[U-Boot] [PATCH 0/7] stm32mp1: update clock driver
This serie udpates the stm32mp1 clock driver with the latest patches and prepare alignment with latest kernel device tree.
This patch is applicable on the top of the serie "stm32mp1: add trusted boot with TF-A"
http://patchwork.ozlabs.org/project/uboot/list/?series=88521
Patrick Delaunay (7): clk: stm32mp1: no more get ck_usbo_48m in device tree clk: stm32mp1: add IPCC clock clk: stm32mp1: correct access to RCC_OCENSETR/RCC_OCENCLRR clk: stm32mp1: recalculate counter when switching freq clk: stm32mp1: add debug information dts: stm32mp1: clock tree update clk: stm32mp1: correctly handle Clock Spreading Generator
arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi | 27 +++--- configs/stm32mp15_basic_defconfig | 1 + configs/stm32mp15_trusted_defconfig | 1 + doc/device-tree-bindings/clock/st,stm32mp1.txt | 10 +-- drivers/clk/clk_stm32mp1.c | 120 +++++++++++++++++++++---- include/dt-bindings/clock/stm32mp1-clks.h | 3 - 6 files changed, 124 insertions(+), 38 deletions(-)
Remove support of ck_usbo_48m clock node in device tree, but force 48MHz frequency to prepare alignment with kernel device tree.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
drivers/clk/clk_stm32mp1.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/clk/clk_stm32mp1.c b/drivers/clk/clk_stm32mp1.c index 9e9c667..e3ea29a 100644 --- a/drivers/clk/clk_stm32mp1.c +++ b/drivers/clk/clk_stm32mp1.c @@ -243,7 +243,6 @@ enum stm32mp1_parent_id { _LSI, _LSE, _I2S_CKIN, - _USB_PHY_48, NB_OSC,
/* other parent source */ @@ -275,6 +274,7 @@ enum stm32mp1_parent_id { _CK_MPU, _CK_MCU, _DSI_PHY, + _USB_PHY_48, _PARENT_NB, _UNKNOWN_ID = 0xff, }; @@ -1081,7 +1081,7 @@ static ulong stm32mp1_clk_get(struct stm32mp1_clk_priv *priv, int p) break; /* other */ case _USB_PHY_48: - clock = stm32mp1_clk_get_fixed(priv, _USB_PHY_48); + clock = 48000000; break; case _DSI_PHY: { @@ -1861,7 +1861,7 @@ static void stm32mp1_osc_init(struct udevice *dev) [_HSE] = "clk-hse", [_CSI] = "clk-csi", [_I2S_CKIN] = "i2s_ckin", - [_USB_PHY_48] = "ck_usbo_48m"}; + };
for (i = 0; i < NB_OSC; i++) { stm32mp1_osc_clk_init(name[i], priv, i);
Add support for enable/disable of IPCC clock using AHB3 registers
drivers/clk/clk_stm32mp1.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/clk/clk_stm32mp1.c b/drivers/clk/clk_stm32mp1.c index e3ea29a..e1477a1 100644 --- a/drivers/clk/clk_stm32mp1.c +++ b/drivers/clk/clk_stm32mp1.c @@ -538,6 +538,7 @@ static const struct stm32mp1_clk_gate stm32mp1_clk_gate[] = { STM32MP1_CLK_SET_CLR(RCC_MP_AHB2ENSETR, 16, SDMMC3_K, _SDMMC3_SEL),
STM32MP1_CLK_SET_CLR(RCC_MP_AHB3ENSETR, 11, HSEM, _UNKNOWN_SEL), + STM32MP1_CLK_SET_CLR(RCC_MP_AHB3ENSETR, 12, IPCC, _UNKNOWN_SEL),
STM32MP1_CLK_SET_CLR(RCC_MP_AHB4ENSETR, 0, GPIOA, _UNKNOWN_SEL), STM32MP1_CLK_SET_CLR(RCC_MP_AHB4ENSETR, 1, GPIOB, _UNKNOWN_SEL),
Remove unnecessary setbits on set/clear registers. Avoid to deactivate HSI with HSE.
