * @type: object type: 0 - not corrupted, 1 - corrupted + */ +void ubi_dbg_dump_seb(const struct ubi_scan_leb *seb, int type) +{ + dbg_msg("eraseblock scanning information dump:"); + dbg_msg("ec %d", seb->ec); + dbg_msg("pnum %d", seb->pnum); + if (type == 0) { + dbg_msg("lnum %d", seb->lnum); + dbg_msg("scrub %d", seb->scrub); + dbg_msg("sqnum %llu", seb->sqnum); + dbg_msg("leb_ver %u", seb->leb_ver); + } +} + +/** + * ubi_dbg_dump_mkvol_req - dump a &struct ubi_mkvol_req object. + * @req: the object to dump + */ +void ubi_dbg_dump_mkvol_req(const struct ubi_mkvol_req *req) +{ + char nm[17]; + + dbg_msg("volume creation request dump:"); + dbg_msg("vol_id %d", req->vol_id); + dbg_msg("alignment %d", req->alignment); + dbg_msg("bytes %lld", (long long)req->bytes); + dbg_msg("vol_type %d", req->vol_type); + dbg_msg("name_len %d", req->name_len); + + memcpy(nm, req->name, 16); + nm[16] = 0; + dbg_msg("the 1st 16 characters of the name: %s", nm); +} + +#endif /* CONFIG_MTD_UBI_DEBUG_MSG */ diff --git a/drivers/mtd/ubi/debug.h b/drivers/mtd/ubi/debug.h new file mode 100644 index 0000000..3ea43a4 --- /dev/null +++ b/drivers/mtd/ubi/debug.h @@ -0,0 +1,152 @@ +/* + * Copyright (c) International Business Machines Corp., 2006 + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See + * the GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + * Author: Artem Bityutskiy (Битюцкий Артём) + */ + +#ifndef __UBI_DEBUG_H__ +#define __UBI_DEBUG_H__ + +#ifdef CONFIG_MTD_UBI_DEBUG +#if 0 +#include <linux/random.h> +#endif + +#define ubi_assert(expr) BUG_ON(!(expr)) +#define dbg_err(fmt, ...) ubi_err(fmt, ##__VA_ARGS__) +#else +#define ubi_assert(expr) ({}) +#define dbg_err(fmt, ...) ({}) +#endif + +#ifdef CONFIG_MTD_UBI_DEBUG_DISABLE_BGT +#define DBG_DISABLE_BGT 1 +#else +#define DBG_DISABLE_BGT 0 +#endif + +#ifdef CONFIG_MTD_UBI_DEBUG_MSG +/* Generic debugging message */ +#define dbg_msg(fmt, ...) \ + printk(KERN_DEBUG "UBI DBG: %s: " fmt "\n", \ + __FUNCTION__, ##__VA_ARGS__) + +#define ubi_dbg_dump_stack() dump_stack() + +struct ubi_ec_hdr; +struct ubi_vid_hdr; +struct ubi_volume; +struct ubi_vtbl_record; +struct ubi_scan_volume; +struct ubi_scan_leb; +struct ubi_mkvol_req; + +void ubi_dbg_dump_ec_hdr(const struct ubi_ec_hdr *ec_hdr); +void ubi_dbg_dump_vid_hdr(const struct ubi_vid_hdr *vid_hdr); +void ubi_dbg_dump_vol_info(const struct ubi_volume *vol); +void ubi_dbg_dump_vtbl_record(const struct ubi_vtbl_record *r, int idx); +void ubi_dbg_dump_sv(const struct ubi_scan_volume *sv); +void ubi_dbg_dump_seb(const struct ubi_scan_leb *seb, int type); +void ubi_dbg_dump_mkvol_req(const struct ubi_mkvol_req *req); + +#else + +#define dbg_msg(fmt, ...) ({}) +#define ubi_dbg_dump_stack() ({}) +#define ubi_dbg_dump_ec_hdr(ec_hdr) ({}) +#define ubi_dbg_dump_vid_hdr(vid_hdr) ({}) +#define ubi_dbg_dump_vol_info(vol) ({}) +#define ubi_dbg_dump_vtbl_record(r, idx) ({}) +#define ubi_dbg_dump_sv(sv) ({}) +#define ubi_dbg_dump_seb(seb, type) ({}) +#define ubi_dbg_dump_mkvol_req(req) ({}) + +#endif /* CONFIG_MTD_UBI_DEBUG_MSG */ + +#ifdef CONFIG_MTD_UBI_DEBUG_MSG_EBA +/* Messages from the eraseblock association unit */ +#define dbg_eba(fmt, ...) dbg_msg(fmt, ##__VA_ARGS__) +#else +#define dbg_eba(fmt, ...) ({}) +#endif + +#ifdef CONFIG_MTD_UBI_DEBUG_MSG_WL +/* Messages from the wear-leveling unit */ +#define dbg_wl(fmt, ...) dbg_msg(fmt, ##__VA_ARGS__) +#else +#define dbg_wl(fmt, ...) ({}) +#endif + +#ifdef CONFIG_MTD_UBI_DEBUG_MSG_IO +/* Messages from the input/output unit */ +#define dbg_io(fmt, ...) dbg_msg(fmt, ##__VA_ARGS__) +#else +#define dbg_io(fmt, ...) ({}) +#endif + +#ifdef CONFIG_MTD_UBI_DEBUG_MSG_BLD +/* Initialization and build messages */ +#define dbg_bld(fmt, ...) dbg_msg(fmt, ##__VA_ARGS__) +#else +#define dbg_bld(fmt, ...) ({}) +#endif + +#ifdef CONFIG_MTD_UBI_DEBUG_EMULATE_BITFLIPS +/** + * ubi_dbg_is_bitflip - if it is time to emulate a bit-flip. + * + * Returns non-zero if a bit-flip should be emulated, otherwise returns zero. + */ +static inline int ubi_dbg_is_bitflip(void) +{ + return !(random32() % 200); +} +#else +#define ubi_dbg_is_bitflip() 0 +#endif + +#ifdef CONFIG_MTD_UBI_DEBUG_EMULATE_WRITE_FAILURES +/** + * ubi_dbg_is_write_failure - if it is time to emulate a write failure. + * + * Returns non-zero if a write failure should be emulated, otherwise returns + * zero. + */ +static inline int ubi_dbg_is_write_failure(void) +{ + return !(random32() % 500); +} +#else +#define ubi_dbg_is_write_failure() 0 +#endif + +#ifdef CONFIG_MTD_UBI_DEBUG_EMULATE_ERASE_FAILURES +/** + * ubi_dbg_is_erase_failure - if its time to emulate an erase failure. + * + * Returns non-zero if an erase failure should be emulated, otherwise returns + * zero. + */ +static inline int ubi_dbg_is_erase_failure(void) +{ + return !(random32() % 400); +} +#else +#define ubi_dbg_is_erase_failure() 0 +#endif + +#endif /* !__UBI_DEBUG_H__ */ diff --git a/drivers/mtd/ubi/eba.c b/drivers/mtd/ubi/eba.c new file mode 100644 index 0000000..3f9b780 --- /dev/null +++ b/drivers/mtd/ubi/eba.c @@ -0,0 +1,1256 @@ +/* + * Copyright (c) International Business Machines Corp., 2006 + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See + * the GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + * Author: Artem Bityutskiy (Битюцкий Артём) + */ + +/* + * The UBI Eraseblock Association (EBA) unit. + * + * This unit is responsible for I/O to/from logical eraseblock. + * + * Although in this implementation the EBA table is fully kept and managed in + * RAM, which assumes poor scalability, it might be (partially) maintained on + * flash in future implementations. + * + * The EBA unit implements per-logical eraseblock locking. Before accessing a + * logical eraseblock it is locked for reading or writing. The per-logical + * eraseblock locking is implemented by means of the lock tree. The lock tree + * is an RB-tree which refers all the currently locked logical eraseblocks. The + * lock tree elements are &struct ubi_ltree_entry objects. They are indexed by + * (@vol_id, @lnum) pairs. + * + * EBA also maintains the global sequence counter which is incremented each + * time a logical eraseblock is mapped to a physical eraseblock and it is + * stored in the volume identifier header. This means that each VID header has + * a unique sequence number. The sequence number is only increased an we assume + * 64 bits is enough to never overflow. + */ + +#if 0 +#include <linux/slab.h> +#include <linux/crc32.h> +#include <linux/err.h> +#endif + +#include <ubi_uboot.h> +#include "ubi.h" + +/* Number of physical eraseblocks reserved for atomic LEB change operation */ +#define EBA_RESERVED_PEBS 1 + +/** + * next_sqnum - get next sequence number. + * @ubi: UBI device description object + * + * This function returns next sequence number to use, which is just the current + * global sequence counter value. It also increases the global sequence + * counter. + */ +static unsigned long long next_sqnum(struct ubi_device *ubi) +{ + unsigned long long sqnum; + + spin_lock(&ubi->ltree_lock); + sqnum = ubi->global_sqnum++; + spin_unlock(&ubi->ltree_lock); + + return sqnum; +} + +/** + * ubi_get_compat - get compatibility flags of a volume. + * @ubi: UBI device description object + * @vol_id: volume ID + * + * This function returns compatibility flags for an internal volume. User + * volumes have no compatibility flags, so %0 is returned. + */ +static int ubi_get_compat(const struct ubi_device *ubi, int vol_id) +{ + if (vol_id == UBI_LAYOUT_VOLUME_ID) + return UBI_LAYOUT_VOLUME_COMPAT; + return 0; +} + +/** + * ltree_lookup - look up the lock tree. + * @ubi: UBI device description object + * @vol_id: volume ID + * @lnum: logical eraseblock number + * + * This function returns a pointer to the corresponding &struct ubi_ltree_entry + * object if the logical eraseblock is locked and %NULL if it is not. + * @ubi->ltree_lock has to be locked. + */ +static struct ubi_ltree_entry *ltree_lookup(struct ubi_device *ubi, int vol_id, + int lnum) +{ + struct rb_node *p; + + p = ubi->ltree.rb_node; + while (p) { + struct ubi_ltree_entry *le; + + le = rb_entry(p, struct ubi_ltree_entry, rb); + + if (vol_id < le->vol_id) + p = p->rb_left; + else if (vol_id > le->vol_id) + p = p->rb_right; + else { + if (lnum < le->lnum) + p = p->rb_left; + else if (lnum > le->lnum) + p = p->rb_right; + else + return le; + } + } + + return NULL; +} + +/** + * ltree_add_entry - add new entry to the lock tree. + * @ubi: UBI device description object + * @vol_id: volume ID + * @lnum: logical eraseblock number + * + * This function adds new entry for logical eraseblock (@vol_id, @lnum) to the + * lock tree. If such entry is already there, its usage counter is increased. + * Returns pointer to the lock tree entry or %-ENOMEM if memory allocation + * failed. + */ +static struct ubi_ltree_entry *ltree_add_entry(struct ubi_device *ubi, + int vol_id, int lnum) +{ + struct ubi_ltree_entry *le, *le1, *le_free; + + le = kmalloc(sizeof(struct ubi_ltree_entry), GFP_NOFS); + if (!le) + return ERR_PTR(-ENOMEM); + + le->users = 0; + init_rwsem(&le->mutex); + le->vol_id = vol_id; + le->lnum = lnum; + + spin_lock(&ubi->ltree_lock); + le1 = ltree_lookup(ubi, vol_id, lnum); + + if (le1) { + /* + * This logical eraseblock is already locked. The newly + * allocated lock entry is not needed. + */ + le_free = le; + le = le1; + } else { + struct rb_node **p, *parent = NULL; + + /* + * No lock entry, add the newly allocated one to the + * @ubi->ltree RB-tree. + */ + le_free = NULL; + + p = &ubi->ltree.rb_node; + while (*p) { + parent = *p; + le1 = rb_entry(parent, struct ubi_ltree_entry, rb); + + if (vol_id < le1->vol_id) + p = &(*p)->rb_left; + else if (vol_id > le1->vol_id) + p = &(*p)->rb_right; + else { + ubi_assert(lnum != le1->lnum); + if (lnum < le1->lnum) + p = &(*p)->rb_left; + else + p = &(*p)->rb_right; + } + } + + rb_link_node(&le->rb, parent, p); + rb_insert_color(&le->rb, &ubi->ltree); + } + le->users += 1; + spin_unlock(&ubi->ltree_lock); + + if (le_free) + kfree(le_free); + + return le; +} + +/** + * leb_read_lock - lock logical eraseblock for reading. + * @ubi: UBI device description object + * @vol_id: volume ID + * @lnum: logical eraseblock number + * + * This function locks a logical eraseblock for reading. Returns zero in case + * of success and a negative error code in case of failure. + */ +static int leb_read_lock(struct ubi_device *ubi, int vol_id, int lnum) +{ + struct ubi_ltree_entry *le; + + le = ltree_add_entry(ubi, vol_id, lnum); + if (IS_ERR(le)) + return PTR_ERR(le); + down_read(&le->mutex); + return 0; +} + +/** + * leb_read_unlock - unlock logical eraseblock. + * @ubi: UBI device description object + * @vol_id: volume ID + * @lnum: logical eraseblock number + */ +static void leb_read_unlock(struct ubi_device *ubi, int vol_id, int lnum) +{ + int _free = 0; + struct ubi_ltree_entry *le; + + spin_lock(&ubi->ltree_lock); + le = ltree_lookup(ubi, vol_id, lnum); + le->users -= 1; + ubi_assert(le->users >= 0); + if (le->users == 0) { + rb_erase(&le->rb, &ubi->ltree); + _free = 1; + } + spin_unlock(&ubi->ltree_lock); + + up_read(&le->mutex); + if (_free) + kfree(le); +} + +/** + * leb_write_lock - lock logical eraseblock for writing. + * @ubi: UBI device description object + * @vol_id: volume ID + * @lnum: logical eraseblock number + * + * This function locks a logical eraseblock for writing. Returns zero in case + * of success and a negative error code in case of failure. + */ +static int leb_write_lock(struct ubi_device *ubi, int vol_id, int lnum) +{ + struct ubi_ltree_entry *le; + + le = ltree_add_entry(ubi, vol_id, lnum); + if (IS_ERR(le)) + return PTR_ERR(le); + down_write(&le->mutex); + return 0; +} + +/** + * leb_write_lock - lock logical eraseblock for writing. + * @ubi: UBI device description object + * @vol_id: volume ID + * @lnum: logical eraseblock number + * + * This function locks a logical eraseblock for writing if there is no + * contention and does nothing if there is contention. Returns %0 in case of + * success, %1 in case of contention, and and a negative error code in case of + * failure. + */ +static int leb_write_trylock(struct ubi_device *ubi, int vol_id, int lnum) +{ + int _free; + struct ubi_ltree_entry *le; + + le = ltree_add_entry(ubi, vol_id, lnum); + if (IS_ERR(le)) + return PTR_ERR(le); + if (down_write_trylock(&le->mutex)) + return 0; + + /* Contention, cancel */ + spin_lock(&ubi->ltree_lock); + le->users -= 1; + ubi_assert(le->users >= 0); + if (le->users == 0) { + rb_erase(&le->rb, &ubi->ltree); + _free = 1; + } else + _free = 0; + spin_unlock(&ubi->ltree_lock); + if (_free) + kfree(le); + + return 1; +} + +/** + * leb_write_unlock - unlock logical eraseblock. + * @ubi: UBI device description object + * @vol_id: volume ID + * @lnum: logical eraseblock number + */ +static void leb_write_unlock(struct ubi_device *ubi, int vol_id, int lnum) +{ + int _free; + struct ubi_ltree_entry *le; + + spin_lock(&ubi->ltree_lock); + le = ltree_lookup(ubi, vol_id, lnum); + le->users -= 1; + ubi_assert(le->users >= 0); + if (le->users == 0) { + rb_erase(&le->rb, &ubi->ltree); + _free = 1; + } else + _free = 0; + spin_unlock(&ubi->ltree_lock); + + up_write(&le->mutex); + if (_free) + kfree(le); +} + +/** + * ubi_eba_unmap_leb - un-map logical eraseblock. + * @ubi: UBI device description object + * @vol: volume description object + * @lnum: logical eraseblock number + * + * This function un-maps logical eraseblock @lnum and schedules corresponding + * physical eraseblock for erasure. Returns zero in case of success and a + * negative error code in case of failure. + */ +int ubi_eba_unmap_leb(struct ubi_device *ubi, struct ubi_volume *vol, + int lnum) +{ + int err, pnum, vol_id = vol->vol_id; + + if (ubi->ro_mode) + return -EROFS; + + err = leb_write_lock(ubi, vol_id, lnum); + if (err) + return err; + + pnum = vol->eba_tbl[lnum]; + if (pnum < 0) + /* This logical eraseblock is already unmapped */ + goto out_unlock; + + dbg_eba("erase LEB %d:%d, PEB %d", vol_id, lnum, pnum); + + vol->eba_tbl[lnum] = UBI_LEB_UNMAPPED; + err = ubi_wl_put_peb(ubi, pnum, 0); + +out_unlock: + leb_write_unlock(ubi, vol_id, lnum); + return err; +} + +/** + * ubi_eba_read_leb - read data. + * @ubi: UBI device description object + * @vol: volume description object + * @lnum: logical eraseblock number + * @buf: buffer to store the read data + * @offset: offset from where to read + * @len: how many bytes to read + * @check: data CRC check flag + * + * If the logical eraseblock @lnum is unmapped, @buf is filled with 0xFF + * bytes. The @check flag only makes sense for static volumes and forces + * eraseblock data CRC checking. + * + * In case of success this function returns zero. In case of a static volume, + * if data CRC mismatches - %-EBADMSG is returned. %-EBADMSG may also be + * returned for any volume type if an ECC error was detected by the MTD device + * driver. Other negative error cored may be returned in case of other errors. + */ +int ubi_eba_read_leb(struct ubi_device *ubi, struct ubi_volume *vol, int lnum, + void *buf, int offset, int len, int check) +{ + int err, pnum, scrub = 0, vol_id = vol->vol_id; + struct ubi_vid_hdr *vid_hdr; + uint32_t uninitialized_var(crc); + + err = leb_read_lock(ubi, vol_id, lnum); + if (err) + return err; + + pnum = vol->eba_tbl[lnum]; + if (pnum < 0) { + /* + * The logical eraseblock is not mapped, fill the whole buffer + * with 0xFF bytes. The exception is static volumes for which + * it is an error to read unmapped logical eraseblocks. + */ + dbg_eba("read %d bytes from offset %d of LEB %d:%d (unmapped)", + len, offset, vol_id, lnum); + leb_read_unlock(ubi, vol_id, lnum); + ubi_assert(vol->vol_type != UBI_STATIC_VOLUME); + memset(buf, 0xFF, len); + return 0; + } + + dbg_eba("read %d bytes from offset %d of LEB %d:%d, PEB %d", + len, offset, vol_id, lnum, pnum); + + if (vol->vol_type == UBI_DYNAMIC_VOLUME) + check = 0; + +retry: + if (check) { + vid_hdr = ubi_zalloc_vid_hdr(ubi, GFP_NOFS); + if (!vid_hdr) { + err = -ENOMEM; + goto out_unlock; + } + + err = ubi_io_read_vid_hdr(ubi, pnum, vid_hdr, 1); + if (err && err != UBI_IO_BITFLIPS) { + if (err > 0) { + /* + * The header is either absent or corrupted. + * The former case means there is a bug - + * switch to read-only mode just in case. + * The latter case means a real corruption - we + * may try to recover data. FIXME: but this is + * not implemented. + */ + if (err == UBI_IO_BAD_VID_HDR) { + ubi_warn("bad VID header at PEB %d, LEB" + "%d:%d", pnum, vol_id, lnum); + err = -EBADMSG; + } else + ubi_ro_mode(ubi); + } + goto out_free; + } else if (err == UBI_IO_BITFLIPS) + scrub = 1; + + ubi_assert(lnum < be32_to_cpu(vid_hdr->used_ebs)); + ubi_assert(len == be32_to_cpu(vid_hdr->data_size)); + + crc = be32_to_cpu(vid_hdr->data_crc); + ubi_free_vid_hdr(ubi, vid_hdr); + } + + err = ubi_io_read_data(ubi, buf, pnum, offset, len); + if (err) { + if (err == UBI_IO_BITFLIPS) { + scrub = 1; + err = 0; + } else if (err == -EBADMSG) { + if (vol->vol_type == UBI_DYNAMIC_VOLUME) + goto out_unlock; + scrub = 1; + if (!check) { + ubi_msg("force data checking"); + check = 1; + goto retry; + } + } else + goto out_unlock; + } + + if (check) { + uint32_t crc1 = crc32(UBI_CRC32_INIT, buf, len); + if (crc1 != crc) { + ubi_warn("CRC error: calculated %#08x, must be %#08x", + crc1, crc); + err = -EBADMSG; + goto out_unlock; + } + } + + if (scrub) + err = ubi_wl_scrub_peb(ubi, pnum); + + leb_read_unlock(ubi, vol_id, lnum); + return err; + +out_free: + ubi_free_vid_hdr(ubi, vid_hdr); +out_unlock: + leb_read_unlock(ubi, vol_id, lnum); + return err; +} + +/** + * recover_peb - recover from write failure. + * @ubi: UBI device description object + * @pnum: the physical eraseblock to recover + * @vol_id: volume ID + * @lnum: logical eraseblock number + * @buf: data which was not written because of the write failure + * @offset: offset of the failed write + * @len: how many bytes should have been written + * + * This function