[U-Boot] [PATCH v5] ARM: am335x: Add phyCORE AM335x R2 support
Support for Phytech phyCORE AM335x R2 SOM (PCL060) on the Phytec phyBOARD-Wega AM335x.
CPU : AM335X-GP rev 2.1 Model: Phytec AM335x phyBOARD-WEGA DRAM: 256 MiB NAND: 256 MiB MMC: OMAP SD/MMC: 0 eth0: ethernet@4a100000
Working: - Eth0 - i2C - MMC/SD - NAND - UART - USB (host)
Device trees were taken from Linux mainline: commit 37624b58542f ("Linux 5.1-rc7")
Signed-off-by: Niel Fourie lusus@denx.de
--- Changes for v2: - Remove formatting changes to upstream Linux dtsi files - Remove incorrectly added MACH_TYPE - Rename board from phycore_pcl060 to phycore_am335x_r2 - Implement selecting memory size from device tree - Remove non-DM Ethernet board code - General clean-up
Changes for v3: - Added kernel revision of upstream Linux dtsi files - Place TARGET_PHYCORE_AM335X_R2 alphabetically in Kconfig - Rework TPS65910 I2C init code - Remove non-DM USB board macros - Minor tweaks
Changes for v4: - Propose abstracting common sections to am33xx-u-boot.dtsi - Remove dead Falcon mode code - Remove non-DM I2C support for TPS65910 I2C
Changes for v5: - Revert proposed moving of sections to am33xx-u-boot.dtsi - Remove redundant/incorrect lines from am33xx-u-boot.dtsi - Add missing changelog
arch/arm/dts/Makefile | 3 +- arch/arm/dts/am335x-phycore-som.dtsi | 322 +++++++++++++++++++++ arch/arm/dts/am335x-wega-rdk-u-boot.dtsi | 31 ++ arch/arm/dts/am335x-wega-rdk.dts | 23 ++ arch/arm/dts/am335x-wega.dtsi | 230 +++++++++++++++ arch/arm/mach-omap2/Kconfig | 1 + arch/arm/mach-omap2/am33xx/Kconfig | 7 + board/phytec/phycore_am335x_r2/Kconfig | 15 + board/phytec/phycore_am335x_r2/MAINTAINERS | 7 + board/phytec/phycore_am335x_r2/Makefile | 11 + board/phytec/phycore_am335x_r2/board.c | 252 ++++++++++++++++ board/phytec/phycore_am335x_r2/board.h | 24 ++ board/phytec/phycore_am335x_r2/mux.c | 117 ++++++++ configs/phycore-am335x-r2-wega_defconfig | 79 +++++ include/configs/phycore_am335x_r2.h | 130 +++++++++ 15 files changed, 1251 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/am335x-phycore-som.dtsi create mode 100644 arch/arm/dts/am335x-wega-rdk-u-boot.dtsi create mode 100644 arch/arm/dts/am335x-wega-rdk.dts create mode 100644 arch/arm/dts/am335x-wega.dtsi create mode 100644 board/phytec/phycore_am335x_r2/Kconfig create mode 100644 board/phytec/phycore_am335x_r2/MAINTAINERS create mode 100644 board/phytec/phycore_am335x_r2/Makefile create mode 100644 board/phytec/phycore_am335x_r2/board.c create mode 100644 board/phytec/phycore_am335x_r2/board.h create mode 100644 board/phytec/phycore_am335x_r2/mux.c create mode 100644 configs/phycore-am335x-r2-wega_defconfig create mode 100644 include/configs/phycore_am335x_r2.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 8e082f2840..381a64ae13 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -264,7 +264,8 @@ dtb-$(CONFIG_AM33XX) += \ am335x-chiliboard.dtb \ am335x-sl50.dtb \ am335x-base0033.dtb \ - am335x-guardian.dtb + am335x-guardian.dtb \ + am335x-wega-rdk.dtb dtb-$(CONFIG_AM43XX) += am437x-gp-evm.dtb am437x-sk-evm.dtb \ am43x-epos-evm.dtb \ am437x-idk-evm.dtb \ diff --git a/arch/arm/dts/am335x-phycore-som.dtsi b/arch/arm/dts/am335x-phycore-som.dtsi new file mode 100644 index 0000000000..8d7c19e5e1 --- /dev/null +++ b/arch/arm/dts/am335x-phycore-som.dtsi @@ -0,0 +1,322 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2015 Phytec Messtechnik GmbH + * Author: Teresa Remmet t.remmet@phytec.de + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +#include "am33xx.dtsi" +#include <dt-bindings/interrupt-controller/irq.h> + +/ { + model = "Phytec AM335x phyCORE"; + compatible = "phytec,am335x-phycore-som", "ti,am33xx"; + + aliases { + rtc0 = &i2c_rtc; + rtc1 = &rtc; + }; + + cpus { + cpu@0 { + cpu0-supply = <&vdd1_reg>; + }; + }; + + memory@80000000 { + device_type = "memory"; + reg = <0x80000000 0x10000000>; /* 256 MB */ + }; + + regulators { + compatible = "simple-bus"; + + vcc5v: fixedregulator0 { + compatible = "regulator-fixed"; + regulator-name = "vcc5v"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-boot-on; + regulator-always-on; + }; + }; +}; + +/* Crypto Module */ +&aes { + status = "okay"; +}; + +&sham { + status = "okay"; +}; + +/* Ethernet */ +&am33xx_pinmux { + ethernet0_pins: pinmux_ethernet0 { + pinctrl-single,pins = < + AM33XX_IOPAD(0x90c, PIN_INPUT_PULLDOWN | MUX_MODE1) /* mii1_crs.rmii1_crs_dv */ + AM33XX_IOPAD(0x910, PIN_INPUT_PULLDOWN | MUX_MODE1) /* mii1_rxerr.rmii1_rxerr */ + AM33XX_IOPAD(0x914, PIN_OUTPUT | MUX_MODE1) /* mii1_txen.rmii1_txen */ + AM33XX_IOPAD(0x924, PIN_OUTPUT | MUX_MODE1) /* mii1_txd1.rmii1_txd1 */ + AM33XX_IOPAD(0x928, PIN_OUTPUT | MUX_MODE1) /* mii1_txd0.rmii1_txd0 */ + AM33XX_IOPAD(0x93c, PIN_INPUT_PULLDOWN | MUX_MODE1) /* mii1_rxd1.rmii1_rxd1 */ + AM33XX_IOPAD(0x940, PIN_INPUT_PULLDOWN | MUX_MODE1) /* mii1_rxd0.rmii1_rxd0 */ + AM33XX_IOPAD(0x944, PIN_INPUT_PULLDOWN | MUX_MODE0) /* rmii1_refclk.rmii1_refclk */ + >; + }; + + mdio_pins: pinmux_mdio { + pinctrl-single,pins = < + /* MDIO */ + AM33XX_IOPAD(0x948, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0) /* mdio_data.mdio_data */ + AM33XX_IOPAD(0x94c, PIN_OUTPUT_PULLUP | MUX_MODE0) /* mdio_clk.mdio_clk */ + >; + }; +}; + +&cpsw_emac0 { + phy-handle = <&phy0>; + phy-mode = "rmii"; + dual_emac_res_vlan = <1>; +}; + +&davinci_mdio { + pinctrl-names = "default"; + pinctrl-0 = <&mdio_pins>; + status = "okay"; + + phy0: ethernet-phy@0 { + reg = <0>; + }; +}; + +&mac { + slaves = <1>; + pinctrl-names = "default"; + pinctrl-0 = <ðernet0_pins>; + status = "okay"; +}; + +/* I2C