[U-Boot] [PATCH] ppc/8xxx: Add is_core_disabled to remove disabled cores from dtb
If we explicitly disabled a core remove it from the dtb we pass on to the kernel.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/mp.c | 25 +++++++++++++++++++++++++ arch/powerpc/cpu/mpc86xx/mp.c | 19 +++++++++++++++++++ arch/powerpc/cpu/mpc8xxx/fdt.c | 3 ++- arch/powerpc/include/asm/mp.h | 3 ++- 4 files changed, 48 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/mp.c b/arch/powerpc/cpu/mpc85xx/mp.c index 826bf32..0d39f3b 100644 --- a/arch/powerpc/cpu/mpc85xx/mp.c +++ b/arch/powerpc/cpu/mpc85xx/mp.c @@ -77,6 +77,13 @@ int cpu_disable(int nr)
return 0; } + +int is_core_disabled(int nr) { + volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 coredisrl = in_be32(&gur->coredisrl); + + return (coredisrl & (1 << nr)); +} #else int cpu_disable(int nr) { @@ -96,6 +103,24 @@ int cpu_disable(int nr)
return 0; } + +int is_core_disabled(int nr) { + volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 devdisr = in_be32(&gur->devdisr); + + switch (nr) { + case 0: + return (devdisr & MPC85xx_DEVDISR_CPU0); + break; + case 1: + return (devdisr & MPC85xx_DEVDISR_CPU1); + break; + default: + printf("Invalid cpu number for disable %d\n", nr); + } + + return 0; +} #endif
static u8 boot_entry_map[4] = { diff --git a/arch/powerpc/cpu/mpc86xx/mp.c b/arch/powerpc/cpu/mpc86xx/mp.c index b4a0faa..97e4692 100644 --- a/arch/powerpc/cpu/mpc86xx/mp.c +++ b/arch/powerpc/cpu/mpc86xx/mp.c @@ -66,6 +66,25 @@ int cpu_disable(int nr) return 0; }
+int is_core_disabled(int nr) { + volatile immap_t *immap = (immap_t *) CONFIG_SYS_CCSRBAR; + volatile ccsr_gur_t *gur = &immap->im_gur; + u32 devdisr = in_be32(&gur->devdisr); + + switch (nr) { + case 0: + return (devdisr & MPC86xx_DEVDISR_CPU0); + break; + case 1: + return (devdisr & MPC86xx_DEVDISR_CPU1); + break; + default: + printf("Invalid cpu number for disable %d\n", nr); + } + + return 0; +} + int cpu_release(int nr, int argc, char *argv[]) { /* dummy function so common/cmd_mp.c will build diff --git a/arch/powerpc/cpu/mpc8xxx/fdt.c b/arch/powerpc/cpu/mpc8xxx/fdt.c index c9956b6..02bdb70 100644 --- a/arch/powerpc/cpu/mpc8xxx/fdt.c +++ b/arch/powerpc/cpu/mpc8xxx/fdt.c @@ -26,6 +26,7 @@ #include <common.h> #include <libfdt.h> #include <fdt_support.h> +#include <asm/mp.h>
#if defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) static int ft_del_cpuhandle(void *blob, int cpuhandle) @@ -57,7 +58,7 @@ void ft_fixup_num_cores(void *blob) { while (off != -FDT_ERR_NOTFOUND) { u32 *reg = (u32 *)fdt_getprop(blob, off, "reg", 0);
- if (*reg > num_cores-1) { + if ((*reg > num_cores-1) || (is_core_disabled(*reg))) { int ph = fdt_get_phandle(blob, off);
/* Delete the cpu node once there are no cpu handles */ diff --git a/arch/powerpc/include/asm/mp.h b/arch/powerpc/include/asm/mp.h index 5388c95..3ffa30b 100644 --- a/arch/powerpc/include/asm/mp.h +++ b/arch/powerpc/include/asm/mp.h @@ -1,5 +1,5 @@ /* - * Copyright 2009 Freescale Semiconductor, Inc. + * Copyright 2009-2010 Freescale Semiconductor, Inc. * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as @@ -26,5 +26,6 @@ void setup_mp(void); void cpu_mp_lmb_reserve(struct lmb *lmb); u32 determine_mp_bootpg(void); +int is_core_disabled(int nr);
#endif
- volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR);
- u32 coredisrl = in_be32(&gur->coredisrl);
You don't need to declare the variable as volatile if you use an I/O accessor.