is called in case of a write failure and moves all good data + * from the potentially bad physical eraseblock to a good physical eraseblock. + * This function also writes the data which was not written due to the failure. + * Returns new physical eraseblock number in case of success, and a negative + * error code in case of failure. + */ +static int recover_peb(struct ubi_device *ubi, int pnum, int vol_id, int lnum, + const void *buf, int offset, int len) +{ + int err, idx = vol_id2idx(ubi, vol_id), new_pnum, data_size, tries = 0; + struct ubi_volume *vol = ubi->volumes[idx]; + struct ubi_vid_hdr *vid_hdr; + + vid_hdr = ubi_zalloc_vid_hdr(ubi, GFP_NOFS); + if (!vid_hdr) { + return -ENOMEM; + } + + mutex_lock(&ubi->buf_mutex); + +retry: + new_pnum = ubi_wl_get_peb(ubi, UBI_UNKNOWN); + if (new_pnum < 0) { + mutex_unlock(&ubi->buf_mutex); + ubi_free_vid_hdr(ubi, vid_hdr); + return new_pnum; + } + + ubi_msg("recover PEB %d, move data to PEB %d", pnum, new_pnum); + + err = ubi_io_read_vid_hdr(ubi, pnum, vid_hdr, 1); + if (err && err != UBI_IO_BITFLIPS) { + if (err > 0) + err = -EIO; + goto out_put; + } + + vid_hdr->sqnum = cpu_to_be64(next_sqnum(ubi)); + err = ubi_io_write_vid_hdr(ubi, new_pnum, vid_hdr); + if (err) + goto write_error; + + data_size = offset + len; + memset(ubi->peb_buf1 + offset, 0xFF, len); + + /* Read everything before the area where the write failure happened */ + if (offset > 0) { + err = ubi_io_read_data(ubi, ubi->peb_buf1, pnum, 0, offset); + if (err && err != UBI_IO_BITFLIPS) + goto out_put; + } + + memcpy(ubi->peb_buf1 + offset, buf, len); + + err = ubi_io_write_data(ubi, ubi->peb_buf1, new_pnum, 0, data_size); + if (err) + goto write_error; + + mutex_unlock(&ubi->buf_mutex); + ubi_free_vid_hdr(ubi, vid_hdr); + + vol->eba_tbl[lnum] = new_pnum; + ubi_wl_put_peb(ubi, pnum, 1); + + ubi_msg("data was successfully recovered"); + return 0; + +out_put: + mutex_unlock(&ubi->buf_mutex); + ubi_wl_put_peb(ubi, new_pnum, 1); + ubi_free_vid_hdr(ubi, vid_hdr); + return err; + +write_error: + /* + * Bad luck? This physical eraseblock is bad too? Crud. Let's try to + * get another one. + */ + ubi_warn("failed to write to PEB %d", new_pnum); + ubi_wl_put_peb(ubi, new_pnum, 1); + if (++tries > UBI_IO_RETRIES) { + mutex_unlock(&ubi->buf_mutex); + ubi_free_vid_hdr(ubi, vid_hdr); + return err; + } + ubi_msg("try again"); + goto retry; +} + +/** + * ubi_eba_write_leb - write data to dynamic volume. + * @ubi: UBI device description object + * @vol: volume description object + * @lnum: logical eraseblock number + * @buf: the data to write + * @offset: offset within the logical eraseblock where to write + * @len: how many bytes to write + * @dtype: data type + * + * This function writes data to logical eraseblock @lnum of a dynamic volume + * @vol. Returns zero in case of success and a negative error code in case + * of failure. In case of error, it is possible that something was still + * written to the flash media, but may be some garbage. + */ +int ubi_eba_write_leb(struct ubi_device *ubi, struct ubi_volume *vol, int lnum, + const void *buf, int offset, int len, int dtype) +{ + int err, pnum, tries = 0, vol_id = vol->vol_id; + struct ubi_vid_hdr *vid_hdr; + + if (ubi->ro_mode) + return -EROFS; + + err = leb_write_lock(ubi, vol_id, lnum); + if (err) + return err; + + pnum = vol->eba_tbl[lnum]; + if (pnum >= 0) { + dbg_eba("write %d bytes at offset %d of LEB %d:%d, PEB %d", + len, offset, vol_id, lnum, pnum); + + err = ubi_io_write_data(ubi, buf, pnum, offset, len); + if (err) { + ubi_warn("failed to write data to PEB %d", pnum); + if (err == -EIO && ubi->bad_allowed) + err = recover_peb(ubi, pnum, vol_id, lnum, buf, + offset, len); + if (err) + ubi_ro_mode(ubi); + } + leb_write_unlock(ubi, vol_id, lnum); + return err; + } + + /* + * The logical eraseblock is not mapped. We have to get a free physical + * eraseblock and write the volume identifier header there first. + */ + vid_hdr = ubi_zalloc_vid_hdr(ubi, GFP_NOFS); + if (!vid_hdr) { + leb_write_unlock(ubi, vol_id, lnum); + return -ENOMEM; + } + + vid_hdr->vol_type = UBI_VID_DYNAMIC; + vid_hdr->sqnum = cpu_to_be64(next_sqnum(ubi)); + vid_hdr->vol_id = cpu_to_be32(vol_id); + vid_hdr->lnum = cpu_to_be32(lnum); + vid_hdr->compat = ubi_get_compat(ubi, vol_id); + vid_hdr->data_pad = cpu_to_be32(vol->data_pad); + +retry: + pnum = ubi_wl_get_peb(ubi, dtype); + if (pnum < 0) { + ubi_free_vid_hdr(ubi, vid_hdr); + leb_write_unlock(ubi, vol_id, lnum); + return pnum; + } + + dbg_eba("write VID hdr and %d bytes at offset %d of LEB %d:%d, PEB %d", + len, offset, vol_id, lnum, pnum); + + err = ubi_io_write_vid_hdr(ubi, pnum, vid_hdr); + if (err) { + ubi_warn("failed to write VID header to LEB %d:%d, PEB %d", + vol_id, lnum, pnum); + goto write_error; + } + + if (len) { + err = ubi_io_write_data(ubi, buf, pnum, offset, len); + if (err) { + ubi_warn("failed to write %d bytes at offset %d of " + "LEB %d:%d, PEB %d", len, offset, vol_id, + lnum, pnum); + goto write_error; + } + } + + vol->eba_tbl[lnum] = pnum; + + leb_write_unlock(ubi, vol_id, lnum); + ubi_free_vid_hdr(ubi, vid_hdr); + return 0; + +write_error: + if (err != -EIO || !ubi->bad_allowed) { + ubi_ro_mode(ubi); + leb_write_unlock(ubi, vol_id, lnum); + ubi_free_vid_hdr(ubi, vid_hdr); + return err; + } + + /* + * Fortunately, this is the first write operation to this physical + * eraseblock, so just put it and request a new one. We assume that if + * this physical eraseblock went bad, the erase code will handle that. + */ + err = ubi_wl_put_peb(ubi, pnum, 1); + if (err || ++tries > UBI_IO_RETRIES) { + ubi_ro_mode(ubi); + leb_write_unlock(ubi, vol_id, lnum); + ubi_free_vid_hdr(ubi, vid_hdr); + return err; + } + + vid_hdr->sqnum = cpu_to_be64(next_sqnum(ubi)); + ubi_msg("try another PEB"); + goto retry; +} + +/** + * ubi_eba_write_leb_st - write data to static volume. + * @ubi: UBI device description object + * @vol: volume description object + * @lnum: logical eraseblock number + * @buf: data to write + * @len: how many bytes to write + * @dtype: data type + * @used_ebs: how many logical eraseblocks will this volume contain + * + * This function writes data to logical eraseblock @lnum of static volume + * @vol. The @used_ebs argument should contain total number of logical + * eraseblock in this static volume. + * + * When writing to the last logical eraseblock, the @len argument doesn't have + * to be aligned to the minimal I/O unit size. Instead, it has to be equivalent + * to the real data size, although the @buf buffer has to contain the + * alignment. In all other cases, @len has to be aligned. + * + * It is prohibited to write more then once to logical eraseblocks of static + * volumes. This function returns zero in case of success and a negative error + * code in case of failure. + */ +int ubi_eba_write_leb_st(struct ubi_device *ubi, struct ubi_volume *vol, + int lnum, const void *buf, int len, int dtype, + int used_ebs) +{ + int err, pnum, tries = 0, data_size = len, vol_id = vol->vol_id; + struct ubi_vid_hdr *vid_hdr; + uint32_t crc; + + if (ubi->ro_mode) + return -EROFS; + + if (lnum == used_ebs - 1) + /* If this is the last LEB @len may be unaligned */ + len = ALIGN(data_size, ubi->min_io_size); + else + ubi_assert(!(len & (ubi->min_io_size - 1))); + + vid_hdr = ubi_zalloc_vid_hdr(ubi, GFP_NOFS); + if (!vid_hdr) + return -ENOMEM; + + err = leb_write_lock(ubi, vol_id, lnum); + if (err) { + ubi_free_vid_hdr(ubi, vid_hdr); + return err; + } + + vid_hdr->sqnum = cpu_to_be64(next_sqnum(ubi)); + vid_hdr->vol_id = cpu_to_be32(vol_id); + vid_hdr->lnum = cpu_to_be32(lnum); + vid_hdr->compat = ubi_get_compat(ubi, vol_id); + vid_hdr->data_pad = cpu_to_be32(vol->data_pad); + + crc = crc32(UBI_CRC32_INIT, buf, data_size); + vid_hdr->vol_type = UBI_VID_STATIC; + vid_hdr->data_size = cpu_to_be32(data_size); + vid_hdr->used_ebs = cpu_to_be32(used_ebs); + vid_hdr->data_crc = cpu_to_be32(crc); + +retry: + pnum = ubi_wl_get_peb(ubi, dtype); + if (pnum < 0) { + ubi_free_vid_hdr(ubi, vid_hdr); + leb_write_unlock(ubi, vol_id, lnum); + return pnum; + } + + dbg_eba("write VID hdr and %d bytes at LEB %d:%d, PEB %d, used_ebs %d", + len, vol_id, lnum, pnum, used_ebs); + + err = ubi_io_write_vid_hdr(ubi, pnum, vid_hdr); + if (err) { + ubi_warn("failed to write VID header to LEB %d:%d, PEB %d", + vol_id, lnum, pnum); + goto write_error; + } + + err = ubi_io_write_data(ubi, buf, pnum, 0, len); + if (err) { + ubi_warn("failed to write %d bytes of data to PEB %d", + len, pnum); + goto write_error; + } + + ubi_assert(vol->eba_tbl[lnum] < 0); + vol->eba_tbl[lnum] = pnum; + + leb_write_unlock(ubi, vol_id, lnum); + ubi_free_vid_hdr(ubi, vid_hdr); + return 0; + +write_error: + if (err != -EIO || !ubi->bad_allowed) { + /* + * This flash device does not admit of bad eraseblocks or + * something nasty and unexpected happened. Switch to read-only + * mode just in case. + */ + ubi_ro_mode(ubi); + leb_write_unlock(ubi, vol_id, lnum); + ubi_free_vid_hdr(ubi, vid_hdr); + return err; + } + + err = ubi_wl_put_peb(ubi, pnum, 1); + if (err || ++tries > UBI_IO_RETRIES) { + ubi_ro_mode(ubi); + leb_write_unlock(ubi, vol_id, lnum); + ubi_free_vid_hdr(ubi, vid_hdr); + return err; + } + + vid_hdr->sqnum = cpu_to_be64(next_sqnum(ubi)); + ubi_msg("try another PEB"); + goto retry; +} + +/* + * ubi_eba_atomic_leb_change - change logical eraseblock atomically. + * @ubi: UBI device description object + * @vol: volume description object + * @lnum: logical eraseblock number + * @buf: data to write + * @len: how many bytes to write + * @dtype: data type + * + * This function changes the contents of a logical eraseblock atomically. @buf + * has to contain new logical eraseblock data, and @len - the length of the + * data, which has to be aligned. This function guarantees that in case of an + * unclean reboot the old contents is preserved. Returns zero in case of + * success and a negative error code in case of failure. + * + * UBI reserves one LEB for the "atomic LEB change" operation, so only one + * LEB change may be done at a time. This is ensured by @ubi->alc_mutex. + */ +int ubi_eba_atomic_leb_change(struct ubi_device *ubi, struct ubi_volume *vol, + int lnum, const void *buf, int len, int dtype) +{ + int err, pnum, tries = 0, vol_id = vol->vol_id; + struct ubi_vid_hdr *vid_hdr; + uint32_t crc; + + if (ubi->ro_mode) + return -EROFS; + + if (len == 0) { + /* + * Special case when data length is zero. In this case the LEB + * has to be unmapped and mapped somewhere else. + */ + err = ubi_eba_unmap_leb(ubi, vol, lnum); + if (err) + return err; + return ubi_eba_write_leb(ubi, vol, lnum, NULL, 0, 0, dtype); + } + + vid_hdr = ubi_zalloc_vid_hdr(ubi, GFP_NOFS); + if (!vid_hdr) + return -ENOMEM; + + mutex_lock(&ubi->alc_mutex); + err = leb_write_lock(ubi, vol_id, lnum); + if (err) + goto out_mutex; + + vid_hdr->sqnum = cpu_to_be64(next_sqnum(ubi)); + vid_hdr->vol_id = cpu_to_be32(vol_id); + vid_hdr->lnum = cpu_to_be32(lnum); + vid_hdr->compat = ubi_get_compat(ubi, vol_id); + vid_hdr->data_pad = cpu_to_be32(vol->data_pad); + + crc = crc32(UBI_CRC32_INIT, buf, len); + vid_hdr->vol_type = UBI_VID_DYNAMIC; + vid_hdr->data_size = cpu_to_be32(len); + vid_hdr->copy_flag = 1; + vid_hdr->data_crc = cpu_to_be32(crc); + +retry: + pnum = ubi_wl_get_peb(ubi, dtype); + if (pnum < 0) { + err = pnum; + goto out_leb_unlock; + } + + dbg_eba("change LEB %d:%d, PEB %d, write VID hdr to PEB %d", + vol_id, lnum, vol->eba_tbl[lnum], pnum); + + err = ubi_io_write_vid_hdr(ubi, pnum, vid_hdr); + if (err) { + ubi_warn("failed to write VID header to LEB %d:%d, PEB %d", + vol_id, lnum, pnum); + goto write_error; + } + + err = ubi_io_write_data(ubi, buf, pnum, 0, len); + if (err) { + ubi_warn("failed to write %d bytes of data to PEB %d", + len, pnum); + goto write_error; + } + + if (vol->eba_tbl[lnum] >= 0) { + err = ubi_wl_put_peb(ubi, vol->eba_tbl[lnum], 1); + if (err) + goto out_leb_unlock; + } + + vol->eba_tbl[lnum] = pnum; + +out_leb_unlock: + leb_write_unlock(ubi, vol_id, lnum); +out_mutex: + mutex_unlock(&ubi->alc_mutex); + ubi_free_vid_hdr(ubi, vid_hdr); + return err; + +write_error: + if (err != -EIO || !ubi->bad_allowed) { + /* + * This flash device does not admit of bad eraseblocks or + * something nasty and unexpected happened. Switch to read-only + * mode just in case. + */ + ubi_ro_mode(ubi); + goto out_leb_unlock; + } + + err = ubi_wl_put_peb(ubi, pnum, 1); + if (err || ++tries > UBI_IO_RETRIES) { + ubi_ro_mode(ubi); + goto out_leb_unlock; + } + + vid_hdr->sqnum = cpu_to_be64(next_sqnum(ubi)); + ubi_msg("try another PEB"); + goto retry; +} + +/** + * ubi_eba_copy_leb - copy logical eraseblock. + * @ubi: UBI device description object + * @from: physical eraseblock number from where to copy + * @to: physical eraseblock number where to copy + * @vid_hdr: VID header of the @from physical eraseblock + * + * This function copies logical eraseblock from physical eraseblock @from to + * physical eraseblock @to. The @vid_hdr buffer may be changed by this + * function. Returns: + * o %0 in case of success; + * o %1 if the operation was canceled and should be tried later (e.g., + * because a bit-flip was detected at the target PEB); + * o %2 if the volume is being deleted and this LEB should not be moved. + */ +int ubi_eba_copy_leb(struct ubi_device *ubi, int from, int to, + struct ubi_vid_hdr *vid_hdr) +{ + int err, vol_id, lnum, data_size, aldata_size, idx; + struct ubi_volume *vol; + uint32_t crc; + + vol_id = be32_to_cpu(vid_hdr->vol_id); + lnum = be32_to_cpu(vid_hdr->lnum); + + dbg_eba("copy LEB %d:%d, PEB %d to PEB %d", vol_id, lnum, from, to); + + if (vid_hdr->vol_type == UBI_VID_STATIC) { + data_size = be32_to_cpu(vid_hdr->data_size); + aldata_size = ALIGN(data_size, ubi->min_io_size); + } else + data_size = aldata_size = + ubi->leb_size - be32_to_cpu(vid_hdr->data_pad); + + idx = vol_id2idx(ubi, vol_id); + spin_lock(&ubi->volumes_lock); + /* + * Note, we may race with volume deletion, which means that the volume + * this logical eraseblock belongs to might be being deleted. Since the + * volume deletion unmaps all the volume's logical eraseblocks, it will + * be locked in 'ubi_wl_put_peb()' and wait for the WL worker to finish. + */ + vol = ubi->volumes[idx]; + if (!vol) { + /* No need to do further work, cancel */ + dbg_eba("volume %d is being removed, cancel", vol_id); + spin_unlock(&ubi->volumes_lock); + return 2; + } + spin_unlock(&ubi->volumes_lock); + + /* + * We do not want anybody to write to this logical eraseblock while we + * are moving it, so lock it. + * + * Note, we are using non-waiting locking here, because we cannot sleep + * on the LEB, since it may cause deadlocks. Indeed, imagine a task is + * unmapping the LEB which is mapped to the PEB we are going to move + * (@from). This task locks the LEB and goes sleep in the + * 'ubi_wl_put_peb()' function on the @ubi->move_mutex. In turn, we are + * holding @ubi->move_mutex and go sleep on the LEB lock. So, if the + * LEB is already locked, we just do not move it and return %1. + */ + err = leb_write_trylock(ubi, vol_id, lnum); + if (err) { + dbg_eba("contention on LEB %d:%d, cancel", vol_id, lnum); + return err; + } + + /* + * The LEB might have been put meanwhile, and the task which put it is + * probably waiting on @ubi->move_mutex. No need to continue the work, + * cancel it. + */ + if (vol->eba_tbl[lnum] != from) { + dbg_eba("LEB %d:%d is no longer mapped to PEB %d, mapped to " + "PEB %d, cancel", vol_id, lnum, from, + vol->eba_tbl[lnum]); + err = 1; + goto out_unlock_leb; + } + + /* + * OK, now the LEB is locked and we can safely start moving iy. Since + * this function utilizes thie @ubi->peb1_buf buffer which is shared + * with some other functions, so lock the buffer by taking the + * @ubi->buf_mutex. + */ + mutex_lock(&ubi->buf_mutex); + dbg_eba("read %d bytes of data", aldata_size); + err = ubi_io_read_data(ubi, ubi->peb_buf1, from, 0, aldata_size); + if (err && err != UBI_IO_BITFLIPS) { + ubi_warn("error %d while reading data from PEB %d", + err, from); + goto out_unlock_buf; + } + + /* + * Now we have got to calculate how much data we have to to copy. In + * case of a static volume it is fairly easy - the VID header contains + * the data size. In case of a dynamic volume it is more difficult - we + * have to read the contents, cut 0xFF bytes from the end and copy only + * the first part. We must do this to avoid writing 0xFF bytes as it + * may have some side-effects. And not only this. It is important not + * to include those 0xFFs to CRC because later the they may be filled + * by data. + */ + if (vid_hdr->vol_type == UBI_VID_DYNAMIC) + aldata_size = data_size = + ubi_calc_data_len(ubi, ubi->peb_buf1, data_size); + + cond_resched(); + crc = crc32(UBI_CRC32_INIT, ubi->peb_buf1, data_size); + cond_resched(); + + /* + * It may turn out to me that the whole @from physical eraseblock + * contains only 0xFF bytes. Then we have to only write the VID header + * and do not write any data. This also means we should not set + * @vid_hdr->copy_flag, @vid_hdr->data_size, and @vid_hdr->data_crc. + */ + if (data_size > 0) { + vid_hdr->copy_flag = 1; + vid_hdr->data_size = cpu_to_be32(data_size); + vid_hdr->data_crc = cpu_to_be32(crc); + } + vid_hdr->sqnum = cpu_to_be64(next_sqnum(ubi)); + + err = ubi_io_write_vid_hdr(ubi, to, vid_hdr); + if (err) + goto out_unlock_buf; + + cond_resched(); + + /* Read the VID header back and check if it was written correctly */ + err = ubi_io_read_vid_hdr(ubi, to, vid_hdr, 1); + if (err) { + if (err != UBI_IO_BITFLIPS) + ubi_warn("cannot read VID header back from PEB %d", to); + else + err = 1; + goto out_unlock_buf; + } + + if (data_size > 0) { + err = ubi_io_write_data(ubi, ubi->peb_buf1, to, 0, aldata_size); + if (err) + goto out_unlock_buf; + + cond_resched(); + + /* + * We've written the data and are going to read it back to make + * sure it was written correctly. + */ + + err = ubi_io_read_data(ubi, ubi->peb_buf2, to, 0, aldata_size); + if (err) { + if (err != UBI_IO_BITFLIPS) + ubi_warn("cannot read data back from PEB %d", + to); + else + err = 1; + goto out_unlock_buf; + } + + cond_resched(); + + if (memcmp(ubi->peb_buf1, ubi->peb_buf2, aldata_size)) { + ubi_warn("read data back from PEB %d - it is different", + to); + goto out_unlock_buf; + } + } + + ubi_assert(vol->eba_tbl[lnum] == from); + vol->eba_tbl[lnum] = to; + +out_unlock_buf: + mutex_unlock(&ubi->buf_mutex); +out_unlock_leb: + leb_write_unlock(ubi, vol_id, lnum); + return err; +} + +/** + * ubi_eba_init_scan - initialize the EBA unit using scanning information. + * @ubi: UBI device description object + * @si: scanning information + * + * This function returns zero in case of success and a negative error code in + * case of failure. + */ +int ubi_eba_init_scan(struct ubi_device *ubi, struct ubi_scan_info *si) +{ + int i, j, err, num_volumes; + struct ubi_scan_volume *sv; + struct ubi_volume *vol; + struct ubi_scan_leb *seb; + struct rb_node *rb; + + dbg_eba("initialize EBA unit"); + + spin_lock_init(&ubi->ltree_lock); + mutex_init(&ubi->alc_mutex); + ubi->ltree = RB_ROOT; + + ubi->global_sqnum = si->max_sqnum + 1; + num_volumes = ubi->vtbl_slots + UBI_INT_VOL_COUNT; + + for (i = 0; i < num_volumes; i++) { + vol = ubi->volumes[i]; + if (!vol) + continue; + + cond_resched(); + + vol->eba_tbl = kmalloc(vol->reserved_pebs * sizeof(int), + GFP_KERNEL); + if (!vol->eba_tbl) { + err = -ENOMEM; + goto out_free; + } + + for (j = 0; j < vol->reserved_pebs; j++) + vol->eba_tbl[j] = UBI_LEB_UNMAPPED; + + sv = ubi_scan_find_sv(si, idx2vol_id(ubi, i)); + if (!sv) + continue; + + ubi_rb_for_each_entry(rb, seb, &sv->root, u.rb) { + if (seb->lnum >= vol->reserved_pebs) + /* + * This may happen in case of an unclean reboot + * during re-size. + */ + ubi_scan_move_to_list(sv, seb, &si->erase); + vol->eba_tbl[seb->lnum] = seb->pnum; + } + } + + if (ubi->avail_pebs < EBA_RESERVED_PEBS) { + ubi_err("no enough physical eraseblocks (%d, need %d)", + ubi->avail_pebs, EBA_RESERVED_PEBS); + err = -ENOSPC; + goto out_free; + } + ubi->avail_pebs -= EBA_RESERVED_PEBS; + ubi->rsvd_pebs += EBA_RESERVED_PEBS; + + if (ubi->bad_allowed) { + ubi_calculate_reserved(ubi); + + if (ubi->avail_pebs < ubi->beb_rsvd_level) { + /* No enough free physical eraseblocks */ + ubi->beb_rsvd_pebs = ubi->avail_pebs; + ubi_warn("cannot reserve enough PEBs for bad PEB " + "handling, reserved %d, need %d", + ubi->beb_rsvd_pebs, ubi->beb_rsvd_level); + } else + ubi->beb_rsvd_pebs = ubi->beb_rsvd_level; + + ubi->avail_pebs -= ubi->beb_rsvd_pebs; + ubi->rsvd_pebs += ubi->beb_rsvd_pebs; + } + + dbg_eba("EBA unit is initialized"); + return 0; + +out_free: + for (i = 0; i < num_volumes; i++) { + if (!ubi->volumes[i]) + continue; + kfree(ubi->volumes[i]->eba_tbl); + } + return err; +} + +/** + * ubi_eba_close - close EBA unit. + * @ubi: UBI device description object + */ +void ubi_eba_close(const struct ubi_device *ubi) +{ + int i, num_volumes = ubi->vtbl_slots + UBI_INT_VOL_COUNT; + + dbg_eba("close EBA unit"); + + for (i = 0; i < num_volumes; i++) { + if (!ubi->volumes[i]) + continue; + kfree(ubi->volumes[i]->eba_tbl); + } +} diff --git a/drivers/mtd/ubi/io.c b/drivers/mtd/ubi/io.c new file mode 100644 index 0000000..3387d7e --- /dev/null +++ b/drivers/mtd/ubi/io.c @@ -0,0 +1,1274 @@ +/* + * Copyright (c) International Business Machines Corp., 2006 + * Copyright (c) Nokia Corporation, 2006, 2007 + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See + * the GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + * Author: Artem Bityutskiy (Битюцкий Артём) + */ + +/* + * UBI input/output unit. + * + * This unit provides a uniform way to work with all kinds of the underlying + * MTD devices. It also implements handy functions for reading and writing UBI + * headers. + * + * We are trying to have a paranoid mindset and not to trust to what we read + * from the flash media in order to be more secure and robust. So this unit + * validates every single header it reads from the flash media. + * + * Some words about how the eraseblock headers are stored. + * + * The erase counter header is always stored at offset zero. By default, the + * VID header is stored after the EC header at the closest aligned offset + * (i.e. aligned to the minimum I/O unit size). Data starts next to the VID + * header at the closest aligned offset. But this default layout may be + * changed. For example, for different reasons (e.g., optimization) UBI may be + * asked to put the VID header at further offset, and even at an unaligned + * offset. Of course, if the offset of the VID header is unaligned, UBI adds + * proper padding in front of it. Data offset may also be changed but it has to + * be aligned. + * + * About minimal I/O units. In general, UBI assumes flash device model where + * there is only one minimal I/O unit size. E.g., in case of NOR flash it is 1, + * in case of NAND flash it is a NAND page, etc. This is reported by MTD in the + * @ubi->mtd->writesize field. But as an exception, UBI admits of using another + * (smaller) minimal I/O unit size for EC and VID headers to make it possible + * to do different optimizations. + * + * This is extremely useful in case of NAND flashes which admit of several + * write operations to one NAND page. In this case UBI can fit EC and VID + * headers at one NAND page. Thus, UBI may use "sub-page" size as the minimal + * I/O unit for the headers (the @ubi->hdrs_min_io_size field). But it still + * reports NAND page size (@ubi->min_io_size) as a minimal I/O unit for the UBI + * users. + * + * Example: some Samsung NANDs with 2KiB pages allow 4x 512-byte writes, so + * although the minimal I/O unit is 2K, UBI uses 512 bytes for EC and VID + * headers. + * + * Q: why not just to treat sub-page as a minimal I/O unit of this flash + * device, e.g., make @ubi->min_io_size = 512 in the example above? + * + * A: because when writing a sub-page, MTD still writes a full 2K page but the + * bytes which are no relevant to the sub-page are 0xFF. So, basically, writing + * 4x512 sub-pages is 4 times slower then writing one 2KiB NAND page. Thus, we + * prefer to use sub-pages only for EV and VID headers. + * + * As it was noted above, the VID header may start at a non-aligned offset. + * For example, in case of a 2KiB page NAND flash with a 512 bytes sub-page, + * the VID header may reside at offset 1984 which is the last 64 bytes of the + * last sub-page (EC header is always at offset zero). This causes some + * difficulties when reading and writing VID headers. + * + * Suppose we have a 64-byte buffer and we read a VID header at it. We change + * the data and want to write this VID header out. As we can only write in + * 512-byte chunks, we have to allocate one more buffer and copy our VID header + * to offset 448 of this buffer. + * + * The I/O unit does the following trick in order to avoid this extra copy. + * It always allocates a @ubi->vid_hdr_alsize bytes buffer for the VID header + * and returns a pointer to offset @ubi->vid_hdr_shift of this buffer. When the + * VID header is being written out, it shifts the VID header pointer back and + * writes the whole sub-page. + */ + +#if 0 +#include <linux/crc32.h> +#include <linux/err.h> +#endif + +#include <ubi_uboot.h> +#include "ubi.h" + +#ifdef CONFIG_MTD_UBI_DEBUG_PARANOID +static int paranoid_check_not_bad(const struct ubi_device *ubi, int pnum); +static int paranoid_check_peb_ec_hdr(const struct ubi_device *ubi, int pnum); +static int paranoid_check_ec_hdr(const struct ubi_device *ubi, int pnum, + const struct ubi_ec_hdr *ec_hdr); +static int paranoid_check_peb_vid_hdr(const struct ubi_device *ubi, int pnum); +static int paranoid_check_vid_hdr(const struct ubi_device *ubi, int pnum, + const struct ubi_vid_hdr *vid_hdr); +static int paranoid_check_all_ff(struct ubi_device *ubi, int pnum, int offset, + int len); +#else +#define paranoid_check_not_bad(ubi, pnum) 0 +#define paranoid_check_peb_ec_hdr(ubi, pnum) 0 +#define paranoid_check_ec_hdr(ubi, pnum, ec_hdr) 0 +#define paranoid_check_peb_vid_hdr(ubi, pnum) 0 +#define paranoid_check_vid_hdr(ubi, pnum, vid_hdr) 0 +#define paranoid_check_all_ff(ubi, pnum, offset, len) 0 +#endif + +/** + * ubi_io_read - read data from a physical eraseblock. + * @ubi: UBI device description object + * @buf: buffer where to store the read data + * @pnum: physical eraseblock number to read from + * @offset: offset within the physical eraseblock from where to read + * @len: how many bytes to read + * + * This function reads data from offset @offset of physical eraseblock @pnum + * and stores the read data in the @buf buffer. The following return codes are + * possible: + * + * o %0 if all the requested data were successfully read; + * o %UBI_IO_BITFLIPS if all the requested data were successfully read, but + * correctable bit-flips were detected; this is harmless but may indicate + * that this eraseblock may become bad soon (but do not have to); + * o %-EBADMSG if the MTD subsystem reported about data integrity problems, for + * example it can be an ECC error in case of NAND; this most probably means + * that the data is corrupted; + * o %-EIO if some I/O error occurred; + * o other negative error codes in case of other errors. + */ +int ubi_io_read(const struct ubi_device *ubi, void *buf, int pnum, int offset, + int len) +{ + int err, retries = 0; + size_t read; + loff_t addr; + + dbg_io("read %d bytes from PEB %d:%d", len, pnum, offset); + + ubi_assert(pnum >= 0 && pnum < ubi->peb_count); + ubi_assert(offset >= 0 && offset + len <= ubi->peb_size); + ubi_assert(len > 0); + + err = paranoid_check_not_bad(ubi, pnum); + if (err) + return err > 0 ? -EINVAL : err; + + addr = (loff_t)pnum * ubi->peb_size + offset; +retry: + err = ubi->mtd->read(ubi->mtd, addr, len, &read, buf); + if (err) { + if (err == -EUCLEAN) { + /* + * -EUCLEAN is reported if there was a bit-flip which + * was corrected, so this is harmless. + */ + ubi_msg("fixable bit-flip detected at PEB %d", pnum); + ubi_assert(len == read); + return UBI_IO_BITFLIPS; + } + + if (read != len && retries++ < UBI_IO_RETRIES) { + dbg_io("error %d while reading %d bytes from PEB %d:%d, " + "read only %zd bytes, retry", + err, len, pnum, offset, read); + yield(); + goto retry; + } + + ubi_err("error %d while reading %d bytes from PEB %d:%d, " + "read %zd bytes", err, len, pnum, offset, read); + ubi_dbg_dump_stack(); + + /* + * The driver should never return -EBADMSG if it failed to read + * all the requested data. But some buggy drivers might do + * this, so we change it to -EIO. + */ + if (read != len && err == -EBADMSG) { + ubi_assert(0); + printk("%s[%d] not here\n", __func__, __LINE__); +// err = -EIO; + } + } else { + ubi_assert(len == read); + + if (ubi_dbg_is_bitflip()) { + dbg_msg("bit-flip (emulated)"); + err = UBI_IO_BITFLIPS; + } + } + + return err; +} + +/** + * ubi_io_write - write data to a physical eraseblock. + * @ubi: UBI device description object + * @buf: buffer with the data to write + * @pnum: physical eraseblock number to write to + * @offset: offset within the physical eraseblock where to write + * @len: how many bytes to write + * + * This function writes @len bytes of data from buffer @buf to offset @offset + * of physical eraseblock @pnum. If all the data were successfully written, + * zero is returned. If an error occurred, this function returns a negative + * error code. If %-EIO is returned, the physical eraseblock most probably went + * bad. + * + * Note, in case of an error, it is possible that something was still written + * to the flash media, but may be some garbage. + */ +int ubi_io_write(struct ubi_device *ubi, const void *buf, int pnum, int offset, + int len) +{ + int err; + size_t written; + loff_t addr; + + dbg_io("write %d bytes to PEB %d:%d", len, pnum, offset); + + ubi_assert(pnum >= 0 && pnum < ubi->peb_count); + ubi_assert(offset >= 0 && offset + len <= ubi->peb_size); + ubi_assert(offset % ubi->hdrs_min_io_size == 0); + ubi_assert(len > 0 && len % ubi->hdrs_min_io_size == 0); + + if (ubi->ro_mode) { + ubi_err("read-only mode"); + return -EROFS; + } + + /* The below has to be compiled out if paranoid checks are disabled */ + + err = paranoid_check_not_bad(ubi, pnum); + if (err) + return err > 0 ? -EINVAL : err; + + /* The area we are writing to has to contain all 0xFF bytes */ + err = paranoid_check_all_ff(ubi, pnum, offset, len); + if (err) + return err > 0 ? -EINVAL : err; + + if (offset >= ubi->leb_start) { + /* + * We write to the data area of the physical eraseblock. Make + * sure it has valid EC and VID headers. + */ + err = paranoid_check_peb_ec_hdr(ubi, pnum); + if (err) + return err > 0 ? -EINVAL : err; + err = paranoid_check_peb_vid_hdr(ubi, pnum); + if (err) + return err > 0 ? -EINVAL : err; + } + + if (ubi_dbg_is_write_failure()) { + dbg_err("cannot write %d bytes to PEB %d:%d " + "(emulated)", len, pnum, offset); + ubi_dbg_dump_stack(); + return -EIO; + } + + addr = (loff_t)pnum * ubi->peb_size + offset; + err = ubi->mtd->write(ubi->mtd, addr, len, &written, buf); + if (err) { + ubi_err("error %d while writing %d bytes to PEB %d:%d, written" + " %zd bytes", err, len, pnum, offset, written); + ubi_dbg_dump_stack(); + } else + ubi_assert(written == len); + + return err; +} + +/** + * erase_callback - MTD erasure call-back. + * @ei: MTD erase information object. + * + * Note, even though MTD erase interface is asynchronous, all the current + * implementations are synchronous anyway. + */ +static void erase_callback(struct erase_info *ei) +{ + wake_up_interruptible((wait_queue_head_t *)ei->priv); +} + +/** + * do_sync_erase - synchronously erase a physical eraseblock. + * @ubi: UBI device description object + * @pnum: the physical eraseblock number to erase + * + * This function synchronously erases physical eraseblock @pnum and returns + * zero in case of success and a negative error code in case of failure. If + * %-EIO is returned, the physical eraseblock most probably went bad. + */ +static int do_sync_erase(struct ubi_device *ubi, int pnum) +{ + int err, retries = 0; + struct erase_info ei; + wait_queue_head_t wq; + + dbg_io("erase PEB %d", pnum); + +retry: + init_waitqueue_head(&wq); + memset(&ei, 0, sizeof(struct erase_info)); + + ei.mtd = ubi->mtd; + ei.addr = (loff_t)pnum * ubi->peb_size; + ei.len = ubi->peb_size; + ei.callback = erase_callback; + ei.priv = (unsigned long)&wq; + + err = ubi->mtd->erase(ubi->mtd, &ei); + if (err) { + if (retries++ < UBI_IO_RETRIES) { + dbg_io("error %d while erasing PEB %d, retry", + err, pnum); + yield(); + goto retry; + } + ubi_err("cannot erase PEB %d, error %d", pnum, err); + ubi_dbg_dump_stack(); + return err; + } + + err = wait_event_interruptible(wq, ei.state == MTD_ERASE_DONE || + ei.state == MTD_ERASE_FAILED); + if (err) { + ubi_err("interrupted PEB %d erasure", pnum); + return -EINTR; + } + + if (ei.state == MTD_ERASE_FAILED) { + if (retries++ < UBI_IO_RETRIES) { + dbg_io("error while erasing PEB %d, retry", pnum); + yield(); + goto retry; + } + ubi_err("cannot erase PEB %d", pnum); + ubi_dbg_dump_stack(); + return -EIO; + } + + err = paranoid_check_all_ff(ubi, pnum, 0, ubi->peb_size); + if (err) + return err > 0 ? -EINVAL : err; + + if (ubi_dbg_is_erase_failure() && !err) { + dbg_err("cannot erase PEB %d (emulated)", pnum); + return -EIO; + } + + return 0; +} + +/** + * check_pattern - check if buffer contains only a certain byte pattern. + * @buf: buffer to check + * @patt: the pattern to check + * @size: buffer size in bytes + * + * This function returns %1 in there are only @patt bytes in @buf, and %0 if + * something else was also found. + */ +static int check_pattern(const void *buf, uint8_t patt, int size) +{ + int i; + + for (i = 0; i < size; i++) + if (((const uint8_t *)buf)[i] != patt) + return 0; + return 1; +} + +/* Patterns to write to a physical eraseblock when torturing it */ +static uint8_t patterns[] = {0xa5, 0x5a, 0x0}; + +/** + * torture_peb - test a supposedly bad physical eraseblock. + * @ubi: UBI device description object + * @pnum: the physical eraseblock number to test + * + * This function returns %-EIO if the physical eraseblock did not pass the + * test, a positive number of erase operations done if the test was + * successfully passed, and other negative error codes in case of other errors. + */ +static int torture_peb(struct ubi_device *ubi, int pnum) +{ + int err, i, patt_count; + + patt_count = ARRAY_SIZE(patterns); + ubi_assert(patt_count > 0); + + mutex_lock(&ubi->buf_mutex); + for (i = 0; i < patt_count; i++) { + err = do_sync_erase(ubi, pnum); + if (err) + goto out; + + /* Make sure the PEB contains only 0xFF bytes */ + err = ubi_io_read(ubi, ubi->peb_buf1, pnum, 0, ubi->peb_size); + if (err) + goto out; + + err = check_pattern(ubi->peb_buf1, 0xFF, ubi->peb_size); + if (err == 0) { + ubi_err("erased PEB %d, but a non-0xFF byte found", + pnum); + err = -EIO; + goto out; + } + + /* Write a pattern and check it */ + memset(ubi->peb_buf1, patterns[i], ubi->peb_size); + err = ubi_io_write(ubi, ubi->peb_buf1, pnum, 0, ubi->peb_size); + if (err) + goto out; + + memset(ubi->peb_buf1, ~patterns[i], ubi->peb_size); + err = ubi_io_read(ubi, ubi->peb_buf1, pnum, 0, ubi->peb_size); + if (err) + goto out; + + err = check_pattern(ubi->peb_buf1, patterns[i], ubi->peb_size); + if (err == 0) { + ubi_err("pattern %x checking failed for PEB %d", + patterns[i], pnum); + err = -EIO; + goto out; + } + } + + err = patt_count; + +out: + mutex_unlock(&ubi->buf_mutex); + if (err == UBI_IO_BITFLIPS || err == -EBADMSG) { + /* + * If a bit-flip or data integrity error was detected, the test + * has not passed because it happened on a freshly erased + * physical eraseblock which means something is wrong with it. + */ + ubi_err("read problems on freshly erased PEB %d, must be bad", + pnum); + err = -EIO; + } + return err; +} + +/** + * ubi_io_sync_erase - synchronously erase a physical eraseblock. + * @ubi: UBI device description object + * @pnum: physical