[U-Boot] What if ATF can be part of U-Boot source, like SPL?
In terms of code maintenance and development feasibility it is always a better approach to have out-of-tree code or binary to be part of in-house source tree.
This is what exactly it was done for SPL, if I'm not wrong. So can we do the same thing for ATF on ARM64 SoCs?
We are using ATF (on Allwinner) to switch EL3 to EL2 for start loading U-Boot proper and minimal PSCI, PMIC initialization. So assuming the functionality of ATF (like here) is limited so the code it require can be limited too, so why can't this code to be part of U-Boot tree?
This would ultimately avoid out-off-tree ATF builds with associated variable exporting during u-boot builds.
More over this idea would also help to design a single-step bootloader where it can't depends on out-of-tree sources.
Code sync from ATF source to U-Boot can be possible in-terms licensing point-of-view since ATF licensed under BSD-3-Clause.
I'm thinking this can be a worth-idea to look at it and I'm sure It may require some hard changes and other things to consider but just posted to understand how hard or feasible or meaningful it is?
Feel free for any comments?
Jagan, Amarula Solutions India.
From: Jagan Teki jagan@amarulasolutions.com Date: Sat, 29 Jun 2019 20:32:00 +0530
I disagree. This strategy often leads to diverging codebases where local improvements are not fed back upstream and/or not picking up bug- and security fixes from upstream.
It also means that developers of non-ARM U-Boot platforms will have to check out the full ATF source tree.
SPL and U-Boot proper share a lot of code. I'd say it is totally different.
I don't see this as a huge issue. For OpenBSD we already have the (small) build infrastructure to handle this.
I don't think this makes a lot of sense. Apart from what I wrote above, some platforms use U-Boot as a payload for ATF (or TF-A as it is called now) instead of the other way around. It also makes it difficult to do development on platforms where ATF sources have not yet been upstreamed.
You are free to do so locally, but following this train of thought would possibly lead to putting Linux kernel sources in the same repository too, and possible the entire userspace.
Mixing two completely different projects, with different goals, makes zero sense.
I agree with Mark, SPL and U-Boot share a lot of code.
ATF and U-Boot share nothing, in fact, from what I was told, ATF was designed to be explicitly non-GPL, to make it easier for vendors to take the ATF code and close source it. Hence, ATF cannot import any U-Boot code and reimplements everything from scratch.
See above.
See the Linux + userspace argument.
U-Boot code should ideally be GPLv2, other licenses should be an exception.
IMO the better solution here would be to take the BL2 hardware init code and put it into SPL. Then you won't need the ATF BL1/BL2 hardware init, which is the bulk of what ATF does on many platforms.
If you need resident services, BL31, either implement some sort of PSCI-like support into U-Boot (possibly alongside SPL/TPL/U-Boot proper), or build it from ATF sources.
I am not sure this is really true. If I get you right, you want to mirror and sync the ATF source into the U-Boot tree, which sounds like a pain: - ATF development is quite dynamic, with just shy of 1000 commits alone this year. This would mean constant churn of keeping the source up-to-date. - The overlap of U-Boot and ATF users is not that big: ATF has support for a lot more platforms (most of them typically paired with EDK-2), also provides a lot more code than U-Boot platforms typically use: BL1, BL2, secure payload support, etc. I am not sure a lot of people are happy if we add tons of code lines to the repo which will never be used.
But this SPL/proper code sharing does not come without a price. Think about the problems with DM and the often limited SPL code size, which causes us some headaches. Also I wonder how much code they actually share? Thinking about DRAM init, the separate SPI flash driver for Allwinner and all those #ifdefs everywhere. I am not questioning the current design, but just want to point out that this might not be best thing since sliced bread.
Minimal PSCI? TF-A is the full fledged reference implementation of PSCI, it always supports the newest revisions, including Spectre/Meltdown support. This alone is a killer argument for me to use ATF.
So do you want to just import the part of ATF that we need? That sounds like a pain to start off first and will even induce more pain once ATF changes something. They are doing constant refactoring and increasing the code sharing, so ripping something out of there will not end well.
So what is the problem you are seeing with the current approach, exactly? Is it just that it's annoying to have an external binary glued in? I don't buy that this is a real problem.
What do you mean with single-step bootloader, exactly? I think it's actually an advantage to have the steps in separate projects. So every platform can use a common ATF, and they have a choice of U-Boot and EDK-2, for instance. Or skip the extra loader altogether, just use the SPL and launch the kernel from ATF directly. I hacked this once for Allwinner based on this: https://git.trustedfirmware.org/TF-A/trusted-firmware-a.git/tree/docs/plat/r...
