[PATCH] common/board_f: Make reserve_mmu generic
Introduce arch_reserve_mmu to allow for architecture-specific reserve_mmu routines.
For ARM, move the reserve_mmu definition from common/board_f.c to arch/arm/lib/cache.c. Define arm_reserve_mmu and make it a weak define to allow machines to override it (in mach-versal/cpu.c and mach-zynqmp/cpu.c).
Signed-off-by: Ovidiu Panait ovpanait@gmail.com --- arch/arm/include/asm/cache.h | 2 ++ arch/arm/lib/cache.c | 33 +++++++++++++++++++++++++++++++++ arch/arm/mach-versal/cpu.c | 6 +++++- arch/arm/mach-zynqmp/cpu.c | 6 +++++- common/board_f.c | 32 ++++++-------------------------- include/init.h | 2 +- 6 files changed, 52 insertions(+), 29 deletions(-)
diff --git a/arch/arm/include/asm/cache.h b/arch/arm/include/asm/cache.h index 950ec1e793..dbb9c554ae 100644 --- a/arch/arm/include/asm/cache.h +++ b/arch/arm/include/asm/cache.h @@ -49,4 +49,6 @@ void dram_bank_mmu_setup(int bank); */ #define ARCH_DMA_MINALIGN CONFIG_SYS_CACHELINE_SIZE
+int arm_reserve_mmu(void); + #endif /* _ASM_CACHE_H */ diff --git a/arch/arm/lib/cache.c b/arch/arm/lib/cache.c index 007d4ebc49..76c10a577b 100644 --- a/arch/arm/lib/cache.c +++ b/arch/arm/lib/cache.c @@ -10,6 +10,8 @@ #include <cpu_func.h> #include <malloc.h>
+DECLARE_GLOBAL_DATA_PTR; + /* * Flush range from all levels of d-cache/unified-cache. * Affects the range [start, start + size - 1]. @@ -118,3 +120,34 @@ void invalidate_l2_cache(void) isb(); } #endif + +int arch_reserve_mmu(void) +{ + return arm_reserve_mmu(); +} + +__weak int arm_reserve_mmu(void) +{ +#if !(CONFIG_IS_ENABLED(SYS_ICACHE_OFF) && CONFIG_IS_ENABLED(SYS_DCACHE_OFF)) + /* reserve TLB table */ + gd->arch.tlb_size = PGTABLE_SIZE; + gd->relocaddr -= gd->arch.tlb_size; + + /* round down to next 64 kB limit */ + gd->relocaddr &= ~(0x10000 - 1); + + gd->arch.tlb_addr = gd->relocaddr; + debug("TLB table from %08lx to %08lx\n", gd->arch.tlb_addr, + gd->arch.tlb_addr + gd->arch.tlb_size); + +#ifdef CONFIG_SYS_MEM_RESERVE_SECURE + /* + * Record allocated tlb_addr in case gd->tlb_addr to be overwritten + * with location within secure ram. + */ + gd->arch.tlb_allocated = gd->arch.tlb_addr; +#endif +#endif + + return 0; +} diff --git a/arch/arm/mach-versal/cpu.c b/arch/arm/mach-versal/cpu.c index 6ee6cd43ec..6c5da8b29e 100644 --- a/arch/arm/mach-versal/cpu.c +++ b/arch/arm/mach-versal/cpu.c @@ -10,6 +10,10 @@ #include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h>
+#if defined(CONFIG_SYS_MEM_RSVD_FOR_MMU) +#include <asm/cache.h> +#endif + DECLARE_GLOBAL_DATA_PTR;
#define VERSAL_MEM_MAP_USED 5 @@ -98,7 +102,7 @@ u64 get_page_table_size(void) }
#if defined(CONFIG_SYS_MEM_RSVD_FOR_MMU) -int reserve_mmu(void) +int arm_reserve_mmu(void) { tcm_init(TCM_LOCK); gd->arch.tlb_size = PGTABLE_SIZE; diff --git a/arch/arm/mach-zynqmp/cpu.c b/arch/arm/mach-zynqmp/cpu.c index 442427bc11..363a20b621 100644 --- a/arch/arm/mach-zynqmp/cpu.c +++ b/arch/arm/mach-zynqmp/cpu.c @@ -12,6 +12,10 @@ #include <asm/io.h> #include <zynqmp_firmware.h>
+#ifdef CONFIG_SYS_MEM_RSVD_FOR_MMU +#include <asm/cache.h> +#endif + #define ZYNQ_SILICON_VER_MASK 0xF000 #define ZYNQ_SILICON_VER_SHIFT 12
@@ -116,7 +120,7 @@ void tcm_init(u8 mode) #endif
#ifdef CONFIG_SYS_MEM_RSVD_FOR_MMU -int reserve_mmu(void) +int arm_reserve_mmu(void) { tcm_init(TCM_LOCK); gd->arch.tlb_size = PGTABLE_SIZE; diff --git a/common/board_f.c b/common/board_f.c index 82a164752a..2ab23cf239 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -385,33 +385,15 @@ static int reserve_round_4k(void) return 0; }
-#ifdef CONFIG_ARM -__weak int reserve_mmu(void) +__weak int arch_reserve_mmu(void) { -#if !(CONFIG_IS_ENABLED(SYS_ICACHE_OFF) && CONFIG_IS_ENABLED(SYS_DCACHE_OFF)) - /* reserve TLB table */ - gd->arch.tlb_size = PGTABLE_SIZE; - gd->relocaddr -= gd->arch.tlb_size; - - /* round down to next 64 kB limit */ - gd->relocaddr &= ~(0x10000 - 1); - - gd->arch.tlb_addr = gd->relocaddr; - debug("TLB table from %08lx to %08lx\n", gd->arch.tlb_addr, - gd->arch.tlb_addr + gd->arch.tlb_size); - -#ifdef CONFIG_SYS_MEM_RESERVE_SECURE - /* - * Record allocated tlb_addr in case gd->tlb_addr to be overwritten - * with location within secure ram. - */ - gd->arch.tlb_allocated = gd->arch.tlb_addr; -#endif -#endif - return 0; } -#endif + +static int reserve_mmu(void) +{ + return arch_reserve_mmu(); +}
static int reserve_video(void) { @@ -970,9 +952,7 @@ static const init_fnc_t init_sequence_f[] = { reserve_pram, #endif reserve_round_4k, -#ifdef CONFIG_ARM reserve_mmu, -#endif reserve_video, reserve_trace, reserve_uboot, diff --git a/include/init.h b/include/init.h index 2a33a3fd1e..5700dc7ecb 100644 --- a/include/init.h +++ b/include/init.h @@ -145,7 +145,7 @@ int init_cache_f_r(void); int print_cpuinfo(void); #endif int timer_init(void); -int reserve_mmu(void); +int arch_reserve_mmu(void); int misc_init_f(void);
#if defined(CONFIG_DTB_RESELECT)
Can you please do that bit in an initial patch before this one?
Can you please try to use if() instead of #if as much as possible?
Function comment
- Flush range from all levels of d-cache/unified-cache.
- Affects the range [start, start + size - 1].
+#endif +#endif
Can you drop that #if?
Can you drop this #ifdef?
-#endif -#endif
} -#endif
Then can we just put arch_reserve_mmu() in the thing below and drop this fnuction?
function comment
2.17.1
Ovidiu Panait