drivers/clk/clk_stm32mp1.c | 13 +++++-------- 1 file changed, 5 insertions(+), 8 deletions(-)
diff --git a/drivers/clk/clk_stm32mp1.c b/drivers/clk/clk_stm32mp1.c index e1477a1..5f2b2f1 100644 --- a/drivers/clk/clk_stm32mp1.c +++ b/drivers/clk/clk_stm32mp1.c @@ -1182,10 +1182,7 @@ static void stm32mp1_ls_osc_set(int enable, fdt_addr_t rcc, u32 offset,
static void stm32mp1_hs_ocs_set(int enable, fdt_addr_t rcc, u32 mask_on) { - if (enable) - setbits_le32(rcc + RCC_OCENSETR, mask_on); - else - setbits_le32(rcc + RCC_OCENCLRR, mask_on); + writel(mask_on, rcc + (enable ? RCC_OCENSETR : RCC_OCENCLRR)); }
static int stm32mp1_osc_wait(int enable, fdt_addr_t rcc, u32 offset, @@ -1256,20 +1253,20 @@ static void stm32mp1_lsi_set(fdt_addr_t rcc, int enable) static void stm32mp1_hse_enable(fdt_addr_t rcc, int bypass, int digbyp, int css) { if (digbyp) - setbits_le32(rcc + RCC_OCENSETR, RCC_OCENR_DIGBYP); + writel(RCC_OCENR_DIGBYP, rcc + RCC_OCENSETR); if (bypass || digbyp) - setbits_le32(rcc + RCC_OCENSETR, RCC_OCENR_HSEBYP); + writel(RCC_OCENR_HSEBYP, rcc + RCC_OCENSETR);
stm32mp1_hs_ocs_set(1, rcc, RCC_OCENR_HSEON); stm32mp1_osc_wait(1, rcc, RCC_OCRDYR, RCC_OCRDYR_HSERDY);
if (css) - setbits_le32(rcc + RCC_OCENSETR, RCC_OCENR_HSECSSON); + writel(RCC_OCENR_HSECSSON, rcc + RCC_OCENSETR); }
static void stm32mp1_csi_set(fdt_addr_t rcc, int enable) { - stm32mp1_ls_osc_set(enable, rcc, RCC_OCENSETR, RCC_OCENR_CSION); + stm32mp1_hs_ocs_set(enable, rcc, RCC_OCENR_CSION); stm32mp1_osc_wait(enable, rcc, RCC_OCRDYR, RCC_OCRDYR_CSIRDY); }
Because stgen is initialized with HSI clock, we need to recalculate the counter when changing frequency.
Signed-off-by: Lionel Debieve lionel.debieve@st.com Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
drivers/clk/clk_stm32mp1.c | 9 +++++++-- 1 file changed, 7 insertions(+), 2 deletions(-)
diff --git a/drivers/clk/clk_stm32mp1.c b/drivers/clk/clk_stm32mp1.c index 5f2b2f1..ca98e0b 100644 --- a/drivers/clk/clk_stm32mp1.c +++ b/drivers/clk/clk_stm32mp1.c @@ -1471,10 +1471,15 @@ static void stgen_config(struct stm32mp1_clk_priv *priv) rate = stm32mp1_clk_get(priv, p);
if (cntfid0 != rate) { + u64 counter; + pr_debug("System Generic Counter (STGEN) update\n"); clrbits_le32(stgenc + STGENC_CNTCR, STGENC_CNTCR_EN); - writel(0x0, stgenc + STGENC_CNTCVL); - writel(0x0, stgenc + STGENC_CNTCVU); + counter = (u64)readl(stgenc + STGENC_CNTCVL); + counter |= ((u64)(readl(stgenc + STGENC_CNTCVU))) << 32; + counter = lldiv(counter * (u64)rate, cntfid0); + writel((u32)counter, stgenc + STGENC_CNTCVL); + writel((u32)(counter >> 32), stgenc + STGENC_CNTCVU); writel(rate, stgenc + STGENC_CNTFID0); setbits_le32(stgenc + STGENC_CNTCR, STGENC_CNTCR_EN);
Add support of clk dump command and display information during probe (under CONFIG_DISPLAY_CPUINFO).
