[U-Boot] [PATCH 1/8] MX28: Fix a typo in mx28_reg_8 macro
The macro mistakenly referred to 32bit struct instead of 8bit one.
Signed-off-by: Otavio Salvador otavio@ossystems.com.br Cc: Fabio Estevam fabio.estevam@freescale.com Cc: Marek Vasut marex@denx.de --- arch/arm/include/asm/arch-mx28/regs-common.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-mx28/regs-common.h b/arch/arm/include/asm/arch-mx28/regs-common.h index 94b512d..d2e1953 100644 --- a/arch/arm/include/asm/arch-mx28/regs-common.h +++ b/arch/arm/include/asm/arch-mx28/regs-common.h @@ -70,7 +70,7 @@ struct mx28_register_32 { #define mx28_reg_8(name) \ union { \ struct { __mx28_reg_8(name) }; \ - struct mx28_register_32 name##_reg; \ + struct mx28_register_8 name##_reg; \ };
#define mx28_reg_32(name) \
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- include/configs/m28evk.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/m28evk.h b/include/configs/m28evk.h index c62f4d0..7472ddc 100644 --- a/include/configs/m28evk.h +++ b/include/configs/m28evk.h @@ -88,7 +88,7 @@ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ #define PHYS_SDRAM_1 0x40000000 /* Base address */ #define PHYS_SDRAM_1_SIZE 0x20000000 /* Max 512 MB RAM */ -#define CONFIG_STACKSIZE 0x00010000 /* 128 KB stack */ +#define CONFIG_STACKSIZE (128 * 1024) /* 128 KB stack */ #define CONFIG_SYS_MALLOC_LEN 0x00400000 /* 4 MB for malloc */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* Initial data */ #define CONFIG_SYS_MEMTEST_START 0x40000000 /* Memtest start adr */
diff --git a/include/configs/m28evk.h b/include/configs/m28evk.h index 7472ddc..ebf7e39 100644 --- a/include/configs/m28evk.h +++ b/include/configs/m28evk.h @@ -114,7 +114,7 @@ * U-Boot general configurations */ #define CONFIG_SYS_LONGHELP -#define CONFIG_SYS_PROMPT "=> " +#define CONFIG_SYS_PROMPT "M28EVK U-Boot => " #define CONFIG_SYS_CBSIZE 1024 /* Console I/O buffer size */ #define CONFIG_SYS_PBSIZE \ (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16)
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- include/configs/mx28evk.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/mx28evk.h b/include/configs/mx28evk.h index 0c18e50..5ccfe70 100644 --- a/include/configs/mx28evk.h +++ b/include/configs/mx28evk.h @@ -54,11 +54,11 @@ #include <config_cmd_default.h> #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_FAT
#define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE #define CONFIG_CMD_DHCP +#define CONFIG_CMD_FAT #define CONFIG_CMD_GPIO #define CONFIG_CMD_MII #define CONFIG_CMD_MMC
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- tools/mxsboot.c | 110 +++++++++++++++++++++++++++---------------------------- 1 file changed, 55 insertions(+), 55 deletions(-)
diff --git a/tools/mxsboot.c b/tools/mxsboot.c index 6c05aa4..9661a48 100644 --- a/tools/mxsboot.c +++ b/tools/mxsboot.c @@ -1,5 +1,5 @@ /* - * Freescale i.MX28 image generator + * Freescale i.MXS image generator * * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com * on behalf of DENX Software Engineering GmbH @@ -60,13 +60,13 @@ uint32_t sd_sector = 2048; */ #define MAX_BOOTSTREAM_SIZE (1 * 1024 * 1024)
-/* i.MX28 NAND controller-specific constants. DO NOT TWEAK! */ +/* i.MXS NAND controller-specific constants. DO NOT TWEAK! */ #define MXS_NAND_DMA_DESCRIPTOR_COUNT 4 #define MXS_NAND_CHUNK_DATA_CHUNK_SIZE 512 #define MXS_NAND_METADATA_SIZE 10 #define MXS_NAND_COMMAND_BUFFER_SIZE 32
-struct mx28_nand_fcb { +struct mxs_nand_fcb { uint32_t checksum; uint32_t fingerprint; uint32_t version; @@ -111,7 +111,7 @@ struct mx28_nand_fcb { uint32_t bb_marker_physical_offset; };
-struct mx28_nand_dbbt { +struct mxs_nand_dbbt { uint32_t checksum; uint32_t fingerprint; uint32_t version; @@ -119,13 +119,13 @@ struct mx28_nand_dbbt { uint32_t number_2k_pages_bb; };
-struct mx28_nand_bbt { +struct mxs_nand_bbt { uint32_t nand; uint32_t number_bb; uint32_t badblock[510]; };
-struct mx28_sd_drive_info { +struct mxs_sd_drive_info { uint32_t chip_num; uint32_t drive_type; uint32_t tag; @@ -133,20 +133,20 @@ struct mx28_sd_drive_info { uint32_t sector_count; };
-struct mx28_sd_config_block { +struct mxs_sd_config_block { uint32_t signature; uint32_t primary_boot_tag; uint32_t secondary_boot_tag; uint32_t num_copies; - struct mx28_sd_drive_info drv_info[1]; + struct mxs_sd_drive_info drv_info[1]; };
-static inline uint32_t mx28_nand_ecc_size_in_bits(uint32_t ecc_strength) +static inline uint32_t mxs_nand_ecc_size_in_bits(uint32_t ecc_strength) { return ecc_strength * 13; }
-static inline uint32_t mx28_nand_get_ecc_strength(uint32_t page_data_size, +static inline uint32_t mxs_nand_get_ecc_strength(uint32_t page_data_size, uint32_t page_oob_size) { if (page_data_size == 2048) @@ -163,7 +163,7 @@ static inline uint32_t mx28_nand_get_ecc_strength(uint32_t page_data_size, return 0; }
-static inline uint32_t mx28_nand_get_mark_offset(uint32_t page_data_size, +static inline uint32_t mxs_nand_get_mark_offset(uint32_t page_data_size, uint32_t ecc_strength) { uint32_t chunk_data_size_in_bits; @@ -174,7 +174,7 @@ static inline uint32_t mx28_nand_get_mark_offset(uint32_t page_data_size, uint32_t block_mark_bit_offset;
chunk_data_size_in_bits = MXS_NAND_CHUNK_DATA_CHUNK_SIZE * 8; - chunk_ecc_size_in_bits = mx28_nand_ecc_size_in_bits(ecc_strength); + chunk_ecc_size_in_bits = mxs_nand_ecc_size_in_bits(ecc_strength);
chunk_total_size_in_bits = chunk_data_size_in_bits + chunk_ecc_size_in_bits; @@ -212,21 +212,21 @@ static inline uint32_t mx28_nand_get_mark_offset(uint32_t page_data_size, return block_mark_bit_offset; }
-static inline uint32_t mx28_nand_mark_byte_offset(void) +static inline uint32_t mxs_nand_mark_byte_offset(void) { uint32_t ecc_strength; - ecc_strength = mx28_nand_get_ecc_strength(nand_writesize, nand_oobsize); - return mx28_nand_get_mark_offset(nand_writesize, ecc_strength) >> 3; + ecc_strength = mxs_nand_get_ecc_strength(nand_writesize, nand_oobsize); + return mxs_nand_get_mark_offset(nand_writesize, ecc_strength) >> 3; }
-static inline uint32_t mx28_nand_mark_bit_offset(void) +static inline uint32_t mxs_nand_mark_bit_offset(void) { uint32_t ecc_strength; - ecc_strength = mx28_nand_get_ecc_strength(nand_writesize, nand_oobsize); - return mx28_nand_get_mark_offset(nand_writesize, ecc_strength) & 0x7; + ecc_strength = mxs_nand_get_ecc_strength(nand_writesize, nand_oobsize); + return mxs_nand_get_mark_offset(nand_writesize, ecc_strength) & 0x7; }
-static uint32_t mx28_nand_block_csum(uint8_t *block, uint32_t size) +static uint32_t mxs_nand_block_csum(uint8_t *block, uint32_t size) { uint32_t csum = 0; int i; @@ -237,9 +237,9 @@ static uint32_t mx28_nand_block_csum(uint8_t *block, uint32_t size) return csum ^ 0xffffffff; }
-static struct mx28_nand_fcb *mx28_nand_get_fcb(uint32_t size) +static struct mxs_nand_fcb *mxs_nand_get_fcb(uint32_t size) { - struct mx28_nand_fcb *fcb; + struct mxs_nand_fcb *fcb; uint32_t bcb_size_bytes; uint32_t stride_size_bytes; uint32_t bootstream_size_pages; @@ -248,7 +248,7 @@ static struct mx28_nand_fcb *mx28_nand_get_fcb(uint32_t size)
fcb = malloc(nand_writesize); if (!fcb) { - printf("MX28 NAND: Unable to allocate FCB\n"); + printf("MXS NAND: Unable to allocate FCB\n"); return NULL; }
@@ -289,15 +289,15 @@ static struct mx28_nand_fcb *mx28_nand_get_fcb(uint32_t size) }
if (fcb->ecc_block_n_ecc_type == 0) { - printf("MX28 NAND: Unsupported NAND geometry\n"); + printf("MXS NAND: Unsupported NAND geometry\n"); goto err; }
fcb->boot_patch = 0; fcb->patch_sectors = 0;
- fcb->badblock_marker_byte = mx28_nand_mark_byte_offset(); - fcb->badblock_marker_start_bit = mx28_nand_mark_bit_offset(); + fcb->badblock_marker_byte = mxs_nand_mark_byte_offset(); + fcb->badblock_marker_start_bit = mxs_nand_mark_bit_offset(); fcb->bb_marker_physical_offset = nand_writesize;
stride_size_bytes = STRIDE_PAGES * nand_writesize; @@ -324,13 +324,13 @@ err: return NULL; }
-static struct mx28_nand_dbbt *mx28_nand_get_dbbt(void) +static struct mxs_nand_dbbt *mxs_nand_get_dbbt(void) { - struct mx28_nand_dbbt *dbbt; + struct mxs_nand_dbbt *dbbt;
dbbt = malloc(nand_writesize); if (!dbbt) { - printf("MX28 NAND: Unable to allocate DBBT\n"); + printf("MXS NAND: Unable to allocate DBBT\n"); return NULL; }
@@ -342,7 +342,7 @@ static struct mx28_nand_dbbt *mx28_nand_get_dbbt(void) return dbbt; }
-static inline uint8_t mx28_nand_parity_13_8(const uint8_t b) +static inline uint8_t mxs_nand_parity_13_8(const uint8_t b) { uint32_t parity = 0, tmp;
@@ -365,7 +365,7 @@ static inline uint8_t mx28_nand_parity_13_8(const uint8_t b) return parity; }
-static uint8_t *mx28_nand_fcb_block(struct mx28_nand_fcb *fcb) +static uint8_t *mxs_nand_fcb_block(struct mxs_nand_fcb *fcb) { uint8_t *block; uint8_t *ecc; @@ -373,36 +373,36 @@ static uint8_t *mx28_nand_fcb_block(struct mx28_nand_fcb *fcb)
block = malloc(nand_writesize + nand_oobsize); if (!block) { - printf("MX28 NAND: Unable to allocate FCB block\n"); + printf("MXS NAND: Unable to allocate FCB block\n"); return NULL; }
memset(block, 0, nand_writesize + nand_oobsize);
/* Update the FCB checksum */ - fcb->checksum = mx28_nand_block_csum(((uint8_t *)fcb) + 4, 508); + fcb->checksum = mxs_nand_block_csum(((uint8_t *)fcb) + 4, 508);
- /* Figure 12-11. in iMX28RM, rev. 1, says FCB is at offset 12 */ - memcpy(block + 12, fcb, sizeof(struct mx28_nand_fcb)); + /* Figure 12-11. in iMXSRM, rev. 1, says FCB is at offset 12 */ + memcpy(block + 12, fcb, sizeof(struct mxs_nand_fcb));
/* ECC is at offset 12 + 512 */ ecc = block + 12 + 512;
/* Compute the ECC parity */ - for (i = 0; i < sizeof(struct mx28_nand_fcb); i++) - ecc[i] = mx28_nand_parity_13_8(block[i + 12]); + for (i = 0; i < sizeof(struct mxs_nand_fcb); i++) + ecc[i] = mxs_nand_parity_13_8(block[i + 12]);
return block; }
-static int mx28_nand_write_fcb(struct mx28_nand_fcb *fcb, char *buf) +static int mxs_nand_write_fcb(struct mxs_nand_fcb *fcb, char *buf) { uint32_t offset; uint8_t *fcbblock; int ret = 0; int i;
- fcbblock = mx28_nand_fcb_block(fcb); + fcbblock = mxs_nand_fcb_block(fcb); if (!fcbblock) return -1;
@@ -415,20 +415,20 @@ static int mx28_nand_write_fcb(struct mx28_nand_fcb *fcb, char *buf) return ret; }
-static int mx28_nand_write_dbbt(struct mx28_nand_dbbt *dbbt, char *buf) +static int mxs_nand_write_dbbt(struct mxs_nand_dbbt *dbbt, char *buf) { uint32_t offset; int i = STRIDE_PAGES * STRIDE_COUNT;
for (; i < 2 * STRIDE_PAGES * STRIDE_COUNT; i += STRIDE_PAGES) { offset = i * nand_writesize; - memcpy(buf + offset, dbbt, sizeof(struct mx28_nand_dbbt)); + memcpy(buf + offset, dbbt, sizeof(struct mxs_nand_dbbt)); }
return 0; }
-static int mx28_nand_write_firmware(struct mx28_nand_fcb *fcb, int infd, +static int mxs_nand_write_firmware(struct mxs_nand_fcb *fcb, int infd, char *buf) { int ret; @@ -454,7 +454,7 @@ void usage(void) { printf( "Usage: mxsboot [ops] <type> <infile> <outfile>\n" - "Augment BootStream file with a proper header for i.MX28 boot\n" + "Augment BootStream file with a proper header for i.MXS boot\n" "\n" " <type> type of image:\n" " "nand" for NAND image\n" @@ -473,10 +473,10 @@ void usage(void) ); }
-static int mx28_create_nand_image(int infd, int outfd) +static int mxs_create_nand_image(int infd, int outfd) { - struct mx28_nand_fcb *fcb; - struct mx28_nand_dbbt *dbbt; + struct mxs_nand_fcb *fcb; + struct mxs_nand_dbbt *dbbt; int ret = -1; char *buf; int size; @@ -492,31 +492,31 @@ static int mx28_create_nand_image(int infd, int outfd)
memset(buf, 0, size);
- fcb = mx28_nand_get_fcb(MAX_BOOTSTREAM_SIZE); + fcb = mxs_nand_get_fcb(MAX_BOOTSTREAM_SIZE); if (!fcb) { printf("Unable to compile FCB\n"); goto err1; }
- dbbt = mx28_nand_get_dbbt(); + dbbt = mxs_nand_get_dbbt(); if (!dbbt) { printf("Unable to compile DBBT\n"); goto err2; }
- ret = mx28_nand_write_fcb(fcb, buf); + ret = mxs_nand_write_fcb(fcb, buf); if (ret) { printf("Unable to write FCB to buffer\n"); goto err3; }
- ret = mx28_nand_write_dbbt(dbbt, buf); + ret = mxs_nand_write_dbbt(dbbt, buf); if (ret) { printf("Unable to write DBBT to buffer\n"); goto err3; }
- ret = mx28_nand_write_firmware(fcb, infd, buf); + ret = mxs_nand_write_firmware(fcb, infd, buf); if (ret) { printf("Unable to write firmware to buffer\n"); goto err3; @@ -540,14 +540,14 @@ err0: return ret; }
-static int mx28_create_sd_image(int infd, int outfd) +static int mxs_create_sd_image(int infd, int outfd) { int ret = -1; uint32_t *buf; int size; off_t fsize; ssize_t wr_size; - struct mx28_sd_config_block *cb; + struct mxs_sd_config_block *cb;
fsize = lseek(infd, 0, SEEK_END); lseek(infd, 0, SEEK_SET); @@ -565,7 +565,7 @@ static int mx28_create_sd_image(int infd, int outfd) goto err1; }
- cb = (struct mx28_sd_config_block *)buf; + cb = (struct mxs_sd_config_block *)buf;
cb->signature = 0x00112233; cb->primary_boot_tag = 0x1; @@ -675,9 +675,9 @@ int main(int argc, char **argv) }
if (!strcmp(argv[offset], "sd")) - ret = mx28_create_sd_image(infd, outfd); + ret = mxs_create_sd_image(infd, outfd); else if (!strcmp(argv[offset], "nand")) - ret = mx28_create_nand_image(infd, outfd); + ret = mxs_create_nand_image(infd, outfd);
close(outfd); err2:
Most code can be shared amount i.MX23 and i.MX28 as both are from i.MXS family; this source directory structure makes easy to share code among them.
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- arch/arm/cpu/arm926ejs/mx28/Makefile | 50 - arch/arm/cpu/arm926ejs/mx28/clock.c | 339 ------- arch/arm/cpu/arm926ejs/mx28/iomux.c | 109 --- arch/arm/cpu/arm926ejs/mx28/mx28.c | 310 ------ arch/arm/cpu/arm926ejs/mx28/mx28_init.h | 45 - arch/arm/cpu/arm926ejs/mx28/spl_boot.c | 135 --- arch/arm/cpu/arm926ejs/mx28/spl_mem_init.c | 242 ----- arch/arm/cpu/arm926ejs/mx28/spl_power_init.c | 1007 ------------------- arch/arm/cpu/arm926ejs/mx28/start.S | 247 ----- arch/arm/cpu/arm926ejs/mx28/timer.c | 156 --- arch/arm/cpu/arm926ejs/mx28/u-boot-spl.lds | 87 -- arch/arm/cpu/arm926ejs/mxs/Makefile | 50 + arch/arm/cpu/arm926ejs/mxs/clock.c | 339 +++++++ arch/arm/cpu/arm926ejs/mxs/iomux.c | 109 +++ arch/arm/cpu/arm926ejs/mxs/mx28.c | 310 ++++++ arch/arm/cpu/arm926ejs/mxs/mx28_init.h | 45 + arch/arm/cpu/arm926ejs/mxs/spl_boot.c | 135 +++ arch/arm/cpu/arm926ejs/mxs/spl_mem_init.c | 242 +++++ arch/arm/cpu/arm926ejs/mxs/spl_power_init.c | 1007 +++++++++++++++++++ arch/arm/cpu/arm926ejs/mxs/start.S | 247 +++++ arch/arm/cpu/arm926ejs/mxs/timer.c | 156 +++ arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds | 87 ++ arch/arm/include/asm/arch-mx28/clock.h | 61 -- arch/arm/include/asm/arch-mx28/dma.h | 147 --- arch/arm/include/asm/arch-mx28/gpio.h | 32 - arch/arm/include/asm/arch-mx28/imx-regs.h | 42 - arch/arm/include/asm/arch-mx28/iomux-mx28.h | 537 ----------- arch/arm/include/asm/arch-mx28/iomux.h | 168 ---- arch/arm/include/asm/arch-mx28/regs-apbh.h | 466 --------- arch/arm/include/asm/arch-mx28/regs-base.h | 88 -- arch/arm/include/asm/arch-mx28/regs-bch.h | 230 ----- arch/arm/include/asm/arch-mx28/regs-clkctrl.h | 294 ------ arch/arm/include/asm/arch-mx28/regs-common.h | 82 -- arch/arm/include/asm/arch-mx28/regs-digctl.h | 155 --- arch/arm/include/asm/arch-mx28/regs-gpmi.h | 222 ----- arch/arm/include/asm/arch-mx28/regs-i2c.h | 207 ---- arch/arm/include/asm/arch-mx28/regs-ocotp.h | 173 ---- arch/arm/include/asm/arch-mx28/regs-pinctrl.h | 1284 ------------------------- arch/arm/include/asm/arch-mx28/regs-power.h | 413 -------- arch/arm/include/asm/arch-mx28/regs-rtc.h | 147 --- arch/arm/include/asm/arch-mx28/regs-ssp.h | 349 ------- arch/arm/include/asm/arch-mx28/regs-timrot.h | 171 ---- arch/arm/include/asm/arch-mx28/regs-usb.h | 178 ---- arch/arm/include/asm/arch-mx28/regs-usbphy.h | 151 --- arch/arm/include/asm/arch-mx28/sys_proto.h | 74 -- arch/arm/include/asm/arch-mxs/clock.h | 61 ++ arch/arm/include/asm/arch-mxs/dma.h | 147 +++ arch/arm/include/asm/arch-mxs/gpio.h | 32 + arch/arm/include/asm/arch-mxs/imx-regs.h | 42 + arch/arm/include/asm/arch-mxs/iomux-mx28.h | 537 +++++++++++ arch/arm/include/asm/arch-mxs/iomux.h | 168 ++++ arch/arm/include/asm/arch-mxs/regs-apbh.h | 466 +++++++++ arch/arm/include/asm/arch-mxs/regs-base.h | 88 ++ arch/arm/include/asm/arch-mxs/regs-bch.h | 230 +++++ arch/arm/include/asm/arch-mxs/regs-clkctrl.h | 294 ++++++ arch/arm/include/asm/arch-mxs/regs-common.h | 82 ++ arch/arm/include/asm/arch-mxs/regs-digctl.h | 155 +++ arch/arm/include/asm/arch-mxs/regs-gpmi.h | 222 +++++ arch/arm/include/asm/arch-mxs/regs-i2c.h | 207 ++++ arch/arm/include/asm/arch-mxs/regs-ocotp.h | 173 ++++ arch/arm/include/asm/arch-mxs/regs-pinctrl.h | 1284 +++++++++++++++++++++++++ arch/arm/include/asm/arch-mxs/regs-power.h | 413 ++++++++ arch/arm/include/asm/arch-mxs/regs-rtc.h | 147 +++ arch/arm/include/asm/arch-mxs/regs-ssp.h | 349 +++++++ arch/arm/include/asm/arch-mxs/regs-timrot.h | 171 ++++ arch/arm/include/asm/arch-mxs/regs-usb.h | 178 ++++ arch/arm/include/asm/arch-mxs/regs-usbphy.h | 151 +++ arch/arm/include/asm/arch-mxs/sys_proto.h | 74 ++ boards.cfg | 4 +- doc/README.m28 | 2 +- doc/README.mx28evk | 6 +- include/configs/m28evk.h | 4 +- include/configs/mx28evk.h | 4 +- 73 files changed, 8408 insertions(+), 8408 deletions(-) delete mode 100644 arch/arm/cpu/arm926ejs/mx28/Makefile delete mode 100644 arch/arm/cpu/arm926ejs/mx28/clock.c delete mode 100644 arch/arm/cpu/arm926ejs/mx28/iomux.c delete mode 100644 arch/arm/cpu/arm926ejs/mx28/mx28.c delete mode 100644 arch/arm/cpu/arm926ejs/mx28/mx28_init.h delete mode 100644 arch/arm/cpu/arm926ejs/mx28/spl_boot.c delete mode 100644 arch/arm/cpu/arm926ejs/mx28/spl_mem_init.c delete mode 100644 arch/arm/cpu/arm926ejs/mx28/spl_power_init.c delete mode 100644 arch/arm/cpu/arm926ejs/mx28/start.S delete mode 100644 arch/arm/cpu/arm926ejs/mx28/timer.c delete mode 100644 arch/arm/cpu/arm926ejs/mx28/u-boot-spl.lds create mode 100644 arch/arm/cpu/arm926ejs/mxs/Makefile create mode 100644 arch/arm/cpu/arm926ejs/mxs/clock.c create mode 100644 arch/arm/cpu/arm926ejs/mxs/iomux.c create mode 100644 arch/arm/cpu/arm926ejs/mxs/mx28.c create mode 100644 arch/arm/cpu/arm926ejs/mxs/mx28_init.h create mode 100644 arch/arm/cpu/arm926ejs/mxs/spl_boot.c create mode 100644 arch/arm/cpu/arm926ejs/mxs/spl_mem_init.c create mode 100644 arch/arm/cpu/arm926ejs/mxs/spl_power_init.c create mode 100644 arch/arm/cpu/arm926ejs/mxs/start.S create mode 100644 arch/arm/cpu/arm926ejs/mxs/timer.c create mode 100644 arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds delete mode 100644 arch/arm/include/asm/arch-mx28/clock.h delete mode 100644 arch/arm/include/asm/arch-mx28/dma.h delete mode 100644 arch/arm/include/asm/arch-mx28/gpio.h delete mode 100644 arch/arm/include/asm/arch-mx28/imx-regs.h delete mode 100644 arch/arm/include/asm/arch-mx28/iomux-mx28.h delete mode 100644 arch/arm/include/asm/arch-mx28/iomux.h delete mode 100644 arch/arm/include/asm/arch-mx28/regs-apbh.h delete mode 100644 arch/arm/include/asm/arch-mx28/regs-base.h delete mode 100644 arch/arm/include/asm/arch-mx28/regs-bch.h delete mode 100644 arch/arm/include/asm/arch-mx28/regs-clkctrl.h delete mode 100644 arch/arm/include/asm/arch-mx28/regs-common.h delete mode 100644 arch/arm/include/asm/arch-mx28/regs-digctl.h delete mode 100644 arch/arm/include/asm/arch-mx28/regs-gpmi.h delete mode 100644 arch/arm/include/asm/arch-mx28/regs-i2c.h delete mode 100644 arch/arm/include/asm/arch-mx28/regs-ocotp.h delete mode 100644 arch/arm/include/asm/arch-mx28/regs-pinctrl.h delete mode 100644 arch/arm/include/asm/arch-mx28/regs-power.h delete mode 100644 arch/arm/include/asm/arch-mx28/regs-rtc.h delete mode 100644 arch/arm/include/asm/arch-mx28/regs-ssp.h delete mode 100644 arch/arm/include/asm/arch-mx28/regs-timrot.h delete mode 100644 arch/arm/include/asm/arch-mx28/regs-usb.h delete mode 100644 arch/arm/include/asm/arch-mx28/regs-usbphy.h delete mode 100644 arch/arm/include/asm/arch-mx28/sys_proto.h create mode 100644 arch/arm/include/asm/arch-mxs/clock.h create mode 100644 arch/arm/include/asm/arch-mxs/dma.h create mode 100644 arch/arm/include/asm/arch-mxs/gpio.h create mode 100644 arch/arm/include/asm/arch-mxs/imx-regs.h create mode 100644 arch/arm/include/asm/arch-mxs/iomux-mx28.h create mode 100644 arch/arm/include/asm/arch-mxs/iomux.h create mode 100644 arch/arm/include/asm/arch-mxs/regs-apbh.h create mode 100644 arch/arm/include/asm/arch-mxs/regs-base.h create mode 100644 arch/arm/include/asm/arch-mxs/regs-bch.h create mode 100644 arch/arm/include/asm/arch-mxs/regs-clkctrl.h create mode 100644 arch/arm/include/asm/arch-mxs/regs-common.h create mode 100644 arch/arm/include/asm/arch-mxs/regs-digctl.h create mode 100644 arch/arm/include/asm/arch-mxs/regs-gpmi.h create mode 100644 arch/arm/include/asm/arch-mxs/regs-i2c.h create mode 100644 arch/arm/include/asm/arch-mxs/regs-ocotp.h create mode 100644 arch/arm/include/asm/arch-mxs/regs-pinctrl.h create mode 100644 arch/arm/include/asm/arch-mxs/regs-power.h create mode 100644 arch/arm/include/asm/arch-mxs/regs-rtc.h create mode 100644 arch/arm/include/asm/arch-mxs/regs-ssp.h create mode 100644 arch/arm/include/asm/arch-mxs/regs-timrot.h create mode 100644 arch/arm/include/asm/arch-mxs/regs-usb.h create mode 100644 arch/arm/include/asm/arch-mxs/regs-usbphy.h create mode 100644 arch/arm/include/asm/arch-mxs/sys_proto.h
diff --git a/arch/arm/cpu/arm926ejs/mx28/Makefile b/arch/arm/cpu/arm926ejs/mx28/Makefile deleted file mode 100644 index 674a3af..0000000 --- a/arch/arm/cpu/arm926ejs/mx28/Makefile +++ /dev/null @@ -1,50 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# - -include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS = clock.o mx28.o iomux.o timer.o - -ifdef CONFIG_SPL_BUILD -COBJS += spl_boot.o spl_lradc_init.o spl_mem_init.o spl_power_init.o -endif - -SRCS := $(START:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/arm/cpu/arm926ejs/mx28/clock.c b/arch/arm/cpu/arm926ejs/mx28/clock.c deleted file mode 100644 index 0439f9c..0000000 --- a/arch/arm/cpu/arm926ejs/mx28/clock.c +++ /dev/null @@ -1,339 +0,0 @@ -/* - * Freescale i.MX28 clock setup code - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * on behalf of DENX Software Engineering GmbH - * - * Based on code from LTIB: - * Copyright (C) 2010 Freescale Semiconductor, Inc. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/errno.h> -#include <asm/io.h> -#include <asm/arch/clock.h> -#include <asm/arch/imx-regs.h> - -/* The PLL frequency is always 480MHz, see section 10.2 in iMX28 datasheet. */ -#define PLL_FREQ_KHZ 480000 -#define PLL_FREQ_COEF 18 -/* The XTAL frequency is always 24MHz, see section 10.2 in iMX28 datasheet. */ -#define XTAL_FREQ_KHZ 24000 - -#define PLL_FREQ_MHZ (PLL_FREQ_KHZ / 1000) -#define XTAL_FREQ_MHZ (XTAL_FREQ_KHZ / 1000) - -static uint32_t mx28_get_pclk(void) -{ - struct mx28_clkctrl_regs *clkctrl_regs = - (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; - - uint32_t clkctrl, clkseq, div; - uint8_t clkfrac, frac; - - clkctrl = readl(&clkctrl_regs->hw_clkctrl_cpu); - - /* No support of fractional divider calculation */ - if (clkctrl & - (CLKCTRL_CPU_DIV_XTAL_FRAC_EN | CLKCTRL_CPU_DIV_CPU_FRAC_EN)) { - return 0; - } - - clkseq = readl(&clkctrl_regs->hw_clkctrl_clkseq); - - /* XTAL Path */ - if (clkseq & CLKCTRL_CLKSEQ_BYPASS_CPU) { - div = (clkctrl & CLKCTRL_CPU_DIV_XTAL_MASK) >> - CLKCTRL_CPU_DIV_XTAL_OFFSET; - return XTAL_FREQ_MHZ / div; - } - - /* REF Path */ - clkfrac = readb(&clkctrl_regs->hw_clkctrl_frac0[CLKCTRL_FRAC0_CPU]); - frac = clkfrac & CLKCTRL_FRAC_FRAC_MASK; - div = clkctrl & CLKCTRL_CPU_DIV_CPU_MASK; - return (PLL_FREQ_MHZ * PLL_FREQ_COEF / frac) / div; -} - -static uint32_t mx28_get_hclk(void) -{ - struct mx28_clkctrl_regs *clkctrl_regs = - (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; - - uint32_t div; - uint32_t clkctrl; - - clkctrl = readl(&clkctrl_regs->hw_clkctrl_hbus); - - /* No support of fractional divider calculation */ - if (clkctrl & CLKCTRL_HBUS_DIV_FRAC_EN) - return 0; - - div = clkctrl & CLKCTRL_HBUS_DIV_MASK; - return mx28_get_pclk() / div; -} - -static uint32_t mx28_get_emiclk(void) -{ - struct mx28_clkctrl_regs *clkctrl_regs = - (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; - - uint32_t clkctrl, clkseq, div; - uint8_t clkfrac, frac; - - clkseq = readl(&clkctrl_regs->hw_clkctrl_clkseq); - clkctrl = readl(&clkctrl_regs->hw_clkctrl_emi); - - /* XTAL Path */ - if (clkseq & CLKCTRL_CLKSEQ_BYPASS_EMI) { - div = (clkctrl & CLKCTRL_EMI_DIV_XTAL_MASK) >> - CLKCTRL_EMI_DIV_XTAL_OFFSET; - return XTAL_FREQ_MHZ / div; - } - - /* REF Path */ - clkfrac = readb(&clkctrl_regs->hw_clkctrl_frac0[CLKCTRL_FRAC0_EMI]); - frac = clkfrac & CLKCTRL_FRAC_FRAC_MASK; - div = clkctrl & CLKCTRL_EMI_DIV_EMI_MASK; - return (PLL_FREQ_MHZ * PLL_FREQ_COEF / frac) / div; -} - -static uint32_t mx28_get_gpmiclk(void) -{ - struct mx28_clkctrl_regs *clkctrl_regs = - (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; - - uint32_t clkctrl, clkseq, div; - uint8_t clkfrac, frac; - - clkseq = readl(&clkctrl_regs->hw_clkctrl_clkseq); - clkctrl = readl(&clkctrl_regs->hw_clkctrl_gpmi); - - /* XTAL Path */ - if (clkseq & CLKCTRL_CLKSEQ_BYPASS_GPMI) { - div = clkctrl & CLKCTRL_GPMI_DIV_MASK; - return XTAL_FREQ_MHZ / div; - } - - /* REF Path */ - clkfrac = readb(&clkctrl_regs->hw_clkctrl_frac1[CLKCTRL_FRAC1_GPMI]); - frac = clkfrac & CLKCTRL_FRAC_FRAC_MASK; - div = clkctrl & CLKCTRL_GPMI_DIV_MASK; - return (PLL_FREQ_MHZ * PLL_FREQ_COEF / frac) / div; -} - -/* - * Set IO clock frequency, in kHz - */ -void mx28_set_ioclk(enum mxs_ioclock io, uint32_t freq) -{ - struct mx28_clkctrl_regs *clkctrl_regs = - (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; - uint32_t div; - int io_reg; - - if (freq == 0) - return; - - if ((io < MXC_IOCLK0) || (io > MXC_IOCLK1)) - return; - - div = (PLL_FREQ_KHZ * PLL_FREQ_COEF) / freq; - - if (div < 18) - div = 18; - - if (div > 35) - div = 35; - - io_reg = CLKCTRL_FRAC0_IO0 - io; /* Register order is reversed */ - writeb(CLKCTRL_FRAC_CLKGATE, - &clkctrl_regs->hw_clkctrl_frac0_set[io_reg]); - writeb(CLKCTRL_FRAC_CLKGATE | (div & CLKCTRL_FRAC_FRAC_MASK), - &clkctrl_regs->hw_clkctrl_frac0[io_reg]); - writeb(CLKCTRL_FRAC_CLKGATE, - &clkctrl_regs->hw_clkctrl_frac0_clr[io_reg]); -} - -/* - * Get IO clock, returns IO clock in kHz - */ -static uint32_t mx28_get_ioclk(enum mxs_ioclock io) -{ - struct mx28_clkctrl_regs *clkctrl_regs = - (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; - uint8_t ret; - int io_reg; - - if ((io < MXC_IOCLK0) || (io > MXC_IOCLK1)) - return 0; - - io_reg = CLKCTRL_FRAC0_IO0 - io; /* Register order is reversed */ - - ret = readb(&clkctrl_regs->hw_clkctrl_frac0[io_reg]) & - CLKCTRL_FRAC_FRAC_MASK; - - return (PLL_FREQ_KHZ * PLL_FREQ_COEF) / ret; -} - -/* - * Configure SSP clock frequency, in kHz - */ -void mx28_set_sspclk(enum mxs_sspclock ssp, uint32_t freq, int xtal) -{ - struct mx28_clkctrl_regs *clkctrl_regs = - (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; - uint32_t clk, clkreg; - - if (ssp > MXC_SSPCLK3) - return; - - clkreg = (uint32_t)(&clkctrl_regs->hw_clkctrl_ssp0) + - (ssp * sizeof(struct mx28_register_32)); - - clrbits_le32(clkreg, CLKCTRL_SSP_CLKGATE); - while (readl(clkreg) & CLKCTRL_SSP_CLKGATE) - ; - - if (xtal) - clk = XTAL_FREQ_KHZ; - else - clk = mx28_get_ioclk(ssp >> 1); - - if (freq > clk) - return; - - /* Calculate the divider and cap it if necessary */ - clk /= freq; - if (clk > CLKCTRL_SSP_DIV_MASK) - clk = CLKCTRL_SSP_DIV_MASK; - - clrsetbits_le32(clkreg, CLKCTRL_SSP_DIV_MASK, clk); - while (readl(clkreg) & CLKCTRL_SSP_BUSY) - ; - - if (xtal) - writel(CLKCTRL_CLKSEQ_BYPASS_SSP0 << ssp, - &clkctrl_regs->hw_clkctrl_clkseq_set); - else - writel(CLKCTRL_CLKSEQ_BYPASS_SSP0 << ssp, - &clkctrl_regs->hw_clkctrl_clkseq_clr); -} - -/* - * Return SSP frequency, in kHz - */ -static uint32_t mx28_get_sspclk(enum mxs_sspclock ssp) -{ - struct mx28_clkctrl_regs *clkctrl_regs = - (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; - uint32_t clkreg; - uint32_t clk, tmp; - - if (ssp > MXC_SSPCLK3) - return 0; - - tmp = readl(&clkctrl_regs->hw_clkctrl_clkseq); - if (tmp & (CLKCTRL_CLKSEQ_BYPASS_SSP0 << ssp)) - return XTAL_FREQ_KHZ; - - clkreg = (uint32_t)(&clkctrl_regs->hw_clkctrl_ssp0) + - (ssp * sizeof(struct mx28_register_32)); - - tmp = readl(clkreg) & CLKCTRL_SSP_DIV_MASK; - - if (tmp == 0) - return 0; - - clk = mx28_get_ioclk(ssp >> 1); - - return clk / tmp; -} - -/* - * Set SSP/MMC bus frequency, in kHz) - */ -void mx28_set_ssp_busclock(unsigned int bus, uint32_t freq) -{ - struct mx28_ssp_regs *ssp_regs; - const uint32_t sspclk = mx28_get_sspclk(bus); - uint32_t reg; - uint32_t divide, rate, tgtclk; - - ssp_regs = (struct mx28_ssp_regs *)(MXS_SSP0_BASE + (bus * 0x2000)); - - /* - * SSP bit rate = SSPCLK / (CLOCK_DIVIDE * (1 + CLOCK_RATE)), - * CLOCK_DIVIDE has to be an even value from 2 to 254, and - * CLOCK_RATE could be any integer from 0 to 255. - */ - for (divide = 2; divide < 254; divide += 2) { - rate = sspclk / freq / divide; - if (rate <= 256) - break; - } - - tgtclk = sspclk / divide / rate; - while (tgtclk > freq) { - rate++; - tgtclk = sspclk / divide / rate; - } - if (rate > 256) - rate = 256; - - /* Always set timeout the maximum */ - reg = SSP_TIMING_TIMEOUT_MASK | - (divide << SSP_TIMING_CLOCK_DIVIDE_OFFSET) | - ((rate - 1) << SSP_TIMING_CLOCK_RATE_OFFSET); - writel(reg, &ssp_regs->hw_ssp_timing); - - debug("SPI%d: Set freq rate to %d KHz (requested %d KHz)\n", - bus, tgtclk, freq); -} - -uint32_t mxc_get_clock(enum mxc_clock clk) -{ - switch (clk) { - case MXC_ARM_CLK: - return mx28_get_pclk() * 1000000; - case MXC_GPMI_CLK: - return mx28_get_gpmiclk() * 1000000; - case MXC_AHB_CLK: - case MXC_IPG_CLK: - return mx28_get_hclk() * 1000000; - case MXC_EMI_CLK: - return mx28_get_emiclk(); - case MXC_IO0_CLK: - return mx28_get_ioclk(MXC_IOCLK0); - case MXC_IO1_CLK: - return mx28_get_ioclk(MXC_IOCLK1); - case MXC_SSP0_CLK: - return mx28_get_sspclk(MXC_SSPCLK0); - case MXC_SSP1_CLK: - return mx28_get_sspclk(MXC_SSPCLK1); - case MXC_SSP2_CLK: - return mx28_get_sspclk(MXC_SSPCLK2); - case MXC_SSP3_CLK: - return mx28_get_sspclk(MXC_SSPCLK3); - } - - return 0; -} diff --git a/arch/arm/cpu/arm926ejs/mx28/iomux.c b/arch/arm/cpu/arm926ejs/mx28/iomux.c deleted file mode 100644 index 12916b6..0000000 --- a/arch/arm/cpu/arm926ejs/mx28/iomux.c +++ /dev/null @@ -1,109 +0,0 @@ -/* - * Copyright 2004-2006,2010 Freescale Semiconductor, Inc. All Rights Reserved. - * Copyright (C) 2008 by Sascha Hauer kernel@pengutronix.de - * Copyright (C) 2009 by Jan Weitzel Phytec Messtechnik GmbH, - * armlinux@phytec.de - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License - * as published by the Free Software Foundation; either version 2 - * of the License, or (at your option) any later version. - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, - * MA 02110-1301, USA. - */ - -#include <common.h> -#include <asm/errno.h> -#include <asm/io.h> -#include <asm/arch/clock.h> -#include <asm/arch/iomux.h> -#include <asm/arch/imx-regs.h> - -#if defined(CONFIG_MX23) -#define DRIVE_OFFSET 0x200 -#define PULL_OFFSET 0x400 -#elif defined(CONFIG_MX28) -#define DRIVE_OFFSET 0x300 -#define PULL_OFFSET 0x600 -#else -#error "Please select CONFIG_MX23 or CONFIG_MX28" -#endif - -/* - * configures a single pad in the iomuxer - */ -int mxs_iomux_setup_pad(iomux_cfg_t pad) -{ - u32 reg, ofs, bp, bm; - void *iomux_base = (void *)MXS_PINCTRL_BASE; - struct mx28_register_32 *mxs_reg; - - /* muxsel */ - ofs = 0x100; - ofs += PAD_BANK(pad) * 0x20 + PAD_PIN(pad) / 16 * 0x10; - bp = PAD_PIN(pad) % 16 * 2; - bm = 0x3 << bp; - reg = readl(iomux_base + ofs); - reg &= ~bm; - reg |= PAD_MUXSEL(pad) << bp; - writel(reg, iomux_base + ofs); - - /* drive */ - ofs = DRIVE_OFFSET; - ofs += PAD_BANK(pad) * 0x40 + PAD_PIN(pad) / 8 * 0x10; - /* mA */ - if (PAD_MA_VALID(pad)) { - bp = PAD_PIN(pad) % 8 * 4; - bm = 0x3 << bp; - reg = readl(iomux_base + ofs); - reg &= ~bm; - reg |= PAD_MA(pad) << bp; - writel(reg, iomux_base + ofs); - } - /* vol */ - if (PAD_VOL_VALID(pad)) { - bp = PAD_PIN(pad) % 8 * 4 + 2; - mxs_reg = (struct mx28_register_32 *)(iomux_base + ofs); - if (PAD_VOL(pad)) - writel(1 << bp, &mxs_reg->reg_set); - else - writel(1 << bp, &mxs_reg->reg_clr); - } - - /* pull */ - if (PAD_PULL_VALID(pad)) { - ofs = PULL_OFFSET; - ofs += PAD_BANK(pad) * 0x10; - bp = PAD_PIN(pad); - mxs_reg = (struct mx28_register_32 *)(iomux_base + ofs); - if (PAD_PULL(pad)) - writel(1 << bp, &mxs_reg->reg_set); - else - writel(1 << bp, &mxs_reg->reg_clr); - } - - return 0; -} - -int mxs_iomux_setup_multiple_pads(const iomux_cfg_t *pad_list, unsigned count) -{ - const iomux_cfg_t *p = pad_list; - int i; - int ret; - - for (i = 0; i < count; i++) { - ret = mxs_iomux_setup_pad(*p); - if (ret) - return ret; - p++; - } - - return 0; -} diff --git a/arch/arm/cpu/arm926ejs/mx28/mx28.c b/arch/arm/cpu/arm926ejs/mx28/mx28.c deleted file mode 100644 index a82ff25..0000000 --- a/arch/arm/cpu/arm926ejs/mx28/mx28.c +++ /dev/null @@ -1,310 +0,0 @@ -/* - * Freescale i.MX28 common code - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * on behalf of DENX Software Engineering GmbH - * - * Based on code from LTIB: - * Copyright (C) 2010 Freescale Semiconductor, Inc. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/errno.h> -#include <asm/io.h> -#include <asm/arch/clock.h> -#include <asm/arch/dma.h> -#include <asm/arch/gpio.h> -#include <asm/arch/iomux.h> -#include <asm/arch/imx-regs.h> -#include <asm/arch/sys_proto.h> - -DECLARE_GLOBAL_DATA_PTR; - -/* 1 second delay should be plenty of time for block reset. */ -#define RESET_MAX_TIMEOUT 1000000 - -#define MX28_BLOCK_SFTRST (1 << 31) -#define MX28_BLOCK_CLKGATE (1 << 30) - -/* Lowlevel init isn't used on i.MX28, so just have a dummy here */ -inline void lowlevel_init(void) {} - -void reset_cpu(ulong ignored) __attribute__((noreturn)); - -void reset_cpu(ulong ignored) -{ - struct mx28_rtc_regs *rtc_regs = - (struct mx28_rtc_regs *)MXS_RTC_BASE; - struct mx28_lcdif_regs *lcdif_regs = - (struct mx28_lcdif_regs *)MXS_LCDIF_BASE; - - /* - * Shut down the LCD controller as it interferes with BootROM boot mode - * pads sampling. - */ - writel(LCDIF_CTRL_RUN, &lcdif_regs->hw_lcdif_ctrl_clr); - - /* Wait 1 uS before doing the actual watchdog reset */ - writel(1, &rtc_regs->hw_rtc_watchdog); - writel(RTC_CTRL_WATCHDOGEN, &rtc_regs->hw_rtc_ctrl_set); - - /* Endless loop, reset will exit from here */ - for (;;) - ; -} - -void enable_caches(void) -{ -#ifndef CONFIG_SYS_ICACHE_OFF - icache_enable(); -#endif -#ifndef CONFIG_SYS_DCACHE_OFF - dcache_enable(); -#endif -} - -int mx28_wait_mask_set(struct mx28_register_32 *reg, uint32_t mask, int timeout) -{ - while (--timeout) { - if ((readl(®->reg) & mask) == mask) - break; - udelay(1); - } - - return !timeout; -} - -int mx28_wait_mask_clr(struct mx28_register_32 *reg, uint32_t mask, int timeout) -{ - while (--timeout) { - if ((readl(®->reg) & mask) == 0) - break; - udelay(1); - } - - return !timeout; -} - -int mx28_reset_block(struct mx28_register_32 *reg) -{ - /* Clear SFTRST */ - writel(MX28_BLOCK_SFTRST, ®->reg_clr); - - if (mx28_wait_mask_clr(reg, MX28_BLOCK_SFTRST, RESET_MAX_TIMEOUT)) - return 1; - - /* Clear CLKGATE */ - writel(MX28_BLOCK_CLKGATE, ®->reg_clr); - - /* Set SFTRST */ - writel(MX28_BLOCK_SFTRST, ®->reg_set); - - /* Wait for CLKGATE being set */ - if (mx28_wait_mask_set(reg, MX28_BLOCK_CLKGATE, RESET_MAX_TIMEOUT)) - return 1; - - /* Clear SFTRST */ - writel(MX28_BLOCK_SFTRST, ®->reg_clr); - - if (mx28_wait_mask_clr(reg, MX28_BLOCK_SFTRST, RESET_MAX_TIMEOUT)) - return 1; - - /* Clear CLKGATE */ - writel(MX28_BLOCK_CLKGATE, ®->reg_clr); - - if (mx28_wait_mask_clr(reg, MX28_BLOCK_CLKGATE, RESET_MAX_TIMEOUT)) - return 1; - - return 0; -} - -void mx28_fixup_vt(uint32_t start_addr) -{ - uint32_t *vt = (uint32_t *)0x20; - int i; - - for (i = 0; i < 8; i++) - vt[i] = start_addr + (4 * i); -} - -#ifdef CONFIG_ARCH_MISC_INIT -int arch_misc_init(void) -{ - mx28_fixup_vt(gd->relocaddr); - return 0; -} -#endif - -#ifdef CONFIG_ARCH_CPU_INIT -int arch_cpu_init(void) -{ - struct mx28_clkctrl_regs *clkctrl_regs = - (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; - extern uint32_t _start; - - mx28_fixup_vt((uint32_t)&_start); - - /* - * Enable NAND clock - */ - /* Clear bypass bit */ - writel(CLKCTRL_CLKSEQ_BYPASS_GPMI, - &clkctrl_regs->hw_clkctrl_clkseq_set); - - /* Set GPMI clock to ref_gpmi / 12 */ - clrsetbits_le32(&clkctrl_regs->hw_clkctrl_gpmi, - CLKCTRL_GPMI_CLKGATE | CLKCTRL_GPMI_DIV_MASK, 1); - - udelay(1000); - - /* - * Configure GPIO unit - */ - mxs_gpio_init(); - -#ifdef CONFIG_APBH_DMA - /* Start APBH DMA */ - mxs_dma_init(); -#endif - - return 0; -} -#endif - -#if defined(CONFIG_DISPLAY_CPUINFO) -int print_cpuinfo(void) -{ - struct mx28_spl_data *data = (struct mx28_spl_data *) - ((CONFIG_SYS_TEXT_BASE - sizeof(struct mx28_spl_data)) & ~0xf); - - printf("Freescale i.MX28 family at %d MHz\n", - mxc_get_clock(MXC_ARM_CLK) / 1000000); - printf("BOOT: %s\n", mx28_boot_modes[data->boot_mode_idx].mode); - return 0; -} -#endif - -int do_mx28_showclocks(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) -{ - printf("CPU: %3d MHz\n", mxc_get_clock(MXC_ARM_CLK) / 1000000); - printf("BUS: %3d MHz\n", mxc_get_clock(MXC_AHB_CLK) / 1000000); - printf("EMI: %3d MHz\n", mxc_get_clock(MXC_EMI_CLK)); - printf("GPMI: %3d MHz\n", mxc_get_clock(MXC_GPMI_CLK) / 1000000); - return 0; -} - -/* - * Initializes on-chip ethernet controllers. - */ -#ifdef CONFIG_CMD_NET -int cpu_eth_init(bd_t *bis) -{ - struct mx28_clkctrl_regs *clkctrl_regs = - (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; - - /* Turn on ENET clocks */ - clrbits_le32(&clkctrl_regs->hw_clkctrl_enet, - CLKCTRL_ENET_SLEEP | CLKCTRL_ENET_DISABLE); - - /* Set up ENET PLL for 50 MHz */ - /* Power on ENET PLL */ - writel(CLKCTRL_PLL2CTRL0_POWER, - &clkctrl_regs->hw_clkctrl_pll2ctrl0_set); - - udelay(10); - - /* Gate on ENET PLL */ - writel(CLKCTRL_PLL2CTRL0_CLKGATE, - &clkctrl_regs->hw_clkctrl_pll2ctrl0_clr); - - /* Enable pad output */ - setbits_le32(&clkctrl_regs->hw_clkctrl_enet, CLKCTRL_ENET_CLK_OUT_EN); - - return 0; -} -#endif - -static void __mx28_adjust_mac(int dev_id, unsigned char *mac) -{ - mac[0] = 0x00; - mac[1] = 0x04; /* Use FSL vendor MAC address by default */ - - if (dev_id == 1) /* Let MAC1 be MAC0 + 1 by default */ - mac[5] += 1; -} - -void mx28_adjust_mac(int dev_id, unsigned char *mac) - __attribute__((weak, alias("__mx28_adjust_mac"))); - -#ifdef CONFIG_MX28_FEC_MAC_IN_OCOTP - -#define MXS_OCOTP_MAX_TIMEOUT 1000000 -void imx_get_mac_from_fuse(int dev_id, unsigned char *mac) -{ - struct mx28_ocotp_regs *ocotp_regs = - (struct mx28_ocotp_regs *)MXS_OCOTP_BASE; - uint32_t data; - - memset(mac, 0, 6); - - writel(OCOTP_CTRL_RD_BANK_OPEN, &ocotp_regs->hw_ocotp_ctrl_set); - - if (mx28_wait_mask_clr(&ocotp_regs->hw_ocotp_ctrl_reg, OCOTP_CTRL_BUSY, - MXS_OCOTP_MAX_TIMEOUT)) { - printf("MXS FEC: Can't get MAC from OCOTP\n"); - return; - } - - data = readl(&ocotp_regs->hw_ocotp_cust0); - - mac[2] = (data >> 24) & 0xff; - mac[3] = (data >> 16) & 0xff; - mac[4] = (data >> 8) & 0xff; - mac[5] = data & 0xff; - mx28_adjust_mac(dev_id, mac); -} -#else -void imx_get_mac_from_fuse(int dev_id, unsigned char *mac) -{ - memset(mac, 0, 6); -} -#endif - -int mx28_dram_init(void) -{ - struct mx28_spl_data *data = (struct mx28_spl_data *) - ((CONFIG_SYS_TEXT_BASE - sizeof(struct mx28_spl_data)) & ~0xf); - - if (data->mem_dram_size == 0) { - printf("MX28:\n" - "Error, the RAM size passed up from SPL is 0!\n"); - hang(); - } - - gd->ram_size = data->mem_dram_size; - return 0; -} - -U_BOOT_CMD( - clocks, CONFIG_SYS_MAXARGS, 1, do_mx28_showclocks, - "display clocks", - "" -); diff --git a/arch/arm/cpu/arm926ejs/mx28/mx28_init.h b/arch/arm/cpu/arm926ejs/mx28/mx28_init.h deleted file mode 100644 index e3a4493..0000000 --- a/arch/arm/cpu/arm926ejs/mx28/mx28_init.h +++ /dev/null @@ -1,45 +0,0 @@ -/* - * Freescale i.MX28 SPL functions - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * on behalf of DENX Software Engineering GmbH - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef __M28_INIT_H__ -#define __M28_INIT_H__ - -void early_delay(int delay); - -void mx28_power_init(void); - -#ifdef CONFIG_SPL_MX28_PSWITCH_WAIT -void mx28_power_wait_pswitch(void); -#else -static inline void mx28_power_wait_pswitch(void) { } -#endif - -void mx28_mem_init(void); -uint32_t mx28_mem_get_size(void); - -void mx28_lradc_init(void); -void mx28_lradc_enable_batt_measurement(void); - -#endif /* __M28_INIT_H__ */ diff --git a/arch/arm/cpu/arm926ejs/mx28/spl_boot.c b/arch/arm/cpu/arm926ejs/mx28/spl_boot.c deleted file mode 100644 index a6dfca3..0000000 --- a/arch/arm/cpu/arm926ejs/mx28/spl_boot.c +++ /dev/null @@ -1,135 +0,0 @@ -/* - * Freescale i.MX28 Boot setup - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * on behalf of DENX Software Engineering GmbH - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <config.h> -#include <asm/io.h> -#include <asm/arch/iomux-mx28.h> -#include <asm/arch/imx-regs.h> -#include <asm/arch/sys_proto.h> -#include <asm/gpio.h> - -#include "mx28_init.h" - -/* - * This delay function is intended to be used only in early stage of boot, where - * clock are not set up yet. The timer used here is reset on every boot and - * takes a few seconds to roll. The boot doesn't take that long, so to keep the - * code simple, it doesn't take rolling into consideration. - */ -#define HW_DIGCTRL_MICROSECONDS 0x8001c0c0 -void early_delay(int delay) -{ - uint32_t st = readl(HW_DIGCTRL_MICROSECONDS); - st += delay; - while (st > readl(HW_DIGCTRL_MICROSECONDS)) - ; -} - -#define MUX_CONFIG_BOOTMODE_PAD (MXS_PAD_3V3 | MXS_PAD_4MA | MXS_PAD_NOPULL) -const iomux_cfg_t iomux_boot[] = { - MX28_PAD_LCD_D00__GPIO_1_0 | MUX_CONFIG_BOOTMODE_PAD, - MX28_PAD_LCD_D01__GPIO_1_1 | MUX_CONFIG_BOOTMODE_PAD, - MX28_PAD_LCD_D02__GPIO_1_2 | MUX_CONFIG_BOOTMODE_PAD, - MX28_PAD_LCD_D03__GPIO_1_3 | MUX_CONFIG_BOOTMODE_PAD, - MX28_PAD_LCD_D04__GPIO_1_4 | MUX_CONFIG_BOOTMODE_PAD, - MX28_PAD_LCD_D05__GPIO_1_5 | MUX_CONFIG_BOOTMODE_PAD, -}; - -uint8_t mx28_get_bootmode_index(void) -{ - uint8_t bootmode = 0; - int i; - uint8_t masked; - - /* Setup IOMUX of bootmode pads to GPIO */ - mxs_iomux_setup_multiple_pads(iomux_boot, ARRAY_SIZE(iomux_boot)); - - /* Setup bootmode pins as GPIO input */ - gpio_direction_input(MX28_PAD_LCD_D00__GPIO_1_0); - gpio_direction_input(MX28_PAD_LCD_D01__GPIO_1_1); - gpio_direction_input(MX28_PAD_LCD_D02__GPIO_1_2); - gpio_direction_input(MX28_PAD_LCD_D03__GPIO_1_3); - gpio_direction_input(MX28_PAD_LCD_D04__GPIO_1_4); - gpio_direction_input(MX28_PAD_LCD_D05__GPIO_1_5); - - /* Read bootmode pads */ - bootmode |= (gpio_get_value(MX28_PAD_LCD_D00__GPIO_1_0) ? 1 : 0) << 0; - bootmode |= (gpio_get_value(MX28_PAD_LCD_D01__GPIO_1_1) ? 1 : 0) << 1; - bootmode |= (gpio_get_value(MX28_PAD_LCD_D02__GPIO_1_2) ? 1 : 0) << 2; - bootmode |= (gpio_get_value(MX28_PAD_LCD_D03__GPIO_1_3) ? 1 : 0) << 3; - bootmode |= (gpio_get_value(MX28_PAD_LCD_D04__GPIO_1_4) ? 1 : 0) << 4; - bootmode |= (gpio_get_value(MX28_PAD_LCD_D05__GPIO_1_5) ? 1 : 0) << 5; - - for (i = 0; i < ARRAY_SIZE(mx28_boot_modes); i++) { - masked = bootmode & mx28_boot_modes[i].boot_mask; - if (masked == mx28_boot_modes[i].boot_pads) - break; - } - - return i; -} - -void mx28_common_spl_init(const iomux_cfg_t *iomux_setup, - const unsigned int iomux_size) -{ - struct mx28_spl_data *data = (struct mx28_spl_data *) - ((CONFIG_SYS_TEXT_BASE - sizeof(struct mx28_spl_data)) & ~0xf); - uint8_t bootmode = mx28_get_bootmode_index(); - - mxs_iomux_setup_multiple_pads(iomux_setup, iomux_size); - mx28_power_init(); - - mx28_mem_init(); - data->mem_dram_size = mx28_mem_get_size(); - - data->boot_mode_idx = bootmode; - - mx28_power_wait_pswitch(); -} - -/* Support aparatus */ -inline void board_init_f(unsigned long bootflag) -{ - for (;;) - ; -} - -inline void board_init_r(gd_t *id, ulong dest_addr) -{ - for (;;) - ; -} - -#ifndef CONFIG_SPL_SERIAL_SUPPORT -void serial_putc(const char c) {} -void serial_puts(const char *s) {} -#endif -void hang(void) __attribute__ ((noreturn)); -void hang(void) -{ - for (;;) - ; -} diff --git a/arch/arm/cpu/arm926ejs/mx28/spl_mem_init.c b/arch/arm/cpu/arm926ejs/mx28/spl_mem_init.c deleted file mode 100644 index 9fa5d29..0000000 --- a/arch/arm/cpu/arm926ejs/mx28/spl_mem_init.c +++ /dev/null @@ -1,242 +0,0 @@ -/* - * Freescale i.MX28 RAM init - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * on behalf of DENX Software Engineering GmbH - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <config.h> -#include <asm/io.h> -#include <asm/arch/iomux-mx28.h> -#include <asm/arch/imx-regs.h> - -#include "mx28_init.h" - -uint32_t dram_vals[] = { - 0x00000000, 0x00000000, 0x00000000, 0x00000000, - 0x00000000, 0x00000000, 0x00000000, 0x00000000, - 0x00000000, 0x00000000, 0x00000000, 0x00000000, - 0x00000000, 0x00000000, 0x00000000, 0x00000000, - 0x00000000, 0x00000100, 0x00000000, 0x00000000, - 0x00000000, 0x00000000, 0x00000000, 0x00000000, - 0x00000000, 0x00000000, 0x00010101, 0x01010101, - 0x000f0f01, 0x0f02020a, 0x00000000, 0x00010101, - 0x00000100, 0x00000100, 0x00000000, 0x00000002, - 0x01010000, 0x05060302, 0x06005003, 0x0a0000c8, - 0x02009c40, 0x0000030c, 0x0036a609, 0x031a0612, - 0x02030202, 0x00c8001c, 0x00000000, 0x00000000, - 0x00012100, 0xffff0303, 0x00012100, 0xffff0303, - 0x00012100, 0xffff0303, 0x00012100, 0xffff0303, - 0x00000003, 0x00000000, 0x00000000, 0x00000000, - 0x00000000, 0x00000000, 0x00000000, 0x00000000, - 0x00000000, 0x00000000, 0x00000612, 0x01000F02, - 0x06120612, 0x00000200, 0x00020007, 0xf5014b27, - 0xf5014b27, 0xf5014b27, 0xf5014b27, 0x07000300, - 0x07000300, 0x07000300, 0x07000300, 0x00000006, - 0x00000000, 0x00000000, 0x01000000, 0x01020408, - 0x08040201, 0x000f1133, 0x00000000, 0x00001f04, - 0x00001f04, 0x00001f04, 0x00001f04, 0x00001f04, - 0x00001f04, 0x00001f04, 0x00001f04, 0x00000000, - 0x00000000, 0x00000000, 0x00000000, 0x00000000, - 0x00000000, 0x00000000, 0x00000000, 0x00000000, - 0x00000000, 0x00000000, 0x00000000, 0x00000000, - 0x00000000, 0x00000000, 0x00000000, 0x00000000, - 0x00000000, 0x00000000, 0x00000000, 0x00000000, - 0x00000000, 0x00000000, 0x00000000, 0x00000000, - 0x00000000, 0x00000000, 0x00000000, 0x00000000, - 0x00000000, 0x00000000, 0x00000000, 0x00000000, - 0x00000000, 0x00000000, 0x00000000, 0x00000000, - 0x00000000, 0x00000000, 0x00000000, 0x00000000, - 0x00000000, 0x00000000, 0x00000000, 0x00000000, - 0x00000000, 0x00000000, 0x00000000, 0x00000000, - 0x00000000, 0x00000000, 0x00000000, 0x00000000, - 0x00000000, 0x00000000, 0x00000000, 0x00000000, - 0x00000000, 0x00000000, 0x00000000, 0x00000000, - 0x00000000, 0x00000000, 0x00000000, 0x00000000, - 0x00000000, 0x00000000, 0x00010000, 0x00020304, - 0x00000004, 0x00000000, 0x00000000, 0x00000000, - 0x00000000, 0x00000000, 0x00000000, 0x01010000, - 0x01000000, 0x03030000, 0x00010303, 0x01020202, - 0x00000000, 0x02040303, 0x21002103, 0x00061200, - 0x06120612, 0x04320432, 0x04320432, 0x00040004, - 0x00040004, 0x00000000, 0x00000000, 0x00000000, - 0x00000000, 0x00010001 -}; - -void init_m28_200mhz_ddr2(void) -{ - int i; - - for (i = 0; i < ARRAY_SIZE(dram_vals); i++) - writel(dram_vals[i], MXS_DRAM_BASE + (4 * i)); -} - -void mx28_mem_init_clock(void) -{ - struct mx28_clkctrl_regs *clkctrl_regs = - (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; - - /* Gate EMI clock */ - writeb(CLKCTRL_FRAC_CLKGATE, - &clkctrl_regs->hw_clkctrl_frac0_set[CLKCTRL_FRAC0_EMI]); - - /* Set fractional divider for ref_emi to 480 * 18 / 21 = 411MHz */ - writeb(CLKCTRL_FRAC_CLKGATE | (21 & CLKCTRL_FRAC_FRAC_MASK), - &clkctrl_regs->hw_clkctrl_frac0[CLKCTRL_FRAC0_EMI]); - - /* Ungate EMI clock */ - writeb(CLKCTRL_FRAC_CLKGATE, - &clkctrl_regs->hw_clkctrl_frac0_clr[CLKCTRL_FRAC0_EMI]); - - early_delay(11000); - - /* Set EMI clock divider for EMI clock to 411 / 2 = 205MHz */ - writel((2 << CLKCTRL_EMI_DIV_EMI_OFFSET) | - (1 << CLKCTRL_EMI_DIV_XTAL_OFFSET), - &clkctrl_regs->hw_clkctrl_emi); - - /* Unbypass EMI */ - writel(CLKCTRL_CLKSEQ_BYPASS_EMI, - &clkctrl_regs->hw_clkctrl_clkseq_clr); - - early_delay(10000); -} - -void mx28_mem_setup_cpu_and_hbus(void) -{ - struct mx28_clkctrl_regs *clkctrl_regs = - (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; - - /* Set fractional divider for ref_cpu to 480 * 18 / 19 = 454MHz - * and ungate CPU clock */ - writeb(19 & CLKCTRL_FRAC_FRAC_MASK, - (uint8_t *)&clkctrl_regs->hw_clkctrl_frac0[CLKCTRL_FRAC0_CPU]); - - /* Set CPU bypass */ - writel(CLKCTRL_CLKSEQ_BYPASS_CPU, - &clkctrl_regs->hw_clkctrl_clkseq_set); - - /* HBUS = 151MHz */ - writel(CLKCTRL_HBUS_DIV_MASK, &clkctrl_regs->hw_clkctrl_hbus_set); - writel(((~3) << CLKCTRL_HBUS_DIV_OFFSET) & CLKCTRL_HBUS_DIV_MASK, - &clkctrl_regs->hw_clkctrl_hbus_clr); - - early_delay(10000); - - /* CPU clock divider = 1 */ - clrsetbits_le32(&clkctrl_regs->hw_clkctrl_cpu, - CLKCTRL_CPU_DIV_CPU_MASK, 1); - - /* Disable CPU bypass */ - writel(CLKCTRL_CLKSEQ_BYPASS_CPU, - &clkctrl_regs->hw_clkctrl_clkseq_clr); - - early_delay(15000); -} - -void mx28_mem_setup_vdda(void) -{ - struct mx28_power_regs *power_regs = - (struct mx28_power_regs *)MXS_POWER_BASE; - - writel((0xc << POWER_VDDACTRL_TRG_OFFSET) | - (0x7 << POWER_VDDACTRL_BO_OFFSET_OFFSET) | - POWER_VDDACTRL_LINREG_OFFSET_1STEPS_BELOW, - &power_regs->hw_power_vddactrl); -} - -void mx28_mem_setup_vddd(void) -{ - struct mx28_power_regs *power_regs = - (struct mx28_power_regs *)MXS_POWER_BASE; - - writel((0x1c << POWER_VDDDCTRL_TRG_OFFSET) | - (0x7 << POWER_VDDDCTRL_BO_OFFSET_OFFSET) | - POWER_VDDDCTRL_LINREG_OFFSET_1STEPS_BELOW, - &power_regs->hw_power_vdddctrl); -} - -uint32_t mx28_mem_get_size(void) -{ - uint32_t sz, da; - uint32_t *vt = (uint32_t *)0x20; - /* The following is "subs pc, r14, #4", used as return from DABT. */ - const uint32_t data_abort_memdetect_handler = 0xe25ef004; - - /* Replace the DABT handler. */ - da = vt[4]; - vt[4] = data_abort_memdetect_handler; - - sz = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE); - - /* Restore the old DABT handler. */ - vt[4] = da; - - return sz; -} - -void mx28_mem_init(void) -{ - struct mx28_clkctrl_regs *clkctrl_regs = - (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; - struct mx28_pinctrl_regs *pinctrl_regs = - (struct mx28_pinctrl_regs *)MXS_PINCTRL_BASE; - - /* Set DDR2 mode */ - writel(PINCTRL_EMI_DS_CTRL_DDR_MODE_DDR2, - &pinctrl_regs->hw_pinctrl_emi_ds_ctrl_set); - - /* Power up PLL0 */ - writel(CLKCTRL_PLL0CTRL0_POWER, - &clkctrl_regs->hw_clkctrl_pll0ctrl0_set); - - early_delay(11000); - - mx28_mem_init_clock(); - - mx28_mem_setup_vdda(); - - /* - * Configure the DRAM registers - */ - - /* Clear START bit from DRAM_CTL16 */ - clrbits_le32(MXS_DRAM_BASE + 0x40, 1); - - init_m28_200mhz_ddr2(); - - /* Clear SREFRESH bit from DRAM_CTL17 */ - clrbits_le32(MXS_DRAM_BASE + 0x44, 1); - - /* Set START bit in DRAM_CTL16 */ - setbits_le32(MXS_DRAM_BASE + 0x40, 1); - - /* Wait for bit 20 (DRAM init complete) in DRAM_CTL58 */ - while (!(readl(MXS_DRAM_BASE + 0xe8) & (1 << 20))) - ; - - mx28_mem_setup_vddd(); - - early_delay(10000); - - mx28_mem_setup_cpu_and_hbus(); -} diff --git a/arch/arm/cpu/arm926ejs/mx28/spl_power_init.c b/arch/arm/cpu/arm926ejs/mx28/spl_power_init.c deleted file mode 100644 index 4b09b0c..0000000 --- a/arch/arm/cpu/arm926ejs/mx28/spl_power_init.c +++ /dev/null @@ -1,1007 +0,0 @@ -/* - * Freescale i.MX28 Boot PMIC init - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * on behalf of DENX Software Engineering GmbH - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <config.h> -#include <asm/io.h> -#include <asm/arch/imx-regs.h> - -#include "mx28_init.h" - -void mx28_power_clock2xtal(void) -{ - struct mx28_clkctrl_regs *clkctrl_regs = - (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; - - /* Set XTAL as CPU reference clock */ - writel(CLKCTRL_CLKSEQ_BYPASS_CPU, - &clkctrl_regs->hw_clkctrl_clkseq_set); -} - -void mx28_power_clock2pll(void) -{ - struct mx28_clkctrl_regs *clkctrl_regs = - (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; - - setbits_le32(&clkctrl_regs->hw_clkctrl_pll0ctrl0, - CLKCTRL_PLL0CTRL0_POWER); - early_delay(100); - setbits_le32(&clkctrl_regs->hw_clkctrl_clkseq, - CLKCTRL_CLKSEQ_BYPASS_CPU); -} - -void mx28_power_clear_auto_restart(void) -{ - struct mx28_rtc_regs *rtc_regs = - (struct mx28_rtc_regs *)MXS_RTC_BASE; - - writel(RTC_CTRL_SFTRST, &rtc_regs->hw_rtc_ctrl_clr); - while (readl(&rtc_regs->hw_rtc_ctrl) & RTC_CTRL_SFTRST) - ; - - writel(RTC_CTRL_CLKGATE, &rtc_regs->hw_rtc_ctrl_clr); - while (readl(&rtc_regs->hw_rtc_ctrl) & RTC_CTRL_CLKGATE) - ; - - /* - * Due to the hardware design bug of mx28 EVK-A - * we need to set the AUTO_RESTART bit. - */ - if (readl(&rtc_regs->hw_rtc_persistent0) & RTC_PERSISTENT0_AUTO_RESTART) - return; - - while (readl(&rtc_regs->hw_rtc_stat) & RTC_STAT_NEW_REGS_MASK) - ; - - setbits_le32(&rtc_regs->hw_rtc_persistent0, - RTC_PERSISTENT0_AUTO_RESTART); - writel(RTC_CTRL_FORCE_UPDATE, &rtc_regs->hw_rtc_ctrl_set); - writel(RTC_CTRL_FORCE_UPDATE, &rtc_regs->hw_rtc_ctrl_clr); - while (readl(&rtc_regs->hw_rtc_stat) & RTC_STAT_NEW_REGS_MASK) - ; - while (readl(&rtc_regs->hw_rtc_stat) & RTC_STAT_STALE_REGS_MASK) - ; -} - -void mx28_power_set_linreg(void) -{ - struct mx28_power_regs *power_regs = - (struct mx28_power_regs *)MXS_POWER_BASE; - - /* Set linear regulator 25mV below switching converter */ - clrsetbits_le32(&power_regs->hw_power_vdddctrl, - POWER_VDDDCTRL_LINREG_OFFSET_MASK, - POWER_VDDDCTRL_LINREG_OFFSET_1STEPS_BELOW); - - clrsetbits_le32(&power_regs->hw_power_vddactrl, - POWER_VDDACTRL_LINREG_OFFSET_MASK, - POWER_VDDACTRL_LINREG_OFFSET_1STEPS_BELOW); - - clrsetbits_le32(&power_regs->hw_power_vddioctrl, - POWER_VDDIOCTRL_LINREG_OFFSET_MASK, - POWER_VDDIOCTRL_LINREG_OFFSET_1STEPS_BELOW); -} - -int mx28_get_batt_volt(void) -{ - struct mx28_power_regs *power_regs = - (struct mx28_power_regs *)MXS_POWER_BASE; - uint32_t volt = readl(&power_regs->hw_power_battmonitor); - volt &= POWER_BATTMONITOR_BATT_VAL_MASK; - volt >>= POWER_BATTMONITOR_BATT_VAL_OFFSET; - volt *= 8; - return volt; -} - -int mx28_is_batt_ready(void) -{ - return (mx28_get_batt_volt() >= 3600); -} - -int mx28_is_batt_good(void) -{ - struct mx28_power_regs *power_regs = - (struct mx28_power_regs *)MXS_POWER_BASE; - uint32_t volt = mx28_get_batt_volt(); - - if ((volt >= 2400) && (volt <= 4300)) - return 1; - - clrsetbits_le32(&power_regs->hw_power_5vctrl, - POWER_5VCTRL_CHARGE_4P2_ILIMIT_MASK, - 0x3 << POWER_5VCTRL_CHARGE_4P2_ILIMIT_OFFSET); - writel(POWER_5VCTRL_PWD_CHARGE_4P2_MASK, - &power_regs->hw_power_5vctrl_clr); - - clrsetbits_le32(&power_regs->hw_power_charge, - POWER_CHARGE_STOP_ILIMIT_MASK | POWER_CHARGE_BATTCHRG_I_MASK, - POWER_CHARGE_STOP_ILIMIT_10MA | 0x3); - - writel(POWER_CHARGE_PWD_BATTCHRG, &power_regs->hw_power_charge_clr); - writel(POWER_5VCTRL_PWD_CHARGE_4P2_MASK, - &power_regs->hw_power_5vctrl_clr); - - early_delay(500000); - - volt = mx28_get_batt_volt(); - - if (volt >= 3500) - return 0; - - if (volt >= 2400) - return 1; - - writel(POWER_CHARGE_STOP_ILIMIT_MASK | POWER_CHARGE_BATTCHRG_I_MASK, - &power_regs->hw_power_charge_clr); - writel(POWER_CHARGE_PWD_BATTCHRG, &power_regs->hw_power_charge_set); - - return 0; -} - -void mx28_power_setup_5v_detect(void) -{ - struct mx28_power_regs *power_regs = - (struct mx28_power_regs *)MXS_POWER_BASE; - - /* Start 5V detection */ - clrsetbits_le32(&power_regs->hw_power_5vctrl, - POWER_5VCTRL_VBUSVALID_TRSH_MASK, - POWER_5VCTRL_VBUSVALID_TRSH_4V4 | - POWER_5VCTRL_PWRUP_VBUS_CMPS); -} - -void mx28_src_power_init(void) -{ - struct mx28_power_regs *power_regs = - (struct mx28_power_regs *)MXS_POWER_BASE; - - /* Improve efficieny and reduce transient ripple */ - writel(POWER_LOOPCTRL_TOGGLE_DIF | POWER_LOOPCTRL_EN_CM_HYST | - POWER_LOOPCTRL_EN_DF_HYST, &power_regs->hw_power_loopctrl_set); - - clrsetbits_le32(&power_regs->hw_power_dclimits, - POWER_DCLIMITS_POSLIMIT_BUCK_MASK, - 0x30 << POWER_DCLIMITS_POSLIMIT_BUCK_OFFSET); - - setbits_le32(&power_regs->hw_power_battmonitor, - POWER_BATTMONITOR_EN_BATADJ); - - /* Increase the RCSCALE level for quick DCDC response to dynamic load */ - clrsetbits_le32(&power_regs->hw_power_loopctrl, - POWER_LOOPCTRL_EN_RCSCALE_MASK, - POWER_LOOPCTRL_RCSCALE_THRESH | - POWER_LOOPCTRL_EN_RCSCALE_8X); - - clrsetbits_le32(&power_regs->hw_power_minpwr, - POWER_MINPWR_HALFFETS, POWER_MINPWR_DOUBLE_FETS); - - /* 5V to battery handoff ... FIXME */ - setbits_le32(&power_regs->hw_power_5vctrl, POWER_5VCTRL_DCDC_XFER); - early_delay(30); - clrbits_le32(&power_regs->hw_power_5vctrl, POWER_5VCTRL_DCDC_XFER); -} - -void mx28_power_init_4p2_params(void) -{ - struct mx28_power_regs *power_regs = - (struct mx28_power_regs *)MXS_POWER_BASE; - - /* Setup 4P2 parameters */ - clrsetbits_le32(&power_regs->hw_power_dcdc4p2, - POWER_DCDC4P2_CMPTRIP_MASK | POWER_DCDC4P2_TRG_MASK, - POWER_DCDC4P2_TRG_4V2 | (31 << POWER_DCDC4P2_CMPTRIP_OFFSET)); - - clrsetbits_le32(&power_regs->hw_power_5vctrl, - POWER_5VCTRL_HEADROOM_ADJ_MASK, - 0x4 << POWER_5VCTRL_HEADROOM_ADJ_OFFSET); - - clrsetbits_le32(&power_regs->hw_power_dcdc4p2, - POWER_DCDC4P2_DROPOUT_CTRL_MASK, - POWER_DCDC4P2_DROPOUT_CTRL_100MV | - POWER_DCDC4P2_DROPOUT_CTRL_SRC_SEL); - - clrsetbits_le32(&power_regs->hw_power_5vctrl, - POWER_5VCTRL_CHARGE_4P2_ILIMIT_MASK, - 0x3f << POWER_5VCTRL_CHARGE_4P2_ILIMIT_OFFSET); -} - -void mx28_enable_4p2_dcdc_input(int xfer) -{ - struct mx28_power_regs *power_regs = - (struct mx28_power_regs *)MXS_POWER_BASE; - uint32_t tmp, vbus_thresh, vbus_5vdetect, pwd_bo; - uint32_t prev_5v_brnout, prev_5v_droop; - - prev_5v_brnout = readl(&power_regs->hw_power_5vctrl) & - POWER_5VCTRL_PWDN_5VBRNOUT; - prev_5v_droop = readl(&power_regs->hw_power_ctrl) & - POWER_CTRL_ENIRQ_VDD5V_DROOP; - - clrbits_le32(&power_regs->hw_power_5vctrl, POWER_5VCTRL_PWDN_5VBRNOUT); - writel(POWER_RESET_UNLOCK_KEY | POWER_RESET_PWD_OFF, - &power_regs->hw_power_reset); - - clrbits_le32(&power_regs->hw_power_ctrl, POWER_CTRL_ENIRQ_VDD5V_DROOP); - - if (xfer && (readl(&power_regs->hw_power_5vctrl) & - POWER_5VCTRL_ENABLE_DCDC)) { - return; - } - - /* - * Recording orignal values that will be modified temporarlily - * to handle a chip bug. See chip errata for CQ ENGR00115837 - */ - tmp = readl(&power_regs->hw_power_5vctrl); - vbus_thresh = tmp & POWER_5VCTRL_VBUSVALID_TRSH_MASK; - vbus_5vdetect = tmp & POWER_5VCTRL_VBUSVALID_5VDETECT; - - pwd_bo = readl(&power_regs->hw_power_minpwr) & POWER_MINPWR_PWD_BO; - - /* - * Disable mechanisms that get erroneously tripped by when setting - * the DCDC4P2 EN_DCDC - */ - clrbits_le32(&power_regs->hw_power_5vctrl, - POWER_5VCTRL_VBUSVALID_5VDETECT | - POWER_5VCTRL_VBUSVALID_TRSH_MASK); - - writel(POWER_MINPWR_PWD_BO, &power_regs->hw_power_minpwr_set); - - if (xfer) { - setbits_le32(&power_regs->hw_power_5vctrl, - POWER_5VCTRL_DCDC_XFER); - early_delay(20); - clrbits_le32(&power_regs->hw_power_5vctrl, - POWER_5VCTRL_DCDC_XFER); - - setbits_le32(&power_regs->hw_power_5vctrl, - POWER_5VCTRL_ENABLE_DCDC); - } else { - setbits_le32(&power_regs->hw_power_dcdc4p2, - POWER_DCDC4P2_ENABLE_DCDC); - } - - early_delay(25); - - clrsetbits_le32(&power_regs->hw_power_5vctrl, - POWER_5VCTRL_VBUSVALID_TRSH_MASK, vbus_thresh); - - if (vbus_5vdetect) - writel(vbus_5vdetect, &power_regs->hw_power_5vctrl_set); - - if (!pwd_bo) - clrbits_le32(&power_regs->hw_power_minpwr, POWER_MINPWR_PWD_BO); - - while (readl(&power_regs->hw_power_ctrl) & POWER_CTRL_VBUS_VALID_IRQ) - writel(POWER_CTRL_VBUS_VALID_IRQ, - &power_regs->hw_power_ctrl_clr); - - if (prev_5v_brnout) { - writel(POWER_5VCTRL_PWDN_5VBRNOUT, - &power_regs->hw_power_5vctrl_set); - writel(POWER_RESET_UNLOCK_KEY, - &power_regs->hw_power_reset); - } else { - writel(POWER_5VCTRL_PWDN_5VBRNOUT, - &power_regs->hw_power_5vctrl_clr); - writel(POWER_RESET_UNLOCK_KEY | POWER_RESET_PWD_OFF, - &power_regs->hw_power_reset); - } - - while (readl(&power_regs->hw_power_ctrl) & POWER_CTRL_VDD5V_DROOP_IRQ) - writel(POWER_CTRL_VDD5V_DROOP_IRQ, - &power_regs->hw_power_ctrl_clr); - - if (prev_5v_droop) - clrbits_le32(&power_regs->hw_power_ctrl, - POWER_CTRL_ENIRQ_VDD5V_DROOP); - else - setbits_le32(&power_regs->hw_power_ctrl, - POWER_CTRL_ENIRQ_VDD5V_DROOP); -} - -void mx28_power_init_4p2_regulator(void) -{ - struct mx28_power_regs *power_regs = - (struct mx28_power_regs *)MXS_POWER_BASE; - uint32_t tmp, tmp2; - - setbits_le32(&power_regs->hw_power_dcdc4p2, POWER_DCDC4P2_ENABLE_4P2); - - writel(POWER_CHARGE_ENABLE_LOAD, &power_regs->hw_power_charge_set); - - writel(POWER_5VCTRL_CHARGE_4P2_ILIMIT_MASK, - &power_regs->hw_power_5vctrl_clr); - clrbits_le32(&power_regs->hw_power_dcdc4p2, POWER_DCDC4P2_TRG_MASK); - - /* Power up the 4p2 rail and logic/control */ - writel(POWER_5VCTRL_PWD_CHARGE_4P2_MASK, - &power_regs->hw_power_5vctrl_clr); - - /* - * Start charging up the 4p2 capacitor. We ramp of this charge - * gradually to avoid large inrush current from the 5V cable which can - * cause transients/problems - */ - mx28_enable_4p2_dcdc_input(0); - - if (readl(&power_regs->hw_power_ctrl) & POWER_CTRL_VBUS_VALID_IRQ) { - /* - * If we arrived here, we were unable to recover from mx23 chip - * errata 5837. 4P2 is disabled and sufficient battery power is - * not present. Exiting to not enable DCDC power during 5V - * connected state. - */ - clrbits_le32(&power_regs->hw_power_dcdc4p2, - POWER_DCDC4P2_ENABLE_DCDC); - writel(POWER_5VCTRL_PWD_CHARGE_4P2_MASK, - &power_regs->hw_power_5vctrl_set); - hang(); - } - - /* - * Here we set the 4p2 brownout level to something very close to 4.2V. - * We then check the brownout status. If the brownout status is false, - * the voltage is already close to the target voltage of 4.2V so we - * can go ahead and set the 4P2 current limit to our max target limit. - * If the brownout status is true, we need to ramp us the current limit - * so that we don't cause large inrush current issues. We step up the - * current limit until the brownout status is false or until we've - * reached our maximum defined 4p2 current limit. - */ - clrsetbits_le32(&power_regs->hw_power_dcdc4p2, - POWER_DCDC4P2_BO_MASK, - 22 << POWER_DCDC4P2_BO_OFFSET); /* 4.15V */ - - if (!(readl(&power_regs->hw_power_sts) & POWER_STS_DCDC_4P2_BO)) { - setbits_le32(&power_regs->hw_power_5vctrl, - 0x3f << POWER_5VCTRL_CHARGE_4P2_ILIMIT_OFFSET); - } else { - tmp = (readl(&power_regs->hw_power_5vctrl) & - POWER_5VCTRL_CHARGE_4P2_ILIMIT_MASK) >> - POWER_5VCTRL_CHARGE_4P2_ILIMIT_OFFSET; - while (tmp < 0x3f) { - if (!(readl(&power_regs->hw_power_sts) & - POWER_STS_DCDC_4P2_BO)) { - tmp = readl(&power_regs->hw_power_5vctrl); - tmp |= POWER_5VCTRL_CHARGE_4P2_ILIMIT_MASK; - early_delay(100); - writel(tmp, &power_regs->hw_power_5vctrl); - break; - } else { - tmp++; - tmp2 = readl(&power_regs->hw_power_5vctrl); - tmp2 &= ~POWER_5VCTRL_CHARGE_4P2_ILIMIT_MASK; - tmp2 |= tmp << - POWER_5VCTRL_CHARGE_4P2_ILIMIT_OFFSET; - writel(tmp2, &power_regs->hw_power_5vctrl); - early_delay(100); - } - } - } - - clrbits_le32(&power_regs->hw_power_dcdc4p2, POWER_DCDC4P2_BO_MASK); - writel(POWER_CTRL_DCDC4P2_BO_IRQ, &power_regs->hw_power_ctrl_clr); -} - -void mx28_power_init_dcdc_4p2_source(void) -{ - struct mx28_power_regs *power_regs = - (struct mx28_power_regs *)MXS_POWER_BASE; - - if (!(readl(&power_regs->hw_power_dcdc4p2) & - POWER_DCDC4P2_ENABLE_DCDC)) { - hang(); - } - - mx28_enable_4p2_dcdc_input(1); - - if (readl(&power_regs->hw_power_ctrl) & POWER_CTRL_VBUS_VALID_IRQ) { - clrbits_le32(&power_regs->hw_power_dcdc4p2, - POWER_DCDC4P2_ENABLE_DCDC); - writel(POWER_5VCTRL_ENABLE_DCDC, - &power_regs->hw_power_5vctrl_clr); - writel(POWER_5VCTRL_PWD_CHARGE_4P2_MASK, - &power_regs->hw_power_5vctrl_set); - } -} - -void mx28_power_enable_4p2(void) -{ - struct mx28_power_regs *power_regs = - (struct mx28_power_regs *)MXS_POWER_BASE; - uint32_t vdddctrl, vddactrl, vddioctrl; - uint32_t tmp; - - vdddctrl = readl(&power_regs->hw_power_vdddctrl); - vddactrl = readl(&power_regs->hw_power_vddactrl); - vddioctrl = readl(&power_regs->hw_power_vddioctrl); - - setbits_le32(&power_regs->hw_power_vdddctrl, - POWER_VDDDCTRL_DISABLE_FET | POWER_VDDDCTRL_ENABLE_LINREG | - POWER_VDDDCTRL_PWDN_BRNOUT); - - setbits_le32(&power_regs->hw_power_vddactrl, - POWER_VDDACTRL_DISABLE_FET | POWER_VDDACTRL_ENABLE_LINREG | - POWER_VDDACTRL_PWDN_BRNOUT); - - setbits_le32(&power_regs->hw_power_vddioctrl, - POWER_VDDIOCTRL_DISABLE_FET | POWER_VDDIOCTRL_PWDN_BRNOUT); - - mx28_power_init_4p2_params(); - mx28_power_init_4p2_regulator(); - - /* Shutdown battery (none present) */ - if (!mx28_is_batt_ready()) { - clrbits_le32(&power_regs->hw_power_dcdc4p2, - POWER_DCDC4P2_BO_MASK); - writel(POWER_CTRL_DCDC4P2_BO_IRQ, - &power_regs->hw_power_ctrl_clr); - writel(POWER_CTRL_ENIRQ_DCDC4P2_BO, - &power_regs->hw_power_ctrl_clr); - } - - mx28_power_init_dcdc_4p2_source(); - - writel(vdddctrl, &power_regs->hw_power_vdddctrl); - early_delay(20); - writel(vddactrl, &power_regs->hw_power_vddactrl); - early_delay(20); - writel(vddioctrl, &power_regs->hw_power_vddioctrl); - - /* - * Check if FET is enabled on either powerout and if so, - * disable load. - */ - tmp = 0; - tmp |= !(readl(&power_regs->hw_power_vdddctrl) & - POWER_VDDDCTRL_DISABLE_FET); - tmp |= !(readl(&power_regs->hw_power_vddactrl) & - POWER_VDDACTRL_DISABLE_FET); - tmp |= !(readl(&power_regs->hw_power_vddioctrl) & - POWER_VDDIOCTRL_DISABLE_FET); - if (tmp) - writel(POWER_CHARGE_ENABLE_LOAD, - &power_regs->hw_power_charge_clr); -} - -void mx28_boot_valid_5v(void) -{ - struct mx28_power_regs *power_regs = - (struct mx28_power_regs *)MXS_POWER_BASE; - - /* - * Use VBUSVALID level instead of VDD5V_GT_VDDIO level to trigger a 5V - * disconnect event. FIXME - */ - writel(POWER_5VCTRL_VBUSVALID_5VDETECT, - &power_regs->hw_power_5vctrl_set); - - /* Configure polarity to check for 5V disconnection. */ - writel(POWER_CTRL_POLARITY_VBUSVALID | - POWER_CTRL_POLARITY_VDD5V_GT_VDDIO, - &power_regs->hw_power_ctrl_clr); - - writel(POWER_CTRL_VBUS_VALID_IRQ | POWER_CTRL_VDD5V_GT_VDDIO_IRQ, - &power_regs->hw_power_ctrl_clr); - - mx28_power_enable_4p2(); -} - -void mx28_powerdown(void) -{ - struct mx28_power_regs *power_regs = - (struct mx28_power_regs *)MXS_POWER_BASE; - writel(POWER_RESET_UNLOCK_KEY, &power_regs->hw_power_reset); - writel(POWER_RESET_UNLOCK_KEY | POWER_RESET_PWD_OFF, - &power_regs->hw_power_reset); -} - -void mx28_batt_boot(void) -{ - struct mx28_power_regs *power_regs = - (struct mx28_power_regs *)MXS_POWER_BASE; - - clrbits_le32(&power_regs->hw_power_5vctrl, POWER_5VCTRL_PWDN_5VBRNOUT); - clrbits_le32(&power_regs->hw_power_5vctrl, POWER_5VCTRL_ENABLE_DCDC); - - clrbits_le32(&power_regs->hw_power_dcdc4p2, - POWER_DCDC4P2_ENABLE_DCDC | POWER_DCDC4P2_ENABLE_4P2); - writel(POWER_CHARGE_ENABLE_LOAD, &power_regs->hw_power_charge_clr); - - /* 5V to battery handoff. */ - setbits_le32(&power_regs->hw_power_5vctrl, POWER_5VCTRL_DCDC_XFER); - early_delay(30); - clrbits_le32(&power_regs->hw_power_5vctrl, POWER_5VCTRL_DCDC_XFER); - - writel(POWER_CTRL_ENIRQ_DCDC4P2_BO, &power_regs->hw_power_ctrl_clr); - - clrsetbits_le32(&power_regs->hw_power_minpwr, - POWER_MINPWR_HALFFETS, POWER_MINPWR_DOUBLE_FETS); - - mx28_power_set_linreg(); - - clrbits_le32(&power_regs->hw_power_vdddctrl, - POWER_VDDDCTRL_DISABLE_FET | POWER_VDDDCTRL_ENABLE_LINREG); - - clrbits_le32(&power_regs->hw_power_vddactrl, - POWER_VDDACTRL_DISABLE_FET | POWER_VDDACTRL_ENABLE_LINREG); - - clrbits_le32(&power_regs->hw_power_vddioctrl, - POWER_VDDIOCTRL_DISABLE_FET); - - setbits_le32(&power_regs->hw_power_5vctrl, - POWER_5VCTRL_PWD_CHARGE_4P2_MASK); - - setbits_le32(&power_regs->hw_power_5vctrl, - POWER_5VCTRL_ENABLE_DCDC); - - clrsetbits_le32(&power_regs->hw_power_5vctrl, - POWER_5VCTRL_CHARGE_4P2_ILIMIT_MASK, - 0x8 << POWER_5VCTRL_CHARGE_4P2_ILIMIT_OFFSET); -} - -void mx28_handle_5v_conflict(void) -{ - struct mx28_power_regs *power_regs = - (struct mx28_power_regs *)MXS_POWER_BASE; - uint32_t tmp; - - setbits_le32(&power_regs->hw_power_vddioctrl, - POWER_VDDIOCTRL_BO_OFFSET_MASK); - - for (;;) { - tmp = readl(&power_regs->hw_power_sts); - - if (tmp & POWER_STS_VDDIO_BO) { - mx28_powerdown(); - break; - } - - if (tmp & POWER_STS_VDD5V_GT_VDDIO) { - mx28_boot_valid_5v(); - break; - } else { - mx28_powerdown(); - break; - } - - if (tmp & POWER_STS_PSWITCH_MASK) { - mx28_batt_boot(); - break; - } - } -} - -void mx28_5v_boot(void) -{ - struct mx28_power_regs *power_regs = - (struct mx28_power_regs *)MXS_POWER_BASE; - - /* - * NOTE: In original IMX-Bootlets, this also checks for VBUSVALID, - * but their implementation always returns 1 so we omit it here. - */ - if (readl(&power_regs->hw_power_sts) & POWER_STS_VDD5V_GT_VDDIO) { - mx28_boot_valid_5v(); - return; - } - - early_delay(1000); - if (readl(&power_regs->hw_power_sts) & POWER_STS_VDD5V_GT_VDDIO) { - mx28_boot_valid_5v(); - return; - } - - mx28_handle_5v_conflict(); -} - -void mx28_init_batt_bo(void) -{ - struct mx28_power_regs *power_regs = - (struct mx28_power_regs *)MXS_POWER_BASE; - - /* Brownout at 3V */ - clrsetbits_le32(&power_regs->hw_power_battmonitor, - POWER_BATTMONITOR_BRWNOUT_LVL_MASK, - 15 << POWER_BATTMONITOR_BRWNOUT_LVL_OFFSET); - - writel(POWER_CTRL_BATT_BO_IRQ, &power_regs->hw_power_ctrl_clr); - writel(POWER_CTRL_ENIRQ_BATT_BO, &power_regs->hw_power_ctrl_clr); -} - -void mx28_switch_vddd_to_dcdc_source(void) -{ - struct mx28_power_regs *power_regs = - (struct mx28_power_regs *)MXS_POWER_BASE; - - clrsetbits_le32(&power_regs->hw_power_vdddctrl, - POWER_VDDDCTRL_LINREG_OFFSET_MASK, - POWER_VDDDCTRL_LINREG_OFFSET_1STEPS_BELOW); - - clrbits_le32(&power_regs->hw_power_vdddctrl, - POWER_VDDDCTRL_DISABLE_FET | POWER_VDDDCTRL_ENABLE_LINREG | - POWER_VDDDCTRL_DISABLE_STEPPING); -} - -void mx28_power_configure_power_source(void) -{ - int batt_ready, batt_good; - struct mx28_power_regs *power_regs = - (struct mx28_power_regs *)MXS_POWER_BASE; - struct mx28_lradc_regs *lradc_regs = - (struct mx28_lradc_regs *)MXS_LRADC_BASE; - - mx28_src_power_init(); - - batt_ready = mx28_is_batt_ready(); - - if (readl(&power_regs->hw_power_sts) & POWER_STS_VDD5V_GT_VDDIO) { - batt_good = mx28_is_batt_good(); - if (batt_ready) { - /* 5V source detected, good battery detected. */ - mx28_batt_boot(); - } else { - if (batt_good) { - /* 5V source detected, low battery detceted. */ - } else { - /* 5V source detected, bad battery detected. */ - writel(LRADC_CONVERSION_AUTOMATIC, - &lradc_regs->hw_lradc_conversion_clr); - clrbits_le32(&power_regs->hw_power_battmonitor, - POWER_BATTMONITOR_BATT_VAL_MASK); - } - mx28_5v_boot(); - } - } else { - /* 5V not detected, booting from battery. */ - mx28_batt_boot(); - } - - mx28_power_clock2pll(); - - mx28_init_batt_bo(); - - mx28_switch_vddd_to_dcdc_source(); -} - -void mx28_enable_output_rail_protection(void) -{ - struct mx28_power_regs *power_regs = - (struct mx28_power_regs *)MXS_POWER_BASE; - - writel(POWER_CTRL_VDDD_BO_IRQ | POWER_CTRL_VDDA_BO_IRQ | - POWER_CTRL_VDDIO_BO_IRQ, &power_regs->hw_power_ctrl_clr); - - setbits_le32(&power_regs->hw_power_vdddctrl, - POWER_VDDDCTRL_PWDN_BRNOUT); - - setbits_le32(&power_regs->hw_power_vddactrl, - POWER_VDDACTRL_PWDN_BRNOUT); - - setbits_le32(&power_regs->hw_power_vddioctrl, - POWER_VDDIOCTRL_PWDN_BRNOUT); -} - -int mx28_get_vddio_power_source_off(void) -{ - struct mx28_power_regs *power_regs = - (struct mx28_power_regs *)MXS_POWER_BASE; - uint32_t tmp; - - if (readl(&power_regs->hw_power_sts) & POWER_STS_VDD5V_GT_VDDIO) { - tmp = readl(&power_regs->hw_power_vddioctrl); - if (tmp & POWER_VDDIOCTRL_DISABLE_FET) { - if ((tmp & POWER_VDDIOCTRL_LINREG_OFFSET_MASK) == - POWER_VDDDCTRL_LINREG_OFFSET_0STEPS) { - return 1; - } - } - - if (!(readl(&power_regs->hw_power_5vctrl) & - POWER_5VCTRL_ENABLE_DCDC)) { - if ((tmp & POWER_VDDIOCTRL_LINREG_OFFSET_MASK) == - POWER_VDDDCTRL_LINREG_OFFSET_0STEPS) { - return 1; - } - } - } - - return 0; - -} - -int mx28_get_vddd_power_source_off(void) -{ - struct mx28_power_regs *power_regs = - (struct mx28_power_regs *)MXS_POWER_BASE; - uint32_t tmp; - - tmp = readl(&power_regs->hw_power_vdddctrl); - if (tmp & POWER_VDDDCTRL_DISABLE_FET) { - if ((tmp & POWER_VDDDCTRL_LINREG_OFFSET_MASK) == - POWER_VDDDCTRL_LINREG_OFFSET_0STEPS) { - return 1; - } - } - - if (readl(&power_regs->hw_power_sts) & POWER_STS_VDD5V_GT_VDDIO) { - if (!(readl(&power_regs->hw_power_5vctrl) & - POWER_5VCTRL_ENABLE_DCDC)) { - return 1; - } - } - - if (!(tmp & POWER_VDDDCTRL_ENABLE_LINREG)) { - if ((tmp & POWER_VDDDCTRL_LINREG_OFFSET_MASK) == - POWER_VDDDCTRL_LINREG_OFFSET_1STEPS_BELOW) { - return 1; - } - } - - return 0; -} - -void mx28_power_set_vddio(uint32_t new_target, uint32_t new_brownout) -{ - struct mx28_power_regs *power_regs = - (struct mx28_power_regs *)MXS_POWER_BASE; - uint32_t cur_target, diff, bo_int = 0; - uint32_t powered_by_linreg = 0; - - new_brownout = new_target - new_brownout; - - cur_target = readl(&power_regs->hw_power_vddioctrl); - cur_target &= POWER_VDDIOCTRL_TRG_MASK; - cur_target *= 50; /* 50 mV step*/ - cur_target += 2800; /* 2800 mV lowest */ - - powered_by_linreg = mx28_get_vddio_power_source_off(); - if (new_target > cur_target) { - - if (powered_by_linreg) { - bo_int = readl(&power_regs->hw_power_vddioctrl); - clrbits_le32(&power_regs->hw_power_vddioctrl, - POWER_CTRL_ENIRQ_VDDIO_BO); - } - - setbits_le32(&power_regs->hw_power_vddioctrl, - POWER_VDDIOCTRL_BO_OFFSET_MASK); - do { - if (new_target - cur_target > 100) - diff = cur_target + 100; - else - diff = new_target; - - diff -= 2800; - diff /= 50; - - clrsetbits_le32(&power_regs->hw_power_vddioctrl, - POWER_VDDIOCTRL_TRG_MASK, diff); - - if (powered_by_linreg || - (readl(&power_regs->hw_power_sts) & - POWER_STS_VDD5V_GT_VDDIO)) - early_delay(500); - else { - while (!(readl(&power_regs->hw_power_sts) & - POWER_STS_DC_OK)) - ; - - } - - cur_target = readl(&power_regs->hw_power_vddioctrl); - cur_target &= POWER_VDDIOCTRL_TRG_MASK; - cur_target *= 50; /* 50 mV step*/ - cur_target += 2800; /* 2800 mV lowest */ - } while (new_target > cur_target); - - if (powered_by_linreg) { - writel(POWER_CTRL_VDDIO_BO_IRQ, - &power_regs->hw_power_ctrl_clr); - if (bo_int & POWER_CTRL_ENIRQ_VDDIO_BO) - setbits_le32(&power_regs->hw_power_vddioctrl, - POWER_CTRL_ENIRQ_VDDIO_BO); - } - } else { - do { - if (cur_target - new_target > 100) - diff = cur_target - 100; - else - diff = new_target; - - diff -= 2800; - diff /= 50; - - clrsetbits_le32(&power_regs->hw_power_vddioctrl, - POWER_VDDIOCTRL_TRG_MASK, diff); - - if (powered_by_linreg || - (readl(&power_regs->hw_power_sts) & - POWER_STS_VDD5V_GT_VDDIO)) - early_delay(500); - else { - while (!(readl(&power_regs->hw_power_sts) & - POWER_STS_DC_OK)) - ; - - } - - cur_target = readl(&power_regs->hw_power_vddioctrl); - cur_target &= POWER_VDDIOCTRL_TRG_MASK; - cur_target *= 50; /* 50 mV step*/ - cur_target += 2800; /* 2800 mV lowest */ - } while (new_target < cur_target); - } - - clrsetbits_le32(&power_regs->hw_power_vddioctrl, - POWER_VDDDCTRL_BO_OFFSET_MASK, - new_brownout << POWER_VDDDCTRL_BO_OFFSET_OFFSET); -} - -void mx28_power_set_vddd(uint32_t new_target, uint32_t new_brownout) -{ - struct mx28_power_regs *power_regs = - (struct mx28_power_regs *)MXS_POWER_BASE; - uint32_t cur_target, diff, bo_int = 0; - uint32_t powered_by_linreg = 0; - - new_brownout = new_target - new_brownout; - - cur_target = readl(&power_regs->hw_power_vdddctrl); - cur_target &= POWER_VDDDCTRL_TRG_MASK; - cur_target *= 25; /* 25 mV step*/ - cur_target += 800; /* 800 mV lowest */ - - powered_by_linreg = mx28_get_vddd_power_source_off(); - if (new_target > cur_target) { - if (powered_by_linreg) { - bo_int = readl(&power_regs->hw_power_vdddctrl); - clrbits_le32(&power_regs->hw_power_vdddctrl, - POWER_CTRL_ENIRQ_VDDD_BO); - } - - setbits_le32(&power_regs->hw_power_vdddctrl, - POWER_VDDDCTRL_BO_OFFSET_MASK); - - do { - if (new_target - cur_target > 100) - diff = cur_target + 100; - else - diff = new_target; - - diff -= 800; - diff /= 25; - - clrsetbits_le32(&power_regs->hw_power_vdddctrl, - POWER_VDDDCTRL_TRG_MASK, diff); - - if (powered_by_linreg || - (readl(&power_regs->hw_power_sts) & - POWER_STS_VDD5V_GT_VDDIO)) - early_delay(500); - else { - while (!(readl(&power_regs->hw_power_sts) & - POWER_STS_DC_OK)) - ; - - } - - cur_target = readl(&power_regs->hw_power_vdddctrl); - cur_target &= POWER_VDDDCTRL_TRG_MASK; - cur_target *= 25; /* 25 mV step*/ - cur_target += 800; /* 800 mV lowest */ - } while (new_target > cur_target); - - if (powered_by_linreg) { - writel(POWER_CTRL_VDDD_BO_IRQ, - &power_regs->hw_power_ctrl_clr); - if (bo_int & POWER_CTRL_ENIRQ_VDDD_BO) - setbits_le32(&power_regs->hw_power_vdddctrl, - POWER_CTRL_ENIRQ_VDDD_BO); - } - } else { - do { - if (cur_target - new_target > 100) - diff = cur_target - 100; - else - diff = new_target; - - diff -= 800; - diff /= 25; - - clrsetbits_le32(&power_regs->hw_power_vdddctrl, - POWER_VDDDCTRL_TRG_MASK, diff); - - if (powered_by_linreg || - (readl(&power_regs->hw_power_sts) & - POWER_STS_VDD5V_GT_VDDIO)) - early_delay(500); - else { - while (!(readl(&power_regs->hw_power_sts) & - POWER_STS_DC_OK)) - ; - - } - - cur_target = readl(&power_regs->hw_power_vdddctrl); - cur_target &= POWER_VDDDCTRL_TRG_MASK; - cur_target *= 25; /* 25 mV step*/ - cur_target += 800; /* 800 mV lowest */ - } while (new_target < cur_target); - } - - clrsetbits_le32(&power_regs->hw_power_vdddctrl, - POWER_VDDDCTRL_BO_OFFSET_MASK, - new_brownout << POWER_VDDDCTRL_BO_OFFSET_OFFSET); -} - -void mx28_setup_batt_detect(void) -{ - mx28_lradc_init(); - mx28_lradc_enable_batt_measurement(); - early_delay(10); -} - -void mx28_power_init(void) -{ - struct mx28_power_regs *power_regs = - (struct mx28_power_regs *)MXS_POWER_BASE; - - mx28_power_clock2xtal(); - mx28_power_clear_auto_restart(); - mx28_power_set_linreg(); - mx28_power_setup_5v_detect(); - - mx28_setup_batt_detect(); - - mx28_power_configure_power_source(); - mx28_enable_output_rail_protection(); - - mx28_power_set_vddio(3300, 3150); - - mx28_power_set_vddd(1350, 1200); - - writel(POWER_CTRL_VDDD_BO_IRQ | POWER_CTRL_VDDA_BO_IRQ | - POWER_CTRL_VDDIO_BO_IRQ | POWER_CTRL_VDD5V_DROOP_IRQ | - POWER_CTRL_VBUS_VALID_IRQ | POWER_CTRL_BATT_BO_IRQ | - POWER_CTRL_DCDC4P2_BO_IRQ, &power_regs->hw_power_ctrl_clr); - - writel(POWER_5VCTRL_PWDN_5VBRNOUT, &power_regs->hw_power_5vctrl_set); - - early_delay(1000); -} - -#ifdef CONFIG_SPL_MX28_PSWITCH_WAIT -void mx28_power_wait_pswitch(void) -{ - struct mx28_power_regs *power_regs = - (struct mx28_power_regs *)MXS_POWER_BASE; - - while (!(readl(&power_regs->hw_power_sts) & POWER_STS_PSWITCH_MASK)) - ; -} -#endif diff --git a/arch/arm/cpu/arm926ejs/mx28/start.S b/arch/arm/cpu/arm926ejs/mx28/start.S deleted file mode 100644 index e572b78..0000000 --- a/arch/arm/cpu/arm926ejs/mx28/start.S +++ /dev/null @@ -1,247 +0,0 @@ -/* - * armboot - Startup Code for ARM926EJS CPU-core - * - * Copyright (c) 2003 Texas Instruments - * - * ----- Adapted for OMAP1610 OMAP730 from ARM925t code ------ - * - * Copyright (c) 2001 Marius Groger mag@sysgo.de - * Copyright (c) 2002 Alex Zupke azu@sysgo.de - * Copyright (c) 2002 Gary Jennejohn garyj@denx.de - * Copyright (c) 2003 Richard Woodruff r-woodruff2@ti.com - * Copyright (c) 2003 Kshitij kshitij@ti.com - * Copyright (c) 2010 Albert Aribaud albert.u.boot@aribaud.net - * - * Change to support call back into iMX28 bootrom - * Copyright (c) 2011 Marek Vasut marek.vasut@gmail.com - * on behalf of DENX Software Engineering GmbH - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <asm-offsets.h> -#include <config.h> -#include <common.h> -#include <version.h> - -/* - ************************************************************************* - * - * Jump vector table as in table 3.1 in [1] - * - ************************************************************************* - */ - - -.globl _start -_start: - b reset - b undefined_instruction - b software_interrupt - b prefetch_abort - b data_abort - b not_used - b irq - b fiq - -/* - * Vector table, located at address 0x20. - * This table allows the code running AFTER SPL, the U-Boot, to install it's - * interrupt handlers here. The problem is that the U-Boot is loaded into RAM, - * including it's interrupt vectoring table and the table at 0x0 is still the - * SPLs. So if interrupt happens in U-Boot, the SPLs interrupt vectoring table - * is still used. - */ -_vt_reset: - .word _reset -_vt_undefined_instruction: - .word _hang -_vt_software_interrupt: - .word _hang -_vt_prefetch_abort: - .word _hang -_vt_data_abort: - .word _hang -_vt_not_used: - .word _reset -_vt_irq: - .word _hang -_vt_fiq: - .word _hang - -reset: - ldr pc, _vt_reset -undefined_instruction: - ldr pc, _vt_undefined_instruction -software_interrupt: - ldr pc, _vt_software_interrupt -prefetch_abort: - ldr pc, _vt_prefetch_abort -data_abort: - ldr pc, _vt_data_abort -not_used: - ldr pc, _vt_not_used -irq: - ldr pc, _vt_irq -fiq: - ldr pc, _vt_fiq - - .balignl 16,0xdeadbeef - -/* - ************************************************************************* - * - * Startup Code (reset vector) - * - * do important init only if we don't start from memory! - * setup Memory and board specific bits prior to relocation. - * relocate armboot to ram - * setup stack - * - ************************************************************************* - */ - -.globl _TEXT_BASE -_TEXT_BASE: - .word CONFIG_SYS_TEXT_BASE - -/* - * These are defined in the board-specific linker script. - * Subtracting _start from them lets the linker put their - * relative position in the executable instead of leaving - * them null. - */ -.globl _bss_start_ofs -_bss_start_ofs: - .word __bss_start - _start - -.globl _bss_end_ofs -_bss_end_ofs: - .word __bss_end__ - _start - -.globl _end_ofs -_end_ofs: - .word _end - _start - -#ifdef CONFIG_USE_IRQ -/* IRQ stack memory (calculated at run-time) */ -.globl IRQ_STACK_START -IRQ_STACK_START: - .word 0x0badc0de - -/* IRQ stack memory (calculated at run-time) */ -.globl FIQ_STACK_START -FIQ_STACK_START: - .word 0x0badc0de -#endif - -/* IRQ stack memory (calculated at run-time) + 8 bytes */ -.globl IRQ_STACK_START_IN -IRQ_STACK_START_IN: - .word 0x0badc0de - -/* - * the actual reset code - */ - -_reset: - /* - * Store all registers on old stack pointer, this will allow us later to - * return to the BootROM and let the BootROM load U-Boot into RAM. - */ - push {r0-r12,r14} - - /* save control register c1 */ - mrc p15, 0, r0, c1, c0, 0 - push {r0} - - /* - * set the cpu to SVC32 mode and store old CPSR register content - */ - mrs r0,cpsr - push {r0} - bic r0,r0,#0x1f - orr r0,r0,#0xd3 - msr cpsr,r0 - - /* - * we do sys-critical inits only at reboot, - * not when booting from ram! - */ -#ifndef CONFIG_SKIP_LOWLEVEL_INIT - bl cpu_init_crit -#endif - - bl board_init_ll - - /* - * restore bootrom's cpu mode (especially FIQ) - */ - pop {r0} - msr cpsr,r0 - - /* - * restore c1 register - * (especially set exception vector location back to - * bootrom space which is required by bootrom for USB boot) - */ - pop {r0} - mcr p15, 0, r0, c1, c0, 0 - - pop {r0-r12,r14} - bx lr - -/* - ************************************************************************* - * - * CPU_init_critical registers - * - * setup important registers - * setup memory timing - * - ************************************************************************* - */ -#ifndef CONFIG_SKIP_LOWLEVEL_INIT -cpu_init_crit: - /* - * flush v4 I/D caches - */ - mov r0, #0 - mcr p15, 0, r0, c7, c7, 0 /* flush v3/v4 cache */ - mcr p15, 0, r0, c8, c7, 0 /* flush v4 TLB */ - - /* - * disable MMU stuff and caches - */ - mrc p15, 0, r0, c1, c0, 0 - bic r0, r0, #0x00002300 /* clear bits 13, 9:8 (--V- --RS) */ - bic r0, r0, #0x00000087 /* clear bits 7, 2:0 (B--- -CAM) */ - orr r0, r0, #0x00000002 /* set bit 2 (A) Align */ - orr r0, r0, #0x00001000 /* set bit 12 (I) I-Cache */ - mcr p15, 0, r0, c1, c0, 0 - - mov pc, lr /* back to my caller */ - - .align 5 -#endif /* CONFIG_SKIP_LOWLEVEL_INIT */ - -_hang: - ldr sp, _TEXT_BASE /* switch to abort stack */ -1: - bl 1b /* hang and never return */ diff --git a/arch/arm/cpu/arm926ejs/mx28/timer.c b/arch/arm/cpu/arm926ejs/mx28/timer.c deleted file mode 100644 index 5b73f4a..0000000 --- a/arch/arm/cpu/arm926ejs/mx28/timer.c +++ /dev/null @@ -1,156 +0,0 @@ -/* - * Freescale i.MX28 timer driver - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * on behalf of DENX Software Engineering GmbH - * - * Based on code from LTIB: - * (C) Copyright 2009-2010 Freescale Semiconductor, Inc. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/io.h> -#include <asm/arch/imx-regs.h> -#include <asm/arch/sys_proto.h> - -/* Maximum fixed count */ -#define TIMER_LOAD_VAL 0xffffffff - -DECLARE_GLOBAL_DATA_PTR; - -#define timestamp (gd->tbl) -#define lastdec (gd->lastinc) - -/* - * This driver uses 1kHz clock source. - */ -#define MX28_INCREMENTER_HZ 1000 - -static inline unsigned long tick_to_time(unsigned long tick) -{ - return tick / (MX28_INCREMENTER_HZ / CONFIG_SYS_HZ); -} - -static inline unsigned long time_to_tick(unsigned long time) -{ - return time * (MX28_INCREMENTER_HZ / CONFIG_SYS_HZ); -} - -/* Calculate how many ticks happen in "us" microseconds */ -static inline unsigned long us_to_tick(unsigned long us) -{ - return (us * MX28_INCREMENTER_HZ) / 1000000; -} - -int timer_init(void) -{ - struct mx28_timrot_regs *timrot_regs = - (struct mx28_timrot_regs *)MXS_TIMROT_BASE; - - /* Reset Timers and Rotary Encoder module */ - mx28_reset_block(&timrot_regs->hw_timrot_rotctrl_reg); - - /* Set fixed_count to 0 */ - writel(0, &timrot_regs->hw_timrot_fixed_count0); - - /* Set UPDATE bit and 1Khz frequency */ - writel(TIMROT_TIMCTRLn_UPDATE | TIMROT_TIMCTRLn_RELOAD | - TIMROT_TIMCTRLn_SELECT_1KHZ_XTAL, - &timrot_regs->hw_timrot_timctrl0); - - /* Set fixed_count to maximal value */ - writel(TIMER_LOAD_VAL, &timrot_regs->hw_timrot_fixed_count0); - - return 0; -} - -unsigned long long get_ticks(void) -{ - struct mx28_timrot_regs *timrot_regs = - (struct mx28_timrot_regs *)MXS_TIMROT_BASE; - - /* Current tick value */ - uint32_t now = readl(&timrot_regs->hw_timrot_running_count0); - - if (lastdec >= now) { - /* - * normal mode (non roll) - * move stamp forward with absolut diff ticks - */ - timestamp += (lastdec - now); - } else { - /* we have rollover of decrementer */ - timestamp += (TIMER_LOAD_VAL - now) + lastdec; - - } - lastdec = now; - - return timestamp; -} - -ulong get_timer_masked(void) -{ - return tick_to_time(get_ticks()); -} - -ulong get_timer(ulong base) -{ - return get_timer_masked() - base; -} - -/* We use the HW_DIGCTL_MICROSECONDS register for sub-millisecond timer. */ -#define MX28_HW_DIGCTL_MICROSECONDS 0x8001c0c0 - -void __udelay(unsigned long usec) -{ - uint32_t old, new, incr; - uint32_t counter = 0; - - old = readl(MX28_HW_DIGCTL_MICROSECONDS); - - while (counter < usec) { - new = readl(MX28_HW_DIGCTL_MICROSECONDS); - - /* Check if the timer wrapped. */ - if (new < old) { - incr = 0xffffffff - old; - incr += new; - } else { - incr = new - old; - } - - /* - * Check if we are close to the maximum time and the counter - * would wrap if incremented. If that's the case, break out - * from the loop as the requested delay time passed. - */ - if (counter + incr < counter) - break; - - counter += incr; - old = new; - } -} - -ulong get_tbclk(void) -{ - return MX28_INCREMENTER_HZ; -} diff --git a/arch/arm/cpu/arm926ejs/mx28/u-boot-spl.lds b/arch/arm/cpu/arm926ejs/mx28/u-boot-spl.lds deleted file mode 100644 index 0fccd52..0000000 --- a/arch/arm/cpu/arm926ejs/mx28/u-boot-spl.lds +++ /dev/null @@ -1,87 +0,0 @@ -/* - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * on behalf of DENX Software Engineering GmbH - * - * January 2004 - Changed to support H4 device - * Copyright (c) 2004-2008 Texas Instruments - * - * (C) Copyright 2002 - * Gary Jennejohn, DENX Software Engineering, garyj@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") -OUTPUT_ARCH(arm) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - arch/arm/cpu/arm926ejs/mx28/start.o (.text) - *(.text) - } - - . = ALIGN(4); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } - - . = ALIGN(4); - .data : { - *(.data) - } - - . = ALIGN(4); - __u_boot_cmd_start = .; - .u_boot_cmd : { *(.u_boot_cmd) } - __u_boot_cmd_end = .; - - . = ALIGN(4); - - .rel.dyn : { - __rel_dyn_start = .; - *(.rel*) - __rel_dyn_end = .; - } - - .dynsym : { - __dynsym_start = .; - *(.dynsym) - } - - .bss : { - . = ALIGN(4); - __bss_start = .; - *(.bss*) - . = ALIGN(4); - __bss_end__ = .; - } - - _end = .; - - /DISCARD/ : { *(.dynstr*) } - /DISCARD/ : { *(.dynsym*) } - /DISCARD/ : { *(.dynamic*) } - /DISCARD/ : { *(.hash*) } - /DISCARD/ : { *(.plt*) } - /DISCARD/ : { *(.interp*) } - /DISCARD/ : { *(.gnu*) } -} diff --git a/arch/arm/cpu/arm926ejs/mxs/Makefile b/arch/arm/cpu/arm926ejs/mxs/Makefile new file mode 100644 index 0000000..674a3af --- /dev/null +++ b/arch/arm/cpu/arm926ejs/mxs/Makefile @@ -0,0 +1,50 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).o + +COBJS = clock.o mx28.o iomux.o timer.o + +ifdef CONFIG_SPL_BUILD +COBJS += spl_boot.o spl_lradc_init.o spl_mem_init.o spl_power_init.o +endif + +SRCS := $(START:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +START := $(addprefix $(obj),$(START)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/arch/arm/cpu/arm926ejs/mxs/clock.c b/arch/arm/cpu/arm926ejs/mxs/clock.c new file mode 100644 index 0000000..0439f9c --- /dev/null +++ b/arch/arm/cpu/arm926ejs/mxs/clock.c @@ -0,0 +1,339 @@ +/* + * Freescale i.MX28 clock setup code + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * Based on code from LTIB: + * Copyright (C) 2010 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/errno.