- u32 devdisr = in_be32(&gur->devdisr);
Same thing here.
- switch (nr) {
- case 0:
- return (devdisr & MPC85xx_DEVDISR_CPU0);
- break;
- case 1:
- return (devdisr & MPC85xx_DEVDISR_CPU1);
- break;
And you don't need a 'break' after a 'return' in a switch-case statement. You also don't need parentheses around the expression in the 'return' statement.
Same thing here.
will fix.
switch (nr) {
case 0:
break;
case 1:
break;
Going to leave the parens for readability, will drop the break's.
- k
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- * Fix issues reported by Timur
arch/powerpc/cpu/mpc85xx/mp.c | 23 +++++++++++++++++++++++ arch/powerpc/cpu/mpc86xx/mp.c | 17 +++++++++++++++++ arch/powerpc/cpu/mpc8xxx/fdt.c | 3 ++- arch/powerpc/include/asm/mp.h | 3 ++- 4 files changed, 44 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/mp.c b/arch/powerpc/cpu/mpc85xx/mp.c index 826bf32..af3c1eb 100644 --- a/arch/powerpc/cpu/mpc85xx/mp.c +++ b/arch/powerpc/cpu/mpc85xx/mp.c @@ -77,6 +77,13 @@ int cpu_disable(int nr)
return 0; } + +int is_core_disabled(int nr) { + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 coredisrl = in_be32(&gur->coredisrl); + + return (coredisrl & (1 << nr)); +} #else int cpu_disable(int nr) { @@ -96,6 +103,22 @@ int cpu_disable(int nr)
return 0; } + +int is_core_disabled(int nr) { + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 devdisr = in_be32(&gur->devdisr); + + switch (nr) { + case 0: + return (devdisr & MPC85xx_DEVDISR_CPU0); + case 1: + return (devdisr & MPC85xx_DEVDISR_CPU1); + default: + printf("Invalid cpu number for disable %d\n", nr); + } + + return 0; +} #endif
static u8 boot_entry_map[4] = { diff --git a/arch/powerpc/cpu/mpc86xx/mp.c b/arch/powerpc/cpu/mpc86xx/mp.c index b4a0faa..e726218 100644 --- a/arch/powerpc/cpu/mpc86xx/mp.c +++ b/arch/powerpc/cpu/mpc86xx/mp.c @@ -66,6 +66,23 @@ int cpu_disable(int nr) return 0; }
+int is_core_disabled(int nr) { + immap_t *immap = (immap_t *) CONFIG_SYS_CCSRBAR; + ccsr_gur_t *gur = &immap->im_gur; + u32 devdisr = in_be32(&gur->devdisr); + + switch (nr) { + case 0: + return (devdisr & MPC86xx_DEVDISR_CPU0); + case 1: + return (devdisr & MPC86xx_DEVDISR_CPU1); + default: + printf("Invalid cpu number for disable %d\n", nr); + } + + return 0; +} + int cpu_release(int nr, int argc, char *argv[]) { /* dummy function so common/cmd_mp.c will build diff --git a/arch/powerpc/cpu/mpc8xxx/fdt.c b/arch/powerpc/cpu/mpc8xxx/fdt.c index c9956b6..02bdb70 100644 --- a/arch/powerpc/cpu/mpc8xxx/fdt.c +++ b/arch/powerpc/cpu/mpc8xxx/fdt.c @@ -26,6 +26,7 @@ #include <common.h> #include <libfdt.h> #include <fdt_support.h> +#include <asm/mp.h>
#endif
- Fix issues reported by Timur
applied to 85xx
- k
Kumar Gala
Timur Tabi