eraseblock number to erase + * @torture: if this physical eraseblock has to be tortured + * + * This function synchronously erases physical eraseblock @pnum. If @torture + * flag is not zero, the physical eraseblock is checked by means of writing + * different patterns to it and reading them back. If the torturing is enabled, + * the physical eraseblock is erased more then once. + * + * This function returns the number of erasures made in case of success, %-EIO + * if the erasure failed or the torturing test failed, and other negative error + * codes in case of other errors. Note, %-EIO means that the physical + * eraseblock is bad. + */ +int ubi_io_sync_erase(struct ubi_device *ubi, int pnum, int torture) +{ + int err, ret = 0; + + ubi_assert(pnum >= 0 && pnum < ubi->peb_count); + + err = paranoid_check_not_bad(ubi, pnum); + if (err != 0) + return err > 0 ? -EINVAL : err; + + if (ubi->ro_mode) { + ubi_err("read-only mode"); + return -EROFS; + } + + if (torture) { + ret = torture_peb(ubi, pnum); + if (ret < 0) + return ret; + } + + err = do_sync_erase(ubi, pnum); + if (err) + return err; + + return ret + 1; +} + +/** + * ubi_io_is_bad - check if a physical eraseblock is bad. + * @ubi: UBI device description object + * @pnum: the physical eraseblock number to check + * + * This function returns a positive number if the physical eraseblock is bad, + * zero if not, and a negative error code if an error occurred. + */ +int ubi_io_is_bad(const struct ubi_device *ubi, int pnum) +{ + struct mtd_info *mtd = ubi->mtd; + + ubi_assert(pnum >= 0 && pnum < ubi->peb_count); + + if (ubi->bad_allowed) { + int ret; + + ret = mtd->block_isbad(mtd, (loff_t)pnum * ubi->peb_size); + if (ret < 0) + ubi_err("error %d while checking if PEB %d is bad", + ret, pnum); + else if (ret) + dbg_io("PEB %d is bad", pnum); + return ret; + } + + return 0; +} + +/** + * ubi_io_mark_bad - mark a physical eraseblock as bad. + * @ubi: UBI device description object + * @pnum: the physical eraseblock number to mark + * + * This function returns zero in case of success and a negative error code in + * case of failure. + */ +int ubi_io_mark_bad(const struct ubi_device *ubi, int pnum) +{ + int err; + struct mtd_info *mtd = ubi->mtd; + + ubi_assert(pnum >= 0 && pnum < ubi->peb_count); + + if (ubi->ro_mode) { + ubi_err("read-only mode"); + return -EROFS; + } + + if (!ubi->bad_allowed) + return 0; + + err = mtd->block_markbad(mtd, (loff_t)pnum * ubi->peb_size); + if (err) + ubi_err("cannot mark PEB %d bad, error %d", pnum, err); + return err; +} + +/** + * validate_ec_hdr - validate an erase counter header. + * @ubi: UBI device description object + * @ec_hdr: the erase counter header to check + * + * This function returns zero if the erase counter header is OK, and %1 if + * not. + */ +static int validate_ec_hdr(const struct ubi_device *ubi, + const struct ubi_ec_hdr *ec_hdr) +{ + long long ec; + int vid_hdr_offset, leb_start; + + ec = be64_to_cpu(ec_hdr->ec); + vid_hdr_offset = be32_to_cpu(ec_hdr->vid_hdr_offset); + leb_start = be32_to_cpu(ec_hdr->data_offset); + + if (ec_hdr->version != UBI_VERSION) { + ubi_err("node with incompatible UBI version found: " + "this UBI version is %d, image version is %d", + UBI_VERSION, (int)ec_hdr->version); + goto bad; + } + + if (vid_hdr_offset != ubi->vid_hdr_offset) { + ubi_err("bad VID header offset %d, expected %d", + vid_hdr_offset, ubi->vid_hdr_offset); + goto bad; + } + + if (leb_start != ubi->leb_start) { + ubi_err("bad data offset %d, expected %d", + leb_start, ubi->leb_start); + goto bad; + } + + if (ec < 0 || ec > UBI_MAX_ERASECOUNTER) { + ubi_err("bad erase counter %lld", ec); + goto bad; + } + + return 0; + +bad: + ubi_err("bad EC header"); + ubi_dbg_dump_ec_hdr(ec_hdr); + ubi_dbg_dump_stack(); + return 1; +} + +/** + * ubi_io_read_ec_hdr - read and check an erase counter header. + * @ubi: UBI device description object + * @pnum: physical eraseblock to read from + * @ec_hdr: a &struct ubi_ec_hdr object where to store the read erase counter + * header + * @verbose: be verbose if the header is corrupted or was not found + * + * This function reads erase counter header from physical eraseblock @pnum and + * stores it in @ec_hdr. This function also checks CRC checksum of the read + * erase counter header. The following codes may be returned: + * + * o %0 if the CRC checksum is correct and the header was successfully read; + * o %UBI_IO_BITFLIPS if the CRC is correct, but bit-flips were detected + * and corrected by the flash driver; this is harmless but may indicate that + * this eraseblock may become bad soon (but may be not); + * o %UBI_IO_BAD_EC_HDR if the erase counter header is corrupted (a CRC error); + * o %UBI_IO_PEB_EMPTY if the physical eraseblock is empty; + * o a negative error code in case of failure. + */ +int ubi_io_read_ec_hdr(struct ubi_device *ubi, int pnum, + struct ubi_ec_hdr *ec_hdr, int verbose) +{ + int err, read_err = 0; + uint32_t crc, magic, hdr_crc; + + dbg_io("read EC header from PEB %d", pnum); + ubi_assert(pnum >= 0 && pnum < ubi->peb_count); + if (UBI_IO_DEBUG) + verbose = 1; + + err = ubi_io_read(ubi, ec_hdr, pnum, 0, UBI_EC_HDR_SIZE); + if (err) { + if (err != UBI_IO_BITFLIPS && err != -EBADMSG) + return err; + + /* + * We read all the data, but either a correctable bit-flip + * occurred, or MTD reported about some data integrity error, + * like an ECC error in case of NAND. The former is harmless, + * the later may mean that the read data is corrupted. But we + * have a CRC check-sum and we will detect this. If the EC + * header is still OK, we just report this as there was a + * bit-flip. + */ + read_err = err; + } + + magic = be32_to_cpu(ec_hdr->magic); + if (magic != UBI_EC_HDR_MAGIC) { + /* + * The magic field is wrong. Let's check if we have read all + * 0xFF. If yes, this physical eraseblock is assumed to be + * empty. + * + * But if there was a read error, we do not test it for all + * 0xFFs. Even if it does contain all 0xFFs, this error + * indicates that something is still wrong with this physical + * eraseblock and we anyway cannot treat it as empty. + */ + if (read_err != -EBADMSG && + check_pattern(ec_hdr, 0xFF, UBI_EC_HDR_SIZE)) { + /* The physical eraseblock is supposedly empty */ + + /* + * The below is just a paranoid check, it has to be + * compiled out if paranoid checks are disabled. + */ + err = paranoid_check_all_ff(ubi, pnum, 0, + ubi->peb_size); + if (err) + return err > 0 ? UBI_IO_BAD_EC_HDR : err; + + if (verbose) + ubi_warn("no EC header found at PEB %d, " + "only 0xFF bytes", pnum); + return UBI_IO_PEB_EMPTY; + } + + /* + * This is not a valid erase counter header, and these are not + * 0xFF bytes. Report that the header is corrupted. + */ + if (verbose) { + ubi_warn("bad magic number at PEB %d: %08x instead of " + "%08x", pnum, magic, UBI_EC_HDR_MAGIC); + ubi_dbg_dump_ec_hdr(ec_hdr); + } + return UBI_IO_BAD_EC_HDR; + } + + crc = crc32(UBI_CRC32_INIT, ec_hdr, UBI_EC_HDR_SIZE_CRC); + hdr_crc = be32_to_cpu(ec_hdr->hdr_crc); + + if (hdr_crc != crc) { + if (verbose) { + ubi_warn("bad EC header CRC at PEB %d, calculated %#08x," + " read %#08x", pnum, crc, hdr_crc); + ubi_dbg_dump_ec_hdr(ec_hdr); + } + return UBI_IO_BAD_EC_HDR; + } + + /* And of course validate what has just been read from the media */ + err = validate_ec_hdr(ubi, ec_hdr); + if (err) { + ubi_err("validation failed for PEB %d", pnum); + return -EINVAL; + } + + return read_err ? UBI_IO_BITFLIPS : 0; +} + +/** + * ubi_io_write_ec_hdr - write an erase counter header. + * @ubi: UBI device description object + * @pnum: physical eraseblock to write to + * @ec_hdr: the erase counter header to write + * + * This function writes erase counter header described by @ec_hdr to physical + * eraseblock @pnum. It also fills most fields of @ec_hdr before writing, so + * the caller do not have to fill them. Callers must only fill the @ec_hdr->ec + * field. + * + * This function returns zero in case of success and a negative error code in + * case of failure. If %-EIO is returned, the physical eraseblock most probably + * went bad. + */ +int ubi_io_write_ec_hdr(struct ubi_device *ubi, int pnum, + struct ubi_ec_hdr *ec_hdr) +{ + int err; + uint32_t crc; + + dbg_io("write EC header to PEB %d", pnum); + ubi_assert(pnum >= 0 && pnum < ubi->peb_count); + + ec_hdr->magic = cpu_to_be32(UBI_EC_HDR_MAGIC); + ec_hdr->version = UBI_VERSION; + ec_hdr->vid_hdr_offset = cpu_to_be32(ubi->vid_hdr_offset); + ec_hdr->data_offset = cpu_to_be32(ubi->leb_start); + crc = crc32(UBI_CRC32_INIT, ec_hdr, UBI_EC_HDR_SIZE_CRC); + ec_hdr->hdr_crc = cpu_to_be32(crc); + + err = paranoid_check_ec_hdr(ubi, pnum, ec_hdr); + if (err) + return -EINVAL; + + err = ubi_io_write(ubi, ec_hdr, pnum, 0, ubi->ec_hdr_alsize); + return err; +} + +/** + * validate_vid_hdr - validate a volume identifier header. + * @ubi: UBI device description object + * @vid_hdr: the volume identifier header to check + * + * This function checks that data stored in the volume identifier header + * @vid_hdr. Returns zero if the VID header is OK and %1 if not. + */ +static int validate_vid_hdr(const struct ubi_device *ubi, + const struct ubi_vid_hdr *vid_hdr) +{ + int vol_type = vid_hdr->vol_type; + int copy_flag = vid_hdr->copy_flag; + int vol_id = be32_to_cpu(vid_hdr->vol_id); + int lnum = be32_to_cpu(vid_hdr->lnum); + int compat = vid_hdr->compat; + int data_size = be32_to_cpu(vid_hdr->data_size); + int used_ebs = be32_to_cpu(vid_hdr->used_ebs); + int data_pad = be32_to_cpu(vid_hdr->data_pad); + int data_crc = be32_to_cpu(vid_hdr->data_crc); + int usable_leb_size = ubi->leb_size - data_pad; + + if (copy_flag != 0 && copy_flag != 1) { + dbg_err("bad copy_flag"); + goto bad; + } + + if (vol_id < 0 || lnum < 0 || data_size < 0 || used_ebs < 0 || + data_pad < 0) { + dbg_err("negative values"); + goto bad; + } + + if (vol_id >= UBI_MAX_VOLUMES && vol_id < UBI_INTERNAL_VOL_START) { + dbg_err("bad vol_id"); + goto bad; + } + + if (vol_id < UBI_INTERNAL_VOL_START && compat != 0) { + dbg_err("bad compat"); + goto bad; + } + + if (vol_id >= UBI_INTERNAL_VOL_START && compat != UBI_COMPAT_DELETE && + compat != UBI_COMPAT_RO && compat != UBI_COMPAT_PRESERVE && + compat != UBI_COMPAT_REJECT) { + dbg_err("bad compat"); + goto bad; + } + + if (vol_type != UBI_VID_DYNAMIC && vol_type != UBI_VID_STATIC) { + dbg_err("bad vol_type"); + goto bad; + } + + if (data_pad >= ubi->leb_size / 2) { + dbg_err("bad data_pad"); + goto bad; + } + + if (vol_type == UBI_VID_STATIC) { + /* + * Although from high-level point of view static volumes may + * contain zero bytes of data, but no VID headers can contain + * zero at these fields, because they empty volumes do not have + * mapped logical eraseblocks. + */ + if (used_ebs == 0) { + dbg_err("zero used_ebs"); + goto bad; + } + if (data_size == 0) { + dbg_err("zero data_size"); + goto bad; + } + if (lnum < used_ebs - 1) { + if (data_size != usable_leb_size) { + dbg_err("bad data_size"); + goto bad; + } + } else if (lnum == used_ebs - 1) { + if (data_size == 0) { + dbg_err("bad data_size at last LEB"); + goto bad; + } + } else { + dbg_err("too high lnum"); + goto bad; + } + } else { + if (copy_flag == 0) { + if (data_crc != 0) { + dbg_err("non-zero data CRC"); + goto bad; + } + if (data_size != 0) { + dbg_err("non-zero data_size"); + goto bad; + } + } else { + if (data_size == 0) { + dbg_err("zero data_size of copy"); + goto bad; + } + } + if (used_ebs != 0) { + dbg_err("bad used_ebs"); + goto bad; + } + } + + return 0; + +bad: + ubi_err("bad VID header"); + ubi_dbg_dump_vid_hdr(vid_hdr); + ubi_dbg_dump_stack(); + return 1; +} + +/** + * ubi_io_read_vid_hdr - read and check a volume identifier header. + * @ubi: UBI device description object + * @pnum: physical eraseblock number to read from + * @vid_hdr: &struct ubi_vid_hdr object where to store the read volume + * identifier header + * @verbose: be verbose if the header is corrupted or wasn't found + * + * This function reads the volume identifier header from physical eraseblock + * @pnum and stores it in @vid_hdr. It also checks CRC checksum of the read + * volume identifier header. The following codes may be returned: + * + * o %0 if the CRC checksum is correct and the header was successfully read; + * o %UBI_IO_BITFLIPS if the CRC is correct, but bit-flips were detected + * and corrected by the flash driver; this is harmless but may indicate that + * this eraseblock may become bad soon; + * o %UBI_IO_BAD_VID_HRD if the volume identifier header is corrupted (a CRC + * error detected); + * o %UBI_IO_PEB_FREE if the physical eraseblock is free (i.e., there is no VID + * header there); + * o a negative error code in case of failure. + */ +int ubi_io_read_vid_hdr(struct ubi_device *ubi, int pnum, + struct ubi_vid_hdr *vid_hdr, int verbose) +{ + int err, read_err = 0; + uint32_t crc, magic, hdr_crc; + void *p; + + dbg_io("read VID header from PEB %d", pnum); + ubi_assert(pnum >= 0 && pnum < ubi->peb_count); + if (UBI_IO_DEBUG) + verbose = 1; + + p = (char *)vid_hdr - ubi->vid_hdr_shift; + err = ubi_io_read(ubi, p, pnum, ubi->vid_hdr_aloffset, + ubi->vid_hdr_alsize); + if (err) { + if (err != UBI_IO_BITFLIPS && err != -EBADMSG) + return err; + + /* + * We read all the data, but either a correctable bit-flip + * occurred, or MTD reported about some data integrity error, + * like an ECC error in case of NAND. The former is harmless, + * the later may mean the read data is corrupted. But we have a + * CRC check-sum and we will identify this. If the VID header is + * still OK, we just report this as there was a bit-flip. + */ + read_err = err; + } + + magic = be32_to_cpu(vid_hdr->magic); + if (magic != UBI_VID_HDR_MAGIC) { + /* + * If we have read all 0xFF bytes, the VID header probably does + * not exist and the physical eraseblock is assumed to be free. + * + * But if there was a read error, we do not test the data for + * 0xFFs. Even if it does contain all 0xFFs, this error + * indicates that something is still wrong with this physical + * eraseblock and it cannot be regarded as free. + */ + if (read_err != -EBADMSG && + check_pattern(vid_hdr, 0xFF, UBI_VID_HDR_SIZE)) { + /* The physical eraseblock is supposedly free */ + + /* + * The below is just a paranoid check, it has to be + * compiled out if paranoid checks are disabled. + */ + err = paranoid_check_all_ff(ubi, pnum, ubi->leb_start, + ubi->leb_size); + if (err) + return err > 0 ? UBI_IO_BAD_VID_HDR : err; + + if (verbose) + ubi_warn("no VID header found at PEB %d, " + "only 0xFF bytes", pnum); + return UBI_IO_PEB_FREE; + } + + /* + * This is not a valid VID header, and these are not 0xFF + * bytes. Report that the header is corrupted. + */ + if (verbose) { + ubi_warn("bad magic number at PEB %d: %08x instead of " + "%08x", pnum, magic, UBI_VID_HDR_MAGIC); + ubi_dbg_dump_vid_hdr(vid_hdr); + } + return UBI_IO_BAD_VID_HDR; + } + + crc = crc32(UBI_CRC32_INIT, vid_hdr, UBI_VID_HDR_SIZE_CRC); + hdr_crc = be32_to_cpu(vid_hdr->hdr_crc); + + if (hdr_crc != crc) { + if (verbose) { + ubi_warn("bad CRC at PEB %d, calculated %#08x, " + "read %#08x", pnum, crc, hdr_crc); + ubi_dbg_dump_vid_hdr(vid_hdr); + } + return UBI_IO_BAD_VID_HDR; + } + + /* Validate the VID header that we have just read */ + err = validate_vid_hdr(ubi, vid_hdr); + if (err) { + ubi_err("validation failed for PEB %d", pnum); + return -EINVAL; + } + + return read_err ? UBI_IO_BITFLIPS : 0; +} + +/** + * ubi_io_write_vid_hdr - write a volume identifier header. + * @ubi: UBI device description object + * @pnum: the physical eraseblock number to write to + * @vid_hdr: the volume identifier header to write + * + * This function writes the volume identifier header described by @vid_hdr to + * physical eraseblock @pnum. This function automatically fills the + * @vid_hdr->magic and the @vid_hdr->version fields, as well as calculates + * header CRC checksum and stores it at vid_hdr->hdr_crc. + * + * This function returns zero in case of success and a negative error code in + * case of failure. If %-EIO is returned, the physical eraseblock probably went + * bad. + */ +int ubi_io_write_vid_hdr(struct ubi_device *ubi, int pnum, + struct ubi_vid_hdr *vid_hdr) +{ + int err; + uint32_t crc; + void *p; + + dbg_io("write VID header to PEB %d", pnum); + ubi_assert(pnum >= 0 && pnum < ubi->peb_count); + + err = paranoid_check_peb_ec_hdr(ubi, pnum); + if (err) + return err > 0 ? -EINVAL: err; + + vid_hdr->magic = cpu_to_be32(UBI_VID_HDR_MAGIC); + vid_hdr->version = UBI_VERSION; + crc = crc32(UBI_CRC32_INIT, vid_hdr, UBI_VID_HDR_SIZE_CRC); + vid_hdr->hdr_crc = cpu_to_be32(crc); + + err = paranoid_check_vid_hdr(ubi, pnum, vid_hdr); + if (err) + return -EINVAL; + + p = (char *)vid_hdr - ubi->vid_hdr_shift; + err = ubi_io_write(ubi, p, pnum, ubi->vid_hdr_aloffset, + ubi->vid_hdr_alsize); + return err; +} + +#ifdef CONFIG_MTD_UBI_DEBUG_PARANOID + +/** + * paranoid_check_not_bad - ensure that a physical eraseblock is not bad. + * @ubi: UBI device description object + * @pnum: physical eraseblock number to check + * + * This function returns zero if the physical eraseblock is good, a positive + * number if it is bad and a negative error code if an error occurred. + */ +static int paranoid_check_not_bad(const struct ubi_device *ubi, int pnum) +{ + int err; + + err = ubi_io_is_bad(ubi, pnum); + if (!err) + return err; + + ubi_err("paranoid check failed for PEB %d", pnum); + ubi_dbg_dump_stack(); + return err; +} + +/** + * paranoid_check_ec_hdr - check if an erase counter header is all right. + * @ubi: UBI device description object + * @pnum: physical eraseblock number the erase counter header belongs to + * @ec_hdr: the erase counter header to check + * + * This function returns zero if the erase counter header contains valid + * values, and %1 if not. + */ +static int paranoid_check_ec_hdr(const struct ubi_device *ubi, int pnum, + const struct ubi_ec_hdr *ec_hdr) +{ + int err; + uint32_t magic; + + magic = be32_to_cpu(ec_hdr->magic); + if (magic != UBI_EC_HDR_MAGIC) { + ubi_err("bad