[U-Boot] [PATCH 1/2] powerpc/mpc8xxx: Fix DDR3 timing_cfg_1 and sdram_mode registers
The write recovery time of both registers should match. Since mode register doesn't support cycles of 9,11,13,15, we should use next higher number for both registers.
Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c | 28 ++++++++++++++++++++++++---- 1 files changed, 24 insertions(+), 4 deletions(-)
diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c b/arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c index 41bad35..52bbe76 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c +++ b/arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c @@ -371,6 +371,21 @@ static void set_timing_cfg_1(fsl_ddr_cfg_regs_t *ddr,
refrec_ctrl = picos_to_mclk(common_dimm->tRFC_ps) - 8; wrrec_mclk = picos_to_mclk(common_dimm->tWR_ps); + + switch (wrrec_mclk) { /* DDR_SDRAM_MODE doesn't support 9,11,13,15 */ + case 9: + wrrec_mclk = 10; + break; + case 11: + wrrec_mclk = 12; + break; + case 13: + wrrec_mclk = 14; + break; + case 16: + wrrec_mclk = 16; + break; + } if (popts->OTF_burst_chop_en) wrrec_mclk += 2;
@@ -854,12 +869,17 @@ static void set_ddr_sdram_mode(fsl_ddr_cfg_regs_t *ddr, */ dll_on = 1; wr_mclk = (common_dimm->tWR_ps + mclk_ps - 1) / mclk_ps; - if (wr_mclk >= 12) - wr = 6; + if (wr_mclk >= 15) + wr = 0; /* 16 cycles */ + else if (wr_mclk >= 13) + wr = 7; /* 14 cycles */ + else if (wr_mclk >= 11) + wr = 6; /* 12 cycles */ else if (wr_mclk >= 9) - wr = 5; + wr = 5; /* 10 cycles */ else - wr = wr_mclk - 4; + wr = wr_mclk - 4; /* 5~8 cycles */ + dll_rst = 0; /* dll no reset */ mode = 0; /* normal mode */
This patch revised clk_adjust and wrlvl_start timings for corenet_ds, based on testing on Virtium VL33B5163F-K9S and Kingston KVR1333D3Q8R9S/4G.
Signed-off-by: York Sun yorksun@freescale.com --- board/freescale/corenet_ds/ddr.c | 8 ++++---- 1 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/board/freescale/corenet_ds/ddr.c b/board/freescale/corenet_ds/ddr.c index f8df9d1..07b950f 100644 --- a/board/freescale/corenet_ds/ddr.c +++ b/board/freescale/corenet_ds/ddr.c @@ -170,8 +170,8 @@ const board_specific_parameters_t board_specific_parameters[][30] = { * lo| hi| num| clk| wrlvl | cpo |wrdata|2T * mhz| mhz|ranks|adjst| start | delay| */ - { 0, 850, 4, 1, 5, 0xff, 2, 0}, - {851, 950, 4, 3, 5, 0xff, 2, 0}, + { 0, 850, 4, 4, 6, 0xff, 2, 0}, + {851, 950, 4, 5, 7, 0xff, 2, 0}, {951, 1050, 4, 5, 8, 0xff, 2, 0}, {1051, 1250, 4, 5, 10, 0xff, 2, 0}, {1251, 1350, 4, 5, 11, 0xff, 2, 0}, @@ -188,8 +188,8 @@ const board_specific_parameters_t board_specific_parameters[][30] = { * lo| hi| num| clk| wrlvl | cpo |wrdata|2T * mhz| mhz|ranks|adjst| start | delay| */ - { 0, 850, 4, 1, 5, 0xff, 2, 0}, - {851, 950, 4, 3, 5, 0xff, 2, 0}, + { 0, 850, 4, 4, 6, 0xff, 2, 0}, + {851, 950, 4, 5, 7, 0xff, 2, 0}, {951, 1050, 4, 5, 8, 0xff, 2, 0}, {1051, 1250, 4, 5, 10, 0xff, 2, 0}, {1251, 1350, 4, 5, 11, 0xff, 2, 0},
York Sun wrote:
- switch (wrrec_mclk) { /* DDR_SDRAM_MODE doesn't support 9,11,13,15 */
- case 9:
wrrec_mclk = 10;
break;
- case 11:
wrrec_mclk = 12;
break;
- case 13:
wrrec_mclk = 14;
break;
- case 16:
15?
wrrec_mclk = 16;
break;
How about something simpler:
if (wrrec_mclk & 1) wrrec_mclk++;
On Wed, 2011-03-02 at 13:31 -0600, Timur Tabi wrote:
- case 9:
wrrec_mclk = 10;
break;
- case 11:
wrrec_mclk = 12;
break;
- case 13:
wrrec_mclk = 14;
break;
- case 16:
15?
Nice catch. Thank you. I will submit a fixed version.
wrrec_mclk = 16;
break;
Only 9, 11, 13, 15 need to round up.
York
What are all the possible values for wrrec_mclk?
There is no limitation on register timing_cfg_1[wrrec_mclk]. It can be any value. The limitation comes from JEDEC spec on mode register MR0. The write recovery for autoprecharge is within the values of 5, 6, 7, 8, 10, 12, 14, 16.
York
My point is that we can do something like this:
if (wrrec_mclk > 8 && wrrec_mclk < 16 && wrrec_mclk & 1) wrrec_mclk++;
But we can simplify this if I can know what all possible values are.
Timur Tabi
York Sun