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/imx-regs.h> + +/* The PLL frequency is always 480MHz, see section 10.2 in iMX28 datasheet. */ +#define PLL_FREQ_KHZ 480000 +#define PLL_FREQ_COEF 18 +/* The XTAL frequency is always 24MHz, see section 10.2 in iMX28 datasheet. */ +#define XTAL_FREQ_KHZ 24000 + +#define PLL_FREQ_MHZ (PLL_FREQ_KHZ / 1000) +#define XTAL_FREQ_MHZ (XTAL_FREQ_KHZ / 1000) + +static uint32_t mx28_get_pclk(void) +{ + struct mx28_clkctrl_regs *clkctrl_regs = + (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; + + uint32_t clkctrl, clkseq, div; + uint8_t clkfrac, frac; + + clkctrl = readl(&clkctrl_regs->hw_clkctrl_cpu); + + /* No support of fractional divider calculation */ + if (clkctrl & + (CLKCTRL_CPU_DIV_XTAL_FRAC_EN | CLKCTRL_CPU_DIV_CPU_FRAC_EN)) { + return 0; + } + + clkseq = readl(&clkctrl_regs->hw_clkctrl_clkseq); + + /* XTAL Path */ + if (clkseq & CLKCTRL_CLKSEQ_BYPASS_CPU) { + div = (clkctrl & CLKCTRL_CPU_DIV_XTAL_MASK) >> + CLKCTRL_CPU_DIV_XTAL_OFFSET; + return XTAL_FREQ_MHZ / div; + } + + /* REF Path */ + clkfrac = readb(&clkctrl_regs->hw_clkctrl_frac0[CLKCTRL_FRAC0_CPU]); + frac = clkfrac & CLKCTRL_FRAC_FRAC_MASK; + div = clkctrl & CLKCTRL_CPU_DIV_CPU_MASK; + return (PLL_FREQ_MHZ * PLL_FREQ_COEF / frac) / div; +} + +static uint32_t mx28_get_hclk(void) +{ + struct mx28_clkctrl_regs *clkctrl_regs = + (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; + + uint32_t div; + uint32_t clkctrl; + + clkctrl = readl(&clkctrl_regs->hw_clkctrl_hbus); + + /* No support of fractional divider calculation */ + if (clkctrl & CLKCTRL_HBUS_DIV_FRAC_EN) + return 0; + + div = clkctrl & CLKCTRL_HBUS_DIV_MASK; + return mx28_get_pclk() / div; +} + +static uint32_t mx28_get_emiclk(void) +{ + struct mx28_clkctrl_regs *clkctrl_regs = + (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; + + uint32_t clkctrl, clkseq, div; + uint8_t clkfrac, frac; + + clkseq = readl(&clkctrl_regs->hw_clkctrl_clkseq); + clkctrl = readl(&clkctrl_regs->hw_clkctrl_emi); + + /* XTAL Path */ + if (clkseq & CLKCTRL_CLKSEQ_BYPASS_EMI) { + div = (clkctrl & CLKCTRL_EMI_DIV_XTAL_MASK) >> + CLKCTRL_EMI_DIV_XTAL_OFFSET; + return XTAL_FREQ_MHZ / div; + } + + /* REF Path */ + clkfrac = readb(&clkctrl_regs->hw_clkctrl_frac0[CLKCTRL_FRAC0_EMI]); + frac = clkfrac & CLKCTRL_FRAC_FRAC_MASK; + div = clkctrl & CLKCTRL_EMI_DIV_EMI_MASK; + return (PLL_FREQ_MHZ * PLL_FREQ_COEF / frac) / div; +} + +static uint32_t mx28_get_gpmiclk(void) +{ + struct mx28_clkctrl_regs *clkctrl_regs = + (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; + + uint32_t clkctrl, clkseq, div; + uint8_t clkfrac, frac; + + clkseq = readl(&clkctrl_regs->hw_clkctrl_clkseq); + clkctrl = readl(&clkctrl_regs->hw_clkctrl_gpmi); + + /* XTAL Path */ + if (clkseq & CLKCTRL_CLKSEQ_BYPASS_GPMI) { + div = clkctrl & CLKCTRL_GPMI_DIV_MASK; + return XTAL_FREQ_MHZ / div; + } + + /* REF Path */ + clkfrac = readb(&clkctrl_regs->hw_clkctrl_frac1[CLKCTRL_FRAC1_GPMI]); + frac = clkfrac & CLKCTRL_FRAC_FRAC_MASK; + div = clkctrl & CLKCTRL_GPMI_DIV_MASK; + return (PLL_FREQ_MHZ * PLL_FREQ_COEF / frac) / div; +} + +/* + * Set IO clock frequency, in kHz + */ +void mx28_set_ioclk(enum mxs_ioclock io, uint32_t freq) +{ + struct mx28_clkctrl_regs *clkctrl_regs = + (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; + uint32_t div; + int io_reg; + + if (freq == 0) + return; + + if ((io < MXC_IOCLK0) || (io > MXC_IOCLK1)) + return; + + div = (PLL_FREQ_KHZ * PLL_FREQ_COEF) / freq; + + if (div < 18) + div = 18; + + if (div > 35) + div = 35; + + io_reg = CLKCTRL_FRAC0_IO0 - io; /* Register order is reversed */ + writeb(CLKCTRL_FRAC_CLKGATE, + &clkctrl_regs->hw_clkctrl_frac0_set[io_reg]); + writeb(CLKCTRL_FRAC_CLKGATE | (div & CLKCTRL_FRAC_FRAC_MASK), + &clkctrl_regs->hw_clkctrl_frac0[io_reg]); + writeb(CLKCTRL_FRAC_CLKGATE, + &clkctrl_regs->hw_clkctrl_frac0_clr[io_reg]); +} + +/* + * Get IO clock, returns IO clock in kHz + */ +static uint32_t mx28_get_ioclk(enum mxs_ioclock io) +{ + struct mx28_clkctrl_regs *clkctrl_regs = + (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; + uint8_t ret; + int io_reg; + + if ((io < MXC_IOCLK0) || (io > MXC_IOCLK1)) + return 0; + + io_reg = CLKCTRL_FRAC0_IO0 - io; /* Register order is reversed */ + + ret = readb(&clkctrl_regs->hw_clkctrl_frac0[io_reg]) & + CLKCTRL_FRAC_FRAC_MASK; + + return (PLL_FREQ_KHZ * PLL_FREQ_COEF) / ret; +} + +/* + * Configure SSP clock frequency, in kHz + */ +void mx28_set_sspclk(enum mxs_sspclock ssp, uint32_t freq, int xtal) +{ + struct mx28_clkctrl_regs *clkctrl_regs = + (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; + uint32_t clk, clkreg; + + if (ssp > MXC_SSPCLK3) + return; + + clkreg = (uint32_t)(&clkctrl_regs->hw_clkctrl_ssp0) + + (ssp * sizeof(struct mx28_register_32)); + + clrbits_le32(clkreg, CLKCTRL_SSP_CLKGATE); + while (readl(clkreg) & CLKCTRL_SSP_CLKGATE) + ; + + if (xtal) + clk = XTAL_FREQ_KHZ; + else + clk = mx28_get_ioclk(ssp >> 1); + + if (freq > clk) + return; + + /* Calculate the divider and cap it if necessary */ + clk /= freq; + if (clk > CLKCTRL_SSP_DIV_MASK) + clk = CLKCTRL_SSP_DIV_MASK; + + clrsetbits_le32(clkreg, CLKCTRL_SSP_DIV_MASK, clk); + while (readl(clkreg) & CLKCTRL_SSP_BUSY) + ; + + if (xtal) + writel(CLKCTRL_CLKSEQ_BYPASS_SSP0 << ssp, + &clkctrl_regs->hw_clkctrl_clkseq_set); + else + writel(CLKCTRL_CLKSEQ_BYPASS_SSP0 << ssp, + &clkctrl_regs->hw_clkctrl_clkseq_clr); +} + +/* + * Return SSP frequency, in kHz + */ +static uint32_t mx28_get_sspclk(enum mxs_sspclock ssp) +{ + struct mx28_clkctrl_regs *clkctrl_regs = + (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; + uint32_t clkreg; + uint32_t clk, tmp; + + if (ssp > MXC_SSPCLK3) + return 0; + + tmp = readl(&clkctrl_regs->hw_clkctrl_clkseq); + if (tmp & (CLKCTRL_CLKSEQ_BYPASS_SSP0 << ssp)) + return XTAL_FREQ_KHZ; + + clkreg = (uint32_t)(&clkctrl_regs->hw_clkctrl_ssp0) + + (ssp * sizeof(struct mx28_register_32)); + + tmp = readl(clkreg) & CLKCTRL_SSP_DIV_MASK; + + if (tmp == 0) + return 0; + + clk = mx28_get_ioclk(ssp >> 1); + + return clk / tmp; +} + +/* + * Set SSP/MMC bus frequency, in kHz) + */ +void mx28_set_ssp_busclock(unsigned int bus, uint32_t freq) +{ + struct mx28_ssp_regs *ssp_regs; + const uint32_t sspclk = mx28_get_sspclk(bus); + uint32_t reg; + uint32_t divide, rate, tgtclk; + + ssp_regs = (struct mx28_ssp_regs *)(MXS_SSP0_BASE + (bus * 0x2000)); + + /* + * SSP bit rate = SSPCLK / (CLOCK_DIVIDE * (1 + CLOCK_RATE)), + * CLOCK_DIVIDE has to be an even value from 2 to 254, and + * CLOCK_RATE could be any integer from 0 to 255. + */ + for (divide = 2; divide < 254; divide += 2) { + rate = sspclk / freq / divide; + if (rate <= 256) + break; + } + + tgtclk = sspclk / divide / rate; + while (tgtclk > freq) { + rate++; + tgtclk = sspclk / divide / rate; + } + if (rate > 256) + rate = 256; + + /* Always set timeout the maximum */ + reg = SSP_TIMING_TIMEOUT_MASK | + (divide << SSP_TIMING_CLOCK_DIVIDE_OFFSET) | + ((rate - 1) << SSP_TIMING_CLOCK_RATE_OFFSET); + writel(reg, &ssp_regs->hw_ssp_timing); + + debug("SPI%d: Set freq rate to %d KHz (requested %d KHz)\n", + bus, tgtclk, freq); +} + +uint32_t mxc_get_clock(enum mxc_clock clk) +{ + switch (clk) { + case MXC_ARM_CLK: + return mx28_get_pclk() * 1000000; + case MXC_GPMI_CLK: + return mx28_get_gpmiclk() * 1000000; + case MXC_AHB_CLK: + case MXC_IPG_CLK: + return mx28_get_hclk() * 1000000; + case MXC_EMI_CLK: + return mx28_get_emiclk(); + case MXC_IO0_CLK: + return mx28_get_ioclk(MXC_IOCLK0); + case MXC_IO1_CLK: + return mx28_get_ioclk(MXC_IOCLK1); + case MXC_SSP0_CLK: + return mx28_get_sspclk(MXC_SSPCLK0); + case MXC_SSP1_CLK: + return mx28_get_sspclk(MXC_SSPCLK1); + case MXC_SSP2_CLK: + return mx28_get_sspclk(MXC_SSPCLK2); + case MXC_SSP3_CLK: + return mx28_get_sspclk(MXC_SSPCLK3); + } + + return 0; +} diff --git a/arch/arm/cpu/arm926ejs/mxs/iomux.c b/arch/arm/cpu/arm926ejs/mxs/iomux.c new file mode 100644 index 0000000..12916b6 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/mxs/iomux.c @@ -0,0 +1,109 @@ +/* + * Copyright 2004-2006,2010 Freescale Semiconductor, Inc. All Rights Reserved. + * Copyright (C) 2008 by Sascha Hauer kernel@pengutronix.de + * Copyright (C) 2009 by Jan Weitzel Phytec Messtechnik GmbH, + * armlinux@phytec.de + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version 2 + * of the License, or (at your option) any later version. + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301, USA. + */ + +#include <common.h> +#include <asm/errno.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/iomux.h> +#include <asm/arch/imx-regs.h> + +#if defined(CONFIG_MX23) +#define DRIVE_OFFSET 0x200 +#define PULL_OFFSET 0x400 +#elif defined(CONFIG_MX28) +#define DRIVE_OFFSET 0x300 +#define PULL_OFFSET 0x600 +#else +#error "Please select CONFIG_MX23 or CONFIG_MX28" +#endif + +/* + * configures a single pad in the iomuxer + */ +int mxs_iomux_setup_pad(iomux_cfg_t pad) +{ + u32 reg, ofs, bp, bm; + void *iomux_base = (void *)MXS_PINCTRL_BASE; + struct mx28_register_32 *mxs_reg; + + /* muxsel */ + ofs = 0x100; + ofs += PAD_BANK(pad) * 0x20 + PAD_PIN(pad) / 16 * 0x10; + bp = PAD_PIN(pad) % 16 * 2; + bm = 0x3 << bp; + reg = readl(iomux_base + ofs); + reg &= ~bm; + reg |= PAD_MUXSEL(pad) << bp; + writel(reg, iomux_base + ofs); + + /* drive */ + ofs = DRIVE_OFFSET; + ofs += PAD_BANK(pad) * 0x40 + PAD_PIN(pad) / 8 * 0x10; + /* mA */ + if (PAD_MA_VALID(pad)) { + bp = PAD_PIN(pad) % 8 * 4; + bm = 0x3 << bp; + reg = readl(iomux_base + ofs); + reg &= ~bm; + reg |= PAD_MA(pad) << bp; + writel(reg, iomux_base + ofs); + } + /* vol */ + if (PAD_VOL_VALID(pad)) { + bp = PAD_PIN(pad) % 8 * 4 + 2; + mxs_reg = (struct mx28_register_32 *)(iomux_base + ofs); + if (PAD_VOL(pad)) + writel(1 << bp, &mxs_reg->reg_set); + else + writel(1 << bp, &mxs_reg->reg_clr); + } + + /* pull */ + if (PAD_PULL_VALID(pad)) { + ofs = PULL_OFFSET; + ofs += PAD_BANK(pad) * 0x10; + bp = PAD_PIN(pad); + mxs_reg = (struct mx28_register_32 *)(iomux_base + ofs); + if (PAD_PULL(pad)) + writel(1 << bp, &mxs_reg->reg_set); + else + writel(1 << bp, &mxs_reg->reg_clr); + } + + return 0; +} + +int mxs_iomux_setup_multiple_pads(const iomux_cfg_t *pad_list, unsigned count) +{ + const iomux_cfg_t *p = pad_list; + int i; + int ret; + + for (i = 0; i < count; i++) { + ret = mxs_iomux_setup_pad(*p); + if (ret) + return ret; + p++; + } + + return 0; +} diff --git a/arch/arm/cpu/arm926ejs/mxs/mx28.c b/arch/arm/cpu/arm926ejs/mxs/mx28.c new file mode 100644 index 0000000..a82ff25 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/mxs/mx28.c @@ -0,0 +1,310 @@ +/* + * Freescale i.MX28 common code + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * Based on code from LTIB: + * Copyright (C) 2010 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/errno.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/dma.h> +#include <asm/arch/gpio.h> +#include <asm/arch/iomux.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/sys_proto.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* 1 second delay should be plenty of time for block reset. */ +#define RESET_MAX_TIMEOUT 1000000 + +#define MX28_BLOCK_SFTRST (1 << 31) +#define MX28_BLOCK_CLKGATE (1 << 30) + +/* Lowlevel init isn't used on i.MX28, so just have a dummy here */ +inline void lowlevel_init(void) {} + +void reset_cpu(ulong ignored) __attribute__((noreturn)); + +void reset_cpu(ulong ignored) +{ + struct mx28_rtc_regs *rtc_regs = + (struct mx28_rtc_regs *)MXS_RTC_BASE; + struct mx28_lcdif_regs *lcdif_regs = + (struct mx28_lcdif_regs *)MXS_LCDIF_BASE; + + /* + * Shut down the LCD controller as it interferes with BootROM boot mode + * pads sampling. + */ + writel(LCDIF_CTRL_RUN, &lcdif_regs->hw_lcdif_ctrl_clr); + + /* Wait 1 uS before doing the actual watchdog reset */ + writel(1, &rtc_regs->hw_rtc_watchdog); + writel(RTC_CTRL_WATCHDOGEN, &rtc_regs->hw_rtc_ctrl_set); + + /* Endless loop, reset will exit from here */ + for (;;) + ; +} + +void enable_caches(void) +{ +#ifndef CONFIG_SYS_ICACHE_OFF + icache_enable(); +#endif +#ifndef CONFIG_SYS_DCACHE_OFF + dcache_enable(); +#endif +} + +int mx28_wait_mask_set(struct mx28_register_32 *reg, uint32_t mask, int timeout) +{ + while (--timeout) { + if ((readl(®->reg) & mask) == mask) + break; + udelay(1); + } + + return !timeout; +} + +int mx28_wait_mask_clr(struct mx28_register_32 *reg, uint32_t mask, int timeout) +{ + while (--timeout) { + if ((readl(®->reg) & mask) == 0) + break; + udelay(1); + } + + return !timeout; +} + +int mx28_reset_block(struct mx28_register_32 *reg) +{ + /* Clear SFTRST */ + writel(MX28_BLOCK_SFTRST, ®->reg_clr); + + if (mx28_wait_mask_clr(reg, MX28_BLOCK_SFTRST, RESET_MAX_TIMEOUT)) + return 1; + + /* Clear CLKGATE */ + writel(MX28_BLOCK_CLKGATE, ®->reg_clr); + + /* Set SFTRST */ + writel(MX28_BLOCK_SFTRST, ®->reg_set); + + /* Wait for CLKGATE being set */ + if (mx28_wait_mask_set(reg, MX28_BLOCK_CLKGATE, RESET_MAX_TIMEOUT)) + return 1; + + /* Clear SFTRST */ + writel(MX28_BLOCK_SFTRST, ®->reg_clr); + + if (mx28_wait_mask_clr(reg, MX28_BLOCK_SFTRST, RESET_MAX_TIMEOUT)) + return 1; + + /* Clear CLKGATE */ + writel(MX28_BLOCK_CLKGATE, ®->reg_clr); + + if (mx28_wait_mask_clr(reg, MX28_BLOCK_CLKGATE, RESET_MAX_TIMEOUT)) + return 1; + + return 0; +} + +void mx28_fixup_vt(uint32_t start_addr) +{ + uint32_t *vt = (uint32_t *)0x20; + int i; + + for (i = 0; i < 8; i++) + vt[i] = start_addr + (4 * i); +} + +#ifdef CONFIG_ARCH_MISC_INIT +int arch_misc_init(void) +{ + mx28_fixup_vt(gd->relocaddr); + return 0; +} +#endif + +#ifdef CONFIG_ARCH_CPU_INIT +int arch_cpu_init(void) +{ + struct mx28_clkctrl_regs *clkctrl_regs = + (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; + extern uint32_t _start; + + mx28_fixup_vt((uint32_t)&_start); + + /* + * Enable NAND clock + */ + /* Clear bypass bit */ + writel(CLKCTRL_CLKSEQ_BYPASS_GPMI, + &clkctrl_regs->hw_clkctrl_clkseq_set); + + /* Set GPMI clock to ref_gpmi / 12 */ + clrsetbits_le32(&clkctrl_regs->hw_clkctrl_gpmi, + CLKCTRL_GPMI_CLKGATE | CLKCTRL_GPMI_DIV_MASK, 1); + + udelay(1000); + + /* + * Configure GPIO unit + */ + mxs_gpio_init(); + +#ifdef CONFIG_APBH_DMA + /* Start APBH DMA */ + mxs_dma_init(); +#endif + + return 0; +} +#endif + +#if defined(CONFIG_DISPLAY_CPUINFO) +int print_cpuinfo(void) +{ + struct mx28_spl_data *data = (struct mx28_spl_data *) + ((CONFIG_SYS_TEXT_BASE - sizeof(struct mx28_spl_data)) & ~0xf); + + printf("Freescale i.MX28 family at %d MHz\n", + mxc_get_clock(MXC_ARM_CLK) / 1000000); + printf("BOOT: %s\n", mx28_boot_modes[data->boot_mode_idx].mode); + return 0; +} +#endif + +int do_mx28_showclocks(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + printf("CPU: %3d MHz\n", mxc_get_clock(MXC_ARM_CLK) / 1000000); + printf("BUS: %3d MHz\n", mxc_get_clock(MXC_AHB_CLK) / 1000000); + printf("EMI: %3d MHz\n", mxc_get_clock(MXC_EMI_CLK)); + printf("GPMI: %3d MHz\n", mxc_get_clock(MXC_GPMI_CLK) / 1000000); + return 0; +} + +/* + * Initializes on-chip ethernet controllers. + */ +#ifdef CONFIG_CMD_NET +int cpu_eth_init(bd_t *bis) +{ + struct mx28_clkctrl_regs *clkctrl_regs = + (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; + + /* Turn on ENET clocks */ + clrbits_le32(&clkctrl_regs->hw_clkctrl_enet, + CLKCTRL_ENET_SLEEP | CLKCTRL_ENET_DISABLE); + + /* Set up ENET PLL for 50 MHz */ + /* Power on ENET PLL */ + writel(CLKCTRL_PLL2CTRL0_POWER, + &clkctrl_regs->hw_clkctrl_pll2ctrl0_set); + + udelay(10); + + /* Gate on ENET PLL */ + writel(CLKCTRL_PLL2CTRL0_CLKGATE, + &clkctrl_regs->hw_clkctrl_pll2ctrl0_clr); + + /* Enable pad output */ + setbits_le32(&clkctrl_regs->hw_clkctrl_enet, CLKCTRL_ENET_CLK_OUT_EN); + + return 0; +} +#endif + +static void __mx28_adjust_mac(int dev_id, unsigned char *mac) +{ + mac[0] = 0x00; + mac[1] = 0x04; /* Use FSL vendor MAC address by default */ + + if (dev_id == 1) /* Let MAC1 be MAC0 + 1 by default */ + mac[5] += 1; +} + +void mx28_adjust_mac(int dev_id, unsigned char *mac) + __attribute__((weak, alias("__mx28_adjust_mac"))); + +#ifdef CONFIG_MX28_FEC_MAC_IN_OCOTP + +#define MXS_OCOTP_MAX_TIMEOUT 1000000 +void imx_get_mac_from_fuse(int dev_id, unsigned char *mac) +{ + struct mx28_ocotp_regs *ocotp_regs = + (struct mx28_ocotp_regs *)MXS_OCOTP_BASE; + uint32_t data; + + memset(mac, 0, 6); + + writel(OCOTP_CTRL_RD_BANK_OPEN, &ocotp_regs->hw_ocotp_ctrl_set); + + if (mx28_wait_mask_clr(&ocotp_regs->hw_ocotp_ctrl_reg, OCOTP_CTRL_BUSY, + MXS_OCOTP_MAX_TIMEOUT)) { + printf("MXS FEC: Can't get MAC from OCOTP\n"); + return; + } + + data = readl(&ocotp_regs->hw_ocotp_cust0); + + mac[2] = (data >> 24) & 0xff; + mac[3] = (data >> 16) & 0xff; + mac[4] = (data >> 8) & 0xff; + mac[5] = data & 0xff; + mx28_adjust_mac(dev_id, mac); +} +#else +void imx_get_mac_from_fuse(int dev_id, unsigned char *mac) +{ + memset(mac, 0, 6); +} +#endif + +int mx28_dram_init(void) +{ + struct mx28_spl_data *data = (struct mx28_spl_data *) + ((CONFIG_SYS_TEXT_BASE - sizeof(struct mx28_spl_data)) & ~0xf); + + if (data->mem_dram_size == 0) { + printf("MX28:\n" + "Error, the RAM size passed up from SPL is 0!\n"); + hang(); + } + + gd->ram_size = data->mem_dram_size; + return 0; +} + +U_BOOT_CMD( + clocks, CONFIG_SYS_MAXARGS, 1, do_mx28_showclocks, + "display clocks", + "" +); diff --git a/arch/arm/cpu/arm926ejs/mxs/mx28_init.h b/arch/arm/cpu/arm926ejs/mxs/mx28_init.h new file mode 100644 index 0000000..e3a4493 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/mxs/mx28_init.h @@ -0,0 +1,45 @@ +/* + * Freescale i.MX28 SPL functions + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __M28_INIT_H__ +#define __M28_INIT_H__ + +void early_delay(int delay); + +void mx28_power_init(void); + +#ifdef CONFIG_SPL_MX28_PSWITCH_WAIT +void mx28_power_wait_pswitch(void); +#else +static inline void mx28_power_wait_pswitch(void) { } +#endif + +void mx28_mem_init(void); +uint32_t mx28_mem_get_size(void); + +void mx28_lradc_init(void); +void mx28_lradc_enable_batt_measurement(void); + +#endif /* __M28_INIT_H__ */ diff --git a/arch/arm/cpu/arm926ejs/mxs/spl_boot.c b/arch/arm/cpu/arm926ejs/mxs/spl_boot.c new file mode 100644 index 0000000..a6dfca3 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/mxs/spl_boot.c @@ -0,0 +1,135 @@ +/* + * Freescale i.MX28 Boot setup + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <config.h> +#include <asm/io.h> +#include <asm/arch/iomux-mx28.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> + +#include "mx28_init.h" + +/* + * This delay function is intended to be used only in early stage of boot, where + * clock are not set up yet. The timer used here is reset on every boot and + * takes a few seconds to roll. The boot doesn't take that long, so to keep the + * code simple, it doesn't take rolling into consideration. + */ +#define HW_DIGCTRL_MICROSECONDS 0x8001c0c0 +void early_delay(int delay) +{ + uint32_t st = readl(HW_DIGCTRL_MICROSECONDS); + st += delay; + while (st > readl(HW_DIGCTRL_MICROSECONDS)) + ; +} + +#define MUX_CONFIG_BOOTMODE_PAD (MXS_PAD_3V3 | MXS_PAD_4MA | MXS_PAD_NOPULL) +const iomux_cfg_t iomux_boot[] = { + MX28_PAD_LCD_D00__GPIO_1_0 | MUX_CONFIG_BOOTMODE_PAD, + MX28_PAD_LCD_D01__GPIO_1_1 | MUX_CONFIG_BOOTMODE_PAD, + MX28_PAD_LCD_D02__GPIO_1_2 | MUX_CONFIG_BOOTMODE_PAD, + MX28_PAD_LCD_D03__GPIO_1_3 | MUX_CONFIG_BOOTMODE_PAD, + MX28_PAD_LCD_D04__GPIO_1_4 | MUX_CONFIG_BOOTMODE_PAD, + MX28_PAD_LCD_D05__GPIO_1_5 | MUX_CONFIG_BOOTMODE_PAD, +}; + +uint8_t mx28_get_bootmode_index(void) +{ + uint8_t bootmode = 0; + int i; + uint8_t masked; + + /* Setup IOMUX of bootmode pads to GPIO */ + mxs_iomux_setup_multiple_pads(iomux_boot, ARRAY_SIZE(iomux_boot)); + + /* Setup bootmode pins as GPIO input */ + gpio_direction_input(MX28_PAD_LCD_D00__GPIO_1_0); + gpio_direction_input(MX28_PAD_LCD_D01__GPIO_1_1); + gpio_direction_input(MX28_PAD_LCD_D02__GPIO_1_2); + gpio_direction_input(MX28_PAD_LCD_D03__GPIO_1_3); + gpio_direction_input(MX28_PAD_LCD_D04__GPIO_1_4); + gpio_direction_input(MX28_PAD_LCD_D05__GPIO_1_5); + + /* Read bootmode pads */ + bootmode |= (gpio_get_value(MX28_PAD_LCD_D00__GPIO_1_0) ? 1 : 0) << 0; + bootmode |= (gpio_get_value(MX28_PAD_LCD_D01__GPIO_1_1) ? 1 : 0) << 1; + bootmode |= (gpio_get_value(MX28_PAD_LCD_D02__GPIO_1_2) ? 1 : 0) << 2; + bootmode |= (gpio_get_value(MX28_PAD_LCD_D03__GPIO_1_3) ? 1 : 0) << 3; + bootmode |= (gpio_get_value(MX28_PAD_LCD_D04__GPIO_1_4) ? 1 : 0) << 4; + bootmode |= (gpio_get_value(MX28_PAD_LCD_D05__GPIO_1_5) ? 1 : 0) << 5; + + for (i = 0; i < ARRAY_SIZE(mx28_boot_modes); i++) { + masked = bootmode & mx28_boot_modes[i].boot_mask; + if (masked == mx28_boot_modes[i].boot_pads) + break; + } + + return i; +} + +void mx28_common_spl_init(const iomux_cfg_t *iomux_setup, + const unsigned int iomux_size) +{ + struct mx28_spl_data *data = (struct mx28_spl_data *) + ((CONFIG_SYS_TEXT_BASE - sizeof(struct mx28_spl_data)) & ~0xf); + uint8_t bootmode = mx28_get_bootmode_index(); + + mxs_iomux_setup_multiple_pads(iomux_setup, iomux_size); + mx28_power_init(); + + mx28_mem_init(); + data->mem_dram_size = mx28_mem_get_size(); + + data->boot_mode_idx = bootmode; + + mx28_power_wait_pswitch(); +} + +/* Support aparatus */ +inline void board_init_f(unsigned long bootflag) +{ + for (;;) + ; +} + +inline void board_init_r(gd_t *id, ulong dest_addr) +{ + for (;;) + ; +} + +#ifndef CONFIG_SPL_SERIAL_SUPPORT +void serial_putc(const char c) {} +void serial_puts(const char *s) {} +#endif +void hang(void) __attribute__ ((noreturn)); +void hang(void) +{ + for (;;) + ; +} diff --git a/arch/arm/cpu/arm926ejs/mxs/spl_mem_init.c b/arch/arm/cpu/arm926ejs/mxs/spl_mem_init.c new file mode 100644 index 0000000..9fa5d29 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/mxs/spl_mem_init.c @@ -0,0 +1,242 @@ +/* + * Freescale i.MX28 RAM init + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <config.h> +#include <asm/io.h> +#include <asm/arch/iomux-mx28.h> +#include <asm/arch/imx-regs.h> + +#include "mx28_init.h" + +uint32_t dram_vals[] = { + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000100, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00010101, 0x01010101, + 0x000f0f01, 0x0f02020a, 0x00000000, 0x00010101, + 0x00000100, 0x00000100, 0x00000000, 0x00000002, + 0x01010000, 0x05060302, 0x06005003, 0x0a0000c8, + 0x02009c40, 0x0000030c, 0x0036a609, 0x031a0612, + 0x02030202, 0x00c8001c, 0x00000000, 0x00000000, + 0x00012100, 0xffff0303, 0x00012100, 0xffff0303, + 0x00012100, 0xffff0303, 0x00012100, 0xffff0303, + 0x00000003, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000612, 0x01000F02, + 0x06120612, 0x00000200, 0x00020007, 0xf5014b27, + 0xf5014b27, 0xf5014b27, 0xf5014b27, 0x07000300, + 0x07000300, 0x07000300, 0x07000300, 0x00000006, + 0x00000000, 0x00000000, 0x01000000, 0x01020408, + 0x08040201, 0x000f1133, 0x00000000, 0x00001f04, + 0x00001f04, 0x00001f04, 0x00001f04, 0x00001f04, + 0x00001f04, 0x00001f04, 0x00001f04, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00010000, 0x00020304, + 0x00000004, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x01010000, + 0x01000000, 0x03030000, 0x00010303, 0x01020202, + 0x00000000, 0x02040303, 0x21002103, 0x00061200, + 0x06120612, 0x04320432, 0x04320432, 0x00040004, + 0x00040004, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00010001 +}; + +void init_m28_200mhz_ddr2(void) +{ + int i; + + for (i = 0; i < ARRAY_SIZE(dram_vals); i++) + writel(dram_vals[i], MXS_DRAM_BASE + (4 * i)); +} + +void mx28_mem_init_clock(void) +{ + struct mx28_clkctrl_regs *clkctrl_regs = + (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; + + /* Gate EMI clock */ + writeb(CLKCTRL_FRAC_CLKGATE, + &clkctrl_regs->hw_clkctrl_frac0_set[CLKCTRL_FRAC0_EMI]); + + /* Set fractional divider for ref_emi to 480 * 18 / 21 = 411MHz */ + writeb(CLKCTRL_FRAC_CLKGATE | (21 & CLKCTRL_FRAC_FRAC_MASK), + &clkctrl_regs->hw_clkctrl_frac0[CLKCTRL_FRAC0_EMI]); + + /* Ungate EMI clock */ + writeb(CLKCTRL_FRAC_CLKGATE, + &clkctrl_regs->hw_clkctrl_frac0_clr[CLKCTRL_FRAC0_EMI]); + + early_delay(11000); + + /* Set EMI clock divider for EMI clock to 411 / 2 = 205MHz */ + writel((2 << CLKCTRL_EMI_DIV_EMI_OFFSET) | + (1 << CLKCTRL_EMI_DIV_XTAL_OFFSET), + &clkctrl_regs->hw_clkctrl_emi); + + /* Unbypass EMI */ + writel(CLKCTRL_CLKSEQ_BYPASS_EMI, + &clkctrl_regs->hw_clkctrl_clkseq_clr); + + early_delay(10000); +} + +void mx28_mem_setup_cpu_and_hbus(void) +{ + struct mx28_clkctrl_regs *clkctrl_regs = + (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; + + /* Set fractional divider for ref_cpu to 480 * 18 / 19 = 454MHz + * and ungate CPU clock */ + writeb(19 & CLKCTRL_FRAC_FRAC_MASK, + (uint8_t *)&clkctrl_regs->hw_clkctrl_frac0[CLKCTRL_FRAC0_CPU]); + + /* Set CPU bypass */ + writel(CLKCTRL_CLKSEQ_BYPASS_CPU, + &clkctrl_regs->hw_clkctrl_clkseq_set); + + /* HBUS = 151MHz */ + writel(CLKCTRL_HBUS_DIV_MASK, &clkctrl_regs->hw_clkctrl_hbus_set); + writel(((~3) << CLKCTRL_HBUS_DIV_OFFSET) & CLKCTRL_HBUS_DIV_MASK, + &clkctrl_regs->hw_clkctrl_hbus_clr); + + early_delay(10000); + + /* CPU clock divider = 1 */ + clrsetbits_le32(&clkctrl_regs->hw_clkctrl_cpu, + CLKCTRL_CPU_DIV_CPU_MASK, 1); + + /* Disable CPU bypass */ + writel(CLKCTRL_CLKSEQ_BYPASS_CPU, + &clkctrl_regs->hw_clkctrl_clkseq_clr); + + early_delay(15000); +} + +void mx28_mem_setup_vdda(void) +{ + struct mx28_power_regs *power_regs = + (struct mx28_power_regs *)MXS_POWER_BASE; + + writel((0xc << POWER_VDDACTRL_TRG_OFFSET) | + (0x7 << POWER_VDDACTRL_BO_OFFSET_OFFSET) | + POWER_VDDACTRL_LINREG_OFFSET_1STEPS_BELOW, + &power_regs->hw_power_vddactrl); +} + +void mx28_mem_setup_vddd(void) +{ + struct mx28_power_regs *power_regs = + (struct mx28_power_regs *)MXS_POWER_BASE; + + writel((0x1c << POWER_VDDDCTRL_TRG_OFFSET) | + (0x7 << POWER_VDDDCTRL_BO_OFFSET_OFFSET) | + POWER_VDDDCTRL_LINREG_OFFSET_1STEPS_BELOW, + &power_regs->hw_power_vdddctrl); +} + +uint32_t mx28_mem_get_size(void) +{ + uint32_t sz, da; + uint32_t *vt = (uint32_t *)0x20; + /* The following is "subs pc, r14, #4", used as return from DABT. */ + const uint32_t data_abort_memdetect_handler = 0xe25ef004; + + /* Replace the DABT handler. */ + da = vt[4]; + vt[4] = data_abort_memdetect_handler; + + sz = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE); + + /* Restore the old DABT handler. */ + vt[4] = da; + + return sz; +} + +void mx28_mem_init(void) +{ + struct mx28_clkctrl_regs *clkctrl_regs = + (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; + struct mx28_pinctrl_regs *pinctrl_regs = + (struct mx28_pinctrl_regs *)MXS_PINCTRL_BASE; + + /* Set DDR2 mode */ + writel(PINCTRL_EMI_DS_CTRL_DDR_MODE_DDR2, + &pinctrl_regs->hw_pinctrl_emi_ds_ctrl_set); + + /* Power up PLL0 */ + writel(CLKCTRL_PLL0CTRL0_POWER, + &clkctrl_regs->hw_clkctrl_pll0ctrl0_set); + + early_delay(11000); + + mx28_mem_init_clock(); + + mx28_mem_setup_vdda(); + + /* + * Configure the DRAM registers + */ + + /* Clear START bit from DRAM_CTL16 */ + clrbits_le32(MXS_DRAM_BASE + 0x40, 1); + + init_m28_200mhz_ddr2(); + + /* Clear SREFRESH bit from DRAM_CTL17 */ + clrbits_le32(MXS_DRAM_BASE + 0x44, 1); + + /* Set START bit in DRAM_CTL16 */ + setbits_le32(MXS_DRAM_BASE + 0x40, 1); + + /* Wait for bit 20 (DRAM init complete) in DRAM_CTL58 */ + while (!(readl(MXS_DRAM_BASE + 0xe8) & (1 << 20))) + ; + + mx28_mem_setup_vddd(); + + early_delay(10000); + + mx28_mem_setup_cpu_and_hbus(); +} diff --git a/arch/arm/cpu/arm926ejs/mxs/spl_power_init.c b/arch/arm/cpu/arm926ejs/mxs/spl_power_init.c new file mode 100644 index 0000000..4b09b0c --- /dev/null +++ b/arch/arm/cpu/arm926ejs/mxs/spl_power_init.c @@ -0,0 +1,1007 @@ +/* + * Freescale i.MX28 Boot PMIC init + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <config.h> +#include <asm/io.h> +#include <asm/arch/imx-regs.h> + +#include "mx28_init.h" + +void mx28_power_clock2xtal(void) +{ + struct mx28_clkctrl_regs *clkctrl_regs = + (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; + + /* Set XTAL as CPU reference clock */ + writel(CLKCTRL_CLKSEQ_BYPASS_CPU, + &clkctrl_regs->hw_clkctrl_clkseq_set); +} + +void mx28_power_clock2pll(void) +{ + struct mx28_clkctrl_regs *clkctrl_regs = + (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; + + setbits_le32(&clkctrl_regs->hw_clkctrl_pll0ctrl0, + CLKCTRL_PLL0CTRL0_POWER); + early_delay(100); + setbits_le32(&clkctrl_regs->hw_clkctrl_clkseq, + CLKCTRL_CLKSEQ_BYPASS_CPU); +} + +void mx28_power_clear_auto_restart(void) +{ + struct mx28_rtc_regs *rtc_regs = + (struct mx28_rtc_regs *)MXS_RTC_BASE; + + writel(RTC_CTRL_SFTRST, &rtc_regs->hw_rtc_ctrl_clr); + while (readl(&rtc_regs->hw_rtc_ctrl) & RTC_CTRL_SFTRST) + ; + + writel(RTC_CTRL_CLKGATE, &rtc_regs->hw_rtc_ctrl_clr); + while (readl(&rtc_regs->hw_rtc_ctrl) & RTC_CTRL_CLKGATE) + ; + + /* + * Due to the hardware design bug of mx28 EVK-A + * we need to set the AUTO_RESTART bit. + */ + if (readl(&rtc_regs->hw_rtc_persistent0) & RTC_PERSISTENT0_AUTO_RESTART) + return; + + while (readl(&rtc_regs->hw_rtc_stat) & RTC_STAT_NEW_REGS_MASK) + ; + + setbits_le32(&rtc_regs->hw_rtc_persistent0, + RTC_PERSISTENT0_AUTO_RESTART); + writel(RTC_CTRL_FORCE_UPDATE, &rtc_regs->hw_rtc_ctrl_set); + writel(RTC_CTRL_FORCE_UPDATE, &rtc_regs->hw_rtc_ctrl_clr); + while (readl(&rtc_regs->hw_rtc_stat) & RTC_STAT_NEW_REGS_MASK) + ; + while (readl(&rtc_regs->hw_rtc_stat) & RTC_STAT_STALE_REGS_MASK) + ; +} + +void mx28_power_set_linreg(void) +{ + struct mx28_power_regs *power_regs = + (struct mx28_power_regs *)MXS_POWER_BASE; + + /* Set linear regulator 25mV below switching converter */ + clrsetbits_le32(&power_regs->hw_power_vdddctrl, + POWER_VDDDCTRL_LINREG_OFFSET_MASK, + POWER_VDDDCTRL_LINREG_OFFSET_1STEPS_BELOW); + + clrsetbits_le32(&power_regs->hw_power_vddactrl, + POWER_VDDACTRL_LINREG_OFFSET_MASK, + POWER_VDDACTRL_LINREG_OFFSET_1STEPS_BELOW); + + clrsetbits_le32(&power_regs->hw_power_vddioctrl, + POWER_VDDIOCTRL_LINREG_OFFSET_MASK, + POWER_VDDIOCTRL_LINREG_OFFSET_1STEPS_BELOW); +} + +int mx28_get_batt_volt(void) +{ + struct mx28_power_regs *power_regs = + (struct mx28_power_regs *)MXS_POWER_BASE; + uint32_t volt = readl(&power_regs->hw_power_battmonitor); + volt &= POWER_BATTMONITOR_BATT_VAL_MASK; + volt >>= POWER_BATTMONITOR_BATT_VAL_OFFSET; + volt *= 8; + return volt; +} + +int mx28_is_batt_ready(void) +{ + return (mx28_get_batt_volt() >= 3600); +} + +int mx28_is_batt_good(void) +{ + struct mx28_power_regs *power_regs = + (struct mx28_power_regs *)MXS_POWER_BASE; + uint32_t volt = mx28_get_batt_volt(); + + if ((volt >= 2400) && (volt <= 4300)) + return 1; + + clrsetbits_le32(&power_regs->hw_power_5vctrl, + POWER_5VCTRL_CHARGE_4P2_ILIMIT_MASK, + 0x3 << POWER_5VCTRL_CHARGE_4P2_ILIMIT_OFFSET); + writel(POWER_5VCTRL_PWD_CHARGE_4P2_MASK, + &power_regs->hw_power_5vctrl_clr); + + clrsetbits_le32(&power_regs->hw_power_charge, + POWER_CHARGE_STOP_ILIMIT_MASK | POWER_CHARGE_BATTCHRG_I_MASK, + POWER_CHARGE_STOP_ILIMIT_10MA | 0x3); + + writel(POWER_CHARGE_PWD_BATTCHRG, &power_regs->hw_power_charge_clr); + writel(POWER_5VCTRL_PWD_CHARGE_4P2_MASK, + &power_regs->hw_power_5vctrl_clr); + + early_delay(500000); + + volt = mx28_get_batt_volt(); + + if (volt >= 3500) + return 0; + + if (volt >= 2400) + return 1; + + writel(POWER_CHARGE_STOP_ILIMIT_MASK | POWER_CHARGE_BATTCHRG_I_MASK, + &power_regs->hw_power_charge_clr); + writel(POWER_CHARGE_PWD_BATTCHRG, &power_regs->hw_power_charge_set); + + return 0; +} + +void mx28_power_setup_5v_detect(void) +{ + struct mx28_power_regs *power_regs = + (struct mx28_power_regs *)MXS_POWER_BASE; + + /* Start 5V detection */ + clrsetbits_le32(&power_regs->hw_power_5vctrl, + POWER_5VCTRL_VBUSVALID_TRSH_MASK, + POWER_5VCTRL_VBUSVALID_TRSH_4V4 | + POWER_5VCTRL_PWRUP_VBUS_CMPS); +} + +void mx28_src_power_init(void) +{ + struct mx28_power_regs *power_regs = + (struct mx28_power_regs *)MXS_POWER_BASE; + + /* Improve efficieny and reduce transient ripple */ + writel(POWER_LOOPCTRL_TOGGLE_DIF | POWER_LOOPCTRL_EN_CM_HYST | + POWER_LOOPCTRL_EN_DF_HYST, &power_regs->hw_power_loopctrl_set); + + clrsetbits_le32(&power_regs->hw_power_dclimits, + POWER_DCLIMITS_POSLIMIT_BUCK_MASK, + 0x30 << POWER_DCLIMITS_POSLIMIT_BUCK_OFFSET); + + setbits_le32(&power_regs->hw_power_battmonitor, + POWER_BATTMONITOR_EN_BATADJ); + + /* Increase the RCSCALE level for quick DCDC response to dynamic load */ + clrsetbits_le32(&power_regs->hw_power_loopctrl, + POWER_LOOPCTRL_EN_RCSCALE_MASK, + POWER_LOOPCTRL_RCSCALE_THRESH | + POWER_LOOPCTRL_EN_RCSCALE_8X); + + clrsetbits_le32(&power_regs->hw_power_minpwr, + POWER_MINPWR_HALFFETS, POWER_MINPWR_DOUBLE_FETS); + + /* 5V to battery handoff ... FIXME */ + setbits_le32(&power_regs->hw_power_5vctrl, POWER_5VCTRL_DCDC_XFER); + early_delay(30); + clrbits_le32(&power_regs->hw_power_5vctrl, POWER_5VCTRL_DCDC_XFER); +} + +void mx28_power_init_4p2_params(void) +{ + struct mx28_power_regs *power_regs = + (struct mx28_power_regs *)MXS_POWER_BASE; + + /* Setup 4P2 parameters */ + clrsetbits_le32(&power_regs->hw_power_dcdc4p2, + POWER_DCDC4P2_CMPTRIP_MASK | POWER_DCDC4P2_TRG_MASK, + POWER_DCDC4P2_TRG_4V2 | (31 << POWER_DCDC4P2_CMPTRIP_OFFSET)); + + clrsetbits_le32(&power_regs->hw_power_5vctrl, + POWER_5VCTRL_HEADROOM_ADJ_MASK, + 0x4 << POWER_5VCTRL_HEADROOM_ADJ_OFFSET); + + clrsetbits_le32(&power_regs->hw_power_dcdc4p2, + POWER_DCDC4P2_DROPOUT_CTRL_MASK, + POWER_DCDC4P2_DROPOUT_CTRL_100MV | + POWER_DCDC4P2_DROPOUT_CTRL_SRC_SEL); + + clrsetbits_le32(&power_regs->hw_power_5vctrl, + POWER_5VCTRL_CHARGE_4P2_ILIMIT_MASK, + 0x3f << POWER_5VCTRL_CHARGE_4P2_ILIMIT_OFFSET); +} + +void mx28_enable_4p2_dcdc_input(int xfer) +{ + struct mx28_power_regs *power_regs = + (struct mx28_power_regs *)MXS_POWER_BASE; + uint32_t tmp, vbus_thresh, vbus_5vdetect, pwd_bo; + uint32_t prev_5v_brnout, prev_5v_droop; + + prev_5v_brnout = readl(&power_regs->hw_power_5vctrl) & + POWER_5VCTRL_PWDN_5VBRNOUT; + prev_5v_droop = readl(&power_regs->hw_power_ctrl) & + POWER_CTRL_ENIRQ_VDD5V_DROOP; + + clrbits_le32(&power_regs->hw_power_5vctrl, POWER_5VCTRL_PWDN_5VBRNOUT); + writel(POWER_RESET_UNLOCK_KEY | POWER_RESET_PWD_OFF, + &power_regs->hw_power_reset); + + clrbits_le32(&power_regs->hw_power_ctrl, POWER_CTRL_ENIRQ_VDD5V_DROOP); + + if (xfer && (readl(&power_regs->hw_power_5vctrl) & + POWER_5VCTRL_ENABLE_DCDC)) { + return; + } + + /* + * Recording orignal values that will be modified temporarlily + * to handle a chip bug. See chip errata for CQ ENGR00115837 + */ + tmp = readl(&power_regs->hw_power_5vctrl); + vbus_thresh = tmp & POWER_5VCTRL_VBUSVALID_TRSH_MASK; + vbus_5vdetect = tmp & POWER_5VCTRL_VBUSVALID_5VDETECT; + + pwd_bo = readl(&power_regs->hw_power_minpwr) & POWER_MINPWR_PWD_BO; + + /* + * Disable mechanisms that get erroneously tripped by when setting + * the DCDC4P2 EN_DCDC + */ + clrbits_le32(&power_regs->hw_power_5vctrl, + POWER_5VCTRL_VBUSVALID_5VDETECT | + POWER_5VCTRL_VBUSVALID_TRSH_MASK); + + writel(POWER_MINPWR_PWD_BO, &power_regs->hw_power_minpwr_set); + + if (xfer) { + setbits_le32(&power_regs->hw_power_5vctrl, + POWER_5VCTRL_DCDC_XFER); + early_delay(20); + clrbits_le32(&power_regs->hw_power_5vctrl, + POWER_5VCTRL_DCDC_XFER); + + setbits_le32(&power_regs->hw_power_5vctrl, + POWER_5VCTRL_ENABLE_DCDC); + } else { + setbits_le32(&power_regs->hw_power_dcdc4p2, + POWER_DCDC4P2_ENABLE_DCDC); + } + + early_delay(25); + + clrsetbits_le32(&power_regs->hw_power_5vctrl, + POWER_5VCTRL_VBUSVALID_TRSH_MASK, vbus_thresh); + + if (vbus_5vdetect) + writel(vbus_5vdetect, &power_regs->hw_power_5vctrl_set); + + if (!pwd_bo) + clrbits_le32(&power_regs->hw_power_minpwr, POWER_MINPWR_PWD_BO); + + while (readl(&power_regs->hw_power_ctrl) & POWER_CTRL_VBUS_VALID_IRQ) + writel(POWER_CTRL_VBUS_VALID_IRQ, + &power_regs->hw_power_ctrl_clr); + + if (prev_5v_brnout) { + writel(POWER_5VCTRL_PWDN_5VBRNOUT, + &power_regs->hw_power_5vctrl_set); + writel(POWER_RESET_UNLOCK_KEY, + &power_regs->hw_power_reset); + } else { + writel(POWER_5VCTRL_PWDN_5VBRNOUT, + &power_regs->hw_power_5vctrl_clr); + writel(POWER_RESET_UNLOCK_KEY | POWER_RESET_PWD_OFF, + &power_regs->hw_power_reset); + } + + while (readl(&power_regs->hw_power_ctrl) & POWER_CTRL_VDD5V_DROOP_IRQ) + writel(POWER_CTRL_VDD5V_DROOP_IRQ, + &power_regs->hw_power_ctrl_clr); + + if (prev_5v_droop) + clrbits_le32(&power_regs->hw_power_ctrl, + POWER_CTRL_ENIRQ_VDD5V_DROOP); + else + setbits_le32(&power_regs->hw_power_ctrl, + POWER_CTRL_ENIRQ_VDD5V_DROOP); +} + +void mx28_power_init_4p2_regulator(void) +{ + struct mx28_power_regs *power_regs = + (struct mx28_power_regs *)MXS_POWER_BASE; + uint32_t tmp, tmp2; + + setbits_le32(&power_regs->hw_power_dcdc4p2, POWER_DCDC4P2_ENABLE_4P2); + + writel(POWER_CHARGE_ENABLE_LOAD, &power_regs->hw_power_charge_set); + + writel(POWER_5VCTRL_CHARGE_4P2_ILIMIT_MASK, + &power_regs->hw_power_5vctrl_clr); + clrbits_le32(&power_regs->hw_power_dcdc4p2, POWER_DCDC4P2_TRG_MASK); + + /* Power up the 4p2 rail and logic/control */ + writel(POWER_5VCTRL_PWD_CHARGE_4P2_MASK, + &power_regs->hw_power_5vctrl_clr); + + /* + * Start charging up the 4p2 capacitor. We ramp of this charge + * gradually to avoid large inrush current from the 5V cable which can + * cause transients/problems + */ + mx28_enable_4p2_dcdc_input(0); + + if (readl(&power_regs->hw_power_ctrl) & POWER_CTRL_VBUS_VALID_IRQ) { + /* + * If we arrived here, we were unable to recover from mx23 chip + * errata 5837. 4P2 is disabled and sufficient battery power is + * not present. Exiting to not enable DCDC power during 5V + * connected state. + */ + clrbits_le32(&power_regs->hw_power_dcdc4p2, + POWER_DCDC4P2_ENABLE_DCDC); + writel(POWER_5VCTRL_PWD_CHARGE_4P2_MASK, + &power_regs->hw_power_5vctrl_set); + hang(); + } + + /* + * Here we set the 4p2 brownout level to something very close to 4.2V. + * We then check the brownout status. If the brownout status is false, + * the voltage is already close to the target voltage of 4.2V so we + * can go ahead and set the 4P2 current limit to our max target limit. + * If the brownout status is true, we need to ramp us the current limit + * so that we don't cause large inrush current issues. We step up the + * current limit until the brownout status is false or until we've + * reached our maximum defined 4p2 current limit. + */ + clrsetbits_le32(&power_regs->hw_power_dcdc4p2, + POWER_DCDC4P2_BO_MASK, + 22 << POWER_DCDC4P2_BO_OFFSET); /* 4.15V */ + + if (!(readl(&power_regs->hw_power_sts) & POWER_STS_DCDC_4P2_BO)) { + setbits_le32(&power_regs->hw_power_5vctrl, + 0x3f << POWER_5VCTRL_CHARGE_4P2_ILIMIT_OFFSET); + } else { + tmp = (readl(&power_regs->hw_power_5vctrl) & + POWER_5VCTRL_CHARGE_4P2_ILIMIT_MASK) >> + POWER_5VCTRL_CHARGE_4P2_ILIMIT_OFFSET; + while (tmp < 0x3f) { + if (!(readl(&power_regs->hw_power_sts) & + POWER_STS_DCDC_4P2_BO)) { + tmp = readl(&power_regs->hw_power_5vctrl); + tmp |= POWER_5VCTRL_CHARGE_4P2_ILIMIT_MASK; + early_delay(100); + writel(tmp, &power_regs->hw_power_5vctrl); + break; + } else { + tmp++; + tmp2 = readl(&power_regs->hw_power_5vctrl); + tmp2 &= ~POWER_5VCTRL_CHARGE_4P2_ILIMIT_MASK; + tmp2 |= tmp << + POWER_5VCTRL_CHARGE_4P2_ILIMIT_OFFSET; + writel(tmp2, &power_regs->hw_power_5vctrl); + early_delay(100); + } + } + } + + clrbits_le32(&power_regs->hw_power_dcdc4p2, POWER_DCDC4P2_BO_MASK); + writel(POWER_CTRL_DCDC4P2_BO_IRQ, &power_regs->hw_power_ctrl_clr); +} + +void mx28_power_init_dcdc_4p2_source(void) +{ + struct mx28_power_regs *power_regs = + (struct mx28_power_regs *)MXS_POWER_BASE; + + if (!(readl(&power_regs->hw_power_dcdc4p2) & + POWER_DCDC4P2_ENABLE_DCDC)) { + hang(); + } + + mx28_enable_4p2_dcdc_input(1); + + if (readl(&power_regs->hw_power_ctrl) & POWER_CTRL_VBUS_VALID_IRQ) { + clrbits_le32(&power_regs->hw_power_dcdc4p2, + POWER_DCDC4P2_ENABLE_DCDC); + writel(POWER_5VCTRL_ENABLE_DCDC, + &power_regs->hw_power_5vctrl_clr); + writel(POWER_5VCTRL_PWD_CHARGE_4P2_MASK, + &power_regs->hw_power_5vctrl_set); + } +} + +void mx28_power_enable_4p2(void) +{ + struct mx28_power_regs *power_regs = + (struct mx28_power_regs *)MXS_POWER_BASE; + uint32_t vdddctrl, vddactrl, vddioctrl; + uint32_t tmp; + + vdddctrl = readl(&power_regs->hw_power_vdddctrl); + vddactrl = readl(&power_regs->hw_power_vddactrl); + vddioctrl = readl(&power_regs->hw_power_vddioctrl); + + setbits_le32(&power_regs->hw_power_vdddctrl, + POWER_VDDDCTRL_DISABLE_FET | POWER_VDDDCTRL_ENABLE_LINREG | + POWER_VDDDCTRL_PWDN_BRNOUT); + + setbits_le32(&power_regs->hw_power_vddactrl, + POWER_VDDACTRL_DISABLE_FET | POWER_VDDACTRL_ENABLE_LINREG | + POWER_VDDACTRL_PWDN_BRNOUT); + + setbits_le32(&power_regs->hw_power_vddioctrl, + POWER_VDDIOCTRL_DISABLE_FET | POWER_VDDIOCTRL_PWDN_BRNOUT); + + mx28_power_init_4p2_params(); + mx28_power_init_4p2_regulator(); + + /* Shutdown battery (none present) */ + if (!mx28_is_batt_ready()) { + clrbits_le32(&power_regs->hw_power_dcdc4p2, + POWER_DCDC4P2_BO_MASK); + writel(POWER_CTRL_DCDC4P2_BO_IRQ, + &power_regs->hw_power_ctrl_clr); + writel(POWER_CTRL_ENIRQ_DCDC4P2_BO, + &power_regs->hw_power_ctrl_clr); + } + + mx28_power_init_dcdc_4p2_source(); + + writel(vdddctrl, &power_regs->hw_power_vdddctrl); + early_delay(20); + writel(vddactrl, &power_regs->hw_power_vddactrl); + early_delay(20); + writel(vddioctrl, &power_regs->hw_power_vddioctrl); + + /* + * Check if FET is enabled on either powerout and if so, + * disable load. + */ + tmp = 0; + tmp |= !(readl(&power_regs->hw_power_vdddctrl) & + POWER_VDDDCTRL_DISABLE_FET); + tmp |= !(readl(&power_regs->hw_power_vddactrl) & + POWER_VDDACTRL_DISABLE_FET); + tmp |= !(readl(&power_regs->hw_power_vddioctrl) & + POWER_VDDIOCTRL_DISABLE_FET); + if (tmp) + writel(POWER_CHARGE_ENABLE_LOAD, + &power_regs->hw_power_charge_clr); +} + +void mx28_boot_valid_5v(void) +{ + struct mx28_power_regs *power_regs = + (struct mx28_power_regs *)MXS_POWER_BASE; + + /* + * Use VBUSVALID level instead of VDD5V_GT_VDDIO level to trigger a 5V + * disconnect event. FIXME + */ + writel(POWER_5VCTRL_VBUSVALID_5VDETECT, + &power_regs->hw_power_5vctrl_set); + + /* Configure polarity to check for 5V disconnection. */ + writel(POWER_CTRL_POLARITY_VBUSVALID | + POWER_CTRL_POLARITY_VDD5V_GT_VDDIO, + &power_regs->hw_power_ctrl_clr); + + writel(POWER_CTRL_VBUS_VALID_IRQ | POWER_CTRL_VDD5V_GT_VDDIO_IRQ, + &power_regs->hw_power_ctrl_clr); + + mx28_power_enable_4p2(); +} + +void mx28_powerdown(void) +{ + struct mx28_power_regs *power_regs = + (struct mx28_power_regs *)MXS_POWER_BASE; + writel(POWER_RESET_UNLOCK_KEY, &power_regs->hw_power_reset); + writel(POWER_RESET_UNLOCK_KEY | POWER_RESET_PWD_OFF, + &power_regs->hw_power_reset); +} + +void mx28_batt_boot(void) +{ + struct mx28_power_regs *power_regs = + (struct mx28_power_regs *)MXS_POWER_BASE; + + clrbits_le32(&power_regs->hw_power_5vctrl, POWER_5VCTRL_PWDN_5VBRNOUT); + clrbits_le32(&power_regs->hw_power_5vctrl, POWER_5VCTRL_ENABLE_DCDC); + + clrbits_le32(&power_regs->hw_power_dcdc4p2, + POWER_DCDC4P2_ENABLE_DCDC | POWER_DCDC4P2_ENABLE_4P2); + writel(POWER_CHARGE_ENABLE_LOAD, &power_regs->hw_power_charge_clr); + + /* 5V to battery handoff. */ + setbits_le32(&power_regs->hw_power_5vctrl, POWER_5VCTRL_DCDC_XFER); + early_delay(30); + clrbits_le32(&power_regs->hw_power_5vctrl, POWER_5VCTRL_DCDC_XFER); + + writel(POWER_CTRL_ENIRQ_DCDC4P2_BO, &power_regs->hw_power_ctrl_clr); + + clrsetbits_le32(&power_regs->hw_power_minpwr, + POWER_MINPWR_HALFFETS, POWER_MINPWR_DOUBLE_FETS); + + mx28_power_set_linreg(); + + clrbits_le32(&power_regs->hw_power_vdddctrl, + POWER_VDDDCTRL_DISABLE_FET | POWER_VDDDCTRL_ENABLE_LINREG); + + clrbits_le32(&power_regs->hw_power_vddactrl, + POWER_VDDACTRL_DISABLE_FET | POWER_VDDACTRL_ENABLE_LINREG); + + clrbits_le32(&power_regs->hw_power_vddioctrl, + POWER_VDDIOCTRL_DISABLE_FET); + + setbits_le32(&power_regs->hw_power_5vctrl, + POWER_5VCTRL_PWD_CHARGE_4P2_MASK); + + setbits_le32(&power_regs->hw_power_5vctrl, + POWER_5VCTRL_ENABLE_DCDC); + + clrsetbits_le32(&power_regs->hw_power_5vctrl, + POWER_5VCTRL_CHARGE_4P2_ILIMIT_MASK, + 0x8 << POWER_5VCTRL_CHARGE_4P2_ILIMIT_OFFSET); +} + +void mx28_handle_5v_conflict(void) +{ + struct mx28_power_regs *power_regs = + (struct mx28_power_regs *)MXS_POWER_BASE; + uint32_t tmp; + + setbits_le32(&power_regs->hw_power_vddioctrl, + POWER_VDDIOCTRL_BO_OFFSET_MASK); + + for (;;) { + tmp = readl(&power_regs->hw_power_sts); + + if (tmp & POWER_STS_VDDIO_BO) { + mx28_powerdown(); + break; + } + + if (tmp & POWER_STS_VDD5V_GT_VDDIO) { + mx28_boot_valid_5v(); + break; + } else { + mx28_powerdown(); + break; + } + + if (tmp & POWER_STS_PSWITCH_MASK) { + mx28_batt_boot(); + break; + } + } +} + +void mx28_5v_boot(void) +{ + struct mx28_power_regs *power_regs = + (struct mx28_power_regs *)MXS_POWER_BASE; + + /* + * NOTE: In original IMX-Bootlets, this also checks for VBUSVALID, + * but their implementation always returns 1 so we omit it here. + */ + if (readl(&power_regs->hw_power_sts) & POWER_STS_VDD5V_GT_VDDIO) { + mx28_boot_valid_5v(); + return; + } + + early_delay(1000); + if (readl(&power_regs->hw_power_sts) & POWER_STS_VDD5V_GT_VDDIO) { + mx28_boot_valid_5v(); + return; + } + + mx28_handle_5v_conflict(); +} + +void mx28_init_batt_bo(void) +{ + struct mx28_power_regs *power_regs = + (struct mx28_power_regs *)MXS_POWER_BASE; + + /* Brownout at 3V */ + clrsetbits_le32(&power_regs->hw_power_battmonitor, + POWER_BATTMONITOR_BRWNOUT_LVL_MASK, + 15 << POWER_BATTMONITOR_BRWNOUT_LVL_OFFSET); + + writel(POWER_CTRL_BATT_BO_IRQ, &power_regs->hw_power_ctrl_clr); + writel(POWER_CTRL_ENIRQ_BATT_BO, &power_regs->hw_power_ctrl_clr); +} + +void mx28_switch_vddd_to_dcdc_source(void) +{ + struct mx28_power_regs *power_regs = + (struct mx28_power_regs *)MXS_POWER_BASE; + + clrsetbits_le32(&power_regs->hw_power_vdddctrl, + POWER_VDDDCTRL_LINREG_OFFSET_MASK, + POWER_VDDDCTRL_LINREG_OFFSET_1STEPS_BELOW); + + clrbits_le32(&power_regs->hw_power_vdddctrl, + POWER_VDDDCTRL_DISABLE_FET | POWER_VDDDCTRL_ENABLE_LINREG | + POWER_VDDDCTRL_DISABLE_STEPPING); +} + +void mx28_power_configure_power_source(void) +{ + int batt_ready, batt_good; + struct mx28_power_regs *power_regs = + (struct mx28_power_regs *)MXS_POWER_BASE; + struct mx28_lradc_regs *lradc_regs = + (struct mx28_lradc_regs *)MXS_LRADC_BASE; + + mx28_src_power_init(); + + batt_ready = mx28_is_batt_ready(); + + if (readl(&power_regs->hw_power_sts) & POWER_STS_VDD5V_GT_VDDIO) { + batt_good = mx28_is_batt_good(); + if (batt_ready) { + /* 5V source detected, good battery detected. */ + mx28_batt_boot(); + } else { + if (batt_good) { + /* 5V source detected, low battery detceted. */ + } else { + /* 5V source detected, bad battery detected. */ + writel(LRADC_CONVERSION_AUTOMATIC, + &lradc_regs->hw_lradc_conversion_clr); + clrbits_le32(&power_regs->hw_power_battmonitor, + POWER_BATTMONITOR_BATT_VAL_MASK); + } + mx28_5v_boot(); + } + } else { + /* 5V not detected, booting from battery. */ + mx28_batt_boot(); + } + + mx28_power_clock2pll(); + + mx28_init_batt_bo(); + + mx28_switch_vddd_to_dcdc_source(); +} + +void mx28_enable_output_rail_protection(void) +{ + struct mx28_power_regs *power_regs = + (struct mx28_power_regs *)MXS_POWER_BASE; + + writel(POWER_CTRL_VDDD_BO_IRQ | POWER_CTRL_VDDA_BO_IRQ | + POWER_CTRL_VDDIO_BO_IRQ, &power_regs->hw_power_ctrl_clr); + + setbits_le32(&power_regs->hw_power_vdddctrl, + POWER_VDDDCTRL_PWDN_BRNOUT); + + setbits_le32(&power_regs->hw_power_vddactrl, + POWER_VDDACTRL_PWDN_BRNOUT); + + setbits_le32(&power_regs->hw_power_vddioctrl, + POWER_VDDIOCTRL_PWDN_BRNOUT); +} + +int mx28_get_vddio_power_source_off(void) +{ + struct mx28_power_regs *power_regs = + (struct mx28_power_regs *)MXS_POWER_BASE; + uint32_t tmp; + + if (readl(&power_regs->hw_power_sts) & POWER_STS_VDD5V_GT_VDDIO) { + tmp = readl(&power_regs->hw_power_vddioctrl); + if (tmp & POWER_VDDIOCTRL_DISABLE_FET) { + if ((tmp & POWER_VDDIOCTRL_LINREG_OFFSET_MASK) == + POWER_VDDDCTRL_LINREG_OFFSET_0STEPS) { + return 1; + } + } + + if (!(readl(&power_regs->hw_power_5vctrl) & + POWER_5VCTRL_ENABLE_DCDC)) { + if ((tmp & POWER_VDDIOCTRL_LINREG_OFFSET_MASK) == + POWER_VDDDCTRL_LINREG_OFFSET_0STEPS) { + return 1; + } + } + } + + return 0; + +} + +int mx28_get_vddd_power_source_off(void) +{ + struct mx28_power_regs *power_regs = + (struct mx28_power_regs *)MXS_POWER_BASE; + uint32_t tmp; + + tmp = readl(&power_regs->hw_power_vdddctrl); + if (tmp & POWER_VDDDCTRL_DISABLE_FET) { + if ((tmp & POWER_VDDDCTRL_LINREG_OFFSET_MASK) == + POWER_VDDDCTRL_LINREG_OFFSET_0STEPS) { + return 1; + } + } + + if (readl(&power_regs->hw_power_sts) & POWER_STS_VDD5V_GT_VDDIO) { + if (!(readl(&power_regs->hw_power_5vctrl) & + POWER_5VCTRL_ENABLE_DCDC)) { + return 1; + } + } + + if (!(tmp & POWER_VDDDCTRL_ENABLE_LINREG)) { + if ((tmp & POWER_VDDDCTRL_LINREG_OFFSET_MASK) == + POWER_VDDDCTRL_LINREG_OFFSET_1STEPS_BELOW) { + return 1; + } + } + + return 0; +} + +void mx28_power_set_vddio(uint32_t new_target, uint32_t new_brownout) +{ + struct mx28_power_regs *power_regs = + (struct mx28_power_regs *)MXS_POWER_BASE; + uint32_t cur_target, diff, bo_int = 0; + uint32_t powered_by_linreg = 0; + + new_brownout = new_target - new_brownout; + + cur_target = readl(&power_regs->hw_power_vddioctrl); + cur_target &= POWER_VDDIOCTRL_TRG_MASK; + cur_target *= 50; /* 50 mV step*/ + cur_target += 2800; /* 2800 mV lowest */ + + powered_by_linreg = mx28_get_vddio_power_source_off(); + if (new_target > cur_target) { + + if (powered_by_linreg) { + bo_int = readl(&power_regs->hw_power_vddioctrl); + clrbits_le32(&power_regs->hw_power_vddioctrl, + POWER_CTRL_ENIRQ_VDDIO_BO); + } + + setbits_le32(&power_regs->hw_power_vddioctrl, + POWER_VDDIOCTRL_BO_OFFSET_MASK); + do { + if (new_target - cur_target > 100) + diff = cur_target + 100; + else + diff = new_target; + + diff -= 2800; + diff /= 50; + + clrsetbits_le32(&power_regs->hw_power_vddioctrl, + POWER_VDDIOCTRL_TRG_MASK, diff); + + if (powered_by_linreg || + (readl(&power_regs->hw_power_sts) & + POWER_STS_VDD5V_GT_VDDIO)) + early_delay(500); + else { + while (!(readl(&power_regs->hw_power_sts) & + POWER_STS_DC_OK)) + ; + + } + + cur_target = readl(&power_regs->hw_power_vddioctrl); + cur_target &= POWER_VDDIOCTRL_TRG_MASK; + cur_target *= 50; /* 50 mV step*/ + cur_target += 2800; /* 2800 mV lowest */ + } while (new_target > cur_target); + + if (powered_by_linreg) { + writel(POWER_CTRL_VDDIO_BO_IRQ, + &power_regs->hw_power_ctrl_clr); + if (bo_int & POWER_CTRL_ENIRQ_VDDIO_BO) + setbits_le32(&power_regs->hw_power_vddioctrl, + POWER_CTRL_ENIRQ_VDDIO_BO); + } + } else { + do { + if (cur_target - new_target > 100) + diff = cur_target - 100; + else + diff = new_target; + + diff -= 2800; + diff /= 50; + + clrsetbits_le32(&power_regs->hw_power_vddioctrl, + POWER_VDDIOCTRL_TRG_MASK, diff); + + if (powered_by_linreg || + (readl(&power_regs->hw_power_sts) & + POWER_STS_VDD5V_GT_VDDIO)) + early_delay(500); + else { + while (!(readl(&power_regs->hw_power_sts) & + POWER_STS_DC_OK)) + ; + + } + + cur_target = readl(&power_regs->hw_power_vddioctrl); + cur_target &= POWER_VDDIOCTRL_TRG_MASK; + cur_target *= 50; /* 50 mV step*/ + cur_target += 2800; /* 2800 mV lowest */ + } while (new_target < cur_target); + } + + clrsetbits_le32(&power_regs->hw_power_vddioctrl, + POWER_VDDDCTRL_BO_OFFSET_MASK, + new_brownout << POWER_VDDDCTRL_BO_OFFSET_OFFSET); +} + +void mx28_power_set_vddd(uint32_t new_target, uint32_t new_brownout) +{ + struct mx28_power_regs *power_regs = + (struct mx28_power_regs *)MXS_POWER_BASE; + uint32_t cur_target, diff, bo_int = 0; + uint32_t powered_by_linreg = 0; + + new_brownout = new_target - new_brownout; + + cur_target = readl(&power_regs->hw_power_vdddctrl); + cur_target &= POWER_VDDDCTRL_TRG_MASK; + cur_target *= 25; /* 25 mV step*/ + cur_target += 800; /* 800 mV lowest */ + + powered_by_linreg = mx28_get_vddd_power_source_off(); + if (new_target > cur_target) { + if (powered_by_linreg) { + bo_int = readl(&power_regs->hw_power_vdddctrl); + clrbits_le32(&power_regs->hw_power_vdddctrl, + POWER_CTRL_ENIRQ_VDDD_BO); + } + + setbits_le32(&power_regs->hw_power_vdddctrl, + POWER_VDDDCTRL_BO_OFFSET_MASK); + + do { + if (new_target - cur_target > 100) + diff = cur_target + 100; + else + diff = new_target; + + diff -= 800; + diff /= 25; + + clrsetbits_le32(&power_regs->hw_power_vdddctrl, + POWER_VDDDCTRL_TRG_MASK, diff); + + if (powered_by_linreg || + (readl(&power_regs->hw_power_sts) & + POWER_STS_VDD5V_GT_VDDIO)) + early_delay(500); + else { + while (!(readl(&power_regs->hw_power_sts) & + POWER_STS_DC_OK)) + ; + + } + + cur_target = readl(&power_regs->hw_power_vdddctrl); + cur_target &= POWER_VDDDCTRL_TRG_MASK; + cur_target *= 25; /* 25 mV step*/ + cur_target += 800; /* 800 mV lowest */ + } while (new_target > cur_target); + + if (powered_by_linreg) { + writel(POWER_CTRL_VDDD_BO_IRQ, + &power_regs->hw_power_ctrl_clr); + if (bo_int & POWER_CTRL_ENIRQ_VDDD_BO) + setbits_le32(&power_regs->hw_power_vdddctrl, + POWER_CTRL_ENIRQ_VDDD_BO); + } + } else { + do { + if (cur_target - new_target > 100) + diff = cur_target - 100; + else + diff = new_target; + + diff -= 800; + diff /= 25; + + clrsetbits_le32(&power_regs->hw_power_vdddctrl, + POWER_VDDDCTRL_TRG_MASK, diff); + + if (powered_by_linreg || + (readl(&power_regs->hw_power_sts) & + POWER_STS_VDD5V_GT_VDDIO)) + early_delay(500); + else { + while (!(readl(&power_regs->hw_power_sts) & + POWER_STS_DC_OK)) + ; + + } + + cur_target = readl(&power_regs->hw_power_vdddctrl); + cur_target &= POWER_VDDDCTRL_TRG_MASK; + cur_target *= 25; /* 25 mV step*/ + cur_target += 800; /* 800 mV lowest */ + } while (new_target < cur_target); + } + + clrsetbits_le32(&power_regs->hw_power_vdddctrl, + POWER_VDDDCTRL_BO_OFFSET_MASK, + new_brownout << POWER_VDDDCTRL_BO_OFFSET_OFFSET); +} + +void mx28_setup_batt_detect(void) +{ + mx28_lradc_init(); + mx28_lradc_enable_batt_measurement(); + early_delay(10); +} + +void mx28_power_init(void) +{ + struct mx28_power_regs *power_regs = + (struct mx28_power_regs *)MXS_POWER_BASE; + + mx28_power_clock2xtal(); + mx28_power_clear_auto_restart(); + mx28_power_set_linreg(); + mx28_power_setup_5v_detect(); + + mx28_setup_batt_detect(); + + mx28_power_configure_power_source(); + mx28_enable_output_rail_protection(); + + mx28_power_set_vddio(3300, 3150); + + mx28_power_set_vddd(1350, 1200); + + writel(POWER_CTRL_VDDD_BO_IRQ | POWER_CTRL_VDDA_BO_IRQ | + POWER_CTRL_VDDIO_BO_IRQ | POWER_CTRL_VDD5V_DROOP_IRQ | + POWER_CTRL_VBUS_VALID_IRQ | POWER_CTRL_BATT_BO_IRQ | + POWER_CTRL_DCDC4P2_BO_IRQ, &power_regs->hw_power_ctrl_clr); + + writel(POWER_5VCTRL_PWDN_5VBRNOUT, &power_regs->hw_power_5vctrl_set); + + early_delay(1000); +} + +#ifdef CONFIG_SPL_MX28_PSWITCH_WAIT +void mx28_power_wait_pswitch(void) +{ + struct mx28_power_regs *power_regs = + (struct mx28_power_regs *)MXS_POWER_BASE; + + while (!(readl(&power_regs->hw_power_sts) & POWER_STS_PSWITCH_MASK)) + ; +} +#endif diff --git a/arch/arm/cpu/arm926ejs/mxs/start.S b/arch/arm/cpu/arm926ejs/mxs/start.S new file mode 100644 index 0000000..e572b78 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/mxs/start.S @@ -0,0 +1,247 @@ +/* + * armboot - Startup Code for ARM926EJS CPU-core + * + * Copyright (c) 2003 Texas Instruments + * + * ----- Adapted for OMAP1610 OMAP730 from ARM925t code ------ + * + * Copyright (c) 2001 Marius Groger mag@sysgo.de + * Copyright (c) 2002 Alex Zupke azu@sysgo.de + * Copyright (c) 2002 Gary Jennejohn garyj@denx.de + * Copyright (c) 2003 Richard Woodruff r-woodruff2@ti.com + * Copyright (c) 2003 Kshitij kshitij@ti.com + * Copyright (c) 2010 Albert Aribaud albert.u.boot@aribaud.net + * + * Change to support call back into iMX28 bootrom + * Copyright (c) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <asm-offsets.h> +#include <config.h> +#include <common.h> +#include <version.h> + +/* + ************************************************************************* + * + * Jump vector table as in table 3.1 in [1] + * + ************************************************************************* + */ + + +.globl _start +_start: + b reset + b undefined_instruction + b software_interrupt + b prefetch_abort + b data_abort + b not_used + b irq + b fiq + +/* + * Vector table, located at address 0x20. + * This table allows the code running AFTER SPL, the U-Boot, to install it's + * interrupt handlers here. The problem is that the U-Boot is loaded into RAM, + * including it's interrupt vectoring table and the table at 0x0 is still the + * SPLs. So if interrupt happens in U-Boot, the SPLs interrupt vectoring table + * is still used. + */ +_vt_reset: + .word _reset +_vt_undefined_instruction: + .word _hang +_vt_software_interrupt: + .word _hang +_vt_prefetch_abort: + .word _hang +_vt_data_abort: + .word _hang +_vt_not_used: + .word _reset +_vt_irq: + .word _hang +_vt_fiq: + .word _hang + +reset: + ldr pc, _vt_reset +undefined_instruction: + ldr pc, _vt_undefined_instruction +software_interrupt: + ldr pc, _vt_software_interrupt +prefetch_abort: + ldr pc, _vt_prefetch_abort +data_abort: + ldr pc, _vt_data_abort +not_used: + ldr pc, _vt_not_used +irq: + ldr pc, _vt_irq +fiq: + ldr pc, _vt_fiq + + .balignl 16,0xdeadbeef + +/* + ************************************************************************* + * + * Startup Code (reset vector) + * + * do important init only if we don't start from memory! + * setup Memory and board specific bits prior to relocation. + * relocate armboot to ram + * setup stack + * + ************************************************************************* + */ + +.globl _TEXT_BASE +_TEXT_BASE: + .word CONFIG_SYS_TEXT_BASE + +/* + * These are defined in the board-specific linker script. + * Subtracting _start from them lets the linker put their + * relative position in the executable instead of leaving + * them null. + */ +.globl _bss_start_ofs +_bss_start_ofs: + .word __bss_start - _start + +.globl _bss_end_ofs +_bss_end_ofs: + .word __bss_end__ - _start + +.globl _end_ofs +_end_ofs: + .word _end - _start + +#ifdef CONFIG_USE_IRQ +/* IRQ stack memory (calculated at run-time) */ +.globl IRQ_STACK_START +IRQ_STACK_START: + .word 0x0badc0de + +/* IRQ stack memory (calculated at run-time) */ +.globl FIQ_STACK_START +FIQ_STACK_START: + .word 0x0badc0de +#endif + +/* IRQ stack memory (calculated at run-time) + 8 bytes */ +.globl IRQ_STACK_START_IN +IRQ_STACK_START_IN: + .word 0x0badc0de + +/* + * the actual reset code + */ + +_reset: + /* + * Store all registers on old stack pointer, this will allow us later to + * return to the BootROM and let the BootROM load U-Boot into RAM. + */ + push {r0-r12,r14} + + /* save control register c1 */ + mrc p15, 0, r0, c1, c0, 0 + push {r0} + + /* + * set the cpu to SVC32 mode and store old CPSR register content + */ + mrs r0,cpsr + push {r0} + bic r0,r0,#0x1f + orr r0,r0,#0xd3 + msr cpsr,r0 + + /* + * we do sys-critical inits only at reboot, + * not when booting from ram! + */ +#ifndef CONFIG_SKIP_LOWLEVEL_INIT + bl cpu_init_crit +#endif + + bl board_init_ll + + /* + * restore bootrom's cpu mode (especially FIQ) + */ + pop {r0} + msr cpsr,r0 + + /* + * restore c1 register + * (especially set exception vector location back to + * bootrom space which is required by bootrom for USB boot) + */ + pop {r0} + mcr p15, 0, r0, c1, c0, 0 + + pop {r0-r12,r14} + bx lr + +/* + ************************************************************************* + * + * CPU_init_critical registers + * + * setup important registers + * setup memory timing + * + ************************************************************************* + */ +#ifndef CONFIG_SKIP_LOWLEVEL_INIT +cpu_init_crit: + /* + * flush v4 I/D caches + */ + mov r0, #0 + mcr p15, 0, r0, c7, c7, 0 /* flush v3/v4 cache */ + mcr p15, 0, r0, c8, c7, 0 /* flush v4 TLB */ + + /* + * disable MMU stuff and caches + */ + mrc p15, 0, r0, c1, c0, 0 + bic r0, r0, #0x00002300 /* clear bits 13, 9:8 (--V- --RS) */ + bic r0, r0, #0x00000087 /* clear bits 7, 2:0 (B--- -CAM) */ + orr r0, r0, #0x00000002 /* set bit 2 (A) Align */ + orr r0, r0, #0x00001000 /* set bit 12 (I) I-Cache */ + mcr p15, 0, r0, c1, c0, 0 + + mov pc, lr /* back to my caller */ + + .align 5 +#endif /* CONFIG_SKIP_LOWLEVEL_INIT */ + +_hang: + ldr sp, _TEXT_BASE /* switch to abort stack */ +1: + bl 1b /* hang and never return */ diff --git a/arch/arm/cpu/arm926ejs/mxs/timer.c b/arch/arm/cpu/arm926ejs/mxs/timer.c new file mode 100644 index 0000000..5b73f4a --- /dev/null +++ b/arch/arm/cpu/arm926ejs/mxs/timer.c @@ -0,0 +1,156 @@ +/* + * Freescale i.MX28 timer driver + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * Based on code from LTIB: + * (C) Copyright 2009-2010 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/sys_proto.h> + +/* Maximum fixed count */ +#define TIMER_LOAD_VAL 0xffffffff + +DECLARE_GLOBAL_DATA_PTR; + +#define timestamp (gd->tbl) +#define lastdec (gd->lastinc) + +/* + * This driver uses 1kHz clock source. + */ +#define MX28_INCREMENTER_HZ 1000 + +static inline unsigned long tick_to_time(unsigned long tick) +{ + return tick / (MX28_INCREMENTER_HZ / CONFIG_SYS_HZ); +} + +static inline unsigned long time_to_tick(unsigned long time) +{ + return time * (MX28_INCREMENTER_HZ / CONFIG_SYS_HZ); +} + +/* Calculate how many ticks happen in "us" microseconds */ +static inline unsigned long us_to_tick(unsigned long us) +{ + return (us * MX28_INCREMENTER_HZ) / 1000000; +} + +int timer_init(void) +{ + struct mx28_timrot_regs *timrot_regs = + (struct mx28_timrot_regs *)MXS_TIMROT_BASE; + + /* Reset Timers and Rotary Encoder module */ + mx28_reset_block(&timrot_regs->hw_timrot_rotctrl_reg); + + /* Set fixed_count to 0 */ + writel(0, &timrot_regs->hw_timrot_fixed_count0); + + /* Set UPDATE bit and 1Khz frequency */ + writel(TIMROT_TIMCTRLn_UPDATE | TIMROT_TIMCTRLn_RELOAD | + TIMROT_TIMCTRLn_SELECT_1KHZ_XTAL, + &timrot_regs->hw_timrot_timctrl0); + + /* Set fixed_count to maximal value */ + writel(TIMER_LOAD_VAL, &timrot_regs->hw_timrot_fixed_count0); + + return 0; +} + +unsigned long long get_ticks(void) +{ + struct mx28_timrot_regs *timrot_regs = + (struct mx28_timrot_regs *)MXS_TIMROT_BASE; + + /* Current tick value */ + uint32_t now = readl(&timrot_regs->hw_timrot_running_count0); + + if (lastdec >= now) { + /* + * normal mode (non roll) + * move stamp forward with absolut diff ticks + */ + timestamp += (lastdec - now); + } else { + /* we have rollover of decrementer */ + timestamp += (TIMER_LOAD_VAL - now) + lastdec; + + } + lastdec = now; + + return timestamp; +} + +ulong get_timer_masked(void) +{ + return tick_to_time(get_ticks()); +} + +ulong get_timer(ulong base) +{ + return get_timer_masked() - base; +} + +/* We use the HW_DIGCTL_MICROSECONDS register for sub-millisecond timer. */ +#define MX28_HW_DIGCTL_MICROSECONDS 0x8001c0c0 + +void __udelay(unsigned long usec) +{ + uint32_t old, new, incr; + uint32_t counter = 0; + + old = readl(MX28_HW_DIGCTL_MICROSECONDS); + + while (counter < usec) { + new = readl(MX28_HW_DIGCTL_MICROSECONDS); + + /* Check if the timer wrapped. */ + if (new < old) { + incr = 0xffffffff - old; + incr += new; + } else { + incr = new - old; + } + + /* + * Check if we are close to the maximum time and the counter + * would wrap if incremented. If that's the case, break out + * from the loop as the requested delay time passed. + */ + if (counter + incr < counter) + break; + + counter += incr; + old = new; + } +} + +ulong get_tbclk(void) +{ + return MX28_INCREMENTER_HZ; +} diff --git a/arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds b/arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds new file mode 100644 index 0000000..f8ea38c --- /dev/null +++ b/arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds @@ -0,0 +1,87 @@ +/* + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * January 2004 - Changed to support H4 device + * Copyright (c) 2004-2008 Texas Instruments + * + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, garyj@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + arch/arm/cpu/arm926ejs/mxs/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } + + . = ALIGN(4); + .data : { + *(.data) + } + + . = ALIGN(4); + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + + .rel.dyn : { + __rel_dyn_start = .; + *(.rel*) + __rel_dyn_end = .; + } + + .dynsym : { + __dynsym_start = .; + *(.dynsym) + } + + .bss : { + . = ALIGN(4); + __bss_start = .; + *(.bss*) + . = ALIGN(4); + __bss_end__ = .; + } + + _end = .; + + /DISCARD/ : { *(.dynstr*) } + /DISCARD/ : { *(.dynsym*) } + /DISCARD/ : { *(.dynamic*) } + /DISCARD/ : { *(.hash*) } + /DISCARD/ : { *(.plt*) } + /DISCARD/ : { *(.interp*) } + /DISCARD/ : { *(.gnu*) } +} diff --git a/arch/arm/include/asm/arch-mx28/clock.h b/arch/arm/include/asm/arch-mx28/clock.h deleted file mode 100644 index 1700fe3..0000000 --- a/arch/arm/include/asm/arch-mx28/clock.h +++ /dev/null @@ -1,61 +0,0 @@ -/* - * Freescale i.MX28 Clock - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * on behalf of DENX Software Engineering GmbH - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA - * - */ - -#ifndef __CLOCK_H__ -#define __CLOCK_H__ - -enum mxc_clock { - MXC_ARM_CLK = 0, - MXC_AHB_CLK, - MXC_IPG_CLK, - MXC_EMI_CLK, - MXC_GPMI_CLK, - MXC_IO0_CLK, - MXC_IO1_CLK, - MXC_SSP0_CLK, - MXC_SSP1_CLK, - MXC_SSP2_CLK, - MXC_SSP3_CLK, -}; - -enum mxs_ioclock { - MXC_IOCLK0 = 0, - MXC_IOCLK1, -}; - -enum mxs_sspclock { - MXC_SSPCLK0 = 0, - MXC_SSPCLK1, - MXC_SSPCLK2, - MXC_SSPCLK3, -}; - -uint32_t mxc_get_clock(enum mxc_clock clk); - -void mx28_set_ioclk(enum mxs_ioclock io, uint32_t freq); -void mx28_set_sspclk(enum mxs_sspclock ssp, uint32_t freq, int xtal); -void mx28_set_ssp_busclock(unsigned int bus, uint32_t freq); - -/* Compatibility with the FEC Ethernet driver */ -#define imx_get_fecclk() mxc_get_clock(MXC_AHB_CLK) - -#endif /* __CLOCK_H__ */ diff --git a/arch/arm/include/asm/arch-mx28/dma.h b/arch/arm/include/asm/arch-mx28/dma.h deleted file mode 100644 index 4a1820b..0000000 --- a/arch/arm/include/asm/arch-mx28/dma.h +++ /dev/null @@ -1,147 +0,0 @@ -/* - * Freescale i.MX28 APBH DMA - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * on behalf of DENX Software Engineering GmbH - * - * Based on code from LTIB: - * Copyright 2008-2010 Freescale Semiconductor, Inc. All Rights Reserved. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA - * - */ - -#ifndef __DMA_H__ -#define __DMA_H__ - -#include <linux/list.h> - -#ifndef CONFIG_ARCH_DMA_PIO_WORDS -#define DMA_PIO_WORDS 15 -#else -#define DMA_PIO_WORDS CONFIG_ARCH_DMA_PIO_WORDS -#endif - -#define MXS_DMA_ALIGNMENT 32 - -/* - * MXS DMA channels - */ -enum { - MXS_DMA_CHANNEL_AHB_APBH_SSP0 = 0, - MXS_DMA_CHANNEL_AHB_APBH_SSP1, - MXS_DMA_CHANNEL_AHB_APBH_SSP2, - MXS_DMA_CHANNEL_AHB_APBH_SSP3, - MXS_DMA_CHANNEL_AHB_APBH_GPMI0, - MXS_DMA_CHANNEL_AHB_APBH_GPMI1, - MXS_DMA_CHANNEL_AHB_APBH_GPMI2, - MXS_DMA_CHANNEL_AHB_APBH_GPMI3, - MXS_DMA_CHANNEL_AHB_APBH_GPMI4, - MXS_DMA_CHANNEL_AHB_APBH_GPMI5, - MXS_DMA_CHANNEL_AHB_APBH_GPMI6, - MXS_DMA_CHANNEL_AHB_APBH_GPMI7, - MXS_DMA_CHANNEL_AHB_APBH_SSP, - MXS_MAX_DMA_CHANNELS, -}; - -/* - * MXS DMA hardware command. - * - * This structure describes the in-memory layout of an entire DMA command, - * including space for the maximum number of PIO accesses. See the appropriate - * reference manual for a detailed description of what these fields mean to the - * DMA hardware. - */ -#define MXS_DMA_DESC_COMMAND_MASK 0x3 -#define MXS_DMA_DESC_COMMAND_OFFSET 0 -#define MXS_DMA_DESC_COMMAND_NO_DMAXFER 0x0 -#define MXS_DMA_DESC_COMMAND_DMA_WRITE 0x1 -#define MXS_DMA_DESC_COMMAND_DMA_READ 0x2 -#define MXS_DMA_DESC_COMMAND_DMA_SENSE 0x3 -#define MXS_DMA_DESC_CHAIN (1 << 2) -#define MXS_DMA_DESC_IRQ (1 << 3) -#define MXS_DMA_DESC_NAND_LOCK (1 << 4) -#define MXS_DMA_DESC_NAND_WAIT_4_READY (1 << 5) -#define MXS_DMA_DESC_DEC_SEM (1 << 6) -#define MXS_DMA_DESC_WAIT4END (1 << 7) -#define MXS_DMA_DESC_HALT_ON_TERMINATE (1 << 8) -#define MXS_DMA_DESC_TERMINATE_FLUSH (1 << 9) -#define MXS_DMA_DESC_PIO_WORDS_MASK (0xf << 12) -#define MXS_DMA_DESC_PIO_WORDS_OFFSET 12 -#define MXS_DMA_DESC_BYTES_MASK (0xffff << 16) -#define MXS_DMA_DESC_BYTES_OFFSET 16 - -struct mxs_dma_cmd { - unsigned long next; - unsigned long data; - union { - dma_addr_t address; - unsigned long alternate; - }; - unsigned long pio_words[DMA_PIO_WORDS]; -}; - -/* - * MXS DMA command descriptor. - * - * This structure incorporates an MXS DMA hardware command structure, along - * with metadata. - */ -#define MXS_DMA_DESC_FIRST (1 << 0) -#define MXS_DMA_DESC_LAST (1 << 1) -#define MXS_DMA_DESC_READY (1 << 31) - -struct mxs_dma_desc { - struct mxs_dma_cmd cmd; - unsigned int flags; - dma_addr_t address; - void *buffer; - struct list_head node; -}; - -/** - * MXS DMA channel - * - * This structure represents a single DMA channel. The MXS platform code - * maintains an array of these structures to represent every DMA channel in the - * system (see mxs_dma_channels). - */ -#define MXS_DMA_FLAGS_IDLE 0 -#define MXS_DMA_FLAGS_BUSY (1 << 0) -#define MXS_DMA_FLAGS_FREE 0 -#define MXS_DMA_FLAGS_ALLOCATED (1 << 16) -#define MXS_DMA_FLAGS_VALID (1 << 31) - -struct mxs_dma_chan { - const char *name; - unsigned long dev; - struct mxs_dma_device *dma; - unsigned int flags; - unsigned int active_num; - unsigned int pending_num; - struct list_head active; - struct list_head done; -}; - -struct mxs_dma_desc *mxs_dma_desc_alloc(void); -void mxs_dma_desc_free(struct mxs_dma_desc *); -int mxs_dma_desc_append(int channel, struct mxs_dma_desc *pdesc); - -int mxs_dma_go(int chan); -void mxs_dma_init(void); -int mxs_dma_init_channel(int chan); -int mxs_dma_release(int chan); - -#endif /* __DMA_H__ */ diff --git a/arch/arm/include/asm/arch-mx28/gpio.h b/arch/arm/include/asm/arch-mx28/gpio.h deleted file mode 100644 index be1c944..0000000 --- a/arch/arm/include/asm/arch-mx28/gpio.h +++ /dev/null @@ -1,32 +0,0 @@ -/* - * Freescale i.MX28 GPIO - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * on behalf of DENX Software Engineering GmbH - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA - * - */ - -#ifndef __MX28_GPIO_H__ -#define __MX28_GPIO_H__ - -#ifdef CONFIG_MXS_GPIO -void mxs_gpio_init(void); -#else -inline void mxs_gpio_init(void) {} -#endif - -#endif /* __MX28_GPIO_H__ */ diff --git a/arch/arm/include/asm/arch-mx28/imx-regs.h b/arch/arm/include/asm/arch-mx28/imx-regs.h deleted file mode 100644 index 37d0a93..0000000 --- a/arch/arm/include/asm/arch-mx28/imx-regs.h +++ /dev/null @@ -1,42 +0,0 @@ -/* - * Freescale i.MX28 Registers - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * on behalf of DENX Software Engineering GmbH - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA - * - */ - -#ifndef __IMX_REGS_H__ -#define __IMX_REGS_H__ - -#include <asm/arch/regs-apbh.h> -#include <asm/arch/regs-base.h> -#include <asm/arch/regs-bch.h> -#include <asm/arch/regs-clkctrl.h> -#include <asm/arch/regs-digctl.h> -#include <asm/arch/regs-gpmi.h> -#include <asm/arch/regs-i2c.h> -#include <asm/arch/regs-lcdif.h> -#include <asm/arch/regs-lradc.h> -#include <asm/arch/regs-ocotp.h> -#include <asm/arch/regs-pinctrl.h> -#include <asm/arch/regs-power.h> -#include <asm/arch/regs-rtc.h> -#include <asm/arch/regs-ssp.h> -#include <asm/arch/regs-timrot.h> - -#endif /* __IMX_REGS_H__ */ diff --git a/arch/arm/include/asm/arch-mx28/iomux-mx28.h b/arch/arm/include/asm/arch-mx28/iomux-mx28.h deleted file mode 100644 index b42820d..0000000 --- a/arch/arm/include/asm/arch-mx28/iomux-mx28.h +++ /dev/null @@ -1,537 +0,0 @@ -/* - * Copyright (C) 2009-2010 Amit Kucheria amit.kucheria@canonical.com - * Copyright (C) 2010 Freescale Semiconductor, Inc. - * - * The code contained herein is licensed under the GNU General Public - * License. You may obtain a copy of the GNU General Public License - * Version 2 or later at the following locations: - * - * http://www.opensource.org/licenses/gpl-license.html - * http://www.gnu.org/copyleft/gpl.html - */ - -#ifndef __MACH_IOMUX_MX28_H__ -#define __MACH_IOMUX_MX28_H__ - -#include <asm/arch/iomux.h> - -/* - * The naming convention for the pad modes is MX28_PAD_<padname>__<padmode> - * If <padname> or <padmode> refers to a GPIO, it is named GPIO_<unit>_<num> - * See also iomux.h - * - * BANK PIN MUX - */ -/* MUXSEL_0 */ -#define MX28_PAD_GPMI_D00__GPMI_D0 MXS_IOMUX_PAD_NAKED(0, 0, PAD_MUXSEL_0) -#define MX28_PAD_GPMI_D01__GPMI_D1 MXS_IOMUX_PAD_NAKED(0, 1, PAD_MUXSEL_0) -#define MX28_PAD_GPMI_D02__GPMI_D2 MXS_IOMUX_PAD_NAKED(0, 2, PAD_MUXSEL_0) -#define MX28_PAD_GPMI_D03__GPMI_D3 MXS_IOMUX_PAD_NAKED(0, 3, PAD_MUXSEL_0) -#define MX28_PAD_GPMI_D04__GPMI_D4 MXS_IOMUX_PAD_NAKED(0, 4, PAD_MUXSEL_0) -#define MX28_PAD_GPMI_D05__GPMI_D5 MXS_IOMUX_PAD_NAKED(0, 5, PAD_MUXSEL_0) -#define MX28_PAD_GPMI_D06__GPMI_D6 MXS_IOMUX_PAD_NAKED(0, 6, PAD_MUXSEL_0) -#define MX28_PAD_GPMI_D07__GPMI_D7 MXS_IOMUX_PAD_NAKED(0, 7, PAD_MUXSEL_0) -#define MX28_PAD_GPMI_CE0N__GPMI_CE0N MXS_IOMUX_PAD_NAKED(0, 16, PAD_MUXSEL_0) -#define MX28_PAD_GPMI_CE1N__GPMI_CE1N MXS_IOMUX_PAD_NAKED(0, 17, PAD_MUXSEL_0) -#define MX28_PAD_GPMI_CE2N__GPMI_CE2N MXS_IOMUX_PAD_NAKED(0, 18, PAD_MUXSEL_0) -#define MX28_PAD_GPMI_CE3N__GPMI_CE3N MXS_IOMUX_PAD_NAKED(0, 19, PAD_MUXSEL_0) -#define MX28_PAD_GPMI_RDY0__GPMI_READY0 MXS_IOMUX_PAD_NAKED(0, 20, PAD_MUXSEL_0) -#define MX28_PAD_GPMI_RDY1__GPMI_READY1 MXS_IOMUX_PAD_NAKED(0, 21, PAD_MUXSEL_0) -#define MX28_PAD_GPMI_RDY2__GPMI_READY2 MXS_IOMUX_PAD_NAKED(0, 22, PAD_MUXSEL_0) -#define MX28_PAD_GPMI_RDY3__GPMI_READY3 MXS_IOMUX_PAD_NAKED(0, 23, PAD_MUXSEL_0) -#define MX28_PAD_GPMI_RDN__GPMI_RDN MXS_IOMUX_PAD_NAKED(0, 24, PAD_MUXSEL_0) -#define MX28_PAD_GPMI_WRN__GPMI_WRN MXS_IOMUX_PAD_NAKED(0, 25, PAD_MUXSEL_0) -#define MX28_PAD_GPMI_ALE__GPMI_ALE MXS_IOMUX_PAD_NAKED(0, 26, PAD_MUXSEL_0) -#define MX28_PAD_GPMI_CLE__GPMI_CLE MXS_IOMUX_PAD_NAKED(0, 27, PAD_MUXSEL_0) -#define MX28_PAD_GPMI_RESETN__GPMI_RESETN MXS_IOMUX_PAD_NAKED(0, 28, PAD_MUXSEL_0) - -#define MX28_PAD_LCD_D00__LCD_D0 MXS_IOMUX_PAD_NAKED(1, 0, PAD_MUXSEL_0) -#define MX28_PAD_LCD_D01__LCD_D1 MXS_IOMUX_PAD_NAKED(1, 1, PAD_MUXSEL_0) -#define MX28_PAD_LCD_D02__LCD_D2 MXS_IOMUX_PAD_NAKED(1, 2, PAD_MUXSEL_0) -#define MX28_PAD_LCD_D03__LCD_D3 MXS_IOMUX_PAD_NAKED(1, 3, PAD_MUXSEL_0) -#define MX28_PAD_LCD_D04__LCD_D4 MXS_IOMUX_PAD_NAKED(1, 4, PAD_MUXSEL_0) -#define MX28_PAD_LCD_D05__LCD_D5 MXS_IOMUX_PAD_NAKED(1, 5, PAD_MUXSEL_0) -#define MX28_PAD_LCD_D06__LCD_D6 MXS_IOMUX_PAD_NAKED(1, 6, PAD_MUXSEL_0) -#define MX28_PAD_LCD_D07__LCD_D7 MXS_IOMUX_PAD_NAKED(1, 7, PAD_MUXSEL_0) -#define MX28_PAD_LCD_D08__LCD_D8 MXS_IOMUX_PAD_NAKED(1, 8, PAD_MUXSEL_0) -#define MX28_PAD_LCD_D09__LCD_D9 MXS_IOMUX_PAD_NAKED(1, 9, PAD_MUXSEL_0) -#define MX28_PAD_LCD_D10__LCD_D10 MXS_IOMUX_PAD_NAKED(1, 10, PAD_MUXSEL_0) -#define MX28_PAD_LCD_D11__LCD_D11 MXS_IOMUX_PAD_NAKED(1, 11, PAD_MUXSEL_0) -#define MX28_PAD_LCD_D12__LCD_D12 MXS_IOMUX_PAD_NAKED(1, 12, PAD_MUXSEL_0) -#define MX28_PAD_LCD_D13__LCD_D13 MXS_IOMUX_PAD_NAKED(1, 13, PAD_MUXSEL_0) -#define MX28_PAD_LCD_D14__LCD_D14 MXS_IOMUX_PAD_NAKED(1, 14, PAD_MUXSEL_0) -#define MX28_PAD_LCD_D15__LCD_D15 MXS_IOMUX_PAD_NAKED(1, 15, PAD_MUXSEL_0) -#define MX28_PAD_LCD_D16__LCD_D16 MXS_IOMUX_PAD_NAKED(1, 16, PAD_MUXSEL_0) -#define MX28_PAD_LCD_D17__LCD_D17 MXS_IOMUX_PAD_NAKED(1, 17, PAD_MUXSEL_0) -#define MX28_PAD_LCD_D18__LCD_D18 MXS_IOMUX_PAD_NAKED(1, 18, PAD_MUXSEL_0) -#define MX28_PAD_LCD_D19__LCD_D19 MXS_IOMUX_PAD_NAKED(1, 19, PAD_MUXSEL_0) -#define MX28_PAD_LCD_D20__LCD_D20 MXS_IOMUX_PAD_NAKED(1, 20, PAD_MUXSEL_0) -#define MX28_PAD_LCD_D21__LCD_D21 MXS_IOMUX_PAD_NAKED(1, 21, PAD_MUXSEL_0) -#define MX28_PAD_LCD_D22__LCD_D22 MXS_IOMUX_PAD_NAKED(1, 22, PAD_MUXSEL_0) -#define MX28_PAD_LCD_D23__LCD_D23 MXS_IOMUX_PAD_NAKED(1, 23, PAD_MUXSEL_0) -#define MX28_PAD_LCD_RD_E__LCD_RD_E MXS_IOMUX_PAD_NAKED(1, 24, PAD_MUXSEL_0) -#define MX28_PAD_LCD_WR_RWN__LCD_WR_RWN MXS_IOMUX_PAD_NAKED(1, 25, PAD_MUXSEL_0) -#define MX28_PAD_LCD_RS__LCD_RS MXS_IOMUX_PAD_NAKED(1, 26, PAD_MUXSEL_0) -#define MX28_PAD_LCD_CS__LCD_CS MXS_IOMUX_PAD_NAKED(1, 27, PAD_MUXSEL_0) -#define MX28_PAD_LCD_VSYNC__LCD_VSYNC MXS_IOMUX_PAD_NAKED(1, 28, PAD_MUXSEL_0) -#define MX28_PAD_LCD_HSYNC__LCD_HSYNC MXS_IOMUX_PAD_NAKED(1, 29, PAD_MUXSEL_0) -#define MX28_PAD_LCD_DOTCLK__LCD_DOTCLK MXS_IOMUX_PAD_NAKED(1, 30, PAD_MUXSEL_0) -#define MX28_PAD_LCD_ENABLE__LCD_ENABLE MXS_IOMUX_PAD_NAKED(1, 31, PAD_MUXSEL_0) - -#define MX28_PAD_SSP0_DATA0__SSP0_D0 MXS_IOMUX_PAD_NAKED(2, 0, PAD_MUXSEL_0) -#define MX28_PAD_SSP0_DATA1__SSP0_D1 MXS_IOMUX_PAD_NAKED(2, 1, PAD_MUXSEL_0) -#define MX28_PAD_SSP0_DATA2__SSP0_D2 MXS_IOMUX_PAD_NAKED(2, 2, PAD_MUXSEL_0) -#define MX28_PAD_SSP0_DATA3__SSP0_D3 MXS_IOMUX_PAD_NAKED(2, 3, PAD_MUXSEL_0) -#define MX28_PAD_SSP0_DATA4__SSP0_D4 MXS_IOMUX_PAD_NAKED(2, 4, PAD_MUXSEL_0) -#define MX28_PAD_SSP0_DATA5__SSP0_D5 MXS_IOMUX_PAD_NAKED(2, 5, PAD_MUXSEL_0) -#define MX28_PAD_SSP0_DATA6__SSP0_D6 MXS_IOMUX_PAD_NAKED(2, 6, PAD_MUXSEL_0) -#define MX28_PAD_SSP0_DATA7__SSP0_D7 MXS_IOMUX_PAD_NAKED(2, 7, PAD_MUXSEL_0) -#define MX28_PAD_SSP0_CMD__SSP0_CMD MXS_IOMUX_PAD_NAKED(2, 8, PAD_MUXSEL_0) -#define MX28_PAD_SSP0_DETECT__SSP0_CARD_DETECT MXS_IOMUX_PAD_NAKED(2, 9, PAD_MUXSEL_0) -#define MX28_PAD_SSP0_SCK__SSP0_SCK MXS_IOMUX_PAD_NAKED(2, 10, PAD_MUXSEL_0) -#define MX28_PAD_SSP1_SCK__SSP1_SCK MXS_IOMUX_PAD_NAKED(2, 12, PAD_MUXSEL_0) -#define MX28_PAD_SSP1_CMD__SSP1_CMD MXS_IOMUX_PAD_NAKED(2, 13, PAD_MUXSEL_0) -#define MX28_PAD_SSP1_DATA0__SSP1_D0 MXS_IOMUX_PAD_NAKED(2, 14, PAD_MUXSEL_0) -#define MX28_PAD_SSP1_DATA3__SSP1_D3 MXS_IOMUX_PAD_NAKED(2, 15, PAD_MUXSEL_0) -#define MX28_PAD_SSP2_SCK__SSP2_SCK MXS_IOMUX_PAD_NAKED(2, 16, PAD_MUXSEL_0) -#define MX28_PAD_SSP2_MOSI__SSP2_CMD MXS_IOMUX_PAD_NAKED(2, 17, PAD_MUXSEL_0) -#define MX28_PAD_SSP2_MISO__SSP2_D0 MXS_IOMUX_PAD_NAKED(2, 18, PAD_MUXSEL_0) -#define MX28_PAD_SSP2_SS0__SSP2_D3 MXS_IOMUX_PAD_NAKED(2, 19, PAD_MUXSEL_0) -#define MX28_PAD_SSP2_SS1__SSP2_D4 MXS_IOMUX_PAD_NAKED(2, 20, PAD_MUXSEL_0) -#define MX28_PAD_SSP2_SS2__SSP2_D5 MXS_IOMUX_PAD_NAKED(2, 21, PAD_MUXSEL_0) -#define MX28_PAD_SSP3_SCK__SSP3_SCK MXS_IOMUX_PAD_NAKED(2, 24, PAD_MUXSEL_0) -#define MX28_PAD_SSP3_MOSI__SSP3_CMD MXS_IOMUX_PAD_NAKED(2, 25, PAD_MUXSEL_0) -#define MX28_PAD_SSP3_MISO__SSP3_D0 MXS_IOMUX_PAD_NAKED(2, 26, PAD_MUXSEL_0) -#define MX28_PAD_SSP3_SS0__SSP3_D3 MXS_IOMUX_PAD_NAKED(2, 27, PAD_MUXSEL_0) - -#define MX28_PAD_AUART0_RX__AUART0_RX MXS_IOMUX_PAD_NAKED(3, 0, PAD_MUXSEL_0) -#define MX28_PAD_AUART0_TX__AUART0_TX MXS_IOMUX_PAD_NAKED(3, 1, PAD_MUXSEL_0) -#define MX28_PAD_AUART0_CTS__AUART0_CTS MXS_IOMUX_PAD_NAKED(3, 2, PAD_MUXSEL_0) -#define MX28_PAD_AUART0_RTS__AUART0_RTS MXS_IOMUX_PAD_NAKED(3, 3, PAD_MUXSEL_0) -#define MX28_PAD_AUART1_RX__AUART1_RX MXS_IOMUX_PAD_NAKED(3, 4, PAD_MUXSEL_0) -#define MX28_PAD_AUART1_TX__AUART1_TX MXS_IOMUX_PAD_NAKED(3, 5, PAD_MUXSEL_0) -#define MX28_PAD_AUART1_CTS__AUART1_CTS MXS_IOMUX_PAD_NAKED(3, 6, PAD_MUXSEL_0) -#define MX28_PAD_AUART1_RTS__AUART1_RTS MXS_IOMUX_PAD_NAKED(3, 7, PAD_MUXSEL_0) -#define MX28_PAD_AUART2_RX__AUART2_RX MXS_IOMUX_PAD_NAKED(3, 8, PAD_MUXSEL_0) -#define MX28_PAD_AUART2_TX__AUART2_TX MXS_IOMUX_PAD_NAKED(3, 9, PAD_MUXSEL_0) -#define MX28_PAD_AUART2_CTS__AUART2_CTS MXS_IOMUX_PAD_NAKED(3, 10, PAD_MUXSEL_0) -#define MX28_PAD_AUART2_RTS__AUART2_RTS MXS_IOMUX_PAD_NAKED(3, 11, PAD_MUXSEL_0) -#define MX28_PAD_AUART3_RX__AUART3_RX MXS_IOMUX_PAD_NAKED(3, 12, PAD_MUXSEL_0) -#define MX28_PAD_AUART3_TX__AUART3_TX MXS_IOMUX_PAD_NAKED(3, 13, PAD_MUXSEL_0) -#define MX28_PAD_AUART3_CTS__AUART3_CTS MXS_IOMUX_PAD_NAKED(3, 14, PAD_MUXSEL_0) -#define MX28_PAD_AUART3_RTS__AUART3_RTS MXS_IOMUX_PAD_NAKED(3, 15, PAD_MUXSEL_0) -#define MX28_PAD_PWM0__PWM_0 MXS_IOMUX_PAD_NAKED(3, 16, PAD_MUXSEL_0) -#define MX28_PAD_PWM1__PWM_1 MXS_IOMUX_PAD_NAKED(3, 17, PAD_MUXSEL_0) -#define MX28_PAD_PWM2__PWM_2 MXS_IOMUX_PAD_NAKED(3, 18, PAD_MUXSEL_0) -#define MX28_PAD_SAIF0_MCLK__SAIF0_MCLK MXS_IOMUX_PAD_NAKED(3, 20, PAD_MUXSEL_0) -#define MX28_PAD_SAIF0_LRCLK__SAIF0_LRCLK MXS_IOMUX_PAD_NAKED(3, 21, PAD_MUXSEL_0) -#define MX28_PAD_SAIF0_BITCLK__SAIF0_BITCLK MXS_IOMUX_PAD_NAKED(3, 22, PAD_MUXSEL_0) -#define MX28_PAD_SAIF0_SDATA0__SAIF0_SDATA0 MXS_IOMUX_PAD_NAKED(3, 23, PAD_MUXSEL_0) -#define MX28_PAD_I2C0_SCL__I2C0_SCL MXS_IOMUX_PAD_NAKED(3, 24, PAD_MUXSEL_0) -#define MX28_PAD_I2C0_SDA__I2C0_SDA MXS_IOMUX_PAD_NAKED(3, 25, PAD_MUXSEL_0) -#define MX28_PAD_SAIF1_SDATA0__SAIF1_SDATA0 MXS_IOMUX_PAD_NAKED(3, 26, PAD_MUXSEL_0) -#define MX28_PAD_SPDIF__SPDIF_TX MXS_IOMUX_PAD_NAKED(3, 27, PAD_MUXSEL_0) -#define MX28_PAD_PWM3__PWM_3 MXS_IOMUX_PAD_NAKED(3, 28, PAD_MUXSEL_0) -#define MX28_PAD_PWM4__PWM_4 MXS_IOMUX_PAD_NAKED(3, 29, PAD_MUXSEL_0) -#define MX28_PAD_LCD_RESET__LCD_RESET MXS_IOMUX_PAD_NAKED(3, 30, PAD_MUXSEL_0) - -#define MX28_PAD_ENET0_MDC__ENET0_MDC MXS_IOMUX_PAD_NAKED(4, 0, PAD_MUXSEL_0) -#define MX28_PAD_ENET0_MDIO__ENET0_MDIO MXS_IOMUX_PAD_NAKED(4, 1, PAD_MUXSEL_0) -#define MX28_PAD_ENET0_RX_EN__ENET0_RX_EN MXS_IOMUX_PAD_NAKED(4, 2, PAD_MUXSEL_0) -#define MX28_PAD_ENET0_RXD0__ENET0_RXD0 MXS_IOMUX_PAD_NAKED(4, 3, PAD_MUXSEL_0) -#define MX28_PAD_ENET0_RXD1__ENET0_RXD1 MXS_IOMUX_PAD_NAKED(4, 4, PAD_MUXSEL_0) -#define MX28_PAD_ENET0_TX_CLK__ENET0_TX_CLK MXS_IOMUX_PAD_NAKED(4, 5, PAD_MUXSEL_0) -#define MX28_PAD_ENET0_TX_EN__ENET0_TX_EN MXS_IOMUX_PAD_NAKED(4, 6, PAD_MUXSEL_0) -#define MX28_PAD_ENET0_TXD0__ENET0_TXD0 MXS_IOMUX_PAD_NAKED(4, 7, PAD_MUXSEL_0) -#define MX28_PAD_ENET0_TXD1__ENET0_TXD1 MXS_IOMUX_PAD_NAKED(4, 8, PAD_MUXSEL_0) -#define MX28_PAD_ENET0_RXD2__ENET0_RXD2 MXS_IOMUX_PAD_NAKED(4, 9, PAD_MUXSEL_0) -#define MX28_PAD_ENET0_RXD3__ENET0_RXD3 MXS_IOMUX_PAD_NAKED(4, 10, PAD_MUXSEL_0) -#define MX28_PAD_ENET0_TXD2__ENET0_TXD2 MXS_IOMUX_PAD_NAKED(4, 11, PAD_MUXSEL_0) -#define MX28_PAD_ENET0_TXD3__ENET0_TXD3 MXS_IOMUX_PAD_NAKED(4, 12, PAD_MUXSEL_0) -#define MX28_PAD_ENET0_RX_CLK__ENET0_RX_CLK MXS_IOMUX_PAD_NAKED(4, 13, PAD_MUXSEL_0) -#define MX28_PAD_ENET0_COL__ENET0_COL MXS_IOMUX_PAD_NAKED(4, 14, PAD_MUXSEL_0) -#define MX28_PAD_ENET0_CRS__ENET0_CRS MXS_IOMUX_PAD_NAKED(4, 15, PAD_MUXSEL_0) -#define MX28_PAD_ENET_CLK__CLKCTRL_ENET MXS_IOMUX_PAD_NAKED(4, 16, PAD_MUXSEL_0) -#define MX28_PAD_JTAG_RTCK__JTAG_RTCK MXS_IOMUX_PAD_NAKED(4, 20, PAD_MUXSEL_0) - -#define MX28_PAD_EMI_D00__EMI_DATA0 MXS_IOMUX_PAD_NAKED(5, 0, PAD_MUXSEL_0) -#define MX28_PAD_EMI_D01__EMI_DATA1 MXS_IOMUX_PAD_NAKED(5, 1, PAD_MUXSEL_0) -#define MX28_PAD_EMI_D02__EMI_DATA2 MXS_IOMUX_PAD_NAKED(5, 2, PAD_MUXSEL_0) -#define MX28_PAD_EMI_D03__EMI_DATA3 MXS_IOMUX_PAD_NAKED(5, 3, PAD_MUXSEL_0) -#define MX28_PAD_EMI_D04__EMI_DATA4 MXS_IOMUX_PAD_NAKED(5, 4, PAD_MUXSEL_0) -#define MX28_PAD_EMI_D05__EMI_DATA5 MXS_IOMUX_PAD_NAKED(5, 5, PAD_MUXSEL_0) -#define MX28_PAD_EMI_D06__EMI_DATA6 MXS_IOMUX_PAD_NAKED(5, 6, PAD_MUXSEL_0) -#define MX28_PAD_EMI_D07__EMI_DATA7 MXS_IOMUX_PAD_NAKED(5, 7, PAD_MUXSEL_0) -#define MX28_PAD_EMI_D08__EMI_DATA8 MXS_IOMUX_PAD_NAKED(5, 8, PAD_MUXSEL_0) -#define MX28_PAD_EMI_D09__EMI_DATA9 MXS_IOMUX_PAD_NAKED(5, 9, PAD_MUXSEL_0) -#define MX28_PAD_EMI_D10__EMI_DATA10 MXS_IOMUX_PAD_NAKED(5, 10, PAD_MUXSEL_0) -#define MX28_PAD_EMI_D11__EMI_DATA11 MXS_IOMUX_PAD_NAKED(5, 11, PAD_MUXSEL_0) -#define MX28_PAD_EMI_D12__EMI_DATA12 MXS_IOMUX_PAD_NAKED(5, 12, PAD_MUXSEL_0) -#define MX28_PAD_EMI_D13__EMI_DATA13 MXS_IOMUX_PAD_NAKED(5, 13, PAD_MUXSEL_0) -#define MX28_PAD_EMI_D14__EMI_DATA14 MXS_IOMUX_PAD_NAKED(5, 14, PAD_MUXSEL_0) -#define MX28_PAD_EMI_D15__EMI_DATA15 MXS_IOMUX_PAD_NAKED(5, 15, PAD_MUXSEL_0) -#define MX28_PAD_EMI_ODT0__EMI_ODT0 MXS_IOMUX_PAD_NAKED(5, 16, PAD_MUXSEL_0) -#define MX28_PAD_EMI_DQM0__EMI_DQM0 MXS_IOMUX_PAD_NAKED(5, 17, PAD_MUXSEL_0) -#define MX28_PAD_EMI_ODT1__EMI_ODT1 MXS_IOMUX_PAD_NAKED(5, 18, PAD_MUXSEL_0) -#define MX28_PAD_EMI_DQM1__EMI_DQM1 MXS_IOMUX_PAD_NAKED(5, 19, PAD_MUXSEL_0) -#define MX28_PAD_EMI_DDR_OPEN_FB__EMI_DDR_OPEN_FEEDBACK MXS_IOMUX_PAD_NAKED(5, 20, PAD_MUXSEL_0) -#define MX28_PAD_EMI_CLK__EMI_CLK MXS_IOMUX_PAD_NAKED(5, 21, PAD_MUXSEL_0) -#define MX28_PAD_EMI_DQS0__EMI_DQS0 MXS_IOMUX_PAD_NAKED(5, 22, PAD_MUXSEL_0) -#define MX28_PAD_EMI_DQS1__EMI_DQS1 MXS_IOMUX_PAD_NAKED(5, 23, PAD_MUXSEL_0) -#define MX28_PAD_EMI_DDR_OPEN__EMI_DDR_OPEN MXS_IOMUX_PAD_NAKED(5, 26, PAD_MUXSEL_0) - -#define MX28_PAD_EMI_A00__EMI_ADDR0 MXS_IOMUX_PAD_NAKED(6, 0, PAD_MUXSEL_0) -#define MX28_PAD_EMI_A01__EMI_ADDR1 MXS_IOMUX_PAD_NAKED(6, 1, PAD_MUXSEL_0) -#define MX28_PAD_EMI_A02__EMI_ADDR2 MXS_IOMUX_PAD_NAKED(6, 2, PAD_MUXSEL_0) -#define MX28_PAD_EMI_A03__EMI_ADDR3 MXS_IOMUX_PAD_NAKED(6, 3, PAD_MUXSEL_0) -#define MX28_PAD_EMI_A04__EMI_ADDR4 MXS_IOMUX_PAD_NAKED(6, 4, PAD_MUXSEL_0) -#define MX28_PAD_EMI_A05__EMI_ADDR5 MXS_IOMUX_PAD_NAKED(6, 5, PAD_MUXSEL_0) -#define MX28_PAD_EMI_A06__EMI_ADDR6 MXS_IOMUX_PAD_NAKED(6, 6, PAD_MUXSEL_0) -#define MX28_PAD_EMI_A07__EMI_ADDR7 MXS_IOMUX_PAD_NAKED(6, 7, PAD_MUXSEL_0) -#define MX28_PAD_EMI_A08__EMI_ADDR8 MXS_IOMUX_PAD_NAKED(6, 8, PAD_MUXSEL_0) -#define MX28_PAD_EMI_A09__EMI_ADDR9 MXS_IOMUX_PAD_NAKED(6, 9, PAD_MUXSEL_0) -#define MX28_PAD_EMI_A10__EMI_ADDR10 MXS_IOMUX_PAD_NAKED(6, 10, PAD_MUXSEL_0) -#define MX28_PAD_EMI_A11__EMI_ADDR11 MXS_IOMUX_PAD_NAKED(6, 11, PAD_MUXSEL_0) -#define MX28_PAD_EMI_A12__EMI_ADDR12 MXS_IOMUX_PAD_NAKED(6, 12, PAD_MUXSEL_0) -#define MX28_PAD_EMI_A13__EMI_ADDR13 MXS_IOMUX_PAD_NAKED(6, 13, PAD_MUXSEL_0) -#define MX28_PAD_EMI_A14__EMI_ADDR14 MXS_IOMUX_PAD_NAKED(6, 14, PAD_MUXSEL_0) -#define MX28_PAD_EMI_BA0__EMI_BA0 MXS_IOMUX_PAD_NAKED(6, 16, PAD_MUXSEL_0) -#define MX28_PAD_EMI_BA1__EMI_BA1 MXS_IOMUX_PAD_NAKED(6, 17, PAD_MUXSEL_0) -#define MX28_PAD_EMI_BA2__EMI_BA2 MXS_IOMUX_PAD_NAKED(6, 18, PAD_MUXSEL_0) -#define MX28_PAD_EMI_CASN__EMI_CASN MXS_IOMUX_PAD_NAKED(6, 19, PAD_MUXSEL_0) -#define MX28_PAD_EMI_RASN__EMI_RASN MXS_IOMUX_PAD_NAKED(6, 20, PAD_MUXSEL_0) -#define MX28_PAD_EMI_WEN__EMI_WEN MXS_IOMUX_PAD_NAKED(6, 21, PAD_MUXSEL_0) -#define MX28_PAD_EMI_CE0N__EMI_CE0N MXS_IOMUX_PAD_NAKED(6, 22, PAD_MUXSEL_0) -#define MX28_PAD_EMI_CE1N__EMI_CE1N MXS_IOMUX_PAD_NAKED(6, 23, PAD_MUXSEL_0) -#define MX28_PAD_EMI_CKE__EMI_CKE MXS_IOMUX_PAD_NAKED(6, 24, PAD_MUXSEL_0) - -/* MUXSEL_1 */ -#define MX28_PAD_GPMI_D00__SSP1_D0 MXS_IOMUX_PAD_NAKED(0, 0, PAD_MUXSEL_1) -#define MX28_PAD_GPMI_D01__SSP1_D1 MXS_IOMUX_PAD_NAKED(0, 1, PAD_MUXSEL_1) -#define MX28_PAD_GPMI_D02__SSP1_D2 MXS_IOMUX_PAD_NAKED(0, 2, PAD_MUXSEL_1) -#define MX28_PAD_GPMI_D03__SSP1_D3 MXS_IOMUX_PAD_NAKED(0, 3, PAD_MUXSEL_1) -#define MX28_PAD_GPMI_D04__SSP1_D4 MXS_IOMUX_PAD_NAKED(0, 4, PAD_MUXSEL_1) -#define MX28_PAD_GPMI_D05__SSP1_D5 MXS_IOMUX_PAD_NAKED(0, 5, PAD_MUXSEL_1) -#define MX28_PAD_GPMI_D06__SSP1_D6 MXS_IOMUX_PAD_NAKED(0, 6, PAD_MUXSEL_1) -#define MX28_PAD_GPMI_D07__SSP1_D7 MXS_IOMUX_PAD_NAKED(0, 7, PAD_MUXSEL_1) -#define MX28_PAD_GPMI_CE0N__SSP3_D0 MXS_IOMUX_PAD_NAKED(0, 16, PAD_MUXSEL_1) -#define MX28_PAD_GPMI_CE1N__SSP3_D3 MXS_IOMUX_PAD_NAKED(0, 17, PAD_MUXSEL_1) -#define MX28_PAD_GPMI_CE2N__CAN1_TX MXS_IOMUX_PAD_NAKED(0, 18, PAD_MUXSEL_1) -#define MX28_PAD_GPMI_CE3N__CAN1_RX MXS_IOMUX_PAD_NAKED(0, 19, PAD_MUXSEL_1) -#define MX28_PAD_GPMI_RDY0__SSP1_CARD_DETECT MXS_IOMUX_PAD_NAKED(0, 20, PAD_MUXSEL_1) -#define MX28_PAD_GPMI_RDY1__SSP1_CMD MXS_IOMUX_PAD_NAKED(0, 21, PAD_MUXSEL_1) -#define MX28_PAD_GPMI_RDY2__CAN0_TX MXS_IOMUX_PAD_NAKED(0, 22, PAD_MUXSEL_1) -#define MX28_PAD_GPMI_RDY3__CAN0_RX MXS_IOMUX_PAD_NAKED(0, 23, PAD_MUXSEL_1) -#define MX28_PAD_GPMI_RDN__SSP3_SCK MXS_IOMUX_PAD_NAKED(0, 24, PAD_MUXSEL_1) -#define MX28_PAD_GPMI_WRN__SSP1_SCK MXS_IOMUX_PAD_NAKED(0, 25, PAD_MUXSEL_1) -#define MX28_PAD_GPMI_ALE__SSP3_D1 MXS_IOMUX_PAD_NAKED(0, 26, PAD_MUXSEL_1) -#define MX28_PAD_GPMI_CLE__SSP3_D2 MXS_IOMUX_PAD_NAKED(0, 27, PAD_MUXSEL_1) -#define MX28_PAD_GPMI_RESETN__SSP3_CMD MXS_IOMUX_PAD_NAKED(0, 28, PAD_MUXSEL_1) - -#define MX28_PAD_LCD_D03__ETM_DA8 MXS_IOMUX_PAD_NAKED(1, 3, PAD_MUXSEL_1) -#define MX28_PAD_LCD_D04__ETM_DA9 MXS_IOMUX_PAD_NAKED(1, 4, PAD_MUXSEL_1) -#define MX28_PAD_LCD_D08__ETM_DA3 MXS_IOMUX_PAD_NAKED(1, 8, PAD_MUXSEL_1) -#define MX28_PAD_LCD_D09__ETM_DA4 MXS_IOMUX_PAD_NAKED(1, 9, PAD_MUXSEL_1) -#define MX28_PAD_LCD_D20__ENET1_1588_EVENT2_OUT MXS_IOMUX_PAD_NAKED(1, 20, PAD_MUXSEL_1) -#define MX28_PAD_LCD_D21__ENET1_1588_EVENT2_IN MXS_IOMUX_PAD_NAKED(1, 21, PAD_MUXSEL_1) -#define MX28_PAD_LCD_D22__ENET1_1588_EVENT3_OUT MXS_IOMUX_PAD_NAKED(1, 22, PAD_MUXSEL_1) -#define MX28_PAD_LCD_D23__ENET1_1588_EVENT3_IN MXS_IOMUX_PAD_NAKED(1, 23, PAD_MUXSEL_1) -#define MX28_PAD_LCD_RD_E__LCD_VSYNC MXS_IOMUX_PAD_NAKED(1, 24, PAD_MUXSEL_1) -#define MX28_PAD_LCD_WR_RWN__LCD_HSYNC MXS_IOMUX_PAD_NAKED(1, 25, PAD_MUXSEL_1) -#define MX28_PAD_LCD_RS__LCD_DOTCLK MXS_IOMUX_PAD_NAKED(1, 26, PAD_MUXSEL_1) -#define MX28_PAD_LCD_CS__LCD_ENABLE MXS_IOMUX_PAD_NAKED(1, 27, PAD_MUXSEL_1) -#define MX28_PAD_LCD_VSYNC__SAIF1_SDATA0 MXS_IOMUX_PAD_NAKED(1, 28, PAD_MUXSEL_1) -#define MX28_PAD_LCD_HSYNC__SAIF1_SDATA1 MXS_IOMUX_PAD_NAKED(1, 29, PAD_MUXSEL_1) -#define MX28_PAD_LCD_DOTCLK__SAIF1_MCLK MXS_IOMUX_PAD_NAKED(1, 