Apart from the practical issues I outlined above I don't see the architectural merit of merging in ATF. What actually would make more sense is to merge the SPL into ATF, so that we have a clean separation between platform initialisation and boot loader. But this also has a lot of practical issues, and as mentioned I don't really see that the current process is that painful that it demands such changes.
Cheers, Andre.
this year.
I don't think ATF development is anywhere near as dynamic as U-Boot, there's over 1000 commits in each U-Boot release, with quarterly release cycle.
Can you elaborate on how you came to this conclusion ? Last time I counted (a few days ago, in ATF master), the upstream ATF supported some low tens of boards, upstream U-Boot around a thousand. And then there's the part where ATF is ARM-centric while U-Boot is platform-agnostic.
BL1 is bootrom, right ? BL2 is hardware initialization, which is roughly doing the same thing as U-Boot SPL. Secure payload support was in U-Boot for a very long time too.
Maybe you should take a look at some other platform(s), rather than draw conclusion from one platform, that's not a good statistical practice. SoCFPGA for example uses the same drivers in SPL as it does in U-Boot, same for TI, and I can go on.
Allwinner has severe SRAM limitations, so there it cannot be helped that it needs custom driver. I don't see how using ATF would make any difference here.
It would certainly help if we could have one, or a few, bootloader project(s) and work on those few, to make them great. Currently there are many, each with a limited developer community. Adding more does not help, it only increases the fragmentation and the mess.
So ARM creates new PSCI version, ARM implements it into ARM trusted firmware, and then presents it to the users as the latest greatest. That sounds a bit like the old windows development model -- one company does everything and then presents it to developers for them to consume.
My recent impression of ATF development is there is no community around ATF, so I presume there is no interest from collecting any feedback on the PSCI development from people outside of ARM, is that right ?
On 30/06/2019 00:03, Marek Vasut wrote:
Marek,
you seem to be quite defensive in your answer, but I was just talking against merging ATF into U-Boot, not against U-Boot - I think we agree on this. I don't think there is much of a point in comparing ATF and U-Boot, as the two do not compete against each other. They just complement each other nicely, hence we use ATF and save us the burden of having to reprogram something in U-Boot.
this year.
Wasn't comparing, just saying that it's nothing you want to sync regularly. Unlike libfdt, for instance.
I now see that my wording was unclear: ATF supports more platforms than those that also use U-Boot. So you pull in code that you will never need.
I was just pointing out that ATF and U-Boot are quite different and there is very little (if at all) overlap. So if you pull in ATF, you pull in all those BLx code that you don't need. And since ATF is heavily sharing code between the stages, you can't easily rip one out.
I didn't say it would, I was merely saying that the SPL code sharing is not always as big as one might think, and that this code sharing comes at a price - the ifdef hell, for instance. So it might not serve as a picture book example of perfect integration - especially since the experience with integrating ATF would be much worse. But as mentioned below here, I am not fighting this SPL model.
And that's exactly the point of ATF: You can use the tested PSCI code, the secure GIC setup and all those core errata workarounds and spare yourself from wrongly implementing this on your own. Also ATF is not a bootloader, it explicitly leaves out that part.
Yes, that's the definition of a reference implementation. And it's Open Source with a permissive license.
PSCI is an interface, with a publicly available spec. You can go ahead and implement it yourself - and U-Boot does. And by using PSCI, you win so much, because SMP in *any* kernel suddenly becomes very straightforward. So if you mean with "Windows model" that there is a standard that makes everyone's life easier by providing compatibility and well defined interfaces - I agree. For everything else I fail to see how it would compare.
ATF and PSCI are two quite separate things, it's just that the former implements the latter. And I am not sure how the community aspect relates to the feedback process. Section 1.1 in the PSCI PDF tells you about how to report back any comments.
Anything in particular you want to discuss about PSCI? Happy to make contacts.
Cheers, Andre.
Marek,
I am just correcting the mistakes I perceive in the previous email.
I suspect I answered those already in the thread.
this year.
I think s/more/different/
Which is a benefit of one single vendor being in control of everything? Surely, this single vendor has perfect engineers that make no mistakes, right? I think we had that before, and it didn't work out very well :)
Yes, it's Open Source and it's not Free Software, which is unfortunate. It allows disasters like vendors taking ATF, reaping all the benefits of external contributions, but releasing only closed-source blobs and giving everyone who wants to study the code or change it the finger.
Just about like ACPI on x86.
I meant more like one company in control of everything, just providing consumables for developers.
I am talking about ATF.
Marek,
this year.
I have been avoiding this thread but today I attended a talk on ATF and ARM's approach in general. ARM seems to be moving towards an approach of providing increasingly complex source code to add more layers of security software to fully round out two mostly separate worlds (secure and normal).