configs/stm32mp15_basic_defconfig | 1 + configs/stm32mp15_trusted_defconfig | 1 + drivers/clk/clk_stm32mp1.c | 83 +++++++++++++++++++++++++++++++++++-- 3 files changed, 81 insertions(+), 4 deletions(-)
diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index 304688e..d20b2ab 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_PROMPT="STM32MP> " # CONFIG_CMD_IMPORTENV is not set CONFIG_CMD_MEMINFO=y CONFIG_CMD_ADC=y +CONFIG_CMD_CLK=y CONFIG_CMD_FUSE=y CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index e905ae1..62ab010 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -13,6 +13,7 @@ CONFIG_SYS_PROMPT="STM32MP> " # CONFIG_CMD_IMPORTENV is not set CONFIG_CMD_MEMINFO=y CONFIG_CMD_ADC=y +CONFIG_CMD_CLK=y CONFIG_CMD_FUSE=y CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y diff --git a/drivers/clk/clk_stm32mp1.c b/drivers/clk/clk_stm32mp1.c index ca98e0b..76b7b5a 100644 --- a/drivers/clk/clk_stm32mp1.c +++ b/drivers/clk/clk_stm32mp1.c @@ -668,8 +668,8 @@ static const u8 stm32mp1_axi_div[8] = { 1, 2, 3, 4, 4, 4, 4, 4 };
-#ifdef DEBUG -static const char * const stm32mp1_clk_parent_name[_PARENT_NB] = { +static const __maybe_unused +char * const stm32mp1_clk_parent_name[_PARENT_NB] = { [_HSI] = "HSI", [_HSE] = "HSE", [_CSI] = "CSI", @@ -707,7 +707,8 @@ static const char * const stm32mp1_clk_parent_name[_PARENT_NB] = { [_DSI_PHY] = "DSI_PHY_PLL", };
-static const char * const stm32mp1_clk_parent_sel_name[_PARENT_SEL_NB] = { +static const __maybe_unused +char * const stm32mp1_clk_parent_sel_name[_PARENT_SEL_NB] = { [_I2C12_SEL] = "I2C12", [_I2C35_SEL] = "I2C35", [_I2C46_SEL] = "I2C46", @@ -726,7 +727,6 @@ static const char * const stm32mp1_clk_parent_sel_name[_PARENT_SEL_NB] = { [_DSI_SEL] = "DSI", [_ADC12_SEL] = "ADC12", }; -#endif
static const struct stm32mp1_clk_data stm32mp1_data = { .gate = stm32mp1_clk_gate, @@ -1872,6 +1872,54 @@ static void stm32mp1_osc_init(struct udevice *dev) } }
+static void __maybe_unused stm32mp1_clk_dump(struct stm32mp1_clk_priv *priv) +{ + char buf[32]; + int i, s, p; + + printf("Clocks:\n"); + for (i = 0; i < _PARENT_NB; i++) { + printf("- %s : %s MHz\n", + stm32mp1_clk_parent_name[i], + strmhz(buf, stm32mp1_clk_get(priv, i))); + } + printf("Source Clocks:\n"); + for (i = 0; i < _PARENT_SEL_NB; i++) { + p = (readl(priv->base + priv->data->sel[i].offset) >> + priv->data->sel[i].src) & priv->data->sel[i].msk; + if (p < priv->data->sel[i].nb_parent) { + s = priv->data->sel[i].parent[p]; + printf("- %s(%d) => parent %s(%d)\n", + stm32mp1_clk_parent_sel_name[i], i, + stm32mp1_clk_parent_name[s], s); + } else { + printf("- %s(%d) => parent index %d is invalid\n", + stm32mp1_clk_parent_sel_name[i], i, p); + } + } +} + +#ifdef CONFIG_CMD_CLK +int soc_clk_dump(void) +{ + struct udevice *dev; + struct stm32mp1_clk_priv *priv; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_CLK, + DM_GET_DRIVER(stm32mp1_clock), + &dev); + if (ret) + return ret; + + priv = dev_get_priv(dev); + + stm32mp1_clk_dump(priv); + + return 0; +} +#endif + static int stm32mp1_clk_probe(struct udevice *dev) { int result = 0; @@ -1895,6 +1943,33 @@ static int stm32mp1_clk_probe(struct udevice *dev) result = stm32mp1_clktree(dev); #endif
+#ifndef CONFIG_SPL_BUILD +#if defined(DEBUG) + /* display debug information for probe after relocation */ + if (gd->flags & GD_FLG_RELOC) + stm32mp1_clk_dump(priv); +#endif + +#if defined(CONFIG_DISPLAY_CPUINFO) + if (gd->flags & GD_FLG_RELOC) { + char buf[32]; + + printf("Clocks:\n"); + printf("- MPU : %s MHz\n", + strmhz(buf, stm32mp1_clk_get(priv, _CK_MPU))); + printf("- MCU : %s MHz\n", + strmhz(buf, stm32mp1_clk_get(priv, _CK_MCU))); + printf("- AXI : %s MHz\n", + strmhz(buf, stm32mp1_clk_get(priv, _ACLK))); + printf("- PER : %s MHz\n", + strmhz(buf, stm32mp1_clk_get(priv, _CK_PER))); + /* DDRPHYC father */ + printf("- DDR : %s MHz\n", + strmhz(buf, stm32mp1_clk_get(priv, _PLL2_R))); + } +#endif /* CONFIG_DISPLAY_CPUINFO */ +#endif + return result; }
After dropping the hunk to the "trusted" defconfig, applied to u-boot/master, thanks!