30, PAD_MUXSEL_1) - -#define MX28_PAD_SSP0_DATA4__SSP2_D0 MXS_IOMUX_PAD_NAKED(2, 4, PAD_MUXSEL_1) -#define MX28_PAD_SSP0_DATA5__SSP2_D3 MXS_IOMUX_PAD_NAKED(2, 5, PAD_MUXSEL_1) -#define MX28_PAD_SSP0_DATA6__SSP2_CMD MXS_IOMUX_PAD_NAKED(2, 6, PAD_MUXSEL_1) -#define MX28_PAD_SSP0_DATA7__SSP2_SCK MXS_IOMUX_PAD_NAKED(2, 7, PAD_MUXSEL_1) -#define MX28_PAD_SSP1_SCK__SSP2_D1 MXS_IOMUX_PAD_NAKED(2, 12, PAD_MUXSEL_1) -#define MX28_PAD_SSP1_CMD__SSP2_D2 MXS_IOMUX_PAD_NAKED(2, 13, PAD_MUXSEL_1) -#define MX28_PAD_SSP1_DATA0__SSP2_D6 MXS_IOMUX_PAD_NAKED(2, 14, PAD_MUXSEL_1) -#define MX28_PAD_SSP1_DATA3__SSP2_D7 MXS_IOMUX_PAD_NAKED(2, 15, PAD_MUXSEL_1) -#define MX28_PAD_SSP2_SCK__AUART2_RX MXS_IOMUX_PAD_NAKED(2, 16, PAD_MUXSEL_1) -#define MX28_PAD_SSP2_MOSI__AUART2_TX MXS_IOMUX_PAD_NAKED(2, 17, PAD_MUXSEL_1) -#define MX28_PAD_SSP2_MISO__AUART3_RX MXS_IOMUX_PAD_NAKED(2, 18, PAD_MUXSEL_1) -#define MX28_PAD_SSP2_SS0__AUART3_TX MXS_IOMUX_PAD_NAKED(2, 19, PAD_MUXSEL_1) -#define MX28_PAD_SSP2_SS1__SSP2_D1 MXS_IOMUX_PAD_NAKED(2, 20, PAD_MUXSEL_1) -#define MX28_PAD_SSP2_SS2__SSP2_D2 MXS_IOMUX_PAD_NAKED(2, 21, PAD_MUXSEL_1) -#define MX28_PAD_SSP3_SCK__AUART4_TX MXS_IOMUX_PAD_NAKED(2, 24, PAD_MUXSEL_1) -#define MX28_PAD_SSP3_MOSI__AUART4_RX MXS_IOMUX_PAD_NAKED(2, 25, PAD_MUXSEL_1) -#define MX28_PAD_SSP3_MISO__AUART4_RTS MXS_IOMUX_PAD_NAKED(2, 26, PAD_MUXSEL_1) -#define MX28_PAD_SSP3_SS0__AUART4_CTS MXS_IOMUX_PAD_NAKED(2, 27, PAD_MUXSEL_1) - -#define MX28_PAD_AUART0_RX__I2C0_SCL MXS_IOMUX_PAD_NAKED(3, 0, PAD_MUXSEL_1) -#define MX28_PAD_AUART0_TX__I2C0_SDA MXS_IOMUX_PAD_NAKED(3, 1, PAD_MUXSEL_1) -#define MX28_PAD_AUART0_CTS__AUART4_RX MXS_IOMUX_PAD_NAKED(3, 2, PAD_MUXSEL_1) -#define MX28_PAD_AUART0_RTS__AUART4_TX MXS_IOMUX_PAD_NAKED(3, 3, PAD_MUXSEL_1) -#define MX28_PAD_AUART1_RX__SSP2_CARD_DETECT MXS_IOMUX_PAD_NAKED(3, 4, PAD_MUXSEL_1) -#define MX28_PAD_AUART1_TX__SSP3_CARD_DETECT MXS_IOMUX_PAD_NAKED(3, 5, PAD_MUXSEL_1) -#define MX28_PAD_AUART1_CTS__USB0_OVERCURRENT MXS_IOMUX_PAD_NAKED(3, 6, PAD_MUXSEL_1) -#define MX28_PAD_AUART1_RTS__USB0_ID MXS_IOMUX_PAD_NAKED(3, 7, PAD_MUXSEL_1) -#define MX28_PAD_AUART2_RX__SSP3_D1 MXS_IOMUX_PAD_NAKED(3, 8, PAD_MUXSEL_1) -#define MX28_PAD_AUART2_TX__SSP3_D2 MXS_IOMUX_PAD_NAKED(3, 9, PAD_MUXSEL_1) -#define MX28_PAD_AUART2_CTS__I2C1_SCL MXS_IOMUX_PAD_NAKED(3, 10, PAD_MUXSEL_1) -#define MX28_PAD_AUART2_RTS__I2C1_SDA MXS_IOMUX_PAD_NAKED(3, 11, PAD_MUXSEL_1) -#define MX28_PAD_AUART3_RX__CAN0_TX MXS_IOMUX_PAD_NAKED(3, 12, PAD_MUXSEL_1) -#define MX28_PAD_AUART3_TX__CAN0_RX MXS_IOMUX_PAD_NAKED(3, 13, PAD_MUXSEL_1) -#define MX28_PAD_AUART3_CTS__CAN1_TX MXS_IOMUX_PAD_NAKED(3, 14, PAD_MUXSEL_1) -#define MX28_PAD_AUART3_RTS__CAN1_RX MXS_IOMUX_PAD_NAKED(3, 15, PAD_MUXSEL_1) -#define MX28_PAD_PWM0__I2C1_SCL MXS_IOMUX_PAD_NAKED(3, 16, PAD_MUXSEL_1) -#define MX28_PAD_PWM1__I2C1_SDA MXS_IOMUX_PAD_NAKED(3, 17, PAD_MUXSEL_1) -#define MX28_PAD_PWM2__USB0_ID MXS_IOMUX_PAD_NAKED(3, 18, PAD_MUXSEL_1) -#define MX28_PAD_SAIF0_MCLK__PWM_3 MXS_IOMUX_PAD_NAKED(3, 20, PAD_MUXSEL_1) -#define MX28_PAD_SAIF0_LRCLK__PWM_4 MXS_IOMUX_PAD_NAKED(3, 21, PAD_MUXSEL_1) -#define MX28_PAD_SAIF0_BITCLK__PWM_5 MXS_IOMUX_PAD_NAKED(3, 22, PAD_MUXSEL_1) -#define MX28_PAD_SAIF0_SDATA0__PWM_6 MXS_IOMUX_PAD_NAKED(3, 23, PAD_MUXSEL_1) -#define MX28_PAD_I2C0_SCL__TIMROT_ROTARYA MXS_IOMUX_PAD_NAKED(3, 24, PAD_MUXSEL_1) -#define MX28_PAD_I2C0_SDA__TIMROT_ROTARYB MXS_IOMUX_PAD_NAKED(3, 25, PAD_MUXSEL_1) -#define MX28_PAD_SAIF1_SDATA0__PWM_7 MXS_IOMUX_PAD_NAKED(3, 26, PAD_MUXSEL_1) -#define MX28_PAD_LCD_RESET__LCD_VSYNC MXS_IOMUX_PAD_NAKED(3, 30, PAD_MUXSEL_1) - -#define MX28_PAD_ENET0_MDC__GPMI_CE4N MXS_IOMUX_PAD_NAKED(4, 0, PAD_MUXSEL_1) -#define MX28_PAD_ENET0_MDIO__GPMI_CE5N MXS_IOMUX_PAD_NAKED(4, 1, PAD_MUXSEL_1) -#define MX28_PAD_ENET0_RX_EN__GPMI_CE6N MXS_IOMUX_PAD_NAKED(4, 2, PAD_MUXSEL_1) -#define MX28_PAD_ENET0_RXD0__GPMI_CE7N MXS_IOMUX_PAD_NAKED(4, 3, PAD_MUXSEL_1) -#define MX28_PAD_ENET0_RXD1__GPMI_READY4 MXS_IOMUX_PAD_NAKED(4, 4, PAD_MUXSEL_1) -#define MX28_PAD_ENET0_TX_CLK__HSADC_TRIGGER MXS_IOMUX_PAD_NAKED(4, 5, PAD_MUXSEL_1) -#define MX28_PAD_ENET0_TX_EN__GPMI_READY5 MXS_IOMUX_PAD_NAKED(4, 6, PAD_MUXSEL_1) -#define MX28_PAD_ENET0_TXD0__GPMI_READY6 MXS_IOMUX_PAD_NAKED(4, 7, PAD_MUXSEL_1) -#define MX28_PAD_ENET0_TXD1__GPMI_READY7 MXS_IOMUX_PAD_NAKED(4, 8, PAD_MUXSEL_1) -#define MX28_PAD_ENET0_RXD2__ENET1_RXD0 MXS_IOMUX_PAD_NAKED(4, 9, PAD_MUXSEL_1) -#define MX28_PAD_ENET0_RXD3__ENET1_RXD1 MXS_IOMUX_PAD_NAKED(4, 10, PAD_MUXSEL_1) -#define MX28_PAD_ENET0_TXD2__ENET1_TXD0 MXS_IOMUX_PAD_NAKED(4, 11, PAD_MUXSEL_1) -#define MX28_PAD_ENET0_TXD3__ENET1_TXD1 MXS_IOMUX_PAD_NAKED(4, 12, PAD_MUXSEL_1) -#define MX28_PAD_ENET0_RX_CLK__ENET0_RX_ER MXS_IOMUX_PAD_NAKED(4, 13, PAD_MUXSEL_1) -#define MX28_PAD_ENET0_COL__ENET1_TX_EN MXS_IOMUX_PAD_NAKED(4, 14, PAD_MUXSEL_1) -#define MX28_PAD_ENET0_CRS__ENET1_RX_EN MXS_IOMUX_PAD_NAKED(4, 15, PAD_MUXSEL_1) - -/* MUXSEL_2 */ -#define MX28_PAD_GPMI_CE2N__ENET0_RX_ER MXS_IOMUX_PAD_NAKED(0, 18, PAD_MUXSEL_2) -#define MX28_PAD_GPMI_CE3N__SAIF1_MCLK MXS_IOMUX_PAD_NAKED(0, 19, PAD_MUXSEL_2) -#define MX28_PAD_GPMI_RDY0__USB0_ID MXS_IOMUX_PAD_NAKED(0, 20, PAD_MUXSEL_2) -#define MX28_PAD_GPMI_RDY2__ENET0_TX_ER MXS_IOMUX_PAD_NAKED(0, 22, PAD_MUXSEL_2) -#define MX28_PAD_GPMI_RDY3__HSADC_TRIGGER MXS_IOMUX_PAD_NAKED(0, 23, PAD_MUXSEL_2) -#define MX28_PAD_GPMI_ALE__SSP3_D4 MXS_IOMUX_PAD_NAKED(0, 26, PAD_MUXSEL_2) -#define MX28_PAD_GPMI_CLE__SSP3_D5 MXS_IOMUX_PAD_NAKED(0, 27, PAD_MUXSEL_2) - -#define MX28_PAD_LCD_D00__ETM_DA0 MXS_IOMUX_PAD_NAKED(1, 0, PAD_MUXSEL_2) -#define MX28_PAD_LCD_D01__ETM_DA1 MXS_IOMUX_PAD_NAKED(1, 1, PAD_MUXSEL_2) -#define MX28_PAD_LCD_D02__ETM_DA2 MXS_IOMUX_PAD_NAKED(1, 2, PAD_MUXSEL_2) -#define MX28_PAD_LCD_D03__ETM_DA3 MXS_IOMUX_PAD_NAKED(1, 3, PAD_MUXSEL_2) -#define MX28_PAD_LCD_D04__ETM_DA4 MXS_IOMUX_PAD_NAKED(1, 4, PAD_MUXSEL_2) -#define MX28_PAD_LCD_D05__ETM_DA5 MXS_IOMUX_PAD_NAKED(1, 5, PAD_MUXSEL_2) -#define MX28_PAD_LCD_D06__ETM_DA6 MXS_IOMUX_PAD_NAKED(1, 6, PAD_MUXSEL_2) -#define MX28_PAD_LCD_D07__ETM_DA7 MXS_IOMUX_PAD_NAKED(1, 7, PAD_MUXSEL_2) -#define MX28_PAD_LCD_D08__ETM_DA8 MXS_IOMUX_PAD_NAKED(1, 8, PAD_MUXSEL_2) -#define MX28_PAD_LCD_D09__ETM_DA9 MXS_IOMUX_PAD_NAKED(1, 9, PAD_MUXSEL_2) -#define MX28_PAD_LCD_D10__ETM_DA10 MXS_IOMUX_PAD_NAKED(1, 10, PAD_MUXSEL_2) -#define MX28_PAD_LCD_D11__ETM_DA11 MXS_IOMUX_PAD_NAKED(1, 11, PAD_MUXSEL_2) -#define MX28_PAD_LCD_D12__ETM_DA12 MXS_IOMUX_PAD_NAKED(1, 12, PAD_MUXSEL_2) -#define MX28_PAD_LCD_D13__ETM_DA13 MXS_IOMUX_PAD_NAKED(1, 13, PAD_MUXSEL_2) -#define MX28_PAD_LCD_D14__ETM_DA14 MXS_IOMUX_PAD_NAKED(1, 14, PAD_MUXSEL_2) -#define MX28_PAD_LCD_D15__ETM_DA15 MXS_IOMUX_PAD_NAKED(1, 15, PAD_MUXSEL_2) -#define MX28_PAD_LCD_D16__ETM_DA7 MXS_IOMUX_PAD_NAKED(1, 16, PAD_MUXSEL_2) -#define MX28_PAD_LCD_D17__ETM_DA6 MXS_IOMUX_PAD_NAKED(1, 17, PAD_MUXSEL_2) -#define MX28_PAD_LCD_D18__ETM_DA5 MXS_IOMUX_PAD_NAKED(1, 18, PAD_MUXSEL_2) -#define MX28_PAD_LCD_D19__ETM_DA4 MXS_IOMUX_PAD_NAKED(1, 19, PAD_MUXSEL_2) -#define MX28_PAD_LCD_D20__ETM_DA3 MXS_IOMUX_PAD_NAKED(1, 20, PAD_MUXSEL_2) -#define MX28_PAD_LCD_D21__ETM_DA2 MXS_IOMUX_PAD_NAKED(1, 21, PAD_MUXSEL_2) -#define MX28_PAD_LCD_D22__ETM_DA1 MXS_IOMUX_PAD_NAKED(1, 22, PAD_MUXSEL_2) -#define MX28_PAD_LCD_D23__ETM_DA0 MXS_IOMUX_PAD_NAKED(1, 23, PAD_MUXSEL_2) -#define MX28_PAD_LCD_RD_E__ETM_TCTL MXS_IOMUX_PAD_NAKED(1, 24, PAD_MUXSEL_2) -#define MX28_PAD_LCD_WR_RWN__ETM_TCLK MXS_IOMUX_PAD_NAKED(1, 25, PAD_MUXSEL_2) -#define MX28_PAD_LCD_HSYNC__ETM_TCTL MXS_IOMUX_PAD_NAKED(1, 29, PAD_MUXSEL_2) -#define MX28_PAD_LCD_DOTCLK__ETM_TCLK MXS_IOMUX_PAD_NAKED(1, 30, PAD_MUXSEL_2) - -#define MX28_PAD_SSP1_SCK__ENET0_1588_EVENT2_OUT MXS_IOMUX_PAD_NAKED(2, 12, PAD_MUXSEL_2) -#define MX28_PAD_SSP1_CMD__ENET0_1588_EVENT2_IN MXS_IOMUX_PAD_NAKED(2, 13, PAD_MUXSEL_2) -#define MX28_PAD_SSP1_DATA0__ENET0_1588_EVENT3_OUT MXS_IOMUX_PAD_NAKED(2, 14, PAD_MUXSEL_2) -#define MX28_PAD_SSP1_DATA3__ENET0_1588_EVENT3_IN MXS_IOMUX_PAD_NAKED(2, 15, PAD_MUXSEL_2) -#define MX28_PAD_SSP2_SCK__SAIF0_SDATA1 MXS_IOMUX_PAD_NAKED(2, 16, PAD_MUXSEL_2) -#define MX28_PAD_SSP2_MOSI__SAIF0_SDATA2 MXS_IOMUX_PAD_NAKED(2, 17, PAD_MUXSEL_2) -#define MX28_PAD_SSP2_MISO__SAIF1_SDATA1 MXS_IOMUX_PAD_NAKED(2, 18, PAD_MUXSEL_2) -#define MX28_PAD_SSP2_SS0__SAIF1_SDATA2 MXS_IOMUX_PAD_NAKED(2, 19, PAD_MUXSEL_2) -#define MX28_PAD_SSP2_SS1__USB1_OVERCURRENT MXS_IOMUX_PAD_NAKED(2, 20, PAD_MUXSEL_2) -#define MX28_PAD_SSP2_SS2__USB0_OVERCURRENT MXS_IOMUX_PAD_NAKED(2, 21, PAD_MUXSEL_2) -#define MX28_PAD_SSP3_SCK__ENET1_1588_EVENT0_OUT MXS_IOMUX_PAD_NAKED(2, 24, PAD_MUXSEL_2) -#define MX28_PAD_SSP3_MOSI__ENET1_1588_EVENT0_IN MXS_IOMUX_PAD_NAKED(2, 25, PAD_MUXSEL_2) -#define MX28_PAD_SSP3_MISO__ENET1_1588_EVENT1_OUT MXS_IOMUX_PAD_NAKED(2, 26, PAD_MUXSEL_2) -#define MX28_PAD_SSP3_SS0__ENET1_1588_EVENT1_IN MXS_IOMUX_PAD_NAKED(2, 27, PAD_MUXSEL_2) - -#define MX28_PAD_AUART0_RX__DUART_CTS MXS_IOMUX_PAD_NAKED(3, 0, PAD_MUXSEL_2) -#define MX28_PAD_AUART0_TX__DUART_RTS MXS_IOMUX_PAD_NAKED(3, 1, PAD_MUXSEL_2) -#define MX28_PAD_AUART0_CTS__DUART_RX MXS_IOMUX_PAD_NAKED(3, 2, PAD_MUXSEL_2) -#define MX28_PAD_AUART0_RTS__DUART_TX MXS_IOMUX_PAD_NAKED(3, 3, PAD_MUXSEL_2) -#define MX28_PAD_AUART1_RX__PWM_0 MXS_IOMUX_PAD_NAKED(3, 4, PAD_MUXSEL_2) -#define MX28_PAD_AUART1_TX__PWM_1 MXS_IOMUX_PAD_NAKED(3, 5, PAD_MUXSEL_2) -#define MX28_PAD_AUART1_CTS__TIMROT_ROTARYA MXS_IOMUX_PAD_NAKED(3, 6, PAD_MUXSEL_2) -#define MX28_PAD_AUART1_RTS__TIMROT_ROTARYB MXS_IOMUX_PAD_NAKED(3, 7, PAD_MUXSEL_2) -#define MX28_PAD_AUART2_RX__SSP3_D4 MXS_IOMUX_PAD_NAKED(3, 8, PAD_MUXSEL_2) -#define MX28_PAD_AUART2_TX__SSP3_D5 MXS_IOMUX_PAD_NAKED(3, 9, PAD_MUXSEL_2) -#define MX28_PAD_AUART2_CTS__SAIF1_BITCLK MXS_IOMUX_PAD_NAKED(3, 10, PAD_MUXSEL_2) -#define MX28_PAD_AUART2_RTS__SAIF1_LRCLK MXS_IOMUX_PAD_NAKED(3, 11, PAD_MUXSEL_2) -#define MX28_PAD_AUART3_RX__ENET0_1588_EVENT0_OUT MXS_IOMUX_PAD_NAKED(3, 12, PAD_MUXSEL_2) -#define MX28_PAD_AUART3_TX__ENET0_1588_EVENT0_IN MXS_IOMUX_PAD_NAKED(3, 13, PAD_MUXSEL_2) -#define MX28_PAD_AUART3_CTS__ENET0_1588_EVENT1_OUT MXS_IOMUX_PAD_NAKED(3, 14, PAD_MUXSEL_2) -#define MX28_PAD_AUART3_RTS__ENET0_1588_EVENT1_IN MXS_IOMUX_PAD_NAKED(3, 15, PAD_MUXSEL_2) -#define MX28_PAD_PWM0__DUART_RX MXS_IOMUX_PAD_NAKED(3, 16, PAD_MUXSEL_2) -#define MX28_PAD_PWM1__DUART_TX MXS_IOMUX_PAD_NAKED(3, 17, PAD_MUXSEL_2) -#define MX28_PAD_PWM2__USB1_OVERCURRENT MXS_IOMUX_PAD_NAKED(3, 18, PAD_MUXSEL_2) -#define MX28_PAD_SAIF0_MCLK__AUART4_CTS MXS_IOMUX_PAD_NAKED(3, 20, PAD_MUXSEL_2) -#define MX28_PAD_SAIF0_LRCLK__AUART4_RTS MXS_IOMUX_PAD_NAKED(3, 21, PAD_MUXSEL_2) -#define MX28_PAD_SAIF0_BITCLK__AUART4_RX MXS_IOMUX_PAD_NAKED(3, 22, PAD_MUXSEL_2) -#define MX28_PAD_SAIF0_SDATA0__AUART4_TX MXS_IOMUX_PAD_NAKED(3, 23, PAD_MUXSEL_2) -#define MX28_PAD_I2C0_SCL__DUART_RX MXS_IOMUX_PAD_NAKED(3, 24, PAD_MUXSEL_2) -#define MX28_PAD_I2C0_SDA__DUART_TX MXS_IOMUX_PAD_NAKED(3, 25, PAD_MUXSEL_2) -#define MX28_PAD_SAIF1_SDATA0__SAIF0_SDATA1 MXS_IOMUX_PAD_NAKED(3, 26, PAD_MUXSEL_2) -#define MX28_PAD_SPDIF__ENET1_RX_ER MXS_IOMUX_PAD_NAKED(3, 27, PAD_MUXSEL_2) - -#define MX28_PAD_ENET0_MDC__SAIF0_SDATA1 MXS_IOMUX_PAD_NAKED(4, 0, PAD_MUXSEL_2) -#define MX28_PAD_ENET0_MDIO__SAIF0_SDATA2 MXS_IOMUX_PAD_NAKED(4, 1, PAD_MUXSEL_2) -#define MX28_PAD_ENET0_RX_EN__SAIF1_SDATA1 MXS_IOMUX_PAD_NAKED(4, 2, PAD_MUXSEL_2) -#define MX28_PAD_ENET0_RXD0__SAIF1_SDATA2 MXS_IOMUX_PAD_NAKED(4, 3, PAD_MUXSEL_2) -#define MX28_PAD_ENET0_TX_CLK__ENET0_1588_EVENT2_OUT MXS_IOMUX_PAD_NAKED(4, 5, PAD_MUXSEL_2) -#define MX28_PAD_ENET0_RXD2__ENET0_1588_EVENT0_OUT MXS_IOMUX_PAD_NAKED(4, 9, PAD_MUXSEL_2) -#define MX28_PAD_ENET0_RXD3__ENET0_1588_EVENT0_IN MXS_IOMUX_PAD_NAKED(4, 10, PAD_MUXSEL_2) -#define MX28_PAD_ENET0_TXD2__ENET0_1588_EVENT1_OUT MXS_IOMUX_PAD_NAKED(4, 11, PAD_MUXSEL_2) -#define MX28_PAD_ENET0_TXD3__ENET0_1588_EVENT1_IN MXS_IOMUX_PAD_NAKED(4, 12, PAD_MUXSEL_2) -#define MX28_PAD_ENET0_RX_CLK__ENET0_1588_EVENT2_IN MXS_IOMUX_PAD_NAKED(4, 13, PAD_MUXSEL_2) -#define MX28_PAD_ENET0_COL__ENET0_1588_EVENT3_OUT MXS_IOMUX_PAD_NAKED(4, 14, PAD_MUXSEL_2) -#define MX28_PAD_ENET0_CRS__ENET0_1588_EVENT3_IN MXS_IOMUX_PAD_NAKED(4, 15, PAD_MUXSEL_2) - -/* MUXSEL_GPIO */ -#define MX28_PAD_GPMI_D00__GPIO_0_0 MXS_IOMUX_PAD_NAKED(0, 0, PAD_MUXSEL_GPIO) -#define MX28_PAD_GPMI_D01__GPIO_0_1 MXS_IOMUX_PAD_NAKED(0, 1, PAD_MUXSEL_GPIO) -#define MX28_PAD_GPMI_D02__GPIO_0_2 MXS_IOMUX_PAD_NAKED(0, 2, PAD_MUXSEL_GPIO) -#define MX28_PAD_GPMI_D03__GPIO_0_3 MXS_IOMUX_PAD_NAKED(0, 3, PAD_MUXSEL_GPIO) -#define MX28_PAD_GPMI_D04__GPIO_0_4 MXS_IOMUX_PAD_NAKED(0, 4, PAD_MUXSEL_GPIO) -#define MX28_PAD_GPMI_D05__GPIO_0_5 MXS_IOMUX_PAD_NAKED(0, 5, PAD_MUXSEL_GPIO) -#define MX28_PAD_GPMI_D06__GPIO_0_6 MXS_IOMUX_PAD_NAKED(0, 6, PAD_MUXSEL_GPIO) -#define MX28_PAD_GPMI_D07__GPIO_0_7 MXS_IOMUX_PAD_NAKED(0, 7, PAD_MUXSEL_GPIO) -#define MX28_PAD_GPMI_CE0N__GPIO_0_16 MXS_IOMUX_PAD_NAKED(0, 16, PAD_MUXSEL_GPIO) -#define MX28_PAD_GPMI_CE1N__GPIO_0_17 MXS_IOMUX_PAD_NAKED(0, 17, PAD_MUXSEL_GPIO) -#define MX28_PAD_GPMI_CE2N__GPIO_0_18 MXS_IOMUX_PAD_NAKED(0, 18, PAD_MUXSEL_GPIO) -#define MX28_PAD_GPMI_CE3N__GPIO_0_19 MXS_IOMUX_PAD_NAKED(0, 19, PAD_MUXSEL_GPIO) -#define MX28_PAD_GPMI_RDY0__GPIO_0_20 MXS_IOMUX_PAD_NAKED(0, 20, PAD_MUXSEL_GPIO) -#define MX28_PAD_GPMI_RDY1__GPIO_0_21 MXS_IOMUX_PAD_NAKED(0, 21, PAD_MUXSEL_GPIO) -#define MX28_PAD_GPMI_RDY2__GPIO_0_22 MXS_IOMUX_PAD_NAKED(0, 22, PAD_MUXSEL_GPIO) -#define MX28_PAD_GPMI_RDY3__GPIO_0_23 MXS_IOMUX_PAD_NAKED(0, 23, PAD_MUXSEL_GPIO) -#define MX28_PAD_GPMI_RDN__GPIO_0_24 MXS_IOMUX_PAD_NAKED(0, 24, PAD_MUXSEL_GPIO) -#define MX28_PAD_GPMI_WRN__GPIO_0_25 MXS_IOMUX_PAD_NAKED(0, 25, PAD_MUXSEL_GPIO) -#define MX28_PAD_GPMI_ALE__GPIO_0_26 MXS_IOMUX_PAD_NAKED(0, 26, PAD_MUXSEL_GPIO) -#define MX28_PAD_GPMI_CLE__GPIO_0_27 MXS_IOMUX_PAD_NAKED(0, 27, PAD_MUXSEL_GPIO) -#define MX28_PAD_GPMI_RESETN__GPIO_0_28 MXS_IOMUX_PAD_NAKED(0, 28, PAD_MUXSEL_GPIO) - -#define MX28_PAD_LCD_D00__GPIO_1_0 MXS_IOMUX_PAD_NAKED(1, 0, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_D01__GPIO_1_1 MXS_IOMUX_PAD_NAKED(1, 1, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_D02__GPIO_1_2 MXS_IOMUX_PAD_NAKED(1, 2, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_D03__GPIO_1_3 MXS_IOMUX_PAD_NAKED(1, 3, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_D04__GPIO_1_4 MXS_IOMUX_PAD_NAKED(1, 4, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_D05__GPIO_1_5 MXS_IOMUX_PAD_NAKED(1, 5, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_D06__GPIO_1_6 MXS_IOMUX_PAD_NAKED(1, 6, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_D07__GPIO_1_7 MXS_IOMUX_PAD_NAKED(1, 7, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_D08__GPIO_1_8 MXS_IOMUX_PAD_NAKED(1, 8, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_D09__GPIO_1_9 MXS_IOMUX_PAD_NAKED(1, 9, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_D10__GPIO_1_10 MXS_IOMUX_PAD_NAKED(1, 10, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_D11__GPIO_1_11 MXS_IOMUX_PAD_NAKED(1, 11, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_D12__GPIO_1_12 MXS_IOMUX_PAD_NAKED(1, 12, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_D13__GPIO_1_13 MXS_IOMUX_PAD_NAKED(1, 13, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_D14__GPIO_1_14 MXS_IOMUX_PAD_NAKED(1, 14, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_D15__GPIO_1_15 MXS_IOMUX_PAD_NAKED(1, 15, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_D16__GPIO_1_16 MXS_IOMUX_PAD_NAKED(1, 16, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_D17__GPIO_1_17 MXS_IOMUX_PAD_NAKED(1, 17, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_D18__GPIO_1_18 MXS_IOMUX_PAD_NAKED(1, 18, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_D19__GPIO_1_19 MXS_IOMUX_PAD_NAKED(1, 19, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_D20__GPIO_1_20 MXS_IOMUX_PAD_NAKED(1, 20, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_D21__GPIO_1_21 MXS_IOMUX_PAD_NAKED(1, 21, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_D22__GPIO_1_22 MXS_IOMUX_PAD_NAKED(1, 22, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_D23__GPIO_1_23 MXS_IOMUX_PAD_NAKED(1, 23, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_RD_E__GPIO_1_24 MXS_IOMUX_PAD_NAKED(1, 24, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_WR_RWN__GPIO_1_25 MXS_IOMUX_PAD_NAKED(1, 25, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_RS__GPIO_1_26 MXS_IOMUX_PAD_NAKED(1, 26, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_CS__GPIO_1_27 MXS_IOMUX_PAD_NAKED(1, 27, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_VSYNC__GPIO_1_28 MXS_IOMUX_PAD_NAKED(1, 28, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_HSYNC__GPIO_1_29 MXS_IOMUX_PAD_NAKED(1, 29, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_DOTCLK__GPIO_1_30 MXS_IOMUX_PAD_NAKED(1, 30, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_ENABLE__GPIO_1_31 MXS_IOMUX_PAD_NAKED(1, 31, PAD_MUXSEL_GPIO) - -#define MX28_PAD_SSP0_DATA0__GPIO_2_0 MXS_IOMUX_PAD_NAKED(2, 0, PAD_MUXSEL_GPIO) -#define MX28_PAD_SSP0_DATA1__GPIO_2_1 MXS_IOMUX_PAD_NAKED(2, 1, PAD_MUXSEL_GPIO) -#define MX28_PAD_SSP0_DATA2__GPIO_2_2 MXS_IOMUX_PAD_NAKED(2, 2, PAD_MUXSEL_GPIO) -#define MX28_PAD_SSP0_DATA3__GPIO_2_3 MXS_IOMUX_PAD_NAKED(2, 3, PAD_MUXSEL_GPIO) -#define MX28_PAD_SSP0_DATA4__GPIO_2_4 MXS_IOMUX_PAD_NAKED(2, 4, PAD_MUXSEL_GPIO) -#define MX28_PAD_SSP0_DATA5__GPIO_2_5 MXS_IOMUX_PAD_NAKED(2, 5, PAD_MUXSEL_GPIO) -#define MX28_PAD_SSP0_DATA6__GPIO_2_6 MXS_IOMUX_PAD_NAKED(2, 6, PAD_MUXSEL_GPIO) -#define MX28_PAD_SSP0_DATA7__GPIO_2_7 MXS_IOMUX_PAD_NAKED(2, 7, PAD_MUXSEL_GPIO) -#define MX28_PAD_SSP0_CMD__GPIO_2_8 MXS_IOMUX_PAD_NAKED(2, 8, PAD_MUXSEL_GPIO) -#define MX28_PAD_SSP0_DETECT__GPIO_2_9 MXS_IOMUX_PAD_NAKED(2, 9, PAD_MUXSEL_GPIO) -#define MX28_PAD_SSP0_SCK__GPIO_2_10 MXS_IOMUX_PAD_NAKED(2, 10, PAD_MUXSEL_GPIO) -#define MX28_PAD_SSP1_SCK__GPIO_2_12 MXS_IOMUX_PAD_NAKED(2, 12, PAD_MUXSEL_GPIO) -#define MX28_PAD_SSP1_CMD__GPIO_2_13 MXS_IOMUX_PAD_NAKED(2, 13, PAD_MUXSEL_GPIO) -#define MX28_PAD_SSP1_DATA0__GPIO_2_14 MXS_IOMUX_PAD_NAKED(2, 14, PAD_MUXSEL_GPIO) -#define MX28_PAD_SSP1_DATA3__GPIO_2_15 MXS_IOMUX_PAD_NAKED(2, 15, PAD_MUXSEL_GPIO) -#define MX28_PAD_SSP2_SCK__GPIO_2_16 MXS_IOMUX_PAD_NAKED(2, 16, PAD_MUXSEL_GPIO) -#define MX28_PAD_SSP2_MOSI__GPIO_2_17 MXS_IOMUX_PAD_NAKED(2, 17, PAD_MUXSEL_GPIO) -#define MX28_PAD_SSP2_MISO__GPIO_2_18 MXS_IOMUX_PAD_NAKED(2, 18, PAD_MUXSEL_GPIO) -#define MX28_PAD_SSP2_SS0__GPIO_2_19 MXS_IOMUX_PAD_NAKED(2, 19, PAD_MUXSEL_GPIO) -#define MX28_PAD_SSP2_SS1__GPIO_2_20 MXS_IOMUX_PAD_NAKED(2, 20, PAD_MUXSEL_GPIO) -#define MX28_PAD_SSP2_SS2__GPIO_2_21 MXS_IOMUX_PAD_NAKED(2, 21, PAD_MUXSEL_GPIO) -#define MX28_PAD_SSP3_SCK__GPIO_2_24 MXS_IOMUX_PAD_NAKED(2, 24, PAD_MUXSEL_GPIO) -#define MX28_PAD_SSP3_MOSI__GPIO_2_25 MXS_IOMUX_PAD_NAKED(2, 25, PAD_MUXSEL_GPIO) -#define MX28_PAD_SSP3_MISO__GPIO_2_26 MXS_IOMUX_PAD_NAKED(2, 26, PAD_MUXSEL_GPIO) -#define MX28_PAD_SSP3_SS0__GPIO_2_27 MXS_IOMUX_PAD_NAKED(2, 27, PAD_MUXSEL_GPIO) - -#define MX28_PAD_AUART0_RX__GPIO_3_0 MXS_IOMUX_PAD_NAKED(3, 0, PAD_MUXSEL_GPIO) -#define MX28_PAD_AUART0_TX__GPIO_3_1 MXS_IOMUX_PAD_NAKED(3, 1, PAD_MUXSEL_GPIO) -#define MX28_PAD_AUART0_CTS__GPIO_3_2 MXS_IOMUX_PAD_NAKED(3, 2, PAD_MUXSEL_GPIO) -#define MX28_PAD_AUART0_RTS__GPIO_3_3 MXS_IOMUX_PAD_NAKED(3, 3, PAD_MUXSEL_GPIO) -#define MX28_PAD_AUART1_RX__GPIO_3_4 MXS_IOMUX_PAD_NAKED(3, 4, PAD_MUXSEL_GPIO) -#define MX28_PAD_AUART1_TX__GPIO_3_5 MXS_IOMUX_PAD_NAKED(3, 5, PAD_MUXSEL_GPIO) -#define MX28_PAD_AUART1_CTS__GPIO_3_6 MXS_IOMUX_PAD_NAKED(3, 6, PAD_MUXSEL_GPIO) -#define MX28_PAD_AUART1_RTS__GPIO_3_7 MXS_IOMUX_PAD_NAKED(3, 7, PAD_MUXSEL_GPIO) -#define MX28_PAD_AUART2_RX__GPIO_3_8 MXS_IOMUX_PAD_NAKED(3, 8, PAD_MUXSEL_GPIO) -#define MX28_PAD_AUART2_TX__GPIO_3_9 MXS_IOMUX_PAD_NAKED(3, 9, PAD_MUXSEL_GPIO) -#define MX28_PAD_AUART2_CTS__GPIO_3_10 MXS_IOMUX_PAD_NAKED(3, 10, PAD_MUXSEL_GPIO) -#define MX28_PAD_AUART2_RTS__GPIO_3_11 MXS_IOMUX_PAD_NAKED(3, 11, PAD_MUXSEL_GPIO) -#define MX28_PAD_AUART3_RX__GPIO_3_12 MXS_IOMUX_PAD_NAKED(3, 12, PAD_MUXSEL_GPIO) -#define MX28_PAD_AUART3_TX__GPIO_3_13 MXS_IOMUX_PAD_NAKED(3, 13, PAD_MUXSEL_GPIO) -#define MX28_PAD_AUART3_CTS__GPIO_3_14 MXS_IOMUX_PAD_NAKED(3, 14, PAD_MUXSEL_GPIO) -#define MX28_PAD_AUART3_RTS__GPIO_3_15 MXS_IOMUX_PAD_NAKED(3, 15, PAD_MUXSEL_GPIO) -#define MX28_PAD_PWM0__GPIO_3_16 MXS_IOMUX_PAD_NAKED(3, 16, PAD_MUXSEL_GPIO) -#define MX28_PAD_PWM1__GPIO_3_17 MXS_IOMUX_PAD_NAKED(3, 17, PAD_MUXSEL_GPIO) -#define MX28_PAD_PWM2__GPIO_3_18 MXS_IOMUX_PAD_NAKED(3, 18, PAD_MUXSEL_GPIO) -#define MX28_PAD_SAIF0_MCLK__GPIO_3_20 MXS_IOMUX_PAD_NAKED(3, 20, PAD_MUXSEL_GPIO) -#define MX28_PAD_SAIF0_LRCLK__GPIO_3_21 MXS_IOMUX_PAD_NAKED(3, 21, PAD_MUXSEL_GPIO) -#define MX28_PAD_SAIF0_BITCLK__GPIO_3_22 MXS_IOMUX_PAD_NAKED(3, 22, PAD_MUXSEL_GPIO) -#define MX28_PAD_SAIF0_SDATA0__GPIO_3_23 MXS_IOMUX_PAD_NAKED(3, 23, PAD_MUXSEL_GPIO) -#define MX28_PAD_I2C0_SCL__GPIO_3_24 MXS_IOMUX_PAD_NAKED(3, 24, PAD_MUXSEL_GPIO) -#define MX28_PAD_I2C0_SDA__GPIO_3_25 MXS_IOMUX_PAD_NAKED(3, 25, PAD_MUXSEL_GPIO) -#define MX28_PAD_SAIF1_SDATA0__GPIO_3_26 MXS_IOMUX_PAD_NAKED(3, 26, PAD_MUXSEL_GPIO) -#define MX28_PAD_SPDIF__GPIO_3_27 MXS_IOMUX_PAD_NAKED(3, 27, PAD_MUXSEL_GPIO) -#define MX28_PAD_PWM3__GPIO_3_28 MXS_IOMUX_PAD_NAKED(3, 28, PAD_MUXSEL_GPIO) -#define MX28_PAD_PWM4__GPIO_3_29 MXS_IOMUX_PAD_NAKED(3, 29, PAD_MUXSEL_GPIO) -#define MX28_PAD_LCD_RESET__GPIO_3_30 MXS_IOMUX_PAD_NAKED(3, 30, PAD_MUXSEL_GPIO) - -#define MX28_PAD_ENET0_MDC__GPIO_4_0 MXS_IOMUX_PAD_NAKED(4, 0, PAD_MUXSEL_GPIO) -#define MX28_PAD_ENET0_MDIO__GPIO_4_1 MXS_IOMUX_PAD_NAKED(4, 1, PAD_MUXSEL_GPIO) -#define MX28_PAD_ENET0_RX_EN__GPIO_4_2 MXS_IOMUX_PAD_NAKED(4, 2, PAD_MUXSEL_GPIO) -#define MX28_PAD_ENET0_RXD0__GPIO_4_3 MXS_IOMUX_PAD_NAKED(4, 3, PAD_MUXSEL_GPIO) -#define MX28_PAD_ENET0_RXD1__GPIO_4_4 MXS_IOMUX_PAD_NAKED(4, 4, PAD_MUXSEL_GPIO) -#define MX28_PAD_ENET0_TX_CLK__GPIO_4_5 MXS_IOMUX_PAD_NAKED(4, 5, PAD_MUXSEL_GPIO) -#define MX28_PAD_ENET0_TX_EN__GPIO_4_6 MXS_IOMUX_PAD_NAKED(4, 6, PAD_MUXSEL_GPIO) -#define MX28_PAD_ENET0_TXD0__GPIO_4_7 MXS_IOMUX_PAD_NAKED(4, 7, PAD_MUXSEL_GPIO) -#define MX28_PAD_ENET0_TXD1__GPIO_4_8 MXS_IOMUX_PAD_NAKED(4, 8, PAD_MUXSEL_GPIO) -#define MX28_PAD_ENET0_RXD2__GPIO_4_9 MXS_IOMUX_PAD_NAKED(4, 9, PAD_MUXSEL_GPIO) -#define MX28_PAD_ENET0_RXD3__GPIO_4_10 MXS_IOMUX_PAD_NAKED(4, 10, PAD_MUXSEL_GPIO) -#define MX28_PAD_ENET0_TXD2__GPIO_4_11 MXS_IOMUX_PAD_NAKED(4, 11, PAD_MUXSEL_GPIO) -#define MX28_PAD_ENET0_TXD3__GPIO_4_12 MXS_IOMUX_PAD_NAKED(4, 12, PAD_MUXSEL_GPIO) -#define MX28_PAD_ENET0_RX_CLK__GPIO_4_13 MXS_IOMUX_PAD_NAKED(4, 13, PAD_MUXSEL_GPIO) -#define MX28_PAD_ENET0_COL__GPIO_4_14 MXS_IOMUX_PAD_NAKED(4, 14, PAD_MUXSEL_GPIO) -#define MX28_PAD_ENET0_CRS__GPIO_4_15 MXS_IOMUX_PAD_NAKED(4, 15, PAD_MUXSEL_GPIO) -#define MX28_PAD_ENET_CLK__GPIO_4_16 MXS_IOMUX_PAD_NAKED(4, 16, PAD_MUXSEL_GPIO) -#define MX28_PAD_JTAG_RTCK__GPIO_4_20 MXS_IOMUX_PAD_NAKED(4, 20, PAD_MUXSEL_GPIO) - -#endif /* __MACH_IOMUX_MX28_H__ */ diff --git a/arch/arm/include/asm/arch-mx28/iomux.h b/arch/arm/include/asm/arch-mx28/iomux.h deleted file mode 100644 index 7abdf58..0000000 --- a/arch/arm/include/asm/arch-mx28/iomux.h +++ /dev/null @@ -1,168 +0,0 @@ -/* - * Copyright (C) 2009 by Jan Weitzel Phytec Messtechnik GmbH, - * armlinux@phytec.de - * Copyright (C) 2010 Freescale Semiconductor, Inc. All Rights Reserved. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License - * as published by the Free Software Foundation; either version 2 - * of the License, or (at your option) any later version. - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, - * MA 02110-1301, USA. - */ - -#ifndef __MACH_MXS_IOMUX_H__ -#define __MACH_MXS_IOMUX_H__ - -/* - * IOMUX/PAD Bit field definitions - * - * PAD_BANK: 0..2 (3) - * PAD_PIN: 3..7 (5) - * PAD_MUXSEL: 8..9 (2) - * PAD_MA: 10..11 (2) - * PAD_MA_VALID: 12 (1) - * PAD_VOL: 13 (1) - * PAD_VOL_VALID: 14 (1) - * PAD_PULL: 15 (1) - * PAD_PULL_VALID: 16 (1) - * RESERVED: 17..31 (15) - */ -typedef u32 iomux_cfg_t; - -#define MXS_PAD_BANK_SHIFT 0 -#define MXS_PAD_BANK_MASK ((iomux_cfg_t)0x7 << MXS_PAD_BANK_SHIFT) -#define MXS_PAD_PIN_SHIFT 3 -#define MXS_PAD_PIN_MASK ((iomux_cfg_t)0x1f << MXS_PAD_PIN_SHIFT) -#define MXS_PAD_MUXSEL_SHIFT 8 -#define MXS_PAD_MUXSEL_MASK ((iomux_cfg_t)0x3 << MXS_PAD_MUXSEL_SHIFT) -#define MXS_PAD_MA_SHIFT 10 -#define MXS_PAD_MA_MASK ((iomux_cfg_t)0x3 << MXS_PAD_MA_SHIFT) -#define MXS_PAD_MA_VALID_SHIFT 12 -#define MXS_PAD_MA_VALID_MASK ((iomux_cfg_t)0x1 << MXS_PAD_MA_VALID_SHIFT) -#define MXS_PAD_VOL_SHIFT 13 -#define MXS_PAD_VOL_MASK ((iomux_cfg_t)0x1 << MXS_PAD_VOL_SHIFT) -#define MXS_PAD_VOL_VALID_SHIFT 14 -#define MXS_PAD_VOL_VALID_MASK ((iomux_cfg_t)0x1 << MXS_PAD_VOL_VALID_SHIFT) -#define MXS_PAD_PULL_SHIFT 15 -#define MXS_PAD_PULL_MASK ((iomux_cfg_t)0x1 << MXS_PAD_PULL_SHIFT) -#define MXS_PAD_PULL_VALID_SHIFT 16 -#define MXS_PAD_PULL_VALID_MASK ((iomux_cfg_t)0x1 << MXS_PAD_PULL_VALID_SHIFT) - -#define PAD_MUXSEL_0 0 -#define PAD_MUXSEL_1 1 -#define PAD_MUXSEL_2 2 -#define PAD_MUXSEL_GPIO 3 - -#define PAD_4MA 0 -#define PAD_8MA 1 -#define PAD_12MA 2 -#define PAD_16MA 3 - -#define PAD_1V8 0 -#define PAD_3V3 1 - -#define PAD_NOPULL 0 -#define PAD_PULLUP 1 - -#define MXS_PAD_4MA ((PAD_4MA << MXS_PAD_MA_SHIFT) | \ - MXS_PAD_MA_VALID_MASK) -#define MXS_PAD_8MA ((PAD_8MA << MXS_PAD_MA_SHIFT) | \ - MXS_PAD_MA_VALID_MASK) -#define MXS_PAD_12MA ((PAD_12MA << MXS_PAD_MA_SHIFT) | \ - MXS_PAD_MA_VALID_MASK) -#define MXS_PAD_16MA ((PAD_16MA << MXS_PAD_MA_SHIFT) | \ - MXS_PAD_MA_VALID_MASK) - -#define MXS_PAD_1V8 ((PAD_1V8 << MXS_PAD_VOL_SHIFT) | \ - MXS_PAD_VOL_VALID_MASK) -#define MXS_PAD_3V3 ((PAD_3V3 << MXS_PAD_VOL_SHIFT) | \ - MXS_PAD_VOL_VALID_MASK) - -#define MXS_PAD_NOPULL ((PAD_NOPULL << MXS_PAD_PULL_SHIFT) | \ - MXS_PAD_PULL_VALID_MASK) -#define MXS_PAD_PULLUP ((PAD_PULLUP << MXS_PAD_PULL_SHIFT) | \ - MXS_PAD_PULL_VALID_MASK) - -/* generic pad control used in most cases */ -#define MXS_PAD_CTRL (MXS_PAD_4MA | MXS_PAD_3V3 | MXS_PAD_NOPULL) - -#define MXS_IOMUX_PAD(_bank, _pin, _muxsel, _ma, _vol, _pull) \ - (((iomux_cfg_t)(_bank) << MXS_PAD_BANK_SHIFT) | \ - ((iomux_cfg_t)(_pin) << MXS_PAD_PIN_SHIFT) | \ - ((iomux_cfg_t)(_muxsel) << MXS_PAD_MUXSEL_SHIFT) | \ - ((iomux_cfg_t)(_ma) << MXS_PAD_MA_SHIFT) | \ - ((iomux_cfg_t)(_vol) << MXS_PAD_VOL_SHIFT) | \ - ((iomux_cfg_t)(_pull) << MXS_PAD_PULL_SHIFT)) - -/* - * A pad becomes naked, when none of mA, vol or pull - * validity bits is set. - */ -#define MXS_IOMUX_PAD_NAKED(_bank, _pin, _muxsel) \ - MXS_IOMUX_PAD(_bank, _pin, _muxsel, 0, 0, 0) - -static inline unsigned int PAD_BANK(iomux_cfg_t pad) -{ - return (pad & MXS_PAD_BANK_MASK) >> MXS_PAD_BANK_SHIFT; -} - -static inline unsigned int PAD_PIN(iomux_cfg_t pad) -{ - return (pad & MXS_PAD_PIN_MASK) >> MXS_PAD_PIN_SHIFT; -} - -static inline unsigned int PAD_MUXSEL(iomux_cfg_t pad) -{ - return (pad & MXS_PAD_MUXSEL_MASK) >> MXS_PAD_MUXSEL_SHIFT; -} - -static inline unsigned int PAD_MA(iomux_cfg_t pad) -{ - return (pad & MXS_PAD_MA_MASK) >> MXS_PAD_MA_SHIFT; -} - -static inline unsigned int PAD_MA_VALID(iomux_cfg_t pad) -{ - return (pad & MXS_PAD_MA_VALID_MASK) >> MXS_PAD_MA_VALID_SHIFT; -} - -static inline unsigned int PAD_VOL(iomux_cfg_t pad) -{ - return (pad & MXS_PAD_VOL_MASK) >> MXS_PAD_VOL_SHIFT; -} - -static inline unsigned int PAD_VOL_VALID(iomux_cfg_t pad) -{ - return (pad & MXS_PAD_VOL_VALID_MASK) >> MXS_PAD_VOL_VALID_SHIFT; -} - -static inline unsigned int PAD_PULL(iomux_cfg_t pad) -{ - return (pad & MXS_PAD_PULL_MASK) >> MXS_PAD_PULL_SHIFT; -} - -static inline unsigned int PAD_PULL_VALID(iomux_cfg_t pad) -{ - return (pad & MXS_PAD_PULL_VALID_MASK) >> MXS_PAD_PULL_VALID_SHIFT; -} - -/* - * configures a single pad in the iomuxer - */ -int mxs_iomux_setup_pad(iomux_cfg_t pad); - -/* - * configures multiple pads - * convenient way to call the above function with tables - */ -int mxs_iomux_setup_multiple_pads(const iomux_cfg_t *pad_list, unsigned count); - -#endif /* __MACH_MXS_IOMUX_H__*/ diff --git a/arch/arm/include/asm/arch-mx28/regs-apbh.h b/arch/arm/include/asm/arch-mx28/regs-apbh.h deleted file mode 100644 index 91d7bc8..0000000 --- a/arch/arm/include/asm/arch-mx28/regs-apbh.h +++ /dev/null @@ -1,466 +0,0 @@ -/* - * Freescale i.MX28 APBH Register Definitions - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * on behalf of DENX Software Engineering GmbH - * - * Based on code from LTIB: - * Copyright 2008-2010 Freescale Semiconductor, Inc. All Rights Reserved. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA - * - */ - -#ifndef __REGS_APBH_H__ -#define __REGS_APBH_H__ - -#include <asm/arch/regs-common.h> - -#ifndef __ASSEMBLY__ -struct mx28_apbh_regs { - mx28_reg_32(hw_apbh_ctrl0) - mx28_reg_32(hw_apbh_ctrl1) - mx28_reg_32(hw_apbh_ctrl2) - mx28_reg_32(hw_apbh_channel_ctrl) - mx28_reg_32(hw_apbh_devsel) - mx28_reg_32(hw_apbh_dma_burst_size) - mx28_reg_32(hw_apbh_debug) - - uint32_t reserved[36]; - - union { - struct { - mx28_reg_32(hw_apbh_ch_curcmdar) - mx28_reg_32(hw_apbh_ch_nxtcmdar) - mx28_reg_32(hw_apbh_ch_cmd) - mx28_reg_32(hw_apbh_ch_bar) - mx28_reg_32(hw_apbh_ch_sema) - mx28_reg_32(hw_apbh_ch_debug1) - mx28_reg_32(hw_apbh_ch_debug2) - } ch[16]; - struct { - mx28_reg_32(hw_apbh_ch0_curcmdar) - mx28_reg_32(hw_apbh_ch0_nxtcmdar) - mx28_reg_32(hw_apbh_ch0_cmd) - mx28_reg_32(hw_apbh_ch0_bar) - mx28_reg_32(hw_apbh_ch0_sema) - mx28_reg_32(hw_apbh_ch0_debug1) - mx28_reg_32(hw_apbh_ch0_debug2) - mx28_reg_32(hw_apbh_ch1_curcmdar) - mx28_reg_32(hw_apbh_ch1_nxtcmdar) - mx28_reg_32(hw_apbh_ch1_cmd) - mx28_reg_32(hw_apbh_ch1_bar) - mx28_reg_32(hw_apbh_ch1_sema) - mx28_reg_32(hw_apbh_ch1_debug1) - mx28_reg_32(hw_apbh_ch1_debug2) - mx28_reg_32(hw_apbh_ch2_curcmdar) - mx28_reg_32(hw_apbh_ch2_nxtcmdar) - mx28_reg_32(hw_apbh_ch2_cmd) - mx28_reg_32(hw_apbh_ch2_bar) - mx28_reg_32(hw_apbh_ch2_sema) - mx28_reg_32(hw_apbh_ch2_debug1) - mx28_reg_32(hw_apbh_ch2_debug2) - mx28_reg_32(hw_apbh_ch3_curcmdar) - mx28_reg_32(hw_apbh_ch3_nxtcmdar) - mx28_reg_32(hw_apbh_ch3_cmd) - mx28_reg_32(hw_apbh_ch3_bar) - mx28_reg_32(hw_apbh_ch3_sema) - mx28_reg_32(hw_apbh_ch3_debug1) - mx28_reg_32(hw_apbh_ch3_debug2) - mx28_reg_32(hw_apbh_ch4_curcmdar) - mx28_reg_32(hw_apbh_ch4_nxtcmdar) - mx28_reg_32(hw_apbh_ch4_cmd) - mx28_reg_32(hw_apbh_ch4_bar) - mx28_reg_32(hw_apbh_ch4_sema) - mx28_reg_32(hw_apbh_ch4_debug1) - mx28_reg_32(hw_apbh_ch4_debug2) - mx28_reg_32(hw_apbh_ch5_curcmdar) - mx28_reg_32(hw_apbh_ch5_nxtcmdar) - mx28_reg_32(hw_apbh_ch5_cmd) - mx28_reg_32(hw_apbh_ch5_bar) - mx28_reg_32(hw_apbh_ch5_sema) - mx28_reg_32(hw_apbh_ch5_debug1) - mx28_reg_32(hw_apbh_ch5_debug2) - mx28_reg_32(hw_apbh_ch6_curcmdar) - mx28_reg_32(hw_apbh_ch6_nxtcmdar) - mx28_reg_32(hw_apbh_ch6_cmd) - mx28_reg_32(hw_apbh_ch6_bar) - mx28_reg_32(hw_apbh_ch6_sema) - mx28_reg_32(hw_apbh_ch6_debug1) - mx28_reg_32(hw_apbh_ch6_debug2) - mx28_reg_32(hw_apbh_ch7_curcmdar) - mx28_reg_32(hw_apbh_ch7_nxtcmdar) - mx28_reg_32(hw_apbh_ch7_cmd) - mx28_reg_32(hw_apbh_ch7_bar) - mx28_reg_32(hw_apbh_ch7_sema) - mx28_reg_32(hw_apbh_ch7_debug1) - mx28_reg_32(hw_apbh_ch7_debug2) - mx28_reg_32(hw_apbh_ch8_curcmdar) - mx28_reg_32(hw_apbh_ch8_nxtcmdar) - mx28_reg_32(hw_apbh_ch8_cmd) - mx28_reg_32(hw_apbh_ch8_bar) - mx28_reg_32(hw_apbh_ch8_sema) - mx28_reg_32(hw_apbh_ch8_debug1) - mx28_reg_32(hw_apbh_ch8_debug2) - mx28_reg_32(hw_apbh_ch9_curcmdar) - mx28_reg_32(hw_apbh_ch9_nxtcmdar) - mx28_reg_32(hw_apbh_ch9_cmd) - mx28_reg_32(hw_apbh_ch9_bar) - mx28_reg_32(hw_apbh_ch9_sema) - mx28_reg_32(hw_apbh_ch9_debug1) - mx28_reg_32(hw_apbh_ch9_debug2) - mx28_reg_32(hw_apbh_ch10_curcmdar) - mx28_reg_32(hw_apbh_ch10_nxtcmdar) - mx28_reg_32(hw_apbh_ch10_cmd) - mx28_reg_32(hw_apbh_ch10_bar) - mx28_reg_32(hw_apbh_ch10_sema) - mx28_reg_32(hw_apbh_ch10_debug1) - mx28_reg_32(hw_apbh_ch10_debug2) - mx28_reg_32(hw_apbh_ch11_curcmdar) - mx28_reg_32(hw_apbh_ch11_nxtcmdar) - mx28_reg_32(hw_apbh_ch11_cmd) - mx28_reg_32(hw_apbh_ch11_bar) - mx28_reg_32(hw_apbh_ch11_sema) - mx28_reg_32(hw_apbh_ch11_debug1) - mx28_reg_32(hw_apbh_ch11_debug2) - mx28_reg_32(hw_apbh_ch12_curcmdar) - mx28_reg_32(hw_apbh_ch12_nxtcmdar) - mx28_reg_32(hw_apbh_ch12_cmd) - mx28_reg_32(hw_apbh_ch12_bar) - mx28_reg_32(hw_apbh_ch12_sema) - mx28_reg_32(hw_apbh_ch12_debug1) - mx28_reg_32(hw_apbh_ch12_debug2) - mx28_reg_32(hw_apbh_ch13_curcmdar) - mx28_reg_32(hw_apbh_ch13_nxtcmdar) - mx28_reg_32(hw_apbh_ch13_cmd) - mx28_reg_32(hw_apbh_ch13_bar) - mx28_reg_32(hw_apbh_ch13_sema) - mx28_reg_32(hw_apbh_ch13_debug1) - mx28_reg_32(hw_apbh_ch13_debug2) - mx28_reg_32(hw_apbh_ch14_curcmdar) - mx28_reg_32(hw_apbh_ch14_nxtcmdar) - mx28_reg_32(hw_apbh_ch14_cmd) - mx28_reg_32(hw_apbh_ch14_bar) - mx28_reg_32(hw_apbh_ch14_sema) - mx28_reg_32(hw_apbh_ch14_debug1) - mx28_reg_32(hw_apbh_ch14_debug2) - mx28_reg_32(hw_apbh_ch15_curcmdar) - mx28_reg_32(hw_apbh_ch15_nxtcmdar) - mx28_reg_32(hw_apbh_ch15_cmd) - mx28_reg_32(hw_apbh_ch15_bar) - mx28_reg_32(hw_apbh_ch15_sema) - mx28_reg_32(hw_apbh_ch15_debug1) - mx28_reg_32(hw_apbh_ch15_debug2) - }; - }; - mx28_reg_32(hw_apbh_version) -}; -#endif - -#define APBH_CTRL0_SFTRST (1 << 31) -#define APBH_CTRL0_CLKGATE (1 << 30) -#define APBH_CTRL0_AHB_BURST8_EN (1 << 29) -#define APBH_CTRL0_APB_BURST_EN (1 << 28) -#define APBH_CTRL0_RSVD0_MASK (0xfff << 16) -#define APBH_CTRL0_RSVD0_OFFSET 16 -#define APBH_CTRL0_CLKGATE_CHANNEL_MASK 0xffff -#define APBH_CTRL0_CLKGATE_CHANNEL_OFFSET 0 -#define APBH_CTRL0_CLKGATE_CHANNEL_SSP0 0x0001 -#define APBH_CTRL0_CLKGATE_CHANNEL_SSP1 0x0002 -#define APBH_CTRL0_CLKGATE_CHANNEL_SSP2 0x0004 -#define APBH_CTRL0_CLKGATE_CHANNEL_SSP3 0x0008 -#define APBH_CTRL0_CLKGATE_CHANNEL_NAND0 0x0010 -#define APBH_CTRL0_CLKGATE_CHANNEL_NAND1 0x0020 -#define APBH_CTRL0_CLKGATE_CHANNEL_NAND2 0x0040 -#define APBH_CTRL0_CLKGATE_CHANNEL_NAND3 0x0080 -#define APBH_CTRL0_CLKGATE_CHANNEL_NAND4 0x0100 -#define APBH_CTRL0_CLKGATE_CHANNEL_NAND5 0x0200 -#define APBH_CTRL0_CLKGATE_CHANNEL_NAND6 0x0400 -#define APBH_CTRL0_CLKGATE_CHANNEL_NAND7 0x0800 -#define APBH_CTRL0_CLKGATE_CHANNEL_HSADC 0x1000 -#define APBH_CTRL0_CLKGATE_CHANNEL_LCDIF 0x2000 - -#define APBH_CTRL1_CH15_CMDCMPLT_IRQ_EN (1 << 31) -#define APBH_CTRL1_CH14_CMDCMPLT_IRQ_EN (1 << 30) -#define APBH_CTRL1_CH13_CMDCMPLT_IRQ_EN (1 << 29) -#define APBH_CTRL1_CH12_CMDCMPLT_IRQ_EN (1 << 28) -#define APBH_CTRL1_CH11_CMDCMPLT_IRQ_EN (1 << 27) -#define APBH_CTRL1_CH10_CMDCMPLT_IRQ_EN (1 << 26) -#define APBH_CTRL1_CH9_CMDCMPLT_IRQ_EN (1 << 25) -#define APBH_CTRL1_CH8_CMDCMPLT_IRQ_EN (1 << 24) -#define APBH_CTRL1_CH7_CMDCMPLT_IRQ_EN (1 << 23) -#define APBH_CTRL1_CH6_CMDCMPLT_IRQ_EN (1 << 22) -#define APBH_CTRL1_CH5_CMDCMPLT_IRQ_EN (1 << 21) -#define APBH_CTRL1_CH4_CMDCMPLT_IRQ_EN (1 << 20) -#define APBH_CTRL1_CH3_CMDCMPLT_IRQ_EN (1 << 19) -#define APBH_CTRL1_CH2_CMDCMPLT_IRQ_EN (1 << 18) -#define APBH_CTRL1_CH1_CMDCMPLT_IRQ_EN (1 << 17) -#define APBH_CTRL1_CH0_CMDCMPLT_IRQ_EN (1 << 16) -#define APBH_CTRL1_CH_CMDCMPLT_IRQ_EN_OFFSET 16 -#define APBH_CTRL1_CH_CMDCMPLT_IRQ_EN_MASK (0xffff << 16) -#define APBH_CTRL1_CH15_CMDCMPLT_IRQ (1 << 15) -#define APBH_CTRL1_CH14_CMDCMPLT_IRQ (1 << 14) -#define APBH_CTRL1_CH13_CMDCMPLT_IRQ (1 << 13) -#define APBH_CTRL1_CH12_CMDCMPLT_IRQ (1 << 12) -#define APBH_CTRL1_CH11_CMDCMPLT_IRQ (1 << 11) -#define APBH_CTRL1_CH10_CMDCMPLT_IRQ (1 << 10) -#define APBH_CTRL1_CH9_CMDCMPLT_IRQ (1 << 9) -#define APBH_CTRL1_CH8_CMDCMPLT_IRQ (1 << 8) -#define APBH_CTRL1_CH7_CMDCMPLT_IRQ (1 << 7) -#define APBH_CTRL1_CH6_CMDCMPLT_IRQ (1 << 6) -#define APBH_CTRL1_CH5_CMDCMPLT_IRQ (1 << 5) -#define APBH_CTRL1_CH4_CMDCMPLT_IRQ (1 << 4) -#define APBH_CTRL1_CH3_CMDCMPLT_IRQ (1 << 3) -#define APBH_CTRL1_CH2_CMDCMPLT_IRQ (1 << 2) -#define APBH_CTRL1_CH1_CMDCMPLT_IRQ (1 << 1) -#define APBH_CTRL1_CH0_CMDCMPLT_IRQ (1 << 0) - -#define APBH_CTRL2_CH15_ERROR_STATUS (1 << 31) -#define APBH_CTRL2_CH14_ERROR_STATUS (1 << 30) -#define APBH_CTRL2_CH13_ERROR_STATUS (1 << 29) -#define APBH_CTRL2_CH12_ERROR_STATUS (1 << 28) -#define APBH_CTRL2_CH11_ERROR_STATUS (1 << 27) -#define APBH_CTRL2_CH10_ERROR_STATUS (1 << 26) -#define APBH_CTRL2_CH9_ERROR_STATUS (1 << 25) -#define APBH_CTRL2_CH8_ERROR_STATUS (1 << 24) -#define APBH_CTRL2_CH7_ERROR_STATUS (1 << 23) -#define APBH_CTRL2_CH6_ERROR_STATUS (1 << 22) -#define APBH_CTRL2_CH5_ERROR_STATUS (1 << 21) -#define APBH_CTRL2_CH4_ERROR_STATUS (1 << 20) -#define APBH_CTRL2_CH3_ERROR_STATUS (1 << 19) -#define APBH_CTRL2_CH2_ERROR_STATUS (1 << 18) -#define APBH_CTRL2_CH1_ERROR_STATUS (1 << 17) -#define APBH_CTRL2_CH0_ERROR_STATUS (1 << 16) -#define APBH_CTRL2_CH15_ERROR_IRQ (1 << 15) -#define APBH_CTRL2_CH14_ERROR_IRQ (1 << 14) -#define APBH_CTRL2_CH13_ERROR_IRQ (1 << 13) -#define APBH_CTRL2_CH12_ERROR_IRQ (1 << 12) -#define APBH_CTRL2_CH11_ERROR_IRQ (1 << 11) -#define APBH_CTRL2_CH10_ERROR_IRQ (1 << 10) -#define APBH_CTRL2_CH9_ERROR_IRQ (1 << 9) -#define APBH_CTRL2_CH8_ERROR_IRQ (1 << 8) -#define APBH_CTRL2_CH7_ERROR_IRQ (1 << 7) -#define APBH_CTRL2_CH6_ERROR_IRQ (1 << 6) -#define APBH_CTRL2_CH5_ERROR_IRQ (1 << 5) -#define APBH_CTRL2_CH4_ERROR_IRQ (1 << 4) -#define APBH_CTRL2_CH3_ERROR_IRQ (1 << 3) -#define APBH_CTRL2_CH2_ERROR_IRQ (1 << 2) -#define APBH_CTRL2_CH1_ERROR_IRQ (1 << 1) -#define APBH_CTRL2_CH0_ERROR_IRQ (1 << 0) - -#define APBH_CHANNEL_CTRL_RESET_CHANNEL_MASK (0xffff << 16) -#define APBH_CHANNEL_CTRL_RESET_CHANNEL_OFFSET 16 -#define APBH_CHANNEL_CTRL_RESET_CHANNEL_SSP0 (0x0001 << 16) -#define APBH_CHANNEL_CTRL_RESET_CHANNEL_SSP1 (0x0002 << 16) -#define APBH_CHANNEL_CTRL_RESET_CHANNEL_SSP2 (0x0004 << 16) -#define APBH_CHANNEL_CTRL_RESET_CHANNEL_SSP3 (0x0008 << 16) -#define APBH_CHANNEL_CTRL_RESET_CHANNEL_NAND0 (0x0010 << 16) -#define APBH_CHANNEL_CTRL_RESET_CHANNEL_NAND1 (0x0020 << 16) -#define APBH_CHANNEL_CTRL_RESET_CHANNEL_NAND2 (0x0040 << 16) -#define APBH_CHANNEL_CTRL_RESET_CHANNEL_NAND3 (0x0080 << 16) -#define APBH_CHANNEL_CTRL_RESET_CHANNEL_NAND4 (0x0100 << 16) -#define APBH_CHANNEL_CTRL_RESET_CHANNEL_NAND5 (0x0200 << 16) -#define APBH_CHANNEL_CTRL_RESET_CHANNEL_NAND6 (0x0400 << 16) -#define APBH_CHANNEL_CTRL_RESET_CHANNEL_NAND7 (0x0800 << 16) -#define APBH_CHANNEL_CTRL_RESET_CHANNEL_HSADC (0x1000 << 16) -#define APBH_CHANNEL_CTRL_RESET_CHANNEL_LCDIF (0x2000 << 16) -#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_MASK 0xffff -#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_OFFSET 0 -#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_SSP0 0x0001 -#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_SSP1 0x0002 -#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_SSP2 0x0004 -#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_SSP3 0x0008 -#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_NAND0 0x0010 -#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_NAND1 0x0020 -#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_NAND2 0x0040 -#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_NAND3 0x0080 -#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_NAND4 0x0100 -#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_NAND5 0x0200 -#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_NAND6 0x0400 -#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_NAND7 0x0800 -#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_HSADC 0x1000 -#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_LCDIF 0x2000 - -#define APBH_DEVSEL_CH15_MASK (0x3 << 30) -#define APBH_DEVSEL_CH15_OFFSET 30 -#define APBH_DEVSEL_CH14_MASK (0x3 << 28) -#define APBH_DEVSEL_CH14_OFFSET 28 -#define APBH_DEVSEL_CH13_MASK (0x3 << 26) -#define APBH_DEVSEL_CH13_OFFSET 26 -#define APBH_DEVSEL_CH12_MASK (0x3 << 24) -#define APBH_DEVSEL_CH12_OFFSET 24 -#define APBH_DEVSEL_CH11_MASK (0x3 << 22) -#define APBH_DEVSEL_CH11_OFFSET 22 -#define APBH_DEVSEL_CH10_MASK (0x3 << 20) -#define APBH_DEVSEL_CH10_OFFSET 20 -#define APBH_DEVSEL_CH9_MASK (0x3 << 18) -#define APBH_DEVSEL_CH9_OFFSET 18 -#define APBH_DEVSEL_CH8_MASK (0x3 << 16) -#define APBH_DEVSEL_CH8_OFFSET 16 -#define APBH_DEVSEL_CH7_MASK (0x3 << 14) -#define APBH_DEVSEL_CH7_OFFSET 14 -#define APBH_DEVSEL_CH6_MASK (0x3 << 12) -#define APBH_DEVSEL_CH6_OFFSET 12 -#define APBH_DEVSEL_CH5_MASK (0x3 << 10) -#define APBH_DEVSEL_CH5_OFFSET 10 -#define APBH_DEVSEL_CH4_MASK (0x3 << 8) -#define APBH_DEVSEL_CH4_OFFSET 8 -#define APBH_DEVSEL_CH3_MASK (0x3 << 6) -#define APBH_DEVSEL_CH3_OFFSET 6 -#define APBH_DEVSEL_CH2_MASK (0x3 << 4) -#define APBH_DEVSEL_CH2_OFFSET 4 -#define APBH_DEVSEL_CH1_MASK (0x3 << 2) -#define APBH_DEVSEL_CH1_OFFSET 2 -#define APBH_DEVSEL_CH0_MASK (0x3 << 0) -#define APBH_DEVSEL_CH0_OFFSET 0 - -#define APBH_DMA_BURST_SIZE_CH15_MASK (0x3 << 30) -#define APBH_DMA_BURST_SIZE_CH15_OFFSET 30 -#define APBH_DMA_BURST_SIZE_CH14_MASK (0x3 << 28) -#define APBH_DMA_BURST_SIZE_CH14_OFFSET 28 -#define APBH_DMA_BURST_SIZE_CH13_MASK (0x3 << 26) -#define APBH_DMA_BURST_SIZE_CH13_OFFSET 26 -#define APBH_DMA_BURST_SIZE_CH12_MASK (0x3 << 24) -#define APBH_DMA_BURST_SIZE_CH12_OFFSET 24 -#define APBH_DMA_BURST_SIZE_CH11_MASK (0x3 << 22) -#define APBH_DMA_BURST_SIZE_CH11_OFFSET 22 -#define APBH_DMA_BURST_SIZE_CH10_MASK (0x3 << 20) -#define APBH_DMA_BURST_SIZE_CH10_OFFSET 20 -#define APBH_DMA_BURST_SIZE_CH9_MASK (0x3 << 18) -#define APBH_DMA_BURST_SIZE_CH9_OFFSET 18 -#define APBH_DMA_BURST_SIZE_CH8_MASK (0x3 << 16) -#define APBH_DMA_BURST_SIZE_CH8_OFFSET 16 -#define APBH_DMA_BURST_SIZE_CH8_BURST0 (0x0 << 16) -#define APBH_DMA_BURST_SIZE_CH8_BURST4 (0x1 << 16) -#define APBH_DMA_BURST_SIZE_CH8_BURST8 (0x2 << 16) -#define APBH_DMA_BURST_SIZE_CH7_MASK (0x3 << 14) -#define APBH_DMA_BURST_SIZE_CH7_OFFSET 14 -#define APBH_DMA_BURST_SIZE_CH6_MASK (0x3 << 12) -#define APBH_DMA_BURST_SIZE_CH6_OFFSET 12 -#define APBH_DMA_BURST_SIZE_CH5_MASK (0x3 << 10) -#define APBH_DMA_BURST_SIZE_CH5_OFFSET 10 -#define APBH_DMA_BURST_SIZE_CH4_MASK (0x3 << 8) -#define APBH_DMA_BURST_SIZE_CH4_OFFSET 8 -#define APBH_DMA_BURST_SIZE_CH3_MASK (0x3 << 6) -#define APBH_DMA_BURST_SIZE_CH3_OFFSET 6 -#define APBH_DMA_BURST_SIZE_CH3_BURST0 (0x0 << 6) -#define APBH_DMA_BURST_SIZE_CH3_BURST4 (0x1 << 6) -#define APBH_DMA_BURST_SIZE_CH3_BURST8 (0x2 << 6) - -#define APBH_DMA_BURST_SIZE_CH2_MASK (0x3 << 4) -#define APBH_DMA_BURST_SIZE_CH2_OFFSET 4 -#define APBH_DMA_BURST_SIZE_CH2_BURST0 (0x0 << 4) -#define APBH_DMA_BURST_SIZE_CH2_BURST4 (0x1 << 4) -#define APBH_DMA_BURST_SIZE_CH2_BURST8 (0x2 << 4) -#define APBH_DMA_BURST_SIZE_CH1_MASK (0x3 << 2) -#define APBH_DMA_BURST_SIZE_CH1_OFFSET 2 -#define APBH_DMA_BURST_SIZE_CH1_BURST0 (0x0 << 2) -#define APBH_DMA_BURST_SIZE_CH1_BURST4 (0x1 << 2) -#define APBH_DMA_BURST_SIZE_CH1_BURST8 (0x2 << 2) - -#define APBH_DMA_BURST_SIZE_CH0_MASK 0x3 -#define APBH_DMA_BURST_SIZE_CH0_OFFSET 0 -#define APBH_DMA_BURST_SIZE_CH0_BURST0 0x0 -#define APBH_DMA_BURST_SIZE_CH0_BURST4 0x1 -#define APBH_DMA_BURST_SIZE_CH0_BURST8 0x2 - -#define APBH_DEBUG_GPMI_ONE_FIFO (1 << 0) - -#define APBH_CHn_CURCMDAR_CMD_ADDR_MASK 0xffffffff -#define APBH_CHn_CURCMDAR_CMD_ADDR_OFFSET 0 - -#define APBH_CHn_NXTCMDAR_CMD_ADDR_MASK 0xffffffff -#define APBH_CHn_NXTCMDAR_CMD_ADDR_OFFSET 0 - -#define APBH_CHn_CMD_XFER_COUNT_MASK (0xffff << 16) -#define APBH_CHn_CMD_XFER_COUNT_OFFSET 16 -#define APBH_CHn_CMD_CMDWORDS_MASK (0xf << 12) -#define APBH_CHn_CMD_CMDWORDS_OFFSET 12 -#define APBH_CHn_CMD_HALTONTERMINATE (1 << 8) -#define APBH_CHn_CMD_WAIT4ENDCMD (1 << 7) -#define APBH_CHn_CMD_SEMAPHORE (1 << 6) -#define APBH_CHn_CMD_NANDWAIT4READY (1 << 5) -#define APBH_CHn_CMD_NANDLOCK (1 << 4) -#define APBH_CHn_CMD_IRQONCMPLT (1 << 3) -#define APBH_CHn_CMD_CHAIN (1 << 2) -#define APBH_CHn_CMD_COMMAND_MASK 0x3 -#define APBH_CHn_CMD_COMMAND_OFFSET 0 -#define APBH_CHn_CMD_COMMAND_NO_DMA_XFER 0x0 -#define APBH_CHn_CMD_COMMAND_DMA_WRITE 0x1 -#define APBH_CHn_CMD_COMMAND_DMA_READ 0x2 -#define APBH_CHn_CMD_COMMAND_DMA_SENSE 0x3 - -#define APBH_CHn_BAR_ADDRESS_MASK 0xffffffff -#define APBH_CHn_BAR_ADDRESS_OFFSET 0 - -#define APBH_CHn_SEMA_RSVD2_MASK (0xff << 24) -#define APBH_CHn_SEMA_RSVD2_OFFSET 24 -#define APBH_CHn_SEMA_PHORE_MASK (0xff << 16) -#define APBH_CHn_SEMA_PHORE_OFFSET 16 -#define APBH_CHn_SEMA_RSVD1_MASK (0xff << 8) -#define APBH_CHn_SEMA_RSVD1_OFFSET 8 -#define APBH_CHn_SEMA_INCREMENT_SEMA_MASK (0xff << 0) -#define APBH_CHn_SEMA_INCREMENT_SEMA_OFFSET 0 - -#define APBH_CHn_DEBUG1_REQ (1 << 31) -#define APBH_CHn_DEBUG1_BURST (1 << 30) -#define APBH_CHn_DEBUG1_KICK (1 << 29) -#define APBH_CHn_DEBUG1_END (1 << 28) -#define APBH_CHn_DEBUG1_SENSE (1 << 27) -#define APBH_CHn_DEBUG1_READY (1 << 26) -#define APBH_CHn_DEBUG1_LOCK (1 << 25) -#define APBH_CHn_DEBUG1_NEXTCMDADDRVALID (1 << 24) -#define APBH_CHn_DEBUG1_RD_FIFO_EMPTY (1 << 23) -#define APBH_CHn_DEBUG1_RD_FIFO_FULL (1 << 22) -#define APBH_CHn_DEBUG1_WR_FIFO_EMPTY (1 << 21) -#define APBH_CHn_DEBUG1_WR_FIFO_FULL (1 << 20) -#define APBH_CHn_DEBUG1_RSVD1_MASK (0x7fff << 5) -#define APBH_CHn_DEBUG1_RSVD1_OFFSET 5 -#define APBH_CHn_DEBUG1_STATEMACHINE_MASK 0x1f -#define APBH_CHn_DEBUG1_STATEMACHINE_OFFSET 0 -#define APBH_CHn_DEBUG1_STATEMACHINE_IDLE 0x00 -#define APBH_CHn_DEBUG1_STATEMACHINE_REQ_CMD1 0x01 -#define APBH_CHn_DEBUG1_STATEMACHINE_REQ_CMD3 0x02 -#define APBH_CHn_DEBUG1_STATEMACHINE_REQ_CMD2 0x03 -#define APBH_CHn_DEBUG1_STATEMACHINE_XFER_DECODE 0x04 -#define APBH_CHn_DEBUG1_STATEMACHINE_REQ_WAIT 0x05 -#define APBH_CHn_DEBUG1_STATEMACHINE_REQ_CMD4 0x06 -#define APBH_CHn_DEBUG1_STATEMACHINE_PIO_REQ 0x07 -#define APBH_CHn_DEBUG1_STATEMACHINE_READ_FLUSH 0x08 -#define APBH_CHn_DEBUG1_STATEMACHINE_READ_WAIT 0x09 -#define APBH_CHn_DEBUG1_STATEMACHINE_WRITE 0x0c -#define APBH_CHn_DEBUG1_STATEMACHINE_READ_REQ 0x0d -#define APBH_CHn_DEBUG1_STATEMACHINE_CHECK_CHAIN 0x0e -#define APBH_CHn_DEBUG1_STATEMACHINE_XFER_COMPLETE 0x0f -#define APBH_CHn_DEBUG1_STATEMACHINE_TERMINATE 0x14 -#define APBH_CHn_DEBUG1_STATEMACHINE_WAIT_END 0x15 -#define APBH_CHn_DEBUG1_STATEMACHINE_WRITE_WAIT 0x1c -#define APBH_CHn_DEBUG1_STATEMACHINE_HALT_AFTER_TERM 0x1d -#define APBH_CHn_DEBUG1_STATEMACHINE_CHECK_WAIT 0x1e -#define APBH_CHn_DEBUG1_STATEMACHINE_WAIT_READY 0x1f - -#define APBH_CHn_DEBUG2_APB_BYTES_MASK (0xffff << 16) -#define APBH_CHn_DEBUG2_APB_BYTES_OFFSET 16 -#define APBH_CHn_DEBUG2_AHB_BYTES_MASK 0xffff -#define APBH_CHn_DEBUG2_AHB_BYTES_OFFSET 0 - -#define APBH_VERSION_MAJOR_MASK (0xff << 24) -#define APBH_VERSION_MAJOR_OFFSET 24 -#define APBH_VERSION_MINOR_MASK (0xff << 16) -#define APBH_VERSION_MINOR_OFFSET 16 -#define APBH_VERSION_STEP_MASK 0xffff -#define APBH_VERSION_STEP_OFFSET 0 - -#endif /* __REGS_APBH_H__ */ diff --git a/arch/arm/include/asm/arch-mx28/regs-base.h b/arch/arm/include/asm/arch-mx28/regs-base.h deleted file mode 100644 index dbdcc2b..0000000 --- a/arch/arm/include/asm/arch-mx28/regs-base.h +++ /dev/null @@ -1,88 +0,0 @@ -/* - * Freescale i.MX28 Peripheral Base Addresses - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * on behalf of DENX Software Engineering GmbH - * - * Based on code from LTIB: - * Copyright (C) 2008 Embedded Alley Solutions Inc. - * - * (C) Copyright 2009-2010 Freescale Semiconductor, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA - * - */ - -#ifndef __MX28_REGS_BASE_H__ -#define __MX28_REGS_BASE_H__ - -/* - * Register base address - */ -#define MXS_ICOL_BASE 0x80000000 -#define MXS_HSADC_BASE 0x80002000 -#define MXS_APBH_BASE 0x80004000 -#define MXS_PERFMON_BASE 0x80006000 -#define MXS_BCH_BASE 0x8000A000 -#define MXS_GPMI_BASE 0x8000C000 -#define MXS_SSP0_BASE 0x80010000 -#define MXS_SSP1_BASE 0x80012000 -#define MXS_SSP2_BASE 0x80014000 -#define MXS_SSP3_BASE 0x80016000 -#define MXS_PINCTRL_BASE 0x80018000 -#define MXS_DIGCTL_BASE 0x8001C000 -#define MXS_ETM_BASE 0x80022000 -#define MXS_APBX_BASE 0x80024000 -#define MXS_DCP_BASE 0x80028000 -#define MXS_PXP_BASE 0x8002A000 -#define MXS_OCOTP_BASE 0x8002C000 -#define MXS_AXI_AHB0_BASE 0x8002E000 -#define MXS_LCDIF_BASE 0x80030000 -#define MXS_CAN0_BASE 0x80032000 -#define MXS_CAN1_BASE 0x80034000 -#define MXS_SIMDBG_BASE 0x8003C000 -#define MXS_SIMGPMISEL_BASE 0x8003C200 -#define MXS_SIMSSPSEL_BASE 0x8003C300 -#define MXS_SIMMEMSEL_BASE 0x8003C400 -#define MXS_GPIOMON_BASE 0x8003C500 -#define MXS_SIMENET_BASE 0x8003C700 -#define MXS_ARMJTAG_BASE 0x8003C800 -#define MXS_CLKCTRL_BASE 0x80040000 -#define MXS_SAIF0_BASE 0x80042000 -#define MXS_POWER_BASE 0x80044000 -#define MXS_SAIF1_BASE 0x80046000 -#define MXS_LRADC_BASE 0x80050000 -#define MXS_SPDIF_BASE 0x80054000 -#define MXS_RTC_BASE 0x80056000 -#define MXS_I2C0_BASE 0x80058000 -#define MXS_I2C1_BASE 0x8005A000 -#define MXS_PWM_BASE 0x80064000 -#define MXS_TIMROT_BASE 0x80068000 -#define MXS_UARTAPP0_BASE 0x8006A000 -#define MXS_UARTAPP1_BASE 0x8006C000 -#define MXS_UARTAPP2_BASE 0x8006E000 -#define MXS_UARTAPP3_BASE 0x80070000 -#define MXS_UARTAPP4_BASE 0x80072000 -#define MXS_UARTDBG_BASE 0x80074000 -#define MXS_USBPHY0_BASE 0x8007C000 -#define MXS_USBPHY1_BASE 0x8007E000 -#define MXS_USBCTRL0_BASE 0x80080000 -#define MXS_USBCTRL1_BASE 0x80090000 -#define MXS_DFLPT_BASE 0x800C0000 -#define MXS_DRAM_BASE 0x800E0000 -#define MXS_ENET0_BASE 0x800F0000 -#define MXS_ENET1_BASE 0x800F4000 - -#endif /* __MX28_REGS_BASE_H__ */ diff --git a/arch/arm/include/asm/arch-mx28/regs-bch.h b/arch/arm/include/asm/arch-mx28/regs-bch.h deleted file mode 100644 index 9243bdd..0000000 --- a/arch/arm/include/asm/arch-mx28/regs-bch.h +++ /dev/null @@ -1,230 +0,0 @@ -/* - * Freescale i.MX28 BCH Register Definitions - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * on behalf of DENX Software Engineering GmbH - * - * Based on code from LTIB: - * Copyright 2008-2010 Freescale Semiconductor, Inc. All Rights Reserved. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA - * - */ - -#ifndef __MX28_REGS_BCH_H__ -#define __MX28_REGS_BCH_H__ - -#include <asm/arch/regs-common.h> - -#ifndef __ASSEMBLY__ -struct mx28_bch_regs { - mx28_reg_32(hw_bch_ctrl) - mx28_reg_32(hw_bch_status0) - mx28_reg_32(hw_bch_mode) - mx28_reg_32(hw_bch_encodeptr) - mx28_reg_32(hw_bch_dataptr) - mx28_reg_32(hw_bch_metaptr) - - uint32_t reserved[4]; - - mx28_reg_32(hw_bch_layoutselect) - mx28_reg_32(hw_bch_flash0layout0) - mx28_reg_32(hw_bch_flash0layout1) - mx28_reg_32(hw_bch_flash1layout0) - mx28_reg_32(hw_bch_flash1layout1) - mx28_reg_32(hw_bch_flash2layout0) - mx28_reg_32(hw_bch_flash2layout1) - mx28_reg_32(hw_bch_flash3layout0) - mx28_reg_32(hw_bch_flash3layout1) - mx28_reg_32(hw_bch_dbgkesread) - mx28_reg_32(hw_bch_dbgcsferead) - mx28_reg_32(hw_bch_dbgsyndegread) - mx28_reg_32(hw_bch_dbgahbmread) - mx28_reg_32(hw_bch_blockname) - mx28_reg_32(hw_bch_version) -}; -#endif - -#define BCH_CTRL_SFTRST (1 << 31) -#define BCH_CTRL_CLKGATE (1 << 30) -#define BCH_CTRL_DEBUGSYNDROME (1 << 22) -#define BCH_CTRL_M2M_LAYOUT_MASK (0x3 << 18) -#define BCH_CTRL_M2M_LAYOUT_OFFSET 18 -#define BCH_CTRL_M2M_ENCODE (1 << 17) -#define BCH_CTRL_M2M_ENABLE (1 << 16) -#define BCH_CTRL_DEBUG_STALL_IRQ_EN (1 << 10) -#define BCH_CTRL_COMPLETE_IRQ_EN (1 << 8) -#define BCH_CTRL_BM_ERROR_IRQ (1 << 3) -#define BCH_CTRL_DEBUG_STALL_IRQ (1 << 2) -#define BCH_CTRL_COMPLETE_IRQ (1 << 0) - -#define BCH_STATUS0_HANDLE_MASK (0xfff << 20) -#define BCH_STATUS0_HANDLE_OFFSET 20 -#define BCH_STATUS0_COMPLETED_CE_MASK (0xf << 16) -#define BCH_STATUS0_COMPLETED_CE_OFFSET 16 -#define BCH_STATUS0_STATUS_BLK0_MASK (0xff << 8) -#define BCH_STATUS0_STATUS_BLK0_OFFSET 8 -#define BCH_STATUS0_STATUS_BLK0_ZERO (0x00 << 8) -#define BCH_STATUS0_STATUS_BLK0_ERROR1 (0x01 << 8) -#define BCH_STATUS0_STATUS_BLK0_ERROR2 (0x02 << 8) -#define BCH_STATUS0_STATUS_BLK0_ERROR3 (0x03 << 8) -#define BCH_STATUS0_STATUS_BLK0_ERROR4 (0x04 << 8) -#define BCH_STATUS0_STATUS_BLK0_UNCORRECTABLE (0xfe << 8) -#define BCH_STATUS0_STATUS_BLK0_ERASED (0xff << 8) -#define BCH_STATUS0_ALLONES (1 << 4) -#define BCH_STATUS0_CORRECTED (1 << 3) -#define BCH_STATUS0_UNCORRECTABLE (1 << 2) - -#define BCH_MODE_ERASE_THRESHOLD_MASK 0xff -#define BCH_MODE_ERASE_THRESHOLD_OFFSET 0 - -#define BCH_ENCODEPTR_ADDR_MASK 0xffffffff -#define BCH_ENCODEPTR_ADDR_OFFSET 0 - -#define BCH_DATAPTR_ADDR_MASK 0xffffffff -#define BCH_DATAPTR_ADDR_OFFSET 0 - -#define BCH_METAPTR_ADDR_MASK 0xffffffff -#define BCH_METAPTR_ADDR_OFFSET 0 - -#define BCH_LAYOUTSELECT_CS15_SELECT_MASK (0x3 << 30) -#define BCH_LAYOUTSELECT_CS15_SELECT_OFFSET 30 -#define BCH_LAYOUTSELECT_CS14_SELECT_MASK (0x3 << 28) -#define BCH_LAYOUTSELECT_CS14_SELECT_OFFSET 28 -#define BCH_LAYOUTSELECT_CS13_SELECT_MASK (0x3 << 26) -#define BCH_LAYOUTSELECT_CS13_SELECT_OFFSET 26 -#define BCH_LAYOUTSELECT_CS12_SELECT_MASK (0x3 << 24) -#define BCH_LAYOUTSELECT_CS12_SELECT_OFFSET 24 -#define BCH_LAYOUTSELECT_CS11_SELECT_MASK (0x3 << 22) -#define BCH_LAYOUTSELECT_CS11_SELECT_OFFSET 22 -#define BCH_LAYOUTSELECT_CS10_SELECT_MASK (0x3 << 20) -#define BCH_LAYOUTSELECT_CS10_SELECT_OFFSET 20 -#define BCH_LAYOUTSELECT_CS9_SELECT_MASK (0x3 << 18) -#define BCH_LAYOUTSELECT_CS9_SELECT_OFFSET 18 -#define BCH_LAYOUTSELECT_CS8_SELECT_MASK (0x3 << 16) -#define BCH_LAYOUTSELECT_CS8_SELECT_OFFSET 16 -#define BCH_LAYOUTSELECT_CS7_SELECT_MASK (0x3 << 14) -#define BCH_LAYOUTSELECT_CS7_SELECT_OFFSET 14 -#define BCH_LAYOUTSELECT_CS6_SELECT_MASK (0x3 << 12) -#define BCH_LAYOUTSELECT_CS6_SELECT_OFFSET 12 -#define BCH_LAYOUTSELECT_CS5_SELECT_MASK (0x3 << 10) -#define BCH_LAYOUTSELECT_CS5_SELECT_OFFSET 10 -#define BCH_LAYOUTSELECT_CS4_SELECT_MASK (0x3 << 8) -#define BCH_LAYOUTSELECT_CS4_SELECT_OFFSET 8 -#define BCH_LAYOUTSELECT_CS3_SELECT_MASK (0x3 << 6) -#define BCH_LAYOUTSELECT_CS3_SELECT_OFFSET 6 -#define BCH_LAYOUTSELECT_CS2_SELECT_MASK (0x3 << 4) -#define BCH_LAYOUTSELECT_CS2_SELECT_OFFSET 4 -#define BCH_LAYOUTSELECT_CS1_SELECT_MASK (0x3 << 2) -#define BCH_LAYOUTSELECT_CS1_SELECT_OFFSET 2 -#define BCH_LAYOUTSELECT_CS0_SELECT_MASK (0x3 << 0) -#define BCH_LAYOUTSELECT_CS0_SELECT_OFFSET 0 - -#define BCH_FLASHLAYOUT0_NBLOCKS_MASK (0xff << 24) -#define BCH_FLASHLAYOUT0_NBLOCKS_OFFSET 24 -#define BCH_FLASHLAYOUT0_META_SIZE_MASK (0xff << 16) -#define BCH_FLASHLAYOUT0_META_SIZE_OFFSET 16 -#define BCH_FLASHLAYOUT0_ECC0_MASK (0xf << 12) -#define BCH_FLASHLAYOUT0_ECC0_OFFSET 12 -#define BCH_FLASHLAYOUT0_ECC0_NONE (0x0 << 12) -#define BCH_FLASHLAYOUT0_ECC0_ECC2 (0x1 << 12) -#define BCH_FLASHLAYOUT0_ECC0_ECC4 (0x2 << 12) -#define BCH_FLASHLAYOUT0_ECC0_ECC6 (0x3 << 12) -#define BCH_FLASHLAYOUT0_ECC0_ECC8 (0x4 << 12) -#define BCH_FLASHLAYOUT0_ECC0_ECC10 (0x5 << 12) -#define BCH_FLASHLAYOUT0_ECC0_ECC12 (0x6 << 12) -#define BCH_FLASHLAYOUT0_ECC0_ECC14 (0x7 << 12) -#define BCH_FLASHLAYOUT0_ECC0_ECC16 (0x8 << 12) -#define BCH_FLASHLAYOUT0_ECC0_ECC18 (0x9 << 12) -#define BCH_FLASHLAYOUT0_ECC0_ECC20 (0xa << 12) -#define BCH_FLASHLAYOUT0_ECC0_ECC22 (0xb << 12) -#define BCH_FLASHLAYOUT0_ECC0_ECC24 (0xc << 12) -#define BCH_FLASHLAYOUT0_ECC0_ECC26 (0xd << 12) -#define BCH_FLASHLAYOUT0_ECC0_ECC28 (0xe << 12) -#define BCH_FLASHLAYOUT0_ECC0_ECC30 (0xf << 12) -#define BCH_FLASHLAYOUT0_ECC0_ECC32 (0x10 << 12) -#define BCH_FLASHLAYOUT0_GF13_0_GF14_1 (1 << 10) -#define BCH_FLASHLAYOUT0_DATA0_SIZE_MASK 0xfff -#define BCH_FLASHLAYOUT0_DATA0_SIZE_OFFSET 0 - -#define BCH_FLASHLAYOUT1_PAGE_SIZE_MASK (0xffff << 16) -#define BCH_FLASHLAYOUT1_PAGE_SIZE_OFFSET 16 -#define BCH_FLASHLAYOUT1_ECCN_MASK (0xf << 12) -#define BCH_FLASHLAYOUT1_ECCN_OFFSET 12 -#define BCH_FLASHLAYOUT1_ECCN_NONE (0x0 << 12) -#define BCH_FLASHLAYOUT1_ECCN_ECC2 (0x1 << 12) -#define BCH_FLASHLAYOUT1_ECCN_ECC4 (0x2 << 12) -#define BCH_FLASHLAYOUT1_ECCN_ECC6 (0x3 << 12) -#define BCH_FLASHLAYOUT1_ECCN_ECC8 (0x4 << 12) -#define BCH_FLASHLAYOUT1_ECCN_ECC10 (0x5 << 12) -#define BCH_FLASHLAYOUT1_ECCN_ECC12 (0x6 << 12) -#define BCH_FLASHLAYOUT1_ECCN_ECC14 (0x7 << 12) -#define BCH_FLASHLAYOUT1_ECCN_ECC16 (0x8 << 12) -#define BCH_FLASHLAYOUT1_ECCN_ECC18 (0x9 << 12) -#define BCH_FLASHLAYOUT1_ECCN_ECC20 (0xa << 12) -#define BCH_FLASHLAYOUT1_ECCN_ECC22 (0xb << 12) -#define BCH_FLASHLAYOUT1_ECCN_ECC24 (0xc << 12) -#define BCH_FLASHLAYOUT1_ECCN_ECC26 (0xd << 12) -#define BCH_FLASHLAYOUT1_ECCN_ECC28 (0xe << 12) -#define BCH_FLASHLAYOUT1_ECCN_ECC30 (0xf << 12) -#define BCH_FLASHLAYOUT1_ECCN_ECC32 (0x10 << 12) -#define BCH_FLASHLAYOUT1_GF13_0_GF14_1 (1 << 10) -#define BCH_FLASHLAYOUT1_DATAN_SIZE_MASK 0xfff -#define BCH_FLASHLAYOUT1_DATAN_SIZE_OFFSET 0 - -#define BCH_DEBUG0_RSVD1_MASK (0x1f << 27) -#define BCH_DEBUG0_RSVD1_OFFSET 27 -#define BCH_DEBUG0_ROM_BIST_ENABLE (1 << 26) -#define BCH_DEBUG0_ROM_BIST_COMPLETE (1 << 25) -#define BCH_DEBUG0_KES_DEBUG_SYNDROME_SYMBOL_MASK (0x1ff << 16) -#define BCH_DEBUG0_KES_DEBUG_SYNDROME_SYMBOL_OFFSET 16 -#define BCH_DEBUG0_KES_DEBUG_SYNDROME_SYMBOL_NORMAL (0x0 << 16) -#define BCH_DEBUG0_KES_DEBUG_SYNDROME_SYMBOL_TEST_MODE (0x1 << 16) -#define BCH_DEBUG0_KES_DEBUG_SHIFT_SYND (1 << 15) -#define BCH_DEBUG0_KES_DEBUG_PAYLOAD_FLAG (1 << 14) -#define BCH_DEBUG0_KES_DEBUG_MODE4K (1 << 13) -#define BCH_DEBUG0_KES_DEBUG_KICK (1 << 12) -#define BCH_DEBUG0_KES_STANDALONE (1 << 11) -#define BCH_DEBUG0_KES_DEBUG_STEP (1 << 10) -#define BCH_DEBUG0_KES_DEBUG_STALL (1 << 9) -#define BCH_DEBUG0_BM_KES_TEST_BYPASS (1 << 8) -#define BCH_DEBUG0_RSVD0_MASK (0x3 << 6) -#define BCH_DEBUG0_RSVD0_OFFSET 6 -#define BCH_DEBUG0_DEBUG_REG_SELECT_MASK 0x3f -#define BCH_DEBUG0_DEBUG_REG_SELECT_OFFSET 0 - -#define BCH_DBGKESREAD_VALUES_MASK 0xffffffff -#define BCH_DBGKESREAD_VALUES_OFFSET 0 - -#define BCH_DBGCSFEREAD_VALUES_MASK 0xffffffff -#define BCH_DBGCSFEREAD_VALUES_OFFSET 0 - -#define BCH_DBGSYNDGENREAD_VALUES_MASK 0xffffffff -#define BCH_DBGSYNDGENREAD_VALUES_OFFSET 0 - -#define BCH_DBGAHBMREAD_VALUES_MASK 0xffffffff -#define BCH_DBGAHBMREAD_VALUES_OFFSET 0 - -#define BCH_BLOCKNAME_NAME_MASK 0xffffffff -#define BCH_BLOCKNAME_NAME_OFFSET 0 - -#define BCH_VERSION_MAJOR_MASK (0xff << 24) -#define BCH_VERSION_MAJOR_OFFSET 24 -#define BCH_VERSION_MINOR_MASK (0xff << 16) -#define BCH_VERSION_MINOR_OFFSET 16 -#define BCH_VERSION_STEP_MASK 0xffff -#define BCH_VERSION_STEP_OFFSET 0 - -#endif /* __MX28_REGS_BCH_H__ */ diff --git a/arch/arm/include/asm/arch-mx28/regs-clkctrl.h b/arch/arm/include/asm/arch-mx28/regs-clkctrl.h deleted file mode 100644 index 3c4947d..0000000 --- a/arch/arm/include/asm/arch-mx28/regs-clkctrl.h +++ /dev/null @@ -1,294 +0,0 @@ -/* - * Freescale i.MX28 CLKCTRL Register Definitions - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * on behalf of DENX Software Engineering GmbH - * - * Based on code from LTIB: - * Copyright 2008-2010 Freescale Semiconductor, Inc. All Rights Reserved. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA - * - */ - -#ifndef __MX28_REGS_CLKCTRL_H__ -#define __MX28_REGS_CLKCTRL_H__ - -#include <asm/arch/regs-common.h> - -#ifndef __ASSEMBLY__ -struct mx28_clkctrl_regs { - mx28_reg_32(hw_clkctrl_pll0ctrl0) /* 0x00 */ - mx28_reg_32(hw_clkctrl_pll0ctrl1) /* 0x10 */ - mx28_reg_32(hw_clkctrl_pll1ctrl0) /* 0x20 */ - mx28_reg_32(hw_clkctrl_pll1ctrl1) /* 0x30 */ - mx28_reg_32(hw_clkctrl_pll2ctrl0) /* 0x40 */ - mx28_reg_32(hw_clkctrl_cpu) /* 0x50 */ - mx28_reg_32(hw_clkctrl_hbus) /* 0x60 */ - mx28_reg_32(hw_clkctrl_xbus) /* 0x70 */ - mx28_reg_32(hw_clkctrl_xtal) /* 0x80 */ - mx28_reg_32(hw_clkctrl_ssp0) /* 0x90 */ - mx28_reg_32(hw_clkctrl_ssp1) /* 0xa0 */ - mx28_reg_32(hw_clkctrl_ssp2) /* 0xb0 */ - mx28_reg_32(hw_clkctrl_ssp3) /* 0xc0 */ - mx28_reg_32(hw_clkctrl_gpmi) /* 0xd0 */ - mx28_reg_32(hw_clkctrl_spdif) /* 0xe0 */ - mx28_reg_32(hw_clkctrl_emi) /* 0xf0 */ - mx28_reg_32(hw_clkctrl_saif0) /* 0x100 */ - mx28_reg_32(hw_clkctrl_saif1) /* 0x110 */ - mx28_reg_32(hw_clkctrl_lcdif) /* 0x120 */ - mx28_reg_32(hw_clkctrl_etm) /* 0x130 */ - mx28_reg_32(hw_clkctrl_enet) /* 0x140 */ - mx28_reg_32(hw_clkctrl_hsadc) /* 0x150 */ - mx28_reg_32(hw_clkctrl_flexcan) /* 0x160 */ - - uint32_t reserved[16]; - - mx28_reg_8(hw_clkctrl_frac0) /* 0x1b0 */ - mx28_reg_8(hw_clkctrl_frac1) /* 0x1c0 */ - mx28_reg_32(hw_clkctrl_clkseq) /* 0x1d0 */ - mx28_reg_32(hw_clkctrl_reset) /* 0x1e0 */ - mx28_reg_32(hw_clkctrl_status) /* 0x1f0 */ - mx28_reg_32(hw_clkctrl_version) /* 0x200 */ -}; -#endif - -#define CLKCTRL_PLL0CTRL0_LFR_SEL_MASK (0x3 << 28) -#define CLKCTRL_PLL0CTRL0_LFR_SEL_OFFSET 28 -#define CLKCTRL_PLL0CTRL0_LFR_SEL_DEFAULT (0x0 << 28) -#define CLKCTRL_PLL0CTRL0_LFR_SEL_TIMES_2 (0x1 << 28) -#define CLKCTRL_PLL0CTRL0_LFR_SEL_TIMES_05 (0x2 << 28) -#define CLKCTRL_PLL0CTRL0_LFR_SEL_UNDEFINED (0x3 << 28) -#define CLKCTRL_PLL0CTRL0_CP_SEL_MASK (0x3 << 24) -#define CLKCTRL_PLL0CTRL0_CP_SEL_OFFSET 24 -#define CLKCTRL_PLL0CTRL0_CP_SEL_DEFAULT (0x0 << 24) -#define CLKCTRL_PLL0CTRL0_CP_SEL_TIMES_2 (0x1 << 24) -#define CLKCTRL_PLL0CTRL0_CP_SEL_TIMES_05 (0x2 << 24) -#define CLKCTRL_PLL0CTRL0_CP_SEL_UNDEFINED (0x3 << 24) -#define CLKCTRL_PLL0CTRL0_DIV_SEL_MASK (0x3 << 20) -#define CLKCTRL_PLL0CTRL0_DIV_SEL_OFFSET 20 -#define CLKCTRL_PLL0CTRL0_DIV_SEL_DEFAULT (0x0 << 20) -#define CLKCTRL_PLL0CTRL0_DIV_SEL_LOWER (0x1 << 20) -#define CLKCTRL_PLL0CTRL0_DIV_SEL_LOWEST (0x2 << 20) -#define CLKCTRL_PLL0CTRL0_DIV_SEL_UNDEFINED (0x3 << 20) -#define CLKCTRL_PLL0CTRL0_EN_USB_CLKS (1 << 18) -#define CLKCTRL_PLL0CTRL0_POWER (1 << 17) - -#define CLKCTRL_PLL0CTRL1_LOCK (1 << 31) -#define CLKCTRL_PLL0CTRL1_FORCE_LOCK (1 << 30) -#define CLKCTRL_PLL0CTRL1_LOCK_COUNT_MASK 0xffff -#define CLKCTRL_PLL0CTRL1_LOCK_COUNT_OFFSET 0 - -#define CLKCTRL_PLL1CTRL0_CLKGATEEMI (1 << 31) -#define CLKCTRL_PLL1CTRL0_LFR_SEL_MASK (0x3 << 28) -#define CLKCTRL_PLL1CTRL0_LFR_SEL_OFFSET 28 -#define CLKCTRL_PLL1CTRL0_LFR_SEL_DEFAULT (0x0 << 28) -#define CLKCTRL_PLL1CTRL0_LFR_SEL_TIMES_2 (0x1 << 28) -#define CLKCTRL_PLL1CTRL0_LFR_SEL_TIMES_05 (0x2 << 28) -#define CLKCTRL_PLL1CTRL0_LFR_SEL_UNDEFINED (0x3 << 28) -#define CLKCTRL_PLL1CTRL0_CP_SEL_MASK (0x3 << 24) -#define CLKCTRL_PLL1CTRL0_CP_SEL_OFFSET 24 -#define CLKCTRL_PLL1CTRL0_CP_SEL_DEFAULT (0x0 << 24) -#define CLKCTRL_PLL1CTRL0_CP_SEL_TIMES_2 (0x1 << 24) -#define CLKCTRL_PLL1CTRL0_CP_SEL_TIMES_05 (0x2 << 24) -#define CLKCTRL_PLL1CTRL0_CP_SEL_UNDEFINED (0x3 << 24) -#define CLKCTRL_PLL1CTRL0_DIV_SEL_MASK (0x3 << 20) -#define CLKCTRL_PLL1CTRL0_DIV_SEL_OFFSET 20 -#define CLKCTRL_PLL1CTRL0_DIV_SEL_DEFAULT (0x0 << 20) -#define CLKCTRL_PLL1CTRL0_DIV_SEL_LOWER (0x1 << 20) -#define CLKCTRL_PLL1CTRL0_DIV_SEL_LOWEST (0x2 << 20) -#define CLKCTRL_PLL1CTRL0_DIV_SEL_UNDEFINED (0x3 << 20) -#define CLKCTRL_PLL1CTRL0_EN_USB_CLKS (1 << 18) -#define CLKCTRL_PLL1CTRL0_POWER (1 << 17) - -#define CLKCTRL_PLL1CTRL1_LOCK (1 << 31) -#define CLKCTRL_PLL1CTRL1_FORCE_LOCK (1 << 30) -#define CLKCTRL_PLL1CTRL1_LOCK_COUNT_MASK 0xffff -#define CLKCTRL_PLL1CTRL1_LOCK_COUNT_OFFSET 0 - -#define CLKCTRL_PLL2CTRL0_CLKGATE (1 << 31) -#define CLKCTRL_PLL2CTRL0_LFR_SEL_MASK (0x3 << 28) -#define CLKCTRL_PLL2CTRL0_LFR_SEL_OFFSET 28 -#define CLKCTRL_PLL2CTRL0_HOLD_RING_OFF_B (1 << 26) -#define CLKCTRL_PLL2CTRL0_CP_SEL_MASK (0x3 << 24) -#define CLKCTRL_PLL2CTRL0_CP_SEL_OFFSET 24 -#define CLKCTRL_PLL2CTRL0_POWER (1 << 23) - -#define CLKCTRL_CPU_BUSY_REF_XTAL (1 << 29) -#define CLKCTRL_CPU_BUSY_REF_CPU (1 << 28) -#define CLKCTRL_CPU_DIV_XTAL_FRAC_EN (1 << 26) -#define CLKCTRL_CPU_DIV_XTAL_MASK (0x3ff << 16) -#define CLKCTRL_CPU_DIV_XTAL_OFFSET 16 -#define CLKCTRL_CPU_INTERRUPT_WAIT (1 << 12) -#define CLKCTRL_CPU_DIV_CPU_FRAC_EN (1 << 10) -#define CLKCTRL_CPU_DIV_CPU_MASK 0x3f -#define CLKCTRL_CPU_DIV_CPU_OFFSET 0 - -#define CLKCTRL_HBUS_ASM_BUSY (1 << 31) -#define CLKCTRL_HBUS_DCP_AS_ENABLE (1 << 30) -#define CLKCTRL_HBUS_PXP_AS_ENABLE (1 << 29) -#define CLKCTRL_HBUS_ASM_EMIPORT_AS_ENABLE (1 << 27) -#define CLKCTRL_HBUS_APBHDMA_AS_ENABLE (1 << 26) -#define CLKCTRL_HBUS_APBXDMA_AS_ENABLE (1 << 25) -#define CLKCTRL_HBUS_TRAFFIC_JAM_AS_ENABLE (1 << 24) -#define CLKCTRL_HBUS_TRAFFIC_AS_ENABLE (1 << 23) -#define CLKCTRL_HBUS_CPU_DATA_AS_ENABLE (1 << 22) -#define CLKCTRL_HBUS_CPU_INSTR_AS_ENABLE (1 << 21) -#define CLKCTRL_HBUS_ASM_ENABLE (1 << 20) -#define CLKCTRL_HBUS_AUTO_CLEAR_DIV_ENABLE (1 << 19) -#define CLKCTRL_HBUS_SLOW_DIV_MASK (0x7 << 16) -#define CLKCTRL_HBUS_SLOW_DIV_OFFSET 16 -#define CLKCTRL_HBUS_SLOW_DIV_BY1 (0x0 << 16) -#define CLKCTRL_HBUS_SLOW_DIV_BY2 (0x1 << 16) -#define CLKCTRL_HBUS_SLOW_DIV_BY4 (0x2 << 16) -#define CLKCTRL_HBUS_SLOW_DIV_BY8 (0x3 << 16) -#define CLKCTRL_HBUS_SLOW_DIV_BY16 (0x4 << 16) -#define CLKCTRL_HBUS_SLOW_DIV_BY32 (0x5 << 16) -#define CLKCTRL_HBUS_DIV_FRAC_EN (1 << 5) -#define CLKCTRL_HBUS_DIV_MASK 0x1f -#define CLKCTRL_HBUS_DIV_OFFSET 0 - -#define CLKCTRL_XBUS_BUSY (1 << 31) -#define CLKCTRL_XBUS_AUTO_CLEAR_DIV_ENABLE (1 << 11) -#define CLKCTRL_XBUS_DIV_FRAC_EN (1 << 10) -#define CLKCTRL_XBUS_DIV_MASK 0x3ff -#define CLKCTRL_XBUS_DIV_OFFSET 0 - -#define CLKCTRL_XTAL_UART_CLK_GATE (1 << 31) -#define CLKCTRL_XTAL_PWM_CLK24M_GATE (1 << 29) -#define CLKCTRL_XTAL_TIMROT_CLK32K_GATE (1 << 26) -#define CLKCTRL_XTAL_DIV_UART_MASK 0x3 -#define CLKCTRL_XTAL_DIV_UART_OFFSET 0 - -#define CLKCTRL_SSP_CLKGATE (1 << 31) -#define CLKCTRL_SSP_BUSY (1 << 29) -#define CLKCTRL_SSP_DIV_FRAC_EN (1 << 9) -#define CLKCTRL_SSP_DIV_MASK 0x1ff -#define CLKCTRL_SSP_DIV_OFFSET 0 - -#define CLKCTRL_GPMI_CLKGATE (1 << 31) -#define CLKCTRL_GPMI_BUSY (1 << 29) -#define CLKCTRL_GPMI_DIV_FRAC_EN (1 << 10) -#define CLKCTRL_GPMI_DIV_MASK 0x3ff -#define CLKCTRL_GPMI_DIV_OFFSET 0 - -#define CLKCTRL_SPDIF_CLKGATE (1 << 31) - -#define CLKCTRL_EMI_CLKGATE (1 << 31) -#define CLKCTRL_EMI_SYNC_MODE_EN (1 << 30) -#define CLKCTRL_EMI_BUSY_REF_XTAL (1 << 29) -#define CLKCTRL_EMI_BUSY_REF_EMI (1 << 28) -#define CLKCTRL_EMI_BUSY_REF_CPU (1 << 27) -#define CLKCTRL_EMI_BUSY_SYNC_MODE (1 << 26) -#define CLKCTRL_EMI_BUSY_DCC_RESYNC (1 << 17) -#define CLKCTRL_EMI_DCC_RESYNC_ENABLE (1 << 16) -#define CLKCTRL_EMI_DIV_XTAL_MASK (0xf << 8) -#define CLKCTRL_EMI_DIV_XTAL_OFFSET 8 -#define CLKCTRL_EMI_DIV_EMI_MASK 0x3f -#define CLKCTRL_EMI_DIV_EMI_OFFSET 0 - -#define CLKCTRL_SAIF0_CLKGATE (1 << 31) -#define CLKCTRL_SAIF0_BUSY (1 << 29) -#define CLKCTRL_SAIF0_DIV_FRAC_EN (1 << 16) -#define CLKCTRL_SAIF0_DIV_MASK 0xffff -#define CLKCTRL_SAIF0_DIV_OFFSET 0 - -#define CLKCTRL_SAIF1_CLKGATE (1 << 31) -#define CLKCTRL_SAIF1_BUSY (1 << 29) -#define CLKCTRL_SAIF1_DIV_FRAC_EN (1 << 16) -#define CLKCTRL_SAIF1_DIV_MASK 0xffff -#define CLKCTRL_SAIF1_DIV_OFFSET 0 - -#define CLKCTRL_DIS_LCDIF_CLKGATE (1 << 31) -#define CLKCTRL_DIS_LCDIF_BUSY (1 << 29) -#define CLKCTRL_DIS_LCDIF_DIV_FRAC_EN (1 << 13) -#define CLKCTRL_DIS_LCDIF_DIV_MASK 0x1fff -#define CLKCTRL_DIS_LCDIF_DIV_OFFSET 0 - -#define CLKCTRL_ETM_CLKGATE (1 << 31) -#define CLKCTRL_ETM_BUSY (1 << 29) -#define CLKCTRL_ETM_DIV_FRAC_EN (1 << 7) -#define CLKCTRL_ETM_DIV_MASK 0x7f -#define CLKCTRL_ETM_DIV_OFFSET 0 - -#define CLKCTRL_ENET_SLEEP (1 << 31) -#define CLKCTRL_ENET_DISABLE (1 << 30) -#define CLKCTRL_ENET_STATUS (1 << 29) -#define CLKCTRL_ENET_BUSY_TIME (1 << 27) -#define CLKCTRL_ENET_DIV_TIME_MASK (0x3f << 21) -#define CLKCTRL_ENET_DIV_TIME_OFFSET 21 -#define CLKCTRL_ENET_TIME_SEL_MASK (0x3 << 19) -#define CLKCTRL_ENET_TIME_SEL_OFFSET 19 -#define CLKCTRL_ENET_TIME_SEL_XTAL (0x0 << 19) -#define CLKCTRL_ENET_TIME_SEL_PLL (0x1 << 19) -#define CLKCTRL_ENET_TIME_SEL_RMII_CLK (0x2 << 19) -#define CLKCTRL_ENET_TIME_SEL_UNDEFINED (0x3 << 19) -#define CLKCTRL_ENET_CLK_OUT_EN (1 << 18) -#define CLKCTRL_ENET_RESET_BY_SW_CHIP (1 << 17) -#define CLKCTRL_ENET_RESET_BY_SW (1 << 16) - -#define CLKCTRL_HSADC_RESETB (1 << 30) -#define CLKCTRL_HSADC_FREQDIV_MASK (0x3 << 28) -#define CLKCTRL_HSADC_FREQDIV_OFFSET 28 - -#define CLKCTRL_FLEXCAN_STOP_CAN0 (1 << 30) -#define CLKCTRL_FLEXCAN_CAN0_STATUS (1 << 29) -#define CLKCTRL_FLEXCAN_STOP_CAN1 (1 << 28) -#define CLKCTRL_FLEXCAN_CAN1_STATUS (1 << 27) - -#define CLKCTRL_FRAC_CLKGATE (1 << 7) -#define CLKCTRL_FRAC_STABLE (1 << 6) -#define CLKCTRL_FRAC_FRAC_MASK 0x3f -#define CLKCTRL_FRAC_FRAC_OFFSET 0 -#define CLKCTRL_FRAC0_CPU 0 -#define CLKCTRL_FRAC0_EMI 1 -#define CLKCTRL_FRAC0_IO1 2 -#define CLKCTRL_FRAC0_IO0 3 -#define CLKCTRL_FRAC1_PIX 0 -#define CLKCTRL_FRAC1_HSADC 1 -#define CLKCTRL_FRAC1_GPMI 2 - -#define CLKCTRL_CLKSEQ_BYPASS_CPU (1 << 18) -#define CLKCTRL_CLKSEQ_BYPASS_DIS_LCDIF (1 << 14) -#define CLKCTRL_CLKSEQ_BYPASS_DIS_LCDIF_BYPASS (0x1 << 14) -#define CLKCTRL_CLKSEQ_BYPASS_DIS_LCDIF_PFD (0x0 << 14) -#define CLKCTRL_CLKSEQ_BYPASS_ETM (1 << 8) -#define CLKCTRL_CLKSEQ_BYPASS_EMI (1 << 7) -#define CLKCTRL_CLKSEQ_BYPASS_SSP3 (1 << 6) -#define CLKCTRL_CLKSEQ_BYPASS_SSP2 (1 << 5) -#define CLKCTRL_CLKSEQ_BYPASS_SSP1 (1 << 4) -#define CLKCTRL_CLKSEQ_BYPASS_SSP0 (1 << 3) -#define CLKCTRL_CLKSEQ_BYPASS_GPMI (1 << 2) -#define CLKCTRL_CLKSEQ_BYPASS_SAIF1 (1 << 1) -#define CLKCTRL_CLKSEQ_BYPASS_SAIF0 (1 << 0) - -#define CLKCTRL_RESET_WDOG_POR_DISABLE (1 << 5) -#define CLKCTRL_RESET_EXTERNAL_RESET_ENABLE (1 << 4) -#define CLKCTRL_RESET_THERMAL_RESET_ENABLE (1 << 3) -#define CLKCTRL_RESET_THERMAL_RESET_DEFAULT (1 << 2) -#define CLKCTRL_RESET_CHIP (1 << 1) -#define CLKCTRL_RESET_DIG (1 << 0) - -#define CLKCTRL_STATUS_CPU_LIMIT_MASK (0x3 << 30) -#define CLKCTRL_STATUS_CPU_LIMIT_OFFSET 30 - -#define CLKCTRL_VERSION_MAJOR_MASK (0xff << 24) -#define CLKCTRL_VERSION_MAJOR_OFFSET 24 -#define CLKCTRL_VERSION_MINOR_MASK (0xff << 16) -#define CLKCTRL_VERSION_MINOR_OFFSET 16 -#define CLKCTRL_VERSION_STEP_MASK 0xffff -#define CLKCTRL_VERSION_STEP_OFFSET 0 - -#endif /* __MX28_REGS_CLKCTRL_H__ */ diff --git a/arch/arm/include/asm/arch-mx28/regs-common.h b/arch/arm/include/asm/arch-mx28/regs-common.h deleted file mode 100644 index d2e1953..0000000 --- a/arch/arm/include/asm/arch-mx28/regs-common.h +++ /dev/null @@ -1,82 +0,0 @@ -/* - * Freescale i.MX28 Register Accessors - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * on behalf of DENX Software Engineering GmbH - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA - * - */ - -#ifndef __MX28_REGS_COMMON_H__ -#define __MX28_REGS_COMMON_H__ - -/* - * The i.MX28 has interesting feature when it comes to register access. There - * are four kinds of access to one particular register. Those are: - * - * 1) Common read/write access. To use this mode, just write to the address of - * the register. - * 2) Set bits only access. To set bits, write which bits you want to set to the - * address of the register + 0x4. - * 3) Clear bits only access. To clear bits, write which bits you want to clear - * to the address of the register + 0x8. - * 4) Toggle bits only access. To toggle bits, write which bits you want to - * toggle to the address of the register + 0xc. - * - * IMPORTANT NOTE: Not all registers support accesses 2-4! Also, not all bits - * can be set/cleared by pure write as in access type 1, some need to be - * explicitly set/cleared by using access type 2-3. - * - * The following macros and structures allow the user to either access the - * register in all aforementioned modes (by accessing reg_name, reg_name_set, - * reg_name_clr, reg_name_tog) or pass the register structure further into - * various functions with correct type information (by accessing reg_name_reg). - * - */ - -#define __mx28_reg_8(name) \ - uint8_t name[4]; \ - uint8_t name##_set[4]; \ - uint8_t name##_clr[4]; \ - uint8_t name##_tog[4]; \ - -#define __mx28_reg_32(name) \ - uint32_t name; \ - uint32_t name##_set; \ - uint32_t name##_clr; \ - uint32_t name##_tog; - -struct mx28_register_8 { - __mx28_reg_8(reg) -}; - -struct mx28_register_32 { - __mx28_reg_32(reg) -}; - -#define mx28_reg_8(name) \ - union { \ - struct { __mx28_reg_8(name) }; \ - struct mx28_register_8 name##_reg; \ - }; - -#define mx28_reg_32(name) \ - union { \ - struct { __mx28_reg_32(name) }; \ - struct mx28_register_32 name##_reg; \ - }; - -#endif /* __MX28_REGS_COMMON_H__ */ diff --git a/arch/arm/include/asm/arch-mx28/regs-digctl.h b/arch/arm/include/asm/arch-mx28/regs-digctl.h deleted file mode 100644 index 9a63594..0000000 --- a/arch/arm/include/asm/arch-mx28/regs-digctl.h +++ /dev/null @@ -1,155 +0,0 @@ -/* - * Freescale i.MX28 DIGCTL Register Definitions - * - * Copyright (C) 2012 Robert Delien robert@delien.nl - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA - * - */ - -#ifndef __MX28_REGS_DIGCTL_H__ -#define __MX28_REGS_DIGCTL_H__ - -#include <asm/arch/regs-common.h> - -#ifndef __ASSEMBLY__ -struct mx28_digctl_regs { - mx28_reg_32(hw_digctl_ctrl) /* 0x000 */ - mx28_reg_32(hw_digctl_status) /* 0x010 */ - mx28_reg_32(hw_digctl_hclkcount) /* 0x020 */ - mx28_reg_32(hw_digctl_ramctrl) /* 0x030 */ - mx28_reg_32(hw_digctl_emi_status) /* 0x040 */ - mx28_reg_32(hw_digctl_read_margin) /* 0x050 */ - uint32_t hw_digctl_writeonce; /* 0x060 */ - uint32_t reserved_writeonce[3]; - mx28_reg_32(hw_digctl_bist_ctl) /* 0x070 */ - mx28_reg_32(hw_digctl_bist_status) /* 0x080 */ - uint32_t hw_digctl_entropy; /* 0x090 */ - uint32_t reserved_entropy[3]; - uint32_t hw_digctl_entropy_latched; /* 0x0a0 */ - uint32_t reserved_entropy_latched[3]; - - uint32_t reserved1[4]; - - mx28_reg_32(hw_digctl_microseconds) /* 0x0c0 */ - uint32_t hw_digctl_dbgrd; /* 0x0d0 */ - uint32_t reserved_hw_digctl_dbgrd[3]; - uint32_t hw_digctl_dbg; /* 0x0e0 */ - uint32_t reserved_hw_digctl_dbg[3]; - - uint32_t reserved2[4]; - - mx28_reg_32(hw_digctl_usb_loopback) /* 0x100 */ - mx28_reg_32(hw_digctl_ocram_status0) /* 0x110 */ - mx28_reg_32(hw_digctl_ocram_status1) /* 0x120 */ - mx28_reg_32(hw_digctl_ocram_status2) /* 0x130 */ - mx28_reg_32(hw_digctl_ocram_status3) /* 0x140 */ - mx28_reg_32(hw_digctl_ocram_status4) /* 0x150 */ - mx28_reg_32(hw_digctl_ocram_status5) /* 0x160 */ - mx28_reg_32(hw_digctl_ocram_status6) /* 0x170 */ - mx28_reg_32(hw_digctl_ocram_status7) /* 0x180 */ - mx28_reg_32(hw_digctl_ocram_status8) /* 0x190 */ - mx28_reg_32(hw_digctl_ocram_status9) /* 0x1a0 */ - mx28_reg_32(hw_digctl_ocram_status10) /* 0x1b0 */ - mx28_reg_32(hw_digctl_ocram_status11) /* 0x1c0 */ - mx28_reg_32(hw_digctl_ocram_status12) /* 0x1d0 */ - mx28_reg_32(hw_digctl_ocram_status13) /* 0x1e0 */ - - uint32_t reserved3[36]; - - uint32_t hw_digctl_scratch0; /* 0x280 */ - uint32_t reserved_hw_digctl_scratch0[3]; - uint32_t hw_digctl_scratch1; /* 0x290 */ - uint32_t reserved_hw_digctl_scratch1[3]; - uint32_t hw_digctl_armcache; /* 0x2a0 */ - uint32_t reserved_hw_digctl_armcache[3]; - mx28_reg_32(hw_digctl_debug_trap) /* 0x2b0 */ - uint32_t hw_digctl_debug_trap_l0_addr_low; /* 0x2c0 */ - uint32_t reserved_hw_digctl_debug_trap_l0_addr_low[3]; - uint32_t hw_digctl_debug_trap_l0_addr_high; /* 0x2d0 */ - uint32_t reserved_hw_digctl_debug_trap_l0_addr_high[3]; - uint32_t hw_digctl_debug_trap_l3_addr_low; /* 0x2e0 */ - uint32_t reserved_hw_digctl_debug_trap_l3_addr_low[3]; - uint32_t hw_digctl_debug_trap_l3_addr_high; /* 0x2f0 */ - uint32_t reserved_hw_digctl_debug_trap_l3_addr_high[3]; - uint32_t hw_digctl_fsl; /* 0x300 */ - uint32_t reserved_hw_digctl_fsl[3]; - uint32_t hw_digctl_chipid; /* 0x310 */ - uint32_t reserved_hw_digctl_chipid[3]; - - uint32_t reserved4[4]; - - uint32_t hw_digctl_ahb_stats_select; /* 0x330 */ - uint32_t reserved_hw_digctl_ahb_stats_select[3]; - - uint32_t reserved5[12]; - - uint32_t hw_digctl_l1_ahb_active_cycles; /* 0x370 */ - uint32_t reserved_hw_digctl_l1_ahb_active_cycles[3]; - uint32_t hw_digctl_l1_ahb_data_stalled; /* 0x380 */ - uint32_t reserved_hw_digctl_l1_ahb_data_stalled[3]; - uint32_t hw_digctl_l1_ahb_data_cycles; /* 0x390 */ - uint32_t reserved_hw_digctl_l1_ahb_data_cycles[3]; - uint32_t hw_digctl_l2_ahb_active_cycles; /* 0x3a0 */ - uint32_t reserved_hw_digctl_l2_ahb_active_cycles[3]; - uint32_t hw_digctl_l2_ahb_data_stalled; /* 0x3b0 */ - uint32_t reserved_hw_digctl_l2_ahb_data_stalled[3]; - uint32_t hw_digctl_l2_ahb_data_cycles; /* 0x3c0 */ - uint32_t reserved_hw_digctl_l2_ahb_data_cycles[3]; - uint32_t hw_digctl_l3_ahb_active_cycles; /* 0x3d0 */ - uint32_t reserved_hw_digctl_l3_ahb_active_cycles[3]; - uint32_t hw_digctl_l3_ahb_data_stalled; /* 0x3e0 */ - uint32_t reserved_hw_digctl_l3_ahb_data_stalled[3]; - uint32_t hw_digctl_l3_ahb_data_cycles; /* 0x3f0 */ - uint32_t reserved_hw_digctl_l3_ahb_data_cycles[3]; - - uint32_t reserved6[64]; - - uint32_t hw_digctl_mpte0_loc; /* 0x500 */ - uint32_t reserved_hw_digctl_mpte0_loc[3]; - uint32_t hw_digctl_mpte1_loc; /* 0x510 */ - uint32_t reserved_hw_digctl_mpte1_loc[3]; - uint32_t hw_digctl_mpte2_loc; /* 0x520 */ - uint32_t reserved_hw_digctl_mpte2_loc[3]; - uint32_t hw_digctl_mpte3_loc; /* 0x530 */ - uint32_t reserved_hw_digctl_mpte3_loc[3]; - uint32_t hw_digctl_mpte4_loc; /* 0x540 */ - uint32_t reserved_hw_digctl_mpte4_loc[3]; - uint32_t hw_digctl_mpte5_loc; /* 0x550 */ - uint32_t reserved_hw_digctl_mpte5_loc[3]; - uint32_t hw_digctl_mpte6_loc; /* 0x560 */ - uint32_t reserved_hw_digctl_mpte6_loc[3]; - uint32_t hw_digctl_mpte7_loc; /* 0x570 */ - uint32_t reserved_hw_digctl_mpte7_loc[3]; - uint32_t hw_digctl_mpte8_loc; /* 0x580 */ - uint32_t reserved_hw_digctl_mpte8_loc[3]; - uint32_t hw_digctl_mpte9_loc; /* 0x590 */ - uint32_t reserved_hw_digctl_mpte9_loc[3]; - uint32_t hw_digctl_mpte10_loc; /* 0x5a0 */ - uint32_t reserved_hw_digctl_mpte10_loc[3]; - uint32_t hw_digctl_mpte11_loc; /* 0x5b0 */ - uint32_t reserved_hw_digctl_mpte11_loc[3]; - uint32_t hw_digctl_mpte12_loc; /* 0x5c0 */ - uint32_t reserved_hw_digctl_mpte12_loc[3]; - uint32_t hw_digctl_mpte13_loc; /* 0x5d0 */ - uint32_t reserved_hw_digctl_mpte13_loc[3]; - uint32_t hw_digctl_mpte14_loc; /* 0x5e0 */ - uint32_t reserved_hw_digctl_mpte14_loc[3]; - uint32_t hw_digctl_mpte15_loc; /* 0x5f0 */ - uint32_t reserved_hw_digctl_mpte15_loc[3]; -}; -#endif - -#endif /* __MX28_REGS_DIGCTL_H__ */ diff --git a/arch/arm/include/asm/arch-mx28/regs-gpmi.h b/arch/arm/include/asm/arch-mx28/regs-gpmi.h deleted file mode 100644 index 1b487f4..0000000 --- a/arch/arm/include/asm/arch-mx28/regs-gpmi.h +++ /dev/null @@ -1,222 +0,0 @@ -/* - * Freescale i.MX28 GPMI Register Definitions - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * on behalf of DENX Software Engineering GmbH - * - * Based on code from LTIB: - * Copyright 2008-2010 Freescale Semiconductor, Inc. All Rights Reserved. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA - * - */ - -#ifndef __MX28_REGS_GPMI_H__ -#define __MX28_REGS_GPMI_H__ - -#include <asm/arch/regs-common.h> - -#ifndef __ASSEMBLY__ -struct mx28_gpmi_regs { - mx28_reg_32(hw_gpmi_ctrl0) - mx28_reg_32(hw_gpmi_compare) - mx28_reg_32(hw_gpmi_eccctrl) - mx28_reg_32(hw_gpmi_ecccount) - mx28_reg_32(hw_gpmi_payload) - mx28_reg_32(hw_gpmi_auxiliary) - mx28_reg_32(hw_gpmi_ctrl1) - mx28_reg_32(hw_gpmi_timing0) - mx28_reg_32(hw_gpmi_timing1) - - uint32_t reserved[4]; - - mx28_reg_32(hw_gpmi_data) - mx28_reg_32(hw_gpmi_stat) - mx28_reg_32(hw_gpmi_debug) - mx28_reg_32(hw_gpmi_version) -}; -#endif - -#define GPMI_CTRL0_SFTRST (1 << 31) -#define GPMI_CTRL0_CLKGATE (1 << 30) -#define GPMI_CTRL0_RUN (1 << 29) -#define GPMI_CTRL0_DEV_IRQ_EN (1 << 28) -#define GPMI_CTRL0_LOCK_CS (1 << 27) -#define GPMI_CTRL0_UDMA (1 << 26) -#define GPMI_CTRL0_COMMAND_MODE_MASK (0x3 << 24) -#define GPMI_CTRL0_COMMAND_MODE_OFFSET 24 -#define GPMI_CTRL0_COMMAND_MODE_WRITE (0x0 << 24) -#define GPMI_CTRL0_COMMAND_MODE_READ (0x1 << 24) -#define GPMI_CTRL0_COMMAND_MODE_READ_AND_COMPARE (0x2 << 24) -#define GPMI_CTRL0_COMMAND_MODE_WAIT_FOR_READY (0x3 << 24) -#define GPMI_CTRL0_WORD_LENGTH (1 << 23) -#define GPMI_CTRL0_CS_MASK (0x7 << 20) -#define GPMI_CTRL0_CS_OFFSET 20 -#define GPMI_CTRL0_ADDRESS_MASK (0x7 << 17) -#define GPMI_CTRL0_ADDRESS_OFFSET 17 -#define GPMI_CTRL0_ADDRESS_NAND_DATA (0x0 << 17) -#define GPMI_CTRL0_ADDRESS_NAND_CLE (0x1 << 17) -#define GPMI_CTRL0_ADDRESS_NAND_ALE (0x2 << 17) -#define GPMI_CTRL0_ADDRESS_INCREMENT (1 << 16) -#define GPMI_CTRL0_XFER_COUNT_MASK 0xffff -#define GPMI_CTRL0_XFER_COUNT_OFFSET 0 - -#define GPMI_COMPARE_MASK_MASK (0xffff << 16) -#define GPMI_COMPARE_MASK_OFFSET 16 -#define GPMI_COMPARE_REFERENCE_MASK 0xffff -#define GPMI_COMPARE_REFERENCE_OFFSET 0 - -#define GPMI_ECCCTRL_HANDLE_MASK (0xffff << 16) -#define GPMI_ECCCTRL_HANDLE_OFFSET 16 -#define GPMI_ECCCTRL_ECC_CMD_MASK (0x3 << 13) -#define GPMI_ECCCTRL_ECC_CMD_OFFSET 13 -#define GPMI_ECCCTRL_ECC_CMD_DECODE (0x0 << 13) -#define GPMI_ECCCTRL_ECC_CMD_ENCODE (0x1 << 13) -#define GPMI_ECCCTRL_ENABLE_ECC (1 << 12) -#define GPMI_ECCCTRL_BUFFER_MASK_MASK 0x1ff -#define GPMI_ECCCTRL_BUFFER_MASK_OFFSET 0 -#define GPMI_ECCCTRL_BUFFER_MASK_BCH_AUXONLY 0x100 -#define GPMI_ECCCTRL_BUFFER_MASK_BCH_PAGE 0x1ff - -#define GPMI_ECCCOUNT_COUNT_MASK 0xffff -#define GPMI_ECCCOUNT_COUNT_OFFSET 0 - -#define GPMI_PAYLOAD_ADDRESS_MASK (0x3fffffff << 2) -#define GPMI_PAYLOAD_ADDRESS_OFFSET 2 - -#define GPMI_AUXILIARY_ADDRESS_MASK (0x3fffffff << 2) -#define GPMI_AUXILIARY_ADDRESS_OFFSET 2 - -#define GPMI_CTRL1_DECOUPLE_CS (1 << 24) -#define GPMI_CTRL1_WRN_DLY_SEL_MASK (0x3 << 22) -#define GPMI_CTRL1_WRN_DLY_SEL_OFFSET 22 -#define GPMI_CTRL1_TIMEOUT_IRQ_EN (1 << 20) -#define GPMI_CTRL1_GANGED_RDYBUSY (1 << 19) -#define GPMI_CTRL1_BCH_MODE (1 << 18) -#define GPMI_CTRL1_DLL_ENABLE (1 << 17) -#define GPMI_CTRL1_HALF_PERIOD (1 << 16) -#define GPMI_CTRL1_RDN_DELAY_MASK (0xf << 12) -#define GPMI_CTRL1_RDN_DELAY_OFFSET 12 -#define GPMI_CTRL1_DMA2ECC_MODE (1 << 11) -#define GPMI_CTRL1_DEV_IRQ (1 << 10) -#define GPMI_CTRL1_TIMEOUT_IRQ (1 << 9) -#define GPMI_CTRL1_BURST_EN (1 << 8) -#define GPMI_CTRL1_ABORT_WAIT_REQUEST (1 << 7) -#define GPMI_CTRL1_ABORT_WAIT_FOR_READY_CHANNEL_MASK (0x7 << 4) -#define GPMI_CTRL1_ABORT_WAIT_FOR_READY_CHANNEL_OFFSET 4 -#define GPMI_CTRL1_DEV_RESET (1 << 3) -#define GPMI_CTRL1_ATA_IRQRDY_POLARITY (1 << 2) -#define GPMI_CTRL1_CAMERA_MODE (1 << 1) -#define GPMI_CTRL1_GPMI_MODE (1 << 0) - -#define GPMI_TIMING0_ADDRESS_SETUP_MASK (0xff << 16) -#define GPMI_TIMING0_ADDRESS_SETUP_OFFSET 16 -#define GPMI_TIMING0_DATA_HOLD_MASK (0xff << 8) -#define GPMI_TIMING0_DATA_HOLD_OFFSET 8 -#define GPMI_TIMING0_DATA_SETUP_MASK 0xff -#define GPMI_TIMING0_DATA_SETUP_OFFSET 0 - -#define GPMI_TIMING1_DEVICE_BUSY_TIMEOUT_MASK (0xffff << 16) -#define GPMI_TIMING1_DEVICE_BUSY_TIMEOUT_OFFSET 16 - -#define GPMI_TIMING2_UDMA_TRP_MASK (0xff << 24) -#define GPMI_TIMING2_UDMA_TRP_OFFSET 24 -#define GPMI_TIMING2_UDMA_ENV_MASK (0xff << 16) -#define GPMI_TIMING2_UDMA_ENV_OFFSET 16 -#define GPMI_TIMING2_UDMA_HOLD_MASK (0xff << 8) -#define GPMI_TIMING2_UDMA_HOLD_OFFSET 8 -#define GPMI_TIMING2_UDMA_SETUP_MASK 0xff -#define GPMI_TIMING2_UDMA_SETUP_OFFSET 0 - -#define GPMI_DATA_DATA_MASK 0xffffffff -#define GPMI_DATA_DATA_OFFSET 0 - -#define GPMI_STAT_READY_BUSY_MASK (0xff << 24) -#define GPMI_STAT_READY_BUSY_OFFSET 24 -#define GPMI_STAT_RDY_TIMEOUT_MASK (0xff << 16) -#define GPMI_STAT_RDY_TIMEOUT_OFFSET 16 -#define GPMI_STAT_DEV7_ERROR (1 << 15) -#define GPMI_STAT_DEV6_ERROR (1 << 14) -#define GPMI_STAT_DEV5_ERROR (1 << 13) -#define GPMI_STAT_DEV4_ERROR (1 << 12) -#define GPMI_STAT_DEV3_ERROR (1 << 11) -#define GPMI_STAT_DEV2_ERROR (1 << 10) -#define GPMI_STAT_DEV1_ERROR (1 << 9) -#define GPMI_STAT_DEV0_ERROR (1 << 8) -#define GPMI_STAT_ATA_IRQ (1 << 4) -#define GPMI_STAT_INVALID_BUFFER_MASK (1 << 3) -#define GPMI_STAT_FIFO_EMPTY (1 << 2) -#define GPMI_STAT_FIFO_FULL (1 << 1) -#define GPMI_STAT_PRESENT (1 << 0) - -#define GPMI_DEBUG_WAIT_FOR_READY_END_MASK (0xff << 24) -#define GPMI_DEBUG_WAIT_FOR_READY_END_OFFSET 24 -#define GPMI_DEBUG_DMA_SENSE_MASK (0xff << 16) -#define GPMI_DEBUG_DMA_SENSE_OFFSET 16 -#define GPMI_DEBUG_DMAREQ_MASK (0xff << 8) -#define GPMI_DEBUG_DMAREQ_OFFSET 8 -#define GPMI_DEBUG_CMD_END_MASK 0xff -#define GPMI_DEBUG_CMD_END_OFFSET 0 - -#define GPMI_VERSION_MAJOR_MASK (0xff << 24) -#define GPMI_VERSION_MAJOR_OFFSET 24 -#define GPMI_VERSION_MINOR_MASK (0xff << 16) -#define GPMI_VERSION_MINOR_OFFSET 16 -#define GPMI_VERSION_STEP_MASK 0xffff -#define GPMI_VERSION_STEP_OFFSET 0 - -#define GPMI_DEBUG2_UDMA_STATE_MASK (0xf << 24) -#define GPMI_DEBUG2_UDMA_STATE_OFFSET 24 -#define GPMI_DEBUG2_BUSY (1 << 23) -#define GPMI_DEBUG2_PIN_STATE_MASK (0x7 << 20) -#define GPMI_DEBUG2_PIN_STATE_OFFSET 20 -#define GPMI_DEBUG2_PIN_STATE_PSM_IDLE (0x0 << 20) -#define GPMI_DEBUG2_PIN_STATE_PSM_BYTCNT (0x1 << 20) -#define GPMI_DEBUG2_PIN_STATE_PSM_ADDR (0x2 << 20) -#define GPMI_DEBUG2_PIN_STATE_PSM_STALL (0x3 << 20) -#define GPMI_DEBUG2_PIN_STATE_PSM_STROBE (0x4 << 20) -#define GPMI_DEBUG2_PIN_STATE_PSM_ATARDY (0x5 << 20) -#define GPMI_DEBUG2_PIN_STATE_PSM_DHOLD (0x6 << 20) -#define GPMI_DEBUG2_PIN_STATE_PSM_DONE (0x7 << 20) -#define GPMI_DEBUG2_MAIN_STATE_MASK (0xf << 16) -#define GPMI_DEBUG2_MAIN_STATE_OFFSET 16 -#define GPMI_DEBUG2_MAIN_STATE_MSM_IDLE (0x0 << 16) -#define GPMI_DEBUG2_MAIN_STATE_MSM_BYTCNT (0x1 << 16) -#define GPMI_DEBUG2_MAIN_STATE_MSM_WAITFE (0x2 << 16) -#define GPMI_DEBUG2_MAIN_STATE_MSM_WAITFR (0x3 << 16) -#define GPMI_DEBUG2_MAIN_STATE_MSM_DMAREQ (0x4 << 16) -#define GPMI_DEBUG2_MAIN_STATE_MSM_DMAACK (0x5 << 16) -#define GPMI_DEBUG2_MAIN_STATE_MSM_WAITFF (0x6 << 16) -#define GPMI_DEBUG2_MAIN_STATE_MSM_LDFIFO (0x7 << 16) -#define GPMI_DEBUG2_MAIN_STATE_MSM_LDDMAR (0x8 << 16) -#define GPMI_DEBUG2_MAIN_STATE_MSM_RDCMP (0x9 << 16) -#define GPMI_DEBUG2_MAIN_STATE_MSM_DONE (0xa << 16) -#define GPMI_DEBUG2_SYND2GPMI_BE_MASK (0xf << 12) -#define GPMI_DEBUG2_SYND2GPMI_BE_OFFSET 12 -#define GPMI_DEBUG2_GPMI2SYND_VALID (1 << 11) -#define GPMI_DEBUG2_GPMI2SYND_READY (1 << 10) -#define GPMI_DEBUG2_SYND2GPMI_VALID (1 << 9) -#define GPMI_DEBUG2_SYND2GPMI_READY (1 << 8) -#define GPMI_DEBUG2_VIEW_DELAYED_RDN (1 << 7) -#define GPMI_DEBUG2_UPDATE_WINDOW (1 << 6) -#define GPMI_DEBUG2_RDN_TAP_MASK 0x3f -#define GPMI_DEBUG2_RDN_TAP_OFFSET 0 - -#define GPMI_DEBUG3_APB_WORD_CNTR_MASK (0xffff << 16) -#define GPMI_DEBUG3_APB_WORD_CNTR_OFFSET 16 -#define GPMI_DEBUG3_DEV_WORD_CNTR_MASK 0xffff -#define GPMI_DEBUG3_DEV_WORD_CNTR_OFFSET 0 - -#endif /* __MX28_REGS_GPMI_H__ */ diff --git a/arch/arm/include/asm/arch-mx28/regs-i2c.h b/arch/arm/include/asm/arch-mx28/regs-i2c.h deleted file mode 100644 index 2e2e814..0000000 --- a/arch/arm/include/asm/arch-mx28/regs-i2c.h +++ /dev/null @@ -1,207 +0,0 @@ -/* - * Freescale i.MX28 I2C Register Definitions - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * on behalf of DENX Software Engineering GmbH - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA - * - */ - -#ifndef __MX28_REGS_I2C_H__ -#define __MX28_REGS_I2C_H__ - -#include <asm/arch/regs-common.h> - -#ifndef __ASSEMBLY__ -struct mx28_i2c_regs { - mx28_reg_32(hw_i2c_ctrl0) - mx28_reg_32(hw_i2c_timing0) - mx28_reg_32(hw_i2c_timing1) - mx28_reg_32(hw_i2c_timing2) - mx28_reg_32(hw_i2c_ctrl1) - mx28_reg_32(hw_i2c_stat) - mx28_reg_32(hw_i2c_queuectrl) - mx28_reg_32(hw_i2c_queuestat) - mx28_reg_32(hw_i2c_queuecmd) - mx28_reg_32(hw_i2c_queuedata) - mx28_reg_32(hw_i2c_data) - mx28_reg_32(hw_i2c_debug0) - mx28_reg_32(hw_i2c_debug1) - mx28_reg_32(hw_i2c_version) -}; -#endif - -#define I2C_CTRL_SFTRST (1 << 31) -#define I2C_CTRL_CLKGATE (1 << 30) -#define I2C_CTRL_RUN (1 << 29) -#define I2C_CTRL_PREACK (1 << 27) -#define I2C_CTRL_ACKNOWLEDGE (1 << 26) -#define I2C_CTRL_SEND_NAK_ON_LAST (1 << 25) -#define I2C_CTRL_MULTI_MASTER (1 << 23) -#define I2C_CTRL_CLOCK_HELD (1 << 22) -#define I2C_CTRL_RETAIN_CLOCK (1 << 21) -#define I2C_CTRL_POST_SEND_STOP (1 << 20) -#define I2C_CTRL_PRE_SEND_START (1 << 19) -#define I2C_CTRL_SLAVE_ADDRESS_ENABLE (1 << 18) -#define I2C_CTRL_MASTER_MODE (1 << 17) -#define I2C_CTRL_DIRECTION (1 << 16) -#define I2C_CTRL_XFER_COUNT_MASK 0xffff -#define I2C_CTRL_XFER_COUNT_OFFSET 0 - -#define I2C_TIMING0_HIGH_COUNT_MASK (0x3ff << 16) -#define I2C_TIMING0_HIGH_COUNT_OFFSET 16 -#define I2C_TIMING0_RCV_COUNT_MASK 0x3ff -#define I2C_TIMING0_RCV_COUNT_OFFSET 0 - -#define I2C_TIMING1_LOW_COUNT_MASK (0x3ff << 16) -#define I2C_TIMING1_LOW_COUNT_OFFSET 16 -#define I2C_TIMING1_XMIT_COUNT_MASK 0x3ff -#define I2C_TIMING1_XMIT_COUNT_OFFSET 0 - -#define I2C_TIMING2_BUS_FREE_MASK (0x3ff << 16) -#define I2C_TIMING2_BUS_FREE_OFFSET 16 -#define I2C_TIMING2_LEADIN_COUNT_MASK 0x3ff -#define I2C_TIMING2_LEADIN_COUNT_OFFSET 0 - -#define I2C_CTRL1_RD_QUEUE_IRQ (1 << 30) -#define I2C_CTRL1_WR_QUEUE_IRQ (1 << 29) -#define I2C_CTRL1_CLR_GOT_A_NAK (1 << 28) -#define I2C_CTRL1_ACK_MODE (1 << 27) -#define I2C_CTRL1_FORCE_DATA_IDLE (1 << 26) -#define I2C_CTRL1_FORCE_CLK_IDLE (1 << 25) -#define I2C_CTRL1_BCAST_SLAVE_EN (1 << 24) -#define I2C_CTRL1_SLAVE_ADDRESS_BYTE_MASK (0xff << 16) -#define I2C_CTRL1_SLAVE_ADDRESS_BYTE_OFFSET 16 -#define I2C_CTRL1_BUS_FREE_IRQ_EN (1 << 15) -#define I2C_CTRL1_DATA_ENGINE_CMPLT_IRQ_EN (1 << 14) -#define I2C_CTRL1_NO_SLAVE_ACK_IRQ_EN (1 << 13) -#define I2C_CTRL1_OVERSIZE_XFER_TERM_IRQ_EN (1 << 12) -#define I2C_CTRL1_EARLY_TERM_IRQ_EN (1 << 11) -#define I2C_CTRL1_MASTER_LOSS_IRQ_EN (1 << 10) -#define I2C_CTRL1_SLAVE_STOP_IRQ_EN (1 << 9) -#define I2C_CTRL1_SLAVE_IRQ_EN (1 << 8) -#define I2C_CTRL1_BUS_FREE_IRQ (1 << 7) -#define I2C_CTRL1_DATA_ENGINE_CMPLT_IRQ (1 << 6) -#define I2C_CTRL1_NO_SLAVE_ACK_IRQ (1 << 5) -#define I2C_CTRL1_OVERSIZE_XFER_TERM_IRQ (1 << 4) -#define I2C_CTRL1_EARLY_TERM_IRQ (1 << 3) -#define I2C_CTRL1_MASTER_LOSS_IRQ (1 << 2) -#define I2C_CTRL1_SLAVE_STOP_IRQ (1 << 1) -#define I2C_CTRL1_SLAVE_IRQ (1 << 0) - -#define I2C_STAT_MASTER_PRESENT (1 << 31) -#define I2C_STAT_SLAVE_PRESENT (1 << 30) -#define I2C_STAT_ANY_ENABLED_IRQ (1 << 29) -#define I2C_STAT_GOT_A_NAK (1 << 28) -#define I2C_STAT_RCVD_SLAVE_ADDR_MASK (0xff << 16) -#define I2C_STAT_RCVD_SLAVE_ADDR_OFFSET 16 -#define I2C_STAT_SLAVE_ADDR_EQ_ZERO (1 << 15) -#define I2C_STAT_SLAVE_FOUND (1 << 14) -#define I2C_STAT_SLAVE_SEARCHING (1 << 13) -#define I2C_STAT_DATA_ENGING_DMA_WAIT (1 << 12) -#define I2C_STAT_BUS_BUSY (1 << 11) -#define I2C_STAT_CLK_GEN_BUSY (1 << 10) -#define I2C_STAT_DATA_ENGINE_BUSY (1 << 9) -#define I2C_STAT_SLAVE_BUSY (1 << 8) -#define I2C_STAT_BUS_FREE_IRQ_SUMMARY (1 << 7) -#define I2C_STAT_DATA_ENGINE_CMPLT_IRQ_SUMMARY (1 << 6) -#define I2C_STAT_NO_SLAVE_ACK_IRQ_SUMMARY (1 << 5) -#define I2C_STAT_OVERSIZE_XFER_TERM_IRQ_SUMMARY (1 << 4) -#define I2C_STAT_EARLY_TERM_IRQ_SUMMARY (1 << 3) -#define I2C_STAT_MASTER_LOSS_IRQ_SUMMARY (1 << 2) -#define I2C_STAT_SLAVE_STOP_IRQ_SUMMARY (1 << 1) -#define I2C_STAT_SLAVE_IRQ_SUMMARY (1 << 0) - -#define I2C_QUEUECTRL_RD_THRESH_MASK (0x1f << 16) -#define I2C_QUEUECTRL_RD_THRESH_OFFSET 16 -#define I2C_QUEUECTRL_WR_THRESH_MASK (0x1f << 8) -#define I2C_QUEUECTRL_WR_THRESH_OFFSET 8 -#define I2C_QUEUECTRL_QUEUE_RUN (1 << 5) -#define I2C_QUEUECTRL_RD_CLEAR (1 << 4) -#define I2C_QUEUECTRL_WR_CLEAR (1 << 3) -#define I2C_QUEUECTRL_PIO_QUEUE_MODE (1 << 2) -#define I2C_QUEUECTRL_RD_QUEUE_IRQ_EN (1 << 1) -#define I2C_QUEUECTRL_WR_QUEUE_IRQ_EN (1 << 0) - -#define I2C_QUEUESTAT_RD_QUEUE_FULL (1 << 14) -#define I2C_QUEUESTAT_RD_QUEUE_EMPTY (1 << 13) -#define I2C_QUEUESTAT_RD_QUEUE_CNT_MASK (0x1f << 8) -#define I2C_QUEUESTAT_RD_QUEUE_CNT_OFFSET 8 -#define I2C_QUEUESTAT_WR_QUEUE_FULL (1 << 6) -#define I2C_QUEUESTAT_WR_QUEUE_EMPTY (1 << 5) -#define I2C_QUEUESTAT_WR_QUEUE_CNT_MASK 0x1f -#define I2C_QUEUESTAT_WR_QUEUE_CNT_OFFSET 0 - -#define I2C_QUEUECMD_PREACK (1 << 27) -#define I2C_QUEUECMD_ACKNOWLEDGE (1 << 26) -#define I2C_QUEUECMD_SEND_NAK_ON_LAST (1 << 25) -#define I2C_QUEUECMD_MULTI_MASTER (1 << 23) -#define I2C_QUEUECMD_CLOCK_HELD (1 << 22) -#define I2C_QUEUECMD_RETAIN_CLOCK (1 << 21) -#define I2C_QUEUECMD_POST_SEND_STOP (1 << 20) -#define I2C_QUEUECMD_PRE_SEND_START (1 << 19) -#define I2C_QUEUECMD_SLAVE_ADDRESS_ENABLE (1 << 18) -#define I2C_QUEUECMD_MASTER_MODE (1 << 17) -#define I2C_QUEUECMD_DIRECTION (1 << 16) -#define I2C_QUEUECMD_XFER_COUNT_MASK 0xffff -#define I2C_QUEUECMD_XFER_COUNT_OFFSET 0 - -#define I2C_QUEUEDATA_DATA_MASK 0xffffffff -#define I2C_QUEUEDATA_DATA_OFFSET 0 - -#define I2C_DATA_DATA_MASK 0xffffffff -#define I2C_DATA_DATA_OFFSET 0 - -#define I2C_DEBUG0_DMAREQ (1 << 31) -#define I2C_DEBUG0_DMAENDCMD (1 << 30) -#define I2C_DEBUG0_DMAKICK (1 << 29) -#define I2C_DEBUG0_DMATERMINATE (1 << 28) -#define I2C_DEBUG0_STATE_VALUE_MASK (0x3 << 26) -#define I2C_DEBUG0_STATE_VALUE_OFFSET 26 -#define I2C_DEBUG0_DMA_STATE_MASK (0x3ff << 16) -#define I2C_DEBUG0_DMA_STATE_OFFSET 16 -#define I2C_DEBUG0_START_TOGGLE (1 << 15) -#define I2C_DEBUG0_STOP_TOGGLE (1 << 14) -#define I2C_DEBUG0_GRAB_TOGGLE (1 << 13) -#define I2C_DEBUG0_CHANGE_TOGGLE (1 << 12) -#define I2C_DEBUG0_STATE_LATCH (1 << 11) -#define I2C_DEBUG0_SLAVE_HOLD_CLK (1 << 10) -#define I2C_DEBUG0_STATE_STATE_MASK 0x3ff -#define I2C_DEBUG0_STATE_STATE_OFFSET 0 - -#define I2C_DEBUG1_I2C_CLK_IN (1 << 31) -#define I2C_DEBUG1_I2C_DATA_IN (1 << 30) -#define I2C_DEBUG1_DMA_BYTE_ENABLES_MASK (0xf << 24) -#define I2C_DEBUG1_DMA_BYTE_ENABLES_OFFSET 24 -#define I2C_DEBUG1_CLK_GEN_STATE_MASK (0xff << 16) -#define I2C_DEBUG1_CLK_GEN_STATE_OFFSET 16 -#define I2C_DEBUG1_LST_MODE_MASK (0x3 << 9) -#define I2C_DEBUG1_LST_MODE_OFFSET 9 -#define I2C_DEBUG1_LOCAL_SLAVE_TEST (1 << 8) -#define I2C_DEBUG1_FORCE_CLK_ON (1 << 4) -#define I2C_DEBUG1_FORCE_ABR_LOSS (1 << 3) -#define I2C_DEBUG1_FORCE_RCV_ACK (1 << 2) -#define I2C_DEBUG1_FORCE_I2C_DATA_OE (1 << 1) -#define I2C_DEBUG1_FORCE_I2C_CLK_OE (1 << 0) - -#define I2C_VERSION_MAJOR_MASK (0xff << 24) -#define I2C_VERSION_MAJOR_OFFSET 24 -#define I2C_VERSION_MINOR_MASK (0xff << 16) -#define I2C_VERSION_MINOR_OFFSET 16 -#define I2C_VERSION_STEP_MASK 0xffff -#define I2C_VERSION_STEP_OFFSET 0 - -#endif /* __MX28_REGS_I2C_H__ */ diff --git a/arch/arm/include/asm/arch-mx28/regs-ocotp.h b/arch/arm/include/asm/arch-mx28/regs-ocotp.h deleted file mode 100644 index 2738035..0000000 --- a/arch/arm/include/asm/arch-mx28/regs-ocotp.h +++ /dev/null @@ -1,173 +0,0 @@ -/* - * Freescale i.MX28 OCOTP Register Definitions - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * on behalf of DENX Software Engineering GmbH - * - * Based on code from LTIB: - * Copyright 2008-2010 Freescale Semiconductor, Inc. All Rights Reserved. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA - * - */ - -#ifndef __MX28_REGS_OCOTP_H__ -#define __MX28_REGS_OCOTP_H__ - -#include <asm/arch/regs-common.h> - -#ifndef __ASSEMBLY__ -struct mx28_ocotp_regs { - mx28_reg_32(hw_ocotp_ctrl) /* 0x0 */ - mx28_reg_32(hw_ocotp_data) /* 0x10 */ - mx28_reg_32(hw_ocotp_cust0) /* 0x20 */ - mx28_reg_32(hw_ocotp_cust1) /* 0x30 */ - mx28_reg_32(hw_ocotp_cust2) /* 0x40 */ - mx28_reg_32(hw_ocotp_cust3) /* 0x50 */ - mx28_reg_32(hw_ocotp_crypto0) /* 0x60 */ - mx28_reg_32(hw_ocotp_crypto1) /* 0x70 */ - mx28_reg_32(hw_ocotp_crypto2) /* 0x80 */ - mx28_reg_32(hw_ocotp_crypto3) /* 0x90 */ - mx28_reg_32(hw_ocotp_hwcap0) /* 0xa0 */ - mx28_reg_32(hw_ocotp_hwcap1) /* 0xb0 */ - mx28_reg_32(hw_ocotp_hwcap2) /* 0xc0 */ - mx28_reg_32(hw_ocotp_hwcap3) /* 0xd0 */ - mx28_reg_32(hw_ocotp_hwcap4) /* 0xe0 */ - mx28_reg_32(hw_ocotp_hwcap5) /* 0xf0 */ - mx28_reg_32(hw_ocotp_swcap) /* 0x100 */ - mx28_reg_32(hw_ocotp_custcap) /* 0x110 */ - mx28_reg_32(hw_ocotp_lock) /* 0x120 */ - mx28_reg_32(hw_ocotp_ops0) /* 0x130 */ - mx28_reg_32(hw_ocotp_ops1) /* 0x140 */ - mx28_reg_32(hw_ocotp_ops2) /* 0x150 */ - mx28_reg_32(hw_ocotp_ops3) /* 0x160 */ - mx28_reg_32(hw_ocotp_un0) /* 0x170 */ - mx28_reg_32(hw_ocotp_un1) /* 0x180 */ - mx28_reg_32(hw_ocotp_un2) /* 0x190 */ - mx28_reg_32(hw_ocotp_rom0) /* 0x1a0 */ - mx28_reg_32(hw_ocotp_rom1) /* 0x1b0 */ - mx28_reg_32(hw_ocotp_rom2) /* 0x1c0 */ - mx28_reg_32(hw_ocotp_rom3) /* 0x1d0 */ - mx28_reg_32(hw_ocotp_rom4) /* 0x1e0 */ - mx28_reg_32(hw_ocotp_rom5) /* 0x1f0 */ - mx28_reg_32(hw_ocotp_rom6) /* 0x200 */ - mx28_reg_32(hw_ocotp_rom7) /* 0x210 */ - mx28_reg_32(hw_ocotp_srk0) /* 0x220 */ - mx28_reg_32(hw_ocotp_srk1) /* 0x230 */ - mx28_reg_32(hw_ocotp_srk2) /* 0x240 */ - mx28_reg_32(hw_ocotp_srk3) /* 0x250 */ - mx28_reg_32(hw_ocotp_srk4) /* 0x260 */ - mx28_reg_32(hw_ocotp_srk5) /* 0x270 */ - mx28_reg_32(hw_ocotp_srk6) /* 0x280 */ - mx28_reg_32(hw_ocotp_srk7) /* 0x290 */ - mx28_reg_32(hw_ocotp_version) /* 0x2a0 */ -}; -#endif - -#define OCOTP_CTRL_WR_UNLOCK_MASK (0xffff << 16) -#define OCOTP_CTRL_WR_UNLOCK_OFFSET 16 -#define OCOTP_CTRL_WR_UNLOCK_KEY (0x3e77 << 16) -#define OCOTP_CTRL_RELOAD_SHADOWS (1 << 13) -#define OCOTP_CTRL_RD_BANK_OPEN (1 << 12) -#define OCOTP_CTRL_ERROR (1 << 9) -#define OCOTP_CTRL_BUSY (1 << 8) -#define OCOTP_CTRL_ADDR_MASK 0x3f -#define OCOTP_CTRL_ADDR_OFFSET 0 - -#define OCOTP_DATA_DATA_MASK 0xffffffff -#define OCOTP_DATA_DATA_OFFSET 0 - -#define OCOTP_CUST_BITS_MASK 0xffffffff -#define OCOTP_CUST_BITS_OFFSET 0 - -#define OCOTP_CRYPTO_BITS_MASK 0xffffffff -#define OCOTP_CRYPTO_BITS_OFFSET 0 - -#define OCOTP_HWCAP_BITS_MASK 0xffffffff -#define OCOTP_HWCAP_BITS_OFFSET 0 - -#define OCOTP_SWCAP_BITS_MASK 0xffffffff -#define OCOTP_SWCAP_BITS_OFFSET 0 - -#define OCOTP_CUSTCAP_RTC_XTAL_32768_PRESENT (1 << 2) -#define OCOTP_CUSTCAP_RTC_XTAL_32000_PRESENT (1 << 1) - -#define OCOTP_LOCK_ROM7 (1 << 31) -#define OCOTP_LOCK_ROM6 (1 << 30) -#define OCOTP_LOCK_ROM5 (1 << 29) -#define OCOTP_LOCK_ROM4 (1 << 28) -#define OCOTP_LOCK_ROM3 (1 << 27) -#define OCOTP_LOCK_ROM2 (1 << 26) -#define OCOTP_LOCK_ROM1 (1 << 25) -#define OCOTP_LOCK_ROM0 (1 << 24) -#define OCOTP_LOCK_HWSW_SHADOW_ALT (1 << 23) -#define OCOTP_LOCK_CRYPTODCP_ALT (1 << 22) -#define OCOTP_LOCK_CRYPTOKEY_ALT (1 << 21) -#define OCOTP_LOCK_PIN (1 << 20) -#define OCOTP_LOCK_OPS (1 << 19) -#define OCOTP_LOCK_UN2 (1 << 18) -#define OCOTP_LOCK_UN1 (1 << 17) -#define OCOTP_LOCK_UN0 (1 << 16) -#define OCOTP_LOCK_SRK (1 << 15) -#define OCOTP_LOCK_UNALLOCATED_MASK (0x7 << 12) -#define OCOTP_LOCK_UNALLOCATED_OFFSET 12 -#define OCOTP_LOCK_SRK_SHADOW (1 << 11) -#define OCOTP_LOCK_ROM_SHADOW (1 << 10) -#define OCOTP_LOCK_CUSTCAP (1 << 9) -#define OCOTP_LOCK_HWSW (1 << 8) -#define OCOTP_LOCK_CUSTCAP_SHADOW (1 << 7) -#define OCOTP_LOCK_HWSW_SHADOW (1 << 6) -#define OCOTP_LOCK_CRYPTODCP (1 << 5) -#define OCOTP_LOCK_CRYPTOKEY (1 << 4) -#define OCOTP_LOCK_CUST3 (1 << 3) -#define OCOTP_LOCK_CUST2 (1 << 2) -#define OCOTP_LOCK_CUST1 (1 << 1) -#define OCOTP_LOCK_CUST0 (1 << 0) - -#define OCOTP_OPS_BITS_MASK 0xffffffff -#define OCOTP_OPS_BITS_OFFSET 0 - -#define OCOTP_UN_BITS_MASK 0xffffffff -#define OCOTP_UN_BITS_OFFSET 0 - -#define OCOTP_ROM_BOOT_MODE_MASK (0xff << 24) -#define OCOTP_ROM_BOOT_MODE_OFFSET 24 -#define OCOTP_ROM_SD_MMC_MODE_MASK (0x3 << 22) -#define OCOTP_ROM_SD_MMC_MODE_OFFSET 22 -#define OCOTP_ROM_SD_POWER_GATE_GPIO_MASK (0x3 << 20) -#define OCOTP_ROM_SD_POWER_GATE_GPIO_OFFSET 20 -#define OCOTP_ROM_SD_POWER_UP_DELAY_MASK (0x3f << 14) -#define OCOTP_ROM_SD_POWER_UP_DELAY_OFFSET 14 -#define OCOTP_ROM_SD_BUS_WIDTH_MASK (0x3 << 12) -#define OCOTP_ROM_SD_BUS_WIDTH_OFFSET 12 -#define OCOTP_ROM_SSP_SCK_INDEX_MASK (0xf << 8) -#define OCOTP_ROM_SSP_SCK_INDEX_OFFSET 8 -#define OCOTP_ROM_EMMC_USE_DDR (1 << 7) -#define OCOTP_ROM_DISABLE_SPI_NOR_FAST_READ (1 << 6) -#define OCOTP_ROM_ENABLE_USB_BOOT_SERIAL_NUM (1 << 5) -#define OCOTP_ROM_ENABLE_UNENCRYPTED_BOOT (1 << 4) -#define OCOTP_ROM_SD_MBR_BOOT (1 << 3) - -#define OCOTP_SRK_BITS_MASK 0xffffffff -#define OCOTP_SRK_BITS_OFFSET 0 - -#define OCOTP_VERSION_MAJOR_MASK (0xff << 24) -#define OCOTP_VERSION_MAJOR_OFFSET 24 -#define OCOTP_VERSION_MINOR_MASK (0xff << 16) -#define OCOTP_VERSION_MINOR_OFFSET 16 -#define OCOTP_VERSION_STEP_MASK 0xffff -#define OCOTP_VERSION_STEP_OFFSET 0 - -#endif /* __MX28_REGS_OCOTP_H__ */ diff --git a/arch/arm/include/asm/arch-mx28/regs-pinctrl.h b/arch/arm/include/asm/arch-mx28/regs-pinctrl.h deleted file mode 100644 index 80dcdf6..0000000 --- a/arch/arm/include/asm/arch-mx28/regs-pinctrl.h +++ /dev/null @@ -1,1284 +0,0 @@ -/* - * Freescale i.MX28 PINCTRL Register Definitions - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * on behalf of DENX Software Engineering GmbH - * - * Based on code from LTIB: - * Copyright 2008-2010 Freescale Semiconductor, Inc. All Rights Reserved. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA - * - */ - -#ifndef __MX28_REGS_PINCTRL_H__ -#define __MX28_REGS_PINCTRL_H__ - -#include <asm/arch/regs-common.h> - -#ifndef __ASSEMBLY__ -struct mx28_pinctrl_regs { - mx28_reg_32(hw_pinctrl_ctrl) /* 0x0 */ - - uint32_t reserved1[60]; - - mx28_reg_32(hw_pinctrl_muxsel0) /* 0x100 */ - mx28_reg_32(hw_pinctrl_muxsel1) /* 0x110 */ - mx28_reg_32(hw_pinctrl_muxsel2) /* 0x120 */ - mx28_reg_32(hw_pinctrl_muxsel3) /* 0x130 */ - mx28_reg_32(hw_pinctrl_muxsel4) /* 0x140 */ - mx28_reg_32(hw_pinctrl_muxsel5) /* 0x150 */ - mx28_reg_32(hw_pinctrl_muxsel6) /* 0x160 */ - mx28_reg_32(hw_pinctrl_muxsel7) /* 0x170 */ - mx28_reg_32(hw_pinctrl_muxsel8) /* 0x180 */ - mx28_reg_32(hw_pinctrl_muxsel9) /* 0x190 */ - mx28_reg_32(hw_pinctrl_muxsel10) /* 0x1a0 */ - mx28_reg_32(hw_pinctrl_muxsel11) /* 0x1b0 */ - mx28_reg_32(hw_pinctrl_muxsel12) /* 0x1c0 */ - mx28_reg_32(hw_pinctrl_muxsel13) /* 0x1d0 */ - - uint32_t reserved2[72]; - - mx28_reg_32(hw_pinctrl_drive0) /* 0x300 */ - mx28_reg_32(hw_pinctrl_drive1) /* 0x310 */ - mx28_reg_32(hw_pinctrl_drive2) /* 0x320 */ - mx28_reg_32(hw_pinctrl_drive3) /* 0x330 */ - mx28_reg_32(hw_pinctrl_drive4) /* 0x340 */ - mx28_reg_32(hw_pinctrl_drive5) /* 0x350 */ - mx28_reg_32(hw_pinctrl_drive6) /* 0x360 */ - mx28_reg_32(hw_pinctrl_drive7) /* 0x370 */ - mx28_reg_32(hw_pinctrl_drive8) /* 0x380 */ - mx28_reg_32(hw_pinctrl_drive9) /* 0x390 */ - mx28_reg_32(hw_pinctrl_drive10) /* 0x3a0 */ - mx28_reg_32(hw_pinctrl_drive11) /* 0x3b0 */ - mx28_reg_32(hw_pinctrl_drive12) /* 0x3c0 */ - mx28_reg_32(hw_pinctrl_drive13) /* 0x3d0 */ - mx28_reg_32(hw_pinctrl_drive14) /* 0x3e0 */ - mx28_reg_32(hw_pinctrl_drive15) /* 0x3f0 */ - mx28_reg_32(hw_pinctrl_drive16) /* 0x400 */ - mx28_reg_32(hw_pinctrl_drive17) /* 0x410 */ - mx28_reg_32(hw_pinctrl_drive18) /* 0x420 */ - mx28_reg_32(hw_pinctrl_drive19) /* 0x430 */ - - uint32_t reserved3[112]; - - mx28_reg_32(hw_pinctrl_pull0) /* 0x600 */ - mx28_reg_32(hw_pinctrl_pull1) /* 0x610 */ - mx28_reg_32(hw_pinctrl_pull2) /* 0x620 */ - mx28_reg_32(hw_pinctrl_pull3) /* 0x630 */ - mx28_reg_32(hw_pinctrl_pull4) /* 0x640 */ - mx28_reg_32(hw_pinctrl_pull5) /* 0x650 */ - mx28_reg_32(hw_pinctrl_pull6) /* 0x660 */ - - uint32_t reserved4[36]; - - mx28_reg_32(hw_pinctrl_dout0) /* 0x700 */ - mx28_reg_32(hw_pinctrl_dout1) /* 0x710 */ - mx28_reg_32(hw_pinctrl_dout2) /* 0x720 */ - mx28_reg_32(hw_pinctrl_dout3) /* 0x730 */ - mx28_reg_32(hw_pinctrl_dout4) /* 0x740 */ - - uint32_t reserved5[108]; - - mx28_reg_32(hw_pinctrl_din0) /* 0x900 */ - mx28_reg_32(hw_pinctrl_din1) /* 0x910 */ - mx28_reg_32(hw_pinctrl_din2) /* 0x920 */ - mx28_reg_32(hw_pinctrl_din3) /* 0x930 */ - mx28_reg_32(hw_pinctrl_din4) /* 0x940 */ - - uint32_t reserved6[108]; - - mx28_reg_32(hw_pinctrl_doe0) /* 0xb00 */ - mx28_reg_32(hw_pinctrl_doe1) /* 0xb10 */ - mx28_reg_32(hw_pinctrl_doe2) /* 0xb20 */ - mx28_reg_32(hw_pinctrl_doe3) /* 0xb30 */ - mx28_reg_32(hw_pinctrl_doe4) /* 0xb40 */ - - uint32_t reserved7[300]; - - mx28_reg_32(hw_pinctrl_pin2irq0) /* 0x1000 */ - mx28_reg_32(hw_pinctrl_pin2irq1) /* 0x1010 */ - mx28_reg_32(hw_pinctrl_pin2irq2) /* 0x1020 */ - mx28_reg_32(hw_pinctrl_pin2irq3) /* 0x1030 */ - mx28_reg_32(hw_pinctrl_pin2irq4) /* 0x1040 */ - - uint32_t reserved8[44]; - - mx28_reg_32(hw_pinctrl_irqen0) /* 0x1100 */ - mx28_reg_32(hw_pinctrl_irqen1) /* 0x1110 */ - mx28_reg_32(hw_pinctrl_irqen2) /* 0x1120 */ - mx28_reg_32(hw_pinctrl_irqen3) /* 0x1130 */ - mx28_reg_32(hw_pinctrl_irqen4) /* 0x1140 */ - - uint32_t reserved9[44]; - - mx28_reg_32(hw_pinctrl_irqlevel0) /* 0x1200 */ - mx28_reg_32(hw_pinctrl_irqlevel1) /* 0x1210 */ - mx28_reg_32(hw_pinctrl_irqlevel2) /* 0x1220 */ - mx28_reg_32(hw_pinctrl_irqlevel3) /* 0x1230 */ - mx28_reg_32(hw_pinctrl_irqlevel4) /* 0x1240 */ - - uint32_t reserved10[44]; - - mx28_reg_32(hw_pinctrl_irqpol0) /* 0x1300 */ - mx28_reg_32(hw_pinctrl_irqpol1) /* 0x1310 */ - mx28_reg_32(hw_pinctrl_irqpol2) /* 0x1320 */ - mx28_reg_32(hw_pinctrl_irqpol3) /* 0x1330 */ - mx28_reg_32(hw_pinctrl_irqpol4) /* 0x1340 */ - - uint32_t reserved11[44]; - - mx28_reg_32(hw_pinctrl_irqstat0) /* 0x1400 */ - mx28_reg_32(hw_pinctrl_irqstat1) /* 0x1410 */ - mx28_reg_32(hw_pinctrl_irqstat2) /* 0x1420 */ - mx28_reg_32(hw_pinctrl_irqstat3) /* 0x1430 */ - mx28_reg_32(hw_pinctrl_irqstat4) /* 0x1440 */ - - uint32_t reserved12[380]; - - mx28_reg_32(hw_pinctrl_emi_odt_ctrl) /* 0x1a40 */ - - uint32_t reserved13[76]; - - mx28_reg_32(hw_pinctrl_emi_ds_ctrl) /* 0x1b80 */ -}; -#endif - -#define PINCTRL_CTRL_SFTRST (1 << 31) -#define PINCTRL_CTRL_CLKGATE (1 << 30) -#define PINCTRL_CTRL_PRESENT4 (1 << 24) -#define PINCTRL_CTRL_PRESENT3 (1 << 23) -#define PINCTRL_CTRL_PRESENT2 (1 << 22) -#define PINCTRL_CTRL_PRESENT1 (1 << 21) -#define PINCTRL_CTRL_PRESENT0 (1 << 20) -#define PINCTRL_CTRL_IRQOUT4 (1 << 4) -#define PINCTRL_CTRL_IRQOUT3 (1 << 3) -#define PINCTRL_CTRL_IRQOUT2 (1 << 2) -#define PINCTRL_CTRL_IRQOUT1 (1 << 1) -#define PINCTRL_CTRL_IRQOUT0 (1 << 0) - -#define PINCTRL_MUXSEL0_BANK0_PIN07_MASK (0x3 << 14) -#define PINCTRL_MUXSEL0_BANK0_PIN07_OFFSET 14 -#define PINCTRL_MUXSEL0_BANK0_PIN06_MASK (0x3 << 12) -#define PINCTRL_MUXSEL0_BANK0_PIN06_OFFSET 12 -#define PINCTRL_MUXSEL0_BANK0_PIN05_MASK (0x3 << 10) -#define PINCTRL_MUXSEL0_BANK0_PIN05_OFFSET 10 -#define PINCTRL_MUXSEL0_BANK0_PIN04_MASK (0x3 << 8) -#define PINCTRL_MUXSEL0_BANK0_PIN04_OFFSET 8 -#define PINCTRL_MUXSEL0_BANK0_PIN03_MASK (0x3 << 6) -#define PINCTRL_MUXSEL0_BANK0_PIN03_OFFSET 6 -#define PINCTRL_MUXSEL0_BANK0_PIN02_MASK (0x3 << 4) -#define PINCTRL_MUXSEL0_BANK0_PIN02_OFFSET 4 -#define PINCTRL_MUXSEL0_BANK0_PIN01_MASK (0x3 << 2) -#define PINCTRL_MUXSEL0_BANK0_PIN01_OFFSET 2 -#define PINCTRL_MUXSEL0_BANK0_PIN00_MASK (0x3 << 0) -#define PINCTRL_MUXSEL0_BANK0_PIN00_OFFSET 0 - -#define PINCTRL_MUXSEL1_BANK0_PIN28_MASK (0x3 << 24) -#define PINCTRL_MUXSEL1_BANK0_PIN28_OFFSET 24 -#define PINCTRL_MUXSEL1_BANK0_PIN27_MASK (0x3 << 22) -#define PINCTRL_MUXSEL1_BANK0_PIN27_OFFSET 22 -#define PINCTRL_MUXSEL1_BANK0_PIN26_MASK (0x3 << 20) -#define PINCTRL_MUXSEL1_BANK0_PIN26_OFFSET 20 -#define PINCTRL_MUXSEL1_BANK0_PIN25_MASK (0x3 << 18) -#define PINCTRL_MUXSEL1_BANK0_PIN25_OFFSET 18 -#define PINCTRL_MUXSEL1_BANK0_PIN24_MASK (0x3 << 16) -#define PINCTRL_MUXSEL1_BANK0_PIN24_OFFSET 16 -#define PINCTRL_MUXSEL1_BANK0_PIN23_MASK (0x3 << 14) -#define PINCTRL_MUXSEL1_BANK0_PIN23_OFFSET 14 -#define PINCTRL_MUXSEL1_BANK0_PIN22_MASK (0x3 << 12) -#define PINCTRL_MUXSEL1_BANK0_PIN22_OFFSET 12 -#define PINCTRL_MUXSEL1_BANK0_PIN21_MASK (0x3 << 10) -#define PINCTRL_MUXSEL1_BANK0_PIN21_OFFSET 10 -#define PINCTRL_MUXSEL1_BANK0_PIN20_MASK (0x3 << 8) -#define PINCTRL_MUXSEL1_BANK0_PIN20_OFFSET 8 -#define PINCTRL_MUXSEL1_BANK0_PIN19_MASK (0x3 << 6) -#define PINCTRL_MUXSEL1_BANK0_PIN19_OFFSET 6 -#define PINCTRL_MUXSEL1_BANK0_PIN18_MASK (0x3 << 4) -#define PINCTRL_MUXSEL1_BANK0_PIN18_OFFSET 4 -#define PINCTRL_MUXSEL1_BANK0_PIN17_MASK (0x3 << 2) -#define PINCTRL_MUXSEL1_BANK0_PIN17_OFFSET 2 -#define PINCTRL_MUXSEL1_BANK0_PIN16_MASK (0x3 << 0) -#define PINCTRL_MUXSEL1_BANK0_PIN16_OFFSET 0 - -#define PINCTRL_MUXSEL2_BANK1_PIN15_MASK (0x3 << 30) -#define PINCTRL_MUXSEL2_BANK1_PIN15_OFFSET 30 -#define PINCTRL_MUXSEL2_BANK1_PIN14_MASK (0x3 << 28) -#define PINCTRL_MUXSEL2_BANK1_PIN14_OFFSET 28 -#define PINCTRL_MUXSEL2_BANK1_PIN13_MASK (0x3 << 26) -#define PINCTRL_MUXSEL2_BANK1_PIN13_OFFSET 26 -#define PINCTRL_MUXSEL2_BANK1_PIN12_MASK (0x3 << 24) -#define PINCTRL_MUXSEL2_BANK1_PIN12_OFFSET 24 -#define PINCTRL_MUXSEL2_BANK1_PIN11_MASK (0x3 << 22) -#define PINCTRL_MUXSEL2_BANK1_PIN11_OFFSET 22 -#define PINCTRL_MUXSEL2_BANK1_PIN10_MASK (0x3 << 20) -#define PINCTRL_MUXSEL2_BANK1_PIN10_OFFSET 20 -#define PINCTRL_MUXSEL2_BANK1_PIN09_MASK (0x3 << 18) -#define PINCTRL_MUXSEL2_BANK1_PIN09_OFFSET 18 -#define PINCTRL_MUXSEL2_BANK1_PIN08_MASK (0x3 << 16) -#define PINCTRL_MUXSEL2_BANK1_PIN08_OFFSET 16 -#define PINCTRL_MUXSEL2_BANK1_PIN07_MASK (0x3 << 14) -#define PINCTRL_MUXSEL2_BANK1_PIN07_OFFSET 14 -#define PINCTRL_MUXSEL2_BANK1_PIN06_MASK (0x3 << 12) -#define PINCTRL_MUXSEL2_BANK1_PIN06_OFFSET 12 -#define PINCTRL_MUXSEL2_BANK1_PIN05_MASK (0x3 << 10) -#define PINCTRL_MUXSEL2_BANK1_PIN05_OFFSET 10 -#define PINCTRL_MUXSEL2_BANK1_PIN04_MASK (0x3 << 8) -#define PINCTRL_MUXSEL2_BANK1_PIN04_OFFSET 8 -#define PINCTRL_MUXSEL2_BANK1_PIN03_MASK (0x3 << 6) -#define PINCTRL_MUXSEL2_BANK1_PIN03_OFFSET 6 -#define PINCTRL_MUXSEL2_BANK1_PIN02_MASK (0x3 << 4) -#define PINCTRL_MUXSEL2_BANK1_PIN02_OFFSET 4 -#define PINCTRL_MUXSEL2_BANK1_PIN01_MASK (0x3 << 2) -#define PINCTRL_MUXSEL2_BANK1_PIN01_OFFSET 2 -#define PINCTRL_MUXSEL2_BANK1_PIN00_MASK (0x3 << 0) -#define PINCTRL_MUXSEL2_BANK1_PIN00_OFFSET 0 - -#define PINCTRL_MUXSEL3_BANK1_PIN31_MASK (0x3 << 30) -#define PINCTRL_MUXSEL3_BANK1_PIN31_OFFSET 30 -#define PINCTRL_MUXSEL3_BANK1_PIN30_MASK (0x3 << 28) -#define PINCTRL_MUXSEL3_BANK1_PIN30_OFFSET 28 -#define PINCTRL_MUXSEL3_BANK1_PIN29_MASK (0x3 << 26) -#define PINCTRL_MUXSEL3_BANK1_PIN29_OFFSET 26 -#define PINCTRL_MUXSEL3_BANK1_PIN28_MASK (0x3 << 24) -#define PINCTRL_MUXSEL3_BANK1_PIN28_OFFSET 24 -#define PINCTRL_MUXSEL3_BANK1_PIN27_MASK (0x3 << 22) -#define PINCTRL_MUXSEL3_BANK1_PIN27_OFFSET 22 -#define PINCTRL_MUXSEL3_BANK1_PIN26_MASK (0x3 << 20) -#define PINCTRL_MUXSEL3_BANK1_PIN26_OFFSET 20 -#define PINCTRL_MUXSEL3_BANK1_PIN25_MASK (0x3 << 18) -#define PINCTRL_MUXSEL3_BANK1_PIN25_OFFSET 18 -#define PINCTRL_MUXSEL3_BANK1_PIN24_MASK (0x3 << 16) -#define PINCTRL_MUXSEL3_BANK1_PIN24_OFFSET 16 -#define PINCTRL_MUXSEL3_BANK1_PIN23_MASK (0x3 << 14) -#define PINCTRL_MUXSEL3_BANK1_PIN23_OFFSET 14 -#define PINCTRL_MUXSEL3_BANK1_PIN22_MASK (0x3 << 12) -#define PINCTRL_MUXSEL3_BANK1_PIN22_OFFSET 12 -#define PINCTRL_MUXSEL3_BANK1_PIN21_MASK (0x3 << 10) -#define PINCTRL_MUXSEL3_BANK1_PIN21_OFFSET 10 -#define PINCTRL_MUXSEL3_BANK1_PIN20_MASK (0x3 << 8) -#define PINCTRL_MUXSEL3_BANK1_PIN20_OFFSET 8 -#define PINCTRL_MUXSEL3_BANK1_PIN19_MASK (0x3 << 6) -#define PINCTRL_MUXSEL3_BANK1_PIN19_OFFSET 6 -#define PINCTRL_MUXSEL3_BANK1_PIN18_MASK (0x3 << 4) -#define PINCTRL_MUXSEL3_BANK1_PIN18_OFFSET 4 -#define PINCTRL_MUXSEL3_BANK1_PIN17_MASK (0x3 << 2) -#define PINCTRL_MUXSEL3_BANK1_PIN17_OFFSET 2 -#define PINCTRL_MUXSEL3_BANK1_PIN16_MASK (0x3 << 0) -#define PINCTRL_MUXSEL3_BANK1_PIN16_OFFSET 0 - -#define PINCTRL_MUXSEL4_BANK2_PIN15_MASK (0x3 << 30) -#define PINCTRL_MUXSEL4_BANK2_PIN15_OFFSET 30 -#define PINCTRL_MUXSEL4_BANK2_PIN14_MASK (0x3 << 28) -#define PINCTRL_MUXSEL4_BANK2_PIN14_OFFSET 28 -#define PINCTRL_MUXSEL4_BANK2_PIN13_MASK (0x3 << 26) -#define PINCTRL_MUXSEL4_BANK2_PIN13_OFFSET 26 -#define PINCTRL_MUXSEL4_BANK2_PIN12_MASK (0x3 << 24) -#define PINCTRL_MUXSEL4_BANK2_PIN12_OFFSET 24 -#define PINCTRL_MUXSEL4_BANK2_PIN10_MASK (0x3 << 20) -#define PINCTRL_MUXSEL4_BANK2_PIN10_OFFSET 20 -#define PINCTRL_MUXSEL4_BANK2_PIN09_MASK (0x3 << 18) -#define PINCTRL_MUXSEL4_BANK2_PIN09_OFFSET 18 -#define PINCTRL_MUXSEL4_BANK2_PIN08_MASK (0x3 << 16) -#define PINCTRL_MUXSEL4_BANK2_PIN08_OFFSET 16 -#define PINCTRL_MUXSEL4_BANK2_PIN07_MASK (0x3 << 14) -#define PINCTRL_MUXSEL4_BANK2_PIN07_OFFSET 14 -#define PINCTRL_MUXSEL4_BANK2_PIN06_MASK (0x3 << 12) -#define PINCTRL_MUXSEL4_BANK2_PIN06_OFFSET 12 -#define PINCTRL_MUXSEL4_BANK2_PIN05_MASK (0x3 << 10) -#define PINCTRL_MUXSEL4_BANK2_PIN05_OFFSET 10 -#define PINCTRL_MUXSEL4_BANK2_PIN04_MASK (0x3 << 8) -#define PINCTRL_MUXSEL4_BANK2_PIN04_OFFSET 8 -#define PINCTRL_MUXSEL4_BANK2_PIN03_MASK (0x3 << 6) -#define PINCTRL_MUXSEL4_BANK2_PIN03_OFFSET 6 -#define PINCTRL_MUXSEL4_BANK2_PIN02_MASK (0x3 << 4) -#define PINCTRL_MUXSEL4_BANK2_PIN02_OFFSET 4 -#define PINCTRL_MUXSEL4_BANK2_PIN01_MASK (0x3 << 2) -#define PINCTRL_MUXSEL4_BANK2_PIN01_OFFSET 2 -#define PINCTRL_MUXSEL4_BANK2_PIN00_MASK (0x3 << 0) -#define PINCTRL_MUXSEL4_BANK2_PIN00_OFFSET 0 - -#define PINCTRL_MUXSEL5_BANK2_PIN27_MASK (0x3 << 22) -#define PINCTRL_MUXSEL5_BANK2_PIN27_OFFSET 22 -#define PINCTRL_MUXSEL5_BANK2_PIN26_MASK (0x3 << 20) -#define PINCTRL_MUXSEL5_BANK2_PIN26_OFFSET 20 -#define PINCTRL_MUXSEL5_BANK2_PIN25_MASK (0x3 << 18) -#define PINCTRL_MUXSEL5_BANK2_PIN25_OFFSET 18 -#define PINCTRL_MUXSEL5_BANK2_PIN24_MASK (0x3 << 16) -#define PINCTRL_MUXSEL5_BANK2_PIN24_OFFSET 16 -#define PINCTRL_MUXSEL5_BANK2_PIN21_MASK (0x3 << 10) -#define PINCTRL_MUXSEL5_BANK2_PIN21_OFFSET 10 -#define PINCTRL_MUXSEL5_BANK2_PIN20_MASK (0x3 << 8) -#define PINCTRL_MUXSEL5_BANK2_PIN20_OFFSET 8 -#define PINCTRL_MUXSEL5_BANK2_PIN19_MASK (0x3 << 6) -#define PINCTRL_MUXSEL5_BANK2_PIN19_OFFSET 6 -#define PINCTRL_MUXSEL5_BANK2_PIN18_MASK (0x3 << 4) -#define PINCTRL_MUXSEL5_BANK2_PIN18_OFFSET 4 -#define PINCTRL_MUXSEL5_BANK2_PIN17_MASK (0x3 << 2) -#define PINCTRL_MUXSEL5_BANK2_PIN17_OFFSET 2 -#define PINCTRL_MUXSEL5_BANK2_PIN16_MASK (0x3 << 0) -#define PINCTRL_MUXSEL5_BANK2_PIN16_OFFSET 0 - -#define PINCTRL_MUXSEL6_BANK3_PIN15_MASK (0x3 << 30) -#define PINCTRL_MUXSEL6_BANK3_PIN15_OFFSET 30 -#define PINCTRL_MUXSEL6_BANK3_PIN14_MASK (0x3 << 28) -#define PINCTRL_MUXSEL6_BANK3_PIN14_OFFSET 28 -#define PINCTRL_MUXSEL6_BANK3_PIN13_MASK (0x3 << 26) -#define PINCTRL_MUXSEL6_BANK3_PIN13_OFFSET 26 -#define PINCTRL_MUXSEL6_BANK3_PIN12_MASK (0x3 << 24) -#define PINCTRL_MUXSEL6_BANK3_PIN12_OFFSET 24 -#define PINCTRL_MUXSEL6_BANK3_PIN11_MASK (0x3 << 22) -#define PINCTRL_MUXSEL6_BANK3_PIN11_OFFSET 22 -#define PINCTRL_MUXSEL6_BANK3_PIN10_MASK (0x3 << 20) -#define PINCTRL_MUXSEL6_BANK3_PIN10_OFFSET 20 -#define PINCTRL_MUXSEL6_BANK3_PIN09_MASK (0x3 << 18) -#define PINCTRL_MUXSEL6_BANK3_PIN09_OFFSET 18 -#define PINCTRL_MUXSEL6_BANK3_PIN08_MASK (0x3 << 16) -#define PINCTRL_MUXSEL6_BANK3_PIN08_OFFSET 16 -#define PINCTRL_MUXSEL6_BANK3_PIN07_MASK (0x3 << 14) -#define PINCTRL_MUXSEL6_BANK3_PIN07_OFFSET 14 -#define PINCTRL_MUXSEL6_BANK3_PIN06_MASK (0x3 << 12) -#define PINCTRL_MUXSEL6_BANK3_PIN06_OFFSET 12 -#define PINCTRL_MUXSEL6_BANK3_PIN05_MASK (0x3 << 10) -#define PINCTRL_MUXSEL6_BANK3_PIN05_OFFSET 10 -#define PINCTRL_MUXSEL6_BANK3_PIN04_MASK (0x3 << 8) -#define PINCTRL_MUXSEL6_BANK3_PIN04_OFFSET 8 -#define PINCTRL_MUXSEL6_BANK3_PIN03_MASK (0x3 << 6) -#define PINCTRL_MUXSEL6_BANK3_PIN03_OFFSET 6 -#define PINCTRL_MUXSEL6_BANK3_PIN02_MASK (0x3 << 4) -#define PINCTRL_MUXSEL6_BANK3_PIN02_OFFSET 4 -#define PINCTRL_MUXSEL6_BANK3_PIN01_MASK (0x3 << 2) -#define PINCTRL_MUXSEL6_BANK3_PIN01_OFFSET 2 -#define PINCTRL_MUXSEL6_BANK3_PIN00_MASK (0x3 << 0) -#define PINCTRL_MUXSEL6_BANK3_PIN00_OFFSET 0 - -#define PINCTRL_MUXSEL7_BANK3_PIN30_MASK (0x3 << 28) -#define PINCTRL_MUXSEL7_BANK3_PIN30_OFFSET 28 -#define PINCTRL_MUXSEL7_BANK3_PIN29_MASK (0x3 << 26) -#define PINCTRL_MUXSEL7_BANK3_PIN29_OFFSET 26 -#define PINCTRL_MUXSEL7_BANK3_PIN28_MASK (0x3 << 24) -#define PINCTRL_MUXSEL7_BANK3_PIN28_OFFSET 24 -#define PINCTRL_MUXSEL7_BANK3_PIN27_MASK (0x3 << 22) -#define PINCTRL_MUXSEL7_BANK3_PIN27_OFFSET 22 -#define PINCTRL_MUXSEL7_BANK3_PIN26_MASK (0x3 << 20) -#define PINCTRL_MUXSEL7_BANK3_PIN26_OFFSET 20 -#define PINCTRL_MUXSEL7_BANK3_PIN25_MASK (0x3 << 18) -#define PINCTRL_MUXSEL7_BANK3_PIN25_OFFSET 18 -#define PINCTRL_MUXSEL7_BANK3_PIN24_MASK (0x3 << 16) -#define PINCTRL_MUXSEL7_BANK3_PIN24_OFFSET 16 -#define PINCTRL_MUXSEL7_BANK3_PIN23_MASK (0x3 << 14) -#define PINCTRL_MUXSEL7_BANK3_PIN23_OFFSET 14 -#define PINCTRL_MUXSEL7_BANK3_PIN22_MASK (0x3 << 12) -#define PINCTRL_MUXSEL7_BANK3_PIN22_OFFSET 12 -#define PINCTRL_MUXSEL7_BANK3_PIN21_MASK (0x3 << 10) -#define PINCTRL_MUXSEL7_BANK3_PIN21_OFFSET 10 -#define PINCTRL_MUXSEL7_BANK3_PIN20_MASK (0x3 << 8) -#define PINCTRL_MUXSEL7_BANK3_PIN20_OFFSET 8 -#define PINCTRL_MUXSEL7_BANK3_PIN18_MASK (0x3 << 4) -#define PINCTRL_MUXSEL7_BANK3_PIN18_OFFSET 4 -#define PINCTRL_MUXSEL7_BANK3_PIN17_MASK (0x3 << 2) -#define PINCTRL_MUXSEL7_BANK3_PIN17_OFFSET 2 -#define PINCTRL_MUXSEL7_BANK3_PIN16_MASK (0x3 << 0) -#define PINCTRL_MUXSEL7_BANK3_PIN16_OFFSET 0 - -#define PINCTRL_MUXSEL8_BANK4_PIN15_MASK (0x3 << 30) -#define PINCTRL_MUXSEL8_BANK4_PIN15_OFFSET 30 -#define PINCTRL_MUXSEL8_BANK4_PIN14_MASK (0x3 << 28) -#define PINCTRL_MUXSEL8_BANK4_PIN14_OFFSET 28 -#define PINCTRL_MUXSEL8_BANK4_PIN13_MASK (0x3 << 26) -#define PINCTRL_MUXSEL8_BANK4_PIN13_OFFSET 26 -#define PINCTRL_MUXSEL8_BANK4_PIN12_MASK (0x3 << 24) -#define PINCTRL_MUXSEL8_BANK4_PIN12_OFFSET 24 -#define PINCTRL_MUXSEL8_BANK4_PIN11_MASK (0x3 << 22) -#define PINCTRL_MUXSEL8_BANK4_PIN11_OFFSET 22 -#define PINCTRL_MUXSEL8_BANK4_PIN10_MASK (0x3 << 20) -#define PINCTRL_MUXSEL8_BANK4_PIN10_OFFSET 20 -#define PINCTRL_MUXSEL8_BANK4_PIN09_MASK (0x3 << 18) -#define PINCTRL_MUXSEL8_BANK4_PIN09_OFFSET 18 -#define PINCTRL_MUXSEL8_BANK4_PIN08_MASK (0x3 << 16) -#define PINCTRL_MUXSEL8_BANK4_PIN08_OFFSET 16 -#define PINCTRL_MUXSEL8_BANK4_PIN07_MASK (0x3 << 14) -#define PINCTRL_MUXSEL8_BANK4_PIN07_OFFSET 14 -#define PINCTRL_MUXSEL8_BANK4_PIN06_MASK (0x3 << 12) -#define PINCTRL_MUXSEL8_BANK4_PIN06_OFFSET 12 -#define PINCTRL_MUXSEL8_BANK4_PIN05_MASK (0x3 << 10) -#define PINCTRL_MUXSEL8_BANK4_PIN05_OFFSET 10 -#define PINCTRL_MUXSEL8_BANK4_PIN04_MASK (0x3 << 8) -#define PINCTRL_MUXSEL8_BANK4_PIN04_OFFSET 8 -#define PINCTRL_MUXSEL8_BANK4_PIN03_MASK (0x3 << 6) -#define PINCTRL_MUXSEL8_BANK4_PIN03_OFFSET 6 -#define PINCTRL_MUXSEL8_BANK4_PIN02_MASK (0x3 << 4) -#define PINCTRL_MUXSEL8_BANK4_PIN02_OFFSET 4 -#define PINCTRL_MUXSEL8_BANK4_PIN01_MASK (0x3 << 2) -#define PINCTRL_MUXSEL8_BANK4_PIN01_OFFSET 2 -#define PINCTRL_MUXSEL8_BANK4_PIN00_MASK (0x3 << 0) -#define PINCTRL_MUXSEL8_BANK4_PIN00_OFFSET 0 - -#define PINCTRL_MUXSEL9_BANK4_PIN20_MASK (0x3 << 8) -#define PINCTRL_MUXSEL9_BANK4_PIN20_OFFSET 8 -#define PINCTRL_MUXSEL9_BANK4_PIN16_MASK (0x3 << 0) -#define PINCTRL_MUXSEL9_BANK4_PIN16_OFFSET 0 - -#define PINCTRL_MUXSEL10_BANK5_PIN15_MASK (0x3 << 30) -#define PINCTRL_MUXSEL10_BANK5_PIN15_OFFSET 30 -#define PINCTRL_MUXSEL10_BANK5_PIN14_MASK (0x3 << 28) -#define PINCTRL_MUXSEL10_BANK5_PIN14_OFFSET 28 -#define PINCTRL_MUXSEL10_BANK5_PIN13_MASK (0x3 << 26) -#define PINCTRL_MUXSEL10_BANK5_PIN13_OFFSET 26 -#define PINCTRL_MUXSEL10_BANK5_PIN12_MASK (0x3 << 24) -#define PINCTRL_MUXSEL10_BANK5_PIN12_OFFSET 24 -#define PINCTRL_MUXSEL10_BANK5_PIN11_MASK (0x3 << 22) -#define PINCTRL_MUXSEL10_BANK5_PIN11_OFFSET 22 -#define PINCTRL_MUXSEL10_BANK5_PIN10_MASK (0x3 << 20) -#define PINCTRL_MUXSEL10_BANK5_PIN10_OFFSET 20 -#define PINCTRL_MUXSEL10_BANK5_PIN09_MASK (0x3 << 18) -#define PINCTRL_MUXSEL10_BANK5_PIN09_OFFSET 18 -#define PINCTRL_MUXSEL10_BANK5_PIN08_MASK (0x3 << 16) -#define PINCTRL_MUXSEL10_BANK5_PIN08_OFFSET 16 -#define PINCTRL_MUXSEL10_BANK5_PIN07_MASK (0x3 << 14) -#define PINCTRL_MUXSEL10_BANK5_PIN07_OFFSET 14 -#define PINCTRL_MUXSEL10_BANK5_PIN06_MASK (0x3 << 12) -#define PINCTRL_MUXSEL10_BANK5_PIN06_OFFSET 12 -#define PINCTRL_MUXSEL10_BANK5_PIN05_MASK (0x3 << 10) -#define PINCTRL_MUXSEL10_BANK5_PIN05_OFFSET 10 -#define PINCTRL_MUXSEL10_BANK5_PIN04_MASK (0x3 << 8) -#define PINCTRL_MUXSEL10_BANK5_PIN04_OFFSET 8 -#define PINCTRL_MUXSEL10_BANK5_PIN03_MASK (0x3 << 6) -#define PINCTRL_MUXSEL10_BANK5_PIN03_OFFSET 6 -#define PINCTRL_MUXSEL10_BANK5_PIN02_MASK (0x3 << 4) -#define PINCTRL_MUXSEL10_BANK5_PIN02_OFFSET 4 -#define PINCTRL_MUXSEL10_BANK5_PIN01_MASK (0x3 << 2) -#define PINCTRL_MUXSEL10_BANK5_PIN01_OFFSET 2 -#define PINCTRL_MUXSEL10_BANK5_PIN00_MASK (0x3 << 0) -#define PINCTRL_MUXSEL10_BANK5_PIN00_OFFSET 0 - -#define PINCTRL_MUXSEL11_BANK5_PIN26_MASK (0x3 << 20) -#define PINCTRL_MUXSEL11_BANK5_PIN26_OFFSET 20 -#define PINCTRL_MUXSEL11_BANK5_PIN23_MASK (0x3 << 14) -#define PINCTRL_MUXSEL11_BANK5_PIN23_OFFSET 14 -#define PINCTRL_MUXSEL11_BANK5_PIN22_MASK (0x3 << 12) -#define PINCTRL_MUXSEL11_BANK5_PIN22_OFFSET 12 -#define PINCTRL_MUXSEL11_BANK5_PIN21_MASK (0x3 << 10) -#define PINCTRL_MUXSEL11_BANK5_PIN21_OFFSET 10 -#define PINCTRL_MUXSEL11_BANK5_PIN20_MASK (0x3 << 8) -#define PINCTRL_MUXSEL11_BANK5_PIN20_OFFSET 8 -#define PINCTRL_MUXSEL11_BANK5_PIN19_MASK (0x3 << 6) -#define PINCTRL_MUXSEL11_BANK5_PIN19_OFFSET 6 -#define PINCTRL_MUXSEL11_BANK5_PIN18_MASK (0x3 << 4) -#define PINCTRL_MUXSEL11_BANK5_PIN18_OFFSET 4 -#define PINCTRL_MUXSEL11_BANK5_PIN17_MASK (0x3 << 2) -#define PINCTRL_MUXSEL11_BANK5_PIN17_OFFSET 2 -#define PINCTRL_MUXSEL11_BANK5_PIN16_MASK (0x3 << 0) -#define PINCTRL_MUXSEL11_BANK5_PIN16_OFFSET 0 - -#define PINCTRL_MUXSEL12_BANK6_PIN14_MASK (0x3 << 28) -#define PINCTRL_MUXSEL12_BANK6_PIN14_OFFSET 28 -#define PINCTRL_MUXSEL12_BANK6_PIN13_MASK (0x3 << 26) -#define PINCTRL_MUXSEL12_BANK6_PIN13_OFFSET 26 -#define PINCTRL_MUXSEL12_BANK6_PIN12_MASK (0x3 << 24) -#define PINCTRL_MUXSEL12_BANK6_PIN12_OFFSET 24 -#define PINCTRL_MUXSEL12_BANK6_PIN11_MASK (0x3 << 22) -#define PINCTRL_MUXSEL12_BANK6_PIN11_OFFSET 22 -#define PINCTRL_MUXSEL12_BANK6_PIN10_MASK (0x3 << 20) -#define PINCTRL_MUXSEL12_BANK6_PIN10_OFFSET 20 -#define PINCTRL_MUXSEL12_BANK6_PIN09_MASK (0x3 << 18) -#define PINCTRL_MUXSEL12_BANK6_PIN09_OFFSET 18 -#define PINCTRL_MUXSEL12_BANK6_PIN08_MASK (0x3 << 16) -#define PINCTRL_MUXSEL12_BANK6_PIN08_OFFSET 16 -#define PINCTRL_MUXSEL12_BANK6_PIN07_MASK (0x3 << 14) -#define PINCTRL_MUXSEL12_BANK6_PIN07_OFFSET 14 -#define PINCTRL_MUXSEL12_BANK6_PIN06_MASK (0x3 << 12) -#define PINCTRL_MUXSEL12_BANK6_PIN06_OFFSET 12 -#define PINCTRL_MUXSEL12_BANK6_PIN05_MASK (0x3 << 10) -#define PINCTRL_MUXSEL12_BANK6_PIN05_OFFSET 10 -#define PINCTRL_MUXSEL12_BANK6_PIN04_MASK (0x3 << 8) -#define PINCTRL_MUXSEL12_BANK6_PIN04_OFFSET 8 -#define PINCTRL_MUXSEL12_BANK6_PIN03_MASK (0x3 << 6) -#define PINCTRL_MUXSEL12_BANK6_PIN03_OFFSET 6 -#define PINCTRL_MUXSEL12_BANK6_PIN02_MASK (0x3 << 4) -#define PINCTRL_MUXSEL12_BANK6_PIN02_OFFSET 4 -#define PINCTRL_MUXSEL12_BANK6_PIN01_MASK (0x3 << 2) -#define PINCTRL_MUXSEL12_BANK6_PIN01_OFFSET 2 -#define PINCTRL_MUXSEL12_BANK6_PIN00_MASK (0x3 << 0) -#define PINCTRL_MUXSEL12_BANK6_PIN00_OFFSET 0 - -#define PINCTRL_MUXSEL13_BANK6_PIN24_MASK (0x3 << 16) -#define PINCTRL_MUXSEL13_BANK6_PIN24_OFFSET 16 -#define PINCTRL_MUXSEL13_BANK6_PIN23_MASK (0x3 << 14) -#define PINCTRL_MUXSEL13_BANK6_PIN23_OFFSET 14 -#define PINCTRL_MUXSEL13_BANK6_PIN22_MASK (0x3 << 12) -#define PINCTRL_MUXSEL13_BANK6_PIN22_OFFSET 12 -#define PINCTRL_MUXSEL13_BANK6_PIN21_MASK (0x3 << 10) -#define PINCTRL_MUXSEL13_BANK6_PIN21_OFFSET 10 -#define PINCTRL_MUXSEL13_BANK6_PIN20_MASK (0x3 << 8) -#define PINCTRL_MUXSEL13_BANK6_PIN20_OFFSET 8 -#define PINCTRL_MUXSEL13_BANK6_PIN19_MASK (0x3 << 6) -#define PINCTRL_MUXSEL13_BANK6_PIN19_OFFSET 6 -#define PINCTRL_MUXSEL13_BANK6_PIN18_MASK (0x3 << 4) -#define PINCTRL_MUXSEL13_BANK6_PIN18_OFFSET 4 -#define PINCTRL_MUXSEL13_BANK6_PIN17_MASK (0x3 << 2) -#define PINCTRL_MUXSEL13_BANK6_PIN17_OFFSET 2 -#define PINCTRL_MUXSEL13_BANK6_PIN16_MASK (0x3 << 0) -#define PINCTRL_MUXSEL13_BANK6_PIN16_OFFSET 0 - -#define PINCTRL_DRIVE0_BANK0_PIN07_V (1 << 30) -#define PINCTRL_DRIVE0_BANK0_PIN07_MA_MASK (0x3 << 28) -#define PINCTRL_DRIVE0_BANK0_PIN07_MA_OFFSET 28 -#define PINCTRL_DRIVE0_BANK0_PIN06_V (1 << 26) -#define PINCTRL_DRIVE0_BANK0_PIN06_MA_MASK (0x3 << 24) -#define PINCTRL_DRIVE0_BANK0_PIN06_MA_OFFSET 24 -#define PINCTRL_DRIVE0_BANK0_PIN05_V (1 << 22) -#define PINCTRL_DRIVE0_BANK0_PIN05_MA_MASK (0x3 << 20) -#define PINCTRL_DRIVE0_BANK0_PIN05_MA_OFFSET 20 -#define PINCTRL_DRIVE0_BANK0_PIN04_V (1 << 18) -#define PINCTRL_DRIVE0_BANK0_PIN04_MA_MASK (0x3 << 16) -#define PINCTRL_DRIVE0_BANK0_PIN04_MA_OFFSET 16 -#define PINCTRL_DRIVE0_BANK0_PIN03_V (1 << 14) -#define PINCTRL_DRIVE0_BANK0_PIN03_MA_MASK (0x3 << 12) -#define PINCTRL_DRIVE0_BANK0_PIN03_MA_OFFSET 12 -#define PINCTRL_DRIVE0_BANK0_PIN02_V (1 << 10) -#define PINCTRL_DRIVE0_BANK0_PIN02_MA_MASK (0x3 << 8) -#define PINCTRL_DRIVE0_BANK0_PIN02_MA_OFFSET 8 -#define PINCTRL_DRIVE0_BANK0_PIN01_V (1 << 6) -#define PINCTRL_DRIVE0_BANK0_PIN01_MA_MASK (0x3 << 4) -#define PINCTRL_DRIVE0_BANK0_PIN01_MA_OFFSET 4 -#define PINCTRL_DRIVE0_BANK0_PIN00_V (1 << 2) -#define PINCTRL_DRIVE0_BANK0_PIN00_MA_MASK (0x3 << 0) -#define PINCTRL_DRIVE0_BANK0_PIN00_MA_OFFSET 0 - -#define PINCTRL_DRIVE2_BANK0_PIN23_V (1 << 30) -#define PINCTRL_DRIVE2_BANK0_PIN23_MA_MASK (0x3 << 28) -#define PINCTRL_DRIVE2_BANK0_PIN23_MA_OFFSET 28 -#define PINCTRL_DRIVE2_BANK0_PIN22_V (1 << 26) -#define PINCTRL_DRIVE2_BANK0_PIN22_MA_MASK (0x3 << 24) -#define PINCTRL_DRIVE2_BANK0_PIN22_MA_OFFSET 24 -#define PINCTRL_DRIVE2_BANK0_PIN21_V (1 << 22) -#define PINCTRL_DRIVE2_BANK0_PIN21_MA_MASK (0x3 << 20) -#define PINCTRL_DRIVE2_BANK0_PIN21_MA_OFFSET 20 -#define PINCTRL_DRIVE2_BANK0_PIN20_V (1 << 18) -#define PINCTRL_DRIVE2_BANK0_PIN20_MA_MASK (0x3 << 16) -#define PINCTRL_DRIVE2_BANK0_PIN20_MA_OFFSET 16 -#define PINCTRL_DRIVE2_BANK0_PIN19_V (1 << 14) -#define PINCTRL_DRIVE2_BANK0_PIN19_MA_MASK (0x3 << 12) -#define PINCTRL_DRIVE2_BANK0_PIN19_MA_OFFSET 12 -#define PINCTRL_DRIVE2_BANK0_PIN18_V (1 << 10) -#define PINCTRL_DRIVE2_BANK0_PIN18_MA_MASK (0x3 << 8) -#define PINCTRL_DRIVE2_BANK0_PIN18_MA_OFFSET 8 -#define PINCTRL_DRIVE2_BANK0_PIN17_V (1 << 6) -#define PINCTRL_DRIVE2_BANK0_PIN17_MA_MASK (0x3 << 4) -#define PINCTRL_DRIVE2_BANK0_PIN17_MA_OFFSET 4 -#define PINCTRL_DRIVE2_BANK0_PIN16_V (1 << 2) -#define PINCTRL_DRIVE2_BANK0_PIN16_MA_MASK (0x3 << 0) -#define PINCTRL_DRIVE2_BANK0_PIN16_MA_OFFSET 0 - -#define PINCTRL_DRIVE3_BANK0_PIN28_V (1 << 18) -#define PINCTRL_DRIVE3_BANK0_PIN28_MA_MASK (0x3 << 16) -#define PINCTRL_DRIVE3_BANK0_PIN28_MA_OFFSET 16 -#define PINCTRL_DRIVE3_BANK0_PIN27_V (1 << 14) -#define PINCTRL_DRIVE3_BANK0_PIN27_MA_MASK (0x3 << 12) -#define PINCTRL_DRIVE3_BANK0_PIN27_MA_OFFSET 12 -#define PINCTRL_DRIVE3_BANK0_PIN26_V (1 << 10) -#define PINCTRL_DRIVE3_BANK0_PIN26_MA_MASK (0x3 << 8) -#define PINCTRL_DRIVE3_BANK0_PIN26_MA_OFFSET 8 -#define PINCTRL_DRIVE3_BANK0_PIN25_V (1 << 6) -#define PINCTRL_DRIVE3_BANK0_PIN25_MA_MASK (0x3 << 4) -#define PINCTRL_DRIVE3_BANK0_PIN25_MA_OFFSET 4 -#define PINCTRL_DRIVE3_BANK0_PIN24_V (1 << 2) -#define PINCTRL_DRIVE3_BANK0_PIN24_MA_MASK (0x3 << 0) -#define PINCTRL_DRIVE3_BANK0_PIN24_MA_OFFSET 0 - -#define PINCTRL_DRIVE4_BANK1_PIN07_V (1 << 30) -#define PINCTRL_DRIVE4_BANK1_PIN07_MA_MASK (0x3 << 28) -#define PINCTRL_DRIVE4_BANK1_PIN07_MA_OFFSET 28 -#define PINCTRL_DRIVE4_BANK1_PIN06_V (1 << 26) -#define PINCTRL_DRIVE4_BANK1_PIN06_MA_MASK (0x3 << 24) -#define PINCTRL_DRIVE4_BANK1_PIN06_MA_OFFSET 24 -#define PINCTRL_DRIVE4_BANK1_PIN05_V (1 << 22) -#define PINCTRL_DRIVE4_BANK1_PIN05_MA_MASK (0x3 << 20) -#define PINCTRL_DRIVE4_BANK1_PIN05_MA_OFFSET 20 -#define PINCTRL_DRIVE4_BANK1_PIN04_V (1 << 18) -#define PINCTRL_DRIVE4_BANK1_PIN04_MA_MASK (0x3 << 16) -#define PINCTRL_DRIVE4_BANK1_PIN04_MA_OFFSET 16 -#define PINCTRL_DRIVE4_BANK1_PIN03_V (1 << 14) -#define PINCTRL_DRIVE4_BANK1_PIN03_MA_MASK (0x3 << 12) -#define PINCTRL_DRIVE4_BANK1_PIN03_MA_OFFSET 12 -#define PINCTRL_DRIVE4_BANK1_PIN02_V (1 << 10) -#define PINCTRL_DRIVE4_BANK1_PIN02_MA_MASK (0x3 << 8) -#define PINCTRL_DRIVE4_BANK1_PIN02_MA_OFFSET 8 -#define PINCTRL_DRIVE4_BANK1_PIN01_V (1 << 6) -#define PINCTRL_DRIVE4_BANK1_PIN01_MA_MASK (0x3 << 4) -#define PINCTRL_DRIVE4_BANK1_PIN01_MA_OFFSET 4 -#define PINCTRL_DRIVE4_BANK1_PIN00_V (1 << 2) -#define PINCTRL_DRIVE4_BANK1_PIN00_MA_MASK (0x3 << 0) -#define PINCTRL_DRIVE4_BANK1_PIN00_MA_OFFSET 0 - -#define PINCTRL_DRIVE5_BANK1_PIN15_V (1 << 30) -#define PINCTRL_DRIVE5_BANK1_PIN15_MA_MASK (0x3 << 28) -#define PINCTRL_DRIVE5_BANK1_PIN15_MA_OFFSET 28 -#define PINCTRL_DRIVE5_BANK1_PIN14_V (1 << 26) -#define PINCTRL_DRIVE5_BANK1_PIN14_MA_MASK (0x3 << 24) -#define PINCTRL_DRIVE5_BANK1_PIN14_MA_OFFSET 24 -#define PINCTRL_DRIVE5_BANK1_PIN13_V (1 << 22) -#define PINCTRL_DRIVE5_BANK1_PIN13_MA_MASK (0x3 << 20) -#define PINCTRL_DRIVE5_BANK1_PIN13_MA_OFFSET 20 -#define PINCTRL_DRIVE5_BANK1_PIN12_V (1 << 18) -#define PINCTRL_DRIVE5_BANK1_PIN12_MA_MASK (0x3 << 16) -#define PINCTRL_DRIVE5_BANK1_PIN12_MA_OFFSET 16 -#define PINCTRL_DRIVE5_BANK1_PIN11_V (1 << 14) -#define PINCTRL_DRIVE5_BANK1_PIN11_MA_MASK (0x3 << 12) -#define PINCTRL_DRIVE5_BANK1_PIN11_MA_OFFSET 12 -#define PINCTRL_DRIVE5_BANK1_PIN10_V (1 << 10) -#define PINCTRL_DRIVE5_BANK1_PIN10_MA_MASK (0x3 << 8) -#define PINCTRL_DRIVE5_BANK1_PIN10_MA_OFFSET 8 -#define PINCTRL_DRIVE5_BANK1_PIN09_V (1 << 6) -#define PINCTRL_DRIVE5_BANK1_PIN09_MA_MASK (0x3 << 4) -#define PINCTRL_DRIVE5_BANK1_PIN09_MA_OFFSET 4 -#define PINCTRL_DRIVE5_BANK1_PIN08_V (1 << 2) -#define PINCTRL_DRIVE5_BANK1_PIN08_MA_MASK (0x3 << 0) -#define PINCTRL_DRIVE5_BANK1_PIN08_MA_OFFSET 0 - -#define PINCTRL_DRIVE6_BANK1_PIN23_V (1 << 30) -#define PINCTRL_DRIVE6_BANK1_PIN23_MA_MASK (0x3 << 28) -#define PINCTRL_DRIVE6_BANK1_PIN23_MA_OFFSET 28 -#define PINCTRL_DRIVE6_BANK1_PIN22_V (1 << 26) -#define PINCTRL_DRIVE6_BANK1_PIN22_MA_MASK (0x3 << 24) -#define PINCTRL_DRIVE6_BANK1_PIN22_MA_OFFSET 24 -#define PINCTRL_DRIVE6_BANK1_PIN21_V (1 << 22) -#define PINCTRL_DRIVE6_BANK1_PIN21_MA_MASK (0x3 << 20) -#define PINCTRL_DRIVE6_BANK1_PIN21_MA_OFFSET 20 -#define PINCTRL_DRIVE6_BANK1_PIN20_V (1 << 18) -#define PINCTRL_DRIVE6_BANK1_PIN20_MA_MASK (0x3 << 16) -#define PINCTRL_DRIVE6_BANK1_PIN20_MA_OFFSET 16 -#define PINCTRL_DRIVE6_BANK1_PIN19_V (1 << 14) -#define PINCTRL_DRIVE6_BANK1_PIN19_MA_MASK (0x3 << 12) -#define PINCTRL_DRIVE6_BANK1_PIN19_MA_OFFSET 12 -#define PINCTRL_DRIVE6_BANK1_PIN18_V (1 << 10) -#define PINCTRL_DRIVE6_BANK1_PIN18_MA_MASK (0x3 << 8) -#define PINCTRL_DRIVE6_BANK1_PIN18_MA_OFFSET 8 -#define PINCTRL_DRIVE6_BANK1_PIN17_V (1 << 6) -#define PINCTRL_DRIVE6_BANK1_PIN17_MA_MASK (0x3 << 4) -#define PINCTRL_DRIVE6_BANK1_PIN17_MA_OFFSET 4 -#define PINCTRL_DRIVE6_BANK1_PIN16_V (1 << 2) -#define PINCTRL_DRIVE6_BANK1_PIN16_MA_MASK (0x3 << 0) -#define PINCTRL_DRIVE6_BANK1_PIN16_MA_OFFSET 0 - -#define PINCTRL_DRIVE7_BANK1_PIN31_V (1 << 30) -#define PINCTRL_DRIVE7_BANK1_PIN31_MA_MASK (0x3 << 28) -#define PINCTRL_DRIVE7_BANK1_PIN31_MA_OFFSET 28 -#define PINCTRL_DRIVE7_BANK1_PIN30_V (1 << 26) -#define PINCTRL_DRIVE7_BANK1_PIN30_MA_MASK (0x3 << 24) -#define PINCTRL_DRIVE7_BANK1_PIN30_MA_OFFSET 24 -#define PINCTRL_DRIVE7_BANK1_PIN29_V (1 << 22) -#define PINCTRL_DRIVE7_BANK1_PIN29_MA_MASK (0x3 << 20) -#define PINCTRL_DRIVE7_BANK1_PIN29_MA_OFFSET 20 -#define PINCTRL_DRIVE7_BANK1_PIN28_V (1 << 18) -#define PINCTRL_DRIVE7_BANK1_PIN28_MA_MASK (0x3 << 16) -#define PINCTRL_DRIVE7_BANK1_PIN28_MA_OFFSET 16 -#define PINCTRL_DRIVE7_BANK1_PIN27_V (1 << 14) -#define PINCTRL_DRIVE7_BANK1_PIN27_MA_MASK (0x3 << 12) -#define PINCTRL_DRIVE7_BANK1_PIN27_MA_OFFSET 12 -#define PINCTRL_DRIVE7_BANK1_PIN26_V (1 << 10) -#define PINCTRL_DRIVE7_BANK1_PIN26_MA_MASK (0x3 << 8) -#define PINCTRL_DRIVE7_BANK1_PIN26_MA_OFFSET 8 -#define PINCTRL_DRIVE7_BANK1_PIN25_V (1 << 6) -#define PINCTRL_DRIVE7_BANK1_PIN25_MA_MASK (0x3 << 4) -#define PINCTRL_DRIVE7_BANK1_PIN25_MA_OFFSET 4 -#define PINCTRL_DRIVE7_BANK1_PIN24_V (1 << 2) -#define PINCTRL_DRIVE7_BANK1_PIN24_MA_MASK (0x3 << 0) -#define PINCTRL_DRIVE7_BANK1_PIN24_MA_OFFSET 0 - -#define PINCTRL_DRIVE8_BANK2_PIN07_V (1 << 30) -#define PINCTRL_DRIVE8_BANK2_PIN07_MA_MASK (0x3 << 28) -#define PINCTRL_DRIVE8_BANK2_PIN07_MA_OFFSET 28 -#define PINCTRL_DRIVE8_BANK2_PIN06_V (1 << 26) -#define PINCTRL_DRIVE8_BANK2_PIN06_MA_MASK (0x3 << 24) -#define PINCTRL_DRIVE8_BANK2_PIN06_MA_OFFSET 24 -#define PINCTRL_DRIVE8_BANK2_PIN05_V (1 << 22) -#define PINCTRL_DRIVE8_BANK2_PIN05_MA_MASK (0x3 << 20) -#define PINCTRL_DRIVE8_BANK2_PIN05_MA_OFFSET 20 -#define PINCTRL_DRIVE8_BANK2_PIN04_V (1 << 18) -#define PINCTRL_DRIVE8_BANK2_PIN04_MA_MASK (0x3 << 16) -#define PINCTRL_DRIVE8_BANK2_PIN04_MA_OFFSET 16 -#define PINCTRL_DRIVE8_BANK2_PIN03_V (1 << 14) -#define PINCTRL_DRIVE8_BANK2_PIN03_MA_MASK (0x3 << 12) -#define PINCTRL_DRIVE8_BANK2_PIN03_MA_OFFSET 12 -#define PINCTRL_DRIVE8_BANK2_PIN02_V (1 << 10) -#define PINCTRL_DRIVE8_BANK2_PIN02_MA_MASK (0x3 << 8) -#define PINCTRL_DRIVE8_BANK2_PIN02_MA_OFFSET 8 -#define PINCTRL_DRIVE8_BANK2_PIN01_V (1 << 6) -#define PINCTRL_DRIVE8_BANK2_PIN01_MA_MASK (0x3 << 4) -#define PINCTRL_DRIVE8_BANK2_PIN01_MA_OFFSET 4 -#define PINCTRL_DRIVE8_BANK2_PIN00_V (1 << 2) -#define PINCTRL_DRIVE8_BANK2_PIN00_MA_MASK (0x3 << 0) -#define PINCTRL_DRIVE8_BANK2_PIN00_MA_OFFSET 0 - -#define PINCTRL_DRIVE9_BANK2_PIN15_V (1 << 30) -#define PINCTRL_DRIVE9_BANK2_PIN15_MA_MASK (0x3 << 28) -#define PINCTRL_DRIVE9_BANK2_PIN15_MA_OFFSET 28 -#define PINCTRL_DRIVE9_BANK2_PIN14_V (1 << 26) -#define PINCTRL_DRIVE9_BANK2_PIN14_MA_MASK (0x3 << 24) -#define PINCTRL_DRIVE9_BANK2_PIN14_MA_OFFSET 24 -#define PINCTRL_DRIVE9_BANK2_PIN13_V (1 << 22) -#define PINCTRL_DRIVE9_BANK2_PIN13_MA_MASK (0x3 << 20) -#define PINCTRL_DRIVE9_BANK2_PIN13_MA_OFFSET 20 -#define PINCTRL_DRIVE9_BANK2_PIN12_V (1 << 18) -#define PINCTRL_DRIVE9_BANK2_PIN12_MA_MASK (0x3 << 16) -#define PINCTRL_DRIVE9_BANK2_PIN12_MA_OFFSET 16 -#define PINCTRL_DRIVE9_BANK2_PIN10_V (1 << 10) -#define PINCTRL_DRIVE9_BANK2_PIN10_MA_MASK (0x3 << 8) -#define PINCTRL_DRIVE9_BANK2_PIN10_MA_OFFSET 8 -#define PINCTRL_DRIVE9_BANK2_PIN09_V (1 << 6) -#define PINCTRL_DRIVE9_BANK2_PIN09_MA_MASK (0x3 << 4) -#define PINCTRL_DRIVE9_BANK2_PIN09_MA_OFFSET 4 -#define PINCTRL_DRIVE9_BANK2_PIN08_V (1 << 2) -#define PINCTRL_DRIVE9_BANK2_PIN08_MA_MASK (0x3 << 0) -#define PINCTRL_DRIVE9_BANK2_PIN08_MA_OFFSET 0 - -#define PINCTRL_DRIVE10_BANK2_PIN21_V (1 << 22) -#define PINCTRL_DRIVE10_BANK2_PIN21_MA_MASK (0x3 << 20) -#define PINCTRL_DRIVE10_BANK2_PIN21_MA_OFFSET 20 -#define PINCTRL_DRIVE10_BANK2_PIN20_V (1 << 18) -#define PINCTRL_DRIVE10_BANK2_PIN20_MA_MASK (0x3 << 16) -#define PINCTRL_DRIVE10_BANK2_PIN20_MA_OFFSET 16 -#define PINCTRL_DRIVE10_BANK2_PIN19_V (1 << 14) -#define PINCTRL_DRIVE10_BANK2_PIN19_MA_MASK (0x3 << 12) -#define PINCTRL_DRIVE10_BANK2_PIN19_MA_OFFSET 12 -#define PINCTRL_DRIVE10_BANK2_PIN18_V (1 << 10) -#define PINCTRL_DRIVE10_BANK2_PIN18_MA_MASK (0x3 << 8) -#define PINCTRL_DRIVE10_BANK2_PIN18_MA_OFFSET 8 -#define PINCTRL_DRIVE10_BANK2_PIN17_V (1 << 6) -#define PINCTRL_DRIVE10_BANK2_PIN17_MA_MASK (0x3 << 4) -#define PINCTRL_DRIVE10_BANK2_PIN17_MA_OFFSET 4 -#define PINCTRL_DRIVE10_BANK2_PIN16_V (1 << 2) -#define PINCTRL_DRIVE10_BANK2_PIN16_MA_MASK (0x3 << 0) -#define PINCTRL_DRIVE10_BANK2_PIN16_MA_OFFSET 0 - -#define PINCTRL_DRIVE11_BANK2_PIN27_V (1 << 14) -#define PINCTRL_DRIVE11_BANK2_PIN27_MA_MASK (0x3 << 12) -#define PINCTRL_DRIVE11_BANK2_PIN27_MA_OFFSET 12 -#define PINCTRL_DRIVE11_BANK2_PIN26_V (1 << 10) -#define PINCTRL_DRIVE11_BANK2_PIN26_MA_MASK (0x3 << 8) -#define PINCTRL_DRIVE11_BANK2_PIN26_MA_OFFSET 8 -#define PINCTRL_DRIVE11_BANK2_PIN25_V (1 << 6) -#define PINCTRL_DRIVE11_BANK2_PIN25_MA_MASK (0x3 << 4) -#define PINCTRL_DRIVE11_BANK2_PIN25_MA_OFFSET 4 -#define PINCTRL_DRIVE11_BANK2_PIN24_V (1 << 2) -#define PINCTRL_DRIVE11_BANK2_PIN24_MA_MASK (0x3 << 0) -#define PINCTRL_DRIVE11_BANK2_PIN24_MA_OFFSET 0 - -#define PINCTRL_DRIVE12_BANK3_PIN07_V (1 << 30) -#define PINCTRL_DRIVE12_BANK3_PIN07_MA_MASK (0x3 << 28) -#define PINCTRL_DRIVE12_BANK3_PIN07_MA_OFFSET 28 -#define PINCTRL_DRIVE12_BANK3_PIN06_V (1 << 26) -#define PINCTRL_DRIVE12_BANK3_PIN06_MA_MASK (0x3 << 24) -#define PINCTRL_DRIVE12_BANK3_PIN06_MA_OFFSET 24 -#define PINCTRL_DRIVE12_BANK3_PIN05_V (1 << 22) -#define PINCTRL_DRIVE12_BANK3_PIN05_MA_MASK (0x3 << 20) -#define PINCTRL_DRIVE12_BANK3_PIN05_MA_OFFSET 20 -#define PINCTRL_DRIVE12_BANK3_PIN04_V (1 << 18) -#define PINCTRL_DRIVE12_BANK3_PIN04_MA_MASK (0x3 << 16) -#define PINCTRL_DRIVE12_BANK3_PIN04_MA_OFFSET 16 -#define PINCTRL_DRIVE12_BANK3_PIN03_V (1 << 14) -#define PINCTRL_DRIVE12_BANK3_PIN03_MA_MASK (0x3 << 12) -#define PINCTRL_DRIVE12_BANK3_PIN03_MA_OFFSET 12 -#define PINCTRL_DRIVE12_BANK3_PIN02_V (1 << 10) -#define PINCTRL_DRIVE12_BANK3_PIN02_MA_MASK (0x3 << 8) -#define PINCTRL_DRIVE12_BANK3_PIN02_MA_OFFSET 8 -#define PINCTRL_DRIVE12_BANK3_PIN01_V (1 << 6) -#define PINCTRL_DRIVE12_BANK3_PIN01_MA_MASK (0x3 << 4) -#define PINCTRL_DRIVE12_BANK3_PIN01_MA_OFFSET 4 -#define PINCTRL_DRIVE12_BANK3_PIN00_V (1 << 2) -#define PINCTRL_DRIVE12_BANK3_PIN00_MA_MASK (0x3 << 0) -#define PINCTRL_DRIVE12_BANK3_PIN00_MA_OFFSET 0 - -#define PINCTRL_DRIVE13_BANK3_PIN15_V (1 << 30) -#define PINCTRL_DRIVE13_BANK3_PIN15_MA_MASK (0x3 << 28) -#define PINCTRL_DRIVE13_BANK3_PIN15_MA_OFFSET 28 -#define PINCTRL_DRIVE13_BANK3_PIN14_V (1 << 26) -#define PINCTRL_DRIVE13_BANK3_PIN14_MA_MASK (0x3 << 24) -#define PINCTRL_DRIVE13_BANK3_PIN14_MA_OFFSET 24 -#define PINCTRL_DRIVE13_BANK3_PIN13_V (1 << 22) -#define PINCTRL_DRIVE13_BANK3_PIN13_MA_MASK (0x3 << 20) -#define PINCTRL_DRIVE13_BANK3_PIN13_MA_OFFSET 20 -#define PINCTRL_DRIVE13_BANK3_PIN12_V (1 << 18) -#define PINCTRL_DRIVE13_BANK3_PIN12_MA_MASK (0x3 << 16) -#define PINCTRL_DRIVE13_BANK3_PIN12_MA_OFFSET 16 -#define PINCTRL_DRIVE13_BANK3_PIN11_V (1 << 14) -#define PINCTRL_DRIVE13_BANK3_PIN11_MA_MASK (0x3 << 12) -#define PINCTRL_DRIVE13_BANK3_PIN11_MA_OFFSET 12 -#define PINCTRL_DRIVE13_BANK3_PIN10_V (1 << 10) -#define PINCTRL_DRIVE13_BANK3_PIN10_MA_MASK (0x3 << 8) -#define PINCTRL_DRIVE13_BANK3_PIN10_MA_OFFSET 8 -#define PINCTRL_DRIVE13_BANK3_PIN09_V (1 << 6) -#define PINCTRL_DRIVE13_BANK3_PIN09_MA_MASK (0x3 << 4) -#define PINCTRL_DRIVE13_BANK3_PIN09_MA_OFFSET 4 -#define PINCTRL_DRIVE13_BANK3_PIN08_V (1 << 2) -#define PINCTRL_DRIVE13_BANK3_PIN08_MA_MASK (0x3 << 0) -#define PINCTRL_DRIVE13_BANK3_PIN08_MA_OFFSET 0 - -#define PINCTRL_DRIVE14_BANK3_PIN23_V (1 << 30) -#define PINCTRL_DRIVE14_BANK3_PIN23_MA_MASK (0x3 << 28) -#define PINCTRL_DRIVE14_BANK3_PIN23_MA_OFFSET 28 -#define PINCTRL_DRIVE14_BANK3_PIN22_V (1 << 26) -#define PINCTRL_DRIVE14_BANK3_PIN22_MA_MASK (0x3 << 24) -#define PINCTRL_DRIVE14_BANK3_PIN22_MA_OFFSET 24 -#define PINCTRL_DRIVE14_BANK3_PIN21_V (1 << 22) -#define PINCTRL_DRIVE14_BANK3_PIN21_MA_MASK (0x3 << 20) -#define PINCTRL_DRIVE14_BANK3_PIN21_MA_OFFSET 20 -#define PINCTRL_DRIVE14_BANK3_PIN20_V (1 << 18) -#define PINCTRL_DRIVE14_BANK3_PIN20_MA_MASK (0x3 << 16) -#define PINCTRL_DRIVE14_BANK3_PIN20_MA_OFFSET 16 -#define PINCTRL_DRIVE14_BANK3_PIN18_V (1 << 10) -#define PINCTRL_DRIVE14_BANK3_PIN18_MA_MASK (0x3 << 8) -#define PINCTRL_DRIVE14_BANK3_PIN18_MA_OFFSET 8 -#define PINCTRL_DRIVE14_BANK3_PIN17_V (1 << 6) -#define PINCTRL_DRIVE14_BANK3_PIN17_MA_MASK (0x3 << 4) -#define PINCTRL_DRIVE14_BANK3_PIN17_MA_OFFSET 4 -#define PINCTRL_DRIVE14_BANK3_PIN16_V (1 << 2) -#define PINCTRL_DRIVE14_BANK3_PIN16_MA_MASK (0x3 << 0) -#define PINCTRL_DRIVE14_BANK3_PIN16_MA_OFFSET 0 - -#define PINCTRL_DRIVE15_BANK3_PIN30_V (1 << 26) -#define PINCTRL_DRIVE15_BANK3_PIN30_MA_MASK (0x3 << 24) -#define PINCTRL_DRIVE15_BANK3_PIN30_MA_OFFSET 24 -#define PINCTRL_DRIVE15_BANK3_PIN29_V (1 << 22) -#define PINCTRL_DRIVE15_BANK3_PIN29_MA_MASK (0x3 << 20) -#define PINCTRL_DRIVE15_BANK3_PIN29_MA_OFFSET 20 -#define PINCTRL_DRIVE15_BANK3_PIN28_V (1 << 18) -#define PINCTRL_DRIVE15_BANK3_PIN28_MA_MASK (0x3 << 16) -#define PINCTRL_DRIVE15_BANK3_PIN28_MA_OFFSET 16 -#define PINCTRL_DRIVE15_BANK3_PIN27_V (1 << 14) -#define PINCTRL_DRIVE15_BANK3_PIN27_MA_MASK (0x3 << 12) -#define PINCTRL_DRIVE15_BANK3_PIN27_MA_OFFSET 12 -#define PINCTRL_DRIVE15_BANK3_PIN26_V (1 << 10) -#define PINCTRL_DRIVE15_BANK3_PIN26_MA_MASK (0x3 << 8) -#define PINCTRL_DRIVE15_BANK3_PIN26_MA_OFFSET 8 -#define PINCTRL_DRIVE15_BANK3_PIN25_V (1 << 6) -#define PINCTRL_DRIVE15_BANK3_PIN25_MA_MASK (0x3 << 4) -#define PINCTRL_DRIVE15_BANK3_PIN25_MA_OFFSET 4 -#define PINCTRL_DRIVE15_BANK3_PIN24_V (1 << 2) -#define PINCTRL_DRIVE15_BANK3_PIN24_MA_MASK (0x3 << 0) -#define PINCTRL_DRIVE15_BANK3_PIN24_MA_OFFSET 0 - -#define PINCTRL_DRIVE16_BANK4_PIN07_V (1 << 30) -#define PINCTRL_DRIVE16_BANK4_PIN07_MA_MASK (0x3 << 28) -#define PINCTRL_DRIVE16_BANK4_PIN07_MA_OFFSET 28 -#define PINCTRL_DRIVE16_BANK4_PIN06_V (1 << 26) -#define PINCTRL_DRIVE16_BANK4_PIN06_MA_MASK (0x3 << 24) -#define PINCTRL_DRIVE16_BANK4_PIN06_MA_OFFSET 24 -#define PINCTRL_DRIVE16_BANK4_PIN05_V (1 << 22) -#define PINCTRL_DRIVE16_BANK4_PIN05_MA_MASK (0x3 << 20) -#define PINCTRL_DRIVE16_BANK4_PIN05_MA_OFFSET 20 -#define PINCTRL_DRIVE16_BANK4_PIN04_V (1 << 18) -#define PINCTRL_DRIVE16_BANK4_PIN04_MA_MASK (0x3 << 16) -#define PINCTRL_DRIVE16_BANK4_PIN04_MA_OFFSET 16 -#define PINCTRL_DRIVE16_BANK4_PIN03_V (1 << 14) -#define PINCTRL_DRIVE16_BANK4_PIN03_MA_MASK (0x3 << 12) -#define PINCTRL_DRIVE16_BANK4_PIN03_MA_OFFSET 12 -#define PINCTRL_DRIVE16_BANK4_PIN02_V (1 << 10) -#define PINCTRL_DRIVE16_BANK4_PIN02_MA_MASK (0x3 << 8) -#define PINCTRL_DRIVE16_BANK4_PIN02_MA_OFFSET 8 -#define PINCTRL_DRIVE16_BANK4_PIN01_V (1 << 6) -#define PINCTRL_DRIVE16_BANK4_PIN01_MA_MASK (0x3 << 4) -#define PINCTRL_DRIVE16_BANK4_PIN01_MA_OFFSET 4 -#define PINCTRL_DRIVE16_BANK4_PIN00_V (1 << 2) -#define PINCTRL_DRIVE16_BANK4_PIN00_MA_MASK (0x3 << 0) -#define PINCTRL_DRIVE16_BANK4_PIN00_MA_OFFSET 0 - -#define PINCTRL_DRIVE17_BANK4_PIN15_V (1 << 30) -#define PINCTRL_DRIVE17_BANK4_PIN15_MA_MASK (0x3 << 28) -#define PINCTRL_DRIVE17_BANK4_PIN15_MA_OFFSET 28 -#define PINCTRL_DRIVE17_BANK4_PIN14_V (1 << 26) -#define PINCTRL_DRIVE17_BANK4_PIN14_MA_MASK (0x3 << 24) -#define PINCTRL_DRIVE17_BANK4_PIN14_MA_OFFSET 24 -#define PINCTRL_DRIVE17_BANK4_PIN13_V (1 << 22) -#define PINCTRL_DRIVE17_BANK4_PIN13_MA_MASK (0x3 << 20) -#define PINCTRL_DRIVE17_BANK4_PIN13_MA_OFFSET 20 -#define PINCTRL_DRIVE17_BANK4_PIN12_V (1 << 18) -#define PINCTRL_DRIVE17_BANK4_PIN12_MA_MASK (0x3 << 16) -#define PINCTRL_DRIVE17_BANK4_PIN12_MA_OFFSET 16 -#define PINCTRL_DRIVE17_BANK4_PIN11_V (1 << 14) -#define PINCTRL_DRIVE17_BANK4_PIN11_MA_MASK (0x3 << 12) -#define PINCTRL_DRIVE17_BANK4_PIN11_MA_OFFSET 12 -#define PINCTRL_DRIVE17_BANK4_PIN10_V (1 << 10) -#define PINCTRL_DRIVE17_BANK4_PIN10_MA_MASK (0x3 << 8) -#define PINCTRL_DRIVE17_BANK4_PIN10_MA_OFFSET 8 -#define PINCTRL_DRIVE17_BANK4_PIN09_V (1 << 6) -#define PINCTRL_DRIVE17_BANK4_PIN09_MA_MASK (0x3 << 4) -#define PINCTRL_DRIVE17_BANK4_PIN09_MA_OFFSET 4 -#define PINCTRL_DRIVE17_BANK4_PIN08_V (1 << 2) -#define PINCTRL_DRIVE17_BANK4_PIN08_MA_MASK (0x3 << 0) -#define PINCTRL_DRIVE17_BANK4_PIN08_MA_OFFSET 0 - -#define PINCTRL_DRIVE18_BANK4_PIN20_V (1 << 18) -#define PINCTRL_DRIVE18_BANK4_PIN20_MA_MASK (0x3 << 16) -#define PINCTRL_DRIVE18_BANK4_PIN20_MA_OFFSET 16 -#define PINCTRL_DRIVE18_BANK4_PIN16_V (1 << 2) -#define PINCTRL_DRIVE18_BANK4_PIN16_MA_MASK (0x3 << 0) -#define PINCTRL_DRIVE18_BANK4_PIN16_MA_OFFSET 0 - -#define PINCTRL_PULL0_BANK0_PIN28 (1 << 28) -#define PINCTRL_PULL0_BANK0_PIN27 (1 << 27) -#define PINCTRL_PULL0_BANK0_PIN26 (1 << 26) -#define PINCTRL_PULL0_BANK0_PIN25 (1 << 25) -#define PINCTRL_PULL0_BANK0_PIN24 (1 << 24) -#define PINCTRL_PULL0_BANK0_PIN23 (1 << 23) -#define PINCTRL_PULL0_BANK0_PIN22 (1 << 22) -#define PINCTRL_PULL0_BANK0_PIN21 (1 << 21) -#define PINCTRL_PULL0_BANK0_PIN20 (1 << 20) -#define PINCTRL_PULL0_BANK0_PIN19 (1 << 19) -#define PINCTRL_PULL0_BANK0_PIN18 (1 << 18) -#define PINCTRL_PULL0_BANK0_PIN17 (1 << 17) -#define PINCTRL_PULL0_BANK0_PIN16 (1 << 16) -#define PINCTRL_PULL0_BANK0_PIN07 (1 << 7) -#define PINCTRL_PULL0_BANK0_PIN06 (1 << 6) -#define PINCTRL_PULL0_BANK0_PIN05 (1 << 5) -#define PINCTRL_PULL0_BANK0_PIN04 (1 << 4) -#define PINCTRL_PULL0_BANK0_PIN03 (1 << 3) -#define PINCTRL_PULL0_BANK0_PIN02 (1 << 2) -#define PINCTRL_PULL0_BANK0_PIN01 (1 << 1) -#define PINCTRL_PULL0_BANK0_PIN00 (1 << 0) - -#define PINCTRL_PULL1_BANK1_PIN31 (1 << 31) -#define PINCTRL_PULL1_BANK1_PIN30 (1 << 30) -#define PINCTRL_PULL1_BANK1_PIN29 (1 << 29) -#define PINCTRL_PULL1_BANK1_PIN28 (1 << 28) -#define PINCTRL_PULL1_BANK1_PIN27 (1 << 27) -#define PINCTRL_PULL1_BANK1_PIN26 (1 << 26) -#define PINCTRL_PULL1_BANK1_PIN25 (1 << 25) -#define PINCTRL_PULL1_BANK1_PIN24 (1 << 24) -#define PINCTRL_PULL1_BANK1_PIN23 (1 << 23) -#define PINCTRL_PULL1_BANK1_PIN22 (1 << 22) -#define PINCTRL_PULL1_BANK1_PIN21 (1 << 21) -#define PINCTRL_PULL1_BANK1_PIN20 (1 << 20) -#define PINCTRL_PULL1_BANK1_PIN19 (1 << 19) -#define PINCTRL_PULL1_BANK1_PIN18 (1 << 18) -#define PINCTRL_PULL1_BANK1_PIN17 (1 << 17) -#define PINCTRL_PULL1_BANK1_PIN16 (1 << 16) -#define PINCTRL_PULL1_BANK1_PIN15 (1 << 15) -#define PINCTRL_PULL1_BANK1_PIN14 (1 << 14) -#define PINCTRL_PULL1_BANK1_PIN13 (1 << 13) -#define PINCTRL_PULL1_BANK1_PIN12 (1 << 12) -#define PINCTRL_PULL1_BANK1_PIN11 (1 << 11) -#define PINCTRL_PULL1_BANK1_PIN10 (1 << 10) -#define PINCTRL_PULL1_BANK1_PIN09 (1 << 9) -#define PINCTRL_PULL1_BANK1_PIN08 (1 << 8) -#define PINCTRL_PULL1_BANK1_PIN07 (1 << 7) -#define PINCTRL_PULL1_BANK1_PIN06 (1 << 6) -#define PINCTRL_PULL1_BANK1_PIN05 (1 << 5) -#define PINCTRL_PULL1_BANK1_PIN04 (1 << 4) -#define PINCTRL_PULL1_BANK1_PIN03 (1 << 3) -#define PINCTRL_PULL1_BANK1_PIN02 (1 << 2) -#define PINCTRL_PULL1_BANK1_PIN01 (1 << 1) -#define PINCTRL_PULL1_BANK1_PIN00 (1 << 0) - -#define PINCTRL_PULL2_BANK2_PIN27 (1 << 27) -#define PINCTRL_PULL2_BANK2_PIN26 (1 << 26) -#define PINCTRL_PULL2_BANK2_PIN25 (1 << 25) -#define PINCTRL_PULL2_BANK2_PIN24 (1 << 24) -#define PINCTRL_PULL2_BANK2_PIN21 (1 << 21) -#define PINCTRL_PULL2_BANK2_PIN20 (1 << 20) -#define PINCTRL_PULL2_BANK2_PIN19 (1 << 19) -#define PINCTRL_PULL2_BANK2_PIN18 (1 << 18) -#define PINCTRL_PULL2_BANK2_PIN17 (1 << 17) -#define PINCTRL_PULL2_BANK2_PIN16 (1 << 16) -#define PINCTRL_PULL2_BANK2_PIN15 (1 << 15) -#define PINCTRL_PULL2_BANK2_PIN14 (1 << 14) -#define PINCTRL_PULL2_BANK2_PIN13 (1 << 13) -#define PINCTRL_PULL2_BANK2_PIN12 (1 << 12) -#define PINCTRL_PULL2_BANK2_PIN10 (1 << 10) -#define PINCTRL_PULL2_BANK2_PIN09 (1 << 9) -#define PINCTRL_PULL2_BANK2_PIN08 (1 << 8) -#define PINCTRL_PULL2_BANK2_PIN07 (1 << 7) -#define PINCTRL_PULL2_BANK2_PIN06 (1 << 6) -#define PINCTRL_PULL2_BANK2_PIN05 (1 << 5) -#define PINCTRL_PULL2_BANK2_PIN04 (1 << 4) -#define PINCTRL_PULL2_BANK2_PIN03 (1 << 3) -#define PINCTRL_PULL2_BANK2_PIN02 (1 << 2) -#define PINCTRL_PULL2_BANK2_PIN01 (1 << 1) -#define PINCTRL_PULL2_BANK2_PIN00 (1 << 0) - -#define PINCTRL_PULL3_BANK3_PIN30 (1 << 30) -#define PINCTRL_PULL3_BANK3_PIN29 (1 << 29) -#define PINCTRL_PULL3_BANK3_PIN28 (1 << 28) -#define PINCTRL_PULL3_BANK3_PIN27 (1 << 27) -#define PINCTRL_PULL3_BANK3_PIN26 (1 << 26) -#define PINCTRL_PULL3_BANK3_PIN25 (1 << 25) -#define PINCTRL_PULL3_BANK3_PIN24 (1 << 24) -#define PINCTRL_PULL3_BANK3_PIN23 (1 << 23) -#define PINCTRL_PULL3_BANK3_PIN22 (1 << 22) -#define PINCTRL_PULL3_BANK3_PIN21 (1 << 21) -#define PINCTRL_PULL3_BANK3_PIN20 (1 << 20) -#define PINCTRL_PULL3_BANK3_PIN18 (1 << 18) -#define PINCTRL_PULL3_BANK3_PIN17 (1 << 17) -#define PINCTRL_PULL3_BANK3_PIN16 (1 << 16) -#define PINCTRL_PULL3_BANK3_PIN15 (1 << 15) -#define PINCTRL_PULL3_BANK3_PIN14 (1 << 14) -#define PINCTRL_PULL3_BANK3_PIN13 (1 << 13) -#define PINCTRL_PULL3_BANK3_PIN12 (1 << 12) -#define PINCTRL_PULL3_BANK3_PIN11 (1 << 11) -#define PINCTRL_PULL3_BANK3_PIN10 (1 << 10) -#define PINCTRL_PULL3_BANK3_PIN09 (1 << 9) -#define PINCTRL_PULL3_BANK3_PIN08 (1 << 8) -#define PINCTRL_PULL3_BANK3_PIN07 (1 << 7) -#define PINCTRL_PULL3_BANK3_PIN06 (1 << 6) -#define PINCTRL_PULL3_BANK3_PIN05 (1 << 5) -#define PINCTRL_PULL3_BANK3_PIN04 (1 << 4) -#define PINCTRL_PULL3_BANK3_PIN03 (1 << 3) -#define PINCTRL_PULL3_BANK3_PIN02 (1 << 2) -#define PINCTRL_PULL3_BANK3_PIN01 (1 << 1) -#define PINCTRL_PULL3_BANK3_PIN00 (1 << 0) - -#define PINCTRL_PULL4_BANK4_PIN20 (1 << 20) -#define PINCTRL_PULL4_BANK4_PIN16 (1 << 16) -#define PINCTRL_PULL4_BANK4_PIN15 (1 << 15) -#define PINCTRL_PULL4_BANK4_PIN14 (1 << 14) -#define PINCTRL_PULL4_BANK4_PIN13 (1 << 13) -#define PINCTRL_PULL4_BANK4_PIN12 (1 << 12) -#define PINCTRL_PULL4_BANK4_PIN11 (1 << 11) -#define PINCTRL_PULL4_BANK4_PIN10 (1 << 10) -#define PINCTRL_PULL4_BANK4_PIN09 (1 << 9) -#define PINCTRL_PULL4_BANK4_PIN08 (1 << 8) -#define PINCTRL_PULL4_BANK4_PIN07 (1 << 7) -#define PINCTRL_PULL4_BANK4_PIN06 (1 << 6) -#define PINCTRL_PULL4_BANK4_PIN05 (1 << 5) -#define PINCTRL_PULL4_BANK4_PIN04 (1 << 4) -#define PINCTRL_PULL4_BANK4_PIN03 (1 << 3) -#define PINCTRL_PULL4_BANK4_PIN02 (1 << 2) -#define PINCTRL_PULL4_BANK4_PIN01 (1 << 1) -#define PINCTRL_PULL4_BANK4_PIN00 (1 << 0) - -#define PINCTRL_PULL5_BANK5_PIN26 (1 << 26) -#define PINCTRL_PULL5_BANK5_PIN23 (1 << 23) -#define PINCTRL_PULL5_BANK5_PIN22 (1 << 22) -#define PINCTRL_PULL5_BANK5_PIN21 (1 << 21) -#define PINCTRL_PULL5_BANK5_PIN20 (1 << 20) -#define PINCTRL_PULL5_BANK5_PIN19 (1 << 19) -#define PINCTRL_PULL5_BANK5_PIN18 (1 << 18) -#define PINCTRL_PULL5_BANK5_PIN17 (1 << 17) -#define PINCTRL_PULL5_BANK5_PIN16 (1 << 16) -#define PINCTRL_PULL5_BANK5_PIN15 (1 << 15) -#define PINCTRL_PULL5_BANK5_PIN14 (1 << 14) -#define PINCTRL_PULL5_BANK5_PIN13 (1 << 13) -#define PINCTRL_PULL5_BANK5_PIN12 (1 << 12) -#define PINCTRL_PULL5_BANK5_PIN11 (1 << 11) -#define PINCTRL_PULL5_BANK5_PIN10 (1 << 10) -#define PINCTRL_PULL5_BANK5_PIN09 (1 << 9) -#define PINCTRL_PULL5_BANK5_PIN08 (1 << 8) -#define PINCTRL_PULL5_BANK5_PIN07 (1 << 7) -#define PINCTRL_PULL5_BANK5_PIN06 (1 << 6) -#define PINCTRL_PULL5_BANK5_PIN05 (1 << 5) -#define PINCTRL_PULL5_BANK5_PIN04 (1 << 4) -#define PINCTRL_PULL5_BANK5_PIN03 (1 << 3) -#define PINCTRL_PULL5_BANK5_PIN02 (1 << 2) -#define PINCTRL_PULL5_BANK5_PIN01 (1 << 1) -#define PINCTRL_PULL5_BANK5_PIN00 (1 << 0) - -#define PINCTRL_PULL6_BANK6_PIN24 (1 << 24) -#define PINCTRL_PULL6_BANK6_PIN23 (1 << 23) -#define PINCTRL_PULL6_BANK6_PIN22 (1 << 22) -#define PINCTRL_PULL6_BANK6_PIN21 (1 << 21) -#define PINCTRL_PULL6_BANK6_PIN20 (1 << 20) -#define PINCTRL_PULL6_BANK6_PIN19 (1 << 19) -#define PINCTRL_PULL6_BANK6_PIN18 (1 << 18) -#define PINCTRL_PULL6_BANK6_PIN17 (1 << 17) -#define PINCTRL_PULL6_BANK6_PIN16 (1 << 16) -#define PINCTRL_PULL6_BANK6_PIN14 (1 << 14) -#define PINCTRL_PULL6_BANK6_PIN13 (1 << 13) -#define PINCTRL_PULL6_BANK6_PIN12 (1 << 12) -#define PINCTRL_PULL6_BANK6_PIN11 (1 << 11) -#define PINCTRL_PULL6_BANK6_PIN10 (1 << 10) -#define PINCTRL_PULL6_BANK6_PIN09 (1 << 9) -#define PINCTRL_PULL6_BANK6_PIN08 (1 << 8) -#define PINCTRL_PULL6_BANK6_PIN07 (1 << 7) -#define PINCTRL_PULL6_BANK6_PIN06 (1 << 6) -#define PINCTRL_PULL6_BANK6_PIN05 (1 << 5) -#define PINCTRL_PULL6_BANK6_PIN04 (1 << 4) -#define PINCTRL_PULL6_BANK6_PIN03 (1 << 3) -#define PINCTRL_PULL6_BANK6_PIN02 (1 << 2) -#define PINCTRL_PULL6_BANK6_PIN01 (1 << 1) -#define PINCTRL_PULL6_BANK6_PIN00 (1 << 0) - -#define PINCTRL_DOUT0_DOUT_MASK 0x1fffffff -#define PINCTRL_DOUT0_DOUT_OFFSET 0 - -#define PINCTRL_DOUT1_DOUT_MASK 0xffffffff -#define PINCTRL_DOUT1_DOUT_OFFSET 0 - -#define PINCTRL_DOUT2_DOUT_MASK 0xfffffff -#define PINCTRL_DOUT2_DOUT_OFFSET 0 - -#define PINCTRL_DOUT3_DOUT_MASK 0x7fffffff -#define PINCTRL_DOUT3_DOUT_OFFSET 0 - -#define PINCTRL_DOUT4_DOUT_MASK 0x1fffff -#define PINCTRL_DOUT4_DOUT_OFFSET 0 - -#define PINCTRL_DIN0_DIN_MASK 0x1fffffff -#define PINCTRL_DIN0_DIN_OFFSET 0 - -#define PINCTRL_DIN1_DIN_MASK 0xffffffff -#define PINCTRL_DIN1_DIN_OFFSET 0 - -#define PINCTRL_DIN2_DIN_MASK 0xfffffff -#define PINCTRL_DIN2_DIN_OFFSET 0 - -#define PINCTRL_DIN3_DIN_MASK 0x7fffffff -#define PINCTRL_DIN3_DIN_OFFSET 0 - -#define PINCTRL_DIN4_DIN_MASK 0x1fffff -#define PINCTRL_DIN4_DIN_OFFSET 0 - -#define PINCTRL_DOE0_DOE_MASK 0x1fffffff -#define PINCTRL_DOE0_DOE_OFFSET 0 - -#define PINCTRL_DOE1_DOE_MASK 0xffffffff -#define PINCTRL_DOE1_DOE_OFFSET 0 - -#define PINCTRL_DOE2_DOE_MASK 0xfffffff -#define PINCTRL_DOE2_DOE_OFFSET 0 - -#define PINCTRL_DOE3_DOE_MASK 0x7fffffff -#define PINCTRL_DOE3_DOE_OFFSET 0 - -#define PINCTRL_DOE4_DOE_MASK 0x1fffff -#define PINCTRL_DOE4_DOE_OFFSET 0 - -#define PINCTRL_PIN2IRQ0_PIN2IRQ_MASK 0x1fffffff -#define PINCTRL_PIN2IRQ0_PIN2IRQ_OFFSET 0 - -#define PINCTRL_PIN2IRQ1_PIN2IRQ_MASK 0xffffffff -#define PINCTRL_PIN2IRQ1_PIN2IRQ_OFFSET 0 - -#define PINCTRL_PIN2IRQ2_PIN2IRQ_MASK 0xfffffff -#define PINCTRL_PIN2IRQ2_PIN2IRQ_OFFSET 0 - -#define PINCTRL_PIN2IRQ3_PIN2IRQ_MASK 0x7fffffff -#define PINCTRL_PIN2IRQ3_PIN2IRQ_OFFSET 0 - -#define PINCTRL_PIN2IRQ4_PIN2IRQ_MASK 0x1fffff -#define PINCTRL_PIN2IRQ4_PIN2IRQ_OFFSET 0 - -#define PINCTRL_IRQEN0_IRQEN_MASK 0x1fffffff -#define PINCTRL_IRQEN0_IRQEN_OFFSET 0 - -#define PINCTRL_IRQEN1_IRQEN_MASK 0xffffffff -#define PINCTRL_IRQEN1_IRQEN_OFFSET 0 - -#define PINCTRL_IRQEN2_IRQEN_MASK 0xfffffff -#define PINCTRL_IRQEN2_IRQEN_OFFSET 0 - -#define PINCTRL_IRQEN3_IRQEN_MASK 0x7fffffff -#define PINCTRL_IRQEN3_IRQEN_OFFSET 0 - -#define PINCTRL_IRQEN4_IRQEN_MASK 0x1fffff -#define PINCTRL_IRQEN4_IRQEN_OFFSET 0 - -#define PINCTRL_IRQLEVEL0_IRQLEVEL_MASK 0x1fffffff -#define PINCTRL_IRQLEVEL0_IRQLEVEL_OFFSET 0 - -#define PINCTRL_IRQLEVEL1_IRQLEVEL_MASK 0xffffffff -#define PINCTRL_IRQLEVEL1_IRQLEVEL_OFFSET 0 - -#define PINCTRL_IRQLEVEL2_IRQLEVEL_MASK 0xfffffff -#define PINCTRL_IRQLEVEL2_IRQLEVEL_OFFSET 0 - -#define PINCTRL_IRQLEVEL3_IRQLEVEL_MASK 0x7fffffff -#define PINCTRL_IRQLEVEL3_IRQLEVEL_OFFSET 0 - -#define PINCTRL_IRQLEVEL4_IRQLEVEL_MASK 0x1fffff -#define PINCTRL_IRQLEVEL4_IRQLEVEL_OFFSET 0 - -#define PINCTRL_IRQPOL0_IRQPOL_MASK 0x1fffffff -#define PINCTRL_IRQPOL0_IRQPOL_OFFSET 0 - -#define PINCTRL_IRQPOL1_IRQPOL_MASK 0xffffffff -#define PINCTRL_IRQPOL1_IRQPOL_OFFSET 0 - -#define PINCTRL_IRQPOL2_IRQPOL_MASK 0xfffffff -#define PINCTRL_IRQPOL2_IRQPOL_OFFSET 0 - -#define PINCTRL_IRQPOL3_IRQPOL_MASK 0x7fffffff -#define PINCTRL_IRQPOL3_IRQPOL_OFFSET 0 - -#define PINCTRL_IRQPOL4_IRQPOL_MASK 0x1fffff -#define PINCTRL_IRQPOL4_IRQPOL_OFFSET 0 - -#define PINCTRL_IRQSTAT0_IRQSTAT_MASK 0x1fffffff -#define PINCTRL_IRQSTAT0_IRQSTAT_OFFSET 0 - -#define PINCTRL_IRQSTAT1_IRQSTAT_MASK 0xffffffff -#define PINCTRL_IRQSTAT1_IRQSTAT_OFFSET 0 - -#define PINCTRL_IRQSTAT2_IRQSTAT_MASK 0xfffffff -#define PINCTRL_IRQSTAT2_IRQSTAT_OFFSET 0 - -#define PINCTRL_IRQSTAT3_IRQSTAT_MASK 0x7fffffff -#define PINCTRL_IRQSTAT3_IRQSTAT_OFFSET 0 - -#define PINCTRL_IRQSTAT4_IRQSTAT_MASK 0x1fffff -#define PINCTRL_IRQSTAT4_IRQSTAT_OFFSET 0 - -#define PINCTRL_EMI_ODT_CTRL_ADDRESS_CALIB_MASK (0x3 << 26) -#define PINCTRL_EMI_ODT_CTRL_ADDRESS_CALIB_OFFSET 26 -#define PINCTRL_EMI_ODT_CTRL_ADDRESS_TLOAD_MASK (0x3 << 24) -#define PINCTRL_EMI_ODT_CTRL_ADDRESS_TLOAD_OFFSET 24 -#define PINCTRL_EMI_ODT_CTRL_CONTROL_CALIB_MASK (0x3 << 22) -#define PINCTRL_EMI_ODT_CTRL_CONTROL_CALIB_OFFSET 22 -#define PINCTRL_EMI_ODT_CTRL_CONTROL_TLOAD_MASK (0x3 << 20) -#define PINCTRL_EMI_ODT_CTRL_CONTROL_TLOAD_OFFSET 20 -#define PINCTRL_EMI_ODT_CTRL_DUALPAD_CALIB_MASK (0x3 << 18) -#define PINCTRL_EMI_ODT_CTRL_DUALPAD_CALIB_OFFSET 18 -#define PINCTRL_EMI_ODT_CTRL_DUALPAD_TLOAD_MASK (0x3 << 16) -#define PINCTRL_EMI_ODT_CTRL_DUALPAD_TLOAD_OFFSET 16 -#define PINCTRL_EMI_ODT_CTRL_SLICE3_CALIB_MASK (0x3 << 14) -#define PINCTRL_EMI_ODT_CTRL_SLICE3_CALIB_OFFSET 14 -#define PINCTRL_EMI_ODT_CTRL_SLICE3_TLOAD_MASK (0x3 << 12) -#define PINCTRL_EMI_ODT_CTRL_SLICE3_TLOAD_OFFSET 12 -#define PINCTRL_EMI_ODT_CTRL_SLICE2_CALIB_MASK (0x3 << 10) -#define PINCTRL_EMI_ODT_CTRL_SLICE2_CALIB_OFFSET 10 -#define PINCTRL_EMI_ODT_CTRL_SLICE2_TLOAD_MASK (0x3 << 8) -#define PINCTRL_EMI_ODT_CTRL_SLICE2_TLOAD_OFFSET 8 -#define PINCTRL_EMI_ODT_CTRL_SLICE1_CALIB_MASK (0x3 << 6) -#define PINCTRL_EMI_ODT_CTRL_SLICE1_CALIB_OFFSET 6 -#define PINCTRL_EMI_ODT_CTRL_SLICE1_TLOAD_MASK (0x3 << 4) -#define PINCTRL_EMI_ODT_CTRL_SLICE1_TLOAD_OFFSET 4 -#define PINCTRL_EMI_ODT_CTRL_SLICE0_CALIB_MASK (0x3 << 2) -#define PINCTRL_EMI_ODT_CTRL_SLICE0_CALIB_OFFSET 2 -#define PINCTRL_EMI_ODT_CTRL_SLICE0_TLOAD_MASK (0x3 << 0) -#define PINCTRL_EMI_ODT_CTRL_SLICE0_TLOAD_OFFSET 0 - -#define PINCTRL_EMI_DS_CTRL_DDR_MODE_MASK (0x3 << 16) -#define PINCTRL_EMI_DS_CTRL_DDR_MODE_OFFSET 16 -#define PINCTRL_EMI_DS_CTRL_DDR_MODE_mDDR (0x0 << 16) -#define PINCTRL_EMI_DS_CTRL_DDR_MODE_GPIO (0x1 << 16) -#define PINCTRL_EMI_DS_CTRL_DDR_MODE_LVDDR2 (0x2 << 16) -#define PINCTRL_EMI_DS_CTRL_DDR_MODE_DDR2 (0x3 << 16) -#define PINCTRL_EMI_DS_CTRL_ADDRESS_MA_MASK (0x3 << 12) -#define PINCTRL_EMI_DS_CTRL_ADDRESS_MA_OFFSET 12 -#define PINCTRL_EMI_DS_CTRL_CONTROL_MA_MASK (0x3 << 10) -#define PINCTRL_EMI_DS_CTRL_CONTROL_MA_OFFSET 10 -#define PINCTRL_EMI_DS_CTRL_DUALPAD_MA_MASK (0x3 << 8) -#define PINCTRL_EMI_DS_CTRL_DUALPAD_MA_OFFSET 8 -#define PINCTRL_EMI_DS_CTRL_SLICE3_MA_MASK (0x3 << 6) -#define PINCTRL_EMI_DS_CTRL_SLICE3_MA_OFFSET 6 -#define PINCTRL_EMI_DS_CTRL_SLICE2_MA_MASK (0x3 << 4) -#define PINCTRL_EMI_DS_CTRL_SLICE2_MA_OFFSET 4 -#define PINCTRL_EMI_DS_CTRL_SLICE1_MA_MASK (0x3 << 2) -#define PINCTRL_EMI_DS_CTRL_SLICE1_MA_OFFSET 2 -#define PINCTRL_EMI_DS_CTRL_SLICE0_MA_MASK (0x3 << 0) -#define PINCTRL_EMI_DS_CTRL_SLICE0_MA_OFFSET 0 - -#endif /* __MX28_REGS_PINCTRL_H__ */ diff --git a/arch/arm/include/asm/arch-mx28/regs-power.h b/arch/arm/include/asm/arch-mx28/regs-power.h deleted file mode 100644 index 8eadc6d..0000000 --- a/arch/arm/include/asm/arch-mx28/regs-power.h +++ /dev/null @@ -1,413 +0,0 @@ -/* - * Freescale i.MX28 Power Controller Register Definitions - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA - * - */ - -#ifndef __MX28_REGS_POWER_H__ -#define __MX28_REGS_POWER_H__ - -#include <asm/arch/regs-common.h> - -#ifndef __ASSEMBLY__ -struct mx28_power_regs { - mx28_reg_32(hw_power_ctrl) - mx28_reg_32(hw_power_5vctrl) - mx28_reg_32(hw_power_minpwr) - mx28_reg_32(hw_power_charge) - uint32_t hw_power_vdddctrl; - uint32_t reserved_vddd[3]; - uint32_t hw_power_vddactrl; - uint32_t reserved_vdda[3]; - uint32_t hw_power_vddioctrl; - uint32_t reserved_vddio[3]; - uint32_t hw_power_vddmemctrl; - uint32_t reserved_vddmem[3]; - uint32_t hw_power_dcdc4p2; - uint32_t reserved_dcdc4p2[3]; - uint32_t hw_power_misc; - uint32_t reserved_misc[3]; - uint32_t hw_power_dclimits; - uint32_t reserved_dclimits[3]; - mx28_reg_32(hw_power_loopctrl) - uint32_t hw_power_sts; - uint32_t reserved_sts[3]; - mx28_reg_32(hw_power_speed) - uint32_t hw_power_battmonitor; - uint32_t reserved_battmonitor[3]; - - uint32_t reserved[4]; - - mx28_reg_32(hw_power_reset) - mx28_reg_32(hw_power_debug) - mx28_reg_32(hw_power_thermal) - mx28_reg_32(hw_power_usb1ctrl) - mx28_reg_32(hw_power_special) - mx28_reg_32(hw_power_version) - mx28_reg_32(hw_power_anaclkctrl) - mx28_reg_32(hw_power_refctrl) -}; -#endif - -#define POWER_CTRL_PSWITCH_MID_TRAN (1 << 27) -#define POWER_CTRL_DCDC4P2_BO_IRQ (1 << 24) -#define POWER_CTRL_ENIRQ_DCDC4P2_BO (1 << 23) -#define POWER_CTRL_VDD5V_DROOP_IRQ (1 << 22) -#define POWER_CTRL_ENIRQ_VDD5V_DROOP (1 << 21) -#define POWER_CTRL_PSWITCH_IRQ (1 << 20) -#define POWER_CTRL_PSWITCH_IRQ_SRC (1 << 19) -#define POWER_CTRL_POLARITY_PSWITCH (1 << 18) -#define POWER_CTRL_ENIRQ_PSWITCH (1 << 17) -#define POWER_CTRL_POLARITY_DC_OK (1 << 16) -#define POWER_CTRL_DC_OK_IRQ (1 << 15) -#define POWER_CTRL_ENIRQ_DC_OK (1 << 14) -#define POWER_CTRL_BATT_BO_IRQ (1 << 13) -#define POWER_CTRL_ENIRQ_BATT_BO (1 << 12) -#define POWER_CTRL_VDDIO_BO_IRQ (1 << 11) -#define POWER_CTRL_ENIRQ_VDDIO_BO (1 << 10) -#define POWER_CTRL_VDDA_BO_IRQ (1 << 9) -#define POWER_CTRL_ENIRQ_VDDA_BO (1 << 8) -#define POWER_CTRL_VDDD_BO_IRQ (1 << 7) -#define POWER_CTRL_ENIRQ_VDDD_BO (1 << 6) -#define POWER_CTRL_POLARITY_VBUSVALID (1 << 5) -#define POWER_CTRL_VBUS_VALID_IRQ (1 << 4) -#define POWER_CTRL_ENIRQ_VBUS_VALID (1 << 3) -#define POWER_CTRL_POLARITY_VDD5V_GT_VDDIO (1 << 2) -#define POWER_CTRL_VDD5V_GT_VDDIO_IRQ (1 << 1) -#define POWER_CTRL_ENIRQ_VDD5V_GT_VDDIO (1 << 0) - -#define POWER_5VCTRL_VBUSDROOP_TRSH_MASK (0x3 << 30) -#define POWER_5VCTRL_VBUSDROOP_TRSH_OFFSET 30 -#define POWER_5VCTRL_VBUSDROOP_TRSH_4V3 (0x0 << 30) -#define POWER_5VCTRL_VBUSDROOP_TRSH_4V4 (0x1 << 30) -#define POWER_5VCTRL_VBUSDROOP_TRSH_4V5 (0x2 << 30) -#define POWER_5VCTRL_VBUSDROOP_TRSH_4V7 (0x3 << 30) -#define POWER_5VCTRL_HEADROOM_ADJ_MASK (0x7 << 24) -#define POWER_5VCTRL_HEADROOM_ADJ_OFFSET 24 -#define POWER_5VCTRL_PWD_CHARGE_4P2_MASK (0x3 << 20) -#define POWER_5VCTRL_PWD_CHARGE_4P2_OFFSET 20 -#define POWER_5VCTRL_CHARGE_4P2_ILIMIT_MASK (0x3f << 12) -#define POWER_5VCTRL_CHARGE_4P2_ILIMIT_OFFSET 12 -#define POWER_5VCTRL_VBUSVALID_TRSH_MASK (0x7 << 8) -#define POWER_5VCTRL_VBUSVALID_TRSH_OFFSET 8 -#define POWER_5VCTRL_VBUSVALID_TRSH_2V9 (0x0 << 8) -#define POWER_5VCTRL_VBUSVALID_TRSH_4V0 (0x1 << 8) -#define POWER_5VCTRL_VBUSVALID_TRSH_4V1 (0x2 << 8) -#define POWER_5VCTRL_VBUSVALID_TRSH_4V2 (0x3 << 8) -#define POWER_5VCTRL_VBUSVALID_TRSH_4V3 (0x4 << 8) -#define POWER_5VCTRL_VBUSVALID_TRSH_4V4 (0x5 << 8) -#define POWER_5VCTRL_VBUSVALID_TRSH_4V5 (0x6 << 8) -#define POWER_5VCTRL_VBUSVALID_TRSH_4V6 (0x7 << 8) -#define POWER_5VCTRL_PWDN_5VBRNOUT (1 << 7) -#define POWER_5VCTRL_ENABLE_LINREG_ILIMIT (1 << 6) -#define POWER_5VCTRL_DCDC_XFER (1 << 5) -#define POWER_5VCTRL_VBUSVALID_5VDETECT (1 << 4) -#define POWER_5VCTRL_VBUSVALID_TO_B (1 << 3) -#define POWER_5VCTRL_ILIMIT_EQ_ZERO (1 << 2) -#define POWER_5VCTRL_PWRUP_VBUS_CMPS (1 << 1) -#define POWER_5VCTRL_ENABLE_DCDC (1 << 0) - -#define POWER_MINPWR_LOWPWR_4P2 (1 << 14) -#define POWER_MINPWR_PWD_BO (1 << 12) -#define POWER_MINPWR_USE_VDDXTAL_VBG (1 << 11) -#define POWER_MINPWR_PWD_ANA_CMPS (1 << 10) -#define POWER_MINPWR_ENABLE_OSC (1 << 9) -#define POWER_MINPWR_SELECT_OSC (1 << 8) -#define POWER_MINPWR_FBG_OFF (1 << 7) -#define POWER_MINPWR_DOUBLE_FETS (1 << 6) -#define POWER_MINPWR_HALFFETS (1 << 5) -#define POWER_MINPWR_LESSANA_I (1 << 4) -#define POWER_MINPWR_PWD_XTAL24 (1 << 3) -#define POWER_MINPWR_DC_STOPCLK (1 << 2) -#define POWER_MINPWR_EN_DC_PFM (1 << 1) -#define POWER_MINPWR_DC_HALFCLK (1 << 0) - -#define POWER_CHARGE_ADJ_VOLT_MASK (0x7 << 24) -#define POWER_CHARGE_ADJ_VOLT_OFFSET 24 -#define POWER_CHARGE_ADJ_VOLT_M025P (0x1 << 24) -#define POWER_CHARGE_ADJ_VOLT_P050P (0x2 << 24) -#define POWER_CHARGE_ADJ_VOLT_M075P (0x3 << 24) -#define POWER_CHARGE_ADJ_VOLT_P025P (0x4 << 24) -#define POWER_CHARGE_ADJ_VOLT_M050P (0x5 << 24) -#define POWER_CHARGE_ADJ_VOLT_P075P (0x6 << 24) -#define POWER_CHARGE_ADJ_VOLT_M100P (0x7 << 24) -#define POWER_CHARGE_ENABLE_LOAD (1 << 22) -#define POWER_CHARGE_ENABLE_FAULT_DETECT (1 << 20) -#define POWER_CHARGE_CHRG_STS_OFF (1 << 19) -#define POWER_CHARGE_LIION_4P1 (1 << 18) -#define POWER_CHARGE_PWD_BATTCHRG (1 << 16) -#define POWER_CHARGE_ENABLE_CHARGER_USB1 (1 << 13) -#define POWER_CHARGE_ENABLE_CHARGER_USB0 (1 << 12) -#define POWER_CHARGE_STOP_ILIMIT_MASK (0xf << 8) -#define POWER_CHARGE_STOP_ILIMIT_OFFSET 8 -#define POWER_CHARGE_STOP_ILIMIT_10MA (0x1 << 8) -#define POWER_CHARGE_STOP_ILIMIT_20MA (0x2 << 8) -#define POWER_CHARGE_STOP_ILIMIT_50MA (0x4 << 8) -#define POWER_CHARGE_STOP_ILIMIT_100MA (0x8 << 8) -#define POWER_CHARGE_BATTCHRG_I_MASK 0x3f -#define POWER_CHARGE_BATTCHRG_I_OFFSET 0 -#define POWER_CHARGE_BATTCHRG_I_10MA 0x01 -#define POWER_CHARGE_BATTCHRG_I_20MA 0x02 -#define POWER_CHARGE_BATTCHRG_I_50MA 0x04 -#define POWER_CHARGE_BATTCHRG_I_100MA 0x08 -#define POWER_CHARGE_BATTCHRG_I_200MA 0x10 -#define POWER_CHARGE_BATTCHRG_I_400MA 0x20 - -#define POWER_VDDDCTRL_ADJTN_MASK (0xf << 28) -#define POWER_VDDDCTRL_ADJTN_OFFSET 28 -#define POWER_VDDDCTRL_PWDN_BRNOUT (1 << 23) -#define POWER_VDDDCTRL_DISABLE_STEPPING (1 << 22) -#define POWER_VDDDCTRL_ENABLE_LINREG (1 << 21) -#define POWER_VDDDCTRL_DISABLE_FET (1 << 20) -#define POWER_VDDDCTRL_LINREG_OFFSET_MASK (0x3 << 16) -#define POWER_VDDDCTRL_LINREG_OFFSET_OFFSET 16 -#define POWER_VDDDCTRL_LINREG_OFFSET_0STEPS (0x0 << 16) -#define POWER_VDDDCTRL_LINREG_OFFSET_1STEPS_ABOVE (0x1 << 16) -#define POWER_VDDDCTRL_LINREG_OFFSET_1STEPS_BELOW (0x2 << 16) -#define POWER_VDDDCTRL_LINREG_OFFSET_2STEPS_BELOW (0x3 << 16) -#define POWER_VDDDCTRL_BO_OFFSET_MASK (0x7 << 8) -#define POWER_VDDDCTRL_BO_OFFSET_OFFSET 8 -#define POWER_VDDDCTRL_TRG_MASK 0x1f -#define POWER_VDDDCTRL_TRG_OFFSET 0 - -#define POWER_VDDACTRL_PWDN_BRNOUT (1 << 19) -#define POWER_VDDACTRL_DISABLE_STEPPING (1 << 18) -#define POWER_VDDACTRL_ENABLE_LINREG (1 << 17) -#define POWER_VDDACTRL_DISABLE_FET (1 << 16) -#define POWER_VDDACTRL_LINREG_OFFSET_MASK (0x3 << 12) -#define POWER_VDDACTRL_LINREG_OFFSET_OFFSET 12 -#define POWER_VDDACTRL_LINREG_OFFSET_0STEPS (0x0 << 12) -#define POWER_VDDACTRL_LINREG_OFFSET_1STEPS_ABOVE (0x1 << 12) -#define POWER_VDDACTRL_LINREG_OFFSET_1STEPS_BELOW (0x2 << 12) -#define POWER_VDDACTRL_LINREG_OFFSET_2STEPS_BELOW (0x3 << 12) -#define POWER_VDDACTRL_BO_OFFSET_MASK (0x7 << 8) -#define POWER_VDDACTRL_BO_OFFSET_OFFSET 8 -#define POWER_VDDACTRL_TRG_MASK 0x1f -#define POWER_VDDACTRL_TRG_OFFSET 0 - -#define POWER_VDDIOCTRL_ADJTN_MASK (0xf << 20) -#define POWER_VDDIOCTRL_ADJTN_OFFSET 20 -#define POWER_VDDIOCTRL_PWDN_BRNOUT (1 << 18) -#define POWER_VDDIOCTRL_DISABLE_STEPPING (1 << 17) -#define POWER_VDDIOCTRL_DISABLE_FET (1 << 16) -#define POWER_VDDIOCTRL_LINREG_OFFSET_MASK (0x3 << 12) -#define POWER_VDDIOCTRL_LINREG_OFFSET_OFFSET 12 -#define POWER_VDDIOCTRL_LINREG_OFFSET_0STEPS (0x0 << 12) -#define POWER_VDDIOCTRL_LINREG_OFFSET_1STEPS_ABOVE (0x1 << 12) -#define POWER_VDDIOCTRL_LINREG_OFFSET_1STEPS_BELOW (0x2 << 12) -#define POWER_VDDIOCTRL_LINREG_OFFSET_2STEPS_BELOW (0x3 << 12) -#define POWER_VDDIOCTRL_BO_OFFSET_MASK (0x7 << 8) -#define POWER_VDDIOCTRL_BO_OFFSET_OFFSET 8 -#define POWER_VDDIOCTRL_TRG_MASK 0x1f -#define POWER_VDDIOCTRL_TRG_OFFSET 0 - -#define POWER_VDDMEMCTRL_PULLDOWN_ACTIVE (1 << 10) -#define POWER_VDDMEMCTRL_ENABLE_ILIMIT (1 << 9) -#define POWER_VDDMEMCTRL_ENABLE_LINREG (1 << 8) -#define POWER_VDDMEMCTRL_BO_OFFSET_MASK (0x7 << 5) -#define POWER_VDDMEMCTRL_BO_OFFSET_OFFSET 5 -#define POWER_VDDMEMCTRL_TRG_MASK 0x1f -#define POWER_VDDMEMCTRL_TRG_OFFSET 0 - -#define POWER_DCDC4P2_DROPOUT_CTRL_MASK (0xf << 28) -#define POWER_DCDC4P2_DROPOUT_CTRL_OFFSET 28 -#define POWER_DCDC4P2_DROPOUT_CTRL_200MV (0x3 << 30) -#define POWER_DCDC4P2_DROPOUT_CTRL_100MV (0x2 << 30) -#define POWER_DCDC4P2_DROPOUT_CTRL_50MV (0x1 << 30) -#define POWER_DCDC4P2_DROPOUT_CTRL_25MV (0x0 << 30) -#define POWER_DCDC4P2_DROPOUT_CTRL_SRC_4P2 (0x0 << 28) -#define POWER_DCDC4P2_DROPOUT_CTRL_SRC_4P2_LT_BATT (0x1 << 28) -#define POWER_DCDC4P2_DROPOUT_CTRL_SRC_SEL (0x2 << 28) -#define POWER_DCDC4P2_ISTEAL_THRESH_MASK (0x3 << 24) -#define POWER_DCDC4P2_ISTEAL_THRESH_OFFSET 24 -#define POWER_DCDC4P2_ENABLE_4P2 (1 << 23) -#define POWER_DCDC4P2_ENABLE_DCDC (1 << 22) -#define POWER_DCDC4P2_HYST_DIR (1 << 21) -#define POWER_DCDC4P2_HYST_THRESH (1 << 20) -#define POWER_DCDC4P2_TRG_MASK (0x7 << 16) -#define POWER_DCDC4P2_TRG_OFFSET 16 -#define POWER_DCDC4P2_TRG_4V2 (0x0 << 16) -#define POWER_DCDC4P2_TRG_4V1 (0x1 << 16) -#define POWER_DCDC4P2_TRG_4V0 (0x2 << 16) -#define POWER_DCDC4P2_TRG_3V9 (0x3 << 16) -#define POWER_DCDC4P2_TRG_BATT (0x4 << 16) -#define POWER_DCDC4P2_BO_MASK (0x1f << 8) -#define POWER_DCDC4P2_BO_OFFSET 8 -#define POWER_DCDC4P2_CMPTRIP_MASK 0x1f -#define POWER_DCDC4P2_CMPTRIP_OFFSET 0 - -#define POWER_MISC_FREQSEL_MASK (0x7 << 4) -#define POWER_MISC_FREQSEL_OFFSET 4 -#define POWER_MISC_FREQSEL_20MHZ (0x1 << 4) -#define POWER_MISC_FREQSEL_24MHZ (0x2 << 4) -#define POWER_MISC_FREQSEL_19MHZ (0x3 << 4) -#define POWER_MISC_FREQSEL_14MHZ (0x4 << 4) -#define POWER_MISC_FREQSEL_18MHZ (0x5 << 4) -#define POWER_MISC_FREQSEL_21MHZ (0x6 << 4) -#define POWER_MISC_FREQSEL_17MHZ (0x7 << 4) -#define POWER_MISC_DISABLE_FET_BO_LOGIC (1 << 3) -#define POWER_MISC_DELAY_TIMING (1 << 2) -#define POWER_MISC_TEST (1 << 1) -#define POWER_MISC_SEL_PLLCLK (1 << 0) - -#define POWER_DCLIMITS_POSLIMIT_BUCK_MASK (0x7f << 8) -#define POWER_DCLIMITS_POSLIMIT_BUCK_OFFSET 8 -#define POWER_DCLIMITS_NEGLIMIT_MASK 0x7f -#define POWER_DCLIMITS_NETLIMIT_OFFSET 0 - -#define POWER_LOOPCTRL_TOGGLE_DIF (1 << 20) -#define POWER_LOOPCTRL_HYST_SIGN (1 << 19) -#define POWER_LOOPCTRL_EN_CM_HYST (1 << 18) -#define POWER_LOOPCTRL_EN_DF_HYST (1 << 17) -#define POWER_LOOPCTRL_CM_HYST_THRESH (1 << 16) -#define POWER_LOOPCTRL_DF_HYST_THRESH (1 << 15) -#define POWER_LOOPCTRL_RCSCALE_THRESH (1 << 14) -#define POWER_LOOPCTRL_EN_RCSCALE_MASK (0x3 << 12) -#define POWER_LOOPCTRL_EN_RCSCALE_OFFSET 12 -#define POWER_LOOPCTRL_EN_RCSCALE_DIS (0x0 << 12) -#define POWER_LOOPCTRL_EN_RCSCALE_2X (0x1 << 12) -#define POWER_LOOPCTRL_EN_RCSCALE_4X (0x2 << 12) -#define POWER_LOOPCTRL_EN_RCSCALE_8X (0x3 << 12) -#define POWER_LOOPCTRL_DC_FF_MASK (0x7 << 8) -#define POWER_LOOPCTRL_DC_FF_OFFSET 8 -#define POWER_LOOPCTRL_DC_R_MASK (0xf << 4) -#define POWER_LOOPCTRL_DC_R_OFFSET 4 -#define POWER_LOOPCTRL_DC_C_MASK 0x3 -#define POWER_LOOPCTRL_DC_C_OFFSET 0 -#define POWER_LOOPCTRL_DC_C_MAX 0x0 -#define POWER_LOOPCTRL_DC_C_2X 0x1 -#define POWER_LOOPCTRL_DC_C_4X 0x2 -#define POWER_LOOPCTRL_DC_C_MIN 0x3 - -#define POWER_STS_PWRUP_SOURCE_MASK (0x3f << 24) -#define POWER_STS_PWRUP_SOURCE_OFFSET 24 -#define POWER_STS_PWRUP_SOURCE_5V (0x20 << 24) -#define POWER_STS_PWRUP_SOURCE_RTC (0x10 << 24) -#define POWER_STS_PWRUP_SOURCE_PSWITCH_HIGH (0x02 << 24) -#define POWER_STS_PWRUP_SOURCE_PSWITCH_MID (0x01 << 24) -#define POWER_STS_PSWITCH_MASK (0x3 << 20) -#define POWER_STS_PSWITCH_OFFSET 20 -#define POWER_STS_THERMAL_WARNING (1 << 19) -#define POWER_STS_VDDMEM_BO (1 << 18) -#define POWER_STS_AVALID0_STATUS (1 << 17) -#define POWER_STS_BVALID0_STATUS (1 << 16) -#define POWER_STS_VBUSVALID0_STATUS (1 << 15) -#define POWER_STS_SESSEND0_STATUS (1 << 14) -#define POWER_STS_BATT_BO (1 << 13) -#define POWER_STS_VDD5V_FAULT (1 << 12) -#define POWER_STS_CHRGSTS (1 << 11) -#define POWER_STS_DCDC_4P2_BO (1 << 10) -#define POWER_STS_DC_OK (1 << 9) -#define POWER_STS_VDDIO_BO (1 << 8) -#define POWER_STS_VDDA_BO (1 << 7) -#define POWER_STS_VDDD_BO (1 << 6) -#define POWER_STS_VDD5V_GT_VDDIO (1 << 5) -#define POWER_STS_VDD5V_DROOP (1 << 4) -#define POWER_STS_AVALID0 (1 << 3) -#define POWER_STS_BVALID0 (1 << 2) -#define POWER_STS_VBUSVALID0 (1 << 1) -#define POWER_STS_SESSEND0 (1 << 0) - -#define POWER_SPEED_STATUS_MASK (0xffff << 8) -#define POWER_SPEED_STATUS_OFFSET 8 -#define POWER_SPEED_STATUS_SEL_MASK (0x3 << 6) -#define POWER_SPEED_STATUS_SEL_OFFSET 6 -#define POWER_SPEED_STATUS_SEL_DCDC_STAT (0x0 << 6) -#define POWER_SPEED_STATUS_SEL_CORE_STAT (0x1 << 6) -#define POWER_SPEED_STATUS_SEL_ARM_STAT (0x2 << 6) -#define POWER_SPEED_CTRL_MASK 0x3 -#define POWER_SPEED_CTRL_OFFSET 0 -#define POWER_SPEED_CTRL_SS_OFF 0x0 -#define POWER_SPEED_CTRL_SS_ON 0x1 -#define POWER_SPEED_CTRL_SS_ENABLE 0x3 - -#define POWER_BATTMONITOR_BATT_VAL_MASK (0x3ff << 16) -#define POWER_BATTMONITOR_BATT_VAL_OFFSET 16 -#define POWER_BATTMONITOR_PWDN_BATTBRNOUT_5VDETECT_EN (1 << 11) -#define POWER_BATTMONITOR_EN_BATADJ (1 << 10) -#define POWER_BATTMONITOR_PWDN_BATTBRNOUT (1 << 9) -#define POWER_BATTMONITOR_BRWNOUT_PWD (1 << 8) -#define POWER_BATTMONITOR_BRWNOUT_LVL_MASK 0x1f -#define POWER_BATTMONITOR_BRWNOUT_LVL_OFFSET 0 - -#define POWER_RESET_UNLOCK_MASK (0xffff << 16) -#define POWER_RESET_UNLOCK_OFFSET 16 -#define POWER_RESET_UNLOCK_KEY (0x3e77 << 16) -#define POWER_RESET_FASTFALL_PSWITCH_OFF (1 << 2) -#define POWER_RESET_PWD_OFF (1 << 1) -#define POWER_RESET_PWD (1 << 0) - -#define POWER_DEBUG_VBUSVALIDPIOLOCK (1 << 3) -#define POWER_DEBUG_AVALIDPIOLOCK (1 << 2) -#define POWER_DEBUG_BVALIDPIOLOCK (1 << 1) -#define POWER_DEBUG_SESSENDPIOLOCK (1 << 0) - -#define POWER_THERMAL_TEST (1 << 8) -#define POWER_THERMAL_PWD (1 << 7) -#define POWER_THERMAL_LOW_POWER (1 << 6) -#define POWER_THERMAL_OFFSET_ADJ_MASK (0x3 << 4) -#define POWER_THERMAL_OFFSET_ADJ_OFFSET 4 -#define POWER_THERMAL_OFFSET_ADJ_ENABLE (1 << 3) -#define POWER_THERMAL_TEMP_THRESHOLD_MASK 0x7 -#define POWER_THERMAL_TEMP_THRESHOLD_OFFSET 0 - -#define POWER_USB1CTRL_AVALID1 (1 << 3) -#define POWER_USB1CTRL_BVALID1 (1 << 2) -#define POWER_USB1CTRL_VBUSVALID1 (1 << 1) -#define POWER_USB1CTRL_SESSEND1 (1 << 0) - -#define POWER_SPECIAL_TEST_MASK 0xffffffff -#define POWER_SPECIAL_TEST_OFFSET 0 - -#define POWER_VERSION_MAJOR_MASK (0xff << 24) -#define POWER_VERSION_MAJOR_OFFSET 24 -#define POWER_VERSION_MINOR_MASK (0xff << 16) -#define POWER_VERSION_MINOR_OFFSET 16 -#define POWER_VERSION_STEP_MASK 0xffff -#define POWER_VERSION_STEP_OFFSET 0 - -#define POWER_ANACLKCTRL_CLKGATE_0 (1 << 31) -#define POWER_ANACLKCTRL_OUTDIV_MASK (0x7 << 28) -#define POWER_ANACLKCTRL_OUTDIV_OFFSET 28 -#define POWER_ANACLKCTRL_INVERT_OUTCLK (1 << 27) -#define POWER_ANACLKCTRL_CLKGATE_I (1 << 26) -#define POWER_ANACLKCTRL_DITHER_OFF (1 << 10) -#define POWER_ANACLKCTRL_SLOW_DITHER (1 << 9) -#define POWER_ANACLKCTRL_INVERT_INCLK (1 << 8) -#define POWER_ANACLKCTRL_INCLK_SHIFT_MASK (0x3 << 4) -#define POWER_ANACLKCTRL_INCLK_SHIFT_OFFSET 4 -#define POWER_ANACLKCTRL_INDIV_MASK 0x7 -#define POWER_ANACLKCTRL_INDIV_OFFSET 0 - -#define POWER_REFCTRL_FASTSETTLING (1 << 26) -#define POWER_REFCTRL_RAISE_REF (1 << 25) -#define POWER_REFCTRL_XTAL_BGR_BIAS (1 << 24) -#define POWER_REFCTRL_VBG_ADJ_MASK (0x7 << 20) -#define POWER_REFCTRL_VBG_ADJ_OFFSET 20 -#define POWER_REFCTRL_LOW_PWR (1 << 19) -#define POWER_REFCTRL_BIAS_CTRL_MASK (0x3 << 16) -#define POWER_REFCTRL_BIAS_CTRL_OFFSET 16 -#define POWER_REFCTRL_VDDXTAL_TO_VDDD (1 << 14) -#define POWER_REFCTRL_ADJ_ANA (1 << 13) -#define POWER_REFCTRL_ADJ_VAG (1 << 12) -#define POWER_REFCTRL_ANA_REFVAL_MASK (0xf << 8) -#define POWER_REFCTRL_ANA_REFVAL_OFFSET 8 -#define POWER_REFCTRL_VAG_VAL_MASK (0xf << 4) -#define POWER_REFCTRL_VAG_VAL_OFFSET 4 - -#endif /* __MX28_REGS_POWER_H__ */ diff --git a/arch/arm/include/asm/arch-mx28/regs-rtc.h b/arch/arm/include/asm/arch-mx28/regs-rtc.h deleted file mode 100644 index e605a03..0000000 --- a/arch/arm/include/asm/arch-mx28/regs-rtc.h +++ /dev/null @@ -1,147 +0,0 @@ -/* - * Freescale i.MX28 RTC Register Definitions - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * on behalf of DENX Software Engineering GmbH - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA - * - */ - -#ifndef __MX28_REGS_RTC_H__ -#define __MX28_REGS_RTC_H__ - -#include <asm/arch/regs-common.h> - -#ifndef __ASSEMBLY__ -struct mx28_rtc_regs { - mx28_reg_32(hw_rtc_ctrl) - mx28_reg_32(hw_rtc_stat) - mx28_reg_32(hw_rtc_milliseconds) - mx28_reg_32(hw_rtc_seconds) - mx28_reg_32(hw_rtc_rtc_alarm) - mx28_reg_32(hw_rtc_watchdog) - mx28_reg_32(hw_rtc_persistent0) - mx28_reg_32(hw_rtc_persistent1) - mx28_reg_32(hw_rtc_persistent2) - mx28_reg_32(hw_rtc_persistent3) - mx28_reg_32(hw_rtc_persistent4) - mx28_reg_32(hw_rtc_persistent5) - mx28_reg_32(hw_rtc_debug) - mx28_reg_32(hw_rtc_version) -}; -#endif - -#define RTC_CTRL_SFTRST (1 << 31) -#define RTC_CTRL_CLKGATE (1 << 30) -#define RTC_CTRL_SUPPRESS_COPY2ANALOG (1 << 6) -#define RTC_CTRL_FORCE_UPDATE (1 << 5) -#define RTC_CTRL_WATCHDOGEN (1 << 4) -#define RTC_CTRL_ONEMSEC_IRQ (1 << 3) -#define RTC_CTRL_ALARM_IRQ (1 << 2) -#define RTC_CTRL_ONEMSEC_IRQ_EN (1 << 1) -#define RTC_CTRL_ALARM_IRQ_EN (1 << 0) - -#define RTC_STAT_RTC_PRESENT (1 << 31) -#define RTC_STAT_ALARM_PRESENT (1 << 30) -#define RTC_STAT_WATCHDOG_PRESENT (1 << 29) -#define RTC_STAT_XTAL32000_PRESENT (1 << 28) -#define RTC_STAT_XTAL32768_PRESENT (1 << 27) -#define RTC_STAT_STALE_REGS_MASK (0xff << 16) -#define RTC_STAT_STALE_REGS_OFFSET 16 -#define RTC_STAT_NEW_REGS_MASK (0xff << 8) -#define RTC_STAT_NEW_REGS_OFFSET 8 - -#define RTC_MILLISECONDS_COUNT_MASK 0xffffffff -#define RTC_MILLISECONDS_COUNT_OFFSET 0 - -#define RTC_SECONDS_COUNT_MASK 0xffffffff -#define RTC_SECONDS_COUNT_OFFSET 0 - -#define RTC_ALARM_VALUE_MASK 0xffffffff -#define RTC_ALARM_VALUE_OFFSET 0 - -#define RTC_WATCHDOG_COUNT_MASK 0xffffffff -#define RTC_WATCHDOG_COUNT_OFFSET 0 - -#define RTC_PERSISTENT0_ADJ_POSLIMITBUCK_MASK (0xf << 28) -#define RTC_PERSISTENT0_ADJ_POSLIMITBUCK_OFFSET 28 -#define RTC_PERSISTENT0_ADJ_POSLIMITBUCK_2V83 (0x0 << 28) -#define RTC_PERSISTENT0_ADJ_POSLIMITBUCK_2V78 (0x1 << 28) -#define RTC_PERSISTENT0_ADJ_POSLIMITBUCK_2V73 (0x2 << 28) -#define RTC_PERSISTENT0_ADJ_POSLIMITBUCK_2V68 (0x3 << 28) -#define RTC_PERSISTENT0_ADJ_POSLIMITBUCK_2V62 (0x4 << 28) -#define RTC_PERSISTENT0_ADJ_POSLIMITBUCK_2V57 (0x5 << 28) -#define RTC_PERSISTENT0_ADJ_POSLIMITBUCK_2V52 (0x6 << 28) -#define RTC_PERSISTENT0_ADJ_POSLIMITBUCK_2V48 (0x7 << 28) -#define RTC_PERSISTENT0_EXTERNAL_RESET (1 << 21) -#define RTC_PERSISTENT0_THERMAL_RESET (1 << 20) -#define RTC_PERSISTENT0_ENABLE_LRADC_PWRUP (1 << 18) -#define RTC_PERSISTENT0_AUTO_RESTART (1 << 17) -#define RTC_PERSISTENT0_DISABLE_PSWITCH (1 << 16) -#define RTC_PERSISTENT0_LOWERBIAS_MASK (0xf << 14) -#define RTC_PERSISTENT0_LOWERBIAS_OFFSET 14 -#define RTC_PERSISTENT0_LOWERBIAS_NOMINAL (0x0 << 14) -#define RTC_PERSISTENT0_LOWERBIAS_M25P (0x1 << 14) -#define RTC_PERSISTENT0_LOWERBIAS_M50P (0x3 << 14) -#define RTC_PERSISTENT0_DISABLE_XTALOK (1 << 13) -#define RTC_PERSISTENT0_MSEC_RES_MASK (0x1f << 8) -#define RTC_PERSISTENT0_MSEC_RES_OFFSET 8 -#define RTC_PERSISTENT0_MSEC_RES_1MS (0x01 << 8) -#define RTC_PERSISTENT0_MSEC_RES_2MS (0x02 << 8) -#define RTC_PERSISTENT0_MSEC_RES_4MS (0x04 << 8) -#define RTC_PERSISTENT0_MSEC_RES_8MS (0x08 << 8) -#define RTC_PERSISTENT0_MSEC_RES_16MS (0x10 << 8) -#define RTC_PERSISTENT0_ALARM_WAKE (1 << 7) -#define RTC_PERSISTENT0_XTAL32_FREQ (1 << 6) -#define RTC_PERSISTENT0_XTAL32KHZ_PWRUP (1 << 5) -#define RTC_PERSISTENT0_XTAL24KHZ_PWRUP (1 << 4) -#define RTC_PERSISTENT0_LCK_SECS (1 << 3) -#define RTC_PERSISTENT0_ALARM_EN (1 << 2) -#define RTC_PERSISTENT0_ALARM_WAKE_EN (1 << 1) -#define RTC_PERSISTENT0_CLOCKSOURCE (1 << 0) - -#define RTC_PERSISTENT1_GENERAL_MASK 0xffffffff -#define RTC_PERSISTENT1_GENERAL_OFFSET 0 -#define RTC_PERSISTENT1_GENERAL_OTG_ALT_ROLE 0x0080 -#define RTC_PERSISTENT1_GENERAL_OTG_HNP 0x0100 -#define RTC_PERSISTENT1_GENERAL_USB_LPM 0x0200 -#define RTC_PERSISTENT1_GENERAL_SKIP_CHECKDISK 0x0400 -#define RTC_PERSISTENT1_GENERAL_USB_BOOT_PLAYER 0x0800 -#define RTC_PERSISTENT1_GENERAL_ENUM_500MA_2X 0x1000 - -#define RTC_PERSISTENT2_GENERAL_MASK 0xffffffff -#define RTC_PERSISTENT2_GENERAL_OFFSET 0 - -#define RTC_PERSISTENT3_GENERAL_MASK 0xffffffff -#define RTC_PERSISTENT3_GENERAL_OFFSET 0 - -#define RTC_PERSISTENT4_GENERAL_MASK 0xffffffff -#define RTC_PERSISTENT4_GENERAL_OFFSET 0 - -#define RTC_PERSISTENT5_GENERAL_MASK 0xffffffff -#define RTC_PERSISTENT5_GENERAL_OFFSET 0 - -#define RTC_DEBUG_WATCHDOG_RESET_MASK (1 << 1) -#define RTC_DEBUG_WATCHDOG_RESET (1 << 0) - -#define RTC_VERSION_MAJOR_MASK (0xff << 24) -#define RTC_VERSION_MAJOR_OFFSET 24 -#define RTC_VERSION_MINOR_MASK (0xff << 16) -#define RTC_VERSION_MINOR_OFFSET 16 -#define RTC_VERSION_STEP_MASK 0xffff -#define RTC_VERSION_STEP_OFFSET 0 - -#endif /* __MX28_REGS_RTC_H__ */ diff --git a/arch/arm/include/asm/arch-mx28/regs-ssp.h b/arch/arm/include/asm/arch-mx28/regs-ssp.h deleted file mode 100644 index be71d48..0000000 --- a/arch/arm/include/asm/arch-mx28/regs-ssp.h +++ /dev/null @@ -1,349 +0,0 @@ -/* - * Freescale i.MX28 SSP Register Definitions - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * - * Based on code from LTIB: - * Copyright 2008-2010 Freescale Semiconductor, Inc. All Rights Reserved. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA - * - */ - -#ifndef __MX28_REGS_SSP_H__ -#define __MX28_REGS_SSP_H__ - -#include <asm/arch/regs-common.h> - -#ifndef __ASSEMBLY__ -struct mx28_ssp_regs { - mx28_reg_32(hw_ssp_ctrl0) - mx28_reg_32(hw_ssp_cmd0) - mx28_reg_32(hw_ssp_cmd1) - mx28_reg_32(hw_ssp_xfer_size) - mx28_reg_32(hw_ssp_block_size) - mx28_reg_32(hw_ssp_compref) - mx28_reg_32(hw_ssp_compmask) - mx28_reg_32(hw_ssp_timing) - mx28_reg_32(hw_ssp_ctrl1) - mx28_reg_32(hw_ssp_data) - mx28_reg_32(hw_ssp_sdresp0) - mx28_reg_32(hw_ssp_sdresp1) - mx28_reg_32(hw_ssp_sdresp2) - mx28_reg_32(hw_ssp_sdresp3) - mx28_reg_32(hw_ssp_ddr_ctrl) - mx28_reg_32(hw_ssp_dll_ctrl) - mx28_reg_32(hw_ssp_status) - mx28_reg_32(hw_ssp_dll_sts) - mx28_reg_32(hw_ssp_debug) - mx28_reg_32(hw_ssp_version) -}; -#endif - -#define SSP_CTRL0_SFTRST (1 << 31) -#define SSP_CTRL0_CLKGATE (1 << 30) -#define SSP_CTRL0_RUN (1 << 29) -#define SSP_CTRL0_SDIO_IRQ_CHECK (1 << 28) -#define SSP_CTRL0_LOCK_CS (1 << 27) -#define SSP_CTRL0_IGNORE_CRC (1 << 26) -#define SSP_CTRL0_READ (1 << 25) -#define SSP_CTRL0_DATA_XFER (1 << 24) -#define SSP_CTRL0_BUS_WIDTH_MASK (0x3 << 22) -#define SSP_CTRL0_BUS_WIDTH_OFFSET 22 -#define SSP_CTRL0_BUS_WIDTH_ONE_BIT (0x0 << 22) -#define SSP_CTRL0_BUS_WIDTH_FOUR_BIT (0x1 << 22) -#define SSP_CTRL0_BUS_WIDTH_EIGHT_BIT (0x2 << 22) -#define SSP_CTRL0_WAIT_FOR_IRQ (1 << 21) -#define SSP_CTRL0_WAIT_FOR_CMD (1 << 20) -#define SSP_CTRL0_LONG_RESP (1 << 19) -#define SSP_CTRL0_CHECK_RESP (1 << 18) -#define SSP_CTRL0_GET_RESP (1 << 17) -#define SSP_CTRL0_ENABLE (1 << 16) - -#define SSP_CMD0_SOFT_TERMINATE (1 << 26) -#define SSP_CMD0_DBL_DATA_RATE_EN (1 << 25) -#define SSP_CMD0_PRIM_BOOT_OP_EN (1 << 24) -#define SSP_CMD0_BOOT_ACK_EN (1 << 23) -#define SSP_CMD0_SLOW_CLKING_EN (1 << 22) -#define SSP_CMD0_CONT_CLKING_EN (1 << 21) -#define SSP_CMD0_APPEND_8CYC (1 << 20) -#define SSP_CMD0_CMD_MASK 0xff -#define SSP_CMD0_CMD_OFFSET 0 -#define SSP_CMD0_CMD_MMC_GO_IDLE_STATE 0x00 -#define SSP_CMD0_CMD_MMC_SEND_OP_COND 0x01 -#define SSP_CMD0_CMD_MMC_ALL_SEND_CID 0x02 -#define SSP_CMD0_CMD_MMC_SET_RELATIVE_ADDR 0x03 -#define SSP_CMD0_CMD_MMC_SET_DSR 0x04 -#define SSP_CMD0_CMD_MMC_RESERVED_5 0x05 -#define SSP_CMD0_CMD_MMC_SWITCH 0x06 -#define SSP_CMD0_CMD_MMC_SELECT_DESELECT_CARD 0x07 -#define SSP_CMD0_CMD_MMC_SEND_EXT_CSD 0x08 -#define SSP_CMD0_CMD_MMC_SEND_CSD 0x09 -#define SSP_CMD0_CMD_MMC_SEND_CID 0x0a -#define SSP_CMD0_CMD_MMC_READ_DAT_UNTIL_STOP 0x0b -#define SSP_CMD0_CMD_MMC_STOP_TRANSMISSION 0x0c -#define SSP_CMD0_CMD_MMC_SEND_STATUS 0x0d -#define SSP_CMD0_CMD_MMC_BUSTEST_R 0x0e -#define SSP_CMD0_CMD_MMC_GO_INACTIVE_STATE 0x0f -#define SSP_CMD0_CMD_MMC_SET_BLOCKLEN 0x10 -#define SSP_CMD0_CMD_MMC_READ_SINGLE_BLOCK 0x11 -#define SSP_CMD0_CMD_MMC_READ_MULTIPLE_BLOCK 0x12 -#define SSP_CMD0_CMD_MMC_BUSTEST_W 0x13 -#define SSP_CMD0_CMD_MMC_WRITE_DAT_UNTIL_STOP 0x14 -#define SSP_CMD0_CMD_MMC_SET_BLOCK_COUNT 0x17 -#define SSP_CMD0_CMD_MMC_WRITE_BLOCK 0x18 -#define SSP_CMD0_CMD_MMC_WRITE_MULTIPLE_BLOCK 0x19 -#define SSP_CMD0_CMD_MMC_PROGRAM_CID 0x1a -#define SSP_CMD0_CMD_MMC_PROGRAM_CSD 0x1b -#define SSP_CMD0_CMD_MMC_SET_WRITE_PROT 0x1c -#define SSP_CMD0_CMD_MMC_CLR_WRITE_PROT 0x1d -#define SSP_CMD0_CMD_MMC_SEND_WRITE_PROT 0x1e -#define SSP_CMD0_CMD_MMC_ERASE_GROUP_START 0x23 -#define SSP_CMD0_CMD_MMC_ERASE_GROUP_END 0x24 -#define SSP_CMD0_CMD_MMC_ERASE 0x26 -#define SSP_CMD0_CMD_MMC_FAST_IO 0x27 -#define SSP_CMD0_CMD_MMC_GO_IRQ_STATE 0x28 -#define SSP_CMD0_CMD_MMC_LOCK_UNLOCK 0x2a -#define SSP_CMD0_CMD_MMC_APP_CMD 0x37 -#define SSP_CMD0_CMD_MMC_GEN_CMD 0x38 -#define SSP_CMD0_CMD_SD_GO_IDLE_STATE 0x00 -#define SSP_CMD0_CMD_SD_ALL_SEND_CID 0x02 -#define SSP_CMD0_CMD_SD_SEND_RELATIVE_ADDR 0x03 -#define SSP_CMD0_CMD_SD_SET_DSR 0x04 -#define SSP_CMD0_CMD_SD_IO_SEND_OP_COND 0x05 -#define SSP_CMD0_CMD_SD_SELECT_DESELECT_CARD 0x07 -#define SSP_CMD0_CMD_SD_SEND_CSD 0x09 -#define SSP_CMD0_CMD_SD_SEND_CID 0x0a -#define SSP_CMD0_CMD_SD_STOP_TRANSMISSION 0x0c -#define SSP_CMD0_CMD_SD_SEND_STATUS 0x0d -#define SSP_CMD0_CMD_SD_GO_INACTIVE_STATE 0x0f -#define SSP_CMD0_CMD_SD_SET_BLOCKLEN 0x10 -#define SSP_CMD0_CMD_SD_READ_SINGLE_BLOCK 0x11 -#define SSP_CMD0_CMD_SD_READ_MULTIPLE_BLOCK 0x12 -#define SSP_CMD0_CMD_SD_WRITE_BLOCK 0x18 -#define SSP_CMD0_CMD_SD_WRITE_MULTIPLE_BLOCK 0x19 -#define SSP_CMD0_CMD_SD_PROGRAM_CSD 0x1b -#define SSP_CMD0_CMD_SD_SET_WRITE_PROT 0x1c -#define SSP_CMD0_CMD_SD_CLR_WRITE_PROT 0x1d -#define SSP_CMD0_CMD_SD_SEND_WRITE_PROT 0x1e -#define SSP_CMD0_CMD_SD_ERASE_WR_BLK_START 0x20 -#define SSP_CMD0_CMD_SD_ERASE_WR_BLK_END 0x21 -#define SSP_CMD0_CMD_SD_ERASE_GROUP_START 0x23 -#define SSP_CMD0_CMD_SD_ERASE_GROUP_END 0x24 -#define SSP_CMD0_CMD_SD_ERASE 0x26 -#define SSP_CMD0_CMD_SD_LOCK_UNLOCK 0x2a -#define SSP_CMD0_CMD_SD_IO_RW_DIRECT 0x34 -#define SSP_CMD0_CMD_SD_IO_RW_EXTENDED 0x35 -#define SSP_CMD0_CMD_SD_APP_CMD 0x37 -#define SSP_CMD0_CMD_SD_GEN_CMD 0x38 - -#define SSP_CMD1_CMD_ARG_MASK 0xffffffff -#define SSP_CMD1_CMD_ARG_OFFSET 0 - -#define SSP_XFER_SIZE_XFER_COUNT_MASK 0xffffffff -#define SSP_XFER_SIZE_XFER_COUNT_OFFSET 0 - -#define SSP_BLOCK_SIZE_BLOCK_COUNT_MASK (0xffffff << 4) -#define SSP_BLOCK_SIZE_BLOCK_COUNT_OFFSET 4 -#define SSP_BLOCK_SIZE_BLOCK_SIZE_MASK 0xf -#define SSP_BLOCK_SIZE_BLOCK_SIZE_OFFSET 0 - -#define SSP_COMPREF_REFERENCE_MASK 0xffffffff -#define SSP_COMPREF_REFERENCE_OFFSET 0 - -#define SSP_COMPMASK_MASK_MASK 0xffffffff -#define SSP_COMPMASK_MASK_OFFSET 0 - -#define SSP_TIMING_TIMEOUT_MASK (0xffff << 16) -#define SSP_TIMING_TIMEOUT_OFFSET 16 -#define SSP_TIMING_CLOCK_DIVIDE_MASK (0xff << 8) -#define SSP_TIMING_CLOCK_DIVIDE_OFFSET 8 -#define SSP_TIMING_CLOCK_RATE_MASK 0xff -#define SSP_TIMING_CLOCK_RATE_OFFSET 0 - -#define SSP_CTRL1_SDIO_IRQ (1 << 31) -#define SSP_CTRL1_SDIO_IRQ_EN (1 << 30) -#define SSP_CTRL1_RESP_ERR_IRQ (1 << 29) -#define SSP_CTRL1_RESP_ERR_IRQ_EN (1 << 28) -#define SSP_CTRL1_RESP_TIMEOUT_IRQ (1 << 27) -#define SSP_CTRL1_RESP_TIMEOUT_IRQ_EN (1 << 26) -#define SSP_CTRL1_DATA_TIMEOUT_IRQ (1 << 25) -#define SSP_CTRL1_DATA_TIMEOUT_IRQ_EN (1 << 24) -#define SSP_CTRL1_DATA_CRC_IRQ (1 << 23) -#define SSP_CTRL1_DATA_CRC_IRQ_EN (1 << 22) -#define SSP_CTRL1_FIFO_UNDERRUN_IRQ (1 << 21) -#define SSP_CTRL1_FIFO_UNDERRUN_EN (1 << 20) -#define SSP_CTRL1_CEATA_CCS_ERR_IRQ (1 << 19) -#define SSP_CTRL1_CEATA_CCS_ERR_IRQ_EN (1 << 18) -#define SSP_CTRL1_RECV_TIMEOUT_IRQ (1 << 17) -#define SSP_CTRL1_RECV_TIMEOUT_IRQ_EN (1 << 16) -#define SSP_CTRL1_FIFO_OVERRUN_IRQ (1 << 15) -#define SSP_CTRL1_FIFO_OVERRUN_IRQ_EN (1 << 14) -#define SSP_CTRL1_DMA_ENABLE (1 << 13) -#define SSP_CTRL1_CEATA_CCS_ERR_EN (1 << 12) -#define SSP_CTRL1_SLAVE_OUT_DISABLE (1 << 11) -#define SSP_CTRL1_PHASE (1 << 10) -#define SSP_CTRL1_POLARITY (1 << 9) -#define SSP_CTRL1_SLAVE_MODE (1 << 8) -#define SSP_CTRL1_WORD_LENGTH_MASK (0xf << 4) -#define SSP_CTRL1_WORD_LENGTH_OFFSET 4 -#define SSP_CTRL1_WORD_LENGTH_RESERVED0 (0x0 << 4) -#define SSP_CTRL1_WORD_LENGTH_RESERVED1 (0x1 << 4) -#define SSP_CTRL1_WORD_LENGTH_RESERVED2 (0x2 << 4) -#define SSP_CTRL1_WORD_LENGTH_FOUR_BITS (0x3 << 4) -#define SSP_CTRL1_WORD_LENGTH_EIGHT_BITS (0x7 << 4) -#define SSP_CTRL1_WORD_LENGTH_SIXTEEN_BITS (0xf << 4) -#define SSP_CTRL1_SSP_MODE_MASK 0xf -#define SSP_CTRL1_SSP_MODE_OFFSET 0 -#define SSP_CTRL1_SSP_MODE_SPI 0x0 -#define SSP_CTRL1_SSP_MODE_SSI 0x1 -#define SSP_CTRL1_SSP_MODE_SD_MMC 0x3 -#define SSP_CTRL1_SSP_MODE_MS 0x4 - -#define SSP_DATA_DATA_MASK 0xffffffff -#define SSP_DATA_DATA_OFFSET 0 - -#define SSP_SDRESP0_RESP0_MASK 0xffffffff -#define SSP_SDRESP0_RESP0_OFFSET 0 - -#define SSP_SDRESP1_RESP1_MASK 0xffffffff -#define SSP_SDRESP1_RESP1_OFFSET 0 - -#define SSP_SDRESP2_RESP2_MASK 0xffffffff -#define SSP_SDRESP2_RESP2_OFFSET 0 - -#define SSP_SDRESP3_RESP3_MASK 0xffffffff -#define SSP_SDRESP3_RESP3_OFFSET 0 - -#define SSP_DDR_CTRL_DMA_BURST_TYPE_MASK (0x3 << 30) -#define SSP_DDR_CTRL_DMA_BURST_TYPE_OFFSET 30 -#define SSP_DDR_CTRL_NIBBLE_POS (1 << 1) -#define SSP_DDR_CTRL_TXCLK_DELAY_TYPE (1 << 0) - -#define SSP_DLL_CTRL_REF_UPDATE_INT_MASK (0xf << 28) -#define SSP_DLL_CTRL_REF_UPDATE_INT_OFFSET 28 -#define SSP_DLL_CTRL_SLV_UPDATE_INT_MASK (0xff << 20) -#define SSP_DLL_CTRL_SLV_UPDATE_INT_OFFSET 20 -#define SSP_DLL_CTRL_SLV_OVERRIDE_VAL_MASK (0x3f << 10) -#define SSP_DLL_CTRL_SLV_OVERRIDE_VAL_OFFSET 10 -#define SSP_DLL_CTRL_SLV_OVERRIDE (1 << 9) -#define SSP_DLL_CTRL_GATE_UPDATE (1 << 7) -#define SSP_DLL_CTRL_SLV_DLY_TARGET_MASK (0xf << 3) -#define SSP_DLL_CTRL_SLV_DLY_TARGET_OFFSET 3 -#define SSP_DLL_CTRL_SLV_FORCE_UPD (1 << 2) -#define SSP_DLL_CTRL_RESET (1 << 1) -#define SSP_DLL_CTRL_ENABLE (1 << 0) - -#define SSP_STATUS_PRESENT (1 << 31) -#define SSP_STATUS_MS_PRESENT (1 << 30) -#define SSP_STATUS_SD_PRESENT (1 << 29) -#define SSP_STATUS_CARD_DETECT (1 << 28) -#define SSP_STATUS_DMABURST (1 << 22) -#define SSP_STATUS_DMASENSE (1 << 21) -#define SSP_STATUS_DMATERM (1 << 20) -#define SSP_STATUS_DMAREQ (1 << 19) -#define SSP_STATUS_DMAEND (1 << 18) -#define SSP_STATUS_SDIO_IRQ (1 << 17) -#define SSP_STATUS_RESP_CRC_ERR (1 << 16) -#define SSP_STATUS_RESP_ERR (1 << 15) -#define SSP_STATUS_RESP_TIMEOUT (1 << 14) -#define SSP_STATUS_DATA_CRC_ERR (1 << 13) -#define SSP_STATUS_TIMEOUT (1 << 12) -#define SSP_STATUS_RECV_TIMEOUT_STAT (1 << 11) -#define SSP_STATUS_CEATA_CCS_ERR (1 << 10) -#define SSP_STATUS_FIFO_OVRFLW (1 << 9) -#define SSP_STATUS_FIFO_FULL (1 << 8) -#define SSP_STATUS_FIFO_EMPTY (1 << 5) -#define SSP_STATUS_FIFO_UNDRFLW (1 << 4) -#define SSP_STATUS_CMD_BUSY (1 << 3) -#define SSP_STATUS_DATA_BUSY (1 << 2) -#define SSP_STATUS_BUSY (1 << 0) - -#define SSP_DLL_STS_REF_SEL_MASK (0x3f << 8) -#define SSP_DLL_STS_REF_SEL_OFFSET 8 -#define SSP_DLL_STS_SLV_SEL_MASK (0x3f << 2) -#define SSP_DLL_STS_SLV_SEL_OFFSET 2 -#define SSP_DLL_STS_REF_LOCK (1 << 1) -#define SSP_DLL_STS_SLV_LOCK (1 << 0) - -#define SSP_DEBUG_DATACRC_ERR_MASK (0xf << 28) -#define SSP_DEBUG_DATACRC_ERR_OFFSET 28 -#define SSP_DEBUG_DATA_STALL (1 << 27) -#define SSP_DEBUG_DAT_SM_MASK (0x7 << 24) -#define SSP_DEBUG_DAT_SM_OFFSET 24 -#define SSP_DEBUG_DAT_SM_DSM_IDLE (0x0 << 24) -#define SSP_DEBUG_DAT_SM_DSM_WORD (0x2 << 24) -#define SSP_DEBUG_DAT_SM_DSM_CRC1 (0x3 << 24) -#define SSP_DEBUG_DAT_SM_DSM_CRC2 (0x4 << 24) -#define SSP_DEBUG_DAT_SM_DSM_END (0x5 << 24) -#define SSP_DEBUG_MSTK_SM_MASK (0xf << 20) -#define SSP_DEBUG_MSTK_SM_OFFSET 20 -#define SSP_DEBUG_MSTK_SM_MSTK_IDLE (0x0 << 20) -#define SSP_DEBUG_MSTK_SM_MSTK_CKON (0x1 << 20) -#define SSP_DEBUG_MSTK_SM_MSTK_BS1 (0x2 << 20) -#define SSP_DEBUG_MSTK_SM_MSTK_TPC (0x3 << 20) -#define SSP_DEBUG_MSTK_SM_MSTK_BS2 (0x4 << 20) -#define SSP_DEBUG_MSTK_SM_MSTK_HDSHK (0x5 << 20) -#define SSP_DEBUG_MSTK_SM_MSTK_BS3 (0x6 << 20) -#define SSP_DEBUG_MSTK_SM_MSTK_RW (0x7 << 20) -#define SSP_DEBUG_MSTK_SM_MSTK_CRC1 (0x8 << 20) -#define SSP_DEBUG_MSTK_SM_MSTK_CRC2 (0x9 << 20) -#define SSP_DEBUG_MSTK_SM_MSTK_BS0 (0xa << 20) -#define SSP_DEBUG_MSTK_SM_MSTK_END1 (0xb << 20) -#define SSP_DEBUG_MSTK_SM_MSTK_END2W (0xc << 20) -#define SSP_DEBUG_MSTK_SM_MSTK_END2R (0xd << 20) -#define SSP_DEBUG_MSTK_SM_MSTK_DONE (0xe << 20) -#define SSP_DEBUG_CMD_OE (1 << 19) -#define SSP_DEBUG_DMA_SM_MASK (0x7 << 16) -#define SSP_DEBUG_DMA_SM_OFFSET 16 -#define SSP_DEBUG_DMA_SM_DMA_IDLE (0x0 << 16) -#define SSP_DEBUG_DMA_SM_DMA_DMAREQ (0x1 << 16) -#define SSP_DEBUG_DMA_SM_DMA_DMAACK (0x2 << 16) -#define SSP_DEBUG_DMA_SM_DMA_STALL (0x3 << 16) -#define SSP_DEBUG_DMA_SM_DMA_BUSY (0x4 << 16) -#define SSP_DEBUG_DMA_SM_DMA_DONE (0x5 << 16) -#define SSP_DEBUG_DMA_SM_DMA_COUNT (0x6 << 16) -#define SSP_DEBUG_MMC_SM_MASK (0xf << 12) -#define SSP_DEBUG_MMC_SM_OFFSET 12 -#define SSP_DEBUG_MMC_SM_MMC_IDLE (0x0 << 12) -#define SSP_DEBUG_MMC_SM_MMC_CMD (0x1 << 12) -#define SSP_DEBUG_MMC_SM_MMC_TRC (0x2 << 12) -#define SSP_DEBUG_MMC_SM_MMC_RESP (0x3 << 12) -#define SSP_DEBUG_MMC_SM_MMC_RPRX (0x4 << 12) -#define SSP_DEBUG_MMC_SM_MMC_TX (0x5 << 12) -#define SSP_DEBUG_MMC_SM_MMC_CTOK (0x6 << 12) -#define SSP_DEBUG_MMC_SM_MMC_RX (0x7 << 12) -#define SSP_DEBUG_MMC_SM_MMC_CCS (0x8 << 12) -#define SSP_DEBUG_MMC_SM_MMC_PUP (0x9 << 12) -#define SSP_DEBUG_MMC_SM_MMC_WAIT (0xa << 12) -#define SSP_DEBUG_CMD_SM_MASK (0x3 << 10) -#define SSP_DEBUG_CMD_SM_OFFSET 10 -#define SSP_DEBUG_CMD_SM_CSM_IDLE (0x0 << 10) -#define SSP_DEBUG_CMD_SM_CSM_INDEX (0x1 << 10) -#define SSP_DEBUG_CMD_SM_CSM_ARG (0x2 << 10) -#define SSP_DEBUG_CMD_SM_CSM_CRC (0x3 << 10) -#define SSP_DEBUG_SSP_CMD (1 << 9) -#define SSP_DEBUG_SSP_RESP (1 << 8) -#define SSP_DEBUG_SSP_RXD_MASK 0xff -#define SSP_DEBUG_SSP_RXD_OFFSET 0 - -#define SSP_VERSION_MAJOR_MASK (0xff << 24) -#define SSP_VERSION_MAJOR_OFFSET 24 -#define SSP_VERSION_MINOR_MASK (0xff << 16) -#define SSP_VERSION_MINOR_OFFSET 16 -#define SSP_VERSION_STEP_MASK 0xffff -#define SSP_VERSION_STEP_OFFSET 0 - -#endif /* __MX28_REGS_SSP_H__ */ diff --git a/arch/arm/include/asm/arch-mx28/regs-timrot.h b/arch/arm/include/asm/arch-mx28/regs-timrot.h deleted file mode 100644 index 3e8dfe7..0000000 --- a/arch/arm/include/asm/arch-mx28/regs-timrot.h +++ /dev/null @@ -1,171 +0,0 @@ -/* - * Freescale i.MX28 TIMROT Register Definitions - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * - * Based on code from LTIB: - * Copyright 2008-2010 Freescale Semiconductor, Inc. All Rights Reserved. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA - * - */ - -#ifndef __MX28_REGS_TIMROT_H__ -#define __MX28_REGS_TIMROT_H__ - -#include <asm/arch/regs-common.h> - -#ifndef __ASSEMBLY__ -struct mx28_timrot_regs { - mx28_reg_32(hw_timrot_rotctrl) - mx28_reg_32(hw_timrot_rotcount) - mx28_reg_32(hw_timrot_timctrl0) - mx28_reg_32(hw_timrot_running_count0) - mx28_reg_32(hw_timrot_fixed_count0) - mx28_reg_32(hw_timrot_match_count0) - mx28_reg_32(hw_timrot_timctrl1) - mx28_reg_32(hw_timrot_running_count1) - mx28_reg_32(hw_timrot_fixed_count1) - mx28_reg_32(hw_timrot_match_count1) - mx28_reg_32(hw_timrot_timctrl2) - mx28_reg_32(hw_timrot_running_count2) - mx28_reg_32(hw_timrot_fixed_count2) - mx28_reg_32(hw_timrot_match_count2) - mx28_reg_32(hw_timrot_timctrl3) - mx28_reg_32(hw_timrot_running_count3) - mx28_reg_32(hw_timrot_fixed_count3) - mx28_reg_32(hw_timrot_match_count3) - mx28_reg_32(hw_timrot_version) -}; -#endif - -#define TIMROT_ROTCTRL_SFTRST (1 << 31) -#define TIMROT_ROTCTRL_CLKGATE (1 << 30) -#define TIMROT_ROTCTRL_ROTARY_PRESENT (1 << 29) -#define TIMROT_ROTCTRL_TIM3_PRESENT (1 << 28) -#define TIMROT_ROTCTRL_TIM2_PRESENT (1 << 27) -#define TIMROT_ROTCTRL_TIM1_PRESENT (1 << 26) -#define TIMROT_ROTCTRL_TIM0_PRESENT (1 << 25) -#define TIMROT_ROTCTRL_STATE_MASK (0x7 << 22) -#define TIMROT_ROTCTRL_STATE_OFFSET 22 -#define TIMROT_ROTCTRL_DIVIDER_MASK (0x3f << 16) -#define TIMROT_ROTCTRL_DIVIDER_OFFSET 16 -#define TIMROT_ROTCTRL_RELATIVE (1 << 12) -#define TIMROT_ROTCTRL_OVERSAMPLE_MASK (0x3 << 10) -#define TIMROT_ROTCTRL_OVERSAMPLE_OFFSET 10 -#define TIMROT_ROTCTRL_OVERSAMPLE_8X (0x0 << 10) -#define TIMROT_ROTCTRL_OVERSAMPLE_4X (0x1 << 10) -#define TIMROT_ROTCTRL_OVERSAMPLE_2X (0x2 << 10) -#define TIMROT_ROTCTRL_OVERSAMPLE_1X (0x3 << 10) -#define TIMROT_ROTCTRL_POLARITY_B (1 << 9) -#define TIMROT_ROTCTRL_POLARITY_A (1 << 8) -#define TIMROT_ROTCTRL_SELECT_B_MASK (0xf << 4) -#define TIMROT_ROTCTRL_SELECT_B_OFFSET 4 -#define TIMROT_ROTCTRL_SELECT_B_NEVER_TICK (0x0 << 4) -#define TIMROT_ROTCTRL_SELECT_B_PWM0 (0x1 << 4) -#define TIMROT_ROTCTRL_SELECT_B_PWM1 (0x2 << 4) -#define TIMROT_ROTCTRL_SELECT_B_PWM2 (0x3 << 4) -#define TIMROT_ROTCTRL_SELECT_B_PWM3 (0x4 << 4) -#define TIMROT_ROTCTRL_SELECT_B_PWM4 (0x5 << 4) -#define TIMROT_ROTCTRL_SELECT_B_PWM5 (0x6 << 4) -#define TIMROT_ROTCTRL_SELECT_B_PWM6 (0x7 << 4) -#define TIMROT_ROTCTRL_SELECT_B_PWM7 (0x8 << 4) -#define TIMROT_ROTCTRL_SELECT_B_ROTARYA (0x9 << 4) -#define TIMROT_ROTCTRL_SELECT_B_ROTARYB (0xa << 4) -#define TIMROT_ROTCTRL_SELECT_A_MASK 0xf -#define TIMROT_ROTCTRL_SELECT_A_OFFSET 0 -#define TIMROT_ROTCTRL_SELECT_A_NEVER_TICK 0x0 -#define TIMROT_ROTCTRL_SELECT_A_PWM0 0x1 -#define TIMROT_ROTCTRL_SELECT_A_PWM1 0x2 -#define TIMROT_ROTCTRL_SELECT_A_PWM2 0x3 -#define TIMROT_ROTCTRL_SELECT_A_PWM3 0x4 -#define TIMROT_ROTCTRL_SELECT_A_PWM4 0x5 -#define TIMROT_ROTCTRL_SELECT_A_PWM5 0x6 -#define TIMROT_ROTCTRL_SELECT_A_PWM6 0x7 -#define TIMROT_ROTCTRL_SELECT_A_PWM7 0x8 -#define TIMROT_ROTCTRL_SELECT_A_ROTARYA 0x9 -#define TIMROT_ROTCTRL_SELECT_A_ROTARYB 0xa - -#define TIMROT_ROTCOUNT_UPDOWN_MASK 0xffff -#define TIMROT_ROTCOUNT_UPDOWN_OFFSET 0 - -#define TIMROT_TIMCTRLn_IRQ (1 << 15) -#define TIMROT_TIMCTRLn_IRQ_EN (1 << 14) -#define TIMROT_TIMCTRLn_MATCH_MODE (1 << 11) -#define TIMROT_TIMCTRLn_POLARITY (1 << 8) -#define TIMROT_TIMCTRLn_UPDATE (1 << 7) -#define TIMROT_TIMCTRLn_RELOAD (1 << 6) -#define TIMROT_TIMCTRLn_PRESCALE_MASK (0x3 << 4) -#define TIMROT_TIMCTRLn_PRESCALE_OFFSET 4 -#define TIMROT_TIMCTRLn_PRESCALE_DIV_BY_1 (0x0 << 4) -#define TIMROT_TIMCTRLn_PRESCALE_DIV_BY_2 (0x1 << 4) -#define TIMROT_TIMCTRLn_PRESCALE_DIV_BY_4 (0x2 << 4) -#define TIMROT_TIMCTRLn_PRESCALE_DIV_BY_8 (0x3 << 4) -#define TIMROT_TIMCTRLn_SELECT_MASK 0xf -#define TIMROT_TIMCTRLn_SELECT_OFFSET 0 -#define TIMROT_TIMCTRLn_SELECT_NEVER_TICK 0x0 -#define TIMROT_TIMCTRLn_SELECT_PWM0 0x1 -#define TIMROT_TIMCTRLn_SELECT_PWM1 0x2 -#define TIMROT_TIMCTRLn_SELECT_PWM2 0x3 -#define TIMROT_TIMCTRLn_SELECT_PWM3 0x4 -#define TIMROT_TIMCTRLn_SELECT_PWM4 0x5 -#define TIMROT_TIMCTRLn_SELECT_PWM5 0x6 -#define TIMROT_TIMCTRLn_SELECT_PWM6 0x7 -#define TIMROT_TIMCTRLn_SELECT_PWM7 0x8 -#define TIMROT_TIMCTRLn_SELECT_ROTARYA 0x9 -#define TIMROT_TIMCTRLn_SELECT_ROTARYB 0xa -#define TIMROT_TIMCTRLn_SELECT_32KHZ_XTAL 0xb -#define TIMROT_TIMCTRLn_SELECT_8KHZ_XTAL 0xc -#define TIMROT_TIMCTRLn_SELECT_4KHZ_XTAL 0xd -#define TIMROT_TIMCTRLn_SELECT_1KHZ_XTAL 0xe -#define TIMROT_TIMCTRLn_SELECT_TICK_ALWAYS 0xf - -#define TIMROT_RUNNING_COUNTn_RUNNING_COUNT_MASK 0xffffffff -#define TIMROT_RUNNING_COUNTn_RUNNING_COUNT_OFFSET 0 - -#define TIMROT_FIXED_COUNTn_FIXED_COUNT_MASK 0xffffffff -#define TIMROT_FIXED_COUNTn_FIXED_COUNT_OFFSET 0 - -#define TIMROT_MATCH_COUNTn_MATCH_COUNT_MASK 0xffffffff -#define TIMROT_MATCH_COUNTn_MATCH_COUNT_OFFSET 0 - -#define TIMROT_TIMCTRL3_TEST_SIGNAL_MASK (0xf << 16) -#define TIMROT_TIMCTRL3_TEST_SIGNAL_OFFSET 16 -#define TIMROT_TIMCTRL3_TEST_SIGNAL_NEVER_TICK (0x0 << 16) -#define TIMROT_TIMCTRL3_TEST_SIGNAL_PWM0 (0x1 << 16) -#define TIMROT_TIMCTRL3_TEST_SIGNAL_PWM1 (0x2 << 16) -#define TIMROT_TIMCTRL3_TEST_SIGNAL_PWM2 (0x3 << 16) -#define TIMROT_TIMCTRL3_TEST_SIGNAL_PWM3 (0x4 << 16) -#define TIMROT_TIMCTRL3_TEST_SIGNAL_PWM4 (0x5 << 16) -#define TIMROT_TIMCTRL3_TEST_SIGNAL_PWM5 (0x6 << 16) -#define TIMROT_TIMCTRL3_TEST_SIGNAL_PWM6 (0x7 << 16) -#define TIMROT_TIMCTRL3_TEST_SIGNAL_PWM7 (0x8 << 16) -#define TIMROT_TIMCTRL3_TEST_SIGNAL_ROTARYA (0x9 << 16) -#define TIMROT_TIMCTRL3_TEST_SIGNAL_ROTARYB (0xa << 16) -#define TIMROT_TIMCTRL3_TEST_SIGNAL_32KHZ_XTAL (0xb << 16) -#define TIMROT_TIMCTRL3_TEST_SIGNAL_8KHZ_XTAL (0xc << 16) -#define TIMROT_TIMCTRL3_TEST_SIGNAL_4KHZ_XTAL (0xd << 16) -#define TIMROT_TIMCTRL3_TEST_SIGNAL_1KHZ_XTAL (0xe << 16) -#define TIMROT_TIMCTRL3_TEST_SIGNAL_TICK_ALWAYS (0xf << 16) -#define TIMROT_TIMCTRL3_DUTY_CYCLE (1 << 9) - -#define TIMROT_VERSION_MAJOR_MASK (0xff << 24) -#define TIMROT_VERSION_MAJOR_OFFSET 24 -#define TIMROT_VERSION_MINOR_MASK (0xff << 16) -#define TIMROT_VERSION_MINOR_OFFSET 16 -#define TIMROT_VERSION_STEP_MASK 0xffff -#define TIMROT_VERSION_STEP_OFFSET 0 - -#endif /* __MX28_REGS_TIMROT_H__ */ diff --git a/arch/arm/include/asm/arch-mx28/regs-usb.h b/arch/arm/include/asm/arch-mx28/regs-usb.h deleted file mode 100644 index ea61de8..0000000 --- a/arch/arm/include/asm/arch-mx28/regs-usb.h +++ /dev/null @@ -1,178 +0,0 @@ -/* - * Freescale i.MX28 USB OTG Register Definitions - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * on behalf of DENX Software Engineering GmbH - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA - * - */ - -#ifndef __REGS_USB_H__ -#define __REGS_USB_H__ - -struct mx28_usb_regs { - uint32_t hw_usbctrl_id; /* 0x000 */ - uint32_t hw_usbctrl_hwgeneral; /* 0x004 */ - uint32_t hw_usbctrl_hwhost; /* 0x008 */ - uint32_t hw_usbctrl_hwdevice; /* 0x00c */ - uint32_t hw_usbctrl_hwtxbuf; /* 0x010 */ - uint32_t hw_usbctrl_hwrxbuf; /* 0x014 */ - - uint32_t reserved1[26]; - - uint32_t hw_usbctrl_gptimer0ld; /* 0x080 */ - uint32_t hw_usbctrl_gptimer0ctrl; /* 0x084 */ - uint32_t hw_usbctrl_gptimer1ld; /* 0x088 */ - uint32_t hw_usbctrl_gptimer1ctrl; /* 0x08c */ - uint32_t hw_usbctrl_sbuscfg; /* 0x090 */ - - uint32_t reserved2[27]; - - uint32_t hw_usbctrl_caplength; /* 0x100 */ - uint32_t hw_usbctrl_hcsparams; /* 0x104 */ - uint32_t hw_usbctrl_hccparams; /* 0x108 */ - - uint32_t reserved3[5]; - - uint32_t hw_usbctrl_dciversion; /* 0x120 */ - uint32_t hw_usbctrl_dccparams; /* 0x124 */ - - uint32_t reserved4[6]; - - uint32_t hw_usbctrl_usbcmd; /* 0x140 */ - uint32_t hw_usbctrl_usbsts; /* 0x144 */ - uint32_t hw_usbctrl_usbintr; /* 0x148 */ - uint32_t hw_usbctrl_frindex; /* 0x14c */ - - uint32_t reserved5; - - union { - uint32_t hw_usbctrl_periodiclistbase; /* 0x154 */ - uint32_t hw_usbctrl_deviceaddr; /* 0x154 */ - }; - union { - uint32_t hw_usbctrl_asynclistaddr; /* 0x158 */ - uint32_t hw_usbctrl_endpointlistaddr; /* 0x158 */ - }; - - uint32_t hw_usbctrl_ttctrl; /* 0x15c */ - uint32_t hw_usbctrl_burstsize; /* 0x160 */ - uint32_t hw_usbctrl_txfilltuning; /* 0x164 */ - - uint32_t reserved6; - - uint32_t hw_usbctrl_ic_usb; /* 0x16c */ - uint32_t hw_usbctrl_ulpi; /* 0x170 */ - - uint32_t reserved7; - - uint32_t hw_usbctrl_endptnak; /* 0x178 */ - uint32_t hw_usbctrl_endptnaken; /* 0x17c */ - - uint32_t reserved8; - - uint32_t hw_usbctrl_portsc1; /* 0x184 */ - - uint32_t reserved9[7]; - - uint32_t hw_usbctrl_otgsc; /* 0x1a4 */ - uint32_t hw_usbctrl_usbmode; /* 0x1a8 */ - uint32_t hw_usbctrl_endptsetupstat; /* 0x1ac */ - uint32_t hw_usbctrl_endptprime; /* 0x1b0 */ - uint32_t hw_usbctrl_endptflush; /* 0x1b4 */ - uint32_t hw_usbctrl_endptstat; /* 0x1b8 */ - uint32_t hw_usbctrl_endptcomplete; /* 0x1bc */ - uint32_t hw_usbctrl_endptctrl0; /* 0x1c0 */ - uint32_t hw_usbctrl_endptctrl1; /* 0x1c4 */ - uint32_t hw_usbctrl_endptctrl2; /* 0x1c8 */ - uint32_t hw_usbctrl_endptctrl3; /* 0x1cc */ - uint32_t hw_usbctrl_endptctrl4; /* 0x1d0 */ - uint32_t hw_usbctrl_endptctrl5; /* 0x1d4 */ - uint32_t hw_usbctrl_endptctrl6; /* 0x1d8 */ - uint32_t hw_usbctrl_endptctrl7; /* 0x1dc */ -}; - -#define CLKCTRL_PLL0CTRL0_LFR_SEL_MASK (0x3 << 28) - -#define HW_USBCTRL_ID_CIVERSION_OFFSET 29 -#define HW_USBCTRL_ID_CIVERSION_MASK (0x7 << 29) -#define HW_USBCTRL_ID_VERSION_OFFSET 25 -#define HW_USBCTRL_ID_VERSION_MASK (0xf << 25) -#define HW_USBCTRL_ID_REVISION_OFFSET 21 -#define HW_USBCTRL_ID_REVISION_MASK (0xf << 21) -#define HW_USBCTRL_ID_TAG_OFFSET 16 -#define HW_USBCTRL_ID_TAG_MASK (0x1f << 16) -#define HW_USBCTRL_ID_NID_OFFSET 8 -#define HW_USBCTRL_ID_NID_MASK (0x3f << 8) -#define HW_USBCTRL_ID_ID_OFFSET 0 -#define HW_USBCTRL_ID_ID_MASK (0x3f << 0) - -#define HW_USBCTRL_HWGENERAL_SM_OFFSET 9 -#define HW_USBCTRL_HWGENERAL_SM_MASK (0x3 << 9) -#define HW_USBCTRL_HWGENERAL_PHYM_OFFSET 6 -#define HW_USBCTRL_HWGENERAL_PHYM_MASK (0x7 << 6) -#define HW_USBCTRL_HWGENERAL_PHYW_OFFSET 4 -#define HW_USBCTRL_HWGENERAL_PHYW_MASK (0x3 << 4) -#define HW_USBCTRL_HWGENERAL_BWT (1 << 3) -#define HW_USBCTRL_HWGENERAL_CLKC_OFFSET 1 -#define HW_USBCTRL_HWGENERAL_CLKC_MASK (0x3 << 1) -#define HW_USBCTRL_HWGENERAL_RT (1 << 0) - -#define HW_USBCTRL_HWHOST_TTPER_OFFSET 24 -#define HW_USBCTRL_HWHOST_TTPER_MASK (0xff << 24) -#define HW_USBCTRL_HWHOST_TTASY_OFFSET 16 -#define HW_USBCTRL_HWHOST_TTASY_MASK (0xff << 19) -#define HW_USBCTRL_HWHOST_NPORT_OFFSET 1 -#define HW_USBCTRL_HWHOST_NPORT_MASK (0x7 << 1) -#define HW_USBCTRL_HWHOST_HC (1 << 0) - -#define HW_USBCTRL_HWDEVICE_DEVEP_OFFSET 1 -#define HW_USBCTRL_HWDEVICE_DEVEP_MASK (0x1f << 1) -#define HW_USBCTRL_HWDEVICE_DC (1 << 0) - -#define HW_USBCTRL_HWTXBUF_TXLCR (1 << 31) -#define HW_USBCTRL_HWTXBUF_TXCHANADD_OFFSET 16 -#define HW_USBCTRL_HWTXBUF_TXCHANADD_MASK (0xff << 16) -#define HW_USBCTRL_HWTXBUF_TXADD_OFFSET 8 -#define HW_USBCTRL_HWTXBUF_TXADD_MASK (0xff << 8) -#define HW_USBCTRL_HWTXBUF_TXBURST_OFFSET 0 -#define HW_USBCTRL_HWTXBUF_TXBURST_MASK 0xff - -#define HW_USBCTRL_HWRXBUF_RXADD_OFFSET 8 -#define HW_USBCTRL_HWRXBUF_RXADD_MASK (0xff << 8) -#define HW_USBCTRL_HWRXBUF_RXBURST_OFFSET 0 -#define HW_USBCTRL_HWRXBUF_RXBURST_MASK 0xff - -#define HW_USBCTRL_GPTIMERLD_GPTLD_OFFSET 0 -#define HW_USBCTRL_GPTIMERLD_GPTLD_MASK 0xffffff - -#define HW_USBCTRL_GPTIMERCTRL_GPTRUN (1 << 31) -#define HW_USBCTRL_GPTIMERCTRL_GPTRST (1 << 30) -#define HW_USBCTRL_GPTIMERCTRL_GPTMODE (1 << 24) -#define HW_USBCTRL_GPTIMERCTRL_GPTCNT_OFFSET 0 -#define HW_USBCTRL_GPTIMERCTRL_GPTCNT_MASK 0xffffff - -#define HW_USBCTRL_SBUSCFG_AHBBURST_OFFSET 0 -#define HW_USBCTRL_SBUSCFG_AHBBURST_MASK 0x7 -#define HW_USBCTRL_SBUSCFG_AHBBURST_U_INCR 0x0 -#define HW_USBCTRL_SBUSCFG_AHBBURST_S_INCR4 0x1 -#define HW_USBCTRL_SBUSCFG_AHBBURST_S_INCR8 0x2 -#define HW_USBCTRL_SBUSCFG_AHBBURST_S_INCR16 0x3 -#define HW_USBCTRL_SBUSCFG_AHBBURST_U_INCR4 0x5 -#define HW_USBCTRL_SBUSCFG_AHBBURST_U_INCR8 0x6 -#define HW_USBCTRL_SBUSCFG_AHBBURST_U_INCR16 0x7 - -#endif /* __REGS_USB_H__ */ diff --git a/arch/arm/include/asm/arch-mx28/regs-usbphy.h b/arch/arm/include/asm/arch-mx28/regs-usbphy.h deleted file mode 100644 index 0291d81..0000000 --- a/arch/arm/include/asm/arch-mx28/regs-usbphy.h +++ /dev/null @@ -1,151 +0,0 @@ -/* - * Freescale i.MX28 USB PHY Register Definitions - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * on behalf of DENX Software Engineering GmbH - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA - * - */ - -#ifndef __REGS_USBPHY_H__ -#define __REGS_USBPHY_H__ - -struct mx28_usbphy_regs { - mx28_reg_32(hw_usbphy_pwd) - mx28_reg_32(hw_usbphy_tx) - mx28_reg_32(hw_usbphy_rx) - mx28_reg_32(hw_usbphy_ctrl) - mx28_reg_32(hw_usbphy_status) - mx28_reg_32(hw_usbphy_debug) - mx28_reg_32(hw_usbphy_debug0_status) - mx28_reg_32(hw_usbphy_debug1) - mx28_reg_32(hw_usbphy_version) - mx28_reg_32(hw_usbphy_ip) -}; - -#define USBPHY_PWD_RXPWDRX (1 << 20) -#define USBPHY_PWD_RXPWDDIFF (1 << 19) -#define USBPHY_PWD_RXPWD1PT1 (1 << 18) -#define USBPHY_PWD_RXPWDENV (1 << 17) -#define USBPHY_PWD_TXPWDV2I (1 << 12) -#define USBPHY_PWD_TXPWDIBIAS (1 << 11) -#define USBPHY_PWD_TXPWDFS (1 << 10) - -#define USBPHY_TX_USBPHY_TX_EDGECTRL_OFFSET 26 -#define USBPHY_TX_USBPHY_TX_EDGECTRL_MASK (0x7 << 26) -#define USBPHY_TX_USBPHY_TX_SYNC_INVERT (1 << 25) -#define USBPHY_TX_USBPHY_TX_SYNC_MUX (1 << 24) -#define USBPHY_TX_TXENCAL45DP (1 << 21) -#define USBPHY_TX_TXCAL45DP_OFFSET 16 -#define USBPHY_TX_TXCAL45DP_MASK (0xf << 16) -#define USBPHY_TX_TXENCAL45DM (1 << 13) -#define USBPHY_TX_TXCAL45DM_OFFSET 8 -#define USBPHY_TX_TXCAL45DM_MASK (0xf << 8) -#define USBPHY_TX_D_CAL_OFFSET 0 -#define USBPHY_TX_D_CAL_MASK 0xf - -#define USBPHY_RX_RXDBYPASS (1 << 22) -#define USBPHY_RX_DISCONADJ_OFFSET 4 -#define USBPHY_RX_DISCONADJ_MASK (0x7 << 4) -#define USBPHY_RX_ENVADJ_OFFSET 0 -#define USBPHY_RX_ENVADJ_MASK 0x7 - -#define USBPHY_CTRL_SFTRST (1 << 31) -#define USBPHY_CTRL_CLKGATE (1 << 30) -#define USBPHY_CTRL_UTMI_SUSPENDM (1 << 29) -#define USBPHY_CTRL_HOST_FORCE_LS_SE0 (1 << 28) -#define USBPHY_CTRL_ENAUTOSET_USBCLKS (1 << 26) -#define USBPHY_CTRL_ENAUTOCLR_USBCLKGATE (1 << 25) -#define USBPHY_CTRL_FSDLL_RST_EN (1 << 24) -#define USBPHY_CTRL_ENVBUSCHG_WKUP (1 << 23) -#define USBPHY_CTRL_ENIDCHG_WKUP (1 << 22) -#define USBPHY_CTRL_ENDPDMCHG_WKUP (1 << 21) -#define USBPHY_CTRL_ENAUTOCLR_PHY_PWD (1 << 20) -#define USBPHY_CTRL_ENAUTOCLR_CLKGATE (1 << 19) -#define USBPHY_CTRL_ENAUTO_PWRON_PLL (1 << 18) -#define USBPHY_CTRL_WAKEUP_IRQ (1 << 17) -#define USBPHY_CTRL_ENIRQWAKEUP (1 << 16) -#define USBPHY_CTRL_ENUTMILEVEL3 (1 << 15) -#define USBPHY_CTRL_ENUTMILEVEL2 (1 << 14) -#define USBPHY_CTRL_DATA_ON_LRADC (1 << 13) -#define USBPHY_CTRL_DEVPLUGIN_IRQ (1 << 12) -#define USBPHY_CTRL_ENIRQDEVPLUGIN (1 << 11) -#define USBPHY_CTRL_RESUME_IRQ (1 << 10) -#define USBPHY_CTRL_ENIRQRESUMEDETECT (1 << 9) -#define USBPHY_CTRL_RESUMEIRQSTICKY (1 << 8) -#define USBPHY_CTRL_ENOTGIDDETECT (1 << 7) -#define USBPHY_CTRL_DEVPLUGIN_POLARITY (1 << 5) -#define USBPHY_CTRL_ENDEVPLUGINDETECT (1 << 4) -#define USBPHY_CTRL_HOSTDISCONDETECT_IRQ (1 << 3) -#define USBPHY_CTRL_ENIRQHOSTDISCON (1 << 2) -#define USBPHY_CTRL_ENHOSTDISCONDETECT (1 << 1) - -#define USBPHY_STATUS_RESUME_STATUS (1 << 10) -#define USBPHY_STATUS_OTGID_STATUS (1 << 8) -#define USBPHY_STATUS_DEVPLUGIN_STATUS (1 << 6) -#define USBPHY_STATUS_HOSTDISCONDETECT_STATUS (1 << 3) - -#define USBPHY_DEBUG_CLKGATE (1 << 30) -#define USBPHY_DEBUG_HOST_RESUME_DEBUG (1 << 29) -#define USBPHY_DEBUG_SQUELCHRESETLENGTH_OFFSET 25 -#define USBPHY_DEBUG_SQUELCHRESETLENGTH_MASK (0xf << 25) -#define USBPHY_DEBUG_ENSQUELCHRESET (1 << 24) -#define USBPHY_DEBUG_SQUELCHRESETCOUNT_OFFSET 16 -#define USBPHY_DEBUG_SQUELCHRESETCOUNT_MASK (0x1f << 16) -#define USBPHY_DEBUG_ENTX2RXCOUNT (1 << 12) -#define USBPHY_DEBUG_TX2RXCOUNT_OFFSET 8 -#define USBPHY_DEBUG_TX2RXCOUNT_MASK (0xf << 8) -#define USBPHY_DEBUG_ENHSTPULLDOWN_OFFSET 4 -#define USBPHY_DEBUG_ENHSTPULLDOWN_MASK (0x3 << 4) -#define USBPHY_DEBUG_HSTPULLDOWN_OFFSET 2 -#define USBPHY_DEBUG_HSTPULLDOWN_MASK (0x3 << 2) -#define USBPHY_DEBUG_DEBUG_INTERFACE_HOLD (1 << 1) -#define USBPHY_DEBUG_OTGIDPIDLOCK (1 << 0) - -#define USBPHY_DEBUG0_STATUS_SQUELCH_COUNT_OFFSET 26 -#define USBPHY_DEBUG0_STATUS_SQUELCH_COUNT_MASK (0x3f << 26) -#define USBPHY_DEBUG0_STATUS_UTMI_RXERROR_OFFSET 16 -#define USBPHY_DEBUG0_STATUS_UTMI_RXERROR_MASK (0x3ff << 16) -#define USBPHY_DEBUG0_STATUS_LOOP_BACK_OFFSET 0 -#define USBPHY_DEBUG0_STATUS_LOOP_BACK_MASK 0xffff - -#define USBPHY_DEBUG1_ENTAILADJVD_OFFSET 13 -#define USBPHY_DEBUG1_ENTAILADJVD_MASK (0x3 << 13) -#define USBPHY_DEBUG1_ENTX2TX (1 << 12) -#define USBPHY_DEBUG1_DBG_ADDRESS_OFFSET 0 -#define USBPHY_DEBUG1_DBG_ADDRESS_MASK 0xf - -#define USBPHY_VERSION_MAJOR_MASK (0xff << 24) -#define USBPHY_VERSION_MAJOR_OFFSET 24 -#define USBPHY_VERSION_MINOR_MASK (0xff << 16) -#define USBPHY_VERSION_MINOR_OFFSET 16 -#define USBPHY_VERSION_STEP_MASK 0xffff -#define USBPHY_VERSION_STEP_OFFSET 0 - -#define USBPHY_IP_DIV_SEL_OFFSET 23 -#define USBPHY_IP_DIV_SEL_MASK (0x3 << 23) -#define USBPHY_IP_LFR_SEL_OFFSET 21 -#define USBPHY_IP_LFR_SEL_MASK (0x3 << 21) -#define USBPHY_IP_CP_SEL_OFFSET 19 -#define USBPHY_IP_CP_SEL_MASK (0x3 << 19) -#define USBPHY_IP_TSTI_TX_DP (1 << 18) -#define USBPHY_IP_TSTI_TX_DM (1 << 17) -#define USBPHY_IP_ANALOG_TESTMODE (1 << 16) -#define USBPHY_IP_EN_USB_CLKS (1 << 2) -#define USBPHY_IP_PLL_LOCKED (1 << 1) -#define USBPHY_IP_PLL_POWER (1 << 0) - -#endif /* __REGS_USBPHY_H__ */ diff --git a/arch/arm/include/asm/arch-mx28/sys_proto.h b/arch/arm/include/asm/arch-mx28/sys_proto.h deleted file mode 100644 index e701c64..0000000 --- a/arch/arm/include/asm/arch-mx28/sys_proto.h +++ /dev/null @@ -1,74 +0,0 @@ -/* - * Freescale i.MX28 MX28 specific functions - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * on behalf of DENX Software Engineering GmbH - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA - * - */ - -#ifndef __MX28_H__ -#define __MX28_H__ - -int mx28_reset_block(struct mx28_register_32 *reg); -int mx28_wait_mask_set(struct mx28_register_32 *reg, - uint32_t mask, - int timeout); -int mx28_wait_mask_clr(struct mx28_register_32 *reg, - uint32_t mask, - int timeout); - -int mxsmmc_initialize(bd_t *bis, int id, int (*wp)(int)); - -#ifdef CONFIG_SPL_BUILD -#include <asm/arch/iomux-mx28.h> -void mx28_common_spl_init(const iomux_cfg_t *iomux_setup, - const unsigned int iomux_size); -#endif - -struct mx28_pair { - uint8_t boot_pads; - uint8_t boot_mask; - const char *mode; -}; - -static const struct mx28_pair mx28_boot_modes[] = { - { 0x00, 0x0f, "USB #0" }, - { 0x01, 0x1f, "I2C #0, master, 3V3" }, - { 0x11, 0x1f, "I2C #0, master, 1V8" }, - { 0x02, 0x1f, "SSP SPI #2, master, 3V3 NOR" }, - { 0x12, 0x1f, "SSP SPI #2, master, 1V8 NOR" }, - { 0x03, 0x1f, "SSP SPI #3, master, 3V3 NOR" }, - { 0x13, 0x1f, "SSP SPI #3, master, 1V8 NOR" }, - { 0x04, 0x1f, "NAND, 3V3" }, - { 0x14, 0x1f, "NAND, 1V8" }, - { 0x08, 0x1f, "SSP SPI #3, master, 3V3 EEPROM" }, - { 0x18, 0x1f, "SSP SPI #3, master, 1V8 EEPROM" }, - { 0x09, 0x1f, "SSP SD/MMC #0, 3V3" }, - { 0x19, 0x1f, "SSP SD/MMC #0, 1V8" }, - { 0x0a, 0x1f, "SSP SD/MMC #1, 3V3" }, - { 0x1a, 0x1f, "SSP SD/MMC #1, 1V8" }, - { 0x00, 0x00, "Reserved/Unknown/Wrong" }, -}; - -struct mx28_spl_data { - uint8_t boot_mode_idx; - uint32_t mem_dram_size; -}; - -int mx28_dram_init(void); - -#endif /* __MX28_H__ */ diff --git a/arch/arm/include/asm/arch-mxs/clock.h b/arch/arm/include/asm/arch-mxs/clock.h new file mode 100644 index 0000000..1700fe3 --- /dev/null +++ b/arch/arm/include/asm/arch-mxs/clock.h @@ -0,0 +1,61 @@ +/* + * Freescale i.MX28 Clock + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __CLOCK_H__ +#define __CLOCK_H__ + +enum mxc_clock { + MXC_ARM_CLK = 0, + MXC_AHB_CLK, + MXC_IPG_CLK, + MXC_EMI_CLK, + MXC_GPMI_CLK, + MXC_IO0_CLK, + MXC_IO1_CLK, + MXC_SSP0_CLK, + MXC_SSP1_CLK, + MXC_SSP2_CLK, + MXC_SSP3_CLK, +}; + +enum mxs_ioclock { + MXC_IOCLK0 = 0, + MXC_IOCLK1, +}; + +enum mxs_sspclock { + MXC_SSPCLK0 = 0, + MXC_SSPCLK1, + MXC_SSPCLK2, + MXC_SSPCLK3, +}; + +uint32_t mxc_get_clock(enum mxc_clock clk); + +void mx28_set_ioclk(enum mxs_ioclock io, uint32_t freq); +void mx28_set_sspclk(enum mxs_sspclock ssp, uint32_t freq, int xtal); +void mx28_set_ssp_busclock(unsigned int bus, uint32_t freq); + +/* Compatibility with the FEC Ethernet driver */ +#define imx_get_fecclk() mxc_get_clock(MXC_AHB_CLK) + +#endif /* __CLOCK_H__ */ diff --git a/arch/arm/include/asm/arch-mxs/dma.h b/arch/arm/include/asm/arch-mxs/dma.h new file mode 100644 index 0000000..4a1820b --- /dev/null +++ b/arch/arm/include/asm/arch-mxs/dma.h @@ -0,0 +1,147 @@ +/* + * Freescale i.MX28 APBH DMA + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * Based on code from LTIB: + * Copyright 2008-2010 Freescale Semiconductor, Inc. All Rights Reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __DMA_H__ +#define __DMA_H__ + +#include <linux/list.h> + +#ifndef CONFIG_ARCH_DMA_PIO_WORDS +#define DMA_PIO_WORDS 15 +#else +#define DMA_PIO_WORDS CONFIG_ARCH_DMA_PIO_WORDS +#endif + +#define MXS_DMA_ALIGNMENT 32 + +/* + * MXS DMA channels + */ +enum { + MXS_DMA_CHANNEL_AHB_APBH_SSP0 = 0, + MXS_DMA_CHANNEL_AHB_APBH_SSP1, + MXS_DMA_CHANNEL_AHB_APBH_SSP2, + MXS_DMA_CHANNEL_AHB_APBH_SSP3, + MXS_DMA_CHANNEL_AHB_APBH_GPMI0, + MXS_DMA_CHANNEL_AHB_APBH_GPMI1, + MXS_DMA_CHANNEL_AHB_APBH_GPMI2, + MXS_DMA_CHANNEL_AHB_APBH_GPMI3, + MXS_DMA_CHANNEL_AHB_APBH_GPMI4, + MXS_DMA_CHANNEL_AHB_APBH_GPMI5, + MXS_DMA_CHANNEL_AHB_APBH_GPMI6, + MXS_DMA_CHANNEL_AHB_APBH_GPMI7, + MXS_DMA_CHANNEL_AHB_APBH_SSP, + MXS_MAX_DMA_CHANNELS, +}; + +/* + * MXS DMA hardware command. + * + * This structure describes the in-memory layout of an entire DMA command, + * including space for the maximum number of PIO accesses. See the appropriate + * reference manual for a detailed description of what these fields mean to the + * DMA hardware. + */ +#define MXS_DMA_DESC_COMMAND_MASK 0x3 +#define MXS_DMA_DESC_COMMAND_OFFSET 0 +#define MXS_DMA_DESC_COMMAND_NO_DMAXFER 0x0 +#define MXS_DMA_DESC_COMMAND_DMA_WRITE 0x1 +#define MXS_DMA_DESC_COMMAND_DMA_READ 0x2 +#define MXS_DMA_DESC_COMMAND_DMA_SENSE 0x3 +#define MXS_DMA_DESC_CHAIN (1 << 2) +#define MXS_DMA_DESC_IRQ (1 << 3) +#define MXS_DMA_DESC_NAND_LOCK (1 << 4) +#define MXS_DMA_DESC_NAND_WAIT_4_READY (1 << 5) +#define MXS_DMA_DESC_DEC_SEM (1 << 6) +#define MXS_DMA_DESC_WAIT4END (1 << 7) +#define MXS_DMA_DESC_HALT_ON_TERMINATE (1 << 8) +#define MXS_DMA_DESC_TERMINATE_FLUSH (1 << 9) +#define MXS_DMA_DESC_PIO_WORDS_MASK (0xf << 12) +#define MXS_DMA_DESC_PIO_WORDS_OFFSET 12 +#define MXS_DMA_DESC_BYTES_MASK (0xffff << 16) +#define MXS_DMA_DESC_BYTES_OFFSET 16 + +struct mxs_dma_cmd { + unsigned long next; + unsigned long data; + union { + dma_addr_t address; + unsigned long alternate; + }; + unsigned long pio_words[DMA_PIO_WORDS]; +}; + +/* + * MXS DMA command descriptor. + * + * This structure incorporates an MXS DMA hardware command structure, along + * with metadata. + */ +#define MXS_DMA_DESC_FIRST (1 << 0) +#define MXS_DMA_DESC_LAST (1 << 1) +#define MXS_DMA_DESC_READY (1 << 31) + +struct mxs_dma_desc { + struct mxs_dma_cmd cmd; + unsigned int flags; + dma_addr_t address; + void *buffer; + struct list_head node; +}; + +/** + * MXS DMA channel + * + * This structure represents a single DMA channel. The MXS platform code + * maintains an array of these structures to represent every DMA channel in the + * system (see mxs_dma_channels). + */ +#define MXS_DMA_FLAGS_IDLE 0 +#define MXS_DMA_FLAGS_BUSY (1 << 0) +#define MXS_DMA_FLAGS_FREE 0 +#define MXS_DMA_FLAGS_ALLOCATED (1 << 16) +#define MXS_DMA_FLAGS_VALID (1 << 31) + +struct mxs_dma_chan { + const char *name; + unsigned long dev; + struct mxs_dma_device *dma; + unsigned int flags; + unsigned int active_num; + unsigned int pending_num; + struct list_head active; + struct list_head done; +}; + +struct mxs_dma_desc *mxs_dma_desc_alloc(void); +void mxs_dma_desc_free(struct mxs_dma_desc *); +int mxs_dma_desc_append(int channel, struct mxs_dma_desc *pdesc); + +int mxs_dma_go(int chan); +void mxs_dma_init(void); +int mxs_dma_init_channel(int chan); +int mxs_dma_release(int chan); + +#endif /* __DMA_H__ */ diff --git a/arch/arm/include/asm/arch-mxs/gpio.h b/arch/arm/include/asm/arch-mxs/gpio.h new file mode 100644 index 0000000..be1c944 --- /dev/null +++ b/arch/arm/include/asm/arch-mxs/gpio.h @@ -0,0 +1,32 @@ +/* + * Freescale i.MX28 GPIO + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __MX28_GPIO_H__ +#define __MX28_GPIO_H__ + +#ifdef CONFIG_MXS_GPIO +void mxs_gpio_init(void); +#else +inline void mxs_gpio_init(void) {} +#endif + +#endif /* __MX28_GPIO_H__ */ diff --git a/arch/arm/include/asm/arch-mxs/imx-regs.h b/arch/arm/include/asm/arch-mxs/imx-regs.h new file mode 100644 index 0000000..37d0a93 --- /dev/null +++ b/arch/arm/include/asm/arch-mxs/imx-regs.h @@ -0,0 +1,42 @@ +/* + * Freescale i.MX28 Registers + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __IMX_REGS_H__ +#define __IMX_REGS_H__ + +#include <asm/arch/regs-apbh.h> +#include <asm/arch/regs-base.h> +#include <asm/arch/regs-bch.h> +#include <asm/arch/regs-clkctrl.h> +#include <asm/arch/regs-digctl.h> +#include <asm/arch/regs-gpmi.h> +#include <asm/arch/regs-i2c.h> +#include <asm/arch/regs-lcdif.h> +#include <asm/arch/regs-lradc.h> +#include <asm/arch/regs-ocotp.h> +#include <asm/arch/regs-pinctrl.h> +#include <asm/arch/regs-power.h> +#include <asm/arch/regs-rtc.h> +#include <asm/arch/regs-ssp.h> +#include <asm/arch/regs-timrot.h> + +#endif /* __IMX_REGS_H__ */ diff --git a/arch/arm/include/asm/arch-mxs/iomux-mx28.h b/arch/arm/include/asm/arch-mxs/iomux-mx28.h new file mode 100644 index 0000000..b42820d --- /dev/null +++ b/arch/arm/include/asm/arch-mxs/iomux-mx28.h @@ -0,0 +1,537 @@ +/* + * Copyright (C) 2009-2010 Amit Kucheria amit.kucheria@canonical.com + * Copyright (C) 2010 Freescale Semiconductor, Inc. + * + * The code contained herein is licensed under the GNU General Public + * License. You may obtain a copy of the GNU General Public License + * Version 2 or later at the following locations: + * + * http://www.opensource.org/licenses/gpl-license.html + * http://www.gnu.org/copyleft/gpl.html + */ + +#ifndef __MACH_IOMUX_MX28_H__ +#define __MACH_IOMUX_MX28_H__ + +#include <asm/arch/iomux.h> + +/* + * The naming convention for the pad modes is MX28_PAD_<padname>__<padmode> + * If <padname> or <padmode> refers to a GPIO, it is named GPIO_<unit>_<num> + * See also iomux.h + * + * BANK PIN MUX + */ +/* MUXSEL_0 */ +#define MX28_PAD_GPMI_D00__GPMI_D0 MXS_IOMUX_PAD_NAKED(0, 0, PAD_MUXSEL_0) +#define MX28_PAD_GPMI_D01__GPMI_D1 MXS_IOMUX_PAD_NAKED(0, 1, PAD_MUXSEL_0) +#define MX28_PAD_GPMI_D02__GPMI_D2 MXS_IOMUX_PAD_NAKED(0, 2, PAD_MUXSEL_0) +#define MX28_PAD_GPMI_D03__GPMI_D3 MXS_IOMUX_PAD_NAKED(0, 3, PAD_MUXSEL_0) +#define MX28_PAD_GPMI_D04__GPMI_D4 MXS_IOMUX_PAD_NAKED(0, 4, PAD_MUXSEL_0) +#define MX28_PAD_GPMI_D05__GPMI_D5 MXS_IOMUX_PAD_NAKED(0, 5, PAD_MUXSEL_0) +#define MX28_PAD_GPMI_D06__GPMI_D6 MXS_IOMUX_PAD_NAKED(0, 6, PAD_MUXSEL_0) +#define MX28_PAD_GPMI_D07__GPMI_D7 MXS_IOMUX_PAD_NAKED(0, 7, PAD_MUXSEL_0) +#define MX28_PAD_GPMI_CE0N__GPMI_CE0N MXS_IOMUX_PAD_NAKED(0, 16, PAD_MUXSEL_0) +#define MX28_PAD_GPMI_CE1N__GPMI_CE1N MXS_IOMUX_PAD_NAKED(0, 17, PAD_MUXSEL_0) +#define MX28_PAD_GPMI_CE2N__GPMI_CE2N MXS_IOMUX_PAD_NAKED(0, 18, PAD_MUXSEL_0) +#define MX28_PAD_GPMI_CE3N__GPMI_CE3N MXS_IOMUX_PAD_NAKED(0, 19, PAD_MUXSEL_0) +#define MX28_PAD_GPMI_RDY0__GPMI_READY0 MXS_IOMUX_PAD_NAKED(0, 20, PAD_MUXSEL_0) +#define MX28_PAD_GPMI_RDY1__GPMI_READY1 MXS_IOMUX_PAD_NAKED(0, 21, PAD_MUXSEL_0) +#define MX28_PAD_GPMI_RDY2__GPMI_READY2 MXS_IOMUX_PAD_NAKED(0, 22, PAD_MUXSEL_0) +#define MX28_PAD_GPMI_RDY3__GPMI_READY3 MXS_IOMUX_PAD_NAKED(0, 23, PAD_MUXSEL_0) +#define MX28_PAD_GPMI_RDN__GPMI_RDN MXS_IOMUX_PAD_NAKED(0, 24, PAD_MUXSEL_0) +#define MX28_PAD_GPMI_WRN__GPMI_WRN MXS_IOMUX_PAD_NAKED(0, 25, PAD_MUXSEL_0) +#define MX28_PAD_GPMI_ALE__GPMI_ALE MXS_IOMUX_PAD_NAKED(0, 26, PAD_MUXSEL_0) +#define MX28_PAD_GPMI_CLE__GPMI_CLE MXS_IOMUX_PAD_NAKED(0, 27, PAD_MUXSEL_0) +#define MX28_PAD_GPMI_RESETN__GPMI_RESETN MXS_IOMUX_PAD_NAKED(0, 28, PAD_MUXSEL_0) + +#define MX28_PAD_LCD_D00__LCD_D0 MXS_IOMUX_PAD_NAKED(1, 0, PAD_MUXSEL_0) +#define MX28_PAD_LCD_D01__LCD_D1 MXS_IOMUX_PAD_NAKED(1, 1, PAD_MUXSEL_0) +#define MX28_PAD_LCD_D02__LCD_D2 MXS_IOMUX_PAD_NAKED(1, 2, PAD_MUXSEL_0) +#define MX28_PAD_LCD_D03__LCD_D3 MXS_IOMUX_PAD_NAKED(1, 3, PAD_MUXSEL_0) +#define MX28_PAD_LCD_D04__LCD_D4 MXS_IOMUX_PAD_NAKED(1, 4, PAD_MUXSEL_0) +#define MX28_PAD_LCD_D05__LCD_D5 MXS_IOMUX_PAD_NAKED(1, 5, PAD_MUXSEL_0) +#define MX28_PAD_LCD_D06__LCD_D6 MXS_IOMUX_PAD_NAKED(1, 6, PAD_MUXSEL_0) +#define MX28_PAD_LCD_D07__LCD_D7 MXS_IOMUX_PAD_NAKED(1, 7, PAD_MUXSEL_0) +#define MX28_PAD_LCD_D08__LCD_D8 MXS_IOMUX_PAD_NAKED(1, 8, PAD_MUXSEL_0) +#define MX28_PAD_LCD_D09__LCD_D9 MXS_IOMUX_PAD_NAKED(1, 9, PAD_MUXSEL_0) +#define MX28_PAD_LCD_D10__LCD_D10 MXS_IOMUX_PAD_NAKED(1, 10, PAD_MUXSEL_0) +#define MX28_PAD_LCD_D11__LCD_D11 MXS_IOMUX_PAD_NAKED(1, 11, PAD_MUXSEL_0) +#define MX28_PAD_LCD_D12__LCD_D12 MXS_IOMUX_PAD_NAKED(1, 12, PAD_MUXSEL_0) +#define MX28_PAD_LCD_D13__LCD_D13 MXS_IOMUX_PAD_NAKED(1, 13, PAD_MUXSEL_0) +#define MX28_PAD_LCD_D14__LCD_D14 MXS_IOMUX_PAD_NAKED(1, 14, PAD_MUXSEL_0) +#define MX28_PAD_LCD_D15__LCD_D15 MXS_IOMUX_PAD_NAKED(1, 15, PAD_MUXSEL_0) +#define MX28_PAD_LCD_D16__LCD_D16 MXS_IOMUX_PAD_NAKED(1, 16, PAD_MUXSEL_0) +#define MX28_PAD_LCD_D17__LCD_D17 MXS_IOMUX_PAD_NAKED(1, 17, PAD_MUXSEL_0) +#define MX28_PAD_LCD_D18__LCD_D18 MXS_IOMUX_PAD_NAKED(1, 18, PAD_MUXSEL_0) +#define MX28_PAD_LCD_D19__LCD_D19 MXS_IOMUX_PAD_NAKED(1, 19, PAD_MUXSEL_0) +#define MX28_PAD_LCD_D20__LCD_D20 MXS_IOMUX_PAD_NAKED(1, 20, PAD_MUXSEL_0) +#define MX28_PAD_LCD_D21__LCD_D21 MXS_IOMUX_PAD_NAKED(1, 21, PAD_MUXSEL_0) +#define MX28_PAD_LCD_D22__LCD_D22 MXS_IOMUX_PAD_NAKED(1, 22, PAD_MUXSEL_0) +#define MX28_PAD_LCD_D23__LCD_D23 MXS_IOMUX_PAD_NAKED(1, 23, PAD_MUXSEL_0) +#define MX28_PAD_LCD_RD_E__LCD_RD_E MXS_IOMUX_PAD_NAKED(1, 24, PAD_MUXSEL_0) +#define MX28_PAD_LCD_WR_RWN__LCD_WR_RWN MXS_IOMUX_PAD_NAKED(1, 25, PAD_MUXSEL_0) +#define MX28_PAD_LCD_RS__LCD_RS MXS_IOMUX_PAD_NAKED(1, 26, PAD_MUXSEL_0) +#define MX28_PAD_LCD_CS__LCD_CS MXS_IOMUX_PAD_NAKED(1, 27, PAD_MUXSEL_0) +#define MX28_PAD_LCD_VSYNC__LCD_VSYNC MXS_IOMUX_PAD_NAKED(1, 28, PAD_MUXSEL_0) +#define MX28_PAD_LCD_HSYNC__LCD_HSYNC MXS_IOMUX_PAD_NAKED(1, 29, PAD_MUXSEL_0) +#define MX28_PAD_LCD_DOTCLK__LCD_DOTCLK MXS_IOMUX_PAD_NAKED(1, 30, PAD_MUXSEL_0) +#define MX28_PAD_LCD_ENABLE__LCD_ENABLE MXS_IOMUX_PAD_NAKED(1, 31, PAD_MUXSEL_0) + +#define MX28_PAD_SSP0_DATA0__SSP0_D0 MXS_IOMUX_PAD_NAKED(2, 0, PAD_MUXSEL_0) +#define MX28_PAD_SSP0_DATA1__SSP0_D1 MXS_IOMUX_PAD_NAKED(2, 1, PAD_MUXSEL_0) +#define MX28_PAD_SSP0_DATA2__SSP0_D2 MXS_IOMUX_PAD_NAKED(2, 2, PAD_MUXSEL_0) +#define MX28_PAD_SSP0_DATA3__SSP0_D3 MXS_IOMUX_PAD_NAKED(2, 3, PAD_MUXSEL_0) +#define MX28_PAD_SSP0_DATA4__SSP0_D4 MXS_IOMUX_PAD_NAKED(2, 4, PAD_MUXSEL_0) +#define MX28_PAD_SSP0_DATA5__SSP0_D5 MXS_IOMUX_PAD_NAKED(2, 5, PAD_MUXSEL_0) +#define MX28_PAD_SSP0_DATA6__SSP0_D6 MXS_IOMUX_PAD_NAKED(2, 6, PAD_MUXSEL_0) +#define MX28_PAD_SSP0_DATA7__SSP0_D7 MXS_IOMUX_PAD_NAKED(2, 7, PAD_MUXSEL_0) +#define MX28_PAD_SSP0_CMD__SSP0_CMD MXS_IOMUX_PAD_NAKED(2, 8, PAD_MUXSEL_0) +#define MX28_PAD_SSP0_DETECT__SSP0_CARD_DETECT MXS_IOMUX_PAD_NAKED(2, 9, PAD_MUXSEL_0) +#define MX28_PAD_SSP0_SCK__SSP0_SCK MXS_IOMUX_PAD_NAKED(2, 10, PAD_MUXSEL_0) +#define MX28_PAD_SSP1_SCK__SSP1_SCK MXS_IOMUX_PAD_NAKED(2, 12, PAD_MUXSEL_0) +#define MX28_PAD_SSP1_CMD__SSP1_CMD MXS_IOMUX_PAD_NAKED(2, 13, PAD_MUXSEL_0) +#define MX28_PAD_SSP1_DATA0__SSP1_D0 MXS_IOMUX_PAD_NAKED(2, 14, PAD_MUXSEL_0) +#define MX28_PAD_SSP1_DATA3__SSP1_D3 MXS_IOMUX_PAD_NAKED(2, 15, PAD_MUXSEL_0) +#define MX28_PAD_SSP2_SCK__SSP2_SCK MXS_IOMUX_PAD_NAKED(2, 16, PAD_MUXSEL_0) +#define MX28_PAD_SSP2_MOSI__SSP2_CMD MXS_IOMUX_PAD_NAKED(2, 17, PAD_MUXSEL_0) +#define MX28_PAD_SSP2_MISO__SSP2_D0 MXS_IOMUX_PAD_NAKED(2, 18, PAD_MUXSEL_0) +#define MX28_PAD_SSP2_SS0__SSP2_D3 MXS_IOMUX_PAD_NAKED(2, 19, PAD_MUXSEL_0) +#define MX28_PAD_SSP2_SS1__SSP2_D4 MXS_IOMUX_PAD_NAKED(2, 20, PAD_MUXSEL_0) +#define MX28_PAD_SSP2_SS2__SSP2_D5 MXS_IOMUX_PAD_NAKED(2, 21, PAD_MUXSEL_0) +#define MX28_PAD_SSP3_SCK__SSP3_SCK MXS_IOMUX_PAD_NAKED(2, 24, PAD_MUXSEL_0) +#define MX28_PAD_SSP3_MOSI__SSP3_CMD MXS_IOMUX_PAD_NAKED(2, 25, PAD_MUXSEL_0) +#define MX28_PAD_SSP3_MISO__SSP3_D0 MXS_IOMUX_PAD_NAKED(2, 26, PAD_MUXSEL_0) +#define MX28_PAD_SSP3_SS0__SSP3_D3 MXS_IOMUX_PAD_NAKED(2, 27, PAD_MUXSEL_0) + +#define MX28_PAD_AUART0_RX__AUART0_RX MXS_IOMUX_PAD_NAKED(3, 0, PAD_MUXSEL_0) +#define MX28_PAD_AUART0_TX__AUART0_TX MXS_IOMUX_PAD_NAKED(3, 1, PAD_MUXSEL_0) +#define MX28_PAD_AUART0_CTS__AUART0_CTS MXS_IOMUX_PAD_NAKED(3, 2, PAD_MUXSEL_0) +#define MX28_PAD_AUART0_RTS__AUART0_RTS MXS_IOMUX_PAD_NAKED(3, 3, PAD_MUXSEL_0) +#define MX28_PAD_AUART1_RX__AUART1_RX MXS_IOMUX_PAD_NAKED(3, 4, PAD_MUXSEL_0) +#define MX28_PAD_AUART1_TX__AUART1_TX MXS_IOMUX_PAD_NAKED(3, 5, PAD_MUXSEL_0) +#define MX28_PAD_AUART1_CTS__AUART1_CTS MXS_IOMUX_PAD_NAKED(3, 6, PAD_MUXSEL_0) +#define MX28_PAD_AUART1_RTS__AUART1_RTS MXS_IOMUX_PAD_NAKED(3, 7, PAD_MUXSEL_0) +#define MX28_PAD_AUART2_RX__AUART2_RX MXS_IOMUX_PAD_NAKED(3, 8, PAD_MUXSEL_0) +#define MX28_PAD_AUART2_TX__AUART2_TX MXS_IOMUX_PAD_NAKED(3, 9, PAD_MUXSEL_0) +#define MX28_PAD_AUART2_CTS__AUART2_CTS MXS_IOMUX_PAD_NAKED(3, 10, PAD_MUXSEL_0) +#define MX28_PAD_AUART2_RTS__AUART2_RTS MXS_IOMUX_PAD_NAKED(3, 11, PAD_MUXSEL_0) +#define MX28_PAD_AUART3_RX__AUART3_RX MXS_IOMUX_PAD_NAKED(3, 12, PAD_MUXSEL_0) +#define MX28_PAD_AUART3_TX__AUART3_TX MXS_IOMUX_PAD_NAKED(3, 13, PAD_MUXSEL_0) +#define MX28_PAD_AUART3_CTS__AUART3_CTS MXS_IOMUX_PAD_NAKED(3, 14, PAD_MUXSEL_0) +#define MX28_PAD_AUART3_RTS__AUART3_RTS MXS_IOMUX_PAD_NAKED(3, 15, PAD_MUXSEL_0) +#define MX28_PAD_PWM0__PWM_0 MXS_IOMUX_PAD_NAKED(3, 16, PAD_MUXSEL_0) +#define MX28_PAD_PWM1__PWM_1 MXS_IOMUX_PAD_NAKED(3, 17, PAD_MUXSEL_0) +#define MX28_PAD_PWM2__PWM_2 MXS_IOMUX_PAD_NAKED(3, 18, PAD_MUXSEL_0) +#define MX28_PAD_SAIF0_MCLK__SAIF0_MCLK MXS_IOMUX_PAD_NAKED(3, 20, PAD_MUXSEL_0) +#define MX28_PAD_SAIF0_LRCLK__SAIF0_LRCLK MXS_IOMUX_PAD_NAKED(3, 21, PAD_MUXSEL_0) +#define MX28_PAD_SAIF0_BITCLK__SAIF0_BITCLK MXS_IOMUX_PAD_NAKED(3, 22, PAD_MUXSEL_0) +#define MX28_PAD_SAIF0_SDATA0__SAIF0_SDATA0 MXS_IOMUX_PAD_NAKED(3, 23, PAD_MUXSEL_0) +#define MX28_PAD_I2C0_SCL__I2C0_SCL MXS_IOMUX_PAD_NAKED(3, 24, PAD_MUXSEL_0) +#define MX28_PAD_I2C0_SDA__I2C0_SDA MXS_IOMUX_PAD_NAKED(3, 25, PAD_MUXSEL_0) +#define MX28_PAD_SAIF1_SDATA0__SAIF1_SDATA0 MXS_IOMUX_PAD_NAKED(3, 26, PAD_MUXSEL_0) +#define MX28_PAD_SPDIF__SPDIF_TX MXS_IOMUX_PAD_NAKED(3, 27, PAD_MUXSEL_0) +#define MX28_PAD_PWM3__PWM_3 MXS_IOMUX_PAD_NAKED(3, 28, PAD_MUXSEL_0) +#define MX28_PAD_PWM4__PWM_4 MXS_IOMUX_PAD_NAKED(3, 29, PAD_MUXSEL_0) +#define MX28_PAD_LCD_RESET__LCD_RESET MXS_IOMUX_PAD_NAKED(3, 30, PAD_MUXSEL_0) + +#define MX28_PAD_ENET0_MDC__ENET0_MDC MXS_IOMUX_PAD_NAKED(4, 0, PAD_MUXSEL_0) +#define MX28_PAD_ENET0_MDIO__ENET0_MDIO MXS_IOMUX_PAD_NAKED(4, 1, PAD_MUXSEL_0) +#define MX28_PAD_ENET0_RX_EN__ENET0_RX_EN MXS_IOMUX_PAD_NAKED(4, 2, PAD_MUXSEL_0) +#define MX28_PAD_ENET0_RXD0__ENET0_RXD0 MXS_IOMUX_PAD_NAKED(4, 3, PAD_MUXSEL_0) +#define MX28_PAD_ENET0_RXD1__ENET0_RXD1 MXS_IOMUX_PAD_NAKED(4, 4, PAD_MUXSEL_0) +#define MX28_PAD_ENET0_TX_CLK__ENET0_TX_CLK MXS_IOMUX_PAD_NAKED(4, 5, PAD_MUXSEL_0) +#define MX28_PAD_ENET0_TX_EN__ENET0_TX_EN MXS_IOMUX_PAD_NAKED(4, 6, PAD_MUXSEL_0) +#define MX28_PAD_ENET0_TXD0__ENET0_TXD0 MXS_IOMUX_PAD_NAKED(4, 7, PAD_MUXSEL_0) +#define MX28_PAD_ENET0_TXD1__ENET0_TXD1 MXS_IOMUX_PAD_NAKED(4, 8, PAD_MUXSEL_0) +#define MX28_PAD_ENET0_RXD2__ENET0_RXD2 MXS_IOMUX_PAD_NAKED(4, 9, PAD_MUXSEL_0) +#define MX28_PAD_ENET0_RXD3__ENET0_RXD3 MXS_IOMUX_PAD_NAKED(4, 10, PAD_MUXSEL_0) +#define MX28_PAD_ENET0_TXD2__ENET0_TXD2 MXS_IOMUX_PAD_NAKED(4, 11, PAD_MUXSEL_0) +#define MX28_PAD_ENET0_TXD3__ENET0_TXD3 MXS_IOMUX_PAD_NAKED(4, 12, PAD_MUXSEL_0) +#define MX28_PAD_ENET0_RX_CLK__ENET0_RX_CLK MXS_IOMUX_PAD_NAKED(4, 13, PAD_MUXSEL_0) +#define MX28_PAD_ENET0_COL__ENET0_COL MXS_IOMUX_PAD_NAKED(4, 14, PAD_MUXSEL_0) +#define MX28_PAD_ENET0_CRS__ENET0_CRS MXS_IOMUX_PAD_NAKED(4, 15, PAD_MUXSEL_0) +#define MX28_PAD_ENET_CLK__CLKCTRL_ENET MXS_IOMUX_PAD_NAKED(4, 16, PAD_MUXSEL_0) +#define MX28_PAD_JTAG_RTCK__JTAG_RTCK MXS_IOMUX_PAD_NAKED(4, 20, PAD_MUXSEL_0) + +#define MX28_PAD_EMI_D00__EMI_DATA0 MXS_IOMUX_PAD_NAKED(5, 0, PAD_MUXSEL_0) +#define MX28_PAD_EMI_D01__EMI_DATA1 MXS_IOMUX_PAD_NAKED(5, 1, PAD_MUXSEL_0) +#define MX28_PAD_EMI_D02__EMI_DATA2 MXS_IOMUX_PAD_NAKED(5, 2, PAD_MUXSEL_0) +#define MX28_PAD_EMI_D03__EMI_DATA3 MXS_IOMUX_PAD_NAKED(5, 3, PAD_MUXSEL_0) +#define MX28_PAD_EMI_D04__EMI_DATA4 MXS_IOMUX_PAD_NAKED(5, 4, PAD_MUXSEL_0) +#define MX28_PAD_EMI_D05__EMI_DATA5 MXS_IOMUX_PAD_NAKED(5, 5, PAD_MUXSEL_0) +#define MX28_PAD_EMI_D06__EMI_DATA6 MXS_IOMUX_PAD_NAKED(5, 6, PAD_MUXSEL_0) +#define MX28_PAD_EMI_D07__EMI_DATA7 MXS_IOMUX_PAD_NAKED(5, 7, PAD_MUXSEL_0) +#define MX28_PAD_EMI_D08__EMI_DATA8 MXS_IOMUX_PAD_NAKED(5, 8, PAD_MUXSEL_0) +#define MX28_PAD_EMI_D09__EMI_DATA9 MXS_IOMUX_PAD_NAKED(5, 9, PAD_MUXSEL_0) +#define MX28_PAD_EMI_D10__EMI_DATA10 MXS_IOMUX_PAD_NAKED(5, 10, PAD_MUXSEL_0) +#define MX28_PAD_EMI_D11__EMI_DATA11 MXS_IOMUX_PAD_NAKED(5, 11, PAD_MUXSEL_0) +#define MX28_PAD_EMI_D12__EMI_DATA12 MXS_IOMUX_PAD_NAKED(5, 12, PAD_MUXSEL_0) +#define MX28_PAD_EMI_D13__EMI_DATA13 MXS_IOMUX_PAD_NAKED(5, 13, PAD_MUXSEL_0) +#define MX28_PAD_EMI_D14__EMI_DATA14 MXS_IOMUX_PAD_NAKED(5, 14, PAD_MUXSEL_0) +#define MX28_PAD_EMI_D15__EMI_DATA15 MXS_IOMUX_PAD_NAKED(5, 15, PAD_MUXSEL_0) +#define MX28_PAD_EMI_ODT0__EMI_ODT0 MXS_IOMUX_PAD_NAKED(5, 16, PAD_MUXSEL_0) +#define MX28_PAD_EMI_DQM0__EMI_DQM0 MXS_IOMUX_PAD_NAKED(5, 17, PAD_MUXSEL_0) +#define MX28_PAD_EMI_ODT1__EMI_ODT1 MXS_IOMUX_PAD_NAKED(5, 18, PAD_MUXSEL_0) +#define MX28_PAD_EMI_DQM1__EMI_DQM1 MXS_IOMUX_PAD_NAKED(5, 19, PAD_MUXSEL_0) +#define MX28_PAD_EMI_DDR_OPEN_FB__EMI_DDR_OPEN_FEEDBACK MXS_IOMUX_PAD_NAKED(5, 20, PAD_MUXSEL_0) +#define MX28_PAD_EMI_CLK__EMI_CLK MXS_IOMUX_PAD_NAKED(5, 21, PAD_MUXSEL_0) +#define MX28_PAD_EMI_DQS0__EMI_DQS0 MXS_IOMUX_PAD_NAKED(5, 22, PAD_MUXSEL_0) +#define MX28_PAD_EMI_DQS1__EMI_DQS1 MXS_IOMUX_PAD_NAKED(5, 23, PAD_MUXSEL_0) +#define MX28_PAD_EMI_DDR_OPEN__EMI_DDR_OPEN MXS_IOMUX_PAD_NAKED(5, 26, PAD_MUXSEL_0) + +#define MX28_PAD_EMI_A00__EMI_ADDR0 MXS_IOMUX_PAD_NAKED(6, 0, PAD_MUXSEL_0) +#define MX28_PAD_EMI_A01__EMI_ADDR1 MXS_IOMUX_PAD_NAKED(6, 1, PAD_MUXSEL_0) +#define MX28_PAD_EMI_A02__EMI_ADDR2 MXS_IOMUX_PAD_NAKED(6, 2, PAD_MUXSEL_0) +#define MX28_PAD_EMI_A03__EMI_ADDR3 MXS_IOMUX_PAD_NAKED(6, 3, PAD_MUXSEL_0) +#define MX28_PAD_EMI_A04__EMI_ADDR4 MXS_IOMUX_PAD_NAKED(6, 4, PAD_MUXSEL_0) +#define MX28_PAD_EMI_A05__EMI_ADDR5 MXS_IOMUX_PAD_NAKED(6, 5, PAD_MUXSEL_0) +#define MX28_PAD_EMI_A06__EMI_ADDR6 MXS_IOMUX_PAD_NAKED(6, 6, PAD_MUXSEL_0) +#define MX28_PAD_EMI_A07__EMI_ADDR7 MXS_IOMUX_PAD_NAKED(6, 7, PAD_MUXSEL_0) +#define MX28_PAD_EMI_A08__EMI_ADDR8 MXS_IOMUX_PAD_NAKED(6, 8, PAD_MUXSEL_0) +#define MX28_PAD_EMI_A09__EMI_ADDR9 MXS_IOMUX_PAD_NAKED(6, 9, PAD_MUXSEL_0) +#define MX28_PAD_EMI_A10__EMI_ADDR10 MXS_IOMUX_PAD_NAKED(6, 10, PAD_MUXSEL_0) +#define MX28_PAD_EMI_A11__EMI_ADDR11 MXS_IOMUX_PAD_NAKED(6, 11, PAD_MUXSEL_0) +#define MX28_PAD_EMI_A12__EMI_ADDR12 MXS_IOMUX_PAD_NAKED(6, 12, PAD_MUXSEL_0) +#define MX28_PAD_EMI_A13__EMI_ADDR13 MXS_IOMUX_PAD_NAKED(6, 13, PAD_MUXSEL_0) +#define MX28_PAD_EMI_A14__EMI_ADDR14 MXS_IOMUX_PAD_NAKED(6, 14, PAD_MUXSEL_0) +#define MX28_PAD_EMI_BA0__EMI_BA0 MXS_IOMUX_PAD_NAKED(6, 16, PAD_MUXSEL_0) +#define MX28_PAD_EMI_BA1__EMI_BA1 MXS_IOMUX_PAD_NAKED(6, 17, PAD_MUXSEL_0) +#define MX28_PAD_EMI_BA2__EMI_BA2 MXS_IOMUX_PAD_NAKED(6, 18, PAD_MUXSEL_0) +#define MX28_PAD_EMI_CASN__EMI_CASN MXS_IOMUX_PAD_NAKED(6, 19, PAD_MUXSEL_0) +#define MX28_PAD_EMI_RASN__EMI_RASN MXS_IOMUX_PAD_NAKED(6, 20, PAD_MUXSEL_0) +#define MX28_PAD_EMI_WEN__EMI_WEN MXS_IOMUX_PAD_NAKED(6, 21, PAD_MUXSEL_0) +#define MX28_PAD_EMI_CE0N__EMI_CE0N MXS_IOMUX_PAD_NAKED(6, 22, PAD_MUXSEL_0) +#define MX28_PAD_EMI_CE1N__EMI_CE1N MXS_IOMUX_PAD_NAKED(6, 23, PAD_MUXSEL_0) +#define MX28_PAD_EMI_CKE__EMI_CKE MXS_IOMUX_PAD_NAKED(6, 24, PAD_MUXSEL_0) + +/* MUXSEL_1 */ +#define MX28_PAD_GPMI_D00__SSP1_D0 MXS_IOMUX_PAD_NAKED(0, 0, PAD_MUXSEL_1) +#define MX28_PAD_GPMI_D01__SSP1_D1 MXS_IOMUX_PAD_NAKED(0, 1, PAD_MUXSEL_1) +#define MX28_PAD_GPMI_D02__SSP1_D2 MXS_IOMUX_PAD_NAKED(0, 2, PAD_MUXSEL_1) +#define MX28_PAD_GPMI_D03__SSP1_D3 MXS_IOMUX_PAD_NAKED(0, 3, PAD_MUXSEL_1) +#define MX28_PAD_GPMI_D04__SSP1_D4 MXS_IOMUX_PAD_NAKED(0, 4, PAD_MUXSEL_1) +#define MX28_PAD_GPMI_D05__SSP1_D5 MXS_IOMUX_PAD_NAKED(0, 5, PAD_MUXSEL_1) +#define MX28_PAD_GPMI_D06__SSP1_D6 MXS_IOMUX_PAD_NAKED(0, 6, PAD_MUXSEL_1) +#define MX28_PAD_GPMI_D07__SSP1_D7 MXS_IOMUX_PAD_NAKED(0, 7, PAD_MUXSEL_1) +#define MX28_PAD_GPMI_CE0N__SSP3_D0 MXS_IOMUX_PAD_NAKED(0, 16, PAD_MUXSEL_1) +#define MX28_PAD_GPMI_CE1N__SSP3_D3 MXS_IOMUX_PAD_NAKED(0, 17, PAD_MUXSEL_1) +#define MX28_PAD_GPMI_CE2N__CAN1_TX MXS_IOMUX_PAD_NAKED(0, 18, PAD_MUXSEL_1) +#define MX28_PAD_GPMI_CE3N__CAN1_RX MXS_IOMUX_PAD_NAKED(0, 19, PAD_MUXSEL_1) +#define MX28_PAD_GPMI_RDY0__SSP1_CARD_DETECT MXS_IOMUX_PAD_NAKED(0, 20, PAD_MUXSEL_1) +#define MX28_PAD_GPMI_RDY1__SSP1_CMD MXS_IOMUX_PAD_NAKED(0, 21, PAD_MUXSEL_1) +#define MX28_PAD_GPMI_RDY2__CAN0_TX MXS_IOMUX_PAD_NAKED(0, 22, PAD_MUXSEL_1) +#define MX28_PAD_GPMI_RDY3__CAN0_RX MXS_IOMUX_PAD_NAKED(0, 23, PAD_MUXSEL_1) +#define MX28_PAD_GPMI_RDN__SSP3_SCK MXS_IOMUX_PAD_NAKED(0, 24, PAD_MUXSEL_1) +#define MX28_PAD_GPMI_WRN__SSP1_SCK MXS_IOMUX_PAD_NAKED(0, 25, PAD_MUXSEL_1) +#define MX28_PAD_GPMI_ALE__SSP3_D1 MXS_IOMUX_PAD_NAKED(0, 26, PAD_MUXSEL_1) +#define MX28_PAD_GPMI_CLE__SSP3_D2 MXS_IOMUX_PAD_NAKED(0, 27, PAD_MUXSEL_1) +#define MX28_PAD_GPMI_RESETN__SSP3_CMD MXS_IOMUX_PAD_NAKED(0, 28, PAD_MUXSEL_1) + +#define MX28_PAD_LCD_D03__ETM_DA8 MXS_IOMUX_PAD_NAKED(1, 3, PAD_MUXSEL_1) +#define MX28_PAD_LCD_D04__ETM_DA9 MXS_IOMUX_PAD_NAKED(1, 4, PAD_MUXSEL_1) +#define MX28_PAD_LCD_D08__ETM_DA3 MXS_IOMUX_PAD_NAKED(1, 8, PAD_MUXSEL_1) +#define MX28_PAD_LCD_D09__ETM_DA4 MXS_IOMUX_PAD_NAKED(1, 9, PAD_MUXSEL_1) +#define MX28_PAD_LCD_D20__ENET1_1588_EVENT2_OUT MXS_IOMUX_PAD_NAKED(1, 20, PAD_MUXSEL_1) +#define MX28_PAD_LCD_D21__ENET1_1588_EVENT2_IN MXS_IOMUX_PAD_NAKED(1, 21, PAD_MUXSEL_1) +#define MX28_PAD_LCD_D22__ENET1_1588_EVENT3_OUT MXS_IOMUX_PAD_NAKED(1, 22, PAD_MUXSEL_1) +#define MX28_PAD_LCD_D23__ENET1_1588_EVENT3_IN MXS_IOMUX_PAD_NAKED(1, 23, PAD_MUXSEL_1) +#define MX28_PAD_LCD_RD_E__LCD_VSYNC MXS_IOMUX_PAD_NAKED(1, 24, PAD_MUXSEL_1) +#define MX28_PAD_LCD_WR_RWN__LCD_HSYNC MXS_IOMUX_PAD_NAKED(1, 25, PAD_MUXSEL_1) +#define MX28_PAD_LCD_RS__LCD_DOTCLK MXS_IOMUX_PAD_NAKED(1, 26, PAD_MUXSEL_1) +#define MX28_PAD_LCD_CS__LCD_ENABLE MXS_IOMUX_PAD_NAKED(1, 27, PAD_MUXSEL_1) +#define MX28_PAD_LCD_VSYNC__SAIF1_SDATA0 MXS_IOMUX_PAD_NAKED(1, 28, PAD_MUXSEL_1) +#define MX28_PAD_LCD_HSYNC__SAIF1_SDATA1 MXS_IOMUX_PAD_NAKED(1, 29, PAD_MUXSEL_1) +#define MX28_PAD_LCD_DOTCLK__SAIF1_MCLK MXS_IOMUX_PAD_NAKED(1, 30, PAD_MUXSEL_1) + +#define MX28_PAD_SSP0_DATA4__SSP2_D0 MXS_IOMUX_PAD_NAKED(2, 4, PAD_MUXSEL_1) +#define MX28_PAD_SSP0_DATA5__SSP2_D3 MXS_IOMUX_PAD_NAKED(2, 5, PAD_MUXSEL_1) +#define MX28_PAD_SSP0_DATA6__SSP2_CMD MXS_IOMUX_PAD_NAKED(2, 6, PAD_MUXSEL_1) +#define MX28_PAD_SSP0_DATA7__SSP2_SCK MXS_IOMUX_PAD_NAKED(2, 7, PAD_MUXSEL_1) +#define MX28_PAD_SSP1_SCK__SSP2_D1 MXS_IOMUX_PAD_NAKED(2, 12, PAD_MUXSEL_1) +#define MX28_PAD_SSP1_CMD__SSP2_D2 MXS_IOMUX_PAD_NAKED(2, 13, PAD_MUXSEL_1) +#define MX28_PAD_SSP1_DATA0__SSP2_D6 MXS_IOMUX_PAD_NAKED(2, 14, PAD_MUXSEL_1) +#define MX28_PAD_SSP1_DATA3__SSP2_D7 MXS_IOMUX_PAD_NAKED(2, 15, PAD_MUXSEL_1) +#define MX28_PAD_SSP2_SCK__AUART2_RX MXS_IOMUX_PAD_NAKED(2, 16, PAD_MUXSEL_1) +#define MX28_PAD_SSP2_MOSI__AUART2_TX MXS_IOMUX_PAD_NAKED(2, 17, PAD_MUXSEL_1) +#define MX28_PAD_SSP2_MISO__AUART3_RX MXS_IOMUX_PAD_NAKED(2, 18, PAD_MUXSEL_1) +#define MX28_PAD_SSP2_SS0__AUART3_TX MXS_IOMUX_PAD_NAKED(2, 19, PAD_MUXSEL_1) +#define MX28_PAD_SSP2_SS1__SSP2_D1 MXS_IOMUX_PAD_NAKED(2, 20, PAD_MUXSEL_1) +#define MX28_PAD_SSP2_SS2__SSP2_D2 MXS_IOMUX_PAD_NAKED(2, 21, PAD_MUXSEL_1) +#define MX28_PAD_SSP3_SCK__AUART4_TX MXS_IOMUX_PAD_NAKED(2, 24, PAD_MUXSEL_1) +#define MX28_PAD_SSP3_MOSI__AUART4_RX MXS_IOMUX_PAD_NAKED(2, 25, PAD_MUXSEL_1) +#define MX28_PAD_SSP3_MISO__AUART4_RTS MXS_IOMUX_PAD_NAKED(2, 26, PAD_MUXSEL_1) +#define MX28_PAD_SSP3_SS0__AUART4_CTS MXS_IOMUX_PAD_NAKED(2, 27, PAD_MUXSEL_1) + +#define MX28_PAD_AUART0_RX__I2C0_SCL MXS_IOMUX_PAD_NAKED(3, 0, PAD_MUXSEL_1) +#define MX28_PAD_AUART0_TX__I2C0_SDA MXS_IOMUX_PAD_NAKED(3, 1, PAD_MUXSEL_1) +#define MX28_PAD_AUART0_CTS__AUART4_RX MXS_IOMUX_PAD_NAKED(3, 2, PAD_MUXSEL_1) +#define MX28_PAD_AUART0_RTS__AUART4_TX MXS_IOMUX_PAD_NAKED(3, 3, PAD_MUXSEL_1) +#define MX28_PAD_AUART1_RX__SSP2_CARD_DETECT MXS_IOMUX_PAD_NAKED(3, 4, PAD_MUXSEL_1) +#define MX28_PAD_AUART1_TX__SSP3_CARD_DETECT MXS_IOMUX_PAD_NAKED(3, 5, PAD_MUXSEL_1) +#define MX28_PAD_AUART1_CTS__USB0_OVERCURRENT MXS_IOMUX_PAD_NAKED(3, 6, PAD_MUXSEL_1) +#define MX28_PAD_AUART1_RTS__USB0_ID MXS_IOMUX_PAD_NAKED(3, 7, PAD_MUXSEL_1) +#define MX28_PAD_AUART2_RX__SSP3_D1 MXS_IOMUX_PAD_NAKED(3, 8, PAD_MUXSEL_1) +#define MX28_PAD_AUART2_TX__SSP3_D2 MXS_IOMUX_PAD_NAKED(3, 9, PAD_MUXSEL_1) +#define MX28_PAD_AUART2_CTS__I2C1_SCL MXS_IOMUX_PAD_NAKED(3, 10, PAD_MUXSEL_1) +#define MX28_PAD_AUART2_RTS__I2C1_SDA MXS_IOMUX_PAD_NAKED(3, 11, PAD_MUXSEL_1) +#define MX28_PAD_AUART3_RX__CAN0_TX MXS_IOMUX_PAD_NAKED(3, 12, PAD_MUXSEL_1) +#define MX28_PAD_AUART3_TX__CAN0_RX MXS_IOMUX_PAD_NAKED(3, 13, PAD_MUXSEL_1) +#define MX28_PAD_AUART3_CTS__CAN1_TX MXS_IOMUX_PAD_NAKED(3, 14, PAD_MUXSEL_1) +#define MX28_PAD_AUART3_RTS__CAN1_RX MXS_IOMUX_PAD_NAKED(3, 15, PAD_MUXSEL_1) +#define MX28_PAD_PWM0__I2C1_SCL MXS_IOMUX_PAD_NAKED(3, 16, PAD_MUXSEL_1) +#define MX28_PAD_PWM1__I2C1_SDA MXS_IOMUX_PAD_NAKED(3, 17, PAD_MUXSEL_1) +#define MX28_PAD_PWM2__USB0_ID MXS_IOMUX_PAD_NAKED(3, 18, PAD_MUXSEL_1) +#define MX28_PAD_SAIF0_MCLK__PWM_3 MXS_IOMUX_PAD_NAKED(3, 20, PAD_MUXSEL_1) +#define MX28_PAD_SAIF0_LRCLK__PWM_4 MXS_IOMUX_PAD_NAKED(3, 21, PAD_MUXSEL_1) +#define MX28_PAD_SAIF0_BITCLK__PWM_5 MXS_IOMUX_PAD_NAKED(3, 22, PAD_MUXSEL_1) +#define MX28_PAD_SAIF0_SDATA0__PWM_6 MXS_IOMUX_PAD_NAKED(3, 23, PAD_MUXSEL_1) +#define MX28_PAD_I2C0_SCL__TIMROT_ROTARYA MXS_IOMUX_PAD_NAKED(3, 24, PAD_MUXSEL_1) +#define MX28_PAD_I2C0_SDA__TIMROT_ROTARYB MXS_IOMUX_PAD_NAKED(3, 25, PAD_MUXSEL_1) +#define MX28_PAD_SAIF1_SDATA0__PWM_7 MXS_IOMUX_PAD_NAKED(3, 26, PAD_MUXSEL_1) +#define MX28_PAD_LCD_RESET__LCD_VSYNC MXS_IOMUX_PAD_NAKED(3, 30, PAD_MUXSEL_1) + +#define MX28_PAD_ENET0_MDC__GPMI_CE4N MXS_IOMUX_PAD_NAKED(4, 0, PAD_MUXSEL_1) +#define MX28_PAD_ENET0_MDIO__GPMI_CE5N MXS_IOMUX_PAD_NAKED(4, 1, PAD_MUXSEL_1) +#define MX28_PAD_ENET0_RX_EN__GPMI_CE6N MXS_IOMUX_PAD_NAKED(4, 2, PAD_MUXSEL_1) +#define MX28_PAD_ENET0_RXD0__GPMI_CE7N MXS_IOMUX_PAD_NAKED(4, 3, PAD_MUXSEL_1) +#define MX28_PAD_ENET0_RXD1__GPMI_READY4 MXS_IOMUX_PAD_NAKED(4, 4, PAD_MUXSEL_1) +#define MX28_PAD_ENET0_TX_CLK__HSADC_TRIGGER MXS_IOMUX_PAD_NAKED(4, 5, PAD_MUXSEL_1) +#define MX28_PAD_ENET0_TX_EN__GPMI_READY5 MXS_IOMUX_PAD_NAKED(4, 6, PAD_MUXSEL_1) +#define MX28_PAD_ENET0_TXD0__GPMI_READY6 MXS_IOMUX_PAD_NAKED(4, 7, PAD_MUXSEL_1) +#define MX28_PAD_ENET0_TXD1__GPMI_READY7 MXS_IOMUX_PAD_NAKED(4, 8, PAD_MUXSEL_1) +#define MX28_PAD_ENET0_RXD2__ENET1_RXD0 MXS_IOMUX_PAD_NAKED(4, 9, PAD_MUXSEL_1) +#define MX28_PAD_ENET0_RXD3__ENET1_RXD1 MXS_IOMUX_PAD_NAKED(4, 10, PAD_MUXSEL_1) +#define MX28_PAD_ENET0_TXD2__ENET1_TXD0 MXS_IOMUX_PAD_NAKED(4, 11, PAD_MUXSEL_1) +#define MX28_PAD_ENET0_TXD3__ENET1_TXD1 MXS_IOMUX_PAD_NAKED(4, 12, PAD_MUXSEL_1) +#define MX28_PAD_ENET0_RX_CLK__ENET0_RX_ER MXS_IOMUX_PAD_NAKED(4, 13, PAD_MUXSEL_1) +#define MX28_PAD_ENET0_COL__ENET1_TX_EN MXS_IOMUX_PAD_NAKED(4, 14, PAD_MUXSEL_1) +#define MX28_PAD_ENET0_CRS__ENET1_RX_EN MXS_IOMUX_PAD_NAKED(4, 15, PAD_MUXSEL_1) + +/* MUXSEL_2 */ +#define MX28_PAD_GPMI_CE2N__ENET0_RX_ER MXS_IOMUX_PAD_NAKED(0, 18, PAD_MUXSEL_2) +#define MX28_PAD_GPMI_CE3N__SAIF1_MCLK MXS_IOMUX_PAD_NAKED(0, 19, PAD_MUXSEL_2) +#define MX28_PAD_GPMI_RDY0__USB0_ID MXS_IOMUX_PAD_NAKED(0, 20, PAD_MUXSEL_2) +#define MX28_PAD_GPMI_RDY2__ENET0_TX_ER MXS_IOMUX_PAD_NAKED(0, 22, PAD_MUXSEL_2) +#define MX28_PAD_GPMI_RDY3__HSADC_TRIGGER MXS_IOMUX_PAD_NAKED(0, 23, PAD_MUXSEL_2) +#define MX28_PAD_GPMI_ALE__SSP3_D4 MXS_IOMUX_PAD_NAKED(0, 26, PAD_MUXSEL_2) +#define MX28_PAD_GPMI_CLE__SSP3_D5 MXS_IOMUX_PAD_NAKED(0, 27, PAD_MUXSEL_2) + +#define MX28_PAD_LCD_D00__ETM_DA0 MXS_IOMUX_PAD_NAKED(1, 0, PAD_MUXSEL_2) +#define MX28_PAD_LCD_D01__ETM_DA1 MXS_IOMUX_PAD_NAKED(1, 1, PAD_MUXSEL_2) +#define MX28_PAD_LCD_D02__ETM_DA2 MXS_IOMUX_PAD_NAKED(1, 2, PAD_MUXSEL_2) +#define MX28_PAD_LCD_D03__ETM_DA3 MXS_IOMUX_PAD_NAKED(1, 3, PAD_MUXSEL_2) +#define MX28_PAD_LCD_D04__ETM_DA4 MXS_IOMUX_PAD_NAKED(1, 4, PAD_MUXSEL_2) +#define MX28_PAD_LCD_D05__ETM_DA5 MXS_IOMUX_PAD_NAKED(1, 5, PAD_MUXSEL_2) +#define MX28_PAD_LCD_D06__ETM_DA6 MXS_IOMUX_PAD_NAKED(1, 6, PAD_MUXSEL_2) +#define MX28_PAD_LCD_D07__ETM_DA7 MXS_IOMUX_PAD_NAKED(1, 7, PAD_MUXSEL_2) +#define MX28_PAD_LCD_D08__ETM_DA8 MXS_IOMUX_PAD_NAKED(1, 8, PAD_MUXSEL_2) +#define MX28_PAD_LCD_D09__ETM_DA9 MXS_IOMUX_PAD_NAKED(1, 9, PAD_MUXSEL_2) +#define MX28_PAD_LCD_D10__ETM_DA10 MXS_IOMUX_PAD_NAKED(1, 10, PAD_MUXSEL_2) +#define MX28_PAD_LCD_D11__ETM_DA11 MXS_IOMUX_PAD_NAKED(1, 11, PAD_MUXSEL_2) +#define MX28_PAD_LCD_D12__ETM_DA12 MXS_IOMUX_PAD_NAKED(1, 12, PAD_MUXSEL_2) +#define MX28_PAD_LCD_D13__ETM_DA13 MXS_IOMUX_PAD_NAKED(1, 13, PAD_MUXSEL_2) +#define MX28_PAD_LCD_D14__ETM_DA14 MXS_IOMUX_PAD_NAKED(1, 14, PAD_MUXSEL_2) +#define MX28_PAD_LCD_D15__ETM_DA15 MXS_IOMUX_PAD_NAKED(1, 15, PAD_MUXSEL_2) +#define MX28_PAD_LCD_D16__ETM_DA7 MXS_IOMUX_PAD_NAKED(1, 16, PAD_MUXSEL_2) +#define MX28_PAD_LCD_D17__ETM_DA6 MXS_IOMUX_PAD_NAKED(1, 17, PAD_MUXSEL_2) +#define MX28_PAD_LCD_D18__ETM_DA5 MXS_IOMUX_PAD_NAKED(1, 18, PAD_MUXSEL_2) +#define MX28_PAD_LCD_D19__ETM_DA4 MXS_IOMUX_PAD_NAKED(1, 19, PAD_MUXSEL_2) +#define MX28_PAD_LCD_D20__ETM_DA3 MXS_IOMUX_PAD_NAKED(1, 20, PAD_MUXSEL_2) +#define MX28_PAD_LCD_D21__ETM_DA2 MXS_IOMUX_PAD_NAKED(1, 21, PAD_MUXSEL_2) +#define MX28_PAD_LCD_D22__ETM_DA1 MXS_IOMUX_PAD_NAKED(1, 22, PAD_MUXSEL_2) +#define MX28_PAD_LCD_D23__ETM_DA0 MXS_IOMUX_PAD_NAKED(1, 23, PAD_MUXSEL_2) +#define MX28_PAD_LCD_RD_E__ETM_TCTL MXS_IOMUX_PAD_NAKED(1, 24, PAD_MUXSEL_2) +#define MX28_PAD_LCD_WR_RWN__ETM_TCLK MXS_IOMUX_PAD_NAKED(1, 25, PAD_MUXSEL_2) +#define MX28_PAD_LCD_HSYNC__ETM_TCTL MXS_IOMUX_PAD_NAKED(1, 29, PAD_MUXSEL_2) +#define MX28_PAD_LCD_DOTCLK__ETM_TCLK MXS_IOMUX_PAD_NAKED(1, 30, PAD_MUXSEL_2) + +#define MX28_PAD_SSP1_SCK__ENET0_1588_EVENT2_OUT MXS_IOMUX_PAD_NAKED(2, 12, PAD_MUXSEL_2) +#define MX28_PAD_SSP1_CMD__ENET0_1588_EVENT2_IN MXS_IOMUX_PAD_NAKED(2, 13, PAD_MUXSEL_2) +#define MX28_PAD_SSP1_DATA0__ENET0_1588_EVENT3_OUT MXS_IOMUX_PAD_NAKED(2, 14, PAD_MUXSEL_2) +#define MX28_PAD_SSP1_DATA3__ENET0_1588_EVENT3_IN MXS_IOMUX_PAD_NAKED(2, 15, PAD_MUXSEL_2) +#define MX28_PAD_SSP2_SCK__SAIF0_SDATA1 MXS_IOMUX_PAD_NAKED(2, 16, PAD_MUXSEL_2) +#define MX28_PAD_SSP2_MOSI__SAIF0_SDATA2 MXS_IOMUX_PAD_NAKED(2, 17, PAD_MUXSEL_2) +#define MX28_PAD_SSP2_MISO__SAIF1_SDATA1 MXS_IOMUX_PAD_NAKED(2, 18, PAD_MUXSEL_2) +#define MX28_PAD_SSP2_SS0__SAIF1_SDATA2 MXS_IOMUX_PAD_NAKED(2, 19, PAD_MUXSEL_2) +#define MX28_PAD_SSP2_SS1__USB1_OVERCURRENT MXS_IOMUX_PAD_NAKED(2, 20, PAD_MUXSEL_2) +#define MX28_PAD_SSP2_SS2__USB0_OVERCURRENT MXS_IOMUX_PAD_NAKED(2, 21, PAD_MUXSEL_2) +#define MX28_PAD_SSP3_SCK__ENET1_1588_EVENT0_OUT MXS_IOMUX_PAD_NAKED(2, 24, PAD_MUXSEL_2) +#define MX28_PAD_SSP3_MOSI__ENET1_1588_EVENT0_IN MXS_IOMUX_PAD_NAKED(2, 25, PAD_MUXSEL_2) +#define MX28_PAD_SSP3_MISO__ENET1_1588_EVENT1_OUT MXS_IOMUX_PAD_NAKED(2, 26, PAD_MUXSEL_2) +#define MX28_PAD_SSP3_SS0__ENET1_1588_EVENT1_IN MXS_IOMUX_PAD_NAKED(2, 27, PAD_MUXSEL_2) + +#define MX28_PAD_AUART0_RX__DUART_CTS MXS_IOMUX_PAD_NAKED(3, 0, PAD_MUXSEL_2) +#define MX28_PAD_AUART0_TX__DUART_RTS MXS_IOMUX_PAD_NAKED(3, 1, PAD_MUXSEL_2) +#define MX28_PAD_AUART0_CTS__DUART_RX MXS_IOMUX_PAD_NAKED(3, 2, PAD_MUXSEL_2) +#define MX28_PAD_AUART0_RTS__DUART_TX MXS_IOMUX_PAD_NAKED(3, 3, PAD_MUXSEL_2) +#define MX28_PAD_AUART1_RX__PWM_0 MXS_IOMUX_PAD_NAKED(3, 4, PAD_MUXSEL_2) +#define MX28_PAD_AUART1_TX__PWM_1 MXS_IOMUX_PAD_NAKED(3, 5, PAD_MUXSEL_2) +#define MX28_PAD_AUART1_CTS__TIMROT_ROTARYA MXS_IOMUX_PAD_NAKED(3, 6, PAD_MUXSEL_2) +#define MX28_PAD_AUART1_RTS__TIMROT_ROTARYB MXS_IOMUX_PAD_NAKED(3, 7, PAD_MUXSEL_2) +#define MX28_PAD_AUART2_RX__SSP3_D4 MXS_IOMUX_PAD_NAKED(3, 8, PAD_MUXSEL_2) +#define MX28_PAD_AUART2_TX__SSP3_D5 MXS_IOMUX_PAD_NAKED(3, 9, PAD_MUXSEL_2) +#define MX28_PAD_AUART2_CTS__SAIF1_BITCLK MXS_IOMUX_PAD_NAKED(3, 10, PAD_MUXSEL_2) +#define MX28_PAD_AUART2_RTS__SAIF1_LRCLK MXS_IOMUX_PAD_NAKED(3, 11, PAD_MUXSEL_2) +#define MX28_PAD_AUART3_RX__ENET0_1588_EVENT0_OUT MXS_IOMUX_PAD_NAKED(3, 12, PAD_MUXSEL_2) +#define MX28_PAD_AUART3_TX__ENET0_1588_EVENT0_IN MXS_IOMUX_PAD_NAKED(3, 13, PAD_MUXSEL_2) +#define MX28_PAD_AUART3_CTS__ENET0_1588_EVENT1_OUT MXS_IOMUX_PAD_NAKED(3, 14, PAD_MUXSEL_2) +#define MX28_PAD_AUART3_RTS__ENET0_1588_EVENT1_IN MXS_IOMUX_PAD_NAKED(3, 15, PAD_MUXSEL_2) +#define MX28_PAD_PWM0__DUART_RX MXS_IOMUX_PAD_NAKED(3, 16, PAD_MUXSEL_2) +#define MX28_PAD_PWM1__DUART_TX MXS_IOMUX_PAD_NAKED(3, 17, PAD_MUXSEL_2) +#define MX28_PAD_PWM2__USB1_OVERCURRENT MXS_IOMUX_PAD_NAKED(3, 18, PAD_MUXSEL_2) +#define MX28_PAD_SAIF0_MCLK__AUART4_CTS MXS_IOMUX_PAD_NAKED(3, 20, PAD_MUXSEL_2) +#define MX28_PAD_SAIF0_LRCLK__AUART4_RTS MXS_IOMUX_PAD_NAKED(3, 21, PAD_MUXSEL_2) +#define MX28_PAD_SAIF0_BITCLK__AUART4_RX MXS_IOMUX_PAD_NAKED(3, 22, PAD_MUXSEL_2) +#define MX28_PAD_SAIF0_SDATA0__AUART4_TX MXS_IOMUX_PAD_NAKED(3, 23, PAD_MUXSEL_2) +#define MX28_PAD_I2C0_SCL__DUART_RX MXS_IOMUX_PAD_NAKED(3, 24, PAD_MUXSEL_2) +#define MX28_PAD_I2C0_SDA__DUART_TX MXS_IOMUX_PAD_NAKED(3, 25, PAD_MUXSEL_2) +#define MX28_PAD_SAIF1_SDATA0__SAIF0_SDATA1 MXS_IOMUX_PAD_NAKED(3, 26, PAD_MUXSEL_2) +#define MX28_PAD_SPDIF__ENET1_RX_ER MXS_IOMUX_PAD_NAKED(3, 27, PAD_MUXSEL_2) + +#define MX28_PAD_ENET0_MDC__SAIF0_SDATA1 MXS_IOMUX_PAD_NAKED(4, 0, PAD_MUXSEL_2) +#define MX28_PAD_ENET0_MDIO__SAIF0_SDATA2 MXS_IOMUX_PAD_NAKED(4, 1, PAD_MUXSEL_2) +#define MX28_PAD_ENET0_RX_EN__SAIF1_SDATA1 MXS_IOMUX_PAD_NAKED(4, 2, PAD_MUXSEL_2) +#define MX28_PAD_ENET0_RXD0__SAIF1_SDATA2 MXS_IOMUX_PAD_NAKED(4, 3, PAD_MUXSEL_2) +#define MX28_PAD_ENET0_TX_CLK__ENET0_1588_EVENT2_OUT MXS_IOMUX_PAD_NAKED(4, 5, PAD_MUXSEL_2) +#define MX28_PAD_ENET0_RXD2__ENET0_1588_EVENT0_OUT MXS_IOMUX_PAD_NAKED(4, 9, PAD_MUXSEL_2) +#define MX28_PAD_ENET0_RXD3__ENET0_1588_EVENT0_IN MXS_IOMUX_PAD_NAKED(4, 10, PAD_MUXSEL_2) +#define MX28_PAD_ENET0_TXD2__ENET0_1588_EVENT1_OUT MXS_IOMUX_PAD_NAKED(4, 11, PAD_MUXSEL_2) +#define MX28_PAD_ENET0_TXD3__ENET0_1588_EVENT1_IN MXS_IOMUX_PAD_NAKED(4, 12, PAD_MUXSEL_2) +#define MX28_PAD_ENET0_RX_CLK__ENET0_1588_EVENT2_IN MXS_IOMUX_PAD_NAKED(4, 13, PAD_MUXSEL_2) +#define MX28_PAD_ENET0_COL__ENET0_1588_EVENT3_OUT MXS_IOMUX_PAD_NAKED(4, 14, PAD_MUXSEL_2) +#define MX28_PAD_ENET0_CRS__ENET0_1588_EVENT3_IN MXS_IOMUX_PAD_NAKED(4, 15, PAD_MUXSEL_2) + +/* MUXSEL_GPIO */ +#define MX28_PAD_GPMI_D00__GPIO_0_0 MXS_IOMUX_PAD_NAKED(0, 0, PAD_MUXSEL_GPIO) +#define MX28_PAD_GPMI_D01__GPIO_0_1 MXS_IOMUX_PAD_NAKED(0, 1, PAD_MUXSEL_GPIO) +#define MX28_PAD_GPMI_D02__GPIO_0_2 MXS_IOMUX_PAD_NAKED(0, 2, PAD_MUXSEL_GPIO) +#define MX28_PAD_GPMI_D03__GPIO_0_3 MXS_IOMUX_PAD_NAKED(0, 3, PAD_MUXSEL_GPIO) +#define MX28_PAD_GPMI_D04__GPIO_0_4 MXS_IOMUX_PAD_NAKED(0, 4, PAD_MUXSEL_GPIO) +#define MX28_PAD_GPMI_D05__GPIO_0_5 MXS_IOMUX_PAD_NAKED(0, 5, PAD_MUXSEL_GPIO) +#define MX28_PAD_GPMI_D06__GPIO_0_6 MXS_IOMUX_PAD_NAKED(0, 6, PAD_MUXSEL_GPIO) +#define MX28_PAD_GPMI_D07__GPIO_0_7 MXS_IOMUX_PAD_NAKED(0, 7, PAD_MUXSEL_GPIO) +#define MX28_PAD_GPMI_CE0N__GPIO_0_16 MXS_IOMUX_PAD_NAKED(0, 16, PAD_MUXSEL_GPIO) +#define MX28_PAD_GPMI_CE1N__GPIO_0_17 MXS_IOMUX_PAD_NAKED(0, 17, PAD_MUXSEL_GPIO) +#define MX28_PAD_GPMI_CE2N__GPIO_0_18 MXS_IOMUX_PAD_NAKED(0, 18, PAD_MUXSEL_GPIO) +#define MX28_PAD_GPMI_CE3N__GPIO_0_19 MXS_IOMUX_PAD_NAKED(0, 19, PAD_MUXSEL_GPIO) +#define MX28_PAD_GPMI_RDY0__GPIO_0_20 MXS_IOMUX_PAD_NAKED(0, 20, PAD_MUXSEL_GPIO) +#define MX28_PAD_GPMI_RDY1__GPIO_0_21 MXS_IOMUX_PAD_NAKED(0, 21, PAD_MUXSEL_GPIO) +#define MX28_PAD_GPMI_RDY2__GPIO_0_22 MXS_IOMUX_PAD_NAKED(0, 22, PAD_MUXSEL_GPIO) +#define MX28_PAD_GPMI_RDY3__GPIO_0_23 MXS_IOMUX_PAD_NAKED(0, 23, PAD_MUXSEL_GPIO) +#define MX28_PAD_GPMI_RDN__GPIO_0_24 MXS_IOMUX_PAD_NAKED(0, 24, PAD_MUXSEL_GPIO) +#define MX28_PAD_GPMI_WRN__GPIO_0_25 MXS_IOMUX_PAD_NAKED(0, 25, PAD_MUXSEL_GPIO) +#define MX28_PAD_GPMI_ALE__GPIO_0_26 MXS_IOMUX_PAD_NAKED(0, 26, PAD_MUXSEL_GPIO) +#define MX28_PAD_GPMI_CLE__GPIO_0_27 MXS_IOMUX_PAD_NAKED(0, 27, PAD_MUXSEL_GPIO) +#define MX28_PAD_GPMI_RESETN__GPIO_0_28 MXS_IOMUX_PAD_NAKED(0, 28, PAD_MUXSEL_GPIO) + +#define MX28_PAD_LCD_D00__GPIO_1_0 MXS_IOMUX_PAD_NAKED(1, 0, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_D01__GPIO_1_1 MXS_IOMUX_PAD_NAKED(1, 1, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_D02__GPIO_1_2 MXS_IOMUX_PAD_NAKED(1, 2, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_D03__GPIO_1_3 MXS_IOMUX_PAD_NAKED(1, 3, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_D04__GPIO_1_4 MXS_IOMUX_PAD_NAKED(1, 4, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_D05__GPIO_1_5 MXS_IOMUX_PAD_NAKED(1, 5, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_D06__GPIO_1_6 MXS_IOMUX_PAD_NAKED(1, 6, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_D07__GPIO_1_7 MXS_IOMUX_PAD_NAKED(1, 7, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_D08__GPIO_1_8 MXS_IOMUX_PAD_NAKED(1, 8, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_D09__GPIO_1_9 MXS_IOMUX_PAD_NAKED(1, 9, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_D10__GPIO_1_10 MXS_IOMUX_PAD_NAKED(1, 10, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_D11__GPIO_1_11 MXS_IOMUX_PAD_NAKED(1, 11, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_D12__GPIO_1_12 MXS_IOMUX_PAD_NAKED(1, 12, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_D13__GPIO_1_13 MXS_IOMUX_PAD_NAKED(1, 13, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_D14__GPIO_1_14 MXS_IOMUX_PAD_NAKED(1, 14, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_D15__GPIO_1_15 MXS_IOMUX_PAD_NAKED(1, 15, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_D16__GPIO_1_16 MXS_IOMUX_PAD_NAKED(1, 16, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_D17__GPIO_1_17 MXS_IOMUX_PAD_NAKED(1, 17, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_D18__GPIO_1_18 MXS_IOMUX_PAD_NAKED(1, 18, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_D19__GPIO_1_19 MXS_IOMUX_PAD_NAKED(1, 19, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_D20__GPIO_1_20 MXS_IOMUX_PAD_NAKED(1, 20, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_D21__GPIO_1_21 MXS_IOMUX_PAD_NAKED(1, 21, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_D22__GPIO_1_22 MXS_IOMUX_PAD_NAKED(1, 22, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_D23__GPIO_1_23 MXS_IOMUX_PAD_NAKED(1, 23, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_RD_E__GPIO_1_24 MXS_IOMUX_PAD_NAKED(1, 24, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_WR_RWN__GPIO_1_25 MXS_IOMUX_PAD_NAKED(1, 25, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_RS__GPIO_1_26 MXS_IOMUX_PAD_NAKED(1, 26, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_CS__GPIO_1_27 MXS_IOMUX_PAD_NAKED(1, 27, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_VSYNC__GPIO_1_28 MXS_IOMUX_PAD_NAKED(1, 28, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_HSYNC__GPIO_1_29 MXS_IOMUX_PAD_NAKED(1, 29, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_DOTCLK__GPIO_1_30 MXS_IOMUX_PAD_NAKED(1, 30, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_ENABLE__GPIO_1_31 MXS_IOMUX_PAD_NAKED(1, 31, PAD_MUXSEL_GPIO) + +#define MX28_PAD_SSP0_DATA0__GPIO_2_0 MXS_IOMUX_PAD_NAKED(2, 0, PAD_MUXSEL_GPIO) +#define MX28_PAD_SSP0_DATA1__GPIO_2_1 MXS_IOMUX_PAD_NAKED(2, 1, PAD_MUXSEL_GPIO) +#define MX28_PAD_SSP0_DATA2__GPIO_2_2 MXS_IOMUX_PAD_NAKED(2, 2, PAD_MUXSEL_GPIO) +#define MX28_PAD_SSP0_DATA3__GPIO_2_3 MXS_IOMUX_PAD_NAKED(2, 3, PAD_MUXSEL_GPIO) +#define MX28_PAD_SSP0_DATA4__GPIO_2_4 MXS_IOMUX_PAD_NAKED(2, 4, PAD_MUXSEL_GPIO) +#define MX28_PAD_SSP0_DATA5__GPIO_2_5 MXS_IOMUX_PAD_NAKED(2, 5, PAD_MUXSEL_GPIO) +#define MX28_PAD_SSP0_DATA6__GPIO_2_6 MXS_IOMUX_PAD_NAKED(2, 6, PAD_MUXSEL_GPIO) +#define MX28_PAD_SSP0_DATA7__GPIO_2_7 MXS_IOMUX_PAD_NAKED(2, 7, PAD_MUXSEL_GPIO) +#define MX28_PAD_SSP0_CMD__GPIO_2_8 MXS_IOMUX_PAD_NAKED(2, 8, PAD_MUXSEL_GPIO) +#define MX28_PAD_SSP0_DETECT__GPIO_2_9 MXS_IOMUX_PAD_NAKED(2, 9, PAD_MUXSEL_GPIO) +#define MX28_PAD_SSP0_SCK__GPIO_2_10 MXS_IOMUX_PAD_NAKED(2, 10, PAD_MUXSEL_GPIO) +#define MX28_PAD_SSP1_SCK__GPIO_2_12 MXS_IOMUX_PAD_NAKED(2, 12, PAD_MUXSEL_GPIO) +#define MX28_PAD_SSP1_CMD__GPIO_2_13 MXS_IOMUX_PAD_NAKED(2, 13, PAD_MUXSEL_GPIO) +#define MX28_PAD_SSP1_DATA0__GPIO_2_14 MXS_IOMUX_PAD_NAKED(2, 14, PAD_MUXSEL_GPIO) +#define MX28_PAD_SSP1_DATA3__GPIO_2_15 MXS_IOMUX_PAD_NAKED(2, 15, PAD_MUXSEL_GPIO) +#define MX28_PAD_SSP2_SCK__GPIO_2_16 MXS_IOMUX_PAD_NAKED(2, 16, PAD_MUXSEL_GPIO) +#define MX28_PAD_SSP2_MOSI__GPIO_2_17 MXS_IOMUX_PAD_NAKED(2, 17, PAD_MUXSEL_GPIO) +#define MX28_PAD_SSP2_MISO__GPIO_2_18 MXS_IOMUX_PAD_NAKED(2, 18, PAD_MUXSEL_GPIO) +#define MX28_PAD_SSP2_SS0__GPIO_2_19 MXS_IOMUX_PAD_NAKED(2, 19, PAD_MUXSEL_GPIO) +#define MX28_PAD_SSP2_SS1__GPIO_2_20 MXS_IOMUX_PAD_NAKED(2, 20, PAD_MUXSEL_GPIO) +#define MX28_PAD_SSP2_SS2__GPIO_2_21 MXS_IOMUX_PAD_NAKED(2, 21, PAD_MUXSEL_GPIO) +#define MX28_PAD_SSP3_SCK__GPIO_2_24 MXS_IOMUX_PAD_NAKED(2, 24, PAD_MUXSEL_GPIO) +#define MX28_PAD_SSP3_MOSI__GPIO_2_25 MXS_IOMUX_PAD_NAKED(2, 25, PAD_MUXSEL_GPIO) +#define MX28_PAD_SSP3_MISO__GPIO_2_26 MXS_IOMUX_PAD_NAKED(2, 26, PAD_MUXSEL_GPIO) +#define MX28_PAD_SSP3_SS0__GPIO_2_27 MXS_IOMUX_PAD_NAKED(2, 27, PAD_MUXSEL_GPIO) + +#define MX28_PAD_AUART0_RX__GPIO_3_0 MXS_IOMUX_PAD_NAKED(3, 0, PAD_MUXSEL_GPIO) +#define MX28_PAD_AUART0_TX__GPIO_3_1 MXS_IOMUX_PAD_NAKED(3, 1, PAD_MUXSEL_GPIO) +#define MX28_PAD_AUART0_CTS__GPIO_3_2 MXS_IOMUX_PAD_NAKED(3, 2, PAD_MUXSEL_GPIO) +#define MX28_PAD_AUART0_RTS__GPIO_3_3 MXS_IOMUX_PAD_NAKED(3, 3, PAD_MUXSEL_GPIO) +#define MX28_PAD_AUART1_RX__GPIO_3_4 MXS_IOMUX_PAD_NAKED(3, 4, PAD_MUXSEL_GPIO) +#define MX28_PAD_AUART1_TX__GPIO_3_5 MXS_IOMUX_PAD_NAKED(3, 5, PAD_MUXSEL_GPIO) +#define MX28_PAD_AUART1_CTS__GPIO_3_6 MXS_IOMUX_PAD_NAKED(3, 6, PAD_MUXSEL_GPIO) +#define MX28_PAD_AUART1_RTS__GPIO_3_7 MXS_IOMUX_PAD_NAKED(3, 7, PAD_MUXSEL_GPIO) +#define MX28_PAD_AUART2_RX__GPIO_3_8 MXS_IOMUX_PAD_NAKED(3, 8, PAD_MUXSEL_GPIO) +#define MX28_PAD_AUART2_TX__GPIO_3_9 MXS_IOMUX_PAD_NAKED(3, 9, PAD_MUXSEL_GPIO) +#define MX28_PAD_AUART2_CTS__GPIO_3_10 MXS_IOMUX_PAD_NAKED(3, 10, PAD_MUXSEL_GPIO) +#define MX28_PAD_AUART2_RTS__GPIO_3_11 MXS_IOMUX_PAD_NAKED(3, 11, PAD_MUXSEL_GPIO) +#define MX28_PAD_AUART3_RX__GPIO_3_12 MXS_IOMUX_PAD_NAKED(3, 12, PAD_MUXSEL_GPIO) +#define MX28_PAD_AUART3_TX__GPIO_3_13 MXS_IOMUX_PAD_NAKED(3, 13, PAD_MUXSEL_GPIO) +#define MX28_PAD_AUART3_CTS__GPIO_3_14 MXS_IOMUX_PAD_NAKED(3, 14, PAD_MUXSEL_GPIO) +#define MX28_PAD_AUART3_RTS__GPIO_3_15 MXS_IOMUX_PAD_NAKED(3, 15, PAD_MUXSEL_GPIO) +#define MX28_PAD_PWM0__GPIO_3_16 MXS_IOMUX_PAD_NAKED(3, 16, PAD_MUXSEL_GPIO) +#define MX28_PAD_PWM1__GPIO_3_17 MXS_IOMUX_PAD_NAKED(3, 17, PAD_MUXSEL_GPIO) +#define MX28_PAD_PWM2__GPIO_3_18 MXS_IOMUX_PAD_NAKED(3, 18, PAD_MUXSEL_GPIO) +#define MX28_PAD_SAIF0_MCLK__GPIO_3_20 MXS_IOMUX_PAD_NAKED(3, 20, PAD_MUXSEL_GPIO) +#define MX28_PAD_SAIF0_LRCLK__GPIO_3_21 MXS_IOMUX_PAD_NAKED(3, 21, PAD_MUXSEL_GPIO) +#define MX28_PAD_SAIF0_BITCLK__GPIO_3_22 MXS_IOMUX_PAD_NAKED(3, 22, PAD_MUXSEL_GPIO) +#define MX28_PAD_SAIF0_SDATA0__GPIO_3_23 MXS_IOMUX_PAD_NAKED(3, 23, PAD_MUXSEL_GPIO) +#define MX28_PAD_I2C0_SCL__GPIO_3_24 MXS_IOMUX_PAD_NAKED(3, 24, PAD_MUXSEL_GPIO) +#define MX28_PAD_I2C0_SDA__GPIO_3_25 MXS_IOMUX_PAD_NAKED(3, 25, PAD_MUXSEL_GPIO) +#define MX28_PAD_SAIF1_SDATA0__GPIO_3_26 MXS_IOMUX_PAD_NAKED(3, 26, PAD_MUXSEL_GPIO) +#define MX28_PAD_SPDIF__GPIO_3_27 MXS_IOMUX_PAD_NAKED(3, 27, PAD_MUXSEL_GPIO) +#define MX28_PAD_PWM3__GPIO_3_28 MXS_IOMUX_PAD_NAKED(3, 28, PAD_MUXSEL_GPIO) +#define MX28_PAD_PWM4__GPIO_3_29 MXS_IOMUX_PAD_NAKED(3, 29, PAD_MUXSEL_GPIO) +#define MX28_PAD_LCD_RESET__GPIO_3_30 MXS_IOMUX_PAD_NAKED(3, 30, PAD_MUXSEL_GPIO) + +#define MX28_PAD_ENET0_MDC__GPIO_4_0 MXS_IOMUX_PAD_NAKED(4, 0, PAD_MUXSEL_GPIO) +#define MX28_PAD_ENET0_MDIO__GPIO_4_1 MXS_IOMUX_PAD_NAKED(4, 1, PAD_MUXSEL_GPIO) +#define MX28_PAD_ENET0_RX_EN__GPIO_4_2 MXS_IOMUX_PAD_NAKED(4, 2, PAD_MUXSEL_GPIO) +#define MX28_PAD_ENET0_RXD0__GPIO_4_3 MXS_IOMUX_PAD_NAKED(4, 3, PAD_MUXSEL_GPIO) +#define MX28_PAD_ENET0_RXD1__GPIO_4_4 MXS_IOMUX_PAD_NAKED(4, 4, PAD_MUXSEL_GPIO) +#define MX28_PAD_ENET0_TX_CLK__GPIO_4_5 MXS_IOMUX_PAD_NAKED(4, 5, PAD_MUXSEL_GPIO) +#define MX28_PAD_ENET0_TX_EN__GPIO_4_6 MXS_IOMUX_PAD_NAKED(4, 6, PAD_MUXSEL_GPIO) +#define MX28_PAD_ENET0_TXD0__GPIO_4_7 MXS_IOMUX_PAD_NAKED(4, 7, PAD_MUXSEL_GPIO) +#define MX28_PAD_ENET0_TXD1__GPIO_4_8 MXS_IOMUX_PAD_NAKED(4, 8, PAD_MUXSEL_GPIO) +#define MX28_PAD_ENET0_RXD2__GPIO_4_9 MXS_IOMUX_PAD_NAKED(4, 9, PAD_MUXSEL_GPIO) +#define MX28_PAD_ENET0_RXD3__GPIO_4_10 MXS_IOMUX_PAD_NAKED(4, 10, PAD_MUXSEL_GPIO) +#define MX28_PAD_ENET0_TXD2__GPIO_4_11 MXS_IOMUX_PAD_NAKED(4, 11, PAD_MUXSEL_GPIO) +#define MX28_PAD_ENET0_TXD3__GPIO_4_12 MXS_IOMUX_PAD_NAKED(4, 12, PAD_MUXSEL_GPIO) +#define MX28_PAD_ENET0_RX_CLK__GPIO_4_13 MXS_IOMUX_PAD_NAKED(4, 13, PAD_MUXSEL_GPIO) +#define MX28_PAD_ENET0_COL__GPIO_4_14 MXS_IOMUX_PAD_NAKED(4, 14, PAD_MUXSEL_GPIO) +#define MX28_PAD_ENET0_CRS__GPIO_4_15 MXS_IOMUX_PAD_NAKED(4, 15, PAD_MUXSEL_GPIO) +#define MX28_PAD_ENET_CLK__GPIO_4_16 MXS_IOMUX_PAD_NAKED(4, 16, PAD_MUXSEL_GPIO) +#define MX28_PAD_JTAG_RTCK__GPIO_4_20 MXS_IOMUX_PAD_NAKED(4, 20, PAD_MUXSEL_GPIO) + +#endif /* __MACH_IOMUX_MX28_H__ */ diff --git a/arch/arm/include/asm/arch-mxs/iomux.h b/arch/arm/include/asm/arch-mxs/iomux.h new file mode 100644 index 0000000..7abdf58 --- /dev/null +++ b/arch/arm/include/asm/arch-mxs/iomux.h @@ -0,0 +1,168 @@ +/* + * Copyright (C) 2009 by Jan Weitzel Phytec Messtechnik GmbH, + * armlinux@phytec.de + * Copyright (C) 2010 Freescale Semiconductor, Inc. All Rights Reserved. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version 2 + * of the License, or (at your option) any later version. + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301, USA. + */ + +#ifndef __MACH_MXS_IOMUX_H__ +#define __MACH_MXS_IOMUX_H__ + +/* + * IOMUX/PAD Bit field definitions + * + * PAD_BANK: 0..2 (3) + * PAD_PIN: 3..7 (5) + * PAD_MUXSEL: 8..9 (2) + * PAD_MA: 10..11 (2) + * PAD_MA_VALID: 12 (1) + * PAD_VOL: 13 (1) + * PAD_VOL_VALID: 14 (1) + * PAD_PULL: 15 (1) + * PAD_PULL_VALID: 16 (1) + * RESERVED: 17..31 (15) + */ +typedef u32 iomux_cfg_t; + +#define MXS_PAD_BANK_SHIFT 0 +#define MXS_PAD_BANK_MASK ((iomux_cfg_t)0x7 << MXS_PAD_BANK_SHIFT) +#define MXS_PAD_PIN_SHIFT 3 +#define MXS_PAD_PIN_MASK ((iomux_cfg_t)0x1f << MXS_PAD_PIN_SHIFT) +#define MXS_PAD_MUXSEL_SHIFT 8 +#define MXS_PAD_MUXSEL_MASK ((iomux_cfg_t)0x3 << MXS_PAD_MUXSEL_SHIFT) +#define MXS_PAD_MA_SHIFT 10 +#define MXS_PAD_MA_MASK ((iomux_cfg_t)0x3 << MXS_PAD_MA_SHIFT) +#define MXS_PAD_MA_VALID_SHIFT 12 +#define MXS_PAD_MA_VALID_MASK ((iomux_cfg_t)0x1 << MXS_PAD_MA_VALID_SHIFT) +#define MXS_PAD_VOL_SHIFT 13 +#define MXS_PAD_VOL_MASK ((iomux_cfg_t)0x1 << MXS_PAD_VOL_SHIFT) +#define MXS_PAD_VOL_VALID_SHIFT 14 +#define MXS_PAD_VOL_VALID_MASK ((iomux_cfg_t)0x1 << MXS_PAD_VOL_VALID_SHIFT) +#define MXS_PAD_PULL_SHIFT 15 +#define MXS_PAD_PULL_MASK ((iomux_cfg_t)0x1 << MXS_PAD_PULL_SHIFT) +#define MXS_PAD_PULL_VALID_SHIFT 16 +#define MXS_PAD_PULL_VALID_MASK ((iomux_cfg_t)0x1 << MXS_PAD_PULL_VALID_SHIFT) + +#define PAD_MUXSEL_0 0 +#define PAD_MUXSEL_1 1 +#define PAD_MUXSEL_2 2 +#define PAD_MUXSEL_GPIO 3 + +#define PAD_4MA 0 +#define PAD_8MA 1 +#define PAD_12MA 2 +#define PAD_16MA 3 + +#define PAD_1V8 0 +#define PAD_3V3 1 + +#define PAD_NOPULL 0 +#define PAD_PULLUP 1 + +#define MXS_PAD_4MA ((PAD_4MA << MXS_PAD_MA_SHIFT) | \ + MXS_PAD_MA_VALID_MASK) +#define MXS_PAD_8MA ((PAD_8MA << MXS_PAD_MA_SHIFT) | \ + MXS_PAD_MA_VALID_MASK) +#define MXS_PAD_12MA ((PAD_12MA << MXS_PAD_MA_SHIFT) | \ + MXS_PAD_MA_VALID_MASK) +#define MXS_PAD_16MA ((PAD_16MA << MXS_PAD_MA_SHIFT) | \ + MXS_PAD_MA_VALID_MASK) + +#define MXS_PAD_1V8 ((PAD_1V8 << MXS_PAD_VOL_SHIFT) | \ + MXS_PAD_VOL_VALID_MASK) +#define MXS_PAD_3V3 ((PAD_3V3 << MXS_PAD_VOL_SHIFT) | \ + MXS_PAD_VOL_VALID_MASK) + +#define MXS_PAD_NOPULL ((PAD_NOPULL << MXS_PAD_PULL_SHIFT) | \ + MXS_PAD_PULL_VALID_MASK) +#define MXS_PAD_PULLUP ((PAD_PULLUP << MXS_PAD_PULL_SHIFT) | \ + MXS_PAD_PULL_VALID_MASK) + +/* generic pad control used in most cases */ +#define MXS_PAD_CTRL (MXS_PAD_4MA | MXS_PAD_3V3 | MXS_PAD_NOPULL) + +#define MXS_IOMUX_PAD(_bank, _pin, _muxsel, _ma, _vol, _pull) \ + (((iomux_cfg_t)(_bank) << MXS_PAD_BANK_SHIFT) | \ + ((iomux_cfg_t)(_pin) << MXS_PAD_PIN_SHIFT) | \ + ((iomux_cfg_t)(_muxsel) << MXS_PAD_MUXSEL_SHIFT) | \ + ((iomux_cfg_t)(_ma) << MXS_PAD_MA_SHIFT) | \ + ((iomux_cfg_t)(_vol) << MXS_PAD_VOL_SHIFT) | \ + ((iomux_cfg_t)(_pull) << MXS_PAD_PULL_SHIFT)) + +/* + * A pad becomes naked, when none of mA, vol or pull + * validity bits is set. + */ +#define MXS_IOMUX_PAD_NAKED(_bank, _pin, _muxsel) \ + MXS_IOMUX_PAD(_bank, _pin, _muxsel, 0, 0, 0) + +static inline unsigned int PAD_BANK(iomux_cfg_t pad) +{ + return (pad & MXS_PAD_BANK_MASK) >> MXS_PAD_BANK_SHIFT; +} + +static inline unsigned int PAD_PIN(iomux_cfg_t pad) +{ + return (pad & MXS_PAD_PIN_MASK) >> MXS_PAD_PIN_SHIFT; +} + +static inline unsigned int PAD_MUXSEL(iomux_cfg_t pad) +{ + return (pad & MXS_PAD_MUXSEL_MASK) >> MXS_PAD_MUXSEL_SHIFT; +} + +static inline unsigned int PAD_MA(iomux_cfg_t pad) +{ + return (pad & MXS_PAD_MA_MASK) >> MXS_PAD_MA_SHIFT; +} + +static inline unsigned int PAD_MA_VALID(iomux_cfg_t pad) +{ + return (pad & MXS_PAD_MA_VALID_MASK) >> MXS_PAD_MA_VALID_SHIFT; +} + +static inline unsigned int PAD_VOL(iomux_cfg_t pad) +{ + return (pad & MXS_PAD_VOL_MASK) >> MXS_PAD_VOL_SHIFT; +} + +static inline unsigned int PAD_VOL_VALID(iomux_cfg_t pad) +{ + return (pad & MXS_PAD_VOL_VALID_MASK) >> MXS_PAD_VOL_VALID_SHIFT; +} + +static inline unsigned int PAD_PULL(iomux_cfg_t pad) +{ + return (pad & MXS_PAD_PULL_MASK) >> MXS_PAD_PULL_SHIFT; +} + +static inline unsigned int PAD_PULL_VALID(iomux_cfg_t pad) +{ + return (pad & MXS_PAD_PULL_VALID_MASK) >> MXS_PAD_PULL_VALID_SHIFT; +} + +/* + * configures a single pad in the iomuxer + */ +int mxs_iomux_setup_pad(iomux_cfg_t pad); + +/* + * configures multiple pads + * convenient way to call the above function with tables + */ +int mxs_iomux_setup_multiple_pads(const iomux_cfg_t *pad_list, unsigned count); + +#endif /* __MACH_MXS_IOMUX_H__*/ diff --git a/arch/arm/include/asm/arch-mxs/regs-apbh.h b/arch/arm/include/asm/arch-mxs/regs-apbh.h new file mode 100644 index 0000000..91d7bc8 --- /dev/null +++ b/arch/arm/include/asm/arch-mxs/regs-apbh.h @@ -0,0 +1,466 @@ +/* + * Freescale i.MX28 APBH Register Definitions + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * Based on code from LTIB: + * Copyright 2008-2010 Freescale Semiconductor, Inc. All Rights Reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __REGS_APBH_H__ +#define __REGS_APBH_H__ + +#include <asm/arch/regs-common.h> + +#ifndef __ASSEMBLY__ +struct mx28_apbh_regs { + mx28_reg_32(hw_apbh_ctrl0) + mx28_reg_32(hw_apbh_ctrl1) + mx28_reg_32(hw_apbh_ctrl2) + mx28_reg_32(hw_apbh_channel_ctrl) + mx28_reg_32(hw_apbh_devsel) + mx28_reg_32(hw_apbh_dma_burst_size) + mx28_reg_32(hw_apbh_debug) + + uint32_t reserved[36]; + + union { + struct { + mx28_reg_32(hw_apbh_ch_curcmdar) + mx28_reg_32(hw_apbh_ch_nxtcmdar) + mx28_reg_32(hw_apbh_ch_cmd) + mx28_reg_32(hw_apbh_ch_bar) + mx28_reg_32(hw_apbh_ch_sema) + mx28_reg_32(hw_apbh_ch_debug1) + mx28_reg_32(hw_apbh_ch_debug2) + } ch[16]; + struct { + mx28_reg_32(hw_apbh_ch0_curcmdar) + mx28_reg_32(hw_apbh_ch0_nxtcmdar) + mx28_reg_32(hw_apbh_ch0_cmd) + mx28_reg_32(hw_apbh_ch0_bar) + mx28_reg_32(hw_apbh_ch0_sema) + mx28_reg_32(hw_apbh_ch0_debug1) + mx28_reg_32(hw_apbh_ch0_debug2) + mx28_reg_32(hw_apbh_ch1_curcmdar) + mx28_reg_32(hw_apbh_ch1_nxtcmdar) + mx28_reg_32(hw_apbh_ch1_cmd) + mx28_reg_32(hw_apbh_ch1_bar) + mx28_reg_32(hw_apbh_ch1_sema) + mx28_reg_32(hw_apbh_ch1_debug1) + mx28_reg_32(hw_apbh_ch1_debug2) + mx28_reg_32(hw_apbh_ch2_curcmdar) + mx28_reg_32(hw_apbh_ch2_nxtcmdar) + mx28_reg_32(hw_apbh_ch2_cmd) + mx28_reg_32(hw_apbh_ch2_bar) + mx28_reg_32(hw_apbh_ch2_sema) + mx28_reg_32(hw_apbh_ch2_debug1) + mx28_reg_32(hw_apbh_ch2_debug2) + mx28_reg_32(hw_apbh_ch3_curcmdar) + mx28_reg_32(hw_apbh_ch3_nxtcmdar) + mx28_reg_32(hw_apbh_ch3_cmd) + mx28_reg_32(hw_apbh_ch3_bar) + mx28_reg_32(hw_apbh_ch3_sema) + mx28_reg_32(hw_apbh_ch3_debug1) + mx28_reg_32(hw_apbh_ch3_debug2) + mx28_reg_32(hw_apbh_ch4_curcmdar) + mx28_reg_32(hw_apbh_ch4_nxtcmdar) + mx28_reg_32(hw_apbh_ch4_cmd) + mx28_reg_32(hw_apbh_ch4_bar) + mx28_reg_32(hw_apbh_ch4_sema) + mx28_reg_32(hw_apbh_ch4_debug1) + mx28_reg_32(hw_apbh_ch4_debug2) + mx28_reg_32(hw_apbh_ch5_curcmdar) + mx28_reg_32(hw_apbh_ch5_nxtcmdar) + mx28_reg_32(hw_apbh_ch5_cmd) + mx28_reg_32(hw_apbh_ch5_bar) + mx28_reg_32(hw_apbh_ch5_sema) + mx28_reg_32(hw_apbh_ch5_debug1) + mx28_reg_32(hw_apbh_ch5_debug2) + mx28_reg_32(hw_apbh_ch6_curcmdar) + mx28_reg_32(hw_apbh_ch6_nxtcmdar) + mx28_reg_32(hw_apbh_ch6_cmd) + mx28_reg_32(hw_apbh_ch6_bar) + mx28_reg_32(hw_apbh_ch6_sema) + mx28_reg_32(hw_apbh_ch6_debug1) + mx28_reg_32(hw_apbh_ch6_debug2) + mx28_reg_32(hw_apbh_ch7_curcmdar) + mx28_reg_32(hw_apbh_ch7_nxtcmdar) + mx28_reg_32(hw_apbh_ch7_cmd) + mx28_reg_32(hw_apbh_ch7_bar) + mx28_reg_32(hw_apbh_ch7_sema) + mx28_reg_32(hw_apbh_ch7_debug1) + mx28_reg_32(hw_apbh_ch7_debug2) + mx28_reg_32(hw_apbh_ch8_curcmdar) + mx28_reg_32(hw_apbh_ch8_nxtcmdar) + mx28_reg_32(hw_apbh_ch8_cmd) + mx28_reg_32(hw_apbh_ch8_bar) + mx28_reg_32(hw_apbh_ch8_sema) + mx28_reg_32(hw_apbh_ch8_debug1) + mx28_reg_32(hw_apbh_ch8_debug2) + mx28_reg_32(hw_apbh_ch9_curcmdar) + mx28_reg_32(hw_apbh_ch9_nxtcmdar) + mx28_reg_32(hw_apbh_ch9_cmd) + mx28_reg_32(hw_apbh_ch9_bar) + mx28_reg_32(hw_apbh_ch9_sema) + mx28_reg_32(hw_apbh_ch9_debug1) + mx28_reg_32(hw_apbh_ch9_debug2) + mx28_reg_32(hw_apbh_ch10_curcmdar) + mx28_reg_32(hw_apbh_ch10_nxtcmdar) + mx28_reg_32(hw_apbh_ch10_cmd) + mx28_reg_32(hw_apbh_ch10_bar) + mx28_reg_32(hw_apbh_ch10_sema) + mx28_reg_32(hw_apbh_ch10_debug1) + mx28_reg_32(hw_apbh_ch10_debug2) + mx28_reg_32(hw_apbh_ch11_curcmdar) + mx28_reg_32(hw_apbh_ch11_nxtcmdar) + mx28_reg_32(hw_apbh_ch11_cmd) + mx28_reg_32(hw_apbh_ch11_bar) + mx28_reg_32(hw_apbh_ch11_sema) + mx28_reg_32(hw_apbh_ch11_debug1) + mx28_reg_32(hw_apbh_ch11_debug2) + mx28_reg_32(hw_apbh_ch12_curcmdar) + mx28_reg_32(hw_apbh_ch12_nxtcmdar) + mx28_reg_32(hw_apbh_ch12_cmd) + mx28_reg_32(hw_apbh_ch12_bar) + mx28_reg_32(hw_apbh_ch12_sema) + mx28_reg_32(hw_apbh_ch12_debug1) + mx28_reg_32(hw_apbh_ch12_debug2) + mx28_reg_32(hw_apbh_ch13_curcmdar) + mx28_reg_32(hw_apbh_ch13_nxtcmdar) + mx28_reg_32(hw_apbh_ch13_cmd) + mx28_reg_32(hw_apbh_ch13_bar) + mx28_reg_32(hw_apbh_ch13_sema) + mx28_reg_32(hw_apbh_ch13_debug1) + mx28_reg_32(hw_apbh_ch13_debug2) + mx28_reg_32(hw_apbh_ch14_curcmdar) + mx28_reg_32(hw_apbh_ch14_nxtcmdar) + mx28_reg_32(hw_apbh_ch14_cmd) + mx28_reg_32(hw_apbh_ch14_bar) + mx28_reg_32(hw_apbh_ch14_sema) + mx28_reg_32(hw_apbh_ch14_debug1) + mx28_reg_32(hw_apbh_ch14_debug2) + mx28_reg_32(hw_apbh_ch15_curcmdar) + mx28_reg_32(hw_apbh_ch15_nxtcmdar) + mx28_reg_32(hw_apbh_ch15_cmd) + mx28_reg_32(hw_apbh_ch15_bar) + mx28_reg_32(hw_apbh_ch15_sema) + mx28_reg_32(hw_apbh_ch15_debug1) + mx28_reg_32(hw_apbh_ch15_debug2) + }; + }; + mx28_reg_32(hw_apbh_version) +}; +#endif + +#define APBH_CTRL0_SFTRST (1 << 31) +#define APBH_CTRL0_CLKGATE (1 << 30) +#define APBH_CTRL0_AHB_BURST8_EN (1 << 29) +#define APBH_CTRL0_APB_BURST_EN (1 << 28) +#define APBH_CTRL0_RSVD0_MASK (0xfff << 16) +#define APBH_CTRL0_RSVD0_OFFSET 16 +#define APBH_CTRL0_CLKGATE_CHANNEL_MASK 0xffff +#define APBH_CTRL0_CLKGATE_CHANNEL_OFFSET 0 +#define APBH_CTRL0_CLKGATE_CHANNEL_SSP0 0x0001 +#define APBH_CTRL0_CLKGATE_CHANNEL_SSP1 0x0002 +#define APBH_CTRL0_CLKGATE_CHANNEL_SSP2 0x0004 +#define APBH_CTRL0_CLKGATE_CHANNEL_SSP3 0x0008 +#define APBH_CTRL0_CLKGATE_CHANNEL_NAND0 0x0010 +#define APBH_CTRL0_CLKGATE_CHANNEL_NAND1 0x0020 +#define APBH_CTRL0_CLKGATE_CHANNEL_NAND2 0x0040 +#define APBH_CTRL0_CLKGATE_CHANNEL_NAND3 0x0080 +#define APBH_CTRL0_CLKGATE_CHANNEL_NAND4 0x0100 +#define APBH_CTRL0_CLKGATE_CHANNEL_NAND5 0x0200 +#define APBH_CTRL0_CLKGATE_CHANNEL_NAND6 0x0400 +#define APBH_CTRL0_CLKGATE_CHANNEL_NAND7 0x0800 +#define APBH_CTRL0_CLKGATE_CHANNEL_HSADC 0x1000 +#define APBH_CTRL0_CLKGATE_CHANNEL_LCDIF 0x2000 + +#define APBH_CTRL1_CH15_CMDCMPLT_IRQ_EN (1 << 31) +#define APBH_CTRL1_CH14_CMDCMPLT_IRQ_EN (1 << 30) +#define APBH_CTRL1_CH13_CMDCMPLT_IRQ_EN (1 << 29) +#define APBH_CTRL1_CH12_CMDCMPLT_IRQ_EN (1 << 28) +#define APBH_CTRL1_CH11_CMDCMPLT_IRQ_EN (1 << 27) +#define APBH_CTRL1_CH10_CMDCMPLT_IRQ_EN (1 << 26) +#define APBH_CTRL1_CH9_CMDCMPLT_IRQ_EN (1 << 25) +#define APBH_CTRL1_CH8_CMDCMPLT_IRQ_EN (1 << 24) +#define APBH_CTRL1_CH7_CMDCMPLT_IRQ_EN (1 << 23) +#define APBH_CTRL1_CH6_CMDCMPLT_IRQ_EN (1 << 22) +#define APBH_CTRL1_CH5_CMDCMPLT_IRQ_EN (1 << 21) +#define APBH_CTRL1_CH4_CMDCMPLT_IRQ_EN (1 << 20) +#define APBH_CTRL1_CH3_CMDCMPLT_IRQ_EN (1 << 19) +#define APBH_CTRL1_CH2_CMDCMPLT_IRQ_EN (1 << 18) +#define APBH_CTRL1_CH1_CMDCMPLT_IRQ_EN (1 << 17) +#define APBH_CTRL1_CH0_CMDCMPLT_IRQ_EN (1 << 16) +#define APBH_CTRL1_CH_CMDCMPLT_IRQ_EN_OFFSET 16 +#define APBH_CTRL1_CH_CMDCMPLT_IRQ_EN_MASK (0xffff << 16) +#define APBH_CTRL1_CH15_CMDCMPLT_IRQ (1 << 15) +#define APBH_CTRL1_CH14_CMDCMPLT_IRQ (1 << 14) +#define APBH_CTRL1_CH13_CMDCMPLT_IRQ (1 << 13) +#define APBH_CTRL1_CH12_CMDCMPLT_IRQ (1 << 12) +#define APBH_CTRL1_CH11_CMDCMPLT_IRQ (1 << 11) +#define APBH_CTRL1_CH10_CMDCMPLT_IRQ (1 << 10) +#define APBH_CTRL1_CH9_CMDCMPLT_IRQ (1 << 9) +#define APBH_CTRL1_CH8_CMDCMPLT_IRQ (1 << 8) +#define APBH_CTRL1_CH7_CMDCMPLT_IRQ (1 << 7) +#define APBH_CTRL1_CH6_CMDCMPLT_IRQ (1 << 6) +#define APBH_CTRL1_CH5_CMDCMPLT_IRQ (1 << 5) +#define APBH_CTRL1_CH4_CMDCMPLT_IRQ (1 << 4) +#define APBH_CTRL1_CH3_CMDCMPLT_IRQ (1 << 3) +#define APBH_CTRL1_CH2_CMDCMPLT_IRQ (1 << 2) +#define APBH_CTRL1_CH1_CMDCMPLT_IRQ (1 << 1) +#define APBH_CTRL1_CH0_CMDCMPLT_IRQ (1 << 0) + +#define APBH_CTRL2_CH15_ERROR_STATUS (1 << 31) +#define APBH_CTRL2_CH14_ERROR_STATUS (1 << 30) +#define APBH_CTRL2_CH13_ERROR_STATUS (1 << 29) +#define APBH_CTRL2_CH12_ERROR_STATUS (1 << 28) +#define APBH_CTRL2_CH11_ERROR_STATUS (1 << 27) +#define APBH_CTRL2_CH10_ERROR_STATUS (1 << 26) +#define APBH_CTRL2_CH9_ERROR_STATUS (1 << 25) +#define APBH_CTRL2_CH8_ERROR_STATUS (1 << 24) +#define APBH_CTRL2_CH7_ERROR_STATUS (1 << 23) +#define APBH_CTRL2_CH6_ERROR_STATUS (1 << 22) +#define APBH_CTRL2_CH5_ERROR_STATUS (1 << 21) +#define APBH_CTRL2_CH4_ERROR_STATUS (1 << 20) +#define APBH_CTRL2_CH3_ERROR_STATUS (1 << 19) +#define APBH_CTRL2_CH2_ERROR_STATUS (1 << 18) +#define APBH_CTRL2_CH1_ERROR_STATUS (1 << 17) +#define APBH_CTRL2_CH0_ERROR_STATUS (1 << 16) +#define APBH_CTRL2_CH15_ERROR_IRQ (1 << 15) +#define APBH_CTRL2_CH14_ERROR_IRQ (1 << 14) +#define APBH_CTRL2_CH13_ERROR_IRQ (1 << 13) +#define APBH_CTRL2_CH12_ERROR_IRQ (1 << 12) +#define APBH_CTRL2_CH11_ERROR_IRQ (1 << 11) +#define APBH_CTRL2_CH10_ERROR_IRQ (1 << 10) +#define APBH_CTRL2_CH9_ERROR_IRQ (1 << 9) +#define APBH_CTRL2_CH8_ERROR_IRQ (1 << 8) +#define APBH_CTRL2_CH7_ERROR_IRQ (1 << 7) +#define APBH_CTRL2_CH6_ERROR_IRQ (1 << 6) +#define APBH_CTRL2_CH5_ERROR_IRQ (1 << 5) +#define APBH_CTRL2_CH4_ERROR_IRQ (1 << 4) +#define APBH_CTRL2_CH3_ERROR_IRQ (1 << 3) +#define APBH_CTRL2_CH2_ERROR_IRQ (1 << 2) +#define APBH_CTRL2_CH1_ERROR_IRQ (1 << 1) +#define APBH_CTRL2_CH0_ERROR_IRQ (1 << 0) + +#define APBH_CHANNEL_CTRL_RESET_CHANNEL_MASK (0xffff << 16) +#define APBH_CHANNEL_CTRL_RESET_CHANNEL_OFFSET 16 +#define APBH_CHANNEL_CTRL_RESET_CHANNEL_SSP0 (0x0001 << 16) +#define APBH_CHANNEL_CTRL_RESET_CHANNEL_SSP1 (0x0002 << 16) +#define APBH_CHANNEL_CTRL_RESET_CHANNEL_SSP2 (0x0004 << 16) +#define APBH_CHANNEL_CTRL_RESET_CHANNEL_SSP3 (0x0008 << 16) +#define APBH_CHANNEL_CTRL_RESET_CHANNEL_NAND0 (0x0010 << 16) +#define APBH_CHANNEL_CTRL_RESET_CHANNEL_NAND1 (0x0020 << 16) +#define APBH_CHANNEL_CTRL_RESET_CHANNEL_NAND2 (0x0040 << 16) +#define APBH_CHANNEL_CTRL_RESET_CHANNEL_NAND3 (0x0080 << 16) +#define APBH_CHANNEL_CTRL_RESET_CHANNEL_NAND4 (0x0100 << 16) +#define APBH_CHANNEL_CTRL_RESET_CHANNEL_NAND5 (0x0200 << 16) +#define APBH_CHANNEL_CTRL_RESET_CHANNEL_NAND6 (0x0400 << 16) +#define APBH_CHANNEL_CTRL_RESET_CHANNEL_NAND7 (0x0800 << 16) +#define APBH_CHANNEL_CTRL_RESET_CHANNEL_HSADC (0x1000 << 16) +#define APBH_CHANNEL_CTRL_RESET_CHANNEL_LCDIF (0x2000 << 16) +#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_MASK 0xffff +#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_OFFSET 0 +#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_SSP0 0x0001 +#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_SSP1 0x0002 +#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_SSP2 0x0004 +#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_SSP3 0x0008 +#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_NAND0 0x0010 +#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_NAND1 0x0020 +#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_NAND2 0x0040 +#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_NAND3 0x0080 +#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_NAND4 0x0100 +#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_NAND5 0x0200 +#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_NAND6 0x0400 +#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_NAND7 0x0800 +#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_HSADC 0x1000 +#define APBH_CHANNEL_CTRL_FREEZE_CHANNEL_LCDIF 0x2000 + +#define APBH_DEVSEL_CH15_MASK (0x3 << 30) +#define APBH_DEVSEL_CH15_OFFSET 30 +#define APBH_DEVSEL_CH14_MASK (0x3 << 28) +#define APBH_DEVSEL_CH14_OFFSET 28 +#define APBH_DEVSEL_CH13_MASK (0x3 << 26) +#define APBH_DEVSEL_CH13_OFFSET 26 +#define APBH_DEVSEL_CH12_MASK (0x3 << 24) +#define APBH_DEVSEL_CH12_OFFSET 24 +#define APBH_DEVSEL_CH11_MASK (0x3 << 22) +#define APBH_DEVSEL_CH11_OFFSET 22 +#define APBH_DEVSEL_CH10_MASK (0x3 << 20) +#define APBH_DEVSEL_CH10_OFFSET 20 +#define APBH_DEVSEL_CH9_MASK (0x3 << 18) +#define APBH_DEVSEL_CH9_OFFSET 18 +#define APBH_DEVSEL_CH8_MASK (0x3 << 16) +#define APBH_DEVSEL_CH8_OFFSET 16 +#define APBH_DEVSEL_CH7_MASK (0x3 << 14) +#define APBH_DEVSEL_CH7_OFFSET 14 +#define APBH_DEVSEL_CH6_MASK (0x3 << 12) +#define APBH_DEVSEL_CH6_OFFSET 12 +#define APBH_DEVSEL_CH5_MASK (0x3 << 10) +#define APBH_DEVSEL_CH5_OFFSET 10 +#define APBH_DEVSEL_CH4_MASK (0x3 << 8) +#define APBH_DEVSEL_CH4_OFFSET 8 +#define APBH_DEVSEL_CH3_MASK (0x3 << 6) +#define APBH_DEVSEL_CH3_OFFSET 6 +#define APBH_DEVSEL_CH2_MASK (0x3 << 4) +#define APBH_DEVSEL_CH2_OFFSET 4 +#define APBH_DEVSEL_CH1_MASK (0x3 << 2) +#define APBH_DEVSEL_CH1_OFFSET 2 +#define APBH_DEVSEL_CH0_MASK (0x3 << 0) +#define APBH_DEVSEL_CH0_OFFSET 0 + +#define APBH_DMA_BURST_SIZE_CH15_MASK (0x3 << 30) +#define APBH_DMA_BURST_SIZE_CH15_OFFSET 30 +#define APBH_DMA_BURST_SIZE_CH14_MASK (0x3 << 28) +#define APBH_DMA_BURST_SIZE_CH14_OFFSET 28 +#define APBH_DMA_BURST_SIZE_CH13_MASK (0x3 << 26) +#define APBH_DMA_BURST_SIZE_CH13_OFFSET 26 +#define APBH_DMA_BURST_SIZE_CH12_MASK (0x3 << 24) +#define APBH_DMA_BURST_SIZE_CH12_OFFSET 24 +#define APBH_DMA_BURST_SIZE_CH11_MASK (0x3 << 22) +#define APBH_DMA_BURST_SIZE_CH11_OFFSET 22 +#define APBH_DMA_BURST_SIZE_CH10_MASK (0x3 << 20) +#define APBH_DMA_BURST_SIZE_CH10_OFFSET 20 +#define APBH_DMA_BURST_SIZE_CH9_MASK (0x3 << 18) +#define APBH_DMA_BURST_SIZE_CH9_OFFSET 18 +#define APBH_DMA_BURST_SIZE_CH8_MASK (0x3 << 16) +#define APBH_DMA_BURST_SIZE_CH8_OFFSET 16 +#define APBH_DMA_BURST_SIZE_CH8_BURST0 (0x0 << 16) +#define APBH_DMA_BURST_SIZE_CH8_BURST4 (0x1 << 16) +#define APBH_DMA_BURST_SIZE_CH8_BURST8 (0x2 << 16) +#define APBH_DMA_BURST_SIZE_CH7_MASK (0x3 << 14) +#define APBH_DMA_BURST_SIZE_CH7_OFFSET 14 +#define APBH_DMA_BURST_SIZE_CH6_MASK (0x3 << 12) +#define APBH_DMA_BURST_SIZE_CH6_OFFSET 12 +#define APBH_DMA_BURST_SIZE_CH5_MASK (0x3 << 10) +#define APBH_DMA_BURST_SIZE_CH5_OFFSET 10 +#define APBH_DMA_BURST_SIZE_CH4_MASK (0x3 << 8) +#define APBH_DMA_BURST_SIZE_CH4_OFFSET 8 +#define APBH_DMA_BURST_SIZE_CH3_MASK (0x3 << 6) +#define APBH_DMA_BURST_SIZE_CH3_OFFSET 6 +#define APBH_DMA_BURST_SIZE_CH3_BURST0 (0x0 << 6) +#define APBH_DMA_BURST_SIZE_CH3_BURST4 (0x1 << 6) +#define APBH_DMA_BURST_SIZE_CH3_BURST8 (0x2 << 6) + +#define APBH_DMA_BURST_SIZE_CH2_MASK (0x3 << 4) +#define APBH_DMA_BURST_SIZE_CH2_OFFSET 4 +#define APBH_DMA_BURST_SIZE_CH2_BURST0 (0x0 << 4) +#define APBH_DMA_BURST_SIZE_CH2_BURST4 (0x1 << 4) +#define APBH_DMA_BURST_SIZE_CH2_BURST8 (0x2 << 4) +#define APBH_DMA_BURST_SIZE_CH1_MASK (0x3 << 2) +#define APBH_DMA_BURST_SIZE_CH1_OFFSET 2 +#define APBH_DMA_BURST_SIZE_CH1_BURST0 (0x0 << 2) +#define APBH_DMA_BURST_SIZE_CH1_BURST4 (0x1 << 2) +#define APBH_DMA_BURST_SIZE_CH1_BURST8 (0x2 << 2) + +#define APBH_DMA_BURST_SIZE_CH0_MASK 0x3 +#define APBH_DMA_BURST_SIZE_CH0_OFFSET 0 +#define APBH_DMA_BURST_SIZE_CH0_BURST0 0x0 +#define APBH_DMA_BURST_SIZE_CH0_BURST4 0x1 +#define APBH_DMA_BURST_SIZE_CH0_BURST8 0x2 + +#define APBH_DEBUG_GPMI_ONE_FIFO (1 << 0) + +#define APBH_CHn_CURCMDAR_CMD_ADDR_MASK 0xffffffff +#define APBH_CHn_CURCMDAR_CMD_ADDR_OFFSET 0 + +#define APBH_CHn_NXTCMDAR_CMD_ADDR_MASK 0xffffffff +#define APBH_CHn_NXTCMDAR_CMD_ADDR_OFFSET 0 + +#define APBH_CHn_CMD_XFER_COUNT_MASK (0xffff << 16) +#define APBH_CHn_CMD_XFER_COUNT_OFFSET 16 +#define APBH_CHn_CMD_CMDWORDS_MASK (0xf << 12) +#define APBH_CHn_CMD_CMDWORDS_OFFSET 12 +#define APBH_CHn_CMD_HALTONTERMINATE (1 << 8) +#define APBH_CHn_CMD_WAIT4ENDCMD (1 << 7) +#define APBH_CHn_CMD_SEMAPHORE (1 << 6) +#define APBH_CHn_CMD_NANDWAIT4READY (1 << 5) +#define APBH_CHn_CMD_NANDLOCK (1 << 4) +#define APBH_CHn_CMD_IRQONCMPLT (1 << 3) +#define APBH_CHn_CMD_CHAIN (1 << 2) +#define APBH_CHn_CMD_COMMAND_MASK 0x3 +#define APBH_CHn_CMD_COMMAND_OFFSET 0 +#define APBH_CHn_CMD_COMMAND_NO_DMA_XFER 0x0 +#define APBH_CHn_CMD_COMMAND_DMA_WRITE 0x1 +#define APBH_CHn_CMD_COMMAND_DMA_READ 0x2 +#define APBH_CHn_CMD_COMMAND_DMA_SENSE 0x3 + +#define APBH_CHn_BAR_ADDRESS_MASK 0xffffffff +#define APBH_CHn_BAR_ADDRESS_OFFSET 0 + +#define APBH_CHn_SEMA_RSVD2_MASK (0xff << 24) +#define APBH_CHn_SEMA_RSVD2_OFFSET 24 +#define APBH_CHn_SEMA_PHORE_MASK (0xff << 16) +#define APBH_CHn_SEMA_PHORE_OFFSET 16 +#define APBH_CHn_SEMA_RSVD1_MASK (0xff << 8) +#define APBH_CHn_SEMA_RSVD1_OFFSET 8 +#define APBH_CHn_SEMA_INCREMENT_SEMA_MASK (0xff << 0) +#define APBH_CHn_SEMA_INCREMENT_SEMA_OFFSET 0 + +#define APBH_CHn_DEBUG1_REQ (1 << 31) +#define APBH_CHn_DEBUG1_BURST (1 << 30) +#define APBH_CHn_DEBUG1_KICK (1 << 29) +#define APBH_CHn_DEBUG1_END (1 << 28) +#define APBH_CHn_DEBUG1_SENSE (1 << 27) +#define APBH_CHn_DEBUG1_READY (1 << 26) +#define APBH_CHn_DEBUG1_LOCK (1 << 25) +#define APBH_CHn_DEBUG1_NEXTCMDADDRVALID (1 << 24) +#define APBH_CHn_DEBUG1_RD_FIFO_EMPTY (1 << 23) +#define APBH_CHn_DEBUG1_RD_FIFO_FULL (1 << 22) +#define APBH_CHn_DEBUG1_WR_FIFO_EMPTY (1 << 21) +#define APBH_CHn_DEBUG1_WR_FIFO_FULL (1 << 20) +#define APBH_CHn_DEBUG1_RSVD1_MASK (0x7fff << 5) +#define APBH_CHn_DEBUG1_RSVD1_OFFSET 5 +#define APBH_CHn_DEBUG1_STATEMACHINE_MASK 0x1f +#define APBH_CHn_DEBUG1_STATEMACHINE_OFFSET 0 +#define APBH_CHn_DEBUG1_STATEMACHINE_IDLE 0x00 +#define APBH_CHn_DEBUG1_STATEMACHINE_REQ_CMD1 0x01 +#define APBH_CHn_DEBUG1_STATEMACHINE_REQ_CMD3 0x02 +#define APBH_CHn_DEBUG1_STATEMACHINE_REQ_CMD2 0x03 +#define APBH_CHn_DEBUG1_STATEMACHINE_XFER_DECODE 0x04 +#define APBH_CHn_DEBUG1_STATEMACHINE_REQ_WAIT 0x05 +#define APBH_CHn_DEBUG1_STATEMACHINE_REQ_CMD4 0x06 +#define APBH_CHn_DEBUG1_STATEMACHINE_PIO_REQ 0x07 +#define APBH_CHn_DEBUG1_STATEMACHINE_READ_FLUSH 0x08 +#define APBH_CHn_DEBUG1_STATEMACHINE_READ_WAIT 0x09 +#define APBH_CHn_DEBUG1_STATEMACHINE_WRITE 0x0c +#define APBH_CHn_DEBUG1_STATEMACHINE_READ_REQ 0x0d +#define APBH_CHn_DEBUG1_STATEMACHINE_CHECK_CHAIN 0x0e +#define APBH_CHn_DEBUG1_STATEMACHINE_XFER_COMPLETE 0x0f +#define APBH_CHn_DEBUG1_STATEMACHINE_TERMINATE 0x14 +#define APBH_CHn_DEBUG1_STATEMACHINE_WAIT_END 0x15 +#define APBH_CHn_DEBUG1_STATEMACHINE_WRITE_WAIT 0x1c +#define APBH_CHn_DEBUG1_STATEMACHINE_HALT_AFTER_TERM 0x1d +#define APBH_CHn_DEBUG1_STATEMACHINE_CHECK_WAIT 0x1e +#define APBH_CHn_DEBUG1_STATEMACHINE_WAIT_READY 0x1f + +#define APBH_CHn_DEBUG2_APB_BYTES_MASK (0xffff << 16) +#define APBH_CHn_DEBUG2_APB_BYTES_OFFSET 16 +#define APBH_CHn_DEBUG2_AHB_BYTES_MASK 0xffff +#define APBH_CHn_DEBUG2_AHB_BYTES_OFFSET 0 + +#define APBH_VERSION_MAJOR_MASK (0xff << 24) +#define APBH_VERSION_MAJOR_OFFSET 24 +#define APBH_VERSION_MINOR_MASK (0xff << 16) +#define APBH_VERSION_MINOR_OFFSET 16 +#define APBH_VERSION_STEP_MASK 0xffff +#define APBH_VERSION_STEP_OFFSET 0 + +#endif /* __REGS_APBH_H__ */ diff --git a/arch/arm/include/asm/arch-mxs/regs-base.h b/arch/arm/include/asm/arch-mxs/regs-base.h new file mode 100644 index 0000000..dbdcc2b --- /dev/null +++ b/arch/arm/include/asm/arch-mxs/regs-base.h @@ -0,0 +1,88 @@ +/* + * Freescale i.MX28 Peripheral Base Addresses + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * Based on code from LTIB: + * Copyright (C) 2008 Embedded Alley Solutions Inc. + * + * (C) Copyright 2009-2010 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __MX28_REGS_BASE_H__ +#define __MX28_REGS_BASE_H__ + +/* + * Register base address + */ +#define MXS_ICOL_BASE 0x80000000 +#define MXS_HSADC_BASE 0x80002000 +#define MXS_APBH_BASE 0x80004000 +#define MXS_PERFMON_BASE 0x80006000 +#define MXS_BCH_BASE 0x8000A000 +#define MXS_GPMI_BASE 0x8000C000 +#define MXS_SSP0_BASE 0x80010000 +#define MXS_SSP1_BASE 0x80012000 +#define MXS_SSP2_BASE 0x80014000 +#define MXS_SSP3_BASE 0x80016000 +#define MXS_PINCTRL_BASE 0x80018000 +#define MXS_DIGCTL_BASE 0x8001C000 +#define MXS_ETM_BASE 0x80022000 +#define MXS_APBX_BASE 0x80024000 +#define MXS_DCP_BASE 0x80028000 +#define MXS_PXP_BASE 0x8002A000 +#define MXS_OCOTP_BASE 0x8002C000 +#define MXS_AXI_AHB0_BASE 0x8002E000 +#define MXS_LCDIF_BASE 0x80030000 +#define MXS_CAN0_BASE 0x80032000 +#define MXS_CAN1_BASE 0x80034000 +#define MXS_SIMDBG_BASE 0x8003C000 +#define MXS_SIMGPMISEL_BASE 0x8003C200 +#define MXS_SIMSSPSEL_BASE 0x8003C300 +#define MXS_SIMMEMSEL_BASE 0x8003C400 +#define MXS_GPIOMON_BASE 0x8003C500 +#define MXS_SIMENET_BASE 0x8003C700 +#define MXS_ARMJTAG_BASE 0x8003C800 +#define MXS_CLKCTRL_BASE 0x80040000 +#define MXS_SAIF0_BASE 0x80042000 +#define MXS_POWER_BASE 0x80044000 +#define MXS_SAIF1_BASE 0x80046000 +#define MXS_LRADC_BASE 0x80050000 +#define MXS_SPDIF_BASE 0x80054000 +#define MXS_RTC_BASE 0x80056000 +#define MXS_I2C0_BASE 0x80058000 +#define MXS_I2C1_BASE 0x8005A000 +#define MXS_PWM_BASE 0x80064000 +#define MXS_TIMROT_BASE 0x80068000 +#define MXS_UARTAPP0_BASE 0x8006A000 +#define MXS_UARTAPP1_BASE 0x8006C000 +#define MXS_UARTAPP2_BASE 0x8006E000 +#define MXS_UARTAPP3_BASE 0x80070000 +#define MXS_UARTAPP4_BASE 0x80072000 +#define MXS_UARTDBG_BASE 0x80074000 +#define MXS_USBPHY0_BASE 0x8007C000 +#define MXS_USBPHY1_BASE 0x8007E000 +#define MXS_USBCTRL0_BASE 0x80080000 +#define MXS_USBCTRL1_BASE 0x80090000 +#define MXS_DFLPT_BASE 0x800C0000 +#define MXS_DRAM_BASE 0x800E0000 +#define MXS_ENET0_BASE 0x800F0000 +#define MXS_ENET1_BASE 0x800F4000 + +#endif /* __MX28_REGS_BASE_H__ */ diff --git a/arch/arm/include/asm/arch-mxs/regs-bch.h b/arch/arm/include/asm/arch-mxs/regs-bch.h new file mode 100644 index 0000000..9243bdd --- /dev/null +++ b/arch/arm/include/asm/arch-mxs/regs-bch.h @@ -0,0 +1,230 @@ +/* + * Freescale i.MX28 BCH Register Definitions + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * Based on code from LTIB: + * Copyright 2008-2010 Freescale Semiconductor, Inc. All Rights Reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __MX28_REGS_BCH_H__ +#define __MX28_REGS_BCH_H__ + +#include <asm/arch/regs-common.h> + +#ifndef __ASSEMBLY__ +struct mx28_bch_regs { + mx28_reg_32(hw_bch_ctrl) + mx28_reg_32(hw_bch_status0) + mx28_reg_32(hw_bch_mode) + mx28_reg_32(hw_bch_encodeptr) + mx28_reg_32(hw_bch_dataptr) + mx28_reg_32(hw_bch_metaptr) + + uint32_t reserved[4]; + + mx28_reg_32(hw_bch_layoutselect) + mx28_reg_32(hw_bch_flash0layout0) + mx28_reg_32(hw_bch_flash0layout1) + mx28_reg_32(hw_bch_flash1layout0) + mx28_reg_32(hw_bch_flash1layout1) + mx28_reg_32(hw_bch_flash2layout0) + mx28_reg_32(hw_bch_flash2layout1) + mx28_reg_32(hw_bch_flash3layout0) + mx28_reg_32(hw_bch_flash3layout1) + mx28_reg_32(hw_bch_dbgkesread) + mx28_reg_32(hw_bch_dbgcsferead) + mx28_reg_32(hw_bch_dbgsyndegread) + mx28_reg_32(hw_bch_dbgahbmread) + mx28_reg_32(hw_bch_blockname) + mx28_reg_32(hw_bch_version) +}; +#endif + +#define BCH_CTRL_SFTRST (1 << 31) +#define BCH_CTRL_CLKGATE (1 << 30) +#define BCH_CTRL_DEBUGSYNDROME (1 << 22) +#define BCH_CTRL_M2M_LAYOUT_MASK (0x3 << 18) +#define BCH_CTRL_M2M_LAYOUT_OFFSET 18 +#define BCH_CTRL_M2M_ENCODE (1 << 17) +#define BCH_CTRL_M2M_ENABLE (1 << 16) +#define BCH_CTRL_DEBUG_STALL_IRQ_EN (1 << 10) +#define BCH_CTRL_COMPLETE_IRQ_EN (1 << 8) +#define BCH_CTRL_BM_ERROR_IRQ (1 << 3) +#define BCH_CTRL_DEBUG_STALL_IRQ (1 << 2) +#define BCH_CTRL_COMPLETE_IRQ (1 << 0) + +#define BCH_STATUS0_HANDLE_MASK (0xfff << 20) +#define BCH_STATUS0_HANDLE_OFFSET 20 +#define BCH_STATUS0_COMPLETED_CE_MASK (0xf << 16) +#define BCH_STATUS0_COMPLETED_CE_OFFSET 16 +#define BCH_STATUS0_STATUS_BLK0_MASK (0xff << 8) +#define BCH_STATUS0_STATUS_BLK0_OFFSET 8 +#define BCH_STATUS0_STATUS_BLK0_ZERO (0x00 << 8) +#define BCH_STATUS0_STATUS_BLK0_ERROR1 (0x01 << 8) +#define BCH_STATUS0_STATUS_BLK0_ERROR2 (0x02 << 8) +#define BCH_STATUS0_STATUS_BLK0_ERROR3 (0x03 << 8) +#define BCH_STATUS0_STATUS_BLK0_ERROR4 (0x04 << 8) +#define BCH_STATUS0_STATUS_BLK0_UNCORRECTABLE (0xfe << 8) +#define BCH_STATUS0_STATUS_BLK0_ERASED (0xff << 8) +#define BCH_STATUS0_ALLONES (1 << 4) +#define BCH_STATUS0_CORRECTED (1 << 3) +#define BCH_STATUS0_UNCORRECTABLE (1 << 2) + +#define BCH_MODE_ERASE_THRESHOLD_MASK 0xff +#define BCH_MODE_ERASE_THRESHOLD_OFFSET 0 + +#define BCH_ENCODEPTR_ADDR_MASK 0xffffffff +#define BCH_ENCODEPTR_ADDR_OFFSET 0 + +#define BCH_DATAPTR_ADDR_MASK 0xffffffff +#define BCH_DATAPTR_ADDR_OFFSET 0 + +#define BCH_METAPTR_ADDR_MASK 0xffffffff +#define BCH_METAPTR_ADDR_OFFSET 0 + +#define BCH_LAYOUTSELECT_CS15_SELECT_MASK (0x3 << 30) +#define BCH_LAYOUTSELECT_CS15_SELECT_OFFSET 30 +#define BCH_LAYOUTSELECT_CS14_SELECT_MASK (0x3 << 28) +#define BCH_LAYOUTSELECT_CS14_SELECT_OFFSET 28 +#define BCH_LAYOUTSELECT_CS13_SELECT_MASK (0x3 << 26) +#define BCH_LAYOUTSELECT_CS13_SELECT_OFFSET 26 +#define BCH_LAYOUTSELECT_CS12_SELECT_MASK (0x3 << 24) +#define BCH_LAYOUTSELECT_CS12_SELECT_OFFSET 24 +#define BCH_LAYOUTSELECT_CS11_SELECT_MASK (0x3 << 22) +#define BCH_LAYOUTSELECT_CS11_SELECT_OFFSET 22 +#define BCH_LAYOUTSELECT_CS10_SELECT_MASK (0x3 << 20) +#define BCH_LAYOUTSELECT_CS10_SELECT_OFFSET 20 +#define BCH_LAYOUTSELECT_CS9_SELECT_MASK (0x3 << 18) +#define BCH_LAYOUTSELECT_CS9_SELECT_OFFSET 18 +#define BCH_LAYOUTSELECT_CS8_SELECT_MASK (0x3 << 16) +#define BCH_LAYOUTSELECT_CS8_SELECT_OFFSET 16 +#define BCH_LAYOUTSELECT_CS7_SELECT_MASK (0x3 << 14) +#define BCH_LAYOUTSELECT_CS7_SELECT_OFFSET 14 +#define BCH_LAYOUTSELECT_CS6_SELECT_MASK (0x3 << 12) +#define BCH_LAYOUTSELECT_CS6_SELECT_OFFSET 12 +#define BCH_LAYOUTSELECT_CS5_SELECT_MASK (0x3 << 10) +#define BCH_LAYOUTSELECT_CS5_SELECT_OFFSET 10 +#define BCH_LAYOUTSELECT_CS4_SELECT_MASK (0x3 << 8) +#define BCH_LAYOUTSELECT_CS4_SELECT_OFFSET 8 +#define BCH_LAYOUTSELECT_CS3_SELECT_MASK (0x3 << 6) +#define BCH_LAYOUTSELECT_CS3_SELECT_OFFSET 6 +#define BCH_LAYOUTSELECT_CS2_SELECT_MASK (0x3 << 4) +#define BCH_LAYOUTSELECT_CS2_SELECT_OFFSET 4 +#define BCH_LAYOUTSELECT_CS1_SELECT_MASK (0x3 << 2) +#define BCH_LAYOUTSELECT_CS1_SELECT_OFFSET 2 +#define BCH_LAYOUTSELECT_CS0_SELECT_MASK (0x3 << 0) +#define BCH_LAYOUTSELECT_CS0_SELECT_OFFSET 0 + +#define BCH_FLASHLAYOUT0_NBLOCKS_MASK (0xff << 24) +#define BCH_FLASHLAYOUT0_NBLOCKS_OFFSET 24 +#define BCH_FLASHLAYOUT0_META_SIZE_MASK (0xff << 16) +#define BCH_FLASHLAYOUT0_META_SIZE_OFFSET 16 +#define BCH_FLASHLAYOUT0_ECC0_MASK (0xf << 12) +#define BCH_FLASHLAYOUT0_ECC0_OFFSET 12 +#define BCH_FLASHLAYOUT0_ECC0_NONE (0x0 << 12) +#define BCH_FLASHLAYOUT0_ECC0_ECC2 (0x1 << 12) +#define BCH_FLASHLAYOUT0_ECC0_ECC4 (0x2 << 12) +#define BCH_FLASHLAYOUT0_ECC0_ECC6 (0x3 << 12) +#define BCH_FLASHLAYOUT0_ECC0_ECC8 (0x4 << 12) +#define BCH_FLASHLAYOUT0_ECC0_ECC10 (0x5 << 12) +#define BCH_FLASHLAYOUT0_ECC0_ECC12 (0x6 << 12) +#define BCH_FLASHLAYOUT0_ECC0_ECC14 (0x7 << 12) +#define BCH_FLASHLAYOUT0_ECC0_ECC16 (0x8 << 12) +#define BCH_FLASHLAYOUT0_ECC0_ECC18 (0x9 << 12) +#define BCH_FLASHLAYOUT0_ECC0_ECC20 (0xa << 12) +#define BCH_FLASHLAYOUT0_ECC0_ECC22 (0xb << 12) +#define BCH_FLASHLAYOUT0_ECC0_ECC24 (0xc << 12) +#define BCH_FLASHLAYOUT0_ECC0_ECC26 (0xd << 12) +#define BCH_FLASHLAYOUT0_ECC0_ECC28 (0xe << 12) +#define BCH_FLASHLAYOUT0_ECC0_ECC30 (0xf << 12) +#define BCH_FLASHLAYOUT0_ECC0_ECC32 (0x10 << 12) +#define BCH_FLASHLAYOUT0_GF13_0_GF14_1 (1 << 10) +#define BCH_FLASHLAYOUT0_DATA0_SIZE_MASK 0xfff +#define BCH_FLASHLAYOUT0_DATA0_SIZE_OFFSET 0 + +#define BCH_FLASHLAYOUT1_PAGE_SIZE_MASK (0xffff << 16) +#define BCH_FLASHLAYOUT1_PAGE_SIZE_OFFSET 16 +#define BCH_FLASHLAYOUT1_ECCN_MASK (0xf << 12) +#define BCH_FLASHLAYOUT1_ECCN_OFFSET 12 +#define BCH_FLASHLAYOUT1_ECCN_NONE (0x0 << 12) +#define BCH_FLASHLAYOUT1_ECCN_ECC2 (0x1 << 12) +#define BCH_FLASHLAYOUT1_ECCN_ECC4 (0x2 << 12) +#define BCH_FLASHLAYOUT1_ECCN_ECC6 (0x3 << 12) +#define BCH_FLASHLAYOUT1_ECCN_ECC8 (0x4 << 12) +#define BCH_FLASHLAYOUT1_ECCN_ECC10 (0x5 << 12) +#define BCH_FLASHLAYOUT1_ECCN_ECC12 (0x6 << 12) +#define BCH_FLASHLAYOUT1_ECCN_ECC14 (0x7 << 12) +#define BCH_FLASHLAYOUT1_ECCN_ECC16 (0x8 << 12) +#define BCH_FLASHLAYOUT1_ECCN_ECC18 (0x9 << 12) +#define BCH_FLASHLAYOUT1_ECCN_ECC20 (0xa << 12) +#define BCH_FLASHLAYOUT1_ECCN_ECC22 (0xb << 12) +#define BCH_FLASHLAYOUT1_ECCN_ECC24 (0xc << 12) +#define BCH_FLASHLAYOUT1_ECCN_ECC26 (0xd << 12) +#define BCH_FLASHLAYOUT1_ECCN_ECC28 (0xe << 12) +#define BCH_FLASHLAYOUT1_ECCN_ECC30 (0xf << 12) +#define BCH_FLASHLAYOUT1_ECCN_ECC32 (0x10 << 12) +#define BCH_FLASHLAYOUT1_GF13_0_GF14_1 (1 << 10) +#define BCH_FLASHLAYOUT1_DATAN_SIZE_MASK 0xfff +#define BCH_FLASHLAYOUT1_DATAN_SIZE_OFFSET 0 + +#define BCH_DEBUG0_RSVD1_MASK (0x1f << 27) +#define BCH_DEBUG0_RSVD1_OFFSET 27 +#define BCH_DEBUG0_ROM_BIST_ENABLE (1 << 26) +#define BCH_DEBUG0_ROM_BIST_COMPLETE (1 << 25) +#define BCH_DEBUG0_KES_DEBUG_SYNDROME_SYMBOL_MASK (0x1ff << 16) +#define BCH_DEBUG0_KES_DEBUG_SYNDROME_SYMBOL_OFFSET 16 +#define BCH_DEBUG0_KES_DEBUG_SYNDROME_SYMBOL_NORMAL (0x0 << 16) +#define BCH_DEBUG0_KES_DEBUG_SYNDROME_SYMBOL_TEST_MODE (0x1 << 16) +#define BCH_DEBUG0_KES_DEBUG_SHIFT_SYND (1 << 15) +#define BCH_DEBUG0_KES_DEBUG_PAYLOAD_FLAG (1 << 14) +#define BCH_DEBUG0_KES_DEBUG_MODE4K (1 << 13) +#define BCH_DEBUG0_KES_DEBUG_KICK (1 << 12) +#define BCH_DEBUG0_KES_STANDALONE (1 << 11) +#define BCH_DEBUG0_KES_DEBUG_STEP (1 << 10) +#define BCH_DEBUG0_KES_DEBUG_STALL (1 << 9) +#define BCH_DEBUG0_BM_KES_TEST_BYPASS (1 << 8) +#define BCH_DEBUG0_RSVD0_MASK (0x3 << 6) +#define BCH_DEBUG0_RSVD0_OFFSET 6 +#define BCH_DEBUG0_DEBUG_REG_SELECT_MASK 0x3f +#define BCH_DEBUG0_DEBUG_REG_SELECT_OFFSET 0 + +#define BCH_DBGKESREAD_VALUES_MASK 0xffffffff +#define BCH_DBGKESREAD_VALUES_OFFSET 0 + +#define BCH_DBGCSFEREAD_VALUES_MASK 0xffffffff +#define BCH_DBGCSFEREAD_VALUES_OFFSET 0 + +#define BCH_DBGSYNDGENREAD_VALUES_MASK 0xffffffff +#define BCH_DBGSYNDGENREAD_VALUES_OFFSET 0 + +#define BCH_DBGAHBMREAD_VALUES_MASK 0xffffffff +#define BCH_DBGAHBMREAD_VALUES_OFFSET 0 + +#define BCH_BLOCKNAME_NAME_MASK 0xffffffff +#define BCH_BLOCKNAME_NAME_OFFSET 0 + +#define BCH_VERSION_MAJOR_MASK (0xff << 24) +#define BCH_VERSION_MAJOR_OFFSET 24 +#define BCH_VERSION_MINOR_MASK (0xff << 16) +#define BCH_VERSION_MINOR_OFFSET 16 +#define BCH_VERSION_STEP_MASK 0xffff +#define BCH_VERSION_STEP_OFFSET 0 + +#endif /* __MX28_REGS_BCH_H__ */ diff --git a/arch/arm/include/asm/arch-mxs/regs-clkctrl.h b/arch/arm/include/asm/arch-mxs/regs-clkctrl.h new file mode 100644 index 0000000..3c4947d --- /dev/null +++ b/arch/arm/include/asm/arch-mxs/regs-clkctrl.h @@ -0,0 +1,294 @@ +/* + * Freescale i.MX28 CLKCTRL Register Definitions + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * Based on code from LTIB: + * Copyright 2008-2010 Freescale Semiconductor, Inc. All Rights Reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __MX28_REGS_CLKCTRL_H__ +#define __MX28_REGS_CLKCTRL_H__ + +#include <asm/arch/regs-common.h> + +#ifndef __ASSEMBLY__ +struct mx28_clkctrl_regs { + mx28_reg_32(hw_clkctrl_pll0ctrl0) /* 0x00 */ + mx28_reg_32(hw_clkctrl_pll0ctrl1) /* 0x10 */ + mx28_reg_32(hw_clkctrl_pll1ctrl0) /* 0x20 */ + mx28_reg_32(hw_clkctrl_pll1ctrl1) /* 0x30 */ + mx28_reg_32(hw_clkctrl_pll2ctrl0) /* 0x40 */ + mx28_reg_32(hw_clkctrl_cpu) /* 0x50 */ + mx28_reg_32(hw_clkctrl_hbus) /* 0x60 */ + mx28_reg_32(hw_clkctrl_xbus) /* 0x70 */ + mx28_reg_32(hw_clkctrl_xtal) /* 0x80 */ + mx28_reg_32(hw_clkctrl_ssp0) /* 0x90 */ + mx28_reg_32(hw_clkctrl_ssp1) /* 0xa0 */ + mx28_reg_32(hw_clkctrl_ssp2) /* 0xb0 */ + mx28_reg_32(hw_clkctrl_ssp3) /* 0xc0 */ + mx28_reg_32(hw_clkctrl_gpmi) /* 0xd0 */ + mx28_reg_32(hw_clkctrl_spdif) /* 0xe0 */ + mx28_reg_32(hw_clkctrl_emi) /* 0xf0 */ + mx28_reg_32(hw_clkctrl_saif0) /* 0x100 */ + mx28_reg_32(hw_clkctrl_saif1) /* 0x110 */ + mx28_reg_32(hw_clkctrl_lcdif) /* 0x120 */ + mx28_reg_32(hw_clkctrl_etm) /* 0x130 */ + mx28_reg_32(hw_clkctrl_enet) /* 0x140 */ + mx28_reg_32(hw_clkctrl_hsadc) /* 0x150 */ + mx28_reg_32(hw_clkctrl_flexcan) /* 0x160 */ + + uint32_t reserved[16]; + + mx28_reg_8(hw_clkctrl_frac0) /* 0x1b0 */ + mx28_reg_8(hw_clkctrl_frac1) /* 0x1c0 */ + mx28_reg_32(hw_clkctrl_clkseq) /* 0x1d0 */ + mx28_reg_32(hw_clkctrl_reset) /* 0x1e0 */ + mx28_reg_32(hw_clkctrl_status) /* 0x1f0 */ + mx28_reg_32(hw_clkctrl_version) /* 0x200 */ +}; +#endif + +#define CLKCTRL_PLL0CTRL0_LFR_SEL_MASK (0x3 << 28) +#define CLKCTRL_PLL0CTRL0_LFR_SEL_OFFSET 28 +#define CLKCTRL_PLL0CTRL0_LFR_SEL_DEFAULT (0x0 << 28) +#define CLKCTRL_PLL0CTRL0_LFR_SEL_TIMES_2 (0x1 << 28) +#define CLKCTRL_PLL0CTRL0_LFR_SEL_TIMES_05 (0x2 << 28) +#define CLKCTRL_PLL0CTRL0_LFR_SEL_UNDEFINED (0x3 << 28) +#define CLKCTRL_PLL0CTRL0_CP_SEL_MASK (0x3 << 24) +#define CLKCTRL_PLL0CTRL0_CP_SEL_OFFSET 24 +#define CLKCTRL_PLL0CTRL0_CP_SEL_DEFAULT (0x0 << 24) +#define CLKCTRL_PLL0CTRL0_CP_SEL_TIMES_2 (0x1 << 24) +#define CLKCTRL_PLL0CTRL0_CP_SEL_TIMES_05 (0x2 << 24) +#define CLKCTRL_PLL0CTRL0_CP_SEL_UNDEFINED (0x3 << 24) +#define CLKCTRL_PLL0CTRL0_DIV_SEL_MASK (0x3 << 20) +#define CLKCTRL_PLL0CTRL0_DIV_SEL_OFFSET 20 +#define CLKCTRL_PLL0CTRL0_DIV_SEL_DEFAULT (0x0 << 20) +#define CLKCTRL_PLL0CTRL0_DIV_SEL_LOWER (0x1 << 20) +#define CLKCTRL_PLL0CTRL0_DIV_SEL_LOWEST (0x2 << 20) +#define CLKCTRL_PLL0CTRL0_DIV_SEL_UNDEFINED (0x3 << 20) +#define CLKCTRL_PLL0CTRL0_EN_USB_CLKS (1 << 18) +#define CLKCTRL_PLL0CTRL0_POWER (1 << 17) + +#define CLKCTRL_PLL0CTRL1_LOCK (1 << 31) +#define CLKCTRL_PLL0CTRL1_FORCE_LOCK (1 << 30) +#define CLKCTRL_PLL0CTRL1_LOCK_COUNT_MASK 0xffff +#define CLKCTRL_PLL0CTRL1_LOCK_COUNT_OFFSET 0 + +#define CLKCTRL_PLL1CTRL0_CLKGATEEMI (1 << 31) +#define CLKCTRL_PLL1CTRL0_LFR_SEL_MASK (0x3 << 28) +#define CLKCTRL_PLL1CTRL0_LFR_SEL_OFFSET 28 +#define CLKCTRL_PLL1CTRL0_LFR_SEL_DEFAULT (0x0 << 28) +#define CLKCTRL_PLL1CTRL0_LFR_SEL_TIMES_2 (0x1 << 28) +#define CLKCTRL_PLL1CTRL0_LFR_SEL_TIMES_05 (0x2 << 28) +#define CLKCTRL_PLL1CTRL0_LFR_SEL_UNDEFINED (0x3 << 28) +#define CLKCTRL_PLL1CTRL0_CP_SEL_MASK (0x3 << 24) +#define CLKCTRL_PLL1CTRL0_CP_SEL_OFFSET 24 +#define CLKCTRL_PLL1CTRL0_CP_SEL_DEFAULT (0x0 << 24) +#define CLKCTRL_PLL1CTRL0_CP_SEL_TIMES_2 (0x1 << 24) +#define CLKCTRL_PLL1CTRL0_CP_SEL_TIMES_05 (0x2 << 24) +#define CLKCTRL_PLL1CTRL0_CP_SEL_UNDEFINED (0x3 << 24) +#define CLKCTRL_PLL1CTRL0_DIV_SEL_MASK (0x3 << 20) +#define CLKCTRL_PLL1CTRL0_DIV_SEL_OFFSET 20 +#define CLKCTRL_PLL1CTRL0_DIV_SEL_DEFAULT (0x0 << 20) +#define CLKCTRL_PLL1CTRL0_DIV_SEL_LOWER (0x1 << 20) +#define CLKCTRL_PLL1CTRL0_DIV_SEL_LOWEST (0x2 << 20) +#define CLKCTRL_PLL1CTRL0_DIV_SEL_UNDEFINED (0x3 << 20) +#define CLKCTRL_PLL1CTRL0_EN_USB_CLKS (1 << 18) +#define CLKCTRL_PLL1CTRL0_POWER (1 << 17) + +#define CLKCTRL_PLL1CTRL1_LOCK (1 << 31) +#define CLKCTRL_PLL1CTRL1_FORCE_LOCK (1 << 30) +#define CLKCTRL_PLL1CTRL1_LOCK_COUNT_MASK 0xffff +#define CLKCTRL_PLL1CTRL1_LOCK_COUNT_OFFSET 0 + +#define CLKCTRL_PLL2CTRL0_CLKGATE (1 << 31) +#define CLKCTRL_PLL2CTRL0_LFR_SEL_MASK (0x3 << 28) +#define CLKCTRL_PLL2CTRL0_LFR_SEL_OFFSET 28 +#define CLKCTRL_PLL2CTRL0_HOLD_RING_OFF_B (1 << 26) +#define CLKCTRL_PLL2CTRL0_CP_SEL_MASK (0x3 << 24) +#define CLKCTRL_PLL2CTRL0_CP_SEL_OFFSET 24 +#define CLKCTRL_PLL2CTRL0_POWER (1 << 23) + +#define CLKCTRL_CPU_BUSY_REF_XTAL (1 << 29) +#define CLKCTRL_CPU_BUSY_REF_CPU (1 << 28) +#define CLKCTRL_CPU_DIV_XTAL_FRAC_EN (1 << 26) +#define CLKCTRL_CPU_DIV_XTAL_MASK (0x3ff << 16) +#define CLKCTRL_CPU_DIV_XTAL_OFFSET 16 +#define CLKCTRL_CPU_INTERRUPT_WAIT (1 << 12) +#define CLKCTRL_CPU_DIV_CPU_FRAC_EN (1 << 10) +#define CLKCTRL_CPU_DIV_CPU_MASK 0x3f +#define CLKCTRL_CPU_DIV_CPU_OFFSET 0 + +#define CLKCTRL_HBUS_ASM_BUSY (1 << 31) +#define CLKCTRL_HBUS_DCP_AS_ENABLE (1 << 30) +#define CLKCTRL_HBUS_PXP_AS_ENABLE (1 << 29) +#define CLKCTRL_HBUS_ASM_EMIPORT_AS_ENABLE (1 << 27) +#define CLKCTRL_HBUS_APBHDMA_AS_ENABLE (1 << 26) +#define CLKCTRL_HBUS_APBXDMA_AS_ENABLE (1 << 25) +#define CLKCTRL_HBUS_TRAFFIC_JAM_AS_ENABLE (1 << 24) +#define CLKCTRL_HBUS_TRAFFIC_AS_ENABLE (1 << 23) +#define CLKCTRL_HBUS_CPU_DATA_AS_ENABLE (1 << 22) +#define CLKCTRL_HBUS_CPU_INSTR_AS_ENABLE (1 << 21) +#define CLKCTRL_HBUS_ASM_ENABLE (1 << 20) +#define CLKCTRL_HBUS_AUTO_CLEAR_DIV_ENABLE (1 << 19) +#define CLKCTRL_HBUS_SLOW_DIV_MASK (0x7 << 16) +#define CLKCTRL_HBUS_SLOW_DIV_OFFSET 16 +#define CLKCTRL_HBUS_SLOW_DIV_BY1 (0x0 << 16) +#define CLKCTRL_HBUS_SLOW_DIV_BY2 (0x1 << 16) +#define CLKCTRL_HBUS_SLOW_DIV_BY4 (0x2 << 16) +#define CLKCTRL_HBUS_SLOW_DIV_BY8 (0x3 << 16) +#define CLKCTRL_HBUS_SLOW_DIV_BY16 (0x4 << 16) +#define CLKCTRL_HBUS_SLOW_DIV_BY32 (0x5 << 16) +#define CLKCTRL_HBUS_DIV_FRAC_EN (1 << 5) +#define CLKCTRL_HBUS_DIV_MASK 0x1f +#define CLKCTRL_HBUS_DIV_OFFSET 0 + +#define CLKCTRL_XBUS_BUSY (1 << 31) +#define CLKCTRL_XBUS_AUTO_CLEAR_DIV_ENABLE (1 << 11) +#define CLKCTRL_XBUS_DIV_FRAC_EN (1 << 10) +#define CLKCTRL_XBUS_DIV_MASK 0x3ff +#define CLKCTRL_XBUS_DIV_OFFSET 0 + +#define CLKCTRL_XTAL_UART_CLK_GATE (1 << 31) +#define CLKCTRL_XTAL_PWM_CLK24M_GATE (1 << 29) +#define CLKCTRL_XTAL_TIMROT_CLK32K_GATE (1 << 26) +#define CLKCTRL_XTAL_DIV_UART_MASK 0x3 +#define CLKCTRL_XTAL_DIV_UART_OFFSET 0 + +#define CLKCTRL_SSP_CLKGATE (1 << 31) +#define CLKCTRL_SSP_BUSY (1 << 29) +#define CLKCTRL_SSP_DIV_FRAC_EN (1 << 9) +#define CLKCTRL_SSP_DIV_MASK 0x1ff +#define CLKCTRL_SSP_DIV_OFFSET 0 + +#define CLKCTRL_GPMI_CLKGATE (1 << 31) +#define CLKCTRL_GPMI_BUSY (1 << 29) +#define CLKCTRL_GPMI_DIV_FRAC_EN (1 << 10) +#define CLKCTRL_GPMI_DIV_MASK 0x3ff +#define CLKCTRL_GPMI_DIV_OFFSET 0 + +#define CLKCTRL_SPDIF_CLKGATE (1 << 31) + +#define CLKCTRL_EMI_CLKGATE (1 << 31) +#define CLKCTRL_EMI_SYNC_MODE_EN (1 << 30) +#define CLKCTRL_EMI_BUSY_REF_XTAL (1 << 29) +#define CLKCTRL_EMI_BUSY_REF_EMI (1 << 28) +#define CLKCTRL_EMI_BUSY_REF_CPU (1 << 27) +#define CLKCTRL_EMI_BUSY_SYNC_MODE (1 << 26) +#define CLKCTRL_EMI_BUSY_DCC_RESYNC (1 << 17) +#define CLKCTRL_EMI_DCC_RESYNC_ENABLE (1 << 16) +#define CLKCTRL_EMI_DIV_XTAL_MASK (0xf << 8) +#define CLKCTRL_EMI_DIV_XTAL_OFFSET 8 +#define CLKCTRL_EMI_DIV_EMI_MASK 0x3f +#define CLKCTRL_EMI_DIV_EMI_OFFSET 0 + +#define CLKCTRL_SAIF0_CLKGATE (1 << 31) +#define CLKCTRL_SAIF0_BUSY (1 << 29) +#define CLKCTRL_SAIF0_DIV_FRAC_EN (1 << 16) +#define CLKCTRL_SAIF0_DIV_MASK 0xffff +#define CLKCTRL_SAIF0_DIV_OFFSET 0 + +#define CLKCTRL_SAIF1_CLKGATE (1 << 31) +#define CLKCTRL_SAIF1_BUSY (1 << 29) +#define CLKCTRL_SAIF1_DIV_FRAC_EN (1 << 16) +#define CLKCTRL_SAIF1_DIV_MASK 0xffff +#define CLKCTRL_SAIF1_DIV_OFFSET 0 + +#define CLKCTRL_DIS_LCDIF_CLKGATE (1 << 31) +#define CLKCTRL_DIS_LCDIF_BUSY (1 << 29) +#define CLKCTRL_DIS_LCDIF_DIV_FRAC_EN (1 << 13) +#define CLKCTRL_DIS_LCDIF_DIV_MASK 0x1fff +#define CLKCTRL_DIS_LCDIF_DIV_OFFSET 0 + +#define CLKCTRL_ETM_CLKGATE (1 << 31) +#define CLKCTRL_ETM_BUSY (1 << 29) +#define CLKCTRL_ETM_DIV_FRAC_EN (1 << 7) +#define CLKCTRL_ETM_DIV_MASK 0x7f +#define CLKCTRL_ETM_DIV_OFFSET 0 + +#define CLKCTRL_ENET_SLEEP (1 << 31) +#define CLKCTRL_ENET_DISABLE (1 << 30) +#define CLKCTRL_ENET_STATUS (1 << 29) +#define CLKCTRL_ENET_BUSY_TIME (1 << 27) +#define CLKCTRL_ENET_DIV_TIME_MASK (0x3f << 21) +#define CLKCTRL_ENET_DIV_TIME_OFFSET 21 +#define CLKCTRL_ENET_TIME_SEL_MASK (0x3 << 19) +#define CLKCTRL_ENET_TIME_SEL_OFFSET 19 +#define CLKCTRL_ENET_TIME_SEL_XTAL (0x0 << 19) +#define CLKCTRL_ENET_TIME_SEL_PLL (0x1 << 19) +#define CLKCTRL_ENET_TIME_SEL_RMII_CLK (0x2 << 19) +#define CLKCTRL_ENET_TIME_SEL_UNDEFINED (0x3 << 19) +#define CLKCTRL_ENET_CLK_OUT_EN (1 << 18) +#define CLKCTRL_ENET_RESET_BY_SW_CHIP (1 << 17) +#define CLKCTRL_ENET_RESET_BY_SW (1 << 16) + +#define CLKCTRL_HSADC_RESETB (1 << 30) +#define CLKCTRL_HSADC_FREQDIV_MASK (0x3 << 28) +#define CLKCTRL_HSADC_FREQDIV_OFFSET 28 + +#define CLKCTRL_FLEXCAN_STOP_CAN0 (1 << 30) +#define CLKCTRL_FLEXCAN_CAN0_STATUS (1 << 29) +#define CLKCTRL_FLEXCAN_STOP_CAN1 (1 << 28) +#define CLKCTRL_FLEXCAN_CAN1_STATUS (1 << 27) + +#define CLKCTRL_FRAC_CLKGATE (1 << 7) +#define CLKCTRL_FRAC_STABLE (1 << 6) +#define CLKCTRL_FRAC_FRAC_MASK 0x3f +#define CLKCTRL_FRAC_FRAC_OFFSET 0 +#define CLKCTRL_FRAC0_CPU 0 +#define CLKCTRL_FRAC0_EMI 1 +#define CLKCTRL_FRAC0_IO1 2 +#define CLKCTRL_FRAC0_IO0 3 +#define CLKCTRL_FRAC1_PIX 0 +#define CLKCTRL_FRAC1_HSADC 1 +#define CLKCTRL_FRAC1_GPMI 2 + +#define CLKCTRL_CLKSEQ_BYPASS_CPU (1 << 18) +#define CLKCTRL_CLKSEQ_BYPASS_DIS_LCDIF (1 << 14) +#define CLKCTRL_CLKSEQ_BYPASS_DIS_LCDIF_BYPASS (0x1 << 14) +#define CLKCTRL_CLKSEQ_BYPASS_DIS_LCDIF_PFD (0x0 << 14) +#define CLKCTRL_CLKSEQ_BYPASS_ETM (1 << 8) +#define CLKCTRL_CLKSEQ_BYPASS_EMI (1 << 7) +#define CLKCTRL_CLKSEQ_BYPASS_SSP3 (1 << 6) +#define CLKCTRL_CLKSEQ_BYPASS_SSP2 (1 << 5) +#define CLKCTRL_CLKSEQ_BYPASS_SSP1 (1 << 4) +#define CLKCTRL_CLKSEQ_BYPASS_SSP0 (1 << 3) +#define CLKCTRL_CLKSEQ_BYPASS_GPMI (1 << 2) +#define CLKCTRL_CLKSEQ_BYPASS_SAIF1 (1 << 1) +#define CLKCTRL_CLKSEQ_BYPASS_SAIF0 (1 << 0) + +#define CLKCTRL_RESET_WDOG_POR_DISABLE (1 << 5) +#define CLKCTRL_RESET_EXTERNAL_RESET_ENABLE (1 << 4) +#define CLKCTRL_RESET_THERMAL_RESET_ENABLE (1 << 3) +#define CLKCTRL_RESET_THERMAL_RESET_DEFAULT (1 << 2) +#define CLKCTRL_RESET_CHIP (1 << 1) +#define CLKCTRL_RESET_DIG (1 << 0) + +#define CLKCTRL_STATUS_CPU_LIMIT_MASK (0x3 << 30) +#define CLKCTRL_STATUS_CPU_LIMIT_OFFSET 30 + +#define CLKCTRL_VERSION_MAJOR_MASK (0xff << 24) +#define CLKCTRL_VERSION_MAJOR_OFFSET 24 +#define CLKCTRL_VERSION_MINOR_MASK (0xff << 16) +#define CLKCTRL_VERSION_MINOR_OFFSET 16 +#define CLKCTRL_VERSION_STEP_MASK 0xffff +#define CLKCTRL_VERSION_STEP_OFFSET 0 + +#endif /* __MX28_REGS_CLKCTRL_H__ */ diff --git a/arch/arm/include/asm/arch-mxs/regs-common.h b/arch/arm/include/asm/arch-mxs/regs-common.h new file mode 100644 index 0000000..d2e1953 --- /dev/null +++ b/arch/arm/include/asm/arch-mxs/regs-common.h @@ -0,0 +1,82 @@ +/* + * Freescale i.MX28 Register Accessors + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __MX28_REGS_COMMON_H__ +#define __MX28_REGS_COMMON_H__ + +/* + * The i.MX28 has interesting feature when it comes to register access. There + * are four kinds of access to one particular register. Those are: + * + * 1) Common read/write access. To use this mode, just write to the address of + * the register. + * 2) Set bits only access. To set bits, write which bits you want to set to the + * address of the register + 0x4. + * 3) Clear bits only access. To clear bits, write which bits you want to clear + * to the address of the register + 0x8. + * 4) Toggle bits only access. To toggle bits, write which bits you want to + * toggle to the address of the register + 0xc. + * + * IMPORTANT NOTE: Not all registers support accesses 2-4! Also, not all bits + * can be set/cleared by pure write as in access type 1, some need to be + * explicitly set/cleared by using access type 2-3. + * + * The following macros and structures allow the user to either access the + * register in all aforementioned modes (by accessing reg_name, reg_name_set, + * reg_name_clr, reg_name_tog) or pass the register structure further into + * various functions with correct type information (by accessing reg_name_reg). + * + */ + +#define __mx28_reg_8(name) \ + uint8_t name[4]; \ + uint8_t name##_set[4]; \ + uint8_t name##_clr[4]; \ + uint8_t name##_tog[4]; \ + +#define __mx28_reg_32(name) \ + uint32_t name; \ + uint32_t name##_set; \ + uint32_t name##_clr; \ + uint32_t name##_tog; + +struct mx28_register_8 { + __mx28_reg_8(reg) +}; + +struct mx28_register_32 { + __mx28_reg_32(reg) +}; + +#define mx28_reg_8(name) \ + union { \ + struct { __mx28_reg_8(name) }; \ + struct mx28_register_8 name##_reg; \ + }; + +#define mx28_reg_32(name) \ + union { \ + struct { __mx28_reg_32(name) }; \ + struct mx28_register_32 name##_reg; \ + }; + +#endif /* __MX28_REGS_COMMON_H__ */ diff --git a/arch/arm/include/asm/arch-mxs/regs-digctl.h b/arch/arm/include/asm/arch-mxs/regs-digctl.h new file mode 100644 index 0000000..9a63594 --- /dev/null +++ b/arch/arm/include/asm/arch-mxs/regs-digctl.h @@ -0,0 +1,155 @@ +/* + * Freescale i.MX28 DIGCTL Register Definitions + * + * Copyright (C) 2012 Robert Delien robert@delien.nl + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __MX28_REGS_DIGCTL_H__ +#define __MX28_REGS_DIGCTL_H__ + +#include <asm/arch/regs-common.h> + +#ifndef __ASSEMBLY__ +struct mx28_digctl_regs { + mx28_reg_32(hw_digctl_ctrl) /* 0x000 */ + mx28_reg_32(hw_digctl_status) /* 0x010 */ + mx28_reg_32(hw_digctl_hclkcount) /* 0x020 */ + mx28_reg_32(hw_digctl_ramctrl) /* 0x030 */ + mx28_reg_32(hw_digctl_emi_status) /* 0x040 */ + mx28_reg_32(hw_digctl_read_margin) /* 0x050 */ + uint32_t hw_digctl_writeonce; /* 0x060 */ + uint32_t reserved_writeonce[3]; + mx28_reg_32(hw_digctl_bist_ctl) /* 0x070 */ + mx28_reg_32(hw_digctl_bist_status) /* 0x080 */ + uint32_t hw_digctl_entropy; /* 0x090 */ + uint32_t reserved_entropy[3]; + uint32_t hw_digctl_entropy_latched; /* 0x0a0 */ + uint32_t reserved_entropy_latched[3]; + + uint32_t reserved1[4]; + + mx28_reg_32(hw_digctl_microseconds) /* 0x0c0 */ + uint32_t hw_digctl_dbgrd; /* 0x0d0 */ + uint32_t reserved_hw_digctl_dbgrd[3]; + uint32_t hw_digctl_dbg; /* 0x0e0 */ + uint32_t reserved_hw_digctl_dbg[3]; + + uint32_t reserved2[4]; + + mx28_reg_32(hw_digctl_usb_loopback) /* 0x100 */ + mx28_reg_32(hw_digctl_ocram_status0) /* 0x110 */ + mx28_reg_32(hw_digctl_ocram_status1) /* 0x120 */ + mx28_reg_32(hw_digctl_ocram_status2) /* 0x130 */ + mx28_reg_32(hw_digctl_ocram_status3) /* 0x140 */ + mx28_reg_32(hw_digctl_ocram_status4) /* 0x150 */ + mx28_reg_32(hw_digctl_ocram_status5) /* 0x160 */ + mx28_reg_32(hw_digctl_ocram_status6) /* 0x170 */ + mx28_reg_32(hw_digctl_ocram_status7) /* 0x180 */ + mx28_reg_32(hw_digctl_ocram_status8) /* 0x190 */ + mx28_reg_32(hw_digctl_ocram_status9) /* 0x1a0 */ + mx28_reg_32(hw_digctl_ocram_status10) /* 0x1b0 */ + mx28_reg_32(hw_digctl_ocram_status11) /* 0x1c0 */ + mx28_reg_32(hw_digctl_ocram_status12) /* 0x1d0 */ + mx28_reg_32(hw_digctl_ocram_status13) /* 0x1e0 */ + + uint32_t reserved3[36]; + + uint32_t hw_digctl_scratch0; /* 0x280 */ + uint32_t reserved_hw_digctl_scratch0[3]; + uint32_t hw_digctl_scratch1; /* 0x290 */ + uint32_t reserved_hw_digctl_scratch1[3]; + uint32_t hw_digctl_armcache; /* 0x2a0 */ + uint32_t reserved_hw_digctl_armcache[3]; + mx28_reg_32(hw_digctl_debug_trap) /* 0x2b0 */ + uint32_t hw_digctl_debug_trap_l0_addr_low; /* 0x2c0 */ + uint32_t reserved_hw_digctl_debug_trap_l0_addr_low[3]; + uint32_t hw_digctl_debug_trap_l0_addr_high; /* 0x2d0 */ + uint32_t reserved_hw_digctl_debug_trap_l0_addr_high[3]; + uint32_t hw_digctl_debug_trap_l3_addr_low; /* 0x2e0 */ + uint32_t reserved_hw_digctl_debug_trap_l3_addr_low[3]; + uint32_t hw_digctl_debug_trap_l3_addr_high; /* 0x2f0 */ + uint32_t reserved_hw_digctl_debug_trap_l3_addr_high[3]; + uint32_t hw_digctl_fsl; /* 0x300 */ + uint32_t reserved_hw_digctl_fsl[3]; + uint32_t hw_digctl_chipid; /* 0x310 */ + uint32_t reserved_hw_digctl_chipid[3]; + + uint32_t reserved4[4]; + + uint32_t hw_digctl_ahb_stats_select; /* 0x330 */ + uint32_t reserved_hw_digctl_ahb_stats_select[3]; + + uint32_t reserved5[12]; + + uint32_t hw_digctl_l1_ahb_active_cycles; /* 0x370 */ + uint32_t reserved_hw_digctl_l1_ahb_active_cycles[3]; + uint32_t hw_digctl_l1_ahb_data_stalled; /* 0x380 */ + uint32_t reserved_hw_digctl_l1_ahb_data_stalled[3]; + uint32_t hw_digctl_l1_ahb_data_cycles; /* 0x390 */ + uint32_t reserved_hw_digctl_l1_ahb_data_cycles[3]; + uint32_t hw_digctl_l2_ahb_active_cycles; /* 0x3a0 */ + uint32_t reserved_hw_digctl_l2_ahb_active_cycles[3]; + uint32_t hw_digctl_l2_ahb_data_stalled; /* 0x3b0 */ + uint32_t reserved_hw_digctl_l2_ahb_data_stalled[3]; + uint32_t hw_digctl_l2_ahb_data_cycles; /* 0x3c0 */ + uint32_t reserved_hw_digctl_l2_ahb_data_cycles[3]; + uint32_t hw_digctl_l3_ahb_active_cycles; /* 0x3d0 */ + uint32_t reserved_hw_digctl_l3_ahb_active_cycles[3]; + uint32_t hw_digctl_l3_ahb_data_stalled; /* 0x3e0 */ + uint32_t reserved_hw_digctl_l3_ahb_data_stalled[3]; + uint32_t hw_digctl_l3_ahb_data_cycles; /* 0x3f0 */ + uint32_t reserved_hw_digctl_l3_ahb_data_cycles[3]; + + uint32_t reserved6[64]; + + uint32_t hw_digctl_mpte0_loc; /* 0x500 */ + uint32_t reserved_hw_digctl_mpte0_loc[3]; + uint32_t hw_digctl_mpte1_loc; /* 0x510 */ + uint32_t reserved_hw_digctl_mpte1_loc[3]; + uint32_t hw_digctl_mpte2_loc; /* 0x520 */ + uint32_t reserved_hw_digctl_mpte2_loc[3]; + uint32_t hw_digctl_mpte3_loc; /* 0x530 */ + uint32_t reserved_hw_digctl_mpte3_loc[3]; + uint32_t hw_digctl_mpte4_loc; /* 0x540 */ + uint32_t reserved_hw_digctl_mpte4_loc[3]; + uint32_t hw_digctl_mpte5_loc; /* 0x550 */ + uint32_t reserved_hw_digctl_mpte5_loc[3]; + uint32_t hw_digctl_mpte6_loc; /* 0x560 */ + uint32_t reserved_hw_digctl_mpte6_loc[3]; + uint32_t hw_digctl_mpte7_loc; /* 0x570 */ + uint32_t reserved_hw_digctl_mpte7_loc[3]; + uint32_t hw_digctl_mpte8_loc; /* 0x580 */ + uint32_t reserved_hw_digctl_mpte8_loc[3]; + uint32_t hw_digctl_mpte9_loc; /* 0x590 */ + uint32_t reserved_hw_digctl_mpte9_loc[3]; + uint32_t hw_digctl_mpte10_loc; /* 0x5a0 */ + uint32_t reserved_hw_digctl_mpte10_loc[3]; + uint32_t hw_digctl_mpte11_loc; /* 0x5b0 */ + uint32_t reserved_hw_digctl_mpte11_loc[3]; + uint32_t hw_digctl_mpte12_loc; /* 0x5c0 */ + uint32_t reserved_hw_digctl_mpte12_loc[3]; + uint32_t hw_digctl_mpte13_loc; /* 0x5d0 */ + uint32_t reserved_hw_digctl_mpte13_loc[3]; + uint32_t hw_digctl_mpte14_loc; /* 0x5e0 */ + uint32_t reserved_hw_digctl_mpte14_loc[3]; + uint32_t hw_digctl_mpte15_loc; /* 0x5f0 */ + uint32_t reserved_hw_digctl_mpte15_loc[3]; +}; +#endif + +#endif /* __MX28_REGS_DIGCTL_H__ */ diff --git a/arch/arm/include/asm/arch-mxs/regs-gpmi.h b/arch/arm/include/asm/arch-mxs/regs-gpmi.h new file mode 100644 index 0000000..1b487f4 --- /dev/null +++ b/arch/arm/include/asm/arch-mxs/regs-gpmi.h @@ -0,0 +1,222 @@ +/* + * Freescale i.MX28 GPMI Register Definitions + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * Based on code from LTIB: + * Copyright 2008-2010 Freescale Semiconductor, Inc. All Rights Reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __MX28_REGS_GPMI_H__ +#define __MX28_REGS_GPMI_H__ + +#include <asm/arch/regs-common.h> + +#ifndef __ASSEMBLY__ +struct mx28_gpmi_regs { + mx28_reg_32(hw_gpmi_ctrl0) + mx28_reg_32(hw_gpmi_compare) + mx28_reg_32(hw_gpmi_eccctrl) + mx28_reg_32(hw_gpmi_ecccount) + mx28_reg_32(hw_gpmi_payload) + mx28_reg_32(hw_gpmi_auxiliary) + mx28_reg_32(hw_gpmi_ctrl1) + mx28_reg_32(hw_gpmi_timing0) + mx28_reg_32(hw_gpmi_timing1) + + uint32_t reserved[4]; + + mx28_reg_32(hw_gpmi_data) + mx28_reg_32(hw_gpmi_stat) + mx28_reg_32(hw_gpmi_debug) + mx28_reg_32(hw_gpmi_version) +}; +#endif + +#define GPMI_CTRL0_SFTRST (1 << 31) +#define GPMI_CTRL0_CLKGATE (1 << 30) +#define GPMI_CTRL0_RUN (1 << 29) +#define GPMI_CTRL0_DEV_IRQ_EN (1 << 28) +#define GPMI_CTRL0_LOCK_CS (1 << 27) +#define GPMI_CTRL0_UDMA (1 << 26) +#define GPMI_CTRL0_COMMAND_MODE_MASK (0x3 << 24) +#define GPMI_CTRL0_COMMAND_MODE_OFFSET 24 +#define GPMI_CTRL0_COMMAND_MODE_WRITE (0x0 << 24) +#define GPMI_CTRL0_COMMAND_MODE_READ (0x1 << 24) +#define GPMI_CTRL0_COMMAND_MODE_READ_AND_COMPARE (0x2 << 24) +#define GPMI_CTRL0_COMMAND_MODE_WAIT_FOR_READY (0x3 << 24) +#define GPMI_CTRL0_WORD_LENGTH (1 << 23) +#define GPMI_CTRL0_CS_MASK (0x7 << 20) +#define GPMI_CTRL0_CS_OFFSET 20 +#define GPMI_CTRL0_ADDRESS_MASK (0x7 << 17) +#define GPMI_CTRL0_ADDRESS_OFFSET 17 +#define GPMI_CTRL0_ADDRESS_NAND_DATA (0x0 << 17) +#define GPMI_CTRL0_ADDRESS_NAND_CLE (0x1 << 17) +#define GPMI_CTRL0_ADDRESS_NAND_ALE (0x2 << 17) +#define GPMI_CTRL0_ADDRESS_INCREMENT (1 << 16) +#define GPMI_CTRL0_XFER_COUNT_MASK 0xffff +#define GPMI_CTRL0_XFER_COUNT_OFFSET 0 + +#define GPMI_COMPARE_MASK_MASK (0xffff << 16) +#define GPMI_COMPARE_MASK_OFFSET 16 +#define GPMI_COMPARE_REFERENCE_MASK 0xffff +#define GPMI_COMPARE_REFERENCE_OFFSET 0 + +#define GPMI_ECCCTRL_HANDLE_MASK (0xffff << 16) +#define GPMI_ECCCTRL_HANDLE_OFFSET 16 +#define GPMI_ECCCTRL_ECC_CMD_MASK (0x3 << 13) +#define GPMI_ECCCTRL_ECC_CMD_OFFSET 13 +#define GPMI_ECCCTRL_ECC_CMD_DECODE (0x0 << 13) +#define GPMI_ECCCTRL_ECC_CMD_ENCODE (0x1 << 13) +#define GPMI_ECCCTRL_ENABLE_ECC (1 << 12) +#define GPMI_ECCCTRL_BUFFER_MASK_MASK 0x1ff +#define GPMI_ECCCTRL_BUFFER_MASK_OFFSET 0 +#define GPMI_ECCCTRL_BUFFER_MASK_BCH_AUXONLY 0x100 +#define GPMI_ECCCTRL_BUFFER_MASK_BCH_PAGE 0x1ff + +#define GPMI_ECCCOUNT_COUNT_MASK 0xffff +#define GPMI_ECCCOUNT_COUNT_OFFSET 0 + +#define GPMI_PAYLOAD_ADDRESS_MASK (0x3fffffff << 2) +#define GPMI_PAYLOAD_ADDRESS_OFFSET 2 + +#define GPMI_AUXILIARY_ADDRESS_MASK (0x3fffffff << 2) +#define GPMI_AUXILIARY_ADDRESS_OFFSET 2 + +#define GPMI_CTRL1_DECOUPLE_CS (1 << 24) +#define GPMI_CTRL1_WRN_DLY_SEL_MASK (0x3 << 22) +#define GPMI_CTRL1_WRN_DLY_SEL_OFFSET 22 +#define GPMI_CTRL1_TIMEOUT_IRQ_EN (1 << 20) +#define GPMI_CTRL1_GANGED_RDYBUSY (1 << 19) +#define GPMI_CTRL1_BCH_MODE (1 << 18) +#define GPMI_CTRL1_DLL_ENABLE (1 << 17) +#define GPMI_CTRL1_HALF_PERIOD (1 << 16) +#define GPMI_CTRL1_RDN_DELAY_MASK (0xf << 12) +#define GPMI_CTRL1_RDN_DELAY_OFFSET 12 +#define GPMI_CTRL1_DMA2ECC_MODE (1 << 11) +#define GPMI_CTRL1_DEV_IRQ (1 << 10) +#define GPMI_CTRL1_TIMEOUT_IRQ (1 << 9) +#define GPMI_CTRL1_BURST_EN (1 << 8) +#define GPMI_CTRL1_ABORT_WAIT_REQUEST (1 << 7) +#define GPMI_CTRL1_ABORT_WAIT_FOR_READY_CHANNEL_MASK (0x7 << 4) +#define GPMI_CTRL1_ABORT_WAIT_FOR_READY_CHANNEL_OFFSET 4 +#define GPMI_CTRL1_DEV_RESET (1 << 3) +#define GPMI_CTRL1_ATA_IRQRDY_POLARITY (1 << 2) +#define GPMI_CTRL1_CAMERA_MODE (1 << 1) +#define GPMI_CTRL1_GPMI_MODE (1 << 0) + +#define GPMI_TIMING0_ADDRESS_SETUP_MASK (0xff << 16) +#define GPMI_TIMING0_ADDRESS_SETUP_OFFSET 16 +#define GPMI_TIMING0_DATA_HOLD_MASK (0xff << 8) +#define GPMI_TIMING0_DATA_HOLD_OFFSET 8 +#define GPMI_TIMING0_DATA_SETUP_MASK 0xff +#define GPMI_TIMING0_DATA_SETUP_OFFSET 0 + +#define GPMI_TIMING1_DEVICE_BUSY_TIMEOUT_MASK (0xffff << 16) +#define GPMI_TIMING1_DEVICE_BUSY_TIMEOUT_OFFSET 16 + +#define GPMI_TIMING2_UDMA_TRP_MASK (0xff << 24) +#define GPMI_TIMING2_UDMA_TRP_OFFSET 24 +#define GPMI_TIMING2_UDMA_ENV_MASK (0xff << 16) +#define GPMI_TIMING2_UDMA_ENV_OFFSET 16 +#define GPMI_TIMING2_UDMA_HOLD_MASK (0xff << 8) +#define GPMI_TIMING2_UDMA_HOLD_OFFSET 8 +#define GPMI_TIMING2_UDMA_SETUP_MASK 0xff +#define GPMI_TIMING2_UDMA_SETUP_OFFSET 0 + +#define GPMI_DATA_DATA_MASK 0xffffffff +#define GPMI_DATA_DATA_OFFSET 0 + +#define GPMI_STAT_READY_BUSY_MASK (0xff << 24) +#define GPMI_STAT_READY_BUSY_OFFSET 24 +#define GPMI_STAT_RDY_TIMEOUT_MASK (0xff << 16) +#define GPMI_STAT_RDY_TIMEOUT_OFFSET 16 +#define GPMI_STAT_DEV7_ERROR (1 << 15) +#define GPMI_STAT_DEV6_ERROR (1 << 14) +#define GPMI_STAT_DEV5_ERROR (1 << 13) +#define GPMI_STAT_DEV4_ERROR (1 << 12) +#define GPMI_STAT_DEV3_ERROR (1 << 11) +#define GPMI_STAT_DEV2_ERROR (1 << 10) +#define GPMI_STAT_DEV1_ERROR (1 << 9) +#define GPMI_STAT_DEV0_ERROR (1 << 8) +#define GPMI_STAT_ATA_IRQ (1 << 4) +#define GPMI_STAT_INVALID_BUFFER_MASK (1 << 3) +#define GPMI_STAT_FIFO_EMPTY (1 << 2) +#define GPMI_STAT_FIFO_FULL (1 << 1) +#define GPMI_STAT_PRESENT (1 << 0) + +#define GPMI_DEBUG_WAIT_FOR_READY_END_MASK (0xff << 24) +#define GPMI_DEBUG_WAIT_FOR_READY_END_OFFSET 24 +#define GPMI_DEBUG_DMA_SENSE_MASK (0xff << 16) +#define GPMI_DEBUG_DMA_SENSE_OFFSET 16 +#define GPMI_DEBUG_DMAREQ_MASK (0xff << 8) +#define GPMI_DEBUG_DMAREQ_OFFSET 8 +#define GPMI_DEBUG_CMD_END_MASK 0xff +#define GPMI_DEBUG_CMD_END_OFFSET 0 + +#define GPMI_VERSION_MAJOR_MASK (0xff << 24) +#define GPMI_VERSION_MAJOR_OFFSET 24 +#define GPMI_VERSION_MINOR_MASK (0xff << 16) +#define GPMI_VERSION_MINOR_OFFSET 16 +#define GPMI_VERSION_STEP_MASK 0xffff +#define GPMI_VERSION_STEP_OFFSET 0 + +#define GPMI_DEBUG2_UDMA_STATE_MASK (0xf << 24) +#define GPMI_DEBUG2_UDMA_STATE_OFFSET 24 +#define GPMI_DEBUG2_BUSY (1 << 23) +#define GPMI_DEBUG2_PIN_STATE_MASK (0x7 << 20) +#define GPMI_DEBUG2_PIN_STATE_OFFSET 20 +#define GPMI_DEBUG2_PIN_STATE_PSM_IDLE (0x0 << 20) +#define GPMI_DEBUG2_PIN_STATE_PSM_BYTCNT (0x1 << 20) +#define GPMI_DEBUG2_PIN_STATE_PSM_ADDR (0x2 << 20) +#define GPMI_DEBUG2_PIN_STATE_PSM_STALL (0x3 << 20) +#define GPMI_DEBUG2_PIN_STATE_PSM_STROBE (0x4 << 20) +#define GPMI_DEBUG2_PIN_STATE_PSM_ATARDY (0x5 << 20) +#define GPMI_DEBUG2_PIN_STATE_PSM_DHOLD (0x6 << 20) +#define GPMI_DEBUG2_PIN_STATE_PSM_DONE (0x7 << 20) +#define GPMI_DEBUG2_MAIN_STATE_MASK (0xf << 16) +#define GPMI_DEBUG2_MAIN_STATE_OFFSET 16 +#define GPMI_DEBUG2_MAIN_STATE_MSM_IDLE (0x0 << 16) +#define GPMI_DEBUG2_MAIN_STATE_MSM_BYTCNT (0x1 << 16) +#define GPMI_DEBUG2_MAIN_STATE_MSM_WAITFE (0x2 << 16) +#define GPMI_DEBUG2_MAIN_STATE_MSM_WAITFR (0x3 << 16) +#define GPMI_DEBUG2_MAIN_STATE_MSM_DMAREQ (0x4 << 16) +#define GPMI_DEBUG2_MAIN_STATE_MSM_DMAACK (0x5 << 16) +#define GPMI_DEBUG2_MAIN_STATE_MSM_WAITFF (0x6 << 16) +#define GPMI_DEBUG2_MAIN_STATE_MSM_LDFIFO (0x7 << 16) +#define GPMI_DEBUG2_MAIN_STATE_MSM_LDDMAR (0x8 << 16) +#define GPMI_DEBUG2_MAIN_STATE_MSM_RDCMP (0x9 << 16) +#define GPMI_DEBUG2_MAIN_STATE_MSM_DONE (0xa << 16) +#define GPMI_DEBUG2_SYND2GPMI_BE_MASK (0xf << 12) +#define GPMI_DEBUG2_SYND2GPMI_BE_OFFSET 12 +#define GPMI_DEBUG2_GPMI2SYND_VALID (1 << 11) +#define GPMI_DEBUG2_GPMI2SYND_READY (1 << 10) +#define GPMI_DEBUG2_SYND2GPMI_VALID (1 << 9) +#define GPMI_DEBUG2_SYND2GPMI_READY (1 << 8) +#define GPMI_DEBUG2_VIEW_DELAYED_RDN (1 << 7) +#define GPMI_DEBUG2_UPDATE_WINDOW (1 << 6) +#define GPMI_DEBUG2_RDN_TAP_MASK 0x3f +#define GPMI_DEBUG2_RDN_TAP_OFFSET 0 + +#define GPMI_DEBUG3_APB_WORD_CNTR_MASK (0xffff << 16) +#define GPMI_DEBUG3_APB_WORD_CNTR_OFFSET 16 +#define GPMI_DEBUG3_DEV_WORD_CNTR_MASK 0xffff +#define GPMI_DEBUG3_DEV_WORD_CNTR_OFFSET 0 + +#endif /* __MX28_REGS_GPMI_H__ */ diff --git a/arch/arm/include/asm/arch-mxs/regs-i2c.h b/arch/arm/include/asm/arch-mxs/regs-i2c.h new file mode 100644 index 0000000..2e2e814 --- /dev/null +++ b/arch/arm/include/asm/arch-mxs/regs-i2c.h @@ -0,0 +1,207 @@ +/* + * Freescale i.MX28 I2C Register Definitions + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __MX28_REGS_I2C_H__ +#define __MX28_REGS_I2C_H__ + +#include <asm/arch/regs-common.h> + +#ifndef __ASSEMBLY__ +struct mx28_i2c_regs { + mx28_reg_32(hw_i2c_ctrl0) + mx28_reg_32(hw_i2c_timing0) + mx28_reg_32(hw_i2c_timing1) + mx28_reg_32(hw_i2c_timing2) + mx28_reg_32(hw_i2c_ctrl1) + mx28_reg_32(hw_i2c_stat) + mx28_reg_32(hw_i2c_queuectrl) + mx28_reg_32(hw_i2c_queuestat) + mx28_reg_32(hw_i2c_queuecmd) + mx28_reg_32(hw_i2c_queuedata) + mx28_reg_32(hw_i2c_data) + mx28_reg_32(hw_i2c_debug0) + mx28_reg_32(hw_i2c_debug1) + mx28_reg_32(hw_i2c_version) +}; +#endif + +#define I2C_CTRL_SFTRST (1 << 31) +#define I2C_CTRL_CLKGATE (1 << 30) +#define I2C_CTRL_RUN (1 << 29) +#define I2C_CTRL_PREACK (1 << 27) +#define I2C_CTRL_ACKNOWLEDGE (1 << 26) +#define I2C_CTRL_SEND_NAK_ON_LAST (1 << 25) +#define I2C_CTRL_MULTI_MASTER (1 << 23) +#define I2C_CTRL_CLOCK_HELD (1 << 22) +#define I2C_CTRL_RETAIN_CLOCK (1 << 21) +#define I2C_CTRL_POST_SEND_STOP (1 << 20) +#define I2C_CTRL_PRE_SEND_START (1 << 19) +#define I2C_CTRL_SLAVE_ADDRESS_ENABLE (1 << 18) +#define I2C_CTRL_MASTER_MODE (1 << 17) +#define I2C_CTRL_DIRECTION (1 << 16) +#define I2C_CTRL_XFER_COUNT_MASK 0xffff +#define I2C_CTRL_XFER_COUNT_OFFSET 0 + +#define I2C_TIMING0_HIGH_COUNT_MASK (0x3ff << 16) +#define I2C_TIMING0_HIGH_COUNT_OFFSET 16 +#define I2C_TIMING0_RCV_COUNT_MASK 0x3ff +#define I2C_TIMING0_RCV_COUNT_OFFSET 0 + +#define I2C_TIMING1_LOW_COUNT_MASK (0x3ff << 16) +#define I2C_TIMING1_LOW_COUNT_OFFSET 16 +#define I2C_TIMING1_XMIT_COUNT_MASK 0x3ff +#define I2C_TIMING1_XMIT_COUNT_OFFSET 0 + +#define I2C_TIMING2_BUS_FREE_MASK (0x3ff << 16) +#define I2C_TIMING2_BUS_FREE_OFFSET 16 +#define I2C_TIMING2_LEADIN_COUNT_MASK 0x3ff +#define I2C_TIMING2_LEADIN_COUNT_OFFSET 0 + +#define I2C_CTRL1_RD_QUEUE_IRQ (1 << 30) +#define I2C_CTRL1_WR_QUEUE_IRQ (1 << 29) +#define I2C_CTRL1_CLR_GOT_A_NAK (1 << 28) +#define I2C_CTRL1_ACK_MODE (1 << 27) +#define I2C_CTRL1_FORCE_DATA_IDLE (1 << 26) +#define I2C_CTRL1_FORCE_CLK_IDLE (1 << 25) +#define I2C_CTRL1_BCAST_SLAVE_EN (1 << 24) +#define I2C_CTRL1_SLAVE_ADDRESS_BYTE_MASK (0xff << 16) +#define I2C_CTRL1_SLAVE_ADDRESS_BYTE_OFFSET 16 +#define I2C_CTRL1_BUS_FREE_IRQ_EN (1 << 15) +#define I2C_CTRL1_DATA_ENGINE_CMPLT_IRQ_EN (1 << 14) +#define I2C_CTRL1_NO_SLAVE_ACK_IRQ_EN (1 << 13) +#define I2C_CTRL1_OVERSIZE_XFER_TERM_IRQ_EN (1 << 12) +#define I2C_CTRL1_EARLY_TERM_IRQ_EN (1 << 11) +#define I2C_CTRL1_MASTER_LOSS_IRQ_EN (1 << 10) +#define I2C_CTRL1_SLAVE_STOP_IRQ_EN (1 << 9) +#define I2C_CTRL1_SLAVE_IRQ_EN (1 << 8) +#define I2C_CTRL1_BUS_FREE_IRQ (1 << 7) +#define I2C_CTRL1_DATA_ENGINE_CMPLT_IRQ (1 << 6) +#define I2C_CTRL1_NO_SLAVE_ACK_IRQ (1 << 5) +#define I2C_CTRL1_OVERSIZE_XFER_TERM_IRQ (1 << 4) +#define I2C_CTRL1_EARLY_TERM_IRQ (1 << 3) +#define I2C_CTRL1_MASTER_LOSS_IRQ (1 << 2) +#define I2C_CTRL1_SLAVE_STOP_IRQ (1 << 1) +#define I2C_CTRL1_SLAVE_IRQ (1 << 0) + +#define I2C_STAT_MASTER_PRESENT (1 << 31) +#define I2C_STAT_SLAVE_PRESENT (1 << 30) +#define I2C_STAT_ANY_ENABLED_IRQ (1 << 29) +#define I2C_STAT_GOT_A_NAK (1 << 28) +#define I2C_STAT_RCVD_SLAVE_ADDR_MASK (0xff << 16) +#define I2C_STAT_RCVD_SLAVE_ADDR_OFFSET 16 +#define I2C_STAT_SLAVE_ADDR_EQ_ZERO (1 << 15) +#define I2C_STAT_SLAVE_FOUND (1 << 14) +#define I2C_STAT_SLAVE_SEARCHING (1 << 13) +#define I2C_STAT_DATA_ENGING_DMA_WAIT (1 << 12) +#define I2C_STAT_BUS_BUSY (1 << 11) +#define I2C_STAT_CLK_GEN_BUSY (1 << 10) +#define I2C_STAT_DATA_ENGINE_BUSY (1 << 9) +#define I2C_STAT_SLAVE_BUSY (1 << 8) +#define I2C_STAT_BUS_FREE_IRQ_SUMMARY (1 << 7) +#define I2C_STAT_DATA_ENGINE_CMPLT_IRQ_SUMMARY (1 << 6) +#define I2C_STAT_NO_SLAVE_ACK_IRQ_SUMMARY (1 << 5) +#define I2C_STAT_OVERSIZE_XFER_TERM_IRQ_SUMMARY (1 << 4) +#define I2C_STAT_EARLY_TERM_IRQ_SUMMARY (1 << 3) +#define I2C_STAT_MASTER_LOSS_IRQ_SUMMARY (1 << 2) +#define I2C_STAT_SLAVE_STOP_IRQ_SUMMARY (1 << 1) +#define I2C_STAT_SLAVE_IRQ_SUMMARY (1 << 0) + +#define I2C_QUEUECTRL_RD_THRESH_MASK (0x1f << 16) +#define I2C_QUEUECTRL_RD_THRESH_OFFSET 16 +#define I2C_QUEUECTRL_WR_THRESH_MASK (0x1f << 8) +#define I2C_QUEUECTRL_WR_THRESH_OFFSET 8 +#define I2C_QUEUECTRL_QUEUE_RUN (1 << 5) +#define I2C_QUEUECTRL_RD_CLEAR (1 << 4) +#define I2C_QUEUECTRL_WR_CLEAR (1 << 3) +#define I2C_QUEUECTRL_PIO_QUEUE_MODE (1 << 2) +#define I2C_QUEUECTRL_RD_QUEUE_IRQ_EN (1 << 1) +#define I2C_QUEUECTRL_WR_QUEUE_IRQ_EN (1 << 0) + +#define I2C_QUEUESTAT_RD_QUEUE_FULL (1 << 14) +#define I2C_QUEUESTAT_RD_QUEUE_EMPTY (1 << 13) +#define I2C_QUEUESTAT_RD_QUEUE_CNT_MASK (0x1f << 8) +#define I2C_QUEUESTAT_RD_QUEUE_CNT_OFFSET 8 +#define I2C_QUEUESTAT_WR_QUEUE_FULL (1 << 6) +#define I2C_QUEUESTAT_WR_QUEUE_EMPTY (1 << 5) +#define I2C_QUEUESTAT_WR_QUEUE_CNT_MASK 0x1f +#define I2C_QUEUESTAT_WR_QUEUE_CNT_OFFSET 0 + +#define I2C_QUEUECMD_PREACK (1 << 27) +#define I2C_QUEUECMD_ACKNOWLEDGE (1 << 26) +#define I2C_QUEUECMD_SEND_NAK_ON_LAST (1 << 25) +#define I2C_QUEUECMD_MULTI_MASTER (1 << 23) +#define I2C_QUEUECMD_CLOCK_HELD (1 << 22) +#define I2C_QUEUECMD_RETAIN_CLOCK (1 << 21) +#define I2C_QUEUECMD_POST_SEND_STOP (1 << 20) +#define I2C_QUEUECMD_PRE_SEND_START (1 << 19) +#define I2C_QUEUECMD_SLAVE_ADDRESS_ENABLE (1 << 18) +#define I2C_QUEUECMD_MASTER_MODE (1 << 17) +#define I2C_QUEUECMD_DIRECTION (1 << 16) +#define I2C_QUEUECMD_XFER_COUNT_MASK 0xffff +#define I2C_QUEUECMD_XFER_COUNT_OFFSET 0 + +#define I2C_QUEUEDATA_DATA_MASK 0xffffffff +#define I2C_QUEUEDATA_DATA_OFFSET 0 + +#define I2C_DATA_DATA_MASK 0xffffffff +#define I2C_DATA_DATA_OFFSET 0 + +#define I2C_DEBUG0_DMAREQ (1 << 31) +#define I2C_DEBUG0_DMAENDCMD (1 << 30) +#define I2C_DEBUG0_DMAKICK (1 << 29) +#define I2C_DEBUG0_DMATERMINATE (1 << 28) +#define I2C_DEBUG0_STATE_VALUE_MASK (0x3 << 26) +#define I2C_DEBUG0_STATE_VALUE_OFFSET 26 +#define I2C_DEBUG0_DMA_STATE_MASK (0x3ff << 16) +#define I2C_DEBUG0_DMA_STATE_OFFSET 16 +#define I2C_DEBUG0_START_TOGGLE (1 << 15) +#define I2C_DEBUG0_STOP_TOGGLE (1 << 14) +#define I2C_DEBUG0_GRAB_TOGGLE (1 << 13) +#define I2C_DEBUG0_CHANGE_TOGGLE (1 << 12) +#define I2C_DEBUG0_STATE_LATCH (1 << 11) +#define I2C_DEBUG0_SLAVE_HOLD_CLK (1 << 10) +#define I2C_DEBUG0_STATE_STATE_MASK 0x3ff +#define I2C_DEBUG0_STATE_STATE_OFFSET 0 + +#define I2C_DEBUG1_I2C_CLK_IN (1 << 31) +#define I2C_DEBUG1_I2C_DATA_IN (1 << 30) +#define I2C_DEBUG1_DMA_BYTE_ENABLES_MASK (0xf << 24) +#define I2C_DEBUG1_DMA_BYTE_ENABLES_OFFSET 24 +#define I2C_DEBUG1_CLK_GEN_STATE_MASK (0xff << 16) +#define I2C_DEBUG1_CLK_GEN_STATE_OFFSET 16 +#define I2C_DEBUG1_LST_MODE_MASK (0x3 << 9) +#define I2C_DEBUG1_LST_MODE_OFFSET 9 +#define I2C_DEBUG1_LOCAL_SLAVE_TEST (1 << 8) +#define I2C_DEBUG1_FORCE_CLK_ON (1 << 4) +#define I2C_DEBUG1_FORCE_ABR_LOSS (1 << 3) +#define I2C_DEBUG1_FORCE_RCV_ACK (1 << 2) +#define I2C_DEBUG1_FORCE_I2C_DATA_OE (1 << 1) +#define I2C_DEBUG1_FORCE_I2C_CLK_OE (1 << 0) + +#define I2C_VERSION_MAJOR_MASK (0xff << 24) +#define I2C_VERSION_MAJOR_OFFSET 24 +#define I2C_VERSION_MINOR_MASK (0xff << 16) +#define I2C_VERSION_MINOR_OFFSET 16 +#define I2C_VERSION_STEP_MASK 0xffff +#define I2C_VERSION_STEP_OFFSET 0 + +#endif /* __MX28_REGS_I2C_H__ */ diff --git a/arch/arm/include/asm/arch-mxs/regs-ocotp.h b/arch/arm/include/asm/arch-mxs/regs-ocotp.h new file mode 100644 index 0000000..2738035 --- /dev/null +++ b/arch/arm/include/asm/arch-mxs/regs-ocotp.h @@ -0,0 +1,173 @@ +/* + * Freescale i.MX28 OCOTP Register Definitions + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * Based on code from LTIB: + * Copyright 2008-2010 Freescale Semiconductor, Inc. All Rights Reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __MX28_REGS_OCOTP_H__ +#define __MX28_REGS_OCOTP_H__ + +#include <asm/arch/regs-common.h> + +#ifndef __ASSEMBLY__ +struct mx28_ocotp_regs { + mx28_reg_32(hw_ocotp_ctrl) /* 0x0 */ + mx28_reg_32(hw_ocotp_data) /* 0x10 */ + mx28_reg_32(hw_ocotp_cust0) /* 0x20 */ + mx28_reg_32(hw_ocotp_cust1) /* 0x30 */ + mx28_reg_32(hw_ocotp_cust2) /* 0x40 */ + mx28_reg_32(hw_ocotp_cust3) /* 0x50 */ + mx28_reg_32(hw_ocotp_crypto0) /* 0x60 */ + mx28_reg_32(hw_ocotp_crypto1) /* 0x70 */ + mx28_reg_32(hw_ocotp_crypto2) /* 0x80 */ + mx28_reg_32(hw_ocotp_crypto3) /* 0x90 */ + mx28_reg_32(hw_ocotp_hwcap0) /* 0xa0 */ + mx28_reg_32(hw_ocotp_hwcap1) /* 0xb0 */ + mx28_reg_32(hw_ocotp_hwcap2) /* 0xc0 */ + mx28_reg_32(hw_ocotp_hwcap3) /* 0xd0 */ + mx28_reg_32(hw_ocotp_hwcap4) /* 0xe0 */ + mx28_reg_32(hw_ocotp_hwcap5) /* 0xf0 */ + mx28_reg_32(hw_ocotp_swcap) /* 0x100 */ + mx28_reg_32(hw_ocotp_custcap) /* 0x110 */ + mx28_reg_32(hw_ocotp_lock) /* 0x120 */ + mx28_reg_32(hw_ocotp_ops0) /* 0x130 */ + mx28_reg_32(hw_ocotp_ops1) /* 0x140 */ + mx28_reg_32(hw_ocotp_ops2) /* 0x150 */ + mx28_reg_32(hw_ocotp_ops3) /* 0x160 */ + mx28_reg_32(hw_ocotp_un0) /* 0x170 */ + mx28_reg_32(hw_ocotp_un1) /* 0x180 */ + mx28_reg_32(hw_ocotp_un2) /* 0x190 */ + mx28_reg_32(hw_ocotp_rom0) /* 0x1a0 */ + mx28_reg_32(hw_ocotp_rom1) /* 0x1b0 */ + mx28_reg_32(hw_ocotp_rom2) /* 0x1c0 */ + mx28_reg_32(hw_ocotp_rom3) /* 0x1d0 */ + mx28_reg_32(hw_ocotp_rom4) /* 0x1e0 */ + mx28_reg_32(hw_ocotp_rom5) /* 0x1f0 */ + mx28_reg_32(hw_ocotp_rom6) /* 0x200 */ + mx28_reg_32(hw_ocotp_rom7) /* 0x210 */ + mx28_reg_32(hw_ocotp_srk0) /* 0x220 */ + mx28_reg_32(hw_ocotp_srk1) /* 0x230 */ + mx28_reg_32(hw_ocotp_srk2) /* 0x240 */ + mx28_reg_32(hw_ocotp_srk3) /* 0x250 */ + mx28_reg_32(hw_ocotp_srk4) /* 0x260 */ + mx28_reg_32(hw_ocotp_srk5) /* 0x270 */ + mx28_reg_32(hw_ocotp_srk6) /* 0x280 */ + mx28_reg_32(hw_ocotp_srk7) /* 0x290 */ + mx28_reg_32(hw_ocotp_version) /* 0x2a0 */ +}; +#endif + +#define OCOTP_CTRL_WR_UNLOCK_MASK (0xffff << 16) +#define OCOTP_CTRL_WR_UNLOCK_OFFSET 16 +#define OCOTP_CTRL_WR_UNLOCK_KEY (0x3e77 << 16) +#define OCOTP_CTRL_RELOAD_SHADOWS (1 << 13) +#define OCOTP_CTRL_RD_BANK_OPEN (1 << 12) +#define OCOTP_CTRL_ERROR (1 << 9) +#define OCOTP_CTRL_BUSY (1 << 8) +#define OCOTP_CTRL_ADDR_MASK 0x3f +#define OCOTP_CTRL_ADDR_OFFSET 0 + +#define OCOTP_DATA_DATA_MASK 0xffffffff +#define OCOTP_DATA_DATA_OFFSET 0 + +#define OCOTP_CUST_BITS_MASK 0xffffffff +#define OCOTP_CUST_BITS_OFFSET 0 + +#define OCOTP_CRYPTO_BITS_MASK 0xffffffff +#define OCOTP_CRYPTO_BITS_OFFSET 0 + +#define OCOTP_HWCAP_BITS_MASK 0xffffffff +#define OCOTP_HWCAP_BITS_OFFSET 0 + +#define OCOTP_SWCAP_BITS_MASK 0xffffffff +#define OCOTP_SWCAP_BITS_OFFSET 0 + +#define OCOTP_CUSTCAP_RTC_XTAL_32768_PRESENT (1 << 2) +#define OCOTP_CUSTCAP_RTC_XTAL_32000_PRESENT (1 << 1) + +#define OCOTP_LOCK_ROM7 (1 << 31) +#define OCOTP_LOCK_ROM6 (1 << 30) +#define OCOTP_LOCK_ROM5 (1 << 29) +#define OCOTP_LOCK_ROM4 (1 << 28) +#define OCOTP_LOCK_ROM3 (1 << 27) +#define OCOTP_LOCK_ROM2 (1 << 26) +#define OCOTP_LOCK_ROM1 (1 << 25) +#define OCOTP_LOCK_ROM0 (1 << 24) +#define OCOTP_LOCK_HWSW_SHADOW_ALT (1 << 23) +#define OCOTP_LOCK_CRYPTODCP_ALT (1 << 22) +#define OCOTP_LOCK_CRYPTOKEY_ALT (1 << 21) +#define OCOTP_LOCK_PIN (1 << 20) +#define OCOTP_LOCK_OPS (1 << 19) +#define OCOTP_LOCK_UN2 (1 << 18) +#define OCOTP_LOCK_UN1 (1 << 17) +#define OCOTP_LOCK_UN0 (1 << 16) +#define OCOTP_LOCK_SRK (1 << 15) +#define OCOTP_LOCK_UNALLOCATED_MASK (0x7 << 12) +#define OCOTP_LOCK_UNALLOCATED_OFFSET 12 +#define OCOTP_LOCK_SRK_SHADOW (1 << 11) +#define OCOTP_LOCK_ROM_SHADOW (1 << 10) +#define OCOTP_LOCK_CUSTCAP (1 << 9) +#define OCOTP_LOCK_HWSW (1 << 8) +#define OCOTP_LOCK_CUSTCAP_SHADOW (1 << 7) +#define OCOTP_LOCK_HWSW_SHADOW (1 << 6) +#define OCOTP_LOCK_CRYPTODCP (1 << 5) +#define OCOTP_LOCK_CRYPTOKEY (1 << 4) +#define OCOTP_LOCK_CUST3 (1 << 3) +#define OCOTP_LOCK_CUST2 (1 << 2) +#define OCOTP_LOCK_CUST1 (1 << 1) +#define OCOTP_LOCK_CUST0 (1 << 0) + +#define OCOTP_OPS_BITS_MASK 0xffffffff +#define OCOTP_OPS_BITS_OFFSET 0 + +#define OCOTP_UN_BITS_MASK 0xffffffff +#define OCOTP_UN_BITS_OFFSET 0 + +#define OCOTP_ROM_BOOT_MODE_MASK (0xff << 24) +#define OCOTP_ROM_BOOT_MODE_OFFSET 24 +#define OCOTP_ROM_SD_MMC_MODE_MASK (0x3 << 22) +#define OCOTP_ROM_SD_MMC_MODE_OFFSET 22 +#define OCOTP_ROM_SD_POWER_GATE_GPIO_MASK (0x3 << 20) +#define OCOTP_ROM_SD_POWER_GATE_GPIO_OFFSET 20 +#define OCOTP_ROM_SD_POWER_UP_DELAY_MASK (0x3f << 14) +#define OCOTP_ROM_SD_POWER_UP_DELAY_OFFSET 14 +#define OCOTP_ROM_SD_BUS_WIDTH_MASK (0x3 << 12) +#define OCOTP_ROM_SD_BUS_WIDTH_OFFSET 12 +#define OCOTP_ROM_SSP_SCK_INDEX_MASK (0xf << 8) +#define OCOTP_ROM_SSP_SCK_INDEX_OFFSET 8 +#define OCOTP_ROM_EMMC_USE_DDR (1 << 7) +#define OCOTP_ROM_DISABLE_SPI_NOR_FAST_READ (1 << 6) +#define OCOTP_ROM_ENABLE_USB_BOOT_SERIAL_NUM (1 << 5) +#define OCOTP_ROM_ENABLE_UNENCRYPTED_BOOT (1 << 4) +#define OCOTP_ROM_SD_MBR_BOOT (1 << 3) + +#define OCOTP_SRK_BITS_MASK 0xffffffff +#define OCOTP_SRK_BITS_OFFSET 0 + +#define OCOTP_VERSION_MAJOR_MASK (0xff << 24) +#define OCOTP_VERSION_MAJOR_OFFSET 24 +#define OCOTP_VERSION_MINOR_MASK (0xff << 16) +#define OCOTP_VERSION_MINOR_OFFSET 16 +#define OCOTP_VERSION_STEP_MASK 0xffff +#define OCOTP_VERSION_STEP_OFFSET 0 + +#endif /* __MX28_REGS_OCOTP_H__ */ diff --git a/arch/arm/include/asm/arch-mxs/regs-pinctrl.h b/arch/arm/include/asm/arch-mxs/regs-pinctrl.h new file mode 100644 index 0000000..80dcdf6 --- /dev/null +++ b/arch/arm/include/asm/arch-mxs/regs-pinctrl.h @@ -0,0 +1,1284 @@ +/* + * Freescale i.MX28 PINCTRL Register Definitions + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * Based on code from LTIB: + * Copyright 2008-2010 Freescale Semiconductor, Inc. All Rights Reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __MX28_REGS_PINCTRL_H__ +#define __MX28_REGS_PINCTRL_H__ + +#include <asm/arch/regs-common.h> + +#ifndef __ASSEMBLY__ +struct mx28_pinctrl_regs { + mx28_reg_32(hw_pinctrl_ctrl) /* 0x0 */ + + uint32_t reserved1[60]; + + mx28_reg_32(hw_pinctrl_muxsel0) /* 0x100 */ + mx28_reg_32(hw_pinctrl_muxsel1) /* 0x110 */ + mx28_reg_32(hw_pinctrl_muxsel2) /* 0x120 */ + mx28_reg_32(hw_pinctrl_muxsel3) /* 0x130 */ + mx28_reg_32(hw_pinctrl_muxsel4) /* 0x140 */ + mx28_reg_32(hw_pinctrl_muxsel5) /* 0x150 */ + mx28_reg_32(hw_pinctrl_muxsel6) /* 0x160 */ + mx28_reg_32(hw_pinctrl_muxsel7) /* 0x170 */ + mx28_reg_32(hw_pinctrl_muxsel8) /* 0x180 */ + mx28_reg_32(hw_pinctrl_muxsel9) /* 0x190 */ + mx28_reg_32(hw_pinctrl_muxsel10) /* 0x1a0 */ + mx28_reg_32(hw_pinctrl_muxsel11) /* 0x1b0 */ + mx28_reg_32(hw_pinctrl_muxsel12) /* 0x1c0 */ + mx28_reg_32(hw_pinctrl_muxsel13) /* 0x1d0 */ + + uint32_t reserved2[72]; + + mx28_reg_32(hw_pinctrl_drive0) /* 0x300 */ + mx28_reg_32(hw_pinctrl_drive1) /* 0x310 */ + mx28_reg_32(hw_pinctrl_drive2) /* 0x320 */ + mx28_reg_32(hw_pinctrl_drive3) /* 0x330 */ + mx28_reg_32(hw_pinctrl_drive4) /* 0x340 */ + mx28_reg_32(hw_pinctrl_drive5) /* 0x350 */ + mx28_reg_32(hw_pinctrl_drive6) /* 0x360 */ + mx28_reg_32(hw_pinctrl_drive7) /* 0x370 */ + mx28_reg_32(hw_pinctrl_drive8) /* 0x380 */ + mx28_reg_32(hw_pinctrl_drive9) /* 0x390 */ + mx28_reg_32(hw_pinctrl_drive10) /* 0x3a0 */ + mx28_reg_32(hw_pinctrl_drive11) /* 0x3b0 */ + mx28_reg_32(hw_pinctrl_drive12) /* 0x3c0 */ + mx28_reg_32(hw_pinctrl_drive13) /* 0x3d0 */ + mx28_reg_32(hw_pinctrl_drive14) /* 0x3e0 */ + mx28_reg_32(hw_pinctrl_drive15) /* 0x3f0 */ + mx28_reg_32(hw_pinctrl_drive16) /* 0x400 */ + mx28_reg_32(hw_pinctrl_drive17) /* 0x410 */ + mx28_reg_32(hw_pinctrl_drive18) /* 0x420 */ + mx28_reg_32(hw_pinctrl_drive19) /* 0x430 */ + + uint32_t reserved3[112]; + + mx28_reg_32(hw_pinctrl_pull0) /* 0x600 */ + mx28_reg_32(hw_pinctrl_pull1) /* 0x610 */ + mx28_reg_32(hw_pinctrl_pull2) /* 0x620 */ + mx28_reg_32(hw_pinctrl_pull3) /* 0x630 */ + mx28_reg_32(hw_pinctrl_pull4) /* 0x640 */ + mx28_reg_32(hw_pinctrl_pull5) /* 0x650 */ + mx28_reg_32(hw_pinctrl_pull6) /* 0x660 */ + + uint32_t reserved4[36]; + + mx28_reg_32(hw_pinctrl_dout0) /* 0x700 */ + mx28_reg_32(hw_pinctrl_dout1) /* 0x710 */ + mx28_reg_32(hw_pinctrl_dout2) /* 0x720 */ + mx28_reg_32(hw_pinctrl_dout3) /* 0x730 */ + mx28_reg_32(hw_pinctrl_dout4) /* 0x740 */ + + uint32_t reserved5[108]; + + mx28_reg_32(hw_pinctrl_din0) /* 0x900 */ + mx28_reg_32(hw_pinctrl_din1) /* 0x910 */ + mx28_reg_32(hw_pinctrl_din2) /* 0x920 */ + mx28_reg_32(hw_pinctrl_din3) /* 0x930 */ + mx28_reg_32(hw_pinctrl_din4) /* 0x940 */ + + uint32_t reserved6[108]; + + mx28_reg_32(hw_pinctrl_doe0) /* 0xb00 */ + mx28_reg_32(hw_pinctrl_doe1) /* 0xb10 */ + mx28_reg_32(hw_pinctrl_doe2) /* 0xb20 */ + mx28_reg_32(hw_pinctrl_doe3) /* 0xb30 */ + mx28_reg_32(hw_pinctrl_doe4) /* 0xb40 */ + + uint32_t reserved7[300]; + + mx28_reg_32(hw_pinctrl_pin2irq0) /* 0x1000 */ + mx28_reg_32(hw_pinctrl_pin2irq1) /* 0x1010 */ + mx28_reg_32(hw_pinctrl_pin2irq2) /* 0x1020 */ + mx28_reg_32(hw_pinctrl_pin2irq3) /* 0x1030 */ + mx28_reg_32(hw_pinctrl_pin2irq4) /* 0x1040 */ + + uint32_t reserved8[44]; + + mx28_reg_32(hw_pinctrl_irqen0) /* 0x1100 */ + mx28_reg_32(hw_pinctrl_irqen1) /* 0x1110 */ + mx28_reg_32(hw_pinctrl_irqen2) /* 0x1120 */ + mx28_reg_32(hw_pinctrl_irqen3) /* 0x1130 */ + mx28_reg_32(hw_pinctrl_irqen4) /* 0x1140 */ + + uint32_t reserved9[44]; + + mx28_reg_32(hw_pinctrl_irqlevel0) /* 0x1200 */ + mx28_reg_32(hw_pinctrl_irqlevel1) /* 0x1210 */ + mx28_reg_32(hw_pinctrl_irqlevel2) /* 0x1220 */ + mx28_reg_32(hw_pinctrl_irqlevel3) /* 0x1230 */ + mx28_reg_32(hw_pinctrl_irqlevel4) /* 0x1240 */ + + uint32_t reserved10[44]; + + mx28_reg_32(hw_pinctrl_irqpol0) /* 0x1300 */ + mx28_reg_32(hw_pinctrl_irqpol1) /* 0x1310 */ + mx28_reg_32(hw_pinctrl_irqpol2) /* 0x1320 */ + mx28_reg_32(hw_pinctrl_irqpol3) /* 0x1330 */ + mx28_reg_32(hw_pinctrl_irqpol4) /* 0x1340 */ + + uint32_t reserved11[44]; + + mx28_reg_32(hw_pinctrl_irqstat0) /* 0x1400 */ + mx28_reg_32(hw_pinctrl_irqstat1) /* 0x1410 */ + mx28_reg_32(hw_pinctrl_irqstat2) /* 0x1420 */ + mx28_reg_32(hw_pinctrl_irqstat3) /* 0x1430 */ + mx28_reg_32(hw_pinctrl_irqstat4) /* 0x1440 */ + + uint32_t reserved12[380]; + + mx28_reg_32(hw_pinctrl_emi_odt_ctrl) /* 0x1a40 */ + + uint32_t reserved13[76]; + + mx28_reg_32(hw_pinctrl_emi_ds_ctrl) /* 0x1b80 */ +}; +#endif + +#define PINCTRL_CTRL_SFTRST (1 << 31) +#define PINCTRL_CTRL_CLKGATE (1 << 30) +#define PINCTRL_CTRL_PRESENT4 (1 << 24) +#define PINCTRL_CTRL_PRESENT3 (1 << 23) +#define PINCTRL_CTRL_PRESENT2 (1 << 22) +#define PINCTRL_CTRL_PRESENT1 (1 << 21) +#define PINCTRL_CTRL_PRESENT0 (1 << 20) +#define PINCTRL_CTRL_IRQOUT4 (1 << 4) +#define PINCTRL_CTRL_IRQOUT3 (1 << 3) +#define PINCTRL_CTRL_IRQOUT2 (1 << 2) +#define PINCTRL_CTRL_IRQOUT1 (1 << 1) +#define PINCTRL_CTRL_IRQOUT0 (1 << 0) + +#define PINCTRL_MUXSEL0_BANK0_PIN07_MASK (0x3 << 14) +#define PINCTRL_MUXSEL0_BANK0_PIN07_OFFSET 14 +#define PINCTRL_MUXSEL0_BANK0_PIN06_MASK (0x3 << 12) +#define PINCTRL_MUXSEL0_BANK0_PIN06_OFFSET 12 +#define PINCTRL_MUXSEL0_BANK0_PIN05_MASK (0x3 << 10) +#define PINCTRL_MUXSEL0_BANK0_PIN05_OFFSET 10 +#define PINCTRL_MUXSEL0_BANK0_PIN04_MASK (0x3 << 8) +#define PINCTRL_MUXSEL0_BANK0_PIN04_OFFSET 8 +#define PINCTRL_MUXSEL0_BANK0_PIN03_MASK (0x3 << 6) +#define PINCTRL_MUXSEL0_BANK0_PIN03_OFFSET 6 +#define PINCTRL_MUXSEL0_BANK0_PIN02_MASK (0x3 << 4) +#define PINCTRL_MUXSEL0_BANK0_PIN02_OFFSET 4 +#define PINCTRL_MUXSEL0_BANK0_PIN01_MASK (0x3 << 2) +#define PINCTRL_MUXSEL0_BANK0_PIN01_OFFSET 2 +#define PINCTRL_MUXSEL0_BANK0_PIN00_MASK (0x3 << 0) +#define PINCTRL_MUXSEL0_BANK0_PIN00_OFFSET 0 + +#define PINCTRL_MUXSEL1_BANK0_PIN28_MASK (0x3 << 24) +#define PINCTRL_MUXSEL1_BANK0_PIN28_OFFSET 24 +#define PINCTRL_MUXSEL1_BANK0_PIN27_MASK (0x3 << 22) +#define PINCTRL_MUXSEL1_BANK0_PIN27_OFFSET 22 +#define PINCTRL_MUXSEL1_BANK0_PIN26_MASK (0x3 << 20) +#define PINCTRL_MUXSEL1_BANK0_PIN26_OFFSET 20 +#define PINCTRL_MUXSEL1_BANK0_PIN25_MASK (0x3 << 18) +#define PINCTRL_MUXSEL1_BANK0_PIN25_OFFSET 18 +#define PINCTRL_MUXSEL1_BANK0_PIN24_MASK (0x3 << 16) +#define PINCTRL_MUXSEL1_BANK0_PIN24_OFFSET 16 +#define PINCTRL_MUXSEL1_BANK0_PIN23_MASK (0x3 << 14) +#define PINCTRL_MUXSEL1_BANK0_PIN23_OFFSET 14 +#define PINCTRL_MUXSEL1_BANK0_PIN22_MASK (0x3 << 12) +#define PINCTRL_MUXSEL1_BANK0_PIN22_OFFSET 12 +#define PINCTRL_MUXSEL1_BANK0_PIN21_MASK (0x3 << 10) +#define PINCTRL_MUXSEL1_BANK0_PIN21_OFFSET 10 +#define PINCTRL_MUXSEL1_BANK0_PIN20_MASK (0x3 << 8) +#define PINCTRL_MUXSEL1_BANK0_PIN20_OFFSET 8 +#define PINCTRL_MUXSEL1_BANK0_PIN19_MASK (0x3 << 6) +#define PINCTRL_MUXSEL1_BANK0_PIN19_OFFSET 6 +#define PINCTRL_MUXSEL1_BANK0_PIN18_MASK (0x3 << 4) +#define PINCTRL_MUXSEL1_BANK0_PIN18_OFFSET 4 +#define PINCTRL_MUXSEL1_BANK0_PIN17_MASK (0x3 << 2) +#define PINCTRL_MUXSEL1_BANK0_PIN17_OFFSET 2 +#define PINCTRL_MUXSEL1_BANK0_PIN16_MASK (0x3 << 0) +#define PINCTRL_MUXSEL1_BANK0_PIN16_OFFSET 0 + +#define PINCTRL_MUXSEL2_BANK1_PIN15_MASK (0x3 << 30) +#define PINCTRL_MUXSEL2_BANK1_PIN15_OFFSET 30 +#define PINCTRL_MUXSEL2_BANK1_PIN14_MASK (0x3 << 28) +#define PINCTRL_MUXSEL2_BANK1_PIN14_OFFSET 28 +#define PINCTRL_MUXSEL2_BANK1_PIN13_MASK (0x3 << 26) +#define PINCTRL_MUXSEL2_BANK1_PIN13_OFFSET 26 +#define PINCTRL_MUXSEL2_BANK1_PIN12_MASK (0x3 << 24) +#define PINCTRL_MUXSEL2_BANK1_PIN12_OFFSET 24 +#define PINCTRL_MUXSEL2_BANK1_PIN11_MASK (0x3 << 22) +#define PINCTRL_MUXSEL2_BANK1_PIN11_OFFSET 22 +#define PINCTRL_MUXSEL2_BANK1_PIN10_MASK (0x3 << 20) +#define PINCTRL_MUXSEL2_BANK1_PIN10_OFFSET 20 +#define PINCTRL_MUXSEL2_BANK1_PIN09_MASK (0x3 << 18) +#define PINCTRL_MUXSEL2_BANK1_PIN09_OFFSET 18 +#define PINCTRL_MUXSEL2_BANK1_PIN08_MASK (0x3 << 16) +#define PINCTRL_MUXSEL2_BANK1_PIN08_OFFSET 16 +#define PINCTRL_MUXSEL2_BANK1_PIN07_MASK (0x3 << 14) +#define PINCTRL_MUXSEL2_BANK1_PIN07_OFFSET 14 +#define PINCTRL_MUXSEL2_BANK1_PIN06_MASK (0x3 << 12) +#define PINCTRL_MUXSEL2_BANK1_PIN06_OFFSET 12 +#define PINCTRL_MUXSEL2_BANK1_PIN05_MASK (0x3 << 10) +#define PINCTRL_MUXSEL2_BANK1_PIN05_OFFSET 10 +#define PINCTRL_MUXSEL2_BANK1_PIN04_MASK (0x3 << 8) +#define PINCTRL_MUXSEL2_BANK1_PIN04_OFFSET 8 +#define PINCTRL_MUXSEL2_BANK1_PIN03_MASK (0x3 << 6) +#define PINCTRL_MUXSEL2_BANK1_PIN03_OFFSET 6 +#define PINCTRL_MUXSEL2_BANK1_PIN02_MASK (0x3 << 4) +#define PINCTRL_MUXSEL2_BANK1_PIN02_OFFSET 4 +#define PINCTRL_MUXSEL2_BANK1_PIN01_MASK (0x3 << 2) +#define PINCTRL_MUXSEL2_BANK1_PIN01_OFFSET 2 +#define PINCTRL_MUXSEL2_BANK1_PIN00_MASK (0x3 << 0) +#define PINCTRL_MUXSEL2_BANK1_PIN00_OFFSET 0 + +#define PINCTRL_MUXSEL3_BANK1_PIN31_MASK (0x3 << 30) +#define PINCTRL_MUXSEL3_BANK1_PIN31_OFFSET 30 +#define PINCTRL_MUXSEL3_BANK1_PIN30_MASK (0x3 << 28) +#define PINCTRL_MUXSEL3_BANK1_PIN30_OFFSET 28 +#define PINCTRL_MUXSEL3_BANK1_PIN29_MASK (0x3 << 26) +#define PINCTRL_MUXSEL3_BANK1_PIN29_OFFSET 26 +#define PINCTRL_MUXSEL3_BANK1_PIN28_MASK (0x3 << 24) +#define PINCTRL_MUXSEL3_BANK1_PIN28_OFFSET 24 +#define PINCTRL_MUXSEL3_BANK1_PIN27_MASK (0x3 << 22) +#define PINCTRL_MUXSEL3_BANK1_PIN27_OFFSET 22 +#define PINCTRL_MUXSEL3_BANK1_PIN26_MASK (0x3 << 20) +#define PINCTRL_MUXSEL3_BANK1_PIN26_OFFSET 20 +#define PINCTRL_MUXSEL3_BANK1_PIN25_MASK (0x3 << 18) +#define PINCTRL_MUXSEL3_BANK1_PIN25_OFFSET 18 +#define PINCTRL_MUXSEL3_BANK1_PIN24_MASK (0x3 << 16) +#define PINCTRL_MUXSEL3_BANK1_PIN24_OFFSET 16 +#define PINCTRL_MUXSEL3_BANK1_PIN23_MASK (0x3 << 14) +#define PINCTRL_MUXSEL3_BANK1_PIN23_OFFSET 14 +#define PINCTRL_MUXSEL3_BANK1_PIN22_MASK (0x3 << 12) +#define PINCTRL_MUXSEL3_BANK1_PIN22_OFFSET 12 +#define PINCTRL_MUXSEL3_BANK1_PIN21_MASK (0x3 << 10) +#define PINCTRL_MUXSEL3_BANK1_PIN21_OFFSET 10 +#define PINCTRL_MUXSEL3_BANK1_PIN20_MASK (0x3 << 8) +#define PINCTRL_MUXSEL3_BANK1_PIN20_OFFSET 8 +#define PINCTRL_MUXSEL3_BANK1_PIN19_MASK (0x3 << 6) +#define PINCTRL_MUXSEL3_BANK1_PIN19_OFFSET 6 +#define PINCTRL_MUXSEL3_BANK1_PIN18_MASK (0x3 << 4) +#define PINCTRL_MUXSEL3_BANK1_PIN18_OFFSET 4 +#define PINCTRL_MUXSEL3_BANK1_PIN17_MASK (0x3 << 2) +#define PINCTRL_MUXSEL3_BANK1_PIN17_OFFSET 2 +#define PINCTRL_MUXSEL3_BANK1_PIN16_MASK (0x3 << 0) +#define PINCTRL_MUXSEL3_BANK1_PIN16_OFFSET 0 + +#define PINCTRL_MUXSEL4_BANK2_PIN15_MASK (0x3 << 30) +#define PINCTRL_MUXSEL4_BANK2_PIN15_OFFSET 30 +#define PINCTRL_MUXSEL4_BANK2_PIN14_MASK (0x3 << 28) +#define PINCTRL_MUXSEL4_BANK2_PIN14_OFFSET 28 +#define PINCTRL_MUXSEL4_BANK2_PIN13_MASK (0x3 << 26) +#define PINCTRL_MUXSEL4_BANK2_PIN13_OFFSET 26 +#define PINCTRL_MUXSEL4_BANK2_PIN12_MASK (0x3 << 24) +#define PINCTRL_MUXSEL4_BANK2_PIN12_OFFSET 24 +#define PINCTRL_MUXSEL4_BANK2_PIN10_MASK (0x3 << 20) +#define PINCTRL_MUXSEL4_BANK2_PIN10_OFFSET 20 +#define PINCTRL_MUXSEL4_BANK2_PIN09_MASK (0x3 << 18) +#define PINCTRL_MUXSEL4_BANK2_PIN09_OFFSET 18 +#define PINCTRL_MUXSEL4_BANK2_PIN08_MASK (0x3 << 16) +#define PINCTRL_MUXSEL4_BANK2_PIN08_OFFSET 16 +#define PINCTRL_MUXSEL4_BANK2_PIN07_MASK (0x3 << 14) +#define PINCTRL_MUXSEL4_BANK2_PIN07_OFFSET 14 +#define PINCTRL_MUXSEL4_BANK2_PIN06_MASK (0x3 << 12) +#define PINCTRL_MUXSEL4_BANK2_PIN06_OFFSET 12 +#define PINCTRL_MUXSEL4_BANK2_PIN05_MASK (0x3 << 10) +#define PINCTRL_MUXSEL4_BANK2_PIN05_OFFSET 10 +#define PINCTRL_MUXSEL4_BANK2_PIN04_MASK (0x3 << 8) +#define PINCTRL_MUXSEL4_BANK2_PIN04_OFFSET 8 +#define PINCTRL_MUXSEL4_BANK2_PIN03_MASK (0x3 << 6) +#define PINCTRL_MUXSEL4_BANK2_PIN03_OFFSET 6 +#define PINCTRL_MUXSEL4_BANK2_PIN02_MASK (0x3 << 4) +#define PINCTRL_MUXSEL4_BANK2_PIN02_OFFSET 4 +#define PINCTRL_MUXSEL4_BANK2_PIN01_MASK (0x3 << 2) +#define PINCTRL_MUXSEL4_BANK2_PIN01_OFFSET 2 +#define PINCTRL_MUXSEL4_BANK2_PIN00_MASK (0x3 << 0) +#define PINCTRL_MUXSEL4_BANK2_PIN00_OFFSET 0 + +#define PINCTRL_MUXSEL5_BANK2_PIN27_MASK (0x3 << 22) +#define PINCTRL_MUXSEL5_BANK2_PIN27_OFFSET 22 +#define PINCTRL_MUXSEL5_BANK2_PIN26_MASK (0x3 << 20) +#define PINCTRL_MUXSEL5_BANK2_PIN26_OFFSET 20 +#define PINCTRL_MUXSEL5_BANK2_PIN25_MASK (0x3 << 18) +#define PINCTRL_MUXSEL5_BANK2_PIN25_OFFSET 18 +#define PINCTRL_MUXSEL5_BANK2_PIN24_MASK (0x3 << 16) +#define PINCTRL_MUXSEL5_BANK2_PIN24_OFFSET 16 +#define PINCTRL_MUXSEL5_BANK2_PIN21_MASK (0x3 << 10) +#define PINCTRL_MUXSEL5_BANK2_PIN21_OFFSET 10 +#define PINCTRL_MUXSEL5_BANK2_PIN20_MASK (0x3 << 8) +#define PINCTRL_MUXSEL5_BANK2_PIN20_OFFSET 8 +#define PINCTRL_MUXSEL5_BANK2_PIN19_MASK (0x3 << 6) +#define PINCTRL_MUXSEL5_BANK2_PIN19_OFFSET 6 +#define PINCTRL_MUXSEL5_BANK2_PIN18_MASK (0x3 << 4) +#define PINCTRL_MUXSEL5_BANK2_PIN18_OFFSET 4 +#define PINCTRL_MUXSEL5_BANK2_PIN17_MASK (0x3 << 2) +#define PINCTRL_MUXSEL5_BANK2_PIN17_OFFSET 2 +#define PINCTRL_MUXSEL5_BANK2_PIN16_MASK (0x3 << 0) +#define PINCTRL_MUXSEL5_BANK2_PIN16_OFFSET 0 + +#define PINCTRL_MUXSEL6_BANK3_PIN15_MASK (0x3 << 30) +#define PINCTRL_MUXSEL6_BANK3_PIN15_OFFSET 30 +#define PINCTRL_MUXSEL6_BANK3_PIN14_MASK (0x3 << 28) +#define PINCTRL_MUXSEL6_BANK3_PIN14_OFFSET 28 +#define PINCTRL_MUXSEL6_BANK3_PIN13_MASK (0x3 << 26) +#define PINCTRL_MUXSEL6_BANK3_PIN13_OFFSET 26 +#define PINCTRL_MUXSEL6_BANK3_PIN12_MASK (0x3 << 24) +#define PINCTRL_MUXSEL6_BANK3_PIN12_OFFSET 24 +#define PINCTRL_MUXSEL6_BANK3_PIN11_MASK (0x3 << 22) +#define PINCTRL_MUXSEL6_BANK3_PIN11_OFFSET 22 +#define PINCTRL_MUXSEL6_BANK3_PIN10_MASK (0x3 << 20) +#define PINCTRL_MUXSEL6_BANK3_PIN10_OFFSET 20 +#define PINCTRL_MUXSEL6_BANK3_PIN09_MASK (0x3 << 18) +#define PINCTRL_MUXSEL6_BANK3_PIN09_OFFSET 18 +#define PINCTRL_MUXSEL6_BANK3_PIN08_MASK (0x3 << 16) +#define PINCTRL_MUXSEL6_BANK3_PIN08_OFFSET 16 +#define PINCTRL_MUXSEL6_BANK3_PIN07_MASK (0x3 << 14) +#define PINCTRL_MUXSEL6_BANK3_PIN07_OFFSET 14 +#define PINCTRL_MUXSEL6_BANK3_PIN06_MASK (0x3 << 12) +#define PINCTRL_MUXSEL6_BANK3_PIN06_OFFSET 12 +#define PINCTRL_MUXSEL6_BANK3_PIN05_MASK (0x3 << 10) +#define PINCTRL_MUXSEL6_BANK3_PIN05_OFFSET 10 +#define PINCTRL_MUXSEL6_BANK3_PIN04_MASK (0x3 << 8) +#define PINCTRL_MUXSEL6_BANK3_PIN04_OFFSET 8 +#define PINCTRL_MUXSEL6_BANK3_PIN03_MASK (0x3 << 6) +#define PINCTRL_MUXSEL6_BANK3_PIN03_OFFSET 6 +#define PINCTRL_MUXSEL6_BANK3_PIN02_MASK (0x3 << 4) +#define PINCTRL_MUXSEL6_BANK3_PIN02_OFFSET 4 +#define PINCTRL_MUXSEL6_BANK3_PIN01_MASK (0x3 << 2) +#define PINCTRL_MUXSEL6_BANK3_PIN01_OFFSET 2 +#define PINCTRL_MUXSEL6_BANK3_PIN00_MASK (0x3 << 0) +#define PINCTRL_MUXSEL6_BANK3_PIN00_OFFSET 0 + +#define PINCTRL_MUXSEL7_BANK3_PIN30_MASK (0x3 << 28) +#define PINCTRL_MUXSEL7_BANK3_PIN30_OFFSET 28 +#define PINCTRL_MUXSEL7_BANK3_PIN29_MASK (0x3 << 26) +#define PINCTRL_MUXSEL7_BANK3_PIN29_OFFSET 26 +#define PINCTRL_MUXSEL7_BANK3_PIN28_MASK (0x3 << 24) +#define PINCTRL_MUXSEL7_BANK3_PIN28_OFFSET 24 +#define PINCTRL_MUXSEL7_BANK3_PIN27_MASK (0x3 << 22) +#define PINCTRL_MUXSEL7_BANK3_PIN27_OFFSET 22 +#define PINCTRL_MUXSEL7_BANK3_PIN26_MASK (0x3 << 20) +#define PINCTRL_MUXSEL7_BANK3_PIN26_OFFSET 20 +#define PINCTRL_MUXSEL7_BANK3_PIN25_MASK (0x3 << 18) +#define PINCTRL_MUXSEL7_BANK3_PIN25_OFFSET 18 +#define PINCTRL_MUXSEL7_BANK3_PIN24_MASK (0x3 << 16) +#define PINCTRL_MUXSEL7_BANK3_PIN24_OFFSET 16 +#define PINCTRL_MUXSEL7_BANK3_PIN23_MASK (0x3 << 14) +#define PINCTRL_MUXSEL7_BANK3_PIN23_OFFSET 14 +#define PINCTRL_MUXSEL7_BANK3_PIN22_MASK (0x3 << 12) +#define PINCTRL_MUXSEL7_BANK3_PIN22_OFFSET 12 +#define PINCTRL_MUXSEL7_BANK3_PIN21_MASK (0x3 << 10) +#define PINCTRL_MUXSEL7_BANK3_PIN21_OFFSET 10 +#define PINCTRL_MUXSEL7_BANK3_PIN20_MASK (0x3 << 8) +#define PINCTRL_MUXSEL7_BANK3_PIN20_OFFSET 8 +#define PINCTRL_MUXSEL7_BANK3_PIN18_MASK (0x3 << 4) +#define PINCTRL_MUXSEL7_BANK3_PIN18_OFFSET 4 +#define PINCTRL_MUXSEL7_BANK3_PIN17_MASK (0x3 << 2) +#define PINCTRL_MUXSEL7_BANK3_PIN17_OFFSET 2 +#define PINCTRL_MUXSEL7_BANK3_PIN16_MASK (0x3 << 0) +#define PINCTRL_MUXSEL7_BANK3_PIN16_OFFSET 0 + +#define PINCTRL_MUXSEL8_BANK4_PIN15_MASK (0x3 << 30) +#define PINCTRL_MUXSEL8_BANK4_PIN15_OFFSET 30 +#define PINCTRL_MUXSEL8_BANK4_PIN14_MASK (0x3 << 28) +#define PINCTRL_MUXSEL8_BANK4_PIN14_OFFSET 28 +#define PINCTRL_MUXSEL8_BANK4_PIN13_MASK (0x3 << 26) +#define PINCTRL_MUXSEL8_BANK4_PIN13_OFFSET 26 +#define PINCTRL_MUXSEL8_BANK4_PIN12_MASK (0x3 << 24) +#define PINCTRL_MUXSEL8_BANK4_PIN12_OFFSET 24 +#define PINCTRL_MUXSEL8_BANK4_PIN11_MASK (0x3 << 22) +#define PINCTRL_MUXSEL8_BANK4_PIN11_OFFSET 22 +#define PINCTRL_MUXSEL8_BANK4_PIN10_MASK (0x3 << 20) +#define PINCTRL_MUXSEL8_BANK4_PIN10_OFFSET 20 +#define PINCTRL_MUXSEL8_BANK4_PIN09_MASK (0x3 << 18) +#define PINCTRL_MUXSEL8_BANK4_PIN09_OFFSET 18 +#define PINCTRL_MUXSEL8_BANK4_PIN08_MASK (0x3 << 16) +#define PINCTRL_MUXSEL8_BANK4_PIN08_OFFSET 16 +#define PINCTRL_MUXSEL8_BANK4_PIN07_MASK (0x3 << 14) +#define PINCTRL_MUXSEL8_BANK4_PIN07_OFFSET 14 +#define PINCTRL_MUXSEL8_BANK4_PIN06_MASK (0x3 << 12) +#define PINCTRL_MUXSEL8_BANK4_PIN06_OFFSET 12 +#define PINCTRL_MUXSEL8_BANK4_PIN05_MASK (0x3 << 10) +#define PINCTRL_MUXSEL8_BANK4_PIN05_OFFSET 10 +#define PINCTRL_MUXSEL8_BANK4_PIN04_MASK (0x3 << 8) +#define PINCTRL_MUXSEL8_BANK4_PIN04_OFFSET 8 +#define PINCTRL_MUXSEL8_BANK4_PIN03_MASK (0x3 << 6) +#define PINCTRL_MUXSEL8_BANK4_PIN03_OFFSET 6 +#define PINCTRL_MUXSEL8_BANK4_PIN02_MASK (0x3 << 4) +#define PINCTRL_MUXSEL8_BANK4_PIN02_OFFSET 4 +#define PINCTRL_MUXSEL8_BANK4_PIN01_MASK (0x3 << 2) +#define PINCTRL_MUXSEL8_BANK4_PIN01_OFFSET 2 +#define PINCTRL_MUXSEL8_BANK4_PIN00_MASK (0x3 << 0) +#define PINCTRL_MUXSEL8_BANK4_PIN00_OFFSET 0 + +#define PINCTRL_MUXSEL9_BANK4_PIN20_MASK (0x3 << 8) +#define PINCTRL_MUXSEL9_BANK4_PIN20_OFFSET 8 +#define PINCTRL_MUXSEL9_BANK4_PIN16_MASK (0x3 << 0) +#define PINCTRL_MUXSEL9_BANK4_PIN16_OFFSET 0 + +#define PINCTRL_MUXSEL10_BANK5_PIN15_MASK (0x3 << 30) +#define PINCTRL_MUXSEL10_BANK5_PIN15_OFFSET 30 +#define PINCTRL_MUXSEL10_BANK5_PIN14_MASK (0x3 << 28) +#define PINCTRL_MUXSEL10_BANK5_PIN14_OFFSET 28 +#define PINCTRL_MUXSEL10_BANK5_PIN13_MASK (0x3 << 26) +#define PINCTRL_MUXSEL10_BANK5_PIN13_OFFSET 26 +#define PINCTRL_MUXSEL10_BANK5_PIN12_MASK (0x3 << 24) +#define PINCTRL_MUXSEL10_BANK5_PIN12_OFFSET 24 +#define PINCTRL_MUXSEL10_BANK5_PIN11_MASK (0x3 << 22) +#define PINCTRL_MUXSEL10_BANK5_PIN11_OFFSET 22 +#define PINCTRL_MUXSEL10_BANK5_PIN10_MASK (0x3 << 20) +#define PINCTRL_MUXSEL10_BANK5_PIN10_OFFSET 20 +#define PINCTRL_MUXSEL10_BANK5_PIN09_MASK (0x3 << 18) +#define PINCTRL_MUXSEL10_BANK5_PIN09_OFFSET 18 +#define PINCTRL_MUXSEL10_BANK5_PIN08_MASK (0x3 << 16) +#define PINCTRL_MUXSEL10_BANK5_PIN08_OFFSET 16 +#define PINCTRL_MUXSEL10_BANK5_PIN07_MASK (0x3 << 14) +#define PINCTRL_MUXSEL10_BANK5_PIN07_OFFSET 14 +#define PINCTRL_MUXSEL10_BANK5_PIN06_MASK (0x3 << 12) +#define PINCTRL_MUXSEL10_BANK5_PIN06_OFFSET 12 +#define PINCTRL_MUXSEL10_BANK5_PIN05_MASK (0x3 << 10) +#define PINCTRL_MUXSEL10_BANK5_PIN05_OFFSET 10 +#define PINCTRL_MUXSEL10_BANK5_PIN04_MASK (0x3 << 8) +#define PINCTRL_MUXSEL10_BANK5_PIN04_OFFSET 8 +#define PINCTRL_MUXSEL10_BANK5_PIN03_MASK (0x3 << 6) +#define PINCTRL_MUXSEL10_BANK5_PIN03_OFFSET 6 +#define PINCTRL_MUXSEL10_BANK5_PIN02_MASK (0x3 << 4) +#define PINCTRL_MUXSEL10_BANK5_PIN02_OFFSET 4 +#define PINCTRL_MUXSEL10_BANK5_PIN01_MASK (0x3 << 2) +#define PINCTRL_MUXSEL10_BANK5_PIN01_OFFSET 2 +#define PINCTRL_MUXSEL10_BANK5_PIN00_MASK (0x3 << 0) +#define PINCTRL_MUXSEL10_BANK5_PIN00_OFFSET 0 + +#define PINCTRL_MUXSEL11_BANK5_PIN26_MASK (0x3 << 20) +#define PINCTRL_MUXSEL11_BANK5_PIN26_OFFSET 20 +#define PINCTRL_MUXSEL11_BANK5_PIN23_MASK (0x3 << 14) +#define PINCTRL_MUXSEL11_BANK5_PIN23_OFFSET 14 +#define PINCTRL_MUXSEL11_BANK5_PIN22_MASK (0x3 << 12) +#define PINCTRL_MUXSEL11_BANK5_PIN22_OFFSET 12 +#define PINCTRL_MUXSEL11_BANK5_PIN21_MASK (0x3 << 10) +#define PINCTRL_MUXSEL11_BANK5_PIN21_OFFSET 10 +#define PINCTRL_MUXSEL11_BANK5_PIN20_MASK (0x3 << 8) +#define PINCTRL_MUXSEL11_BANK5_PIN20_OFFSET 8 +#define PINCTRL_MUXSEL11_BANK5_PIN19_MASK (0x3 << 6) +#define PINCTRL_MUXSEL11_BANK5_PIN19_OFFSET 6 +#define PINCTRL_MUXSEL11_BANK5_PIN18_MASK (0x3 << 4) +#define PINCTRL_MUXSEL11_BANK5_PIN18_OFFSET 4 +#define PINCTRL_MUXSEL11_BANK5_PIN17_MASK (0x3 << 2) +#define PINCTRL_MUXSEL11_BANK5_PIN17_OFFSET 2 +#define PINCTRL_MUXSEL11_BANK5_PIN16_MASK (0x3 << 0) +#define PINCTRL_MUXSEL11_BANK5_PIN16_OFFSET 0 + +#define PINCTRL_MUXSEL12_BANK6_PIN14_MASK (0x3 << 28) +#define PINCTRL_MUXSEL12_BANK6_PIN14_OFFSET 28 +#define PINCTRL_MUXSEL12_BANK6_PIN13_MASK (0x3 << 26) +#define PINCTRL_MUXSEL12_BANK6_PIN13_OFFSET 26 +#define PINCTRL_MUXSEL12_BANK6_PIN12_MASK (0x3 << 24) +#define PINCTRL_MUXSEL12_BANK6_PIN12_OFFSET 24 +#define PINCTRL_MUXSEL12_BANK6_PIN11_MASK (0x3 << 22) +#define PINCTRL_MUXSEL12_BANK6_PIN11_OFFSET 22 +#define PINCTRL_MUXSEL12_BANK6_PIN10_MASK (0x3 << 20) +#define PINCTRL_MUXSEL12_BANK6_PIN10_OFFSET 20 +#define PINCTRL_MUXSEL12_BANK6_PIN09_MASK (0x3 << 18) +#define PINCTRL_MUXSEL12_BANK6_PIN09_OFFSET 18 +#define PINCTRL_MUXSEL12_BANK6_PIN08_MASK (0x3 << 16) +#define PINCTRL_MUXSEL12_BANK6_PIN08_OFFSET 16 +#define PINCTRL_MUXSEL12_BANK6_PIN07_MASK (0x3 << 14) +#define PINCTRL_MUXSEL12_BANK6_PIN07_OFFSET 14 +#define PINCTRL_MUXSEL12_BANK6_PIN06_MASK (0x3 << 12) +#define PINCTRL_MUXSEL12_BANK6_PIN06_OFFSET 12 +#define PINCTRL_MUXSEL12_BANK6_PIN05_MASK (0x3 << 10) +#define PINCTRL_MUXSEL12_BANK6_PIN05_OFFSET 10 +#define PINCTRL_MUXSEL12_BANK6_PIN04_MASK (0x3 << 8) +#define PINCTRL_MUXSEL12_BANK6_PIN04_OFFSET 8 +#define PINCTRL_MUXSEL12_BANK6_PIN03_MASK (0x3 << 6) +#define PINCTRL_MUXSEL12_BANK6_PIN03_OFFSET 6 +#define PINCTRL_MUXSEL12_BANK6_PIN02_MASK (0x3 << 4) +#define PINCTRL_MUXSEL12_BANK6_PIN02_OFFSET 4 +#define PINCTRL_MUXSEL12_BANK6_PIN01_MASK (0x3 << 2) +#define PINCTRL_MUXSEL12_BANK6_PIN01_OFFSET 2 +#define PINCTRL_MUXSEL12_BANK6_PIN00_MASK (0x3 << 0) +#define PINCTRL_MUXSEL12_BANK6_PIN00_OFFSET 0 + +#define PINCTRL_MUXSEL13_BANK6_PIN24_MASK (0x3 << 16) +#define PINCTRL_MUXSEL13_BANK6_PIN24_OFFSET 16 +#define PINCTRL_MUXSEL13_BANK6_PIN23_MASK (0x3 << 14) +#define PINCTRL_MUXSEL13_BANK6_PIN23_OFFSET 14 +#define PINCTRL_MUXSEL13_BANK6_PIN22_MASK (0x3 << 12) +#define PINCTRL_MUXSEL13_BANK6_PIN22_OFFSET 12 +#define PINCTRL_MUXSEL13_BANK6_PIN21_MASK (0x3 << 10) +#define PINCTRL_MUXSEL13_BANK6_PIN21_OFFSET 10 +#define PINCTRL_MUXSEL13_BANK6_PIN20_MASK (0x3 << 8) +#define PINCTRL_MUXSEL13_BANK6_PIN20_OFFSET 8 +#define PINCTRL_MUXSEL13_BANK6_PIN19_MASK (0x3 << 6) +#define PINCTRL_MUXSEL13_BANK6_PIN19_OFFSET 6 +#define PINCTRL_MUXSEL13_BANK6_PIN18_MASK (0x3 << 4) +#define PINCTRL_MUXSEL13_BANK6_PIN18_OFFSET 4 +#define PINCTRL_MUXSEL13_BANK6_PIN17_MASK (0x3 << 2) +#define PINCTRL_MUXSEL13_BANK6_PIN17_OFFSET 2 +#define PINCTRL_MUXSEL13_BANK6_PIN16_MASK (0x3 << 0) +#define PINCTRL_MUXSEL13_BANK6_PIN16_OFFSET 0 + +#define PINCTRL_DRIVE0_BANK0_PIN07_V (1 << 30) +#define PINCTRL_DRIVE0_BANK0_PIN07_MA_MASK (0x3 << 28) +#define PINCTRL_DRIVE0_BANK0_PIN07_MA_OFFSET 28 +#define PINCTRL_DRIVE0_BANK0_PIN06_V (1 << 26) +#define PINCTRL_DRIVE0_BANK0_PIN06_MA_MASK (0x3 << 24) +#define PINCTRL_DRIVE0_BANK0_PIN06_MA_OFFSET 24 +#define PINCTRL_DRIVE0_BANK0_PIN05_V (1 << 22) +#define PINCTRL_DRIVE0_BANK0_PIN05_MA_MASK (0x3 << 20) +#define PINCTRL_DRIVE0_BANK0_PIN05_MA_OFFSET 20 +#define PINCTRL_DRIVE0_BANK0_PIN04_V (1 << 18) +#define PINCTRL_DRIVE0_BANK0_PIN04_MA_MASK (0x3 << 16) +#define PINCTRL_DRIVE0_BANK0_PIN04_MA_OFFSET 16 +#define PINCTRL_DRIVE0_BANK0_PIN03_V (1 << 14) +#define PINCTRL_DRIVE0_BANK0_PIN03_MA_MASK (0x3 << 12) +#define PINCTRL_DRIVE0_BANK0_PIN03_MA_OFFSET 12 +#define PINCTRL_DRIVE0_BANK0_PIN02_V (1 << 10) +#define PINCTRL_DRIVE0_BANK0_PIN02_MA_MASK (0x3 << 8) +#define PINCTRL_DRIVE0_BANK0_PIN02_MA_OFFSET 8 +#define PINCTRL_DRIVE0_BANK0_PIN01_V (1 << 6) +#define PINCTRL_DRIVE0_BANK0_PIN01_MA_MASK (0x3 << 4) +#define PINCTRL_DRIVE0_BANK0_PIN01_MA_OFFSET 4 +#define PINCTRL_DRIVE0_BANK0_PIN00_V (1 << 2) +#define PINCTRL_DRIVE0_BANK0_PIN00_MA_MASK (0x3 << 0) +#define PINCTRL_DRIVE0_BANK0_PIN00_MA_OFFSET 0 + +#define PINCTRL_DRIVE2_BANK0_PIN23_V (1 << 30) +#define PINCTRL_DRIVE2_BANK0_PIN23_MA_MASK (0x3 << 28) +#define PINCTRL_DRIVE2_BANK0_PIN23_MA_OFFSET 28 +#define PINCTRL_DRIVE2_BANK0_PIN22_V (1 << 26) +#define PINCTRL_DRIVE2_BANK0_PIN22_MA_MASK (0x3 << 24) +#define PINCTRL_DRIVE2_BANK0_PIN22_MA_OFFSET 24 +#define PINCTRL_DRIVE2_BANK0_PIN21_V (1 << 22) +#define PINCTRL_DRIVE2_BANK0_PIN21_MA_MASK (0x3 << 20) +#define PINCTRL_DRIVE2_BANK0_PIN21_MA_OFFSET 20 +#define PINCTRL_DRIVE2_BANK0_PIN20_V (1 << 18) +#define PINCTRL_DRIVE2_BANK0_PIN20_MA_MASK (0x3 << 16) +#define PINCTRL_DRIVE2_BANK0_PIN20_MA_OFFSET 16 +#define PINCTRL_DRIVE2_BANK0_PIN19_V (1 << 14) +#define PINCTRL_DRIVE2_BANK0_PIN19_MA_MASK (0x3 << 12) +#define PINCTRL_DRIVE2_BANK0_PIN19_MA_OFFSET 12 +#define PINCTRL_DRIVE2_BANK0_PIN18_V (1 << 10) +#define PINCTRL_DRIVE2_BANK0_PIN18_MA_MASK (0x3 << 8) +#define PINCTRL_DRIVE2_BANK0_PIN18_MA_OFFSET 8 +#define PINCTRL_DRIVE2_BANK0_PIN17_V (1 << 6) +#define PINCTRL_DRIVE2_BANK0_PIN17_MA_MASK (0x3 << 4) +#define PINCTRL_DRIVE2_BANK0_PIN17_MA_OFFSET 4 +#define PINCTRL_DRIVE2_BANK0_PIN16_V (1 << 2) +#define PINCTRL_DRIVE2_BANK0_PIN16_MA_MASK (0x3 << 0) +#define PINCTRL_DRIVE2_BANK0_PIN16_MA_OFFSET 0 + +#define PINCTRL_DRIVE3_BANK0_PIN28_V (1 << 18) +#define PINCTRL_DRIVE3_BANK0_PIN28_MA_MASK (0x3 << 16) +#define PINCTRL_DRIVE3_BANK0_PIN28_MA_OFFSET 16 +#define PINCTRL_DRIVE3_BANK0_PIN27_V (1 << 14) +#define PINCTRL_DRIVE3_BANK0_PIN27_MA_MASK (0x3 << 12) +#define PINCTRL_DRIVE3_BANK0_PIN27_MA_OFFSET 12 +#define PINCTRL_DRIVE3_BANK0_PIN26_V (1 << 10) +#define PINCTRL_DRIVE3_BANK0_PIN26_MA_MASK (0x3 << 8) +#define PINCTRL_DRIVE3_BANK0_PIN26_MA_OFFSET 8 +#define PINCTRL_DRIVE3_BANK0_PIN25_V (1 << 6) +#define PINCTRL_DRIVE3_BANK0_PIN25_MA_MASK (0x3 << 4) +#define PINCTRL_DRIVE3_BANK0_PIN25_MA_OFFSET 4 +#define PINCTRL_DRIVE3_BANK0_PIN24_V (1 << 2) +#define PINCTRL_DRIVE3_BANK0_PIN24_MA_MASK (0x3 << 0) +#define PINCTRL_DRIVE3_BANK0_PIN24_MA_OFFSET 0 + +#define PINCTRL_DRIVE4_BANK1_PIN07_V (1 << 30) +#define PINCTRL_DRIVE4_BANK1_PIN07_MA_MASK (0x3 << 28) +#define PINCTRL_DRIVE4_BANK1_PIN07_MA_OFFSET 28 +#define PINCTRL_DRIVE4_BANK1_PIN06_V (1 << 26) +#define PINCTRL_DRIVE4_BANK1_PIN06_MA_MASK (0x3 << 24) +#define PINCTRL_DRIVE4_BANK1_PIN06_MA_OFFSET 24 +#define PINCTRL_DRIVE4_BANK1_PIN05_V (1 << 22) +#define PINCTRL_DRIVE4_BANK1_PIN05_MA_MASK (0x3 << 20) +#define PINCTRL_DRIVE4_BANK1_PIN05_MA_OFFSET 20 +#define PINCTRL_DRIVE4_BANK1_PIN04_V (1 << 18) +#define PINCTRL_DRIVE4_BANK1_PIN04_MA_MASK (0x3 << 16) +#define PINCTRL_DRIVE4_BANK1_PIN04_MA_OFFSET 16 +#define PINCTRL_DRIVE4_BANK1_PIN03_V (1 << 14) +#define PINCTRL_DRIVE4_BANK1_PIN03_MA_MASK (0x3 << 12) +#define PINCTRL_DRIVE4_BANK1_PIN03_MA_OFFSET 12 +#define PINCTRL_DRIVE4_BANK1_PIN02_V (1 << 10) +#define PINCTRL_DRIVE4_BANK1_PIN02_MA_MASK (0x3 << 8) +#define PINCTRL_DRIVE4_BANK1_PIN02_MA_OFFSET 8 +#define PINCTRL_DRIVE4_BANK1_PIN01_V (1 << 6) +#define PINCTRL_DRIVE4_BANK1_PIN01_MA_MASK (0x3 << 4) +#define PINCTRL_DRIVE4_BANK1_PIN01_MA_OFFSET 4 +#define PINCTRL_DRIVE4_BANK1_PIN00_V (1 << 2) +#define PINCTRL_DRIVE4_BANK1_PIN00_MA_MASK (0x3 << 0) +#define PINCTRL_DRIVE4_BANK1_PIN00_MA_OFFSET 0 + +#define PINCTRL_DRIVE5_BANK1_PIN15_V (1 << 30) +#define PINCTRL_DRIVE5_BANK1_PIN15_MA_MASK (0x3 << 28) +#define PINCTRL_DRIVE5_BANK1_PIN15_MA_OFFSET 28 +#define PINCTRL_DRIVE5_BANK1_PIN14_V (1 << 26) +#define PINCTRL_DRIVE5_BANK1_PIN14_MA_MASK (0x3 << 24) +#define PINCTRL_DRIVE5_BANK1_PIN14_MA_OFFSET 24 +#define PINCTRL_DRIVE5_BANK1_PIN13_V (1 << 22) +#define PINCTRL_DRIVE5_BANK1_PIN13_MA_MASK (0x3 << 20) +#define PINCTRL_DRIVE5_BANK1_PIN13_MA_OFFSET 20 +#define PINCTRL_DRIVE5_BANK1_PIN12_V (1 << 18) +#define PINCTRL_DRIVE5_BANK1_PIN12_MA_MASK (0x3 << 16) +#define PINCTRL_DRIVE5_BANK1_PIN12_MA_OFFSET 16 +#define PINCTRL_DRIVE5_BANK1_PIN11_V (1 << 14) +#define PINCTRL_DRIVE5_BANK1_PIN11_MA_MASK (0x3 << 12) +#define PINCTRL_DRIVE5_BANK1_PIN11_MA_OFFSET 12 +#define PINCTRL_DRIVE5_BANK1_PIN10_V (1 << 10) +#define PINCTRL_DRIVE5_BANK1_PIN10_MA_MASK (0x3 << 8) +#define PINCTRL_DRIVE5_BANK1_PIN10_MA_OFFSET 8 +#define PINCTRL_DRIVE5_BANK1_PIN09_V (1 << 6) +#define PINCTRL_DRIVE5_BANK1_PIN09_MA_MASK (0x3 << 4) +#define PINCTRL_DRIVE5_BANK1_PIN09_MA_OFFSET 4 +#define PINCTRL_DRIVE5_BANK1_PIN08_V (1 << 2) +#define PINCTRL_DRIVE5_BANK1_PIN08_MA_MASK (0x3 << 0) +#define PINCTRL_DRIVE5_BANK1_PIN08_MA_OFFSET 0 + +#define PINCTRL_DRIVE6_BANK1_PIN23_V (1 << 30) +#define PINCTRL_DRIVE6_BANK1_PIN23_MA_MASK (0x3 << 28) +#define PINCTRL_DRIVE6_BANK1_PIN23_MA_OFFSET 28 +#define PINCTRL_DRIVE6_BANK1_PIN22_V (1 << 26) +#define PINCTRL_DRIVE6_BANK1_PIN22_MA_MASK (0x3 << 24) +#define PINCTRL_DRIVE6_BANK1_PIN22_MA_OFFSET 24 +#define PINCTRL_DRIVE6_BANK1_PIN21_V (1 << 22) +#define PINCTRL_DRIVE6_BANK1_PIN21_MA_MASK (0x3 << 20) +#define PINCTRL_DRIVE6_BANK1_PIN21_MA_OFFSET 20 +#define PINCTRL_DRIVE6_BANK1_PIN20_V (1 << 18) +#define PINCTRL_DRIVE6_BANK1_PIN20_MA_MASK (0x3 << 16) +#define PINCTRL_DRIVE6_BANK1_PIN20_MA_OFFSET 16 +#define PINCTRL_DRIVE6_BANK1_PIN19_V (1 << 14) +#define PINCTRL_DRIVE6_BANK1_PIN19_MA_MASK (0x3 << 12) +#define PINCTRL_DRIVE6_BANK1_PIN19_MA_OFFSET 12 +#define PINCTRL_DRIVE6_BANK1_PIN18_V (1 << 10) +#define PINCTRL_DRIVE6_BANK1_PIN18_MA_MASK (0x3 << 8) +#define PINCTRL_DRIVE6_BANK1_PIN18_MA_OFFSET 8 +#define PINCTRL_DRIVE6_BANK1_PIN17_V (1 << 6) +#define PINCTRL_DRIVE6_BANK1_PIN17_MA_MASK (0x3 << 4) +#define PINCTRL_DRIVE6_BANK1_PIN17_MA_OFFSET 4 +#define PINCTRL_DRIVE6_BANK1_PIN16_V (1 << 2) +#define PINCTRL_DRIVE6_BANK1_PIN16_MA_MASK (0x3 << 0) +#define PINCTRL_DRIVE6_BANK1_PIN16_MA_OFFSET 0 + +#define PINCTRL_DRIVE7_BANK1_PIN31_V (1 << 30) +#define PINCTRL_DRIVE7_BANK1_PIN31_MA_MASK (0x3 << 28) +#define PINCTRL_DRIVE7_BANK1_PIN31_MA_OFFSET 28 +#define PINCTRL_DRIVE7_BANK1_PIN30_V (1 << 26) +#define PINCTRL_DRIVE7_BANK1_PIN30_MA_MASK (0x3 << 24) +#define PINCTRL_DRIVE7_BANK1_PIN30_MA_OFFSET 24 +#define PINCTRL_DRIVE7_BANK1_PIN29_V (1 << 22) +#define PINCTRL_DRIVE7_BANK1_PIN29_MA_MASK (0x3 << 20) +#define PINCTRL_DRIVE7_BANK1_PIN29_MA_OFFSET 20 +#define PINCTRL_DRIVE7_BANK1_PIN28_V (1 << 18) +#define PINCTRL_DRIVE7_BANK1_PIN28_MA_MASK (0x3 << 16) +#define PINCTRL_DRIVE7_BANK1_PIN28_MA_OFFSET 16 +#define PINCTRL_DRIVE7_BANK1_PIN27_V (1 << 14) +#define PINCTRL_DRIVE7_BANK1_PIN27_MA_MASK (0x3 << 12) +#define PINCTRL_DRIVE7_BANK1_PIN27_MA_OFFSET 12 +#define PINCTRL_DRIVE7_BANK1_PIN26_V (1 << 10) +#define PINCTRL_DRIVE7_BANK1_PIN26_MA_MASK (0x3 << 8) +#define PINCTRL_DRIVE7_BANK1_PIN26_MA_OFFSET 8 +#define PINCTRL_DRIVE7_BANK1_PIN25_V (1 << 6) +#define PINCTRL_DRIVE7_BANK1_PIN25_MA_MASK (0x3 << 4) +#define PINCTRL_DRIVE7_BANK1_PIN25_MA_OFFSET 4 +#define PINCTRL_DRIVE7_BANK1_PIN24_V (1 << 2) +#define PINCTRL_DRIVE7_BANK1_PIN24_MA_MASK (0x3 << 0) +#define PINCTRL_DRIVE7_BANK1_PIN24_MA_OFFSET 0 + +#define PINCTRL_DRIVE8_BANK2_PIN07_V (1 << 30) +#define PINCTRL_DRIVE8_BANK2_PIN07_MA_MASK (0x3 << 28) +#define PINCTRL_DRIVE8_BANK2_PIN07_MA_OFFSET 28 +#define PINCTRL_DRIVE8_BANK2_PIN06_V (1 << 26) +#define PINCTRL_DRIVE8_BANK2_PIN06_MA_MASK (0x3 << 24) +#define PINCTRL_DRIVE8_BANK2_PIN06_MA_OFFSET 24 +#define PINCTRL_DRIVE8_BANK2_PIN05_V (1 << 22) +#define PINCTRL_DRIVE8_BANK2_PIN05_MA_MASK (0x3 << 20) +#define PINCTRL_DRIVE8_BANK2_PIN05_MA_OFFSET 20 +#define PINCTRL_DRIVE8_BANK2_PIN04_V (1 << 18) +#define PINCTRL_DRIVE8_BANK2_PIN04_MA_MASK (0x3 << 16) +#define PINCTRL_DRIVE8_BANK2_PIN04_MA_OFFSET 16 +#define PINCTRL_DRIVE8_BANK2_PIN03_V (1 << 14) +#define PINCTRL_DRIVE8_BANK2_PIN03_MA_MASK (0x3 << 12) +#define PINCTRL_DRIVE8_BANK2_PIN03_MA_OFFSET 12 +#define PINCTRL_DRIVE8_BANK2_PIN02_V (1 << 10) +#define PINCTRL_DRIVE8_BANK2_PIN02_MA_MASK (0x3 << 8) +#define PINCTRL_DRIVE8_BANK2_PIN02_MA_OFFSET 8 +#define PINCTRL_DRIVE8_BANK2_PIN01_V (1 << 6) +#define PINCTRL_DRIVE8_BANK2_PIN01_MA_MASK (0x3 << 4) +#define PINCTRL_DRIVE8_BANK2_PIN01_MA_OFFSET 4 +#define PINCTRL_DRIVE8_BANK2_PIN00_V (1 << 2) +#define PINCTRL_DRIVE8_BANK2_PIN00_MA_MASK (0x3 << 0) +#define PINCTRL_DRIVE8_BANK2_PIN00_MA_OFFSET 0 + +#define PINCTRL_DRIVE9_BANK2_PIN15_V (1 << 30) +#define PINCTRL_DRIVE9_BANK2_PIN15_MA_MASK (0x3 << 28) +#define PINCTRL_DRIVE9_BANK2_PIN15_MA_OFFSET 28 +#define PINCTRL_DRIVE9_BANK2_PIN14_V (1 << 26) +#define PINCTRL_DRIVE9_BANK2_PIN14_MA_MASK (0x3 << 24) +#define PINCTRL_DRIVE9_BANK2_PIN14_MA_OFFSET 24 +#define PINCTRL_DRIVE9_BANK2_PIN13_V (1 << 22) +#define PINCTRL_DRIVE9_BANK2_PIN13_MA_MASK (0x3 << 20) +#define PINCTRL_DRIVE9_BANK2_PIN13_MA_OFFSET 20 +#define PINCTRL_DRIVE9_BANK2_PIN12_V (1 << 18) +#define PINCTRL_DRIVE9_BANK2_PIN12_MA_MASK (0x3 << 16) +#define PINCTRL_DRIVE9_BANK2_PIN12_MA_OFFSET 16 +#define PINCTRL_DRIVE9_BANK2_PIN10_V (1 << 10) +#define PINCTRL_DRIVE9_BANK2_PIN10_MA_MASK (0x3 << 8) +#define PINCTRL_DRIVE9_BANK2_PIN10_MA_OFFSET 8 +#define PINCTRL_DRIVE9_BANK2_PIN09_V (1 << 6) +#define PINCTRL_DRIVE9_BANK2_PIN09_MA_MASK (0x3 << 4) +#define PINCTRL_DRIVE9_BANK2_PIN09_MA_OFFSET 4 +#define PINCTRL_DRIVE9_BANK2_PIN08_V (1 << 2) +#define PINCTRL_DRIVE9_BANK2_PIN08_MA_MASK (0x3 << 0) +#define PINCTRL_DRIVE9_BANK2_PIN08_MA_OFFSET 0 + +#define PINCTRL_DRIVE10_BANK2_PIN21_V (1 << 22) +#define PINCTRL_DRIVE10_BANK2_PIN21_MA_MASK (0x3 << 20) +#define PINCTRL_DRIVE10_BANK2_PIN21_MA_OFFSET 20 +#define PINCTRL_DRIVE10_BANK2_PIN20_V (1 << 18) +#define PINCTRL_DRIVE10_BANK2_PIN20_MA_MASK (0x3 << 16) +#define PINCTRL_DRIVE10_BANK2_PIN20_MA_OFFSET 16 +#define PINCTRL_DRIVE10_BANK2_PIN19_V (1 << 14) +#define PINCTRL_DRIVE10_BANK2_PIN19_MA_MASK (0x3 << 12) +#define PINCTRL_DRIVE10_BANK2_PIN19_MA_OFFSET 12 +#define PINCTRL_DRIVE10_BANK2_PIN18_V (1 << 10) +#define PINCTRL_DRIVE10_BANK2_PIN18_MA_MASK (0x3 << 8) +#define PINCTRL_DRIVE10_BANK2_PIN18_MA_OFFSET 8 +#define PINCTRL_DRIVE10_BANK2_PIN17_V (1 << 6) +#define PINCTRL_DRIVE10_BANK2_PIN17_MA_MASK (0x3 << 4) +#define PINCTRL_DRIVE10_BANK2_PIN17_MA_OFFSET 4 +#define PINCTRL_DRIVE10_BANK2_PIN16_V (1 << 2) +#define PINCTRL_DRIVE10_BANK2_PIN16_MA_MASK (0x3 << 0) +#define PINCTRL_DRIVE10_BANK2_PIN16_MA_OFFSET 0 + +#define PINCTRL_DRIVE11_BANK2_PIN27_V (1 << 14) +#define PINCTRL_DRIVE11_BANK2_PIN27_MA_MASK (0x3 << 12) +#define PINCTRL_DRIVE11_BANK2_PIN27_MA_OFFSET 12 +#define PINCTRL_DRIVE11_BANK2_PIN26_V (1 << 10) +#define PINCTRL_DRIVE11_BANK2_PIN26_MA_MASK (0x3 << 8) +#define PINCTRL_DRIVE11_BANK2_PIN26_MA_OFFSET 8 +#define PINCTRL_DRIVE11_BANK2_PIN25_V (1 << 6) +#define PINCTRL_DRIVE11_BANK2_PIN25_MA_MASK (0x3 << 4) +#define PINCTRL_DRIVE11_BANK2_PIN25_MA_OFFSET 4 +#define PINCTRL_DRIVE11_BANK2_PIN24_V (1 << 2) +#define PINCTRL_DRIVE11_BANK2_PIN24_MA_MASK (0x3 << 0) +#define PINCTRL_DRIVE11_BANK2_PIN24_MA_OFFSET 0 + +#define PINCTRL_DRIVE12_BANK3_PIN07_V (1 << 30) +#define PINCTRL_DRIVE12_BANK3_PIN07_MA_MASK (0x3 << 28) +#define PINCTRL_DRIVE12_BANK3_PIN07_MA_OFFSET 28 +#define PINCTRL_DRIVE12_BANK3_PIN06_V (1 << 26) +#define PINCTRL_DRIVE12_BANK3_PIN06_MA_MASK (0x3 << 24) +#define PINCTRL_DRIVE12_BANK3_PIN06_MA_OFFSET 24 +#define PINCTRL_DRIVE12_BANK3_PIN05_V (1 << 22) +#define PINCTRL_DRIVE12_BANK3_PIN05_MA_MASK (0x3 << 20) +#define PINCTRL_DRIVE12_BANK3_PIN05_MA_OFFSET 20 +#define PINCTRL_DRIVE12_BANK3_PIN04_V (1 << 18) +#define PINCTRL_DRIVE12_BANK3_PIN04_MA_MASK (0x3 << 16) +#define PINCTRL_DRIVE12_BANK3_PIN04_MA_OFFSET 16 +#define PINCTRL_DRIVE12_BANK3_PIN03_V (1 << 14) +#define PINCTRL_DRIVE12_BANK3_PIN03_MA_MASK (0x3 << 12) +#define PINCTRL_DRIVE12_BANK3_PIN03_MA_OFFSET 12 +#define PINCTRL_DRIVE12_BANK3_PIN02_V (1 << 10) +#define PINCTRL_DRIVE12_BANK3_PIN02_MA_MASK (0x3 << 8) +#define PINCTRL_DRIVE12_BANK3_PIN02_MA_OFFSET 8 +#define PINCTRL_DRIVE12_BANK3_PIN01_V (1 << 6) +#define PINCTRL_DRIVE12_BANK3_PIN01_MA_MASK (0x3 << 4) +#define PINCTRL_DRIVE12_BANK3_PIN01_MA_OFFSET 4 +#define PINCTRL_DRIVE12_BANK3_PIN00_V (1 << 2) +#define PINCTRL_DRIVE12_BANK3_PIN00_MA_MASK (0x3 << 0) +#define PINCTRL_DRIVE12_BANK3_PIN00_MA_OFFSET 0 + +#define PINCTRL_DRIVE13_BANK3_PIN15_V (1 << 30) +#define PINCTRL_DRIVE13_BANK3_PIN15_MA_MASK (0x3 << 28) +#define PINCTRL_DRIVE13_BANK3_PIN15_MA_OFFSET 28 +#define PINCTRL_DRIVE13_BANK3_PIN14_V (1 << 26) +#define PINCTRL_DRIVE13_BANK3_PIN14_MA_MASK (0x3 << 24) +#define PINCTRL_DRIVE13_BANK3_PIN14_MA_OFFSET 24 +#define PINCTRL_DRIVE13_BANK3_PIN13_V (1 << 22) +#define PINCTRL_DRIVE13_BANK3_PIN13_MA_MASK (0x3 << 20) +#define PINCTRL_DRIVE13_BANK3_PIN13_MA_OFFSET 20 +#define PINCTRL_DRIVE13_BANK3_PIN12_V (1 << 18) +#define PINCTRL_DRIVE13_BANK3_PIN12_MA_MASK (0x3 << 16) +#define PINCTRL_DRIVE13_BANK3_PIN12_MA_OFFSET 16 +#define PINCTRL_DRIVE13_BANK3_PIN11_V (1 << 14) +#define PINCTRL_DRIVE13_BANK3_PIN11_MA_MASK (0x3 << 12) +#define PINCTRL_DRIVE13_BANK3_PIN11_MA_OFFSET 12 +#define PINCTRL_DRIVE13_BANK3_PIN10_V (1 << 10) +#define PINCTRL_DRIVE13_BANK3_PIN10_MA_MASK (0x3 << 8) +#define PINCTRL_DRIVE13_BANK3_PIN10_MA_OFFSET 8 +#define PINCTRL_DRIVE13_BANK3_PIN09_V (1 << 6) +#define PINCTRL_DRIVE13_BANK3_PIN09_MA_MASK (0x3 << 4) +#define PINCTRL_DRIVE13_BANK3_PIN09_MA_OFFSET 4 +#define PINCTRL_DRIVE13_BANK3_PIN08_V (1 << 2) +#define PINCTRL_DRIVE13_BANK3_PIN08_MA_MASK (0x3 << 0) +#define PINCTRL_DRIVE13_BANK3_PIN08_MA_OFFSET 0 + +#define PINCTRL_DRIVE14_BANK3_PIN23_V (1 << 30) +#define PINCTRL_DRIVE14_BANK3_PIN23_MA_MASK (0x3 << 28) +#define PINCTRL_DRIVE14_BANK3_PIN23_MA_OFFSET 28 +#define PINCTRL_DRIVE14_BANK3_PIN22_V (1 << 26) +#define PINCTRL_DRIVE14_BANK3_PIN22_MA_MASK (0x3 << 24) +#define PINCTRL_DRIVE14_BANK3_PIN22_MA_OFFSET 24 +#define PINCTRL_DRIVE14_BANK3_PIN21_V (1 << 22) +#define PINCTRL_DRIVE14_BANK3_PIN21_MA_MASK (0x3 << 20) +#define PINCTRL_DRIVE14_BANK3_PIN21_MA_OFFSET 20 +#define PINCTRL_DRIVE14_BANK3_PIN20_V (1 << 18) +#define PINCTRL_DRIVE14_BANK3_PIN20_MA_MASK (0x3 << 16) +#define PINCTRL_DRIVE14_BANK3_PIN20_MA_OFFSET 16 +#define PINCTRL_DRIVE14_BANK3_PIN18_V (1 << 10) +#define PINCTRL_DRIVE14_BANK3_PIN18_MA_MASK (0x3 << 8) +#define PINCTRL_DRIVE14_BANK3_PIN18_MA_OFFSET 8 +#define PINCTRL_DRIVE14_BANK3_PIN17_V (1 << 6) +#define PINCTRL_DRIVE14_BANK3_PIN17_MA_MASK (0x3 << 4) +#define PINCTRL_DRIVE14_BANK3_PIN17_MA_OFFSET 4 +#define PINCTRL_DRIVE14_BANK3_PIN16_V (1 << 2) +#define PINCTRL_DRIVE14_BANK3_PIN16_MA_MASK (0x3 << 0) +#define PINCTRL_DRIVE14_BANK3_PIN16_MA_OFFSET 0 + +#define PINCTRL_DRIVE15_BANK3_PIN30_V (1 << 26) +#define PINCTRL_DRIVE15_BANK3_PIN30_MA_MASK (0x3 << 24) +#define PINCTRL_DRIVE15_BANK3_PIN30_MA_OFFSET 24 +#define PINCTRL_DRIVE15_BANK3_PIN29_V (1 << 22) +#define PINCTRL_DRIVE15_BANK3_PIN29_MA_MASK (0x3 << 20) +#define PINCTRL_DRIVE15_BANK3_PIN29_MA_OFFSET 20 +#define PINCTRL_DRIVE15_BANK3_PIN28_V (1 << 18) +#define PINCTRL_DRIVE15_BANK3_PIN28_MA_MASK (0x3 << 16) +#define PINCTRL_DRIVE15_BANK3_PIN28_MA_OFFSET 16 +#define PINCTRL_DRIVE15_BANK3_PIN27_V (1 << 14) +#define PINCTRL_DRIVE15_BANK3_PIN27_MA_MASK (0x3 << 12) +#define PINCTRL_DRIVE15_BANK3_PIN27_MA_OFFSET 12 +#define PINCTRL_DRIVE15_BANK3_PIN26_V (1 << 10) +#define PINCTRL_DRIVE15_BANK3_PIN26_MA_MASK (0x3 << 8) +#define PINCTRL_DRIVE15_BANK3_PIN26_MA_OFFSET 8 +#define PINCTRL_DRIVE15_BANK3_PIN25_V (1 << 6) +#define PINCTRL_DRIVE15_BANK3_PIN25_MA_MASK (0x3 << 4) +#define PINCTRL_DRIVE15_BANK3_PIN25_MA_OFFSET 4 +#define PINCTRL_DRIVE15_BANK3_PIN24_V (1 << 2) +#define PINCTRL_DRIVE15_BANK3_PIN24_MA_MASK (0x3 << 0) +#define PINCTRL_DRIVE15_BANK3_PIN24_MA_OFFSET 0 + +#define PINCTRL_DRIVE16_BANK4_PIN07_V (1 << 30) +#define PINCTRL_DRIVE16_BANK4_PIN07_MA_MASK (0x3 << 28) +#define PINCTRL_DRIVE16_BANK4_PIN07_MA_OFFSET 28 +#define PINCTRL_DRIVE16_BANK4_PIN06_V (1 << 26) +#define PINCTRL_DRIVE16_BANK4_PIN06_MA_MASK (0x3 << 24) +#define PINCTRL_DRIVE16_BANK4_PIN06_MA_OFFSET 24 +#define PINCTRL_DRIVE16_BANK4_PIN05_V (1 << 22) +#define PINCTRL_DRIVE16_BANK4_PIN05_MA_MASK (0x3 << 20) +#define PINCTRL_DRIVE16_BANK4_PIN05_MA_OFFSET 20 +#define PINCTRL_DRIVE16_BANK4_PIN04_V (1 << 18) +#define PINCTRL_DRIVE16_BANK4_PIN04_MA_MASK (0x3 << 16) +#define PINCTRL_DRIVE16_BANK4_PIN04_MA_OFFSET 16 +#define PINCTRL_DRIVE16_BANK4_PIN03_V (1 << 14) +#define PINCTRL_DRIVE16_BANK4_PIN03_MA_MASK (0x3 << 12) +#define PINCTRL_DRIVE16_BANK4_PIN03_MA_OFFSET 12 +#define PINCTRL_DRIVE16_BANK4_PIN02_V (1 << 10) +#define PINCTRL_DRIVE16_BANK4_PIN02_MA_MASK (0x3 << 8) +#define PINCTRL_DRIVE16_BANK4_PIN02_MA_OFFSET 8 +#define PINCTRL_DRIVE16_BANK4_PIN01_V (1 << 6) +#define PINCTRL_DRIVE16_BANK4_PIN01_MA_MASK (0x3 << 4) +#define PINCTRL_DRIVE16_BANK4_PIN01_MA_OFFSET 4 +#define PINCTRL_DRIVE16_BANK4_PIN00_V (1 << 2) +#define PINCTRL_DRIVE16_BANK4_PIN00_MA_MASK (0x3 << 0) +#define PINCTRL_DRIVE16_BANK4_PIN00_MA_OFFSET 0 + +#define PINCTRL_DRIVE17_BANK4_PIN15_V (1 << 30) +#define PINCTRL_DRIVE17_BANK4_PIN15_MA_MASK (0x3 << 28) +#define PINCTRL_DRIVE17_BANK4_PIN15_MA_OFFSET 28 +#define PINCTRL_DRIVE17_BANK4_PIN14_V (1 << 26) +#define PINCTRL_DRIVE17_BANK4_PIN14_MA_MASK (0x3 << 24) +#define PINCTRL_DRIVE17_BANK4_PIN14_MA_OFFSET 24 +#define PINCTRL_DRIVE17_BANK4_PIN13_V (1 << 22) +#define PINCTRL_DRIVE17_BANK4_PIN13_MA_MASK (0x3 << 20) +#define PINCTRL_DRIVE17_BANK4_PIN13_MA_OFFSET 20 +#define PINCTRL_DRIVE17_BANK4_PIN12_V (1 << 18) +#define PINCTRL_DRIVE17_BANK4_PIN12_MA_MASK (0x3 << 16) +#define PINCTRL_DRIVE17_BANK4_PIN12_MA_OFFSET 16 +#define PINCTRL_DRIVE17_BANK4_PIN11_V (1 << 14) +#define PINCTRL_DRIVE17_BANK4_PIN11_MA_MASK (0x3 << 12) +#define PINCTRL_DRIVE17_BANK4_PIN11_MA_OFFSET 12 +#define PINCTRL_DRIVE17_BANK4_PIN10_V (1 << 10) +#define PINCTRL_DRIVE17_BANK4_PIN10_MA_MASK (0x3 << 8) +#define PINCTRL_DRIVE17_BANK4_PIN10_MA_OFFSET 8 +#define PINCTRL_DRIVE17_BANK4_PIN09_V (1 << 6) +#define PINCTRL_DRIVE17_BANK4_PIN09_MA_MASK (0x3 << 4) +#define PINCTRL_DRIVE17_BANK4_PIN09_MA_OFFSET 4 +#define PINCTRL_DRIVE17_BANK4_PIN08_V (1 << 2) +#define PINCTRL_DRIVE17_BANK4_PIN08_MA_MASK (0x3 << 0) +#define PINCTRL_DRIVE17_BANK4_PIN08_MA_OFFSET 0 + +#define PINCTRL_DRIVE18_BANK4_PIN20_V (1 << 18) +#define PINCTRL_DRIVE18_BANK4_PIN20_MA_MASK (0x3 << 16) +#define PINCTRL_DRIVE18_BANK4_PIN20_MA_OFFSET 16 +#define PINCTRL_DRIVE18_BANK4_PIN16_V (1 << 2) +#define PINCTRL_DRIVE18_BANK4_PIN16_MA_MASK (0x3 << 0) +#define PINCTRL_DRIVE18_BANK4_PIN16_MA_OFFSET 0 + +#define PINCTRL_PULL0_BANK0_PIN28 (1 << 28) +#define PINCTRL_PULL0_BANK0_PIN27 (1 << 27) +#define PINCTRL_PULL0_BANK0_PIN26 (1 << 26) +#define PINCTRL_PULL0_BANK0_PIN25 (1 << 25) +#define PINCTRL_PULL0_BANK0_PIN24 (1 << 24) +#define PINCTRL_PULL0_BANK0_PIN23 (1 << 23) +#define PINCTRL_PULL0_BANK0_PIN22 (1 << 22) +#define PINCTRL_PULL0_BANK0_PIN21 (1 << 21) +#define PINCTRL_PULL0_BANK0_PIN20 (1 << 20) +#define PINCTRL_PULL0_BANK0_PIN19 (1 << 19) +#define PINCTRL_PULL0_BANK0_PIN18 (1 << 18) +#define PINCTRL_PULL0_BANK0_PIN17 (1 << 17) +#define PINCTRL_PULL0_BANK0_PIN16 (1 << 16) +#define PINCTRL_PULL0_BANK0_PIN07 (1 << 7) +#define PINCTRL_PULL0_BANK0_PIN06 (1 << 6) +#define PINCTRL_PULL0_BANK0_PIN05 (1 << 5) +#define PINCTRL_PULL0_BANK0_PIN04 (1 << 4) +#define PINCTRL_PULL0_BANK0_PIN03 (1 << 3) +#define PINCTRL_PULL0_BANK0_PIN02 (1 << 2) +#define PINCTRL_PULL0_BANK0_PIN01 (1 << 1) +#define PINCTRL_PULL0_BANK0_PIN00 (1 << 0) + +#define PINCTRL_PULL1_BANK1_PIN31 (1 << 31) +#define PINCTRL_PULL1_BANK1_PIN30 (1 << 30) +#define PINCTRL_PULL1_BANK1_PIN29 (1 << 29) +#define PINCTRL_PULL1_BANK1_PIN28 (1 << 28) +#define PINCTRL_PULL1_BANK1_PIN27 (1 << 27) +#define PINCTRL_PULL1_BANK1_PIN26 (1 << 26) +#define PINCTRL_PULL1_BANK1_PIN25 (1 << 25) +#define PINCTRL_PULL1_BANK1_PIN24 (1 << 24) +#define PINCTRL_PULL1_BANK1_PIN23 (1 << 23) +#define PINCTRL_PULL1_BANK1_PIN22 (1 << 22) +#define PINCTRL_PULL1_BANK1_PIN21 (1 << 21) +#define PINCTRL_PULL1_BANK1_PIN20 (1 << 20) +#define PINCTRL_PULL1_BANK1_PIN19 (1 << 19) +#define PINCTRL_PULL1_BANK1_PIN18 (1 << 18) +#define PINCTRL_PULL1_BANK1_PIN17 (1 << 17) +#define PINCTRL_PULL1_BANK1_PIN16 (1 << 16) +#define PINCTRL_PULL1_BANK1_PIN15 (1 << 15) +#define PINCTRL_PULL1_BANK1_PIN14 (1 << 14) +#define PINCTRL_PULL1_BANK1_PIN13 (1 << 13) +#define PINCTRL_PULL1_BANK1_PIN12 (1 << 12) +#define PINCTRL_PULL1_BANK1_PIN11 (1 << 11) +#define PINCTRL_PULL1_BANK1_PIN10 (1 << 10) +#define PINCTRL_PULL1_BANK1_PIN09 (1 << 9) +#define PINCTRL_PULL1_BANK1_PIN08 (1 << 8) +#define PINCTRL_PULL1_BANK1_PIN07 (1 << 7) +#define PINCTRL_PULL1_BANK1_PIN06 (1 << 6) +#define PINCTRL_PULL1_BANK1_PIN05 (1 << 5) +#define PINCTRL_PULL1_BANK1_PIN04 (1 << 4) +#define PINCTRL_PULL1_BANK1_PIN03 (1 << 3) +#define PINCTRL_PULL1_BANK1_PIN02 (1 << 2) +#define PINCTRL_PULL1_BANK1_PIN01 (1 << 1) +#define PINCTRL_PULL1_BANK1_PIN00 (1 << 0) + +#define PINCTRL_PULL2_BANK2_PIN27 (1 << 27) +#define PINCTRL_PULL2_BANK2_PIN26 (1 << 26) +#define PINCTRL_PULL2_BANK2_PIN25 (1 << 25) +#define PINCTRL_PULL2_BANK2_PIN24 (1 << 24) +#define PINCTRL_PULL2_BANK2_PIN21 (1 << 21) +#define PINCTRL_PULL2_BANK2_PIN20 (1 << 20) +#define PINCTRL_PULL2_BANK2_PIN19 (1 << 19) +#define PINCTRL_PULL2_BANK2_PIN18 (1 << 18) +#define PINCTRL_PULL2_BANK2_PIN17 (1 << 17) +#define PINCTRL_PULL2_BANK2_PIN16 (1 << 16) +#define PINCTRL_PULL2_BANK2_PIN15 (1 << 15) +#define PINCTRL_PULL2_BANK2_PIN14 (1 << 14) +#define PINCTRL_PULL2_BANK2_PIN13 (1 << 13) +#define PINCTRL_PULL2_BANK2_PIN12 (1 << 12) +#define PINCTRL_PULL2_BANK2_PIN10 (1 << 10) +#define PINCTRL_PULL2_BANK2_PIN09 (1 << 9) +#define PINCTRL_PULL2_BANK2_PIN08 (1 << 8) +#define PINCTRL_PULL2_BANK2_PIN07 (1 << 7) +#define PINCTRL_PULL2_BANK2_PIN06 (1 << 6) +#define PINCTRL_PULL2_BANK2_PIN05 (1 << 5) +#define PINCTRL_PULL2_BANK2_PIN04 (1 << 4) +#define PINCTRL_PULL2_BANK2_PIN03 (1 << 3) +#define PINCTRL_PULL2_BANK2_PIN02 (1 << 2) +#define PINCTRL_PULL2_BANK2_PIN01 (1 << 1) +#define PINCTRL_PULL2_BANK2_PIN00 (1 << 0) + +#define PINCTRL_PULL3_BANK3_PIN30 (1 << 30) +#define PINCTRL_PULL3_BANK3_PIN29 (1 << 29) +#define PINCTRL_PULL3_BANK3_PIN28 (1 << 28) +#define PINCTRL_PULL3_BANK3_PIN27 (1 << 27) +#define PINCTRL_PULL3_BANK3_PIN26 (1 << 26) +#define PINCTRL_PULL3_BANK3_PIN25 (1 << 25) +#define PINCTRL_PULL3_BANK3_PIN24 (1 << 24) +#define PINCTRL_PULL3_BANK3_PIN23 (1 << 23) +#define PINCTRL_PULL3_BANK3_PIN22 (1 << 22) +#define PINCTRL_PULL3_BANK3_PIN21 (1 << 21) +#define PINCTRL_PULL3_BANK3_PIN20 (1 << 20) +#define PINCTRL_PULL3_BANK3_PIN18 (1 << 18) +#define PINCTRL_PULL3_BANK3_PIN17 (1 << 17) +#define PINCTRL_PULL3_BANK3_PIN16 (1 << 16) +#define PINCTRL_PULL3_BANK3_PIN15 (1 << 15) +#define PINCTRL_PULL3_BANK3_PIN14 (1 << 14) +#define PINCTRL_PULL3_BANK3_PIN13 (1 << 13) +#define PINCTRL_PULL3_BANK3_PIN12 (1 << 12) +#define PINCTRL_PULL3_BANK3_PIN11 (1 << 11) +#define PINCTRL_PULL3_BANK3_PIN10 (1 << 10) +#define PINCTRL_PULL3_BANK3_PIN09 (1 << 9) +#define PINCTRL_PULL3_BANK3_PIN08 (1 << 8) +#define PINCTRL_PULL3_BANK3_PIN07 (1 << 7) +#define PINCTRL_PULL3_BANK3_PIN06 (1 << 6) +#define PINCTRL_PULL3_BANK3_PIN05 (1 << 5) +#define PINCTRL_PULL3_BANK3_PIN04 (1 << 4) +#define PINCTRL_PULL3_BANK3_PIN03 (1 << 3) +#define PINCTRL_PULL3_BANK3_PIN02 (1 << 2) +#define PINCTRL_PULL3_BANK3_PIN01 (1 << 1) +#define PINCTRL_PULL3_BANK3_PIN00 (1 << 0) + +#define PINCTRL_PULL4_BANK4_PIN20 (1 << 20) +#define PINCTRL_PULL4_BANK4_PIN16 (1 << 16) +#define PINCTRL_PULL4_BANK4_PIN15 (1 << 15) +#define PINCTRL_PULL4_BANK4_PIN14 (1 << 14) +#define PINCTRL_PULL4_BANK4_PIN13 (1 << 13) +#define PINCTRL_PULL4_BANK4_PIN12 (1 << 12) +#define PINCTRL_PULL4_BANK4_PIN11 (1 << 11) +#define PINCTRL_PULL4_BANK4_PIN10 (1 << 10) +#define PINCTRL_PULL4_BANK4_PIN09 (1 << 9) +#define PINCTRL_PULL4_BANK4_PIN08 (1 << 8) +#define PINCTRL_PULL4_BANK4_PIN07 (1 << 7) +#define PINCTRL_PULL4_BANK4_PIN06 (1 << 6) +#define PINCTRL_PULL4_BANK4_PIN05 (1 << 5) +#define PINCTRL_PULL4_BANK4_PIN04 (1 << 4) +#define PINCTRL_PULL4_BANK4_PIN03 (1 << 3) +#define PINCTRL_PULL4_BANK4_PIN02 (1 << 2) +#define PINCTRL_PULL4_BANK4_PIN01 (1 << 1) +#define PINCTRL_PULL4_BANK4_PIN00 (1 << 0) + +#define PINCTRL_PULL5_BANK5_PIN26 (1 << 26) +#define PINCTRL_PULL5_BANK5_PIN23 (1 << 23) +#define PINCTRL_PULL5_BANK5_PIN22 (1 << 22) +#define PINCTRL_PULL5_BANK5_PIN21 (1 << 21) +#define PINCTRL_PULL5_BANK5_PIN20 (1 << 20) +#define PINCTRL_PULL5_BANK5_PIN19 (1 << 19) +#define PINCTRL_PULL5_BANK5_PIN18 (1 << 18) +#define PINCTRL_PULL5_BANK5_PIN17 (1 << 17) +#define PINCTRL_PULL5_BANK5_PIN16 (1 << 16) +#define PINCTRL_PULL5_BANK5_PIN15 (1 << 15) +#define PINCTRL_PULL5_BANK5_PIN14 (1 << 14) +#define PINCTRL_PULL5_BANK5_PIN13 (1 << 13) +#define PINCTRL_PULL5_BANK5_PIN12 (1 << 12) +#define PINCTRL_PULL5_BANK5_PIN11 (1 << 11) +#define PINCTRL_PULL5_BANK5_PIN10 (1 << 10) +#define PINCTRL_PULL5_BANK5_PIN09 (1 << 9) +#define PINCTRL_PULL5_BANK5_PIN08 (1 << 8) +#define PINCTRL_PULL5_BANK5_PIN07 (1 << 7) +#define PINCTRL_PULL5_BANK5_PIN06 (1 << 6) +#define PINCTRL_PULL5_BANK5_PIN05 (1 << 5) +#define PINCTRL_PULL5_BANK5_PIN04 (1 << 4) +#define PINCTRL_PULL5_BANK5_PIN03 (1 << 3) +#define PINCTRL_PULL5_BANK5_PIN02 (1 << 2) +#define PINCTRL_PULL5_BANK5_PIN01 (1 << 1) +#define PINCTRL_PULL5_BANK5_PIN00 (1 << 0) + +#define PINCTRL_PULL6_BANK6_PIN24 (1 << 24) +#define PINCTRL_PULL6_BANK6_PIN23 (1 << 23) +#define PINCTRL_PULL6_BANK6_PIN22 (1 << 22) +#define PINCTRL_PULL6_BANK6_PIN21 (1 << 21) +#define PINCTRL_PULL6_BANK6_PIN20 (1 << 20) +#define PINCTRL_PULL6_BANK6_PIN19 (1 << 19) +#define PINCTRL_PULL6_BANK6_PIN18 (1 << 18) +#define PINCTRL_PULL6_BANK6_PIN17 (1 << 17) +#define PINCTRL_PULL6_BANK6_PIN16 (1 << 16) +#define PINCTRL_PULL6_BANK6_PIN14 (1 << 14) +#define PINCTRL_PULL6_BANK6_PIN13 (1 << 13) +#define PINCTRL_PULL6_BANK6_PIN12 (1 << 12) +#define PINCTRL_PULL6_BANK6_PIN11 (1 << 11) +#define PINCTRL_PULL6_BANK6_PIN10 (1 << 10) +#define PINCTRL_PULL6_BANK6_PIN09 (1 << 9) +#define PINCTRL_PULL6_BANK6_PIN08 (1 << 8) +#define PINCTRL_PULL6_BANK6_PIN07 (1 << 7) +#define PINCTRL_PULL6_BANK6_PIN06 (1 << 6) +#define PINCTRL_PULL6_BANK6_PIN05 (1 << 5) +#define PINCTRL_PULL6_BANK6_PIN04 (1 << 4) +#define PINCTRL_PULL6_BANK6_PIN03 (1 << 3) +#define PINCTRL_PULL6_BANK6_PIN02 (1 << 2) +#define PINCTRL_PULL6_BANK6_PIN01 (1 << 1) +#define PINCTRL_PULL6_BANK6_PIN00 (1 << 0) + +#define PINCTRL_DOUT0_DOUT_MASK 0x1fffffff +#define PINCTRL_DOUT0_DOUT_OFFSET 0 + +#define PINCTRL_DOUT1_DOUT_MASK 0xffffffff +#define PINCTRL_DOUT1_DOUT_OFFSET 0 + +#define PINCTRL_DOUT2_DOUT_MASK 0xfffffff +#define PINCTRL_DOUT2_DOUT_OFFSET 0 + +#define PINCTRL_DOUT3_DOUT_MASK 0x7fffffff +#define PINCTRL_DOUT3_DOUT_OFFSET 0 + +#define PINCTRL_DOUT4_DOUT_MASK 0x1fffff +#define PINCTRL_DOUT4_DOUT_OFFSET 0 + +#define PINCTRL_DIN0_DIN_MASK 0x1fffffff +#define PINCTRL_DIN0_DIN_OFFSET 0 + +#define PINCTRL_DIN1_DIN_MASK 0xffffffff +#define PINCTRL_DIN1_DIN_OFFSET 0 + +#define PINCTRL_DIN2_DIN_MASK 0xfffffff +#define PINCTRL_DIN2_DIN_OFFSET 0 + +#define PINCTRL_DIN3_DIN_MASK 0x7fffffff +#define PINCTRL_DIN3_DIN_OFFSET 0 + +#define PINCTRL_DIN4_DIN_MASK 0x1fffff +#define PINCTRL_DIN4_DIN_OFFSET 0 + +#define PINCTRL_DOE0_DOE_MASK 0x1fffffff +#define PINCTRL_DOE0_DOE_OFFSET 0 + +#define PINCTRL_DOE1_DOE_MASK 0xffffffff +#define PINCTRL_DOE1_DOE_OFFSET 0 + +#define PINCTRL_DOE2_DOE_MASK 0xfffffff +#define PINCTRL_DOE2_DOE_OFFSET 0 + +#define PINCTRL_DOE3_DOE_MASK 0x7fffffff +#define PINCTRL_DOE3_DOE_OFFSET 0 + +#define PINCTRL_DOE4_DOE_MASK 0x1fffff +#define PINCTRL_DOE4_DOE_OFFSET 0 + +#define PINCTRL_PIN2IRQ0_PIN2IRQ_MASK 0x1fffffff +#define PINCTRL_PIN2IRQ0_PIN2IRQ_OFFSET 0 + +#define PINCTRL_PIN2IRQ1_PIN2IRQ_MASK 0xffffffff +#define PINCTRL_PIN2IRQ1_PIN2IRQ_OFFSET 0 + +#define PINCTRL_PIN2IRQ2_PIN2IRQ_MASK 0xfffffff +#define PINCTRL_PIN2IRQ2_PIN2IRQ_OFFSET 0 + +#define PINCTRL_PIN2IRQ3_PIN2IRQ_MASK 0x7fffffff +#define PINCTRL_PIN2IRQ3_PIN2IRQ_OFFSET 0 + +#define PINCTRL_PIN2IRQ4_PIN2IRQ_MASK 0x1fffff +#define PINCTRL_PIN2IRQ4_PIN2IRQ_OFFSET 0 + +#define PINCTRL_IRQEN0_IRQEN_MASK 0x1fffffff +#define PINCTRL_IRQEN0_IRQEN_OFFSET 0 + +#define PINCTRL_IRQEN1_IRQEN_MASK 0xffffffff +#define PINCTRL_IRQEN1_IRQEN_OFFSET 0 + +#define PINCTRL_IRQEN2_IRQEN_MASK 0xfffffff +#define PINCTRL_IRQEN2_IRQEN_OFFSET 0 + +#define PINCTRL_IRQEN3_IRQEN_MASK 0x7fffffff +#define PINCTRL_IRQEN3_IRQEN_OFFSET 0 + +#define PINCTRL_IRQEN4_IRQEN_MASK 0x1fffff +#define PINCTRL_IRQEN4_IRQEN_OFFSET 0 + +#define PINCTRL_IRQLEVEL0_IRQLEVEL_MASK 0x1fffffff +#define PINCTRL_IRQLEVEL0_IRQLEVEL_OFFSET 0 + +#define PINCTRL_IRQLEVEL1_IRQLEVEL_MASK 0xffffffff +#define PINCTRL_IRQLEVEL1_IRQLEVEL_OFFSET 0 + +#define PINCTRL_IRQLEVEL2_IRQLEVEL_MASK 0xfffffff +#define PINCTRL_IRQLEVEL2_IRQLEVEL_OFFSET 0 + +#define PINCTRL_IRQLEVEL3_IRQLEVEL_MASK 0x7fffffff +#define PINCTRL_IRQLEVEL3_IRQLEVEL_OFFSET 0 + +#define PINCTRL_IRQLEVEL4_IRQLEVEL_MASK 0x1fffff +#define PINCTRL_IRQLEVEL4_IRQLEVEL_OFFSET 0 + +#define PINCTRL_IRQPOL0_IRQPOL_MASK 0x1fffffff +#define PINCTRL_IRQPOL0_IRQPOL_OFFSET 0 + +#define PINCTRL_IRQPOL1_IRQPOL_MASK 0xffffffff +#define PINCTRL_IRQPOL1_IRQPOL_OFFSET 0 + +#define PINCTRL_IRQPOL2_IRQPOL_MASK 0xfffffff +#define PINCTRL_IRQPOL2_IRQPOL_OFFSET 0 + +#define PINCTRL_IRQPOL3_IRQPOL_MASK 0x7fffffff +#define PINCTRL_IRQPOL3_IRQPOL_OFFSET 0 + +#define PINCTRL_IRQPOL4_IRQPOL_MASK 0x1fffff +#define PINCTRL_IRQPOL4_IRQPOL_OFFSET 0 + +#define PINCTRL_IRQSTAT0_IRQSTAT_MASK 0x1fffffff +#define PINCTRL_IRQSTAT0_IRQSTAT_OFFSET 0 + +#define PINCTRL_IRQSTAT1_IRQSTAT_MASK 0xffffffff +#define PINCTRL_IRQSTAT1_IRQSTAT_OFFSET 0 + +#define PINCTRL_IRQSTAT2_IRQSTAT_MASK 0xfffffff +#define PINCTRL_IRQSTAT2_IRQSTAT_OFFSET 0 + +#define PINCTRL_IRQSTAT3_IRQSTAT_MASK 0x7fffffff +#define PINCTRL_IRQSTAT3_IRQSTAT_OFFSET 0 + +#define PINCTRL_IRQSTAT4_IRQSTAT_MASK 0x1fffff +#define PINCTRL_IRQSTAT4_IRQSTAT_OFFSET 0 + +#define PINCTRL_EMI_ODT_CTRL_ADDRESS_CALIB_MASK (0x3 << 26) +#define PINCTRL_EMI_ODT_CTRL_ADDRESS_CALIB_OFFSET 26 +#define PINCTRL_EMI_ODT_CTRL_ADDRESS_TLOAD_MASK (0x3 << 24) +#define PINCTRL_EMI_ODT_CTRL_ADDRESS_TLOAD_OFFSET 24 +#define PINCTRL_EMI_ODT_CTRL_CONTROL_CALIB_MASK (0x3 << 22) +#define PINCTRL_EMI_ODT_CTRL_CONTROL_CALIB_OFFSET 22 +#define PINCTRL_EMI_ODT_CTRL_CONTROL_TLOAD_MASK (0x3 << 20) +#define PINCTRL_EMI_ODT_CTRL_CONTROL_TLOAD_OFFSET 20 +#define PINCTRL_EMI_ODT_CTRL_DUALPAD_CALIB_MASK (0x3 << 18) +#define PINCTRL_EMI_ODT_CTRL_DUALPAD_CALIB_OFFSET 18 +#define PINCTRL_EMI_ODT_CTRL_DUALPAD_TLOAD_MASK (0x3 << 16) +#define PINCTRL_EMI_ODT_CTRL_DUALPAD_TLOAD_OFFSET 16 +#define PINCTRL_EMI_ODT_CTRL_SLICE3_CALIB_MASK (0x3 << 14) +#define PINCTRL_EMI_ODT_CTRL_SLICE3_CALIB_OFFSET 14 +#define PINCTRL_EMI_ODT_CTRL_SLICE3_TLOAD_MASK (0x3 << 12) +#define PINCTRL_EMI_ODT_CTRL_SLICE3_TLOAD_OFFSET 12 +#define PINCTRL_EMI_ODT_CTRL_SLICE2_CALIB_MASK (0x3 << 10) +#define PINCTRL_EMI_ODT_CTRL_SLICE2_CALIB_OFFSET 10 +#define PINCTRL_EMI_ODT_CTRL_SLICE2_TLOAD_MASK (0x3 << 8) +#define PINCTRL_EMI_ODT_CTRL_SLICE2_TLOAD_OFFSET 8 +#define PINCTRL_EMI_ODT_CTRL_SLICE1_CALIB_MASK (0x3 << 6) +#define PINCTRL_EMI_ODT_CTRL_SLICE1_CALIB_OFFSET 6 +#define PINCTRL_EMI_ODT_CTRL_SLICE1_TLOAD_MASK (0x3 << 4) +#define PINCTRL_EMI_ODT_CTRL_SLICE1_TLOAD_OFFSET 4 +#define PINCTRL_EMI_ODT_CTRL_SLICE0_CALIB_MASK (0x3 << 2) +#define PINCTRL_EMI_ODT_CTRL_SLICE0_CALIB_OFFSET 2 +#define PINCTRL_EMI_ODT_CTRL_SLICE0_TLOAD_MASK (0x3 << 0) +#define PINCTRL_EMI_ODT_CTRL_SLICE0_TLOAD_OFFSET 0 + +#define PINCTRL_EMI_DS_CTRL_DDR_MODE_MASK (0x3 << 16) +#define PINCTRL_EMI_DS_CTRL_DDR_MODE_OFFSET 16 +#define PINCTRL_EMI_DS_CTRL_DDR_MODE_mDDR (0x0 << 16) +#define PINCTRL_EMI_DS_CTRL_DDR_MODE_GPIO (0x1 << 16) +#define PINCTRL_EMI_DS_CTRL_DDR_MODE_LVDDR2 (0x2 << 16) +#define PINCTRL_EMI_DS_CTRL_DDR_MODE_DDR2 (0x3 << 16) +#define PINCTRL_EMI_DS_CTRL_ADDRESS_MA_MASK (0x3 << 12) +#define PINCTRL_EMI_DS_CTRL_ADDRESS_MA_OFFSET 12 +#define PINCTRL_EMI_DS_CTRL_CONTROL_MA_MASK (0x3 << 10) +#define PINCTRL_EMI_DS_CTRL_CONTROL_MA_OFFSET 10 +#define PINCTRL_EMI_DS_CTRL_DUALPAD_MA_MASK (0x3 << 8) +#define PINCTRL_EMI_DS_CTRL_DUALPAD_MA_OFFSET 8 +#define PINCTRL_EMI_DS_CTRL_SLICE3_MA_MASK (0x3 << 6) +#define PINCTRL_EMI_DS_CTRL_SLICE3_MA_OFFSET 6 +#define PINCTRL_EMI_DS_CTRL_SLICE2_MA_MASK (0x3 << 4) +#define PINCTRL_EMI_DS_CTRL_SLICE2_MA_OFFSET 4 +#define PINCTRL_EMI_DS_CTRL_SLICE1_MA_MASK (0x3 << 2) +#define PINCTRL_EMI_DS_CTRL_SLICE1_MA_OFFSET 2 +#define PINCTRL_EMI_DS_CTRL_SLICE0_MA_MASK (0x3 << 0) +#define PINCTRL_EMI_DS_CTRL_SLICE0_MA_OFFSET 0 + +#endif /* __MX28_REGS_PINCTRL_H__ */ diff --git a/arch/arm/include/asm/arch-mxs/regs-power.h b/arch/arm/include/asm/arch-mxs/regs-power.h new file mode 100644 index 0000000..8eadc6d --- /dev/null +++ b/arch/arm/include/asm/arch-mxs/regs-power.h @@ -0,0 +1,413 @@ +/* + * Freescale i.MX28 Power Controller Register Definitions + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __MX28_REGS_POWER_H__ +#define __MX28_REGS_POWER_H__ + +#include <asm/arch/regs-common.h> + +#ifndef __ASSEMBLY__ +struct mx28_power_regs { + mx28_reg_32(hw_power_ctrl) + mx28_reg_32(hw_power_5vctrl) + mx28_reg_32(hw_power_minpwr) + mx28_reg_32(hw_power_charge) + uint32_t hw_power_vdddctrl; + uint32_t reserved_vddd[3]; + uint32_t hw_power_vddactrl; + uint32_t reserved_vdda[3]; + uint32_t hw_power_vddioctrl; + uint32_t reserved_vddio[3]; + uint32_t hw_power_vddmemctrl; + uint32_t reserved_vddmem[3]; + uint32_t hw_power_dcdc4p2; + uint32_t reserved_dcdc4p2[3]; + uint32_t hw_power_misc; + uint32_t reserved_misc[3]; + uint32_t hw_power_dclimits; + uint32_t reserved_dclimits[3]; + mx28_reg_32(hw_power_loopctrl) + uint32_t hw_power_sts; + uint32_t reserved_sts[3]; + mx28_reg_32(hw_power_speed) + uint32_t hw_power_battmonitor; + uint32_t reserved_battmonitor[3]; + + uint32_t reserved[4]; + + mx28_reg_32(hw_power_reset) + mx28_reg_32(hw_power_debug) + mx28_reg_32(hw_power_thermal) + mx28_reg_32(hw_power_usb1ctrl) + mx28_reg_32(hw_power_special) + mx28_reg_32(hw_power_version) + mx28_reg_32(hw_power_anaclkctrl) + mx28_reg_32(hw_power_refctrl) +}; +#endif + +#define POWER_CTRL_PSWITCH_MID_TRAN (1 << 27) +#define POWER_CTRL_DCDC4P2_BO_IRQ (1 << 24) +#define POWER_CTRL_ENIRQ_DCDC4P2_BO (1 << 23) +#define POWER_CTRL_VDD5V_DROOP_IRQ (1 << 22) +#define POWER_CTRL_ENIRQ_VDD5V_DROOP (1 << 21) +#define POWER_CTRL_PSWITCH_IRQ (1 << 20) +#define POWER_CTRL_PSWITCH_IRQ_SRC (1 << 19) +#define POWER_CTRL_POLARITY_PSWITCH (1 << 18) +#define POWER_CTRL_ENIRQ_PSWITCH (1 << 17) +#define POWER_CTRL_POLARITY_DC_OK (1 << 16) +#define POWER_CTRL_DC_OK_IRQ (1 << 15) +#define POWER_CTRL_ENIRQ_DC_OK (1 << 14) +#define POWER_CTRL_BATT_BO_IRQ (1 << 13) +#define POWER_CTRL_ENIRQ_BATT_BO (1 << 12) +#define POWER_CTRL_VDDIO_BO_IRQ (1 << 11) +#define POWER_CTRL_ENIRQ_VDDIO_BO (1 << 10) +#define POWER_CTRL_VDDA_BO_IRQ (1 << 9) +#define POWER_CTRL_ENIRQ_VDDA_BO (1 << 8) +#define POWER_CTRL_VDDD_BO_IRQ (1 << 7) +#define POWER_CTRL_ENIRQ_VDDD_BO (1 << 6) +#define POWER_CTRL_POLARITY_VBUSVALID (1 << 5) +#define POWER_CTRL_VBUS_VALID_IRQ (1 << 4) +#define POWER_CTRL_ENIRQ_VBUS_VALID (1 << 3) +#define POWER_CTRL_POLARITY_VDD5V_GT_VDDIO (1 << 2) +#define POWER_CTRL_VDD5V_GT_VDDIO_IRQ (1 << 1) +#define POWER_CTRL_ENIRQ_VDD5V_GT_VDDIO (1 << 0) + +#define POWER_5VCTRL_VBUSDROOP_TRSH_MASK (0x3 << 30) +#define POWER_5VCTRL_VBUSDROOP_TRSH_OFFSET 30 +#define POWER_5VCTRL_VBUSDROOP_TRSH_4V3 (0x0 << 30) +#define POWER_5VCTRL_VBUSDROOP_TRSH_4V4 (0x1 << 30) +#define POWER_5VCTRL_VBUSDROOP_TRSH_4V5 (0x2 << 30) +#define POWER_5VCTRL_VBUSDROOP_TRSH_4V7 (0x3 << 30) +#define POWER_5VCTRL_HEADROOM_ADJ_MASK (0x7 << 24) +#define POWER_5VCTRL_HEADROOM_ADJ_OFFSET 24 +#define POWER_5VCTRL_PWD_CHARGE_4P2_MASK (0x3 << 20) +#define POWER_5VCTRL_PWD_CHARGE_4P2_OFFSET 20 +#define POWER_5VCTRL_CHARGE_4P2_ILIMIT_MASK (0x3f << 12) +#define POWER_5VCTRL_CHARGE_4P2_ILIMIT_OFFSET 12 +#define POWER_5VCTRL_VBUSVALID_TRSH_MASK (0x7 << 8) +#define POWER_5VCTRL_VBUSVALID_TRSH_OFFSET 8 +#define POWER_5VCTRL_VBUSVALID_TRSH_2V9 (0x0 << 8) +#define POWER_5VCTRL_VBUSVALID_TRSH_4V0 (0x1 << 8) +#define POWER_5VCTRL_VBUSVALID_TRSH_4V1 (0x2 << 8) +#define POWER_5VCTRL_VBUSVALID_TRSH_4V2 (0x3 << 8) +#define POWER_5VCTRL_VBUSVALID_TRSH_4V3 (0x4 << 8) +#define POWER_5VCTRL_VBUSVALID_TRSH_4V4 (0x5 << 8) +#define POWER_5VCTRL_VBUSVALID_TRSH_4V5 (0x6 << 8) +#define POWER_5VCTRL_VBUSVALID_TRSH_4V6 (0x7 << 8) +#define POWER_5VCTRL_PWDN_5VBRNOUT (1 << 7) +#define POWER_5VCTRL_ENABLE_LINREG_ILIMIT (1 << 6) +#define POWER_5VCTRL_DCDC_XFER (1 << 5) +#define POWER_5VCTRL_VBUSVALID_5VDETECT (1 << 4) +#define POWER_5VCTRL_VBUSVALID_TO_B (1 << 3) +#define POWER_5VCTRL_ILIMIT_EQ_ZERO (1 << 2) +#define POWER_5VCTRL_PWRUP_VBUS_CMPS (1 << 1) +#define POWER_5VCTRL_ENABLE_DCDC (1 << 0) + +#define POWER_MINPWR_LOWPWR_4P2 (1 << 14) +#define POWER_MINPWR_PWD_BO (1 << 12) +#define POWER_MINPWR_USE_VDDXTAL_VBG (1 << 11) +#define POWER_MINPWR_PWD_ANA_CMPS (1 << 10) +#define POWER_MINPWR_ENABLE_OSC (1 << 9) +#define POWER_MINPWR_SELECT_OSC (1 << 8) +#define POWER_MINPWR_FBG_OFF (1 << 7) +#define POWER_MINPWR_DOUBLE_FETS (1 << 6) +#define POWER_MINPWR_HALFFETS (1 << 5) +#define POWER_MINPWR_LESSANA_I (1 << 4) +#define POWER_MINPWR_PWD_XTAL24 (1 << 3) +#define POWER_MINPWR_DC_STOPCLK (1 << 2) +#define POWER_MINPWR_EN_DC_PFM (1 << 1) +#define POWER_MINPWR_DC_HALFCLK (1 << 0) + +#define POWER_CHARGE_ADJ_VOLT_MASK (0x7 << 24) +#define POWER_CHARGE_ADJ_VOLT_OFFSET 24 +#define POWER_CHARGE_ADJ_VOLT_M025P (0x1 << 24) +#define POWER_CHARGE_ADJ_VOLT_P050P (0x2 << 24) +#define POWER_CHARGE_ADJ_VOLT_M075P (0x3 << 24) +#define POWER_CHARGE_ADJ_VOLT_P025P (0x4 << 24) +#define POWER_CHARGE_ADJ_VOLT_M050P (0x5 << 24) +#define POWER_CHARGE_ADJ_VOLT_P075P (0x6 << 24) +#define POWER_CHARGE_ADJ_VOLT_M100P (0x7 << 24) +#define POWER_CHARGE_ENABLE_LOAD (1 << 22) +#define POWER_CHARGE_ENABLE_FAULT_DETECT (1 << 20) +#define POWER_CHARGE_CHRG_STS_OFF (1 << 19) +#define POWER_CHARGE_LIION_4P1 (1 << 18) +#define POWER_CHARGE_PWD_BATTCHRG (1 << 16) +#define POWER_CHARGE_ENABLE_CHARGER_USB1 (1 << 13) +#define POWER_CHARGE_ENABLE_CHARGER_USB0 (1 << 12) +#define POWER_CHARGE_STOP_ILIMIT_MASK (0xf << 8) +#define POWER_CHARGE_STOP_ILIMIT_OFFSET 8 +#define POWER_CHARGE_STOP_ILIMIT_10MA (0x1 << 8) +#define POWER_CHARGE_STOP_ILIMIT_20MA (0x2 << 8) +#define POWER_CHARGE_STOP_ILIMIT_50MA (0x4 << 8) +#define POWER_CHARGE_STOP_ILIMIT_100MA (0x8 << 8) +#define POWER_CHARGE_BATTCHRG_I_MASK 0x3f +#define POWER_CHARGE_BATTCHRG_I_OFFSET 0 +#define POWER_CHARGE_BATTCHRG_I_10MA 0x01 +#define POWER_CHARGE_BATTCHRG_I_20MA 0x02 +#define POWER_CHARGE_BATTCHRG_I_50MA 0x04 +#define POWER_CHARGE_BATTCHRG_I_100MA 0x08 +#define POWER_CHARGE_BATTCHRG_I_200MA 0x10 +#define POWER_CHARGE_BATTCHRG_I_400MA 0x20 + +#define POWER_VDDDCTRL_ADJTN_MASK (0xf << 28) +#define POWER_VDDDCTRL_ADJTN_OFFSET 28 +#define POWER_VDDDCTRL_PWDN_BRNOUT (1 << 23) +#define POWER_VDDDCTRL_DISABLE_STEPPING (1 << 22) +#define POWER_VDDDCTRL_ENABLE_LINREG (1 << 21) +#define POWER_VDDDCTRL_DISABLE_FET (1 << 20) +#define POWER_VDDDCTRL_LINREG_OFFSET_MASK (0x3 << 16) +#define POWER_VDDDCTRL_LINREG_OFFSET_OFFSET 16 +#define POWER_VDDDCTRL_LINREG_OFFSET_0STEPS (0x0 << 16) +#define POWER_VDDDCTRL_LINREG_OFFSET_1STEPS_ABOVE (0x1 << 16) +#define POWER_VDDDCTRL_LINREG_OFFSET_1STEPS_BELOW (0x2 << 16) +#define POWER_VDDDCTRL_LINREG_OFFSET_2STEPS_BELOW (0x3 << 16) +#define POWER_VDDDCTRL_BO_OFFSET_MASK (0x7 << 8) +#define POWER_VDDDCTRL_BO_OFFSET_OFFSET 8 +#define POWER_VDDDCTRL_TRG_MASK 0x1f +#define POWER_VDDDCTRL_TRG_OFFSET 0 + +#define POWER_VDDACTRL_PWDN_BRNOUT (1 << 19) +#define POWER_VDDACTRL_DISABLE_STEPPING (1 << 18) +#define POWER_VDDACTRL_ENABLE_LINREG (1 << 17) +#define POWER_VDDACTRL_DISABLE_FET (1 << 16) +#define POWER_VDDACTRL_LINREG_OFFSET_MASK (0x3 << 12) +#define POWER_VDDACTRL_LINREG_OFFSET_OFFSET 12 +#define POWER_VDDACTRL_LINREG_OFFSET_0STEPS (0x0 << 12) +#define POWER_VDDACTRL_LINREG_OFFSET_1STEPS_ABOVE (0x1 << 12) +#define POWER_VDDACTRL_LINREG_OFFSET_1STEPS_BELOW (0x2 << 12) +#define POWER_VDDACTRL_LINREG_OFFSET_2STEPS_BELOW (0x3 << 12) +#define POWER_VDDACTRL_BO_OFFSET_MASK (0x7 << 8) +#define POWER_VDDACTRL_BO_OFFSET_OFFSET 8 +#define POWER_VDDACTRL_TRG_MASK 0x1f +#define POWER_VDDACTRL_TRG_OFFSET 0 + +#define POWER_VDDIOCTRL_ADJTN_MASK (0xf << 20) +#define POWER_VDDIOCTRL_ADJTN_OFFSET 20 +#define POWER_VDDIOCTRL_PWDN_BRNOUT (1 << 18) +#define POWER_VDDIOCTRL_DISABLE_STEPPING (1 << 17) +#define POWER_VDDIOCTRL_DISABLE_FET (1 << 16) +#define POWER_VDDIOCTRL_LINREG_OFFSET_MASK (0x3 << 12) +#define POWER_VDDIOCTRL_LINREG_OFFSET_OFFSET 12 +#define POWER_VDDIOCTRL_LINREG_OFFSET_0STEPS (0x0 << 12) +#define POWER_VDDIOCTRL_LINREG_OFFSET_1STEPS_ABOVE (0x1 << 12) +#define POWER_VDDIOCTRL_LINREG_OFFSET_1STEPS_BELOW (0x2 << 12) +#define POWER_VDDIOCTRL_LINREG_OFFSET_2STEPS_BELOW (0x3 << 12) +#define POWER_VDDIOCTRL_BO_OFFSET_MASK (0x7 << 8) +#define POWER_VDDIOCTRL_BO_OFFSET_OFFSET 8 +#define POWER_VDDIOCTRL_TRG_MASK 0x1f +#define POWER_VDDIOCTRL_TRG_OFFSET 0 + +#define POWER_VDDMEMCTRL_PULLDOWN_ACTIVE (1 << 10) +#define POWER_VDDMEMCTRL_ENABLE_ILIMIT (1 << 9) +#define POWER_VDDMEMCTRL_ENABLE_LINREG (1 << 8) +#define POWER_VDDMEMCTRL_BO_OFFSET_MASK (0x7 << 5) +#define POWER_VDDMEMCTRL_BO_OFFSET_OFFSET 5 +#define POWER_VDDMEMCTRL_TRG_MASK 0x1f +#define POWER_VDDMEMCTRL_TRG_OFFSET 0 + +#define POWER_DCDC4P2_DROPOUT_CTRL_MASK (0xf << 28) +#define POWER_DCDC4P2_DROPOUT_CTRL_OFFSET 28 +#define POWER_DCDC4P2_DROPOUT_CTRL_200MV (0x3 << 30) +#define POWER_DCDC4P2_DROPOUT_CTRL_100MV (0x2 << 30) +#define POWER_DCDC4P2_DROPOUT_CTRL_50MV (0x1 << 30) +#define POWER_DCDC4P2_DROPOUT_CTRL_25MV (0x0 << 30) +#define POWER_DCDC4P2_DROPOUT_CTRL_SRC_4P2 (0x0 << 28) +#define POWER_DCDC4P2_DROPOUT_CTRL_SRC_4P2_LT_BATT (0x1 << 28) +#define POWER_DCDC4P2_DROPOUT_CTRL_SRC_SEL (0x2 << 28) +#define POWER_DCDC4P2_ISTEAL_THRESH_MASK (0x3 << 24) +#define POWER_DCDC4P2_ISTEAL_THRESH_OFFSET 24 +#define POWER_DCDC4P2_ENABLE_4P2 (1 << 23) +#define POWER_DCDC4P2_ENABLE_DCDC (1 << 22) +#define POWER_DCDC4P2_HYST_DIR (1 << 21) +#define POWER_DCDC4P2_HYST_THRESH (1 << 20) +#define POWER_DCDC4P2_TRG_MASK (0x7 << 16) +#define POWER_DCDC4P2_TRG_OFFSET 16 +#define POWER_DCDC4P2_TRG_4V2 (0x0 << 16) +#define POWER_DCDC4P2_TRG_4V1 (0x1 << 16) +#define POWER_DCDC4P2_TRG_4V0 (0x2 << 16) +#define POWER_DCDC4P2_TRG_3V9 (0x3 << 16) +#define POWER_DCDC4P2_TRG_BATT (0x4 << 16) +#define POWER_DCDC4P2_BO_MASK (0x1f << 8) +#define POWER_DCDC4P2_BO_OFFSET 8 +#define POWER_DCDC4P2_CMPTRIP_MASK 0x1f +#define POWER_DCDC4P2_CMPTRIP_OFFSET 0 + +#define POWER_MISC_FREQSEL_MASK (0x7 << 4) +#define POWER_MISC_FREQSEL_OFFSET 4 +#define POWER_MISC_FREQSEL_20MHZ (0x1 << 4) +#define POWER_MISC_FREQSEL_24MHZ (0x2 << 4) +#define POWER_MISC_FREQSEL_19MHZ (0x3 << 4) +#define POWER_MISC_FREQSEL_14MHZ (0x4 << 4) +#define POWER_MISC_FREQSEL_18MHZ (0x5 << 4) +#define POWER_MISC_FREQSEL_21MHZ (0x6 << 4) +#define POWER_MISC_FREQSEL_17MHZ (0x7 << 4) +#define POWER_MISC_DISABLE_FET_BO_LOGIC (1 << 3) +#define POWER_MISC_DELAY_TIMING (1 << 2) +#define POWER_MISC_TEST (1 << 1) +#define POWER_MISC_SEL_PLLCLK (1 << 0) + +#define POWER_DCLIMITS_POSLIMIT_BUCK_MASK (0x7f << 8) +#define POWER_DCLIMITS_POSLIMIT_BUCK_OFFSET 8 +#define POWER_DCLIMITS_NEGLIMIT_MASK 0x7f +#define POWER_DCLIMITS_NETLIMIT_OFFSET 0 + +#define POWER_LOOPCTRL_TOGGLE_DIF (1 << 20) +#define POWER_LOOPCTRL_HYST_SIGN (1 << 19) +#define POWER_LOOPCTRL_EN_CM_HYST (1 << 18) +#define POWER_LOOPCTRL_EN_DF_HYST (1 << 17) +#define POWER_LOOPCTRL_CM_HYST_THRESH (1 << 16) +#define POWER_LOOPCTRL_DF_HYST_THRESH (1 << 15) +#define POWER_LOOPCTRL_RCSCALE_THRESH (1 << 14) +#define POWER_LOOPCTRL_EN_RCSCALE_MASK (0x3 << 12) +#define POWER_LOOPCTRL_EN_RCSCALE_OFFSET 12 +#define POWER_LOOPCTRL_EN_RCSCALE_DIS (0x0 << 12) +#define POWER_LOOPCTRL_EN_RCSCALE_2X (0x1 << 12) +#define POWER_LOOPCTRL_EN_RCSCALE_4X (0x2 << 12) +#define POWER_LOOPCTRL_EN_RCSCALE_8X (0x3 << 12) +#define POWER_LOOPCTRL_DC_FF_MASK (0x7 << 8) +#define POWER_LOOPCTRL_DC_FF_OFFSET 8 +#define POWER_LOOPCTRL_DC_R_MASK (0xf << 4) +#define POWER_LOOPCTRL_DC_R_OFFSET 4 +#define POWER_LOOPCTRL_DC_C_MASK 0x3 +#define POWER_LOOPCTRL_DC_C_OFFSET 0 +#define POWER_LOOPCTRL_DC_C_MAX 0x0 +#define POWER_LOOPCTRL_DC_C_2X 0x1 +#define POWER_LOOPCTRL_DC_C_4X 0x2 +#define POWER_LOOPCTRL_DC_C_MIN 0x3 + +#define POWER_STS_PWRUP_SOURCE_MASK (0x3f << 24) +#define POWER_STS_PWRUP_SOURCE_OFFSET 24 +#define POWER_STS_PWRUP_SOURCE_5V (0x20 << 24) +#define POWER_STS_PWRUP_SOURCE_RTC (0x10 << 24) +#define POWER_STS_PWRUP_SOURCE_PSWITCH_HIGH (0x02 << 24) +#define POWER_STS_PWRUP_SOURCE_PSWITCH_MID (0x01 << 24) +#define POWER_STS_PSWITCH_MASK (0x3 << 20) +#define POWER_STS_PSWITCH_OFFSET 20 +#define POWER_STS_THERMAL_WARNING (1 << 19) +#define POWER_STS_VDDMEM_BO (1 << 18) +#define POWER_STS_AVALID0_STATUS (1 << 17) +#define POWER_STS_BVALID0_STATUS (1 << 16) +#define POWER_STS_VBUSVALID0_STATUS (1 << 15) +#define POWER_STS_SESSEND0_STATUS (1 << 14) +#define POWER_STS_BATT_BO (1 << 13) +#define POWER_STS_VDD5V_FAULT (1 << 12) +#define POWER_STS_CHRGSTS (1 << 11) +#define POWER_STS_DCDC_4P2_BO (1 << 10) +#define POWER_STS_DC_OK (1 << 9) +#define POWER_STS_VDDIO_BO (1 << 8) +#define POWER_STS_VDDA_BO (1 << 7) +#define POWER_STS_VDDD_BO (1 << 6) +#define POWER_STS_VDD5V_GT_VDDIO (1 << 5) +#define POWER_STS_VDD5V_DROOP (1 << 4) +#define POWER_STS_AVALID0 (1 << 3) +#define POWER_STS_BVALID0 (1 << 2) +#define POWER_STS_VBUSVALID0 (1 << 1) +#define POWER_STS_SESSEND0 (1 << 0) + +#define POWER_SPEED_STATUS_MASK (0xffff << 8) +#define POWER_SPEED_STATUS_OFFSET 8 +#define POWER_SPEED_STATUS_SEL_MASK (0x3 << 6) +#define POWER_SPEED_STATUS_SEL_OFFSET 6 +#define POWER_SPEED_STATUS_SEL_DCDC_STAT (0x0 << 6) +#define POWER_SPEED_STATUS_SEL_CORE_STAT (0x1 << 6) +#define POWER_SPEED_STATUS_SEL_ARM_STAT (0x2 << 6) +#define POWER_SPEED_CTRL_MASK 0x3 +#define POWER_SPEED_CTRL_OFFSET 0 +#define POWER_SPEED_CTRL_SS_OFF 0x0 +#define POWER_SPEED_CTRL_SS_ON 0x1 +#define POWER_SPEED_CTRL_SS_ENABLE 0x3 + +#define POWER_BATTMONITOR_BATT_VAL_MASK (0x3ff << 16) +#define POWER_BATTMONITOR_BATT_VAL_OFFSET 16 +#define POWER_BATTMONITOR_PWDN_BATTBRNOUT_5VDETECT_EN (1 << 11) +#define POWER_BATTMONITOR_EN_BATADJ (1 << 10) +#define POWER_BATTMONITOR_PWDN_BATTBRNOUT (1 << 9) +#define POWER_BATTMONITOR_BRWNOUT_PWD (1 << 8) +#define POWER_BATTMONITOR_BRWNOUT_LVL_MASK 0x1f +#define POWER_BATTMONITOR_BRWNOUT_LVL_OFFSET 0 + +#define POWER_RESET_UNLOCK_MASK (0xffff << 16) +#define POWER_RESET_UNLOCK_OFFSET 16 +#define POWER_RESET_UNLOCK_KEY (0x3e77 << 16) +#define POWER_RESET_FASTFALL_PSWITCH_OFF (1 << 2) +#define POWER_RESET_PWD_OFF (1 << 1) +#define POWER_RESET_PWD (1 << 0) + +#define POWER_DEBUG_VBUSVALIDPIOLOCK (1 << 3) +#define POWER_DEBUG_AVALIDPIOLOCK (1 << 2) +#define POWER_DEBUG_BVALIDPIOLOCK (1 << 1) +#define POWER_DEBUG_SESSENDPIOLOCK (1 << 0) + +#define POWER_THERMAL_TEST (1 << 8) +#define POWER_THERMAL_PWD (1 << 7) +#define POWER_THERMAL_LOW_POWER (1 << 6) +#define POWER_THERMAL_OFFSET_ADJ_MASK (0x3 << 4) +#define POWER_THERMAL_OFFSET_ADJ_OFFSET 4 +#define POWER_THERMAL_OFFSET_ADJ_ENABLE (1 << 3) +#define POWER_THERMAL_TEMP_THRESHOLD_MASK 0x7 +#define POWER_THERMAL_TEMP_THRESHOLD_OFFSET 0 + +#define POWER_USB1CTRL_AVALID1 (1 << 3) +#define POWER_USB1CTRL_BVALID1 (1 << 2) +#define POWER_USB1CTRL_VBUSVALID1 (1 << 1) +#define POWER_USB1CTRL_SESSEND1 (1 << 0) + +#define POWER_SPECIAL_TEST_MASK 0xffffffff +#define POWER_SPECIAL_TEST_OFFSET 0 + +#define POWER_VERSION_MAJOR_MASK (0xff << 24) +#define POWER_VERSION_MAJOR_OFFSET 24 +#define POWER_VERSION_MINOR_MASK (0xff << 16) +#define POWER_VERSION_MINOR_OFFSET 16 +#define POWER_VERSION_STEP_MASK 0xffff +#define POWER_VERSION_STEP_OFFSET 0 + +#define POWER_ANACLKCTRL_CLKGATE_0 (1 << 31) +#define POWER_ANACLKCTRL_OUTDIV_MASK (0x7 << 28) +#define POWER_ANACLKCTRL_OUTDIV_OFFSET 28 +#define POWER_ANACLKCTRL_INVERT_OUTCLK (1 << 27) +#define POWER_ANACLKCTRL_CLKGATE_I (1 << 26) +#define POWER_ANACLKCTRL_DITHER_OFF (1 << 10) +#define POWER_ANACLKCTRL_SLOW_DITHER (1 << 9) +#define POWER_ANACLKCTRL_INVERT_INCLK (1 << 8) +#define POWER_ANACLKCTRL_INCLK_SHIFT_MASK (0x3 << 4) +#define POWER_ANACLKCTRL_INCLK_SHIFT_OFFSET 4 +#define POWER_ANACLKCTRL_INDIV_MASK 0x7 +#define POWER_ANACLKCTRL_INDIV_OFFSET 0 + +#define POWER_REFCTRL_FASTSETTLING (1 << 26) +#define POWER_REFCTRL_RAISE_REF (1 << 25) +#define POWER_REFCTRL_XTAL_BGR_BIAS (1 << 24) +#define POWER_REFCTRL_VBG_ADJ_MASK (0x7 << 20) +#define POWER_REFCTRL_VBG_ADJ_OFFSET 20 +#define POWER_REFCTRL_LOW_PWR (1 << 19) +#define POWER_REFCTRL_BIAS_CTRL_MASK (0x3 << 16) +#define POWER_REFCTRL_BIAS_CTRL_OFFSET 16 +#define POWER_REFCTRL_VDDXTAL_TO_VDDD (1 << 14) +#define POWER_REFCTRL_ADJ_ANA (1 << 13) +#define POWER_REFCTRL_ADJ_VAG (1 << 12) +#define POWER_REFCTRL_ANA_REFVAL_MASK (0xf << 8) +#define POWER_REFCTRL_ANA_REFVAL_OFFSET 8 +#define POWER_REFCTRL_VAG_VAL_MASK (0xf << 4) +#define POWER_REFCTRL_VAG_VAL_OFFSET 4 + +#endif /* __MX28_REGS_POWER_H__ */ diff --git a/arch/arm/include/asm/arch-mxs/regs-rtc.h b/arch/arm/include/asm/arch-mxs/regs-rtc.h new file mode 100644 index 0000000..e605a03 --- /dev/null +++ b/arch/arm/include/asm/arch-mxs/regs-rtc.h @@ -0,0 +1,147 @@ +/* + * Freescale i.MX28 RTC Register Definitions + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __MX28_REGS_RTC_H__ +#define __MX28_REGS_RTC_H__ + +#include <asm/arch/regs-common.h> + +#ifndef __ASSEMBLY__ +struct mx28_rtc_regs { + mx28_reg_32(hw_rtc_ctrl) + mx28_reg_32(hw_rtc_stat) + mx28_reg_32(hw_rtc_milliseconds) + mx28_reg_32(hw_rtc_seconds) + mx28_reg_32(hw_rtc_rtc_alarm) + mx28_reg_32(hw_rtc_watchdog) + mx28_reg_32(hw_rtc_persistent0) + mx28_reg_32(hw_rtc_persistent1) + mx28_reg_32(hw_rtc_persistent2) + mx28_reg_32(hw_rtc_persistent3) + mx28_reg_32(hw_rtc_persistent4) + mx28_reg_32(hw_rtc_persistent5) + mx28_reg_32(hw_rtc_debug) + mx28_reg_32(hw_rtc_version) +}; +#endif + +#define RTC_CTRL_SFTRST (1 << 31) +#define RTC_CTRL_CLKGATE (1 << 30) +#define RTC_CTRL_SUPPRESS_COPY2ANALOG (1 << 6) +#define RTC_CTRL_FORCE_UPDATE (1 << 5) +#define RTC_CTRL_WATCHDOGEN (1 << 4) +#define RTC_CTRL_ONEMSEC_IRQ (1 << 3) +#define RTC_CTRL_ALARM_IRQ (1 << 2) +#define RTC_CTRL_ONEMSEC_IRQ_EN (1 << 1) +#define RTC_CTRL_ALARM_IRQ_EN (1 << 0) + +#define RTC_STAT_RTC_PRESENT (1 << 31) +#define RTC_STAT_ALARM_PRESENT (1 << 30) +#define RTC_STAT_WATCHDOG_PRESENT (1 << 29) +#define RTC_STAT_XTAL32000_PRESENT (1 << 28) +#define RTC_STAT_XTAL32768_PRESENT (1 << 27) +#define RTC_STAT_STALE_REGS_MASK (0xff << 16) +#define RTC_STAT_STALE_REGS_OFFSET 16 +#define RTC_STAT_NEW_REGS_MASK (0xff << 8) +#define RTC_STAT_NEW_REGS_OFFSET 8 + +#define RTC_MILLISECONDS_COUNT_MASK 0xffffffff +#define RTC_MILLISECONDS_COUNT_OFFSET 0 + +#define RTC_SECONDS_COUNT_MASK 0xffffffff +#define RTC_SECONDS_COUNT_OFFSET 0 + +#define RTC_ALARM_VALUE_MASK 0xffffffff +#define RTC_ALARM_VALUE_OFFSET 0 + +#define RTC_WATCHDOG_COUNT_MASK 0xffffffff +#define RTC_WATCHDOG_COUNT_OFFSET 0 + +#define RTC_PERSISTENT0_ADJ_POSLIMITBUCK_MASK (0xf << 28) +#define RTC_PERSISTENT0_ADJ_POSLIMITBUCK_OFFSET 28 +#define RTC_PERSISTENT0_ADJ_POSLIMITBUCK_2V83 (0x0 << 28) +#define RTC_PERSISTENT0_ADJ_POSLIMITBUCK_2V78 (0x1 << 28) +#define RTC_PERSISTENT0_ADJ_POSLIMITBUCK_2V73 (0x2 << 28) +#define RTC_PERSISTENT0_ADJ_POSLIMITBUCK_2V68 (0x3 << 28) +#define RTC_PERSISTENT0_ADJ_POSLIMITBUCK_2V62 (0x4 << 28) +#define RTC_PERSISTENT0_ADJ_POSLIMITBUCK_2V57 (0x5 << 28) +#define RTC_PERSISTENT0_ADJ_POSLIMITBUCK_2V52 (0x6 << 28) +#define RTC_PERSISTENT0_ADJ_POSLIMITBUCK_2V48 (0x7 << 28) +#define RTC_PERSISTENT0_EXTERNAL_RESET (1 << 21) +#define RTC_PERSISTENT0_THERMAL_RESET (1 << 20) +#define RTC_PERSISTENT0_ENABLE_LRADC_PWRUP (1 << 18) +#define RTC_PERSISTENT0_AUTO_RESTART (1 << 17) +#define RTC_PERSISTENT0_DISABLE_PSWITCH (1 << 16) +#define RTC_PERSISTENT0_LOWERBIAS_MASK (0xf << 14) +#define RTC_PERSISTENT0_LOWERBIAS_OFFSET 14 +#define RTC_PERSISTENT0_LOWERBIAS_NOMINAL (0x0 << 14) +#define RTC_PERSISTENT0_LOWERBIAS_M25P (0x1 << 14) +#define RTC_PERSISTENT0_LOWERBIAS_M50P (0x3 << 14) +#define RTC_PERSISTENT0_DISABLE_XTALOK (1 << 13) +#define RTC_PERSISTENT0_MSEC_RES_MASK (0x1f << 8) +#define RTC_PERSISTENT0_MSEC_RES_OFFSET 8 +#define RTC_PERSISTENT0_MSEC_RES_1MS (0x01 << 8) +#define RTC_PERSISTENT0_MSEC_RES_2MS (0x02 << 8) +#define RTC_PERSISTENT0_MSEC_RES_4MS (0x04 << 8) +#define RTC_PERSISTENT0_MSEC_RES_8MS (0x08 << 8) +#define RTC_PERSISTENT0_MSEC_RES_16MS (0x10 << 8) +#define RTC_PERSISTENT0_ALARM_WAKE (1 << 7) +#define RTC_PERSISTENT0_XTAL32_FREQ (1 << 6) +#define RTC_PERSISTENT0_XTAL32KHZ_PWRUP (1 << 5) +#define RTC_PERSISTENT0_XTAL24KHZ_PWRUP (1 << 4) +#define RTC_PERSISTENT0_LCK_SECS (1 << 3) +#define RTC_PERSISTENT0_ALARM_EN (1 << 2) +#define RTC_PERSISTENT0_ALARM_WAKE_EN (1 << 1) +#define RTC_PERSISTENT0_CLOCKSOURCE (1 << 0) + +#define RTC_PERSISTENT1_GENERAL_MASK 0xffffffff +#define RTC_PERSISTENT1_GENERAL_OFFSET 0 +#define RTC_PERSISTENT1_GENERAL_OTG_ALT_ROLE 0x0080 +#define RTC_PERSISTENT1_GENERAL_OTG_HNP 0x0100 +#define RTC_PERSISTENT1_GENERAL_USB_LPM 0x0200 +#define RTC_PERSISTENT1_GENERAL_SKIP_CHECKDISK 0x0400 +#define RTC_PERSISTENT1_GENERAL_USB_BOOT_PLAYER 0x0800 +#define RTC_PERSISTENT1_GENERAL_ENUM_500MA_2X 0x1000 + +#define RTC_PERSISTENT2_GENERAL_MASK 0xffffffff +#define RTC_PERSISTENT2_GENERAL_OFFSET 0 + +#define RTC_PERSISTENT3_GENERAL_MASK 0xffffffff +#define RTC_PERSISTENT3_GENERAL_OFFSET 0 + +#define RTC_PERSISTENT4_GENERAL_MASK 0xffffffff +#define RTC_PERSISTENT4_GENERAL_OFFSET 0 + +#define RTC_PERSISTENT5_GENERAL_MASK 0xffffffff +#define RTC_PERSISTENT5_GENERAL_OFFSET 0 + +#define RTC_DEBUG_WATCHDOG_RESET_MASK (1 << 1) +#define RTC_DEBUG_WATCHDOG_RESET (1 << 0) + +#define RTC_VERSION_MAJOR_MASK (0xff << 24) +#define RTC_VERSION_MAJOR_OFFSET 24 +#define RTC_VERSION_MINOR_MASK (0xff << 16) +#define RTC_VERSION_MINOR_OFFSET 16 +#define RTC_VERSION_STEP_MASK 0xffff +#define RTC_VERSION_STEP_OFFSET 0 + +#endif /* __MX28_REGS_RTC_H__ */ diff --git a/arch/arm/include/asm/arch-mxs/regs-ssp.h b/arch/arm/include/asm/arch-mxs/regs-ssp.h new file mode 100644 index 0000000..be71d48 --- /dev/null +++ b/arch/arm/include/asm/arch-mxs/regs-ssp.h @@ -0,0 +1,349 @@ +/* + * Freescale i.MX28 SSP Register Definitions + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * + * Based on code from LTIB: + * Copyright 2008-2010 Freescale Semiconductor, Inc. All Rights Reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __MX28_REGS_SSP_H__ +#define __MX28_REGS_SSP_H__ + +#include <asm/arch/regs-common.h> + +#ifndef __ASSEMBLY__ +struct mx28_ssp_regs { + mx28_reg_32(hw_ssp_ctrl0) + mx28_reg_32(hw_ssp_cmd0) + mx28_reg_32(hw_ssp_cmd1) + mx28_reg_32(hw_ssp_xfer_size) + mx28_reg_32(hw_ssp_block_size) + mx28_reg_32(hw_ssp_compref) + mx28_reg_32(hw_ssp_compmask) + mx28_reg_32(hw_ssp_timing) + mx28_reg_32(hw_ssp_ctrl1) + mx28_reg_32(hw_ssp_data) + mx28_reg_32(hw_ssp_sdresp0) + mx28_reg_32(hw_ssp_sdresp1) + mx28_reg_32(hw_ssp_sdresp2) + mx28_reg_32(hw_ssp_sdresp3) + mx28_reg_32(hw_ssp_ddr_ctrl) + mx28_reg_32(hw_ssp_dll_ctrl) + mx28_reg_32(hw_ssp_status) + mx28_reg_32(hw_ssp_dll_sts) + mx28_reg_32(hw_ssp_debug) + mx28_reg_32(hw_ssp_version) +}; +#endif + +#define SSP_CTRL0_SFTRST (1 << 31) +#define SSP_CTRL0_CLKGATE (1 << 30) +#define SSP_CTRL0_RUN (1 << 29) +#define SSP_CTRL0_SDIO_IRQ_CHECK (1 << 28) +#define SSP_CTRL0_LOCK_CS (1 << 27) +#define SSP_CTRL0_IGNORE_CRC (1 << 26) +#define SSP_CTRL0_READ (1 << 25) +#define SSP_CTRL0_DATA_XFER (1 << 24) +#define SSP_CTRL0_BUS_WIDTH_MASK (0x3 << 22) +#define SSP_CTRL0_BUS_WIDTH_OFFSET 22 +#define SSP_CTRL0_BUS_WIDTH_ONE_BIT (0x0 << 22) +#define SSP_CTRL0_BUS_WIDTH_FOUR_BIT (0x1 << 22) +#define SSP_CTRL0_BUS_WIDTH_EIGHT_BIT (0x2 << 22) +#define SSP_CTRL0_WAIT_FOR_IRQ (1 << 21) +#define SSP_CTRL0_WAIT_FOR_CMD (1 << 20) +#define SSP_CTRL0_LONG_RESP (1 << 19) +#define SSP_CTRL0_CHECK_RESP (1 << 18) +#define SSP_CTRL0_GET_RESP (1 << 17) +#define SSP_CTRL0_ENABLE (1 << 16) + +#define SSP_CMD0_SOFT_TERMINATE (1 << 26) +#define SSP_CMD0_DBL_DATA_RATE_EN (1 << 25) +#define SSP_CMD0_PRIM_BOOT_OP_EN (1 << 24) +#define SSP_CMD0_BOOT_ACK_EN (1 << 23) +#define SSP_CMD0_SLOW_CLKING_EN (1 << 22) +#define SSP_CMD0_CONT_CLKING_EN (1 << 21) +#define SSP_CMD0_APPEND_8CYC (1 << 20) +#define SSP_CMD0_CMD_MASK 0xff +#define SSP_CMD0_CMD_OFFSET 0 +#define SSP_CMD0_CMD_MMC_GO_IDLE_STATE 0x00 +#define SSP_CMD0_CMD_MMC_SEND_OP_COND 0x01 +#define SSP_CMD0_CMD_MMC_ALL_SEND_CID 0x02 +#define SSP_CMD0_CMD_MMC_SET_RELATIVE_ADDR 0x03 +#define SSP_CMD0_CMD_MMC_SET_DSR 0x04 +#define SSP_CMD0_CMD_MMC_RESERVED_5 0x05 +#define SSP_CMD0_CMD_MMC_SWITCH 0x06 +#define SSP_CMD0_CMD_MMC_SELECT_DESELECT_CARD 0x07 +#define SSP_CMD0_CMD_MMC_SEND_EXT_CSD 0x08 +#define SSP_CMD0_CMD_MMC_SEND_CSD 0x09 +#define SSP_CMD0_CMD_MMC_SEND_CID 0x0a +#define SSP_CMD0_CMD_MMC_READ_DAT_UNTIL_STOP 0x0b +#define SSP_CMD0_CMD_MMC_STOP_TRANSMISSION 0x0c +#define SSP_CMD0_CMD_MMC_SEND_STATUS 0x0d +#define SSP_CMD0_CMD_MMC_BUSTEST_R 0x0e +#define SSP_CMD0_CMD_MMC_GO_INACTIVE_STATE 0x0f +#define SSP_CMD0_CMD_MMC_SET_BLOCKLEN 0x10 +#define SSP_CMD0_CMD_MMC_READ_SINGLE_BLOCK 0x11 +#define SSP_CMD0_CMD_MMC_READ_MULTIPLE_BLOCK 0x12 +#define SSP_CMD0_CMD_MMC_BUSTEST_W 0x13 +#define SSP_CMD0_CMD_MMC_WRITE_DAT_UNTIL_STOP 0x14 +#define SSP_CMD0_CMD_MMC_SET_BLOCK_COUNT 0x17 +#define SSP_CMD0_CMD_MMC_WRITE_BLOCK 0x18 +#define SSP_CMD0_CMD_MMC_WRITE_MULTIPLE_BLOCK 0x19 +#define SSP_CMD0_CMD_MMC_PROGRAM_CID 0x1a +#define SSP_CMD0_CMD_MMC_PROGRAM_CSD 0x1b +#define SSP_CMD0_CMD_MMC_SET_WRITE_PROT 0x1c +#define SSP_CMD0_CMD_MMC_CLR_WRITE_PROT 0x1d +#define SSP_CMD0_CMD_MMC_SEND_WRITE_PROT 0x1e +#define SSP_CMD0_CMD_MMC_ERASE_GROUP_START 0x23 +#define SSP_CMD0_CMD_MMC_ERASE_GROUP_END 0x24 +#define SSP_CMD0_CMD_MMC_ERASE 0x26 +#define SSP_CMD0_CMD_MMC_FAST_IO 0x27 +#define SSP_CMD0_CMD_MMC_GO_IRQ_STATE 0x28 +#define SSP_CMD0_CMD_MMC_LOCK_UNLOCK 0x2a +#define SSP_CMD0_CMD_MMC_APP_CMD 0x37 +#define SSP_CMD0_CMD_MMC_GEN_CMD 0x38 +#define SSP_CMD0_CMD_SD_GO_IDLE_STATE 0x00 +#define SSP_CMD0_CMD_SD_ALL_SEND_CID 0x02 +#define SSP_CMD0_CMD_SD_SEND_RELATIVE_ADDR 0x03 +#define SSP_CMD0_CMD_SD_SET_DSR 0x04 +#define SSP_CMD0_CMD_SD_IO_SEND_OP_COND 0x05 +#define SSP_CMD0_CMD_SD_SELECT_DESELECT_CARD 0x07 +#define SSP_CMD0_CMD_SD_SEND_CSD 0x09 +#define SSP_CMD0_CMD_SD_SEND_CID 0x0a +#define SSP_CMD0_CMD_SD_STOP_TRANSMISSION 0x0c +#define SSP_CMD0_CMD_SD_SEND_STATUS 0x0d +#define SSP_CMD0_CMD_SD_GO_INACTIVE_STATE 0x0f +#define SSP_CMD0_CMD_SD_SET_BLOCKLEN 0x10 +#define SSP_CMD0_CMD_SD_READ_SINGLE_BLOCK 0x11 +#define SSP_CMD0_CMD_SD_READ_MULTIPLE_BLOCK 0x12 +#define SSP_CMD0_CMD_SD_WRITE_BLOCK 0x18 +#define SSP_CMD0_CMD_SD_WRITE_MULTIPLE_BLOCK 0x19 +#define SSP_CMD0_CMD_SD_PROGRAM_CSD 0x1b +#define SSP_CMD0_CMD_SD_SET_WRITE_PROT 0x1c +#define SSP_CMD0_CMD_SD_CLR_WRITE_PROT 0x1d +#define SSP_CMD0_CMD_SD_SEND_WRITE_PROT 0x1e +#define SSP_CMD0_CMD_SD_ERASE_WR_BLK_START 0x20 +#define SSP_CMD0_CMD_SD_ERASE_WR_BLK_END 0x21 +#define SSP_CMD0_CMD_SD_ERASE_GROUP_START 0x23 +#define SSP_CMD0_CMD_SD_ERASE_GROUP_END 0x24 +#define SSP_CMD0_CMD_SD_ERASE 0x26 +#define SSP_CMD0_CMD_SD_LOCK_UNLOCK 0x2a +#define SSP_CMD0_CMD_SD_IO_RW_DIRECT 0x34 +#define SSP_CMD0_CMD_SD_IO_RW_EXTENDED 0x35 +#define SSP_CMD0_CMD_SD_APP_CMD 0x37 +#define SSP_CMD0_CMD_SD_GEN_CMD 0x38 + +#define SSP_CMD1_CMD_ARG_MASK 0xffffffff +#define SSP_CMD1_CMD_ARG_OFFSET 0 + +#define SSP_XFER_SIZE_XFER_COUNT_MASK 0xffffffff +#define SSP_XFER_SIZE_XFER_COUNT_OFFSET 0 + +#define SSP_BLOCK_SIZE_BLOCK_COUNT_MASK (0xffffff << 4) +#define SSP_BLOCK_SIZE_BLOCK_COUNT_OFFSET 4 +#define SSP_BLOCK_SIZE_BLOCK_SIZE_MASK 0xf +#define SSP_BLOCK_SIZE_BLOCK_SIZE_OFFSET 0 + +#define SSP_COMPREF_REFERENCE_MASK 0xffffffff +#define SSP_COMPREF_REFERENCE_OFFSET 0 + +#define SSP_COMPMASK_MASK_MASK 0xffffffff +#define SSP_COMPMASK_MASK_OFFSET 0 + +#define SSP_TIMING_TIMEOUT_MASK (0xffff << 16) +#define SSP_TIMING_TIMEOUT_OFFSET 16 +#define SSP_TIMING_CLOCK_DIVIDE_MASK (0xff << 8) +#define SSP_TIMING_CLOCK_DIVIDE_OFFSET 8 +#define SSP_TIMING_CLOCK_RATE_MASK 0xff +#define SSP_TIMING_CLOCK_RATE_OFFSET 0 + +#define SSP_CTRL1_SDIO_IRQ (1 << 31) +#define SSP_CTRL1_SDIO_IRQ_EN (1 << 30) +#define SSP_CTRL1_RESP_ERR_IRQ (1 << 29) +#define SSP_CTRL1_RESP_ERR_IRQ_EN (1 << 28) +#define SSP_CTRL1_RESP_TIMEOUT_IRQ (1 << 27) +#define SSP_CTRL1_RESP_TIMEOUT_IRQ_EN (1 << 26) +#define SSP_CTRL1_DATA_TIMEOUT_IRQ (1 << 25) +#define SSP_CTRL1_DATA_TIMEOUT_IRQ_EN (1 << 24) +#define SSP_CTRL1_DATA_CRC_IRQ (1 << 23) +#define SSP_CTRL1_DATA_CRC_IRQ_EN (1 << 22) +#define SSP_CTRL1_FIFO_UNDERRUN_IRQ (1 << 21) +#define SSP_CTRL1_FIFO_UNDERRUN_EN (1 << 20) +#define SSP_CTRL1_CEATA_CCS_ERR_IRQ (1 << 19) +#define SSP_CTRL1_CEATA_CCS_ERR_IRQ_EN (1 << 18) +#define SSP_CTRL1_RECV_TIMEOUT_IRQ (1 << 17) +#define SSP_CTRL1_RECV_TIMEOUT_IRQ_EN (1 << 16) +#define SSP_CTRL1_FIFO_OVERRUN_IRQ (1 << 15) +#define SSP_CTRL1_FIFO_OVERRUN_IRQ_EN (1 << 14) +#define SSP_CTRL1_DMA_ENABLE (1 << 13) +#define SSP_CTRL1_CEATA_CCS_ERR_EN (1 << 12) +#define SSP_CTRL1_SLAVE_OUT_DISABLE (1 << 11) +#define SSP_CTRL1_PHASE (1 << 10) +#define SSP_CTRL1_POLARITY (1 << 9) +#define SSP_CTRL1_SLAVE_MODE (1 << 8) +#define SSP_CTRL1_WORD_LENGTH_MASK (0xf << 4) +#define SSP_CTRL1_WORD_LENGTH_OFFSET 4 +#define SSP_CTRL1_WORD_LENGTH_RESERVED0 (0x0 << 4) +#define SSP_CTRL1_WORD_LENGTH_RESERVED1 (0x1 << 4) +#define SSP_CTRL1_WORD_LENGTH_RESERVED2 (0x2 << 4) +#define SSP_CTRL1_WORD_LENGTH_FOUR_BITS (0x3 << 4) +#define SSP_CTRL1_WORD_LENGTH_EIGHT_BITS (0x7 << 4) +#define SSP_CTRL1_WORD_LENGTH_SIXTEEN_BITS (0xf << 4) +#define SSP_CTRL1_SSP_MODE_MASK 0xf +#define SSP_CTRL1_SSP_MODE_OFFSET 0 +#define SSP_CTRL1_SSP_MODE_SPI 0x0 +#define SSP_CTRL1_SSP_MODE_SSI 0x1 +#define SSP_CTRL1_SSP_MODE_SD_MMC 0x3 +#define SSP_CTRL1_SSP_MODE_MS 0x4 + +#define SSP_DATA_DATA_MASK 0xffffffff +#define SSP_DATA_DATA_OFFSET 0 + +#define SSP_SDRESP0_RESP0_MASK 0xffffffff +#define SSP_SDRESP0_RESP0_OFFSET 0 + +#define SSP_SDRESP1_RESP1_MASK 0xffffffff +#define SSP_SDRESP1_RESP1_OFFSET 0 + +#define SSP_SDRESP2_RESP2_MASK 0xffffffff +#define SSP_SDRESP2_RESP2_OFFSET 0 + +#define SSP_SDRESP3_RESP3_MASK 0xffffffff +#define SSP_SDRESP3_RESP3_OFFSET 0 + +#define SSP_DDR_CTRL_DMA_BURST_TYPE_MASK (0x3 << 30) +#define SSP_DDR_CTRL_DMA_BURST_TYPE_OFFSET 30 +#define SSP_DDR_CTRL_NIBBLE_POS (1 << 1) +#define SSP_DDR_CTRL_TXCLK_DELAY_TYPE (1 << 0) + +#define SSP_DLL_CTRL_REF_UPDATE_INT_MASK (0xf << 28) +#define SSP_DLL_CTRL_REF_UPDATE_INT_OFFSET 28 +#define SSP_DLL_CTRL_SLV_UPDATE_INT_MASK (0xff << 20) +#define SSP_DLL_CTRL_SLV_UPDATE_INT_OFFSET 20 +#define SSP_DLL_CTRL_SLV_OVERRIDE_VAL_MASK (0x3f << 10) +#define SSP_DLL_CTRL_SLV_OVERRIDE_VAL_OFFSET 10 +#define SSP_DLL_CTRL_SLV_OVERRIDE (1 << 9) +#define SSP_DLL_CTRL_GATE_UPDATE (1 << 7) +#define SSP_DLL_CTRL_SLV_DLY_TARGET_MASK (0xf << 3) +#define SSP_DLL_CTRL_SLV_DLY_TARGET_OFFSET 3 +#define SSP_DLL_CTRL_SLV_FORCE_UPD (1 << 2) +#define SSP_DLL_CTRL_RESET (1 << 1) +#define SSP_DLL_CTRL_ENABLE (1 << 0) + +#define SSP_STATUS_PRESENT (1 << 31) +#define SSP_STATUS_MS_PRESENT (1 << 30) +#define SSP_STATUS_SD_PRESENT (1 << 29) +#define SSP_STATUS_CARD_DETECT (1 << 28) +#define SSP_STATUS_DMABURST (1 << 22) +#define SSP_STATUS_DMASENSE (1 << 21) +#define SSP_STATUS_DMATERM (1 << 20) +#define SSP_STATUS_DMAREQ (1 << 19) +#define SSP_STATUS_DMAEND (1 << 18) +#define SSP_STATUS_SDIO_IRQ (1 << 17) +#define SSP_STATUS_RESP_CRC_ERR (1 << 16) +#define SSP_STATUS_RESP_ERR (1 << 15) +#define SSP_STATUS_RESP_TIMEOUT (1 << 14) +#define SSP_STATUS_DATA_CRC_ERR (1 << 13) +#define SSP_STATUS_TIMEOUT (1 << 12) +#define SSP_STATUS_RECV_TIMEOUT_STAT (1 << 11) +#define SSP_STATUS_CEATA_CCS_ERR (1 << 10) +#define SSP_STATUS_FIFO_OVRFLW (1 << 9) +#define SSP_STATUS_FIFO_FULL (1 << 8) +#define SSP_STATUS_FIFO_EMPTY (1 << 5) +#define SSP_STATUS_FIFO_UNDRFLW (1 << 4) +#define SSP_STATUS_CMD_BUSY (1 << 3) +#define SSP_STATUS_DATA_BUSY (1 << 2) +#define SSP_STATUS_BUSY (1 << 0) + +#define SSP_DLL_STS_REF_SEL_MASK (0x3f << 8) +#define SSP_DLL_STS_REF_SEL_OFFSET 8 +#define SSP_DLL_STS_SLV_SEL_MASK (0x3f << 2) +#define SSP_DLL_STS_SLV_SEL_OFFSET 2 +#define SSP_DLL_STS_REF_LOCK (1 << 1) +#define SSP_DLL_STS_SLV_LOCK (1 << 0) + +#define SSP_DEBUG_DATACRC_ERR_MASK (0xf << 28) +#define SSP_DEBUG_DATACRC_ERR_OFFSET 28 +#define SSP_DEBUG_DATA_STALL (1 << 27) +#define SSP_DEBUG_DAT_SM_MASK (0x7 << 24) +#define SSP_DEBUG_DAT_SM_OFFSET 24 +#define SSP_DEBUG_DAT_SM_DSM_IDLE (0x0 << 24) +#define SSP_DEBUG_DAT_SM_DSM_WORD (0x2 << 24) +#define SSP_DEBUG_DAT_SM_DSM_CRC1 (0x3 << 24) +#define SSP_DEBUG_DAT_SM_DSM_CRC2 (0x4 << 24) +#define SSP_DEBUG_DAT_SM_DSM_END (0x5 << 24) +#define SSP_DEBUG_MSTK_SM_MASK (0xf << 20) +#define SSP_DEBUG_MSTK_SM_OFFSET 20 +#define SSP_DEBUG_MSTK_SM_MSTK_IDLE (0x0 << 20) +#define SSP_DEBUG_MSTK_SM_MSTK_CKON (0x1 << 20) +#define SSP_DEBUG_MSTK_SM_MSTK_BS1 (0x2 << 20) +#define SSP_DEBUG_MSTK_SM_MSTK_TPC (0x3 << 20) +#define SSP_DEBUG_MSTK_SM_MSTK_BS2 (0x4 << 20) +#define SSP_DEBUG_MSTK_SM_MSTK_HDSHK (0x5 << 20) +#define SSP_DEBUG_MSTK_SM_MSTK_BS3 (0x6 << 20) +#define SSP_DEBUG_MSTK_SM_MSTK_RW (0x7 << 20) +#define SSP_DEBUG_MSTK_SM_MSTK_CRC1 (0x8 << 20) +#define SSP_DEBUG_MSTK_SM_MSTK_CRC2 (0x9 << 20) +#define SSP_DEBUG_MSTK_SM_MSTK_BS0 (0xa << 20) +#define SSP_DEBUG_MSTK_SM_MSTK_END1 (0xb << 20) +#define SSP_DEBUG_MSTK_SM_MSTK_END2W (0xc << 20) +#define SSP_DEBUG_MSTK_SM_MSTK_END2R (0xd << 20) +#define SSP_DEBUG_MSTK_SM_MSTK_DONE (0xe << 20) +#define SSP_DEBUG_CMD_OE (1 << 19) +#define SSP_DEBUG_DMA_SM_MASK (0x7 << 16) +#define SSP_DEBUG_DMA_SM_OFFSET 16 +#define SSP_DEBUG_DMA_SM_DMA_IDLE (0x0 << 16) +#define SSP_DEBUG_DMA_SM_DMA_DMAREQ (0x1 << 16) +#define SSP_DEBUG_DMA_SM_DMA_DMAACK (0x2 << 16) +#define SSP_DEBUG_DMA_SM_DMA_STALL (0x3 << 16) +#define SSP_DEBUG_DMA_SM_DMA_BUSY (0x4 << 16) +#define SSP_DEBUG_DMA_SM_DMA_DONE (0x5 << 16) +#define SSP_DEBUG_DMA_SM_DMA_COUNT (0x6 << 16) +#define SSP_DEBUG_MMC_SM_MASK (0xf << 12) +#define SSP_DEBUG_MMC_SM_OFFSET 12 +#define SSP_DEBUG_MMC_SM_MMC_IDLE (0x0 << 12) +#define SSP_DEBUG_MMC_SM_MMC_CMD (0x1 << 12) +#define SSP_DEBUG_MMC_SM_MMC_TRC (0x2 << 12) +#define SSP_DEBUG_MMC_SM_MMC_RESP (0x3 << 12) +#define SSP_DEBUG_MMC_SM_MMC_RPRX (0x4 << 12) +#define SSP_DEBUG_MMC_SM_MMC_TX (0x5 << 12) +#define SSP_DEBUG_MMC_SM_MMC_CTOK (0x6 << 12) +#define SSP_DEBUG_MMC_SM_MMC_RX (0x7 << 12) +#define SSP_DEBUG_MMC_SM_MMC_CCS (0x8 << 12) +#define SSP_DEBUG_MMC_SM_MMC_PUP (0x9 << 12) +#define SSP_DEBUG_MMC_SM_MMC_WAIT (0xa << 12) +#define SSP_DEBUG_CMD_SM_MASK (0x3 << 10) +#define SSP_DEBUG_CMD_SM_OFFSET 10 +#define SSP_DEBUG_CMD_SM_CSM_IDLE (0x0 << 10) +#define SSP_DEBUG_CMD_SM_CSM_INDEX (0x1 << 10) +#define SSP_DEBUG_CMD_SM_CSM_ARG (0x2 << 10) +#define SSP_DEBUG_CMD_SM_CSM_CRC (0x3 << 10) +#define SSP_DEBUG_SSP_CMD (1 << 9) +#define SSP_DEBUG_SSP_RESP (1 << 8) +#define SSP_DEBUG_SSP_RXD_MASK 0xff +#define SSP_DEBUG_SSP_RXD_OFFSET 0 + +#define SSP_VERSION_MAJOR_MASK (0xff << 24) +#define SSP_VERSION_MAJOR_OFFSET 24 +#define SSP_VERSION_MINOR_MASK (0xff << 16) +#define SSP_VERSION_MINOR_OFFSET 16 +#define SSP_VERSION_STEP_MASK 0xffff +#define SSP_VERSION_STEP_OFFSET 0 + +#endif /* __MX28_REGS_SSP_H__ */ diff --git a/arch/arm/include/asm/arch-mxs/regs-timrot.h b/arch/arm/include/asm/arch-mxs/regs-timrot.h new file mode 100644 index 0000000..3e8dfe7 --- /dev/null +++ b/arch/arm/include/asm/arch-mxs/regs-timrot.h @@ -0,0 +1,171 @@ +/* + * Freescale i.MX28 TIMROT Register Definitions + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * + * Based on code from LTIB: + * Copyright 2008-2010 Freescale Semiconductor, Inc. All Rights Reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __MX28_REGS_TIMROT_H__ +#define __MX28_REGS_TIMROT_H__ + +#include <asm/arch/regs-common.h> + +#ifndef __ASSEMBLY__ +struct mx28_timrot_regs { + mx28_reg_32(hw_timrot_rotctrl) + mx28_reg_32(hw_timrot_rotcount) + mx28_reg_32(hw_timrot_timctrl0) + mx28_reg_32(hw_timrot_running_count0) + mx28_reg_32(hw_timrot_fixed_count0) + mx28_reg_32(hw_timrot_match_count0) + mx28_reg_32(hw_timrot_timctrl1) + mx28_reg_32(hw_timrot_running_count1) + mx28_reg_32(hw_timrot_fixed_count1) + mx28_reg_32(hw_timrot_match_count1) + mx28_reg_32(hw_timrot_timctrl2) + mx28_reg_32(hw_timrot_running_count2) + mx28_reg_32(hw_timrot_fixed_count2) + mx28_reg_32(hw_timrot_match_count2) + mx28_reg_32(hw_timrot_timctrl3) + mx28_reg_32(hw_timrot_running_count3) + mx28_reg_32(hw_timrot_fixed_count3) + mx28_reg_32(hw_timrot_match_count3) + mx28_reg_32(hw_timrot_version) +}; +#endif + +#define TIMROT_ROTCTRL_SFTRST (1 << 31) +#define TIMROT_ROTCTRL_CLKGATE (1 << 30) +#define TIMROT_ROTCTRL_ROTARY_PRESENT (1 << 29) +#define TIMROT_ROTCTRL_TIM3_PRESENT (1 << 28) +#define TIMROT_ROTCTRL_TIM2_PRESENT (1 << 27) +#define TIMROT_ROTCTRL_TIM1_PRESENT (1 << 26) +#define TIMROT_ROTCTRL_TIM0_PRESENT (1 << 25) +#define TIMROT_ROTCTRL_STATE_MASK (0x7 << 22) +#define TIMROT_ROTCTRL_STATE_OFFSET 22 +#define TIMROT_ROTCTRL_DIVIDER_MASK (0x3f << 16) +#define TIMROT_ROTCTRL_DIVIDER_OFFSET 16 +#define TIMROT_ROTCTRL_RELATIVE (1 << 12) +#define TIMROT_ROTCTRL_OVERSAMPLE_MASK (0x3 << 10) +#define TIMROT_ROTCTRL_OVERSAMPLE_OFFSET 10 +#define TIMROT_ROTCTRL_OVERSAMPLE_8X (0x0 << 10) +#define TIMROT_ROTCTRL_OVERSAMPLE_4X (0x1 << 10) +#define TIMROT_ROTCTRL_OVERSAMPLE_2X (0x2 << 10) +#define TIMROT_ROTCTRL_OVERSAMPLE_1X (0x3 << 10) +#define TIMROT_ROTCTRL_POLARITY_B (1 << 9) +#define TIMROT_ROTCTRL_POLARITY_A (1 << 8) +#define TIMROT_ROTCTRL_SELECT_B_MASK (0xf << 4) +#define TIMROT_ROTCTRL_SELECT_B_OFFSET 4 +#define TIMROT_ROTCTRL_SELECT_B_NEVER_TICK (0x0 << 4) +#define TIMROT_ROTCTRL_SELECT_B_PWM0 (0x1 << 4) +#define TIMROT_ROTCTRL_SELECT_B_PWM1 (0x2 << 4) +#define TIMROT_ROTCTRL_SELECT_B_PWM2 (0x3 << 4) +#define TIMROT_ROTCTRL_SELECT_B_PWM3 (0x4 << 4) +#define TIMROT_ROTCTRL_SELECT_B_PWM4 (0x5 << 4) +#define TIMROT_ROTCTRL_SELECT_B_PWM5 (0x6 << 4) +#define TIMROT_ROTCTRL_SELECT_B_PWM6 (0x7 << 4) +#define TIMROT_ROTCTRL_SELECT_B_PWM7 (0x8 << 4) +#define TIMROT_ROTCTRL_SELECT_B_ROTARYA (0x9 << 4) +#define TIMROT_ROTCTRL_SELECT_B_ROTARYB (0xa << 4) +#define TIMROT_ROTCTRL_SELECT_A_MASK 0xf +#define TIMROT_ROTCTRL_SELECT_A_OFFSET 0 +#define TIMROT_ROTCTRL_SELECT_A_NEVER_TICK 0x0 +#define TIMROT_ROTCTRL_SELECT_A_PWM0 0x1 +#define TIMROT_ROTCTRL_SELECT_A_PWM1 0x2 +#define TIMROT_ROTCTRL_SELECT_A_PWM2 0x3 +#define TIMROT_ROTCTRL_SELECT_A_PWM3 0x4 +#define TIMROT_ROTCTRL_SELECT_A_PWM4 0x5 +#define TIMROT_ROTCTRL_SELECT_A_PWM5 0x6 +#define TIMROT_ROTCTRL_SELECT_A_PWM6 0x7 +#define TIMROT_ROTCTRL_SELECT_A_PWM7 0x8 +#define TIMROT_ROTCTRL_SELECT_A_ROTARYA 0x9 +#define TIMROT_ROTCTRL_SELECT_A_ROTARYB 0xa + +#define TIMROT_ROTCOUNT_UPDOWN_MASK 0xffff +#define TIMROT_ROTCOUNT_UPDOWN_OFFSET 0 + +#define TIMROT_TIMCTRLn_IRQ (1 << 15) +#define TIMROT_TIMCTRLn_IRQ_EN (1 << 14) +#define TIMROT_TIMCTRLn_MATCH_MODE (1 << 11) +#define TIMROT_TIMCTRLn_POLARITY (1 << 8) +#define TIMROT_TIMCTRLn_UPDATE (1 << 7) +#define TIMROT_TIMCTRLn_RELOAD (1 << 6) +#define TIMROT_TIMCTRLn_PRESCALE_MASK (0x3 << 4) +#define TIMROT_TIMCTRLn_PRESCALE_OFFSET 4 +#define TIMROT_TIMCTRLn_PRESCALE_DIV_BY_1 (0x0 << 4) +#define TIMROT_TIMCTRLn_PRESCALE_DIV_BY_2 (0x1 << 4) +#define TIMROT_TIMCTRLn_PRESCALE_DIV_BY_4 (0x2 << 4) +#define TIMROT_TIMCTRLn_PRESCALE_DIV_BY_8 (0x3 << 4) +#define TIMROT_TIMCTRLn_SELECT_MASK 0xf +#define TIMROT_TIMCTRLn_SELECT_OFFSET 0 +#define TIMROT_TIMCTRLn_SELECT_NEVER_TICK 0x0 +#define TIMROT_TIMCTRLn_SELECT_PWM0 0x1 +#define TIMROT_TIMCTRLn_SELECT_PWM1 0x2 +#define TIMROT_TIMCTRLn_SELECT_PWM2 0x3 +#define TIMROT_TIMCTRLn_SELECT_PWM3 0x4 +#define TIMROT_TIMCTRLn_SELECT_PWM4 0x5 +#define TIMROT_TIMCTRLn_SELECT_PWM5 0x6 +#define TIMROT_TIMCTRLn_SELECT_PWM6 0x7 +#define TIMROT_TIMCTRLn_SELECT_PWM7 0x8 +#define TIMROT_TIMCTRLn_SELECT_ROTARYA 0x9 +#define TIMROT_TIMCTRLn_SELECT_ROTARYB 0xa +#define TIMROT_TIMCTRLn_SELECT_32KHZ_XTAL 0xb +#define TIMROT_TIMCTRLn_SELECT_8KHZ_XTAL 0xc +#define TIMROT_TIMCTRLn_SELECT_4KHZ_XTAL 0xd +#define TIMROT_TIMCTRLn_SELECT_1KHZ_XTAL 0xe +#define TIMROT_TIMCTRLn_SELECT_TICK_ALWAYS 0xf + +#define TIMROT_RUNNING_COUNTn_RUNNING_COUNT_MASK 0xffffffff +#define TIMROT_RUNNING_COUNTn_RUNNING_COUNT_OFFSET 0 + +#define TIMROT_FIXED_COUNTn_FIXED_COUNT_MASK 0xffffffff +#define TIMROT_FIXED_COUNTn_FIXED_COUNT_OFFSET 0 + +#define TIMROT_MATCH_COUNTn_MATCH_COUNT_MASK 0xffffffff +#define TIMROT_MATCH_COUNTn_MATCH_COUNT_OFFSET 0 + +#define TIMROT_TIMCTRL3_TEST_SIGNAL_MASK (0xf << 16) +#define TIMROT_TIMCTRL3_TEST_SIGNAL_OFFSET 16 +#define TIMROT_TIMCTRL3_TEST_SIGNAL_NEVER_TICK (0x0 << 16) +#define TIMROT_TIMCTRL3_TEST_SIGNAL_PWM0 (0x1 << 16) +#define TIMROT_TIMCTRL3_TEST_SIGNAL_PWM1 (0x2 << 16) +#define TIMROT_TIMCTRL3_TEST_SIGNAL_PWM2 (0x3 << 16) +#define TIMROT_TIMCTRL3_TEST_SIGNAL_PWM3 (0x4 << 16) +#define TIMROT_TIMCTRL3_TEST_SIGNAL_PWM4 (0x5 << 16) +#define TIMROT_TIMCTRL3_TEST_SIGNAL_PWM5 (0x6 << 16) +#define TIMROT_TIMCTRL3_TEST_SIGNAL_PWM6 (0x7 << 16) +#define TIMROT_TIMCTRL3_TEST_SIGNAL_PWM7 (0x8 << 16) +#define TIMROT_TIMCTRL3_TEST_SIGNAL_ROTARYA (0x9 << 16) +#define TIMROT_TIMCTRL3_TEST_SIGNAL_ROTARYB (0xa << 16) +#define TIMROT_TIMCTRL3_TEST_SIGNAL_32KHZ_XTAL (0xb << 16) +#define TIMROT_TIMCTRL3_TEST_SIGNAL_8KHZ_XTAL (0xc << 16) +#define TIMROT_TIMCTRL3_TEST_SIGNAL_4KHZ_XTAL (0xd << 16) +#define TIMROT_TIMCTRL3_TEST_SIGNAL_1KHZ_XTAL (0xe << 16) +#define TIMROT_TIMCTRL3_TEST_SIGNAL_TICK_ALWAYS (0xf << 16) +#define TIMROT_TIMCTRL3_DUTY_CYCLE (1 << 9) + +#define TIMROT_VERSION_MAJOR_MASK (0xff << 24) +#define TIMROT_VERSION_MAJOR_OFFSET 24 +#define TIMROT_VERSION_MINOR_MASK (0xff << 16) +#define TIMROT_VERSION_MINOR_OFFSET 16 +#define TIMROT_VERSION_STEP_MASK 0xffff +#define TIMROT_VERSION_STEP_OFFSET 0 + +#endif /* __MX28_REGS_TIMROT_H__ */ diff --git a/arch/arm/include/asm/arch-mxs/regs-usb.h b/arch/arm/include/asm/arch-mxs/regs-usb.h new file mode 100644 index 0000000..ea61de8 --- /dev/null +++ b/arch/arm/include/asm/arch-mxs/regs-usb.h @@ -0,0 +1,178 @@ +/* + * Freescale i.MX28 USB OTG Register Definitions + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __REGS_USB_H__ +#define __REGS_USB_H__ + +struct mx28_usb_regs { + uint32_t hw_usbctrl_id; /* 0x000 */ + uint32_t hw_usbctrl_hwgeneral; /* 0x004 */ + uint32_t hw_usbctrl_hwhost; /* 0x008 */ + uint32_t hw_usbctrl_hwdevice; /* 0x00c */ + uint32_t hw_usbctrl_hwtxbuf; /* 0x010 */ + uint32_t hw_usbctrl_hwrxbuf; /* 0x014 */ + + uint32_t reserved1[26]; + + uint32_t hw_usbctrl_gptimer0ld; /* 0x080 */ + uint32_t hw_usbctrl_gptimer0ctrl; /* 0x084 */ + uint32_t hw_usbctrl_gptimer1ld; /* 0x088 */ + uint32_t hw_usbctrl_gptimer1ctrl; /* 0x08c */ + uint32_t hw_usbctrl_sbuscfg; /* 0x090 */ + + uint32_t reserved2[27]; + + uint32_t hw_usbctrl_caplength; /* 0x100 */ + uint32_t hw_usbctrl_hcsparams; /* 0x104 */ + uint32_t hw_usbctrl_hccparams; /* 0x108 */ + + uint32_t reserved3[5]; + + uint32_t hw_usbctrl_dciversion; /* 0x120 */ + uint32_t hw_usbctrl_dccparams; /* 0x124 */ + + uint32_t reserved4[6]; + + uint32_t hw_usbctrl_usbcmd; /* 0x140 */ + uint32_t hw_usbctrl_usbsts; /* 0x144 */ + uint32_t hw_usbctrl_usbintr; /* 0x148 */ + uint32_t hw_usbctrl_frindex; /* 0x14c */ + + uint32_t reserved5; + + union { + uint32_t hw_usbctrl_periodiclistbase; /* 0x154 */ + uint32_t hw_usbctrl_deviceaddr; /* 0x154 */ + }; + union { + uint32_t hw_usbctrl_asynclistaddr; /* 0x158 */ + uint32_t hw_usbctrl_endpointlistaddr; /* 0x158 */ + }; + + uint32_t hw_usbctrl_ttctrl; /* 0x15c */ + uint32_t hw_usbctrl_burstsize; /* 0x160 */ + uint32_t hw_usbctrl_txfilltuning; /* 0x164 */ + + uint32_t reserved6; + + uint32_t hw_usbctrl_ic_usb; /* 0x16c */ + uint32_t hw_usbctrl_ulpi; /* 0x170 */ + + uint32_t reserved7; + + uint32_t hw_usbctrl_endptnak; /* 0x178 */ + uint32_t hw_usbctrl_endptnaken; /* 0x17c */ + + uint32_t reserved8; + + uint32_t hw_usbctrl_portsc1; /* 0x184 */ + + uint32_t reserved9[7]; + + uint32_t hw_usbctrl_otgsc; /* 0x1a4 */ + uint32_t hw_usbctrl_usbmode; /* 0x1a8 */ + uint32_t hw_usbctrl_endptsetupstat; /* 0x1ac */ + uint32_t hw_usbctrl_endptprime; /* 0x1b0 */ + uint32_t hw_usbctrl_endptflush; /* 0x1b4 */ + uint32_t hw_usbctrl_endptstat; /* 0x1b8 */ + uint32_t hw_usbctrl_endptcomplete; /* 0x1bc */ + uint32_t hw_usbctrl_endptctrl0; /* 0x1c0 */ + uint32_t hw_usbctrl_endptctrl1; /* 0x1c4 */ + uint32_t hw_usbctrl_endptctrl2; /* 0x1c8 */ + uint32_t hw_usbctrl_endptctrl3; /* 0x1cc */ + uint32_t hw_usbctrl_endptctrl4; /* 0x1d0 */ + uint32_t hw_usbctrl_endptctrl5; /* 0x1d4 */ + uint32_t hw_usbctrl_endptctrl6; /* 0x1d8 */ + uint32_t hw_usbctrl_endptctrl7; /* 0x1dc */ +}; + +#define CLKCTRL_PLL0CTRL0_LFR_SEL_MASK (0x3 << 28) + +#define HW_USBCTRL_ID_CIVERSION_OFFSET 29 +#define HW_USBCTRL_ID_CIVERSION_MASK (0x7 << 29) +#define HW_USBCTRL_ID_VERSION_OFFSET 25 +#define HW_USBCTRL_ID_VERSION_MASK (0xf << 25) +#define HW_USBCTRL_ID_REVISION_OFFSET 21 +#define HW_USBCTRL_ID_REVISION_MASK (0xf << 21) +#define HW_USBCTRL_ID_TAG_OFFSET 16 +#define HW_USBCTRL_ID_TAG_MASK (0x1f << 16) +#define HW_USBCTRL_ID_NID_OFFSET 8 +#define HW_USBCTRL_ID_NID_MASK (0x3f << 8) +#define HW_USBCTRL_ID_ID_OFFSET 0 +#define HW_USBCTRL_ID_ID_MASK (0x3f << 0) + +#define HW_USBCTRL_HWGENERAL_SM_OFFSET 9 +#define HW_USBCTRL_HWGENERAL_SM_MASK (0x3 << 9) +#define HW_USBCTRL_HWGENERAL_PHYM_OFFSET 6 +#define HW_USBCTRL_HWGENERAL_PHYM_MASK (0x7 << 6) +#define HW_USBCTRL_HWGENERAL_PHYW_OFFSET 4 +#define HW_USBCTRL_HWGENERAL_PHYW_MASK (0x3 << 4) +#define HW_USBCTRL_HWGENERAL_BWT (1 << 3) +#define HW_USBCTRL_HWGENERAL_CLKC_OFFSET 1 +#define HW_USBCTRL_HWGENERAL_CLKC_MASK (0x3 << 1) +#define HW_USBCTRL_HWGENERAL_RT (1 << 0) + +#define HW_USBCTRL_HWHOST_TTPER_OFFSET 24 +#define HW_USBCTRL_HWHOST_TTPER_MASK (0xff << 24) +#define HW_USBCTRL_HWHOST_TTASY_OFFSET 16 +#define HW_USBCTRL_HWHOST_TTASY_MASK (0xff << 19) +#define HW_USBCTRL_HWHOST_NPORT_OFFSET 1 +#define HW_USBCTRL_HWHOST_NPORT_MASK (0x7 << 1) +#define HW_USBCTRL_HWHOST_HC (1 << 0) + +#define HW_USBCTRL_HWDEVICE_DEVEP_OFFSET 1 +#define HW_USBCTRL_HWDEVICE_DEVEP_MASK (0x1f << 1) +#define HW_USBCTRL_HWDEVICE_DC (1 << 0) + +#define HW_USBCTRL_HWTXBUF_TXLCR (1 << 31) +#define HW_USBCTRL_HWTXBUF_TXCHANADD_OFFSET 16 +#define HW_USBCTRL_HWTXBUF_TXCHANADD_MASK (0xff << 16) +#define HW_USBCTRL_HWTXBUF_TXADD_OFFSET 8 +#define HW_USBCTRL_HWTXBUF_TXADD_MASK (0xff << 8) +#define HW_USBCTRL_HWTXBUF_TXBURST_OFFSET 0 +#define HW_USBCTRL_HWTXBUF_TXBURST_MASK 0xff + +#define HW_USBCTRL_HWRXBUF_RXADD_OFFSET 8 +#define HW_USBCTRL_HWRXBUF_RXADD_MASK (0xff << 8) +#define HW_USBCTRL_HWRXBUF_RXBURST_OFFSET 0 +#define HW_USBCTRL_HWRXBUF_RXBURST_MASK 0xff + +#define HW_USBCTRL_GPTIMERLD_GPTLD_OFFSET 0 +#define HW_USBCTRL_GPTIMERLD_GPTLD_MASK 0xffffff + +#define HW_USBCTRL_GPTIMERCTRL_GPTRUN (1 << 31) +#define HW_USBCTRL_GPTIMERCTRL_GPTRST (1 << 30) +#define HW_USBCTRL_GPTIMERCTRL_GPTMODE (1 << 24) +#define HW_USBCTRL_GPTIMERCTRL_GPTCNT_OFFSET 0 +#define HW_USBCTRL_GPTIMERCTRL_GPTCNT_MASK 0xffffff + +#define HW_USBCTRL_SBUSCFG_AHBBURST_OFFSET 0 +#define HW_USBCTRL_SBUSCFG_AHBBURST_MASK 0x7 +#define HW_USBCTRL_SBUSCFG_AHBBURST_U_INCR 0x0 +#define HW_USBCTRL_SBUSCFG_AHBBURST_S_INCR4 0x1 +#define HW_USBCTRL_SBUSCFG_AHBBURST_S_INCR8 0x2 +#define HW_USBCTRL_SBUSCFG_AHBBURST_S_INCR16 0x3 +#define HW_USBCTRL_SBUSCFG_AHBBURST_U_INCR4 0x5 +#define HW_USBCTRL_SBUSCFG_AHBBURST_U_INCR8 0x6 +#define HW_USBCTRL_SBUSCFG_AHBBURST_U_INCR16 0x7 + +#endif /* __REGS_USB_H__ */ diff --git a/arch/arm/include/asm/arch-mxs/regs-usbphy.h b/arch/arm/include/asm/arch-mxs/regs-usbphy.h new file mode 100644 index 0000000..0291d81 --- /dev/null +++ b/arch/arm/include/asm/arch-mxs/regs-usbphy.h @@ -0,0 +1,151 @@ +/* + * Freescale i.MX28 USB PHY Register Definitions + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __REGS_USBPHY_H__ +#define __REGS_USBPHY_H__ + +struct mx28_usbphy_regs { + mx28_reg_32(hw_usbphy_pwd) + mx28_reg_32(hw_usbphy_tx) + mx28_reg_32(hw_usbphy_rx) + mx28_reg_32(hw_usbphy_ctrl) + mx28_reg_32(hw_usbphy_status) + mx28_reg_32(hw_usbphy_debug) + mx28_reg_32(hw_usbphy_debug0_status) + mx28_reg_32(hw_usbphy_debug1) + mx28_reg_32(hw_usbphy_version) + mx28_reg_32(hw_usbphy_ip) +}; + +#define USBPHY_PWD_RXPWDRX (1 << 20) +#define USBPHY_PWD_RXPWDDIFF (1 << 19) +#define USBPHY_PWD_RXPWD1PT1 (1 << 18) +#define USBPHY_PWD_RXPWDENV (1 << 17) +#define USBPHY_PWD_TXPWDV2I (1 << 12) +#define USBPHY_PWD_TXPWDIBIAS (1 << 11) +#define USBPHY_PWD_TXPWDFS (1 << 10) + +#define USBPHY_TX_USBPHY_TX_EDGECTRL_OFFSET 26 +#define USBPHY_TX_USBPHY_TX_EDGECTRL_MASK (0x7 << 26) +#define USBPHY_TX_USBPHY_TX_SYNC_INVERT (1 << 25) +#define USBPHY_TX_USBPHY_TX_SYNC_MUX (1 << 24) +#define USBPHY_TX_TXENCAL45DP (1 << 21) +#define USBPHY_TX_TXCAL45DP_OFFSET 16 +#define USBPHY_TX_TXCAL45DP_MASK (0xf << 16) +#define USBPHY_TX_TXENCAL45DM (1 << 13) +#define USBPHY_TX_TXCAL45DM_OFFSET 8 +#define USBPHY_TX_TXCAL45DM_MASK (0xf << 8) +#define USBPHY_TX_D_CAL_OFFSET 0 +#define USBPHY_TX_D_CAL_MASK 0xf + +#define USBPHY_RX_RXDBYPASS (1 << 22) +#define USBPHY_RX_DISCONADJ_OFFSET 4 +#define USBPHY_RX_DISCONADJ_MASK (0x7 << 4) +#define USBPHY_RX_ENVADJ_OFFSET 0 +#define USBPHY_RX_ENVADJ_MASK 0x7 + +#define USBPHY_CTRL_SFTRST (1 << 31) +#define USBPHY_CTRL_CLKGATE (1 << 30) +#define USBPHY_CTRL_UTMI_SUSPENDM (1 << 29) +#define USBPHY_CTRL_HOST_FORCE_LS_SE0 (1 << 28) +#define USBPHY_CTRL_ENAUTOSET_USBCLKS (1 << 26) +#define USBPHY_CTRL_ENAUTOCLR_USBCLKGATE (1 << 25) +#define USBPHY_CTRL_FSDLL_RST_EN (1 << 24) +#define USBPHY_CTRL_ENVBUSCHG_WKUP (1 << 23) +#define USBPHY_CTRL_ENIDCHG_WKUP (1 << 22) +#define USBPHY_CTRL_ENDPDMCHG_WKUP (1 << 21) +#define USBPHY_CTRL_ENAUTOCLR_PHY_PWD (1 << 20) +#define USBPHY_CTRL_ENAUTOCLR_CLKGATE (1 << 19) +#define USBPHY_CTRL_ENAUTO_PWRON_PLL (1 << 18) +#define USBPHY_CTRL_WAKEUP_IRQ (1 << 17) +#define USBPHY_CTRL_ENIRQWAKEUP (1 << 16) +#define USBPHY_CTRL_ENUTMILEVEL3 (1 << 15) +#define USBPHY_CTRL_ENUTMILEVEL2 (1 << 14) +#define USBPHY_CTRL_DATA_ON_LRADC (1 << 13) +#define USBPHY_CTRL_DEVPLUGIN_IRQ (1 << 12) +#define USBPHY_CTRL_ENIRQDEVPLUGIN (1 << 11) +#define USBPHY_CTRL_RESUME_IRQ (1 << 10) +#define USBPHY_CTRL_ENIRQRESUMEDETECT (1 << 9) +#define USBPHY_CTRL_RESUMEIRQSTICKY (1 << 8) +#define USBPHY_CTRL_ENOTGIDDETECT (1 << 7) +#define USBPHY_CTRL_DEVPLUGIN_POLARITY (1 << 5) +#define USBPHY_CTRL_ENDEVPLUGINDETECT (1 << 4) +#define USBPHY_CTRL_HOSTDISCONDETECT_IRQ (1 << 3) +#define USBPHY_CTRL_ENIRQHOSTDISCON (1 << 2) +#define USBPHY_CTRL_ENHOSTDISCONDETECT (1 << 1) + +#define USBPHY_STATUS_RESUME_STATUS (1 << 10) +#define USBPHY_STATUS_OTGID_STATUS (1 << 8) +#define USBPHY_STATUS_DEVPLUGIN_STATUS (1 << 6) +#define USBPHY_STATUS_HOSTDISCONDETECT_STATUS (1 << 3) + +#define USBPHY_DEBUG_CLKGATE (1 << 30) +#define USBPHY_DEBUG_HOST_RESUME_DEBUG (1 << 29) +#define USBPHY_DEBUG_SQUELCHRESETLENGTH_OFFSET 25 +#define USBPHY_DEBUG_SQUELCHRESETLENGTH_MASK (0xf << 25) +#define USBPHY_DEBUG_ENSQUELCHRESET (1 << 24) +#define USBPHY_DEBUG_SQUELCHRESETCOUNT_OFFSET 16 +#define USBPHY_DEBUG_SQUELCHRESETCOUNT_MASK (0x1f << 16) +#define USBPHY_DEBUG_ENTX2RXCOUNT (1 << 12) +#define USBPHY_DEBUG_TX2RXCOUNT_OFFSET 8 +#define USBPHY_DEBUG_TX2RXCOUNT_MASK (0xf << 8) +#define USBPHY_DEBUG_ENHSTPULLDOWN_OFFSET 4 +#define USBPHY_DEBUG_ENHSTPULLDOWN_MASK (0x3 << 4) +#define USBPHY_DEBUG_HSTPULLDOWN_OFFSET 2 +#define USBPHY_DEBUG_HSTPULLDOWN_MASK (0x3 << 2) +#define USBPHY_DEBUG_DEBUG_INTERFACE_HOLD (1 << 1) +#define USBPHY_DEBUG_OTGIDPIDLOCK (1 << 0) + +#define USBPHY_DEBUG0_STATUS_SQUELCH_COUNT_OFFSET 26 +#define USBPHY_DEBUG0_STATUS_SQUELCH_COUNT_MASK (0x3f << 26) +#define USBPHY_DEBUG0_STATUS_UTMI_RXERROR_OFFSET 16 +#define USBPHY_DEBUG0_STATUS_UTMI_RXERROR_MASK (0x3ff << 16) +#define USBPHY_DEBUG0_STATUS_LOOP_BACK_OFFSET 0 +#define USBPHY_DEBUG0_STATUS_LOOP_BACK_MASK 0xffff + +#define USBPHY_DEBUG1_ENTAILADJVD_OFFSET 13 +#define USBPHY_DEBUG1_ENTAILADJVD_MASK (0x3 << 13) +#define USBPHY_DEBUG1_ENTX2TX (1 << 12) +#define USBPHY_DEBUG1_DBG_ADDRESS_OFFSET 0 +#define USBPHY_DEBUG1_DBG_ADDRESS_MASK 0xf + +#define USBPHY_VERSION_MAJOR_MASK (0xff << 24) +#define USBPHY_VERSION_MAJOR_OFFSET 24 +#define USBPHY_VERSION_MINOR_MASK (0xff << 16) +#define USBPHY_VERSION_MINOR_OFFSET 16 +#define USBPHY_VERSION_STEP_MASK 0xffff +#define USBPHY_VERSION_STEP_OFFSET 0 + +#define USBPHY_IP_DIV_SEL_OFFSET 23 +#define USBPHY_IP_DIV_SEL_MASK (0x3 << 23) +#define USBPHY_IP_LFR_SEL_OFFSET 21 +#define USBPHY_IP_LFR_SEL_MASK (0x3 << 21) +#define USBPHY_IP_CP_SEL_OFFSET 19 +#define USBPHY_IP_CP_SEL_MASK (0x3 << 19) +#define USBPHY_IP_TSTI_TX_DP (1 << 18) +#define USBPHY_IP_TSTI_TX_DM (1 << 17) +#define USBPHY_IP_ANALOG_TESTMODE (1 << 16) +#define USBPHY_IP_EN_USB_CLKS (1 << 2) +#define USBPHY_IP_PLL_LOCKED (1 << 1) +#define USBPHY_IP_PLL_POWER (1 << 0) + +#endif /* __REGS_USBPHY_H__ */ diff --git a/arch/arm/include/asm/arch-mxs/sys_proto.h b/arch/arm/include/asm/arch-mxs/sys_proto.h new file mode 100644 index 0000000..e701c64 --- /dev/null +++ b/arch/arm/include/asm/arch-mxs/sys_proto.h @@ -0,0 +1,74 @@ +/* + * Freescale i.MX28 MX28 specific functions + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __MX28_H__ +#define __MX28_H__ + +int mx28_reset_block(struct mx28_register_32 *reg); +int mx28_wait_mask_set(struct mx28_register_32 *reg, + uint32_t mask, + int timeout); +int mx28_wait_mask_clr(struct mx28_register_32 *reg, + uint32_t mask, + int timeout); + +int mxsmmc_initialize(bd_t *bis, int id, int (*wp)(int)); + +#ifdef CONFIG_SPL_BUILD +#include <asm/arch/iomux-mx28.h> +void mx28_common_spl_init(const iomux_cfg_t *iomux_setup, + const unsigned int iomux_size); +#endif + +struct mx28_pair { + uint8_t boot_pads; + uint8_t boot_mask; + const char *mode; +}; + +static const struct mx28_pair mx28_boot_modes[] = { + { 0x00, 0x0f, "USB #0" }, + { 0x01, 0x1f, "I2C #0, master, 3V3" }, + { 0x11, 0x1f, "I2C #0, master, 1V8" }, + { 0x02, 0x1f, "SSP SPI #2, master, 3V3 NOR" }, + { 0x12, 0x1f, "SSP SPI #2, master, 1V8 NOR" }, + { 0x03, 0x1f, "SSP SPI #3, master, 3V3 NOR" }, + { 0x13, 0x1f, "SSP SPI #3, master, 1V8 NOR" }, + { 0x04, 0x1f, "NAND, 3V3" }, + { 0x14, 0x1f, "NAND, 1V8" }, + { 0x08, 0x1f, "SSP SPI #3, master, 3V3 EEPROM" }, + { 0x18, 0x1f, "SSP SPI #3, master, 1V8 EEPROM" }, + { 0x09, 0x1f, "SSP SD/MMC #0, 3V3" }, + { 0x19, 0x1f, "SSP SD/MMC #0, 1V8" }, + { 0x0a, 0x1f, "SSP SD/MMC #1, 3V3" }, + { 0x1a, 0x1f, "SSP SD/MMC #1, 1V8" }, + { 0x00, 0x00, "Reserved/Unknown/Wrong" }, +}; + +struct mx28_spl_data { + uint8_t boot_mode_idx; + uint32_t mem_dram_size; +}; + +int mx28_dram_init(void); + +#endif /* __MX28_H__ */ diff --git a/boards.cfg b/boards.cfg index 6c24697..91ce997 100644 --- a/boards.cfg +++ b/boards.cfg @@ -163,8 +163,8 @@ tx25 arm arm926ejs tx25 karo zmx25 arm arm926ejs zmx25 syteco mx25 imx27lite arm arm926ejs imx27lite logicpd mx27 magnesium arm arm926ejs imx27lite logicpd mx27 -m28evk arm arm926ejs - denx mx28 -mx28evk arm arm926ejs - freescale mx28 +m28evk arm arm926ejs - denx mxs m28evk +mx28evk arm arm926ejs - freescale mxs mx28evk nhk8815 arm arm926ejs nhk8815 st nomadik nhk8815_onenand arm arm926ejs nhk8815 st nomadik nhk8815:BOOT_ONENAND omap5912osk arm arm926ejs - ti omap diff --git a/doc/README.m28 b/doc/README.m28 index 7dee8ce..7f13e63 100644 --- a/doc/README.m28 +++ b/doc/README.m28 @@ -4,7 +4,7 @@ DENX M28EVK Files of the M28/M28EVK port ----------------------------
-arch/arm/cpu/arm926ejs/mx28/ - The CPU support code for the Freescale i.MX28 +arch/arm/cpu/arm926ejs/mxs/ - The CPU support code for the Freescale i.MX28 arch/arm/include/asm/arch-mx28/ - Header files for the Freescale i.MX28 board/denx/m28evk/ - M28EVK board specific files include/configs/m28evk.h - M28EVK configuration file diff --git a/doc/README.mx28evk b/doc/README.mx28evk index c6c3d37..8b10135 100644 --- a/doc/README.mx28evk +++ b/doc/README.mx28evk @@ -6,10 +6,10 @@ Supported hardware: only MX28EVK rev D is supported in U-boot. Files of the MX28EVK port --------------------------
-arch/arm/cpu/arm926ejs/mx28/ - The CPU support code for the Freescale i.MX28 +arch/arm/cpu/arm926ejs/mxs/ - The CPU support code for the Freescale i.MX28 arch/arm/include/asm/arch-mx28/ - Header files for the Freescale i.MX28 -board/freescale/mx28evk/ - MX28EVK board specific files -include/configs/mx28evk.h - MX28EVK configuration file +board/freescale/mxsevk/ - MX28EVK board specific files +include/configs/mxsevk.h - MX28EVK configuration file
Jumper configuration --------------------- diff --git a/include/configs/m28evk.h b/include/configs/m28evk.h index ebf7e39..53b3954 100644 --- a/include/configs/m28evk.h +++ b/include/configs/m28evk.h @@ -50,8 +50,8 @@ */ #define CONFIG_SPL #define CONFIG_SPL_NO_CPU_SUPPORT_CODE -#define CONFIG_SPL_START_S_PATH "arch/arm/cpu/arm926ejs/mx28" -#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/arm926ejs/mx28/u-boot-spl.lds" +#define CONFIG_SPL_START_S_PATH "arch/arm/cpu/arm926ejs/mxs" +#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds" #define CONFIG_SPL_LIBCOMMON_SUPPORT #define CONFIG_SPL_LIBGENERIC_SUPPORT #define CONFIG_SPL_GPIO_SUPPORT diff --git a/include/configs/mx28evk.h b/include/configs/mx28evk.h index 5ccfe70..37d58f6 100644 --- a/include/configs/mx28evk.h +++ b/include/configs/mx28evk.h @@ -42,8 +42,8 @@ */ #define CONFIG_SPL #define CONFIG_SPL_NO_CPU_SUPPORT_CODE -#define CONFIG_SPL_START_S_PATH "arch/arm/cpu/arm926ejs/mx28" -#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/arm926ejs/mx28/u-boot-spl.lds" +#define CONFIG_SPL_START_S_PATH "arch/arm/cpu/arm926ejs/mxs" +#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds" #define CONFIG_SPL_LIBCOMMON_SUPPORT #define CONFIG_SPL_LIBGENERIC_SUPPORT #define CONFIG_SPL_GPIO_SUPPORT
On Fri, May 11, 2012 at 12:38 PM, Otavio Salvador otavio@ossystems.com.br wrote:
Most code can be shared amount i.MX23 and i.MX28 as both are from i.MXS family; this source directory structure makes easy to share code among them.
