[U-Boot] [PATCH v4 1/6] display_options: Refactor to allow obtaining the banner
Move the display options code into a separate function so that the U-Boot banner can be obtained from other code. Adjust the 'version' command to use it.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com ---
Changes in v4: - Fix /** nit in header file
Changes in v3: None Changes in v2: - Update the code to be more testable - Avoid a warning on spring, etc.
cmd/version.c | 4 +++- include/display_options.h | 19 +++++++++++++++++++ lib/display_options.c | 36 +++++++++++++++++++++++++++++++----- 3 files changed, 53 insertions(+), 6 deletions(-)
diff --git a/cmd/version.c b/cmd/version.c index 1be0667f09..15aab5dc18 100644 --- a/cmd/version.c +++ b/cmd/version.c @@ -17,7 +17,9 @@ const char __weak version_string[] = U_BOOT_VERSION_STRING;
static int do_version(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - printf("\n%s\n", version_string); + char buf[DISPLAY_OPTIONS_BANNER_LENGTH]; + + printf(display_options_get_banner(false, buf, sizeof(buf))); #ifdef CC_VERSION_STRING puts(CC_VERSION_STRING "\n"); #endif diff --git a/include/display_options.h b/include/display_options.h index ac44c459b3..d9c8f6dbd4 100644 --- a/include/display_options.h +++ b/include/display_options.h @@ -56,4 +56,23 @@ int print_buffer(ulong addr, const void *data, uint width, uint count, */ int display_options(void);
+/* Suggested length of the buffer to pass to display_options_get_banner() */ +#define DISPLAY_OPTIONS_BANNER_LENGTH 200 + +/** + * display_options_get_banner() - Get the U-Boot banner as a string + * + * This returns the U-Boot banner string + * + * @newlines: true to include two newlines at the start + * @buf: place to put string + * @size: Size of buf (string is truncated to fit) + * @return buf + */ +char *display_options_get_banner(bool newlines, char *buf, int size); + +/* This function is used for testing only */ +char *display_options_get_banner_priv(bool newlines, const char *build_tag, + char *buf, int size); + #endif diff --git a/lib/display_options.c b/lib/display_options.c index 29343fc00e..4ea27ca99d 100644 --- a/lib/display_options.c +++ b/lib/display_options.c @@ -13,13 +13,39 @@ #include <linux/ctype.h> #include <asm/io.h>
-int display_options (void) +char *display_options_get_banner_priv(bool newlines, const char *build_tag, + char *buf, int size) { -#if defined(BUILD_TAG) - printf ("\n\n%s, Build: %s\n\n", version_string, BUILD_TAG); -#else - printf ("\n\n%s\n\n", version_string); + int len; + + len = snprintf(buf, size, "%s%s", newlines ? "\n\n" : "", + version_string); + if (build_tag && len < size) + len += snprintf(buf + len, size - len, ", Build: %s", + build_tag); + if (len > size - 3) + len = size - 3; + strcpy(buf + len, "\n\n"); + + return buf; +} + +#ifndef BUILD_TAG +#define BUILD_TAG NULL #endif + +char *display_options_get_banner(bool newlines, char *buf, int size) +{ + return display_options_get_banner_priv(newlines, BUILD_TAG, buf, size); +} + +int display_options(void) +{ + char buf[DISPLAY_OPTIONS_BANNER_LENGTH]; + + display_options_get_banner(true, buf, sizeof(buf)); + printf("%s", buf); + return 0; }
Applied to u-boot-dm, thanks!
sjg@google.com