Oddly enough Intel was also there talking about how they are breaking things down into pieces and slowly releasing more things into the open source world.
I came away with the impression that the two companies are going in different directions. ARM seems to be heading where Intel was and Intel is heading back. This is a gross simplification of course.
To me it seems that the following scenario might play out:
1. ARM releases new ATF versions as source drops that firmware projects like U-Boot expected to take. In fact, not even U-Boot...this is just users picking up whatever they find
2. ATF keeps getting more complex, adding its own drivers for serial, storage, etc., duplicating and perhaps conflicting with those in U-Boot
3. Over time we end up with binary blobs on ARM that are every bit as impenetrable as what Intel used to have
4. Firmware security and open-sourceness suffers, overall.
One approach might be for ATF to split into a library which can be linked into a new U-Boot phase and a driver/init bit that could be used for other bootloaders, whatever they might be.
But in the meantime, I think it makes more sense to incorporate the relevant parts of ATF into U-Boot and maintain them there, only for the platforms that U-Boot supports. If ATF starts using GUIDs and the like, we at least have somewhere to hide :-)
So overall I support Jagan's proposal based on the current status quo.
On Tue, 3 Sep 2019 19:17:14 -0700 Simon Glass sjg@chromium.org wrote:
Hi Simon,
Marek,
this year.
- ARM releases new ATF versions as source drops that firmware
- ATF keeps getting more complex, adding its own drivers for serial,
A bit like U-Boot, ATF can look quite differently on the various platforms: - There are platforms like Arm's Juno or the fastmodel, where ATF does some loading. This is mostly for features like secure boot or secure payloads (OP-Tee). Typically we don't even use U-Boot primarily on those platforms (but EDK II instead). - There are platforms (low end SoCs like Allwinner, Rockchip, for instance) which don't do any loading at all, actually rely on other code (SPL?) to load ATF itself.
So I don't see how this would duplicate effort or even conflict.
- Over time we end up with binary blobs on ARM that are every bit as
I am not quite sure I follow how you come from 2. to 3. Was there something in the presentation (I guess OSFC?) you are referring to? In contrast to the x86 world the firmware is actually Open Source based, so you actually have a realistic chance to rebuild and/or verify it. If this is not true in a particular case, poke your vendor.
- Firmware security and open-sourceness suffers, overall.
What are the relevant parts, exactly? Do you want to rip them out? Use git submodules? For reasons I detailed before, I doubt the viability of the practical aspect alone.
But on top of that, I see that ATF and U-Boot address two separate areas: CPU initialisation and secure world management on one side, and a very versatile bootloader running in the non-secure world on the other. Keeping them separate allows a clean separation and lets each project focus on its core functionality.
I understand that this separation is not always as clear or as well implemented on every platform, but at least we should aim at this.
Cheers, Andre,
So why don't we put all the platform init code into U-Boot SPL, which already has all the loading code and only load this ATF BL31 with SPL?
I thought ATF was designed to be BSD-licensed to allow vendors to take all the open source contributions, benefit from it, but also allow the vendors to never release their changes if they so desire.
It seems like some platforms even went down this path already and only released blobs, hence, no security fixes etc.
Shouldn't the "secure world" management be as open as possible then ?
Hi Marek,
But this is what we actually do on those platforms: SPL is loaded by the BootROM, PLLs and bus clocks are set up in SPL, then DRAM and MMC are initialised, then we load U-Boot proper and ATF BL31. BL31 does SMP init and errata workaround, and stays resident in EL3 to provide PSCI services.
This BL31-only model is considered a perfectly fine way of using ATF.
BSD was simply chosen because basically every vendor said they would not (be able to) use GPL licensed code for their firmware. So it was BSD license or no (Open Source) firmware at all. You might find that sad (I do), but that's what it is.
If you don't control the platform (servers), then you still have some power as a customer to ask for releasing the firmware source. AFAIK this is well understood by the vendors, as it is a good selling point against x86. And what I meant above is that this is in contrast to x86, where most of the firmware ("BIOS") is proprietary and consists of many third-party parts. So even when your system vendor wanted, it couldn't possibly publish the code. With the core firmware being Open Source, you have a much better chance of getting the source. If the vendor doesn't want to give code away, it would just use proprietary code anyway, probably of much worse quality.
"as open as possible", yes. As mentioned above, this might probably be as good as it can get.
Cheers, Andre.
Hi Marek,
Then why is there so much init code in ATF plat/ and drivers/ ? I think that should rather be in the U-Boot SPL instead of being duplicated in ATF.
There are quite a few GPL licensed bootloaders and they are doing quite fine I think, so it's not that clear cut.