Signed-off-by: Otavio Salvador otavio@ossystems.com.br
This and next patches are not yet ready for merging but I'd like to get an review on the concept of it.
As the register accessing mode is the same for all i.MXS SoCs we ought to use 'mxs' prefix intead of 'mx28'.
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- arch/arm/cpu/arm926ejs/mxs/clock.c | 4 +- arch/arm/cpu/arm926ejs/mxs/iomux.c | 6 +- arch/arm/cpu/arm926ejs/mxs/mx28.c | 6 +- arch/arm/include/asm/arch-mxs/regs-apbh.h | 254 +++++++++++++------------- arch/arm/include/asm/arch-mxs/regs-bch.h | 42 ++--- arch/arm/include/asm/arch-mxs/regs-clkctrl.h | 58 +++--- arch/arm/include/asm/arch-mxs/regs-common.h | 34 ++-- arch/arm/include/asm/arch-mxs/regs-digctl.h | 50 ++--- arch/arm/include/asm/arch-mxs/regs-gpmi.h | 26 +-- arch/arm/include/asm/arch-mxs/regs-i2c.h | 28 +-- arch/arm/include/asm/arch-mxs/regs-ocotp.h | 86 ++++----- arch/arm/include/asm/arch-mxs/regs-pinctrl.h | 168 ++++++++--------- arch/arm/include/asm/arch-mxs/regs-power.h | 28 +-- arch/arm/include/asm/arch-mxs/regs-rtc.h | 28 +-- arch/arm/include/asm/arch-mxs/regs-ssp.h | 40 ++-- arch/arm/include/asm/arch-mxs/regs-timrot.h | 38 ++-- arch/arm/include/asm/arch-mxs/regs-usbphy.h | 20 +- arch/arm/include/asm/arch-mxs/sys_proto.h | 6 +- drivers/gpio/mxs_gpio.c | 16 +- drivers/usb/host/ehci-mxs.c | 8 +- 20 files changed, 473 insertions(+), 473 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mxs/clock.c b/arch/arm/cpu/arm926ejs/mxs/clock.c index 0439f9c..3e29c56 100644 --- a/arch/arm/cpu/arm926ejs/mxs/clock.c +++ b/arch/arm/cpu/arm926ejs/mxs/clock.c @@ -207,7 +207,7 @@ void mx28_set_sspclk(enum mxs_sspclock ssp, uint32_t freq, int xtal) return;
clkreg = (uint32_t)(&clkctrl_regs->hw_clkctrl_ssp0) + - (ssp * sizeof(struct mx28_register_32)); + (ssp * sizeof(struct mxs_register_32));
clrbits_le32(clkreg, CLKCTRL_SSP_CLKGATE); while (readl(clkreg) & CLKCTRL_SSP_CLKGATE) @@ -256,7 +256,7 @@ static uint32_t mx28_get_sspclk(enum mxs_sspclock ssp) return XTAL_FREQ_KHZ;
tmp = readl(clkreg) & CLKCTRL_SSP_DIV_MASK;
diff --git a/arch/arm/cpu/arm926ejs/mxs/iomux.c b/arch/arm/cpu/arm926ejs/mxs/iomux.c index 12916b6..73f1446 100644 --- a/arch/arm/cpu/arm926ejs/mxs/iomux.c +++ b/arch/arm/cpu/arm926ejs/mxs/iomux.c @@ -43,7 +43,7 @@ int mxs_iomux_setup_pad(iomux_cfg_t pad) { u32 reg, ofs, bp, bm; void *iomux_base = (void *)MXS_PINCTRL_BASE; - struct mx28_register_32 *mxs_reg; + struct mxs_register_32 *mxs_reg;
/* muxsel */ ofs = 0x100; @@ -70,7 +70,7 @@ int mxs_iomux_setup_pad(iomux_cfg_t pad) /* vol */ if (PAD_VOL_VALID(pad)) { bp = PAD_PIN(pad) % 8 * 4 + 2; - mxs_reg = (struct mx28_register_32 *)(iomux_base + ofs); + mxs_reg = (struct mxs_register_32 *)(iomux_base + ofs); if (PAD_VOL(pad)) writel(1 << bp, &mxs_reg->reg_set); else @@ -82,7 +82,7 @@ int mxs_iomux_setup_pad(iomux_cfg_t pad) ofs = PULL_OFFSET; ofs += PAD_BANK(pad) * 0x10; bp = PAD_PIN(pad); - mxs_reg = (struct mx28_register_32 *)(iomux_base + ofs); + mxs_reg = (struct mxs_register_32 *)(iomux_base + ofs); if (PAD_PULL(pad)) writel(1 << bp, &mxs_reg->reg_set); else diff --git a/arch/arm/cpu/arm926ejs/mxs/mx28.c b/arch/arm/cpu/arm926ejs/mxs/mx28.c index a82ff25..a0ec06e 100644 --- a/arch/arm/cpu/arm926ejs/mxs/mx28.c +++ b/arch/arm/cpu/arm926ejs/mxs/mx28.c @@ -81,7 +81,7 @@ void enable_caches(void) #endif }
-int mx28_wait_mask_set(struct mx28_register_32 *reg, uint32_t mask, int timeout) +int mx28_wait_mask_set(struct mxs_register_32 *reg, uint32_t mask, int timeout) { while (--timeout) { if ((readl(®->reg) & mask) == mask) @@ -92,7 +92,7 @@ int mx28_wait_mask_set(struct mx28_register_32 *reg, uint32_t mask, int timeout) return !timeout; }
-int mx28_wait_mask_clr(struct mx28_register_32 *reg, uint32_t mask, int timeout) +int mx28_wait_mask_clr(struct mxs_register_32 *reg, uint32_t mask, int timeout) { while (--timeout) { if ((readl(®->reg) & mask) == 0) @@ -103,7 +103,7 @@ int mx28_wait_mask_clr(struct mx28_register_32 *reg, uint32_t mask, int timeout) return !timeout; }
-int mx28_reset_block(struct mx28_register_32 *reg) +int mx28_reset_block(struct mxs_register_32 *reg) { /* Clear SFTRST */ writel(MX28_BLOCK_SFTRST, ®->reg_clr); diff --git a/arch/arm/include/asm/arch-mxs/regs-apbh.h b/arch/arm/include/asm/arch-mxs/regs-apbh.h index 91d7bc8..7c6bd04 100644 --- a/arch/arm/include/asm/arch-mxs/regs-apbh.h +++ b/arch/arm/include/asm/arch-mxs/regs-apbh.h @@ -30,142 +30,142 @@
#ifndef __ASSEMBLY__ struct mx28_apbh_regs { - mx28_reg_32(hw_apbh_ctrl0) - mx28_reg_32(hw_apbh_ctrl1) - mx28_reg_32(hw_apbh_ctrl2) - mx28_reg_32(hw_apbh_channel_ctrl) - mx28_reg_32(hw_apbh_devsel) - mx28_reg_32(hw_apbh_dma_burst_size) - mx28_reg_32(hw_apbh_debug) + mxs_reg_32(hw_apbh_ctrl0) + mxs_reg_32(hw_apbh_ctrl1) + mxs_reg_32(hw_apbh_ctrl2) + mxs_reg_32(hw_apbh_channel_ctrl) + mxs_reg_32(hw_apbh_devsel) + mxs_reg_32(hw_apbh_dma_burst_size) + mxs_reg_32(hw_apbh_debug)
uint32_t reserved[36];
union { struct { - mx28_reg_32(hw_apbh_ch_curcmdar) - mx28_reg_32(hw_apbh_ch_nxtcmdar) - mx28_reg_32(hw_apbh_ch_cmd) - mx28_reg_32(hw_apbh_ch_bar) - mx28_reg_32(hw_apbh_ch_sema) - mx28_reg_32(hw_apbh_ch_debug1) - mx28_reg_32(hw_apbh_ch_debug2) + mxs_reg_32(hw_apbh_ch_curcmdar) + mxs_reg_32(hw_apbh_ch_nxtcmdar) + mxs_reg_32(hw_apbh_ch_cmd) + mxs_reg_32(hw_apbh_ch_bar) + mxs_reg_32(hw_apbh_ch_sema) + mxs_reg_32(hw_apbh_ch_debug1) + mxs_reg_32(hw_apbh_ch_debug2) } ch[16]; struct { - mx28_reg_32(hw_apbh_ch0_curcmdar) - mx28_reg_32(hw_apbh_ch0_nxtcmdar) - mx28_reg_32(hw_apbh_ch0_cmd) - mx28_reg_32(hw_apbh_ch0_bar) - mx28_reg_32(hw_apbh_ch0_sema) - mx28_reg_32(hw_apbh_ch0_debug1) - mx28_reg_32(hw_apbh_ch0_debug2) - mx28_reg_32(hw_apbh_ch1_curcmdar) - mx28_reg_32(hw_apbh_ch1_nxtcmdar) - mx28_reg_32(hw_apbh_ch1_cmd) - mx28_reg_32(hw_apbh_ch1_bar) - mx28_reg_32(hw_apbh_ch1_sema) - mx28_reg_32(hw_apbh_ch1_debug1) - mx28_reg_32(hw_apbh_ch1_debug2) - mx28_reg_32(hw_apbh_ch2_curcmdar) - mx28_reg_32(hw_apbh_ch2_nxtcmdar) - mx28_reg_32(hw_apbh_ch2_cmd) - mx28_reg_32(hw_apbh_ch2_bar) - mx28_reg_32(hw_apbh_ch2_sema) - mx28_reg_32(hw_apbh_ch2_debug1) - mx28_reg_32(hw_apbh_ch2_debug2) - mx28_reg_32(hw_apbh_ch3_curcmdar) - mx28_reg_32(hw_apbh_ch3_nxtcmdar) - mx28_reg_32(hw_apbh_ch3_cmd) - mx28_reg_32(hw_apbh_ch3_bar) - mx28_reg_32(hw_apbh_ch3_sema) - mx28_reg_32(hw_apbh_ch3_debug1) - mx28_reg_32(hw_apbh_ch3_debug2) - mx28_reg_32(hw_apbh_ch4_curcmdar) - mx28_reg_32(hw_apbh_ch4_nxtcmdar) - mx28_reg_32(hw_apbh_ch4_cmd) - mx28_reg_32(hw_apbh_ch4_bar) - mx28_reg_32(hw_apbh_ch4_sema) - mx28_reg_32(hw_apbh_ch4_debug1) - mx28_reg_32(hw_apbh_ch4_debug2) - mx28_reg_32(hw_apbh_ch5_curcmdar) - mx28_reg_32(hw_apbh_ch5_nxtcmdar) - mx28_reg_32(hw_apbh_ch5_cmd) - mx28_reg_32(hw_apbh_ch5_bar) - mx28_reg_32(hw_apbh_ch5_sema) - mx28_reg_32(hw_apbh_ch5_debug1) - mx28_reg_32(hw_apbh_ch5_debug2) - mx28_reg_32(hw_apbh_ch6_curcmdar) - mx28_reg_32(hw_apbh_ch6_nxtcmdar) - mx28_reg_32(hw_apbh_ch6_cmd) - mx28_reg_32(hw_apbh_ch6_bar) - mx28_reg_32(hw_apbh_ch6_sema) - mx28_reg_32(hw_apbh_ch6_debug1) - mx28_reg_32(hw_apbh_ch6_debug2) - mx28_reg_32(hw_apbh_ch7_curcmdar) - mx28_reg_32(hw_apbh_ch7_nxtcmdar) - mx28_reg_32(hw_apbh_ch7_cmd) - mx28_reg_32(hw_apbh_ch7_bar) - mx28_reg_32(hw_apbh_ch7_sema) - mx28_reg_32(hw_apbh_ch7_debug1) - mx28_reg_32(hw_apbh_ch7_debug2) - mx28_reg_32(hw_apbh_ch8_curcmdar) - mx28_reg_32(hw_apbh_ch8_nxtcmdar) - mx28_reg_32(hw_apbh_ch8_cmd) - mx28_reg_32(hw_apbh_ch8_bar) - mx28_reg_32(hw_apbh_ch8_sema) - mx28_reg_32(hw_apbh_ch8_debug1) - mx28_reg_32(hw_apbh_ch8_debug2) - mx28_reg_32(hw_apbh_ch9_curcmdar) - mx28_reg_32(hw_apbh_ch9_nxtcmdar) - mx28_reg_32(hw_apbh_ch9_cmd) - mx28_reg_32(hw_apbh_ch9_bar) - mx28_reg_32(hw_apbh_ch9_sema) - mx28_reg_32(hw_apbh_ch9_debug1) - mx28_reg_32(hw_apbh_ch9_debug2) - mx28_reg_32(hw_apbh_ch10_curcmdar) - mx28_reg_32(hw_apbh_ch10_nxtcmdar) - mx28_reg_32(hw_apbh_ch10_cmd) - mx28_reg_32(hw_apbh_ch10_bar) - mx28_reg_32(hw_apbh_ch10_sema) - mx28_reg_32(hw_apbh_ch10_debug1) - mx28_reg_32(hw_apbh_ch10_debug2) - mx28_reg_32(hw_apbh_ch11_curcmdar) - mx28_reg_32(hw_apbh_ch11_nxtcmdar) - mx28_reg_32(hw_apbh_ch11_cmd) - mx28_reg_32(hw_apbh_ch11_bar) - mx28_reg_32(hw_apbh_ch11_sema) - mx28_reg_32(hw_apbh_ch11_debug1) - mx28_reg_32(hw_apbh_ch11_debug2) - mx28_reg_32(hw_apbh_ch12_curcmdar) - mx28_reg_32(hw_apbh_ch12_nxtcmdar) - mx28_reg_32(hw_apbh_ch12_cmd) - mx28_reg_32(hw_apbh_ch12_bar) - mx28_reg_32(hw_apbh_ch12_sema) - mx28_reg_32(hw_apbh_ch12_debug1) - mx28_reg_32(hw_apbh_ch12_debug2) - mx28_reg_32(hw_apbh_ch13_curcmdar) - mx28_reg_32(hw_apbh_ch13_nxtcmdar) - mx28_reg_32(hw_apbh_ch13_cmd) - mx28_reg_32(hw_apbh_ch13_bar) - mx28_reg_32(hw_apbh_ch13_sema) - mx28_reg_32(hw_apbh_ch13_debug1) - mx28_reg_32(hw_apbh_ch13_debug2) - mx28_reg_32(hw_apbh_ch14_curcmdar) - mx28_reg_32(hw_apbh_ch14_nxtcmdar) - mx28_reg_32(hw_apbh_ch14_cmd) - mx28_reg_32(hw_apbh_ch14_bar) - mx28_reg_32(hw_apbh_ch14_sema) - mx28_reg_32(hw_apbh_ch14_debug1) - mx28_reg_32(hw_apbh_ch14_debug2) - mx28_reg_32(hw_apbh_ch15_curcmdar) - mx28_reg_32(hw_apbh_ch15_nxtcmdar) - mx28_reg_32(hw_apbh_ch15_cmd) - mx28_reg_32(hw_apbh_ch15_bar) - mx28_reg_32(hw_apbh_ch15_sema) - mx28_reg_32(hw_apbh_ch15_debug1) - mx28_reg_32(hw_apbh_ch15_debug2) + mxs_reg_32(hw_apbh_ch0_curcmdar) + mxs_reg_32(hw_apbh_ch0_nxtcmdar) + mxs_reg_32(hw_apbh_ch0_cmd) + mxs_reg_32(hw_apbh_ch0_bar) + mxs_reg_32(hw_apbh_ch0_sema) + mxs_reg_32(hw_apbh_ch0_debug1) + mxs_reg_32(hw_apbh_ch0_debug2) + mxs_reg_32(hw_apbh_ch1_curcmdar) + mxs_reg_32(hw_apbh_ch1_nxtcmdar) + mxs_reg_32(hw_apbh_ch1_cmd) + mxs_reg_32(hw_apbh_ch1_bar) + mxs_reg_32(hw_apbh_ch1_sema) + mxs_reg_32(hw_apbh_ch1_debug1) + mxs_reg_32(hw_apbh_ch1_debug2) + mxs_reg_32(hw_apbh_ch2_curcmdar) + mxs_reg_32(hw_apbh_ch2_nxtcmdar) + mxs_reg_32(hw_apbh_ch2_cmd) + mxs_reg_32(hw_apbh_ch2_bar) + mxs_reg_32(hw_apbh_ch2_sema) + mxs_reg_32(hw_apbh_ch2_debug1) + mxs_reg_32(hw_apbh_ch2_debug2) + mxs_reg_32(hw_apbh_ch3_curcmdar) + mxs_reg_32(hw_apbh_ch3_nxtcmdar) + mxs_reg_32(hw_apbh_ch3_cmd) + mxs_reg_32(hw_apbh_ch3_bar) + mxs_reg_32(hw_apbh_ch3_sema) + mxs_reg_32(hw_apbh_ch3_debug1) + mxs_reg_32(hw_apbh_ch3_debug2) + mxs_reg_32(hw_apbh_ch4_curcmdar) + mxs_reg_32(hw_apbh_ch4_nxtcmdar) + mxs_reg_32(hw_apbh_ch4_cmd) + mxs_reg_32(hw_apbh_ch4_bar) + mxs_reg_32(hw_apbh_ch4_sema) + mxs_reg_32(hw_apbh_ch4_debug1) + mxs_reg_32(hw_apbh_ch4_debug2) + mxs_reg_32(hw_apbh_ch5_curcmdar) + mxs_reg_32(hw_apbh_ch5_nxtcmdar) + mxs_reg_32(hw_apbh_ch5_cmd) + mxs_reg_32(hw_apbh_ch5_bar) + mxs_reg_32(hw_apbh_ch5_sema) + mxs_reg_32(hw_apbh_ch5_debug1) + mxs_reg_32(hw_apbh_ch5_debug2) + mxs_reg_32(hw_apbh_ch6_curcmdar) + mxs_reg_32(hw_apbh_ch6_nxtcmdar) + mxs_reg_32(hw_apbh_ch6_cmd) + mxs_reg_32(hw_apbh_ch6_bar) + mxs_reg_32(hw_apbh_ch6_sema) + mxs_reg_32(hw_apbh_ch6_debug1) + mxs_reg_32(hw_apbh_ch6_debug2) + mxs_reg_32(hw_apbh_ch7_curcmdar) + mxs_reg_32(hw_apbh_ch7_nxtcmdar) + mxs_reg_32(hw_apbh_ch7_cmd) + mxs_reg_32(hw_apbh_ch7_bar) + mxs_reg_32(hw_apbh_ch7_sema) + mxs_reg_32(hw_apbh_ch7_debug1) + mxs_reg_32(hw_apbh_ch7_debug2) + mxs_reg_32(hw_apbh_ch8_curcmdar) + mxs_reg_32(hw_apbh_ch8_nxtcmdar) + mxs_reg_32(hw_apbh_ch8_cmd) + mxs_reg_32(hw_apbh_ch8_bar) + mxs_reg_32(hw_apbh_ch8_sema) + mxs_reg_32(hw_apbh_ch8_debug1) + mxs_reg_32(hw_apbh_ch8_debug2) + mxs_reg_32(hw_apbh_ch9_curcmdar) + mxs_reg_32(hw_apbh_ch9_nxtcmdar) + mxs_reg_32(hw_apbh_ch9_cmd) + mxs_reg_32(hw_apbh_ch9_bar) + mxs_reg_32(hw_apbh_ch9_sema) + mxs_reg_32(hw_apbh_ch9_debug1) + mxs_reg_32(hw_apbh_ch9_debug2) + mxs_reg_32(hw_apbh_ch10_curcmdar) + mxs_reg_32(hw_apbh_ch10_nxtcmdar) + mxs_reg_32(hw_apbh_ch10_cmd) + mxs_reg_32(hw_apbh_ch10_bar) + mxs_reg_32(hw_apbh_ch10_sema) + mxs_reg_32(hw_apbh_ch10_debug1) + mxs_reg_32(hw_apbh_ch10_debug2) + mxs_reg_32(hw_apbh_ch11_curcmdar) + mxs_reg_32(hw_apbh_ch11_nxtcmdar) + mxs_reg_32(hw_apbh_ch11_cmd) + mxs_reg_32(hw_apbh_ch11_bar) + mxs_reg_32(hw_apbh_ch11_sema) + mxs_reg_32(hw_apbh_ch11_debug1) + mxs_reg_32(hw_apbh_ch11_debug2) + mxs_reg_32(hw_apbh_ch12_curcmdar) + mxs_reg_32(hw_apbh_ch12_nxtcmdar) + mxs_reg_32(hw_apbh_ch12_cmd) + mxs_reg_32(hw_apbh_ch12_bar) + mxs_reg_32(hw_apbh_ch12_sema) + mxs_reg_32(hw_apbh_ch12_debug1) + mxs_reg_32(hw_apbh_ch12_debug2) + mxs_reg_32(hw_apbh_ch13_curcmdar) + mxs_reg_32(hw_apbh_ch13_nxtcmdar) + mxs_reg_32(hw_apbh_ch13_cmd) + mxs_reg_32(hw_apbh_ch13_bar) + mxs_reg_32(hw_apbh_ch13_sema) + mxs_reg_32(hw_apbh_ch13_debug1) + mxs_reg_32(hw_apbh_ch13_debug2) + mxs_reg_32(hw_apbh_ch14_curcmdar) + mxs_reg_32(hw_apbh_ch14_nxtcmdar) + mxs_reg_32(hw_apbh_ch14_cmd) + mxs_reg_32(hw_apbh_ch14_bar) + mxs_reg_32(hw_apbh_ch14_sema) + mxs_reg_32(hw_apbh_ch14_debug1) + mxs_reg_32(hw_apbh_ch14_debug2) + mxs_reg_32(hw_apbh_ch15_curcmdar) + mxs_reg_32(hw_apbh_ch15_nxtcmdar) + mxs_reg_32(hw_apbh_ch15_cmd) + mxs_reg_32(hw_apbh_ch15_bar) + mxs_reg_32(hw_apbh_ch15_sema) + mxs_reg_32(hw_apbh_ch15_debug1) + mxs_reg_32(hw_apbh_ch15_debug2) }; }; - mx28_reg_32(hw_apbh_version) + mxs_reg_32(hw_apbh_version) }; #endif
diff --git a/arch/arm/include/asm/arch-mxs/regs-bch.h b/arch/arm/include/asm/arch-mxs/regs-bch.h index 9243bdd..58517c4 100644 --- a/arch/arm/include/asm/arch-mxs/regs-bch.h +++ b/arch/arm/include/asm/arch-mxs/regs-bch.h @@ -30,30 +30,30 @@
#ifndef __ASSEMBLY__ struct mx28_bch_regs { - mx28_reg_32(hw_bch_ctrl) - mx28_reg_32(hw_bch_status0) - mx28_reg_32(hw_bch_mode) - mx28_reg_32(hw_bch_encodeptr) - mx28_reg_32(hw_bch_dataptr) - mx28_reg_32(hw_bch_metaptr) + mxs_reg_32(hw_bch_ctrl) + mxs_reg_32(hw_bch_status0) + mxs_reg_32(hw_bch_mode) + mxs_reg_32(hw_bch_encodeptr) + mxs_reg_32(hw_bch_dataptr) + mxs_reg_32(hw_bch_metaptr)
uint32_t reserved[4];
- mx28_reg_32(hw_bch_layoutselect) - mx28_reg_32(hw_bch_flash0layout0) - mx28_reg_32(hw_bch_flash0layout1) - mx28_reg_32(hw_bch_flash1layout0) - mx28_reg_32(hw_bch_flash1layout1) - mx28_reg_32(hw_bch_flash2layout0) - mx28_reg_32(hw_bch_flash2layout1) - mx28_reg_32(hw_bch_flash3layout0) - mx28_reg_32(hw_bch_flash3layout1) - mx28_reg_32(hw_bch_dbgkesread) - mx28_reg_32(hw_bch_dbgcsferead) - mx28_reg_32(hw_bch_dbgsyndegread) - mx28_reg_32(hw_bch_dbgahbmread) - mx28_reg_32(hw_bch_blockname) - mx28_reg_32(hw_bch_version) + mxs_reg_32(hw_bch_layoutselect) + mxs_reg_32(hw_bch_flash0layout0) + mxs_reg_32(hw_bch_flash0layout1) + mxs_reg_32(hw_bch_flash1layout0) + mxs_reg_32(hw_bch_flash1layout1) + mxs_reg_32(hw_bch_flash2layout0) + mxs_reg_32(hw_bch_flash2layout1) + mxs_reg_32(hw_bch_flash3layout0) + mxs_reg_32(hw_bch_flash3layout1) + mxs_reg_32(hw_bch_dbgkesread) + mxs_reg_32(hw_bch_dbgcsferead) + mxs_reg_32(hw_bch_dbgsyndegread) + mxs_reg_32(hw_bch_dbgahbmread) + mxs_reg_32(hw_bch_blockname) + mxs_reg_32(hw_bch_version) }; #endif
diff --git a/arch/arm/include/asm/arch-mxs/regs-clkctrl.h b/arch/arm/include/asm/arch-mxs/regs-clkctrl.h index 3c4947d..127370b 100644 --- a/arch/arm/include/asm/arch-mxs/regs-clkctrl.h +++ b/arch/arm/include/asm/arch-mxs/regs-clkctrl.h @@ -30,38 +30,38 @@
#ifndef __ASSEMBLY__ struct mx28_clkctrl_regs { - mx28_reg_32(hw_clkctrl_pll0ctrl0) /* 0x00 */ - mx28_reg_32(hw_clkctrl_pll0ctrl1) /* 0x10 */ - mx28_reg_32(hw_clkctrl_pll1ctrl0) /* 0x20 */ - mx28_reg_32(hw_clkctrl_pll1ctrl1) /* 0x30 */ - mx28_reg_32(hw_clkctrl_pll2ctrl0) /* 0x40 */ - mx28_reg_32(hw_clkctrl_cpu) /* 0x50 */ - mx28_reg_32(hw_clkctrl_hbus) /* 0x60 */ - mx28_reg_32(hw_clkctrl_xbus) /* 0x70 */ - mx28_reg_32(hw_clkctrl_xtal) /* 0x80 */ - mx28_reg_32(hw_clkctrl_ssp0) /* 0x90 */ - mx28_reg_32(hw_clkctrl_ssp1) /* 0xa0 */ - mx28_reg_32(hw_clkctrl_ssp2) /* 0xb0 */ - mx28_reg_32(hw_clkctrl_ssp3) /* 0xc0 */ - mx28_reg_32(hw_clkctrl_gpmi) /* 0xd0 */ - mx28_reg_32(hw_clkctrl_spdif) /* 0xe0 */ - mx28_reg_32(hw_clkctrl_emi) /* 0xf0 */ - mx28_reg_32(hw_clkctrl_saif0) /* 0x100 */ - mx28_reg_32(hw_clkctrl_saif1) /* 0x110 */ - mx28_reg_32(hw_clkctrl_lcdif) /* 0x120 */ - mx28_reg_32(hw_clkctrl_etm) /* 0x130 */ - mx28_reg_32(hw_clkctrl_enet) /* 0x140 */ - mx28_reg_32(hw_clkctrl_hsadc) /* 0x150 */ - mx28_reg_32(hw_clkctrl_flexcan) /* 0x160 */ + mxs_reg_32(hw_clkctrl_pll0ctrl0) /* 0x00 */ + mxs_reg_32(hw_clkctrl_pll0ctrl1) /* 0x10 */ + mxs_reg_32(hw_clkctrl_pll1ctrl0) /* 0x20 */ + mxs_reg_32(hw_clkctrl_pll1ctrl1) /* 0x30 */ + mxs_reg_32(hw_clkctrl_pll2ctrl0) /* 0x40 */ + mxs_reg_32(hw_clkctrl_cpu) /* 0x50 */ + mxs_reg_32(hw_clkctrl_hbus) /* 0x60 */ + mxs_reg_32(hw_clkctrl_xbus) /* 0x70 */ + mxs_reg_32(hw_clkctrl_xtal) /* 0x80 */ + mxs_reg_32(hw_clkctrl_ssp0) /* 0x90 */ + mxs_reg_32(hw_clkctrl_ssp1) /* 0xa0 */ + mxs_reg_32(hw_clkctrl_ssp2) /* 0xb0 */ + mxs_reg_32(hw_clkctrl_ssp3) /* 0xc0 */ + mxs_reg_32(hw_clkctrl_gpmi) /* 0xd0 */ + mxs_reg_32(hw_clkctrl_spdif) /* 0xe0 */ + mxs_reg_32(hw_clkctrl_emi) /* 0xf0 */ + mxs_reg_32(hw_clkctrl_saif0) /* 0x100 */ + mxs_reg_32(hw_clkctrl_saif1) /* 0x110 */ + mxs_reg_32(hw_clkctrl_lcdif) /* 0x120 */ + mxs_reg_32(hw_clkctrl_etm) /* 0x130 */ + mxs_reg_32(hw_clkctrl_enet) /* 0x140 */ + mxs_reg_32(hw_clkctrl_hsadc) /* 0x150 */ + mxs_reg_32(hw_clkctrl_flexcan) /* 0x160 */
uint32_t reserved[16];
- mx28_reg_8(hw_clkctrl_frac0) /* 0x1b0 */ - mx28_reg_8(hw_clkctrl_frac1) /* 0x1c0 */ - mx28_reg_32(hw_clkctrl_clkseq) /* 0x1d0 */ - mx28_reg_32(hw_clkctrl_reset) /* 0x1e0 */ - mx28_reg_32(hw_clkctrl_status) /* 0x1f0 */ - mx28_reg_32(hw_clkctrl_version) /* 0x200 */ + mxs_reg_8(hw_clkctrl_frac0) /* 0x1b0 */ + mxs_reg_8(hw_clkctrl_frac1) /* 0x1c0 */ + mxs_reg_32(hw_clkctrl_clkseq) /* 0x1d0 */ + mxs_reg_32(hw_clkctrl_reset) /* 0x1e0 */ + mxs_reg_32(hw_clkctrl_status) /* 0x1f0 */ + mxs_reg_32(hw_clkctrl_version) /* 0x200 */ }; #endif
diff --git a/arch/arm/include/asm/arch-mxs/regs-common.h b/arch/arm/include/asm/arch-mxs/regs-common.h index d2e1953..bcea419 100644 --- a/arch/arm/include/asm/arch-mxs/regs-common.h +++ b/arch/arm/include/asm/arch-mxs/regs-common.h @@ -1,5 +1,5 @@ /* - * Freescale i.MX28 Register Accessors + * Freescale i.MXS Register Accessors * * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com * on behalf of DENX Software Engineering GmbH @@ -20,11 +20,11 @@ * */
-#ifndef __MX28_REGS_COMMON_H__ -#define __MX28_REGS_COMMON_H__ +#ifndef __MXS_REGS_COMMON_H__ +#define __MXS_REGS_COMMON_H__
/* - * The i.MX28 has interesting feature when it comes to register access. There + * The i.MXS has interesting feature when it comes to register access. There * are four kinds of access to one particular register. Those are: * * 1) Common read/write access. To use this mode, just write to the address of @@ -47,36 +47,36 @@ * */
-#define __mx28_reg_8(name) \ +#define __mxs_reg_8(name) \ uint8_t name[4]; \ uint8_t name##_set[4]; \ uint8_t name##_clr[4]; \ uint8_t name##_tog[4]; \
-#define __mx28_reg_32(name) \ +#define __mxs_reg_32(name) \ uint32_t name; \ uint32_t name##_set; \ uint32_t name##_clr; \ uint32_t name##_tog;
-struct mx28_register_8 { - __mx28_reg_8(reg) +struct mxs_register_8 { + __mxs_reg_8(reg) };
-struct mx28_register_32 { - __mx28_reg_32(reg) +struct mxs_register_32 { + __mxs_reg_32(reg) };
-#define mx28_reg_8(name) \ +#define mxs_reg_8(name) \ union { \ - struct { __mx28_reg_8(name) }; \ - struct mx28_register_8 name##_reg; \ + struct { __mxs_reg_8(name) }; \ + struct mxs_register_8 name##_reg; \ };
-#define mx28_reg_32(name) \ +#define mxs_reg_32(name) \ union { \ - struct { __mx28_reg_32(name) }; \ - struct mx28_register_32 name##_reg; \ + struct { __mxs_reg_32(name) }; \ + struct mxs_register_32 name##_reg; \ };
-#endif /* __MX28_REGS_COMMON_H__ */ +#endif /* __MXS_REGS_COMMON_H__ */ diff --git a/arch/arm/include/asm/arch-mxs/regs-digctl.h b/arch/arm/include/asm/arch-mxs/regs-digctl.h index 9a63594..25d318f 100644 --- a/arch/arm/include/asm/arch-mxs/regs-digctl.h +++ b/arch/arm/include/asm/arch-mxs/regs-digctl.h @@ -26,16 +26,16 @@
#ifndef __ASSEMBLY__ struct mx28_digctl_regs { - mx28_reg_32(hw_digctl_ctrl) /* 0x000 */ - mx28_reg_32(hw_digctl_status) /* 0x010 */ - mx28_reg_32(hw_digctl_hclkcount) /* 0x020 */ - mx28_reg_32(hw_digctl_ramctrl) /* 0x030 */ - mx28_reg_32(hw_digctl_emi_status) /* 0x040 */ - mx28_reg_32(hw_digctl_read_margin) /* 0x050 */ + mxs_reg_32(hw_digctl_ctrl) /* 0x000 */ + mxs_reg_32(hw_digctl_status) /* 0x010 */ + mxs_reg_32(hw_digctl_hclkcount) /* 0x020 */ + mxs_reg_32(hw_digctl_ramctrl) /* 0x030 */ + mxs_reg_32(hw_digctl_emi_status) /* 0x040 */ + mxs_reg_32(hw_digctl_read_margin) /* 0x050 */ uint32_t hw_digctl_writeonce; /* 0x060 */ uint32_t reserved_writeonce[3]; - mx28_reg_32(hw_digctl_bist_ctl) /* 0x070 */ - mx28_reg_32(hw_digctl_bist_status) /* 0x080 */ + mxs_reg_32(hw_digctl_bist_ctl) /* 0x070 */ + mxs_reg_32(hw_digctl_bist_status) /* 0x080 */ uint32_t hw_digctl_entropy; /* 0x090 */ uint32_t reserved_entropy[3]; uint32_t hw_digctl_entropy_latched; /* 0x0a0 */ @@ -43,7 +43,7 @@ struct mx28_digctl_regs {
uint32_t reserved1[4];
- mx28_reg_32(hw_digctl_microseconds) /* 0x0c0 */ + mxs_reg_32(hw_digctl_microseconds) /* 0x0c0 */ uint32_t hw_digctl_dbgrd; /* 0x0d0 */ uint32_t reserved_hw_digctl_dbgrd[3]; uint32_t hw_digctl_dbg; /* 0x0e0 */ @@ -51,21 +51,21 @@ struct mx28_digctl_regs {
uint32_t reserved2[4];
- mx28_reg_32(hw_digctl_usb_loopback) /* 0x100 */ - mx28_reg_32(hw_digctl_ocram_status0) /* 0x110 */ - mx28_reg_32(hw_digctl_ocram_status1) /* 0x120 */ - mx28_reg_32(hw_digctl_ocram_status2) /* 0x130 */ - mx28_reg_32(hw_digctl_ocram_status3) /* 0x140 */ - mx28_reg_32(hw_digctl_ocram_status4) /* 0x150 */ - mx28_reg_32(hw_digctl_ocram_status5) /* 0x160 */ - mx28_reg_32(hw_digctl_ocram_status6) /* 0x170 */ - mx28_reg_32(hw_digctl_ocram_status7) /* 0x180 */ - mx28_reg_32(hw_digctl_ocram_status8) /* 0x190 */ - mx28_reg_32(hw_digctl_ocram_status9) /* 0x1a0 */ - mx28_reg_32(hw_digctl_ocram_status10) /* 0x1b0 */ - mx28_reg_32(hw_digctl_ocram_status11) /* 0x1c0 */ - mx28_reg_32(hw_digctl_ocram_status12) /* 0x1d0 */ - mx28_reg_32(hw_digctl_ocram_status13) /* 0x1e0 */ + mxs_reg_32(hw_digctl_usb_loopback) /* 0x100 */ + mxs_reg_32(hw_digctl_ocram_status0) /* 0x110 */ + mxs_reg_32(hw_digctl_ocram_status1) /* 0x120 */ + mxs_reg_32(hw_digctl_ocram_status2) /* 0x130 */ + mxs_reg_32(hw_digctl_ocram_status3) /* 0x140 */ + mxs_reg_32(hw_digctl_ocram_status4) /* 0x150 */ + mxs_reg_32(hw_digctl_ocram_status5) /* 0x160 */ + mxs_reg_32(hw_digctl_ocram_status6) /* 0x170 */ + mxs_reg_32(hw_digctl_ocram_status7) /* 0x180 */ + mxs_reg_32(hw_digctl_ocram_status8) /* 0x190 */ + mxs_reg_32(hw_digctl_ocram_status9) /* 0x1a0 */ + mxs_reg_32(hw_digctl_ocram_status10) /* 0x1b0 */ + mxs_reg_32(hw_digctl_ocram_status11) /* 0x1c0 */ + mxs_reg_32(hw_digctl_ocram_status12) /* 0x1d0 */ + mxs_reg_32(hw_digctl_ocram_status13) /* 0x1e0 */
uint32_t reserved3[36];
@@ -75,7 +75,7 @@ struct mx28_digctl_regs { uint32_t reserved_hw_digctl_scratch1[3]; uint32_t hw_digctl_armcache; /* 0x2a0 */ uint32_t reserved_hw_digctl_armcache[3]; - mx28_reg_32(hw_digctl_debug_trap) /* 0x2b0 */ + mxs_reg_32(hw_digctl_debug_trap) /* 0x2b0 */ uint32_t hw_digctl_debug_trap_l0_addr_low; /* 0x2c0 */ uint32_t reserved_hw_digctl_debug_trap_l0_addr_low[3]; uint32_t hw_digctl_debug_trap_l0_addr_high; /* 0x2d0 */ diff --git a/arch/arm/include/asm/arch-mxs/regs-gpmi.h b/arch/arm/include/asm/arch-mxs/regs-gpmi.h index 1b487f4..190a570 100644 --- a/arch/arm/include/asm/arch-mxs/regs-gpmi.h +++ b/arch/arm/include/asm/arch-mxs/regs-gpmi.h @@ -30,22 +30,22 @@
#ifndef __ASSEMBLY__ struct mx28_gpmi_regs { - mx28_reg_32(hw_gpmi_ctrl0) - mx28_reg_32(hw_gpmi_compare) - mx28_reg_32(hw_gpmi_eccctrl) - mx28_reg_32(hw_gpmi_ecccount) - mx28_reg_32(hw_gpmi_payload) - mx28_reg_32(hw_gpmi_auxiliary) - mx28_reg_32(hw_gpmi_ctrl1) - mx28_reg_32(hw_gpmi_timing0) - mx28_reg_32(hw_gpmi_timing1) + mxs_reg_32(hw_gpmi_ctrl0) + mxs_reg_32(hw_gpmi_compare) + mxs_reg_32(hw_gpmi_eccctrl) + mxs_reg_32(hw_gpmi_ecccount) + mxs_reg_32(hw_gpmi_payload) + mxs_reg_32(hw_gpmi_auxiliary) + mxs_reg_32(hw_gpmi_ctrl1) + mxs_reg_32(hw_gpmi_timing0) + mxs_reg_32(hw_gpmi_timing1)
- mx28_reg_32(hw_gpmi_data) - mx28_reg_32(hw_gpmi_stat) - mx28_reg_32(hw_gpmi_debug) - mx28_reg_32(hw_gpmi_version) + mxs_reg_32(hw_gpmi_data) + mxs_reg_32(hw_gpmi_stat) + mxs_reg_32(hw_gpmi_debug) + mxs_reg_32(hw_gpmi_version) }; #endif
diff --git a/arch/arm/include/asm/arch-mxs/regs-i2c.h b/arch/arm/include/asm/arch-mxs/regs-i2c.h index 2e2e814..418a3c0 100644 --- a/arch/arm/include/asm/arch-mxs/regs-i2c.h +++ b/arch/arm/include/asm/arch-mxs/regs-i2c.h @@ -27,20 +27,20 @@
#ifndef __ASSEMBLY__ struct mx28_i2c_regs { - mx28_reg_32(hw_i2c_ctrl0) - mx28_reg_32(hw_i2c_timing0) - mx28_reg_32(hw_i2c_timing1) - mx28_reg_32(hw_i2c_timing2) - mx28_reg_32(hw_i2c_ctrl1) - mx28_reg_32(hw_i2c_stat) - mx28_reg_32(hw_i2c_queuectrl) - mx28_reg_32(hw_i2c_queuestat) - mx28_reg_32(hw_i2c_queuecmd) - mx28_reg_32(hw_i2c_queuedata) - mx28_reg_32(hw_i2c_data) - mx28_reg_32(hw_i2c_debug0) - mx28_reg_32(hw_i2c_debug1) - mx28_reg_32(hw_i2c_version) + mxs_reg_32(hw_i2c_ctrl0) + mxs_reg_32(hw_i2c_timing0) + mxs_reg_32(hw_i2c_timing1) + mxs_reg_32(hw_i2c_timing2) + mxs_reg_32(hw_i2c_ctrl1) + mxs_reg_32(hw_i2c_stat) + mxs_reg_32(hw_i2c_queuectrl) + mxs_reg_32(hw_i2c_queuestat) + mxs_reg_32(hw_i2c_queuecmd) + mxs_reg_32(hw_i2c_queuedata) + mxs_reg_32(hw_i2c_data) + mxs_reg_32(hw_i2c_debug0) + mxs_reg_32(hw_i2c_debug1) + mxs_reg_32(hw_i2c_version) }; #endif
diff --git a/arch/arm/include/asm/arch-mxs/regs-ocotp.h b/arch/arm/include/asm/arch-mxs/regs-ocotp.h index 2738035..a2ac6a2 100644 --- a/arch/arm/include/asm/arch-mxs/regs-ocotp.h +++ b/arch/arm/include/asm/arch-mxs/regs-ocotp.h @@ -30,49 +30,49 @@
#ifndef __ASSEMBLY__ struct mx28_ocotp_regs { - mx28_reg_32(hw_ocotp_ctrl) /* 0x0 */ - mx28_reg_32(hw_ocotp_data) /* 0x10 */ - mx28_reg_32(hw_ocotp_cust0) /* 0x20 */ - mx28_reg_32(hw_ocotp_cust1) /* 0x30 */ - mx28_reg_32(hw_ocotp_cust2) /* 0x40 */ - mx28_reg_32(hw_ocotp_cust3) /* 0x50 */ - mx28_reg_32(hw_ocotp_crypto0) /* 0x60 */ - mx28_reg_32(hw_ocotp_crypto1) /* 0x70 */ - mx28_reg_32(hw_ocotp_crypto2) /* 0x80 */ - mx28_reg_32(hw_ocotp_crypto3) /* 0x90 */ - mx28_reg_32(hw_ocotp_hwcap0) /* 0xa0 */ - mx28_reg_32(hw_ocotp_hwcap1) /* 0xb0 */ - mx28_reg_32(hw_ocotp_hwcap2) /* 0xc0 */ - mx28_reg_32(hw_ocotp_hwcap3) /* 0xd0 */ - mx28_reg_32(hw_ocotp_hwcap4) /* 0xe0 */ - mx28_reg_32(hw_ocotp_hwcap5) /* 0xf0 */ - mx28_reg_32(hw_ocotp_swcap) /* 0x100 */ - mx28_reg_32(hw_ocotp_custcap) /* 0x110 */ - mx28_reg_32(hw_ocotp_lock) /* 0x120 */ - mx28_reg_32(hw_ocotp_ops0) /* 0x130 */ - mx28_reg_32(hw_ocotp_ops1) /* 0x140 */ - mx28_reg_32(hw_ocotp_ops2) /* 0x150 */ - mx28_reg_32(hw_ocotp_ops3) /* 0x160 */ - mx28_reg_32(hw_ocotp_un0) /* 0x170 */ - mx28_reg_32(hw_ocotp_un1) /* 0x180 */ - mx28_reg_32(hw_ocotp_un2) /* 0x190 */ - mx28_reg_32(hw_ocotp_rom0) /* 0x1a0 */ - mx28_reg_32(hw_ocotp_rom1) /* 0x1b0 */ - mx28_reg_32(hw_ocotp_rom2) /* 0x1c0 */ - mx28_reg_32(hw_ocotp_rom3) /* 0x1d0 */ - mx28_reg_32(hw_ocotp_rom4) /* 0x1e0 */ - mx28_reg_32(hw_ocotp_rom5) /* 0x1f0 */ - mx28_reg_32(hw_ocotp_rom6) /* 0x200 */ - mx28_reg_32(hw_ocotp_rom7) /* 0x210 */ - mx28_reg_32(hw_ocotp_srk0) /* 0x220 */ - mx28_reg_32(hw_ocotp_srk1) /* 0x230 */ - mx28_reg_32(hw_ocotp_srk2) /* 0x240 */ - mx28_reg_32(hw_ocotp_srk3) /* 0x250 */ - mx28_reg_32(hw_ocotp_srk4) /* 0x260 */ - mx28_reg_32(hw_ocotp_srk5) /* 0x270 */ - mx28_reg_32(hw_ocotp_srk6) /* 0x280 */ - mx28_reg_32(hw_ocotp_srk7) /* 0x290 */ - mx28_reg_32(hw_ocotp_version) /* 0x2a0 */ + mxs_reg_32(hw_ocotp_ctrl) /* 0x0 */ + mxs_reg_32(hw_ocotp_data) /* 0x10 */ + mxs_reg_32(hw_ocotp_cust0) /* 0x20 */ + mxs_reg_32(hw_ocotp_cust1) /* 0x30 */ + mxs_reg_32(hw_ocotp_cust2) /* 0x40 */ + mxs_reg_32(hw_ocotp_cust3) /* 0x50 */ + mxs_reg_32(hw_ocotp_crypto0) /* 0x60 */ + mxs_reg_32(hw_ocotp_crypto1) /* 0x70 */ + mxs_reg_32(hw_ocotp_crypto2) /* 0x80 */ + mxs_reg_32(hw_ocotp_crypto3) /* 0x90 */ + mxs_reg_32(hw_ocotp_hwcap0) /* 0xa0 */ + mxs_reg_32(hw_ocotp_hwcap1) /* 0xb0 */ + mxs_reg_32(hw_ocotp_hwcap2) /* 0xc0 */ + mxs_reg_32(hw_ocotp_hwcap3) /* 0xd0 */ + mxs_reg_32(hw_ocotp_hwcap4) /* 0xe0 */ + mxs_reg_32(hw_ocotp_hwcap5) /* 0xf0 */ + mxs_reg_32(hw_ocotp_swcap) /* 0x100 */ + mxs_reg_32(hw_ocotp_custcap) /* 0x110 */ + mxs_reg_32(hw_ocotp_lock) /* 0x120 */ + mxs_reg_32(hw_ocotp_ops0) /* 0x130 */ + mxs_reg_32(hw_ocotp_ops1) /* 0x140 */ + mxs_reg_32(hw_ocotp_ops2) /* 0x150 */ + mxs_reg_32(hw_ocotp_ops3) /* 0x160 */ + mxs_reg_32(hw_ocotp_un0) /* 0x170 */ + mxs_reg_32(hw_ocotp_un1) /* 0x180 */ + mxs_reg_32(hw_ocotp_un2) /* 0x190 */ + mxs_reg_32(hw_ocotp_rom0) /* 0x1a0 */ + mxs_reg_32(hw_ocotp_rom1) /* 0x1b0 */ + mxs_reg_32(hw_ocotp_rom2) /* 0x1c0 */ + mxs_reg_32(hw_ocotp_rom3) /* 0x1d0 */ + mxs_reg_32(hw_ocotp_rom4) /* 0x1e0 */ + mxs_reg_32(hw_ocotp_rom5) /* 0x1f0 */ + mxs_reg_32(hw_ocotp_rom6) /* 0x200 */ + mxs_reg_32(hw_ocotp_rom7) /* 0x210 */ + mxs_reg_32(hw_ocotp_srk0) /* 0x220 */ + mxs_reg_32(hw_ocotp_srk1) /* 0x230 */ + mxs_reg_32(hw_ocotp_srk2) /* 0x240 */ + mxs_reg_32(hw_ocotp_srk3) /* 0x250 */ + mxs_reg_32(hw_ocotp_srk4) /* 0x260 */ + mxs_reg_32(hw_ocotp_srk5) /* 0x270 */ + mxs_reg_32(hw_ocotp_srk6) /* 0x280 */ + mxs_reg_32(hw_ocotp_srk7) /* 0x290 */ + mxs_reg_32(hw_ocotp_version) /* 0x2a0 */ }; #endif
diff --git a/arch/arm/include/asm/arch-mxs/regs-pinctrl.h b/arch/arm/include/asm/arch-mxs/regs-pinctrl.h index 80dcdf6..ca1d791 100644 --- a/arch/arm/include/asm/arch-mxs/regs-pinctrl.h +++ b/arch/arm/include/asm/arch-mxs/regs-pinctrl.h @@ -30,129 +30,129 @@
#ifndef __ASSEMBLY__ struct mx28_pinctrl_regs { - mx28_reg_32(hw_pinctrl_ctrl) /* 0x0 */ + mxs_reg_32(hw_pinctrl_ctrl) /* 0x0 */
uint32_t reserved1[60];
- mx28_reg_32(hw_pinctrl_muxsel0) /* 0x100 */ - mx28_reg_32(hw_pinctrl_muxsel1) /* 0x110 */ - mx28_reg_32(hw_pinctrl_muxsel2) /* 0x120 */ - mx28_reg_32(hw_pinctrl_muxsel3) /* 0x130 */ - mx28_reg_32(hw_pinctrl_muxsel4) /* 0x140 */ - mx28_reg_32(hw_pinctrl_muxsel5) /* 0x150 */ - mx28_reg_32(hw_pinctrl_muxsel6) /* 0x160 */ - mx28_reg_32(hw_pinctrl_muxsel7) /* 0x170 */ - mx28_reg_32(hw_pinctrl_muxsel8) /* 0x180 */ - mx28_reg_32(hw_pinctrl_muxsel9) /* 0x190 */ - mx28_reg_32(hw_pinctrl_muxsel10) /* 0x1a0 */ - mx28_reg_32(hw_pinctrl_muxsel11) /* 0x1b0 */ - mx28_reg_32(hw_pinctrl_muxsel12) /* 0x1c0 */ - mx28_reg_32(hw_pinctrl_muxsel13) /* 0x1d0 */ + mxs_reg_32(hw_pinctrl_muxsel0) /* 0x100 */ + mxs_reg_32(hw_pinctrl_muxsel1) /* 0x110 */ + mxs_reg_32(hw_pinctrl_muxsel2) /* 0x120 */ + mxs_reg_32(hw_pinctrl_muxsel3) /* 0x130 */ + mxs_reg_32(hw_pinctrl_muxsel4) /* 0x140 */ + mxs_reg_32(hw_pinctrl_muxsel5) /* 0x150 */ + mxs_reg_32(hw_pinctrl_muxsel6) /* 0x160 */ + mxs_reg_32(hw_pinctrl_muxsel7) /* 0x170 */ + mxs_reg_32(hw_pinctrl_muxsel8) /* 0x180 */ + mxs_reg_32(hw_pinctrl_muxsel9) /* 0x190 */ + mxs_reg_32(hw_pinctrl_muxsel10) /* 0x1a0 */ + mxs_reg_32(hw_pinctrl_muxsel11) /* 0x1b0 */ + mxs_reg_32(hw_pinctrl_muxsel12) /* 0x1c0 */ + mxs_reg_32(hw_pinctrl_muxsel13) /* 0x1d0 */
uint32_t reserved2[72];
- mx28_reg_32(hw_pinctrl_drive0) /* 0x300 */ - mx28_reg_32(hw_pinctrl_drive1) /* 0x310 */ - mx28_reg_32(hw_pinctrl_drive2) /* 0x320 */ - mx28_reg_32(hw_pinctrl_drive3) /* 0x330 */ - mx28_reg_32(hw_pinctrl_drive4) /* 0x340 */ - mx28_reg_32(hw_pinctrl_drive5) /* 0x350 */ - mx28_reg_32(hw_pinctrl_drive6) /* 0x360 */ - mx28_reg_32(hw_pinctrl_drive7) /* 0x370 */ - mx28_reg_32(hw_pinctrl_drive8) /* 0x380 */ - mx28_reg_32(hw_pinctrl_drive9) /* 0x390 */ - mx28_reg_32(hw_pinctrl_drive10) /* 0x3a0 */ - mx28_reg_32(hw_pinctrl_drive11) /* 0x3b0 */ - mx28_reg_32(hw_pinctrl_drive12) /* 0x3c0 */ - mx28_reg_32(hw_pinctrl_drive13) /* 0x3d0 */ - mx28_reg_32(hw_pinctrl_drive14) /* 0x3e0 */ - mx28_reg_32(hw_pinctrl_drive15) /* 0x3f0 */ - mx28_reg_32(hw_pinctrl_drive16) /* 0x400 */ - mx28_reg_32(hw_pinctrl_drive17) /* 0x410 */ - mx28_reg_32(hw_pinctrl_drive18) /* 0x420 */ - mx28_reg_32(hw_pinctrl_drive19) /* 0x430 */ + mxs_reg_32(hw_pinctrl_drive0) /* 0x300 */ + mxs_reg_32(hw_pinctrl_drive1) /* 0x310 */ + mxs_reg_32(hw_pinctrl_drive2) /* 0x320 */ + mxs_reg_32(hw_pinctrl_drive3) /* 0x330 */ + mxs_reg_32(hw_pinctrl_drive4) /* 0x340 */ + mxs_reg_32(hw_pinctrl_drive5) /* 0x350 */ + mxs_reg_32(hw_pinctrl_drive6) /* 0x360 */ + mxs_reg_32(hw_pinctrl_drive7) /* 0x370 */ + mxs_reg_32(hw_pinctrl_drive8) /* 0x380 */ + mxs_reg_32(hw_pinctrl_drive9) /* 0x390 */ + mxs_reg_32(hw_pinctrl_drive10) /* 0x3a0 */ + mxs_reg_32(hw_pinctrl_drive11) /* 0x3b0 */ + mxs_reg_32(hw_pinctrl_drive12) /* 0x3c0 */ + mxs_reg_32(hw_pinctrl_drive13) /* 0x3d0 */ + mxs_reg_32(hw_pinctrl_drive14) /* 0x3e0 */ + mxs_reg_32(hw_pinctrl_drive15) /* 0x3f0 */ + mxs_reg_32(hw_pinctrl_drive16) /* 0x400 */ + mxs_reg_32(hw_pinctrl_drive17) /* 0x410 */ + mxs_reg_32(hw_pinctrl_drive18) /* 0x420 */ + mxs_reg_32(hw_pinctrl_drive19) /* 0x430 */
uint32_t reserved3[112];
- mx28_reg_32(hw_pinctrl_pull0) /* 0x600 */ - mx28_reg_32(hw_pinctrl_pull1) /* 0x610 */ - mx28_reg_32(hw_pinctrl_pull2) /* 0x620 */ - mx28_reg_32(hw_pinctrl_pull3) /* 0x630 */ - mx28_reg_32(hw_pinctrl_pull4) /* 0x640 */ - mx28_reg_32(hw_pinctrl_pull5) /* 0x650 */ - mx28_reg_32(hw_pinctrl_pull6) /* 0x660 */ + mxs_reg_32(hw_pinctrl_pull0) /* 0x600 */ + mxs_reg_32(hw_pinctrl_pull1) /* 0x610 */ + mxs_reg_32(hw_pinctrl_pull2) /* 0x620 */ + mxs_reg_32(hw_pinctrl_pull3) /* 0x630 */ + mxs_reg_32(hw_pinctrl_pull4) /* 0x640 */ + mxs_reg_32(hw_pinctrl_pull5) /* 0x650 */ + mxs_reg_32(hw_pinctrl_pull6) /* 0x660 */
uint32_t reserved4[36];
- mx28_reg_32(hw_pinctrl_dout0) /* 0x700 */ - mx28_reg_32(hw_pinctrl_dout1) /* 0x710 */ - mx28_reg_32(hw_pinctrl_dout2) /* 0x720 */ - mx28_reg_32(hw_pinctrl_dout3) /* 0x730 */ - mx28_reg_32(hw_pinctrl_dout4) /* 0x740 */ + mxs_reg_32(hw_pinctrl_dout0) /* 0x700 */ + mxs_reg_32(hw_pinctrl_dout1) /* 0x710 */ + mxs_reg_32(hw_pinctrl_dout2) /* 0x720 */ + mxs_reg_32(hw_pinctrl_dout3) /* 0x730 */ + mxs_reg_32(hw_pinctrl_dout4) /* 0x740 */
uint32_t reserved5[108];
- mx28_reg_32(hw_pinctrl_din0) /* 0x900 */ - mx28_reg_32(hw_pinctrl_din1) /* 0x910 */ - mx28_reg_32(hw_pinctrl_din2) /* 0x920 */ - mx28_reg_32(hw_pinctrl_din3) /* 0x930 */ - mx28_reg_32(hw_pinctrl_din4) /* 0x940 */ + mxs_reg_32(hw_pinctrl_din0) /* 0x900 */ + mxs_reg_32(hw_pinctrl_din1) /* 0x910 */ + mxs_reg_32(hw_pinctrl_din2) /* 0x920 */ + mxs_reg_32(hw_pinctrl_din3) /* 0x930 */ + mxs_reg_32(hw_pinctrl_din4) /* 0x940 */
uint32_t reserved6[108];
- mx28_reg_32(hw_pinctrl_doe0) /* 0xb00 */ - mx28_reg_32(hw_pinctrl_doe1) /* 0xb10 */ - mx28_reg_32(hw_pinctrl_doe2) /* 0xb20 */ - mx28_reg_32(hw_pinctrl_doe3) /* 0xb30 */ - mx28_reg_32(hw_pinctrl_doe4) /* 0xb40 */ + mxs_reg_32(hw_pinctrl_doe0) /* 0xb00 */ + mxs_reg_32(hw_pinctrl_doe1) /* 0xb10 */ + mxs_reg_32(hw_pinctrl_doe2) /* 0xb20 */ + mxs_reg_32(hw_pinctrl_doe3) /* 0xb30 */ + mxs_reg_32(hw_pinctrl_doe4) /* 0xb40 */
uint32_t reserved7[300];
- mx28_reg_32(hw_pinctrl_pin2irq0) /* 0x1000 */ - mx28_reg_32(hw_pinctrl_pin2irq1) /* 0x1010 */ - mx28_reg_32(hw_pinctrl_pin2irq2) /* 0x1020 */ - mx28_reg_32(hw_pinctrl_pin2irq3) /* 0x1030 */ - mx28_reg_32(hw_pinctrl_pin2irq4) /* 0x1040 */ + mxs_reg_32(hw_pinctrl_pin2irq0) /* 0x1000 */ + mxs_reg_32(hw_pinctrl_pin2irq1) /* 0x1010 */ + mxs_reg_32(hw_pinctrl_pin2irq2) /* 0x1020 */ + mxs_reg_32(hw_pinctrl_pin2irq3) /* 0x1030 */ + mxs_reg_32(hw_pinctrl_pin2irq4) /* 0x1040 */
uint32_t reserved8[44];
- mx28_reg_32(hw_pinctrl_irqen0) /* 0x1100 */ - mx28_reg_32(hw_pinctrl_irqen1) /* 0x1110 */ - mx28_reg_32(hw_pinctrl_irqen2) /* 0x1120 */ - mx28_reg_32(hw_pinctrl_irqen3) /* 0x1130 */ - mx28_reg_32(hw_pinctrl_irqen4) /* 0x1140 */ + mxs_reg_32(hw_pinctrl_irqen0) /* 0x1100 */ + mxs_reg_32(hw_pinctrl_irqen1) /* 0x1110 */ + mxs_reg_32(hw_pinctrl_irqen2) /* 0x1120 */ + mxs_reg_32(hw_pinctrl_irqen3) /* 0x1130 */ + mxs_reg_32(hw_pinctrl_irqen4) /* 0x1140 */
uint32_t reserved9[44];
- mx28_reg_32(hw_pinctrl_irqlevel0) /* 0x1200 */ - mx28_reg_32(hw_pinctrl_irqlevel1) /* 0x1210 */ - mx28_reg_32(hw_pinctrl_irqlevel2) /* 0x1220 */ - mx28_reg_32(hw_pinctrl_irqlevel3) /* 0x1230 */ - mx28_reg_32(hw_pinctrl_irqlevel4) /* 0x1240 */ + mxs_reg_32(hw_pinctrl_irqlevel0) /* 0x1200 */ + mxs_reg_32(hw_pinctrl_irqlevel1) /* 0x1210 */ + mxs_reg_32(hw_pinctrl_irqlevel2) /* 0x1220 */ + mxs_reg_32(hw_pinctrl_irqlevel3) /* 0x1230 */ + mxs_reg_32(hw_pinctrl_irqlevel4) /* 0x1240 */
uint32_t reserved10[44];
- mx28_reg_32(hw_pinctrl_irqpol0) /* 0x1300 */ - mx28_reg_32(hw_pinctrl_irqpol1) /* 0x1310 */ - mx28_reg_32(hw_pinctrl_irqpol2) /* 0x1320 */ - mx28_reg_32(hw_pinctrl_irqpol3) /* 0x1330 */ - mx28_reg_32(hw_pinctrl_irqpol4) /* 0x1340 */ + mxs_reg_32(hw_pinctrl_irqpol0) /* 0x1300 */ + mxs_reg_32(hw_pinctrl_irqpol1) /* 0x1310 */ + mxs_reg_32(hw_pinctrl_irqpol2) /* 0x1320 */ + mxs_reg_32(hw_pinctrl_irqpol3) /* 0x1330 */ + mxs_reg_32(hw_pinctrl_irqpol4) /* 0x1340 */
uint32_t reserved11[44];
- mx28_reg_32(hw_pinctrl_irqstat0) /* 0x1400 */ - mx28_reg_32(hw_pinctrl_irqstat1) /* 0x1410 */ - mx28_reg_32(hw_pinctrl_irqstat2) /* 0x1420 */ - mx28_reg_32(hw_pinctrl_irqstat3) /* 0x1430 */ - mx28_reg_32(hw_pinctrl_irqstat4) /* 0x1440 */ + mxs_reg_32(hw_pinctrl_irqstat0) /* 0x1400 */ + mxs_reg_32(hw_pinctrl_irqstat1) /* 0x1410 */ + mxs_reg_32(hw_pinctrl_irqstat2) /* 0x1420 */ + mxs_reg_32(hw_pinctrl_irqstat3) /* 0x1430 */ + mxs_reg_32(hw_pinctrl_irqstat4) /* 0x1440 */
uint32_t reserved12[380];
- mx28_reg_32(hw_pinctrl_emi_odt_ctrl) /* 0x1a40 */ + mxs_reg_32(hw_pinctrl_emi_odt_ctrl) /* 0x1a40 */
uint32_t reserved13[76];
- mx28_reg_32(hw_pinctrl_emi_ds_ctrl) /* 0x1b80 */ + mxs_reg_32(hw_pinctrl_emi_ds_ctrl) /* 0x1b80 */ }; #endif
diff --git a/arch/arm/include/asm/arch-mxs/regs-power.h b/arch/arm/include/asm/arch-mxs/regs-power.h index 8eadc6d..3c9e3b0 100644 --- a/arch/arm/include/asm/arch-mxs/regs-power.h +++ b/arch/arm/include/asm/arch-mxs/regs-power.h @@ -26,10 +26,10 @@
#ifndef __ASSEMBLY__ struct mx28_power_regs { - mx28_reg_32(hw_power_ctrl) - mx28_reg_32(hw_power_5vctrl) - mx28_reg_32(hw_power_minpwr) - mx28_reg_32(hw_power_charge) + mxs_reg_32(hw_power_ctrl) + mxs_reg_32(hw_power_5vctrl) + mxs_reg_32(hw_power_minpwr) + mxs_reg_32(hw_power_charge) uint32_t hw_power_vdddctrl; uint32_t reserved_vddd[3]; uint32_t hw_power_vddactrl; @@ -44,23 +44,23 @@ struct mx28_power_regs { uint32_t reserved_misc[3]; uint32_t hw_power_dclimits; uint32_t reserved_dclimits[3]; - mx28_reg_32(hw_power_loopctrl) + mxs_reg_32(hw_power_loopctrl) uint32_t hw_power_sts; uint32_t reserved_sts[3]; - mx28_reg_32(hw_power_speed) + mxs_reg_32(hw_power_speed) uint32_t hw_power_battmonitor; uint32_t reserved_battmonitor[3];
- mx28_reg_32(hw_power_reset) - mx28_reg_32(hw_power_debug) - mx28_reg_32(hw_power_thermal) - mx28_reg_32(hw_power_usb1ctrl) - mx28_reg_32(hw_power_special) - mx28_reg_32(hw_power_version) - mx28_reg_32(hw_power_anaclkctrl) - mx28_reg_32(hw_power_refctrl) + mxs_reg_32(hw_power_reset) + mxs_reg_32(hw_power_debug) + mxs_reg_32(hw_power_thermal) + mxs_reg_32(hw_power_usb1ctrl) + mxs_reg_32(hw_power_special) + mxs_reg_32(hw_power_version) + mxs_reg_32(hw_power_anaclkctrl) + mxs_reg_32(hw_power_refctrl) }; #endif
diff --git a/arch/arm/include/asm/arch-mxs/regs-rtc.h b/arch/arm/include/asm/arch-mxs/regs-rtc.h index e605a03..0b660ae 100644 --- a/arch/arm/include/asm/arch-mxs/regs-rtc.h +++ b/arch/arm/include/asm/arch-mxs/regs-rtc.h @@ -27,20 +27,20 @@
#ifndef __ASSEMBLY__ struct mx28_rtc_regs { - mx28_reg_32(hw_rtc_ctrl) - mx28_reg_32(hw_rtc_stat) - mx28_reg_32(hw_rtc_milliseconds) - mx28_reg_32(hw_rtc_seconds) - mx28_reg_32(hw_rtc_rtc_alarm) - mx28_reg_32(hw_rtc_watchdog) - mx28_reg_32(hw_rtc_persistent0) - mx28_reg_32(hw_rtc_persistent1) - mx28_reg_32(hw_rtc_persistent2) - mx28_reg_32(hw_rtc_persistent3) - mx28_reg_32(hw_rtc_persistent4) - mx28_reg_32(hw_rtc_persistent5) - mx28_reg_32(hw_rtc_debug) - mx28_reg_32(hw_rtc_version) + mxs_reg_32(hw_rtc_ctrl) + mxs_reg_32(hw_rtc_stat) + mxs_reg_32(hw_rtc_milliseconds) + mxs_reg_32(hw_rtc_seconds) + mxs_reg_32(hw_rtc_rtc_alarm) + mxs_reg_32(hw_rtc_watchdog) + mxs_reg_32(hw_rtc_persistent0) + mxs_reg_32(hw_rtc_persistent1) + mxs_reg_32(hw_rtc_persistent2) + mxs_reg_32(hw_rtc_persistent3) + mxs_reg_32(hw_rtc_persistent4) + mxs_reg_32(hw_rtc_persistent5) + mxs_reg_32(hw_rtc_debug) + mxs_reg_32(hw_rtc_version) }; #endif
diff --git a/arch/arm/include/asm/arch-mxs/regs-ssp.h b/arch/arm/include/asm/arch-mxs/regs-ssp.h index be71d48..85b9894 100644 --- a/arch/arm/include/asm/arch-mxs/regs-ssp.h +++ b/arch/arm/include/asm/arch-mxs/regs-ssp.h @@ -29,26 +29,26 @@
#ifndef __ASSEMBLY__ struct mx28_ssp_regs { - mx28_reg_32(hw_ssp_ctrl0) - mx28_reg_32(hw_ssp_cmd0) - mx28_reg_32(hw_ssp_cmd1) - mx28_reg_32(hw_ssp_xfer_size) - mx28_reg_32(hw_ssp_block_size) - mx28_reg_32(hw_ssp_compref) - mx28_reg_32(hw_ssp_compmask) - mx28_reg_32(hw_ssp_timing) - mx28_reg_32(hw_ssp_ctrl1) - mx28_reg_32(hw_ssp_data) - mx28_reg_32(hw_ssp_sdresp0) - mx28_reg_32(hw_ssp_sdresp1) - mx28_reg_32(hw_ssp_sdresp2) - mx28_reg_32(hw_ssp_sdresp3) - mx28_reg_32(hw_ssp_ddr_ctrl) - mx28_reg_32(hw_ssp_dll_ctrl) - mx28_reg_32(hw_ssp_status) - mx28_reg_32(hw_ssp_dll_sts) - mx28_reg_32(hw_ssp_debug) - mx28_reg_32(hw_ssp_version) + mxs_reg_32(hw_ssp_ctrl0) + mxs_reg_32(hw_ssp_cmd0) + mxs_reg_32(hw_ssp_cmd1) + mxs_reg_32(hw_ssp_xfer_size) + mxs_reg_32(hw_ssp_block_size) + mxs_reg_32(hw_ssp_compref) + mxs_reg_32(hw_ssp_compmask) + mxs_reg_32(hw_ssp_timing) + mxs_reg_32(hw_ssp_ctrl1) + mxs_reg_32(hw_ssp_data) + mxs_reg_32(hw_ssp_sdresp0) + mxs_reg_32(hw_ssp_sdresp1) + mxs_reg_32(hw_ssp_sdresp2) + mxs_reg_32(hw_ssp_sdresp3) + mxs_reg_32(hw_ssp_ddr_ctrl) + mxs_reg_32(hw_ssp_dll_ctrl) + mxs_reg_32(hw_ssp_status) + mxs_reg_32(hw_ssp_dll_sts) + mxs_reg_32(hw_ssp_debug) + mxs_reg_32(hw_ssp_version) }; #endif
diff --git a/arch/arm/include/asm/arch-mxs/regs-timrot.h b/arch/arm/include/asm/arch-mxs/regs-timrot.h index 3e8dfe7..332654f 100644 --- a/arch/arm/include/asm/arch-mxs/regs-timrot.h +++ b/arch/arm/include/asm/arch-mxs/regs-timrot.h @@ -29,25 +29,25 @@
#ifndef __ASSEMBLY__ struct mx28_timrot_regs { - mx28_reg_32(hw_timrot_rotctrl) - mx28_reg_32(hw_timrot_rotcount) - mx28_reg_32(hw_timrot_timctrl0) - mx28_reg_32(hw_timrot_running_count0) - mx28_reg_32(hw_timrot_fixed_count0) - mx28_reg_32(hw_timrot_match_count0) - mx28_reg_32(hw_timrot_timctrl1) - mx28_reg_32(hw_timrot_running_count1) - mx28_reg_32(hw_timrot_fixed_count1) - mx28_reg_32(hw_timrot_match_count1) - mx28_reg_32(hw_timrot_timctrl2) - mx28_reg_32(hw_timrot_running_count2) - mx28_reg_32(hw_timrot_fixed_count2) - mx28_reg_32(hw_timrot_match_count2) - mx28_reg_32(hw_timrot_timctrl3) - mx28_reg_32(hw_timrot_running_count3) - mx28_reg_32(hw_timrot_fixed_count3) - mx28_reg_32(hw_timrot_match_count3) - mx28_reg_32(hw_timrot_version) + mxs_reg_32(hw_timrot_rotctrl) + mxs_reg_32(hw_timrot_rotcount) + mxs_reg_32(hw_timrot_timctrl0) + mxs_reg_32(hw_timrot_running_count0) + mxs_reg_32(hw_timrot_fixed_count0) + mxs_reg_32(hw_timrot_match_count0) + mxs_reg_32(hw_timrot_timctrl1) + mxs_reg_32(hw_timrot_running_count1) + mxs_reg_32(hw_timrot_fixed_count1) + mxs_reg_32(hw_timrot_match_count1) + mxs_reg_32(hw_timrot_timctrl2) + mxs_reg_32(hw_timrot_running_count2) + mxs_reg_32(hw_timrot_fixed_count2) + mxs_reg_32(hw_timrot_match_count2) + mxs_reg_32(hw_timrot_timctrl3) + mxs_reg_32(hw_timrot_running_count3) + mxs_reg_32(hw_timrot_fixed_count3) + mxs_reg_32(hw_timrot_match_count3) + mxs_reg_32(hw_timrot_version) }; #endif
diff --git a/arch/arm/include/asm/arch-mxs/regs-usbphy.h b/arch/arm/include/asm/arch-mxs/regs-usbphy.h index 0291d81..5dd5125 100644 --- a/arch/arm/include/asm/arch-mxs/regs-usbphy.h +++ b/arch/arm/include/asm/arch-mxs/regs-usbphy.h @@ -24,16 +24,16 @@ #define __REGS_USBPHY_H__
struct mx28_usbphy_regs { - mx28_reg_32(hw_usbphy_pwd) - mx28_reg_32(hw_usbphy_tx) - mx28_reg_32(hw_usbphy_rx) - mx28_reg_32(hw_usbphy_ctrl) - mx28_reg_32(hw_usbphy_status) - mx28_reg_32(hw_usbphy_debug) - mx28_reg_32(hw_usbphy_debug0_status) - mx28_reg_32(hw_usbphy_debug1) - mx28_reg_32(hw_usbphy_version) - mx28_reg_32(hw_usbphy_ip) + mxs_reg_32(hw_usbphy_pwd) + mxs_reg_32(hw_usbphy_tx) + mxs_reg_32(hw_usbphy_rx) + mxs_reg_32(hw_usbphy_ctrl) + mxs_reg_32(hw_usbphy_status) + mxs_reg_32(hw_usbphy_debug) + mxs_reg_32(hw_usbphy_debug0_status) + mxs_reg_32(hw_usbphy_debug1) + mxs_reg_32(hw_usbphy_version) + mxs_reg_32(hw_usbphy_ip) };
#define USBPHY_PWD_RXPWDRX (1 << 20) diff --git a/arch/arm/include/asm/arch-mxs/sys_proto.h b/arch/arm/include/asm/arch-mxs/sys_proto.h index e701c64..7337458 100644 --- a/arch/arm/include/asm/arch-mxs/sys_proto.h +++ b/arch/arm/include/asm/arch-mxs/sys_proto.h @@ -23,11 +23,11 @@ #ifndef __MX28_H__ #define __MX28_H__
-int mx28_reset_block(struct mx28_register_32 *reg); -int mx28_wait_mask_set(struct mx28_register_32 *reg, +int mx28_reset_block(struct mxs_register_32 *reg); +int mx28_wait_mask_set(struct mxs_register_32 *reg, uint32_t mask, int timeout); -int mx28_wait_mask_clr(struct mx28_register_32 *reg, +int mx28_wait_mask_clr(struct mxs_register_32 *reg, uint32_t mask, int timeout);
diff --git a/drivers/gpio/mxs_gpio.c b/drivers/gpio/mxs_gpio.c index 38dbc81..29f19ba 100644 --- a/drivers/gpio/mxs_gpio.c +++ b/drivers/gpio/mxs_gpio.c @@ -73,8 +73,8 @@ int gpio_get_value(unsigned gpio) { uint32_t bank = PAD_BANK(gpio); uint32_t offset = PINCTRL_DIN(bank); - struct mx28_register_32 *reg = - (struct mx28_register_32 *)(MXS_PINCTRL_BASE + offset); + struct mxs_register_32 *reg = + (struct mxs_register_32 *)(MXS_PINCTRL_BASE + offset);
return (readl(®->reg) >> PAD_PIN(gpio)) & 1; } @@ -83,8 +83,8 @@ void gpio_set_value(unsigned gpio, int value) { uint32_t bank = PAD_BANK(gpio); uint32_t offset = PINCTRL_DOUT(bank); - struct mx28_register_32 *reg = - (struct mx28_register_32 *)(MXS_PINCTRL_BASE + offset); + struct mxs_register_32 *reg = + (struct mxs_register_32 *)(MXS_PINCTRL_BASE + offset);
if (value) writel(1 << PAD_PIN(gpio), ®->reg_set); @@ -96,8 +96,8 @@ int gpio_direction_input(unsigned gpio) { uint32_t bank = PAD_BANK(gpio); uint32_t offset = PINCTRL_DOE(bank); - struct mx28_register_32 *reg = - (struct mx28_register_32 *)(MXS_PINCTRL_BASE + offset); + struct mxs_register_32 *reg = + (struct mxs_register_32 *)(MXS_PINCTRL_BASE + offset);
writel(1 << PAD_PIN(gpio), ®->reg_clr);
@@ -108,8 +108,8 @@ int gpio_direction_output(unsigned gpio, int value) { uint32_t bank = PAD_BANK(gpio); uint32_t offset = PINCTRL_DOE(bank); - struct mx28_register_32 *reg = - (struct mx28_register_32 *)(MXS_PINCTRL_BASE + offset); + struct mxs_register_32 *reg = + (struct mxs_register_32 *)(MXS_PINCTRL_BASE + offset);
diff --git a/drivers/usb/host/ehci-mxs.c b/drivers/usb/host/ehci-mxs.c index e1bd37e..f32df51 100644 --- a/drivers/usb/host/ehci-mxs.c +++ b/drivers/usb/host/ehci-mxs.c @@ -75,8 +75,8 @@ int ehci_hcd_init(void)
int ret; uint32_t usb_base, cap_base; - struct mx28_register_32 *digctl_ctrl = - (struct mx28_register_32 *)HW_DIGCTL_CTRL; + struct mxs_register_32 *digctl_ctrl = + (struct mxs_register_32 *)HW_DIGCTL_CTRL; struct mx28_clkctrl_regs *clkctrl_regs = (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE;
@@ -119,8 +119,8 @@ int ehci_hcd_stop(void) { int ret; uint32_t tmp; - struct mx28_register_32 *digctl_ctrl = - (struct mx28_register_32 *)HW_DIGCTL_CTRL; + struct mxs_register_32 *digctl_ctrl = + (struct mxs_register_32 *)HW_DIGCTL_CTRL; struct mx28_clkctrl_regs *clkctrl_regs = (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE;
The CLKCTRL registers are SoC specific so we ought to have it clear on filename.
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- arch/arm/include/asm/arch-mxs/imx-regs.h | 2 +- arch/arm/include/asm/arch-mxs/regs-clkctrl-mx28.h | 294 +++++++++++++++++++++ arch/arm/include/asm/arch-mxs/regs-clkctrl.h | 294 --------------------- drivers/usb/host/ehci-mxs.c | 2 +- 4 files changed, 296 insertions(+), 296 deletions(-) create mode 100644 arch/arm/include/asm/arch-mxs/regs-clkctrl-mx28.h delete mode 100644 arch/arm/include/asm/arch-mxs/regs-clkctrl.h
diff --git a/arch/arm/include/asm/arch-mxs/imx-regs.h b/arch/arm/include/asm/arch-mxs/imx-regs.h index 37d0a93..5e1901e 100644 --- a/arch/arm/include/asm/arch-mxs/imx-regs.h +++ b/arch/arm/include/asm/arch-mxs/imx-regs.h @@ -26,7 +26,7 @@ #include <asm/arch/regs-apbh.h> #include <asm/arch/regs-base.h> #include <asm/arch/regs-bch.h> -#include <asm/arch/regs-clkctrl.h> +#include <asm/arch/regs-clkctrl-mx28.h> #include <asm/arch/regs-digctl.h> #include <asm/arch/regs-gpmi.h> #include <asm/arch/regs-i2c.h> diff --git a/arch/arm/include/asm/arch-mxs/regs-clkctrl-mx28.h b/arch/arm/include/asm/arch-mxs/regs-clkctrl-mx28.h new file mode 100644 index 0000000..127370b --- /dev/null +++ b/arch/arm/include/asm/arch-mxs/regs-clkctrl-mx28.h @@ -0,0 +1,294 @@ +/* + * Freescale i.MX28 CLKCTRL Register Definitions + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * Based on code from LTIB: + * Copyright 2008-2010 Freescale Semiconductor, Inc. All Rights Reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __MX28_REGS_CLKCTRL_H__ +#define __MX28_REGS_CLKCTRL_H__ + +#include <asm/arch/regs-common.h> + +#ifndef __ASSEMBLY__ +struct mx28_clkctrl_regs { + mxs_reg_32(hw_clkctrl_pll0ctrl0) /* 0x00 */ + mxs_reg_32(hw_clkctrl_pll0ctrl1) /* 0x10 */ + mxs_reg_32(hw_clkctrl_pll1ctrl0) /* 0x20 */ + mxs_reg_32(hw_clkctrl_pll1ctrl1) /* 0x30 */ + mxs_reg_32(hw_clkctrl_pll2ctrl0) /* 0x40 */ + mxs_reg_32(hw_clkctrl_cpu) /* 0x50 */ + mxs_reg_32(hw_clkctrl_hbus) /* 0x60 */ + mxs_reg_32(hw_clkctrl_xbus) /* 0x70 */ + mxs_reg_32(hw_clkctrl_xtal) /* 0x80 */ + mxs_reg_32(hw_clkctrl_ssp0) /* 0x90 */ + mxs_reg_32(hw_clkctrl_ssp1) /* 0xa0 */ + mxs_reg_32(hw_clkctrl_ssp2) /* 0xb0 */ + mxs_reg_32(hw_clkctrl_ssp3) /* 0xc0 */ + mxs_reg_32(hw_clkctrl_gpmi) /* 0xd0 */ + mxs_reg_32(hw_clkctrl_spdif) /* 0xe0 */ + mxs_reg_32(hw_clkctrl_emi) /* 0xf0 */ + mxs_reg_32(hw_clkctrl_saif0) /* 0x100 */ + mxs_reg_32(hw_clkctrl_saif1) /* 0x110 */ + mxs_reg_32(hw_clkctrl_lcdif) /* 0x120 */ + mxs_reg_32(hw_clkctrl_etm) /* 0x130 */ + mxs_reg_32(hw_clkctrl_enet) /* 0x140 */ + mxs_reg_32(hw_clkctrl_hsadc) /* 0x150 */ + mxs_reg_32(hw_clkctrl_flexcan) /* 0x160 */ + + uint32_t reserved[16]; + + mxs_reg_8(hw_clkctrl_frac0) /* 0x1b0 */ + mxs_reg_8(hw_clkctrl_frac1) /* 0x1c0 */ + mxs_reg_32(hw_clkctrl_clkseq) /* 0x1d0 */ + mxs_reg_32(hw_clkctrl_reset) /* 0x1e0 */ + mxs_reg_32(hw_clkctrl_status) /* 0x1f0 */ + mxs_reg_32(hw_clkctrl_version) /* 0x200 */ +}; +#endif + +#define CLKCTRL_PLL0CTRL0_LFR_SEL_MASK (0x3 << 28) +#define CLKCTRL_PLL0CTRL0_LFR_SEL_OFFSET 28 +#define CLKCTRL_PLL0CTRL0_LFR_SEL_DEFAULT (0x0 << 28) +#define CLKCTRL_PLL0CTRL0_LFR_SEL_TIMES_2 (0x1 << 28) +#define CLKCTRL_PLL0CTRL0_LFR_SEL_TIMES_05 (0x2 << 28) +#define CLKCTRL_PLL0CTRL0_LFR_SEL_UNDEFINED (0x3 << 28) +#define CLKCTRL_PLL0CTRL0_CP_SEL_MASK (0x3 << 24) +#define CLKCTRL_PLL0CTRL0_CP_SEL_OFFSET 24 +#define CLKCTRL_PLL0CTRL0_CP_SEL_DEFAULT (0x0 << 24) +#define CLKCTRL_PLL0CTRL0_CP_SEL_TIMES_2 (0x1 << 24) +#define CLKCTRL_PLL0CTRL0_CP_SEL_TIMES_05 (0x2 << 24) +#define CLKCTRL_PLL0CTRL0_CP_SEL_UNDEFINED (0x3 << 24) +#define CLKCTRL_PLL0CTRL0_DIV_SEL_MASK (0x3 << 20) +#define CLKCTRL_PLL0CTRL0_DIV_SEL_OFFSET 20 +#define CLKCTRL_PLL0CTRL0_DIV_SEL_DEFAULT (0x0 << 20) +#define CLKCTRL_PLL0CTRL0_DIV_SEL_LOWER (0x1 << 20) +#define CLKCTRL_PLL0CTRL0_DIV_SEL_LOWEST (0x2 << 20) +#define CLKCTRL_PLL0CTRL0_DIV_SEL_UNDEFINED (0x3 << 20) +#define CLKCTRL_PLL0CTRL0_EN_USB_CLKS (1 << 18) +#define CLKCTRL_PLL0CTRL0_POWER (1 << 17) + +#define CLKCTRL_PLL0CTRL1_LOCK (1 << 31) +#define CLKCTRL_PLL0CTRL1_FORCE_LOCK (1 << 30) +#define CLKCTRL_PLL0CTRL1_LOCK_COUNT_MASK 0xffff +#define CLKCTRL_PLL0CTRL1_LOCK_COUNT_OFFSET 0 + +#define CLKCTRL_PLL1CTRL0_CLKGATEEMI (1 << 31) +#define CLKCTRL_PLL1CTRL0_LFR_SEL_MASK (0x3 << 28) +#define CLKCTRL_PLL1CTRL0_LFR_SEL_OFFSET 28 +#define CLKCTRL_PLL1CTRL0_LFR_SEL_DEFAULT (0x0 << 28) +#define CLKCTRL_PLL1CTRL0_LFR_SEL_TIMES_2 (0x1 << 28) +#define CLKCTRL_PLL1CTRL0_LFR_SEL_TIMES_05 (0x2 << 28) +#define CLKCTRL_PLL1CTRL0_LFR_SEL_UNDEFINED (0x3 << 28) +#define CLKCTRL_PLL1CTRL0_CP_SEL_MASK (0x3 << 24) +#define CLKCTRL_PLL1CTRL0_CP_SEL_OFFSET 24 +#define CLKCTRL_PLL1CTRL0_CP_SEL_DEFAULT (0x0 << 24) +#define CLKCTRL_PLL1CTRL0_CP_SEL_TIMES_2 (0x1 << 24) +#define CLKCTRL_PLL1CTRL0_CP_SEL_TIMES_05 (0x2 << 24) +#define CLKCTRL_PLL1CTRL0_CP_SEL_UNDEFINED (0x3 << 24) +#define CLKCTRL_PLL1CTRL0_DIV_SEL_MASK (0x3 << 20) +#define CLKCTRL_PLL1CTRL0_DIV_SEL_OFFSET 20 +#define CLKCTRL_PLL1CTRL0_DIV_SEL_DEFAULT (0x0 << 20) +#define CLKCTRL_PLL1CTRL0_DIV_SEL_LOWER (0x1 << 20) +#define CLKCTRL_PLL1CTRL0_DIV_SEL_LOWEST (0x2 << 20) +#define CLKCTRL_PLL1CTRL0_DIV_SEL_UNDEFINED (0x3 << 20) +#define CLKCTRL_PLL1CTRL0_EN_USB_CLKS (1 << 18) +#define CLKCTRL_PLL1CTRL0_POWER (1 << 17) + +#define CLKCTRL_PLL1CTRL1_LOCK (1 << 31) +#define CLKCTRL_PLL1CTRL1_FORCE_LOCK (1 << 30) +#define CLKCTRL_PLL1CTRL1_LOCK_COUNT_MASK 0xffff +#define CLKCTRL_PLL1CTRL1_LOCK_COUNT_OFFSET 0 + +#define CLKCTRL_PLL2CTRL0_CLKGATE (1 << 31) +#define CLKCTRL_PLL2CTRL0_LFR_SEL_MASK (0x3 << 28) +#define CLKCTRL_PLL2CTRL0_LFR_SEL_OFFSET 28 +#define CLKCTRL_PLL2CTRL0_HOLD_RING_OFF_B (1 << 26) +#define CLKCTRL_PLL2CTRL0_CP_SEL_MASK (0x3 << 24) +#define CLKCTRL_PLL2CTRL0_CP_SEL_OFFSET 24 +#define CLKCTRL_PLL2CTRL0_POWER (1 << 23) + +#define CLKCTRL_CPU_BUSY_REF_XTAL (1 << 29) +#define CLKCTRL_CPU_BUSY_REF_CPU (1 << 28) +#define CLKCTRL_CPU_DIV_XTAL_FRAC_EN (1 << 26) +#define CLKCTRL_CPU_DIV_XTAL_MASK (0x3ff << 16) +#define CLKCTRL_CPU_DIV_XTAL_OFFSET 16 +#define CLKCTRL_CPU_INTERRUPT_WAIT (1 << 12) +#define CLKCTRL_CPU_DIV_CPU_FRAC_EN (1 << 10) +#define CLKCTRL_CPU_DIV_CPU_MASK 0x3f +#define CLKCTRL_CPU_DIV_CPU_OFFSET 0 + +#define CLKCTRL_HBUS_ASM_BUSY (1 << 31) +#define CLKCTRL_HBUS_DCP_AS_ENABLE (1 << 30) +#define CLKCTRL_HBUS_PXP_AS_ENABLE (1 << 29) +#define CLKCTRL_HBUS_ASM_EMIPORT_AS_ENABLE (1 << 27) +#define CLKCTRL_HBUS_APBHDMA_AS_ENABLE (1 << 26) +#define CLKCTRL_HBUS_APBXDMA_AS_ENABLE (1 << 25) +#define CLKCTRL_HBUS_TRAFFIC_JAM_AS_ENABLE (1 << 24) +#define CLKCTRL_HBUS_TRAFFIC_AS_ENABLE (1 << 23) +#define CLKCTRL_HBUS_CPU_DATA_AS_ENABLE (1 << 22) +#define CLKCTRL_HBUS_CPU_INSTR_AS_ENABLE (1 << 21) +#define CLKCTRL_HBUS_ASM_ENABLE (1 << 20) +#define CLKCTRL_HBUS_AUTO_CLEAR_DIV_ENABLE (1 << 19) +#define CLKCTRL_HBUS_SLOW_DIV_MASK (0x7 << 16) +#define CLKCTRL_HBUS_SLOW_DIV_OFFSET 16 +#define CLKCTRL_HBUS_SLOW_DIV_BY1 (0x0 << 16) +#define CLKCTRL_HBUS_SLOW_DIV_BY2 (0x1 << 16) +#define CLKCTRL_HBUS_SLOW_DIV_BY4 (0x2 << 16) +#define CLKCTRL_HBUS_SLOW_DIV_BY8 (0x3 << 16) +#define CLKCTRL_HBUS_SLOW_DIV_BY16 (0x4 << 16) +#define CLKCTRL_HBUS_SLOW_DIV_BY32 (0x5 << 16) +#define CLKCTRL_HBUS_DIV_FRAC_EN (1 << 5) +#define CLKCTRL_HBUS_DIV_MASK 0x1f +#define CLKCTRL_HBUS_DIV_OFFSET 0 + +#define CLKCTRL_XBUS_BUSY (1 << 31) +#define CLKCTRL_XBUS_AUTO_CLEAR_DIV_ENABLE (1 << 11) +#define CLKCTRL_XBUS_DIV_FRAC_EN (1 << 10) +#define CLKCTRL_XBUS_DIV_MASK 0x3ff +#define CLKCTRL_XBUS_DIV_OFFSET 0 + +#define CLKCTRL_XTAL_UART_CLK_GATE (1 << 31) +#define CLKCTRL_XTAL_PWM_CLK24M_GATE (1 << 29) +#define CLKCTRL_XTAL_TIMROT_CLK32K_GATE (1 << 26) +#define CLKCTRL_XTAL_DIV_UART_MASK 0x3 +#define CLKCTRL_XTAL_DIV_UART_OFFSET 0 + +#define CLKCTRL_SSP_CLKGATE (1 << 31) +#define CLKCTRL_SSP_BUSY (1 << 29) +#define CLKCTRL_SSP_DIV_FRAC_EN (1 << 9) +#define CLKCTRL_SSP_DIV_MASK 0x1ff +#define CLKCTRL_SSP_DIV_OFFSET 0 + +#define CLKCTRL_GPMI_CLKGATE (1 << 31) +#define CLKCTRL_GPMI_BUSY (1 << 29) +#define CLKCTRL_GPMI_DIV_FRAC_EN (1 << 10) +#define CLKCTRL_GPMI_DIV_MASK 0x3ff +#define CLKCTRL_GPMI_DIV_OFFSET 0 + +#define CLKCTRL_SPDIF_CLKGATE (1 << 31) + +#define CLKCTRL_EMI_CLKGATE (1 << 31) +#define CLKCTRL_EMI_SYNC_MODE_EN (1 << 30) +#define CLKCTRL_EMI_BUSY_REF_XTAL (1 << 29) +#define CLKCTRL_EMI_BUSY_REF_EMI (1 << 28) +#define CLKCTRL_EMI_BUSY_REF_CPU (1 << 27) +#define CLKCTRL_EMI_BUSY_SYNC_MODE (1 << 26) +#define CLKCTRL_EMI_BUSY_DCC_RESYNC (1 << 17) +#define CLKCTRL_EMI_DCC_RESYNC_ENABLE (1 << 16) +#define CLKCTRL_EMI_DIV_XTAL_MASK (0xf << 8) +#define CLKCTRL_EMI_DIV_XTAL_OFFSET 8 +#define CLKCTRL_EMI_DIV_EMI_MASK 0x3f +#define CLKCTRL_EMI_DIV_EMI_OFFSET 0 + +#define CLKCTRL_SAIF0_CLKGATE (1 << 31) +#define CLKCTRL_SAIF0_BUSY (1 << 29) +#define CLKCTRL_SAIF0_DIV_FRAC_EN (1 << 16) +#define CLKCTRL_SAIF0_DIV_MASK 0xffff +#define CLKCTRL_SAIF0_DIV_OFFSET 0 + +#define CLKCTRL_SAIF1_CLKGATE (1 << 31) +#define CLKCTRL_SAIF1_BUSY (1 << 29) +#define CLKCTRL_SAIF1_DIV_FRAC_EN (1 << 16) +#define CLKCTRL_SAIF1_DIV_MASK 0xffff +#define CLKCTRL_SAIF1_DIV_OFFSET 0 + +#define CLKCTRL_DIS_LCDIF_CLKGATE (1 << 31) +#define CLKCTRL_DIS_LCDIF_BUSY (1 << 29) +#define CLKCTRL_DIS_LCDIF_DIV_FRAC_EN (1 << 13) +#define CLKCTRL_DIS_LCDIF_DIV_MASK 0x1fff +#define CLKCTRL_DIS_LCDIF_DIV_OFFSET 0 + +#define CLKCTRL_ETM_CLKGATE (1 << 31) +#define CLKCTRL_ETM_BUSY (1 << 29) +#define CLKCTRL_ETM_DIV_FRAC_EN (1 << 7) +#define CLKCTRL_ETM_DIV_MASK 0x7f +#define CLKCTRL_ETM_DIV_OFFSET 0 + +#define CLKCTRL_ENET_SLEEP (1 << 31) +#define CLKCTRL_ENET_DISABLE (1 << 30) +#define CLKCTRL_ENET_STATUS (1 << 29) +#define CLKCTRL_ENET_BUSY_TIME (1 << 27) +#define CLKCTRL_ENET_DIV_TIME_MASK (0x3f << 21) +#define CLKCTRL_ENET_DIV_TIME_OFFSET 21 +#define CLKCTRL_ENET_TIME_SEL_MASK (0x3 << 19) +#define CLKCTRL_ENET_TIME_SEL_OFFSET 19 +#define CLKCTRL_ENET_TIME_SEL_XTAL (0x0 << 19) +#define CLKCTRL_ENET_TIME_SEL_PLL (0x1 << 19) +#define CLKCTRL_ENET_TIME_SEL_RMII_CLK (0x2 << 19) +#define CLKCTRL_ENET_TIME_SEL_UNDEFINED (0x3 << 19) +#define CLKCTRL_ENET_CLK_OUT_EN (1 << 18) +#define CLKCTRL_ENET_RESET_BY_SW_CHIP (1 << 17) +#define CLKCTRL_ENET_RESET_BY_SW (1 << 16) + +#define CLKCTRL_HSADC_RESETB (1 << 30) +#define CLKCTRL_HSADC_FREQDIV_MASK (0x3 << 28) +#define CLKCTRL_HSADC_FREQDIV_OFFSET 28 + +#define CLKCTRL_FLEXCAN_STOP_CAN0 (1 << 30) +#define CLKCTRL_FLEXCAN_CAN0_STATUS (1 << 29) +#define CLKCTRL_FLEXCAN_STOP_CAN1 (1 << 28) +#define CLKCTRL_FLEXCAN_CAN1_STATUS (1 << 27) + +#define CLKCTRL_FRAC_CLKGATE (1 << 7) +#define CLKCTRL_FRAC_STABLE (1 << 6) +#define CLKCTRL_FRAC_FRAC_MASK 0x3f +#define CLKCTRL_FRAC_FRAC_OFFSET 0 +#define CLKCTRL_FRAC0_CPU 0 +#define CLKCTRL_FRAC0_EMI 1 +#define CLKCTRL_FRAC0_IO1 2 +#define CLKCTRL_FRAC0_IO0 3 +#define CLKCTRL_FRAC1_PIX 0 +#define CLKCTRL_FRAC1_HSADC 1 +#define CLKCTRL_FRAC1_GPMI 2 + +#define CLKCTRL_CLKSEQ_BYPASS_CPU (1 << 18) +#define CLKCTRL_CLKSEQ_BYPASS_DIS_LCDIF (1 << 14) +#define CLKCTRL_CLKSEQ_BYPASS_DIS_LCDIF_BYPASS (0x1 << 14) +#define CLKCTRL_CLKSEQ_BYPASS_DIS_LCDIF_PFD (0x0 << 14) +#define CLKCTRL_CLKSEQ_BYPASS_ETM (1 << 8) +#define CLKCTRL_CLKSEQ_BYPASS_EMI (1 << 7) +#define CLKCTRL_CLKSEQ_BYPASS_SSP3 (1 << 6) +#define CLKCTRL_CLKSEQ_BYPASS_SSP2 (1 << 5) +#define CLKCTRL_CLKSEQ_BYPASS_SSP1 (1 << 4) +#define CLKCTRL_CLKSEQ_BYPASS_SSP0 (1 << 3) +#define CLKCTRL_CLKSEQ_BYPASS_GPMI (1 << 2) +#define CLKCTRL_CLKSEQ_BYPASS_SAIF1 (1 << 1) +#define CLKCTRL_CLKSEQ_BYPASS_SAIF0 (1 << 0) + +#define CLKCTRL_RESET_WDOG_POR_DISABLE (1 << 5) +#define CLKCTRL_RESET_EXTERNAL_RESET_ENABLE (1 << 4) +#define CLKCTRL_RESET_THERMAL_RESET_ENABLE (1 << 3) +#define CLKCTRL_RESET_THERMAL_RESET_DEFAULT (1 << 2) +#define CLKCTRL_RESET_CHIP (1 << 1) +#define CLKCTRL_RESET_DIG (1 << 0) + +#define CLKCTRL_STATUS_CPU_LIMIT_MASK (0x3 << 30) +#define CLKCTRL_STATUS_CPU_LIMIT_OFFSET 30 + +#define CLKCTRL_VERSION_MAJOR_MASK (0xff << 24) +#define CLKCTRL_VERSION_MAJOR_OFFSET 24 +#define CLKCTRL_VERSION_MINOR_MASK (0xff << 16) +#define CLKCTRL_VERSION_MINOR_OFFSET 16 +#define CLKCTRL_VERSION_STEP_MASK 0xffff +#define CLKCTRL_VERSION_STEP_OFFSET 0 + +#endif /* __MX28_REGS_CLKCTRL_H__ */ diff --git a/arch/arm/include/asm/arch-mxs/regs-clkctrl.h b/arch/arm/include/asm/arch-mxs/regs-clkctrl.h deleted file mode 100644 index 127370b..0000000 --- a/arch/arm/include/asm/arch-mxs/regs-clkctrl.h +++ /dev/null @@ -1,294 +0,0 @@ -/* - * Freescale i.MX28 CLKCTRL Register Definitions - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * on behalf of DENX Software Engineering GmbH - * - * Based on code from LTIB: - * Copyright 2008-2010 Freescale Semiconductor, Inc. All Rights Reserved. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA - * - */ - -#ifndef __MX28_REGS_CLKCTRL_H__ -#define __MX28_REGS_CLKCTRL_H__ - -#include <asm/arch/regs-common.h> - -#ifndef __ASSEMBLY__ -struct mx28_clkctrl_regs { - mxs_reg_32(hw_clkctrl_pll0ctrl0) /* 0x00 */ - mxs_reg_32(hw_clkctrl_pll0ctrl1) /* 0x10 */ - mxs_reg_32(hw_clkctrl_pll1ctrl0) /* 0x20 */ - mxs_reg_32(hw_clkctrl_pll1ctrl1) /* 0x30 */ - mxs_reg_32(hw_clkctrl_pll2ctrl0) /* 0x40 */ - mxs_reg_32(hw_clkctrl_cpu) /* 0x50 */ - mxs_reg_32(hw_clkctrl_hbus) /* 0x60 */ - mxs_reg_32(hw_clkctrl_xbus) /* 0x70 */ - mxs_reg_32(hw_clkctrl_xtal) /* 0x80 */ - mxs_reg_32(hw_clkctrl_ssp0) /* 0x90 */ - mxs_reg_32(hw_clkctrl_ssp1) /* 0xa0 */ - mxs_reg_32(hw_clkctrl_ssp2) /* 0xb0 */ - mxs_reg_32(hw_clkctrl_ssp3) /* 0xc0 */ - mxs_reg_32(hw_clkctrl_gpmi) /* 0xd0 */ - mxs_reg_32(hw_clkctrl_spdif) /* 0xe0 */ - mxs_reg_32(hw_clkctrl_emi) /* 0xf0 */ - mxs_reg_32(hw_clkctrl_saif0) /* 0x100 */ - mxs_reg_32(hw_clkctrl_saif1) /* 0x110 */ - mxs_reg_32(hw_clkctrl_lcdif) /* 0x120 */ - mxs_reg_32(hw_clkctrl_etm) /* 0x130 */ - mxs_reg_32(hw_clkctrl_enet) /* 0x140 */ - mxs_reg_32(hw_clkctrl_hsadc) /* 0x150 */ - mxs_reg_32(hw_clkctrl_flexcan) /* 0x160 */ - - uint32_t reserved[16]; - - mxs_reg_8(hw_clkctrl_frac0) /* 0x1b0 */ - mxs_reg_8(hw_clkctrl_frac1) /* 0x1c0 */ - mxs_reg_32(hw_clkctrl_clkseq) /* 0x1d0 */ - mxs_reg_32(hw_clkctrl_reset) /* 0x1e0 */ - mxs_reg_32(hw_clkctrl_status) /* 0x1f0 */ - mxs_reg_32(hw_clkctrl_version) /* 0x200 */ -}; -#endif - -#define CLKCTRL_PLL0CTRL0_LFR_SEL_MASK (0x3 << 28) -#define CLKCTRL_PLL0CTRL0_LFR_SEL_OFFSET 28 -#define CLKCTRL_PLL0CTRL0_LFR_SEL_DEFAULT (0x0 << 28) -#define CLKCTRL_PLL0CTRL0_LFR_SEL_TIMES_2 (0x1 << 28) -#define CLKCTRL_PLL0CTRL0_LFR_SEL_TIMES_05 (0x2 << 28) -#define CLKCTRL_PLL0CTRL0_LFR_SEL_UNDEFINED (0x3 << 28) -#define CLKCTRL_PLL0CTRL0_CP_SEL_MASK (0x3 << 24) -#define CLKCTRL_PLL0CTRL0_CP_SEL_OFFSET 24 -#define CLKCTRL_PLL0CTRL0_CP_SEL_DEFAULT (0x0 << 24) -#define CLKCTRL_PLL0CTRL0_CP_SEL_TIMES_2 (0x1 << 24) -#define CLKCTRL_PLL0CTRL0_CP_SEL_TIMES_05 (0x2 << 24) -#define CLKCTRL_PLL0CTRL0_CP_SEL_UNDEFINED (0x3 << 24) -#define CLKCTRL_PLL0CTRL0_DIV_SEL_MASK (0x3 << 20) -#define CLKCTRL_PLL0CTRL0_DIV_SEL_OFFSET 20 -#define CLKCTRL_PLL0CTRL0_DIV_SEL_DEFAULT (0x0 << 20) -#define CLKCTRL_PLL0CTRL0_DIV_SEL_LOWER (0x1 << 20) -#define CLKCTRL_PLL0CTRL0_DIV_SEL_LOWEST (0x2 << 20) -#define CLKCTRL_PLL0CTRL0_DIV_SEL_UNDEFINED (0x3 << 20) -#define CLKCTRL_PLL0CTRL0_EN_USB_CLKS (1 << 18) -#define CLKCTRL_PLL0CTRL0_POWER (1 << 17) - -#define CLKCTRL_PLL0CTRL1_LOCK (1 << 31) -#define CLKCTRL_PLL0CTRL1_FORCE_LOCK (1 << 30) -#define CLKCTRL_PLL0CTRL1_LOCK_COUNT_MASK 0xffff -#define CLKCTRL_PLL0CTRL1_LOCK_COUNT_OFFSET 0 - -#define CLKCTRL_PLL1CTRL0_CLKGATEEMI (1 << 31) -#define CLKCTRL_PLL1CTRL0_LFR_SEL_MASK (0x3 << 28) -#define CLKCTRL_PLL1CTRL0_LFR_SEL_OFFSET 28 -#define CLKCTRL_PLL1CTRL0_LFR_SEL_DEFAULT (0x0 << 28) -#define CLKCTRL_PLL1CTRL0_LFR_SEL_TIMES_2 (0x1 << 28) -#define CLKCTRL_PLL1CTRL0_LFR_SEL_TIMES_05 (0x2 << 28) -#define CLKCTRL_PLL1CTRL0_LFR_SEL_UNDEFINED (0x3 << 28) -#define CLKCTRL_PLL1CTRL0_CP_SEL_MASK (0x3 << 24) -#define CLKCTRL_PLL1CTRL0_CP_SEL_OFFSET 24 -#define CLKCTRL_PLL1CTRL0_CP_SEL_DEFAULT (0x0 << 24) -#define CLKCTRL_PLL1CTRL0_CP_SEL_TIMES_2 (0x1 << 24) -#define CLKCTRL_PLL1CTRL0_CP_SEL_TIMES_05 (0x2 << 24) -#define CLKCTRL_PLL1CTRL0_CP_SEL_UNDEFINED (0x3 << 24) -#define CLKCTRL_PLL1CTRL0_DIV_SEL_MASK (0x3 << 20) -#define CLKCTRL_PLL1CTRL0_DIV_SEL_OFFSET 20 -#define CLKCTRL_PLL1CTRL0_DIV_SEL_DEFAULT (0x0 << 20) -#define CLKCTRL_PLL1CTRL0_DIV_SEL_LOWER (0x1 << 20) -#define CLKCTRL_PLL1CTRL0_DIV_SEL_LOWEST (0x2 << 20) -#define CLKCTRL_PLL1CTRL0_DIV_SEL_UNDEFINED (0x3 << 20) -#define CLKCTRL_PLL1CTRL0_EN_USB_CLKS (1 << 18) -#define CLKCTRL_PLL1CTRL0_POWER (1 << 17) - -#define CLKCTRL_PLL1CTRL1_LOCK (1 << 31) -#define CLKCTRL_PLL1CTRL1_FORCE_LOCK (1 << 30) -#define CLKCTRL_PLL1CTRL1_LOCK_COUNT_MASK 0xffff -#define CLKCTRL_PLL1CTRL1_LOCK_COUNT_OFFSET 0 - -#define CLKCTRL_PLL2CTRL0_CLKGATE (1 << 31) -#define CLKCTRL_PLL2CTRL0_LFR_SEL_MASK (0x3 << 28) -#define CLKCTRL_PLL2CTRL0_LFR_SEL_OFFSET 28 -#define CLKCTRL_PLL2CTRL0_HOLD_RING_OFF_B (1 << 26) -#define CLKCTRL_PLL2CTRL0_CP_SEL_MASK (0x3 << 24) -#define CLKCTRL_PLL2CTRL0_CP_SEL_OFFSET 24 -#define CLKCTRL_PLL2CTRL0_POWER (1 << 23) - -#define CLKCTRL_CPU_BUSY_REF_XTAL (1 << 29) -#define CLKCTRL_CPU_BUSY_REF_CPU (1 << 28) -#define CLKCTRL_CPU_DIV_XTAL_FRAC_EN (1 << 26) -#define CLKCTRL_CPU_DIV_XTAL_MASK (0x3ff << 16) -#define CLKCTRL_CPU_DIV_XTAL_OFFSET 16 -#define CLKCTRL_CPU_INTERRUPT_WAIT (1 << 12) -#define CLKCTRL_CPU_DIV_CPU_FRAC_EN (1 << 10) -#define CLKCTRL_CPU_DIV_CPU_MASK 0x3f -#define CLKCTRL_CPU_DIV_CPU_OFFSET 0 - -#define CLKCTRL_HBUS_ASM_BUSY (1 << 31) -#define CLKCTRL_HBUS_DCP_AS_ENABLE (1 << 30) -#define CLKCTRL_HBUS_PXP_AS_ENABLE (1 << 29) -#define CLKCTRL_HBUS_ASM_EMIPORT_AS_ENABLE (1 << 27) -#define CLKCTRL_HBUS_APBHDMA_AS_ENABLE (1 << 26) -#define CLKCTRL_HBUS_APBXDMA_AS_ENABLE (1 << 25) -#define CLKCTRL_HBUS_TRAFFIC_JAM_AS_ENABLE (1 << 24) -#define CLKCTRL_HBUS_TRAFFIC_AS_ENABLE (1 << 23) -#define CLKCTRL_HBUS_CPU_DATA_AS_ENABLE (1 << 22) -#define CLKCTRL_HBUS_CPU_INSTR_AS_ENABLE (1 << 21) -#define CLKCTRL_HBUS_ASM_ENABLE (1 << 20) -#define CLKCTRL_HBUS_AUTO_CLEAR_DIV_ENABLE (1 << 19) -#define CLKCTRL_HBUS_SLOW_DIV_MASK (0x7 << 16) -#define CLKCTRL_HBUS_SLOW_DIV_OFFSET 16 -#define CLKCTRL_HBUS_SLOW_DIV_BY1 (0x0 << 16) -#define CLKCTRL_HBUS_SLOW_DIV_BY2 (0x1 << 16) -#define CLKCTRL_HBUS_SLOW_DIV_BY4 (0x2 << 16) -#define CLKCTRL_HBUS_SLOW_DIV_BY8 (0x3 << 16) -#define CLKCTRL_HBUS_SLOW_DIV_BY16 (0x4 << 16) -#define CLKCTRL_HBUS_SLOW_DIV_BY32 (0x5 << 16) -#define CLKCTRL_HBUS_DIV_FRAC_EN (1 << 5) -#define CLKCTRL_HBUS_DIV_MASK 0x1f -#define CLKCTRL_HBUS_DIV_OFFSET 0 - -#define CLKCTRL_XBUS_BUSY (1 << 31) -#define CLKCTRL_XBUS_AUTO_CLEAR_DIV_ENABLE (1 << 11) -#define CLKCTRL_XBUS_DIV_FRAC_EN (1 << 10) -#define CLKCTRL_XBUS_DIV_MASK 0x3ff -#define CLKCTRL_XBUS_DIV_OFFSET 0 - -#define CLKCTRL_XTAL_UART_CLK_GATE (1 << 31) -#define CLKCTRL_XTAL_PWM_CLK24M_GATE (1 << 29) -#define CLKCTRL_XTAL_TIMROT_CLK32K_GATE (1 << 26) -#define CLKCTRL_XTAL_DIV_UART_MASK 0x3 -#define CLKCTRL_XTAL_DIV_UART_OFFSET 0 - -#define CLKCTRL_SSP_CLKGATE (1 << 31) -#define CLKCTRL_SSP_BUSY (1 << 29) -#define CLKCTRL_SSP_DIV_FRAC_EN (1 << 9) -#define CLKCTRL_SSP_DIV_MASK 0x1ff -#define CLKCTRL_SSP_DIV_OFFSET 0 - -#define CLKCTRL_GPMI_CLKGATE (1 << 31) -#define CLKCTRL_GPMI_BUSY (1 << 29) -#define CLKCTRL_GPMI_DIV_FRAC_EN (1 << 10) -#define CLKCTRL_GPMI_DIV_MASK 0x3ff -#define CLKCTRL_GPMI_DIV_OFFSET 0 - -#define CLKCTRL_SPDIF_CLKGATE (1 << 31) - -#define CLKCTRL_EMI_CLKGATE (1 << 31) -#define CLKCTRL_EMI_SYNC_MODE_EN (1 << 30) -#define CLKCTRL_EMI_BUSY_REF_XTAL (1 << 29) -#define CLKCTRL_EMI_BUSY_REF_EMI (1 << 28) -#define CLKCTRL_EMI_BUSY_REF_CPU (1 << 27) -#define CLKCTRL_EMI_BUSY_SYNC_MODE (1 << 26) -#define CLKCTRL_EMI_BUSY_DCC_RESYNC (1 << 17) -#define CLKCTRL_EMI_DCC_RESYNC_ENABLE (1 << 16) -#define CLKCTRL_EMI_DIV_XTAL_MASK (0xf << 8) -#define CLKCTRL_EMI_DIV_XTAL_OFFSET 8 -#define CLKCTRL_EMI_DIV_EMI_MASK 0x3f -#define CLKCTRL_EMI_DIV_EMI_OFFSET 0 - -#define CLKCTRL_SAIF0_CLKGATE (1 << 31) -#define CLKCTRL_SAIF0_BUSY (1 << 29) -#define CLKCTRL_SAIF0_DIV_FRAC_EN (1 << 16) -#define CLKCTRL_SAIF0_DIV_MASK 0xffff -#define CLKCTRL_SAIF0_DIV_OFFSET 0 - -#define CLKCTRL_SAIF1_CLKGATE (1 << 31) -#define CLKCTRL_SAIF1_BUSY (1 << 29) -#define CLKCTRL_SAIF1_DIV_FRAC_EN (1 << 16) -#define CLKCTRL_SAIF1_DIV_MASK 0xffff -#define CLKCTRL_SAIF1_DIV_OFFSET 0 - -#define CLKCTRL_DIS_LCDIF_CLKGATE (1 << 31) -#define CLKCTRL_DIS_LCDIF_BUSY (1 << 29) -#define CLKCTRL_DIS_LCDIF_DIV_FRAC_EN (1 << 13) -#define CLKCTRL_DIS_LCDIF_DIV_MASK 0x1fff -#define CLKCTRL_DIS_LCDIF_DIV_OFFSET 0 - -#define CLKCTRL_ETM_CLKGATE (1 << 31) -#define CLKCTRL_ETM_BUSY (1 << 29) -#define CLKCTRL_ETM_DIV_FRAC_EN (1 << 7) -#define CLKCTRL_ETM_DIV_MASK 0x7f -#define CLKCTRL_ETM_DIV_OFFSET 0 - -#define CLKCTRL_ENET_SLEEP (1 << 31) -#define CLKCTRL_ENET_DISABLE (1 << 30) -#define CLKCTRL_ENET_STATUS (1 << 29) -#define CLKCTRL_ENET_BUSY_TIME (1 << 27) -#define CLKCTRL_ENET_DIV_TIME_MASK (0x3f << 21) -#define CLKCTRL_ENET_DIV_TIME_OFFSET 21 -#define CLKCTRL_ENET_TIME_SEL_MASK (0x3 << 19) -#define CLKCTRL_ENET_TIME_SEL_OFFSET 19 -#define CLKCTRL_ENET_TIME_SEL_XTAL (0x0 << 19) -#define CLKCTRL_ENET_TIME_SEL_PLL (0x1 << 19) -#define CLKCTRL_ENET_TIME_SEL_RMII_CLK (0x2 << 19) -#define CLKCTRL_ENET_TIME_SEL_UNDEFINED (0x3 << 19) -#define CLKCTRL_ENET_CLK_OUT_EN (1 << 18) -#define CLKCTRL_ENET_RESET_BY_SW_CHIP (1 << 17) -#define CLKCTRL_ENET_RESET_BY_SW (1 << 16) - -#define CLKCTRL_HSADC_RESETB (1 << 30) -#define CLKCTRL_HSADC_FREQDIV_MASK (0x3 << 28) -#define CLKCTRL_HSADC_FREQDIV_OFFSET 28 - -#define CLKCTRL_FLEXCAN_STOP_CAN0 (1 << 30) -#define CLKCTRL_FLEXCAN_CAN0_STATUS (1 << 29) -#define CLKCTRL_FLEXCAN_STOP_CAN1 (1 << 28) -#define CLKCTRL_FLEXCAN_CAN1_STATUS (1 << 27) - -#define CLKCTRL_FRAC_CLKGATE (1 << 7) -#define CLKCTRL_FRAC_STABLE (1 << 6) -#define CLKCTRL_FRAC_FRAC_MASK 0x3f -#define CLKCTRL_FRAC_FRAC_OFFSET 0 -#define CLKCTRL_FRAC0_CPU 0 -#define CLKCTRL_FRAC0_EMI 1 -#define CLKCTRL_FRAC0_IO1 2 -#define CLKCTRL_FRAC0_IO0 3 -#define CLKCTRL_FRAC1_PIX 0 -#define CLKCTRL_FRAC1_HSADC 1 -#define CLKCTRL_FRAC1_GPMI 2 - -#define CLKCTRL_CLKSEQ_BYPASS_CPU (1 << 18) -#define CLKCTRL_CLKSEQ_BYPASS_DIS_LCDIF (1 << 14) -#define CLKCTRL_CLKSEQ_BYPASS_DIS_LCDIF_BYPASS (0x1 << 14) -#define CLKCTRL_CLKSEQ_BYPASS_DIS_LCDIF_PFD (0x0 << 14) -#define CLKCTRL_CLKSEQ_BYPASS_ETM (1 << 8) -#define CLKCTRL_CLKSEQ_BYPASS_EMI (1 << 7) -#define CLKCTRL_CLKSEQ_BYPASS_SSP3 (1 << 6) -#define CLKCTRL_CLKSEQ_BYPASS_SSP2 (1 << 5) -#define CLKCTRL_CLKSEQ_BYPASS_SSP1 (1 << 4) -#define CLKCTRL_CLKSEQ_BYPASS_SSP0 (1 << 3) -#define CLKCTRL_CLKSEQ_BYPASS_GPMI (1 << 2) -#define CLKCTRL_CLKSEQ_BYPASS_SAIF1 (1 << 1) -#define CLKCTRL_CLKSEQ_BYPASS_SAIF0 (1 << 0) - -#define CLKCTRL_RESET_WDOG_POR_DISABLE (1 << 5) -#define CLKCTRL_RESET_EXTERNAL_RESET_ENABLE (1 << 4) -#define CLKCTRL_RESET_THERMAL_RESET_ENABLE (1 << 3) -#define CLKCTRL_RESET_THERMAL_RESET_DEFAULT (1 << 2) -#define CLKCTRL_RESET_CHIP (1 << 1) -#define CLKCTRL_RESET_DIG (1 << 0) - -#define CLKCTRL_STATUS_CPU_LIMIT_MASK (0x3 << 30) -#define CLKCTRL_STATUS_CPU_LIMIT_OFFSET 30 - -#define CLKCTRL_VERSION_MAJOR_MASK (0xff << 24) -#define CLKCTRL_VERSION_MAJOR_OFFSET 24 -#define CLKCTRL_VERSION_MINOR_MASK (0xff << 16) -#define CLKCTRL_VERSION_MINOR_OFFSET 16 -#define CLKCTRL_VERSION_STEP_MASK 0xffff -#define CLKCTRL_VERSION_STEP_OFFSET 0 - -#endif /* __MX28_REGS_CLKCTRL_H__ */ diff --git a/drivers/usb/host/ehci-mxs.c b/drivers/usb/host/ehci-mxs.c index f32df51..8a36513 100644 --- a/drivers/usb/host/ehci-mxs.c +++ b/drivers/usb/host/ehci-mxs.c @@ -23,7 +23,7 @@ #include <asm/io.h> #include <asm/arch/regs-common.h> #include <asm/arch/regs-base.h> -#include <asm/arch/regs-clkctrl.h> +#include <asm/arch/regs-clkctrl-mx28.h> #include <asm/arch/regs-usb.h> #include <asm/arch/regs-usbphy.h>
Dear Otavio Salvador,
The macro mistakenly referred to 32bit struct instead of 8bit one.
Signed-off-by: Otavio Salvador otavio@ossystems.com.br Cc: Fabio Estevam fabio.estevam@freescale.com Cc: Marek Vasut marex@denx.de
arch/arm/include/asm/arch-mx28/regs-common.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-mx28/regs-common.h b/arch/arm/include/asm/arch-mx28/regs-common.h index 94b512d..d2e1953 100644 --- a/arch/arm/include/asm/arch-mx28/regs-common.h +++ b/arch/arm/include/asm/arch-mx28/regs-common.h @@ -70,7 +70,7 @@ struct mx28_register_32 { #define mx28_reg_8(name) \ union { \ struct { __mx28_reg_8(name) }; \
};struct mx28_register_8 name##_reg; \
Didn't Fabio sent in something similar already? Either way
Acked-by: Marek Vasut marex@denx.de
Best regards, Marek Vasut
Yes; I asked him to send my patch while I was in a client with a very restricted firewall.
Thanks by acking it.
Applied to u-boot-imx, thanks.
Best regards, Stefano Babic
Otavio Salvador
Stefano Babic