Busses */ +&am33xx_pinmux { + i2c0_pins: pinmux_i2c0 { + pinctrl-single,pins = < + AM33XX_IOPAD(0x988, PIN_INPUT | MUX_MODE0) /* i2c0_sda.i2c0_sda */ + AM33XX_IOPAD(0x98c, PIN_INPUT | MUX_MODE0) /* i2c0_scl.i2c0_scl */ + >; + }; +}; + +&i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_pins>; + clock-frequency = <400000>; + status = "okay"; + + tps: pmic@2d { + reg = <0x2d>; + }; + + i2c_tmp102: temp@4b { + compatible = "ti,tmp102"; + reg = <0x4b>; + status = "disabled"; + }; + + i2c_eeprom: eeprom@52 { + compatible = "atmel,24c32"; + pagesize = <32>; + reg = <0x52>; + status = "disabled"; + }; + + i2c_rtc: rtc@68 { + compatible = "microcrystal,rv4162"; + reg = <0x68>; + status = "disabled"; + }; +}; + +/* NAND memory */ +&am33xx_pinmux { + nandflash_pins: pinmux_nandflash { + pinctrl-single,pins = < + AM33XX_IOPAD(0x800, PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad0.gpmc_ad0 */ + AM33XX_IOPAD(0x804, PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad1.gpmc_ad1 */ + AM33XX_IOPAD(0x808, PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad2.gpmc_ad2 */ + AM33XX_IOPAD(0x80c, PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad3.gpmc_ad3 */ + AM33XX_IOPAD(0x810, PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad4.gpmc_ad4 */ + AM33XX_IOPAD(0x814, PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad5.gpmc_ad5 */ + AM33XX_IOPAD(0x818, PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad6.gpmc_ad6 */ + AM33XX_IOPAD(0x81c, PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad7.gpmc_ad7 */ + AM33XX_IOPAD(0x870, PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_wait0.gpmc_wait0 */ + AM33XX_IOPAD(0x87c, PIN_OUTPUT | MUX_MODE0) /* gpmc_csn0.gpmc_csn0 */ + AM33XX_IOPAD(0x890, PIN_OUTPUT | MUX_MODE0) /* gpmc_advn_ale.gpmc_advn_ale */ + AM33XX_IOPAD(0x894, PIN_OUTPUT | MUX_MODE0) /* gpmc_oen_ren.gpmc_oen_ren */ + AM33XX_IOPAD(0x898, PIN_OUTPUT | MUX_MODE0) /* gpmc_wen.gpmc_wen */ + AM33XX_IOPAD(0x89c, PIN_OUTPUT | MUX_MODE0) /* gpmc_be0n_cle.gpmc_be0n_cle */ + >; + }; +}; + +&elm { + status = "okay"; +}; + +&gpmc { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&nandflash_pins>; + ranges = <0 0 0x08000000 0x1000000>; /* CS0: NAND */ + nandflash: nand@0,0 { + compatible = "ti,omap2-nand"; + reg = <0 0 4>; /* CS0, offset 0, IO size 4 */ + interrupt-parent = <&gpmc>; + interrupts = <0 IRQ_TYPE_NONE>, /* fifoevent */ + <1 IRQ_TYPE_NONE>; /* termcount */ + rb-gpios = <&gpmc 0 GPIO_ACTIVE_HIGH>; /* gpmc_wait0 */ + nand-bus-width = <8>; + ti,nand-ecc-opt = "bch8"; + gpmc,device-nand = "true"; + gpmc,device-width = <1>; + gpmc,sync-clk-ps = <0>; + gpmc,cs-on-ns = <0>; + gpmc,cs-rd-off-ns = <30>; + gpmc,cs-wr-off-ns = <30>; + gpmc,adv-on-ns = <0>; + gpmc,adv-rd-off-ns = <30>; + gpmc,adv-wr-off-ns = <30>; + gpmc,we-on-ns = <0>; + gpmc,we-off-ns = <20>; + gpmc,oe-on-ns = <10>; + gpmc,oe-off-ns = <30>; + gpmc,access-ns = <30>; + gpmc,rd-cycle-ns = <30>; + gpmc,wr-cycle-ns = <30>; + gpmc,bus-turnaround-ns = <0>; + gpmc,cycle2cycle-delay-ns = <50>; + gpmc,cycle2cycle-diffcsen; + gpmc,clk-activation-ns = <0>; + gpmc,wr-access-ns = <30>; + gpmc,wr-data-mux-bus-ns = <0>; + + ti,elm-id = <&elm>; + + #address-cells = <1>; + #size-cells = <1>; + }; +}; + +/* Power */ +#include "tps65910.dtsi" + +&tps { + vcc1-supply = <&vcc5v>; + vcc2-supply = <&vcc5v>; + vcc3-supply = <&vcc5v>; + vcc4-supply = <&vcc5v>; + vcc5-supply = <&vcc5v>; + vcc6-supply = <&vcc5v>; + vcc7-supply = <&vcc5v>; + vccio-supply = <&vcc5v>; + + regulators { + vrtc_reg: regulator@0 { + regulator-always-on; + }; + + vio_reg: regulator@1 { + regulator-always-on; + }; + + vdd1_reg: regulator@2 { + /* VDD_MPU voltage limits 0.95V - 1.325V with +/-4% tolerance */ + regulator-name = "vdd_mpu"; + regulator-min-microvolt = <912500>; + regulator-max-microvolt = <1378000>; + regulator-boot-on; + regulator-always-on; + }; + + vdd2_reg: regulator@3 { + /* VDD_CORE voltage limits 0.95V - 1.1V with +/-4% tolerance */ + regulator-name = "vdd_core"; + regulator-min-microvolt = <912500>; + regulator-max-microvolt = <1150000>; + regulator-boot-on; + regulator-always-on; + }; + + vdd3_reg: regulator@4 { + regulator-always-on; + }; + + vdig1_reg: regulator@5 { + regulator-name = "vdig1_1p8v"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + vdig2_reg: regulator@6 { + regulator-always-on; + }; + + vpll_reg: regulator@7 { + regulator-always-on; + }; + + vdac_reg: regulator@8 { + regulator-always-on; + }; + + vaux1_reg: regulator@9 { + regulator-always-on; + }; + + vaux2_reg: regulator@10 { + regulator-always-on; + }; + + vaux33_reg: regulator@11 { + regulator-always-on; + }; + + vmmc_reg: regulator@12 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + }; +}; + +/* SPI Busses */ +&am33xx_pinmux { + spi0_pins: pinmux_spi0 { + pinctrl-single,pins = < + AM33XX_IOPAD(0x950, PIN_INPUT_PULLDOWN | MUX_MODE0) /* spi0_clk.spi0_clk */ + AM33XX_IOPAD(0x954, PIN_INPUT_PULLDOWN | MUX_MODE0) /* spi0_d0.spi0_d0 */ + AM33XX_IOPAD(0x958, PIN_INPUT_PULLUP | MUX_MODE0) /* spi0_d1.spi0_d1 */ + AM33XX_IOPAD(0x95c, PIN_INPUT_PULLUP | MUX_MODE0) /* spi0_cs0.spi0_cs0 */ + >; + }; +}; + +&spi0 { + pinctrl-names = "default"; + pinctrl-0 = <&spi0_pins>; + status = "okay"; + + serial_flash: m25p80@0 { + compatible = "jedec,spi-nor"; + spi-max-frequency = <48000000>; + reg = <0x0>; + m25p,fast-read; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + }; +}; diff --git a/arch/arm/dts/am335x-wega-rdk-u-boot.dtsi b/arch/arm/dts/am335x-wega-rdk-u-boot.dtsi new file mode 100644 index 0000000000..36b761b7bf --- /dev/null +++ b/arch/arm/dts/am335x-wega-rdk-u-boot.dtsi @@ -0,0 +1,31 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2019 DENX Software Engineering GmbH + */ + +/ { + chosen { + #address-cells = <1>; + #size-cells = <1>; + + bootargs = "console=ttyO0,115200 earlyprintk"; + stdout-path = &uart0; + }; + + ocp { + u-boot,dm-pre-reloc; + }; + + memory@80000000 { + u-boot,dm-pre-reloc; + }; +}; + +&uart0 { + u-boot,dm-pre-reloc; +}; + +&mmc1 { + u-boot,dm-pre-reloc; + cd-gpios = <&gpio0 6 GPIO_ACTIVE_LOW>; +}; diff --git a/arch/arm/dts/am335x-wega-rdk.dts b/arch/arm/dts/am335x-wega-rdk.dts new file mode 100644 index 0000000000..fe50f3041a --- /dev/null +++ b/arch/arm/dts/am335x-wega-rdk.dts @@ -0,0 +1,23 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2015 Phytec Messtechnik GmbH + * Author: Teresa Remmet t.remmet@phytec.de + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +/dts-v1/; + +#include "am335x-phycore-som.dtsi" +#include "am335x-wega.dtsi" + +/* SoM */ +&i2c_eeprom { + status = "okay"; +}; + +&i2c_rtc { + status = "okay"; +}; diff --git a/arch/arm/dts/am335x-wega.dtsi b/arch/arm/dts/am335x-wega.dtsi new file mode 100644 index 0000000000..f3e045dfc4 --- /dev/null +++ b/arch/arm/dts/am335x-wega.dtsi @@ -0,0 +1,230 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2015 Phytec Messtechnik GmbH + * Author: Teresa Remmet t.remmet@phytec.de + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +/ { + model = "Phytec AM335x phyBOARD-WEGA"; + compatible = "phytec,am335x-wega", "phytec,am335x-phycore-som", "ti,am33xx"; + + sound: sound_iface { + compatible = "ti,da830-evm-audio"; + }; + + regulators { + compatible = "simple-bus"; + + vcc3v3: fixedregulator1 { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + }; + }; +}; + +/* Audio */ +&am33xx_pinmux { + mcasp0_pins: pinmux_mcasp0 { + pinctrl-single,pins = < + AM33XX_IOPAD(0x9AC, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* mcasp0_ahclkx.mcasp0_ahclkx */ + AM33XX_IOPAD(0x990, PIN_INPUT_PULLDOWN | MUX_MODE0) /* mcasp0_aclkx.mcasp0_aclkx */ + AM33XX_IOPAD(0x994, PIN_INPUT_PULLDOWN | MUX_MODE0) /* mcasp0_fsx.mcasp0_fsx */ + AM33XX_IOPAD(0x998, PIN_INPUT_PULLDOWN | MUX_MODE0) /* mcasp0_axr0.mcasp0_axr0 */ + AM33XX_IOPAD(0x9A8, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* mcasp0_axr1.mcasp0_axr1 */ + >; + }; +}; + +&i2c0 { + tlv320aic3007: tlv320aic3007@18 { + compatible = "ti,tlv320aic3007"; + reg = <0x18>; + AVDD-supply = <&vcc3v3>; + IOVDD-supply = <&vcc3v3>; + DRVDD-supply = <&vcc3v3>; + DVDD-supply = <&vdig1_reg>; + status = "okay"; + }; +}; + +&mcasp0 { + pinctrl-names = "default"; + pinctrl-0 = <&mcasp0_pins>; + op-mode = <0>; /* DAVINCI_MCASP_IIS_MODE */ + tdm-slots = <2>; + serial-dir = < + 2 1 0 0 /* # 0: INACTIVE, 1: TX, 2: RX */ + >; + tx-num-evt = <16>; + rt-num-evt = <16>; + status = "okay"; +}; + +&sound { + ti,model = "AM335x-Wega"; + ti,audio-codec = <&tlv320aic3007>; + ti,mcasp-controller = <&mcasp0>; + ti,audio-routing = + "Line Out", "LLOUT", + "Line Out", "RLOUT", + "LINE1L", "Line In", + "LINE1R", "Line In"; + clocks = <&mcasp0_fck>; + clock-names = "mclk"; + status = "okay"; +}; + +/* CAN Busses */ +&am33xx_pinmux { + dcan1_pins: pinmux_dcan1 { + pinctrl-single,pins = < + AM33XX_IOPAD(0x968, PIN_OUTPUT_PULLUP | MUX_MODE2) /* uart0_ctsn.d_can1_tx */ + AM33XX_IOPAD(0x96c, PIN_INPUT_PULLUP | MUX_MODE2) /* uart0_rtsn.d_can1_rx */ + >; + }; +}; + +&dcan1 { + pinctrl-names = "default"; + pinctrl-0 = <&dcan1_pins>; + status = "okay"; +}; + +/* Ethernet */ +&am33xx_pinmux { + ethernet1_pins: pinmux_ethernet1 { + pinctrl-single,pins = < + AM33XX_IOPAD(0x840, PIN_OUTPUT | MUX_MODE1) /* gpmc_a0.mii2_txen */ + AM33XX_IOPAD(0x844, PIN_INPUT_PULLDOWN | MUX_MODE1) /* gpmc_a1.mii2_rxdv */ + AM33XX_IOPAD(0x848, PIN_OUTPUT | MUX_MODE1) /* gpmc_a2.mii2_txd3 */ + AM33XX_IOPAD(0x84c, PIN_OUTPUT | MUX_MODE1) /* gpmc_a3.mii2_txd2 */ + AM33XX_IOPAD(0x850, PIN_OUTPUT | MUX_MODE1) /* gpmc_a4.mii2_txd1 */ + AM33XX_IOPAD(0x854, PIN_OUTPUT | MUX_MODE1) /* gpmc_a5.mii2_txd0 */ + AM33XX_IOPAD(0x858, PIN_INPUT_PULLDOWN | MUX_MODE1) /* gpmc_a6.mii2_txclk */ + AM33XX_IOPAD(0x85c, PIN_INPUT_PULLDOWN | MUX_MODE1) /* gpmc_a7.mii2_rxclk */ + AM33XX_IOPAD(0x860, PIN_INPUT_PULLDOWN | MUX_MODE1) /* gpmc_a8.mii2_rxd3 */ + AM33XX_IOPAD(0x864, PIN_INPUT_PULLDOWN | MUX_MODE1) /* gpmc_a9.mii2_rxd2 */ + AM33XX_IOPAD(0x868, PIN_INPUT_PULLDOWN | MUX_MODE1) /* gpmc_a10.mii2_rxd1 */ + AM33XX_IOPAD(0x86c, PIN_INPUT_PULLDOWN | MUX_MODE1) /* gpmc_a11.mii2_rxd0 */ + AM33XX_IOPAD(0x874, PIN_INPUT_PULLDOWN | MUX_MODE1) /* gpmc_wpn.mii2_rxerr */ + AM33XX_IOPAD(0x878, PIN_INPUT_PULLDOWN | MUX_MODE1) /* gpmc_ben1.mii2_col */ + >; + }; +}; + +&cpsw_emac1 { + phy-handle = <&phy1>; + phy-mode = "mii"; + dual_emac_res_vlan = <2>; +}; + +&davinci_mdio { + phy1: ethernet-phy@1 { + reg = <1>; + }; +}; + +&mac { + slaves = <2>; + pinctrl-names = "default"; + pinctrl-0 = <ðernet0_pins ðernet1_pins>; + dual_emac = <1>; +}; + +/* MMC */ +&am33xx_pinmux { + mmc1_pins: pinmux_mmc1 { + pinctrl-single,pins = < + AM33XX_IOPAD(0x8f0, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat3.mmc0_dat3 */ + AM33XX_IOPAD(0x8f4, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat2.mmc0_dat2 */ + AM33XX_IOPAD(0x8f8, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat1.mmc0_dat1 */ + AM33XX_IOPAD(0x8fc, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat0.mmc0_dat0 */ + AM33XX_IOPAD(0x900, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_clk.mmc0_clk */ + AM33XX_IOPAD(0x904, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_cmd.mmc0_cmd */ + AM33XX_IOPAD(0x960, PIN_INPUT_PULLUP | MUX_MODE7) /* spi0_cs1.mmc0_sdcd */ + >; + }; +}; + +&mmc1 { + vmmc-supply = <&vcc3v3>; + bus-width = <4>; + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pins>; + cd-gpios = <&gpio0 6 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; + +/* Power */ +&vdig1_reg { + regulator-boot-on; + regulator-always-on; +}; + +/* UARTs */ +&am33xx_pinmux { + uart0_pins: pinmux_uart0 { + pinctrl-single,pins = < + AM33XX_IOPAD(0x970, PIN_INPUT_PULLUP | MUX_MODE0) /* uart0_rxd.uart0_rxd */ + AM33XX_IOPAD(0x974, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* uart0_txd.uart0_txd */ + >; + }; + + uart1_pins: pinmux_uart1_pins { + pinctrl-single,pins = < + AM33XX_IOPAD(0x980, PIN_INPUT_PULLUP | MUX_MODE0) /* uart1_rxd.uart1_rxd */ + AM33XX_IOPAD(0x984, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* uart1_txd.uart1_txd */ + AM33XX_IOPAD(0x978, PIN_INPUT | MUX_MODE0) /* uart1_ctsn.uart1_ctsn */ + AM33XX_IOPAD(0x97c, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* uart1_rtsn.uart1_rtsn */ + >; + }; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins>; + status = "okay"; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&uart1_pins>; + status = "okay"; +}; + +/* USB */ +&cppi41dma { + status = "okay"; +}; + +&usb_ctrl_mod { + status = "okay"; +}; + +&usb { + status = "okay"; +}; + +&usb0 { + status = "okay"; +}; + +&usb0_phy { + status = "okay"; +}; + +&usb1 { + dr_mode = "host"; + status = "okay"; +}; + +&usb1_phy { + status = "okay"; +}; diff --git a/arch/arm/mach-omap2/Kconfig b/arch/arm/mach-omap2/Kconfig index d29f1ca0b5..3fa9dc89b8 100644 --- a/arch/arm/mach-omap2/Kconfig +++ b/arch/arm/mach-omap2/Kconfig @@ -186,6 +186,7 @@ source "board/ti/am43xx/Kconfig" source "board/ti/am335x/Kconfig" source "board/compulab/cm_t335/Kconfig" source "board/compulab/cm_t43/Kconfig" +source "board/phytec/phycore_am335x_r2/Kconfig"
config SPL_LDSCRIPT default "arch/arm/mach-omap2/u-boot-spl.lds" diff --git a/arch/arm/mach-omap2/am33xx/Kconfig b/arch/arm/mach-omap2/am33xx/Kconfig index 500df1aa11..9da2a16a99 100644 --- a/arch/arm/mach-omap2/am33xx/Kconfig +++ b/arch/arm/mach-omap2/am33xx/Kconfig @@ -177,6 +177,13 @@ config TARGET_PEPPER select DM_SERIAL imply CMD_DM
+config TARGET_PHYCORE_AM335X_R2 + bool "Support phyCORE AM335X R2" + select DM + select DM_GPIO + select DM_SERIAL + imply CMD_DM + config TARGET_PXM2 bool "Support pxm2" select BOARD_LATE_INIT diff --git a/board/phytec/phycore_am335x_r2/Kconfig b/board/phytec/phycore_am335x_r2/Kconfig new file mode 100644 index 0000000000..77055e043c --- /dev/null +++ b/board/phytec/phycore_am335x_r2/Kconfig @@ -0,0 +1,15 @@ +if TARGET_PHYCORE_AM335X_R2 + +config SYS_BOARD + default "phycore_am335x_r2" + +config SYS_VENDOR + default "phytec" + +config SYS_SOC + default "am33xx" + +config SYS_CONFIG_NAME + default "phycore_am335x_r2" + +endif diff --git a/board/phytec/phycore_am335x_r2/MAINTAINERS b/board/phytec/phycore_am335x_r2/MAINTAINERS new file mode 100644 index 0000000000..e56f30fdc0 --- /dev/null +++ b/board/phytec/phycore_am335x_r2/MAINTAINERS @@ -0,0 +1,7 @@ +phyCORE AM335x R2 WEGA BOARD +M: Niel Fourie lusus@denx.de +M: Parthiban Nallathambi pn@denx.de +S: Maintained +F: board/phytec/phycore_am335x_r2 +F: include/configs/phycore_am335x_r2.h +F: configs/phycore-am335x-r2-wega_defconfig diff --git a/board/phytec/phycore_am335x_r2/Makefile b/board/phytec/phycore_am335x_r2/Makefile new file mode 100644 index 0000000000..ff6f8b4221 --- /dev/null +++ b/board/phytec/phycore_am335x_r2/Makefile @@ -0,0 +1,11 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Makefile +# +# Copyright (C) 2011 Texas Instruments Incorporated - http://www.ti.com/ + +ifdef CONFIG_SPL_BUILD +obj-y += mux.o +endif + +obj-y += board.o diff --git a/board/phytec/phycore_am335x_r2/board.c b/board/phytec/phycore_am335x_r2/board.c new file mode 100644 index 0000000000..59c44eb284 --- /dev/null +++ b/board/phytec/phycore_am335x_r2/board.c @@ -0,0 +1,252 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * board.c + * + * Board functions for Phytec phyCORE-AM335x R2 (pcl060) based boards + * + * Copyright (C) 2011, Texas Instruments, Incorporated - http://www.ti.com/ + * Copyright (C) 2013 Lars Poeschel, Lemonage Software GmbH + * Copyright (C) 2015 Wadim Egorov, PHYTEC Messtechnik GmbH + * Copyright (C) 2019 DENX Software Engineering GmbH + */ + +#include <common.h> +#include <spl.h> +#include <asm/arch/cpu.h> +#include <asm/arch/ddr_defs.h> +#include <asm/arch/clock.h> +#include <asm/arch/sys_proto.h> +#include <fdtdec.h> +#include <power/tps65910.h> +#include <jffs2/load_kernel.h> +#include <mtd_node.h> +#include <fdt_support.h> +#include "board.h" + +DECLARE_GLOBAL_DATA_PTR; + +#ifdef CONFIG_SPL_BUILD + +static struct ctrl_dev *cdev = (struct ctrl_dev *)CTRL_DEVICE_BASE; + +/* DDR RAM defines */ +#define DDR_CLK_MHZ 400 /* DDR_DPLL_MULT value */ + +#define OSC (V_OSCK / 1000000) +const struct dpll_params dpll_ddr = { + DDR_CLK_MHZ, OSC - 1, 1, -1, -1, -1, -1}; + +const struct dpll_params *get_dpll_ddr_params(void) +{ + return &dpll_ddr; +} + +const struct ctrl_ioregs ioregs = { + .cm0ioctl = 0x18B, + .cm1ioctl = 0x18B, + .cm2ioctl = 0x18B, + .dt0ioctl = 0x18B, + .dt1ioctl = 0x18B, +}; + +static const struct cmd_control ddr3_cmd_ctrl_data = { + .cmd0csratio = 0x80, + .cmd0iclkout = 0x0, + + .cmd1csratio = 0x80, + .cmd1iclkout = 0x0, + + .cmd2csratio = 0x80, + .cmd2iclkout = 0x0, +}; + +enum { + PHYCORE_R2_MT41K128M16JT_256MB, + PHYCORE_R2_MT41K256M16TW107IT_512MB, + PHYCORE_R2_MT41K512M16HA125IT_1024MB, +}; + +struct