- Add st,digbypass on clk_hse node (needed for board rev.C) - MLAHB/AHB max frequency increased from 200 to 209MHz, with: - PLL3P set to 208.8MHz for MCU sub-system - PLL3Q set to 24.57MHz for 48kHz SAI/SPI2S - PLL3R set to 11.29MHz for 44.1kHz SAI/SPI2S - PLL4P set to 99MHz for SDMMC and SPDIFRX - PLL4Q set to 74.25MHz for EVAL board
arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi | 27 +++++++++++++++------------ include/dt-bindings/clock/stm32mp1-clks.h | 3 --- 2 files changed, 15 insertions(+), 15 deletions(-)
diff --git a/arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi b/arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi index 4898483..70bbf66 100644 --- a/arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi +++ b/arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi @@ -39,6 +39,10 @@ }; };
+&clk_hse { + st,digbypass; +}; + &uart4_pins_a { u-boot,dm-pre-reloc; pins1 { @@ -68,7 +72,6 @@ u-boot,dm-pre-reloc; };
-/* CLOCK init */ &rcc { st,clksrc = < CLK_MPU_PLL1P @@ -101,7 +104,7 @@ CLK_FMC_ACLK CLK_QSPI_ACLK CLK_ETH_DISABLED - CLK_SDMMC12_PLL3R + CLK_SDMMC12_PLL4P CLK_DSI_DSIPLL CLK_STGEN_HSE CLK_USBPHY_HSE @@ -110,7 +113,7 @@ CLK_SPI45_HSI CLK_SPI6_HSI CLK_I2C46_HSI - CLK_SDMMC3_PLL3R + CLK_SDMMC3_PLL4P CLK_USBO_USBPHY CLK_ADC_CKPER CLK_CEC_LSE @@ -121,17 +124,17 @@ CLK_UART35_HSI CLK_UART6_HSI CLK_UART78_HSI - CLK_SPDIF_PLL3Q + CLK_SPDIF_PLL4P CLK_FDCAN_PLL4Q CLK_SAI1_PLL3Q CLK_SAI2_PLL3Q CLK_SAI3_PLL3Q CLK_SAI4_PLL3Q - CLK_RNG1_CSI - CLK_RNG2_CSI + CLK_RNG1_LSI + CLK_RNG2_LSI CLK_LPTIM1_PCLK1 CLK_LPTIM23_PCLK3 - CLK_LPTIM45_PCLK3 + CLK_LPTIM45_LSE >;
/* VCO = 1300.0 MHz => P = 650 (CPU) */ @@ -148,16 +151,16 @@ u-boot,dm-pre-reloc; };
- /* VCO = 786.4 MHz => P = 197, Q = 49, R = 98 */ + /* VCO = 417.8 MHz => P = 209, Q = 24, R = 11 */ pll3: st,pll@2 { - cfg = < 2 97 3 15 7 PQR(1,1,1) >; - frac = < 0x9ba >; + cfg = < 1 33 1 16 36 PQR(1,1,1) >; + frac = < 0x1a04 >; u-boot,dm-pre-reloc; };
- /* VCO = 508.0 MHz => P = 56, Q = 56, R = 56 */ + /* VCO = 594.0 MHz => P = 99, Q = 74, R = 74 */ pll4: st,pll@3 { - cfg = < 5 126 8 8 8 PQR(1,1,1) >; + cfg = < 3 98 5 7 7 PQR(1,1,1) >; u-boot,dm-pre-reloc; }; }; diff --git a/include/dt-bindings/clock/stm32mp1-clks.h b/include/dt-bindings/clock/stm32mp1-clks.h index 90ec780..4cdaf13 100644 --- a/include/dt-bindings/clock/stm32mp1-clks.h +++ b/include/dt-bindings/clock/stm32mp1-clks.h @@ -248,7 +248,4 @@
#define STM32MP1_LAST_CLK 232
-#define LTDC_K LTDC_PX -#define ETHMAC_K ETHCK_K - #endif /* _DT_BINDINGS_STM32MP1_CLKS_H_ */
To activate the csg option, the driver need to set the bit2 of PLLNCR register = SSCG_CTRL: Spread Spectrum Clock Generator of PLLn enable.
