[PATCH] boot: image-board: Mismatch a type between variable and return value
phys_addr_t can be used unsigned long long type with CONFIG_PHYS_64BIT. But hextoul() is always returning to unsigned long. It can be assigned to unexpected value. To avoid wrong behavior, change from hextoul() to simple_strtoull().
Fixes: a4df06e41fa2 ("boot: fdt: Change type of env_get_bootm_low() to phys_addr_t")
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- boot/image-board.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/boot/image-board.c b/boot/image-board.c index 1757e5816d84..977343a8995c 100644 --- a/boot/image-board.c +++ b/boot/image-board.c @@ -547,7 +547,7 @@ int boot_ramdisk_high(ulong rd_data, ulong rd_len, ulong *initrd_start, /* a value of "no" or a similar string will act like 0, * turning the "load high" feature off. This is intentional. */ - initrd_high = hextoul(s, NULL); + initrd_high = simple_strtoull(s, NULL, 16); if (initrd_high == ~0) initrd_copy_to_ram = 0; } else {
Looking at:
7e5f460ec457 ("global: Convert simple_strtoul() with hex to hextoul()")
do you have to update any of the other hextoul() calls too ?
Maybe we need hextoull() ?
if (initrd_high == ~0) initrd_copy_to_ram = 0; } else {initrd_high = simple_strtoull(s, NULL, 16);
-----Original Message----- From: Marek Vasut marek.vasut@mailbox.org Sent: Wednesday, November 6, 2024 7:57 AM To: Jaehoon Chung jh80.chung@samsung.com; u-boot@lists.denx.de Cc: trini@konsulko.com; sjg@chromium.org; marek.vasut+renesas@mailbox.org; laurent.pinchart@ideasonboard.com; m.szyprowski@samsung.com Subject: Re: [PATCH] boot: image-board: Mismatch a type between variable and return value
Looking at:
Thanks for informing it.
I didn't check other hextoul(). During booting with initramfs on RPi (32bit), I found the problem that is not working fine because of this.
IMO, We need hextoull() for some cases. If there is no objection, I will send the patch for adding hextoull(). And I will check entire cases.
Best Regards, Jaehoon Chung
Looking at:
Please check the other sites too, maybe there are more of these issues lurking around.
No objection from me. Thank you.
Jaehoon Chung