am335x_sdram_timings { + struct emif_regs ddr3_emif_reg_data; + struct ddr_data ddr3_data; +}; + +static struct am335x_sdram_timings physom_timings[] = { + [PHYCORE_R2_MT41K128M16JT_256MB] = { + .ddr3_emif_reg_data = { + .sdram_config = 0x61C052B2, + .ref_ctrl = 0x00000C30, + .sdram_tim1 = 0x0AAAD4DB, + .sdram_tim2 = 0x26437FDA, + .sdram_tim3 = 0x501F83FF, + .zq_config = 0x50074BE4, + .emif_ddr_phy_ctlr_1 = 0x7, + .ocp_config = 0x003d3d3d, + }, + .ddr3_data = { + .datardsratio0 = 0x36, + .datawdsratio0 = 0x38, + .datafwsratio0 = 0x99, + .datawrsratio0 = 0x73, + }, + }, + [PHYCORE_R2_MT41K256M16TW107IT_512MB] = { + .ddr3_emif_reg_data = { + .sdram_config = 0x61C05332, + .ref_ctrl = 0x00000C30, + .sdram_tim1 = 0x0AAAD4DB, + .sdram_tim2 = 0x266B7FDA, + .sdram_tim3 = 0x501F867F, + .zq_config = 0x50074BE4, + .emif_ddr_phy_ctlr_1 = 0x7, + .ocp_config = 0x003d3d3d, + }, + .ddr3_data = { + .datardsratio0 = 0x37, + .datawdsratio0 = 0x38, + .datafwsratio0 = 0x92, + .datawrsratio0 = 0x72, + }, + }, + [PHYCORE_R2_MT41K512M16HA125IT_1024MB] = { + .ddr3_emif_reg_data = { + .sdram_config = 0x61C053B2, + .ref_ctrl = 0x00000C30, + .sdram_tim1 = 0x0AAAD4DB, + .sdram_tim2 = 0x268F7FDA, + .sdram_tim3 = 0x501F88BF, + .zq_config = 0x50074BE4, + .emif_ddr_phy_ctlr_1 = 0x7, + .ocp_config = 0x003d3d3d, + }, + .ddr3_data = { + .datardsratio0 = 0x38, + .datawdsratio0 = 0x4d, + .datafwsratio0 = 0x9d, + .datawrsratio0 = 0x82, + }, + }, +}; + +void sdram_init(void) +{ + int ram_type_index = PHYCORE_R2_MT41K128M16JT_256MB; + + if (fdtdec_setup_mem_size_base()) + gd->ram_size = SZ_256M; + + switch (gd->ram_size) { + case SZ_1G: + ram_type_index = PHYCORE_R2_MT41K512M16HA125IT_1024MB; + break; + case SZ_512M: + ram_type_index = PHYCORE_R2_MT41K256M16TW107IT_512MB; + break; + case SZ_256M: + default: + ram_type_index = PHYCORE_R2_MT41K128M16JT_256MB; + break; + } + + config_ddr(DDR_CLK_MHZ, &ioregs, + &physom_timings[ram_type_index].ddr3_data, + &ddr3_cmd_ctrl_data, + &physom_timings[ram_type_index].ddr3_emif_reg_data, 0); +} + +const struct dpll_params *get_dpll_mpu_params(void) +{ + int ind = get_sys_clk_index(); + int freq = am335x_get_efuse_mpu_max_freq(cdev); + + switch (freq) { + case MPUPLL_M_1000: + return &dpll_mpu_opp[ind][5]; + case MPUPLL_M_800: + return &dpll_mpu_opp[ind][4]; + case MPUPLL_M_720: + return &dpll_mpu_opp[ind][3]; + case MPUPLL_M_600: + return &dpll_mpu_opp[ind][2]; + case MPUPLL_M_500: + return &dpll_mpu_opp100; + case MPUPLL_M_300: + return &dpll_mpu_opp[ind][0]; + } + + return &dpll_mpu_opp[ind][0]; +} + +void scale_vcores_generic(int freq) +{ + int sil_rev, mpu_vdd; + + /* + * We use a TPS65910 PMIC. For all MPU frequencies we support we use a + * CORE voltage of 1.10V. For MPU voltage we need to switch based on + * the frequency we are running at. + */ + if (power_tps65910_init(0)) + return; + + /* + * Depending on MPU clock and PG we will need a different + * VDD to drive at that speed. + */ + sil_rev = readl(&cdev->deviceid) >> 28; + mpu_vdd = am335x_get_tps65910_mpu_vdd(sil_rev, freq); + + /* Tell the TPS65910 to use i2c */ + tps65910_set_i2c_control(); + + /* First update MPU voltage. */ + if (tps65910_voltage_update(MPU, mpu_vdd)) + return; + + /* Second, update the CORE voltage. */ + if (tps65910_voltage_update(CORE, TPS65910_OP_REG_SEL_1_1_0)) + return; +} + +void scale_vcores(void) +{ + int freq; + + freq = am335x_get_efuse_mpu_max_freq(cdev); + scale_vcores_generic(freq); +} + +void set_uart_mux_conf(void) +{ + enable_uart0_pin_mux(); +} + +void set_mux_conf_regs(void) +{ + enable_i2c0_pin_mux(); + enable_board_pin_mux(); +} +#endif + +/* + * Basic board specific setup. Pinmux has been handled already. + */ +int board_init(void) +{ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; + return 0; +} + +#ifdef CONFIG_OF_BOARD_SETUP +int ft_board_setup(void *blob, bd_t *bd) +{ +#ifdef CONFIG_FDT_FIXUP_PARTITIONS + static const struct node_info nodes[] = { + { "ti,omap2-nand", MTD_DEV_TYPE_NAND, }, + }; + + fdt_fixup_mtdparts(blob, nodes, ARRAY_SIZE(nodes)); +#endif + return 0; +} +#endif diff --git a/board/phytec/phycore_am335x_r2/board.h b/board/phytec/phycore_am335x_r2/board.h new file mode 100644 index 0000000000..68c3d56aa5 --- /dev/null +++ b/board/phytec/phycore_am335x_r2/board.h @@ -0,0 +1,24 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * board.h + * + * Phytec phyCORE-AM335x (pcl060) boards information header + * + * Copyright (C) 2013 Lars Poeschel, Lemonage Software GmbH + * Copyright (C) 2019 DENX Software Engineering GmbH + */ + +#ifndef _BOARD_H_ +#define _BOARD_H_ + +/* + * We have three pin mux functions that must exist. We must be able to enable + * uart0, for initial output and i2c0 to access the PMIC. We then have a main + * pinmux function that can be overridden to enable all other pinmux that + * is required on the board. + */ +void enable_uart0_pin_mux(void); +void enable_i2c0_pin_mux(void); +void enable_board_pin_mux(void); +void enable_cbmux_pin_mux(void); +#endif diff --git a/board/phytec/phycore_am335x_r2/mux.c b/board/phytec/phycore_am335x_r2/mux.c new file mode 100644 index 0000000000..5fd452e66d --- /dev/null +++ b/board/phytec/phycore_am335x_r2/mux.c @@ -0,0 +1,117 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * mux.c + * + * Copyright (C) 2013 Lars Poeschel, Lemonage Software GmbH + * Copyright (C) 2019 DENX Software Engineering GmbH + */ + +#include <common.