Every single time I asked a vendor for changes to BSD-licensed sources, I either got silent treatment or was told off. Hence, I am not a fan of BSD license at all.
Considering how many various blobs recent ARM64 systems are growing (e.g. DDR4 init is usually a blob, some "secure" firmwares are blobs and so on), I don't think BSD licensed bootloader will help here.
I would very much prefer for those security components to have guaranteed source availability, but with BSD license, this is not gonna happen.
Anything in particular you are looking at? ATF handles more platforms that those just using the BL31 only approach. Also there are platforms that don't even support U-Boot. So those have more code in their plat/ directory, and bring their own drivers.
For which platforms? Servers? High end network appliances?
Yes, I can see that from your response and the answers down here ;-) But as mentioned before: GPL was not an option for those components.
Cheers, Andre.
Dear Jagan,
In message CAMty3ZDwHbkNr28m8Q1Q_F716S1tCU0Fhn3aurpWvkK58WyCXA@mail.gmail.com you wrote:
You are wrong. SPL has always been U-Boot internal code.
It may be true that some "external" early boot stages (line xloader) have been replaced by SPL, but in no case such external code was adaptes as is, and in the cases I am aware of this was original U-Boot code anyway which hat just been forked off and maintained out-of-tree.
But SPL is native U-Boot code only.
If U-Boot included a copy of the ATF code, it would have been forked of the mainline ATF code at some point, so it is still out of tree.
Given that we have "TPL" and "SPL", my "pie in the sky" wish would be for the ability to build different U-Boots to fill the different aspects of the aarch64 boot flow.
That said, patches that would in turn allow for users to locally add ATF as a git submodule and then build that, if cleanly done, could be interesting. But must not impact the normal build flow.
So can we also add Linux as a submodule ? And glibc ? Maybe busybox too ?
If we continue to import Linux subsystem, we don't need to import Linux ;). We need a good rsync
Michael
-- Best regards, Marek Vasut
Just as you suggested Jagan look at other SoCs and how they assemble images, I think you also need to take a wider look around. The concept of "take U-Boot, other firmware blobs, combine and mangle that" is somewhat widely used. It's not just sunxi that spits out a "can't find ATF, this image won't boot!" warning. If we can cleanly and solve that by easy for users to add git submodules to their tree (I am _not_ saying mainline U-Boot add submodules, to be clear) and they then get functional images, that will help a lot of different groups. We have a lot of README files today in-tree telling people to jump through hoops to get ATF and put it somewhere and run another tool on top.
So, U-Boot spits out that it cannot find kernel image and refuses to boot, do we also import Linux into the codebase because of that ?
But Linux also spits that it cannot find init and refuses to boot. Do we import systemd/sysvinit/upstart/... because of that ?
No, we do not. That's what build systems like OE or buildroot or whatnot are for. If you want to assemble your image by hand, that's also fine, surely you should be capable of replicating what the documentation / OE / buildroot recipe suggests.
IMO ATF is completely separate from U-Boot and can be updated separately, just like Linux, so I don't see how this would help. Update the READMEs if you want, that would help the most I think.
It's a build time warning, because we're generating the image that people expect to use to initialize their device and we must not produce images that will brick the system.
You're not suggesting OE / buildroot for day to day development of U-Boot are you?
If you don't see how it would help then I think you need to broaden your development horizons. I can see how "make all" producing an image that won't brick your device being helpful.
Some systems without serial console would be considered bricked if Linux doesn't boot too, so that's really not a good argument.
If you ignore build-time warning and your system fails to boot, well, there is no helping you.
I think you can roll a script which will build ATF for you, surely that's not hard.
If you ignore the build process warnings and the result bricks your system, there's really no helping here.
And since we're on the topic of bundling blobs, shall we also add a submodule for intel fsp for example ? Since that's needed for x86 and without that, the platform won't boot. And what if some blobs are still tracked in SVN or only available as HTTP(s) downloads ?
I worked with ATF on NXP, R-Car and Xilinx platforms and got over 100 patches in it. I don't see any from you. I think you should slow down.
Each of the platforms have different ways of deploying the ATF binaries, and they are generally not tied to U-Boot in any way. So I really don't see how this would help, compared to following documentation and copying the ATF binary over (if needed). A few lines of script can do just that.
I agree with Marek. U-Boot should be independent.
I do not like the git-submodule approach. Jagan's proposal..., no way!
-- Best Regards Masahiro Yamada
To repeat myself, as I said in the thread at the time, I still do not believe integration of ATF sources in-to U-Boot to be the right approach.
participants (10)
Andre Przywara
André Przywara
Jagan Teki
Mark Kettenis
Masahiro Yamada
Michael Nazzareno Trimarchi