magic %#08x, must be %#08x", + magic, UBI_EC_HDR_MAGIC); + goto fail; + } + + err = validate_ec_hdr(ubi, ec_hdr); + if (err) { + ubi_err("paranoid check failed for PEB %d", pnum); + goto fail; + } + + return 0; + +fail: + ubi_dbg_dump_ec_hdr(ec_hdr); + ubi_dbg_dump_stack(); + return 1; +} + +/** + * paranoid_check_peb_ec_hdr - check that the erase counter header of a + * physical eraseblock is in-place and is all right. + * @ubi: UBI device description object + * @pnum: the physical eraseblock number to check + * + * This function returns zero if the erase counter header is all right, %1 if + * not, and a negative error code if an error occurred. + */ +static int paranoid_check_peb_ec_hdr(const struct ubi_device *ubi, int pnum) +{ + int err; + uint32_t crc, hdr_crc; + struct ubi_ec_hdr *ec_hdr; + + ec_hdr = kzalloc(ubi->ec_hdr_alsize, GFP_NOFS); + if (!ec_hdr) + return -ENOMEM; + + err = ubi_io_read(ubi, ec_hdr, pnum, 0, UBI_EC_HDR_SIZE); + if (err && err != UBI_IO_BITFLIPS && err != -EBADMSG) + goto exit; + + crc = crc32(UBI_CRC32_INIT, ec_hdr, UBI_EC_HDR_SIZE_CRC); + hdr_crc = be32_to_cpu(ec_hdr->hdr_crc); + if (hdr_crc != crc) { + ubi_err("bad CRC, calculated %#08x, read %#08x", crc, hdr_crc); + ubi_err("paranoid check failed for PEB %d", pnum); + ubi_dbg_dump_ec_hdr(ec_hdr); + ubi_dbg_dump_stack(); + err = 1; + goto exit; + } + + err = paranoid_check_ec_hdr(ubi, pnum, ec_hdr); + +exit: + kfree(ec_hdr); + return err; +} + +/** + * paranoid_check_vid_hdr - check that a volume identifier header is all right. + * @ubi: UBI device description object + * @pnum: physical eraseblock number the volume identifier header belongs to + * @vid_hdr: the volume identifier header to check + * + * This function returns zero if the volume identifier header is all right, and + * %1 if not. + */ +static int paranoid_check_vid_hdr(const struct ubi_device *ubi, int pnum, + const struct ubi_vid_hdr *vid_hdr) +{ + int err; + uint32_t magic; + + magic = be32_to_cpu(vid_hdr->magic); + if (magic != UBI_VID_HDR_MAGIC) { + ubi_err("bad VID header magic %#08x at PEB %d, must be %#08x", + magic, pnum, UBI_VID_HDR_MAGIC); + goto fail; + } + + err = validate_vid_hdr(ubi, vid_hdr); + if (err) { + ubi_err("paranoid check failed for PEB %d", pnum); + goto fail; + } + + return err; + +fail: + ubi_err("paranoid check failed for PEB %d", pnum); + ubi_dbg_dump_vid_hdr(vid_hdr); + ubi_dbg_dump_stack(); + return 1; + +} + +/** + * paranoid_check_peb_vid_hdr - check that the volume identifier header of a + * physical eraseblock is in-place and is all right. + * @ubi: UBI device description object + * @pnum: the physical eraseblock number to check + * + * This function returns zero if the volume identifier header is all right, + * %1 if not, and a negative error code if an error occurred. + */ +static int paranoid_check_peb_vid_hdr(const struct ubi_device *ubi, int pnum) +{ + int err; + uint32_t crc, hdr_crc; + struct ubi_vid_hdr *vid_hdr; + void *p; + + vid_hdr = ubi_zalloc_vid_hdr(ubi, GFP_NOFS); + if (!vid_hdr) + return -ENOMEM; + + p = (char *)vid_hdr - ubi->vid_hdr_shift; + err = ubi_io_read(ubi, p, pnum, ubi->vid_hdr_aloffset, + ubi->vid_hdr_alsize); + if (err && err != UBI_IO_BITFLIPS && err != -EBADMSG) + goto exit; + + crc = crc32(UBI_CRC32_INIT, vid_hdr, UBI_EC_HDR_SIZE_CRC); + hdr_crc = be32_to_cpu(vid_hdr->hdr_crc); + if (hdr_crc != crc) { + ubi_err("bad VID header CRC at PEB %d, calculated %#08x, " + "read %#08x", pnum, crc, hdr_crc); + ubi_err("paranoid check failed for PEB %d", pnum); + ubi_dbg_dump_vid_hdr(vid_hdr); + ubi_dbg_dump_stack(); + err = 1; + goto exit; + } + + err = paranoid_check_vid_hdr(ubi, pnum, vid_hdr); + +exit: + ubi_free_vid_hdr(ubi, vid_hdr); + return err; +} + +/** + * paranoid_check_all_ff - check that a region of flash is empty. + * @ubi: UBI device description object + * @pnum: the physical eraseblock number to check + * @offset: the starting offset within the physical eraseblock to check + * @len: the length of the region to check + * + * This function returns zero if only 0xFF bytes are present at offset + * @offset of the physical eraseblock @pnum, %1 if not, and a negative error + * code if an error occurred. + */ +static int paranoid_check_all_ff(struct ubi_device *ubi, int pnum, int offset, + int len) +{ + size_t read; + int err; + loff_t addr = (loff_t)pnum * ubi->peb_size + offset; + + mutex_lock(&ubi->dbg_buf_mutex); + err = ubi->mtd->read(ubi->mtd, addr, len, &read, ubi->dbg_peb_buf); + if (err && err != -EUCLEAN) { + ubi_err("error %d while reading %d bytes from PEB %d:%d, " + "read %zd bytes", err, len, pnum, offset, read); + goto error; + } + + err = check_pattern(ubi->dbg_peb_buf, 0xFF, len); + if (err == 0) { + ubi_err("flash region at PEB %d:%d, length %d does not " + "contain all 0xFF bytes", pnum, offset, len); + goto fail; + } + mutex_unlock(&ubi->dbg_buf_mutex); + + return 0; + +fail: + ubi_err("paranoid check failed for PEB %d", pnum); + dbg_msg("hex dump of the %d-%d region", offset, offset + len); + print_hex_dump(KERN_DEBUG, "", DUMP_PREFIX_OFFSET, 32, 1, + ubi->dbg_peb_buf, len, 1); + err = 1; +error: + ubi_dbg_dump_stack(); + mutex_unlock(&ubi->dbg_buf_mutex); + return err; +} + +#endif /* CONFIG_MTD_UBI_DEBUG_PARANOID */ diff --git a/drivers/mtd/ubi/kapi.c b/drivers/mtd/ubi/kapi.c new file mode 100644 index 0000000..7aa0a3b --- /dev/null +++ b/drivers/mtd/ubi/kapi.c @@ -0,0 +1,638 @@ +/* + * Copyright (c) International Business Machines Corp., 2006 + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See + * the GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + * Author: Artem Bityutskiy (Битюцкий Артём) + */ + +/* This file mostly implements UBI kernel API functions */ + +#if 0 +#include <linux/module.h> +#include <linux/err.h> +#include <asm/div64.h> +#endif + +#include <ubi_uboot.h> +#include "ubi.h" + +/** + * ubi_get_device_info - get information about UBI device. + * @ubi_num: UBI device number + * @di: the information is stored here + * + * This function returns %0 in case of success, %-EINVAL if the UBI device + * number is invalid, and %-ENODEV if there is no such UBI device. + */ +int ubi_get_device_info(int ubi_num, struct ubi_device_info *di) +{ + struct ubi_device *ubi; + + if (ubi_num < 0 || ubi_num >= UBI_MAX_DEVICES) + return -EINVAL; + + ubi = ubi_get_device(ubi_num); + if (!ubi) + return -ENODEV; + + di->ubi_num = ubi->ubi_num; + di->leb_size = ubi->leb_size; + di->min_io_size = ubi->min_io_size; + di->ro_mode = ubi->ro_mode; + di->cdev = ubi->cdev.dev; + + ubi_put_device(ubi); + return 0; +} +EXPORT_SYMBOL_GPL(ubi_get_device_info); + +/** + * ubi_get_volume_info - get information about UBI volume. + * @desc: volume descriptor + * @vi: the information is stored here + */ +void ubi_get_volume_info(struct ubi_volume_desc *desc, + struct ubi_volume_info *vi) +{ + const struct ubi_volume *vol = desc->vol; + const struct ubi_device *ubi = vol->ubi; + + vi->vol_id = vol->vol_id; + vi->ubi_num = ubi->ubi_num; + vi->size = vol->reserved_pebs; + vi->used_bytes = vol->used_bytes; + vi->vol_type = vol->vol_type; + vi->corrupted = vol->corrupted; + vi->upd_marker = vol->upd_marker; + vi->alignment = vol->alignment; + vi->usable_leb_size = vol->usable_leb_size; + vi->name_len = vol->name_len; + vi->name = vol->name; + vi->cdev = vol->cdev.dev; +} +EXPORT_SYMBOL_GPL(ubi_get_volume_info); + +/** + * ubi_open_volume - open UBI volume. + * @ubi_num: UBI device number + * @vol_id: volume ID + * @mode: open mode + * + * The @mode parameter specifies if the volume should be opened in read-only + * mode, read-write mode, or exclusive mode. The exclusive mode guarantees that + * nobody else will be able to open this volume. UBI allows to have many volume + * readers and one writer at a time. + * + * If a static volume is being opened for the first time since boot, it will be + * checked by this function, which means it will be fully read and the CRC + * checksum of each logical eraseblock will be checked. + * + * This function returns volume descriptor in case of success and a negative + * error code in case of failure. + */ +struct ubi_volume_desc *ubi_open_volume(int ubi_num, int vol_id, int mode) +{ + int err; + struct ubi_volume_desc *desc; + struct ubi_device *ubi; + struct ubi_volume *vol; + + dbg_msg("open device %d volume %d, mode %d", ubi_num, vol_id, mode); + + if (ubi_num < 0 || ubi_num >= UBI_MAX_DEVICES) + return ERR_PTR(-EINVAL); + + if (mode != UBI_READONLY && mode != UBI_READWRITE && + mode != UBI_EXCLUSIVE) + return ERR_PTR(-EINVAL); + + /* + * First of all, we have to get the UBI device to prevent its removal. + */ + ubi = ubi_get_device(ubi_num); + if (!ubi) + return ERR_PTR(-ENODEV); + + if (vol_id < 0 || vol_id >= ubi->vtbl_slots) { + err = -EINVAL; + goto out_put_ubi; + } + + desc = kmalloc(sizeof(struct ubi_volume_desc), GFP_KERNEL); + if (!desc) { + err = -ENOMEM; + goto out_put_ubi; + } + + err = -ENODEV; + if (!try_module_get(THIS_MODULE)) + goto out_free; + + spin_lock(&ubi->volumes_lock); + vol = ubi->volumes[vol_id]; + if (!vol) + goto out_unlock; + + err = -EBUSY; + switch (mode) { + case UBI_READONLY: + if (vol->exclusive) + goto out_unlock; + vol->readers += 1; + break; + + case UBI_READWRITE: + if (vol->exclusive || vol->writers > 0) + goto out_unlock; + vol->writers += 1; + break; + + case UBI_EXCLUSIVE: + if (vol->exclusive || vol->writers || vol->readers) + goto out_unlock; + vol->exclusive = 1; + break; + } + get_device(&vol->dev); + vol->ref_count += 1; + spin_unlock(&ubi->volumes_lock); + + desc->vol = vol; + desc->mode = mode; + + mutex_lock(&ubi->ckvol_mutex); + if (!vol->checked) { + /* This is the first open - check the volume */ + err = ubi_check_volume(ubi, vol_id); + if (err < 0) { + mutex_unlock(&ubi->ckvol_mutex); + ubi_close_volume(desc); + return ERR_PTR(err); + } + if (err == 1) { + ubi_warn("volume %d on UBI device %d is corrupted", + vol_id, ubi->ubi_num); + vol->corrupted = 1; + } + vol->checked = 1; + } + mutex_unlock(&ubi->ckvol_mutex); + + return desc; + +out_unlock: + spin_unlock(&ubi->volumes_lock); + module_put(THIS_MODULE); +out_free: + kfree(desc); +out_put_ubi: + ubi_put_device(ubi); + return ERR_PTR(err); +} +EXPORT_SYMBOL_GPL(ubi_open_volume); + +/** + * ubi_open_volume_nm - open UBI volume by name. + * @ubi_num: UBI device number + * @name: volume name + * @mode: open mode + * + * This function is similar to 'ubi_open_volume()', but opens a volume by name. + */ +struct ubi_volume_desc *ubi_open_volume_nm(int ubi_num, const char *name, + int mode) +{ + int i, vol_id = -1, len; + struct ubi_device *ubi; + struct ubi_volume_desc *ret; + + dbg_msg("open volume %s, mode %d", name, mode); + + if (!name) + return ERR_PTR(-EINVAL); + + len = strnlen(name, UBI_VOL_NAME_MAX + 1); + if (len > UBI_VOL_NAME_MAX) + return ERR_PTR(-EINVAL); + + if (ubi_num < 0 || ubi_num >= UBI_MAX_DEVICES) + return ERR_PTR(-EINVAL); + + ubi = ubi_get_device(ubi_num); + if (!ubi) + return ERR_PTR(-ENODEV); + + spin_lock(&ubi->volumes_lock); + /* Walk all volumes of this UBI device */ + for (i = 0; i < ubi->vtbl_slots; i++) { + struct ubi_volume *vol = ubi->volumes[i]; + + if (vol && len == vol->name_len && !strcmp(name, vol->name)) { + vol_id = i; + break; + } + } + spin_unlock(&ubi->volumes_lock); + + if (vol_id >= 0) + ret = ubi_open_volume(ubi_num, vol_id, mode); + else + ret = ERR_PTR(-ENODEV); + + /* + * We should put the UBI device even in case of success, because + * 'ubi_open_volume()' took a reference as well. + */ + ubi_put_device(ubi); + return ret; +} +EXPORT_SYMBOL_GPL(ubi_open_volume_nm); + +/** + * ubi_close_volume - close UBI volume. + * @desc: volume descriptor + */ +void ubi_close_volume(struct ubi_volume_desc *desc) +{ + struct ubi_volume *vol = desc->vol; + struct ubi_device *ubi = vol->ubi; + + dbg_msg("close volume %d, mode %d", vol->vol_id, desc->mode); + + spin_lock(&ubi->volumes_lock); + switch (desc->mode) { + case UBI_READONLY: + vol->readers -= 1; + break; + case UBI_READWRITE: + vol->writers -= 1; + break; + case UBI_EXCLUSIVE: + vol->exclusive = 0; + } + vol->ref_count -= 1; + spin_unlock(&ubi->volumes_lock); + + kfree(desc); + put_device(&vol->dev); + ubi_put_device(ubi); + module_put(THIS_MODULE); +} +EXPORT_SYMBOL_GPL(ubi_close_volume); + +/** + * ubi_leb_read - read data. + * @desc: volume descriptor + * @lnum: logical eraseblock number to read from + * @buf: buffer where to store the read data + * @offset: offset within the logical eraseblock to read from + * @len: how many bytes to read + * @check: whether UBI has to check the read data's CRC or not. + * + * This function reads data from offset @offset of logical eraseblock @lnum and + * stores the data at @buf. When reading from static volumes, @check specifies + * whether the data has to be checked or not. If yes, the whole logical + * eraseblock will be read and its CRC checksum will be checked (i.e., the CRC + * checksum is per-eraseblock). So checking may substantially slow down the + * read speed. The @check argument is ignored for dynamic volumes. + * + * In case of success, this function returns zero. In case of failure, this + * function returns a negative error code. + * + * %-EBADMSG error code is returned: + * o for both static and dynamic volumes if MTD driver has detected a data + * integrity problem (unrecoverable ECC checksum mismatch in case of NAND); + * o for static volumes in case of data CRC mismatch. + * + * If the volume is damaged because of an interrupted update this function just + * returns immediately with %-EBADF error code. + */ +int ubi_leb_read(struct ubi_volume_desc *desc, int lnum, char *buf, int offset, + int len, int check) +{ + struct ubi_volume *vol = desc->vol; + struct ubi_device *ubi = vol->ubi; + int err, vol_id = vol->vol_id; + + dbg_msg("read %d bytes from LEB %d:%d:%d", len, vol_id, lnum, offset); + + if (vol_id < 0 || vol_id >= ubi->vtbl_slots || lnum < 0 || + lnum >= vol->used_ebs || offset < 0 || len < 0 || + offset + len > vol->usable_leb_size) + return -EINVAL; + + if (vol->vol_type == UBI_STATIC_VOLUME) { + if (vol->used_ebs == 0) + /* Empty static UBI volume */ + return 0; + if (lnum == vol->used_ebs - 1 && + offset + len > vol->last_eb_bytes) + return -EINVAL; + } + + if (vol->upd_marker) + return -EBADF; + if (len == 0) + return 0; + + err = ubi_eba_read_leb(ubi, vol, lnum, buf, offset, len, check); + if (err && err == -EBADMSG && vol->vol_type == UBI_STATIC_VOLUME) { + ubi_warn("mark volume %d as corrupted", vol_id); + vol->corrupted = 1; + } + + return err; +} +EXPORT_SYMBOL_GPL(ubi_leb_read); + +/** + * ubi_leb_write - write data. + * @desc: volume descriptor + * @lnum: logical eraseblock number to write to + * @buf: data to write + * @offset: offset within the logical eraseblock where to write + * @len: how many bytes to write + * @dtype: expected data type + * + * This function writes @len bytes of data from @buf to offset @offset of + * logical eraseblock @lnum. The @dtype argument describes expected lifetime of + * the data. + * + * This function takes care of physical eraseblock write failures. If write to + * the physical eraseblock write operation fails, the logical eraseblock is + * re-mapped to another physical eraseblock, the data is recovered, and the + * write finishes. UBI has a pool of reserved physical eraseblocks for this. + * + * If all the data were successfully written, zero is returned. If an error + * occurred and UBI has not been able to recover from it, this function returns + * a negative error code. Note, in case of an error, it is possible that + * something was still written to the flash media, but that may be some + * garbage. + * + * If the volume is damaged because of an interrupted update this function just + * returns immediately with %-EBADF code. + */ +int ubi_leb_write(struct ubi_volume_desc *desc, int lnum, const void *buf, + int offset, int len, int dtype) +{ + struct ubi_volume *vol = desc->vol; + struct ubi_device *ubi = vol->ubi; + int vol_id = vol->vol_id; + + dbg_msg("write %d bytes to LEB %d:%d:%d", len, vol_id, lnum, offset); + + if (vol_id < 0 || vol_id >= ubi->vtbl_slots) + return -EINVAL; + + if (desc->mode == UBI_READONLY || vol->vol_type == UBI_STATIC_VOLUME) + return -EROFS; + + if (lnum < 0 || lnum >= vol->reserved_pebs || offset < 0 || len < 0 || + offset + len > vol->usable_leb_size || + offset & (ubi->min_io_size - 1) || len & (ubi->min_io_size - 1)) + return -EINVAL; + + if (dtype != UBI_LONGTERM && dtype != UBI_SHORTTERM && + dtype != UBI_UNKNOWN) + return -EINVAL; + + if (vol->upd_marker) + return -EBADF; + + if (len == 0) + return 0; + + return ubi_eba_write_leb(ubi, vol, lnum, buf, offset, len, dtype); +} +EXPORT_SYMBOL_GPL(ubi_leb_write); + +/* + * ubi_leb_change - change logical eraseblock atomically. + * @desc: volume descriptor + * @lnum: logical eraseblock number to change + * @buf: data to write + * @len: how many bytes to write + * @dtype: expected data type + * + * This function changes the contents of a logical eraseblock atomically. @buf + * has to contain new logical eraseblock data, and @len - the length of the + * data, which has to be aligned. The length may be shorter then the logical + * eraseblock size, ant the logical eraseblock may be appended to more times + * later on. This function guarantees that in case of an unclean reboot the old + * contents is preserved. Returns zero in case of success and a negative error + * code in case of failure. + */ +int ubi_leb_change(struct ubi_volume_desc *desc, int lnum, const void *buf, + int len, int dtype) +{ + struct ubi_volume *vol = desc->vol; + struct ubi_device *ubi = vol->ubi; + int vol_id = vol->vol_id; + + dbg_msg("atomically write %d bytes to LEB %d:%d", len, vol_id, lnum); + + if (vol_id < 0 || vol_id >= ubi->vtbl_slots) + return -EINVAL; + + if (desc->mode == UBI_READONLY || vol->vol_type == UBI_STATIC_VOLUME) + return -EROFS; + + if (lnum < 0 || lnum >= vol->reserved_pebs || len < 0 || + len > vol->usable_leb_size || len & (ubi->min_io_size - 1)) + return -EINVAL; + + if (dtype != UBI_LONGTERM && dtype != UBI_SHORTTERM && + dtype != UBI_UNKNOWN) + return -EINVAL; + + if (vol->upd_marker) + return -EBADF; + + if (len == 0) + return 0; + + return ubi_eba_atomic_leb_change(ubi, vol, lnum, buf, len, dtype); +} +EXPORT_SYMBOL_GPL(ubi_leb_change); + +/** + * ubi_leb_erase - erase logical eraseblock. + * @desc: volume descriptor + * @lnum: logical eraseblock number + * + * This function un-maps logical eraseblock @lnum and synchronously erases the + * correspondent physical eraseblock. Returns zero in case of success and a + * negative error code in case of failure. + * + * If the volume is damaged because of an interrupted update this function just + * returns immediately with %-EBADF code. + */ +int ubi_leb_erase(struct ubi_volume_desc *desc, int lnum) +{ + struct ubi_volume *vol = desc->vol; + struct ubi_device *ubi = vol->ubi; + int err; + + dbg_msg("erase LEB %d:%d", vol->vol_id, lnum); + + if (desc->mode == UBI_READONLY || vol->vol_type == UBI_STATIC_VOLUME) + return -EROFS; + + if (lnum < 0 || lnum >= vol->reserved_pebs) + return -EINVAL; + + if (vol->upd_marker) + return -EBADF; + + err = ubi_eba_unmap_leb(ubi, vol, lnum); + if (err) + return err; + + return ubi_wl_flush(ubi); +} +EXPORT_SYMBOL_GPL(ubi_leb_erase); + +/** + * ubi_leb_unmap - un-map logical eraseblock. + * @desc: volume descriptor + * @lnum: logical eraseblock number + * + * This function un-maps logical eraseblock @lnum and schedules the + * corresponding physical eraseblock for erasure, so that it will eventually be + * physically erased in background. This operation is much faster then the + * erase operation. + * + * Unlike erase, the un-map operation does not guarantee that the logical + * eraseblock will contain all 0xFF bytes when UBI is initialized again. For + * example, if several logical eraseblocks are un-mapped, and an unclean reboot + * happens after this, the logical eraseblocks will not necessarily be + * un-mapped again when this MTD device is attached. They may actually be + * mapped to the same physical eraseblocks again. So, this function has to be + * used with care. + * + * In other words, when un-mapping a logical eraseblock, UBI does not store + * any information about this on the flash media, it just marks the logical + * eraseblock as "un-mapped" in RAM. If UBI is detached before the physical + * eraseblock is physically erased, it will be mapped again to the same logical + * eraseblock when the MTD device is attached again. + * + * The main and obvious use-case of this function is when the contents of a + * logical eraseblock has to be re-written. Then it is much more efficient to + * first un-map it, then write new data, rather then first erase it, then write + * new data. Note, once new data has been written to the logical eraseblock, + * UBI guarantees that the old contents has gone forever. In other words, if an + * unclean reboot happens after the logical eraseblock has been un-mapped and + * then written to, it will contain the last written data. + * + * This function returns zero in case of success and a negative error code in + * case of failure. If the volume is damaged because of an interrupted update + * this function just returns immediately with %-EBADF code. + */ +int ubi_leb_unmap(struct ubi_volume_desc *desc, int lnum) +{ + struct ubi_volume *vol = desc->vol; + struct ubi_device *ubi = vol->ubi; + + dbg_msg("unmap LEB %d:%d", vol->vol_id, lnum); + + if (desc->mode == UBI_READONLY || vol->vol_type == UBI_STATIC_VOLUME) + return -EROFS; + + if (lnum < 0 || lnum >= vol->reserved_pebs) + return -EINVAL; + + if (vol->upd_marker) + return -EBADF; + + return ubi_eba_unmap_leb(ubi, vol, lnum); +} +EXPORT_SYMBOL_GPL(ubi_leb_unmap); + +/** + * ubi_leb_map - map logical erasblock to a physical eraseblock. + * @desc: volume descriptor + * @lnum: logical eraseblock number + * @dtype: expected data type + * + * This function maps an un-mapped logical eraseblock @lnum to a physical + * eraseblock. This means, that after a successfull invocation of this + * function the logical eraseblock @lnum will be empty (contain only %0xFF + * bytes) and be mapped to a physical eraseblock, even if an unclean reboot + * happens. + * + * This function returns zero in case of success, %-EBADF if the volume is + * damaged because of an interrupted update, %-EBADMSG if the logical + * eraseblock is already mapped, and other negative error codes in case of + * other failures. + */ +int ubi_leb_map(struct ubi_volume_desc *desc, int lnum, int dtype) +{ + struct ubi_volume *vol = desc->vol; + struct ubi_device *ubi = vol->ubi; + + dbg_msg("unmap LEB %d:%d", vol->vol_id, lnum); + + if (desc->mode == UBI_READONLY || vol->vol_type == UBI_STATIC_VOLUME) + return -EROFS; + + if (lnum < 0 || lnum >= vol->reserved_pebs) + return -EINVAL; + + if (dtype != UBI_LONGTERM && dtype != UBI_SHORTTERM && + dtype != UBI_UNKNOWN) + return -EINVAL; + + if (vol->upd_marker) + return -EBADF; + + if (vol->eba_tbl[lnum] >= 0) + return -EBADMSG; + + return ubi_eba_write_leb(ubi, vol, lnum, NULL, 0, 0, dtype); +} +EXPORT_SYMBOL_GPL(ubi_leb_map); + +/** + * ubi_is_mapped - check if logical eraseblock is mapped. + * @desc: volume descriptor + * @lnum: logical eraseblock number + * + * This function checks if logical eraseblock @lnum is mapped to a physical + * eraseblock. If a logical eraseblock is un-mapped, this does not necessarily + * mean it will still be un-mapped after the UBI device is re-attached. The + * logical eraseblock may become mapped to the physical eraseblock it was last + * mapped to. + * + * This function returns %1 if the LEB is mapped, %0 if not, and a negative + * error code in case of failure. If the volume is damaged because of an + * interrupted update this function just returns immediately with %-EBADF error + * code. + */ +int ubi_is_mapped(struct ubi_volume_desc *desc, int lnum) +{ + struct ubi_volume *vol = desc->vol; + + dbg_msg("test LEB %d:%d", vol->vol_id, lnum); + + if (lnum < 0 || lnum >= vol->reserved_pebs) + return -EINVAL; + + if (vol->upd_marker) + return -EBADF; + + return vol->eba_tbl[lnum] >= 0; +} +EXPORT_SYMBOL_GPL(ubi_is_mapped); diff --git a/drivers/mtd/ubi/misc.c b/drivers/mtd/ubi/misc.c new file mode 100644 index 0000000..a6410bf --- /dev/null +++ b/drivers/mtd/ubi/misc.c @@ -0,0 +1,106 @@ +/* + * Copyright (c) International Business Machines Corp., 2006 + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See + * the GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + * Author: Artem Bityutskiy (Битюцкий Артём) + */ + +/* Here we keep miscellaneous functions which are used all over the UBI code */ + +#include <ubi_uboot.h> +#include "ubi.h" + +/** + * calc_data_len - calculate how much real data is stored in a buffer. + * @ubi: UBI device description object + * @buf: a buffer with the contents of the physical eraseblock + * @length: the buffer length + * + * This function calculates how much "real data" is stored in @buf and returnes + * the length. Continuous 0xFF bytes at the end of the buffer are not + * considered as "real data". + */ +int ubi_calc_data_len(const struct ubi_device *ubi, const void *buf, + int length) +{ + int i; + + ubi_assert(!(length & (ubi->min_io_size - 1))); + + for (i = length - 1; i >= 0; i--) + if (((const uint8_t *)buf)[i] != 0xFF) + break; + + /* The resulting length must be aligned to the minimum flash I/O size */ + length = ALIGN(i + 1, ubi->min_io_size); + return length; +} + +/** + * ubi_check_volume - check the contents of a static volume. + * @ubi: UBI device description object + * @vol_id: ID of the volume to check + * + * This function checks if static volume @vol_id is corrupted by fully reading + * it and checking data CRC. This function returns %0 if the volume is not + * corrupted, %1 if it is corrupted and a negative error code in case of + * failure. Dynamic volumes are not checked and zero is returned immediately. + */ +int ubi_check_volume(struct ubi_device *ubi, int vol_id) +{ + void *buf; + int err = 0, i; + struct ubi_volume *vol = ubi->volumes[vol_id]; + + if (vol->vol_type != UBI_STATIC_VOLUME) + return 0; + + buf = vmalloc(vol->usable_leb_size); + if (!buf) + return -ENOMEM; + + for (i = 0; i < vol->used_ebs; i++) { + int size; + + if (i == vol->used_ebs - 1) + size = vol->last_eb_bytes; + else + size = vol->usable_leb_size; + + err = ubi_eba_read_leb(ubi, vol, i, buf, 0, size, 1); + if (err) { + if (err == -EBADMSG) + err = 1; + break; + } + } + + vfree(buf); + return err; +} + +/** + * ubi_calculate_rsvd_pool - calculate how many PEBs must be reserved for bad + * eraseblock handling. + * @ubi: UBI device description object + */ +void ubi_calculate_reserved(struct ubi_device *ubi) +{ + ubi->beb_rsvd_level = ubi->good_peb_count/100; + ubi->beb_rsvd_level *= CONFIG_MTD_UBI_BEB_RESERVE; + if (ubi->beb_rsvd_level < MIN_RESEVED_PEBS) + ubi->beb_rsvd_level = MIN_RESEVED_PEBS; +} diff --git a/drivers/mtd/ubi/scan.c b/drivers/mtd/ubi/scan.c new file mode 100644 index 0000000..fb02cd8 --- /dev/null +++ b/drivers/mtd/ubi/scan.c @@ -0,0 +1,1361 @@ +/* + * Copyright (c) International Business Machines Corp., 2006 + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See + * the GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + * Author: Artem Bityutskiy (Битюцкий Артём) + */ + +/* + * UBI scanning unit. + * + * This unit is responsible for scanning the flash media, checking UBI + * headers and providing complete information about the UBI flash image. + * + * The scanning information is represented by a &struct ubi_scan_info' object. + * Information about found volumes is represented by &struct ubi_scan_volume + * objects which are kept in volume RB-tree with root at the @volumes field. + * The RB-tree is indexed by the volume ID. + * + * Found logical eraseblocks are represented by &struct ubi_scan_leb objects. + * These objects are kept in per-volume RB-trees with the root at the + * corresponding &struct ubi_scan_volume object. To put it differently, we keep + * an RB-tree of per-volume objects and each of these objects is the root of + * RB-tree of per-eraseblock objects. + * + * Corrupted physical eraseblocks are put to the @corr list, free physical + * eraseblocks are put to the @free list and the physical eraseblock to be + * erased are put to the @erase list. + */ + +#if 0 +#include <linux/err.h> +#include <linux/crc32.h> +#include <asm/div64.h> +#endif + +#include <ubi_uboot.h> +#include "ubi.h" + +#ifdef CONFIG_MTD_UBI_DEBUG_PARANOID +static int paranoid_check_si(struct ubi_device *ubi, struct ubi_scan_info *si); +#else +#define paranoid_check_si(ubi, si) 0 +#endif + +/* Temporary variables used during scanning */ +static struct ubi_ec_hdr *ech; +static struct ubi_vid_hdr *vidh; + +/** + * add_to_list - add physical eraseblock to a list. + * @si: scanning information + * @pnum: physical eraseblock number to add + * @ec: erase counter of the physical eraseblock + * @list: the list to add to + * + * This function adds physical eraseblock @pnum to free, erase, corrupted or + * alien lists. Returns zero in case of success and a negative error code in + * case of failure. + */ +static int add_to_list(struct ubi_scan_info *si, int pnum, int ec, + struct list_head *list) +{ + struct ubi_scan_leb *seb; + + if (list == &si->free) + dbg_bld("add to free: PEB %d, EC %d", pnum, ec); + else if (list == &si->erase) + dbg_bld("add to erase: PEB %d, EC %d", pnum, ec); + else if (list == &si->corr) + dbg_bld("add to corrupted: PEB %d, EC %d", pnum, ec); + else if (list == &si->alien) + dbg_bld("add to alien: PEB %d, EC %d", pnum, ec); + else + BUG(); + + seb = kmalloc(sizeof(struct ubi_scan_leb), GFP_KERNEL); + if (!seb) + return -ENOMEM; + + seb->pnum = pnum; + seb->ec = ec; + list_add_tail(&seb->u.list, list); + return 0; +} + +/** + * validate_vid_hdr - check that volume identifier header is correct and + * consistent. + * @vid_hdr: the volume identifier header to check + * @sv: information about the volume this logical eraseblock belongs to + * @pnum: physical eraseblock number the VID header came from + * + * This function checks that data stored in @vid_hdr is consistent. Returns + * non-zero if an inconsistency was found and zero if not. + * + * Note, UBI does sanity check of everything it reads from the flash media. + * Most of the checks are done in the I/O unit. Here we check that the + * information in the VID header is consistent to the information in other VID + * headers of the same volume. + */ +static int validate_vid_hdr(const struct ubi_vid_hdr *vid_hdr, + const struct ubi_scan_volume *sv, int pnum) +{ + int vol_type = vid_hdr->vol_type; + int vol_id = be32_to_cpu(vid_hdr->vol_id); + int used_ebs = be32_to_cpu(vid_hdr->used_ebs); + int data_pad = be32_to_cpu(vid_hdr->data_pad); + + if (sv->leb_count != 0) { + int sv_vol_type; + + /* + * This is not the first logical eraseblock belonging to this + * volume. Ensure that the data in its VID header is consistent + * to the data in previous logical eraseblock headers. + */ + + if (vol_id != sv->vol_id) { + dbg_err("inconsistent vol_id"); + goto bad; + } + + if (sv->vol_type == UBI_STATIC_VOLUME) + sv_vol_type = UBI_VID_STATIC; + else + sv_vol_type = UBI_VID_DYNAMIC; + + if (vol_type != sv_vol_type) { + dbg_err("inconsistent vol_type"); + goto bad; + } + + if (used_ebs != sv->used_ebs) { + dbg_err("inconsistent used_ebs"); + goto bad; + } + + if (data_pad != sv->data_pad) { + dbg_err("inconsistent data_pad"); + goto bad; + } + } + + return 0; + +bad: + ubi_err("inconsistent VID header at PEB %d", pnum); + ubi_dbg_dump_vid_hdr(vid_hdr); + ubi_dbg_dump_sv(sv); + return -EINVAL; +} + +/** + * add_volume - add volume to the scanning information. + * @si: scanning information + * @vol_id: ID of the volume to add + * @pnum: physical eraseblock number + * @vid_hdr: volume identifier header + * + * If the volume corresponding to the @vid_hdr logical eraseblock is already + * present in the scanning information, this function does nothing. Otherwise + * it adds corresponding volume to the scanning information. Returns a pointer + * to the scanning volume object in case of success and a negative error code + * in case of failure. + */ +static struct ubi_scan_volume *add_volume(struct ubi_scan_info *si, int vol_id, + int pnum, + const struct ubi_vid_hdr *vid_hdr) +{ + struct ubi_scan_volume *sv; + struct rb_node **p = &si->volumes.rb_node, *parent = NULL; + + ubi_assert(vol_id == be32_to_cpu(vid_hdr->vol_id)); + + /* Walk the volume RB-tree to look if this volume is already present */ + while (*p) { + parent = *p; + sv = rb_entry(parent, struct ubi_scan_volume, rb); + + if (vol_id == sv->vol_id) + return sv; + + if (vol_id > sv->vol_id) + p = &(*p)->rb_left; + else + p = &(*p)->rb_right; + } + + /* The volume is absent - add it */ + sv = kmalloc(sizeof(struct ubi_scan_volume), GFP_KERNEL); + if (!sv) + return ERR_PTR(-ENOMEM); + + sv->highest_lnum = sv->leb_count = 0; + sv->vol_id = vol_id; + sv->root = RB_ROOT; + sv->used_ebs = be32_to_cpu(vid_hdr->used_ebs); + sv->data_pad = be32_to_cpu(vid_hdr->data_pad); + sv->compat = vid_hdr->compat; + sv->vol_type = vid_hdr->vol_type == UBI_VID_DYNAMIC ? UBI_DYNAMIC_VOLUME + : UBI_STATIC_VOLUME; + if (vol_id > si->highest_vol_id) + si->highest_vol_id = vol_id; + + rb_link_node(&sv->rb, parent, p); + rb_insert_color(&sv->rb, &si->volumes); + si->vols_found += 1; + dbg_bld("added volume %d", vol_id); + return sv; +} + +/** + * compare_lebs - find out which logical eraseblock is newer. + * @ubi: UBI device description object + * @seb: first logical eraseblock to compare + * @pnum: physical eraseblock number of the second logical eraseblock to + * compare + * @vid_hdr: volume identifier header of the second logical eraseblock + * + * This function compares 2 copies of a LEB and informs which one is newer. In + * case of success this function returns a positive value, in case of failure, a + * negative error code is returned. The success return codes use the following + * bits: + * o bit 0 is cleared: the first PEB (described by @seb) is newer then the + * second PEB (described by @pnum and @vid_hdr); + * o bit 0 is set: the second PEB is newer; + * o bit 1 is cleared: no bit-flips were detected in the newer LEB; + * o bit 1 is set: bit-flips were detected in the newer LEB; + * o bit 2 is cleared: the older LEB is not corrupted; + * o bit 2 is set: the older LEB is corrupted. + */ +static int compare_lebs(struct ubi_device *ubi, const struct ubi_scan_leb *seb, + int pnum, const struct ubi_vid_hdr *vid_hdr) +{ + void *buf; + int len, err, second_is_newer, bitflips = 0, corrupted = 0; + uint32_t data_crc, crc; + struct ubi_vid_hdr *vh = NULL; + unsigned long long sqnum2 = be64_to_cpu(vid_hdr->sqnum); + + if (seb->sqnum == 0 && sqnum2 == 0) { + long long abs, v1 = seb->leb_ver, v2 = be32_to_cpu(vid_hdr->leb_ver); + + /* + * UBI constantly increases the logical eraseblock version + * number and it can overflow. Thus, we have to bear in mind + * that versions that are close to %0xFFFFFFFF are less then + * versions that are close to %0. + * + * The UBI WL unit guarantees that the number of pending tasks + * is not greater then %0x7FFFFFFF. So, if the difference + * between any two versions is greater or equivalent to + * %0x7FFFFFFF, there was an overflow and the logical + * eraseblock with lower version is actually newer then the one + * with higher version. + * + * FIXME: but this is anyway obsolete and will be removed at + * some point. + */ + dbg_bld("using old crappy leb_ver stuff"); + + if (v1 == v2) { + ubi_err("PEB %d and PEB %d have the same version %lld", + seb->pnum, pnum, v1); + return -EINVAL; + } + + abs = v1 - v2; + if (abs < 0) + abs = -abs; + + if (abs < 0x7FFFFFFF) + /* Non-overflow situation */ + second_is_newer = (v2 > v1); + else + second_is_newer = (v2 < v1); + } else + /* Obviously the LEB with lower sequence counter is