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/hardware.h> +#include <asm/arch/mux.h> +#include <asm/io.h> +#include "board.h" + +static struct module_pin_mux uart0_pin_mux[] = { + {OFFSET(uart0_rxd), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* UART0_RXD */ + {OFFSET(uart0_txd), (MODE(0) | PULLUDEN)}, /* UART0_TXD */ + {-1}, +}; + +#ifdef CONFIG_MMC +static struct module_pin_mux mmc0_pin_mux[] = { + {OFFSET(mmc0_dat3), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT3 */ + {OFFSET(mmc0_dat2), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT2 */ + {OFFSET(mmc0_dat1), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT1 */ + {OFFSET(mmc0_dat0), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT0 */ + {OFFSET(mmc0_clk), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_CLK */ + {OFFSET(mmc0_cmd), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_CMD */ + {OFFSET(spi0_cs1), (MODE(5) | RXACTIVE | PULLUP_EN)}, /* MMC0_CD */ + {-1}, +}; +#endif + +static struct module_pin_mux i2c0_pin_mux[] = { + {OFFSET(i2c0_sda), (MODE(0) | RXACTIVE | + PULLUDEN | SLEWCTRL)}, /* I2C_DATA */ + {OFFSET(i2c0_scl), (MODE(0) | RXACTIVE | + PULLUDEN | SLEWCTRL)}, /* I2C_SCLK */ + {-1}, +}; + +#ifdef CONFIG_SPI +static struct module_pin_mux spi0_pin_mux[] = { + {OFFSET(spi0_sclk), (MODE(0) | RXACTIVE | PULLUDEN)}, /* SPI0_SCLK */ + {OFFSET(spi0_d0), (MODE(0) | RXACTIVE | + PULLUDEN | PULLUP_EN)}, /* SPI0_D0 */ + {OFFSET(spi0_d1), (MODE(0) | RXACTIVE | PULLUDEN)}, /* SPI0_D1 */ + {OFFSET(spi0_cs0), (MODE(0) | RXACTIVE | + PULLUDEN | PULLUP_EN)}, /* SPI0_CS0 */ + {-1}, +}; +#endif + +static struct module_pin_mux rmii1_pin_mux[] = { + {OFFSET(mii1_crs), MODE(1) | RXACTIVE}, /* RMII1_CRS */ + {OFFSET(mii1_rxerr), MODE(1) | RXACTIVE}, /* RMII1_RXERR */ + {OFFSET(mii1_txen), MODE(1)}, /* RMII1_TXEN */ + {OFFSET(mii1_txd1), MODE(1)}, /* RMII1_TXD1 */ + {OFFSET(mii1_txd0), MODE(1)}, /* RMII1_TXD0 */ + {OFFSET(mii1_rxd1), MODE(1) | RXACTIVE}, /* RMII1_RXD1 */ + {OFFSET(mii1_rxd0), MODE(1) | RXACTIVE}, /* RMII1_RXD0 */ + {OFFSET(mdio_data), MODE(0) | RXACTIVE | PULLUP_EN}, /* MDIO_DATA */ + {OFFSET(mdio_clk), MODE(0) | PULLUP_EN}, /* MDIO_CLK */ + {OFFSET(rmii1_refclk), MODE(0) | RXACTIVE}, /* RMII1_REFCLK */ + {-1}, +}; + +static struct module_pin_mux cbmux_pin_mux[] = { + {OFFSET(uart0_ctsn), MODE(7) | RXACTIVE | PULLDOWN_EN}, /* JP3 */ + {OFFSET(uart0_rtsn), MODE(7) | RXACTIVE | PULLUP_EN}, /* JP4 */ + {-1}, +}; + +#ifdef CONFIG_NAND +static struct module_pin_mux nand_pin_mux[] = { + {OFFSET(gpmc_ad0), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD0 */ + {OFFSET(gpmc_ad1), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD1 */ + {OFFSET(gpmc_ad2), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD2 */ + {OFFSET(gpmc_ad3), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD3 */ + {OFFSET(gpmc_ad4), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD4 */ + {OFFSET(gpmc_ad5), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD5 */ + {OFFSET(gpmc_ad6), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD6 */ + {OFFSET(gpmc_ad7), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD7 */ + {OFFSET(gpmc_wait0), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* NAND WAIT */ + {OFFSET(gpmc_wpn), (MODE(7) | PULLUP_EN | RXACTIVE)}, /* NAND_WPN */ + {OFFSET(gpmc_csn0), (MODE(0) | PULLUDEN)}, /* NAND_CS0 */ + {OFFSET(gpmc_advn_ale), (MODE(0) | PULLUDEN)}, /* NAND_ADV_ALE */ + {OFFSET(gpmc_oen_ren), (MODE(0) | PULLUDEN)}, /* NAND_OE */ + {OFFSET(gpmc_wen), (MODE(0) | PULLUDEN)}, /* NAND_WEN */ + {OFFSET(gpmc_be0n_cle), (MODE(0) | PULLUDEN)}, /* NAND_BE_CLE */ + {-1}, +}; +#endif + +void enable_uart0_pin_mux(void) +{ + configure_module_pin_mux(uart0_pin_mux); +} + +void enable_i2c0_pin_mux(void) +{ + configure_module_pin_mux(i2c0_pin_mux); +} + +void enable_board_pin_mux(void) +{ + configure_module_pin_mux(rmii1_pin_mux); + configure_module_pin_mux(mmc0_pin_mux); + configure_module_pin_mux(cbmux_pin_mux); +#ifdef CONFIG_NAND + configure_module_pin_mux(nand_pin_mux); +#endif +#ifdef CONFIG_SPI + configure_module_pin_mux(spi0_pin_mux); +#endif +} diff --git a/configs/phycore-am335x-r2-wega_defconfig b/configs/phycore-am335x-r2-wega_defconfig new file mode 100644 index 0000000000..8888d8ff60 --- /dev/null +++ b/configs/phycore-am335x-r2-wega_defconfig @@ -0,0 +1,79 @@ +CONFIG_ARM=y +CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_AM33XX=y +CONFIG_SYS_MPUCLK=1000 +CONFIG_TARGET_PHYCORE_AM335X_R2=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL=y +CONFIG_SPL_FS_FAT=y +CONFIG_SPL_LIBDISK_SUPPORT=y +# CONFIG_FIT is not set +CONFIG_OF_BOARD_SETUP=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_DEFAULT_FDT_FILE="am335x-wega-rdk.dtb" +CONFIG_VERSION_VARIABLE=y +CONFIG_ARCH_MISC_INIT=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_MTD_SUPPORT=y +CONFIG_SPL_PAYLOAD="u-boot.img" +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_SPL=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_NAND=y +CONFIG_CMD_PART=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_MTDPARTS=y +CONFIG_MTDIDS_DEFAULT="nand0=nand.0" +CONFIG_MTDPARTS_DEFAULT="mtdparts=nand.0:128k(NAND.SPL),128k(NAND.SPL.backup1),128k(NAND.SPL.backup2),128k(NAND.SPL.backup3),512k(NAND.u-boot),512k(NAND.u-boot.backup1),256k(NAND.u-boot-env),-(NAND.UBI)" +CONFIG_CMD_UBI=y +CONFIG_DOS_PARTITION=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="am335x-wega-rdk" +CONFIG_ENV_IS_IN_FAT=y +CONFIG_ENV_IS_IN_NAND=y +CONFIG_ENV_FAT_INTERFACE="mmc" +CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_DM_I2C=y +CONFIG_MISC=y +CONFIG_DM_MMC=y +CONFIG_MMC_OMAP_HS=y +CONFIG_MTD=y +CONFIG_NAND=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 +CONFIG_SYS_NAND_U_BOOT_OFFS_REDUND=0x100000 +CONFIG_DM_SPI_FLASH=y +CONFIG_DM_ETH=y +CONFIG_MII=y +CONFIG_DRIVER_TI_CPSW=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_OMAP3_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_DM_USB_GADGET=y +CONFIG_USB_MUSB_HOST=y +CONFIG_USB_MUSB_GADGET=y +CONFIG_USB_MUSB_TI=y +CONFIG_USB_GADGET=y +CONFIG_USB_ETHER=y +# CONFIG_OMAP_WATCHDOG is not set +CONFIG_FDT_FIXUP_PARTITIONS=y +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/phycore_am335x_r2.h b/include/configs/phycore_am335x_r2.h new file mode 100644 index 0000000000..31a07062a0 --- /dev/null +++ b/include/configs/phycore_am335x_r2.h @@ -0,0 +1,130 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * phycore_am335x_r2.h + * + * Phytec phyCORE-AM335x R2 (pcl060) boards information header + * + * Copyright (C) 2011, Texas Instruments, Incorporated - http://www.ti.com/ + * Copyright (C) 2013 Lars Poeschel, Lemonage Software GmbH + * Copyright (C) 2019 DENX Software Engineering GmbH + */ + +#ifndef __CONFIG_PHYCORE_AM335x_R2_H +#define __CONFIG_PHYCORE_AM335x_R2_H + +#include <configs/ti_am335x_common.h> + +#define CONFIG_ENV_SIZE SZ_128K +#define CONFIG_MACH_TYPE MACH_TYPE_SBC_PHYCORE_AM335X +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 + +#ifdef CONFIG_NAND +#define NANDARGS \ + "mtdids=" CONFIG_MTDIDS_DEFAULT "\0" \ + "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ + "nandargs=setenv bootargs console=${console} " \ + "${optargs} " \ + "root=${nandroot} " \ + "rootfstype=${nandrootfstype}\0" \ + "nandroot=ubi0:root ubi.mtd=NAND.UBI\0" \ + "nandrootfstype=ubifs rootwait rw fsck.repair=yes\0" \ + "nandboot=echo Booting from nand ...; " \ + "run nandargs; " \ + "ubi part NAND.UBI; " \ + "ubi readvol ${fdtaddr} oftree; " \ + "ubi readvol ${loadaddr} kernel; " \ + "bootz ${loadaddr} - ${fdtaddr}\0" + +#else +#define NANDARGS "" +#endif + +/* set to negative value for no autoboot */ +#define BOOTENV_DEV_LEGACY_MMC(devtypeu, devtypel, instance) \ + "bootcmd_" #devtypel #instance "=" \ + "setenv mmcdev " #instance "; "\ + "setenv bootpart " #instance ":1 ; "\ + "setenv rootpart " #instance ":2 ; "\ + "run mmcboot\0" + +#define BOOTENV_DEV_NAME_LEGACY_MMC(devtypeu, devtypel, instance) \ + #devtypel #instance " " + +#define BOOTENV_DEV_NAND(devtypeu, devtypel, instance) \ + "bootcmd_" #devtypel #instance "=" \ + "run nandboot\0" + +#define BOOTENV_DEV_NAME_NAND(devtypeu, devtypel, instance) \ + #devtypel #instance " " + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(LEGACY_MMC, legacy_mmc, 0) \ + func(MMC, mmc, 1) \ + func(LEGACY_MMC, legacy_mmc, 1) \ + func(NAND, nand, 0) + +#include <config_distro_bootcmd.h> +#include <environment/ti/dfu.h> +#include <environment/ti/mmc.h> + +#define CONFIG_EXTRA_ENV_SETTINGS \ + DEFAULT_MMC_TI_ARGS \ + DEFAULT_LINUX_BOOT_ENV \ + "bootfile=zImage\0" \ + "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "console=ttyO0,115200n8\0" \ + "optargs=\0" \ + "mmcrootfstype=ext2 rootwait\0" \ + "finduuid=part uuid mmc ${rootpart} uuid\0" \ + "boot_fit=0\0" \ + NANDARGS \ + BOOTENV + +/* Clock Macros */ +#define V_OSCK 25000000 /* Clock output from T2 */ +#define V_SCLK V_OSCK + +#define CONFIG_POWER_TPS65910 + +#ifdef CONFIG_NAND +/* NAND: device related configs */ +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ + CONFIG_SYS_NAND_PAGE_SIZE) +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) +/* NAND: driver related configs */ +#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS +#define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ + 10, 11, 12, 13, 14, 15, 16, 17, \ + 18, 19, 20, 21, 22, 23, 24, 25, \ + 26, 27, 28, 29, 30, 31, 32, 33, \ + 34, 35, 36, 37, 38, 39, 40, 41, \ + 42, 43, 44, 45, 46, 47, 48, 49, \ + 50, 51, 52, 53, 54, 55, 56, 57, } + +#define CONFIG_SYS_NAND_ECCSIZE 512 +#define CONFIG_SYS_NAND_ECCBYTES 14 +#define CONFIG_SYS_NAND_ONFI_DETECTION +#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW + +/* NAND: SPL related configs */ +#ifdef CONFIG_SPL_OS_BOOT +#define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00200000 /* kernel offset */ +#endif +#endif /* !CONFIG_NAND */ + +/* CPU */ + +#ifdef CONFIG_SPI_BOOT +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 +#define CONFIG_SYS_SPI_U_BOOT_SIZE 0x40000 +#elif defined(CONFIG_ENV_IS_IN_NAND) +#define CONFIG_ENV_OFFSET 0x000a0000 +#define CONFIG_SYS_ENV_SECT_SIZE CONFIG_SYS_NAND_BLOCK_SIZE +#endif + +#endif /* ! __CONFIG_PHYCORE_AM335x_R2_H */
Working:
- Eth0
- i2C
- MMC/SD
- NAND
- UART
- USB (host)
[snip]
- memory@80000000 {
You don't need this because:
[snip]
- int ram_type_index = PHYCORE_R2_MT41K128M16JT_256MB;
- if (fdtdec_setup_mem_size_base())
- switch (gd->ram_size) {
- case SZ_1G:
break;
- case SZ_512M:
break;
- case SZ_256M:
- default:
break;
- config_ddr(DDR_CLK_MHZ, &ioregs,
This is wrong. sdram_init() is called by arch/arm/mach-omap2/am33xx/board.c::dram_init() which then sets gd->ram_size based on what get_ram_size() determines. So this is all just a wrapper around how the various parts of the am33xx generations call some form of config_ddr(). And what you have here is a lot of unused code about which module provides how much memory. I assume there's some run-time method to determine which module you're on and thus determine that correct parameters to pass in for the chip that's in use. If you're not there yet then just make sdram_init() call config_ddr(...) with the correct enum for the 256M chip and then update this when you have real detection.
