[U-Boot] [PATCH 0/3] ARM: AM43xx: Enable SPL_DM
Enable SPL_DM on all AM4xx based boards.
This series depends on: - DRA7 SPL_DM series[1] - http://patchwork.ozlabs.org/patch/727106/
[1] https://www.mail-archive.com/u-boot@lists.denx.de/msg238751.html
Lokesh Vutla (3): ARM: dts: am43xx: Add u-boot specific dtsi config: am43xx_usbhost_boot: sync with am43xx_evm configs: am43xx_evm: Enable SPL_DM
arch/arm/dts/am437x-gp-evm-u-boot.dtsi | 38 +++++++++++++++++++++++++++++++ configs/am43xx_evm_defconfig | 7 +++++- configs/am43xx_evm_usbhost_boot_defconfig | 12 +++++++++- configs/am43xx_hs_evm_defconfig | 7 +++++- include/configs/am43xx_evm.h | 4 ---- 5 files changed, 61 insertions(+), 7 deletions(-) create mode 100644 arch/arm/dts/am437x-gp-evm-u-boot.dtsi
Add u-boot specific dtsi for am43xx-gp-evm so that it will be used for SPL.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/dts/am437x-gp-evm-u-boot.dtsi | 38 ++++++++++++++++++++++++++++++++++ 1 file changed, 38 insertions(+) create mode 100644 arch/arm/dts/am437x-gp-evm-u-boot.dtsi
diff --git a/arch/arm/dts/am437x-gp-evm-u-boot.dtsi b/arch/arm/dts/am437x-gp-evm-u-boot.dtsi new file mode 100644 index 0000000000..885a9a92db --- /dev/null +++ b/arch/arm/dts/am437x-gp-evm-u-boot.dtsi @@ -0,0 +1,38 @@ +/* + * Copyright (C) 2017 Texas Instruments Incorporated - http://www.ti.com/ + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * Based on "dra7.dtsi" + */ + +/{ + ocp { + u-boot,dm-pre-reloc; + }; +}; + +&uart0 { + u-boot,dm-pre-reloc; +}; + +&mmc1 { + u-boot,dm-pre-reloc; +}; + +&mac { + u-boot,dm-pre-reloc; +}; + +&davinci_mdio { + u-boot,dm-pre-reloc; +}; + +&cpsw_emac0 { + u-boot,dm-pre-reloc; +}; + +&phy_sel { + u-boot,dm-pre-reloc; +};
am43xx_evm defconfig has been modified without making changes in am43xx_usbhost_boot defconfig. Synce here.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- - The only reason to have usbhost defconfig is that the load address is different from that of other bootmodes.
configs/am43xx_evm_usbhost_boot_defconfig | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index 5775ab16dd..e22bc7fbdb 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -48,13 +48,18 @@ CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y CONFIG_DM_MMC=y # CONFIG_DM_MMC_OPS is not set CONFIG_MMC_OMAP_HS=y +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y +CONFIG_DM_SPI=y CONFIG_TI_QSPI=y CONFIG_TIMER=y CONFIG_OMAP_TIMER=y
Enable SPL_DM on all AM43xx based platforms
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- configs/am43xx_evm_defconfig | 7 ++++++- configs/am43xx_evm_usbhost_boot_defconfig | 7 ++++++- configs/am43xx_hs_evm_defconfig | 7 ++++++- include/configs/am43xx_evm.h | 4 ---- 4 files changed, 18 insertions(+), 7 deletions(-)
diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 6fb2053f33..4b0f5c6106 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -10,7 +10,9 @@ CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1,NAND" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y +CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y @@ -38,8 +40,12 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIST="am437x-gp-evm am437x-sk-evm am43x-epos-evm am437x-idk-evm" CONFIG_DM=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_OF_TRANSLATE=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y @@ -73,4 +79,3 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0403 CONFIG_G_DNL_PRODUCT_NUM=0xbd00 -CONFIG_SPL_OF_LIBFDT=y diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index e22bc7fbdb..6e408d101f 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -11,7 +11,9 @@ CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,NAND" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y +CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_USB_HOST_SUPPORT=y @@ -41,8 +43,12 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIST="am437x-gp-evm am437x-sk-evm am43x-epos-evm am437x-idk-evm" CONFIG_DM=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_OF_TRANSLATE=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y @@ -76,4 +82,3 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0403 CONFIG_G_DNL_PRODUCT_NUM=0xbd00 -CONFIG_SPL_OF_LIBFDT=y diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index 6bcbfd77ed..016f16f630 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -14,7 +14,9 @@ CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1,NAND" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y +CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_ETH_SUPPORT=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_NET_SUPPORT=y @@ -48,8 +50,12 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIST="am437x-gp-evm am437x-sk-evm am43x-epos-evm am437x-idk-evm" CONFIG_DM=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_OF_TRANSLATE=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y @@ -82,4 +88,3 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0403 CONFIG_G_DNL_PRODUCT_NUM=0xbd00 -CONFIG_SPL_OF_LIBFDT=y diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 1d622eff2f..1997145863 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -20,7 +20,6 @@ #define CONFIG_SYS_NS16550_CLK 48000000 #if defined(CONFIG_SPL_BUILD) || !defined(CONFIG_DM_SERIAL) #define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE (-4) #endif
/* I2C Configuration */ @@ -111,9 +110,6 @@ * DM support in SPL */ #ifdef CONFIG_SPL_BUILD -#undef CONFIG_DM_MMC -#undef CONFIG_DM_SPI -#undef CONFIG_DM_SPI_FLASH #undef CONFIG_TIMER #endif
Lokesh Vutla