older */ + second_is_newer = sqnum2 > seb->sqnum; + + /* + * Now we know which copy is newer. If the copy flag of the PEB with + * newer version is not set, then we just return, otherwise we have to + * check data CRC. For the second PEB we already have the VID header, + * for the first one - we'll need to re-read it from flash. + * + * FIXME: this may be optimized so that we wouldn't read twice. + */ + + if (second_is_newer) { + if (!vid_hdr->copy_flag) { + /* It is not a copy, so it is newer */ + dbg_bld("second PEB %d is newer, copy_flag is unset", + pnum); + return 1; + } + } else { + pnum = seb->pnum; + + vh = ubi_zalloc_vid_hdr(ubi, GFP_KERNEL); + if (!vh) + return -ENOMEM; + + err = ubi_io_read_vid_hdr(ubi, pnum, vh, 0); + if (err) { + if (err == UBI_IO_BITFLIPS) + bitflips = 1; + else { + dbg_err("VID of PEB %d header is bad, but it " + "was OK earlier", pnum); + if (err > 0) + err = -EIO; + + goto out_free_vidh; + } + } + + if (!vh->copy_flag) { + /* It is not a copy, so it is newer */ + dbg_bld("first PEB %d is newer, copy_flag is unset", + pnum); + err = bitflips << 1; + goto out_free_vidh; + } + + vid_hdr = vh; + } + + /* Read the data of the copy and check the CRC */ + + len = be32_to_cpu(vid_hdr->data_size); + buf = vmalloc(len); + if (!buf) { + err = -ENOMEM; + goto out_free_vidh; + } + + err = ubi_io_read_data(ubi, buf, pnum, 0, len); + if (err && err != UBI_IO_BITFLIPS) + goto out_free_buf; + + data_crc = be32_to_cpu(vid_hdr->data_crc); + crc = crc32(UBI_CRC32_INIT, buf, len); + if (crc != data_crc) { + dbg_bld("PEB %d CRC error: calculated %#08x, must be %#08x", + pnum, crc, data_crc); + corrupted = 1; + bitflips = 0; + second_is_newer = !second_is_newer; + } else { + dbg_bld("PEB %d CRC is OK", pnum); + bitflips = !!err; + } + + vfree(buf); + ubi_free_vid_hdr(ubi, vh); + + if (second_is_newer) + dbg_bld("second PEB %d is newer, copy_flag is set", pnum); + else + dbg_bld("first PEB %d is newer, copy_flag is set", pnum); + + return second_is_newer | (bitflips << 1) | (corrupted << 2); + +out_free_buf: + vfree(buf); +out_free_vidh: + ubi_free_vid_hdr(ubi, vh); + return err; +} + +/** + * ubi_scan_add_used - add information about a physical eraseblock to the + * scanning information. + * @ubi: UBI device description object + * @si: scanning information + * @pnum: the physical eraseblock number + * @ec: erase counter + * @vid_hdr: the volume identifier header + * @bitflips: if bit-flips were detected when this physical eraseblock was read + * + * This function adds information about a used physical eraseblock to the + * 'used' tree of the corresponding volume. The function is rather complex + * because it has to handle cases when this is not the first physical + * eraseblock belonging to the same logical eraseblock, and the newer one has + * to be picked, while the older one has to be dropped. This function returns + * zero in case of success and a negative error code in case of failure. + */ +int ubi_scan_add_used(struct ubi_device *ubi, struct ubi_scan_info *si, + int pnum, int ec, const struct ubi_vid_hdr *vid_hdr, + int bitflips) +{ + int err, vol_id, lnum; + uint32_t leb_ver; + unsigned long long sqnum; + struct ubi_scan_volume *sv; + struct ubi_scan_leb *seb; + struct rb_node **p, *parent = NULL; + + vol_id = be32_to_cpu(vid_hdr->vol_id); + lnum = be32_to_cpu(vid_hdr->lnum); + sqnum = be64_to_cpu(vid_hdr->sqnum); + leb_ver = be32_to_cpu(vid_hdr->leb_ver); + + dbg_bld("PEB %d, LEB %d:%d, EC %d, sqnum %llu, ver %u, bitflips %d", + pnum, vol_id, lnum, ec, sqnum, leb_ver, bitflips); + + sv = add_volume(si, vol_id, pnum, vid_hdr); + if (IS_ERR(sv) < 0) + return PTR_ERR(sv); + + if (si->max_sqnum < sqnum) + si->max_sqnum = sqnum; + + /* + * Walk the RB-tree of logical eraseblocks of volume @vol_id to look + * if this is the first instance of this logical eraseblock or not. + */ + p = &sv->root.rb_node; + while (*p) { + int cmp_res; + + parent = *p; + seb = rb_entry(parent, struct ubi_scan_leb, u.rb); + if (lnum != seb->lnum) { + if (lnum < seb->lnum) + p = &(*p)->rb_left; + else + p = &(*p)->rb_right; + continue; + } + + /* + * There is already a physical eraseblock describing the same + * logical eraseblock present. + */ + + dbg_bld("this LEB already exists: PEB %d, sqnum %llu, " + "LEB ver %u, EC %d", seb->pnum, seb->sqnum, + seb->leb_ver, seb->ec); + + /* + * Make sure that the logical eraseblocks have different + * versions. Otherwise the image is bad. + */ + if (seb->leb_ver == leb_ver && leb_ver != 0) { + ubi_err("two LEBs with same version %u", leb_ver); + ubi_dbg_dump_seb(seb, 0); + ubi_dbg_dump_vid_hdr(vid_hdr); + return -EINVAL; + } + + /* + * Make sure that the logical eraseblocks have different + * sequence numbers. Otherwise the image is bad. + * + * FIXME: remove 'sqnum != 0' check when leb_ver is removed. + */ + if (seb->sqnum == sqnum && sqnum != 0) { + ubi_err("two LEBs with same sequence number %llu", + sqnum); + ubi_dbg_dump_seb(seb, 0); + ubi_dbg_dump_vid_hdr(vid_hdr); + return -EINVAL; + } + + /* + * Now we have to drop the older one and preserve the newer + * one. + */ + cmp_res = compare_lebs(ubi, seb, pnum, vid_hdr); + if (cmp_res < 0) + return cmp_res; + + if (cmp_res & 1) { + /* + * This logical eraseblock is newer then the one + * found earlier. + */ + err = validate_vid_hdr(vid_hdr, sv, pnum); + if (err) + return err; + + if (cmp_res & 4) + err = add_to_list(si, seb->pnum, seb->ec, + &si->corr); + else + err = add_to_list(si, seb->pnum, seb->ec, + &si->erase); + if (err) + return err; + + seb->ec = ec; + seb->pnum = pnum; + seb->scrub = ((cmp_res & 2) || bitflips); + seb->sqnum = sqnum; + seb->leb_ver = leb_ver; + + if (sv->highest_lnum == lnum) + sv->last_data_size = + be32_to_cpu(vid_hdr->data_size); + + return 0; + } else { + /* + * This logical eraseblock is older then the one found + * previously. + */ + if (cmp_res & 4) + return add_to_list(si, pnum, ec, &si->corr); + else + return add_to_list(si, pnum, ec, &si->erase); + } + } + + /* + * We've met this logical eraseblock for the first time, add it to the + * scanning information. + */ + + err = validate_vid_hdr(vid_hdr, sv, pnum); + if (err) + return err; + + seb = kmalloc(sizeof(struct ubi_scan_leb), GFP_KERNEL); + if (!seb) + return -ENOMEM; + + seb->ec = ec; + seb->pnum = pnum; + seb->lnum = lnum; + seb->sqnum = sqnum; + seb->scrub = bitflips; + seb->leb_ver = leb_ver; + + if (sv->highest_lnum <= lnum) { + sv->highest_lnum = lnum; + sv->last_data_size = be32_to_cpu(vid_hdr->data_size); + } + + sv->leb_count += 1; + rb_link_node(&seb->u.rb, parent, p); + rb_insert_color(&seb->u.rb, &sv->root); + return 0; +} + +/** + * ubi_scan_find_sv - find information about a particular volume in the + * scanning information. + * @si: scanning information + * @vol_id: the requested volume ID + * + * This function returns a pointer to the volume description or %NULL if there + * are no data about this volume in the scanning information. + */ +struct ubi_scan_volume *ubi_scan_find_sv(const struct ubi_scan_info *si, + int vol_id) +{ + struct ubi_scan_volume *sv; + struct rb_node *p = si->volumes.rb_node; + + while (p) { + sv = rb_entry(p, struct ubi_scan_volume, rb); + + if (vol_id == sv->vol_id) + return sv; + + if (vol_id > sv->vol_id) + p = p->rb_left; + else + p = p->rb_right; + } + + return NULL; +} + +/** + * ubi_scan_find_seb - find information about a particular logical + * eraseblock in the volume scanning information. + * @sv: a pointer to the volume scanning information + * @lnum: the requested logical eraseblock + * + * This function returns a pointer to the scanning logical eraseblock or %NULL + * if there are no data about it in the scanning volume information. + */ +struct ubi_scan_leb *ubi_scan_find_seb(const struct ubi_scan_volume *sv, + int lnum) +{ + struct ubi_scan_leb *seb; + struct rb_node *p = sv->root.rb_node; + + while (p) { + seb = rb_entry(p, struct ubi_scan_leb, u.rb); + + if (lnum == seb->lnum) + return seb; + + if (lnum > seb->lnum) + p = p->rb_left; + else + p = p->rb_right; + } + + return NULL; +} + +/** + * ubi_scan_rm_volume - delete scanning information about a volume. + * @si: scanning information + * @sv: the volume scanning information to delete + */ +void ubi_scan_rm_volume(struct ubi_scan_info *si, struct ubi_scan_volume *sv) +{ + struct rb_node *rb; + struct ubi_scan_leb *seb; + + dbg_bld("remove scanning information about volume %d", sv->vol_id); + + while ((rb = rb_first(&sv->root))) { + seb = rb_entry(rb, struct ubi_scan_leb, u.rb); + rb_erase(&seb->u.rb, &sv->root); + list_add_tail(&seb->u.list, &si->erase); + } + + rb_erase(&sv->rb, &si->volumes); + kfree(sv); + si->vols_found -= 1; +} + +/** + * ubi_scan_erase_peb - erase a physical eraseblock. + * @ubi: UBI device description object + * @si: scanning information + * @pnum: physical eraseblock number to erase; + * @ec: erase counter value to write (%UBI_SCAN_UNKNOWN_EC if it is unknown) + * + * This function erases physical eraseblock 'pnum', and writes the erase + * counter header to it. This function should only be used on UBI device + * initialization stages, when the EBA unit had not been yet initialized. This + * function returns zero in case of success and a negative error code in case + * of failure. + */ +int ubi_scan_erase_peb(struct ubi_device *ubi, const struct ubi_scan_info *si, + int pnum, int ec) +{ + int err; + struct ubi_ec_hdr *ec_hdr; + + if ((long long)ec >= UBI_MAX_ERASECOUNTER) { + /* + * Erase counter overflow. Upgrade UBI and use 64-bit + * erase counters internally. + */ + ubi_err("erase counter overflow at PEB %d, EC %d", pnum, ec); + return -EINVAL; + } + + ec_hdr = kzalloc(ubi->ec_hdr_alsize, GFP_KERNEL); + if (!ec_hdr) + return -ENOMEM; + + ec_hdr->ec = cpu_to_be64(ec); + + err = ubi_io_sync_erase(ubi, pnum, 0); + if (err < 0) + goto out_free; + + err = ubi_io_write_ec_hdr(ubi, pnum, ec_hdr); + +out_free: + kfree(ec_hdr); + return err; +} + +/** + * ubi_scan_get_free_peb - get a free physical eraseblock. + * @ubi: UBI device description object + * @si: scanning information + * + * This function returns a free physical eraseblock. It is supposed to be + * called on the UBI initialization stages when the wear-leveling unit is not + * initialized yet. This function picks a physical eraseblocks from one of the + * lists, writes the EC header if it is needed, and removes it from the list. + * + * This function returns scanning physical eraseblock information in case of + * success and an error code in case of failure. + */ +struct ubi_scan_leb *ubi_scan_get_free_peb(struct ubi_device *ubi, + struct ubi_scan_info *si) +{ + int err = 0, i; + struct ubi_scan_leb *seb; + + if (!list_empty(&si->free)) { + seb = list_entry(si->free.next, struct ubi_scan_leb, u.list); + list_del(&seb->u.list); + dbg_bld("return free PEB %d, EC %d", seb->pnum, seb->ec); + return seb; + } + + for (i = 0; i < 2; i++) { + struct list_head *head; + struct ubi_scan_leb *tmp_seb; + + if (i == 0) + head = &si->erase; + else + head = &si->corr; + + /* + * We try to erase the first physical eraseblock from the @head + * list and pick it if we succeed, or try to erase the + * next one if not. And so forth. We don't want to take care + * about bad eraseblocks here - they'll be handled later. + */ + list_for_each_entry_safe(seb, tmp_seb, head, u.list) { + if (seb->ec == UBI_SCAN_UNKNOWN_EC) + seb->ec = si->mean_ec; + + err = ubi_scan_erase_peb(ubi, si, seb->pnum, seb->ec+1); + if (err) + continue; + + seb->ec += 1; + list_del(&seb->u.list); + dbg_bld("return PEB %d, EC %d", seb->pnum, seb->ec); + return seb; + } + } + + ubi_err("no eraseblocks found"); + return ERR_PTR(-ENOSPC); +} + +/** + * process_eb - read UBI headers, check them and add corresponding data + * to the scanning information. + * @ubi: UBI device description object + * @si: scanning information + * @pnum: the physical eraseblock number + * + * This function returns a zero if the physical eraseblock was successfully + * handled and a negative error code in case of failure. + */ +static int process_eb(struct ubi_device *ubi, struct ubi_scan_info *si, int pnum) +{ + long long uninitialized_var(ec); + int err, bitflips = 0, vol_id, ec_corr = 0; + + dbg_bld("scan PEB %d", pnum); + + /* Skip bad physical eraseblocks */ + err = ubi_io_is_bad(ubi, pnum); + if (err < 0) + return err; + else if (err) { + /* + * FIXME: this is actually duty of the I/O unit to initialize + * this, but MTD does not provide enough information. + */ + si->bad_peb_count += 1; + return 0; + } + + err = ubi_io_read_ec_hdr(ubi, pnum, ech, 0); + if (err < 0) + return err; + else if (err == UBI_IO_BITFLIPS) + bitflips = 1; + else if (err == UBI_IO_PEB_EMPTY) + return add_to_list(si, pnum, UBI_SCAN_UNKNOWN_EC, &si->erase); + else if (err == UBI_IO_BAD_EC_HDR) { + /* + * We have to also look at the VID header, possibly it is not + * corrupted. Set %bitflips flag in order to make this PEB be + * moved and EC be re-created. + */ + ec_corr = 1; + ec = UBI_SCAN_UNKNOWN_EC; + bitflips = 1; + } + + si->is_empty = 0; + + if (!ec_corr) { + /* Make sure UBI version is OK */ + if (ech->version != UBI_VERSION) { + ubi_err("this UBI version is %d, image version is %d", + UBI_VERSION, (int)ech->version); + return -EINVAL; + } + + ec = be64_to_cpu(ech->ec); + if (ec > UBI_MAX_ERASECOUNTER) { + /* + * Erase counter overflow. The EC headers have 64 bits + * reserved, but we anyway make use of only 31 bit + * values, as this seems to be enough for any existing + * flash. Upgrade UBI and use 64-bit erase counters + * internally. + */ + ubi_err("erase counter overflow, max is %d", + UBI_MAX_ERASECOUNTER); + ubi_dbg_dump_ec_hdr(ech); + return -EINVAL; + } + } + + /* OK, we've done with the EC header, let's look at the VID header */ + + err = ubi_io_read_vid_hdr(ubi, pnum, vidh, 0); + if (err < 0) + return err; + else if (err == UBI_IO_BITFLIPS) + bitflips = 1; + else if (err == UBI_IO_BAD_VID_HDR || + (err == UBI_IO_PEB_FREE && ec_corr)) { + /* VID header is corrupted */ + err = add_to_list(si, pnum, ec, &si->corr); + if (err) + return err; + goto adjust_mean_ec; + } else if (err == UBI_IO_PEB_FREE) { + /* No VID header - the physical eraseblock is free */ + err = add_to_list(si, pnum, ec, &si->free); + if (err) + return err; + goto adjust_mean_ec; + } + + vol_id = be32_to_cpu(vidh->vol_id); + if (vol_id > UBI_MAX_VOLUMES && vol_id != UBI_LAYOUT_VOLUME_ID) { + int lnum = be32_to_cpu(vidh->lnum); + + /* Unsupported internal volume */ + switch (vidh->compat) { + case UBI_COMPAT_DELETE: + ubi_msg(""delete" compatible internal volume %d:%d" + " found, remove it", vol_id, lnum); + err = add_to_list(si, pnum, ec, &si->corr); + if (err) + return err; + break; + + case UBI_COMPAT_RO: + ubi_msg("read-only compatible internal volume %d:%d" + " found, switch to read-only mode", + vol_id, lnum); + ubi->ro_mode = 1; + break; + + case UBI_COMPAT_PRESERVE: + ubi_msg(""preserve" compatible internal volume %d:%d" + " found", vol_id, lnum); + err = add_to_list(si, pnum, ec, &si->alien); + if (err) + return err; + si->alien_peb_count += 1; + return 0; + + case UBI_COMPAT_REJECT: + ubi_err("incompatible internal volume %d:%d found", + vol_id, lnum); + return -EINVAL; + } + } + + /* Both UBI headers seem to be fine */ + err = ubi_scan_add_used(ubi, si, pnum, ec, vidh, bitflips); + if (err) + return err; + +adjust_mean_ec: + if (!ec_corr) { + si->ec_sum += ec; + si->ec_count += 1; + if (ec > si->max_ec) + si->max_ec = ec; + if (ec < si->min_ec) + si->min_ec = ec; + } + + return 0; +} + +/** + * ubi_scan - scan an MTD device. + * @ubi: UBI device description object + * + * This function does full scanning of an MTD device and returns complete + * information about it. In case of failure, an error code is returned. + */ +struct ubi_scan_info *ubi_scan(struct ubi_device *ubi) +{ + int err, pnum; + struct rb_node *rb1, *rb2; + struct ubi_scan_volume *sv; + struct ubi_scan_leb *seb; + struct ubi_scan_info *si; + + si = kzalloc(sizeof(struct ubi_scan_info), GFP_KERNEL); + if (!si) + return ERR_PTR(-ENOMEM); + + INIT_LIST_HEAD(&si->corr); + INIT_LIST_HEAD(&si->free); + INIT_LIST_HEAD(&si->erase); + INIT_LIST_HEAD(&si->alien); + si->volumes = RB_ROOT; + si->is_empty = 1; + + err = -ENOMEM; + ech = kzalloc(ubi->ec_hdr_alsize, GFP_KERNEL); + if (!ech) + goto out_si; + + vidh = ubi_zalloc_vid_hdr(ubi, GFP_KERNEL); + if (!vidh) + goto out_ech; + + DPRINTK("peb_count %d", ubi->peb_count); + for (pnum = 0; pnum < ubi->peb_count; pnum++) { + cond_resched(); + + dbg_msg("process PEB %d", pnum); + err = process_eb(ubi, si, pnum); + if (err < 0) + goto out_vidh; + } + + dbg_msg("scanning is finished"); + + /* Calculate mean erase counter */ + if (si->ec_count) { + do_div(si->ec_sum, si->ec_count); + si->mean_ec = si->ec_sum; + } + + if (si->is_empty) + ubi_msg("empty MTD device detected"); + + /* + * In case of unknown erase counter we use the mean erase counter + * value. + */ + ubi_rb_for_each_entry(rb1, sv, &si->volumes, rb) { + ubi_rb_for_each_entry(rb2, seb, &sv->root, u.rb) + if (seb->ec == UBI_SCAN_UNKNOWN_EC) + seb->ec = si->mean_ec; + } + + list_for_each_entry(seb, &si->free, u.list) { + if (seb->ec == UBI_SCAN_UNKNOWN_EC) + seb->ec = si->mean_ec; + } + + list_for_each_entry(seb, &si->corr, u.list) + if (seb->ec == UBI_SCAN_UNKNOWN_EC) + seb->ec = si->mean_ec; + + list_for_each_entry(seb, &si->erase, u.list) + if (seb->ec == UBI_SCAN_UNKNOWN_EC) + seb->ec = si->mean_ec; + + err = paranoid_check_si(ubi, si); + if (err) { + if (err > 0) + err = -EINVAL; + goto out_vidh; + } + + ubi_free_vid_hdr(ubi, vidh); + kfree(ech); + + return si; + +out_vidh: + ubi_free_vid_hdr(ubi, vidh); +out_ech: + kfree(ech); +out_si: + ubi_scan_destroy_si(si); + return ERR_PTR(err); +} + +/** + * destroy_sv - free the scanning volume information + * @sv: scanning volume information + * + * This function destroys the volume RB-tree (@sv->root) and the scanning + * volume information. + */ +static void destroy_sv(struct ubi_scan_volume *sv) +{ + struct ubi_scan_leb *seb; + struct rb_node *this = sv->root.rb_node; + + while (this) { + if (this->rb_left) + this = this->rb_left; + else if (this->rb_right) + this = this->rb_right; + else { + seb = rb_entry(this, struct ubi_scan_leb, u.rb); + this = rb_parent(this); + if (this) { + if (this->rb_left == &seb->u.rb) + this->rb_left = NULL; + else + this->rb_right = NULL; + } + + kfree(seb); + } + } + kfree(sv); +} + +/** + * ubi_scan_destroy_si - destroy scanning information. + * @si: scanning information + */ +void ubi_scan_destroy_si(struct ubi_scan_info *si) +{ + struct ubi_scan_leb *seb, *seb_tmp; + struct ubi_scan_volume *sv; + struct rb_node *rb; + + list_for_each_entry_safe(seb, seb_tmp, &si->alien, u.list) { + list_del(&seb->u.list); + kfree(seb); + } + list_for_each_entry_safe(seb, seb_tmp, &si->erase, u.list) { + list_del(&seb->u.list); + kfree(seb); + } + list_for_each_entry_safe(seb, seb_tmp, &si->corr, u.list) { + list_del(&seb->u.list); + kfree(seb); + } + list_for_each_entry_safe(seb, seb_tmp, &si->free, u.list) { + list_del(&seb->u.list); + kfree(seb); + } + + /* Destroy the volume RB-tree */ + rb = si->volumes.rb_node; + while (rb) { + if (rb->rb_left) + rb = rb->rb_left; + else if (rb->rb_right) + rb = rb->rb_right; + else { + sv = rb_entry(rb, struct ubi_scan_volume, rb); + + rb = rb_parent(rb); + if (rb) { + if (rb->rb_left == &sv->rb) + rb->rb_left = NULL; + else + rb->rb_right = NULL; + } + + destroy_sv(sv); + } + } + + kfree(si); +} + +#ifdef CONFIG_MTD_UBI_DEBUG_PARANOID + +/** + * paranoid_check_si - check if the scanning information is correct and + * consistent. + * @ubi: UBI device description object + * @si: scanning information + * + * This function returns zero if the scanning information is all right, %1 if + * not and a negative error code if an error occurred. + */ +static int paranoid_check_si(struct ubi_device *ubi, struct ubi_scan_info *si) +{ + int pnum, err, vols_found = 0; + struct rb_node *rb1, *rb2; + struct ubi_scan_volume *sv; + struct ubi_scan_leb *seb, *last_seb; + uint8_t *buf; + + /* + * At first, check that scanning information is OK. + */ + ubi_rb_for_each_entry(rb1, sv, &si->volumes, rb) { + int leb_count = 0; + + cond_resched(); + + vols_found += 1; + + if (si->is_empty) { + ubi_err("bad is_empty flag"); + goto bad_sv; + } + + if (sv->vol_id < 0 || sv->highest_lnum < 0 || + sv->leb_count < 0 || sv->vol_type < 0 || sv->used_ebs < 0 || + sv->data_pad < 0 || sv->last_data_size < 0) { + ubi_err("negative values"); + goto bad_sv; + } + + if (sv->vol_id >= UBI_MAX_VOLUMES && + sv->vol_id < UBI_INTERNAL_VOL_START) { + ubi_err("bad vol_id"); + goto bad_sv; + } + + if (sv->vol_id > si->highest_vol_id) { + ubi_err("highest_vol_id is %d, but vol_id %d is there", + si->highest_vol_id, sv->vol_id); + goto out; + } + + if (sv->vol_type != UBI_DYNAMIC_VOLUME && + sv->vol_type != UBI_STATIC_VOLUME) { + ubi_err("bad vol_type"); + goto bad_sv; + } + + if (sv->data_pad > ubi->leb_size / 2) { + ubi_err("bad data_pad"); + goto bad_sv; + } + + last_seb = NULL; + ubi_rb_for_each_entry(rb2, seb, &sv->root, u.rb) { + cond_resched(); + + last_seb = seb; + leb_count += 1; + + if (seb->pnum < 0 || seb->ec < 0) { + ubi_err("negative values"); + goto bad_seb; + } + + if (seb->ec < si->min_ec) { + ubi_err("bad si->min_ec (%d), %d found", + si->min_ec, seb->ec); + goto bad_seb; + } + + if (seb->ec > si->max_ec) { + ubi_err("bad si->max_ec (%d), %d found", + si->max_ec, seb->ec); + goto bad_seb; + } + + if (seb->pnum >= ubi->peb_count) { + ubi_err("too high PEB number %d, total PEBs %d", + seb->pnum, ubi->peb_count); + goto bad_seb; + } + + if (sv->vol_type == UBI_STATIC_VOLUME) { + if (seb->lnum >= sv->used_ebs) { + ubi_err("bad lnum or used_ebs"); + goto bad_seb; + } + } else { + if (sv->used_ebs != 0) { + ubi_err("non-zero used_ebs"); + goto bad_seb; + } + } + + if (seb->lnum > sv->highest_lnum) { + ubi_err("incorrect highest_lnum or lnum"); + goto bad_seb; + } + } + + if (sv->leb_count != leb_count) { + ubi_err("bad leb_count, %d objects in the tree", + leb_count); + goto bad_sv; + } + + if (!last_seb) + continue; + + seb = last_seb; + + if (seb->lnum != sv->highest_lnum) { + ubi_err("bad highest_lnum"); + goto bad_seb; + } + } + + if (vols_found != si->vols_found) { + ubi_err("bad si->vols_found %d, should be %d", + si->vols_found, vols_found); + goto out; + } + + /* Check that scanning information is correct */ + ubi_rb_for_each_entry(rb1, sv, &si->volumes, rb) { + last_seb = NULL; + ubi_rb_for_each_entry(rb2, seb, &sv->root, u.rb) { + int vol_type; + + cond_resched(); + + last_seb = seb; + + err = ubi_io_read_vid_hdr(ubi, seb->pnum, vidh, 1); + if (err && err != UBI_IO_BITFLIPS) { + ubi_err("VID header is not OK (%d)", err); + if (err > 0) + err = -EIO; + return err; + } + + vol_type = vidh->vol_type == UBI_VID_DYNAMIC ? + UBI_DYNAMIC_VOLUME : UBI_STATIC_VOLUME; + if (sv->vol_type != vol_type) { + ubi_err("bad vol_type"); + goto bad_vid_hdr; + } + + if (seb->sqnum != be64_to_cpu(vidh->sqnum)) { + ubi_err("bad sqnum %llu", seb->sqnum); + goto bad_vid_hdr; + } + + if (sv->vol_id != be32_to_cpu(vidh->vol_id)) { + ubi_err("bad vol_id %d", sv->vol_id); + goto bad_vid_hdr; + } + + if (sv->compat != vidh->compat) { + ubi_err("bad compat %d", vidh->compat); + goto bad_vid_hdr; + } + + if (seb->lnum != be32_to_cpu(vidh->lnum)) { + ubi_err("bad lnum %d", seb->lnum); + goto bad_vid_hdr; + } + + if (sv->used_ebs != be32_to_cpu(vidh->used_ebs)) { + ubi_err("bad used_ebs %d", sv->used_ebs); + goto bad_vid_hdr; + } + + if (sv->data_pad != be32_to_cpu(vidh->data_pad)) { + ubi_err("bad data_pad %d", sv->data_pad); + goto bad_vid_hdr; + } + + if (seb->leb_ver != be32_to_cpu(vidh->leb_ver)) { + ubi_err("bad leb_ver %u", seb->leb_ver); + goto bad_vid_hdr; + } + } + + if (!last_seb) + continue; + + if (sv->highest_lnum != be32_to_cpu(vidh->lnum)) { + ubi_err("bad highest_lnum %d", sv->highest_lnum); + goto bad_vid_hdr; + } + + if (sv->last_data_size != be32_to_cpu(vidh->data_size)) { + ubi_err("bad last_data_size %d", sv->last_data_size); + goto bad_vid_hdr; + } + } + + /* + * Make sure that all the physical eraseblocks are in one of the lists + * or trees. + */ + buf = kzalloc(ubi->peb_count, GFP_KERNEL); + if (!buf) + return -ENOMEM; + + for (pnum = 0; pnum < ubi->peb_count; pnum++) { + err = ubi_io_is_bad(ubi, pnum); + if (err < 0) { + kfree(buf); + return err; + } + else if (err) + buf[pnum] = 1; + } + + ubi_rb_for_each_entry(rb1, sv, &si->volumes, rb) + ubi_rb_for_each_entry(rb2, seb, &sv->root, u.rb) + buf[seb->pnum] = 1; + + list_for_each_entry(seb, &si->free, u.list) + buf[seb->pnum] = 1; + + list_for_each_entry(seb, &si->corr, u.list) + buf[seb->pnum] = 1; + + list_for_each_entry(seb, &si->erase, u.list) + buf[seb->pnum] = 1; + + list_for_each_entry(seb, &si->alien, u.list) + buf[seb->pnum] = 1; + + err = 0; + for (pnum = 0; pnum < ubi->peb_count; pnum++) + if (!buf[pnum]) { + ubi_err("PEB %d is not referred", pnum); + err = 1; + } + + kfree(buf); + if (err) + goto out; + return 0; + +bad_seb: + ubi_err("bad scanning information about LEB %d", seb->lnum); + ubi_dbg_dump_seb(seb, 0); + ubi_dbg_dump_sv(sv); + goto out; + +bad_sv: + ubi_err("bad scanning information about volume %d", sv->vol_id); + ubi_dbg_dump_sv(sv); + goto out; + +bad_vid_hdr: + ubi_err("bad scanning information about volume %d", sv->vol_id); + ubi_dbg_dump_sv(sv); + ubi_dbg_dump_vid_hdr(vidh); + +out: + ubi_dbg_dump_stack(); + return 1; +} + +#endif /* CONFIG_MTD_UBI_DEBUG_PARANOID */
Dear Kyungmin Park,
In message 20081021091839.GA29297@july you wrote:
Tm93IGl0IGNhbiB1c2UgVUJJIHN1cHBvcnQgb24gVS1Cb290CgpTaWduZWQtb2ZmLWJ5OiBLeXVu Z21pbiBQYXJrIDxreXVuZ21pbi5wYXJrQHNhbXN1bmcuY29tPgotLS0KIE1ha2VmaWxlICAgICAg ICAgICAgICAgICAgICAgICB8ICAgIDEgKwogZHJpdmVycy9tdGQvTWFrZWZpbGUgICAgICAgICAg IHwgICAgMSArCiBkcml2ZXJzL210ZC9tdGRjb3JlLmMgICAgICAgICAgfCAgMTQyICsrKysKIGRy aXZlcnMvbXRkL210ZHBhcnQuYyAgICAgICAgICB8ICA1MzEgKysrKysrKysrKysrKwogZHJpdmVy
Please post patches as PLAIN TEXT, not with base64 encoding!!!
There are lots of coding style violations: trailing white space, using spaces instead of TABs for indentation and for vertical alignment, using C++ comments, etc.
Now it can use UBI support on U-Boot
That's not really a good commit message, it seems.
index 0000000..a9f494a --- /dev/null +++ b/drivers/mtd/mtdcore.c @@ -0,0 +1,142 @@ +/*
- $Id: mtdcore.c,v 1.47 2005/11/07 11:14:20 gleixner Exp $
Please do not include versioninformation in files. We use git for this.
- Core registration and callback routines for MTD
- drivers and users.
GPL header missing - here and in many other files.
+int add_mtd_device(struct mtd_info *mtd) +{
- int i;
- BUG_ON(mtd->writesize == 0);
What's that?
- for (i=0; i < MAX_MTD_DEVICES; i++)
Need "{...}" for multi-line statements.
if (!mtd_table[i]) {
mtd_table[i] = mtd;
mtd->index = i;
mtd->usecount = 0;
printf("mtd: Giving out device %d to %s\n",i, mtd->name);
/* No need to get a refcount on the module containing
the notifier, since we hold the mtd_table_mutex */
/* We _know_ we aren't being removed, because
our caller is still holding us here. So none
of this try_ nonsense, and no bitching about it
either. :) */
- return 1;
Please use plain "/*" as start of multiline comments. Here and everywhere.
diff --git a/drivers/mtd/mtdpart.c b/drivers/mtd/mtdpart.c new file mode 100644 index 0000000..113516a --- /dev/null +++ b/drivers/mtd/mtdpart.c @@ -0,0 +1,531 @@ +/*
- Simple MTD partitioning layer
Hm... We were talking about UBI support.
Do we really have to pull in the whole MTD layer from Linux for this?
I'm not exactly happy about this.
+#if 0
- if (unlikely(res)) {
if (res == -EUCLEAN)
mtd->ecc_stats.corrected++;
if (res == -EBADMSG)
mtd->ecc_stats.failed++;
- return res;
+#if 0
Please do not add dead code.
index 0000000..bf8a19f --- /dev/null +++ b/drivers/mtd/ubi/build.c @@ -0,0 +1,1182 @@ +/*
- Copyright (c) International Business Machines Corp., 2006
- Copyright (c) Nokia Corporation, 2007
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
- (at your option) any later version.
- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See
- the GNU General Public License for more details.
- Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
- Author: Artem Bityutskiy (ÐиÑÑÑкий ÐÑÑÑм),
Frank Haverkamp
- This file includes UBI initialization and building of UBI devices.
- When UBI is initialized, it attaches all the MTD devices specified as the
- module load parameters or the kernel boot parameters. If MTD devices were
- specified, UBI does not attach any MTD device, but it is possible to do
- later using the "UBI control device".
- At the moment we only attach UBI devices by scanning, which will become a
- bottleneck when flashes reach certain large size. Then one may improve UBI
- and add other methods, although it does not seem to be easy to do.
+#if 0 +#include <linux/err.h> +#include <linux/module.h> +#include <linux/moduleparam.h> +#include <linux/stringify.h> +#include <linux/stat.h> +#include <linux/miscdevice.h> +#include <linux/log2.h> +#include <linux/kthread.h> +#endif
Please do not add dead code - here and everywhere.
- ubi_major2num - get UBI device number by character device major number.
- @major: major number
- This function searches UBI device number object by its major number. If UBI
- device was not found, this function returns -ENODEV, otherwise the UBI device
- number is returned.
+int ubi_major2num(int major) +{
- int i, ubi_num = -ENODEV;
- spin_lock(&ubi_devices_lock);
- for (i = 0; i < UBI_MAX_DEVICES; i++) {
struct ubi_device *ubi = ubi_devices[i];
if (ubi && MAJOR(ubi->cdev.dev) == major) {
ubi_num = ubi->ubi_num;
break;
- spin_unlock(&ubi_devices_lock);
- return ubi_num;
Hm... it does not make sense to me to pull in the whole Linux OS unfiltered.
Should we not try and restrict the code to the functions that are really needed and used in U-Boot?
We do not have any such stuff like major or minor device numbers here. And no permissions and al the othe rstuff.
+#if 0 +/* "Show" method for files in '/<sysfs>/class/ubi/ubiX/' */ +static ssize_t dev_attribute_show(struct device *dev,
struct device_attribute *attr, char *buf)
Argh... Again tons of dead code.
I stop reviewing here. It makes no sense.
Can you pelase discuss with Stefan internally how to reduce the amount of code you are importing?
It definitely makes no sense to me to import the whole Linux OS here. If we think we want to run this code, then we should boot Linux instead :-(
Hi Wolfgang & Kyungmin,
Wolfgang, thanks for the internal discussion about this. I now know that you have no general concerns about the Linux "code cloning". But please find my original comments (written before the internal discussion) below.
Ack.
That's directly imported from the Linux source. Most of your comments below also deal with this Linux code copying. I personally think it is a good idea to clone the code from Linux instead of writing a U-Boot specific UBI driver. We have done this before on other occasions and it makes perfect sense here too from my point of view. It makes porting easier and faster and less error prone and even more important, it makes porting of new versions, fixes etc easier.
- int i;
What's that?
It's handled in the UBI Linux->U-Boot porting "layer" (include/ubi_uboot.h):
#define BUILD_BUG_ON(condition) ((void)sizeof(char[1 - 2*!!(condition)]))
Again this has been done before:
[stefan@kubuntu u-boot (master)]$ git grep BUG_ON include/ include/common.h:#define BUG_ON(condition) do { if (unlikely((condition)!=0)) BUG(); } while(0) include/linux/mtd/compat.h:#define BUG_ON(condition) do { if (condition) BUG(); } while(0)
Again from the Linux original source. When we start changing this code because of coding-style issue, it will get very hard to compare those versions and add fixes in the future. So I vote for keeping the code as is. It's not that ugly, at least from my understanding.
mtd_table[i] = mtd;
mtd->index = i;
mtd->usecount = 0;
either. :) */
- return 1;
Again I vote for not changing it.
+#if 0
- return res;
+#if 0
Here I'm not sure which version I prefer. The one Kyungmin used, disabling the not needed code via #if 0 (or something else, like #if UBI_LINUX), or completely removing it. Both has some advantages. But again for comparison with the original Linux source it's perhaps better to just disable the code. An "#if UBI_LINIX" is probably better than on "#if 0" though.
USA + *
Frank Haverkamp
the + * module load parameters or the kernel boot parameters. If MTD devices were + * specified, UBI does not attach any MTD device, but it is possible to do + * later using the "UBI control device".
become a + * bottleneck when flashes reach certain large size. Then one may improve UBI + * and add other methods, although it does not seem to be easy to do. + */
number. + * @major: major number
If UBI + * device was not found, this function returns -ENODEV, otherwise the UBI device + * number is returned.
break;
- return ubi_num;
Of course we haven't. But it's hard to draw the line *if* you decide to include the Linux source. Most OS functions (like spin_lock()...) are defined to no-ops in ubi_uboot.h. So it doesn't really increase the code size for U-Boot. It just keeps the source in-line with the Linux version.
Kyungmin, do you have any ideas on parts of this code that can be removed/dropped completely? Other than the "#if 0" parts?
Thanks.
Best regards, Stefan
Dear Stefan Roese,
We agree on that. So maybe we should send coding style cleanup patches for the Linux kenrel?
This *is* a serious issue. And I don;t care wether the code comes from Linux or not, but I will not accept any code without absolutley clear licensing conditions.
It is a clear violation of Linux Coding Style requirements.
If we don;t want to fix it here, I suggest to fixit at the origin, i.e. in Linux.
Here I'm not sure which version I prefer. The one Kyungmin used, disabling > the not needed code via #if 0 (or something else, like #if UBI_LINUX), or completely removing it. Both has some advantages. But again for comparison> with the original Linux source it's perhaps better to just disable the code> . An "#if UBI_LINIX" is probably better than on "#if 0" though.
There is two things I am concerned about:
1) Do we really need all these files? 2) Do we really need all of this code?
Lots of the code that was left in was obviously dealing with features we don;t have in U-Boot, and will not have: concepts like user IDs, file permissions, major and minor numbers, etc.
Of course we haven't. But it's hard to draw the line *if* you decide to include the Linux source. Most OS functions (like spin_lock()...) are defin> ed to no-ops in ubi_uboot.h. So it doesn't really increase the code size for U-Boot. It just keeps the source in-line with the Linux version.
On the other hand it makes it semi-impossible to review the code in U-Boot context, or even to get an understanding of flow of control etc.
Dear Wolfgang and Stefan,
On Tue, Oct 21, 2008 at 10:16 PM, Wolfgang Denk wd@denx.de wrote:
Dear Stefan Roese,
I added the GPL.
It's needed. almost flash related code except the NOR, are based on MTD and uses. Event though it's only compiled UBI command, it will be changed. Now partition codes use own implementation at u-boot, I think it's better MTD partition code.
I change to use UBI_LINUX instead of if 0.
- Do we really need all these files?
- Do we really need all of this code?
Basically I think if we use the imported code. we don't modify code itself. Instead we give some adaptation layer or wrapper. In this case I use the latter. ubi_uboot.h wrapped the UBI kernel code and can run it on u-boot. Of course it disables the some linux specific kernel if can't wrap.
Meanwhile who is the main users of this modules? It's linux kernel. It means users can familiar with kernel UBI code and they can use it more easily. They don't need to understand the UBI code at u-boot.
Thank you, Kyungmin Park
Kyungmin Park
Stefan Roese