Hi Tom,
Working:
- Eth0
- i2C
- MMC/SD
- NAND
- UART
- USB (host)
Signed-off-by: Niel Fourie lusus@denx.de +void sdram_init(void) +{
- case SZ_1G:
break;
- case SZ_512M:
break;
- case SZ_256M:
- default:
break;
Thanks for that input, you are right. I could not find any documented way to detect the exact module we are running on, but as you pointed out we can use get_ram_size() to find the size of the installed RAM. This is in fact exactly what barebox did, I just missed it. How is this for a replacement of the above?
void sdram_init(void) { /* Configure memory to maximum supported size for detection */ int ram_type_index = PHYCORE_R2_MT41K512M16HA125IT_1024MB; config_ddr(DDR_CLK_MHZ, &ioregs, &physom_timings[ram_type_index].ddr3_data, &ddr3_cmd_ctrl_data, &physom_timings[ram_type_index].ddr3_emif_reg_data, 0);
/* Detect memory physically present */ gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, CONFIG_MAX_RAM_BANK_SIZE);
/* Reconfigure memory for actual detected size */ switch (gd->ram_size) { case SZ_1G: ram_type_index = PHYCORE_R2_MT41K512M16HA125IT_1024MB; break; case SZ_512M: ram_type_index = PHYCORE_R2_MT41K256M16TW107IT_512MB; break; case SZ_256M: default: ram_type_index = PHYCORE_R2_MT41K128M16JT_256MB; break; } config_ddr(DDR_CLK_MHZ, &ioregs, &physom_timings[ram_type_index].ddr3_data, &ddr3_cmd_ctrl_data, &physom_timings[ram_type_index].ddr3_emif_reg_data, 0); }
The ugliest part of this is, as you pointed out, that directly after this is called, get_ram_size() will be called again from sdram_init(). But it at least noninvasive, and no longer requires the device tree.
Best regards, Niel Fourie
On Mon, May 06, 2019 at 06:44:48PM +0200, Niel Fourie wrote:
Hi Tom,
Working:
- Eth0
- i2C
- MMC/SD
- NAND
- UART
- USB (host)
- case SZ_1G:
break;
- case SZ_512M:
break;
- case SZ_256M:
- default:
break;
I don't think it's safe to call config_ddr twice, especially with the possibly wrong parameters. What's barebox doing in this case, being told the presumably correct DDR size in the device tree?
Hi Tom,
Hi Tom,
Working:
- Eth0
- i2C
- MMC/SD
- NAND
- UART
- USB (host)
[snip]
Good point. Barebox uses the above mechanism to detect the memory size, and I could find no equivalent memory size specified in its internal device tree.
Marek originally proposed using the memory size specified in the device tree as an improvement over specifying the size in the defconfig (as in v1 of the patch).
On Tue, May 07, 2019 at 11:39:12AM +0200, Niel Fourie wrote:
Hi Tom,
Hi Tom,
Working:
- Eth0
- i2C
- MMC/SD
- NAND
- UART
- USB (host)
[snip]
Configure for 1GB and then see how much we can actually talk to?
But then you aren't populating 3 device trees nor making it clear / easy to say which module you're on, and then still need to change the config for which DT you're picking up. These SOMs really don't provide any run-time method to see which one you're on? There's no GPIOs to poke?
Hi Tom,
Hi Tom,
Hi Tom,
Working:
- Eth0
- i2C
- MMC/SD
- NAND
- UART
- USB (host)
[snip]
Yes. If you are interested, you can see their implementation here [1], where get_minimal_timings() returns the configuration for 1GiB; everything is in that file. (I did credit the author.)
[1] https://git.pengutronix.de/cgit/barebox/tree/arch/arm/boards/phytec-som-am33...
Agreed, the device tree solution is inferior to autodetection. The SOMs manual makes no mention of how different variants can be distinguished/detected, and the board specific code in Barebox (written by Phytec) does not contain any other detection code (except for the RAM), like checking GPIOs. Unfortunately there is no publicly available schematic, so I can't be completely sure. So I am going to assume it, there is no other way of detection.
On Tue, May 07, 2019 at 04:43:04PM +0200, Niel Fourie wrote:
Hi Tom,
Hi Tom,
Hi Tom,
>Support for Phytech phyCORE AM335x R2 SOM (PCL060) on the Phytec >phyBOARD-Wega AM335x. > >CPU : AM335X-GP rev 2.1 >Model: Phytec AM335x phyBOARD-WEGA >DRAM: 256 MiB >NAND: 256 MiB >MMC: OMAP SD/MMC: 0 >eth0: ethernet@4a100000 > >Working: > - Eth0 > - i2C > - MMC/SD > - NAND > - UART > - USB (host) > >Device trees were taken from Linux mainline: >commit 37624b58542f ("Linux 5.1-rc7") > >Signed-off-by: Niel Fourie lusus@denx.de
[snip]
Thinking back to my time at TI, that leaves me a little worried, but if the vendor is OK with that approach, I'll leave it be, and yes, we can mirror that approach here. Thanks for the links!
On 07.05.19 16:43, Niel Fourie wrote:
Hi Tom,
Hi Tom,
Hi Tom,
> Support for Phytech phyCORE AM335x R2 SOM (PCL060) on the Phytec > phyBOARD-Wega AM335x. > > CPU : AM335X-GP rev 2.1 > Model: Phytec AM335x phyBOARD-WEGA > DRAM: 256 MiB > NAND: 256 MiB > MMC: OMAP SD/MMC: 0 > eth0: ethernet@4a100000 > > Working: > - Eth0 > - i2C > - MMC/SD > - NAND > - UART > - USB (host) > > Device trees were taken from Linux mainline: > commit 37624b58542f ("Linux 5.1-rc7") > > Signed-off-by: Niel Fourie lusus@denx.de
[snip]
You are right, for our AM335 based SOMs there is no way to detect the variant. The barebox generates for every possible RAM configuration an own MLO. The nice thing is that barebox generates all variants with one build by using its multi image mechanism.
Besides the RAM, the phyCORE can be populated with different AM335x variants, NANDs, RTC/EEPROM/Eth-PHY(yes/no) and maybe other things I don't remember now.
I think it would be a good Idea to maintain a list of article numbers (that fully describes the SOM variant) which are supported by the current u-boot version.
Regards, Wadim
Niel Fourie
Wadim Egorov
