[U-Boot] [PATCH] s3c64xx: fix the compiler error and warning
This patch is fixing the following errors
s3c64xx.c:175: error: variable 's3c64xx_serial_drv' has initializer but incomplete type s3c64xx.c:176: error: unknown field 'name' specified in initializer s3c64xx.c:176: warning: excess elements in struct initializer s3c64xx.c:176: warning: (near initialization for 's3c64xx_serial_drv') s3c64xx.c:177: error: unknown field 'start' specified in initializer s3c64xx.c:177: warning: excess elements in struct initializer s3c64xx.c:177: warning: (near initialization for 's3c64xx_serial_drv') s3c64xx.c:178: error: unknown field 'stop' specified in initializer s3c64xx.c:178: warning: excess elements in struct initializer s3c64xx.c:178: warning: (near initialization for 's3c64xx_serial_drv') s3c64xx.c:179: error: unknown field 'setbrg' specified in initializer s3c64xx.c:179: warning: excess elements in struct initializer s3c64xx.c:179: warning: (near initialization for 's3c64xx_serial_drv') s3c64xx.c:180: error: unknown field 'putc' specified in initializer s3c64xx.c:180: warning: excess elements in struct initializer s3c64xx.c:180: warning: (near initialization for 's3c64xx_serial_drv') s3c64xx.c:181: error: unknown field 'puts' specified in initializer s3c64xx.c:181: warning: excess elements in struct initializer s3c64xx.c:181: warning: (near initialization for 's3c64xx_serial_drv') s3c64xx.c:182: error: unknown field 'getc' specified in initializer s3c64xx.c:182: warning: excess elements in struct initializer s3c64xx.c:182: warning: (near initialization for 's3c64xx_serial_drv') s3c64xx.c:183: error: unknown field 'tstc' specified in initializer s3c64xx.c:183: warning: excess elements in struct initializer s3c64xx.c:183: warning: (near initialization for 's3c64xx_serial_drv') s3c64xx.c: In function 's3c64xx_serial_initialize': s3c64xx.c:188: warning: implicit declaration of function 'serial_register' s3c64xx.c: At top level: s3c64xx.c:191: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'struct'
Signed-off-by: Minkyu Kang mk7.kang@samsung.com Cc: Marek Vasut marex@denx.de --- drivers/serial/s3c64xx.c | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/serial/s3c64xx.c b/drivers/serial/s3c64xx.c index 9ab8a28..9886ec6 100644 --- a/drivers/serial/s3c64xx.c +++ b/drivers/serial/s3c64xx.c @@ -22,7 +22,8 @@ */
#include <common.h> - +#include <linux/compiler.h> +#include <serial.h> #include <asm/arch/s3c6400.h>
DECLARE_GLOBAL_DATA_PTR; @@ -40,8 +41,6 @@ DECLARE_GLOBAL_DATA_PTR; #error "Bad: you didn't configure serial ..." #endif
-#define barrier() asm volatile("" ::: "memory") - /* * The coefficient, used to calculate the baudrate on S3C6400 UARTs is * calculated as
Dear Jaehoon Chung,
Acked-by: Marek Vasut marex@denx.de
Best regards, Marek Vasut
2012. 10. 26. 19:12 Marek Vasut marex@denx.de 작성:
Dear Jaehoon Chung,
Best regards, Marek Vasut _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
applied to u-boot-samsung
Minkyu Kang.
Jaehoon Chung
Minkyu Kang