doc/device-tree-bindings/clock/st,stm32mp1.txt | 10 +++++----- drivers/clk/clk_stm32mp1.c | 8 +++++++- 2 files changed, 12 insertions(+), 6 deletions(-)
diff --git a/doc/device-tree-bindings/clock/st,stm32mp1.txt b/doc/device-tree-bindings/clock/st,stm32mp1.txt index 6a9397e..ffcf8cd 100644 --- a/doc/device-tree-bindings/clock/st,stm32mp1.txt +++ b/doc/device-tree-bindings/clock/st,stm32mp1.txt @@ -132,15 +132,15 @@ Optional Properties: frac = < 0x810 >; }; st,pll@1 { - cfg = < 1 43 1 0 0 PQR(0,1,1)>; - csg = <10 20 1>; + cfg = < 1 43 1 0 0 PQR(0,1,1) >; + csg = < 10 20 1 >; }; st,pll@2 { - cfg = < 2 85 3 13 3 0>; - csg = <10 20 SSCG_MODE_CENTER_SPREAD>; + cfg = < 2 85 3 13 3 0 >; + csg = < 10 20 SSCG_MODE_CENTER_SPREAD >; }; st,pll@3 { - cfg = < 2 78 4 7 9 3>; + cfg = < 2 78 4 7 9 3 >; }; st,pkcs = < CLK_STGEN_HSE diff --git a/drivers/clk/clk_stm32mp1.c b/drivers/clk/clk_stm32mp1.c index 76b7b5a..24859fd 100644 --- a/drivers/clk/clk_stm32mp1.c +++ b/drivers/clk/clk_stm32mp1.c @@ -167,6 +167,7 @@ /* used for ALL PLLNCR registers */ #define RCC_PLLNCR_PLLON BIT(0) #define RCC_PLLNCR_PLLRDY BIT(1) +#define RCC_PLLNCR_SSCG_CTRL BIT(2) #define RCC_PLLNCR_DIVPEN BIT(4) #define RCC_PLLNCR_DIVQEN BIT(5) #define RCC_PLLNCR_DIVREN BIT(6) @@ -1321,7 +1322,10 @@ static void pll_start(struct stm32mp1_clk_priv *priv, int pll_id) { const struct stm32mp1_clk_pll *pll = priv->data->pll;
- writel(RCC_PLLNCR_PLLON, priv->base + pll[pll_id].pllxcr); + clrsetbits_le32(priv->base + pll[pll_id].pllxcr, + RCC_PLLNCR_DIVPEN | RCC_PLLNCR_DIVQEN | + RCC_PLLNCR_DIVREN, + RCC_PLLNCR_PLLON); }
static int pll_output(struct stm32mp1_clk_priv *priv, int pll_id, int output) @@ -1440,6 +1444,8 @@ static void pll_csg(struct stm32mp1_clk_priv *priv, int pll_id, u32 *csg) RCC_PLLNCSGR_SSCG_MODE_MASK);
writel(pllxcsg, priv->base + pll[pll_id].pllxcsgr); + + setbits_le32(priv->base + pll[pll_id].pllxcr, RCC_PLLNCR_SSCG_CTRL); }
static int set_clksrc(struct stm32mp1_clk_priv *priv, unsigned int clksrc)
Patrick Delaunay
